[PATCH v3 0/8] Add i2c and reset support for Renesas RZ/G2L
This patch series extends the support for the Renesas RZ/G2L SMARC EVK board (based on the R9A07G044L2 SoC) to include the following new features:
* I2C bus support, including automatic deblocking if SDA is stuck low due to another device on the board.
* Basic PMIC support, with the ability to read, write & dump PMIC registers.
* Support for requesting system reset (SYSRESET_COLD or SYSRESET_POWER) via the PMIC.
Along the way we fix the CPG driver to confirm all clock & reset changes before returning, and update the device tree to align with Linux 6.7.
This series has been tested on RZ/G2L hardware, and the full u-boot GitLab CI pipeline has been executed in our internal GitLab instance.
Changes from v2: * Split the addition of RZ/G2L PMIC support into two patches: one to add the PMIC driver and one to modify the defconfig. * Collected Marek's Reviewed-by tags.
Changes from v1: * Rebased on U-Boot v2024.04-rc2 and re-tested. * Sync with Linux v6.7 instead of v6.6. * Add raa215300_bind() as a stub in patch 4. * Split up the addition of sysreset support into 3 patches: patch 5 adds the driver, patch 6 binds it with the pmic driver and patch 7 enables sysreset for the RZ/G2L.
Paul Barker (8): clk: renesas: Confirm all clock & reset changes on RZ/G2L arm: dts: rzg2l: Sync with Linux v6.7 i2c: rzg2l: Add I2C driver for RZ/G2L family pmic: Add Renesas RAA215300 PMIC driver board: rzg2l: Enable access to Renesas RAA215300 PMIC sysreset: Support reset via Renesas RAA215300 PMIC pmic: raa215300: Bind sysreset driver board: rzg2l: Support reset via Renesas RAA215300 PMIC
arch/arm/dts/r9a07g044.dtsi | 16 +- arch/arm/dts/r9a07g044l2-smarc.dts | 21 + arch/arm/dts/rz-smarc-common.dtsi | 18 +- arch/arm/dts/rzg2l-smarc-pinfunction.dtsi | 20 + arch/arm/dts/rzg2l-smarc-som.dtsi | 22 +- arch/arm/dts/rzg2l-smarc.dtsi | 43 +- arch/arm/mach-rmobile/Kconfig | 1 + board/renesas/rzg2l/rzg2l.c | 8 - configs/renesas_rzg2l_smarc_defconfig | 7 + drivers/clk/renesas/rzg2l-cpg.c | 17 +- drivers/i2c/Kconfig | 7 + drivers/i2c/Makefile | 1 + drivers/i2c/rz_riic.c | 624 ++++++++++++++++++++++ drivers/power/pmic/Kconfig | 9 + drivers/power/pmic/Makefile | 1 + drivers/power/pmic/raa215300.c | 50 ++ drivers/sysreset/Kconfig | 6 + drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset_raa215300.c | 58 ++ 19 files changed, 896 insertions(+), 34 deletions(-) create mode 100644 drivers/i2c/rz_riic.c create mode 100644 drivers/power/pmic/raa215300.c create mode 100644 drivers/sysreset/sysreset_raa215300.c
base-commit: d49fa3defa50c6d3f04acbb52fd486c13c14ab6a
When enabling/disabling a clock or reset signal, confirm that the change has completed before returning from the function. A somewhat arbitrary 100ms timeout is defined to ensure that the system doesn't lock up in the case of an error.
Since we need to dynamically determine if we're waiting for a 0 bit or a 1 bit, it's easier to use wait_for_bit_32() than readl_poll_timeout().
This change is needed for reliable initialization of the I2C driver which is added in a following patch.
Signed-off-by: Paul Barker paul.barker.ct@bp.renesas.com Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org --- drivers/clk/renesas/rzg2l-cpg.c | 17 +++++++++++++---- 1 file changed, 13 insertions(+), 4 deletions(-)
diff --git a/drivers/clk/renesas/rzg2l-cpg.c b/drivers/clk/renesas/rzg2l-cpg.c index e54508c35ce2..dba009997a81 100644 --- a/drivers/clk/renesas/rzg2l-cpg.c +++ b/drivers/clk/renesas/rzg2l-cpg.c @@ -23,10 +23,18 @@ #include <linux/iopoll.h> #include <reset-uclass.h> #include <reset.h> +#include <wait_bit.h>
#include "rzg2l-cpg.h"
+/* + * Monitor registers for both clock and reset signals are offset by 0x180 from + * the corresponding control registers. + */ #define CLK_MON_R(reg) (0x180 + (reg)) +#define RST_MON_R(reg) (0x180 + (reg)) + +#define CPG_TIMEOUT_MSEC 100
static ulong rzg2l_cpg_clk_get_rate_by_id(struct udevice *dev, unsigned int id); static ulong rzg2l_cpg_clk_get_rate_by_name(struct udevice *dev, const char *name); @@ -83,9 +91,9 @@ static int rzg2l_cpg_clk_set(struct clk *clk, bool enable) value |= BIT(mod_clk->bit); writel(value, data->base + mod_clk->off);
- if (enable && readl_poll_timeout(data->base + CLK_MON_R(mod_clk->off), - value, (value & BIT(mod_clk->bit)), - 10)) { + if (enable && wait_for_bit_32(data->base + CLK_MON_R(mod_clk->off), + BIT(mod_clk->bit), enable, + CPG_TIMEOUT_MSEC, false)) { dev_err(clk->dev, "Timeout\n"); return -ETIMEDOUT; } @@ -420,7 +428,8 @@ static int rzg2l_cpg_rst_set(struct reset_ctl *reset_ctl, bool asserted) value |= BIT(rst->bit); writel(value, data->base + rst->off);
- return 0; + return wait_for_bit_32(data->base + RST_MON_R(rst->off), BIT(rst->bit), + asserted, CPG_TIMEOUT_MSEC, false); }
static int rzg2l_cpg_rst_assert(struct reset_ctl *reset_ctl)
Pull in the recent changes to the RZ/G2L device tree and related dtsi files so that we're aligned with Linux v6.7 (commit 0dd3ee311255).
