[U-Boot] [PATCH 0/7] serial: mxc: Add debug uart support
This set add debug uart support by cleaning up exising serial_mxc
Jagan Teki (7): serial: mxc: Add common mxc_uart reg space serial: mxc: Use RFDIV in dm-code serial: mxc: Move cr1 and cr2 write to mxc_serial_setbrg serial: mxc: Move common init into _mxc_serial_init serial: mxc: Move common baud gen into _mxc_serial_setbrg serial: mxc: Code cleanup serial: mxc: Add debug uart support
configs/imx6qdl_icore_mmc_defconfig | 4 + drivers/serial/Kconfig | 8 + drivers/serial/serial_mxc.c | 387 ++++++++++++++++++------------------ 3 files changed, 205 insertions(+), 194 deletions(-)
This patch will add common reg space for non-dm and dm code and non-dm reg space can be accessed using mxc_base.
This will - get rid of __REG volatile assignments - Make common reg_space by removing unneeded macros
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/serial/serial_mxc.c | 115 +++++++++++++++++++------------------------- 1 file changed, 49 insertions(+), 66 deletions(-)
diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index 64126e2..6d1d447 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -110,32 +110,39 @@
DECLARE_GLOBAL_DATA_PTR;
+struct mxc_uart { + u32 rxd; + u32 spare0[15]; + + u32 txd; + u32 spare1[15]; + + u32 cr1; + u32 cr2; + u32 cr3; + u32 cr4; + + u32 fcr; + u32 sr1; + u32 sr2; + u32 esc; + + u32 tim; + u32 bir; + u32 bmr; + u32 brc; + + u32 onems; + u32 ts; +}; + #ifndef CONFIG_DM_SERIAL
#ifndef CONFIG_MXC_UART_BASE #error "define CONFIG_MXC_UART_BASE to use the MXC UART driver" #endif
-#define UART_PHYS CONFIG_MXC_UART_BASE - -#define __REG(x) (*((volatile u32 *)(x))) - -/* Register definitions */ -#define URXD 0x0 /* Receiver Register */ -#define UTXD 0x40 /* Transmitter Register */ -#define UCR1 0x80 /* Control Register 1 */ -#define UCR2 0x84 /* Control Register 2 */ -#define UCR3 0x88 /* Control Register 3 */ -#define UCR4 0x8c /* Control Register 4 */ -#define UFCR 0x90 /* FIFO Control Register */ -#define USR1 0x94 /* Status Register 1 */ -#define USR2 0x98 /* Status Register 2 */ -#define UESC 0x9c /* Escape Character Register */ -#define UTIM 0xa0 /* Escape Timer Register */ -#define UBIR 0xa4 /* BRM Incremental Register */ -#define UBMR 0xa8 /* BRM Modulator Register */ -#define UBRC 0xac /* Baud Rate Count Register */ -#define UTS 0xb4 /* UART Test Register (mx31) */ +#define mxc_base ((struct mxc_uart *)CONFIG_MXC_UART_BASE)
#define TXTL 2 /* reset default */ #define RXTL 1 /* reset default */ @@ -148,19 +155,20 @@ static void mxc_serial_setbrg(void) if (!gd->baudrate) gd->baudrate = CONFIG_BAUDRATE;
- __REG(UART_PHYS + UFCR) = (RFDIV << UFCR_RFDIV_SHF) - | (TXTL << UFCR_TXTL_SHF) - | (RXTL << UFCR_RXTL_SHF); - __REG(UART_PHYS + UBIR) = 0xf; - __REG(UART_PHYS + UBMR) = clk / (2 * gd->baudrate); + writel(((RFDIV << UFCR_RFDIV_SHF) | + (TXTL << UFCR_TXTL_SHF) | + (RXTL << UFCR_RXTL_SHF)), + &mxc_base->fcr); + writel(0xf, &mxc_base->bir); + writel(clk / (2 * gd->baudrate), &mxc_base->bmr);
static int mxc_serial_getc(void) { - while (__REG(UART_PHYS + UTS) & UTS_RXEMPTY) + while (readl(&mxc_base->ts) & UTS_RXEMPTY) WATCHDOG_RESET(); - return (__REG(UART_PHYS + URXD) & URXD_RX_DATA); /* mask out status from upper word */ + return (readl(&mxc_base->rxd) & URXD_RX_DATA); /* mask out status from upper word */ }
