[U-Boot] [PATCH] Tegra: P2571: Clean up config file
Removed NS16550_COM1 #define, not used since there's no SPL for T210 Also changed the number of USB controllers to 1 as only USBD is used.
Signed-off-by: Tom Warren twarren@nvidia.com --- include/configs/p2571.h | 7 +------ 1 file changed, 1 insertion(+), 6 deletions(-)
diff --git a/include/configs/p2571.h b/include/configs/p2571.h index 5df7d2f..b22117b 100644 --- a/include/configs/p2571.h +++ b/include/configs/p2571.h @@ -22,7 +22,6 @@ /* Board-specific serial config */ #define CONFIG_SERIAL_MULTI #define CONFIG_TEGRA_ENABLE_UARTA -#define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE
/* I2C */ #define CONFIG_SYS_I2C_TEGRA @@ -51,7 +50,7 @@ /* USB2.0 Host support */ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA -#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #define CONFIG_USB_STORAGE #define CONFIG_CMD_USB
@@ -62,10 +61,6 @@ /* General networking support */ #define CONFIG_CMD_DHCP
-/* - * TODO(twarren@nvidia.com) - add tegra-common-usb-gadget.h back - * breaks 64-bit build in ci_udc.c - */ #include "tegra-common-usb-gadget.h" #include "tegra-common-post.h"
Acked-by: Stephen Warren swarren@nvidia.com
Hi Tom,
You should be able to drop this now that Tegra uses driver model for USB.
- TODO(twarren@nvidia.com) - add tegra-common-usb-gadget.h back
- breaks 64-bit build in ci_udc.c
-- 1.8.2.1.610.g562af5b
Simon,
-----Original Message----- From: sjg@google.com [mailto:sjg@google.com] On Behalf Of Simon Glass Sent: Thursday, July 30, 2015 2:33 PM To: Tom Warren Cc: U-Boot Mailing List; Tom Warren; Stephen Warren Subject: Re: [PATCH] Tegra: P2571: Clean up config file
Hi Tom,
Doesn't seem to work on P2571. If I drop MAX_CONTROLLER_COUNT, it builds, but I get "EHCI failed to shut down host controller" errors on usb start/reset, and I don't see any of my periphs (mouse, USB stick, network dongle). With it in there as I have it above, everything works.
-- nvpublic
Hi Tom,
On 30 July 2015 at 16:28, Tom Warren TWarren@nvidia.com wrote:
Simon,
Hi Tom,
Odd...
Do you have CONFIG_DM_USB defined for this board? (check .config or u-boot.cfg after a build). Also are you basing on latest mainline? Hans fixed a few bugs which I applied in the past week.
-- nvpublic
Stephen Warren
Tom Warren
Tom Warren