Signed-off-by: Paul Barker paul.barker.ct@bp.renesas.com Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org --- arch/arm/dts/r9a07g044.dtsi | 16 ++++----- arch/arm/dts/r9a07g044l2-smarc.dts | 21 +++++++++++ arch/arm/dts/rz-smarc-common.dtsi | 18 +++++----- arch/arm/dts/rzg2l-smarc-pinfunction.dtsi | 20 +++++++++++ arch/arm/dts/rzg2l-smarc-som.dtsi | 22 ++++++++++-- arch/arm/dts/rzg2l-smarc.dtsi | 43 +++++++++++++++++++++-- 6 files changed, 118 insertions(+), 22 deletions(-)
diff --git a/arch/arm/dts/r9a07g044.dtsi b/arch/arm/dts/r9a07g044.dtsi index 232910e07444..66f68fc2b241 100644 --- a/arch/arm/dts/r9a07g044.dtsi +++ b/arch/arm/dts/r9a07g044.dtsi @@ -223,20 +223,20 @@ <GIC_SPI 212 IRQ_TYPE_EDGE_RISING>, <GIC_SPI 213 IRQ_TYPE_EDGE_RISING>; interrupt-names = "tgia0", "tgib0", "tgic0", "tgid0", - "tgiv0", "tgie0", "tgif0", - "tgia1", "tgib1", "tgiv1", "tgiu1", - "tgia2", "tgib2", "tgiv2", "tgiu2", + "tciv0", "tgie0", "tgif0", + "tgia1", "tgib1", "tciv1", "tciu1", + "tgia2", "tgib2", "tciv2", "tciu2", "tgia3", "tgib3", "tgic3", "tgid3", - "tgiv3", + "tciv3", "tgia4", "tgib4", "tgic4", "tgid4", - "tgiv4", + "tciv4", "tgiu5", "tgiv5", "tgiw5", "tgia6", "tgib6", "tgic6", "tgid6", - "tgiv6", + "tciv6", "tgia7", "tgib7", "tgic7", "tgid7", - "tgiv7", + "tciv7", "tgia8", "tgib8", "tgic8", "tgid8", - "tgiv8", "tgiu8"; + "tciv8", "tciu8"; clocks = <&cpg CPG_MOD R9A07G044_MTU_X_MCK_MTU3>; power-domains = <&cpg>; resets = <&cpg R9A07G044_MTU_X_PRESET_MTU3>; diff --git a/arch/arm/dts/r9a07g044l2-smarc.dts b/arch/arm/dts/r9a07g044l2-smarc.dts index bc2af6c92ccd..568d49cfe44a 100644 --- a/arch/arm/dts/r9a07g044l2-smarc.dts +++ b/arch/arm/dts/r9a07g044l2-smarc.dts @@ -6,6 +6,27 @@ */
/dts-v1/; + +/* Enable SCIF2 (SER0) on PMOD1 (CN7) */ +#define PMOD1_SER0 1 + +/* + * To enable MTU3a PWM on PMOD0, + * Disable PMOD1_SER0 by setting "#define PMOD1_SER0 0" above and + * enable PMOD_MTU3 by setting "#define PMOD_MTU3 1" below. + */ +#define PMOD_MTU3 0 + +#if (PMOD_MTU3 && PMOD1_SER0) +#error "Cannot set as PMOD_MTU3 and PMOD1_SER0 are mutually exclusive " +#endif + +#define MTU3_COUNTER_Z_PHASE_SIGNAL 0 + +#if (!PMOD_MTU3 && MTU3_COUNTER_Z_PHASE_SIGNAL) +#error "Cannot set 1 to MTU3_COUNTER_Z_PHASE_SIGNAL as PMOD_MTU3=0" +#endif + #include "r9a07g044l2.dtsi" #include "rzg2l-smarc-som.dtsi" #include "rzg2l-smarc-pinfunction.dtsi" diff --git a/arch/arm/dts/rz-smarc-common.dtsi b/arch/arm/dts/rz-smarc-common.dtsi index 3962d47b3e59..b7a3e6caa386 100644 --- a/arch/arm/dts/rz-smarc-common.dtsi +++ b/arch/arm/dts/rz-smarc-common.dtsi @@ -32,12 +32,6 @@ stdout-path = "serial0:115200n8"; };
- audio_mclock: audio_mclock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <11289600>; - }; - snd_rzg2l: sound { compatible = "simple-audio-card"; simple-audio-card,format = "i2s"; @@ -55,7 +49,7 @@ };
codec_dai: simple-audio-card,codec { - clocks = <&audio_mclock>; + clocks = <&versa3 2>; sound-dai = <&wm8978>; }; }; @@ -76,13 +70,19 @@ gpios-states = <1>; states = <3300000 1>, <1800000 0>; }; + + x1: x1-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + }; };
-&audio_clk1{ +&audio_clk1 { clock-frequency = <11289600>; };
-&audio_clk2{ +&audio_clk2 { clock-frequency = <12288000>; };
diff --git a/arch/arm/dts/rzg2l-smarc-pinfunction.dtsi b/arch/arm/dts/rzg2l-smarc-pinfunction.dtsi index 9085d8c76ce1..18c526c7a4cf 100644 --- a/arch/arm/dts/rzg2l-smarc-pinfunction.dtsi +++ b/arch/arm/dts/rzg2l-smarc-pinfunction.dtsi @@ -53,6 +53,26 @@ <RZG2L_PORT_PINMUX(18, 1, 3)>; /* SCL */ };
+ mtu3_pins: mtu3 { + mtu3-ext-clk-input-pin { + pinmux = <RZG2L_PORT_PINMUX(48, 0, 4)>, /* MTCLKA */ + <RZG2L_PORT_PINMUX(48, 1, 4)>; /* MTCLKB */ + }; + + mtu3-pwm { + pinmux = <RZG2L_PORT_PINMUX(44, 0, 4)>, /* MTIOC3A */ + <RZG2L_PORT_PINMUX(44, 1, 4)>, /* MTIOC3B */ + <RZG2L_PORT_PINMUX(44, 2, 4)>, /* MTIOC3C */ + <RZG2L_PORT_PINMUX(44, 3, 4)>; /* MTIOC3D */ + }; + +#if MTU3_COUNTER_Z_PHASE_SIGNAL + mtu3-zphase-clk { + pinmux = <RZG2L_PORT_PINMUX(19, 0, 3)>; /* MTIOC1A */ + }; +#endif /* MTU3_COUNTER_Z_PHASE_SIGNAL */ + }; + scif0_pins: scif0 { pinmux = <RZG2L_PORT_PINMUX(38, 0, 1)>, /* TxD */ <RZG2L_PORT_PINMUX(38, 1, 1)>; /* RxD */ diff --git a/arch/arm/dts/rzg2l-smarc-som.dtsi b/arch/arm/dts/rzg2l-smarc-som.dtsi index fbbb4f03440b..547859c388ce 100644 --- a/arch/arm/dts/rzg2l-smarc-som.dtsi +++ b/arch/arm/dts/rzg2l-smarc-som.dtsi @@ -73,6 +73,13 @@ gpios = <&pinctrl RZG2L_GPIO(39, 0) GPIO_ACTIVE_HIGH>; regulator-always-on; }; + + /* 32.768kHz crystal */ + x2: x2-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + }; };
