[U-Boot] [PATCH 1/2][v5] armv8: ls2080a: Reorganise NAND_BOOT code in config flag
Add CONFIG_NAND_BOOT config flag to organise NAND_BOOT specific code in config flag like -nand-boot specfic errata errata_rcw_src() -CONFIG_SYS_NAND_U_BOOT_DST,etc
Signed-off-by: Santan Kumar santan.kumar@nxp.com Signed-off-by: Priyanka Jain priyanka.jain@nxp.com Signed-off-by: Abhimanyu Saini abhimanyu.saini@nxp.com --- Changes in v5: Rebase in latest code base
arch/arm/cpu/armv8/fsl-layerscape/soc.c | 2 +- configs/ls2080aqds_nand_defconfig | 1 + include/configs/ls2080a_common.h | 2 ++ include/configs/ls2080aqds.h | 4 +++- 4 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 9e3cdd7..76e3af0 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -134,7 +134,7 @@ void erratum_a009635(void)
static void erratum_rcw_src(void) { -#if defined(CONFIG_SPL) +#if defined(CONFIG_SPL) && defined(CONFIG_NAND_BOOT) u32 __iomem *dcfg_ccsr = (u32 __iomem *)DCFG_BASE; u32 __iomem *dcfg_dcsr = (u32 __iomem *)DCFG_DCSR_BASE; u32 val; diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index aa4f134..2797e43 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -10,6 +10,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_NAND_BOOT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=10 CONFIG_SPL=y diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 427f623..12078c3 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -222,8 +222,10 @@ unsigned long long get_qixis_addr(void); #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_TEXT_BASE 0x1800a000
+#ifdef CONFIG_NAND_BOOT #define CONFIG_SYS_NAND_U_BOOT_DST 0x80400000 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST +#endif #define CONFIG_SYS_SPL_MALLOC_SIZE 0x00100000 #define CONFIG_SYS_SPL_MALLOC_START 0x80200000 #define CONFIG_SYS_MONITOR_LEN (640 * 1024) diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index beacb99..4c48562 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -197,7 +197,8 @@ unsigned long get_board_ddr_clk(void); FTIM2_GPCM_TWP(0x3E)) #define CONFIG_SYS_CS3_FTIM3 0x0
-#if defined(CONFIG_SPL) && defined(CONFIG_NAND) +#if defined(CONFIG_SPL) +#if defined(CONFIG_NAND_BOOT) #define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR0_CSPR_EXT #define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR0_CSPR_EARLY #define CONFIG_SYS_CSPR1_FINAL CONFIG_SYS_NOR0_CSPR @@ -233,6 +234,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SPL_PAD_TO 0x20000 #define CONFIG_SYS_NAND_U_BOOT_OFFS (256 * 1024) #define CONFIG_SYS_NAND_U_BOOT_SIZE (640 * 1024) +#endif #else #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR_EARLY
Signed-off-by: Santan Kumar santan.kumar@nxp.com Signed-off-by: Priyanka Jain priyanka.jain@nxp.com Signed-off-by: Abhimanyu Saini abhimanyu.saini@nxp.com --- Changes in v5: 1. Update MAINTAINERS file 2. Updated the memory layout
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 6 +-- .../cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c | 6 +-- board/freescale/ls2080a/ls2080a.c | 6 +-- board/freescale/ls2080aqds/MAINTAINERS | 1 + board/freescale/ls2080aqds/README | 13 +++++ board/freescale/ls2080aqds/eth.c | 8 +--- board/freescale/ls2080aqds/ls2080aqds.c | 4 +- configs/ls2080aqds_sdcard_defconfig | 55 ++++++++++++++++++++++ include/configs/ls2080a_common.h | 9 +++- include/configs/ls2080aqds.h | 27 ++++++++++- 10 files changed, 116 insertions(+), 19 deletions(-) create mode 100644 configs/ls2080aqds_sdcard_defconfig
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index bb02960..e5da7a2 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -462,7 +462,7 @@ int cpu_eth_init(bd_t *bis) { int error = 0;
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) error = fsl_mc_ldpaa_init(bis); #endif #ifdef CONFIG_FMAN_ENET @@ -606,7 +606,7 @@ phys_size_t board_reserve_ram_top(phys_size_t ram_size) { phys_size_t ram_top = ram_size;
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) /* The start address of MC reserved memory needs to be aligned. */ ram_top -= mc_get_dram_block_size(); ram_top &= ~(CONFIG_SYS_MC_RSV_MEM_ALIGN - 1); @@ -721,7 +721,7 @@ int dram_init_banksize(void) } #endif /* CONFIG_SYS_MEM_RESERVE_SECURE */
