[U-Boot] [PATCH 1/1] efi_loader: remove deprecated ConsoleControlProtocol
The console control protocol is not defined in the UEFI standard.
It exists in EDK2's EdkCompatiblityPkg package. But this package is deprecated according to https://github.com/tianocore/tianocore.github.io/wiki/Differences-between-ED...
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/efi_api.h | 18 ----------------- lib/efi_loader/efi_boottime.c | 5 ----- lib/efi_loader/efi_console.c | 46 ------------------------------------------- 3 files changed, 69 deletions(-)
diff --git a/include/efi_api.h b/include/efi_api.h index 205f8f1f70..a2706a0ae4 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -542,24 +542,6 @@ struct efi_simple_input_interface { struct efi_event *wait_for_key; };
-#define CONSOLE_CONTROL_GUID \ - EFI_GUID(0xf42f7782, 0x12e, 0x4c12, \ - 0x99, 0x56, 0x49, 0xf9, 0x43, 0x4, 0xf7, 0x21) -#define EFI_CONSOLE_MODE_TEXT 0 -#define EFI_CONSOLE_MODE_GFX 1 - -struct efi_console_control_protocol -{ - efi_status_t (EFIAPI *get_mode)( - struct efi_console_control_protocol *this, int *mode, - char *uga_exists, char *std_in_locked); - efi_status_t (EFIAPI *set_mode)( - struct efi_console_control_protocol *this, int mode); - efi_status_t (EFIAPI *lock_std_in)( - struct efi_console_control_protocol *this, - uint16_t *password); -}; - #define EFI_DEVICE_PATH_TO_TEXT_PROTOCOL_GUID \ EFI_GUID(0x8b843e20, 0x8132, 0x4852, \ 0x90, 0xcc, 0x55, 0x1a, 0x4e, 0x4a, 0x7f, 0x1c) diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index da93498b36..599f0c597d 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -1388,11 +1388,6 @@ efi_status_t efi_setup_loaded_image( if (ret != EFI_SUCCESS) goto failure;
- ret = efi_add_protocol(obj->handle, &efi_guid_console_control, - (void *)&efi_console_control); - if (ret != EFI_SUCCESS) - goto failure; - ret = efi_add_protocol(obj->handle, &efi_guid_device_path_to_text_protocol, (void *)&efi_device_path_to_text); diff --git a/lib/efi_loader/efi_console.c b/lib/efi_loader/efi_console.c index 28d63635ec..3cb580e3ed 100644 --- a/lib/efi_loader/efi_console.c +++ b/lib/efi_loader/efi_console.c @@ -45,7 +45,6 @@ static struct cout_mode efi_cout_modes[] = { }, };
-const efi_guid_t efi_guid_console_control = CONSOLE_CONTROL_GUID; const efi_guid_t efi_guid_text_output_protocol = EFI_SIMPLE_TEXT_OUTPUT_PROTOCOL_GUID; const efi_guid_t efi_guid_text_input_protocol = @@ -54,43 +53,6 @@ const efi_guid_t efi_guid_text_input_protocol = #define cESC '\x1b' #define ESC "\x1b"
-static efi_status_t EFIAPI efi_cin_get_mode( - struct efi_console_control_protocol *this, - int *mode, char *uga_exists, char *std_in_locked) -{ - EFI_ENTRY("%p, %p, %p, %p", this, mode, uga_exists, std_in_locked); - - if (mode) - *mode = EFI_CONSOLE_MODE_TEXT; - if (uga_exists) - *uga_exists = 0; - if (std_in_locked) - *std_in_locked = 0; - - return EFI_EXIT(EFI_SUCCESS); -} - -static efi_status_t EFIAPI efi_cin_set_mode( - struct efi_console_control_protocol *this, int mode) -{ - EFI_ENTRY("%p, %d", this, mode); - return EFI_EXIT(EFI_UNSUPPORTED); -} - -static efi_status_t EFIAPI efi_cin_lock_std_in( - struct efi_console_control_protocol *this, - uint16_t *password) -{ - EFI_ENTRY("%p, %p", this, password); - return EFI_EXIT(EFI_UNSUPPORTED); -} - -struct efi_console_control_protocol efi_console_control = { - .get_mode = efi_cin_get_mode, - .set_mode = efi_cin_set_mode, - .lock_std_in = efi_cin_lock_std_in, -}; - /* Default to mode 0 */ static struct simple_text_output_mode efi_con_mode = { .max_mode = 1, @@ -506,18 +468,10 @@ static void EFIAPI efi_console_timer_notify(struct efi_event *event, int efi_console_register(void) { efi_status_t r; - struct efi_object *efi_console_control_obj; struct efi_object *efi_console_output_obj; struct efi_object *efi_console_input_obj;
/* Create handles */ - r = efi_create_handle((efi_handle_t *)&efi_console_control_obj); - if (r != EFI_SUCCESS) - goto out_of_memory; - r = efi_add_protocol(efi_console_control_obj->handle, - &efi_guid_console_control, &efi_console_control); - if (r != EFI_SUCCESS) - goto out_of_memory; r = efi_create_handle((efi_handle_t *)&efi_console_output_obj); if (r != EFI_SUCCESS) goto out_of_memory;
Grub uses it, but I can confirm that the code path it's using it in is perfectly happy with it not being available. So I think it's safe to remove.
Alex
Alex
Even the very first UEFI spec (2.0, 2006) did not contain the ConsoleControlProtocol.
Grub is trying to switch the console to text mode (see function grub_efi_set_text_mode()). With UEFI text output is always available. This is why the protocol was obsoleted by UEFI. The current grub coding that allows to live without the console control protocol was introduced in 2006 in response to the first UEFI spec.
Regards
Heinrich
Alexander Graf