static void mxc_serial_putc(const char c) @@ -169,10 +177,10 @@ static void mxc_serial_putc(const char c) if (c == '\n') serial_putc('\r');
- __REG(UART_PHYS + UTXD) = c; + writel(c, &mxc_base->txd);
/* wait for transmitter to be ready */ - while (!(__REG(UART_PHYS + UTS) & UTS_TXEMPTY)) + while (!(readl(&mxc_base->ts) & UTS_TXEMPTY)) WATCHDOG_RESET(); }
@@ -182,7 +190,7 @@ static void mxc_serial_putc(const char c) static int mxc_serial_tstc(void) { /* If receive fifo is empty, return false */ - if (__REG(UART_PHYS + UTS) & UTS_RXEMPTY) + if (readl(&mxc_base->ts) & UTS_RXEMPTY) return 0; return 1; } @@ -194,23 +202,24 @@ static int mxc_serial_tstc(void) */ static int mxc_serial_init(void) { - __REG(UART_PHYS + UCR1) = 0x0; - __REG(UART_PHYS + UCR2) = 0x0; + writel(0, &mxc_base->cr1); + writel(0, &mxc_base->cr2);
- while (!(__REG(UART_PHYS + UCR2) & UCR2_SRST)); + while (!(readl(&mxc_base->cr2) & UCR2_SRST));
- __REG(UART_PHYS + UCR3) = 0x0704 | UCR3_ADNIMP; - __REG(UART_PHYS + UCR4) = 0x8000; - __REG(UART_PHYS + UESC) = 0x002b; - __REG(UART_PHYS + UTIM) = 0x0; + writel(0x704 | UCR3_ADNIMP, &mxc_base->cr3); + writel(0x8000, &mxc_base->cr4); + writel(0x2b, &mxc_base->esc); + writel(0, &mxc_base->tim);
- __REG(UART_PHYS + UTS) = 0x0; + writel(0, &mxc_base->ts);
serial_setbrg();
- __REG(UART_PHYS + UCR2) = UCR2_WS | UCR2_IRTS | UCR2_RXEN | UCR2_TXEN | UCR2_SRST; + writel(UCR2_WS | UCR2_IRTS | UCR2_RXEN | UCR2_TXEN | UCR2_SRST, + &mxc_base->cr2);
- __REG(UART_PHYS + UCR1) = UCR1_UARTEN; + writel(UCR1_UARTEN, &mxc_base->cr1);
return 0; } @@ -239,32 +248,6 @@ __weak struct serial_device *default_serial_console(void)
#ifdef CONFIG_DM_SERIAL
-struct mxc_uart { - u32 rxd; - u32 spare0[15]; - - u32 txd; - u32 spare1[15]; - - u32 cr1; - u32 cr2; - u32 cr3; - u32 cr4; - - u32 fcr; - u32 sr1; - u32 sr2; - u32 esc; - - u32 tim; - u32 bir; - u32 bmr; - u32 brc; - - u32 onems; - u32 ts; -}; - int mxc_serial_setbrg(struct udevice *dev, int baudrate) { struct mxc_serial_platdata *plat = dev->platdata;
This will
This will
+struct mxc_uart {
- u32 rxd;
- u32 spare0[15];
- u32 txd;
- u32 spare1[15];
- u32 cr1;
- u32 cr2;
- u32 cr3;
- u32 cr4;
- u32 fcr;
- u32 sr1;
- u32 sr2;
- u32 esc;
- u32 tim;
- u32 bir;
- u32 bmr;
- u32 brc;
- u32 onems;
- u32 ts;
- writel(((RFDIV << UFCR_RFDIV_SHF) |
&mxc_base->fcr);
- writel(0xf, &mxc_base->bir);
- writel(clk / (2 * gd->baudrate), &mxc_base->bmr);
- while (readl(&mxc_base->ts) & UTS_RXEMPTY) WATCHDOG_RESET();
- return (readl(&mxc_base->rxd) & URXD_RX_DATA); /* mask out status from upper word */
- while (!(readl(&mxc_base->ts) & UTS_TXEMPTY)) WATCHDOG_RESET();
- if (readl(&mxc_base->ts) & UTS_RXEMPTY) return 0; return 1;
- writel(0, &mxc_base->cr1);
- writel(0, &mxc_base->cr2);
- while (!(readl(&mxc_base->cr2) & UCR2_SRST));
- writel(0x704 | UCR3_ADNIMP, &mxc_base->cr3);
- writel(0x8000, &mxc_base->cr4);
- writel(0x2b, &mxc_base->esc);
- writel(0, &mxc_base->tim);
serial_setbrg();
- writel(UCR2_WS | UCR2_IRTS | UCR2_RXEN | UCR2_TXEN | UCR2_SRST,
&mxc_base->cr2);
-struct mxc_uart {
- u32 rxd;
- u32 spare0[15];
- u32 txd;
- u32 spare1[15];
- u32 cr1;
- u32 cr2;
- u32 cr3;
- u32 cr4;
- u32 fcr;
- u32 sr1;
- u32 sr2;
- u32 esc;
- u32 tim;
- u32 bir;
- u32 bmr;
- u32 brc;
- u32 onems;
- u32 ts;
Applied (whole series) to u-boot-imx, -next, thanks !
