[U-Boot] [PATCH] mpc83xx: Store and display Arbiter Event Register values
Record the Arbiter Event Register values and optionally display them.
The Arbiter Event Register can record the type and effective address of an arbiter error, even through an HRESET. This patch stores the values in the global data structure.
Display of the Arbiter Event registers immediately after the RSR value can be enabled with defines. The Arbiter values will only be displayed if an arbiter event has occured since the last Power On Reset, and either of the following defines exist: #define CONFIG_DISPLAY_AER_BRIEF - display only the arbiter address and and type register values #define CONFIG_DISPLAY_AER_FULL - display and interpret the arbiter event register values
Address Only transactions are one of the trapped events that can register as an arbiter event. They occur with some cache manipulation instructions if the HID0_ABE (Address Broadcast Enable) is set and the memory region has the MEMORY_COHERENCE WIMG bit set. Setting: #define CONFIG_MASK_AER_AO - prevents the arbiter from recording address only events, so that it can still capture other real problems.
Signed-off-by: Nick Spence nick.spence@freescale.com --- cpu/mpc83xx/cpu_init.c | 136 ++++++++++++++++++++++++++++++++++++++++- cpu/mpc83xx/start.S | 11 +++ include/asm-ppc/global_data.h | 4 + 3 files changed, 150 insertions(+), 1 deletions(-)
diff --git a/cpu/mpc83xx/cpu_init.c b/cpu/mpc83xx/cpu_init.c index 4514dbb..ff01cf1 100644 --- a/cpu/mpc83xx/cpu_init.c +++ b/cpu/mpc83xx/cpu_init.c @@ -167,6 +167,10 @@ void cpu_init_f (volatile immap_t * im) gd->reset_status = im->reset.rsr; im->reset.rsr = ~(RSR_RES);
+ /* AER - Arbiter Event Register - store status */ + gd->arbiter_event_attributes = im->arbiter.aeatr; + gd->arbiter_event_address = im->arbiter.aeadr; + /* * RMR - Reset Mode Register * contains checkstop reset enable (4.6.1.4) @@ -303,6 +307,130 @@ int cpu_init_r (void) }
/* + * Print out the bus arbiter event + */ +#if defined(CONFIG_DISPLAY_AER_FULL) +static int print_83xx_arb_event(int force) +{ + static char* event[] = { + "Address Time Out", + "Data Time Out", + "Address Only Transfer Type", + "External Control Word Transfer Type", + "Reserved Transfer Type", + "Transfer Error", + "reserved", + "reserved" + }; + static char* master[] = { + "e300 Core Data Transaction", + "reserved", + "e300 Core Instruction Fetch", + "reserved", + "TSEC1", + "TSEC2", + "USB MPH", + "USB DR", + "Encryption Core", + "I2C Boot Sequencer", + "JTAG", + "reserved", + "eSDHC", + "PCI1", + "PCI2", + "DMA", + "QUICC Engine 00", + "QUICC Engine 01", + "QUICC Engine 10", + "QUICC Engine 11", + "reserved", + "reserved", + "reserved", + "reserved", + "SATA1", + "SATA2", + "SATA3", + "SATA4", + "reserved", + "PCI Express 1", + "PCI Express 2", + "TDM-DMAC" + }; + static char *transfer[] = { + "Address-only, Clean Block", + "Address-only, lwarx reservation set", + "Single-beat or Burst write", + "reserved", + "Address-only, Flush Block", + "reserved", + "Burst write", + "reserved", + "Address-only, sync", + "Address-only, tlbsync", + "Single-beat or Burst read", + "Single-beat or Burst read", + "Address-only, Kill Block", + "Address-only, icbi", + "Burst read", + "reserved", + "Address-only, eieio", + "reserved", + "Single-beat write", + "reserved", + "ecowx - Illegal single-beat