[U-Boot-Users] [Patch 11/17] U-Boot-V2:ARM:OMAP3: Add support for OMAP3 Silicon files
This patch introduces support for OMAP3430 - provides for base OMAP3 files.
Signed-off-by: Nishanth Menonx0nishan@ti.com
--- arch/arm/mach-omap/Kconfig | 65 +++++ arch/arm/mach-omap/Makefile | 25 ++ arch/arm/mach-omap/omap3_core.S | 101 ++++++++ arch/arm/mach-omap/omap3_generic.c | 416 +++++++++++++++++++++++++++++++++++++ arch/arm/mach-omap/syslib.c | 97 ++++++++ 5 files changed, 704 insertions(+)
Index: u-boot-v2.git/arch/arm/mach-omap/Kconfig =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/arch/arm/mach-omap/Kconfig 2008-05-20 18:10:50.000000000 -0500 @@ -0,0 +1,65 @@ +# +# OMAP Architecture specific features +# +# (C) Copyright 2008 +# Texas Instruments, <www.ti.com> +# Nishanth Menon x0nishan@ti.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA + +menu "OMAP Features" + depends on ARCH_OMAP + +choice + prompt "Select OMAP Variant" + +config ARCH_OMAP3 + bool "OMAP3" + select ARMCORTEXA8 + select ARCH_HAS_LOWLEVEL_INIT + help + Say Y here if you are using Texas Instrument's OMAP343x based platform + +endchoice + +config OMAP_CONFIG_STACKSIZE + prompt "STACKSIZE" + hex + default 0x00020000 + help + Select the Stack Size + +config OMAP_MALLOC_LEN + prompt "MALLOC LENGTH" + hex + default 0x00001000 + help + Select the Malloc Length + +config ARCH_TEXT_BASE + prompt "ARCH TEXT BASE" + hex + default 0x80e80000 + help + Select the load address + +config OMAP3_CLOCK_CONFIG + depends on ARCH_OMAP + bool "Clock Configuration" + help + Say Y here if you like to have OMAP3 Clock configuration done. + +endmenu Index: u-boot-v2.git/arch/arm/mach-omap/Makefile =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/arch/arm/mach-omap/Makefile 2008-05-20 18:10:50.000000000 -0500 @@ -0,0 +1,25 @@ +# OMAP Architecture Makefile +# +# (C) Copyright 2008 +# Texas Instruments, <www.ti.com> +# Nishanth Menon x0nishan@ti.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +obj-$(CONFIG_ARCH_OMAP) += syslib.o +obj-$(CONFIG_OMAP_CLOCK_SOURCE_S32K) += s32k_clksource.o +obj-$(CONFIG_ARCH_OMAP3) += omap3_core.o omap3_generic.o +obj-$(CONFIG_OMAP3_CLOCK_CONFIG) += omap3_clock_core.o omap3_clock.o Index: u-boot-v2.git/arch/arm/mach-omap/omap3_core.S =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/arch/arm/mach-omap/omap3_core.S 2008-05-20 18:10:50.000000000 -0500 @@ -0,0 +1,101 @@ +/** + * @file + * @brief Provide Architecture level Initialization + * + * FileName: arch/arm/mach-omap/omap3_core.S + * + * This provides OMAP3 Architecture initialization. Among these, + * @li OMAP ROM Code is located in SRAM, we can piggy back on + * the same addresses + * @li If clock initialization is required, call the same. + * @li Setup a temporary SRAM stack which is necessary to call C + * functions. + * @li Call architecture initialization function a_init + * + * arch_init_lowlevel is enabled if CONFIG_ARCH_HAS_LOWLEVEL_INIT is defined + * cpy_clk_code is called if CONFIG_OMAP3_COPY_CLOCK_SRAM is defined + */ +/* + * (C) Copyright 2006-2008 + * Texas Instruments, <www.ti.com> + * Nishanth Menon x0nishan@ti.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/arch/silicon.h> +#include <asm/arch/wdt.h> +#include <asm/arch/clocks.h> + +#ifdef CONFIG_ARCH_HAS_LOWLEVEL_INIT +.globl arch_init_lowlevel +arch_init_lowlevel: + /* Copy vectors to mask ROM indirect addr */ + mov r0, pc /* Store the current pc address */ + sub r0, r0, #8 /* Reduce offset */ + ldr r1, arch_start /* Load the link address for arch_int */ + ldr r2, uboot_start /* load the link address of start_init*/ + sub r1, r1, r2 /* get the offset */ + /* subtract the offset from PC of arch=Current start */ + sub r0, r0, r1 + mov r2, #OMAP_SRAM_INTVECT_COPYSIZE /* r2 <- size to copy */ + add r2, r0, r2 /* r2 <- source end address */ + ldr r1, SRAM_INTVECT /* build vect addr */ +next: + ldmia r0!, {r3-r10} /* copy from source address [r0] */ + stmia r1!, {r3-r10} /* copy to target address [r1] */ + cmp r0, r2 /* until source end address [r2] */ + ble next /* loop until equal */ + +#ifdef CONFIG_OMAP3_COPY_CLOCK_SRAM + /* No need to copy/exec the clock code - DPLL adjust already done + * in Perip/NAND/oneNAND Boot. + * Put dpll adjust code behind vectors. r1 has address to copy to + */ + bl cpy_clk_code +#endif + ldr r1, SRAM_INTVECT /* build vect addr */ + /* Read the interrupt vector base address */ + mrc p15, #0, r0, c12, c0, #0 + /* Clear the vector base 4:0 is reserved. */ + and r0, r0, #0xF + /* Store the SRAM_INTVECT address */ + orr r0, r0, r1 + /* Store the new vector address */ + mcr p15, #0, r0, c12, c0, #0 + /* Setup a temporary stack so that we can call C functions */ + ldr sp, SRAM_STACK + str ip, [sp] /* stash old link register */ + str lr, [sp] /* stash current link register */ + mov ip, lr /* save link reg across call */ + bl a_init /* Architecture init */ + ldr lr, [sp] /* restore current link register */ + ldr ip, [sp] /* restore save ip */ + + /* back to arch calling code */ + mov pc, lr + +arch_start: + .word arch_init_lowlevel +uboot_start: + .word _start +SRAM_INTVECT: + .word OMAP_SRAM_INTVECT + +SRAM_STACK: + .word OMAP_SRAM_STACK +#endif /* CONFIG_ARCH_HAS_LOWLEVEL_INIT */ Index: u-boot-v2.git/arch/arm/mach-omap/omap3_generic.c =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/arch/arm/mach-omap/omap3_generic.c 2008-05-20 18:10:50.000000000 -0500 @@ -0,0 +1,416 @@ +/** + * @file + * @brief Provide Generic implementations for OMAP3 architecture + * + * FileName: arch/arm/mach-omap/omap3_generic.c + * + * This file contains the generic implementations of various OMAP3 + * relevant functions + * For more info on OMAP34XX, see http://focus.ti.com/pdfs/wtbu/swpu114g.pdf + * + * Important one is @ref a_init which is architecture init code. + * The implemented functions are present in sys_info.h + * + * Originally from http://linux.omap.com/pub/bootloader/3430sdp/u-boot-v1.tar.gz + */ +/* + * (C) Copyright 2006-2008 + * Texas Instruments, <www.ti.com> + * Richard Woodruff r-woodruff2@ti.com + * Nishanth Menon x0nishan@ti.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <init.h> +#include <asm/io.h> +#include <asm/sizes.h> +#include <asm/arch/silicon.h> +#include <asm/arch/gpmc.h> +#include <asm/arch/sdrc.h> +#include <asm/arch/control.h> +#include <asm/arch/omap3-smx.h> +#include <asm/arch/clocks.h> +#include <asm/arch/wdt.h> +#include <asm/arch/sys_info.h> +#include <asm/arch/syslib.h> + +/** + * @brief Reset the CPU + * + * In case of crashes, reset the CPU + * + * @param[in] addr -Cause of crash + * + * @return void + */ +void reset_cpu(ulong addr) +{ + /* FIXME: Enable WDT and cause reset */ + hang(); +} +EXPORT_SYMBOL(reset_cpu); + +/** + * @brief Low level CPU type + * + * @return CPU_3430 + */ +u32 get_cpu_type(void) +{ + /* FIXME: need to get register defines for 3430 */ + return (CPU_3430); +} + +/** + * @brief Extract the OMAP ES rev + * + * @return CPU_ES version + */ +u32 get_cpu_rev(void) +{ + u32 idcode_val; + idcode_val = __raw_readl(IDCODE_REG); + if ((idcode_val & (HAWKEYE_MASK | VERSION_MASK)) == HAWKEYE_ES2_1) + return CPU_ES2P1; + if ((idcode_val & HAWKEYE_MASK) == HAWKEYE_ES2) + return CPU_ES2; + /* unsupported! */ + return CPU_ES1; +} + +/** + * @brief Get size of chip select 0/1 + * + * @param[in] offset give the offset if we need CS1 + * + * @return return the sdram size. + */ +u32 get_sdr_cs_size(u32 offset) +{ + u32 size; + /* get ram size field */ + size = __raw_readl(SDRC_REG(MCFG_0) + offset) >> 8; + size &= 0x3FF; /* remove unwanted bits */ + size *= SZ_2M; /* find size in MB */ + return (size); +} + +/** + * @brief Get the initial SYSBOOT value + * + * SYSBOOT is useful to know which state OMAP booted from. + * + * @return - Return the value of SYSBOOT. + */ +inline u32 get_sysboot_value(void) +{ + return (0x0000003F & __raw_readl(CONTROL_REG(STATUS))); +} + +/** + * @brief Return the current CS0 base address + * + * Return current address hardware will be + * fetching from. The below effectively gives what is correct, its a bit + * mis-leading compared to the TRM. For the most general case the mask + * needs to be also taken into account this does work in practice. + * + * @return base address + */ +u32 get_gpmc0_base(void) +{ + u32 b; + b = __raw_readl(GPMC_REG(CONFIG7_0)); + b &= 0x1F; /* keep base [5:0] */ + b = b << 24; /* ret 0x0b000000 */ + return (b); +} + +/** + * @brief Get the upper address of current execution + * + * we can use this to figure out if we are running in SRAM / + * XIP Flash or in SDRAM + * + * @return base address + */ +u32 get_base(void) +{ + u32 val; + __asm__ __volatile__("mov %0, pc \n":"=r"(val)::"memory"); + val &= 0xF0000000; + val >>= 28; + return (val); +} + +/** + * @brief Are we running in Flash XIP? + * + * If the base is in GPMC address space, we probably are! + * + * @return 1 if we are running in XIP mode, else return 0 + */ +u32 running_in_flash(void) +{ + if (get_base() < 4) + return (1); /* in