[FIX PATCH v1] Fix: common: usb_hub: Reset only USB3.0 hub
USB 3.0 spec requires hub to reset device while enumeration. Some USB 2.0 hubs / devices don't handle this well and after implementation of reset some USB 2.0 disks weren't detected on Allwinner based boards.
Resetting only when hub is USB 3.0 fixes it.
Tested-by: Andre Przywara andre.przywara@arm.com
Signed-off-by: Shantur Rathore i@shantur.com ---
common/usb_hub.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/common/usb_hub.c b/common/usb_hub.c index 3fb7e14d10..2e054eb935 100644 --- a/common/usb_hub.c +++ b/common/usb_hub.c @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct usb_hub_device *hub)
debug("enabling power on all ports\n"); for (i = 0; i < dev->maxchild; i++) { - usb_set_port_feature(dev, i + 1, USB_PORT_FEAT_RESET); - debug("Reset : port %d returns %lX\n", i + 1, dev->status); + if (usb_hub_is_superspeed(dev)) { + usb_set_port_feature(dev, i + 1, USB_PORT_FEAT_RESET); + debug("Reset : port %d returns %lX\n", i + 1, dev->status); + } usb_set_port_feature(dev, i + 1, USB_PORT_FEAT_POWER); debug("PowerOn : port %d returns %lX\n", i + 1, dev->status); }
It would be good to include as many details about the faulty hardware in the commit message as possible, so that when someone else runs into this, they would have all that information available.
Should this condition be "all which are lower than superspeed" instead , so when the next generation of USB comes, this problem won't trigger ?
What does Linux do btw ?
Hi Marek,
As of now Linux checks if the hub is superspeed https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.c#L2859
which is return hdev->descriptor.bDeviceProtocol == USB_HUB_PR_SS; // USB_HUB_PR_SS = 3
This holds true for newer SuperSpeedPlus hubs as well. https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.h#L155
We can change the check to be bDeviceProtocol > 2 but who knows if things change in the newer version of spec. I am open to suggestions.
Kind regards, Shantur
On 2/8/24 12:30, Shantur Rathore wrote:
Hi Marek,
Please just include the ^ in the commit description. Use link to git.kernel.org , not some mirror . This is extremely useful information and, well, you already wrote the V2 commit message addition in this answer.
Thanks
dev->status);
Shantur, if that would be easier or quicker for you, I can write a quite detailed patch description for you, in exchange for a "Helped-by" tag in the v2 patch submission. :)
dev->status);
That would be really kind of you Dragan. I am down with the flu so that would really help me as my brain is working at 15% capacity.
dev->status);
Sure, I'll write the summary and send it over.
Oh, I'm really sorry to hear that. :( I hope you'll get better soon, and I know very well what's it like; I've also been sick recently, as a result of some kind of flu that unfortunately found its way into my lungs, and it took me about a month to get back to about 90% of my usual mental capacity. I'm still not back to exactly 100%. :/
I really hope you'll recover much faster.
Hello Shantur,
On 2/7/24 11:23, Shantur Rathore wrote: > USB 3.0 spec requires hub to reset device while > enumeration. Some USB 2.0 hubs / devices don't > handle this well and after implementation of > reset some USB 2.0 disks weren't detected on > Allwinner based boards. > > Resetting only when hub is USB 3.0 fixes it.
> Tested-by: Andre Przywara andre.przywara@arm.com > > Signed-off-by: Shantur Rathore i@shantur.com > --- > > common/usb_hub.c | 6 ++++-- > 1 file changed, 4 insertions(+), 2 deletions(-) > > diff --git a/common/usb_hub.c b/common/usb_hub.c > index 3fb7e14d10..2e054eb935 100644 > --- a/common/usb_hub.c > +++ b/common/usb_hub.c > @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct > usb_hub_device *hub) > > debug("enabling power on all ports\n"); > for (i = 0; i < dev->maxchild; i++) { > - usb_set_port_feature(dev, i + 1, USB_PORT_FEAT_RESET); > - debug("Reset : port %d returns %lX\n", i + 1, > dev->status); > + if (usb_hub_is_superspeed(dev)) {
I hope you're feeling better.
Below are the patch subject and description that I prepared for you, please have a look.
------- >8 ------------- >8 ------------- >8 ------------- >8 ------- [PATCH v2] common: usb-hub: Reset USB 3.0 hubs only
Additional testing of the changes introduced in commit 33e06dcbe57a ("common: usb-hub: Reset hub port before scanning") revealed that some USB 3.0 flash drives didn't work in U-Boot on some Allwinner SoCs that support USB 2.0 only. More precisely, some tested USB 3.0 flash drives failed to be detected and work on an OrangePi Zero 3 with Allwinner H616 SoC, which supports USB 2.0 only, while the same USB flash drives worked just fine on a Pine64 H64 with Allwinner H6 SoC, which supports both USB 2.0 and 3.0.
Resetting USB 3.0 hubs only has been tested to work as expected, resolving the previous issues on the Allwinner H616, while not introducing any new issues on other Allwinner SoCs. Thus, let's fix it that way.
According to the USB 3.0 specification, resetting a USB 3.0 port is required when an attached USB device transitions between different states, such as when it resumes from suspend. Though, the Linux kernel performs additional USB 3.0 port resets upon initial USB device attachment, presumably to ensure proper state of the USB 3.0 hub port and proper USB mode negotiation during the initial USB device attachment and enumeration.
Such USB port resets don't seem to exist for USB 2.0 hubs, according the USB 2.0 specification. The resets seem to be added to the USB 3.0 specification as part of the port and device mode negotiation.
The Linux kernel also resets USB 3.0 (i.e. SuperSpeed) hubs only, as visible in file drivers/usb/core/hub.c in the kernel source, line 2859. This check also applies to newer SuperSpeed Plus (USB 3.1 or 3.2) hubs as well, which hopefully makes it future proof.
Fixes: 33e06dcbe57a ("common: usb-hub: Reset hub port before scanning") Link: https://lore.kernel.org/u-boot/20240207102327.35125-1-i@shantur.com/T/#u Link: https://lore.kernel.org/u-boot/20240201164604.13315fa6@donnerap.manchester.a... Signed-off-by: Shantur Rathore i@shantur.com Helped-by: Dragan Simic dsimic@manjaro.org Tested-by: Andre Przywara andre.przywara@arm.com Reviewed-by: Dragan Simic dsimic@manjaro.org ------- >8 ------------- >8 ------------- >8 ------------- >8 -------
Thanks Dragan,
On Sat, Feb 10, 2024 at 7:13 AM Dragan Simic dsimic@manjaro.org wrote:
Hello Shantur,
On Wed, Feb 7, 2024 at 1:07 PM Marek Vasut marex@denx.de wrote: > On 2/7/24 11:23, Shantur Rathore wrote: >> USB 3.0 spec requires hub to reset device while >> enumeration. Some USB 2.0 hubs / devices don't >> handle this well and after implementation of >> reset some USB 2.0 disks weren't detected on >> Allwinner based boards. >> >> Resetting only when hub is USB 3.0 fixes it. > > It would be good to include as many details about the faulty hardware > in > the commit message as possible, so that when someone else runs into > this, they would have all that information available. > >> Tested-by: Andre Przywara andre.przywara@arm.com >> >> Signed-off-by: Shantur Rathore i@shantur.com >> --- >> >> common/usb_hub.c | 6 ++++-- >> 1 file changed, 4 insertions(+), 2 deletions(-) >> >> diff --git a/common/usb_hub.c b/common/usb_hub.c >> index 3fb7e14d10..2e054eb935 100644 >> --- a/common/usb_hub.c >> +++ b/common/usb_hub.c >> @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct >> usb_hub_device *hub) >> >> debug("enabling power on all ports\n"); >> for (i = 0; i < dev->maxchild; i++) { >> - usb_set_port_feature(dev, i + 1, USB_PORT_FEAT_RESET); >> - debug("Reset : port %d returns %lX\n", i + 1, >> dev->status); >> + if (usb_hub_is_superspeed(dev)) { > > Should this condition be "all which are lower than superspeed" > instead , > so when the next generation of USB comes, this problem won't trigger > ? > > What does Linux do btw ?
I think it was a USB 2.0 drive that didn't work on the USB 2.0 port.
