[U-Boot] [PATCHv3 1/2] armv8/fsl-lsch2: refactor the clock system initialization
Up to now, there are 3 kind of SoCs under Layerscape Chassis 2, like LS1043A, LS1046A and LS1012A. But the clocks tree has a lot of differences, for instance, the IP modules have different dividers to derive its clock from Platform PLL. And the core cluster PLL and platform PLL maybe have different reference clocks, such as LS1012A. Another problem is which clock/PLL should be described by sys_info->freq_systembus, it is confused in Layerscape Chissis 2.
This patch is to bind the sys_info->freq_systembus to the Platform PLL, and handle the different divider of IP modules separately between different SoCs, and separate reference clocks of core cluster PLL and platform PLL.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- V3: - Generate the patch set base on the latest git://git.denx.de/u-boot-fsl-qoriq.git. - Use the Kconfig instead of header file to add CONFIG_*
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 76 ++++++++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 3 +- .../arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 68 ++++++++++++++----- .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 1 + include/configs/ls1012a_common.h | 6 +- include/configs/ls1043a_common.h | 3 +- include/configs/ls1046a_common.h | 3 +- include/configs/ls2080aqds.h | 2 - include/configs/ls2080ardb.h | 1 - 9 files changed, 134 insertions(+), 29 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index cc0dc88..de1e5a4 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -87,6 +87,82 @@ config MAX_CPUS cores, count the reserved ports. This will allocate enough memory in spin table to properly handle all cores.
+menu "Layerscape clock tree configuration" + depends on FSL_LSCH2 || FSL_LSCH3 + +config SYS_FSL_CLK + bool "Enable clock tree initialization" + default y + +config CLUSTER_CLK_FREQ + int "Reference clock of core cluster" + depends on ARCH_LS1012A + default 100000000 + help + This number is the reference clock frequency of core PLL. + For most platforms, the core PLL and Platform PLL have the same + reference clock, but for some platforms, LS1012A for instance, + they are provided sepatately. + +config SYS_FSL_PCLK_DIV + int "Platform clock divider" + default 1 if ARCH_LS1043A + default 1 if ARCH_LS1046A + default 2 + help + This is the divider that is used to derive Platform clock from + Platform PLL, in another word: + Platform_clk = Platform_PLL_freq / this_divider + +config SYS_FSL_DSPI_CLK_DIV + int "DSPI clock divider" + default 1 if ARCH_LS1043A + default 2 + help + This is the divider that is used to derive DSPI clock from Platform + PLL, in another word DSPI_clk = Platform_PLL_freq / this_divider. + +config SYS_FSL_DUART_CLK_DIV + int "DUART clock divider" + default 1 if ARCH_LS1043A + default 2 + help + This is the divider that is used to derive DUART clock from Platform + PLL, in another word DUART_clk = Platform_PLL_freq / this_divider. + +config SYS_FSL_I2C_CLK_DIV + int "I2C clock divider" + default 1 if ARCH_LS1043A + default 2 + help + This is the divider that is used to derive I2C clock from Platform + PLL, in another word I2C_clk = Platform_PLL_freq / this_divider. + +config SYS_FSL_IFC_CLK_DIV + int "IFC clock divider" + default 1 if ARCH_LS1043A + default 2 + help + This is the divider that is used to derive IFC clock from Platform + PLL, in another word IFC_clk = Platform_PLL_freq / this_divider. + +config SYS_FSL_LPUART_CLK_DIV + int "LPUART clock divider" + default 1 if ARCH_LS1043A + default 2 + help + This is the divider that is used to derive LPUART