&adc { @@ -100,7 +107,7 @@ rxc-skew-psec = <2400>; txc-skew-psec = <2400>; rxdv-skew-psec = <0>; - txdv-skew-psec = <0>; + txen-skew-psec = <0>; rxd0-skew-psec = <0>; rxd1-skew-psec = <0>; rxd2-skew-psec = <0>; @@ -128,7 +135,7 @@ rxc-skew-psec = <2400>; txc-skew-psec = <2400>; rxdv-skew-psec = <0>; - txdv-skew-psec = <0>; + txen-skew-psec = <0>; rxd0-skew-psec = <0>; rxd1-skew-psec = <0>; rxd2-skew-psec = <0>; @@ -148,6 +155,17 @@ mali-supply = <®_1p1v>; };
+&i2c3 { + raa215300: pmic@12 { + compatible = "renesas,raa215300"; + reg = <0x12>, <0x6f>; + reg-names = "main", "rtc"; + + clocks = <&x2>; + clock-names = "xin"; + }; +}; + &ostm1 { status = "okay"; }; diff --git a/arch/arm/dts/rzg2l-smarc.dtsi b/arch/arm/dts/rzg2l-smarc.dtsi index 2a158a954b2f..37807f1bda4d 100644 --- a/arch/arm/dts/rzg2l-smarc.dtsi +++ b/arch/arm/dts/rzg2l-smarc.dtsi @@ -8,9 +8,6 @@ #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/pinctrl/rzg2l-pinctrl.h>
-/* comment the #define statement to disable SCIF2 (SER0) on PMOD1 (CN7) */ -#define PMOD1_SER0 1 - / { aliases { serial1 = &scif2; @@ -113,8 +110,48 @@ #sound-dai-cells = <0>; reg = <0x1a>; }; + + versa3: clock-generator@68 { + compatible = "renesas,5p35023"; + reg = <0x68>; + #clock-cells = <1>; + clocks = <&x1>; + + renesas,settings = [ + 80 00 11 19 4c 02 23 7f 83 19 08 a9 5f 25 24 bf + 00 14 7a e1 00 00 00 00 01 55 59 bb 3f 30 90 b6 + 80 b0 45 c4 95 + ]; + + assigned-clocks = <&versa3 0>, <&versa3 1>, + <&versa3 2>, <&versa3 3>, + <&versa3 4>, <&versa3 5>; + assigned-clock-rates = <24000000>, <11289600>, + <11289600>, <12000000>, + <25000000>, <12288000>; + }; };
+#if PMOD_MTU3 +&mtu3 { + pinctrl-0 = <&mtu3_pins>; + pinctrl-names = "default"; + + status = "okay"; +}; + +#if MTU3_COUNTER_Z_PHASE_SIGNAL +/* SDHI cd pin is muxed with counter Z phase signal */ +&sdhi1 { + status = "disabled"; +}; +#endif /* MTU3_COUNTER_Z_PHASE_SIGNAL */ + +&spi1 { + status = "disabled"; +}; +#endif /* PMOD_MTU3 */ + /* * To enable SCIF2 (SER0) on PMOD1 (CN7) * SW1 should be at position 2->3 so that SER0_CTS# line is activated
This driver supports the I2C module on the Renesas RZ/G2L (R9A07G044) SoC, also known as the RIIC module.
This patch is based on both the u-boot driver in the Renesas RZ BSP 3.0.5 release [1] (commit 7fcc1fdc2534), and the Linux v6.7 driver (commit 0dd3ee311255).
Support for deblocking the I2C bus is included as this may be needed after triggering a reset via the Power Management IC (PMIC) over I2C (the PMIC asserts the reset line before the SoC completes the I2C write transaction with obvious bus locking effects). If the SDA line is observed to be low during initialisation, we automatically attempt to deblock.
[1]: https://github.com/renesas-rz/renesas-u-boot-cip
Signed-off-by: Paul Barker paul.barker.ct@bp.renesas.com Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org --- arch/arm/mach-rmobile/Kconfig | 1 + configs/renesas_rzg2l_smarc_defconfig | 2 + drivers/i2c/Kconfig | 7 + drivers/i2c/Makefile | 1 + drivers/i2c/rz_riic.c | 624 ++++++++++++++++++++++++++ 5 files changed, 635 insertions(+) create mode 100644 drivers/i2c/rz_riic.c
diff --git a/arch/arm/mach-rmobile/Kconfig b/arch/arm/mach-rmobile/Kconfig index 2bb96749fc0d..38ede6e0b5b5 100644 --- a/arch/arm/mach-rmobile/Kconfig +++ b/arch/arm/mach-rmobile/Kconfig @@ -78,6 +78,7 @@ config RZG2L imply RENESAS_SDHI imply RZG2L_GPIO imply SCIF_CONSOLE + imply SYS_I2C_RZ_RIIC imply SYS_MALLOC_F help Enable support for the Renesas RZ/G2L family of SoCs. Currently diff --git a/configs/renesas_rzg2l_smarc_defconfig b/configs/renesas_rzg2l_smarc_defconfig index e45579ae6b98..ad46297c6619 100644 --- a/configs/renesas_rzg2l_smarc_defconfig +++ b/configs/renesas_rzg2l_smarc_defconfig @@ -24,6 +24,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=64 CONFIG_CMD_CLK=y CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y CONFIG_CMD_EXT2=y @@ -44,6 +45,7 @@ CONFIG_CLK=y CONFIG_CLK_RENESAS=y # CONFIG_CLK_RCAR_GEN3 is not set CONFIG_GPIO_HOG=y +CONFIG_DM_I2C=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS400_SUPPORT=y diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 4f42200f3923..d2a3a13493aa 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -524,6 +524,13 @@ config SYS_I2C_ROCKCHIP have several I2C ports and all are provided, controlled by the device tree.