Regards, Shantur
On Mon, Feb 12, 2024 at 1:40 PM Shantur Rathore i@shantur.com wrote:
Thanks Dragan,
Hello Shantur,
On 2/8/24 12:30, Shantur Rathore wrote: > On Wed, Feb 7, 2024 at 1:07 PM Marek Vasut marex@denx.de wrote: >> On 2/7/24 11:23, Shantur Rathore wrote: >>> USB 3.0 spec requires hub to reset device while >>> enumeration. Some USB 2.0 hubs / devices don't >>> handle this well and after implementation of >>> reset some USB 2.0 disks weren't detected on >>> Allwinner based boards. >>> >>> Resetting only when hub is USB 3.0 fixes it. >> >> It would be good to include as many details about the faulty hardware >> in >> the commit message as possible, so that when someone else runs into >> this, they would have all that information available. >> >>> Tested-by: Andre Przywara andre.przywara@arm.com >>> >>> Signed-off-by: Shantur Rathore i@shantur.com >>> --- >>> >>> common/usb_hub.c | 6 ++++-- >>> 1 file changed, 4 insertions(+), 2 deletions(-) >>> >>> diff --git a/common/usb_hub.c b/common/usb_hub.c >>> index 3fb7e14d10..2e054eb935 100644 >>> --- a/common/usb_hub.c >>> +++ b/common/usb_hub.c >>> @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct >>> usb_hub_device *hub) >>> >>> debug("enabling power on all ports\n"); >>> for (i = 0; i < dev->maxchild; i++) { >>> - usb_set_port_feature(dev, i + 1, USB_PORT_FEAT_RESET); >>> - debug("Reset : port %d returns %lX\n", i + 1, >>> dev->status); >>> + if (usb_hub_is_superspeed(dev)) { >> >> Should this condition be "all which are lower than superspeed" >> instead , >> so when the next generation of USB comes, this problem won't trigger >> ? >> >> What does Linux do btw ? > > As of now Linux checks if the hub is superspeed > https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.c#L2859 > > which is > return hdev->descriptor.bDeviceProtocol == USB_HUB_PR_SS; // > USB_HUB_PR_SS = 3 > > This holds true for newer SuperSpeedPlus hubs as well. > https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.h#L155 > > We can change the check to be bDeviceProtocol > 2 but who knows if > things change in the newer version of spec. > I am open to suggestions.
Regards, Shantur
Is this description acceptable to you Marek.
Thanks, Shantur
Thanks Dragan,
Hello Shantur,
On 2024-02-08 14:33, Marek Vasut wrote: > On 2/8/24 12:30, Shantur Rathore wrote: >> On Wed, Feb 7, 2024 at 1:07 PM Marek Vasut marex@denx.de wrote: >>> On 2/7/24 11:23, Shantur Rathore wrote: >>>> USB 3.0 spec requires hub to reset device while >>>> enumeration. Some USB 2.0 hubs / devices don't >>>> handle this well and after implementation of >>>> reset some USB 2.0 disks weren't detected on >>>> Allwinner based boards. >>>> >>>> Resetting only when hub is USB 3.0 fixes it. >>> >>> It would be good to include as many details about the faulty hardware >>> in >>> the commit message as possible, so that when someone else runs into >>> this, they would have all that information available. >>> >>>> Tested-by: Andre Przywara andre.przywara@arm.com >>>> >>>> Signed-off-by: Shantur Rathore i@shantur.com >>>> --- >>>> >>>> common/usb_hub.c | 6 ++++-- >>>> 1 file changed, 4 insertions(+), 2 deletions(-) >>>> >>>> diff --git a/common/usb_hub.c b/common/usb_hub.c >>>> index 3fb7e14d10..2e054eb935 100644 >>>> --- a/common/usb_hub.c >>>> +++ b/common/usb_hub.c >>>> @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct >>>> usb_hub_device *hub) >>>> >>>> debug("enabling power on all ports\n"); >>>> for (i = 0; i < dev->maxchild; i++) { >>>> - usb_set_port_feature(dev, i + 1, USB_PORT_FEAT_RESET); >>>> - debug("Reset : port %d returns %lX\n", i + 1, >>>> dev->status); >>>> + if (usb_hub_is_superspeed(dev)) { >>> >>> Should this condition be "all which are lower than superspeed" >>> instead , >>> so when the next generation of USB comes, this problem won't trigger >>> ? >>> >>> What does Linux do btw ? >> >> As of now Linux checks if the hub is superspeed >> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.c#L2859 >> >> which is >> return hdev->descriptor.bDeviceProtocol == USB_HUB_PR_SS; // >> USB_HUB_PR_SS = 3 >> >> This holds true for newer SuperSpeedPlus hubs as well. >> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.h#L155 >> >> We can change the check to be bDeviceProtocol > 2 but who knows if >> things change in the newer version of spec. >> I am open to suggestions. > > Please just include the ^ in the commit description. Use link to > git.kernel.org , not some mirror . This is extremely useful > information and, well, you already wrote the V2 commit message > addition in this answer.
Regards, Shantur
Please send a V2 patch . If possible, include the device information as reported by Andre, esp. which USB stick triggered it, including USB IDs, this is important for future reference and in case someone has similar failure.
Please don't use "in the kernel source, line 2859", considering the rate of change of the Linux kernel, it is best to also include exact commit ID as of which this is a line 2859 and spell out this is referring to Linux kernel.
Hello Marek, Andre and Shantur,
On Thu, Feb 8, 2024 at 1:44 PM Dragan Simic dsimic@manjaro.org wrote: > On 2024-02-08 14:33, Marek Vasut wrote: >> On 2/8/24 12:30, Shantur Rathore wrote: >>> On Wed, Feb 7, 2024 at 1:07 PM Marek Vasut marex@denx.de >>> wrote: >>>> On 2/7/24 11:23, Shantur Rathore wrote: >>>>> USB 3.0 spec requires hub to reset device while >>>>> enumeration. Some USB 2.0 hubs / devices don't >>>>> handle this well and after implementation of >>>>> reset some USB 2.0 disks weren't detected on >>>>> Allwinner based boards. >>>>> >>>>> Resetting only when hub is USB 3.0 fixes it. >>>> >>>> It would be good to include as many details about the faulty >>>> hardware >>>> in >>>> the commit message as possible, so that when someone else runs >>>> into >>>> this, they would have all that information available. >>>> >>>>> Tested-by: Andre Przywara andre.przywara@arm.com >>>>> >>>>> Signed-off-by: Shantur Rathore i@shantur.com >>>>> --- >>>>> >>>>> common/usb_hub.c | 6 ++++-- >>>>> 1 file changed, 4 insertions(+), 2 deletions(-) >>>>> >>>>> diff --git a/common/usb_hub.c b/common/usb_hub.c >>>>> index 3fb7e14d10..2e054eb935 100644 >>>>> --- a/common/usb_hub.c >>>>> +++ b/common/usb_hub.c >>>>> @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct >>>>> usb_hub_device *hub) >>>>> >>>>> debug("enabling power on all ports\n"); >>>>> for (i = 0; i < dev->maxchild; i++) { >>>>> - usb_set_port_feature(dev, i + 1, >>>>> USB_PORT_FEAT_RESET); >>>>> - debug("Reset : port %d returns %lX\n", i + 1, >>>>> dev->status); >>>>> + if (usb_hub_is_superspeed(dev)) { >>>> >>>> Should this condition be "all which are lower than superspeed" >>>> instead , >>>> so when the next generation of USB comes, this problem won't >>>> trigger >>>> ? >>>> >>>> What does Linux do btw ? >>> >>> As of now Linux checks if the hub is superspeed >>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.c#L2859 >>> >>> which is >>> return hdev->descriptor.bDeviceProtocol == USB_HUB_PR_SS; // >>> USB_HUB_PR_SS = 3 >>> >>> This holds true for newer SuperSpeedPlus hubs as well. >>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.h#L155 >>> >>> We can change the check to be bDeviceProtocol > 2 but who >>> knows if >>> things change in the newer version of spec. >>> I am open to suggestions. >> >> Please just include the ^ in the commit description. Use link to >> git.kernel.org , not some mirror . This is extremely useful >> information and, well, you already wrote the V2 commit message >> addition in this answer. > > Shantur, if that would be easier or quicker for you, I can write > a quite detailed patch description for you, in exchange for a > "Helped-by" tag in the v2 patch submission. :)
Regards, Shantur
If Andre can supply the USB IDs, I'm willing to help Shantur by adjusting the wording of the patch description to include them.
Good point. I'm willing to adjust the wording.