clock from Platform + PLL, in another word LPUART_clk = Platform_PLL_freq / this_divider. + +config SYS_FSL_SDHC_CLK_DIV + int "SDHC clock divider" + default 1 if ARCH_LS1043A + default 2 + help + This is the divider that is used to derive SDHC clock from Platform + PLL, in another word SDHC_clk = Platform_PLL_freq / this_divider. +endmenu + config NUM_DDR_CONTROLLERS int "Maximum DDR controllers" default 3 if ARCH_LS2080A diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 467d9af..3bdeb0e 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -345,8 +345,9 @@ int print_cpuinfo(void) (type == TY_ITYP_VER_A72 ? "A72" : " "))), strmhz(buf, sysinfo.freq_processor[core])); } + /* Display platform clock as Bus frequency. */ printf("\n Bus: %-4s MHz ", - strmhz(buf, sysinfo.freq_systembus)); + strmhz(buf, sysinfo.freq_systembus / CONFIG_SYS_FSL_PCLK_DIV)); printf("DDR: %-4s MT/s", strmhz(buf, sysinfo.freq_ddrbus)); #ifdef CONFIG_SYS_DPAA_FMAN printf(" FMAN: %-4s MHz", strmhz(buf, sysinfo.freq_fman[0])); diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c index 55005f0..f216231 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -52,22 +52,28 @@ void get_sys_info(struct sys_info *sys_info) uint freq_c_pll[CONFIG_SYS_FSL_NUM_CC_PLLS]; uint ratio[CONFIG_SYS_FSL_NUM_CC_PLLS]; unsigned long sysclk = CONFIG_SYS_CLK_FREQ; + unsigned long cluster_clk;
sys_info->freq_systembus = sysclk; +#ifndef CONFIG_CLUSTER_CLK_FREQ +#define CONFIG_CLUSTER_CLK_FREQ CONFIG_SYS_CLK_FREQ +#endif + cluster_clk = CONFIG_CLUSTER_CLK_FREQ; + #ifdef CONFIG_DDR_CLK_FREQ sys_info->freq_ddrbus = CONFIG_DDR_CLK_FREQ; #else sys_info->freq_ddrbus = sysclk; #endif
-#ifdef CONFIG_ARCH_LS1012A - sys_info->freq_ddrbus *= (gur_in32(&gur->rcwsr[0]) >> - FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_SHIFT) & - FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_MASK; -#else + /* The freq_systembus is used to record frequency of platform PLL */ sys_info->freq_systembus *= (gur_in32(&gur->rcwsr[0]) >> FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_SHIFT) & FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_MASK; + +#ifdef CONFIG_ARCH_LS1012A + sys_info->freq_ddrbus = 2 * sys_info->freq_systembus; +#else sys_info->freq_ddrbus *= (gur_in32(&gur->rcwsr[0]) >> FSL_CHASSIS2_RCWSR0_MEM_PLL_RAT_SHIFT) & FSL_CHASSIS2_RCWSR0_MEM_PLL_RAT_MASK; @@ -76,7 +82,7 @@ void get_sys_info(struct sys_info *sys_info) for (i = 0; i < CONFIG_SYS_FSL_NUM_CC_PLLS; i++) { ratio[i] = (in_be32(&clk->pllcgsr[i].pllcngsr) >> 1) & 0xff; if (ratio[i] > 4) - freq_c_pll[i] = sysclk * ratio[i]; + freq_c_pll[i] = cluster_clk * ratio[i]; else freq_c_pll[i] = sys_info->freq_systembus * ratio[i]; } @@ -91,11 +97,6 @@ void get_sys_info(struct sys_info *sys_info) freq_c_pll[cplx_pll] / core_cplx_pll_div[c_pll_sel]; }
-#ifdef CONFIG_ARCH_LS1012A - sys_info->freq_systembus = sys_info->freq_ddrbus / 2; - sys_info->freq_ddrbus *= 2; -#endif - #define HWA_CGA_M1_CLK_SEL 0xe0000000 #define HWA_CGA_M1_CLK_SHIFT 29 #ifdef CONFIG_SYS_DPAA_FMAN @@ -148,7 +149,8 @@ void get_sys_info(struct sys_info *sys_info) break; } #else - sys_info->freq_sdhc = sys_info->freq_systembus; + sys_info->freq_sdhc = sys_info->freq_systembus / + CONFIG_SYS_FSL_SDHC_CLK_DIV; #endif #endif
@@ -166,7 +168,7 @@ int get_clocks(void)
get_sys_info(&sys_info); gd->cpu_clk = sys_info.freq_processor[0]; - gd->bus_clk = sys_info.freq_systembus; + gd->bus_clk = sys_info.freq_systembus / CONFIG_SYS_FSL_PCLK_DIV; gd->mem_clk = sys_info.freq_ddrbus;
#ifdef CONFIG_FSL_ESDHC @@ -179,41 +181,73 @@ int get_clocks(void) return 1; }