+config SYS_I2C_RZ_RIIC + bool "Renesas RZ/G2L RIIC driver" + depends on RZG2L && DM_I2C + help + Support for the I2C controller (RIIC) on the Renesas RZ/G2L SoC + family. + config SYS_I2C_SANDBOX bool "Sandbox I2C driver" depends on SANDBOX && DM_I2C diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index a96a8c7e955e..692f63bafd02 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -40,6 +40,7 @@ obj-$(CONFIG_SYS_I2C_QUP) += qup_i2c.o obj-$(CONFIG_SYS_I2C_RCAR_I2C) += rcar_i2c.o obj-$(CONFIG_SYS_I2C_RCAR_IIC) += rcar_iic.o obj-$(CONFIG_SYS_I2C_ROCKCHIP) += rk_i2c.o +obj-$(CONFIG_SYS_I2C_RZ_RIIC) += rz_riic.o obj-$(CONFIG_SYS_I2C_S3C24X0) += s3c24x0_i2c.o exynos_hs_i2c.o obj-$(CONFIG_SYS_I2C_SANDBOX) += sandbox_i2c.o i2c-emul-uclass.o obj-$(CONFIG_SYS_I2C_SH) += sh_i2c.o diff --git a/drivers/i2c/rz_riic.c b/drivers/i2c/rz_riic.c new file mode 100644 index 000000000000..5f3f8d1b24b7 --- /dev/null +++ b/drivers/i2c/rz_riic.c @@ -0,0 +1,624 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * RZ/G2L I2C (RIIC) driver + * + * Copyright (C) 2021-2023 Renesas Electronics Corp. + */ + +#include <asm/io.h> +#include <clk.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <errno.h> +#include <i2c.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <reset.h> +#include <wait_bit.h> + +#define RIIC_ICCR1 0x00 +#define RIIC_ICCR2 0x04 +#define RIIC_ICMR1 0x08 +#define RIIC_ICMR2 0x0c +#define RIIC_ICMR3 0x10 +#define RIIC_ICFER 0x14 +#define RIIC_ICSER 0x18 +#define RIIC_ICIER 0x1c +#define RIIC_ICSR1 0x20 +#define RIIC_ICSR2 0x24 +#define RIIC_ICSAR0 0x28 +#define RIIC_ICBRL 0x34 +#define RIIC_ICBRH 0x38 +#define RIIC_ICDRT 0x3c +#define RIIC_ICDRR 0x40 + +/* ICCR1 */ +#define ICCR1_ICE BIT(7) +#define ICCR1_IICRST BIT(6) +#define ICCR1_CLO BIT(5) +#define ICCR1_SOWP BIT(4) +#define ICCR1_SCLO BIT(3) +#define ICCR1_SDAO BIT(2) +#define ICCR1_SCLI BIT(1) +#define ICCR1_SDAI BIT(0) + +/* ICCR2 */ +#define ICCR2_BBSY BIT(7) +#define ICCR2_MST BIT(6) +#define ICCR2_TRS BIT(5) +#define ICCR2_SP BIT(3) +#define ICCR2_RS BIT(2) +#define ICCR2_ST BIT(1) + +/* ICMR1 */ +#define ICMR1_MTWP BIT(7) +#define ICMR1_CKS_MASK GENMASK(6, 4) +#define ICMR1_BCWP BIT(3) +#define ICMR1_BC_MASK GENMASK(2, 0) + +#define ICMR1_CKS(x) (((x) << 4) & ICMR1_CKS_MASK) +#define ICMR1_BC(x) ((x) & ICMR1_BC_MASK) + +/* ICMR2 */ +#define ICMR2_DLCS BIT(7) +#define ICMR2_SDDL_MASK GENMASK(6, 4) +#define ICMR2_TMOH BIT(2) +#define ICMR2_TMOL BIT(1) +#define ICMR2_TMOS BIT(0) + +/* ICMR3 */ +#define ICMR3_SMBS BIT(7) +#define ICMR3_WAIT BIT(6) +#define ICMR3_RDRFS BIT(5) +#define ICMR3_ACKWP BIT(4) +#define ICMR3_ACKBT BIT(3) +#define ICMR3_ACKBR BIT(2) +#define ICMR3_NF_MASK GENMASK(1, 0) + +/* ICFER */ +#define ICFER_FMPE BIT(7) +#define ICFER_SCLE BIT(6) +#define ICFER_NFE BIT(5) +#define ICFER_NACKE BIT(4) +#define ICFER_SALE BIT(3) +#define ICFER_NALE BIT(2) +#define ICFER_MALE BIT(1) +#define ICFER_TMOE BIT(0) + +/* ICSER */ +#define ICSER_HOAE BIT(7) +#define ICSER_DIDE BIT(5) +#define ICSER_GCAE BIT(3) +#define ICSER_SAR2E BIT(2) +#define ICSER_SAR1E BIT(1) +#define ICSER_SAR0E BIT(0) + +/* ICIER */ +#define ICIER_TIE BIT(7) +#define ICIER_TEIE BIT(6) +#define ICIER_RIE BIT(5) +#define ICIER_NAKIE BIT(4) +#define ICIER_SPIE BIT(3) +#define ICIER_STIE BIT(2) +#define ICIER_ALIE BIT(1) +#define ICIER_TMOIE BIT(0) + +/* ICSR1 */ +#define ICSR1_HOA BIT(7) +#define ICSR1_DID BIT(5) +#define ICSR1_GCA BIT(3) +#define ICSR1_AAS2 BIT(2) +#define ICSR1_AAS1 BIT(1) +#define ICSR1_AAS0 BIT(0) + +/* ICSR2 */ +#define ICSR2_TDRE BIT(7) +#define ICSR2_TEND BIT(6) +#define ICSR2_RDRF BIT(5) +#define ICSR2_NACKF BIT(4) +#define ICSR2_STOP BIT(3) +#define ICSR2_START BIT(2) +#define ICSR2_AL BIT(1) +#define ICSR2_TMOF BIT(0) + +/* ICBRH */ +#define ICBRH_RESERVED GENMASK(7, 5) /* The write value should always be 1 */ +#define ICBRH_BRH_MASK GENMASK(4, 0) + +/* ICBRL */ +#define ICBRL_RESERVED GENMASK(7, 5) /* The write value should always be 1 */ +#define ICBRL_BRL_MASK GENMASK(4, 0) + +#define RIIC_TIMEOUT_MSEC 100 + +#define RIIC_FLAG_DEFAULT_SCL_RISE_TIME BIT(0) +#define RIIC_FLAG_DEFAULT_SCL_FALL_TIME BIT(1) + +/* + * If SDA is stuck in a low state, the I2C spec says up to 9 clock cycles on SCL + * may be needed to unblock whichever other device on the bus is holding SDA low. + */ +#define I2C_DEBLOCK_MAX_CYCLES 9 + +struct riic_priv { + void __iomem *base; + struct clk clk; + uint bus_speed; + u32 scl_rise_ns; + u32 scl_fall_ns; + u32 flags; +}; + +static int riic_check_busy(struct udevice *dev) +{ + struct riic_priv *priv = dev_get_priv(dev); + int ret; + + ret = wait_for_bit_8(priv->base + RIIC_ICCR2, ICCR2_BBSY, 0, + RIIC_TIMEOUT_MSEC, 0); + if (ret == -ETIMEDOUT) { + dev_dbg(dev, "bus is busy!\n"); + return -EBUSY; + } + + return ret; +} + +static int riic_wait_for_icsr2(struct udevice *dev, u8 bit) +{ + struct riic_priv *priv = dev_get_priv(dev); + ulong start = get_timer(0); + u8 icsr2; + + /* We can't use wait_for_bit_8() here as we need to check for NACK. */ + while (!