Re: [U-Boot] [PATCH 2/3] nand: Add common functions to nand.h
Hi Scott,
ok. Will have a look - hopefully this weekend.
Regards Simon
2011/10/14 Simon Schwarz simonschwarzcor@googlemail.com:
Hi Scott,
Regards Simon
2011/10/4 Scott Wood scottwood@freescale.com:
On 09/29/2011 02:44 AM, Simon Schwarz wrote:
Functions often used in SPL are now part of nand.h.
Signed-off-by: Simon Schwarz simonschwarzcor@gmail.com
include/nand.h | 10 +++++++--- 1 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/include/nand.h b/include/nand.h index b4140794..980408a 100644 --- a/include/nand.h +++ b/include/nand.h @@ -135,9 +135,6 @@ int nand_get_lock_status(nand_info_t *meminfo, loff_t offset); int nand_spl_load_image(uint32_t offs, unsigned int size, void *dst); void nand_deselect(void);
-void nand_read_buf16(struct mtd_info *mtd, uint8_t *buf, int len); -void nand_read_buf(struct mtd_info *mtd, uint8_t *buf, int len);
#ifdef CONFIG_SYS_NAND_SELECT_DEVICE void board_nand_select_device(struct nand_chip *nand, int chip); #endif @@ -154,3 +151,10 @@ __attribute__((noreturn)) void nand_boot(void); #define ENV_OFFSET_SIZE 8 int get_nand_env_oob(nand_info_t *nand, unsigned long *result); #endif
+/* Standard NAND functions from nand_base.c */ +void nand_write_buf(struct mtd_info *mtd, const uint8_t *buf, int len); +void nand_write_buf16(struct mtd_info *mtd, const uint8_t *buf, int len); +void nand_read_buf(struct mtd_info *mtd, uint8_t *buf, int len); +void nand_read_buf16(struct mtd_info *mtd, uint8_t *buf, int len); +uint8_t nand_read_byte(struct mtd_info *mtd);
Sorry for not noticing this before, but these should go in include/linux/mtd/nand.h since that corresponds to drivers/mtd/nand/nand_base.c. include/nand.h is for U-Boot-specific things.
As it stands now, drivers/mtd/nand/nand_base.c does not include include/nand.h, so we won't get warned if the function signatures diverge.
-Scott
Simon Schwarz