+/******************************************** + * get_bus_freq + * return platform clock in Hz + *********************************************/ ulong get_bus_freq(ulong dummy) { + if (!gd->bus_clk) + get_clocks(); + return gd->bus_clk; }
ulong get_ddr_freq(ulong dummy) { + if (!gd->mem_clk) + get_clocks(); + return gd->mem_clk; }
#ifdef CONFIG_FSL_ESDHC int get_sdhc_freq(ulong dummy) { + if (!gd->arch.sdhc_clk) + get_clocks(); + return gd->arch.sdhc_clk; } #endif
int get_serial_clock(void) { - return gd->bus_clk; + return get_bus_freq(0) / CONFIG_SYS_FSL_DUART_CLK_DIV; +} + +int get_i2c_freq(ulong dummy) +{ + return get_bus_freq(0) / CONFIG_SYS_FSL_I2C_CLK_DIV; +} + +int get_dspi_freq(ulong dummy) +{ + return get_bus_freq(0) / CONFIG_SYS_FSL_DSPI_CLK_DIV; }
+#ifdef CONFIG_FSL_LPUART +int get_uart_freq(ulong dummy) +{ + return get_bus_freq(0) / CONFIG_SYS_FSL_LPUART_CLK_DIV; +} +#endif + unsigned int mxc_get_clock(enum mxc_clock clk) { switch (clk) { case MXC_I2C_CLK: - return get_bus_freq(0); + return get_i2c_freq(0); #if defined(CONFIG_FSL_ESDHC) case MXC_ESDHC_CLK: return get_sdhc_freq(0); #endif case MXC_DSPI_CLK: - return get_bus_freq(0); + return get_dspi_freq(0); +#ifdef CONFIG_FSL_LPUART case MXC_UART_CLK: - return get_bus_freq(0); + return get_uart_freq(0); +#endif default: printf("Unsupported clock\n"); } diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index b3cfd89..6ace3da 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -137,6 +137,7 @@ CONFIG_SYS_CCSRBAR_PHYS_LOW and/or CONFIG_SYS_CCSRBAR_PHYS_HIGH instead."
struct sys_info { unsigned long freq_processor[CONFIG_MAX_CPUS]; + /* frequency of platform PLL */ unsigned long freq_systembus; unsigned long freq_ddrbus; unsigned long freq_localbus; diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 20f0c61..910835e 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -19,9 +19,7 @@
#define CONFIG_SYS_TEXT_BASE 0x40100000
-#define CONFIG_SYS_FSL_CLK -#define CONFIG_SYS_CLK_FREQ 100000000 -#define CONFIG_DDR_CLK_FREQ 125000000 +#define CONFIG_SYS_CLK_FREQ 125000000
#define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_BOARD_EARLY_INIT_F 1 @@ -82,7 +80,7 @@ #define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) +#define CONFIG_SYS_NS16550_CLK (get_serial_clock())
#define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index c1e3ec6..f7a4397 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -11,7 +11,6 @@ #define CONFIG_FSL_LAYERSCAPE #define CONFIG_LS1043A #define CONFIG_MP -#define CONFIG_SYS_FSL_CLK #define CONFIG_GICV2
#include <asm/arch/config.h> @@ -42,7 +41,7 @@ #define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)) +#define CONFIG_SYS_NS16550_CLK (get_serial_clock())
#define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 3887faa..b51e8bf 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -10,7 +10,6 @@ #define CONFIG_REMAKE_ELF #define CONFIG_FSL_LAYERSCAPE #define CONFIG_MP -#define CONFIG_SYS_FSL_CLK #define CONFIG_GICV2
#include <asm/arch/config.h> @@ -41,7 +40,7 @@ #define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) +#define CONFIG_SYS_NS16550_CLK (get_serial_clock())
#define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 838568f..793e1ac 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -14,8 +14,6 @@ unsigned long get_board_sys_clk(void); unsigned long get_board_ddr_clk(void); #endif
-#define CONFIG_SYS_FSL_CLK - #ifdef CONFIG_FSL_QSPI #define CONFIG_SYS_NO_FLASH #undef CONFIG_CMD_IMLS diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 31df781..76e8622 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -32,7 +32,6 @@ unsigned long get_board_sys_clk(void); #endif
