[U-Boot] [PATCH] nios2: fix r15 issue for gcc4
The "-ffixed-r15" option doesn't work well for gcc4. Since we don't use gp for small data with option "-G0", we can use gp as global data pointer. This allows compiler to use r15. It is necessary for gcc4 to work properly.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- arch/nios2/config.mk | 2 +- arch/nios2/cpu/start.S | 7 ------- arch/nios2/include/asm/global_data.h | 2 +- 3 files changed, 2 insertions(+), 9 deletions(-)
diff --git a/arch/nios2/config.mk b/arch/nios2/config.mk index 8e5d6ef..6789038 100644 --- a/arch/nios2/config.mk +++ b/arch/nios2/config.mk @@ -27,6 +27,6 @@ CROSS_COMPILE ?= nios2-elf- STANDALONE_LOAD_ADDR = 0x02000000 -L $(gcclibdir)
PLATFORM_CPPFLAGS += -DCONFIG_NIOS2 -D__NIOS2__ -PLATFORM_CPPFLAGS += -ffixed-r15 -G0 +PLATFORM_CPPFLAGS += -G0
LDSCRIPT ?= $(SRCTREE)/$(CPUDIR)/u-boot.lds diff --git a/arch/nios2/cpu/start.S b/arch/nios2/cpu/start.S index d1016ea..76d3b52 100644 --- a/arch/nios2/cpu/start.S +++ b/arch/nios2/cpu/start.S @@ -113,13 +113,6 @@ _cur: movhi r5, %hi(_cur - _start) bne r5, r6, 4b 5:
- /* GLOBAL POINTER -- the global pointer is used to reference - * "small data" (see -G switch). The linker script must - * provide the gp address. - */ - movhi gp, %hi(_gp) - ori gp, gp, %lo(_gp) - /* JUMP TO RELOC ADDR */ movhi r4, %hi(_reloc) ori r4, r4, %lo(_reloc) diff --git a/arch/nios2/include/asm/global_data.h b/arch/nios2/include/asm/global_data.h index 34aa962..f1b3482 100644 --- a/arch/nios2/include/asm/global_data.h +++ b/arch/nios2/include/asm/global_data.h @@ -48,6 +48,6 @@ typedef struct global_data { #define GD_FLG_LOGINIT 0x00020 /* Log Buffer has been initialized */ #define GD_FLG_DISABLE_CONSOLE 0x00040 /* Disable console (in & out) */
-#define DECLARE_GLOBAL_DATA_PTR register gd_t *gd asm ("r15") +#define DECLARE_GLOBAL_DATA_PTR register gd_t *gd asm ("gp")
#endif /* __ASM_NIOS2_GLOBALDATA_H_ */
This patch fixes the run-time error on div64 when built with gcc4, which was reported by jhwu0625 on nios forum. It merges math support from libgcc of gcc4. This patch is copied from nios2-linux.
It works with both gcc3 and gcc4. The old mult.c, divmod.c and math.h are removed.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- arch/nios2/lib/Makefile | 3 +- arch/nios2/lib/divmod.c | 101 -------- arch/nios2/lib/libgcc.c | 592 +++++++++++++++++++++++++++++++++++++++++++++ arch/nios2/lib/longlong.h | 263 ++++++++++++++++++++ arch/nios2/lib/math.h | 16 -- arch/nios2/lib/mult.c | 56 ----- 6 files changed, 856 insertions(+), 175 deletions(-) delete mode 100644 arch/nios2/lib/divmod.c create mode 100644 arch/nios2/lib/libgcc.c create mode 100644 arch/nios2/lib/longlong.h delete mode 100644 arch/nios2/lib/math.h delete mode 100644 arch/nios2/lib/mult.c
diff --git a/arch/nios2/lib/Makefile b/arch/nios2/lib/Makefile index b69bc38..92320c5 100644 --- a/arch/nios2/lib/Makefile +++ b/arch/nios2/lib/Makefile @@ -29,8 +29,7 @@ SOBJS-y += cache.o
COBJS-y += board.o COBJS-y += bootm.o -COBJS-y += divmod.o -COBJS-y += mult.o +COBJS-y += libgcc.o COBJS-y += time.o
SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) diff --git a/arch/nios2/lib/divmod.c b/arch/nios2/lib/divmod.c deleted file mode 100644 index 3c7e71e..0000000 --- a/arch/nios2/lib/divmod.c +++ /dev/null @@ -1,101 +0,0 @@ -/* - * This file is part of GNU CC. - * - * GNU CC is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published - * by the Free Software Foundation; either version 2, or (at your - * option) any later version. - * - * GNU CC is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with GNU CC; see the file COPYING. If not, write - * to the Free Software Foundation, 59 Temple Place - Suite 330, - * Boston, MA 02111-1307, USA. - */ - - -#include "math.h" - -USItype udivmodsi4 (USItype num, USItype den, word_type modwanted) -{ - USItype bit = 1; - USItype res = 0; - - while (den < num && bit && !(den & (1L << 31))) { - den <<= 1; - bit <<= 1; - } - while (bit) { - if (num >= den) { - num -= den; - res |= bit; - } - bit >>= 1; - den >>= 1; - } - if (modwanted) - return num; - return res; -} - - -SItype __divsi3 (SItype a, SItype b) -{ - word_type neg = 0; - SItype res; - - if (a < 0) { - a = -a; - neg = !neg; - } - - if (b < 0) { - b = -b; - neg = !neg; - } - - res = udivmodsi4 (a, b, 0); - - if (neg) - res = -res; - - return res; -} - - -SItype __modsi3 (SItype a, SItype b) -{ - word_type neg = 0; - SItype res; - - if (a < 0) { - a = -a; - neg = 1; - } - - if (b < 0) - b = -b; - - res = udivmodsi4 (a, b, 1); - - if (neg) - res = -res; - - return res; -} - - -SItype __udivsi3 (SItype a, SItype b) -{ - return udivmodsi4 (a, b, 0); -} - - -SItype __umodsi3 (SItype a, SItype b) -{ - return udivmodsi4 (a, b, 1); -} diff --git a/arch/nios2/lib/libgcc.c b/arch/nios2/lib/libgcc.c new file mode 100644 index 0000000..dc05627 --- /dev/null +++ b/arch/nios2/lib/libgcc.c @@ -0,0 +1,592 @@ +/* + * This file is part of GNU CC. + * + * GNU CC is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published + * by the Free Software Foundation; either version 2, or (at your + * option) any later version. + * + * GNU CC is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public + * License along with GNU CC; see the file COPYING. If not, write + * to the Free Software Foundation, 59 Temple Place - Suite 330, + * Boston, MA 02111-1307, USA. + */ + +typedef unsigned int UWtype; +typedef unsigned int UHWtype; +typedef unsigned long long UDWtype; +#define W_TYPE_SIZE 32 + +typedef unsigned char UQItype; +typedef long SItype; +typedef unsigned long USItype; +typedef long long DItype; +typedef unsigned long long DSItype; + +#include "longlong.h" + + +typedef int word_type; +typedef long Wtype; +typedef long long DWtype; + +struct DWstruct { Wtype low, high;}; + +typedef union +{ + struct DWstruct s; + DWtype ll; +} DWunion; + +#define BITS_PER_UNIT 8 + +UDWtype +__udivmoddi4 (UDWtype n, UDWtype d, UDWtype *rp); + +const UQItype __clz_tab[256] = +{ + 0,1,2,2,3,3,3,3,4,4,4,4,4,4,4,4,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5, + 6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6, + 7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7, + 7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7, + 8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8, + 8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8, + 8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8, + 8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8 +}; + + +DWtype +__ashldi3 (DWtype u, word_type b) +{ + if (b == 0) + return u; + + const DWunion uu = {.ll = u}; + const word_type bm = (sizeof (Wtype) * BITS_PER_UNIT) - b; + DWunion w; + + if (bm <= 0) + { + w.s.low = 0; + w.s.high = (UWtype) uu.s.low << -bm; + } + else + { + const UWtype carries = (UWtype) uu.s.low >> bm; + + w.s.low = (UWtype) uu.s.low << b; + w.s.high = ((UWtype) uu.s.high << b) | carries; + } + + return w.ll; +} + +DWtype +__ashrdi3 (DWtype u, word_type b) +{ + if (b == 0) + return u; + + const DWunion uu = {.ll = u}; + const word_type bm = (sizeof (Wtype) * BITS_PER_UNIT) - b; + DWunion w; + + if (bm <= 0) + { + /* w.s.high = 1..1 or 0..0 */ + w.s.high = uu.s.high >> (sizeof (Wtype) * BITS_PER_UNIT - 1); + w.s.low = uu.s.high >> -bm; + } + else + { + const UWtype carries = (UWtype) uu.s.high << bm; + + w.s.high = uu.s.high >> b; + w.s.low = ((UWtype) uu.s.low >> b) | carries; + } + + return w.ll; +} + +DWtype +__lshrdi3 (DWtype u, word_type b) +{ + if (b == 0) + return u; + + const DWunion uu = {.ll = u}; + const word_type bm = (sizeof (Wtype) * BITS_PER_UNIT) - b; + DWunion w; + + if (bm <= 0) + { + w.s.high = 0; + w.s.low = (UWtype) uu.s.high >> -bm; + } + else + { + const UWtype carries = (UWtype) uu.s.high << bm; + + w.s.high = (UWtype) uu.s.high >> b; + w.s.low = ((UWtype) uu.s.low >> b) | carries; + } + + return w.ll; +} + +word_type +__cmpdi2 (DWtype a, DWtype b) +{ + const DWunion au = {.ll = a}; + const DWunion bu = {.ll = b}; + + if (au.s.high < bu.s.high) + return 0; + else if (au.s.high > bu.s.high) + return 2; + if ((UWtype) au.s.low < (UWtype) bu.s.low) + return 0; + else if ((UWtype) au.s.low > (UWtype) bu.s.low) + return 2; + return 1; +} + +UDWtype +__udivmoddi4 (UDWtype n, UDWtype d, UDWtype *rp) +{ + const DWunion nn = {.ll = n}; + const DWunion dd = {.ll = d}; + DWunion rr; + UWtype d0, d1, n0, n1, n2; + UWtype q0, q1; + UWtype b, bm; + + d0 = dd.s.low; + d1 = dd.s.high; + n0 = nn.s.low; + n1 = nn.s.high; + +#if !UDIV_NEEDS_NORMALIZATION + if (d1 == 0) + { + if (d0 > n1) + { + /* 0q = nn / 0D */ + + udiv_qrnnd (q0, n0, n1, n0, d0); + q1 = 0; + + /* Remainder in n0. */ + } + else + { + /* qq = NN / 0d */ + + if (d0 == 0) + d0 = 1 / d0; /* Divide intentionally by zero. */ + + udiv_qrnnd (q1, n1, 0, n1, d0); + udiv_qrnnd (q0, n0, n1, n0, d0); + + /* Remainder in n0. */ + } + + if (rp != 0) + { + rr.s.low = n0; + rr.s.high = 0; + *rp = rr.ll; + } + } + +#else /* UDIV_NEEDS_NORMALIZATION */ + + if (d1 == 0) + { + if (d0 > n1) + { + /* 0q = nn / 0D */ + + count_leading_zeros (bm, d0); + + if (bm != 0) + { + /* Normalize, i.e. make the most significant bit of the + denominator set. */ + + d0 = d0 << bm; + n1 = (n1 << bm) | (n0 >> (W_TYPE_SIZE - bm)); + n0 = n0 << bm; + } + + udiv_qrnnd (q0, n0, n1, n0, d0); + q1 = 0; + + /* Remainder in n0 >> bm. */ + } + else + { + /* qq = NN / 0d */ + + if (d0 == 0) + d0 = 1 / d0; /* Divide intentionally by zero. */ + + count_leading_zeros (bm, d0); + + if (bm == 0) + { + /* From (n1 >= d0) /\ (the most significant bit of d0 is set), + conclude (the most significant bit of n1 is set) /\ (the + leading quotient digit q1 = 1). + + This special case is necessary, not an optimization. + (Shifts counts of W_TYPE_SIZE are undefined.) */ + + n1 -= d0; + q1 = 1; + } + else + { + /* Normalize. */ + + b = W_TYPE_SIZE - bm; + + d0 = d0 << bm; + n2 = n1 >> b; + n1 = (n1 << bm) | (n0 >> b); + n0 = n0 << bm; + + udiv_qrnnd (q1, n1, n2, n1, d0); + } + + /* n1 != d0... */ + + udiv_qrnnd (q0, n0, n1, n0, d0); + + /* Remainder in n0 >> bm. */ + } + + if (rp != 