On 2024-02-08 15:10, Shantur Rathore wrote: > On Thu, Feb 8, 2024 at 1:44 PM Dragan Simic dsimic@manjaro.org > wrote: >> On 2024-02-08 14:33, Marek Vasut wrote: >>> On 2/8/24 12:30, Shantur Rathore wrote: >>>> On Wed, Feb 7, 2024 at 1:07 PM Marek Vasut marex@denx.de wrote: >>>>> On 2/7/24 11:23, Shantur Rathore wrote: >>>>>> USB 3.0 spec requires hub to reset device while >>>>>> enumeration. Some USB 2.0 hubs / devices don't >>>>>> handle this well and after implementation of >>>>>> reset some USB 2.0 disks weren't detected on >>>>>> Allwinner based boards. >>>>>> >>>>>> Resetting only when hub is USB 3.0 fixes it. >>>>> >>>>> It would be good to include as many details about the faulty >>>>> hardware >>>>> in >>>>> the commit message as possible, so that when someone else >>>>> runs into >>>>> this, they would have all that information available. >>>>> >>>>>> Tested-by: Andre Przywara andre.przywara@arm.com >>>>>> >>>>>> Signed-off-by: Shantur Rathore i@shantur.com >>>>>> --- >>>>>> >>>>>> common/usb_hub.c | 6 ++++-- >>>>>> 1 file changed, 4 insertions(+), 2 deletions(-) >>>>>> >>>>>> diff --git a/common/usb_hub.c b/common/usb_hub.c >>>>>> index 3fb7e14d10..2e054eb935 100644 >>>>>> --- a/common/usb_hub.c >>>>>> +++ b/common/usb_hub.c >>>>>> @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct >>>>>> usb_hub_device *hub) >>>>>> >>>>>> debug("enabling power on all ports\n"); >>>>>> for (i = 0; i < dev->maxchild; i++) { >>>>>> - usb_set_port_feature(dev, i + 1, >>>>>> USB_PORT_FEAT_RESET); >>>>>> - debug("Reset : port %d returns %lX\n", i + 1, >>>>>> dev->status); >>>>>> + if (usb_hub_is_superspeed(dev)) { >>>>> >>>>> Should this condition be "all which are lower than superspeed" >>>>> instead , >>>>> so when the next generation of USB comes, this problem won't >>>>> trigger >>>>> ? >>>>> >>>>> What does Linux do btw ? >>>> >>>> As of now Linux checks if the hub is superspeed >>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.c#L2859 >>>> >>>> which is >>>> return hdev->descriptor.bDeviceProtocol == USB_HUB_PR_SS; // >>>> USB_HUB_PR_SS = 3 >>>> >>>> This holds true for newer SuperSpeedPlus hubs as well. >>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.h#L155 >>>> >>>> We can change the check to be bDeviceProtocol > 2 but who >>>> knows if >>>> things change in the newer version of spec. >>>> I am open to suggestions. >>> >>> Please just include the ^ in the commit description. Use link to >>> git.kernel.org , not some mirror . This is extremely useful >>> information and, well, you already wrote the V2 commit message >>> addition in this answer. >> >> Shantur, if that would be easier or quicker for you, I can write >> a quite detailed patch description for you, in exchange for a >> "Helped-by" tag in the v2 patch submission. :) > > That would be really kind of you Dragan.
> I am down with the flu so that would really help me as my brain is > working at 15% capacity.
Regards, Shantur
That's what I'm hoping is gonna happen , thanks !
Thanks .
On 2024-02-08 15:17, Dragan Simic wrote: > On 2024-02-08 15:10, Shantur Rathore wrote: >> On Thu, Feb 8, 2024 at 1:44 PM Dragan Simic dsimic@manjaro.org >> wrote: >>> On 2024-02-08 14:33, Marek Vasut wrote: >>>> On 2/8/24 12:30, Shantur Rathore wrote: >>>>> On Wed, Feb 7, 2024 at 1:07 PM Marek Vasut marex@denx.de >>>>> wrote: >>>>>> On 2/7/24 11:23, Shantur Rathore wrote: >>>>>>> USB 3.0 spec requires hub to reset device while >>>>>>> enumeration. Some USB 2.0 hubs / devices don't >>>>>>> handle this well and after implementation of >>>>>>> reset some USB 2.0 disks weren't detected on >>>>>>> Allwinner based boards. >>>>>>> >>>>>>> Resetting only when hub is USB 3.0 fixes it. >>>>>> >>>>>> It would be good to include as many details about the faulty >>>>>> hardware >>>>>> in >>>>>> the commit message as possible, so that when someone else >>>>>> runs into >>>>>> this, they would have all that information available. >>>>>> >>>>>>> Tested-by: Andre Przywara andre.przywara@arm.com >>>>>>> >>>>>>> Signed-off-by: Shantur Rathore i@shantur.com >>>>>>> --- >>>>>>> >>>>>>> common/usb_hub.c | 6 ++++-- >>>>>>> 1 file changed, 4 insertions(+), 2 deletions(-) >>>>>>> >>>>>>> diff --git a/common/usb_hub.c b/common/usb_hub.c >>>>>>> index 3fb7e14d10..2e054eb935 100644 >>>>>>> --- a/common/usb_hub.c >>>>>>> +++ b/common/usb_hub.c >>>>>>> @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct >>>>>>> usb_hub_device *hub) >>>>>>> >>>>>>> debug("enabling power on all ports\n"); >>>>>>> for (i = 0; i < dev->maxchild; i++) { >>>>>>> - usb_set_port_feature(dev, i + 1, >>>>>>> USB_PORT_FEAT_RESET); >>>>>>> - debug("Reset : port %d returns %lX\n", i + 1, >>>>>>> dev->status); >>>>>>> + if (usb_hub_is_superspeed(dev)) { >>>>>> >>>>>> Should this condition be "all which are lower than >>>>>> superspeed" >>>>>> instead , >>>>>> so when the next generation of USB comes, this problem won't >>>>>> trigger >>>>>> ? >>>>>> >>>>>> What does Linux do btw ? >>>>> >>>>> As of now Linux checks if the hub is superspeed >>>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.c#L2859 >>>>> >>>>> which is >>>>> return hdev->descriptor.bDeviceProtocol == USB_HUB_PR_SS; >>>>> // >>>>> USB_HUB_PR_SS = 3 >>>>> >>>>> This holds true for newer SuperSpeedPlus hubs as well. >>>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.h#L155 >>>>> >>>>> We can change the check to be bDeviceProtocol > 2 but who >>>>> knows if >>>>> things change in the newer version of spec. >>>>> I am open to suggestions. >>>> >>>> Please just include the ^ in the commit description. Use link >>>> to >>>> git.kernel.org , not some mirror . This is extremely useful >>>> information and, well, you already wrote the V2 commit message >>>> addition in this answer. >>> >>> Shantur, if that would be easier or quicker for you, I can >>> write >>> a quite detailed patch description for you, in exchange for a >>> "Helped-by" tag in the v2 patch submission. :) >> >> That would be really kind of you Dragan. > > Sure, I'll write the summary and send it over. > >> I am down with the flu so that would really help me as my brain >> is >> working at 15% capacity. > > Oh, I'm really sorry to hear that. :( I hope you'll get better > soon, and I know very well what's it like; I've also been sick > recently, as a result of some kind of flu that unfortunately > found > its way into my lungs, and it took me about a month to get back > to about 90% of my usual mental capacity. I'm still not back to > exactly 100%. :/ > > I really hope you'll recover much faster.
Regards, Shantur
Thanks .
I'm glad to help, and I'll be happy to see this patch accepted, with properly detailed description for future reference.
I've already adjusted the wording of the description, and I'll send the adjusted version over after Andre provides the USB IDs of the USB flash drives that initially failed to work.
