[PATCH v5 1/5] imx8m: USDHC3 base address definition for i.MX8MP
The i.MX8MP also has USDHC3, allow access to the relvant base address definition.
Signed-off-by: Martyn Welch martyn.welch@collabora.com ---
Changes in v2: - None
Changes in v3: - None
Changes in v4: - None
Changes in v5: - None
arch/arm/include/asm/arch-imx8m/imx-regs.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-imx8m/imx-regs.h b/arch/arm/include/asm/arch-imx8m/imx-regs.h index 29d5baaab8..c46d4f7e00 100644 --- a/arch/arm/include/asm/arch-imx8m/imx-regs.h +++ b/arch/arm/include/asm/arch-imx8m/imx-regs.h @@ -47,7 +47,7 @@ #define USDHC1_BASE_ADDR 0x30B40000 #define USDHC2_BASE_ADDR 0x30B50000 #define QSPI0_AMBA_BASE 0x08000000 -#ifdef CONFIG_IMX8MM +#if defined(CONFIG_IMX8MM) || defined(CONFIG_IMX8MP) #define USDHC3_BASE_ADDR 0x30B60000 #endif #define UART_BASE_ADDR(n) ( \
The i.MX8MP SoC contains 2 more i2c buses. Add support for the configuration of these buses.
arch/arm/include/asm/arch-imx8m/imx-regs.h | 4 ++++ arch/arm/mach-imx/i2c-mxv7.c | 6 ++++++ arch/arm/mach-imx/imx8m/clock_imx8mm.c | 12 +++++++++--- 3 files changed, 19 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/arch-imx8m/imx-regs.h b/arch/arm/include/asm/arch-imx8m/imx-regs.h index c46d4f7e00..6595d97f0a 100644 --- a/arch/arm/include/asm/arch-imx8m/imx-regs.h +++ b/arch/arm/include/asm/arch-imx8m/imx-regs.h @@ -44,6 +44,10 @@ #define I2C3_BASE_ADDR 0x30A40000 #define I2C4_BASE_ADDR 0x30A50000 #define UART4_BASE_ADDR 0x30A60000 +#ifdef CONFIG_IMX8MP +#define I2C5_BASE_ADDR 0x30AD0000 +#define I2C6_BASE_ADDR 0x30AE0000 +#endif #define USDHC1_BASE_ADDR 0x30B40000 #define USDHC2_BASE_ADDR 0x30B50000 #define QSPI0_AMBA_BASE 0x08000000 diff --git a/arch/arm/mach-imx/i2c-mxv7.c b/arch/arm/mach-imx/i2c-mxv7.c index 85d648b56e..a5866cf9f7 100644 --- a/arch/arm/mach-imx/i2c-mxv7.c +++ b/arch/arm/mach-imx/i2c-mxv7.c @@ -70,6 +70,12 @@ static void * const i2c_bases[] = { #ifdef I2C4_BASE_ADDR (void *)I2C4_BASE_ADDR, #endif +#ifdef I2C5_BASE_ADDR + (void *)I2C5_BASE_ADDR, +#endif +#ifdef I2C6_BASE_ADDR + (void *)I2C6_BASE_ADDR, +#endif };
/* i2c_index can be from 0 - 3 */ diff --git a/arch/arm/mach-imx/imx8m/clock_imx8mm.c b/arch/arm/mach-imx/imx8m/clock_imx8mm.c index 4db55f8608..64ad57e9b3 100644 --- a/arch/arm/mach-imx/imx8m/clock_imx8mm.c +++ b/arch/arm/mach-imx/imx8m/clock_imx8mm.c @@ -36,11 +36,17 @@ void enable_ocotp_clk(unsigned char enable)
int enable_i2c_clk(unsigned char enable, unsigned i2c_num) { - /* 0 - 3 is valid i2c num */ - if (i2c_num > 3) + u8 i2c_ccgr[6] = { + CCGR_I2C1, CCGR_I2C2, CCGR_I2C3, CCGR_I2C4, +#if (IS_ENABLED(CONFIG_IMX8MP)) + CCGR_I2C5_8MP, CCGR_I2C6_8MP +#endif + }; + + if (i2c_num > ARRAY_SIZE(i2c_ccgr)) return -EINVAL;
- clock_enable(CCGR_I2C1 + i2c_num, !!enable); + clock_enable(i2c_ccgr[i2c_num], !!enable);
return 0; }
Changes in v2:
- None
Changes in v3:
- None
Changes in v4:
- None
Changes in v5:
- None
- (void *)I2C5_BASE_ADDR,
- (void *)I2C6_BASE_ADDR,
+#endif };
- if (i2c_num > 3)
- u8 i2c_ccgr[6] = {
- if (i2c_num > ARRAY_SIZE(i2c_ccgr)) return -EINVAL;
return 0; }
With DM_CLK or SPL_DM_CLK enabled, this function is not needed anymore. Do you have DM_CLK and SPL_DM_CLK enabled?