-#define CONFIG_SYS_FSL_CLK #define CONFIG_SYS_CLK_FREQ get_board_sys_clk() #define CONFIG_DDR_CLK_FREQ 133333333 #define COUNTER_FREQUENCY_REAL (CONFIG_SYS_CLK_FREQ/4)
This patch binds the sys_info->freq_systembus to Platform PLL, and implements the IPs' clock function individually.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- V3: - No change
.../arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c | 28 ++++++++++++++++------ .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 1 + include/configs/ls2080a_common.h | 2 +- 3 files changed, 23 insertions(+), 8 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c index a9b12a4..f8fefc7 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c @@ -88,11 +88,10 @@ void get_sys_info(struct sys_info *sys_info) #endif #endif
+ /* The freq_systembus is used to record frequency of platform PLL */ sys_info->freq_systembus *= (gur_in32(&gur->rcwsr[0]) >> FSL_CHASSIS3_RCWSR0_SYS_PLL_RAT_SHIFT) & FSL_CHASSIS3_RCWSR0_SYS_PLL_RAT_MASK; - /* Platform clock is half of platform PLL */ - sys_info->freq_systembus /= 2; sys_info->freq_ddrbus *= (gur_in32(&gur->rcwsr[0]) >> FSL_CHASSIS3_RCWSR0_MEM_PLL_RAT_SHIFT) & FSL_CHASSIS3_RCWSR0_MEM_PLL_RAT_MASK; @@ -142,13 +141,13 @@ int get_clocks(void) struct sys_info sys_info; get_sys_info(&sys_info); gd->cpu_clk = sys_info.freq_processor[0]; - gd->bus_clk = sys_info.freq_systembus; + gd->bus_clk = sys_info.freq_systembus / CONFIG_SYS_FSL_PCLK_DIV; gd->mem_clk = sys_info.freq_ddrbus; #ifdef CONFIG_SYS_FSL_HAS_DP_DDR gd->arch.mem2_clk = sys_info.freq_ddrbus2; #endif #if defined(CONFIG_FSL_ESDHC) - gd->arch.sdhc_clk = gd->bus_clk / 2; + gd->arch.sdhc_clk = gd->bus_clk / CONFIG_SYS_FSL_SDHC_CLK_DIV; #endif /* defined(CONFIG_FSL_ESDHC) */
if (gd->cpu_clk != 0) @@ -159,7 +158,7 @@ int get_clocks(void)
/******************************************** * get_bus_freq - * return system bus freq in Hz + * return platform clock in Hz *********************************************/ ulong get_bus_freq(ulong dummy) { @@ -190,13 +189,28 @@ ulong get_ddr_freq(ulong ctrl_num) return gd->mem_clk; }
+int get_i2c_freq(ulong dummy) +{ + return get_bus_freq(0) / CONFIG_SYS_FSL_I2C_CLK_DIV; +} + +int get_dspi_freq(ulong dummy) +{ + return get_bus_freq(0) / CONFIG_SYS_FSL_DSPI_CLK_DIV; +} + +int get_serial_clock(void) +{ + return get_bus_freq(0) / CONFIG_SYS_FSL_DUART_CLK_DIV; +} + unsigned int mxc_get_clock(enum mxc_clock clk) { switch (clk) { case MXC_I2C_CLK: - return get_bus_freq(0) / 2; + return get_i2c_freq(0); case MXC_DSPI_CLK: - return get_bus_freq(0) / 2; + return get_dspi_freq(0); default: printf("Unsupported clock\n"); } diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index e18dcbd..cd25b48 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -159,6 +159,7 @@ #ifndef __ASSEMBLY__ struct sys_info { unsigned long freq_processor[CONFIG_MAX_CPUS]; + /* frequency of platform PLL */ unsigned long freq_systembus; unsigned long freq_ddrbus; #ifdef CONFIG_SYS_FSL_HAS_DP_DDR diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 2cae966..cf1185c 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -97,7 +97,7 @@ #define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) +#define CONFIG_SYS_NS16550_CLK (get_serial_clock())
-----Original Message----- From: Zhiqiang Hou [mailto:Zhiqiang.Hou@nxp.com] Sent: Tuesday, December 27, 2016 1:06 PM To: u-boot@lists.denx.de; albert.u.boot@aribaud.net; york sun york.sun@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Calvin Johnson calvin.johnson@nxp.com Cc: Z.Q. Hou zhiqiang.hou@nxp.com Subject: [PATCHv3 1/2] armv8/fsl-lsch2: refactor the clock system initialization
V3:
qoriq.git.