Best regards, Stefano Babic
Use RFDIV in dm-code instead of numeric value, so-that it can be common for dm and non-dm.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/serial/serial_mxc.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index 6d1d447..65c301d 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -76,6 +76,7 @@ #define UFCR_RXTL_SHF 0 /* Receiver trigger level shift */ #define UFCR_RFDIV (7<<7) /* Reference freq divider mask */ #define UFCR_RFDIV_SHF 7 /* Reference freq divider shift */ +#define RFDIV 4 /* divide input clock by 2 */ #define UFCR_DCEDTE (1<<6) /* DTE mode select */ #define UFCR_TXTL_SHF 10 /* Transmitter trigger level shift */ #define USR1_PARITYERR (1<<15) /* Parity error interrupt flag */ @@ -106,7 +107,7 @@ #define UTS_RXEMPTY (1<<5) /* RxFIFO empty */ #define UTS_TXFULL (1<<4) /* TxFIFO full */ #define UTS_RXFULL (1<<3) /* RxFIFO full */ -#define UTS_SOFTRST (1<<0) /* Software reset */ +#define UTS_SOFTRS (1<<0) /* Software reset */
@@ -146,7 +147,6 @@ struct mxc_uart {
#define TXTL 2 /* reset default */ #define RXTL 1 /* reset default */ -#define RFDIV 4 /* divide input clock by 2 */
static void mxc_serial_setbrg(void) { @@ -255,7 +255,7 @@ int mxc_serial_setbrg(struct udevice *dev, int baudrate) u32 clk = imx_get_uartclk(); u32 tmp;
- tmp = 4 << UFCR_RFDIV_SHF; + tmp = RFDIV << UFCR_RFDIV_SHF; if (plat->use_dte) tmp |= UFCR_DCEDTE; writel(tmp, &uart->fcr);
Control reg write should be part of setbrg for better buadrate generation, so move cr1 and cr2 write to mxc_serial_setbrg
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/serial/serial_mxc.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index 65c301d..288b610 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -162,6 +162,9 @@ static void mxc_serial_setbrg(void) writel(0xf, &mxc_base->bir); writel(clk / (2 * gd->baudrate), &mxc_base->bmr);
+ writel(UCR2_WS | UCR2_IRTS | UCR2_RXEN | UCR2_TXEN | UCR2_SRST, + &mxc_base->cr2); + writel(UCR1_UARTEN, &mxc_base->cr1); }
static int mxc_serial_getc(void) @@ -216,11 +219,6 @@ static int mxc_serial_init(void)
serial_setbrg();
- writel(UCR2_WS | UCR2_IRTS | UCR2_RXEN | UCR2_TXEN | UCR2_SRST, - &mxc_base->cr2); - - writel(UCR1_UARTEN, &mxc_base->cr1); - return 0; }
Move the common initialization code into _mxc_serial_init so-that dm and non-dm can call this func.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/serial/serial_mxc.c | 37 +++++++++++++++++-------------------- 1 file changed, 17 insertions(+), 20 deletions(-)
diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index 288b610..4b19052 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -137,6 +137,21 @@ struct mxc_uart { u32 ts; };
+static void _mxc_serial_init(struct mxc_uart *base) +{ + writel(0, &base->cr1); + writel(0, &base->cr2); + + while (!(readl(&base->cr2) & UCR2_SRST)); + + writel(0x704 | UCR3_ADNIMP, &base->cr3); + writel(0x8000, &base->cr4); + writel(0x2b, &base->esc); + writel(0, &base->tim); + + writel(0, &base->ts); +} + #ifndef CONFIG_DM_SERIAL
#ifndef CONFIG_MXC_UART_BASE @@ -205,17 +220,7 @@ static int mxc_serial_tstc(void) */ static int mxc_serial_init(void) { - writel(0, &mxc_base->cr1); - writel(0, &mxc_base->cr2); - - while (!(readl(&mxc_base->cr2) & UCR2_SRST)); - - writel(0x704 | UCR3_ADNIMP, &mxc_base->cr3); - writel(0x8000, &mxc_base->cr4); - writel(0x2b, &mxc_base->esc); - writel(0, &mxc_base->tim); - - writel(0, &mxc_base->ts); + _mxc_serial_init(mxc_base);