0) + { + rr.s.low = n0 >> bm; + rr.s.high = 0; + *rp = rr.ll; + } + } +#endif /* UDIV_NEEDS_NORMALIZATION */ + + else + { + if (d1 > n1) + { + /* 00 = nn / DD */ + + q0 = 0; + q1 = 0; + + /* Remainder in n1n0. */ + if (rp != 0) + { + rr.s.low = n0; + rr.s.high = n1; + *rp = rr.ll; + } + } + else + { + /* 0q = NN / dd */ + + count_leading_zeros (bm, d1); + if (bm == 0) + { + /* From (n1 >= d1) /\ (the most significant bit of d1 is set), + conclude (the most significant bit of n1 is set) /\ (the + quotient digit q0 = 0 or 1). + + This special case is necessary, not an optimization. */ + + /* The condition on the next line takes advantage of that + n1 >= d1 (true due to program flow). */ + if (n1 > d1 || n0 >= d0) + { + q0 = 1; + sub_ddmmss (n1, n0, n1, n0, d1, d0); + } + else + q0 = 0; + + q1 = 0; + + if (rp != 0) + { + rr.s.low = n0; + rr.s.high = n1; + *rp = rr.ll; + } + } + else + { + UWtype m1, m0; + /* Normalize. */ + + b = W_TYPE_SIZE - bm; + + d1 = (d1 << bm) | (d0 >> b); + d0 = d0 << bm; + n2 = n1 >> b; + n1 = (n1 << bm) | (n0 >> b); + n0 = n0 << bm; + + udiv_qrnnd (q0, n1, n2, n1, d1); + umul_ppmm (m1, m0, q0, d0); + + if (m1 > n1 || (m1 == n1 && m0 > n0)) + { + q0--; + sub_ddmmss (m1, m0, m1, m0, d1, d0); + } + + q1 = 0; + + /* Remainder in (n1n0 - m1m0) >> bm. */ + if (rp != 0) + { + sub_ddmmss (n1, n0, n1, n0, m1, m0); + rr.s.low = (n1 << b) | (n0 >> bm); + rr.s.high = n1 >> bm; + *rp = rr.ll; + } + } + } + } + + const DWunion ww = {{.low = q0, .high = q1}}; + return ww.ll; +} + +DWtype +__divdi3 (DWtype u, DWtype v) +{ + word_type c = 0; + DWunion uu = {.ll = u}; + DWunion vv = {.ll = v}; + DWtype w; + + if (uu.s.high < 0) + c = ~c, + uu.ll = -uu.ll; + if (vv.s.high < 0) + c = ~c, + vv.ll = -vv.ll; + + w = __udivmoddi4 (uu.ll, vv.ll, (UDWtype *) 0); + if (c) + w = -w; + + return w; +} + +DWtype +__negdi2 (DWtype u) +{ + const DWunion uu = {.ll = u}; + const DWunion w = { {.low = -uu.s.low, + .high = -uu.s.high - ((UWtype) -uu.s.low > 0) } }; + + return w.ll; +} + + +DWtype +__muldi3 (DWtype u, DWtype v) +{ + const DWunion uu = {.ll = u}; + const DWunion vv = {.ll = v}; + DWunion w = {.ll = __umulsidi3 (uu.s.low, vv.s.low)}; + + w.s.high += ((UWtype) uu.s.low * (UWtype) vv.s.high + + (UWtype) uu.s.high * (UWtype) vv.s.low); + + return w.ll; +} + +DWtype +__moddi3 (DWtype u, DWtype v) +{ + word_type c = 0; + DWunion uu = {.ll = u}; + DWunion vv = {.ll = v}; + DWtype w; + + if (uu.s.high < 0) + c = ~c, + uu.ll = -uu.ll; + if (vv.s.high < 0) + vv.ll = -vv.ll; + + (void) __udivmoddi4 (uu.ll, vv.ll, (UDWtype*)&w); + if (c) + w = -w; + + return w; +} + +word_type +__ucmpdi2 (DWtype a, DWtype b) +{ + const DWunion au = {.ll = a}; + const DWunion bu = {.ll = b}; + + if ((UWtype) au.s.high < (UWtype) bu.s.high) + return 0; + else if ((UWtype) au.s.high > (UWtype) bu.s.high) + return 2; + if ((UWtype) au.s.low < (UWtype) bu.s.low) + return 0; + else if ((UWtype) au.s.low > (UWtype) bu.s.low) + return 2; + return 1; +} + + +UDWtype +__udivdi3 (UDWtype n, UDWtype d) +{ + return __udivmoddi4 (n, d, (UDWtype *) 0); +} + +UDWtype +__umoddi3 (UDWtype u, UDWtype v) +{ + UDWtype w; + (void) __udivmoddi4 (u, v, &w); + + return w; +} + +static USItype +udivmodsi4(USItype num, USItype den, word_type modwanted) +{ + USItype bit = 1; + USItype res = 0; + + while (den < num && bit && !(den & (1L<<31))) + { + den <<=1; + bit <<=1; + } + while (bit) + { + if (num >= den) + { + num -= den; + res |= bit; + } + bit >>=1; + den >>=1; + } + if (modwanted) return num; + return res; +} + +SItype +__divsi3 (SItype a, SItype b) +{ + word_type neg = 0; + SItype res; + + if (a < 0) + { + a = -a; + neg = !neg; + } + + if (b < 0) + { + b = -b; + neg = !neg; + } + + res = udivmodsi4 (a, b, 0); + + if (neg) + res = -res; + + return res; +} + + +SItype +__udivsi3 (SItype a, SItype b) +{ + return udivmodsi4 (a, b, 0); +} + + +SItype +__modsi3 (SItype a, SItype b) +{ + word_type neg = 0; + SItype res; + + if (a < 0) + { + a = -a; + neg = 1; + } + + if (b < 0) + b = -b; + + res = udivmodsi4 (a, b, 1); + + if (neg) + res = -res; + + return res; +} + +SItype +__mulsi3 (SItype a, SItype b) +{ + SItype res = 0; + USItype cnt = a; + + while (cnt) + { + if (cnt & 1) + { + res += b; + } + b <<= 1; + cnt >>= 1; + } + + return res; +} + +SItype +__umodsi3 (SItype a, SItype b) + +{ + return udivmodsi4 (a, b, 1); +} + +int +__gcc_bcmp (const unsigned char *s1, const unsigned char *s2, unsigned long size) +{ + while (size > 0) + { + const unsigned char c1 = *s1++, c2 = *s2++; + if (c1 != c2) + return c1 - c2; + size--; + } + return 0; +} diff --git a/arch/nios2/lib/longlong.h b/arch/nios2/lib/longlong.h new file mode 100644 index 0000000..392f7e7 --- /dev/null +++ b/arch/nios2/lib/longlong.h @@ -0,0 +1,263 @@ +/* longlong.h -- definitions for mixed size 32/64 bit arithmetic. + Copyright (C) 1991, 1992, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2004, + 2005 Free Software Foundation, Inc. + + This definition file is free software; you can redistribute it + and/or modify it under the terms of