- depends on FSL_LSCH2 || FSL_LSCH3
+config SYS_FSL_CLK
- bool "Enable clock tree initialization"
- default y
- int "Reference clock of core cluster"
- depends on ARCH_LS1012A
- default 100000000
- help
- int "Platform clock divider"
- default 1 if ARCH_LS1043A
- default 1 if ARCH_LS1046A
- default 2
Only LS2080A and LS2088A requires Platform_PLL_freq / 2. So make 1 as default and exception for LS2080A and LS2088A
- help
<snips>
- cluster_clk = CONFIG_CLUSTER_CLK_FREQ;
-#else
- /* The freq_systembus is used to record frequency of platform PLL */ sys_info->freq_systembus *= (gur_in32(&gur->rcwsr[0]) >> FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_SHIFT) & FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_MASK;
- sys_info->freq_ddrbus = 2 * sys_info->freq_systembus;
else freq_c_pll[i] = sys_info->freq_systembus * ratio[i]; }freq_c_pll[i] = cluster_clk * ratio[i];
Above new logic of calculating sys_clk ddr_clk for LS1012A. It is not matching with previous logic.
Let me try to explain for LS1012A
#define CONFIG_SYS_CLK_FREQ 100000000 #define CONFIG_DDR_CLK_FREQ 125000000
Previous logic sys_info->freq_ddrbus = 125MHz sys_info->freq_ddrbus = 125 * 4 = 500 MHz here 4 is PLL ratio i.e. 4:1 sys_info->freq_systembus = sys_info->freq_ddrbus/2 = 250MHz sys_info->freq_ddrbus *2 = 1000MT/s
New Logic sys_info->freq_systembus = 100MHz sys_info->freq_systembus = 100 * 4 = 400MHz here 4 is PLL ratio sys_info->freq_ddrbus = 2 * sys_info->freq_systembus ==> 800MHz
--prabhakar
Hi Prabhakar,
Thanks a lot for your comments!
-----Original Message----- From: Prabhakar Kushwaha Sent: 2016年12月27日 16:59 To: Z.Q. Hou zhiqiang.hou@nxp.com; u-boot@lists.denx.de; albert.u.boot@aribaud.net; york sun york.sun@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Calvin Johnson calvin.johnson@nxp.com Cc: Z.Q. Hou zhiqiang.hou@nxp.com Subject: RE: [PATCHv3 1/2] armv8/fsl-lsch2: refactor the clock system initialization
V3:
git://git.denx.de/u-boot-fsl- qoriq.git.
| 1 +
+config SYS_FSL_CLK
- default y
- default 100000000
- help
- default 2
The LS1012A also requires Platform_PLL_freq / 2 to derive Platform clock, referring to LS1012A Reference Manual, Rev. C. Isn't it better to make 2 the default value?
