[PATCH] xilinx: fru: Replace spaces with \0 in detected revision
Also fix board revision field where spaces are used instead of \0. The same change was done for board name by commit 530560b6f8eb ("xilinx: fru: Replace spaces with \0 in detected name").
Signed-off-by: Michal Simek michal.simek@amd.com ---
board/xilinx/common/board.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 5be3090c3186..629a6ee036ff 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -245,6 +245,10 @@ static int xilinx_read_eeprom_fru(struct udevice *dev, char *name, } strncpy(desc->revision, (char *)fru_data.brd.rev, sizeof(desc->revision)); + for (i = 0; i < sizeof(desc->revision); i++) { + if (desc->revision[i] == ' ') + desc->revision[i] = '\0'; + } strncpy(desc->serial, (char *)fru_data.brd.serial_number, sizeof(desc->serial));
po 30. 5. 2022 v 13:50 odesÃlatel Michal Simek monstr@monstr.eu napsal:
-- 2.36.0
Applied. M
Michal Simek
