[U-Boot] [PATCH] Handle most LDSCRIPT setting centrally
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc.
Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds.
Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding.
If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used.
If neither of these are specified, then the central config.mk will check for the existence of the following, in order:
$(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds
Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed.
Signed-off-by: Scott Wood scottwood@freescale.com --- "./MAKEALL ppc" had identical output with and without this patch.
I tried building some arm boards, but couldn't find any that built for me even without this patch. They didn't appear to fail differently with it, though.
arch/arm/config.mk | 1 - arch/i386/config.mk | 1 - arch/nios2/config.mk | 2 - arch/powerpc/config.mk | 11 --- arch/sh/config.mk | 6 -- board/actux1/config.mk | 2 - board/actux2/config.mk | 2 - board/actux3/config.mk | 2 - board/altera/nios2-generic/config.mk | 2 - board/amcc/acadia/config.mk | 7 -- board/amcc/bamboo/config.mk | 7 -- board/amcc/canyonlands/config.mk | 7 -- board/amcc/kilauea/config.mk | 7 -- board/amcc/sequoia/config.mk | 7 -- board/atmel/atstk1000/config.mk | 1 - board/avnet/fx12mm/config.mk | 29 ------ board/avnet/v5fx30teval/config.mk | 29 ------ board/cm5200/u-boot.lds | 120 -------------------------- board/cogent/config.mk | 2 - board/earthlcd/favr-32-ezkit/config.mk | 1 - board/freescale/mx31ads/config.mk | 2 - board/hymod/config.mk | 2 - board/munices/u-boot.lds | 120 -------------------------- board/samsung/smdk6400/config.mk | 2 - board/sc3/u-boot.lds | 147 -------------------------------- board/trab/config.mk | 2 - board/xilinx/ml507/config.mk | 4 - board/xilinx/ppc405-generic/config.mk | 4 - board/xilinx/ppc440-generic/config.mk | 4 - config.mk | 33 ++++++- 30 files changed, 28 insertions(+), 538 deletions(-) delete mode 100644 board/avnet/fx12mm/config.mk delete mode 100644 board/avnet/v5fx30teval/config.mk delete mode 100644 board/cm5200/u-boot.lds delete mode 100644 board/munices/u-boot.lds delete mode 100644 board/sc3/u-boot.lds delete mode 100644 board/xilinx/ml507/config.mk delete mode 100644 board/xilinx/ppc405-generic/config.mk delete mode 100644 board/xilinx/ppc440-generic/config.mk
diff --git a/arch/arm/config.mk b/arch/arm/config.mk index a6a4742..709eba9 100644 --- a/arch/arm/config.mk +++ b/arch/arm/config.mk @@ -63,7 +63,6 @@ ifeq (,$(findstring arch/arm/lib/eabi_compat.o,$(PLATFORM_LIBS))) PLATFORM_LIBS += $(OBJTREE)/arch/arm/lib/eabi_compat.o endif endif -LDSCRIPT := $(SRCTREE)/$(CPUDIR)/u-boot.lds
# needed for relocation ifndef CONFIG_NAND_SPL diff --git a/arch/i386/config.mk b/arch/i386/config.mk index 47e0fb4..d6e43d1 100644 --- a/arch/i386/config.mk +++ b/arch/i386/config.mk @@ -39,4 +39,3 @@ PLATFORM_RELFLAGS += -ffunction-sections -fvisibility=hidden PLATFORM_LDFLAGS += --emit-relocs -Bsymbolic -Bsymbolic-functions
LDFLAGS_FINAL += --gc-sections -pie -LDSCRIPT := $(SRCTREE)/$(CPUDIR)/u-boot.lds diff --git a/arch/nios2/config.mk b/arch/nios2/config.mk index d241a96..e58ea24 100644 --- a/arch/nios2/config.mk +++ b/arch/nios2/config.mk @@ -29,7 +29,5 @@ STANDALONE_LOAD_ADDR ?= 0x02000000 PLATFORM_CPPFLAGS += -DCONFIG_NIOS2 -D__NIOS2__ PLATFORM_CPPFLAGS += -G0
-LDSCRIPT ?= $(SRCTREE)/$(CPUDIR)/u-boot.lds - LDFLAGS_FINAL += --gc-sections PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections diff --git a/arch/powerpc/config.mk b/arch/powerpc/config.mk index 31e4416..bb613a7 100644 --- a/arch/powerpc/config.mk +++ b/arch/powerpc/config.mk @@ -29,17 +29,6 @@ PLATFORM_RELFLAGS += -mrelocatable -ffunction-sections -fdata-sections PLATFORM_CPPFLAGS += -DCONFIG_PPC -D__powerpc__ PLATFORM_LDFLAGS += -n