- help
<snips>
-#else
- sys_info->freq_ddrbus = 2 * sys_info->freq_systembus; #else sys_info->freq_ddrbus *= (gur_in32(&gur->rcwsr[0]) >> FSL_CHASSIS2_RCWSR0_MEM_PLL_RAT_SHIFT) & FSL_CHASSIS2_RCWSR0_MEM_PLL_RAT_MASK;
#define CONFIG_SYS_CLK_FREQ 125000000 sys_info->freq_systembus = 125MHz sys_info->freq_systembus = 125 * 4 = 500MHz here 4 is PLL ratio sys_info->freq_ddrbus = 2 * sys_info->freq_systembus ==> 1000MT/s
The new logic has been discussed with York and Mingkai in patch v2. York and Mingkai recommended the new logic. Because the new logic match the clock tree generation process more. The CONFIG_SYS_CLK_FREQ is the Platform PLL reference clock, and actually it is 125MHz instead of 100MHz on ls1012a. And there isn't a DDR PLL to generate DDR clock but use the Platform PLL directly, so the CONFIG_DDR_CLK_FREQ should not be defined.
Thanks, Zhiqiang
-----Original Message----- From: Z.Q. Hou Sent: Tuesday, December 27, 2016 3:58 PM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; u- boot@lists.denx.de; albert.u.boot@aribaud.net; york sun york.sun@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Calvin Johnson calvin.johnson@nxp.com Subject: RE: [PATCHv3 1/2] armv8/fsl-lsch2: refactor the clock system initialization
Hi Prabhakar,
V3:
| 1 +
+config SYS_FSL_CLK
- default y
- default 100000000
- help
- default 2
- help
<snips>
-#else
Following defines are present in ls1012a_common.h in u-boot.git top commit 47895838a4fbe867ba9a170c6d1ea6a794095025 #define CONFIG_SYS_CLK_FREQ 100000000 #define CONFIG_DDR_CLK_FREQ 125000000
Am I missing any pending patch updating CONFIG_DDR_CLK_FREQ
--prabhakar
Hi Prabhakar,
-----Original Message----- From: Prabhakar Kushwaha Sent: 2016年12月28日 12:06 To: Z.Q. Hou zhiqiang.hou@nxp.com; u-boot@lists.denx.de; albert.u.boot@aribaud.net; york sun york.sun@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Calvin Johnson calvin.johnson@nxp.com Subject: RE: [PATCHv3 1/2] armv8/fsl-lsch2: refactor the clock system initialization
Hi Prabhakar,
as LS1012A.
V3:
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 76 ++++++++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 3 +- .../arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 68 ++++++++++++++----- ++++++++++++++.../include/asm/arch-fsl-layerscape/immap_lsch2.h
| 1 +
+config SYS_FSL_CLK
- default y
- default 100000000
- help
- default 2
- help
<snips>
-#else
+PLL */ sys_info->freq_systembus *= (gur_in32(&gur->rcwsr[0]) >> FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_SHIFT) & FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_MASK;
The CONFIG_SYS_CLK_FREQ has been changed to 125MHz and the definition of CONFIG_DDR_CLK_FREQ has been removed in this patch. I paste it here: diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 20f0c61..910835e 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -19,9 +19,7 @@
Thanks, Zhiqiang
-----Original Message----- From: Z.Q. Hou Sent: Wednesday, December 28, 2016 11:41 AM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; u- boot@lists.denx.de; albert.u.boot@aribaud.net; york sun york.sun@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Calvin Johnson calvin.johnson@nxp.com Subject: RE: [PATCHv3 1/2] armv8/fsl-lsch2: refactor the clock system initialization
Hi Prabhakar,
Hi Prabhakar,
as LS1012A.
V3:
| 1 +
+config SYS_FSL_CLK
- default y
- default 100000000
- help
same
- default 2
- help
<snips>
-#else
Only problem I see with new logic is core speed. Earlier core PLLs were getting derived from 100MHz SysClk Now they will be derived as per 125Mhz SysCLK. It is not right.
Please note core PLLs are getting derived from 100MHz SysCLK.