((icsr2 = readb(priv->base + RIIC_ICSR2)) & bit)) { + if (icsr2 & ICSR2_NACKF) + return -EIO; + if (get_timer(start) > RIIC_TIMEOUT_MSEC) { + dev_dbg(dev, "timeout! (bit=%x, icsr2=%x, iccr2=%x)\n", + bit, icsr2, readb(priv->base + RIIC_ICCR2)); + return -ETIMEDOUT; + } + udelay(1); + schedule(); + } + + return 0; +} + +static int riic_check_nack_receive(struct udevice *dev) +{ + struct riic_priv *priv = dev_get_priv(dev); + + if (readb(priv->base + RIIC_ICSR2) & ICSR2_NACKF) { + dev_dbg(dev, "received nack!\n"); + /* received NACK */ + clrbits_8(priv->base + RIIC_ICSR2, ICSR2_NACKF); + setbits_8(priv->base + RIIC_ICCR2, ICCR2_SP); + readb(priv->base + RIIC_ICDRR); /* dummy read */ + return -EIO; + } + return 0; +} + +static int riic_i2c_raw_write(struct udevice *dev, u8 *buf, size_t len) +{ + struct riic_priv *priv = dev_get_priv(dev); + size_t i; + int ret; + + for (i = 0; i < len; i++) { + ret = riic_check_nack_receive(dev); + if (ret < 0) + return ret; + + ret = riic_wait_for_icsr2(dev, ICSR2_TDRE); + if (ret < 0) + return ret; + + writeb(buf[i], priv->base + RIIC_ICDRT); + } + + return riic_check_nack_receive(dev); +} + +static int riic_send_start_cond(struct udevice *dev, int restart) +{ + struct riic_priv *priv = dev_get_priv(dev); + int ret; + + if (restart) + setbits_8(priv->base + RIIC_ICCR2, ICCR2_RS); + else + setbits_8(priv->base + RIIC_ICCR2, ICCR2_ST); + + ret = riic_wait_for_icsr2(dev, ICSR2_START); + if (ret < 0) + return ret; + clrbits_8(priv->base + RIIC_ICSR2, ICSR2_START); + + return ret; +} + +static int riic_receive_data(struct udevice *dev, struct i2c_msg *msg) +{ + struct riic_priv *priv = dev_get_priv(dev); + int ret, stop_ret, i; + + ret = riic_wait_for_icsr2(dev, ICSR2_RDRF); + if (ret < 0) + goto send_stop; + + ret = riic_check_nack_receive(dev); + if (ret < 0) + goto send_stop; + + setbits_8(priv->base + RIIC_ICMR3, ICMR3_WAIT | ICMR3_ACKWP | ICMR3_RDRFS); + + /* A dummy read must be performed to trigger data reception */ + readb(priv->base + RIIC_ICDRR); + + for (i = 0; i < msg->len; i++) { + ret = riic_wait_for_icsr2(dev, ICSR2_RDRF); + if (ret < 0) + goto send_stop; + + if (i == (msg->len - 1)) { + clrbits_8(priv->base + RIIC_ICSR2, ICSR2_STOP); + setbits_8(priv->base + RIIC_ICCR2, ICCR2_SP); + setbits_8(priv->base + RIIC_ICMR3, ICMR3_ACKBT); + } else { + clrbits_8(priv->base + RIIC_ICMR3, ICMR3_ACKBT); + } + + msg->buf[i] = readb(priv->base + RIIC_ICDRR); + }; + +send_stop: + if (ret) { + /* + * We got here due to an error condition, so we need to perform + * a dummy read to issue the stop bit. + */ + clrbits_8(priv->base + RIIC_ICSR2, ICSR2_STOP); + setbits_8(priv->base + RIIC_ICCR2, ICCR2_SP); + readb(priv->base + RIIC_ICDRR); + } + stop_ret = riic_wait_for_icsr2(dev, ICSR2_STOP); + clrbits_8(priv->base + RIIC_ICSR2, ICSR2_STOP | ICSR2_NACKF); + clrbits_8(priv->base + RIIC_ICMR3, ICMR3_WAIT | ICMR3_ACKWP | ICMR3_RDRFS); + return ret ? ret : stop_ret; +} + +static int riic_transmit_stop(struct udevice *dev) +{ + struct riic_priv *priv = dev_get_priv(dev); + int ret; + + clrbits_8(priv->base + RIIC_ICSR2, ICSR2_STOP); + setbits_8(priv->base + RIIC_ICCR2, ICCR2_SP); + + ret = riic_wait_for_icsr2(dev, ICSR2_STOP); + clrbits_8(priv->base + RIIC_ICSR2, ICSR2_STOP | ICSR2_NACKF); + return ret; +} + +static int riic_transmit_data(struct udevice *dev, struct i2c_msg *msg) +{ + int ret, stop_ret; + + ret = riic_i2c_raw_write(dev, msg->buf, msg->len); + if (ret < 0) + goto send_stop; + + ret = riic_wait_for_icsr2(dev, ICSR2_TEND); + if (ret < 0) + goto send_stop; + + if (!ret && !(msg->flags & I2C_M_STOP)) + return 0; + +send_stop: + stop_ret = riic_transmit_stop(dev); + return ret ? ret : stop_ret; +} + +static int riic_xfer_one(struct udevice *dev, struct i2c_msg *msg, int first_msg) +{ + u8 addr_byte = ((msg->addr << 1) | (msg->flags & I2C_M_RD)); + int ret; + + if (!(msg->flags & I2C_M_NOSTART)) { + /* + * Send a start for the first message and a restart for + * subsequent messages. + */ + ret = riic_send_start_cond(dev, !first_msg); + if (ret < 0) + return ret; + } + + ret = riic_i2c_raw_write(dev, &addr_byte, 1); + if (ret < 0) { + /* + * We're aborting the transfer while still in master transmit + * mode. + */ + riic_transmit_stop(dev); + return ret; + } + + if (msg->flags & I2C_M_RD) + return riic_receive_data(dev, msg); + + return riic_transmit_data(dev, msg); +} + +static int riic_xfer(struct udevice *dev, struct i2c_msg *msg, int nmsgs) +{ + int ret, i; + + ret = riic_check_busy(dev); + if (ret < 0) + return ret; + + /* Ensure that the last message is terminated with a stop bit. */ + msg[nmsgs - 1].flags |= I2C_M_STOP; + + for (i = 0; i < nmsgs; i++) { + ret = riic_xfer_one(dev, &msg[i], !i); + if (ret) + return ret; + } + + return 0; +} + +static int riic_deblock(struct udevice *dev) +{ + struct riic_priv *priv = dev_get_priv(dev); + int i = 0; + + /* + * Issue clock cycles on SCL to hopefully unblock whatever is holding + * SDA low. These clock cycles may trigger error conditions such as + * Arbitration Lost, so we clear the status bits in ICSR2 after each + * cycle. + */ + while (!