serial_setbrg();
@@ -271,16 +276,8 @@ int mxc_serial_setbrg(struct udevice *dev, int baudrate) static int mxc_serial_probe(struct udevice *dev) { struct mxc_serial_platdata *plat = dev->platdata; - struct mxc_uart *const uart = plat->reg;
- writel(0, &uart->cr1); - writel(0, &uart->cr2); - while (!(readl(&uart->cr2) & UCR2_SRST)); - writel(0x704 | UCR3_ADNIMP, &uart->cr3); - writel(0x8000, &uart->cr4); - writel(0x2b, &uart->esc); - writel(0, &uart->tim); - writel(0, &uart->ts); + _mxc_serial_init(plat->reg);
return 0; }
Move the common baud generation code into _mxc_serial_setbrg so-that dm and non-dm can call this func.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/serial/serial_mxc.c | 50 ++++++++++++++++++++++----------------------- 1 file changed, 24 insertions(+), 26 deletions(-)
diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index 4b19052..0fd3aaa 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -108,6 +108,8 @@ #define UTS_TXFULL (1<<4) /* TxFIFO full */ #define UTS_RXFULL (1<<3) /* RxFIFO full */ #define UTS_SOFTRS (1<<0) /* Software reset */ +#define TXTL 2 /* reset default */ +#define RXTL 1 /* reset default */
@@ -152,6 +154,26 @@ static void _mxc_serial_init(struct mxc_uart *base) writel(0, &base->ts); }
+static void _mxc_serial_setbrg(struct mxc_uart *base, unsigned long clk, + unsigned long baudrate, bool use_dte) +{ + u32 tmp; + + tmp = RFDIV << UFCR_RFDIV_SHF; + if (use_dte) + tmp |= UFCR_DCEDTE; + else + tmp |= (TXTL << UFCR_TXTL_SHF) | (RXTL << UFCR_RXTL_SHF); + writel(tmp, &base->fcr); + + writel(0xf, &base->bir); + writel(clk / (2 * baudrate), &base->bmr); + + writel(UCR2_WS | UCR2_IRTS | UCR2_RXEN | UCR2_TXEN | UCR2_SRST, + &base->cr2); + writel(UCR1_UARTEN, &base->cr1); +} + #ifndef CONFIG_DM_SERIAL
#ifndef CONFIG_MXC_UART_BASE @@ -160,9 +182,6 @@ static void _mxc_serial_init(struct mxc_uart *base)
-#define TXTL 2 /* reset default */ -#define RXTL 1 /* reset default */ - static void mxc_serial_setbrg(void) { u32 clk = imx_get_uartclk(); @@ -170,16 +189,7 @@ static void mxc_serial_setbrg(void) if (!gd->baudrate) gd->baudrate = CONFIG_BAUDRATE;
- writel(((RFDIV << UFCR_RFDIV_SHF) | - (TXTL << UFCR_TXTL_SHF) | - (RXTL << UFCR_RXTL_SHF)), - &mxc_base->fcr); - writel(0xf, &mxc_base->bir); - writel(clk / (2 * gd->baudrate), &mxc_base->bmr); - - writel(UCR2_WS | UCR2_IRTS | UCR2_RXEN | UCR2_TXEN | UCR2_SRST, - &mxc_base->cr2); - writel(UCR1_UARTEN, &mxc_base->cr1); + _mxc_serial_setbrg(mxc_base, clk, gd->baudrate, false); }
static int mxc_serial_getc(void) @@ -254,21 +264,9 @@ __weak struct serial_device *default_serial_console(void) int mxc_serial_setbrg(struct udevice *dev, int baudrate) { struct mxc_serial_platdata *plat = dev->platdata; - struct mxc_uart *const uart = plat->reg; u32 clk = imx_get_uartclk(); - u32 tmp;
- tmp = RFDIV << UFCR_RFDIV_SHF; - if (plat->use_dte) - tmp |= UFCR_DCEDTE; - writel(tmp, &uart->fcr); - - writel(0xf, &uart->bir); - writel(clk / (2 * baudrate), &uart->bmr); - - writel(UCR2_WS | UCR2_IRTS | UCR2_RXEN | UCR2_TXEN | UCR2_SRST, - &uart->cr2); - writel(UCR1_UARTEN, &uart->cr1); + _mxc_serial_setbrg(plat->reg, clk, baudrate, plat->use_dte);
