[PATCH V2] imx: drop CONFIG_MXC_UART_BASE
Since these boards has CONFIG_DM_SERIAL and/or CONFIG_SPL_DM_SERIAL, the legacy macro no need to be defined.
Reviewed-by: Heiko Schocher hs@denx.de Reviewed-by: Fabio Estevam festevam@denx.de Signed-off-by: Peng Fan peng.fan@nxp.com ---
V2: Add R-b Drop comments add imx8mn_bsh_smm_s2_common.h
include/configs/aristainetos2.h | 2 -- include/configs/imx8mm_evk.h | 1 - include/configs/imx8mn_bsh_smm_s2_common.h | 2 -- include/configs/imx8mn_evk.h | 1 - include/configs/imx8mp_evk.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/somlabs_visionsom_6ull.h | 1 - include/configs/tbs2910.h | 3 --- include/configs/verdin-imx8mm.h | 3 --- include/configs/verdin-imx8mp.h | 3 --- 10 files changed, 18 deletions(-)
diff --git a/include/configs/aristainetos2.h b/include/configs/aristainetos2.h index 8ee97f1d4e3..27adae5d6bf 100644 --- a/include/configs/aristainetos2.h +++ b/include/configs/aristainetos2.h @@ -14,10 +14,8 @@ #define CONFIG_HOSTNAME "aristainetos2"
#if (CONFIG_SYS_BOARD_VERSION == 5) -#define CONFIG_MXC_UART_BASE UART2_BASE #define CONSOLE_DEV "ttymxc1" #elif (CONFIG_SYS_BOARD_VERSION == 6) -#define CONFIG_MXC_UART_BASE UART1_BASE #define CONSOLE_DEV "ttymxc0" #endif
diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index 42b78485cfc..7dd66527c3d 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -68,7 +68,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
-#define CONFIG_MXC_UART_BASE UART2_BASE_ADDR
/* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 2048 diff --git a/include/configs/imx8mn_bsh_smm_s2_common.h b/include/configs/imx8mn_bsh_smm_s2_common.h index 6387576c2da..57be38d9433 100644 --- a/include/configs/imx8mn_bsh_smm_s2_common.h +++ b/include/configs/imx8mn_bsh_smm_s2_common.h @@ -45,8 +45,6 @@ #define CONFIG_SYS_SDRAM_BASE 0x40000000 #define PHYS_SDRAM 0x40000000
-#define CONFIG_MXC_UART_BASE UART4_BASE_ADDR - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE SZ_2K #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index 034132225c6..b20e0a5553d 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -75,7 +75,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
/* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 2048 diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index cc8d65cb54e..cbdd490a300 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -80,7 +80,6 @@ #define PHYS_SDRAM_2 0x100000000 #define PHYS_SDRAM_2_SIZE 0xC0000000 /* 3 GB */
/* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 2048 diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index aaad232f0e4..62e62c6701f 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -12,7 +12,6 @@
#define PHYS_SDRAM_SIZE SZ_1G
-#define CONFIG_MXC_UART_BASE UART1_IPS_BASE_ADDR
#ifdef CONFIG_IMX_BOOTAUX /* Set to QSPI1 A flash at default */ diff --git a/include/configs/somlabs_visionsom_6ull.h b/include/configs/somlabs_visionsom_6ull.h index d4761296c75..e6aad386efe 100644 --- a/include/configs/somlabs_visionsom_6ull.h +++ b/include/configs/somlabs_visionsom_6ull.h @@ -16,7 +16,6 @@ /* SPL options */ #include "imx6_spl.h"
/* MMC Configs */ #ifdef CONFIG_FSL_USDHC diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index b7a94812f35..5d8cb34ad9a 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -24,9 +24,6 @@
#define CONFIG_SYS_BOOTMAPSZ 0x10000000
-/* Serial console */ -#define CONFIG_MXC_UART_BASE UART1_BASE /* select UART1/UART2 */ - /* Framebuffer */ #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index da3dc95f9ee..e0f0347fcf4 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -83,9 +83,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE SZ_2G /* 2GB DDR */
-/* UART */ -#define CONFIG_MXC_UART_BASE UART1_BASE_ADDR - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE SZ_2K #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/verdin-imx8mp.h b/include/configs/verdin-imx8mp.h index 7b7407752c1..370bcb4e46f 100644 --- a/include/configs/verdin-imx8mp.h +++ b/include/configs/verdin-imx8mp.h @@ -100,9 +100,6 @@ #define PHYS_SDRAM_2 0x100000000 #define PHYS_SDRAM_2_SIZE (SZ_4G + SZ_1G)
-/* UART */ -#define CONFIG_MXC_UART_BASE UART3_BASE_ADDR - /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE SZ_2K #define CONFIG_SYS_MAXARGS 64
For tbs2910: Acked-by: Soeren Moch smoch@web.de
Thanks, Soeren
Peng Fan (OSS)
Soeren Moch