flash */ + return (0); /* running in SRAM or SDRAM */ +} + +/** + * @brief Are we running in OMAP internal SRAM? + * + * If in SRAM address, then yes! + * + * @return 1 if we are running in SRAM, else return 0 + */ +u32 running_in_sram(void) +{ + if (get_base() == 4) + return (1); /* in SRAM */ + return (0); /* running in FLASH or SDRAM */ +} + +/** + * @brief Are we running in SDRAM? + * + * if we are not in GPMC nor in SRAM address space, + * we are in SDRAM execution area + * + * @return 1 if we are running from SDRAM, else return 0 + */ +u32 running_in_sdram(void) +{ + if (get_base() > 4) + return (1); /* in sdram */ + return (0); /* running in SRAM or FLASH */ +} +EXPORT_SYMBOL(running_in_sdram); + +/** + * @brief Is this an XIP type device or a stream one + * + * Sysboot bits 4-0 specify type. Bit 5, sys mem/perif + * + * @return Boot type + */ +u32 get_boot_type(void) +{ + u32 v; + v = get_sysboot_value() & (BIT4 | BIT3 | BIT2 | BIT1 | BIT0); + return v; +} + +/** + * @brief What type of device are we? + * + * are we on a GP/HS/EMU/TEST device? + * + * @return device type + */ +u32 get_device_type(void) +{ + int mode; + mode = __raw_readl(CONTROL_REG(STATUS)) & (DEVICE_MASK); + return (mode >>= 8); +} + +/** + * @brief Setup security registers for access + * + * This can be done for GP Device only. for HS/EMU devices, read TRM. + * + * @return void + */ +static void secure_unlock_mem(void) +{ + /* Permission values for registers -Full fledged permissions to all */ +#define UNLOCK_1 0xFFFFFFFF +#define UNLOCK_2 0x00000000 +#define UNLOCK_3 0x0000FFFF + /* Protection Module Register Target APE (PM_RT) */ + __raw_writel(UNLOCK_1, RT_REQ_INFO_PERMISSION_1); + __raw_writel(UNLOCK_1, RT_READ_PERMISSION_0); + __raw_writel(UNLOCK_1, RT_WRITE_PERMISSION_0); + __raw_writel(UNLOCK_2, RT_ADDR_MATCH_1); + + __raw_writel(UNLOCK_3, GPMC_REQ_INFO_PERMISSION_0); + __raw_writel(UNLOCK_3, GPMC_READ_PERMISSION_0); + __raw_writel(UNLOCK_3, GPMC_WRITE_PERMISSION_0); + + __raw_writel(UNLOCK_3, OCM_REQ_INFO_PERMISSION_0); + __raw_writel(UNLOCK_3, OCM_READ_PERMISSION_0); + __raw_writel(UNLOCK_3, OCM_WRITE_PERMISSION_0); + __raw_writel(UNLOCK_2, OCM_ADDR_MATCH_2); + + /* IVA Changes */ + __raw_writel(UNLOCK_3, IVA2_REQ_INFO_PERMISSION_0); + __raw_writel(UNLOCK_3, IVA2_READ_PERMISSION_0); + __raw_writel(UNLOCK_3, IVA2_WRITE_PERMISSION_0); + + __raw_writel(UNLOCK_1, SMS_RG_ATT0); /* SDRC region 0 public */ +} + +/** + * @brief Come out of secure mode + * If chip is EMU and boot type is external configure + * secure registers and exit secure world general use. + * + * @return void + */ +static void secureworld_exit(void) +{ + unsigned long i; + + /* configrue non-secure access control register */ + __asm__ __volatile__("mrc p15, 0, %0, c1, c1, 2":"=r"(i)); + /* enabling co-processor CP10 and CP11 accesses in NS world */ + __asm__ __volatile__("orr %0, %0, #0xC00":"=r"(i)); + /* allow allocation of locked TLBs and L2 lines in NS world */ + /* allow use of PLE registers in NS world also */ + __asm__ __volatile__("orr %0, %0, #0x70000":"=r"(i)); + __asm__ __volatile__("mcr p15, 0, %0, c1, c1, 2":"=r"(i)); + + /* Enable ASA in ACR register */ + __asm__ __volatile__("mrc p15, 0, %0, c1, c0, 1":"=r"(i)); + __asm__ __volatile__("orr %0, %0, #0x10":"=r"(i)); + __asm__ __volatile__("mcr p15, 0, %0, c1, c0, 1":"=r"(i)); + + /* Exiting secure world */ + __asm__ __volatile__("mrc p15, 0, %0, c1, c1, 0":"=r"(i)); + __asm__ __volatile__("orr %0, %0, #0x31":"=r"(i)); + __asm__ __volatile__("mcr p15, 0, %0, c1, c1, 0":"=r"(i)); +} + +/** + * @brief Shut down the watchdogs + * + * There are 3 watch dogs WD1=Secure, WD2=MPU, WD3=IVA. WD1 is + * either taken care of by ROM (HS/EMU) or not accessible (GP). + * We need to take care of WD2-MPU or take a PRCM reset. WD3 + * should not be running and does not generate a PRCM reset. + * + * @return void + */ +static void watchdog_init(void) +{ + int pending = 1; + + sr32(CM_REG(FCLKEN_WKUP), 5, 1, 1); + sr32(CM_REG(ICLKEN_WKUP), 5, 1, 1); + wait_on_value(BIT5, 0x20, CM_REG(IDLEST_WKUP), 5); + + __raw_writel(WDT_DISABLE_CODE1, WDT_REG(WSPR)); + + do { + pending = __raw_readl(WDT_REG(WWPS)); + } while (pending); + + __raw_writel(WDT_DISABLE_CODE2, WDT_REG(WSPR)); +} + +/** + * @brief Write to AuxCR desired value using SMI. + * general use. + * + * @return void + */ +static void setup_auxcr(void) +{ + unsigned long i; + volatile unsigned int j; + /* Save r0, r12 and restore them after usage */ + __asm__ __volatile__("mov %0, r12":"=r"(j)); + __asm__ __volatile__("mov %0, r0":"=r"(i)); + + /* GP Device ROM code API usage here */ + /* r12 = AUXCR Write function and r0 value */ + __asm__ __volatile__("mov r12, #0x3"); + __asm__ __volatile__("mrc p15, 0, r0, c1, c0, 1"); + /* Enabling ASA */ + __asm__ __volatile__("orr r0, r0, #0x10"); + /* SMI instruction to call ROM Code API */ + __asm__ __volatile__(".word 0xE1600070"); + __asm__ __volatile__("mov r0, %0":"=r"(i)); + __asm__ __volatile__("mov r12, %0":"=r"(j)); +} + +/** + * @brief Try to unlock the SRAM for general use + * + * If chip is GP/EMU(special) type, unlock the SRAM for + * general use. + * + * @return void + */ +static void try_unlock_memory(void) +{ + int mode; + int in_sdram = running_in_sdram(); + + /* if GP device unlock device SRAM for general use */ + /* secure code breaks for Secure/Emulation device - HS/E/T */ + mode = get_device_type(); + if (mode == GP_DEVICE) + secure_unlock_mem(); + /* If device is EMU and boot is XIP external booting + * Unlock firewalls and disable L2 and put chip + * out of secure world + */ + /* Assuming memories are unlocked by the demon who put us in SDRAM */ + if ((mode <= EMU_DEVICE) && (get_boot_type() == 0x1F) + && (!in_sdram)) { + secure_unlock_mem(); + secureworld_exit(); + } + + return; +} + +/** + * @brief OMAP3 Architecture specific Initialization + * + * Does early system init of disabling the watchdog, enable + * memory and configuring the clocks. + * + * prcm_init is called only if CONFIG_OMAP3_CLOCK_CONFIG is defined. + * We depend on link time clean up to remove a_init if no caller exists. + * + * @warning Called path is with SRAM stack + * + * @return void + */ +void a_init(void) +{ + watchdog_init(); + + try_unlock_memory(); + + /* Writing to AuxCR in U-boot using SMI for GP DEV */ + /* Currently SMI in Kernel on ES2 devices seems to have an isse + * Once that is resolved, we can postpone this config to kernel + */ + if (get_device_type() == GP_DEVICE) + setup_auxcr(); + + sdelay(100); + +#ifdef CONFIG_OMAP3_CLOCK_CONFIG + prcm_init(); +#endif + +} Index: u-boot-v2.git/arch/arm/mach-omap/syslib.c =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/arch/arm/mach-omap/syslib.c 2008-05-20 18:10:50.000000000 -0500 @@ -0,0 +1,97 @@ +/** + * @file + * @brief Provide OMAP independent utility APIs + * + * FileName: arch/arm/mach-omap/syslib.c + * + * Provide APIs which can be used from platform/architecture code + * to operate on + * + * Originally from http://linux.omap.com/pub/bootloader/3430sdp/u-boot-v1.tar.gz + */ +/* + * (C) Copyright 2006-2008 + * Texas Instruments, <www.ti.com> + * Richard Woodruff r-woodruff2@ti.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/io.h> +#include <asm/arch/syslib.h> + +/** + * @brief simple spin loop + * + * Will be constant time as its generally used in bypass conditions only. + * This is necessary until timers are accessible. if you need timed delays + * use @ref mdelay or @udelay instead + * + * @param[in] loops number of loops + * + * @return void + */ +void sdelay(unsigned long loops) +{ + __asm__ volatile ("1:\n" "subs %0, %1, #1\n" + "bne 1b":"=r" (loops):"0"(loops)); +} + +/** + * @brief clear & set a value in a bit range for a 32 bit address + * + * @param[in] addr Address to set/read from + * @param[in] start_bit Where to put the value + * @param[in] num_bits number of bits the value should be set + * @param[in] value the value to set + * + * @return void + */ +void sr32(u32 addr, u32 start_bit, u32 num_bits, u32 value) +{ + u32 tmp, msk = 0; + msk = 1 << num_bits; + --msk; + tmp = __raw_readl(addr) & ~(msk << start_bit); + tmp |= value << start_bit; + __raw_writel(tmp, addr); +} + +/** + * @brief common routine to allow waiting for changes in volatile regs. + * + * @param[in] read_bit_mask the bit mask to read + * @param[in] match_value match to which value + * @param[in] read_addr address to read from + * @param[in] bound max iterations + * + * @return 1 if match_value is found, else if bound iterations reached, + * returns 0 + */ +u32 wait_on_value(u32 read_bit_mask, u32 match_value, u32 read_addr, u32 bound) +{ + u32 i = 0, val; + do { + ++i; + val = __raw_readl(read_addr) & read_bit_mask; + if (val == match_value) + return (1); + if (i == bound) + return (0); + } while (1); +} +
As per the thread in: http://www.nabble.com/-Patch-06-17--U-Boot-V2%3AARM%3A-Add-sizes.h-tt1737278... sizes.h dependency is removed from the following patch. This is a resubmission.
