[U-Boot-Users] [PATCH 2/2] Updated patch to add SBC8641D
Add support for Wind River's SBC8641D reference board.
Resend to add fixes per JDL.
Signed-off by: Joe Hamman joe.hamman@embeddedspecialties.com
diff -uprN -X dontdiff u-boot/doc/README.sbc8641d u-boot-esi/doc/README.sbc8641d --- u-boot/doc/README.sbc8641d 1969-12-31 18:00:00.000000000 -0600 +++ u-boot-esi/doc/README.sbc8641d 2007-08-06 08:30:50.000000000 -0500 @@ -0,0 +1,28 @@ +Wind River SBC8641D reference board +=========================== + +Created 06/14/2007 Joe Hamman +Copyright 2007, Embedded Specialties, Inc. +Copyright 2007 Wind River Systemes, Inc. +----------------------------- + +1. Building U-Boot +------------------ +The SBC8641D code is known to build using ELDK 4.1. + + $ make sbc8641d_config + Configuring for sbc8641d board... + + $ make + + +2. Switch and Jumper Settings +----------------------------- +All Jumpers & Switches are in their default positions. Please refer to +the board documentation for details. Some settings control CPU voltages +and settings may change with board revisions. + +3. Known limitations +-------------------- +PCI: + The PCI command may hang if no boards are present in either slot. diff -uprN -X dontdiff u-boot/drivers/tsec.h u-boot-esi/drivers/tsec.h --- u-boot/drivers/tsec.h 2007-07-31 08:19:57.000000000 -0500 +++ u-boot-esi/drivers/tsec.h 2007-07-31 06:20:48.000000000 -0500 @@ -70,7 +70,7 @@ #define miim_end -2 #define miim_read -1
-#define TBIPA_VALUE 0x1f +#define TBIPA_VALUE 0x1e #define MIIMCFG_INIT_VALUE 0x00000003 #define MIIMCFG_RESET 0x80000000
diff -uprN -X dontdiff u-boot/include/configs/sbc8641d.h u-boot-esi/include/configs/sbc8641d.h --- u-boot/include/configs/sbc8641d.h 1969-12-31 18:00:00.000000000 -0600 +++ u-boot-esi/include/configs/sbc8641d.h 2007-08-06 09:10:14.000000000 -0500 @@ -0,0 +1,595 @@ +/* + * Copyright 2006 Freescale Semiconductor. + * + * Srikanth Srinivasan (srikanth.srinivasan@freescale.com) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * SBC8641D board configuration file + * + * Make sure you change the MAC address and other network params first, + * search for CONFIG_ETHADDR, CONFIG_SERVERIP, etc in this file. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High Level Configuration Options */ +#define CONFIG_MPC86xx 1 /* MPC86xx */ +#define CONFIG_MPC8641 1 /* MPC8641 specific */ +#define CONFIG_SBC8641D 1 /* SBC8641D board specific */ +#define CONFIG_NUM_CPUS 2 /* Number of CPUs in the system */ +#define CONFIG_LINUX_RESET_VEC 0x100 /* Reset vector used by Linux */ + +#ifdef RUN_DIAG +#define CFG_DIAG_ADDR 0xff800000 +#endif + +#define CFG_RESET_ADDRESS 0xfff00100 + +#define CONFIG_PCI 1 + +#define CONFIG_TSEC_ENET /* tsec ethernet support */ +#define CONFIG_ENV_OVERWRITE + +#undef CONFIG_SPD_EEPROM /* Do not use SPD EEPROM for DDR setup*/ +#undef CONFIG_DDR_DLL /* possible DLL fix needed */ +#define