(readb(priv->base + RIIC_ICCR1) & ICCR1_SDAI)) { + if (i++ == I2C_DEBLOCK_MAX_CYCLES) + return -EIO; + + setbits_8(priv->base + RIIC_ICCR1, ICCR1_CLO); + if (wait_for_bit_8(priv->base + RIIC_ICCR1, ICCR1_CLO, 0, + RIIC_TIMEOUT_MSEC, false)) + return -ETIMEDOUT; + writeb(0, priv->base + RIIC_ICSR2); + } + + /* + * We have released SDA, but the I2C module is now out of sync + * with the bus state, so we need to reset its state machine. + */ + setbits_8(priv->base + RIIC_ICCR1, ICCR1_IICRST); + clrbits_8(priv->base + RIIC_ICCR1, ICCR1_IICRST); + + return 0; +} + +static int riic_set_bus_speed(struct udevice *dev, uint bus_speed) +{ + struct riic_priv *priv = dev_get_priv(dev); + ulong refclk; + uint total_ticks, cks, brl, brh; + + if (bus_speed > I2C_SPEED_FAST_PLUS_RATE) { + dev_err(dev, "unsupported bus speed (%dHz). %d max\n", bus_speed, + I2C_SPEED_FAST_PLUS_RATE); + return -EINVAL; + } + + /* + * Assume the default register settings: + * FER.SCLE = 1 (SCL sync circuit enabled, adds 2 or 3 cycles) + * FER.NFE = 1 (noise circuit enabled) + * MR3.NF = 0 (1 cycle of noise filtered out) + * + * Freq (CKS=000) = (I2CCLK + tr + tf)/ (BRH + 3 + 1) + (BRL + 3 + 1) + * Freq (CKS!=000) = (I2CCLK + tr + tf)/ (BRH + 2 + 1) + (BRL + 2 + 1) + */ + + /* + * Determine reference clock rate. We must be able to get the desired + * frequency with only 62 clock ticks max (31 high, 31 low). + * Aim for a duty of 60% LOW, 40% HIGH. + */ + refclk = clk_get_rate(&priv->clk); + total_ticks = DIV_ROUND_UP(refclk, bus_speed ?: 1); + + for (cks = 0; cks < 7; cks++) { + /* + * 60% low time must be less than BRL + 2 + 1 + * BRL max register value is 0x1F. + */ + brl = ((total_ticks * 6) / 10); + if (brl <= (0x1f + 3)) + break; + + total_ticks /= 2; + refclk /= 2; + } + + if (brl > (0x1f + 3)) { + dev_err(dev, "invalid speed (%u). Too slow.\n", bus_speed); + return -EINVAL; + } + + brh = total_ticks - brl; + + /* Remove automatic clock ticks for sync circuit and NF */ + if (cks == 0) { + brl -= 4; + brh -= 4; + } else { + brl -= 3; + brh -= 3; + } + + /* + * If SCL rise and fall times weren't set in the device tree, set them + * based on the desired bus speed and the maximum timings given in the + * I2C specification. + */ + if (priv->flags & RIIC_FLAG_DEFAULT_SCL_RISE_TIME) + priv->scl_rise_ns = bus_speed <= I2C_SPEED_STANDARD_RATE ? 1000 : + bus_speed <= I2C_SPEED_FAST_RATE ? 300 : 120; + if (priv->flags & RIIC_FLAG_DEFAULT_SCL_FALL_TIME) + priv->scl_fall_ns = bus_speed <= I2C_SPEED_FAST_RATE ? 300 : 120; + + /* + * Remove clock ticks for rise and fall times. Convert ns to clock + * ticks. + */ + brl -= priv->scl_fall_ns / (1000000000 / refclk); + brh -= priv->scl_rise_ns / (1000000000 / refclk); + + /* Adjust for min register values for when SCLE=1 and NFE=1 */ + if (brl < 1) + brl = 1; + if (brh < 1) + brh = 1; + + priv->bus_speed = refclk / total_ticks; + dev_dbg(dev, "freq=%u, duty=%d, fall=%lu, rise=%lu, cks=%d, brl=%d, brh=%d\n", + priv->bus_speed, ((brl + 3) * 100) / (brl + brh + 6), + priv->scl_fall_ns / (1000000000 / refclk), + priv->scl_rise_ns / (1000000000 / refclk), cks, brl, brh); + + setbits_8(priv->base + RIIC_ICCR1, ICCR1_IICRST); + writeb(ICMR1_CKS(cks), priv->base + RIIC_ICMR1); + writeb(brh | ICBRH_RESERVED, priv->base + RIIC_ICBRH); + writeb(brl | ICBRL_RESERVED, priv->base + RIIC_ICBRL); + clrbits_8(priv->base + RIIC_ICCR1, ICCR1_IICRST); + + return 0; +} + +static int riic_get_bus_speed(struct udevice *dev) +{ + struct riic_priv *priv = dev_get_priv(dev); + + return priv->bus_speed; +} + +static const struct dm_i2c_ops riic_ops = { + .xfer = riic_xfer, + .deblock = riic_deblock, + .set_bus_speed = riic_set_bus_speed, + .get_bus_speed = riic_get_bus_speed, +}; + +static int riic_init_setting(struct udevice *dev) +{ + struct riic_priv *priv = dev_get_priv(dev); + int ret; + + clrbits_8(priv->base + RIIC_ICCR1, ICCR1_ICE); + setbits_8(priv->base + RIIC_ICCR1, ICCR1_IICRST); + setbits_8(priv->base + RIIC_ICCR1, ICCR1_ICE); + + /* + * Set a default bitrate. The rate may be overridden based on the device + * tree as part of i2c_post_probe(). + */ + ret = riic_set_bus_speed(dev, I2C_SPEED_STANDARD_RATE); + if (ret < 0) + goto err; + + clrbits_8(priv->base + RIIC_ICCR1, ICCR1_IICRST); + + /* Make sure the bus is not stuck. */ + if (!(readb(priv->base + RIIC_ICCR1) & ICCR1_SDAI)) { + dev_dbg(dev, "clearing SDA low state\n"); + ret = riic_deblock(dev); + if (ret) { + dev_err(dev, "failed to clear SDA low state!