[U-Boot] [PATCH V2 1/3] part: add partition number to disk_partition_t
The FAT filesystem code knows which partition ID it is operating on. Currently, this is passed to fat_register_device() as a parameter. In order to convert FAT to the more standardized fat_set_blk_dev(), the information needs to come from somewhere else, and the partition definition structure is the logical place.
Signed-off-by: Stephen Warren swarren@nvidia.com --- v2: No change. --- disk/part.c | 1 + include/part.h | 1 + 2 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/disk/part.c b/disk/part.c index a0c77dd..2bc7acb 100644 --- a/disk/part.c +++ b/disk/part.c @@ -391,6 +391,7 @@ int get_partition_info(block_dev_desc_t *dev_desc, int part defined(CONFIG_MMC) || \ defined(CONFIG_SYSTEMACE)
+ info->part = part; #ifdef CONFIG_PARTITION_UUIDS /* The common case is no UUID support */ info->uuid[0] = 0; diff --git a/include/part.h b/include/part.h index 27ea283..ebdebd8 100644 --- a/include/part.h +++ b/include/part.h @@ -88,6 +88,7 @@ typedef struct block_dev_desc { #define DEV_TYPE_OPDISK 0x07 /* optical disk */
typedef struct disk_partition { + int part; /* Partition number */ ulong start; /* # of first block in partition */ ulong size; /* number of blocks in partition */ ulong blksz; /* block size in bytes */
This removes the standalone cur_part_nr variable, opening the way to replacing fat_register_device() with fat_set_blk_dev().
Note that when get_partition_info() fails and we use the entire disk, the correct partition number is 0 (whole disk) not 1 (first partition), so that change is also made here.
An alternative to this (and the previous) patch might be to simply remove the partition number from the printf(). I don't know how attached people are to it.
Signed-off-by: Stephen Warren swarren@nvidia.com --- v2: No change. --- fs/fat/fat.c | 6 ++---- 1 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/fs/fat/fat.c b/fs/fat/fat.c index 80156c8..1e0d2a3 100644 --- a/fs/fat/fat.c +++ b/fs/fat/fat.c @@ -46,7 +46,6 @@ static void downcase(char *str) }
static block_dev_desc_t *cur_dev; -static unsigned int cur_part_nr; static disk_partition_t cur_part_info;
#define DOS_BOOT_MAGIC_OFFSET 0x1fe @@ -79,7 +78,6 @@ int fat_register_device(block_dev_desc_t * dev_desc, int part_no) /* Read the partition table, if present */ if (!get_partition_info(dev_desc, part_no, &cur_part_info)) { cur_dev = dev_desc; - cur_part_nr = part_no; } #endif
@@ -92,7 +90,7 @@ int fat_register_device(block_dev_desc_t * dev_desc, int part_no) }
cur_dev = dev_desc; - cur_part_nr = 1; + cur_part_info.part = 0; cur_part_info.start = 0; cur_part_info.size = dev_desc->lba; cur_part_info.blksz = dev_desc->blksz; @@ -1235,7 +1233,7 @@ int file_fat_detectfs(void) vol_label[11] = '\0'; volinfo.fs_type[5] = '\0';
- printf("Partition %d: Filesystem: %s "%s"\n", cur_part_nr, + printf("Partition %d: Filesystem: %s "%s"\n", cur_part_info.part, volinfo.fs_type, vol_label);
This makes the FAT filesystem API more consistent with other block-based filesystems. If in the future standard multi-filesystem commands such as "ls" or "load" are implemented, having FAT work the same way as other filesystems will be necessary.
Convert cmd_fat.c to the new API, so the code looks more like other files implementing the same commands for other filesystems.
Signed-off-by: Stephen Warren swarren@nvidia.com --- v2: Fix inverted test of get_partition_info() result in fat_register_device(). --- common/cmd_fat.c | 8 +++--- fs/fat/fat.c | 65 ++++++++++++++++++++++++++--------------------------- include/fat.h | 1 + 3 files changed, 37 insertions(+), 37 deletions(-)
diff --git a/common/cmd_fat.c b/common/cmd_fat.c index 5a5698b..c38302d 100644 --- a/common/cmd_fat.c +++ b/common/cmd_fat.c @@ -55,7 +55,7 @@ int do_fat_fsload (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1;
dev = dev_desc->dev; - if (fat_register_device(dev_desc,part)!=0) { + if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatload **\n", argv[1], dev, part); return 1; @@ -111,7 +111,7 @@ int do_fat_ls (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1;
dev = dev_desc->dev; - if (fat_register_device(dev_desc,part)!=0) { + if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatls **\n", argv[1], dev, part); return 1; @@ -149,7 +149,7 @@ int do_fat_fsinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1;
dev = dev_desc->dev; - if (fat_register_device(dev_desc,part)!=0) { + if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatinfo **\n", argv[1], dev, part); return 1; @@ -185,7 +185,7 @@ static int do_fat_fswrite(cmd_tbl_t *cmdtp, int flag,
- if (fat_register_device(dev_desc, part) != 0) { + if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatwrite **\n", argv[1], dev, part); return 1; diff --git a/fs/fat/fat.c b/fs/fat/fat.c index 1e0d2a3..79e66ce 100644 --- a/fs/fat/fat.c +++ b/fs/fat/fat.c @@ -61,42 +61,12 @@ static int disk_read(__u32 block, __u32 nr_blocks, void *buf) cur_part_info.start + block, nr_blocks, buf); }