On Sat, Feb 10, 2024 at 7:13 AM Dragan Simic dsimic@manjaro.org wrote: > On 2024-02-08 15:17, Dragan Simic wrote: >> On 2024-02-08 15:10, Shantur Rathore wrote: >>> On Thu, Feb 8, 2024 at 1:44 PM Dragan Simic dsimic@manjaro.org >>> wrote: >>>> On 2024-02-08 14:33, Marek Vasut wrote: >>>>> On 2/8/24 12:30, Shantur Rathore wrote: >>>>>> On Wed, Feb 7, 2024 at 1:07 PM Marek Vasut marex@denx.de >>>>>> wrote: >>>>>>> On 2/7/24 11:23, Shantur Rathore wrote: >>>>>>>> USB 3.0 spec requires hub to reset device while >>>>>>>> enumeration. Some USB 2.0 hubs / devices don't >>>>>>>> handle this well and after implementation of >>>>>>>> reset some USB 2.0 disks weren't detected on >>>>>>>> Allwinner based boards. >>>>>>>> >>>>>>>> Resetting only when hub is USB 3.0 fixes it. >>>>>>> >>>>>>> It would be good to include as many details about the >>>>>>> faulty hardware >>>>>>> in >>>>>>> the commit message as possible, so that when someone else >>>>>>> runs into >>>>>>> this, they would have all that information available. >>>>>>> >>>>>>>> Tested-by: Andre Przywara andre.przywara@arm.com >>>>>>>> >>>>>>>> Signed-off-by: Shantur Rathore i@shantur.com >>>>>>>> --- >>>>>>>> >>>>>>>> common/usb_hub.c | 6 ++++-- >>>>>>>> 1 file changed, 4 insertions(+), 2 deletions(-) >>>>>>>> >>>>>>>> diff --git a/common/usb_hub.c b/common/usb_hub.c >>>>>>>> index 3fb7e14d10..2e054eb935 100644 >>>>>>>> --- a/common/usb_hub.c >>>>>>>> +++ b/common/usb_hub.c >>>>>>>> @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct >>>>>>>> usb_hub_device *hub) >>>>>>>> >>>>>>>> debug("enabling power on all ports\n"); >>>>>>>> for (i = 0; i < dev->maxchild; i++) { >>>>>>>> - usb_set_port_feature(dev, i + 1, >>>>>>>> USB_PORT_FEAT_RESET); >>>>>>>> - debug("Reset : port %d returns %lX\n", i + 1, >>>>>>>> dev->status); >>>>>>>> + if (usb_hub_is_superspeed(dev)) { >>>>>>> >>>>>>> Should this condition be "all which are lower than superspeed" >>>>>>> instead , >>>>>>> so when the next generation of USB comes, this problem >>>>>>> won't trigger >>>>>>> ? >>>>>>> >>>>>>> What does Linux do btw ? >>>>>> >>>>>> As of now Linux checks if the hub is superspeed >>>>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.c#L2859 >>>>>> >>>>>> which is >>>>>> return hdev->descriptor.bDeviceProtocol == USB_HUB_PR_SS; // >>>>>> USB_HUB_PR_SS = 3 >>>>>> >>>>>> This holds true for newer SuperSpeedPlus hubs as well. >>>>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.h#L155 >>>>>> >>>>>> We can change the check to be bDeviceProtocol > 2 but who >>>>>> knows if >>>>>> things change in the newer version of spec. >>>>>> I am open to suggestions. >>>>> >>>>> Please just include the ^ in the commit description. Use link to >>>>> git.kernel.org , not some mirror . This is extremely useful >>>>> information and, well, you already wrote the V2 commit message >>>>> addition in this answer. >>>> >>>> Shantur, if that would be easier or quicker for you, I can write >>>> a quite detailed patch description for you, in exchange for a >>>> "Helped-by" tag in the v2 patch submission. :) >>> >>> That would be really kind of you Dragan. >> >> Sure, I'll write the summary and send it over. >> >>> I am down with the flu so that would really help me as my brain is >>> working at 15% capacity. >> >> Oh, I'm really sorry to hear that. :( I hope you'll get better >> soon, and I know very well what's it like; I've also been sick >> recently, as a result of some kind of flu that unfortunately found >> its way into my lungs, and it took me about a month to get back >> to about 90% of my usual mental capacity. I'm still not back to >> exactly 100%. :/ >> >> I really hope you'll recover much faster. > > I hope you're feeling better. > > Below are the patch subject and description that I prepared for you, > please have a look. > > ------- >8 ------------- >8 ------------- >8 ------------- >8 > ------- > [PATCH v2] common: usb-hub: Reset USB 3.0 hubs only > > Additional testing of the changes introduced in commit 33e06dcbe57a > ("common: > usb-hub: Reset hub port before scanning") revealed that some USB 3.0 > flash
> drives didn't work in U-Boot on some Allwinner SoCs that support > USB 2.0 > only. > More precisely, some tested USB 3.0 flash drives failed to be > detected > and > work on an OrangePi Zero 3 with Allwinner H616 SoC, which > supports USB > 2.0 > only, while the same USB flash drives worked just fine on a > Pine64 H64 > with > Allwinner H6 SoC, which supports both USB 2.0 and 3.0. > > Resetting USB 3.0 hubs only has been tested to work as expected, > resolving > the previous issues on the Allwinner H616, while not introducing > any new > issues on other Allwinner SoCs. Thus, let's fix it that way. > > According to the USB 3.0 specification, resetting a USB 3.0 port is > required > when an attached USB device transitions between different states, > such > as > when it resumes from suspend. Though, the Linux kernel performs > additional > USB 3.0 port resets upon initial USB device attachment, > presumably to > ensure > proper state of the USB 3.0 hub port and proper USB mode negotiation > during > the initial USB device attachment and enumeration. > > Such USB port resets don't seem to exist for USB 2.0 hubs, > according the > USB > 2.0 specification. The resets seem to be added to the USB 3.0 > specification > as part of the port and device mode negotiation. > > The Linux kernel also resets USB 3.0 (i.e. SuperSpeed) hubs only, as > visible > in file drivers/usb/core/hub.c in the kernel source, line 2859. This > check > also applies to newer SuperSpeed Plus (USB 3.1 or 3.2) hubs as well, > which > hopefully makes it future proof. > > Fixes: 33e06dcbe57a ("common: usb-hub: Reset hub port before > scanning") > Link: > https://lore.kernel.org/u-boot/20240207102327.35125-1-i@shantur.com/T/#u > Link: > https://lore.kernel.org/u-boot/20240201164604.13315fa6@donnerap.manchester.a... > Signed-off-by: Shantur Rathore i@shantur.com > Helped-by: Dragan Simic dsimic@manjaro.org > Tested-by: Andre Przywara andre.przywara@arm.com > Reviewed-by: Dragan Simic dsimic@manjaro.org > ------- >8 ------------- >8 ------------- >8 ------------- >8 > -------
Regards, Shantur
Thanks .
Thanks !
Thanks Dragan,
Hello Shantur,
On Thu, Feb 8, 2024 at 1:44 PM Dragan Simic dsimic@manjaro.org wrote: > On 2024-02-08 14:33, Marek Vasut wrote: >> On 2/8/24 12:30, Shantur Rathore wrote: >>> On Wed, Feb 7, 2024 at 1:07 PM Marek Vasut marex@denx.de wrote: >>>> On 2/7/24 11:23, Shantur Rathore wrote: >>>>> USB 3.0 spec requires hub to reset device while >>>>> enumeration. Some USB 2.0 hubs / devices don't >>>>> handle this well and after implementation of >>>>> reset some USB 2.0 disks weren't detected on >>>>> Allwinner based boards. >>>>> >>>>> Resetting only when hub is USB 3.0 fixes it. >>>> >>>> It would be good to include as many details about the faulty hardware >>>> in >>>> the commit message as possible, so that when someone else runs into >>>> this, they would have all that information available. >>>> >>>>> Tested-by: Andre Przywara andre.przywara@arm.com >>>>> >>>>> Signed-off-by: Shantur Rathore i@shantur.com >>>>> --- >>>>> >>>>> common/usb_hub.c | 6 ++++-- >>>>> 1 file changed, 4 insertions(+), 2 deletions(-) >>>>> >>>>> diff --git a/common/usb_hub.c b/common/usb_hub.c >>>>> index 3fb7e14d10..2e054eb935 100644 >>>>> --- a/common/usb_hub.c >>>>> +++ b/common/usb_hub.c >>>>> @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct >>>>> usb_hub_device *hub) >>>>> >>>>> debug("enabling power on all ports\n"); >>>>> for (i = 0; i < dev->maxchild; i++) { >>>>> - usb_set_port_feature(dev, i + 1, USB_PORT_FEAT_RESET); >>>>> - debug("Reset : port %d returns %lX\n", i + 1, >>>>> dev->status); >>>>> + if (usb_hub_is_superspeed(dev)) { >>>> >>>> Should this condition be "all which are lower than superspeed" >>>> instead , >>>> so when the next generation of USB comes, this problem won't trigger >>>> ? >>>> >>>> What does Linux do btw ? >>> >>> As of now Linux checks if the hub is superspeed >>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.c#L2859 >>> >>> which is >>> return hdev->descriptor.bDeviceProtocol == USB_HUB_PR_SS; // >>> USB_HUB_PR_SS = 3 >>> >>> This holds true for newer SuperSpeedPlus hubs as well. >>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.h#L155 >>> >>> We can change the check to be bDeviceProtocol > 2 but who knows if >>> things change in the newer version of spec. >>> I am open to suggestions. >> >> Please just include the ^ in the commit description. Use link to >> git.kernel.org , not some mirror . This is extremely useful >> information and, well, you already wrote the V2 commit message >> addition in this answer. > > Shantur, if that would be easier or quicker for you, I can write > a quite detailed patch description for you, in exchange for a > "Helped-by" tag in the v2 patch submission. :)
Regards, Shantur
So the USB 2.0 stick is some no-name, unlabelled and super cheap one, I think we bought a pack of it, just for boot-strapping machines. The USB ID of "abcd:1234" kind of gives away that this is bogus AF. The USB 3.0 stick is a PNY 32GB one, the USB ID is: 1f75:0917 Innostor Technology Corporation IS917 Mass storage
Hope that helps.
