[PATCH v5 19/20] mips: mtmips: enable SPL for all boards
This patch enables SPL for all mtmips boards. And also remove defconfig files which are intend to build ram bootable u-boot files.
SPL_DM and OF_CONTROL are enabled for both boards.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v3: add CONFIG_SPL_PAD_TO=0 to make sure no padding added --- arch/mips/mach-mtmips/Kconfig | 26 ------- board/gardena/smart-gateway-mt7688/board.c | 2 + ...gardena-smart-gateway-mt7688-ram_defconfig | 74 ------------------- .../gardena-smart-gateway-mt7688_defconfig | 10 ++- configs/linkit-smart-7688-ram_defconfig | 65 ---------------- configs/linkit-smart-7688_defconfig | 10 ++- .../configs/gardena-smart-gateway-mt7688.h | 21 +++++- include/configs/linkit-smart-7688.h | 22 +++++- 8 files changed, 59 insertions(+), 171 deletions(-) delete mode 100644 configs/gardena-smart-gateway-mt7688-ram_defconfig delete mode 100644 configs/linkit-smart-7688-ram_defconfig
diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index 81cec53e72..ad28ef3a8c 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -64,7 +64,6 @@ config BOARD_GARDENA_SMART_GATEWAY_MT7688 bool "GARDENA smart Gateway" depends on SOC_MT7628 select BOARD_LATE_INIT - select SUPPORTS_BOOT_RAM help GARDENA smart Gateway boards have a MT7688 SoC with 128 MiB of RAM and 8 MiB of flash (SPI NOR) and additional SPI NAND storage. @@ -72,7 +71,6 @@ config BOARD_GARDENA_SMART_GATEWAY_MT7688 config BOARD_LINKIT_SMART_7688 bool "LinkIt Smart 7688" depends on SOC_MT7628 - select SUPPORTS_BOOT_RAM help Seeed LinkIt Smart 7688 boards have a MT7688 SoC with 128 MiB of RAM and 32 MiB of flash (SPI). @@ -82,30 +80,6 @@ config BOARD_LINKIT_SMART_7688
endchoice
-choice - prompt "Boot mode" - -config BOOT_RAM - bool "RAM boot" - depends on SUPPORTS_BOOT_RAM - help - This builds an image that is linked to a RAM address. It can be used - for booting from CFE via TFTP using an ELF image, but it can also be - booted from RAM by other bootloaders using a BIN image. - -config BOOT_ROM - bool "ROM boot" - depends on SUPPORTS_BOOT_RAM - help - This builds an image that is linked to a ROM address. It can be - used as main bootloader image which is programmed onto the onboard - flash storage (SPI NOR). - -endchoice - -config SUPPORTS_BOOT_RAM - bool - config SPL_UART2_SPIS_PINMUX bool "Use alternative pinmux for UART2 in SPL stage" depends on SPL_SERIAL_SUPPORT diff --git a/board/gardena/smart-gateway-mt7688/board.c b/board/gardena/smart-gateway-mt7688/board.c index 48cf3091e9..776afa43a6 100644 --- a/board/gardena/smart-gateway-mt7688/board.c +++ b/board/gardena/smart-gateway-mt7688/board.c @@ -295,8 +295,10 @@ err_free: return ret; }
+#ifndef CONFIG_SPL_BUILD U_BOOT_CMD( fd_write, 1, 0, do_fd_write, "Write test factory-data values to SPI NOR", "\n" ); +#endif diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig deleted file mode 100644 index 4b9559a46d..0000000000 --- a/configs/gardena-smart-gateway-mt7688-ram_defconfig +++ /dev/null @@ -1,74 +0,0 @@ -CONFIG_MIPS=y -CONFIG_SYS_TEXT_BASE=0x80010000 -CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_ENV_OFFSET=0xA0000 -CONFIG_SYS_BOOTCOUNT_ADDR=0xb000006c -CONFIG_NR_DRAM_BANKS=1 -CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y -CONFIG_ARCH_MTMIPS=y -CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y -# CONFIG_MIPS_BOOT_ENV_LEGACY is not set -CONFIG_MIPS_BOOT_FDT=y -CONFIG_ENV_VARS_UBOOT_CONFIG=y -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_OF_STDOUT_VIA_ALIAS=y -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="cp.b 83000000 84000000 10000 && dhcp uEnv.txt && env import -t ${fileaddr} ${filesize} && run do_u_boot_init; reset" -CONFIG_USE_PREBOOT=y -CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_LICENSE=y -# CONFIG_CMD_ELF is not set -# CONFIG_CMD_XIMG is not set -CONFIG_CMD_MEMINFO=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -# CONFIG_CMD_LOADS is not set -CONFIG_CMD_MTD=y -CONFIG_CMD_SPI=y -CONFIG_CMD_WDT=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_BOOTCOUNT=y -CONFIG_CMD_TIME=y -CONFIG_CMD_UUID=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="spi-nand0=spi0.1,nor0=spi0.0" -CONFIG_MTDPARTS_DEFAULT="spi0.0:640k(uboot),64k(uboot_env0),64k(uboot_env1),64k(factory),-(unused);spi0.1:-(nand)" -CONFIG_CMD_UBI=y -CONFIG_DEFAULT_DEVICE_TREE="gardena-smart-gateway-mt7688" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_ENV_OFFSET_REDUND=0xB0000 -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -# CONFIG_DM_DEVICE_REMOVE is not set -CONFIG_HAVE_BLOCK_DEVICE=y -CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_LED=y -CONFIG_LED_BLINK=y -CONFIG_LED_GPIO=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_MTD_SPI_NAND=y -CONFIG_SPI_FLASH_GIGADEVICE=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_SPI_FLASH_XMC=y -CONFIG_SPI_FLASH_MTD=y -CONFIG_MTD_UBI_BEB_LIMIT=22 -CONFIG_MT7628_ETH=y -CONFIG_PHY=y -CONFIG_SPI=y -CONFIG_MT7621_SPI=y -CONFIG_WDT=y -CONFIG_WDT_MT7621=y -CONFIG_LZMA=y diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index 50326ae49e..fb656caa2b 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -1,13 +1,16 @@ CONFIG_MIPS=y -CONFIG_SYS_TEXT_BASE=0x9c000000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ENV_OFFSET=0xA0000 CONFIG_SYS_BOOTCOUNT_ADDR=0xb000006c +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x20000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_ARCH_MTMIPS=y -CONFIG_BOOT_ROM=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y @@ -22,6 +25,8 @@ CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_LICENSE=y # CONFIG_CMD_ELF is not set @@ -49,6 +54,7 @@ CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_OFFSET_REDUND=0xB0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_HAVE_BLOCK_DEVICE=y CONFIG_BOOTCOUNT_LIMIT=y diff --git a/configs/linkit-smart-7688-ram_defconfig b/configs/linkit-smart-7688-ram_defconfig deleted file mode 100644 index 1db94db41f..0000000000 --- a/configs/linkit-smart-7688-ram_defconfig +++ /dev/null @@ -1,65 +0,0 @@ -CONFIG_MIPS=y -CONFIG_SYS_TEXT_BASE=0x80010000 -CONFIG_ENV_SIZE=0x4000 -CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_ENV_OFFSET=0x80000 -CONFIG_NR_DRAM_BANKS=1 -CONFIG_ARCH_MTMIPS=y -CONFIG_BOARD_LINKIT_SMART_7688=y -CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y -# CONFIG_MIPS_BOOT_ENV_LEGACY is not set -CONFIG_MIPS_BOOT_FDT=y -CONFIG_FIT=y -CONFIG_FIT_SIGNATURE=y -CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_OF_STDOUT_VIA_ALIAS=y -CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_LICENSE=y -# CONFIG_CMD_ELF is not set -# CONFIG_CMD_XIMG is not set -CONFIG_CMD_MEMINFO=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -# CONFIG_CMD_LOADS is not set -CONFIG_CMD_MTD=y -CONFIG_CMD_PART=y -CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_TIME=y -CONFIG_CMD_FS_GENERIC=y -# CONFIG_DOS_PARTITION is not set -CONFIG_DEFAULT_DEVICE_TREE="linkit-smart-7688" -CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -# CONFIG_DM_DEVICE_REMOVE is not set -CONFIG_BLK=y -CONFIG_LED=y -CONFIG_LED_BLINK=y -CONFIG_LED_GPIO=y -CONFIG_MTD=y -CONFIG_SPI_FLASH_GIGADEVICE=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_SPI_FLASH_MTD=y -CONFIG_MT7628_ETH=y -CONFIG_PHY=y -CONFIG_MT76X8_USB_PHY=y -CONFIG_SPI=y -CONFIG_MT7621_SPI=y -CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_EHCI_GENERIC=y -CONFIG_USB_STORAGE=y -CONFIG_FS_EXT4=y -CONFIG_FS_FAT=y -CONFIG_LZMA=y -CONFIG_LZO=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index 34066dd293..642755ec65 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -1,12 +1,15 @@ CONFIG_MIPS=y -CONFIG_SYS_TEXT_BASE=0x9c000000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ENV_OFFSET=0x80000 +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x20000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y CONFIG_ARCH_MTMIPS=y CONFIG_BOARD_LINKIT_SMART_7688=y -CONFIG_BOOT_ROM=y CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y @@ -16,6 +19,8 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_LICENSE=y # CONFIG_CMD_ELF is not set @@ -39,6 +44,7 @@ CONFIG_DEFAULT_DEVICE_TREE="linkit-smart-7688" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_BLK=y CONFIG_LED=y diff --git a/include/configs/gardena-smart-gateway-mt7688.h b/include/configs/gardena-smart-gateway-mt7688.h index 59c60743d2..6412efcbf8 100644 --- a/include/configs/gardena-smart-gateway-mt7688.h +++ b/include/configs/gardena-smart-gateway-mt7688.h @@ -16,10 +16,29 @@
#define CONFIG_SYS_INIT_SP_OFFSET 0x400000
-#ifdef CONFIG_BOOT_RAM +/* SPL */ +#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) #define CONFIG_SKIP_LOWLEVEL_INIT #endif
+#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SPL_BSS_START_ADDR 0x80010000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x10000 +#define CONFIG_SPL_MAX_SIZE 0x10000 +#define CONFIG_SPL_PAD_TO 0 + +/* Dummy value */ +#define CONFIG_SYS_UBOOT_BASE 0 + +/* Serial SPL */ +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL_SUPPORT) +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_NS16550_CLK 40000000 +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM1 0xb0000c00 +#define CONFIG_CONS_INDEX 1 +#endif + /* UART */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \ 230400, 460800, 921600 } diff --git a/include/configs/linkit-smart-7688.h b/include/configs/linkit-smart-7688.h index ca5b693e4c..4276e95dee 100644 --- a/include/configs/linkit-smart-7688.h +++ b/include/configs/linkit-smart-7688.h @@ -16,10 +16,30 @@
+#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SPL_BSS_START_ADDR 0x80010000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x10000 +#define CONFIG_SPL_MAX_SIZE 0x10000 +#define CONFIG_SPL_PAD_TO 0 + +/* Dummy value */ +#define CONFIG_SYS_UBOOT_BASE 0 + +/* Serial SPL */ +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_SERIAL_SUPPORT) +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_NS16550_CLK 40000000 +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM3 0xb0000e00 +#define CONFIG_CONS_INDEX 3 + +#endif + /* UART */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \ 230400, 460800, 921600 }
Weijie Gao