return 0; }
- Remove space between #define to macro - Add tab between macro and value
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/serial/serial_mxc.c | 191 ++++++++++++++++++++++---------------------- 1 file changed, 94 insertions(+), 97 deletions(-)
diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index 0fd3aaa..0bcd15c 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -15,99 +15,99 @@ #include <linux/compiler.h>
/* UART Control Register Bit Fields.*/ -#define URXD_CHARRDY (1<<15) -#define URXD_ERR (1<<14) -#define URXD_OVRRUN (1<<13) -#define URXD_FRMERR (1<<12) -#define URXD_BRK (1<<11) -#define URXD_PRERR (1<<10) -#define URXD_RX_DATA (0xFF) -#define UCR1_ADEN (1<<15) /* Auto dectect interrupt */ -#define UCR1_ADBR (1<<14) /* Auto detect baud rate */ -#define UCR1_TRDYEN (1<<13) /* Transmitter ready interrupt enable */ -#define UCR1_IDEN (1<<12) /* Idle condition interrupt */ -#define UCR1_RRDYEN (1<<9) /* Recv ready interrupt enable */ -#define UCR1_RDMAEN (1<<8) /* Recv ready DMA enable */ -#define UCR1_IREN (1<<7) /* Infrared interface enable */ -#define UCR1_TXMPTYEN (1<<6) /* Transimitter empty interrupt enable */ -#define UCR1_RTSDEN (1<<5) /* RTS delta interrupt enable */ -#define UCR1_SNDBRK (1<<4) /* Send break */ -#define UCR1_TDMAEN (1<<3) /* Transmitter ready DMA enable */ -#define UCR1_UARTCLKEN (1<<2) /* UART clock enabled */ -#define UCR1_DOZE (1<<1) /* Doze */ -#define UCR1_UARTEN (1<<0) /* UART enabled */ -#define UCR2_ESCI (1<<15) /* Escape seq interrupt enable */ -#define UCR2_IRTS (1<<14) /* Ignore RTS pin */ -#define UCR2_CTSC (1<<13) /* CTS pin control */ -#define UCR2_CTS (1<<12) /* Clear to send */ -#define UCR2_ESCEN (1<<11) /* Escape enable */ -#define UCR2_PREN (1<<8) /* Parity enable */ -#define UCR2_PROE (1<<7) /* Parity odd/even */ -#define UCR2_STPB (1<<6) /* Stop */ -#define UCR2_WS (1<<5) /* Word size */ -#define UCR2_RTSEN (1<<4) /* Request to send interrupt enable */ -#define UCR2_TXEN (1<<2) /* Transmitter enabled */ -#define UCR2_RXEN (1<<1) /* Receiver enabled */ -#define UCR2_SRST (1<<0) /* SW reset */ -#define UCR3_DTREN (1<<13) /* DTR interrupt enable */ -#define UCR3_PARERREN (1<<12) /* Parity enable */ -#define UCR3_FRAERREN (1<<11) /* Frame error interrupt enable */ -#define UCR3_DSR (1<<10) /* Data set ready */ -#define UCR3_DCD (1<<9) /* Data carrier detect */ -#define UCR3_RI (1<<8) /* Ring indicator */ -#define UCR3_ADNIMP (1<<7) /* Autobaud Detection Not Improved */ -#define UCR3_RXDSEN (1<<6) /* Receive status interrupt enable */ -#define UCR3_AIRINTEN (1<<5) /* Async IR wake interrupt enable */ -#define UCR3_AWAKEN (1<<4) /* Async wake interrupt enable */ -#define UCR3_REF25 (1<<3) /* Ref freq 25 MHz */ -#define UCR3_REF30 (1<<2) /* Ref Freq 30 MHz */ -#define UCR3_INVT (1<<1) /* Inverted Infrared transmission */ -#define UCR3_BPEN (1<<0) /* Preset registers enable */ -#define UCR4_CTSTL_32 (32<<10) /* CTS trigger level (32 chars) */ -#define UCR4_INVR (1<<9) /* Inverted infrared reception */ -#define UCR4_ENIRI (1<<8) /* Serial infrared interrupt enable */ -#define UCR4_WKEN (1<<7) /* Wake interrupt enable */ -#define UCR4_REF16 (1<<6) /* Ref freq 16 MHz */ -#define UCR4_IRSC (1<<5) /* IR special case */ -#define UCR4_TCEN (1<<3) /* Transmit complete interrupt enable */ -#define UCR4_BKEN (1<<2) /* Break condition interrupt enable */ -#define UCR4_OREN (1<<1) /* Receiver overrun interrupt enable */ -#define UCR4_DREN (1<<0) /* Recv data ready interrupt enable */ -#define UFCR_RXTL_SHF 0 /* Receiver trigger level shift */ -#define UFCR_RFDIV (7<<7) /* Reference freq divider mask */ -#define UFCR_RFDIV_SHF 7 /* Reference freq divider shift */ -#define RFDIV 4 /* divide input clock by 2 */ -#define UFCR_DCEDTE (1<<6) /* DTE mode select */ -#define UFCR_TXTL_SHF 10 /* Transmitter trigger level shift */ -#define USR1_PARITYERR (1<<15) /* Parity error interrupt flag */ -#define USR1_RTSS (1<<14) /* RTS pin status */ -#define USR1_TRDY (1<<13) /* Transmitter ready interrupt/dma flag */ -#define USR1_RTSD (1<<12) /* RTS delta */ -#define USR1_ESCF (1<<11) /* Escape seq interrupt flag */ -#define USR1_FRAMERR (1<<10) /* Frame error interrupt flag */ -#define USR1_RRDY (1<<9) /* Receiver ready interrupt/dma flag */ -#define USR1_TIMEOUT (1<<7) /* Receive timeout interrupt status */ -#define USR1_RXDS (1<<6) /* Receiver idle interrupt flag */ -#define USR1_AIRINT (1<<5) /* Async IR wake interrupt flag */ -#define USR1_AWAKE (1<<4) /* Aysnc wake interrupt flag */ -#define USR2_ADET (1<<15) /* Auto baud rate detect complete */ -#define USR2_TXFE (1<<14) /* Transmit buffer FIFO empty */ -#define USR2_DTRF (1<<13) /* DTR edge interrupt flag */ -#define USR2_IDLE (1<<12) /* Idle condition */ -#define USR2_IRINT (1<<8) /* Serial infrared interrupt flag */ -#define USR2_WAKE (1<<7) /* Wake */ -#define USR2_RTSF (1<<4) /* RTS edge interrupt flag */ -#define USR2_TXDC (1<<3) /* Transmitter complete */ -#define USR2_BRCD (1<<2) /* Break condition */ -#define USR2_ORE (1<<1) /* Overrun error */ -#define USR2_RDR (1<<0) /* Recv data ready */ -#define UTS_FRCPERR (1<<13) /* Force parity error */ -#define UTS_LOOP (1<<12) /* Loop tx and rx */ -#define UTS_TXEMPTY (1<<6) /* TxFIFO empty */ -#define UTS_RXEMPTY (1<<5) /* RxFIFO empty */ -#define UTS_TXFULL (1<<4) /* TxFIFO full */ -#define UTS_RXFULL (1<<3) /* RxFIFO full */ -#define UTS_SOFTRS (1<<0) /* Software reset */ +#define URXD_CHARRDY (1<<15) +#define URXD_ERR (1<<14) +#define URXD_OVRRUN (1<<13) +#define URXD_FRMERR (1<<12) +#define URXD_BRK (1<<11) +#define URXD_PRERR (1<<10) +#define URXD_RX_DATA (0xFF) +#define UCR1_ADEN (1<<15) /* Auto dectect interrupt */ +#define UCR1_ADBR (1<<14) /* Auto detect baud rate */ +#define UCR1_TRDYEN (1<<13) /* Transmitter ready interrupt enable */ +#define UCR1_IDEN (1<<12) /* Idle condition interrupt */ +#define UCR1_RRDYEN (1<<9) /* Recv ready interrupt enable */ +#define UCR1_RDMAEN (1<<8) /* Recv ready DMA enable */ +#define UCR1_IREN (1<<7) /* Infrared interface enable */ +#define UCR1_TXMPTYEN (1<<6) /* Transimitter empty interrupt enable */ +#define UCR1_RTSDEN (1<<5) /* RTS delta interrupt enable */ +#define UCR1_SNDBRK (1<<4) /* Send break */ +#define UCR1_TDMAEN (1<<3) /* Transmitter ready DMA enable */ +#define UCR1_UARTCLKEN (1<<2) /* UART clock enabled */ +#define UCR1_DOZE (1<<1) /* Doze */ +#define UCR1_UARTEN (1<<0) /* UART enabled */ +#define UCR2_ESCI (1<<15) /* Escape seq