the GNU General Public + License as published by the Free Software Foundation; either + version 2, or (at your option) any later version. + + This definition file is distributed in the hope that it will be + useful, but WITHOUT ANY WARRANTY; without even the implied + warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. + See the GNU General Public License for more details. + + You should have received a copy of the GNU General Public License + along with this program; if not, write to the Free Software + Foundation, Inc., 51 Franklin Street, Fifth Floor, + Boston, MA 02110-1301, USA. */ + +/* You have to define the following before including this file: + + UWtype -- An unsigned type, default type for operations (typically a "word") + UHWtype -- An unsigned type, at least half the size of UWtype. + UDWtype -- An unsigned type, at least twice as large a UWtype + W_TYPE_SIZE -- size in bits of UWtype + + UQItype -- Unsigned 8 bit type. + SItype, USItype -- Signed and unsigned 32 bit types. + DItype, UDItype -- Signed and unsigned 64 bit types. + + On a 32 bit machine UWtype should typically be USItype; + on a 64 bit machine, UWtype should typically be UDItype. */ + +#define __BITS4 (W_TYPE_SIZE / 4) +#define __ll_B ((UWtype) 1 << (W_TYPE_SIZE / 2)) +#define __ll_lowpart(t) ((UWtype) (t) & (__ll_B - 1)) +#define __ll_highpart(t) ((UWtype) (t) >> (W_TYPE_SIZE / 2)) + +#ifndef W_TYPE_SIZE +#define W_TYPE_SIZE 32 +#define UWtype USItype +#define UHWtype USItype +#define UDWtype UDItype +#endif + +extern const UQItype __clz_tab[256]; + +/* Define auxiliary asm macros. + + 1) umul_ppmm(high_prod, low_prod, multiplier, multiplicand) multiplies two + UWtype integers MULTIPLIER and MULTIPLICAND, and generates a two UWtype + word product in HIGH_PROD and LOW_PROD. + + 2) __umulsidi3(a,b) multiplies two UWtype integers A and B, and returns a + UDWtype product. This is just a variant of umul_ppmm. + + 3) udiv_qrnnd(quotient, remainder, high_numerator, low_numerator, + denominator) divides a UDWtype, composed by the UWtype integers + HIGH_NUMERATOR and LOW_NUMERATOR, by DENOMINATOR and places the quotient + in QUOTIENT and the remainder in REMAINDER. HIGH_NUMERATOR must be less + than DENOMINATOR for correct operation. If, in addition, the most + significant bit of DENOMINATOR must be 1, then the pre-processor symbol + UDIV_NEEDS_NORMALIZATION is defined to 1. + + 4) sdiv_qrnnd(quotient, remainder, high_numerator, low_numerator, + denominator). Like udiv_qrnnd but the numbers are signed. The quotient + is rounded towards 0. + + 5) count_leading_zeros(count, x) counts the number of zero-bits from the + msb to the first nonzero bit in the UWtype X. This is the number of + steps X needs to be shifted left to set the msb. Undefined for X == 0, + unless the symbol COUNT_LEADING_ZEROS_0 is defined to some value. + + 6) count_trailing_zeros(count, x) like count_leading_zeros, but counts + from the least significant end. + + 7) add_ssaaaa(high_sum, low_sum, high_addend_1, low_addend_1, + high_addend_2, low_addend_2) adds two UWtype integers, composed by + HIGH_ADDEND_1 and LOW_ADDEND_1, and HIGH_ADDEND_2 and LOW_ADDEND_2 + respectively. The result is placed in HIGH_SUM and LOW_SUM. Overflow + (i.e. carry out) is not stored anywhere, and is lost. + + 8) sub_ddmmss(high_difference, low_difference, high_minuend, low_minuend, + high_subtrahend, low_subtrahend) subtracts two two-word UWtype integers, + composed by HIGH_MINUEND_1 and LOW_MINUEND_1, and HIGH_SUBTRAHEND_2 and + LOW_SUBTRAHEND_2 respectively. The result is placed in HIGH_DIFFERENCE + and LOW_DIFFERENCE. Overflow (i.e. carry out) is not stored anywhere, + and is lost. + + If any of these macros are left undefined for a particular CPU, + C macros are used. */ + +/* The CPUs come in alphabetical order below. + + Please add support for more CPUs here, or improve the current support + for the CPUs below! + (E.g. WE32100, IBM360.) */ + +/* Snipped per CPU support */ + +/* If this machine has no inline assembler, use C macros. */ + +#if !defined (add_ssaaaa) +#define add_ssaaaa(sh, sl, ah, al, bh, bl) \ + do { \ + UWtype __x; \ + __x = (al) + (bl); \ + (sh) = (ah) + (bh) + (__x < (al)); \ + (sl) = __x; \ + } while (0) +#endif + +#if !defined (sub_ddmmss) +#define sub_ddmmss(sh, sl, ah, al, bh, bl) \ + do { \ + UWtype __x; \ + __x = (al) - (bl); \ + (sh) = (ah) - (bh) - (__x > (al)); \ + (sl) = __x; \ + } while (0) +#endif + +/* If we lack umul_ppmm but have smul_ppmm, define umul_ppmm in terms of + smul_ppmm. */ +#if !defined (umul_ppmm) && defined (smul_ppmm) +#define umul_ppmm(w1, w0, u, v) \ + do { \ + UWtype __w1; \ + UWtype __xm0 = (u), __xm1 = (v); \ + smul_ppmm (__w1, w0, __xm0, __xm1); \ + (w1) = __w1 + (-(__xm0 >> (W_TYPE_SIZE - 1)) & __xm1) \ + + (-(__xm1 >> (W_TYPE_SIZE - 1)) & __xm0); \ + } while (0) +#endif + +/* If we still don't have umul_ppmm, define it using plain C. */ +#if !defined (umul_ppmm) +#define umul_ppmm(w1, w0, u, v) \ + do { \ + UWtype __x0, __x1, __x2, __x3; \ + UHWtype __ul, __vl, __uh, __vh; \ + \ + __ul = __ll_lowpart (u); \ + __uh = __ll_highpart (u); \ + __vl = __ll_lowpart (v); \ + __vh = __ll_highpart (v); \ + \ + __x0 = (UWtype) __ul * __vl; \ + __x1 = (UWtype) __ul * __vh; \ + __x2 = (UWtype) __uh * __vl; \ + __x3 = (UWtype) __uh * __vh; \ + \ + __x1 += __ll_highpart (__x0);/* this can't give carry */ \ + __x1 += __x2; /* but this indeed can */ \ + if (__x1 < __x2) /* did we get it? */ \ + __x3 += __ll_B; /* yes, add it in the proper pos. */ \ + \ + (w1) = __x3 + __ll_highpart (__x1); \ + (w0) = __ll_lowpart (__x1) * __ll_B + __ll_lowpart (__x0); \ + } while (0) +#endif + +#if !defined (__umulsidi3) +#define __umulsidi3(u, v) \ + ({DWunion __w; \ + umul_ppmm (__w.s.high, __w.s.low, u, v); \ + __w.ll; }) +#endif + +/* Define this unconditionally, so it can be used for debugging. */ +#define __udiv_qrnnd_c(q, r, n1, n0, d) \ + do { \ + UWtype __d1, __d0, __q1, __q0; \ + UWtype __r1, __r0, __m; \ + __d1 = __ll_highpart (d); \ + __d0 = __ll_lowpart (d); \ + \ + __r1 = (n1) % __d1; \ + __q1 = (n1) / __d1; \ + __m = (UWtype) __q1 * __d0; \ + __r1 = __r1 * __ll_B | __ll_highpart (n0); \ + if (__r1 < __m) \ + { \ + __q1--, __r1 += (d); \ + if (__r1 >= (d)) /* i.e. we didn't get carry when adding to __r1 */\ + if (__r1 < __m) \ + __q1--, __r1 += (d); \ + } \ + __r1 -= __m; \ + \ + __r0 = __r1 % __d1; \ + __q0 = __r1 / __d1; \ + __m = (UWtype) __q0 * __d0; \ + __r0 = __r0 * __ll_B | __ll_lowpart (n0); \ + if (__r0 < __m) \ + { \ + __q0--, __r0 += (d); \ + if (__r0 >= (d)) \ + if (__r0 < __m) \ + __q0--, __r0 += (d); \ + } \ + __r0 -= __m; \ + \ + (q) = (UWtype) __q1 * __ll_B | __q0; \ + (r) = __r0; \ + } while (0) + +/* If the processor has no udiv_qrnnd but sdiv_qrnnd, go through + __udiv_w_sdiv (defined in libgcc or elsewhere). */ +#if !defined (udiv_qrnnd) && defined (sdiv_qrnnd) +#define udiv_qrnnd(q, r, nh, nl, d) \ + do { \ + USItype __r; \ + (q) = __udiv_w_sdiv (&__r, nh, nl, d); \ + (r) = __r; \ + } while (0) +#endif + +/* If udiv_qrnnd was not defined for this processor, use __udiv_qrnnd_c. */ +#if !defined (udiv_qrnnd) +#define UDIV_NEEDS_NORMALIZATION 1 +#define udiv_qrnnd __udiv_qrnnd_c +#endif + +#if !defined (count_leading_zeros) +#define count_leading_zeros(count, x) \ + do { \ + UWtype __xr = (x); \ + UWtype __a; \ + \ + if (W_TYPE_SIZE <= 32) \ + { \ + __a = __xr < ((UWtype)1<<2*__BITS4) \ + ? (__xr < ((UWtype)1<<__BITS4) ? 0 : __BITS4) \ + : (__xr < ((UWtype)1<<3*__BITS4) ? 2*__BITS4 : 3*__BITS4); \ + } \ + else \ + { \ + for (__a = W_TYPE_SIZE - 8; __a > 0; __a -= 8) \ + if (((__xr >> __a) & 0xff) != 0) \ + break; \ + } \ + \ + (count) = W_TYPE_SIZE - (__clz_tab[__xr >> __a] + __a); \ + } while (0) +#define COUNT_LEADING_ZEROS_0 W_TYPE_SIZE +#endif + +#if !defined (count_trailing_zeros) +/* Define count_trailing_zeros using count_leading_zeros. The latter might be + defined in asm, but if it is not, the C version above is good enough. */ +#define count_trailing_zeros(count, x) \ + do { \ + UWtype __ctz_x = (x); \ + UWtype __ctz_c; \ + count_leading_zeros (__ctz_c, __ctz_x & -__ctz_x); \ + (count) = W_TYPE_SIZE - 1 - __ctz_c; \ + } while (0) +#endif + +#ifndef UDIV_NEEDS_NORMALIZATION +#define UDIV_NEEDS_NORMALIZATION 0 +#endif diff --git a/arch/nios2/lib/math.h b/arch/nios2/lib/math.h deleted file mode 100644 index f0aed8e..0000000 --- a/arch/nios2/lib/math.h +++ /dev/null @@ -1,16 +0,0 @@ -#define BITS_PER_UNIT 8 - -typedef int HItype __attribute__ ((mode (HI))); -typedef unsigned int UHItype __attribute__ ((mode (HI))); - -typedef int SItype __attribute__ ((mode (SI))); -typedef unsigned int USItype __attribute__ ((mode (SI))); - -typedef int word_type __attribute__ ((mode (__word__))); - -struct SIstruct {HItype low, high;}; - -typedef union { - struct SIstruct s; - SItype ll; -} SIunion; diff --git a/arch/nios2/lib/mult.c b/arch/nios2/lib/mult.c deleted file mode 100644 index ec8139e..0000000 --- a/arch/nios2/lib/mult.c +++ /dev/null @@ -1,56 +0,0 @@ -/* - * This file is part of GNU CC. - * - * GNU CC is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published - * by the Free Software Foundation; either version 2, or (at your - * option) any later version. - * - * GNU CC is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public - * License along with GNU CC; see the file COPYING. If not, write - * to the Free Software Foundation, 59 Temple Place - Suite 330, - * Boston, MA 02111-1307, USA. - */ - - -#include <common.h> - -#if !defined(CONFIG_SYS_NIOS_MULT_HW) && !defined(CONFIG_SYS_NIOS_MULT_MSTEP) - -#include "math.h" - -USItype __mulsi3 (USItype a, USItype b) -{ - USItype c = 0; - - while (a != 0) { - if (a & 1) - c += b; - a >>= 1; - b <<= 1; - } - - return c; -} - - -UHItype __mulhi3 (UHItype a, UHItype b) -{ - UHItype c = 0; - - while (a != 0) { - if (a & 1) - c += b; - a >>= 1; - b <<= 1; - } - - return c; -} - -#endif /*!defined(CONFIG_SYS_NIOS_MULT_HW) && !defined(CONFIG_SYS_NIOS_MULT_MSTEP) */
Applied to: git://git.denx.de/u-boot-nios.git next
Thanks, --Scott
- This file is part of GNU CC.