CONFIG_DDR_2T_TIMING /* Sets the 2T timing bit */ +#undef CONFIG_DDR_ECC /* only for ECC DDR module */ +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER /* DDR controller or DMA? */ +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef +#define CONFIG_NUM_DDR_CONTROLLERS 2 +#define CACHE_LINE_INTERLEAVING 0x20000000 +#define PAGE_INTERLEAVING 0x21000000 +#define BANK_INTERLEAVING 0x22000000 +#define SUPER_BANK_INTERLEAVING 0x23000000 + + +#define CONFIG_ALTIVEC 1 + +/* + * L2CR setup -- make sure this is right for your board! + */ +#define CFG_L2 +#define L2_INIT 0 +#define L2_ENABLE (L2CR_L2E) + +#ifndef CONFIG_SYS_CLK_FREQ +#define CONFIG_SYS_CLK_FREQ get_board_sys_clk(0) +#endif + +#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */ + +#undef CFG_DRAM_TEST /* memory test, takes time */ +#define CFG_MEMTEST_START 0x00200000 /* memtest region */ +#define CFG_MEMTEST_END 0x00400000 + +/* + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + */ +#define CFG_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ +#define CFG_CCSRBAR 0xf8000000 /* relocated CCSRBAR */ +#define CFG_IMMR CFG_CCSRBAR /* PQII uses CFG_IMMR */ + +/* + * DDR Setup + */ +#define CFG_DDR_SDRAM_BASE 0x00000000 /* DDR is system memory */ +#define CFG_DDR_SDRAM_BASE2 0x10000000 /* DDR bank 2 */ +#define CFG_SDRAM_BASE CFG_DDR_SDRAM_BASE +#define CFG_SDRAM_BASE2 CFG_DDR_SDRAM_BASE2 +#define CONFIG_VERY_BIG_RAM + +#define MPC86xx_DDR_SDRAM_CLK_CNTL + +#if defined(CONFIG_SPD_EEPROM) + /* + * Determine DDR configuration from I2C interface. + */ + #define SPD_EEPROM_ADDRESS1 0x51 /* DDR DIMM */ + #define SPD_EEPROM_ADDRESS2 0x52 /* DDR DIMM */ + #define SPD_EEPROM_ADDRESS3 0x53 /* DDR DIMM */ + #define SPD_EEPROM_ADDRESS4 0x54 /* DDR DIMM */ + +#else + /* + * Manually set up DDR1 & DDR2 parameters + */ + + #define CFG_SDRAM_SIZE 512 /* DDR is 512MB */ + + #define CFG_DDR_CS0_BNDS 0x0000000F + #define CFG_DDR_CS1_BNDS 0x00000000 + #define CFG_DDR_CS2_BNDS 0x00000000 + #define CFG_DDR_CS3_BNDS 0x00000000 + #define CFG_DDR_CS0_CONFIG 0x80010102 + #define CFG_DDR_CS1_CONFIG 0x00000000 + #define CFG_DDR_CS2_CONFIG 0x00000000 + #define CFG_DDR_CS3_CONFIG 0x00000000 + #define CFG_DDR_EXT_REFRESH 0x00000000 + #define CFG_DDR_TIMING_0 0x00220802 + #define CFG_DDR_TIMING_1 0x38377322 + #define CFG_DDR_TIMING_2 0x002040c7 + #define CFG_DDR_CFG_1A 0x43008008 + #define CFG_DDR_CFG_2 0x24401000 + #define CFG_DDR_MODE_1 0x23c00542 + #define CFG_DDR_MODE_2 0x00000000 + #define CFG_DDR_MODE_CTL 0x00000000 + #define CFG_DDR_INTERVAL 0x05080100 + #define CFG_DDR_DATA_INIT 0x00000000 + #define CFG_DDR_CLK_CTRL 0x03800000 + #define CFG_DDR_CFG_1B 0xC3008008 + + #define CFG_DDR2_CS0_BNDS 0x0010001F + #define CFG_DDR2_CS1_BNDS 0x00000000 + #define CFG_DDR2_CS2_BNDS 0x00000000 + #define CFG_DDR2_CS3_BNDS 0x00000000 + #define CFG_DDR2_CS0_CONFIG 0x80010102 + #define CFG_DDR2_CS1_CONFIG 0x00000000 + #define CFG_DDR2_CS2_CONFIG 0x00000000 + #define CFG_DDR2_CS3_CONFIG 0x00000000 + #define CFG_DDR2_EXT_REFRESH 0x00000000 + #define CFG_DDR2_TIMING_0 0x00220802 + #define CFG_DDR2_TIMING_1 0x38377322 + #define CFG_DDR2_TIMING_2 0x002040c7 + #define CFG_DDR2_CFG_1A 0x43008008 + #define CFG_DDR2_CFG_2 0x24401000 + #define CFG_DDR2_MODE_1 0x23c00542 + #define CFG_DDR2_MODE_2 0x00000000 + #define CFG_DDR2_MODE_CTL 0x00000000 + #define CFG_DDR2_INTERVAL 0x05080100 + #define CFG_DDR2_DATA_INIT 0x00000000 + #define CFG_DDR2_CLK_CTRL 0x03800000 + #define CFG_DDR2_CFG_1B 0xC3008008 + + +#endif + +/* #define CFG_ID_EEPROM 1 +#define ID_EEPROM_ADDR 0x57 */ + +/* + * The SBC8641D contains 16MB flash space at ff000000. + */ +#define CFG_FLASH_BASE 0xff000000 /* start of FLASH 16M */ + +/* Flash */ +#define CFG_BR0_PRELIM 0xff001001 /* port size 16bit */ +#define CFG_OR0_PRELIM 0xff006e65 /* 16MB Boot Flash area */ + +/* 64KB EEPROM */ +#define CFG_BR1_PRELIM 0xf0000801 /* port size 16bit */ +#define CFG_OR1_PRELIM 0xffff6e65 /* 64K EEPROM area */ + +/* EPLD - User switches, board id, LEDs */ +#define CFG_BR2_PRELIM 0xf1000801 /* port size 16bit */ +#define CFG_OR2_PRELIM 0xfff06e65 /* EPLD (switches, board ID, LEDs) area */ + +/* Local bus SDRAM 128MB */ +#define CFG_BR3_PRELIM 0xe0001861 /* port size ?bit */ +#define CFG_OR3_PRELIM 0xfc006cc0 /* 128MB local bus SDRAM area (1st half) */ +#define CFG_BR4_PRELIM 0xe4001861 /* port size ?bit */ +#define CFG_OR4_PRELIM 0xfc006cc0 /* 128MB local bus SDRAM area (2nd half) */ + +/* Disk on Chip (DOC) 128MB */ +#define CFG_BR5_PRELIM 0xe8001001 /* port size ?bit */ +#define CFG_OR5_PRELIM 0xf8006e65 /* 128MB local bus SDRAM area (2nd half) */ + +/* LCD */ +#define CFG_BR6_PRELIM 0xf4000801 /* port size ?bit */ +#define CFG_OR6_PRELIM 0xfff06e65 /* 128MB local bus SDRAM area (2nd half) */ + +/* Control logic & misc peripherals */ +#define CFG_BR7_PRELIM 0xf2000801 /* port size ?bit */ +#define CFG_OR7_PRELIM 0xfff06e65 /* 128MB local bus SDRAM area (2nd half) */ + +#define CFG_MAX_FLASH_BANKS 1 /* number of banks */ +#define CFG_MAX_FLASH_SECT 131 /* sectors per device */ + +#undef CFG_FLASH_CHECKSUM +#define CFG_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CFG_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ +#define CFG_MONITOR_BASE TEXT_BASE /* start of monitor */ + +#define CFG_FLASH_CFI_DRIVER +#define CFG_FLASH_CFI +#define CFG_WRITE_SWAPPED_DATA +#define CFG_FLASH_EMPTY_INFO +#define CFG_FLASH_PROTECTION + +#undef CONFIG_CLOCKS_IN_MHZ + +#define CONFIG_L1_INIT_RAM +#define CFG_INIT_RAM_LOCK 1 +#ifndef CFG_INIT_RAM_LOCK +#define CFG_INIT_RAM_ADDR 0x0fd00000 /* Initial RAM address */ +#else +#define CFG_INIT_RAM_ADDR 0xf8400000 /* Initial RAM address */ +#endif +#define CFG_INIT_RAM_END 0x4000 /* End of used area in RAM */ + +#define CFG_GBL_DATA_SIZE 128 /* num bytes initial data */ +#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) +#define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET + +#define CFG_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ +#define CFG_MALLOC_LEN (128 * 1024) /* Reserved for malloc */ + +/* Serial Port */ +#define CONFIG_CONS_INDEX 1 +#undef CONFIG_SERIAL_SOFTWARE_FIFO +#define CFG_NS16550 +#define CFG_NS16550_SERIAL +#define CFG_NS16550_REG_SIZE 1 +#define CFG_NS16550_CLK get_bus_freq(0) + +#define CFG_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200} + +#define CFG_NS16550_COM1 (CFG_CCSRBAR+0x4500) +#define CFG_NS16550_COM2 (CFG_CCSRBAR+0x4600) + +/* Use the HUSH parser */ +#define CFG_HUSH_PARSER +#ifdef CFG_HUSH_PARSER +#define CFG_PROMPT_HUSH_PS2 "> " +#endif + +/* + * Pass open firmware flat tree to kernel + */ +#define CONFIG_OF_FLAT_TREE 1 +#define CONFIG_OF_BOARD_SETUP 1 + +/* maximum size of the flat tree (8K) */ +#define OF_FLAT_TREE_MAX_SIZE 8192 + +#define OF_CPU "PowerPC,8641@0" +#define OF_SOC "soc@f8000000" +#define OF_TBCLK (bd->bi_busfreq / 4) +#define OF_STDOUT_PATH "/soc@f8000000/serial@4500" + +#define CFG_64BIT_VSPRINTF 1 +#define CFG_64BIT_STRTOUL 1 + +/* + * I2C + */ +#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C /* I2C with hardware support*/ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CFG_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CFG_I2C_SLAVE 0x7F +#define CFG_I2C_NOPROBES {0x69} /* Don't probe these addrs */ +#define CFG_I2C_OFFSET 0x3100 + +/* + * RapidIO MMU + */ +#define CFG_RIO_MEM_BASE 0xc0000000 /* base address */ +#define CFG_RIO_MEM_PHYS CFG_RIO_MEM_BASE +#define CFG_RIO_MEM_SIZE 0x20000000 /* 128M */ + +/* + * General PCI + * Addresses are mapped 1-1. + */ +#define CFG_PCI1_MEM_BASE 0x80000000 +#define CFG_PCI1_MEM_PHYS CFG_PCI1_MEM_BASE +#define CFG_PCI1_MEM_SIZE 0x20000000 /* 512M */ +#define CFG_PCI1_IO_BASE 0xe2000000 +#define CFG_PCI1_IO_PHYS CFG_PCI1_IO_BASE +#define CFG_PCI1_IO_SIZE 0x1000000 /* 16M */ + +/* PCI view of System Memory */ +#define CFG_PCI_MEMORY_BUS 0x00000000 +#define CFG_PCI_MEMORY_PHYS 0x00000000 +#define CFG_PCI_MEMORY_SIZE 0x80000000 + +#define CFG_PCI2_MEM_BASE 0xa0000000 +#define CFG_PCI2_MEM_PHYS CFG_PCI2_MEM_BASE +#define CFG_PCI2_MEM_SIZE 0x10000000 /* 256M */ +#define CFG_PCI2_IO_BASE 0xe3000000 +#define CFG_PCI2_IO_PHYS CFG_PCI2_IO_BASE +#define CFG_PCI2_IO_SIZE 0x1000000 /* 16M */ + +#if defined(CONFIG_PCI) + +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ + +#undef CFG_SCSI_SCAN_BUS_REVERSE + +#define CONFIG_NET_MULTI +#define CONFIG_PCI_PNP /* do pci plug-and-play */ + +#undef CONFIG_EEPRO100 +#undef CONFIG_TULIP + +#if !defined(CONFIG_PCI_PNP) + #define PCI_ENET0_IOADDR 0xe0000000 + #define PCI_ENET0_MEMADDR 0xe0000000 + #define PCI_IDSEL_NUMBER 0x0c /* slot0->3(IDSEL)=12->15 */ +#endif + +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ + +#define CONFIG_DOS_PARTITION +#undef CONFIG_SCSI_AHCI + +#ifdef CONFIG_SCSI_AHCI +#define CONFIG_SATA_ULI5288 +#define CFG_SCSI_MAX_SCSI_ID 4 +#define CFG_SCSI_MAX_LUN 1 +#define CFG_SCSI_MAX_DEVICE (CFG_SCSI_MAX_SCSI_ID * CFG_SCSI_MAX_LUN) +#define CFG_SCSI_MAXDEVICE CFG_SCSI_MAX_DEVICE +#endif + +#endif /* CONFIG_PCI */ + +#if defined(CONFIG_TSEC_ENET) + +#ifndef CONFIG_NET_MULTI +#define CONFIG_NET_MULTI 1 +#endif + +/* #define CONFIG_MII 1 */ /* MII PHY management */ + +#define CONFIG_TSEC1 1 +#define CONFIG_TSEC1_NAME "eTSEC1" +#define CONFIG_TSEC2 1 +#define CONFIG_TSEC2_NAME "eTSEC2" +#define CONFIG_TSEC3 1 +#define CONFIG_TSEC3_NAME "eTSEC3" +#define CONFIG_TSEC4 1 +#define CONFIG_TSEC4_NAME "eTSEC4" + +#define TSEC1_PHY_ADDR 0x1F +#define TSEC2_PHY_ADDR 0x00 +#define TSEC3_PHY_ADDR 0x01 +#define TSEC4_PHY_ADDR 0x02 +#define TSEC1_PHYIDX 0 +#define TSEC2_PHYIDX 0 +#define TSEC3_PHYIDX 0 +#define TSEC4_PHYIDX 0 + +#define CONFIG_ETHPRIME "eTSEC1" + +#endif /* CONFIG_TSEC_ENET */ + +/* + * BAT0 2G Cacheable, non-guarded + * 0x0000_0000 2G DDR + */ +#define CFG_DBAT0L (BATL_PP_RW | BATL_MEMCOHERENCE) +#define CFG_DBAT0U (BATU_BL_2G | BATU_VS | BATU_VP) +#define CFG_IBAT0L (BATL_PP_RW | BATL_MEMCOHERENCE ) +#define CFG_IBAT0U CFG_DBAT0U + +/* + * BAT1 1G Cache-inhibited, guarded + * 0x8000_0000 512M PCI-Express 1 Memory + * 0xa000_0000 512M PCI-Express 2 Memory + * Changed it for operating from 0xd0000000 + */ +#define CFG_DBAT1L ( CFG_PCI1_MEM_BASE | BATL_PP_RW \ + | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CFG_DBAT1U (CFG_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CFG_IBAT1L (CFG_PCI1_MEM_BASE | BATL_PP_RW | BATL_CACHEINHIBIT) +#define CFG_IBAT1U CFG_DBAT1U + +/* + * BAT2 512M Cache-inhibited, guarded + * 0xc000_0000 512M RapidIO Memory + */ +#define CFG_DBAT2L (CFG_RIO_MEM_BASE | BATL_PP_RW \ + | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CFG_DBAT2U (CFG_RIO_MEM_BASE | BATU_BL_512M | BATU_VS | BATU_VP) +#define CFG_IBAT2L (CFG_RIO_MEM_BASE | BATL_PP_RW | BATL_CACHEINHIBIT) +#define CFG_IBAT2U CFG_DBAT2U + +/* + * BAT3 4M Cache-inhibited, guarded + * 0xf800_0000 4M CCSR + */ +#define CFG_DBAT3L ( CFG_CCSRBAR | BATL_PP_RW \ + | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CFG_DBAT3U (CFG_CCSRBAR | BATU_BL_4M | BATU_VS | BATU_VP) +#define CFG_IBAT3L (CFG_CCSRBAR | BATL_PP_RW | BATL_CACHEINHIBIT) +#define CFG_IBAT3U CFG_DBAT3U + +/* + * BAT4 32M Cache-inhibited, guarded + * 0xe200_0000 16M PCI-Express 1 I/O + * 0xe300_0000 16M PCI-Express 2 I/0 + * Note that this is at 0xe0000000 + */ +#define CFG_DBAT4L ( CFG_PCI1_IO_BASE | BATL_PP_RW \ + | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CFG_DBAT4U (CFG_PCI1_IO_BASE | BATU_BL_32M | BATU_VS | BATU_VP) +#define CFG_IBAT4L (CFG_PCI1_IO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT) +#define CFG_IBAT4U CFG_DBAT4U + +/* + * BAT5 128K Cacheable, non-guarded + * 0xe401_0000 128K Init RAM for stack in