-ifdef CONFIG_SYS_LDSCRIPT -# need to strip off double quotes -LDSCRIPT := $(subst ",,$(CONFIG_SYS_LDSCRIPT)) -else ifdef CONFIG_NAND_SPL -LDSCRIPT := $(SRCTREE)/$(CONFIG_BOARDDIR)/u-boot-nand.lds -else -ifneq ($(wildcard $(SRCTREE)/arch/powerpc/cpu/$(CPU)/u-boot.lds),) -LDSCRIPT := $(SRCTREE)/arch/powerpc/cpu/$(CPU)/u-boot.lds -endif -endif - # # When cross-compiling on NetBSD, we have to define __PPC__ or else we # will pick up a va_list declaration that is incompatible with the diff --git a/arch/sh/config.mk b/arch/sh/config.mk index cd851f5..b5be5f2 100644 --- a/arch/sh/config.mk +++ b/arch/sh/config.mk @@ -31,9 +31,3 @@ endif PLATFORM_CPPFLAGS += -DCONFIG_SH -D__SH__ PLATFORM_LDFLAGS += -e $(CONFIG_SYS_TEXT_BASE) --defsym reloc_dst=$(CONFIG_SYS_TEXT_BASE) LDFLAGS_FINAL = --gc-sections - -ifdef CONFIG_SYS_LDSCRIPT -LDSCRIPT := $(subst ",,$(CONFIG_SYS_LDSCRIPT)) -else -LDSCRIPT := $(SRCTREE)/$(CPUDIR)/u-boot.lds -endif diff --git a/board/actux1/config.mk b/board/actux1/config.mk index 88634f7..9cb838b 100644 --- a/board/actux1/config.mk +++ b/board/actux1/config.mk @@ -2,5 +2,3 @@ CONFIG_SYS_TEXT_BASE = 0x00e00000
# include NPE ethernet driver BOARDLIBS = arch/arm/cpu/ixp/npe/libnpe.o - -LDSCRIPT := $(SRCTREE)/board/$(BOARDDIR)/u-boot.lds diff --git a/board/actux2/config.mk b/board/actux2/config.mk index 88634f7..9cb838b 100644 --- a/board/actux2/config.mk +++ b/board/actux2/config.mk @@ -2,5 +2,3 @@ CONFIG_SYS_TEXT_BASE = 0x00e00000
# include NPE ethernet driver BOARDLIBS = arch/arm/cpu/ixp/npe/libnpe.o - -LDSCRIPT := $(SRCTREE)/board/$(BOARDDIR)/u-boot.lds diff --git a/board/actux3/config.mk b/board/actux3/config.mk index 88634f7..9cb838b 100644 --- a/board/actux3/config.mk +++ b/board/actux3/config.mk @@ -2,5 +2,3 @@ CONFIG_SYS_TEXT_BASE = 0x00e00000
# include NPE ethernet driver BOARDLIBS = arch/arm/cpu/ixp/npe/libnpe.o - -LDSCRIPT := $(SRCTREE)/board/$(BOARDDIR)/u-boot.lds diff --git a/board/altera/nios2-generic/config.mk b/board/altera/nios2-generic/config.mk index 95e75af..00c16fc 100644 --- a/board/altera/nios2-generic/config.mk +++ b/board/altera/nios2-generic/config.mk @@ -30,5 +30,3 @@ PLATFORM_CPPFLAGS += -I$(TOPDIR)/board/$(VENDOR)/include ifeq ($(debug),1) PLATFORM_CPPFLAGS += -DDEBUG endif - -LDSCRIPT := $(SRCTREE)/board/$(VENDOR)/$(BOARD)/u-boot.lds diff --git a/board/amcc/acadia/config.mk b/board/amcc/acadia/config.mk index 2f2787f..bfc0945 100644 --- a/board/amcc/acadia/config.mk +++ b/board/amcc/acadia/config.mk @@ -28,10 +28,3 @@ ifeq ($(debug),1) PLATFORM_CPPFLAGS += -DDEBUG endif - -ifdef CONFIG_SYS_LDSCRIPT -# need to strip off double quotes -LDSCRIPT := $(subst ",,$(CONFIG_SYS_LDSCRIPT)) -else ifdef CONFIG_NAND_U_BOOT -LDSCRIPT := $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds -endif diff --git a/board/amcc/bamboo/config.mk b/board/amcc/bamboo/config.mk index 7ca16a0..24f74e1 100644 --- a/board/amcc/bamboo/config.mk +++ b/board/amcc/bamboo/config.mk @@ -30,10 +30,3 @@ endif ifeq ($(dbcr),1) PLATFORM_CPPFLAGS += -DCONFIG_SYS_INIT_DBCR=0x8cff0000 endif - -ifdef CONFIG_SYS_LDSCRIPT -# need to strip off double quotes -LDSCRIPT := $(subst ",,$(CONFIG_SYS_LDSCRIPT)) -else ifdef CONFIG_NAND_U_BOOT -LDSCRIPT := $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds -endif diff --git a/board/amcc/canyonlands/config.mk b/board/amcc/canyonlands/config.mk index abf2a26..d693a26 100644 --- a/board/amcc/canyonlands/config.mk +++ b/board/amcc/canyonlands/config.mk @@ -33,10 +33,3 @@ endif ifeq ($(dbcr),1) PLATFORM_CPPFLAGS += -DCONFIG_SYS_INIT_DBCR=0x8cff0000 endif - -ifdef CONFIG_SYS_LDSCRIPT -# need to strip off double quotes -LDSCRIPT := $(subst ",,$(CONFIG_SYS_LDSCRIPT)) -else ifdef CONFIG_NAND_U_BOOT -LDSCRIPT := $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds -endif diff --git a/board/amcc/kilauea/config.mk b/board/amcc/kilauea/config.mk index 4ae3ea9..003b8c3 100644 --- a/board/amcc/kilauea/config.mk +++ b/board/amcc/kilauea/config.mk @@ -24,10 +24,3 @@ ifeq ($(debug),1) PLATFORM_CPPFLAGS += -DDEBUG endif - -ifdef CONFIG_SYS_LDSCRIPT -# need to strip off double quotes -LDSCRIPT := $(subst ",,$(CONFIG_SYS_LDSCRIPT)) -else ifdef CONFIG_NAND_U_BOOT -LDSCRIPT := $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds -endif diff --git a/board/amcc/sequoia/config.mk b/board/amcc/sequoia/config.mk index 73efe72..e0bf071 100644 --- a/board/amcc/sequoia/config.mk +++ b/board/amcc/sequoia/config.mk @@ -33,10 +33,3 @@ endif ifeq ($(dbcr),1) PLATFORM_CPPFLAGS += -DCONFIG_SYS_INIT_DBCR=0x8cff0000 endif - -ifdef CONFIG_SYS_LDSCRIPT -# need to strip off double quotes -LDSCRIPT := $(subst ",,$(CONFIG_SYS_LDSCRIPT)) -else ifdef CONFIG_NAND_U_BOOT -LDSCRIPT := $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds -endif diff --git a/board/atmel/atstk1000/config.mk b/board/atmel/atstk1000/config.mk index 8c03b77..284f7ff 100644 --- a/board/atmel/atstk1000/config.mk +++ b/board/atmel/atstk1000/config.mk @@ -1,4 +1,3 @@ PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections PLATFORM_LDFLAGS += --gc-sections CONFIG_SYS_TEXT_BASE = 0x00000000 -LDSCRIPT = $(src)board/atmel/atstk1000/u-boot.lds diff --git a/board/avnet/fx12mm/config.mk b/board/avnet/fx12mm/config.mk deleted file mode 100644 index 78dde62..0000000 --- a/board/avnet/fx12mm/config.mk +++ /dev/null @@ -1,29 +0,0 @@ -# -# (C) Copyright 2008 -# Ricardo Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es -# Work supported by Qtechnology http://www.qtec.com -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -# - -ifdef CONFIG_SYS_LDSCRIPT -# need to strip off double quotes -LDSCRIPT := $(subst ",,$(CONFIG_SYS_LDSCRIPT)) -endif diff --git a/board/avnet/v5fx30teval/config.mk b/board/avnet/v5fx30teval/config.mk deleted file mode 100644 index 78dde62..0000000 --- a/board/avnet/v5fx30teval/config.mk +++ /dev/null @@ -1,29 +0,0 @@ -# -# (C) Copyright 2008 -# Ricardo Ribalda-Universidad Autonoma de Madrid-ricardo.ribalda@uam.es -# Work supported by Qtechnology http://www.qtec.com -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -# - -ifdef CONFIG_SYS_LDSCRIPT -# need to strip off double quotes -LDSCRIPT := $(subst ",,$(CONFIG_SYS_LDSCRIPT)) -endif diff --git a/board/cm5200/u-boot.lds b/board/cm5200/u-boot.lds deleted file mode 100644 index cf73b11..0000000 --- a/board/cm5200/u-boot.lds +++ /dev/null @@ -1,120 +0,0 @@ -/* - * (C) Copyright 2003-2007 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_ARCH(powerpc) -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .interp : { *(.interp) } - .hash : { *(.hash) } - .dynsym : { *(.dynsym) } - .dynstr : { *(.dynstr) } - .rel.text : { *(.rel.text) } - .rela.text : { *(.rela.text) } - .rel.data : { *(.rel.data) } - .rela.data : { *(.rela.data) } - .rel.rodata : { *(.rel.rodata) } - .rela.rodata : { *(.rela.rodata) } - .rel.got : { *(.rel.got) } - .rela.got : { *(.rela.got) } - .rel.ctors : { *(.rel.ctors) } - .rela.ctors : { *(.rela.ctors) } - .rel.dtors : { *(.rel.dtors) } - .rela.dtors : { *(.rela.dtors) } - .rel.bss : { *(.rel.bss) } - .rela.bss : { *(.rela.bss) } - .rel.plt : { *(.rel.plt) } - .rela.plt : { *(.rela.plt) } - .init : { *(.init) } - .plt : { *(.plt) } - .text : - { - arch/powerpc/cpu/mpc5xxx/start.o (.text) - *(.text) - *(.got1) - . = ALIGN(16); - *(.eh_frame) - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - } - .fini : { *(.fini) } =0 - .ctors : { *(.ctors) } - .dtors : { *(.dtors) } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FFF) & 0xFFFFF000; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - *(.got) - _GOT2_TABLE_ = .; - *(.got2) - _FIXUP_TABLE_ = .; - *(.fixup) - } - __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >> 2; - __fixup_entries = (. - _FIXUP_TABLE_) >> 2; - - .data : - { - *(.data) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } - _edata = .; - PROVIDE (edata = .); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - - . = .; - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(4096); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(4096); - __init_end = .; - - __bss_start = .; - .bss (NOLOAD) : - { - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss) - *(COMMON) - . = ALIGN(4); - } - __bss_end__ = . ; - PROVIDE (end = .); -} diff --git a/board/cogent/config.mk b/board/cogent/config.mk index 78730db..12e2e7c 100644 --- a/board/cogent/config.mk +++ b/board/cogent/config.mk @@ -26,5 +26,3 @@ #
PLATFORM_CPPFLAGS += -I$(TOPDIR) - -LDSCRIPT := $(SRCTREE)/board/cogent/u-boot.lds diff --git a/board/earthlcd/favr-32-ezkit/config.mk b/board/earthlcd/favr-32-ezkit/config.mk index f8bc88d..284f7ff 100644 --- a/board/earthlcd/favr-32-ezkit/config.mk +++ b/board/earthlcd/favr-32-ezkit/config.mk @@ -1,4 +1,3 @@ PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections PLATFORM_LDFLAGS += --gc-sections CONFIG_SYS_TEXT_BASE = 0x00000000 -LDSCRIPT = $(src)board/earthlcd/favr-32-ezkit/u-boot.lds diff --git a/board/freescale/mx31ads/config.mk b/board/freescale/mx31ads/config.mk index 2303f30..0131edf 100644 --- a/board/freescale/mx31ads/config.mk +++ b/board/freescale/mx31ads/config.mk @@ -1,3 +1 @@ CONFIG_SYS_TEXT_BASE = 0x87f00000 - -LDSCRIPT := $(SRCTREE)/board/$(BOARDDIR)/u-boot.lds diff --git a/board/hymod/config.mk b/board/hymod/config.mk index ae766bc..ea64004 100644 --- a/board/hymod/config.mk +++ b/board/hymod/config.mk @@ -28,5 +28,3 @@ PLATFORM_CPPFLAGS += -I$(TOPDIR)
OBJCFLAGS = --remove-section=.ppcenv - -LDSCRIPT := $(SRCTREE)/board/hymod/u-boot.lds diff --git a/board/munices/u-boot.lds b/board/munices/u-boot.lds deleted file mode 100644 index 99576bf..0000000 --- a/board/munices/u-boot.lds +++ /dev/null @@ -1,120 +0,0 @@ -/* - * (C) Copyright 2007 - * Heiko Schocher, DENX Software Engineering, hs@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_ARCH(powerpc) -/* Do we need any of these for elf? - __DYNAMIC = 0; */ -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .interp : { *(.interp) } - .hash : { *(.hash) } - .dynsym : { *(.dynsym) } - .dynstr : { *(.dynstr) } - .rel.text : { *(.rel.text) } - .rela.text : { *(.rela.text) } - .rel.data : { *(.rel.data) } - .rela.data : { *(.rela.data) } - .rel.rodata : { *(.rel.rodata) } - .rela.rodata : { *(.rela.rodata) } - .rel.got : { *(.rel.got) } - .rela.got : { *(.rela.got) } - .rel.ctors : { *(.rel.ctors) } - .rela.ctors : { *(.rela.ctors) } - .rel.dtors : { *(.rel.dtors) } - .rela.dtors : { *(.rela.dtors) } - .rel.bss : { *(.rel.bss) } - .rela.bss : { *(.rela.bss) } - .rel.plt : { *(.rel.plt) } - .rela.plt : { *(.rela.plt) } - .init : { *(.init) } - .plt : { *(.plt) } - .text : - { - arch/powerpc/cpu/mpc5xxx/start.o (.text) - *(.text) - *(.got1) - . = ALIGN(16); - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - } - .fini : { *(.fini) } =0 - .ctors : { *(.ctors) } - .dtors : { *(.dtors) } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FFF) & 0xFFFFF000; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - *(.got) - _GOT2_TABLE_ = .; - *(.got2) - _FIXUP_TABLE_ = .; - *(.fixup) - } - __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >> 2; - __fixup_entries = (. - _FIXUP_TABLE_) >> 2; - - .data : - { - *(.data) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } - _edata = .; - PROVIDE (edata = .); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(4096); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(4096); - __init_end = .; - - __bss_start = .; - .bss (NOLOAD) : - { - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss) - *(COMMON) - . = ALIGN(4); - } - __bss_end__ = . ; - PROVIDE (end = .); -} diff --git a/board/samsung/smdk6400/config.mk b/board/samsung/smdk6400/config.mk index 90cbcf2..6f04c2f 100644 --- a/board/samsung/smdk6400/config.mk +++ b/board/samsung/smdk6400/config.mk @@ -28,5 +28,3 @@ CONFIG_SYS_TEXT_BASE = $(RAM_TEXT) else CONFIG_SYS_TEXT_BASE = 0 endif - -LDSCRIPT := $(SRCTREE)/board/$(BOARDDIR)/u-boot-nand.lds diff --git a/board/sc3/u-boot.lds b/board/sc3/u-boot.lds deleted file mode 100644 index 2cbbca5..0000000 --- a/board/sc3/u-boot.lds +++ /dev/null @@ -1,147 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -OUTPUT_ARCH(powerpc) -/* Do we need any of these for elf? - __DYNAMIC = 0; */ -SECTIONS -{ - .resetvec 0xFFFFFFFC : - { - *(.resetvec) - } = 0xffff - - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .interp : { *(.interp) } - .hash : { *(.hash) } - .dynsym : { *(.dynsym) } - .dynstr : { *(.dynstr) } - .rel.text : { *(.rel.text) } - .rela.text : { *(.rela.text) } - .rel.data : { *(.rel.data) } - .rela.data : { *(.rela.data) } - .rel.rodata : { *(.rel.rodata) } - .rela.rodata : { *(.rela.rodata) } - .rel.got : { *(.rel.got) } - .rela.got : { *(.rela.got) } - .rel.ctors : { *(.rel.ctors) } - .rela.ctors : { *(.rela.ctors) } - .rel.dtors : { *(.rel.dtors) } - .rela.dtors : { *(.rela.dtors) } - .rel.bss : { *(.rel.bss) } - .rela.bss : { *(.rela.bss) } - .rel.plt : { *(.rel.plt) } - .rela.plt : { *(.rela.plt) } - .init : { *(.init) } - .plt : { *(.plt) } - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - arch/powerpc/cpu/ppc4xx/start.o (.text) - board/sc3/init.o (.text) - arch/powerpc/cpu/ppc4xx/kgdb.o (.text) - arch/powerpc/cpu/ppc4xx/traps.o (.text) - arch/powerpc/cpu/ppc4xx/interrupts.o (.text) - arch/powerpc/cpu/ppc4xx/4xx_uart.o (.text) - arch/powerpc/cpu/ppc4xx/cpu_init.o (.text) - arch/powerpc/cpu/ppc4xx/speed.o (.text) - common/dlmalloc.o (.text) - lib/crc32.o (.text) - arch/powerpc/lib/extable.o (.text) - lib/zlib.o (.text) - -/* . = env_offset;*/ -/* common/env_embedded.o(.text)*/ - - *(.text) - *(.got1) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(.eh_frame) - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - } - .fini : { *(.fini) } =0 - .ctors : { *(.ctors) } - .dtors : { *(.dtors) } - - /* Read-write section, merged into data segment: */ - . = (. + 0x00FF) & 0xFFFFFF00; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - *(.got) - _GOT2_TABLE_ = .; - *(.got2) - _FIXUP_TABLE_ = .; - *(.fixup) - } - __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } - _edata = .; - PROVIDE (edata = .); - - . = .; - __u_boot_cmd_start = .; - .u_boot_cmd : { *(.u_boot_cmd) } - __u_boot_cmd_end = .; - - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(256); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(256); - __init_end = .; - - __bss_start = .; - .bss (NOLOAD) : - { - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss) - *(COMMON) - . = ALIGN(4); - } - __bss_end__ = . ; - PROVIDE (end = .); -} diff --git a/board/trab/config.mk b/board/trab/config.mk index a349b8c..367f0b7 100644 --- a/board/trab/config.mk +++ b/board/trab/config.mk @@ -24,5 +24,3 @@ sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp ifndef CONFIG_SYS_TEXT_BASE CONFIG_SYS_TEXT_BASE = 0x0DF40000 endif - -LDSCRIPT := $(SRCTREE)/board/$(BOARDDIR)/u-boot.lds diff --git a/board/xilinx/ml507/config.mk b/board/xilinx/ml507/config.mk deleted file mode 100644 index 4df1d9c..0000000 --- a/board/xilinx/ml507/config.mk +++ /dev/null @@ -1,4 +0,0 @@ -# need to strip off double quotes -ifneq ($(CONFIG_SYS_LDSCRIPT),) -LDSCRIPT := $(subst ",,$(CONFIG_SYS_LDSCRIPT)) -endif diff --git a/board/xilinx/ppc405-generic/config.mk b/board/xilinx/ppc405-generic/config.mk deleted file mode 100644 index 4df1d9c..0000000 --- a/board/xilinx/ppc405-generic/config.mk +++ /dev/null @@ -1,4 +0,0 @@ -# need to strip off double quotes -ifneq ($(CONFIG_SYS_LDSCRIPT),) -LDSCRIPT := $(subst ",,$(CONFIG_SYS_LDSCRIPT)) -endif diff --git a/board/xilinx/ppc440-generic/config.mk b/board/xilinx/ppc440-generic/config.mk deleted file mode 100644 index 4df1d9c..0000000 --- a/board/xilinx/ppc440-generic/config.mk +++ /dev/null @@ -1,4 +0,0 @@ -# need to strip off double quotes -ifneq ($(CONFIG_SYS_LDSCRIPT),) -LDSCRIPT := $(subst ",,$(CONFIG_SYS_LDSCRIPT)) -endif diff --git a/config.mk b/config.mk index fa46ff1..7ce554e 100644 --- a/config.mk +++ b/config.mk @@ -153,14 +153,37 @@ endif RELFLAGS= $(PLATFORM_RELFLAGS) DBGFLAGS= -g # -DDEBUG OPTFLAGS= -Os #-fomit-frame-pointer + +# If board code explicitly specified LDSCRIPT or CONFIG_SYS_LDSCRIPT, use +# that (or fail if absent). Otherwise, search for a linker script in a +# standard location. + ifndef LDSCRIPT -#LDSCRIPT := $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds.debug -ifeq ($(CONFIG_NAND_U_BOOT),y) -LDSCRIPT := $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds -else -LDSCRIPT := $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds + #LDSCRIPT := $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds.debug + ifdef CONFIG_SYS_LDSCRIPT + # need to strip off double quotes + LDSCRIPT := $(subst ",,$(CONFIG_SYS_LDSCRIPT)) + endif endif + +ifndef LDSCRIPT + ifeq ($(CONFIG_NAND_U_BOOT),y) + LDSCRIPT := $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds + ifeq ($(wildcard $(LDSCRIPT)),) + LDSCRIPT := $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds + endif + endif + ifeq ($(wildcard $(LDSCRIPT)),) + LDSCRIPT := $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds + endif + ifeq ($(wildcard $(LDSCRIPT)),) + LDSCRIPT := $(TOPDIR)/$(CPUDIR)/u-boot.lds + endif + ifeq ($(wildcard $(LDSCRIPT)),) +$(error could not find linker script) + endif endif + OBJCFLAGS += --gap-fill=0xff
gccincdir := $(shell $(CC) -print-file-name=include)
Dear Scott Wood,
Thanks for this nice cleanup.
Only one question: Which boards / architectures did you cover during your tests?
On Thu, 7 Apr 2011 09:11:03 +0200 Wolfgang Denk wd@denx.de wrote:
Dear Scott Wood,
As I noted, I did a MAKEALL ppc and all the output (sizes, errors, etc) was the same as before the patch.
I tried a few arm boards, and all the ones I tried failed the same way they did before the patch. I don't have toolchains for the other arches readily available. Any help in testing this change on non-ppc would be appreciated.