\n"); + goto err; + } + } + return 0; + +err: + clrbits_8(priv->base + RIIC_ICCR1, ICCR1_ICE | ICCR1_IICRST); + return ret; +} + +static int riic_probe(struct udevice *dev) +{ + struct riic_priv *priv = dev_get_priv(dev); + struct reset_ctl rst; + int ret; + + priv->base = dev_read_addr_ptr(dev); + + ret = dev_read_u32(dev, "i2c-scl-rising-time-ns", &priv->scl_rise_ns); + if (ret) + priv->flags |= RIIC_FLAG_DEFAULT_SCL_RISE_TIME; + ret = dev_read_u32(dev, "i2c-scl-falling-time-ns", &priv->scl_fall_ns); + if (ret) + priv->flags |= RIIC_FLAG_DEFAULT_SCL_FALL_TIME; + + ret = clk_get_by_index(dev, 0, &priv->clk); + if (ret) { + dev_err(dev, "failed to get clock\n"); + return ret; + } + + ret = clk_enable(&priv->clk); + if (ret) { + dev_err(dev, "failed to enable clock\n"); + return ret; + } + + ret = reset_get_by_index(dev, 0, &rst); + if (ret < 0) { + dev_err(dev, "failed to get reset line\n"); + goto err_get_reset; + } + + ret = reset_deassert(&rst); + if (ret < 0) { + dev_err(dev, "failed to de-assert reset line\n"); + goto err_reset; + } + + ret = riic_init_setting(dev); + if (ret < 0) { + dev_err(dev, "failed to init i2c bus interface\n"); + goto err_init; + } + + return 0; + +err_init: + reset_assert(&rst); +err_reset: + reset_free(&rst); +err_get_reset: + clk_disable(&priv->clk); + return ret; +} + +static const struct udevice_id riic_ids[] = { + { .compatible = "renesas,riic-rz", }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(riic_i2c) = { + .name = "riic-i2c", + .id = UCLASS_I2C, + .of_match = riic_ids, + .probe = riic_probe, + .priv_auto = sizeof(struct riic_priv), + .ops = &riic_ops, +};
The RZ/G2L SMARC module is powered via a Renesas RAA215300 PMIC which provides several voltage converters, a real time clock (RTC) and reset control. A basic driver is implemented for this device so that we can read, write and dump the PMIC registers.
The raa215300_bind() function is added as a stub, binding of the sysreset driver will be added in a later patch.
Additional features of this PMIC (such as reset control) may be supported by future patches.
Signed-off-by: Paul Barker paul.barker.ct@bp.renesas.com --- drivers/power/pmic/Kconfig | 9 ++++++++ drivers/power/pmic/Makefile | 1 + drivers/power/pmic/raa215300.c | 41 ++++++++++++++++++++++++++++++++++ 3 files changed, 51 insertions(+) create mode 100644 drivers/power/pmic/raa215300.c
diff --git a/drivers/power/pmic/Kconfig b/drivers/power/pmic/Kconfig index 454a6e0cf87a..9b61b18e11fd 100644 --- a/drivers/power/pmic/Kconfig +++ b/drivers/power/pmic/Kconfig @@ -404,6 +404,15 @@ config PMIC_TPS65219 help The TPS65219 is a PMIC containing a bunch of SMPS & LDOs. This driver binds the pmic children. + +config PMIC_RAA215300 + bool "Renesas RAA215300 PMIC driver" + depends on DM_PMIC + help + The Renesas RAA215300 PMIC driver includes RTC support, system reset + support and several voltage regulators. For now, this driver simply + allows register access and will bind the sysreset driver + (CONFIG_SYSRESET_RAA215300) if it is enabled. endif
config PMIC_TPS65217 diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index 55ee614364be..a2d59deeed8b 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -35,6 +35,7 @@ obj-$(CONFIG_PMIC_STPMIC1) += stpmic1.o obj-$(CONFIG_PMIC_TPS65217) += pmic_tps65217.o obj-$(CONFIG_PMIC_TPS65219) += tps65219.o obj-$(CONFIG_PMIC_TPS65941) += tps65941.o +obj-$(CONFIG_PMIC_RAA215300) += raa215300.o obj-$(CONFIG_POWER_TPS65218) += pmic_tps65218.o
ifeq ($(CONFIG_$(SPL_)POWER_LEGACY),y) diff --git a/drivers/power/pmic/raa215300.c b/drivers/power/pmic/raa215300.c new file mode 100644 index 000000000000..b93a0d3a084a --- /dev/null +++ b/drivers/power/pmic/raa215300.c @@ -0,0 +1,41 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023 Renesas Electronics Corporation + */ + +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <i2c.h> +#include <power/pmic.h> + +#define RAA215300_REG_COUNT 0x80 + +static int raa215300_reg_count(struct udevice *dev) +{ + return RAA215300_REG_COUNT; +} + +static struct dm_pmic_ops raa215300_ops = { + .reg_count = raa215300_reg_count, + .read = dm_i2c_read, + .write = dm_i2c_write, +}; + +static const struct udevice_id raa215300_ids[] = { + { .compatible = "renesas,raa215300" }, + { /* sentinel */ } +}; + +static int raa215300_bind(struct udevice *dev) +{ + return 0; +} + +U_BOOT_DRIVER(raa215300_pmic) = { + .name = "raa215300_pmic", + .id = UCLASS_PMIC, + .of_match = raa215300_ids, + .bind = raa215300_bind, + .ops = &raa215300_ops, +};
Enable the appropriate PMIC driver as well as the `pmic` command.
Signed-off-by: Paul Barker paul.barker.ct@bp.renesas.com --- configs/renesas_rzg2l_smarc_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/renesas_rzg2l_smarc_defconfig b/configs/renesas_rzg2l_smarc_defconfig index ad46297c6619..2cab79329db4 100644 --- a/configs/renesas_rzg2l_smarc_defconfig +++ b/configs/renesas_rzg2l_smarc_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y +CONFIG_CMD_PMIC=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y @@ -49,6 +50,8 @@ CONFIG_DM_I2C=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS400_SUPPORT=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RAA215300=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y
This patch adds support for resetting a board via the RAA215300 PMIC.