Regards, Peng.
The i.MX8MP SoC contains 2 more i2c buses. Add support for the configuration of these buses. Signed-off-by: Martyn Welch martyn.welch@collabora.com
Best regards, Stefano Babic
Add support for the rn5t568 PMIC to the rn5t567 driver.
drivers/power/pmic/rn5t567.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/power/pmic/rn5t567.c b/drivers/power/pmic/rn5t567.c index d9a8298ebb..9d103dd840 100644 --- a/drivers/power/pmic/rn5t567.c +++ b/drivers/power/pmic/rn5t567.c @@ -53,6 +53,7 @@ static struct dm_pmic_ops rn5t567_ops = {
static const struct udevice_id rn5t567_ids[] = { { .compatible = "ricoh,rn5t567" }, + { .compatible = "ricoh,rn5t568" }, { } };
-----Original Message----- From: Martyn Welch [mailto:martyn.welch@collabora.com] Sent: Tuesday, October 25, 2022 6:55 PM To: uboot-imx@nxp.com; sbabic@denx.de; Jaehoon Chung jh80.chung@samsung.com Cc: Martyn Welch martyn.welch@collabora.com; u-boot@lists.denx.de Subject: [PATCH v5 3/5] drivers: power: pmic: Add support for rn5t568 PMIC
Reviewed-by: Jaehoon Chung j80.chung@samsung.com
Best Regards, Jaehoon Chung
Changes in v2:
- None
Changes in v3:
- None
Changes in v4:
- None
Changes in v5:
- None
- { .compatible = "ricoh,rn5t568" }, { }
-- 2.35.1
Add support for the rn5t568 PMIC to the rn5t567 driver. Signed-off-by: Martyn Welch martyn.welch@collabora.com Reviewed-by: Jaehoon Chung j80.chung@samsung.com
The support added later in this series tweaks the PMIC voltages in the SPL. Enable support for the rn5t567 in SPL builds to allow this to be done cleanly.
Signed-off-by: Martyn Welch martyn.welch@collabora.co.uk Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v3: - New patch (replaces addition of legacy support for rn5t567)
Changes in v5: - Rebase to current master branch
drivers/power/pmic/Kconfig | 8 ++++++++ drivers/power/pmic/Makefile | 2 +- 2 files changed, 9 insertions(+), 1 deletion(-)
diff --git a/drivers/power/pmic/Kconfig b/drivers/power/pmic/Kconfig index 0478f2aa1d..628d3a94bc 100644 --- a/drivers/power/pmic/Kconfig +++ b/drivers/power/pmic/Kconfig @@ -300,6 +300,14 @@ config PMIC_RN5T567 regulators Real-Time Clock and 4 GPIOs. This driver provides register access only.
+config SPL_PMIC_RN5T567 + bool "Enable driver for Ricoh RN5T567 PMIC in SPL" + depends on SPL_DM_PMIC + ---help--- + The RN5T567 is a PMIC with 4 step-down DC/DC converters, 5 LDO + regulators Real-Time Clock and 4 GPIOs. This driver provides + register access only. + config PMIC_TPS65090 bool "Enable driver for Texas Instruments TPS65090 PMIC" ---help--- diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index e1d3545490..58c6507c58 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -22,7 +22,7 @@ obj-$(CONFIG_$(SPL_)PMIC_AXP) += axp.o obj-$(CONFIG_PMIC_MAX8997) += max8997.o obj-$(CONFIG_PMIC_QCOM) += pmic_qcom.o obj-$(CONFIG_$(SPL_TPL_)PMIC_RK8XX) += rk8xx.o -obj-$(CONFIG_PMIC_RN5T567) += rn5t567.o +obj-$(CONFIG_$(SPL_)PMIC_RN5T567) += rn5t567.o obj-$(CONFIG_PMIC_TPS65090) += tps65090.o obj-$(CONFIG_PMIC_S5M8767) += s5m8767.o obj-$(CONFIG_DM_PMIC_TPS65910) += pmic_tps65910_dm.o
-----Original Message----- From: Martyn Welch [mailto:martyn.welch@collabora.com] Sent: Tuesday, October 25, 2022 6:55 PM To: uboot-imx@nxp.com; sbabic@denx.de; Jaehoon Chung jh80.chung@samsung.com Cc: Martyn Welch martyn.welch@collabora.co.uk; Simon Glass sjg@chromium.org; u- boot@lists.denx.de Subject: [PATCH v5 4/5] drivers: power: pmic: Enable use of rn5t567 PMIC in SPL
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Changes in v3:
Changes in v4:
- None
Changes in v5:
- bool "Enable driver for Ricoh RN5T567 PMIC in SPL"
- depends on SPL_DM_PMIC
- ---help---
- The RN5T567 is a PMIC with 4 step-down DC/DC converters, 5 LDO
- regulators Real-Time Clock and 4 GPIOs. This driver provides
- register access only.