interrupt enable */ +#define UCR2_IRTS (1<<14) /* Ignore RTS pin */ +#define UCR2_CTSC (1<<13) /* CTS pin control */ +#define UCR2_CTS (1<<12) /* Clear to send */ +#define UCR2_ESCEN (1<<11) /* Escape enable */ +#define UCR2_PREN (1<<8) /* Parity enable */ +#define UCR2_PROE (1<<7) /* Parity odd/even */ +#define UCR2_STPB (1<<6) /* Stop */ +#define UCR2_WS (1<<5) /* Word size */ +#define UCR2_RTSEN (1<<4) /* Request to send interrupt enable */ +#define UCR2_TXEN (1<<2) /* Transmitter enabled */ +#define UCR2_RXEN (1<<1) /* Receiver enabled */ +#define UCR2_SRST (1<<0) /* SW reset */ +#define UCR3_DTREN (1<<13) /* DTR interrupt enable */ +#define UCR3_PARERREN (1<<12) /* Parity enable */ +#define UCR3_FRAERREN (1<<11) /* Frame error interrupt enable */ +#define UCR3_DSR (1<<10) /* Data set ready */ +#define UCR3_DCD (1<<9) /* Data carrier detect */ +#define UCR3_RI (1<<8) /* Ring indicator */ +#define UCR3_ADNIMP (1<<7) /* Autobaud Detection Not Improved */ +#define UCR3_RXDSEN (1<<6) /* Receive status interrupt enable */ +#define UCR3_AIRINTEN (1<<5) /* Async IR wake interrupt enable */ +#define UCR3_AWAKEN (1<<4) /* Async wake interrupt enable */ +#define UCR3_REF25 (1<<3) /* Ref freq 25 MHz */ +#define UCR3_REF30 (1<<2) /* Ref Freq 30 MHz */ +#define UCR3_INVT (1<<1) /* Inverted Infrared transmission */ +#define UCR3_BPEN (1<<0) /* Preset registers enable */ +#define UCR4_CTSTL_32 (32<<10) /* CTS trigger level (32 chars) */ +#define UCR4_INVR (1<<9) /* Inverted infrared reception */ +#define UCR4_ENIRI (1<<8) /* Serial infrared interrupt enable */ +#define UCR4_WKEN (1<<7) /* Wake interrupt enable */ +#define UCR4_REF16 (1<<6) /* Ref freq 16 MHz */ +#define UCR4_IRSC (1<<5) /* IR special case */ +#define UCR4_TCEN (1<<3) /* Transmit complete interrupt enable */ +#define UCR4_BKEN (1<<2) /* Break condition interrupt enable */ +#define UCR4_OREN (1<<1) /* Receiver overrun interrupt enable */ +#define UCR4_DREN (1<<0) /* Recv data ready interrupt enable */ +#define UFCR_RXTL_SHF 0 /* Receiver trigger level shift */ +#define UFCR_RFDIV (7<<7) /* Reference freq divider mask */ +#define UFCR_RFDIV_SHF 7 /* Reference freq divider shift */ +#define RFDIV 4 /* divide input clock by 2 */ +#define UFCR_DCEDTE (1<<6) /* DTE mode select */ +#define UFCR_TXTL_SHF 10 /* Transmitter trigger level shift */ +#define USR1_PARITYERR (1<<15) /* Parity error interrupt flag */ +#define USR1_RTSS (1<<14) /* RTS pin status */ +#define USR1_TRDY (1<<13) /* Transmitter ready interrupt/dma flag */ +#define USR1_RTSD (1<<12) /* RTS delta */ +#define USR1_ESCF (1<<11) /* Escape seq interrupt flag */ +#define USR1_FRAMERR (1<<10) /* Frame error interrupt flag */ +#define USR1_RRDY (1<<9) /* Receiver ready interrupt/dma flag */ +#define USR1_TIMEOUT (1<<7) /* Receive timeout interrupt status */ +#define USR1_RXDS (1<<6) /* Receiver idle interrupt flag */ +#define USR1_AIRINT (1<<5) /* Async IR wake interrupt flag */ +#define USR1_AWAKE (1<<4) /* Aysnc wake interrupt flag */ +#define USR2_ADET (1<<15) /* Auto baud rate detect complete */ +#define USR2_TXFE (1<<14) /* Transmit buffer FIFO empty */ +#define USR2_DTRF (1<<13) /* DTR edge interrupt flag */ +#define USR2_IDLE (1<<12) /* Idle condition */ +#define USR2_IRINT (1<<8) /* Serial infrared