Note that the RAA215300 documentation names the available reset types differently to u-boot:
* A "warm" reset via the RAA215300 PMIC will fully reset the SoC (CPU & GPIOs), so this corresponds to SYSRESET_COLD.
* A "cold" reset via the RAA215300 PMIC will cycle all power supply rails, so this corresponds to SYSRESET_POWER.
Signed-off-by: Paul Barker paul.barker.ct@bp.renesas.com Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org --- drivers/sysreset/Kconfig | 6 +++ drivers/sysreset/Makefile | 1 + drivers/sysreset/sysreset_raa215300.c | 58 +++++++++++++++++++++++++++ 3 files changed, 65 insertions(+) create mode 100644 drivers/sysreset/sysreset_raa215300.c
diff --git a/drivers/sysreset/Kconfig b/drivers/sysreset/Kconfig index 0e52f996283c..49c0787b26d8 100644 --- a/drivers/sysreset/Kconfig +++ b/drivers/sysreset/Kconfig @@ -229,6 +229,12 @@ config SYSRESET_MPC83XX help Reboot support for NXP MPC83xx SoCs.
+config SYSRESET_RAA215300 + bool "Support sysreset via Renesas RAA215300 PMIC" + depends on PMIC_RAA215300 + help + Add support for the system reboot via the Renesas RAA215300 PMIC. + endif
endmenu diff --git a/drivers/sysreset/Makefile b/drivers/sysreset/Makefile index c9f1c625aebb..e0e732205df3 100644 --- a/drivers/sysreset/Makefile +++ b/drivers/sysreset/Makefile @@ -27,4 +27,5 @@ obj-$(CONFIG_SYSRESET_WATCHDOG) += sysreset_watchdog.o obj-$(CONFIG_SYSRESET_RESETCTL) += sysreset_resetctl.o obj-$(CONFIG_$(SPL_TPL_)SYSRESET_AT91) += sysreset_at91.o obj-$(CONFIG_$(SPL_TPL_)SYSRESET_X86) += sysreset_x86.o +obj-$(CONFIG_SYSRESET_RAA215300) += sysreset_raa215300.o obj-$(CONFIG_TARGET_XTFPGA) += sysreset_xtfpga.o diff --git a/drivers/sysreset/sysreset_raa215300.c b/drivers/sysreset/sysreset_raa215300.c new file mode 100644 index 000000000000..32dfcb0aec84 --- /dev/null +++ b/drivers/sysreset/sysreset_raa215300.c @@ -0,0 +1,58 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023 Renesas Electronics Corporation + */ + +#include <dm.h> +#include <power/pmic.h> +#include <sysreset.h> + +#define RAA215300_REG_SWRESET 0x6D +#define RAA215300_COLD_RESET BIT(0) +#define RAA215300_WARM_RESET BIT(1) + +static int raa215300_sysreset_request(struct udevice *dev, enum sysreset_t type) +{ + struct udevice *pmic = dev_get_parent(dev); + int ret; + u8 val; + + /* + * The RAA215300 documentation names the available reset types + * differently to u-boot: + * + * - A "warm" reset via the RAA215300 PMIC will fully reset the SoC + * (CPU & GPIOs), so this corresponds to SYSRESET_COLD. + * + * - A "cold" reset via the RAA215300 PMIC will cycle all power supply + * rails, so this corresponds to SYSRESET_POWER. + */ + switch (type) { + case SYSRESET_COLD: + val = RAA215300_WARM_RESET; + break; + + case SYSRESET_POWER: + val = RAA215300_COLD_RESET; + break; + + default: + return -EPROTONOSUPPORT; + } + + ret = pmic_reg_write(pmic, RAA215300_REG_SWRESET, val); + if (ret) + return ret; + + return -EINPROGRESS; +} + +static struct sysreset_ops raa215300_sysreset_ops = { + .request = raa215300_sysreset_request, +}; + +U_BOOT_DRIVER(raa215300_sysreset) = { + .name = "raa215300_sysreset", + .id = UCLASS_SYSRESET, + .ops = &raa215300_sysreset_ops, +};
If SYSRESET support is enabled for the RAA215300 PMIC, we need to bind the raa215300_sysreset driver as a child device of the PMIC.
Signed-off-by: Paul Barker paul.barker.ct@bp.renesas.com Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org --- drivers/power/pmic/raa215300.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/power/pmic/raa215300.c b/drivers/power/pmic/raa215300.c index b93a0d3a084a..a581a1f6dc15 100644 --- a/drivers/power/pmic/raa215300.c +++ b/drivers/power/pmic/raa215300.c @@ -29,6 +29,15 @@ static const struct udevice_id raa215300_ids[] = {
static int raa215300_bind(struct udevice *dev) { + if (IS_ENABLED(CONFIG_SYSRESET_RAA215300)) { + struct driver *drv = lists_driver_lookup_name("raa215300_sysreset"); + if (!drv) + return -ENOENT; + + return device_bind(dev, drv, dev->name, NULL, dev_ofnode(dev), + NULL); + } + return 0; }
With the SYSRESET subsystem enabled we do not need to implement reset_cpu() in the board directory.
Signed-off-by: Paul Barker paul.barker.ct@bp.renesas.com Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org --- board/renesas/rzg2l/rzg2l.c | 8 -------- configs/renesas_rzg2l_smarc_defconfig | 2 ++ 2 files changed, 2 insertions(+), 8 deletions(-)
diff --git a/board/renesas/rzg2l/rzg2l.c b/board/renesas/rzg2l/rzg2l.c index 73201a8c69e5..0f6d6e7f514f 100644 --- a/board/renesas/rzg2l/rzg2l.c +++ b/board/renesas/rzg2l/rzg2l.c @@ -56,11 +56,3 @@ int board_init(void) { return 0; } - -void reset_cpu(void) -{ - /* - * TODO: Implement reset support once TrustedFirmware supports - * the appropriate call. - */ -} diff --git a/configs/renesas_rzg2l_smarc_defconfig b/configs/renesas_rzg2l_smarc_defconfig index 2cab79329db4..21365a21fe8c 100644 --- a/configs/renesas_rzg2l_smarc_defconfig +++ b/configs/renesas_rzg2l_smarc_defconfig @@ -55,3 +55,5 @@ CONFIG_PMIC_RAA215300=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_RAA215300=y
Paul Barker
