[U-Boot] [PATCH] ppc4xx/NAND: Add select_chip function to 4xx NDFC driver
This function is needed for the new NAND infrastructure. We only need a dummy implementation though for the NDFC.
Signed-off-by: Stefan Roese sr@denx.de --- cpu/ppc4xx/ndfc.c | 8 ++++++++ 1 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/cpu/ppc4xx/ndfc.c b/cpu/ppc4xx/ndfc.c index a8e8aba..7d96e79 100644 --- a/cpu/ppc4xx/ndfc.c +++ b/cpu/ppc4xx/ndfc.c @@ -168,6 +168,13 @@ void board_nand_select_device(struct nand_chip *nand, int chip) out_be32((u32 *)(base + NDFC_BCFG0 + (cs << 2)), CFG_NAND_BCR); }
+static void ndfc_select_chip(struct mtd_info *mtd, int chip) +{ + /* + * Nothing to do here! + */ +} + int board_nand_init(struct nand_chip *nand) { int cs = (ulong)nand->IO_ADDR_W & 0x00000003; @@ -196,6 +203,7 @@ int board_nand_init(struct nand_chip *nand) nand->ecc.mode = NAND_ECC_HW; nand->ecc.size = 256; nand->ecc.bytes = 3; + nand->select_chip = ndfc_select_chip;
#ifndef CONFIG_NAND_SPL nand->write_buf = ndfc_write_buf;
Stefan Roese
