[U-Boot] [PATCH] board: sandpoint: delete an unused source file
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de Cc: Jim Thompson jim@musenki.com --- board/sandpoint/early_init.S | 137 ------------------------------------------- 1 file changed, 137 deletions(-) delete mode 100644 board/sandpoint/early_init.S
diff --git a/board/sandpoint/early_init.S b/board/sandpoint/early_init.S deleted file mode 100644 index 5a9b924..0000000 --- a/board/sandpoint/early_init.S +++ /dev/null @@ -1,137 +0,0 @@ -/* - * (C) Copyright 2001 - * Thomas Koeller, tkoeller@gmx.net - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __ASSEMBLY__ -#define __ASSEMBLY__ 1 -#endif - -#include <asm-offsets.h> -#include <config.h> -#include <asm/processor.h> -#include <mpc824x.h> -#include <ppc_asm.tmpl> - -#if defined(USE_DINK32) - /* We are running from RAM, so do not clear the MCCR1_MEMGO bit! */ - #define MCCR1VAL ((CONFIG_SYS_ROMNAL << MCCR1_ROMNAL_SHIFT) | (CONFIG_SYS_ROMFAL << MCCR1_ROMFAL_SHIFT) | MCCR1_MEMGO) -#else - #define MCCR1VAL (CONFIG_SYS_ROMNAL << MCCR1_ROMNAL_SHIFT) | (CONFIG_SYS_ROMFAL << MCCR1_ROMFAL_SHIFT) -#endif - - .text - - /* Values to program into memory controller registers */ -tbl: .long MCCR1, MCCR1VAL - .long MCCR2, CONFIG_SYS_REFINT << MCCR2_REFINT_SHIFT - .long MCCR3 - .long (((CONFIG_SYS_BSTOPRE & 0x000000f0) >> 4) << MCCR3_BSTOPRE2TO5_SHIFT) | \ - (CONFIG_SYS_REFREC << MCCR3_REFREC_SHIFT) | \ - (CONFIG_SYS_RDLAT << MCCR3_RDLAT_SHIFT) - .long MCCR4 - .long (CONFIG_SYS_PRETOACT << MCCR4_PRETOACT_SHIFT) | (CONFIG_SYS_ACTTOPRE << MCCR4_ACTTOPRE_SHIFT) | \ - (CONFIG_SYS_REGISTERD_TYPE_BUFFER << 20) | \ - (((CONFIG_SYS_BSTOPRE & 0x00000300) >> 8) << MCCR4_BSTOPRE0TO1_SHIFT ) | \ - ((CONFIG_SYS_SDMODE_CAS_LAT << 4) | (CONFIG_SYS_SDMODE_WRAP << 3) | \ - (CONFIG_SYS_SDMODE_BURSTLEN) << MCCR4_SDMODE_SHIFT) | \ - (CONFIG_SYS_ACTTORW << MCCR4_ACTTORW_SHIFT) | \ - ((CONFIG_SYS_BSTOPRE & 0x0000000f) << MCCR4_BSTOPRE6TO9_SHIFT ) - .long MSAR1 - .long (((CONFIG_SYS_BANK0_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 0) | \ - (((CONFIG_SYS_BANK1_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 8) | \ - (((CONFIG_SYS_BANK2_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 16) | \ - (((CONFIG_SYS_BANK3_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 24) - .long EMSAR1 - .long (((CONFIG_SYS_BANK0_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 0) | \ - (((CONFIG_SYS_BANK1_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 8) | \ - (((CONFIG_SYS_BANK2_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 16) | \ - (((CONFIG_SYS_BANK3_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 24) - .long MSAR2 - .long (((CONFIG_SYS_BANK4_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 0) | \ - (((CONFIG_SYS_BANK5_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 8) | \ - (((CONFIG_SYS_BANK6_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 16) | \ - (((CONFIG_SYS_BANK7_START & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 24) - .long EMSAR2 - .long (((CONFIG_SYS_BANK4_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 0) | \ - (((CONFIG_SYS_BANK5_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 8) | \ - (((CONFIG_SYS_BANK6_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 16) | \ - (((CONFIG_SYS_BANK7_START & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 24) - .long MEAR1 - .long (((CONFIG_SYS_BANK0_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 0) | \ - (((CONFIG_SYS_BANK1_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 8) | \ - (((CONFIG_SYS_BANK2_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 16) | \ - (((CONFIG_SYS_BANK3_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 24) - .long EMEAR1 - .long (((CONFIG_SYS_BANK0_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 0) | \ - (((CONFIG_SYS_BANK1_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 8) | \ - (((CONFIG_SYS_BANK2_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 16) | \ - (((CONFIG_SYS_BANK3_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 24) - .long MEAR2 - .long (((CONFIG_SYS_BANK4_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 0) | \ - (((CONFIG_SYS_BANK5_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 8) | \ - (((CONFIG_SYS_BANK6_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 16) | \ - (((CONFIG_SYS_BANK7_END & MICR_ADDR_MASK) >> MICR_ADDR_SHIFT) << 24) - .long EMEAR2 - .long (((CONFIG_SYS_BANK4_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 0) | \ - (((CONFIG_SYS_BANK5_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 8) | \ - (((CONFIG_SYS_BANK6_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 16) | \ - (((CONFIG_SYS_BANK7_END & MICR_EADDR_MASK) >> MICR_EADDR_SHIFT) << 24) - .long 0 - - - /* - * Early CPU initialization. Set up memory controller, so we can access any RAM at all. This - * must be done in assembly, since we have no stack at this point. - */ - .global early_init_f -early_init_f: - mflr r10 - - /* basic memory controller configuration */ - lis r3, CONFIG_ADDR_HIGH - lis r4, CONFIG_DATA_HIGH - bl lab -lab: mflr r5 - lwzu r0, tbl - lab(r5) -loop: lwz r1, 4(r5) - stwbrx r0, 0, r3 - eieio - stwbrx r1, 0, r4 - eieio - lwzu r0, 8(r5) - cmpli cr0, 0, r0, 0 - bne cr0, loop - - /* set bank enable bits */ - lis r0, MBER@h - ori r0, 0, MBER@l - li r1, CONFIG_SYS_BANK_ENABLE - stwbrx r0, 0, r3 - eieio - stb r1, 0(r4) - eieio - - /* delay loop */ - lis r0, 0x0003 - mtctr r0 -delay: bdnz delay - - /* enable memory controller */ - lis r0, MCCR1@h - ori r0, 0, MCCR1@l - stwbrx r0, 0, r3 - eieio - lwbrx r0, 0, r4 - oris r0, 0, MCCR1_MEMGO@h - stwbrx r0, 0, r4 - eieio - - /* set up stack pointer */ - lis r1, CONFIG_SYS_INIT_SP_OFFSET@h - ori r1, r1, CONFIG_SYS_INIT_SP_OFFSET@l - - mtlr r10 - blr
Masahiro Yamada