This patch introduces support for OMAP3430 - provides for generic OMAP3 files.
--- arch/arm/mach-omap/Kconfig | 65 +++++ arch/arm/mach-omap/Makefile | 25 ++ arch/arm/mach-omap/omap3_core.S | 101 +++++++++ arch/arm/mach-omap/omap3_generic.c | 415 +++++++++++++++++++++++++++++++++++++ arch/arm/mach-omap/syslib.c | 97 ++++++++ 5 files changed, 703 insertions(+)
Index: u-boot-v2.git/arch/arm/mach-omap/Kconfig =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/arch/arm/mach-omap/Kconfig 2008-05-28 10:33:04.000000000 -0500 @@ -0,0 +1,65 @@ +# +# OMAP Architecture specific features +# +# (C) Copyright 2008 +# Texas Instruments, <www.ti.com> +# Nishanth Menon x0nishan@ti.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA + +menu "OMAP Features" + depends on ARCH_OMAP + +choice + prompt "Select OMAP Variant" + +config ARCH_OMAP3 + bool "OMAP3" + select ARMCORTEXA8 + select ARCH_HAS_LOWLEVEL_INIT + help + Say Y here if you are using Texas Instrument's OMAP343x based platform + +endchoice + +config OMAP_CONFIG_STACKSIZE + prompt "STACKSIZE" + hex + default 0x00020000 + help + Select the Stack Size + +config OMAP_MALLOC_LEN + prompt "MALLOC LENGTH" + hex + default 0x00001000 + help + Select the Malloc Length + +config ARCH_TEXT_BASE + prompt "ARCH TEXT BASE" + hex + default 0x80e80000 + help + Select the load address + +config OMAP3_CLOCK_CONFIG + depends on ARCH_OMAP + bool "Clock Configuration" + help + Say Y here if you like to have OMAP3 Clock configuration done. + +endmenu Index: u-boot-v2.git/arch/arm/mach-omap/Makefile =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/arch/arm/mach-omap/Makefile 2008-05-28 10:19:05.000000000 -0500 @@ -0,0 +1,25 @@ +# OMAP Architecture Makefile +# +# (C) Copyright 2008 +# Texas Instruments, <www.ti.com> +# Nishanth Menon x0nishan@ti.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +obj-$(CONFIG_ARCH_OMAP) += syslib.o +obj-$(CONFIG_OMAP_CLOCK_SOURCE_S32K) += s32k_clksource.o +obj-$(CONFIG_ARCH_OMAP3) += omap3_core.o omap3_generic.o +obj-$(CONFIG_OMAP3_CLOCK_CONFIG) += omap3_clock_core.o omap3_clock.o Index: u-boot-v2.git/arch/arm/mach-omap/omap3_core.S =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/arch/arm/mach-omap/omap3_core.S 2008-05-28 10:19:05.000000000 -0500 @@ -0,0 +1,101 @@ +/** + * @file + * @brief Provide Architecture level Initialization + * + * FileName: arch/arm/mach-omap/omap3_core.S + * + * This provides OMAP3 Architecture initialization. Among these, + * @li OMAP ROM Code is located in SRAM, we can piggy back on + * the same addresses + * @li If clock initialization is required, call the same. + * @li Setup a temporary SRAM stack which is necessary to call C + * functions. + * @li Call architecture initialization function a_init + * + * arch_init_lowlevel is enabled if CONFIG_ARCH_HAS_LOWLEVEL_INIT is defined + * cpy_clk_code is called if CONFIG_OMAP3_COPY_CLOCK_SRAM is defined + */ +/* + * (C) Copyright 2006-2008 + * Texas Instruments, <www.ti.com> + * Nishanth Menon x0nishan@ti.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/arch/silicon.h> +#include <asm/arch/wdt.h> +#include <asm/arch/clocks.h> + +#ifdef CONFIG_ARCH_HAS_LOWLEVEL_INIT +.globl arch_init_lowlevel +arch_init_lowlevel: + /* Copy vectors to mask ROM indirect addr */ + mov r0, pc /* Store the current pc address */ + sub r0, r0, #8 /* Reduce offset */ + ldr r1, arch_start /* Load the link address for arch_int */ + ldr r2, uboot_start /* load the link address of start_init*/ + sub r1, r1, r2 /* get the offset */ + /* subtract the offset from PC of arch=Current start */ + sub r0, r0, r1 + mov r2, #OMAP_SRAM_INTVECT_COPYSIZE /* r2 <- size to copy */ + add r2, r0, r2 /* r2 <- source end address */ + ldr r1, SRAM_INTVECT /* build vect addr */ +next: + ldmia r0!, {r3-r10} /* copy from source address [r0] */ + stmia r1!, {r3-r10} /* copy to target address [r1] */ + cmp r0, r2 /* until source end address [r2] */ + ble next /* loop until equal */ + +#ifdef CONFIG_OMAP3_COPY_CLOCK_SRAM + /* No need to copy/exec the clock code - DPLL adjust already done + * in Perip/NAND/oneNAND Boot. + * Put dpll adjust code behind vectors. r1 has address to copy to + */ + bl cpy_clk_code +#endif + ldr r1, SRAM_INTVECT /* build vect addr */ + /* Read the interrupt vector base address */ + mrc p15, #0, r0, c12, c0, #0 + /* Clear the vector base 4:0 is reserved. */ + and r0, r0, #0xF + /* Store the SRAM_INTVECT address */ + orr r0, r0, r1 + /* Store the new vector address */ + mcr p15, #0, r0, c12, c0, #0 + /* Setup a temporary stack so that we can call C functions */ + ldr sp, SRAM_STACK + str ip, [sp] /* stash old link register */ + str lr, [sp] /* stash current link register */ + mov ip, lr /* save link reg across call */ + bl a_init /* Architecture init */ + ldr lr, [sp] /* restore current link register */ + ldr ip, [sp] /* restore save ip */ + + /* back to arch calling code */ + mov pc, lr + +arch_start: + .word arch_init_lowlevel +uboot_start: + .word _start +SRAM_INTVECT: + .word OMAP_SRAM_INTVECT + +SRAM_STACK: + .word OMAP_SRAM_STACK +#endif /* CONFIG_ARCH_HAS_LOWLEVEL_INIT */ Index: u-boot-v2.git/arch/arm/mach-omap/omap3_generic.c =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/arch/arm/mach-omap/omap3_generic.c 2008-05-28 10:32:59.000000000 -0500 @@ -0,0 +1,415 @@ +/** + * @file + * @brief Provide Generic implementations for OMAP3 architecture + * + * FileName: arch/arm/mach-omap/omap3_generic.c + * + * This file contains the generic implementations of various OMAP3 + * relevant functions + * For more info on OMAP34XX, see http://focus.ti.com/pdfs/wtbu/swpu114g.pdf + * + * Important one is @ref a_init which is architecture init code. + * The implemented functions are present in sys_info.h + * + * Originally from http://linux.omap.com/pub/bootloader/3430sdp/u-boot-v1.tar.gz + */ +/* + * (C) Copyright 2006-2008 + * Texas Instruments, <www.ti.com> + * Richard Woodruff r-woodruff2@ti.com + * Nishanth Menon x0nishan@ti.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <init.h> +#include <asm/io.h> +#include <asm/arch/silicon.h> +#include <asm/arch/gpmc.h> +#include <asm/arch/sdrc.h> +#include <asm/arch/control.h> +#include <asm/arch/omap3-smx.h> +#include <asm/arch/clocks.h> +#include <asm/arch/wdt.h> +#include <asm/arch/sys_info.h> +#include <asm/arch/syslib.h> + +/** + * @brief Reset the CPU + * + * In case of crashes, reset the CPU + * + * @param[in] addr -Cause of crash + * + * @return void + */ +void reset_cpu(ulong addr) +{ + /* FIXME: Enable WDT and cause reset */ + hang(); +} +EXPORT_SYMBOL(reset_cpu); + +/** + * @brief Low level CPU type + * + * @return CPU_3430 + */ +u32 get_cpu_type(void) +{ + /* FIXME: need to get register defines for 3430 */ + return (CPU_3430); +} + +/** + * @brief Extract the OMAP ES rev + * + * @return CPU_ES version + */ +u32 get_cpu_rev(void) +{ + u32 idcode_val; + idcode_val = __raw_readl(IDCODE_REG); + if ((idcode_val & (HAWKEYE_MASK | VERSION_MASK)) == HAWKEYE_ES2_1) + return CPU_ES2P1; + if ((idcode_val & HAWKEYE_MASK) == HAWKEYE_ES2) + return CPU_ES2; + /* unsupported! */ + return CPU_ES1; +} + +/** + * @brief Get size of chip select 0/1 + * + * @param[in] offset give the offset if we need CS1 + * + * @return return the sdram size. + */ +u32 get_sdr_cs_size(u32 offset) +{ + u32 size; + /* get ram size field */ + size = __raw_readl(SDRC_REG(MCFG_0) + offset) >> 8; + size &= 0x3FF; /* remove unwanted bits */ + size *= 2 * (1024 * 1024); /* find size in MB */ + return (size); +} + +/** + * @brief Get the initial SYSBOOT value + * + * SYSBOOT is useful to know which state OMAP booted from. + * + * @return - Return the value of SYSBOOT. + */ +inline u32 get_sysboot_value(void) +{ + return (0x0000003F & __raw_readl(CONTROL_REG(STATUS))); +} + +/** + * @brief Return the current CS0 base address + * + * Return current address hardware will be + * fetching from. The below effectively gives what is correct, its a bit + * mis-leading compared to the TRM. For the most general case the mask + * needs to be also taken into account this does work in practice. + * + * @return base address + */ +u32 get_gpmc0_base(void) +{ + u32 b; + b = __raw_readl(GPMC_REG(CONFIG7_0)); + b &= 0x1F; /* keep base [5:0] */ + b = b << 24; /* ret 0x0b000000 */ + return (b); +} + +/** + * @brief Get the upper address of current execution + * + * we can use this to figure out if we are running in SRAM / + * XIP Flash or in SDRAM + * + * @return base address + */ +u32 get_base(void) +{ + u32 val; + __asm__ __volatile__("mov %0, pc \n":"=r"(val)::"memory"); + val &= 0xF0000000; + val >>= 28; + return (val); +} + +/** + * @brief Are we running in Flash XIP? + * + * If the base is in GPMC address space, we probably are! + * + * @return 1 if we are running in XIP mode, else return 0 + */ +u32 running_in_flash(void) +{ + if (get_base() < 4) + return (1); /* in flash */ + return (0); /* running in SRAM or SDRAM */ +} + +/** + * @brief Are we running in OMAP internal SRAM? + * + * If in SRAM address, then yes! + * + * @return 1 if we are running in SRAM, else return 0 + */ +u32 running_in_sram(void) +{ + if (get_base() == 4) + return (1); /* in SRAM */ + return (0); /* running in FLASH or SDRAM */ +} + +/** + * @brief Are we running in SDRAM? + * + * if we are not in GPMC nor in SRAM address space, + * we are in SDRAM execution area + * + * @return 1 if we are running from SDRAM, else return 0 + */ +u32 running_in_sdram(void) +{ + if (get_base() > 4) + return (1); /* in sdram */ + return (0); /* running in SRAM or FLASH */ +} +EXPORT_SYMBOL(running_in_sdram); + +/** + * @brief Is this an XIP type device or a stream one + * + * Sysboot bits 4-0 specify type. Bit 5, sys mem/perif + * + * @return Boot type + */ +u32 get_boot_type(void) +{ + u32 v; + v = get_sysboot_value() & (BIT4 | BIT3 | BIT2 | BIT1 | BIT0); + return v; +} + +/** + * @brief What type of device are we? + * + * are we on a GP/HS/EMU/TEST device? + * + * @return device type + */ +u32 get_device_type(void) +{ + int mode; + mode = __raw_readl(CONTROL_REG(STATUS)) & (DEVICE_MASK); + return (mode >>= 8); +} + +/** + * @brief Setup security registers for access + * + * This can be done for GP Device only. for HS/EMU devices, read TRM. + * + * @return void + */ +static void secure_unlock_mem(void) +{ + /* Permission values for registers -Full fledged permissions to all */ +#define UNLOCK_1 0xFFFFFFFF +#define UNLOCK_2 0x00000000 +#define UNLOCK_3 0x0000FFFF + /* Protection Module Register Target APE (PM_RT) */ + __raw_writel(UNLOCK_1, RT_REQ_INFO_PERMISSION_1); + __raw_writel(UNLOCK_1, RT_READ_PERMISSION_0); + __raw_writel(UNLOCK_1, RT_WRITE_PERMISSION_0); + __raw_writel(UNLOCK_2, RT_ADDR_MATCH_1); + + __raw_writel(UNLOCK_3, GPMC_REQ_INFO_PERMISSION_0); + __raw_writel(UNLOCK_3, GPMC_READ_PERMISSION_0); + __raw_writel(UNLOCK_3, GPMC_WRITE_PERMISSION_0); + + __raw_writel(UNLOCK_3, OCM_REQ_INFO_PERMISSION_0); + __raw_writel(UNLOCK_3, OCM_READ_PERMISSION_0); + __raw_writel(UNLOCK_3, OCM_WRITE_PERMISSION_0); + __raw_writel(UNLOCK_2, OCM_ADDR_MATCH_2); + + /* IVA Changes */ + __raw_writel(UNLOCK_3, IVA2_REQ_INFO_PERMISSION_0); + __raw_writel(UNLOCK_3, IVA2_READ_PERMISSION_0); + __raw_writel(UNLOCK_3, IVA2_WRITE_PERMISSION_0); + + __raw_writel(UNLOCK_1, SMS_RG_ATT0); /* SDRC region 0 public */ +} + +/** + * @brief Come out of secure mode + * If chip is EMU and boot type is external configure + * secure registers and exit secure world general use. + * + * @return void + */ +static void secureworld_exit(void) +{ + unsigned long i; + + /* configrue non-secure access control register */ + __asm__ __volatile__("mrc p15, 0, %0, c1, c1, 2":"=r"(i)); + /* enabling co-processor CP10 and CP11 accesses in NS world */ + __asm__ __volatile__("orr %0, %0, #0xC00":"=r"(i)); + /* allow allocation of locked TLBs and L2 lines in NS world */ + /* allow use of PLE registers in NS world also */ + __asm__ __volatile__("orr %0, %0, #0x70000":"=r"(i)); + __asm__ __volatile__("mcr p15, 0, %0, c1, c1, 2":"=r"(i)); + + /* Enable ASA in ACR register */ + __asm__ __volatile__("mrc p15, 0, %0, c1, c0, 1":"=r"(i)); + __asm__ __volatile__("orr %0, %0, #0x10":"=r"(i)); + __asm__ __volatile__("mcr p15, 0, %0, c1, c0, 1":"=r"(i)); + + /* Exiting secure world */ + __asm__ __volatile__("mrc p15, 0, %0, c1, c1, 0":"=r"(i)); + __asm__ __volatile__("orr %0, %0, #0x31":"=r"(i)); + __asm__ __volatile__("mcr p15, 0, %0, c1, c1, 0":"=r"(i)); +} + +/** + * @brief Shut down the watchdogs + * + * There are 3 watch dogs WD1=Secure, WD2=MPU, WD3=IVA. WD1 is + * either taken care of by ROM (HS/EMU) or not accessible (GP). + * We need to take care of WD2-MPU or take a PRCM reset. WD3 + * should not be running and does not generate a PRCM reset. + * + * @return void + */ +static void watchdog_init(void) +{ + int pending = 1; + + sr32(CM_REG(FCLKEN_WKUP), 5, 1, 1); + sr32(CM_REG(ICLKEN_WKUP), 5, 1, 1); + wait_on_value(BIT5, 0x20, CM_REG(IDLEST_WKUP), 5); + + __raw_writel(WDT_DISABLE_CODE1, WDT_REG(WSPR)); + + do { + pending = __raw_readl(WDT_REG(WWPS)); + } while (pending); + + __raw_writel(WDT_DISABLE_CODE2, WDT_REG(WSPR)); +} + +/** + * @brief Write to AuxCR desired value using SMI. + * general use. + * + * @return void + */ +static void setup_auxcr(void) +{ + unsigned long i; + volatile unsigned int j; + /* Save r0, r12 and restore them after usage */ + __asm__ __volatile__("mov %0, r12":"=r"(j)); + __asm__ __volatile__("mov %0, r0":"=r"(i)); + + /* GP Device ROM code API usage here */ + /* r12 = AUXCR Write function and r0 value */ + __asm__ __volatile__("mov r12, #0x3"); + __asm__ __volatile__("mrc p15, 0, r0, c1, c0, 1"); + /* Enabling ASA */ + __asm__ __volatile__("orr r0, r0, #0x10"); + /* SMI instruction to call ROM Code API */ + __asm__ __volatile__(".word 0xE1600070"); + __asm__ __volatile__("mov r0, %0":"=r"(i)); + __asm__ __volatile__("mov r12, %0":"=r"(j)); +} + +/** + * @brief Try to unlock the SRAM for general use + * + * If chip is GP/EMU(special) type, unlock the SRAM for + * general use. + * + * @return void + */ +static void try_unlock_memory(void) +{ + int mode; + int in_sdram = running_in_sdram(); + + /* if GP device unlock device SRAM for general use */ + /* secure code breaks for Secure/Emulation device - HS/E/T */ + mode = get_device_type(); + if (mode == GP_DEVICE) + secure_unlock_mem(); + /* If device is EMU and boot is XIP external booting + * Unlock firewalls and disable L2 and put chip + * out of secure world + */ + /* Assuming memories are unlocked by the demon who put us in SDRAM */ + if ((mode <= EMU_DEVICE) && (get_boot_type() == 0x1F) + && (!in_sdram)) { + secure_unlock_mem(); + secureworld_exit(); + } + + return; +} + +/** + * @brief OMAP3 Architecture specific Initialization + * + * Does early system init of disabling the watchdog, enable + * memory and configuring the clocks. + * + * prcm_init is called only if CONFIG_OMAP3_CLOCK_CONFIG is defined. + * We depend on link time clean up to remove a_init if no caller exists. + * + * @warning Called path is with SRAM stack + * + * @return void + */ +void a_init(void) +{ + watchdog_init(); + + try_unlock_memory(); + + /* Writing to AuxCR in U-boot using SMI for GP DEV */ + /* Currently SMI in Kernel on ES2 devices seems to have an isse + * Once that is resolved, we can postpone this config to kernel + */ + if (get_device_type() == GP_DEVICE) + setup_auxcr(); + + sdelay(100); + +#ifdef CONFIG_OMAP3_CLOCK_CONFIG + prcm_init(); +#endif + +} Index: u-boot-v2.git/arch/arm/mach-omap/syslib.c =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot-v2.git/arch/arm/mach-omap/syslib.c 2008-05-28 10:19:05.000000000 -0500 @@ -0,0 +1,97 @@ +/** + * @file + * @brief Provide OMAP independent utility APIs + * + * FileName: arch/arm/mach-omap/syslib.c + * + * Provide APIs which can be used from platform/architecture code + * to operate on + * + * Originally from http://linux.omap.com/pub/bootloader/3430sdp/u-boot-v1.tar.gz + */ +/* + * (C) Copyright 2006-2008 + * Texas Instruments, <www.ti.com> + * Richard Woodruff r-woodruff2@ti.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/io.h> +#include <asm/arch/syslib.h> + +/** + * @brief simple spin loop + * + * Will be constant time as its generally used in bypass conditions only. + * This is necessary until timers are accessible. if you need timed delays + * use @ref mdelay or @udelay instead + * + * @param[in] loops number of loops + * + * @return void + */ +void sdelay(unsigned long loops) +{ + __asm__ volatile ("1:\n" "subs %0, %1, #1\n" + "bne 1b":"=r" (loops):"0"(loops)); +} + +/** + * @brief clear & set a value in a bit range for a 32 bit address + * + * @param[in] addr Address to set/read from + * @param[in] start_bit Where to put the value + * @param[in] num_bits number of bits the value should be set + * @param[in] value the value to set + * + * @return void + */ +void sr32(u32 addr, u32 start_bit, u32 num_bits, u32 value) +{ + u32 tmp, msk = 0; + msk = 1 << num_bits; + --msk; + tmp = __raw_readl(addr) & ~(msk << start_bit); + tmp |= value << start_bit; + __raw_writel(tmp, addr); +} + +/** + * @brief common routine to allow waiting for changes in volatile regs. + * + * @param[in] read_bit_mask the bit mask to read + * @param[in] match_value match to which value + * @param[in] read_addr address to read from + * @param[in] bound max iterations + * + * @return 1 if match_value is found, else if bound iterations reached, + * returns 0 + */ +u32 wait_on_value(u32 read_bit_mask, u32 match_value, u32 read_addr, u32 bound) +{ + u32 i = 0, val; + do { + ++i; + val = __raw_readl(read_addr) & read_bit_mask; + if (val == match_value) + return (1); + if (i == bound) + return (0); + } while (1); +} +
Looks ok to me besides the occurences of return with the value in brackets.
