[U-Boot] [PULL] efi patch queue 2017-10-01
Hi Tom,
This is my current patch queue for efi. Please pull.
Alex
The following changes since commit c07f38208a73bbe3efaa939d6742096c1cb7e0ce:
Merge git://git.denx.de/u-boot-x86 (2017-09-17 11:46:51 -0400)
git://github.com/agraf/u-boot.git tags/signed-efi-next
for you to fetch changes up to 7dd5d44753969167a6059405635bdb8b9d961fa1:
efi_loader: fix efi_exit (2017-09-21 09:04:25 +0200)
---------------------------------------------------------------- Patch queue for efi - 2017-10-01
Lots of new things this time. High level highlights are:
- Shim support (to boot Fedora) - Initial set of unit tests - Preparations to support UEFI Shell
---------------------------------------------------------------- Alexander Graf (1): efi_loader: Fix efi_exit gd clobbering
Andre Przywara (1): EFI: find EFI system partition by legacy MBR partition type
Heinrich Schuchardt (21): efi_loader: bootefi hello should use loadaddr efi_disk: efi_disk_rw_blocks is not an API function efi_loader: call __efi_exit_check in efi_exit efi_loader: write protocol GUID in OpenProtocol scripts/Makefile.lib: remove overridden target $(obj)/helloworld.so: efi_loader: rename __efi_hello_world_* scripts/Makefile.lib: generalize building built in EFI app efi_loader: usage of always in Makefile efi_loader: avoid obscure constants in efi_runtime.c efi_loader: fix typo in include/efi.h efi_loader: allow return value in EFI_CALL efi_selftest: provide an EFI selftest application test/py: add a test calling the EFI selftest efi_loader: implement queueing of the notification function efi_loader: efi_set_timer: reset signaled state efi_selftest: provide unit test for event services efi_loader: implement task priority level (TPL) efi_selftest: test task priority levels efi_loader: notify when ExitBootServices is invoked efi_selftest: check notification of ExitBootServices efi_loader: reenable selftest
Peter Jones (2): part: extract MBR signature from partitions efi: add some more device path structures
Rob Clark (20): part: move efi_guid_t efi: add some missing __packed efi_loader: add device-path utils efi_loader: drop redundant efi_device_path_protocol efi_loader: flesh out device-path to text efi_loader: use proper device-paths for partitions efi_loader: use proper device-paths for net efi_loader: refactor boot device and loaded_image handling efi_loader: add file/filesys support efi_loader: support load_image() from a file-path efi_loader: make pool allocations cacheline aligned efi_loader: efi variable support efi_loader: add bootmgr efi_loader: file_path should be variable length efi_loader: set loaded image code/data type properly efi_loader: print GUIDs efi_loader: split out escape sequence based size query efi_loader: Correctly figure out size for vidconsole efi_loader: Some console improvements for vidconsole efi_loader: fix efi_exit
MAINTAINERS | 5 +- cmd/Kconfig | 2 + cmd/bootefi.c | 288 ++++++------ disk/part_dos.c | 14 +- disk/part_efi.c | 20 + include/asm-generic/sections.h | 4 +- include/blk.h | 18 + include/config_distro_bootcmd.h | 5 + include/efi.h | 27 +- include/efi_api.h | 162 ++++++- include/efi_loader.h | 100 +++- include/efi_selftest.h | 91 ++++ include/part.h | 3 +- include/part_efi.h | 4 - include/pe.h | 6 + lib/Makefile | 1 + lib/efi_loader/Makefile | 8 +- lib/efi_loader/efi_bootmgr.c | 180 ++++++++ lib/efi_loader/efi_boottime.c | 263 +++++++++-- lib/efi_loader/efi_console.c | 127 +++-- lib/efi_loader/efi_device_path.c | 563 +++++++++++++++++++++++ lib/efi_loader/efi_device_path_to_text.c | 242 +++++++--- lib/efi_loader/efi_disk.c | 88 +++- lib/efi_loader/efi_file.c | 560 ++++++++++++++++++++++ lib/efi_loader/efi_image_loader.c | 26 ++ lib/efi_loader/efi_memory.c | 5 +- lib/efi_loader/efi_net.c | 24 +- lib/efi_loader/efi_runtime.c | 23 +- lib/efi_loader/efi_variable.c | 335 ++++++++++++++ lib/efi_selftest/Kconfig | 7 + lib/efi_selftest/Makefile | 26 ++ lib/efi_selftest/efi_selftest.c | 219 +++++++++ lib/efi_selftest/efi_selftest_console.c | 187 ++++++++ lib/efi_selftest/efi_selftest_events.c | 195 ++++++++ lib/efi_selftest/efi_selftest_exitbootservices.c | 106 +++++ lib/efi_selftest/efi_selftest_tpl.c | 214 +++++++++ scripts/Makefile.lib | 30 +- test/py/tests/test_efi_selftest.py | 25 + 38 files changed, 3800 insertions(+), 403 deletions(-) create mode 100644 include/efi_selftest.h create mode 100644 lib/efi_loader/efi_bootmgr.c create mode 100644 lib/efi_loader/efi_device_path.c create mode 100644 lib/efi_loader/efi_file.c create mode 100644 lib/efi_loader/efi_variable.c create mode 100644 lib/efi_selftest/Kconfig create mode 100644 lib/efi_selftest/Makefile create mode 100644 lib/efi_selftest/efi_selftest.c create mode 100644 lib/efi_selftest/efi_selftest_console.c create mode 100644 lib/efi_selftest/efi_selftest_events.c create mode 100644 lib/efi_selftest/efi_selftest_exitbootservices.c create mode 100644 lib/efi_selftest/efi_selftest_tpl.c create mode 100644 test/py/tests/test_efi_selftest.py
On Sun, Oct 01, 2017 at 10:30:57AM +0200, Alexander Graf wrote:
Hi Tom,
Alex
Alexander Graf