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) /* Assign memory for MC */ #ifdef CONFIG_SYS_DDR_BLOCK3_BASE if (gd->bd->bi_dram[2].size >= diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c index 955e0b7..ef97556 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c @@ -18,7 +18,7 @@ static u8 serdes1_prtcl_map[SERDES_PRCTL_COUNT]; static u8 serdes2_prtcl_map[SERDES_PRCTL_COUNT]; #endif
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) int xfi_dpmac[XFI8 + 1]; int sgmii_dpmac[SGMII16 + 1]; #endif @@ -110,7 +110,7 @@ void serdes_init(u32 sd, u32 sd_addr, u32 rcwsr, u32 sd_prctl_mask, debug("Unknown SerDes lane protocol %d\n", lane_prtcl); else { serdes_prtcl_map[lane_prtcl] = 1; -#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) switch (lane_prtcl) { case QSGMII_A: case QSGMII_B: @@ -141,7 +141,7 @@ void serdes_init(u32 sd, u32 sd_addr, u32 rcwsr, u32 sd_prctl_mask,
void fsl_serdes_init(void) { -#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) int i , j;
for (i = XFI1, j = 1; i <= XFI8; i++, j++) diff --git a/board/freescale/ls2080a/ls2080a.c b/board/freescale/ls2080a/ls2080a.c index 9e7701d..b357eaa 100644 --- a/board/freescale/ls2080a/ls2080a.c +++ b/board/freescale/ls2080a/ls2080a.c @@ -64,13 +64,13 @@ int board_eth_init(bd_t *bis) error = smc91111_initialize(0, CONFIG_SMC91111_BASE); #endif
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) error = cpu_eth_init(bis); #endif return error; }
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) void fdt_fixup_board_enet(void *fdt) { int offset; @@ -128,7 +128,7 @@ int ft_board_setup(void *blob, bd_t *bd)
fdt_fixup_memory_banks(blob, base, size, 2);
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) fdt_fixup_board_enet(blob); #endif
diff --git a/board/freescale/ls2080aqds/MAINTAINERS b/board/freescale/ls2080aqds/MAINTAINERS index 79877d7..62c8fac 100644 --- a/board/freescale/ls2080aqds/MAINTAINERS +++ b/board/freescale/ls2080aqds/MAINTAINERS @@ -7,6 +7,7 @@ F: include/configs/ls2080aqds.h F: configs/ls2080aqds_defconfig F: configs/ls2080aqds_nand_defconfig F: configs/ls2080aqds_qspi_defconfig +F: configs/ls2080aqds_sdcard_defconfig
LS2080A_SECURE_BOOT BOARD M: Saksham Jain saksham.jain@nxp.freescale.com diff --git a/board/freescale/ls2080aqds/README b/board/freescale/ls2080aqds/README index 2808bd5..d46b394 100644 --- a/board/freescale/ls2080aqds/README +++ b/board/freescale/ls2080aqds/README @@ -89,6 +89,19 @@ c) NAND boot d) SD boot e) QSPI boot
+Memory map for SD boot +------------------------- +Image Flash Offset SD Card + Start Block No. +RCW+PBI 0x00000000 0x00008 +Boot firmware (U-Boot) 0x00100000 0x00800 +Boot firmware Environment 0x00300000 0x01800 +PPA firmware 0x00400000 0x02000 +DPAA2 MC 0x00A00000 0x05000 +DPAA2 DPL 0x00D00000 0x06800 +DPAA2 DPC 0x00E00000 0x07000 +Kernel.itb 0x01000000 0x08000 + Environment Variables --------------------- - mcboottimeout: MC boot timeout in milliseconds. If this variable is not defined diff --git a/board/freescale/ls2080aqds/eth.c b/board/freescale/ls2080aqds/eth.c index 59361e9..302ff76 100644 --- a/board/freescale/ls2080aqds/eth.c +++ b/board/freescale/ls2080aqds/eth.c @@ -22,7 +22,7 @@
#define MC_BOOT_ENV_VAR "mcinitcmd"
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) /* - In LS2080A there are only 16 SERDES lanes, spread across 2 SERDES banks. * Bank 1 -> Lanes A, B, C, D, E, F, G, H * Bank 2 -> Lanes A,B, C, D, E, F, G, H @@ -834,8 +834,8 @@ void ls2080a_handle_phy_interface_xsgmii(int i) int board_eth_init(bd_t *bis) { int error; +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) char *mc_boot_env_var; -#ifdef CONFIG_FSL_MC_ENET struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; int serdes1_prtcl = (in_le32(&gur->rcwsr[28]) & FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_MASK) @@ -918,7 +918,3 @@ int board_eth_init(bd_t *bis) error = pci_eth_init(bis); return error; } - -#ifdef CONFIG_FSL_MC_ENET - -#endif diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index 6da9c6c..f36fb98 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -280,7 +280,7 @@ int arch_misc_init(void) } #endif
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) void fdt_fixup_board_enet(void *fdt) { int offset; @@ -336,7 +336,7 @@ int ft_board_setup(void *blob, bd_t *bd)
fsl_fdt_fixup_dr_usb(blob, bd);
diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig new file mode 100644 index 0000000..c1a93b9 --- /dev/null +++ b/configs/ls2080aqds_sdcard_defconfig @@ -0,0 +1,55 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS2080AQDS=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_SPL=y +CONFIG_FSL_LS_PPA=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 +CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_OF_EMBED=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_DM_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 12078c3..8160036 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -197,10 +197,17 @@ unsigned long long get_qixis_addr(void); "earlycon=uart8250,mmio,0x21c0500 " \ "ramdisk_size=0x2000000 default_hugepagesz=2m" \ " hugepagesz=2m hugepages=256" + +#ifdef CONFIG_SD_BOOT +#define CONFIG_BOOTCOMMAND "mmc read 0x80200000 0x6800 0x800;"\ + " fsl_mc apply dpl 0x80200000 &&" \ + " mmc read $kernel_load $kernel_start" \ + " $kernel_size && bootm $kernel_load" +#else #define CONFIG_BOOTCOMMAND "fsl_mc apply dpl 0x580700000 &&" \ " cp.b $kernel_start $kernel_load" \ " $kernel_size && bootm $kernel_load" - +#endif /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 4c48562..44165a9 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -165,12 +165,14 @@ unsigned long get_board_ddr_clk(void); #define QIXIS_LBMAP_DFLTBANK 0x00 #define QIXIS_LBMAP_ALTBANK 0x04 #define QIXIS_LBMAP_NAND 0x09 +#define QIXIS_LBMAP_SD 0x00 #define QIXIS_LBMAP_QSPI 0x0f #define QIXIS_RST_CTL_RESET 0x31 #define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 #define QIXIS_RCFG_CTL_RECONFIG_START 0x21 #define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 #define QIXIS_RCW_SRC_NAND 0x107 +#define QIXIS_RCW_SRC_SD 0x40 #define QIXIS_RCW_SRC_QSPI 0x62 #define QIXIS_RST_FORCE_MEM 0x01
@@ -234,6 +236,11 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SPL_PAD_TO 0x20000 #define CONFIG_SYS_NAND_U_BOOT_OFFS (256 * 1024) #define CONFIG_SYS_NAND_U_BOOT_SIZE (640 * 1024) +#elif defined(CONFIG_SD_BOOT) +#define CONFIG_ENV_OFFSET 0x200000 +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x20000 #endif #else #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT @@ -375,7 +382,25 @@ unsigned long get_board_ddr_clk(void); "esbc_validate 0x580cc0000;" \ "fsl_mc start mc 0x580300000" \ " 0x580800000 \0" +#elif defined(CONFIG_SD_BOOT) +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x90100000\0" \ + "kernel_addr=0x800\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x8000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x14000\0" \ + "mcinitcmd=mmcinfo;mmc read 0x80000000 0x5000 0x800;" \ + "mmc read 0x80100000 0x7000 0x800;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" \ + "mcmemsize=0x70000000 \0" #else +#undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ "hwconfig=fsl_ddr:bank_intlv=auto\0" \ "loadaddr=0x80100000\0" \ @@ -393,7 +418,7 @@ unsigned long get_board_ddr_clk(void); #endif /* CONFIG_SECURE_BOOT */
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) #define CONFIG_FSL_MEMAC #define CONFIG_PHYLIB #define CONFIG_PHYLIB_10G
Changes in v5:
- Update MAINTAINERS file
- Updated the memory layout
You have many changes like this in this patch. Why don't you change the Kconfig
--- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -96,7 +96,7 @@ config FSL_LSCH3 config FSL_MC_ENET bool "Management Complex network" depends on ARCH_LS2080A - default y + default y if !SPL_BUILD select RESV_RAM help Enable Management Complex (MC) network
Please try it.
York
-----Original Message----- From: York Sun [mailto:york.sun@nxp.com] Sent: Friday, May 12, 2017 9:31 PM To: Santan Kumar santan.kumar@nxp.com; u-boot@lists.denx.de Cc: Priyanka Jain priyanka.jain@nxp.com; Abhimanyu Saini abhimanyu.saini@nxp.com Subject: Re: [PATCH 2/2][v5] armv8: ls2080aqds: Add support for SD boot
Changes in v5:
default y
Please try it.
York
[Santan Kumar] I have already tried it. SPL_BUILD flag was not enabled when we this code is executing. That's why I haven't added it in Kconfig.
default y
Please try it.
York
Thanks for checking.
York
Signed-off-by: Santan Kumarsantan.kumar@nxp.com Signed-off-by: Priyanka Jainpriyanka.jain@nxp.com Signed-off-by: Abhimanyu Sainiabhimanyu.saini@nxp.com
You missed ls2080ardb_nand_defconfig.
Added CONFIG_NAND_BOOT=y to ls2080ardb_nand_defconfig. Applied to fsl-qoriq master, awaiting upstream. Thanks.
York
Santan Kumar
York Sun
york sun