Sascha
- depends on ARCH_OMAP
+choice
- prompt "Select OMAP Variant"
+config ARCH_OMAP3
- bool "OMAP3"
- select ARMCORTEXA8
- select ARCH_HAS_LOWLEVEL_INIT
- help
+endchoice
- prompt "STACKSIZE"
- hex
- default 0x00020000
- help
- prompt "MALLOC LENGTH"
- hex
- default 0x00001000
- help
- prompt "ARCH TEXT BASE"
- hex
- default 0x80e80000
- help
- bool "Clock Configuration"
- help
- @file
- @brief Provide Architecture level Initialization
- FileName: arch/arm/mach-omap/omap3_core.S
- This provides OMAP3 Architecture initialization. Among these,
- @li OMAP ROM Code is located in SRAM, we can piggy back on
- the same addresses
- @li If clock initialization is required, call the same.
- @li Setup a temporary SRAM stack which is necessary to call C
- functions.
- @li Call architecture initialization function a_init
- arch_init_lowlevel is enabled if CONFIG_ARCH_HAS_LOWLEVEL_INIT is defined
- cpy_clk_code is called if CONFIG_OMAP3_COPY_CLOCK_SRAM is defined
- (C) Copyright 2006-2008
- Texas Instruments, <www.ti.com>
- Nishanth Menon x0nishan@ti.com
- MA 02111-1307 USA
- mov r0, pc /* Store the current pc address */
- ldr r1, arch_start /* Load the link address for arch_int */
- ldr r2, uboot_start /* load the link address of start_init*/
- sub r1, r1, r2 /* get the offset */
- /* subtract the offset from PC of arch=Current start */
- sub r0, r0, r1
- mov r2, #OMAP_SRAM_INTVECT_COPYSIZE /* r2 <- size to copy */
- add r2, r0, r2 /* r2 <- source end address */
- ldr r1, SRAM_INTVECT /* build vect addr */
+next:
- ldmia r0!, {r3-r10} /* copy from source address [r0] */
- stmia r1!, {r3-r10} /* copy to target address [r1] */
- cmp r0, r2 /* until source end address [r2] */
- ble next /* loop until equal */
- /* No need to copy/exec the clock code - DPLL adjust already done
- bl cpy_clk_code
- /* Read the interrupt vector base address */
- mrc p15, #0, r0, c12, c0, #0
- /* Clear the vector base 4:0 is reserved. */
- and r0, r0, #0xF
- /* Store the SRAM_INTVECT address */
- orr r0, r0, r1
- /* Store the new vector address */
- mcr p15, #0, r0, c12, c0, #0
- /* Setup a temporary stack so that we can call C functions */
- ldr sp, SRAM_STACK
- mov ip, lr /* save link reg across call */
- bl a_init /* Architecture init */
- /* back to arch calling code */
- mov pc, lr
+arch_start:
- .word arch_init_lowlevel
+uboot_start:
- .word _start
+SRAM_INTVECT:
- .word OMAP_SRAM_INTVECT
+SRAM_STACK:
- .word OMAP_SRAM_STACK
- @file
- @brief Provide Generic implementations for OMAP3 architecture
- FileName: arch/arm/mach-omap/omap3_generic.c
- This file contains the generic implementations of various OMAP3
- relevant functions
- For more info on OMAP34XX, see http://focus.ti.com/pdfs/wtbu/swpu114g.pdf
- Important one is @ref a_init which is architecture init code.
- The implemented functions are present in sys_info.h
- Originally from http://linux.omap.com/pub/bootloader/3430sdp/u-boot-v1.tar.gz
- Richard Woodruff r-woodruff2@ti.com
- MA 02111-1307 USA
- @brief Reset the CPU
- In case of crashes, reset the CPU
- @param[in] addr -Cause of crash
- @return void
- /* FIXME: Enable WDT and cause reset */
- hang();
- @brief Low level CPU type
- @return CPU_3430
- /* FIXME: need to get register defines for 3430 */
- return (CPU_3430);
- @brief Extract the OMAP ES rev
- @return CPU_ES version
- u32 idcode_val;
- idcode_val = __raw_readl(IDCODE_REG);
- if ((idcode_val & (HAWKEYE_MASK | VERSION_MASK)) == HAWKEYE_ES2_1)
return CPU_ES2P1;
- if ((idcode_val & HAWKEYE_MASK) == HAWKEYE_ES2)
return CPU_ES2;
- /* unsupported! */
- return CPU_ES1;
- @brief Get size of chip select 0/1
- @param[in] offset give the offset if we need CS1
- @return return the sdram size.
- u32 size;
- /* get ram size field */
- size = __raw_readl(SDRC_REG(MCFG_0) + offset) >> 8;
- size &= 0x3FF; /* remove unwanted bits */
- size *= 2 * (1024 * 1024); /* find size in MB */
- return (size);
- @brief Get the initial SYSBOOT value
- SYSBOOT is useful to know which state OMAP booted from.
- @return - Return the value of SYSBOOT.
- return (0x0000003F & __raw_readl(CONTROL_REG(STATUS)));
- @brief Return the current CS0 base address
- Return current address hardware will be
- fetching from. The below effectively gives what is correct, its a bit
- mis-leading compared to the TRM. For the most general case the mask
- needs to be also taken into account this does work in practice.
- @return base address
- u32 b;
- b = __raw_readl(GPMC_REG(CONFIG7_0));
- b &= 0x1F; /* keep base [5:0] */
- b = b << 24; /* ret 0x0b000000 */
- return (b);
- @brief Get the upper address of current execution
- we can use this to figure out if we are running in SRAM /
- XIP Flash or in SDRAM
- u32 val;
- __asm__ __volatile__("mov %0, pc \n":"=r"(val)::"memory");
- val &= 0xF0000000;
- val >>= 28;
- return (val);
- @brief Are we running in Flash XIP?
- If the base is in GPMC address space, we probably are!
- @return 1 if we are running in XIP mode, else return 0
- if (get_base() < 4)
- return (0); /* running in SRAM or SDRAM */
- @brief Are we running in OMAP internal SRAM?
- If in SRAM address, then yes!
- @return 1 if we are running in SRAM, else return 0
- if (get_base() == 4)
- return (0); /* running in FLASH or SDRAM */
- @brief Are we running in SDRAM?
- if we are not in GPMC nor in SRAM address space,
- we are in SDRAM execution area
- @return 1 if we are running from SDRAM, else return 0
- if (get_base() > 4)
- return (0); /* running in SRAM or FLASH */
- @brief Is this an XIP type device or a stream one
- Sysboot bits 4-0 specify type. Bit 5, sys mem/perif
- @return Boot type
- u32 v;
- v = get_sysboot_value() & (BIT4 | BIT3 | BIT2 | BIT1 | BIT0);
- return v;
- @brief What type of device are we?
- are we on a GP/HS/EMU/TEST device?
- @return device type
- int mode;
- mode = __raw_readl(CONTROL_REG(STATUS)) & (DEVICE_MASK);
- return (mode >>= 8);
- @brief Setup security registers for access
- This can be done for GP Device only. for HS/EMU devices, read TRM.
