Re: [U-Boot] [U-Boot-Users] Boot from Jffs2 filesystem problem
Hi Pedro,
the SourceForge mailing list is deprecated, please use the one at lists.denx.de.
[This time, the new address is correct]
The u-boot version I'm using is 1.3.1 (self compiled) and Linux Kernel 2.6.23.1.
It is possible to boot it with a stored kernel uImage and the oftree in the flash using a nfs filesystem, but I can't not boot it using the jffs2 image. I've read a lot of documentation from denx.de and this is my configuration at the moment:
mtdparts=mtdparts=TQM5200-0:512k(uboot),256k(environment),3328k(kernel),20m(jffs2),256k(oftree) bootargs_mtd=setenv bootargs ${bootargs} ${mtdparts} bootargs_flash=setenv bootargs ${bootargs} root=/dev/mtdblock4 rw rootfstype=jffs2 (even tried with root=/dev/mtdblock3, I'm not sure if 0 counts or not) bootargs_base=setenv bootargs console=ttyPSC0,115200 bootcmd_flash=run bootargs_base bootargs_flash bootargs_mtd;bootm fC0C0000 – fD800000
I've defined the partitions myself and double checked the numbers, first myself, then using the mtdparts command. The kernel image, oftree, and jffs2 filesystem are stored in the flash. The problem comes at booting. Even when "root=/dev/mtdblock4 rw rootfstype=jffs2" is passed to the kernel, it always tries to boot from a Ramdisk image. This is the output when I run bootcmd_flash command:
=> run bootcmd_flash ## Booting image at fc0c0000 ... Image Name: Linux-2.6.23.1-rt5-pcm030-1trunk Created: 2008-09-02 11:48:23 UTC Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 1534856 Bytes = 1.5 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK ## Loading RAMDisk Image at 00000000 ... Bad Magic Number
It seems to me that U-boot is trying to boot from RAMDisk instead of booting the kernel, but I'm not sure.
Yes, indeed. It looks like the "bootm fc0c0000 - fd800000" is not evaluated properly. In v1.3.1 code the code lines were (common/cmd_bootm.c:622)
#if defined(CONFIG_OF_FLAT_TREE) || defined(CONFIG_OF_LIBFDT) /* Look for a '-' which indicates to ignore the ramdisk argument */ if (argc >= 3 && strcmp(argv[2], "-") == 0) { debug ("Skipping initrd\n"); len = data = 0; } else #endif
So The upstream v1.3.1 config for TQM5200 also has CONFIG_OF_LIBFDT defined:
$ git-show v1.3.1:include/configs/TQM5200.h | grep CONFIG_OF_LIBFDT #define CONFIG_OF_LIBFDT 1
So if you did not change that, my last explanation is that you have hidden escape characters in the definition of bootcmd_flash. Check with 'md' on the environment sectors to find out.
Cheers Detlev
Detlev Zundel