Cheers, Andre
Hello Andre,
On 2024-02-08 15:10, Shantur Rathore wrote: > On Thu, Feb 8, 2024 at 1:44 PM Dragan Simic dsimic@manjaro.org > wrote: >> On 2024-02-08 14:33, Marek Vasut wrote: >>> On 2/8/24 12:30, Shantur Rathore wrote: >>>> On Wed, Feb 7, 2024 at 1:07 PM Marek Vasut marex@denx.de wrote: >>>>> On 2/7/24 11:23, Shantur Rathore wrote: >>>>>> USB 3.0 spec requires hub to reset device while >>>>>> enumeration. Some USB 2.0 hubs / devices don't >>>>>> handle this well and after implementation of >>>>>> reset some USB 2.0 disks weren't detected on >>>>>> Allwinner based boards. >>>>>> >>>>>> Resetting only when hub is USB 3.0 fixes it. >>>>> >>>>> It would be good to include as many details about the faulty hardware >>>>> in >>>>> the commit message as possible, so that when someone else runs into >>>>> this, they would have all that information available. >>>>> >>>>>> Tested-by: Andre Przywara andre.przywara@arm.com >>>>>> >>>>>> Signed-off-by: Shantur Rathore i@shantur.com >>>>>> --- >>>>>> >>>>>> common/usb_hub.c | 6 ++++-- >>>>>> 1 file changed, 4 insertions(+), 2 deletions(-) >>>>>> >>>>>> diff --git a/common/usb_hub.c b/common/usb_hub.c >>>>>> index 3fb7e14d10..2e054eb935 100644 >>>>>> --- a/common/usb_hub.c >>>>>> +++ b/common/usb_hub.c >>>>>> @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct >>>>>> usb_hub_device *hub) >>>>>> >>>>>> debug("enabling power on all ports\n"); >>>>>> for (i = 0; i < dev->maxchild; i++) { >>>>>> - usb_set_port_feature(dev, i + 1, USB_PORT_FEAT_RESET); >>>>>> - debug("Reset : port %d returns %lX\n", i + 1, >>>>>> dev->status); >>>>>> + if (usb_hub_is_superspeed(dev)) { >>>>> >>>>> Should this condition be "all which are lower than superspeed" >>>>> instead , >>>>> so when the next generation of USB comes, this problem won't trigger >>>>> ? >>>>> >>>>> What does Linux do btw ? >>>> >>>> As of now Linux checks if the hub is superspeed >>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.c#L2859 >>>> >>>> which is >>>> return hdev->descriptor.bDeviceProtocol == USB_HUB_PR_SS; // >>>> USB_HUB_PR_SS = 3 >>>> >>>> This holds true for newer SuperSpeedPlus hubs as well. >>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.h#L155 >>>> >>>> We can change the check to be bDeviceProtocol > 2 but who knows if >>>> things change in the newer version of spec. >>>> I am open to suggestions. >>> >>> Please just include the ^ in the commit description. Use link to >>> git.kernel.org , not some mirror . This is extremely useful >>> information and, well, you already wrote the V2 commit message >>> addition in this answer. >> >> Shantur, if that would be easier or quicker for you, I can write >> a quite detailed patch description for you, in exchange for a >> "Helped-by" tag in the v2 patch submission. :) > > That would be really kind of you Dragan.
Regards, Shantur
Hope that helps.
Thank you for replying. I'll include the available information into the revised commit description and send it over a bit later.
Hello Shantur and Marek,
On 2024-02-08 15:17, Dragan Simic wrote: > On 2024-02-08 15:10, Shantur Rathore wrote: >> On Thu, Feb 8, 2024 at 1:44 PM Dragan Simic dsimic@manjaro.org >> wrote: >>> On 2024-02-08 14:33, Marek Vasut wrote: >>>> On 2/8/24 12:30, Shantur Rathore wrote: >>>>> On Wed, Feb 7, 2024 at 1:07 PM Marek Vasut marex@denx.de wrote: >>>>>> On 2/7/24 11:23, Shantur Rathore wrote: >>>>>>> USB 3.0 spec requires hub to reset device while >>>>>>> enumeration. Some USB 2.0 hubs / devices don't >>>>>>> handle this well and after implementation of >>>>>>> reset some USB 2.0 disks weren't detected on >>>>>>> Allwinner based boards. >>>>>>> >>>>>>> Resetting only when hub is USB 3.0 fixes it. >>>>>> >>>>>> It would be good to include as many details about the faulty hardware >>>>>> in >>>>>> the commit message as possible, so that when someone else runs into >>>>>> this, they would have all that information available. >>>>>> >>>>>>> Tested-by: Andre Przywara andre.przywara@arm.com >>>>>>> >>>>>>> Signed-off-by: Shantur Rathore i@shantur.com >>>>>>> --- >>>>>>> >>>>>>> common/usb_hub.c | 6 ++++-- >>>>>>> 1 file changed, 4 insertions(+), 2 deletions(-) >>>>>>> >>>>>>> diff --git a/common/usb_hub.c b/common/usb_hub.c >>>>>>> index 3fb7e14d10..2e054eb935 100644 >>>>>>> --- a/common/usb_hub.c >>>>>>> +++ b/common/usb_hub.c >>>>>>> @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct >>>>>>> usb_hub_device *hub) >>>>>>> >>>>>>> debug("enabling power on all ports\n"); >>>>>>> for (i = 0; i < dev->maxchild; i++) { >>>>>>> - usb_set_port_feature(dev, i + 1, USB_PORT_FEAT_RESET); >>>>>>> - debug("Reset : port %d returns %lX\n", i + 1, >>>>>>> dev->status); >>>>>>> + if (usb_hub_is_superspeed(dev)) { >>>>>> >>>>>> Should this condition be "all which are lower than superspeed" >>>>>> instead , >>>>>> so when the next generation of USB comes, this problem won't trigger >>>>>> ? >>>>>> >>>>>> What does Linux do btw ? >>>>> >>>>> As of now Linux checks if the hub is superspeed >>>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.c#L2859 >>>>> >>>>> which is >>>>> return hdev->descriptor.bDeviceProtocol == USB_HUB_PR_SS; // >>>>> USB_HUB_PR_SS = 3 >>>>> >>>>> This holds true for newer SuperSpeedPlus hubs as well. >>>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.h#L155 >>>>> >>>>> We can change the check to be bDeviceProtocol > 2 but who knows if >>>>> things change in the newer version of spec. >>>>> I am open to suggestions. >>>> >>>> Please just include the ^ in the commit description. Use link to >>>> git.kernel.org , not some mirror . This is extremely useful >>>> information and, well, you already wrote the V2 commit message >>>> addition in this answer. >>> >>> Shantur, if that would be easier or quicker for you, I can write >>> a quite detailed patch description for you, in exchange for a >>> "Helped-by" tag in the v2 patch submission. :) >> >> That would be really kind of you Dragan. > > Sure, I'll write the summary and send it over. > >> I am down with the flu so that would really help me as my brain is >> working at 15% capacity. > > Oh, I'm really sorry to hear that. :( I hope you'll get better > soon, and I know very well what's it like; I've also been sick > recently, as a result of some kind of flu that unfortunately found > its way into my lungs, and it took me about a month to get back > to about 90% of my usual mental capacity. I'm still not back to > exactly 100%. :/ > > I really hope you'll recover much faster.
Regards, Shantur
Hope that helps.
Here are the revised commit subject and description, please have a look and let me know if further improvements are needed.
Additional testing of the changes introduced in commit 33e06dcbe57a ("common: usb-hub: Reset hub port before scanning") revealed that some USB 2.0 and 3.0 flash drives didn't work in U-Boot on some Allwinner SoCs that support USB 2.0 interfaces only. More precisely, some of the tested USB 2.0 and 3.0 flash drives failed to be detected and work on an OrangePi Zero 3, based on the Allwinner H616 SoC that supports USB 2.0 only, while the same USB flash drives worked just fine on a Pine64 H64, based on the Allwinner H6 SoC that supports both USB 2.0 and USB 3.0 interfaces.
The USB ID of the above-mentioned USB 3.0 flash drive that failed to work is 1f75:0917 (Innostor Technology Corporation IS917 Mass storage), it is 32 GB in size and sold under the PNY brand. The mentioned USB 2.0 drive is some inexpensive no-name drive with an invalid USB ID.