-Scott
Dear Scott Wood,
I have tried this patch on all (two!) x86 configurations and looks good
You may have my:
Tested-by: Graeme Russ graeme.russ@gmail.com
Regards,
Graeme
i guess if i simply renamed blackfin/u-boot.lds.S to blackfin/u-boot.lds, things would "just work" for me too. -mike
Now that common code is a bit smarter when it comes to default LDSCRIPT values, rename the default Blackfin file and drop the Blackfin-specific config.mk logic.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/blackfin/config.mk | 4 - arch/blackfin/cpu/u-boot.lds | 158 ++++++++++++++++++++++++++++++++++++++++ arch/blackfin/lib/u-boot.lds.S | 158 ---------------------------------------- 3 files changed, 158 insertions(+), 162 deletions(-) create mode 100644 arch/blackfin/cpu/u-boot.lds delete mode 100644 arch/blackfin/lib/u-boot.lds.S
diff --git a/arch/blackfin/config.mk b/arch/blackfin/config.mk index 95cf7db..f35b579 100644 --- a/arch/blackfin/config.mk +++ b/arch/blackfin/config.mk @@ -76,10 +76,6 @@ LDR_FLAGS += $(LDR_FLAGS-y) # Set some default LDR flags based on boot mode. LDR_FLAGS += $(LDR_FLAGS-$(CONFIG_BFIN_BOOT_MODE))
-ifeq ($(wildcard $(TOPDIR)/board/$(BOARD)/u-boot.lds*),) -LDSCRIPT = $(obj)arch/$(ARCH)/lib/u-boot.lds.S -endif - ifneq ($(CONFIG_SYS_TEXT_BASE),) $(error do not set CONFIG_SYS_TEXT_BASE for Blackfin boards) endif diff --git a/arch/blackfin/cpu/u-boot.lds b/arch/blackfin/cpu/u-boot.lds new file mode 100644 index 0000000..2b8d285 --- /dev/null +++ b/arch/blackfin/cpu/u-boot.lds @@ -0,0 +1,158 @@ +/* + * U-boot - u-boot.lds.S + * + * Copyright (c) 2005-2010 Analog Device Inc. + * + * (C) Copyright 2000-2004 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/blackfin.h> +#undef ALIGN +#undef ENTRY + +#ifndef LDS_BOARD_TEXT +# define LDS_BOARD_TEXT +#endif + +/* If we don't actually load anything into L1 data, this will avoid + * a syntax error. If we do actually load something into L1 data, + * we'll get a linker memory load error (which is what we'd want). + * This is here in the first place so we can quickly test building + * for different CPU's which may lack non-cache L1 data. + */ +#ifndef L1_DATA_A_SRAM +# define L1_DATA_A_SRAM 0 +# define L1_DATA_A_SRAM_SIZE 0 +#endif +#ifndef L1_DATA_B_SRAM +# define L1_DATA_B_SRAM L1_DATA_A_SRAM +# define L1_DATA_B_SRAM_SIZE L1_DATA_A_SRAM_SIZE +#endif + +/* The 0xC offset is so we don't clobber the tiny LDR jump block. */ +#ifdef CONFIG_BFIN_BOOTROM_USES_EVT1 +# define L1_CODE_ORIGIN L1_INST_SRAM +#else +# define L1_CODE_ORIGIN L1_INST_SRAM + 0xC +#endif + +OUTPUT_ARCH(bfin) + +MEMORY +{ +#if CONFIG_MEM_SIZE + ram : ORIGIN = CONFIG_SYS_MONITOR_BASE, LENGTH = CONFIG_SYS_MONITOR_LEN +# define ram_code ram +# define ram_data ram +#else +# define ram_code l1_code +# define ram_data l1_data +#endif + l1_code : ORIGIN = L1_CODE_ORIGIN, LENGTH = L1_INST_SRAM_SIZE + l1_data : ORIGIN = L1_DATA_B_SRAM, LENGTH = L1_DATA_B_SRAM_SIZE +} + +ENTRY(_start) +SECTIONS +{ + .text.pre : + { + arch/blackfin/cpu/start.o (.text .text.*) + + LDS_BOARD_TEXT + } >ram_code + + .text.init : + { + arch/blackfin/cpu/initcode.o (.text .text.*) + } >ram_code + __initcode_lma = LOADADDR(.text.init); + __initcode_len = SIZEOF(.text.init); + + .text : + { + *(.text .text.*) + } >ram_code + + .rodata : + { + . = ALIGN(4); + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + . = ALIGN(4); + } >ram_data + + .data : + { + . = ALIGN(4); + *(.data .data.*) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } >ram_data + + .u_boot_cmd : + { + ___u_boot_cmd_start = .; + *(.u_boot_cmd) + ___u_boot_cmd_end = .; + } >ram_data + + .text_l1 : + { + . = ALIGN(4); + __stext_l1 = .; + *(.l1.text) + . = ALIGN(4); + __etext_l1 = .; + } >l1_code AT>ram_code + __text_l1_lma = LOADADDR(.text_l1); + __text_l1_len = SIZEOF(.text_l1); + ASSERT (__text_l1_len <= L1_INST_SRAM_SIZE, "L1 text overflow!") + + .data_l1 : + { + . = ALIGN(4); + __sdata_l1 = .; + *(.l1.data) + *(.l1.bss) + . = ALIGN(4); + __edata_l1 = .; + } >l1_data AT>ram_data + __data_l1_lma = LOADADDR(.data_l1); + __data_l1_len = SIZEOF(.data_l1); + ASSERT (__data_l1_len <= L1_DATA_B_SRAM_SIZE, "L1 data overflow!") + + .bss : + { + . = ALIGN(4); + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss .bss.*) + *(COMMON) + . = ALIGN(4); + } >ram_data + __bss_vma = ADDR(.bss); + __bss_len = SIZEOF(.bss); +} diff --git a/arch/blackfin/lib/u-boot.lds.S b/arch/blackfin/lib/u-boot.lds.S deleted file mode 100644 index 2b8d285..0000000 --- a/arch/blackfin/lib/u-boot.lds.S +++ /dev/null @@ -1,158 +0,0 @@ -/* - * U-boot - u-boot.lds.S - * - * Copyright (c) 2005-2010 Analog Device Inc. - * - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <asm/blackfin.h> -#undef ALIGN -#undef ENTRY - -#ifndef LDS_BOARD_TEXT -# define LDS_BOARD_TEXT -#endif - -/* If we don't actually load anything into L1 data, this will avoid - * a syntax error. If we do actually load something into L1 data, - * we'll get a linker memory load error (which is what we'd want). - * This is here in the first place so we can quickly test building - * for different CPU's which may lack non-cache L1 data. - */ -#ifndef L1_DATA_A_SRAM -# define L1_DATA_A_SRAM 0 -# define L1_DATA_A_SRAM_SIZE 0 -#endif -#ifndef L1_DATA_B_SRAM -# define L1_DATA_B_SRAM L1_DATA_A_SRAM -# define L1_DATA_B_SRAM_SIZE L1_DATA_A_SRAM_SIZE -#endif - -/* The 0xC offset is so we don't clobber the tiny LDR jump block. */ -#ifdef CONFIG_BFIN_BOOTROM_USES_EVT1 -# define L1_CODE_ORIGIN L1_INST_SRAM -#else -# define L1_CODE_ORIGIN L1_INST_SRAM + 0xC -#endif - -OUTPUT_ARCH(bfin) - -MEMORY -{ -#if CONFIG_MEM_SIZE - ram : ORIGIN = CONFIG_SYS_MONITOR_BASE, LENGTH = CONFIG_SYS_MONITOR_LEN -# define ram_code ram -# define ram_data ram -#else -# define ram_code l1_code -# define ram_data l1_data -#endif - l1_code : ORIGIN = L1_CODE_ORIGIN, LENGTH = L1_INST_SRAM_SIZE - l1_data : ORIGIN = L1_DATA_B_SRAM, LENGTH = L1_DATA_B_SRAM_SIZE -} - -ENTRY(_start) -SECTIONS -{ - .text.pre : - { - arch/blackfin/cpu/start.o (.text .text.*) - - LDS_BOARD_TEXT - } >ram_code - - .text.init : - { - arch/blackfin/cpu/initcode.o (.text .text.*) - } >ram_code - __initcode_lma = LOADADDR(.text.init); - __initcode_len = SIZEOF(.text.init); - - .text : - { - *(.text .text.*) - } >ram_code - - .rodata : - { - . = ALIGN(4); - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - . = ALIGN(4); - } >ram_data - - .data : - { - . = ALIGN(4); - *(.data .data.*) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } >ram_data - - .u_boot_cmd : - { - ___u_boot_cmd_start = .; - *(.u_boot_cmd) - ___u_boot_cmd_end = .; - } >ram_data - - .text_l1 : - { - . = ALIGN(4); - __stext_l1 = .; - *(.l1.text) - . = ALIGN(4); - __etext_l1 = .; - } >l1_code AT>ram_code - __text_l1_lma = LOADADDR(.text_l1); - __text_l1_len = SIZEOF(.text_l1); - ASSERT (__text_l1_len <= L1_INST_SRAM_SIZE, "L1 text overflow!") - - .data_l1 : - { - . = ALIGN(4); - __sdata_l1 = .; - *(.l1.data) - *(.l1.bss) - . = ALIGN(4); - __edata_l1 = .; - } >l1_data AT>ram_data - __data_l1_lma = LOADADDR(.data_l1); - __data_l1_len = SIZEOF(.data_l1); - ASSERT (__data_l1_len <= L1_DATA_B_SRAM_SIZE, "L1 data overflow!") - - .bss : - { - . = ALIGN(4); - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss .bss.*) - *(COMMON) - . = ALIGN(4); - } >ram_data - __bss_vma = ADDR(.bss); - __bss_len = SIZEOF(.bss); -}
blah, prob should have used -M. this is a simple rename. -mike
Dear Scott Wood,
Applied, thanks.
Graeme Russ
Mike Frysinger
Scott Wood