- @return void
- /* Permission values for registers -Full fledged permissions to all */
- /* Protection Module Register Target APE (PM_RT) */
- __raw_writel(UNLOCK_1, RT_REQ_INFO_PERMISSION_1);
- __raw_writel(UNLOCK_1, RT_READ_PERMISSION_0);
- __raw_writel(UNLOCK_1, RT_WRITE_PERMISSION_0);
- __raw_writel(UNLOCK_2, RT_ADDR_MATCH_1);
- __raw_writel(UNLOCK_3, GPMC_REQ_INFO_PERMISSION_0);
- __raw_writel(UNLOCK_3, GPMC_READ_PERMISSION_0);
- __raw_writel(UNLOCK_3, GPMC_WRITE_PERMISSION_0);
- __raw_writel(UNLOCK_3, OCM_REQ_INFO_PERMISSION_0);
- __raw_writel(UNLOCK_3, OCM_READ_PERMISSION_0);
- __raw_writel(UNLOCK_3, OCM_WRITE_PERMISSION_0);
- __raw_writel(UNLOCK_2, OCM_ADDR_MATCH_2);
- /* IVA Changes */
- __raw_writel(UNLOCK_3, IVA2_REQ_INFO_PERMISSION_0);
- __raw_writel(UNLOCK_3, IVA2_READ_PERMISSION_0);
- __raw_writel(UNLOCK_3, IVA2_WRITE_PERMISSION_0);
- __raw_writel(UNLOCK_1, SMS_RG_ATT0); /* SDRC region 0 public */
- @brief Come out of secure mode
- If chip is EMU and boot type is external configure
- secure registers and exit secure world general use.
- @return void
- unsigned long i;
- /* configrue non-secure access control register */
- __asm__ __volatile__("mrc p15, 0, %0, c1, c1, 2":"=r"(i));
- /* enabling co-processor CP10 and CP11 accesses in NS world */
- __asm__ __volatile__("orr %0, %0, #0xC00":"=r"(i));
- /* allow allocation of locked TLBs and L2 lines in NS world */
- /* allow use of PLE registers in NS world also */
- __asm__ __volatile__("orr %0, %0, #0x70000":"=r"(i));
- __asm__ __volatile__("mcr p15, 0, %0, c1, c1, 2":"=r"(i));
- /* Enable ASA in ACR register */
- __asm__ __volatile__("mrc p15, 0, %0, c1, c0, 1":"=r"(i));
- __asm__ __volatile__("orr %0, %0, #0x10":"=r"(i));
- __asm__ __volatile__("mcr p15, 0, %0, c1, c0, 1":"=r"(i));
- /* Exiting secure world */
- __asm__ __volatile__("mrc p15, 0, %0, c1, c1, 0":"=r"(i));
- __asm__ __volatile__("orr %0, %0, #0x31":"=r"(i));
- __asm__ __volatile__("mcr p15, 0, %0, c1, c1, 0":"=r"(i));
- @brief Shut down the watchdogs
- There are 3 watch dogs WD1=Secure, WD2=MPU, WD3=IVA. WD1 is
- either taken care of by ROM (HS/EMU) or not accessible (GP).
- We need to take care of WD2-MPU or take a PRCM reset. WD3
- should not be running and does not generate a PRCM reset.
- @return void
- int pending = 1;
- sr32(CM_REG(FCLKEN_WKUP), 5, 1, 1);
- sr32(CM_REG(ICLKEN_WKUP), 5, 1, 1);
- wait_on_value(BIT5, 0x20, CM_REG(IDLEST_WKUP), 5);
- __raw_writel(WDT_DISABLE_CODE1, WDT_REG(WSPR));
- do {
- } while (pending);
- __raw_writel(WDT_DISABLE_CODE2, WDT_REG(WSPR));
- @brief Write to AuxCR desired value using SMI.
- general use.
- @return void
- unsigned long i;
- volatile unsigned int j;
- /* Save r0, r12 and restore them after usage */
- __asm__ __volatile__("mov %0, r12":"=r"(j));
- __asm__ __volatile__("mov %0, r0":"=r"(i));
- /* GP Device ROM code API usage here */
- /* r12 = AUXCR Write function and r0 value */
- __asm__ __volatile__("mov r12, #0x3");
- __asm__ __volatile__("mrc p15, 0, r0, c1, c0, 1");
- /* Enabling ASA */
- __asm__ __volatile__("orr r0, r0, #0x10");
- /* SMI instruction to call ROM Code API */
- __asm__ __volatile__(".word 0xE1600070");
- __asm__ __volatile__("mov r0, %0":"=r"(i));
- __asm__ __volatile__("mov r12, %0":"=r"(j));
- @brief Try to unlock the SRAM for general use
- If chip is GP/EMU(special) type, unlock the SRAM for
- general use.
- @return void
- int mode;
- int in_sdram = running_in_sdram();
- /* if GP device unlock device SRAM for general use */
- /* secure code breaks for Secure/Emulation device - HS/E/T */
- mode = get_device_type();
- if (mode == GP_DEVICE)
- /* If device is EMU and boot is XIP external booting
- /* Assuming memories are unlocked by the demon who put us in SDRAM */
- if ((mode <= EMU_DEVICE) && (get_boot_type() == 0x1F)
&& (!in_sdram)) {
secureworld_exit();
- return;
- @brief OMAP3 Architecture specific Initialization
- Does early system init of disabling the watchdog, enable
- memory and configuring the clocks.
- prcm_init is called only if CONFIG_OMAP3_CLOCK_CONFIG is defined.
- We depend on link time clean up to remove a_init if no caller exists.
- @warning Called path is with SRAM stack
- @return void
- watchdog_init();
- try_unlock_memory();
- /* Writing to AuxCR in U-boot using SMI for GP DEV */
- /* Currently SMI in Kernel on ES2 devices seems to have an isse
- if (get_device_type() == GP_DEVICE)
setup_auxcr();
- sdelay(100);
- prcm_init();
- @file
- @brief Provide OMAP independent utility APIs
- FileName: arch/arm/mach-omap/syslib.c
- Provide APIs which can be used from platform/architecture code
- to operate on
- MA 02111-1307 USA
- @brief simple spin loop
- Will be constant time as its generally used in bypass conditions only.
- This is necessary until timers are accessible. if you need timed delays
- use @ref mdelay or @udelay instead
- @param[in] loops number of loops
- @return void
- __asm__ volatile ("1:\n" "subs %0, %1, #1\n"
- @brief clear & set a value in a bit range for a 32 bit address
- @param[in] addr Address to set/read from
- @param[in] start_bit Where to put the value
- @param[in] num_bits number of bits the value should be set
- @param[in] value the value to set
- @return void
- u32 tmp, msk = 0;
- msk = 1 << num_bits;
- --msk;
- tmp = __raw_readl(addr) & ~(msk << start_bit);
- tmp |= value << start_bit;
- __raw_writel(tmp, addr);
- @brief common routine to allow waiting for changes in volatile regs.
- @param[in] read_bit_mask the bit mask to read
- @param[in] match_value match to which value
- @param[in] read_addr address to read from
- @param[in] bound max iterations
- @return 1 if match_value is found, else if bound iterations reached,
returns 0
- u32 i = 0, val;
- do {
++i;
return (1);
if (i == bound)
return (0);
- } while (1);
Sascha,
-----Original Message----- From: Sascha Hauer [mailto:s.hauer@pengutronix.de] Sent: Tuesday, June 03, 2008 3:18 AM To: Menon, Nishanth Cc: Peter Pearse; u-boot-users@lists.sourceforge.net; Kamat, Nishant; Syed Mohammed, Khasim; Laurent Desnogues; philip.balister@gmail.com Subject: Re: [Patch 11/17 Try 2] U-Boot-V2:ARM:OMAP3: Add support for OMAP3Silicon files
Sascha
Arrgh.. I have myself to blame for inconsistent return styles. Probably we need an equivalent of checkpatch and a Lindent for U-Boot v2? I suppose the right style is return without brackets?
Regards, Nishanth Menon
On Tue, Jun 03, 2008 at 10:36:05AM -0500, Menon, Nishanth wrote:
Sascha,
Sascha
Yes it is, but that's somewhere on the boarder to nitpicking, don't know which side though ;)
Sascha,
-----Original Message----- From: Sascha Hauer [mailto:s.hauer@pengutronix.de] Sent: Tuesday, June 03, 2008 12:49 PM To: Menon, Nishanth Cc: Peter Pearse; u-boot-users@lists.sourceforge.net; Kamat, Nishant; Syed Mohammed, Khasim; Laurent Desnogues; philip.balister@gmail.com Subject: Re: [Patch 11/17 Try 2] U-Boot-V2:ARM:OMAP3: Add support forOMAP3Silicon files
Sascha,
Laurent
Sascha
With the cleanups :(.