- GNU CC is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published
- by the Free Software Foundation; either version 2, or (at your
- option) any later version.
- GNU CC is distributed in the hope that it will be useful,
- You should have received a copy of the GNU General Public
- License along with GNU CC; see the file COPYING. If not, write
- to the Free Software Foundation, 59 Temple Place - Suite 330,
- Boston, MA 02111-1307, USA.
-#include "math.h"
- USItype bit = 1;
- USItype res = 0;
den <<= 1;
bit <<= 1;
- while (bit) {
if (num >= den) {
num -= den;
res |= bit;
bit >>= 1;
den >>= 1;
- if (modwanted)
return num;
- return res;
- SItype res;
- if (a < 0) {
a = -a;
neg = !neg;
- if (b < 0) {
b = -b;
neg = !neg;
- if (neg)
res = -res;
- return res;
- SItype res;
- if (a < 0) {
a = -a;
neg = 1;
- if (b < 0)
b = -b;
- if (neg)
res = -res;
- return res;
+typedef union +{
- struct DWstruct s;
- DWtype ll;
+} DWunion;
- 0,1,2,2,3,3,3,3,4,4,4,4,4,4,4,4,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,5,
- 6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,
- 7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,7,
- 8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,
- if (b == 0)
- return u;
- const DWunion uu = {.ll = u};
- const word_type bm = (sizeof (Wtype) * BITS_PER_UNIT) - b;
- DWunion w;
- if (bm <= 0)
w.s.low = 0;
- else
- return w.ll;
- if (b == 0)
- return u;
- DWunion w;
- if (bm <= 0)
- else
- return w.ll;
- if (b == 0)
- return u;
- DWunion w;
- if (bm <= 0)
w.s.high = 0;
- else
- return w.ll;
- const DWunion au = {.ll = a};
- const DWunion bu = {.ll = b};
- if (au.s.high < bu.s.high)
- else if (au.s.high > bu.s.high)
- return 2;
- if ((UWtype) au.s.low < (UWtype) bu.s.low)
- else if ((UWtype) au.s.low > (UWtype) bu.s.low)
- return 2;
- return 1;
- const DWunion nn = {.ll = n};
- const DWunion dd = {.ll = d};
- DWunion rr;
- UWtype d0, d1, n0, n1, n2;
- UWtype q0, q1;
- UWtype b, bm;
- d0 = dd.s.low;
- d1 = dd.s.high;
- n0 = nn.s.low;
- n1 = nn.s.high;
- if (d1 == 0)
if (d0 > n1)
/* 0q = nn / 0D */
q1 = 0;
else
/* qq = NN / 0d */
if (d0 == 0)
if (rp != 0)
rr.s.low = n0;
rr.s.high = 0;
*rp = rr.ll;
- if (d1 == 0)
if (d0 > n1)
/* 0q = nn / 0D */
if (bm != 0)
denominator set. */
d0 = d0 << bm;
n0 = n0 << bm;
q1 = 0;
else
/* qq = NN / 0d */
if (d0 == 0)
if (bm == 0)
n1 -= d0;
q1 = 1;
else
/* Normalize. */
d0 = d0 << bm;
n2 = n1 >> b;
n0 = n0 << bm;
/* n1 != d0... */
if (rp != 0)
rr.s.high = 0;
*rp = rr.ll;
- else
if (d1 > n1)
/* 00 = nn / DD */
q0 = 0;
q1 = 0;
if (rp != 0)
rr.s.low = n0;
rr.s.high = n1;
*rp = rr.ll;
else
/* 0q = NN / dd */
if (bm == 0)
q0 = 1;
else
q0 = 0;
q1 = 0;
if (rp != 0)
rr.s.low = n0;
rr.s.high = n1;
*rp = rr.ll;
else
UWtype m1, m0;
/* Normalize. */
d0 = d0 << bm;
n2 = n1 >> b;
n0 = n0 << bm;
q0--;
q1 = 0;
if (rp != 0)
*rp = rr.ll;
- const DWunion ww = {{.low = q0, .high = q1}};
- return ww.ll;
- word_type c = 0;
- DWunion uu = {.ll = u};
- DWunion vv = {.ll = v};
- DWtype w;
- if (uu.s.high < 0)
- c = ~c,
- uu.ll = -uu.ll;
- if (vv.s.high < 0)
- c = ~c,
- vv.ll = -vv.ll;
- w = __udivmoddi4 (uu.ll, vv.ll, (UDWtype *) 0);
- if (c)
- w = -w;
- return w;
- const DWunion w = { {.low = -uu.s.low,
- return w.ll;
- const DWunion vv = {.ll = v};
- DWunion w = {.ll = __umulsidi3 (uu.s.low, vv.s.low)};
- w.s.high += ((UWtype) uu.s.low * (UWtype) vv.s.high
- (UWtype) uu.s.high * (UWtype) vv.s.low);
- return w.ll;
- word_type c = 0;
- DWtype w;
- c = ~c,
- uu.ll = -uu.ll;
- vv.ll = -vv.ll;
- (void) __udivmoddi4 (uu.ll, vv.ll, (UDWtype*)&w);
- if (c)
- w = -w;
- return w;
- if ((UWtype) au.s.high < (UWtype) bu.s.high)
- else if ((UWtype) au.s.high > (UWtype) bu.s.high)
- return 2;
- return 2;
- return 1;
- return __udivmoddi4 (n, d, (UDWtype *) 0);
- UDWtype w;
- (void) __udivmoddi4 (u, v, &w);
- return w;
- USItype bit = 1;
- USItype res = 0;
- while (den < num && bit && !(den & (1L<<31)))
den <<=1;
bit <<=1;
- while (bit)
if (num >= den)
num -= den;
res |= bit;
bit >>=1;
den >>=1;
- if (modwanted) return num;
- return res;
- SItype res;
- if (a < 0)
a = -a;
neg = !neg;
- if (b < 0)
b = -b;
neg = !neg;
- if (neg)
- res = -res;
- return res;
- SItype res;
- if (a < 0)
a = -a;
neg = 1;
- if (b < 0)
- b = -b;
- if (neg)
- res = -res;
- return res;
- SItype res = 0;
- USItype cnt = a;
- while (cnt)
if (cnt & 1)
res += b;
b <<= 1;
cnt >>= 1;
- return res;
- while (size > 0)
if (c1 != c2)
- return c1 - c2;
size--;
- Copyright (C) 1991, 1992, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2004,
- 2005 Free Software Foundation, Inc.
- This definition file is free software; you can redistribute it
- and/or modify it under the terms of the GNU General Public
- License as published by the Free Software Foundation; either
- version 2, or (at your option) any later version.