Resetting USB 3.0 hubs only, which this patch introduces to the USB hub resets, has been tested to work as expected, resolving the identified issues on the Allwinner H616, while not introducing any new issues on other tested Allwinner SoCs. Thus, let's fix it that way.
According to the USB 3.0 specification, resetting a USB 3.0 port is required when an attached USB device transitions between different states, such as when it resumes from suspend. Though, the Linux kernel performs additional USB 3.0 port resets upon initial USB device attachment, as visible in commit 07194ab7be63 ("USB: Reset USB 3.0 devices on (re)discovery") in the kernel source, to ensure proper state of the USB 3.0 hub port and proper USB mode negotiation during the initial USB device attachment and enumeration.
These additional types of USB port resets don't exist for USB 2.0 hubs, according the USB 2.0 specification. The resets seem to be added to the USB 3.0 specification as part of the port and device mode negotiation.
The Linux kernel resets USB 3.0 (i.e. SuperSpeed) hubs only, as visible in commit 10d674a82e55 ("USB: When hot reset for USB3 fails, try warm reset.") in the kernel source. The check for SuperSpeed hubs is performed in a way that also applies to newer SuperSpeed Plus (USB 3.1 or 3.2) hubs as well, which hopefully makes it future proof.
Shantur, I hope you're feeling better.
On Sat, Feb 10, 2024 at 7:13 AM Dragan Simic dsimic@manjaro.org wrote: > On 2024-02-08 15:17, Dragan Simic wrote: >> On 2024-02-08 15:10, Shantur Rathore wrote: >>> On Thu, Feb 8, 2024 at 1:44 PM Dragan Simic dsimic@manjaro.org >>> wrote: >>>> On 2024-02-08 14:33, Marek Vasut wrote: >>>>> On 2/8/24 12:30, Shantur Rathore wrote: >>>>>> On Wed, Feb 7, 2024 at 1:07 PM Marek Vasut marex@denx.de wrote: >>>>>>> On 2/7/24 11:23, Shantur Rathore wrote: >>>>>>>> USB 3.0 spec requires hub to reset device while >>>>>>>> enumeration. Some USB 2.0 hubs / devices don't >>>>>>>> handle this well and after implementation of >>>>>>>> reset some USB 2.0 disks weren't detected on >>>>>>>> Allwinner based boards. >>>>>>>> >>>>>>>> Resetting only when hub is USB 3.0 fixes it. >>>>>>> >>>>>>> It would be good to include as many details about the faulty hardware >>>>>>> in >>>>>>> the commit message as possible, so that when someone else runs into >>>>>>> this, they would have all that information available. >>>>>>> >>>>>>>> Tested-by: Andre Przywara andre.przywara@arm.com >>>>>>>> >>>>>>>> Signed-off-by: Shantur Rathore i@shantur.com >>>>>>>> --- >>>>>>>> >>>>>>>> common/usb_hub.c | 6 ++++-- >>>>>>>> 1 file changed, 4 insertions(+), 2 deletions(-) >>>>>>>> >>>>>>>> diff --git a/common/usb_hub.c b/common/usb_hub.c >>>>>>>> index 3fb7e14d10..2e054eb935 100644 >>>>>>>> --- a/common/usb_hub.c >>>>>>>> +++ b/common/usb_hub.c >>>>>>>> @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct >>>>>>>> usb_hub_device *hub) >>>>>>>> >>>>>>>> debug("enabling power on all ports\n"); >>>>>>>> for (i = 0; i < dev->maxchild; i++) { >>>>>>>> - usb_set_port_feature(dev, i + 1, USB_PORT_FEAT_RESET); >>>>>>>> - debug("Reset : port %d returns %lX\n", i + 1, >>>>>>>> dev->status); >>>>>>>> + if (usb_hub_is_superspeed(dev)) { >>>>>>> >>>>>>> Should this condition be "all which are lower than superspeed" >>>>>>> instead , >>>>>>> so when the next generation of USB comes, this problem won't trigger >>>>>>> ? >>>>>>> >>>>>>> What does Linux do btw ? >>>>>> >>>>>> As of now Linux checks if the hub is superspeed >>>>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.c#L2859 >>>>>> >>>>>> which is >>>>>> return hdev->descriptor.bDeviceProtocol == USB_HUB_PR_SS; // >>>>>> USB_HUB_PR_SS = 3 >>>>>> >>>>>> This holds true for newer SuperSpeedPlus hubs as well. >>>>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.h#L155 >>>>>> >>>>>> We can change the check to be bDeviceProtocol > 2 but who knows if >>>>>> things change in the newer version of spec. >>>>>> I am open to suggestions. >>>>> >>>>> Please just include the ^ in the commit description. Use link to >>>>> git.kernel.org , not some mirror . This is extremely useful >>>>> information and, well, you already wrote the V2 commit message >>>>> addition in this answer. >>>> >>>> Shantur, if that would be easier or quicker for you, I can write >>>> a quite detailed patch description for you, in exchange for a >>>> "Helped-by" tag in the v2 patch submission. :) >>> >>> That would be really kind of you Dragan. >> >> Sure, I'll write the summary and send it over. >> >>> I am down with the flu so that would really help me as my brain is >>> working at 15% capacity. >> >> Oh, I'm really sorry to hear that. :( I hope you'll get better >> soon, and I know very well what's it like; I've also been sick >> recently, as a result of some kind of flu that unfortunately found >> its way into my lungs, and it took me about a month to get back >> to about 90% of my usual mental capacity. I'm still not back to >> exactly 100%. :/ >> >> I really hope you'll recover much faster. > > I hope you're feeling better. > > Below are the patch subject and description that I prepared for you, > please have a look. > > ------- >8 ------------- >8 ------------- >8 ------------- >8 ------- > [PATCH v2] common: usb-hub: Reset USB 3.0 hubs only > > Additional testing of the changes introduced in commit 33e06dcbe57a > ("common: > usb-hub: Reset hub port before scanning") revealed that some USB 3.0 > flash
> drives didn't work in U-Boot on some Allwinner SoCs that support USB 2.0 > only. > More precisely, some tested USB 3.0 flash drives failed to be detected > and > work on an OrangePi Zero 3 with Allwinner H616 SoC, which supports USB > 2.0 > only, while the same USB flash drives worked just fine on a Pine64 H64 > with > Allwinner H6 SoC, which supports both USB 2.0 and 3.0. > > Resetting USB 3.0 hubs only has been tested to work as expected, > resolving > the previous issues on the Allwinner H616, while not introducing any new > issues on other Allwinner SoCs. Thus, let's fix it that way. > > According to the USB 3.0 specification, resetting a USB 3.0 port is > required > when an attached USB device transitions between different states, such > as > when it resumes from suspend. Though, the Linux kernel performs > additional > USB 3.0 port resets upon initial USB device attachment, presumably to > ensure > proper state of the USB 3.0 hub port and proper USB mode negotiation > during > the initial USB device attachment and enumeration. > > Such USB port resets don't seem to exist for USB 2.0 hubs, according the > USB > 2.0 specification. The resets seem to be added to the USB 3.0 > specification > as part of the port and device mode negotiation. > > The Linux kernel also resets USB 3.0 (i.e. SuperSpeed) hubs only, as > visible > in file drivers/usb/core/hub.c in the kernel source, line 2859. This > check > also applies to newer SuperSpeed Plus (USB 3.1 or 3.2) hubs as well, > which > hopefully makes it future proof. > > Fixes: 33e06dcbe57a ("common: usb-hub: Reset hub port before scanning") > Link: > https://lore.kernel.org/u-boot/20240207102327.35125-1-i@shantur.com/T/#u > Link: > https://lore.kernel.org/u-boot/20240201164604.13315fa6@donnerap.manchester.a... > Signed-off-by: Shantur Rathore i@shantur.com > Helped-by: Dragan Simic dsimic@manjaro.org > Tested-by: Andre Przywara andre.przywara@arm.com > Reviewed-by: Dragan Simic dsimic@manjaro.org > ------- >8 ------------- >8 ------------- >8 ------------- >8 -------
Regards, Shantur
Hope that helps.
Thanks Dragan, V2 is submitted. I am feeling much better, thanks for asking.