--prabhakar
Hi Prabhakar,
-----Original Message----- From: Prabhakar Kushwaha Sent: 2016年12月28日 17:27 To: Z.Q. Hou zhiqiang.hou@nxp.com; u-boot@lists.denx.de; albert.u.boot@aribaud.net; york sun york.sun@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Calvin Johnson calvin.johnson@nxp.com Subject: RE: [PATCHv3 1/2] armv8/fsl-lsch2: refactor the clock system initialization
Hi Prabhakar,
Hi Prabhakar,
Prabhakar
as LS1012A.
V3:
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 76 ++++++++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 3 +- .../arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 68 ++++++++++++++----- ++++++++++++++.../include/asm/arch-fsl-layerscape/immap_lsch2. ++++++++++++++h
| 1 +
memory
+config SYS_FSL_CLK
- default y
- default 100000000
- help
same
instance,
- default 2
- help
<snips>
-#else
+platform PLL */ sys_info->freq_systembus *= (gur_in32(&gur->rcwsr[0]) >> FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_SHIFT) & FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_MASK;
- 4 = 400MHz here 4 is PLL ratio sys_info->freq_ddrbus = 2 *
defined.
No, I added a new macro CONFIG_CLUSTER_CLK_FREQ, so it is still derived from 100MHz. +config CLUSTER_CLK_FREQ + int "Reference clock of core cluster" + depends on ARCH_LS1012A + default 100000000 + help + This number is the reference clock frequency of core PLL. + For most platforms, the core PLL and Platform PLL have the same + reference clock, but for some platforms, LS1012A for instance, + they are provided sepatately.
Yes, I knew, 100MHz for core PLL and 125MHz for platform PLL.
Thanks, Zhiqiang
-----Original Message----- From: Zhiqiang Hou [mailto:Zhiqiang.Hou@nxp.com] Sent: 2016年12月27日 15:36 To: u-boot@lists.denx.de; albert.u.boot@aribaud.net; york sun york.sun@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Calvin Johnson calvin.johnson@nxp.com Cc: Z.Q. Hou zhiqiang.hou@nxp.com Subject: [PATCHv3 1/2] armv8/fsl-lsch2: refactor the clock system initialization
V3:
+config SYS_FSL_CLK
- default y
- default 100000000
- help
- default 2
- help
- int "DSPI clock divider"
- default 2
- help
There is a description error, the IP modules' clock should be derived from Platform clock instead of Platform PLL. Will fix next version.
- int "DUART clock divider"
- default 2
- help
- int "I2C clock divider"
- default 2
- help
- int "IFC clock divider"
- default 2
- help
- int "LPUART clock divider"
- default 2
- help
- int "SDHC clock divider"
- default 2
- help
+endmenu
- /* Display platform clock as Bus frequency. */ printf("\n Bus: %-4s MHz ",
-#else
-#endif
- sys_info->freq_sdhc = sys_info->freq_systembus /
#endif #endif
- gd->bus_clk = sys_info.freq_systembus / CONFIG_SYS_FSL_PCLK_DIV; gd->mem_clk = sys_info.freq_ddrbus;
- get_bus_freq
- return platform clock in Hz
- if (!gd->bus_clk)
get_clocks();
- if (!gd->mem_clk)
get_clocks();
- return gd->mem_clk;
- if (!gd->arch.sdhc_clk)
get_clocks();
- return gd->arch.sdhc_clk;
} #endif
- return get_bus_freq(0) / CONFIG_SYS_FSL_DUART_CLK_DIV; }
- return get_bus_freq(0) / CONFIG_SYS_FSL_I2C_CLK_DIV; }
- return get_bus_freq(0) / CONFIG_SYS_FSL_DSPI_CLK_DIV;
- return get_bus_freq(0) / CONFIG_SYS_FSL_LPUART_CLK_DIV; } #endif
- /* frequency of platform PLL */ unsigned long freq_systembus; unsigned long freq_ddrbus; unsigned long freq_localbus;
2.1.0.27.g96db324
Prabhakar Kushwaha
Z.Q. Hou
Zhiqiang Hou
