[PATCH] test: cpu: Handle both 32bit and 64bit CPUs
Handle both 32bit and 64bit systems, i.e. sandbox and sandbox64 the same way drivers/cpu/cpu_sandbox.c does, that is in case CONFIG_PHYS_64BIT is enabled, assume 64bit address width, else assume 32bit address width. This fixes ut_dm_dm_test_cpu test failure on sandbox64.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Simon Glass sjg@chromium.org --- test/dm/cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/test/dm/cpu.c b/test/dm/cpu.c index d7e596ee396..5734cd0a92d 100644 --- a/test/dm/cpu.c +++ b/test/dm/cpu.c @@ -37,7 +37,7 @@ static int dm_test_cpu(struct unit_test_state *uts) ut_assertok(cpu_get_info(dev, &info)); ut_asserteq(info.cpu_freq, 42 * 42 * 42 * 42 * 42); ut_asserteq(info.features, 0x42424242); - ut_asserteq(info.address_width, 32); + ut_asserteq(info.address_width, IS_ENABLED(CONFIG_PHYS_64BIT) ? 64 : 32);
ut_asserteq(cpu_get_count(dev), 42);
On Sun, 13 Aug 2023 at 13:52, Marek Vasut marek.vasut+renesas@mailbox.org wrote:
Applied to u-boot-dm, thanks!