On Mon, Feb 12, 2024 at 1:40 PM Shantur Rathore i@shantur.com wrote: > On Sat, Feb 10, 2024 at 7:13 AM Dragan Simic dsimic@manjaro.org wrote: >> On 2024-02-08 15:17, Dragan Simic wrote: >>> On 2024-02-08 15:10, Shantur Rathore wrote: >>>> On Thu, Feb 8, 2024 at 1:44 PM Dragan Simic dsimic@manjaro.org >>>> wrote: >>>>> On 2024-02-08 14:33, Marek Vasut wrote: >>>>>> On 2/8/24 12:30, Shantur Rathore wrote: >>>>>>> On Wed, Feb 7, 2024 at 1:07 PM Marek Vasut marex@denx.de wrote: >>>>>>>> On 2/7/24 11:23, Shantur Rathore wrote: >>>>>>>>> USB 3.0 spec requires hub to reset device while >>>>>>>>> enumeration. Some USB 2.0 hubs / devices don't >>>>>>>>> handle this well and after implementation of >>>>>>>>> reset some USB 2.0 disks weren't detected on >>>>>>>>> Allwinner based boards. >>>>>>>>> >>>>>>>>> Resetting only when hub is USB 3.0 fixes it. >>>>>>>> >>>>>>>> It would be good to include as many details about the faulty hardware >>>>>>>> in >>>>>>>> the commit message as possible, so that when someone else runs into >>>>>>>> this, they would have all that information available. >>>>>>>> >>>>>>>>> Tested-by: Andre Przywara andre.przywara@arm.com >>>>>>>>> >>>>>>>>> Signed-off-by: Shantur Rathore i@shantur.com >>>>>>>>> --- >>>>>>>>> >>>>>>>>> common/usb_hub.c | 6 ++++-- >>>>>>>>> 1 file changed, 4 insertions(+), 2 deletions(-) >>>>>>>>> >>>>>>>>> diff --git a/common/usb_hub.c b/common/usb_hub.c >>>>>>>>> index 3fb7e14d10..2e054eb935 100644 >>>>>>>>> --- a/common/usb_hub.c >>>>>>>>> +++ b/common/usb_hub.c >>>>>>>>> @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct >>>>>>>>> usb_hub_device *hub) >>>>>>>>> >>>>>>>>> debug("enabling power on all ports\n"); >>>>>>>>> for (i = 0; i < dev->maxchild; i++) { >>>>>>>>> - usb_set_port_feature(dev, i + 1, USB_PORT_FEAT_RESET); >>>>>>>>> - debug("Reset : port %d returns %lX\n", i + 1, >>>>>>>>> dev->status); >>>>>>>>> + if (usb_hub_is_superspeed(dev)) { >>>>>>>> >>>>>>>> Should this condition be "all which are lower than superspeed" >>>>>>>> instead , >>>>>>>> so when the next generation of USB comes, this problem won't trigger >>>>>>>> ? >>>>>>>> >>>>>>>> What does Linux do btw ? >>>>>>> >>>>>>> As of now Linux checks if the hub is superspeed >>>>>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.c#L2859 >>>>>>> >>>>>>> which is >>>>>>> return hdev->descriptor.bDeviceProtocol == USB_HUB_PR_SS; // >>>>>>> USB_HUB_PR_SS = 3 >>>>>>> >>>>>>> This holds true for newer SuperSpeedPlus hubs as well. >>>>>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.h#L155 >>>>>>> >>>>>>> We can change the check to be bDeviceProtocol > 2 but who knows if >>>>>>> things change in the newer version of spec. >>>>>>> I am open to suggestions. >>>>>> >>>>>> Please just include the ^ in the commit description. Use link to >>>>>> git.kernel.org , not some mirror . This is extremely useful >>>>>> information and, well, you already wrote the V2 commit message >>>>>> addition in this answer. >>>>> >>>>> Shantur, if that would be easier or quicker for you, I can write >>>>> a quite detailed patch description for you, in exchange for a >>>>> "Helped-by" tag in the v2 patch submission. :) >>>> >>>> That would be really kind of you Dragan. >>> >>> Sure, I'll write the summary and send it over. >>> >>>> I am down with the flu so that would really help me as my brain is >>>> working at 15% capacity. >>> >>> Oh, I'm really sorry to hear that. :( I hope you'll get better >>> soon, and I know very well what's it like; I've also been sick >>> recently, as a result of some kind of flu that unfortunately found >>> its way into my lungs, and it took me about a month to get back >>> to about 90% of my usual mental capacity. I'm still not back to >>> exactly 100%. :/ >>> >>> I really hope you'll recover much faster. >> >> I hope you're feeling better. >> >> Below are the patch subject and description that I prepared for you, >> please have a look. >> >> ------- >8 ------------- >8 ------------- >8 ------------- >8 ------- >> [PATCH v2] common: usb-hub: Reset USB 3.0 hubs only >> >> Additional testing of the changes introduced in commit 33e06dcbe57a >> ("common: >> usb-hub: Reset hub port before scanning") revealed that some USB 3.0 >> flash > > I think it was a USB 2.0 drive that didn't work on the USB 2.0 port. > >> drives didn't work in U-Boot on some Allwinner SoCs that support USB 2.0 >> only. >> More precisely, some tested USB 3.0 flash drives failed to be detected >> and >> work on an OrangePi Zero 3 with Allwinner H616 SoC, which supports USB >> 2.0 >> only, while the same USB flash drives worked just fine on a Pine64 H64 >> with >> Allwinner H6 SoC, which supports both USB 2.0 and 3.0. >> >> Resetting USB 3.0 hubs only has been tested to work as expected, >> resolving >> the previous issues on the Allwinner H616, while not introducing any new >> issues on other Allwinner SoCs. Thus, let's fix it that way. >> >> According to the USB 3.0 specification, resetting a USB 3.0 port is >> required >> when an attached USB device transitions between different states, such >> as >> when it resumes from suspend. Though, the Linux kernel performs >> additional >> USB 3.0 port resets upon initial USB device attachment, presumably to >> ensure >> proper state of the USB 3.0 hub port and proper USB mode negotiation >> during >> the initial USB device attachment and enumeration. >> >> Such USB port resets don't seem to exist for USB 2.0 hubs, according the >> USB >> 2.0 specification. The resets seem to be added to the USB 3.0 >> specification >> as part of the port and device mode negotiation. >> >> The Linux kernel also resets USB 3.0 (i.e. SuperSpeed) hubs only, as >> visible >> in file drivers/usb/core/hub.c in the kernel source, line 2859. This >> check >> also applies to newer SuperSpeed Plus (USB 3.1 or 3.2) hubs as well, >> which >> hopefully makes it future proof. >> >> Fixes: 33e06dcbe57a ("common: usb-hub: Reset hub port before scanning") >> Link: >> https://lore.kernel.org/u-boot/20240207102327.35125-1-i@shantur.com/T/#u >> Link: >> https://lore.kernel.org/u-boot/20240201164604.13315fa6@donnerap.manchester.a... >> Signed-off-by: Shantur Rathore i@shantur.com >> Helped-by: Dragan Simic dsimic@manjaro.org >> Tested-by: Andre Przywara andre.przywara@arm.com >> Reviewed-by: Dragan Simic dsimic@manjaro.org >> ------- >8 ------------- >8 ------------- >8 ------------- >8 ------- > > Regards, > Shantur
Hope that helps.
PS : I don't think I could ever explain as well as you did Dragan. Thanks a lot for the help.
