Support for Banana Pi BPI-P2 Zero
Hi Developers,
I am struggling with the u-boot for the Banana Pi BPI-P2 Zero. I used this defconfig but it has problems with at least the mmc card:
CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-bananapi-m2-plus-v1.2" CONFIG_SPL=y CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=408 CONFIG_MMC0_CD_PIN="" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_PREBOOT="" # CONFIG_SYS_DEVICE_NULLDEV is not set CONFIG_SPL_STACK=0x8000 CONFIG_SYS_PBSIZE=1024 CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y
This is the output from serial: U-Boot SPL 2022.10 (Oct 28 2022 - 20:34:40 +0200) DRAM: 512 MiB Trying to boot from MMC1
U-Boot 2022.10 (Oct 28 2022 - 20:34:40 +0200) Allwinner Technology
CPU: Allwinner H3 (SUN8I 1680) Model: Banana Pi BPI-M2-Plus v1.2 H3 DRAM: 512 MiB Core: 68 devices, 19 uclasses, devicetree: separate WDT: Not starting watchdog@1c20ca0 MMC: mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1 Loading Environment from FAT... MMC: no card present ** Bad device specification mmc 0 ** In: serial Out: serial Err: serial Net: Could not get PHY for ethernet@1c30000: addr 1 No ethernet found.
Hit any key to stop autoboot: 0 MMC: no card present Card did not respond to voltage select! : -110 starting USB... ...
Thank you for your help!
Regards
Martin
I found a solution. I had to use CONFIG_DEFAULT_DEVICE_TREE="sun8i-h2-plus-bananapi-m2-zero"
This defconfig works!
Best regards
Martin
Am 28.10.22 um 20:38 schrieb Martin Thomas:
Hi Developers,
Regards
Martin
Martin Thomas