the CPU DCache (no backing memory) + */ +#define CFG_DBAT5L (CFG_INIT_RAM_ADDR | BATL_PP_RW | BATL_MEMCOHERENCE) +#define CFG_DBAT5U (CFG_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP) +#define CFG_IBAT5L CFG_DBAT5L +#define CFG_IBAT5U CFG_DBAT5U + +/* + * BAT6 32M Cache-inhibited, guarded + * 0xfe00_0000 32M FLASH + */ +#define CFG_DBAT6L ((CFG_FLASH_BASE & 0xfe000000) | BATL_PP_RW \ + | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CFG_DBAT6U ((CFG_FLASH_BASE & 0xfe000000) | BATU_BL_32M | BATU_VS | BATU_VP) +#define CFG_IBAT6L ((CFG_FLASH_BASE & 0xfe000000) | BATL_PP_RW | BATL_MEMCOHERENCE) +#define CFG_IBAT6U CFG_DBAT6U + +#define CFG_DBAT7L 0x00000000 +#define CFG_DBAT7U 0x00000000 +#define CFG_IBAT7L 0x00000000 +#define CFG_IBAT7U 0x00000000 + +/* + * Environment + */ +#define CFG_ENV_IS_IN_FLASH 1 +#define CFG_ENV_ADDR (CFG_MONITOR_BASE + 0x40000) +#define CFG_ENV_SECT_SIZE 0x40000 /* 256K(one sector) for env */ +#define CFG_ENV_SIZE 0x2000 + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ + +#if defined(CONFIG_PCI) + #define CONFIG_CMD_PCI + #define CONFIG_CMD_PING + #define CONFIG_CMD_I2C +#else + #define CONFIG_CMD_PING + #define CONFIG_CMD_I2C +#endif + +#include <cmd_confdefs.h> + +#undef CONFIG_WATCHDOG /* watchdog disabled */ + +/* + * Miscellaneous configurable options + */ +#define CFG_LONGHELP /* undef to save memory */ +#define CFG_LOAD_ADDR 0x2000000 /* default load address */ +#define CFG_PROMPT "=> " /* Monitor Command Prompt */ + +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) + #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ +#else + #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ +#endif + +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ +#define CFG_HZ 1000 /* decrementer freq: 1ms ticks */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux*/ + +/* Cache Configuration */ +#define CFG_DCACHE_SIZE 32768 +#define CFG_CACHELINE_SIZE 32 +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CFG_CACHELINE_SHIFT 5 /*log base 2 of the above value*/ +#endif + +/* + * Internal Definitions + * + * Boot Flags + */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ + +/* The mac addresses for all ethernet interface */ +#if defined(CONFIG_TSEC_ENET) +#define CONFIG_ETHADDR 00:E0:0C:00:00:01 +#define CONFIG_ETH1ADDR 00:E0:0C:00:01:FD +#define CONFIG_ETH2ADDR 00:E0:0C:00:02:FD +#define CONFIG_ETH3ADDR 00:E0:0C:00:03:FD +#endif + +#define CONFIG_HAS_ETH1 1 +#define CONFIG_HAS_ETH2 1 +#define CONFIG_HAS_ETH3 1 + +#define CONFIG_IPADDR 192.168.0.50 + +#define CONFIG_HOSTNAME sbc8641d +#define CONFIG_ROOTPATH /opt/eldk/ppc_74xx +#define CONFIG_BOOTFILE uImage + +#define CONFIG_SERVERIP 192.168.0.2 +#define CONFIG_GATEWAYIP 192.168.0.1 +#define CONFIG_NETMASK 255.255.255.0 + +/* default location for tftp and bootm */ +#define CONFIG_LOADADDR 1000000 + +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ +#undef CONFIG_BOOTARGS /* the boot command will set bootargs */ + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=2000000\0" \ + "ramdiskfile=uRamdisk\0" \ + "dtbaddr=400000\0" \ + "dtbfile=sbc8641d.dtb\0" \ + "en-wd=mw.b f8100010 0x08; echo -expect:- 08; md.b f8100010 1\0" \ + "dis-wd=mw.b f8100010 0x00; echo -expect:- 00; md.b f8100010 1\0" \ + "maxcpus=1" + +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $dtbaddr $dtbfile;" \ + "bootm $loadaddr - $dtbaddr" + +#define CONFIG_RAMBOOTCOMMAND \ + "setenv bootargs root=/dev/ram rw " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $dtbaddr $dtbfile;" \ + "bootm $loadaddr $ramdiskaddr $dtbaddr" + +#define CONFIG_FLASHBOOTCOMMAND \ + "setenv bootargs root=/dev/ram rw " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "bootm ffd00000 ffb00000 ffa00000" + +#define CONFIG_BOOTCOMMAND CONFIG_FLASHBOOTCOMMAND + +#endif /* __CONFIG_H */ diff -uprN -X dontdiff u-boot/MAINTAINERS u-boot-esi/MAINTAINERS --- u-boot/MAINTAINERS 2007-07-31 08:19:57.000000000 -0500 +++ u-boot-esi/MAINTAINERS 2007-07-31 06:22:16.000000000 -0500 @@ -179,6 +179,10 @@ Howard Gray mvsensor@matrix-vision.de
MVS1 MPC823
+Joe Hamman joe.hamman@embeddedspecialties.com + + sbc8641d MPC8641D + Klaus Heydeck heydeck@kieback-peter.de
KUP4K MPC855 diff -uprN -X dontdiff u-boot/Makefile u-boot-esi/Makefile --- u-boot/Makefile 2007-07-31 08:19:57.000000000 -0500 +++ u-boot-esi/Makefile 2007-07-31 06:23:39.000000000 -0500 @@ -1856,6 +1856,8 @@ TQM8560_config: unconfig MPC8641HPCN_config: unconfig @./mkconfig $(@:_config=) ppc mpc86xx mpc8641hpcn
+sbc8641d_config: unconfig + @./mkconfig $(@:_config=) ppc mpc86xx sbc8641d
######################################################################### ## 74xx/7xx Systems
Please explain why you are changing drivers/tsec.h in this patch?
Are you fixing a bug? If yes, then this should be submitted as a separate patch and not be hidden within bug board support patches.
Hmmm... This isn't really a bug fix. It is really more of a board-specific adjustment for PHY association with the controllers on your board, right?
So, it seems like this should be made board dependent somehow.
Or, it seems like we might have Andy talk to us about the future of Ed's TSEC patches for multiple PHY and TBI support. This _might_ be subsumed by that effort, but I'm not sure.
jdl
- #define CONFIG_CMD_PCI
- #define CONFIG_CMD_PING
- #define CONFIG_CMD_I2C
+#else
I think the above really needs to look more like this:
/* * BOOTP options */ #define CONFIG_BOOTP_BOOTFILESIZE #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
/* * Command line configuration. */ #include <config_cmd_default.h>
#define CONFIG_CMD_PING #define CONFIG_CMD_I2C
#if defined(CFG_RAMBOOT) #undef CONFIG_CMD_ENV #endif
#if defined(CONFIG_PCI) #define CONFIG_CMD_PCI #define CONFIG_CMD_SCSI #define CONFIG_CMD_EXT2 #endif
Joe Hamman
Jon Loeliger
