[U-Boot] [PATCH] altera_spi: add spi_set_speed
Added this for mmc_spi driver. Though altera spi core does not support programmable speed. It is fixed when configured in sopc-builder.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- drivers/spi/altera_spi.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/drivers/spi/altera_spi.c b/drivers/spi/altera_spi.c index 918b223..138d6f4 100644 --- a/drivers/spi/altera_spi.c +++ b/drivers/spi/altera_spi.c @@ -70,6 +70,11 @@ void spi_init(void) { }
+void spi_set_speed(struct spi_slave *slave, uint hz) +{ + /* altera spi core does not support programmable speed */ +} + struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int mode) {
Added to: git://git.denx.de/u-boot-nios.git 'next'
Thank you, --Scott
- /* altera spi core does not support programmable speed */
Scott McNutt
Thomas Chou
