[U-Boot] [PATCH v2] rk3288: Add Vyasa initial board support
This patch adds support for Vyasa RK3288 initial board from Amarula.
Boot from SDMMC: --------------- U-Boot SPL 2017.09-rc1-00111-g3656991-dirty (Aug 10 2017 - 11:40:45) Trying to boot from MMC1
U-Boot 2017.09-rc1-00111-g3656991-dirty (Aug 10 2017 - 11:40:45 +0530)
Model: Amarula Vyasa-RK3288 DRAM: 2 GiB MMC: dwmmc@ff0c0000: 1 *** Warning - bad CRC, using default environment
In: serial@ff690000 Out: serial@ff690000 Err: serial@ff690000 Model: Amarula Vyasa-RK3288 Net: Net Initialization Skipped No ethernet found. Hit any key to stop autoboot: 0 =>
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - Fix commit message - Move CONFIG_ENV_IS_IN_MMC to configs
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3288-vyasa.dts | 327 ++++++++++++++++++++++++++++++ arch/arm/mach-rockchip/rk3288/Kconfig | 11 + board/amarula/vyasa-rk3288/Kconfig | 12 ++ board/amarula/vyasa-rk3288/MAINTAINERS | 6 + board/amarula/vyasa-rk3288/Makefile | 7 + board/amarula/vyasa-rk3288/vyasa-rk3288.c | 7 + configs/vyasa-rk3288_defconfig | 63 ++++++ include/configs/vyasa-rk3288.h | 23 +++ 9 files changed, 457 insertions(+) create mode 100644 arch/arm/dts/rk3288-vyasa.dts create mode 100644 board/amarula/vyasa-rk3288/Kconfig create mode 100644 board/amarula/vyasa-rk3288/MAINTAINERS create mode 100644 board/amarula/vyasa-rk3288/Makefile create mode 100644 board/amarula/vyasa-rk3288/vyasa-rk3288.c create mode 100644 configs/vyasa-rk3288_defconfig create mode 100644 include/configs/vyasa-rk3288.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d07715f..371511b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -41,6 +41,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3288-veyron-jerry.dtb \ rk3288-veyron-mickey.dtb \ rk3288-veyron-minnie.dtb \ + rk3288-vyasa.dtb \ rk3328-evb.dtb \ rk3368-lion.dtb \ rk3368-sheep.dtb \ diff --git a/arch/arm/dts/rk3288-vyasa.dts b/arch/arm/dts/rk3288-vyasa.dts new file mode 100644 index 0000000..93a9c5e --- /dev/null +++ b/arch/arm/dts/rk3288-vyasa.dts @@ -0,0 +1,327 @@ +/* + * Copyright (C) 2017 Jagan Teki jagan@amarulasolutions.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "rk3288.dtsi" + +/ { + model = "Amarula Vyasa-RK3288"; + compatible = "amarula,vyasa-rk3288", "rockchip,rk3288"; + + chosen { + stdout-path = &uart2; + }; + + memory { + device_type = "memory"; + reg = <0 0x80000000>; + }; + + vcc_sd: sdmmc-regulator { + compatible = "regulator-fixed"; + gpio = <&gpio7 RK_PB3 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_pwr>; + regulator-name = "vcc_sd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + vin-supply = <&vcc_io>; + }; + + vcc_sys: vsys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; +}; + +&dmc { + rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa + 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 + 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 + 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 + 0x5 0x0>; + rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 + 0xa60 0x40 0x10 0x0>; + /* Add a dummy value to cause of-platdata think this is bytes */ + rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; +}; + +&cpu0 { + cpu0-supply = <&vdd_cpu>; +}; + +&i2c0 { + clock-frequency = <400000>; + status = "okay"; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA4 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int &global_pwroff>; + wakeup-source; + rockchip,system-power-controller; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk808-clkout2"; + + vcc1-supply = <&vcc_sys>; + vcc2-supply = <&vcc_sys>; + vcc3-supply = <&vcc_sys>; + vcc4-supply = <&vcc_sys>; + vcc6-supply = <&vcc_sys>; + vcc7-supply = <&vcc_sys>; + vcc8-supply = <&vcc_io>; + vcc9-supply = <&vcc_sys>; + vcc10-supply = <&vcc_sys>; + vcc11-supply = <&vcc_sys>; + vcc12-supply = <&vcc_io>; + + regulators { + vdd_cpu: vdd_log: DCDC_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-name = "vdd_log"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: DCDC_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <1250000>; + regulator-name = "vdd_gpu"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc_ddr"; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_io: DCDC_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc_io"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcca_tp: LDO_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc_tp"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_codec: LDO_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc_codec"; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_10: LDO_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-name = "vdd_10"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vcc_gps: LDO_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_gps"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vccio_sd: LDO_REG5 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vccio_sd"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc10_lcd: LDO_REG6 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-name = "vcc10_lcd"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_18: LDO_REG7 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_18"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc18_lcd: LDO_REG8 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc18_lcd"; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc33_sd: SWITCH_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc33_sd"; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_lan: SWITCH_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc_lan"; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + }; + }; +}; + +&sdmmc { + u-boot,dm-pre-reloc; + status = "okay"; + + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <200>; + disable-wp; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk>, <&sdmmc_cmd>, <&sdmmc_cd>, <&sdmmc_bus4>; + vmmc-supply = <&vcc_sd>; + vqmmc-supply = <&vccio_sd>; +}; + +&uart2 { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&wdt { + status = "okay"; +}; + +&pinctrl { + u-boot,dm-pre-reloc; + pmic { + pmic_int: pmic-int { + rockchip,pins = <RK_GPIO0 4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + sdmmc { + sdmmc_pwr: sdmmc-pwr { + rockchip,pins = <7 11 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; diff --git a/arch/arm/mach-rockchip/rk3288/Kconfig b/arch/arm/mach-rockchip/rk3288/Kconfig index 53cc9a0..4ad2940 100644 --- a/arch/arm/mach-rockchip/rk3288/Kconfig +++ b/arch/arm/mach-rockchip/rk3288/Kconfig @@ -84,6 +84,15 @@ config TARGET_POPMETAL_RK3288 2GB DDR3. Expansion connectors provide access to I2C, SPI, UART, GPIOs and display interface.
