[U-Boot] [PATCH] MIPS: fix __raw_* IO accessors
The purpose of the __raw* IO accessors is to provide IO access in native-endian order. However in the current MIPS implementation, the 16 and 32 bit variants of the __raw accessors are swapping the values on big-endian systems if the CONFIG_SWAP_IO_SPACE option is enabled.
The patch changes the IO accessor macros to fix this broken behaviour.
Signed-off-by: Gabor Juhos juhosg@openwrt.org Cc: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- Note:
The change does not affect the existing MIPS targets because none of those are using CONFIG_SWAP_IO_SPACE. Compiling all MIPS targets results in the same binary image with and without the patch. --- arch/mips/include/asm/io.h | 26 +++++++++++++------------- 1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/arch/mips/include/asm/io.h b/arch/mips/include/asm/io.h index 3864c80..50a882c 100644 --- a/arch/mips/include/asm/io.h +++ b/arch/mips/include/asm/io.h @@ -184,19 +184,19 @@ extern void iounmap(void *addr); * 24-31 on SNI. * XXX more SNI hacks. */ -#define readb(addr) (*(volatile unsigned char *)(addr)) -#define readw(addr) __ioswab16((*(volatile unsigned short *)(addr))) -#define readl(addr) __ioswab32((*(volatile unsigned int *)(addr))) -#define __raw_readb readb -#define __raw_readw readw -#define __raw_readl readl - -#define writeb(b,addr) (*(volatile unsigned char *)(addr)) = (b) -#define writew(b,addr) (*(volatile unsigned short *)(addr)) = (__ioswab16(b)) -#define writel(b,addr) (*(volatile unsigned int *)(addr)) = (__ioswab32(b)) -#define __raw_writeb writeb -#define __raw_writew writew -#define __raw_writel writel +#define __raw_readb(addr) (*(volatile unsigned char *)(addr)) +#define __raw_readw(addr) (*(volatile unsigned short *)(addr)) +#define __raw_readl(addr) (*(volatile unsigned int *)(addr)) +#define readb(addr) __raw_readb((addr)) +#define readw(addr) __ioswab16(__raw_readw((addr))) +#define readl(addr) __ioswab32(__raw_readl((addr))) + +#define __raw_writeb(b, addr) (*(volatile unsigned char *)(addr)) = (b) +#define __raw_writew(b, addr) (*(volatile unsigned short *)(addr)) = (b) +#define __raw_writel(b, addr) (*(volatile unsigned int *)(addr)) = (b) +#define writeb(b, addr) __raw_writeb((b), (addr)) +#define writew(b, addr) __raw_writew(__ioswab16(b), (addr)) +#define writel(b, addr) __raw_writel(__ioswab32(b), (addr))
#define memset_io(a,b,c) memset((void *)(a),(b),(c)) #define memcpy_fromio(a,b,c) memcpy((a),(void *)(b),(c))
2013/2/21 Gabor Juhos juhosg@openwrt.org:
Note:
applied to u-boot-mips/master, thanks
Daniel Schwierzeck
Gabor Juhos