- This definition file is distributed in the hope that it will be
- useful, but WITHOUT ANY WARRANTY; without even the implied
- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
- See the GNU General Public License for more details.
- Foundation, Inc., 51 Franklin Street, Fifth Floor,
- Boston, MA 02110-1301, USA. */
- UWtype -- An unsigned type, default type for operations (typically a "word")
- UHWtype -- An unsigned type, at least half the size of UWtype.
- UDWtype -- An unsigned type, at least twice as large a UWtype
- W_TYPE_SIZE -- size in bits of UWtype
- UQItype -- Unsigned 8 bit type.
- SItype, USItype -- Signed and unsigned 32 bit types.
- DItype, UDItype -- Signed and unsigned 64 bit types.
- On a 32 bit machine UWtype should typically be USItype;
- on a 64 bit machine, UWtype should typically be UDItype. */
- umul_ppmm(high_prod, low_prod, multiplier, multiplicand) multiplies two
- UWtype integers MULTIPLIER and MULTIPLICAND, and generates a two UWtype
- word product in HIGH_PROD and LOW_PROD.
- __umulsidi3(a,b) multiplies two UWtype integers A and B, and returns a
- UDWtype product. This is just a variant of umul_ppmm.
- udiv_qrnnd(quotient, remainder, high_numerator, low_numerator,
- denominator) divides a UDWtype, composed by the UWtype integers
- HIGH_NUMERATOR and LOW_NUMERATOR, by DENOMINATOR and places the quotient
- in QUOTIENT and the remainder in REMAINDER. HIGH_NUMERATOR must be less
- than DENOMINATOR for correct operation. If, in addition, the most
- significant bit of DENOMINATOR must be 1, then the pre-processor symbol
- UDIV_NEEDS_NORMALIZATION is defined to 1.
- sdiv_qrnnd(quotient, remainder, high_numerator, low_numerator,
- denominator). Like udiv_qrnnd but the numbers are signed. The quotient
- is rounded towards 0.
- count_leading_zeros(count, x) counts the number of zero-bits from the
- msb to the first nonzero bit in the UWtype X. This is the number of
- steps X needs to be shifted left to set the msb. Undefined for X == 0,
- unless the symbol COUNT_LEADING_ZEROS_0 is defined to some value.
- count_trailing_zeros(count, x) like count_leading_zeros, but counts
- from the least significant end.
- add_ssaaaa(high_sum, low_sum, high_addend_1, low_addend_1,
- high_addend_2, low_addend_2) adds two UWtype integers, composed by
- HIGH_ADDEND_1 and LOW_ADDEND_1, and HIGH_ADDEND_2 and LOW_ADDEND_2
- respectively. The result is placed in HIGH_SUM and LOW_SUM. Overflow
- (i.e. carry out) is not stored anywhere, and is lost.
- sub_ddmmss(high_difference, low_difference, high_minuend, low_minuend,
- high_subtrahend, low_subtrahend) subtracts two two-word UWtype integers,
- composed by HIGH_MINUEND_1 and LOW_MINUEND_1, and HIGH_SUBTRAHEND_2 and
- LOW_SUBTRAHEND_2 respectively. The result is placed in HIGH_DIFFERENCE
- and LOW_DIFFERENCE. Overflow (i.e. carry out) is not stored anywhere,
- and is lost.
- If any of these macros are left undefined for a particular CPU,
- C macros are used. */
- Please add support for more CPUs here, or improve the current support
- for the CPUs below!
- (E.g. WE32100, IBM360.) */
- do { \
- UWtype __x; \
- __x = (al) + (bl); \
- (sh) = (ah) + (bh) + (__x < (al)); \
- (sl) = __x; \
- } while (0)
- do { \
- UWtype __x; \
- __x = (al) - (bl); \
- (sh) = (ah) - (bh) - (__x > (al)); \
- (sl) = __x; \
- } while (0)
- smul_ppmm. */
- do { \
- UWtype __w1; \
- UWtype __xm0 = (u), __xm1 = (v); \
- smul_ppmm (__w1, w0, __xm0, __xm1); \
- (w1) = __w1 + (-(__xm0 >> (W_TYPE_SIZE - 1)) & __xm1) \
- } while (0)
- do { \
- UWtype __x0, __x1, __x2, __x3; \
- UHWtype __ul, __vl, __uh, __vh; \
- __ul = __ll_lowpart (u); \
- __uh = __ll_highpart (u); \
- __vl = __ll_lowpart (v); \
- __vh = __ll_highpart (v); \
- __x0 = (UWtype) __ul * __vl; \
- __x1 = (UWtype) __ul * __vh; \
- __x2 = (UWtype) __uh * __vl; \
- __x3 = (UWtype) __uh * __vh; \
- __x1 += __ll_highpart (__x0);/* this can't give carry */ \
- __x1 += __x2; /* but this indeed can */ \
- if (__x1 < __x2) /* did we get it? */ \
- (w1) = __x3 + __ll_highpart (__x1); \
- (w0) = __ll_lowpart (__x1) * __ll_B + __ll_lowpart (__x0); \
- } while (0)
- ({DWunion __w; \
- umul_ppmm (__w.s.high, __w.s.low, u, v); \
- __w.ll; })
- do { \
- UWtype __d1, __d0, __q1, __q0; \
- UWtype __r1, __r0, __m; \
- __d1 = __ll_highpart (d); \
- __d0 = __ll_lowpart (d); \
- __r1 = (n1) % __d1; \
- __q1 = (n1) / __d1; \
- __m = (UWtype) __q1 * __d0; \
- __r1 = __r1 * __ll_B | __ll_highpart (n0); \
- if (__r1 < __m) \
- __q1--, __r1 += (d); \
- if (__r1 >= (d)) /* i.e. we didn't get carry when adding to __r1 */\
if (__r1 < __m) \
- __r1 -= __m; \
- __r0 = __r1 % __d1; \
- __q0 = __r1 / __d1; \
- __m = (UWtype) __q0 * __d0; \
- __r0 = __r0 * __ll_B | __ll_lowpart (n0); \
- if (__r0 < __m) \
- __q0--, __r0 += (d); \
- if (__r0 >= (d)) \
if (__r0 < __m) \
- __r0 -= __m; \
- (q) = (UWtype) __q1 * __ll_B | __q0; \
- (r) = __r0; \
- } while (0)
- __udiv_w_sdiv (defined in libgcc or elsewhere). */
- do { \
- USItype __r; \
- (q) = __udiv_w_sdiv (&__r, nh, nl, d); \
- (r) = __r; \
- } while (0)
- do { \
- UWtype __xr = (x); \
- UWtype __a; \
- if (W_TYPE_SIZE <= 32) \
- __a = __xr < ((UWtype)1<<2*__BITS4) \
- else \
- for (__a = W_TYPE_SIZE - 8; __a > 0; __a -= 8) \
break; \
- (count) = W_TYPE_SIZE - (__clz_tab[__xr >> __a] + __a); \
- } while (0)
- defined in asm, but if it is not, the C version above is good enough. */
- do { \
- UWtype __ctz_x = (x); \
- UWtype __ctz_c; \
- count_leading_zeros (__ctz_c, __ctz_x & -__ctz_x); \
- (count) = W_TYPE_SIZE - 1 - __ctz_c; \
- } while (0)
-typedef union {
- SItype ll;
-#include "math.h"
- USItype c = 0;
- while (a != 0) {
if (a & 1)
c += b;
a >>= 1;
b <<= 1;
- return c;
- UHItype c = 0;
- while (a != 0) {
if (a & 1)
c += b;
a >>= 1;
b <<= 1;
- return c;
i think you also need to update examples/standalone/stubs.c
maybe also document things in README and doc/README.standalone ? -mike
Dear Mike,
Thank you very mcuh.