-int fat_register_device(block_dev_desc_t * dev_desc, int part_no) +int fat_set_blk_dev(block_dev_desc_t *dev_desc, disk_partition_t *info) { ALLOC_CACHE_ALIGN_BUFFER(unsigned char, buffer, dev_desc->blksz);
- /* First close any currently found FAT filesystem */ - cur_dev = NULL; - -#if (defined(CONFIG_CMD_IDE) || \ - defined(CONFIG_CMD_SATA) || \ - defined(CONFIG_CMD_SCSI) || \ - defined(CONFIG_CMD_USB) || \ - defined(CONFIG_MMC) || \ - defined(CONFIG_SYSTEMACE) ) - - /* Read the partition table, if present */ - if (!get_partition_info(dev_desc, part_no, &cur_part_info)) { - cur_dev = dev_desc; - } -#endif - - /* Otherwise it might be a superfloppy (whole-disk FAT filesystem) */ - if (!cur_dev) { - if (part_no != 0) { - printf("** Partition %d not valid on device %d **\n", - part_no, dev_desc->dev); - return -1; - } - - cur_dev = dev_desc; - cur_part_info.part = 0; - cur_part_info.start = 0; - cur_part_info.size = dev_desc->lba; - cur_part_info.blksz = dev_desc->blksz; - memset(cur_part_info.name, 0, sizeof(cur_part_info.name)); - memset(cur_part_info.type, 0, sizeof(cur_part_info.type)); - } + cur_dev = dev_desc; + cur_part_info = *info;
/* Make sure it has a valid FAT header */ if (disk_read(0, 1, buffer) != 1) { @@ -120,6 +90,35 @@ int fat_register_device(block_dev_desc_t * dev_desc, int part_no) return -1; }
+int fat_register_device(block_dev_desc_t *dev_desc, int part_no) +{ + disk_partition_t info; + + /* First close any currently found FAT filesystem */ + cur_dev = NULL; + + /* Read the partition table, if present */ + if (get_partition_info(dev_desc, part_no, &info)) { + if (part_no != 0) { + printf("** Partition %d not valid on device %d **\n", + part_no, dev_desc->dev); + return -1; + } + + info.part = 0; + info.start = 0; + info.size = dev_desc->lba; + info.blksz = dev_desc->blksz; + memset(info.name, 0, sizeof(info.name)); + memset(info.type, 0, sizeof(info.type)); +#ifdef CONFIG_PARTITION_UUIDS + memset(info.uuid, 0, sizeof(info.uuid)); +#endif + info.bootable = 0; + } + + return fat_set_blk_dev(dev_desc, &info); +}
/* * Get the first occurence of a directory delimiter ('/' or '') in a string. diff --git a/include/fat.h b/include/fat.h index cc85b06..706cd7a 100644 --- a/include/fat.h +++ b/include/fat.h @@ -212,6 +212,7 @@ long file_fat_read_at(const char *filename, unsigned long pos, void *buffer, unsigned long maxsize); long file_fat_read(const char *filename, void *buffer, unsigned long maxsize); const char *file_getfsname(int idx); +int fat_set_blk_dev(block_dev_desc_t *rbdd, disk_partition_t *info); int fat_register_device(block_dev_desc_t *dev_desc, int part_no);
int file_fat_write(const char *filename, void *buffer, unsigned long maxsize);
Hi Stephen,
See my comments inlined below.
- if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatload **\n", argv[1], dev, part); return 1;
- if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatls **\n", argv[1], dev, part); return 1;
- if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatinfo **\n", argv[1], dev, part); return 1;
- if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatwrite **\n", argv[1], dev, part); return 1;
- cur_dev = NULL;
cur_dev = dev_desc;
-#endif
- if (!cur_dev) {
if (part_no != 0) {
return -1;
cur_dev = dev_desc;
cur_dev = dev_desc;
- disk_partition_t info;
- cur_dev = NULL;
- if (get_partition_info(dev_desc, part_no, &info)) {
if (part_no != 0) {
return -1;
info.part = 0;
info.start = 0;
info.bootable = 0;
Sorry for pointing this out only now, but now that cmd_fat.c has been switched to fat_set_blk_dev(), the code above is handled for this file by get_device_and_partition(): --- info->start = 0; info->size = (*dev_desc)->lba; info->blksz = (*dev_desc)->blksz; info->bootable = 0; #ifdef CONFIG_PARTITION_UUIDS info->uuid[0] = 0; #endif ---
This code does not initialize the fields part, name and type, and it clears only the 1st byte of the uuid field. Is this on purpose for some reason, or is this an issue?
- return fat_set_blk_dev(dev_desc, &info);
- Get the first occurence of a directory delimiter ('/' or '') in
Apart from that, this new version of this series looks good.
Best regards, Benoît
On 10/09/2012 05:06 PM, Benoît Thébaudeau wrote:
Hi Stephen,
- cur_dev = NULL;
if (part_no != 0) {
return -1;
info.part = 0;
info.start = 0;
info.bootable = 0;
#endif
get_device_and_partition() should set indeed set info->part in the whole-disk case; I'll fix that.
I think get_device_and_partition() never cleared name or type in this case; I guess that's a pre-existing inconsistency between the two pieces of code? I'll have a look and add a cleanup patch to make the code consistent.
The uuid field is a string, so clearing just the first byte is fine; I ended up using memset in the new code in this patch since the existing fat_register_device() implementation used memset() on name and type; something I imagine is not strictly necessary. Since the function is being re-written anyway, I'll take a look to make sure that clearing only the first byte is fine, and remove all the memsets and just zero out the first byte.
Benoît Thébaudeau
Stephen Warren
