[U-Boot] [PATCH] stm32mp1: configs: fix checking the presence of an environment
Execute env check command within extra env settings section instead of bootcmd whereby we are able to mount rootfs partition from sd card properly.
Signed-off-by: Bartosz Bilas bartosz.bilas@hotmail.com --- include/configs/stm32mp1.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index 988992b336..cadc0358fd 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -115,7 +115,6 @@ "if test ${boot_device} = serial || test ${boot_device} = usb;" \ "then stm32prog ${boot_device} ${boot_instance}; " \ "else " \ - "run env_check;" \ "if test ${boot_device} = mmc;" \ "then env set boot_targets "mmc${boot_instance}"; fi;" \ "if test ${boot_device} = nand;" \ @@ -160,6 +159,7 @@ "initrd_high=0xffffffff\0" \ "altbootcmd=run bootcmd\0" \ "env_default=1\0" \ + "run env_check;" \ "env_check=if test $env_default -eq 1;"\ " then env set env_default 0;env save;fi\0" \ STM32MP_BOOTCMD \
Hi Bartosz,
Please ad get maintainers or tools/patman to sent patch for stm32mp1 platform.
From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Bartosz Bilas Sent: dimanche 27 octobre 2019 15:46 To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH] stm32mp1: configs: fix checking the presence of an environment
"if test ${boot_device} = mmc;" \ "then env set boot_targets "mmc${boot_instance}"; fi;" \ "if test ${boot_device} = nand;" \"run env_check;" \
It is not a correct place, this define CONFIG_EXTRA_ENV_SETTINGS only the default environment (only set env variable). Only "bootcmd" or "preboot" is really executed, this command will be never executed here.
"env_check=if test $env_default -eq 1;"\ " then env set env_default 0;env save;fi\0" \ STM32MP_BOOTCMD \ --
Can you explain you issue and the board used.
I think your patch only mask the issue, as environment is not saved, U-Boot never write in EXT4 file system. You should have again the issue if you execute manually by the command "env save".
Today I have no issue on my side with environment in ext4 file system (generated by donwstrean yocto); the requests done by U-Boot are acceptable if the ext4 file system is generated with only the features supported by U-Boot.
But we solved issue with latest ext4 tools; since e2fsprogs 1.43 at least, we have ascendance incompatibility as new enable features are enable by default = metadata_csum and dir_index.
We remove them with the mkfs.ext4 option: -O ^metadata_csum,^dir_index
Example : mkfs.ext4 -L rootfs -O ^metadata_csum,^dir_index /dev/sdb4
For details of restriction, see commit 10a7a1b8 : update with hash tree directory of EXT4 not support by U-Boot (EXT4_INDEX_FL)
Best regards
Patrick
Hello Patrick,
sorry for the late answer but I'll try to explain you my issue.
On 10/29/19 9:38 AM, Patrick DELAUNAY wrote:
Hi Bartosz,
Ok, I'll remember about that.
From: U-Boot u-boot-bounces@lists.denx.demailto:u-boot-bounces@lists.denx.de On Behalf Of Bartosz Bilas Sent: dimanche 27 octobre 2019 15:46 To: u-boot@lists.denx.demailto:u-boot@lists.denx.de Subject: [U-Boot] [PATCH] stm32mp1: configs: fix checking the presence of an environment
Signed-off-by: Bartosz Bilas bartosz.bilas@hotmail.commailto:bartosz.bilas@hotmail.com --- include/configs/stm32mp1.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
The problem which I've encountered is that I'm not able to boot my rootfs partition properly using the latest U-Boot version (2019.10) using stm32mp157c-dk2 board (I've been getting kernel panic because it wasn't able to mount partition). On the previous version (2019.07) there is no any problems with that. I've used git bisect to check which commit causes the problem and it turned out that the problem is with commit 22bed7ee4988aadfaef0c0da9746bf8541549ed4.
Hmm, it makes sense.
I use buildroot and if you wanna you can build and check that image yourself. Here is a link to guide https://github.com/buildroot/buildroot/tree/master/board/stmicroelectronics/... but remember to comment this line -> BR2_GLOBAL_PATCH_DIR="board/stmicroelectronics/stm32mp157c-dk2/patches" in stm32mp157c_dk2_defconfig file to disable my faulty patch.
I'll check that and let you know about the results.
Thanks
Best regards
Patrick
Best Bartek
Hello Patrick,
On 11/3/19 11:15 AM, Bartosz Biłas wrote:
Hello Patrick,
Hi Bartosz,
"run env_check;" \ "if test ${boot_device} = mmc;" \ "then env set boot_targets \"mmc${boot_instance}\"; fi;" \ "if test ${boot_device} = nand;" \
"run env_check;" \
I've prepared sd card with disabled those options and it works well. I think we can reject that patch then.
Best Bartek
Thanks
Best regards
Patrick
Best Bartek _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Hi Bartosz
From: Bartosz Biłas bartosz.bilas@hotmail.com Sent: dimanche 3 novembre 2019 13:39
Hello Patrick,
Hello Patrick,
Hi Bartosz,
"run env_check;" \ "if test ${boot_device} = mmc;" \ "then env set boot_targets \"mmc${boot_instance}\"; fi;" \ "if test ${boot_device} = nand;" \ @@ -160,6 +159,7
"run env_check;" \
executed here.
partition properly using the latest U-Boot version (2019.10) using stm32mp157c- dk2 board (I've been getting kernel panic because it wasn't able to mount partition). On the previous version (2019.07) there is no any problems with that. I've used git bisect to check which commit causes the problem and it turned out that the problem is with commit 22bed7ee4988aadfaef0c0da9746bf8541549ed4.
save".
Here is a link to guide https://github.com/buildroot/buildroot/tree/master/board/stmicroelectronics/... p157c-dk2 but remember to comment this line -> BR2_GLOBAL_PATCH_DIR="board/stmicroelectronics/stm32mp157c- dk2/patches" in stm32mp157c_dk2_defconfig file to disable my faulty patch.
Thanks for the feedback,
Patch rejected :-)
Best Bartek
Thanks
Regards Patrick
Bartosz Bilas
Bartosz Biłas
Patrick DELAUNAY