The nios2 gd usage was not documented. I will add it to README and doc/README.standalone. I will update examples/standalone/stubs.c, too.
Best regards, Thomas
This patch allows users to override default STANDALONE_LOAD_ADDR. The gcclibdir path was duplicated in the standalone Makefile and can be removed.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- arch/nios2/config.mk | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/nios2/config.mk b/arch/nios2/config.mk index 6789038..793cc43 100644 --- a/arch/nios2/config.mk +++ b/arch/nios2/config.mk @@ -24,7 +24,7 @@
-STANDALONE_LOAD_ADDR = 0x02000000 -L $(gcclibdir) +STANDALONE_LOAD_ADDR ?= 0x02000000
PLATFORM_CPPFLAGS += -DCONFIG_NIOS2 -D__NIOS2__ PLATFORM_CPPFLAGS += -G0
Thanks, --Scott
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2: update standalone stubs and doc.
README | 8 ++++++++ arch/nios2/config.mk | 2 +- arch/nios2/cpu/start.S | 7 ------- arch/nios2/include/asm/global_data.h | 2 +- doc/README.standalone | 13 +++++++------ examples/standalone/stubs.c | 6 +++--- 6 files changed, 20 insertions(+), 18 deletions(-)
diff --git a/README b/README index 81692c0..acb3308 100644 --- a/README +++ b/README @@ -4023,6 +4023,14 @@ On ARM, the following registers are used:
==> U-Boot will use R8 to hold a pointer to the global data
+On Nios II, the ABI is documented here: + http://www.altera.com/literature/hb/nios2/n2cpu_nii51016.pdf + + ==> U-Boot will use gp to hold a pointer to the global data + + Note: on Nios II, we give "-G0" option to gcc and don't use gp + to access small data sections, so gp is free. + NOTE: DECLARE_GLOBAL_DATA_PTR must be used with file-global scope, or current versions of GCC may "optimize" the code too much.
#endif /* __ASM_NIOS2_GLOBALDATA_H_ */ diff --git a/doc/README.standalone b/doc/README.standalone index 885c92f..6381087 100644 --- a/doc/README.standalone +++ b/doc/README.standalone @@ -19,12 +19,12 @@ Design Notes on Exporting U-Boot Functions to Standalone Applications: thus the compiler cannot perform type checks on these assignments.
2. The pointer to the jump table is passed to the application in a - machine-dependent way. PowerPC, ARM, MIPS and Blackfin architectures - use a dedicated register to hold the pointer to the 'global_data' - structure: r2 on PowerPC, r8 on ARM, k0 on MIPS, and P3 on Blackfin. - The x86 architecture does not use such a register; instead, the - pointer to the 'global_data' structure is passed as 'argv[-1]' - pointer. + machine-dependent way. PowerPC, ARM, MIPS, Blackfin and Nios II + architectures use a dedicated register to hold the pointer to the + 'global_data' structure: r2 on PowerPC, r8 on ARM, k0 on MIPS, + P3 on Blackfin and gp on Nios II. The x86 architecture does not + use such a register; instead, the pointer to the 'global_data' + structure is passed as 'argv[-1]' pointer.
The application can access the 'global_data' structure in the same way as U-Boot does: @@ -56,6 +56,7 @@ Design Notes on Exporting U-Boot Functions to Standalone Applications: ARM 0x0c100000 0x0c100000 MIPS 0x80200000 0x80200000 Blackfin 0x00001000 0x00001000 + Nios II 0x02000000 0x02000000
For example, the "hello world" application may be loaded and executed on a PowerPC board with the following commands: diff --git a/examples/standalone/stubs.c b/examples/standalone/stubs.c index ce3371d..0187708 100644 --- a/examples/standalone/stubs.c +++ b/examples/standalone/stubs.c @@ -84,7 +84,7 @@ gd_t *global_data; : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x) : "r0"); #elif defined(CONFIG_NIOS2) /* - * r15 holds the pointer to the global_data, r8 is call-clobbered + * gp holds the pointer to the global_data, r8 is call-clobbered */ #define EXPORT_FUNC(x) \ asm volatile ( \ @@ -92,11 +92,11 @@ gd_t *global_data; #x ":\n" \ " movhi r8, %%hi(%0)\n" \ " ori r8, r0, %%lo(%0)\n" \ -" add r8, r8, r15\n" \ +" add r8, r8, gp\n" \ " ldw r8, 0(r8)\n" \ " ldw r8, %1(r8)\n" \ " jmp r8\n" \ - : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "r15"); + : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "gp"); #elif defined(CONFIG_M68K) /* * d7 holds the pointer to the global_data, a0 is a call-clobbered
Thanks, --Scott
- http://www.altera.com/literature/hb/nios2/n2cpu_nii51016.pdf
- ==> U-Boot will use gp to hold a pointer to the global data
- Note: on Nios II, we give "-G0" option to gcc and don't use gp
- to access small data sections, so gp is free.
movhi gp, %hi(_gp)
- The pointer to the jump table is passed to the application in a
- pointer.
- r15 holds the pointer to the global_data, r8 is call-clobbered
- gp holds the pointer to the global_data, r8 is call-clobbered
- : : "i"(offsetof(gd_t, jt)), "i"(XF_ ## x * sizeof(void *)) : "gp");
- d7 holds the pointer to the global_data, a0 is a call-clobbered
Mike Frysinger
Scott McNutt
Thomas Chou