--- arch/arm/mach-omap/Kconfig | 65 +++++ arch/arm/mach-omap/Makefile | 25 ++ arch/arm/mach-omap/omap3_core.S | 101 ++++++++ arch/arm/mach-omap/omap3_generic.c | 450 +++++++++++++++++++++++++++++++++++++ arch/arm/mach-omap/syslib.c | 97 +++++++ 5 files changed, 738 insertions(+)
Index: u-boot.v2/arch/arm/mach-omap/Kconfig =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot.v2/arch/arm/mach-omap/Kconfig 2008-06-03 22:47:24.000000000 -0500 @@ -0,0 +1,65 @@ +# +# OMAP Architecture specific features +# +# (C) Copyright 2008 +# Texas Instruments, <www.ti.com> +# Nishanth Menon x0nishan@ti.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA + +menu "OMAP Features" + depends on ARCH_OMAP + +choice + prompt "Select OMAP Variant" + +config ARCH_OMAP3 + bool "OMAP3" + select ARMCORTEXA8 + select ARCH_HAS_LOWLEVEL_INIT + help + Say Y here if you are using Texas Instrument's OMAP343x based platform + +endchoice + +config OMAP_CONFIG_STACKSIZE + prompt "STACKSIZE" + hex + default 0x00020000 + help + Select the Stack Size + +config OMAP_MALLOC_LEN + prompt "MALLOC LENGTH" + hex + default 0x00001000 + help + Select the Malloc Length + +config ARCH_TEXT_BASE + prompt "ARCH TEXT BASE" + hex + default 0x80e80000 + help + Select the load address + +config OMAP3_CLOCK_CONFIG + depends on ARCH_OMAP + bool "Clock Configuration" + help + Say Y here if you like to have OMAP3 Clock configuration done. + +endmenu Index: u-boot.v2/arch/arm/mach-omap/Makefile =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot.v2/arch/arm/mach-omap/Makefile 2008-06-03 22:47:24.000000000 -0500 @@ -0,0 +1,25 @@ +# OMAP Architecture Makefile +# +# (C) Copyright 2008 +# Texas Instruments, <www.ti.com> +# Nishanth Menon x0nishan@ti.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +obj-$(CONFIG_ARCH_OMAP) += syslib.o +obj-$(CONFIG_OMAP_CLOCK_SOURCE_S32K) += s32k_clksource.o +obj-$(CONFIG_ARCH_OMAP3) += omap3_core.o omap3_generic.o +obj-$(CONFIG_OMAP3_CLOCK_CONFIG) += omap3_clock_core.o omap3_clock.o Index: u-boot.v2/arch/arm/mach-omap/omap3_core.S =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot.v2/arch/arm/mach-omap/omap3_core.S 2008-06-03 22:47:24.000000000 -0500 @@ -0,0 +1,101 @@ +/** + * @file + * @brief Provide Architecture level Initialization + * + * FileName: arch/arm/mach-omap/omap3_core.S + * + * This provides OMAP3 Architecture initialization. Among these, + * @li OMAP ROM Code is located in SRAM, we can piggy back on + * the same addresses + * @li If clock initialization is required, call the same. + * @li Setup a temporary SRAM stack which is necessary to call C + * functions. + * @li Call architecture initialization function a_init + * + * arch_init_lowlevel is enabled if CONFIG_ARCH_HAS_LOWLEVEL_INIT is defined + * cpy_clk_code is called if CONFIG_OMAP3_COPY_CLOCK_SRAM is defined + */ +/* + * (C) Copyright 2006-2008 + * Texas Instruments, <www.ti.com> + * Nishanth Menon x0nishan@ti.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/arch/silicon.h> +#include <asm/arch/wdt.h> +#include <asm/arch/clocks.h> + +#ifdef CONFIG_ARCH_HAS_LOWLEVEL_INIT +.globl arch_init_lowlevel +arch_init_lowlevel: + /* Copy vectors to mask ROM indirect addr */ + mov r0, pc /* Store the current pc address */ + sub r0, r0, #8 /* Reduce offset */ + ldr r1, arch_start /* Load the link address for arch_int */ + ldr r2, uboot_start /* load the link address of start_init*/ + sub r1, r1, r2 /* get the offset */ + /* subtract the offset from PC of arch=Current start */ + sub r0, r0, r1 + mov r2, #OMAP_SRAM_INTVECT_COPYSIZE /* r2 <- size to copy */ + add r2, r0, r2 /* r2 <- source end address */ + ldr r1, SRAM_INTVECT /* build vect addr */ +next: + ldmia r0!, {r3-r10} /* copy from source address [r0] */ + stmia r1!, {r3-r10} /* copy to target address [r1] */ + cmp r0, r2 /* until source end address [r2] */ + ble next /* loop until equal */ + +#ifdef CONFIG_OMAP3_COPY_CLOCK_SRAM + /* No need to copy/exec the clock code - DPLL adjust already done + * in Perip/NAND/oneNAND Boot. + * Put dpll adjust code behind vectors. r1 has address to copy to + */ + bl cpy_clk_code +#endif + ldr r1, SRAM_INTVECT /* build vect addr */ + /* Read the interrupt vector base address */ + mrc p15, #0, r0, c12, c0, #0 + /* Clear the vector base 4:0 is reserved. */ + and r0, r0, #0xF + /* Store the SRAM_INTVECT address */ + orr r0, r0, r1 + /* Store the new vector address */ + mcr p15, #0, r0, c12, c0, #0 + /* Setup a temporary stack so that we can call C functions */ + ldr sp, SRAM_STACK + str ip, [sp] /* stash old link register */ + str lr, [sp] /* stash current link register */ + mov ip, lr /* save link reg across call */ + bl a_init /* Architecture init */ + ldr lr, [sp] /* restore current link register */ + ldr ip, [sp] /* restore save ip */ + + /* back to arch calling code */ + mov pc, lr + +arch_start: + .word arch_init_lowlevel +uboot_start: + .word _start +SRAM_INTVECT: + .word OMAP_SRAM_INTVECT + +SRAM_STACK: + .word OMAP_SRAM_STACK +#endif /* CONFIG_ARCH_HAS_LOWLEVEL_INIT */ Index: u-boot.v2/arch/arm/mach-omap/omap3_generic.c =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot.v2/arch/arm/mach-omap/omap3_generic.c 2008-06-03 22:48:42.000000000 -0500 @@ -0,0 +1,450 @@ +/** + * @file + * @brief Provide Generic implementations for OMAP3 architecture + * + * FileName: arch/arm/mach-omap/omap3_generic.c + * + * This file contains the generic implementations of various OMAP3 + * relevant functions + * For more info on OMAP34XX, see http://focus.ti.com/pdfs/wtbu/swpu114g.pdf + * + * Important one is @ref a_init which is architecture init code. + * The implemented functions are present in sys_info.h + * + * Originally from http://linux.omap.com/pub/bootloader/3430sdp/u-boot-v1.tar.gz + */ +/* + * (C) Copyright 2006-2008 + * Texas Instruments, <www.ti.com> + * Richard Woodruff r-woodruff2@ti.com + * Nishanth Menon x0nishan@ti.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <init.h> +#include <asm/io.h> +#include <asm/arch/silicon.h> +#include <asm/arch/gpmc.h> +#include <asm/arch/sdrc.h> +#include <asm/arch/control.h> +#include <asm/arch/omap3-smx.h> +#include <asm/arch/clocks.h> +#include <asm/arch/wdt.h> +#include <asm/arch/sys_info.h> +#include <asm/arch/syslib.h> + +/** + * @brief Reset the CPU + * + * In case of crashes, reset the CPU + * + * @param[in] addr -Cause of crash + * + * @return void + */ +void reset_cpu(ulong addr) +{ + /* FIXME: Enable WDT and cause reset */ + hang(); +} +EXPORT_SYMBOL(reset_cpu); + +/** + * @brief Low level CPU type + * + * @return CPU_3430 + */ +u32 get_cpu_type(void) +{ + /* FIXME: need to get register defines for 3430 */ + return CPU_3430; +} + +/** + * @brief Extract the OMAP ES rev + * + * @return CPU_ES version + */ +u32 get_cpu_rev(void) +{ + u32 idcode_val; + idcode_val = __raw_readl(IDCODE_REG); + if ((idcode_val & (HAWKEYE_MASK | VERSION_MASK)) == HAWKEYE_ES2_1) + return CPU_ES2P1; + if ((idcode_val & HAWKEYE_MASK) == HAWKEYE_ES2) + return CPU_ES2; + /* unsupported! */ + return CPU_ES1; +} + +/** + * @brief Get size of chip select 0/1 + * + * @param[in] offset give the offset if we need CS1 + * + * @return return the sdram size. + */ +u32 get_sdr_cs_size(u32 offset) +{ + u32 size; + /* get ram size field */ + size = __raw_readl(SDRC_REG(MCFG_0) + offset) >> 8; + size &= 0x3FF; /* remove unwanted bits */ + size *= 2 * (1024 * 1024); /* find size in MB */ + return size; +} + +/** + * @brief Get the initial SYSBOOT value + * + * SYSBOOT is useful to know which state OMAP booted from. + * + * @return - Return the value of SYSBOOT. + */ +inline u32 get_sysboot_value(void) +{ + return (0x0000003F & __raw_readl(CONTROL_REG(STATUS))); +} + +/** + * @brief Return the current CS0 base address + * + * Return current address hardware will be + * fetching from. The below effectively gives what is correct, its a bit + * mis-leading compared to the TRM. For the most general case the mask + * needs to be also taken into account this does work in practice. + * + * @return base address + */ +u32 get_gpmc0_base(void) +{ + u32 b; + b = __raw_readl(GPMC_REG(CONFIG7_0)); + b &= 0x1F; /* keep base [5:0] */ + b = b << 24; /* ret 0x0b000000 */ + return b; +} + +/** + * @brief Get the upper address of current execution + * + * we can use this to figure out if we are running in SRAM / + * XIP Flash or in SDRAM + * + * @return base address + */ +u32 get_base(void) +{ + u32 val; + __asm__ __volatile__("mov %0, pc \n":"=r"(val)::"memory"); + val &= 0xF0000000; + val >>= 28; + return val; +} + +/** + * @brief Are we running in Flash XIP? + * + * If the base is in GPMC address space, we probably are! + * + * @return 1 if we are running in XIP mode, else return 0 + */ +u32 running_in_flash(void) +{ + if (get_base() < 4) + return 1; /* in flash */ + return 0; /* running in SRAM or SDRAM */ +} + +/** + * @brief Are we running in OMAP internal SRAM? + * + * If in SRAM address, then yes! + * + * @return 1 if we are running in SRAM, else return 0 + */ +u32 running_in_sram(void) +{ + if (get_base() == 4) + return 1; /* in SRAM */ + return 0; /* running in FLASH or SDRAM */ +} + +/** + * @brief Are we running in SDRAM? + * + * if we are not in GPMC nor in SRAM address space, + * we are in SDRAM execution area + * + * @return 1 if we