interrupt flag */ +#define USR2_WAKE (1<<7) /* Wake */ +#define USR2_RTSF (1<<4) /* RTS edge interrupt flag */ +#define USR2_TXDC (1<<3) /* Transmitter complete */ +#define USR2_BRCD (1<<2) /* Break condition */ +#define USR2_ORE (1<<1) /* Overrun error */ +#define USR2_RDR (1<<0) /* Recv data ready */ +#define UTS_FRCPERR (1<<13) /* Force parity error */ +#define UTS_LOOP (1<<12) /* Loop tx and rx */ +#define UTS_TXEMPTY (1<<6) /* TxFIFO empty */ +#define UTS_RXEMPTY (1<<5) /* RxFIFO empty */ +#define UTS_TXFULL (1<<4) /* TxFIFO full */ +#define UTS_RXFULL (1<<3) /* RxFIFO full */ +#define UTS_SOFTRS (1<<0) /* Software reset */ #define TXTL 2 /* reset default */ #define RXTL 1 /* reset default */
@@ -212,9 +212,7 @@ static void mxc_serial_putc(const char c) WATCHDOG_RESET(); }
-/* - * Test whether a character is in the RX buffer - */ +/* Test whether a character is in the RX buffer */ static int mxc_serial_tstc(void) { /* If receive fifo is empty, return false */ @@ -226,7 +224,6 @@ static int mxc_serial_tstc(void) /* * Initialise the serial port with the given baudrate. The settings * are always 8 data bits, no parity, 1 stop bit, no start bits. - * */ static int mxc_serial_init(void) {
Add support for the debug UART to assist with early debugging. Enable it for i.CoreM6 as an example.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/imx6qdl_icore_mmc_defconfig | 4 ++++ drivers/serial/Kconfig | 8 ++++++++ drivers/serial/serial_mxc.c | 26 ++++++++++++++++++++++++++ 3 files changed, 38 insertions(+)
diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index 4ab1fac..24010ec 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -44,3 +44,7 @@ CONFIG_IMX_THERMAL=y CONFIG_VIDEO_IPUV3=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_MXC=y +CONFIG_DEBUG_UART_BASE=0x021f0000 +CONFIG_DEBUG_UART_CLOCK=24000000 diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 58fc7cd..32a3374 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -248,6 +248,14 @@ config DEBUG_UART_PIC32 will need to provide parameters to make this work. The driver will be available until the real driver model serial is running.
+config DEBUG_UART_MXC + bool "IMX Serial port" + depends on MXC_UART + help + Select this to enable a debug UART using the serial_mxc driver. You + will need to provide parameters to make this work. The driver will + be available until the real driver model serial is running. + config DEBUG_UART_UNIPHIER bool "UniPhier on-chip UART" depends on ARCH_UNIPHIER diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index 0bcd15c..18ff421 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -357,3 +357,29 @@ U_BOOT_DRIVER(serial_mxc) = { .flags = DM_FLAG_PRE_RELOC, }; #endif + +#ifdef CONFIG_DEBUG_UART_MXC +#include <debug_uart.h> + +static inline void _debug_uart_init(void) +{ + struct mxc_uart *base = (struct mxc_uart *)CONFIG_DEBUG_UART_BASE; + + _mxc_serial_init(base); + _mxc_serial_setbrg(base, CONFIG_DEBUG_UART_CLOCK, + CONFIG_BAUDRATE, false); +} + +static inline void _debug_uart_putc(int ch) +{ + struct mxc_uart *base = (struct mxc_uart *)CONFIG_DEBUG_UART_BASE; + + while (!(readl(&base->ts) & UTS_TXEMPTY)) + WATCHDOG_RESET(); + + writel(ch, &base->txd); +} + +DEBUG_UART_FUNCS + +#endif
Jagan Teki
Stefano Babic
