[PATCH] pico-imx7d: Add support for the 2GB variant
Add the board detection mechanism to be able to support the 2GB variant.
Based on the code from TechNexion U-Boot downstream tree.
Signed-off-by: Fabio Estevam festevam@denx.de --- board/technexion/pico-imx7d/spl.c | 30 +++++++++++++++++++++++++++--- 1 file changed, 27 insertions(+), 3 deletions(-)
diff --git a/board/technexion/pico-imx7d/spl.c b/board/technexion/pico-imx7d/spl.c index df5f058577..f86fee9c88 100644 --- a/board/technexion/pico-imx7d/spl.c +++ b/board/technexion/pico-imx7d/spl.c @@ -61,6 +61,8 @@ static struct ddrc ddrc_regs_val = { .dramtmg0 = 0x09081109, .addrmap0 = 0x0000001f, .addrmap1 = 0x00080808, + .addrmap2 = 0x00000000, + .addrmap3 = 0x00000000, .addrmap4 = 0x00000f0f, .addrmap5 = 0x07070707, .addrmap6 = 0x0f0f0707, @@ -100,16 +102,38 @@ static void gpr_init(void) writel(0x4F400005, &gpr_regs->gpr[1]); }
-static bool is_1g(void) +/* + * Revision Detection + * + * GPIO1_12 GPIO1_13 + * 0 0 1GB DDR3 + * 0 1 2GB DDR3 + * 1 0 512MB DDR3 + */ + +static int imx7d_pico_detect_board(void) { gpio_direction_input(IMX_GPIO_NR(1, 12)); - return !gpio_get_value(IMX_GPIO_NR(1, 12)); + gpio_direction_input(IMX_GPIO_NR(1, 13)); + + return gpio_get_value(IMX_GPIO_NR(1, 12)) << 1 | + gpio_get_value(IMX_GPIO_NR(1, 13)); }
static void ddr_init(void) { - if (is_1g()) + switch (imx7d_pico_detect_board()) { + case 0: ddrc_regs_val.addrmap6 = 0x0f070707; + break; + case 1: + ddrc_regs_val.addrmap0 = 0x0000001f; + ddrc_regs_val.addrmap1 = 0x00181818; + ddrc_regs_val.addrmap4 = 0x00000f0f; + ddrc_regs_val.addrmap5 = 0x04040404; + ddrc_regs_val.addrmap6 = 0x04040404; + break; + }
mx7_dram_cfg(&ddrc_regs_val, &ddrc_mp_val, &ddr_phy_regs_val, &calib_param);
Add the board detection mechanism to be able to support the 2GB variant. Based on the code from TechNexion U-Boot downstream tree. Signed-off-by: Fabio Estevam festevam@denx.de
Best regards, Stefano Babic
Fabio Estevam
sbabic@denx.de