are running from SDRAM, else return 0 + */ +u32 running_in_sdram(void) +{ + if (get_base() > 4) + return 1; /* in sdram */ + return 0; /* running in SRAM or FLASH */ +} +EXPORT_SYMBOL(running_in_sdram); + +/** + * @brief Is this an XIP type device or a stream one + * + * Sysboot bits 4-0 specify type. Bit 5, sys mem/perif + * + * @return Boot type + */ +u32 get_boot_type(void) +{ + u32 v; + v = get_sysboot_value() & ((0x1 << 4) | (0x1 << 3) | (0x1 << 2) | + (0x1 << 1) | (0x1 << 0)); + return v; +} + +/** + * @brief What type of device are we? + * + * are we on a GP/HS/EMU/TEST device? + * + * @return device type + */ +u32 get_device_type(void) +{ + int mode; + mode = __raw_readl(CONTROL_REG(STATUS)) & (DEVICE_MASK); + return (mode >>= 8); +} + +/** + * @brief Setup security registers for access + * + * This can be done for GP Device only. for HS/EMU devices, read TRM. + * + * @return void + */ +static void secure_unlock_mem(void) +{ + /* Permission values for registers -Full fledged permissions to all */ +#define UNLOCK_1 0xFFFFFFFF +#define UNLOCK_2 0x00000000 +#define UNLOCK_3 0x0000FFFF + /* Protection Module Register Target APE (PM_RT) */ + __raw_writel(UNLOCK_1, RT_REQ_INFO_PERMISSION_1); + __raw_writel(UNLOCK_1, RT_READ_PERMISSION_0); + __raw_writel(UNLOCK_1, RT_WRITE_PERMISSION_0); + __raw_writel(UNLOCK_2, RT_ADDR_MATCH_1); + + __raw_writel(UNLOCK_3, GPMC_REQ_INFO_PERMISSION_0); + __raw_writel(UNLOCK_3, GPMC_READ_PERMISSION_0); + __raw_writel(UNLOCK_3, GPMC_WRITE_PERMISSION_0); + + __raw_writel(UNLOCK_3, OCM_REQ_INFO_PERMISSION_0); + __raw_writel(UNLOCK_3, OCM_READ_PERMISSION_0); + __raw_writel(UNLOCK_3, OCM_WRITE_PERMISSION_0); + __raw_writel(UNLOCK_2, OCM_ADDR_MATCH_2); + + /* IVA Changes */ + __raw_writel(UNLOCK_3, IVA2_REQ_INFO_PERMISSION_0); + __raw_writel(UNLOCK_3, IVA2_READ_PERMISSION_0); + __raw_writel(UNLOCK_3, IVA2_WRITE_PERMISSION_0); + + __raw_writel(UNLOCK_1, SMS_RG_ATT0); /* SDRC region 0 public */ +} + +/** + * @brief Come out of secure mode + * If chip is EMU and boot type is external configure + * secure registers and exit secure world general use. + * + * @return void + */ +static void secureworld_exit(void) +{ + unsigned long i; + + /* configrue non-secure access control register */ + __asm__ __volatile__("mrc p15, 0, %0, c1, c1, 2":"=r"(i)); + /* enabling co-processor CP10 and CP11 accesses in NS world */ + __asm__ __volatile__("orr %0, %0, #0xC00":"=r"(i)); + /* allow allocation of locked TLBs and L2 lines in NS world */ + /* allow use of PLE registers in NS world also */ + __asm__ __volatile__("orr %0, %0, #0x70000":"=r"(i)); + __asm__ __volatile__("mcr p15, 0, %0, c1, c1, 2":"=r"(i)); + + /* Enable ASA in ACR register */ + __asm__ __volatile__("mrc p15, 0, %0, c1, c0, 1":"=r"(i)); + __asm__ __volatile__("orr %0, %0, #0x10":"=r"(i)); + __asm__ __volatile__("mcr p15, 0, %0, c1, c0, 1":"=r"(i)); + + /* Exiting secure world */ + __asm__ __volatile__("mrc p15, 0, %0, c1, c1, 0":"=r"(i)); + __asm__ __volatile__("orr %0, %0, #0x31":"=r"(i)); + __asm__ __volatile__("mcr p15, 0, %0, c1, c1, 0":"=r"(i)); +} + +/** + * @brief Shut down the watchdogs + * + * There are 3 watch dogs WD1=Secure, WD2=MPU, WD3=IVA. WD1 is + * either taken care of by ROM (HS/EMU) or not accessible (GP). + * We need to take care of WD2-MPU or take a PRCM reset. WD3 + * should not be running and does not generate a PRCM reset. + * + * @return void + */ +static void watchdog_init(void) +{ + int pending = 1; + + sr32(CM_REG(FCLKEN_WKUP), 5, 1, 1); + sr32(CM_REG(ICLKEN_WKUP), 5, 1, 1); + wait_on_value((0x1 << 5), 0x20, CM_REG(IDLEST_WKUP), 5); + + __raw_writel(WDT_DISABLE_CODE1, WDT_REG(WSPR)); + + do { + pending = __raw_readl(WDT_REG(WWPS)); + } while (pending); + + __raw_writel(WDT_DISABLE_CODE2, WDT_REG(WSPR)); +} + +/** + * @brief Write to AuxCR desired value using SMI. + * general use. + * + * @return void + */ +static void setup_auxcr(void) +{ + unsigned long i; + volatile unsigned int j; + /* Save r0, r12 and restore them after usage */ + __asm__ __volatile__("mov %0, r12":"=r"(j)); + __asm__ __volatile__("mov %0, r0":"=r"(i)); + + /* GP Device ROM code API usage here */ + /* r12 = AUXCR Write function and r0 value */ + __asm__ __volatile__("mov r12, #0x3"); + __asm__ __volatile__("mrc p15, 0, r0, c1, c0, 1"); + /* Enabling ASA */ + __asm__ __volatile__("orr r0, r0, #0x10"); + /* SMI instruction to call ROM Code API */ + __asm__ __volatile__(".word 0xE1600070"); + __asm__ __volatile__("mov r0, %0":"=r"(i)); + __asm__ __volatile__("mov r12, %0":"=r"(j)); +} + +/** + * @brief Try to unlock the SRAM for general use + * + * If chip is GP/EMU(special) type, unlock the SRAM for + * general use. + * + * @return void + */ +static void try_unlock_memory(void) +{ + int mode; + int in_sdram = running_in_sdram(); + + /* if GP device unlock device SRAM for general use */ + /* secure code breaks for Secure/Emulation device - HS/E/T */ + mode = get_device_type(); + if (mode == GP_DEVICE) + secure_unlock_mem(); + /* If device is EMU and boot is XIP external booting + * Unlock firewalls and disable L2 and put chip + * out of secure world + */ + /* Assuming memories are unlocked by the demon who put us in SDRAM */ + if ((mode <= EMU_DEVICE) && (get_boot_type() == 0x1F) + && (!in_sdram)) { + secure_unlock_mem(); + secureworld_exit(); + } + + return; +} + +/** + * @brief OMAP3 Architecture specific Initialization + * + * Does early system init of disabling the watchdog, enable + * memory and configuring the clocks. + * + * prcm_init is called only if CONFIG_OMAP3_CLOCK_CONFIG is defined. + * We depend on link time clean up to remove a_init if no caller exists. + * + * @warning Called path is with SRAM stack + * + * @return void + */ +void a_init(void) +{ + watchdog_init(); + + try_unlock_memory(); + + /* Writing to AuxCR in U-boot using SMI for GP DEV */ + /* Currently SMI in Kernel on ES2 devices seems to have an isse + * Once that is resolved, we can postpone this config to kernel + */ + if (get_device_type() == GP_DEVICE) + setup_auxcr(); + + sdelay(100); + +#ifdef CONFIG_OMAP3_CLOCK_CONFIG + prcm_init(); +#endif + +} + +/** + * @brief Uart port register read function for OMAP3 + * + * @param base base address of UART + * @param reg_idx register index + * + * @return character read from register + */ +unsigned int omap_uart_read(unsigned long base, unsigned char reg_idx) +{ + unsigned int *reg_addr = (unsigned int *)base; + reg_addr += reg_idx; + return __raw_readb(reg_addr); +} +EXPORT_SYMBOL(omap_uart_read); + +/** + * @brief Uart port register write function for OMAP3 + * + * @param val value to write + * @param base base address of UART + * @param reg_idx register index + * + * @return void + */ +void omap_uart_write(unsigned int val, unsigned long base, + unsigned char reg_idx) +{ + unsigned int *reg_addr = (unsigned int *)base; + reg_addr += reg_idx; + __raw_writeb(val, reg_addr); +} +EXPORT_SYMBOL(omap_uart_write); Index: u-boot.v2/arch/arm/mach-omap/syslib.c =================================================================== --- /dev/null 1970-01-01 00:00:00.000000000 +0000 +++ u-boot.v2/arch/arm/mach-omap/syslib.c 2008-06-03 22:47:24.000000000 -0500 @@ -0,0 +1,97 @@ +/** + * @file + * @brief Provide OMAP independent utility APIs + * + * FileName: arch/arm/mach-omap/syslib.c + * + * Provide APIs which can be used from platform/architecture code + * to operate on + * + * Originally from http://linux.omap.com/pub/bootloader/3430sdp/u-boot-v1.tar.gz + */ +/* + * (C) Copyright 2006-2008 + * Texas Instruments, <www.ti.com> + * Richard Woodruff r-woodruff2@ti.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/io.h> +#include <asm/arch/syslib.h> + +/** + * @brief simple spin loop + * + * Will be constant time as its generally used in bypass conditions only. + * This is necessary until timers are accessible. if you need timed delays + * use @ref mdelay or @udelay instead + * + * @param[in] loops number of loops + * + * @return void + */ +void sdelay(unsigned long loops) +{ + __asm__ volatile ("1:\n" "subs %0, %1, #1\n" + "bne 1b":"=r" (loops):"0"(loops)); +} + +/** + * @brief clear & set a value in a bit range for a 32 bit address + * + * @param[in] addr Address to set/read from + * @param[in] start_bit Where to put the value + * @param[in] num_bits number of bits the value should be set + * @param[in] value the value to set + * + * @return void + */ +void sr32(u32 addr, u32 start_bit, u32 num_bits, u32 value) +{ + u32 tmp, msk = 0; + msk = 1 << num_bits; + --msk; + tmp = __raw_readl(addr) & ~(msk << start_bit); + tmp |= value << start_bit; + __raw_writel(tmp, addr); +} + +/** + * @brief common routine to allow waiting for changes in volatile regs. + * + * @param[in] read_bit_mask the bit mask to read + * @param[in] match_value match to which value + * @param[in] read_addr address to read from + * @param[in] bound max iterations + * + * @return 1 if match_value is found, else if bound iterations reached, + * returns 0 + */ +u32 wait_on_value(u32 read_bit_mask, u32 match_value, u32 read_addr, u32 bound) +{ + u32 i = 0, val; + do { + ++i; + val = __raw_readl(read_addr) & read_bit_mask; + if (val == match_value) + return 1; + if (i == bound) + return 0; + } while (1); +} +
Menon, Nishanth
Sascha Hauer