+config TARGET_VYASA_RK3288 + bool "Vyasa-RK3288" + select BOARD_LATE_INIT + help + Vyasa is a RK3288-based development board with 2 USB ports, + HDMI, VGA, micro-SD card, audio, WiFi and Gigabit Ethernet, It + also includes on-board eMMC and 2GB of SDRAM. Expansion connectors + provide access to display pins, I2C, SPI, UART and GPIOs. + config TARGET_ROCK2 bool "Radxa Rock 2" select BOARD_LATE_INIT @@ -129,6 +138,8 @@ config SPL_LIBGENERIC_SUPPORT config SPL_SERIAL_SUPPORT default y
+source "board/amarula/vyasa-rk3288/Kconfig" + source "board/chipspark/popmetal_rk3288/Kconfig"
source "board/firefly/firefly-rk3288/Kconfig" diff --git a/board/amarula/vyasa-rk3288/Kconfig b/board/amarula/vyasa-rk3288/Kconfig new file mode 100644 index 0000000..8b8c308 --- /dev/null +++ b/board/amarula/vyasa-rk3288/Kconfig @@ -0,0 +1,12 @@ +if TARGET_VYASA_RK3288 + +config SYS_BOARD + default "vyasa-rk3288" + +config SYS_VENDOR + default "amarula" + +config SYS_CONFIG_NAME + default "vyasa-rk3288" + +endif diff --git a/board/amarula/vyasa-rk3288/MAINTAINERS b/board/amarula/vyasa-rk3288/MAINTAINERS new file mode 100644 index 0000000..a75c1bf --- /dev/null +++ b/board/amarula/vyasa-rk3288/MAINTAINERS @@ -0,0 +1,6 @@ +RICO +M: Jagan Teki jagan@amarulasolutions.com +S: Maintained +F: board/amarula/vyasa-rk3288 +F: include/configs/vyasa-rk3288.h +F: configs/vyasa-rk3288_defconfig diff --git a/board/amarula/vyasa-rk3288/Makefile b/board/amarula/vyasa-rk3288/Makefile new file mode 100644 index 0000000..7c0d5c0 --- /dev/null +++ b/board/amarula/vyasa-rk3288/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2017 Amarula Solutions +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += vyasa-rk3288.o diff --git a/board/amarula/vyasa-rk3288/vyasa-rk3288.c b/board/amarula/vyasa-rk3288/vyasa-rk3288.c new file mode 100644 index 0000000..ceee42c --- /dev/null +++ b/board/amarula/vyasa-rk3288/vyasa-rk3288.c @@ -0,0 +1,7 @@ +/* + * Copyright (C) 2017 Amarula Solutions + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> diff --git a/configs/vyasa-rk3288_defconfig b/configs/vyasa-rk3288_defconfig new file mode 100644 index 0000000..7db7b0b --- /dev/null +++ b/configs/vyasa-rk3288_defconfig @@ -0,0 +1,63 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ROCKCHIP_RK3288=y +CONFIG_TARGET_VYASA_RK3288=y +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEFAULT_DEVICE_TREE="rk3288-vyasa" +CONFIG_DEBUG_UART=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SILENT_CONSOLE=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_I2C=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SPL_PARTITION_UUIDS=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +# CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +# CONFIG_SPL_PINCTRL_FULL is not set +CONFIG_PINCTRL_ROCKCHIP_RK3288=y +CONFIG_DM_PMIC=y +# CONFIG_SPL_PMIC_CHILDREN is not set +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_DEBUG_UART_BASE=0xff690000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550=y +CONFIG_SYSRESET=y +CONFIG_CONSOLE_SCROLL_LINES=10 +CONFIG_USE_TINY_PRINTF=y +CONFIG_CMD_DHRYSTONE=y +CONFIG_ERRNO_STR=y diff --git a/include/configs/vyasa-rk3288.h b/include/configs/vyasa-rk3288.h new file mode 100644 index 0000000..93ab7e7 --- /dev/null +++ b/include/configs/vyasa-rk3288.h @@ -0,0 +1,23 @@ +/* + * Copyright (C) 2017 Amarula Solutions + * + * Configuration settings for Amarula Vyasa RK3288. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define ROCKCHIP_DEVICE_SETTINGS +#include <configs/rk3288_common.h> + +#undef BOOT_TARGET_DEVICES + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 1) \ + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 1 + +#endif
Jagan Teki