I will bring another pending matter to your attention on the Linux list now ;P
On 2/12/24 14:41, Shantur Rathore wrote: > On Mon, Feb 12, 2024 at 1:40 PM Shantur Rathore i@shantur.com wrote: >> On Sat, Feb 10, 2024 at 7:13 AM Dragan Simic dsimic@manjaro.org wrote: >>> On 2024-02-08 15:17, Dragan Simic wrote: >>>> On 2024-02-08 15:10, Shantur Rathore wrote: >>>>> On Thu, Feb 8, 2024 at 1:44 PM Dragan Simic dsimic@manjaro.org >>>>> wrote: >>>>>> On 2024-02-08 14:33, Marek Vasut wrote: >>>>>>> On 2/8/24 12:30, Shantur Rathore wrote: >>>>>>>> On Wed, Feb 7, 2024 at 1:07 PM Marek Vasut marex@denx.de wrote: >>>>>>>>> On 2/7/24 11:23, Shantur Rathore wrote: >>>>>>>>>> USB 3.0 spec requires hub to reset device while >>>>>>>>>> enumeration. Some USB 2.0 hubs / devices don't >>>>>>>>>> handle this well and after implementation of >>>>>>>>>> reset some USB 2.0 disks weren't detected on >>>>>>>>>> Allwinner based boards. >>>>>>>>>> >>>>>>>>>> Resetting only when hub is USB 3.0 fixes it. >>>>>>>>> >>>>>>>>> It would be good to include as many details about the faulty hardware >>>>>>>>> in >>>>>>>>> the commit message as possible, so that when someone else runs into >>>>>>>>> this, they would have all that information available. >>>>>>>>> >>>>>>>>>> Tested-by: Andre Przywara andre.przywara@arm.com >>>>>>>>>> >>>>>>>>>> Signed-off-by: Shantur Rathore i@shantur.com >>>>>>>>>> --- >>>>>>>>>> >>>>>>>>>> common/usb_hub.c | 6 ++++-- >>>>>>>>>> 1 file changed, 4 insertions(+), 2 deletions(-) >>>>>>>>>> >>>>>>>>>> diff --git a/common/usb_hub.c b/common/usb_hub.c >>>>>>>>>> index 3fb7e14d10..2e054eb935 100644 >>>>>>>>>> --- a/common/usb_hub.c >>>>>>>>>> +++ b/common/usb_hub.c >>>>>>>>>> @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct >>>>>>>>>> usb_hub_device *hub) >>>>>>>>>> >>>>>>>>>> debug("enabling power on all ports\n"); >>>>>>>>>> for (i = 0; i < dev->maxchild; i++) { >>>>>>>>>> - usb_set_port_feature(dev, i + 1, USB_PORT_FEAT_RESET); >>>>>>>>>> - debug("Reset : port %d returns %lX\n", i + 1, >>>>>>>>>> dev->status); >>>>>>>>>> + if (usb_hub_is_superspeed(dev)) { >>>>>>>>> >>>>>>>>> Should this condition be "all which are lower than superspeed" >>>>>>>>> instead , >>>>>>>>> so when the next generation of USB comes, this problem won't trigger >>>>>>>>> ? >>>>>>>>> >>>>>>>>> What does Linux do btw ? >>>>>>>> >>>>>>>> As of now Linux checks if the hub is superspeed >>>>>>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.c#L2859 >>>>>>>> >>>>>>>> which is >>>>>>>> return hdev->descriptor.bDeviceProtocol == USB_HUB_PR_SS; // >>>>>>>> USB_HUB_PR_SS = 3 >>>>>>>> >>>>>>>> This holds true for newer SuperSpeedPlus hubs as well. >>>>>>>> https://github.com/torvalds/linux/blob/master/drivers/usb/core/hub.h#L155 >>>>>>>> >>>>>>>> We can change the check to be bDeviceProtocol > 2 but who knows if >>>>>>>> things change in the newer version of spec. >>>>>>>> I am open to suggestions. >>>>>>> >>>>>>> Please just include the ^ in the commit description. Use link to >>>>>>> git.kernel.org , not some mirror . This is extremely useful >>>>>>> information and, well, you already wrote the V2 commit message >>>>>>> addition in this answer. >>>>>> >>>>>> Shantur, if that would be easier or quicker for you, I can write >>>>>> a quite detailed patch description for you, in exchange for a >>>>>> "Helped-by" tag in the v2 patch submission. :) >>>>> >>>>> That would be really kind of you Dragan. >>>> >>>> Sure, I'll write the summary and send it over. >>>> >>>>> I am down with the flu so that would really help me as my brain is >>>>> working at 15% capacity. >>>> >>>> Oh, I'm really sorry to hear that. :( I hope you'll get better >>>> soon, and I know very well what's it like; I've also been sick >>>> recently, as a result of some kind of flu that unfortunately found >>>> its way into my lungs, and it took me about a month to get back >>>> to about 90% of my usual mental capacity. I'm still not back to >>>> exactly 100%. :/ >>>> >>>> I really hope you'll recover much faster. >>> >>> I hope you're feeling better. >>> >>> Below are the patch subject and description that I prepared for you, >>> please have a look. >>> >>> ------- >8 ------------- >8 ------------- >8 ------------- >8 ------- >>> [PATCH v2] common: usb-hub: Reset USB 3.0 hubs only >>> >>> Additional testing of the changes introduced in commit 33e06dcbe57a >>> ("common: >>> usb-hub: Reset hub port before scanning") revealed that some USB 3.0 >>> flash >> >> I think it was a USB 2.0 drive that didn't work on the USB 2.0 port. >> >>> drives didn't work in U-Boot on some Allwinner SoCs that support USB 2.0 >>> only. >>> More precisely, some tested USB 3.0 flash drives failed to be detected >>> and >>> work on an OrangePi Zero 3 with Allwinner H616 SoC, which supports USB >>> 2.0 >>> only, while the same USB flash drives worked just fine on a Pine64 H64 >>> with >>> Allwinner H6 SoC, which supports both USB 2.0 and 3.0. >>> >>> Resetting USB 3.0 hubs only has been tested to work as expected, >>> resolving >>> the previous issues on the Allwinner H616, while not introducing any new >>> issues on other Allwinner SoCs. Thus, let's fix it that way. >>> >>> According to the USB 3.0 specification, resetting a USB 3.0 port is >>> required >>> when an attached USB device transitions between different states, such >>> as >>> when it resumes from suspend. Though, the Linux kernel performs >>> additional >>> USB 3.0 port resets upon initial USB device attachment, presumably to >>> ensure >>> proper state of the USB 3.0 hub port and proper USB mode negotiation >>> during >>> the initial USB device attachment and enumeration. >>> >>> Such USB port resets don't seem to exist for USB 2.0 hubs, according the >>> USB >>> 2.0 specification. The resets seem to be added to the USB 3.0 >>> specification >>> as part of the port and device mode negotiation. >>> >>> The Linux kernel also resets USB 3.0 (i.e. SuperSpeed) hubs only, as >>> visible >>> in file drivers/usb/core/hub.c in the kernel source, line 2859. This >>> check >>> also applies to newer SuperSpeed Plus (USB 3.1 or 3.2) hubs as well, >>> which >>> hopefully makes it future proof. >>> >>> Fixes: 33e06dcbe57a ("common: usb-hub: Reset hub port before scanning") >>> Link: >>> https://lore.kernel.org/u-boot/20240207102327.35125-1-i@shantur.com/T/#u >>> Link: >>> https://lore.kernel.org/u-boot/20240201164604.13315fa6@donnerap.manchester.a... >>> Signed-off-by: Shantur Rathore i@shantur.com >>> Helped-by: Dragan Simic dsimic@manjaro.org >>> Tested-by: Andre Przywara andre.przywara@arm.com >>> Reviewed-by: Dragan Simic dsimic@manjaro.org >>> ------- >8 ------------- >8 ------------- >8 ------------- >8 ------- >> >> Regards, >> Shantur > > Is this description acceptable to you Marek.
Hope that helps.
It's good to hear that you're feeling better!
I'm glad to help. :) We're here to work together by combining our skills and strengths.
Is it about the USB regulators on the RockPro64? :) I haven't forgotten that, and I expect to work on that rather soon.
Hello Shantur,
s/some USB 3.0 flash/some USB 2.0 and 3.0 flash/
As visible in the message linked below, there was one USB 3.0 flash drive that didn't work in a USB 2.0 port. Though, you're right, there was also a USB 2.0 drive that didn't work. Thus, it's perhaps best to adjust the wording as I suggested above and below.
https://lore.kernel.org/u-boot/20240202001218.63b4e9c3@minigeek.lan/
s/some tested USB 3.0 flash drives/some tested USB 2.0 and 3.0 flash drives/
Hello Shantur,
Please see my notes below.
On 2024-02-07 11:23, Shantur Rathore wrote:
USB 3.0 spec requires hub to reset device while enumeration. Some USB 2.0 hubs / devices don't handle this well and after implementation of reset some USB 2.0 disks weren't detected on Allwinner based boards.
Please, add the "Fixes" line available below, reformat the patch description to the usual 78-character width, and remove unnecessary "FIX " from the patch subject prefix.
As a side note, such tags can be produced very easily by running "git log --max-count=1 --pretty=fixes <commit>". I have an alias like that defined in my ~/.gitconfig.
With these changes applied, please feel free to also add:
Reviewed-by: Dragan Simic dsimic@anjaro.org
common/usb_hub.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/common/usb_hub.c b/common/usb_hub.c index 3fb7e14d10..2e054eb935 100644 --- a/common/usb_hub.c +++ b/common/usb_hub.c @@ -174,8 +174,10 @@ static void usb_hub_power_on(struct usb_hub_device *hub)
debug("enabling power on all ports\n"); for (i = 0; i < dev->maxchild; i++) {
debug("Reset : port %d returns %lX\n", i + 1, dev->status);
usb_set_port_feature(dev, i + 1, USB_PORT_FEAT_POWER); debug("PowerOn : port %d returns %lX\n", i + 1, dev->status); }}
On 2024-02-07 14:14, Dragan Simic wrote:
Hello Shantur,
Oops, sorry for the typo... s/anjaro/manjaro/
Andre Przywara
Dragan Simic
Shantur Rathore