write", + "reserved", + "reserved", + "reserved", + "Address-only, TLB Invalidate", + "reserved", + "Single-beat or Burst read", + "reserved", + "eciwx - Illegal single-beat read", + "reserved", + "Burst read", + "reserved" + }; + + int etype = (gd->arbiter_event_attributes & AEATR_EVENT) + >> AEATR_EVENT_SHIFT; + int mstr_id = (gd->arbiter_event_attributes & AEATR_MSTR_ID) + >> AEATR_MSTR_ID_SHIFT; + int tbst = (gd->arbiter_event_attributes & AEATR_TBST) + >> AEATR_TBST_SHIFT; + int tsize = (gd->arbiter_event_attributes & AEATR_TSIZE) + >> AEATR_TSIZE_SHIFT; + int ttype = (gd->arbiter_event_attributes & AEATR_TTYPE) + >> AEATR_TTYPE_SHIFT; + + if (!force && !gd->arbiter_event_address) + return 0; + + puts("Arbiter Event Status:\n"); + printf(" Event Address: 0x%08lX\n", gd->arbiter_event_address); + printf(" Event Type: 0x%1x = %s\n", etype, event[etype]); + printf(" Master ID: 0x%02x = %s\n", mstr_id, master[mstr_id]); + printf(" Transfer Size: 0x%1x = %d bytes\n", (tbst<<3) | tsize, + tbst ? (tsize ? tsize : 8) : 16 + 8 * tsize); + printf(" Transfer Type: 0x%02x = %s\n", ttype, transfer[ttype]); + + return gd->arbiter_event_address; +} + +#elif defined(CONFIG_DISPLAY_AER_BRIEF) + +static int print_83xx_arb_event(int force) +{ + if (!force && !gd->arbiter_event_address) + return 0; + + printf("Arbiter Event Status: AEATR=0x%08lX, AEADR=0x%08lX\n", + gd->arbiter_event_attributes, gd->arbiter_event_address); + + return gd->arbiter_event_address; +} +#endif /* CONFIG_DISPLAY_AER_xxxx */ + +/* * Figure out the cause of the reset */ int prt_83xx_rsr(void) @@ -334,6 +462,12 @@ int prt_83xx_rsr(void) printf("%s%s", sep, bits[i].desc); sep = ", "; } - puts("\n\n"); + puts("\n"); + +#if defined(CONFIG_DISPLAY_AER_FULL) || defined(CONFIG_DISPLAY_AER_BRIEF) + print_83xx_arb_event(rsr & RSR_BMRS); +#endif + puts("\n"); + return 0; } diff --git a/cpu/mpc83xx/start.S b/cpu/mpc83xx/start.S index 75ad36c..e452bfb 100644 --- a/cpu/mpc83xx/start.S +++ b/cpu/mpc83xx/start.S @@ -483,6 +483,17 @@ init_e300_core: /* time t 10 */ 1: #endif /* CONFIG_WATCHDOG */
+#if defined(CONFIG_MASK_AER_AO) + /* Write the Arbiter Event Enable to mask Address Only traps. */ + /* This prevents the dcbz instruction from being trapped when */ + /* HID0_ABE Address Broadcast Enable is set and the MEMORY */ + /* COHERENCY bit is set in the WIMG bits, which is often */ + /* needed for PCI operation. */ + lwz r4, 0x0808(r3) + rlwinm r0, r4, 0, ~AER_AO + stw r0, 0x0808(r3) +#endif /* CONFIG_MASK_AER_AO */ + /* Initialize the Hardware Implementation-dependent Registers */ /* HID0 also contains cache control */ /*------------------------------------------------------*/ diff --git a/include/asm-ppc/global_data.h b/include/asm-ppc/global_data.h index be2ce24..a236c4b 100644 --- a/include/asm-ppc/global_data.h +++ b/include/asm-ppc/global_data.h @@ -122,6 +122,10 @@ typedef struct global_data { phys_size_t ram_size; /* RAM size */ unsigned long reloc_off; /* Relocation Offset */ unsigned long reset_status; /* reset status register at boot */ +#if defined(CONFIG_MPC83XX) + unsigned long arbiter_event_attributes; + unsigned long arbiter_event_address; +#endif unsigned long env_addr; /* Address of Environment struct */ unsigned long env_valid; /* Checksum of Environment valid? */ unsigned long have_console; /* serial_init() was called */
Nick Spence