config PMIC_TPS65090 bool "Enable driver for Texas Instruments TPS65090 PMIC" ---help--- diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index e1d3545490..58c6507c58 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -22,7 +22,7 @@ obj-$(CONFIG_$(SPL_)PMIC_AXP) += axp.o obj-$(CONFIG_PMIC_MAX8997) += max8997.o obj-$(CONFIG_PMIC_QCOM) += pmic_qcom.o obj-$(CONFIG_$(SPL_TPL_)PMIC_RK8XX) += rk8xx.o -obj-$(CONFIG_PMIC_RN5T567) += rn5t567.o +obj-$(CONFIG_$(SPL_)PMIC_RN5T567) += rn5t567.o obj-$(CONFIG_PMIC_TPS65090) += tps65090.o obj-$(CONFIG_PMIC_S5M8767) += s5m8767.o obj-$(CONFIG_DM_PMIC_TPS65910) += pmic_tps65910_dm.o -- 2.35.1
From: Martyn Welch martyn.welch@collabora.co.uk The support added later in this series tweaks the PMIC voltages in the SPL. Enable support for the rn5t567 in SPL builds to allow this to be done cleanly. Signed-off-by: Martyn Welch martyn.welch@collabora.co.uk Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Add support for the MSC SM2S-IMX8PLUS SMARC Module. Tested in conjunction with the MSC SM2-MB-EP1 Mini-ITX Carrier Board.
Changes in v2: - Renamed FDT to closer match kernel - Sync with kernel FDT - Update for changes made in U-Boot
Changes in v3: - Use imx8mp-u-boot.dtsi - Switch to use of DM PMIC support in SPL
Changes in v4: - Rebased to latest imx master branch
Changes in v5: - Rebased on latest master branch - Add MAINTAINERS entry - Migrate symbols to Kbuild config - Simplify header file
MAINTAINERS | 9 + arch/arm/dts/Makefile | 1 + arch/arm/dts/imx8mp-msc-sm2s-u-boot.dtsi | 65 + arch/arm/dts/imx8mp-msc-sm2s.dts | 820 ++++++++ arch/arm/mach-imx/imx8m/Kconfig | 8 + board/msc/sm2s_imx8mp/Kconfig | 15 + board/msc/sm2s_imx8mp/Makefile | 12 + board/msc/sm2s_imx8mp/imximage-8mp-lpddr4.cfg | 8 + board/msc/sm2s_imx8mp/lpddr4_timing.c | 1842 +++++++++++++++++ board/msc/sm2s_imx8mp/sm2s_imx8mp.c | 60 + board/msc/sm2s_imx8mp/spl.c | 273 +++ configs/msc_sm2s_imx8mp_defconfig | 105 + include/configs/msc_sm2s_imx8mp.h | 64 + 13 files changed, 3282 insertions(+) create mode 100644 arch/arm/dts/imx8mp-msc-sm2s-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mp-msc-sm2s.dts create mode 100644 board/msc/sm2s_imx8mp/Kconfig create mode 100644 board/msc/sm2s_imx8mp/Makefile create mode 100644 board/msc/sm2s_imx8mp/imximage-8mp-lpddr4.cfg create mode 100644 board/msc/sm2s_imx8mp/lpddr4_timing.c create mode 100644 board/msc/sm2s_imx8mp/sm2s_imx8mp.c create mode 100644 board/msc/sm2s_imx8mp/spl.c create mode 100644 configs/msc_sm2s_imx8mp_defconfig create mode 100644 include/configs/msc_sm2s_imx8mp.h
diff --git a/MAINTAINERS b/MAINTAINERS index cb4d44584d..256e464aff 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -398,6 +398,15 @@ F: drivers/timer/atmel_tcb_timer.c F: include/dt-bindings/mfd/atmel-flexcom.h F: drivers/timer/mchp-pit64b-timer.c
+ARM MSC SM2S IMX8MP SOM +M: Martyn Welch martyn.welch@collabora.com +M: Ian Ray ian.ray@ge.com +S: Maintained +F: arch/arm/dts/imx8mp-msc-sm2s* +F: board/msc/sm2s_imx8mp/ +F: configs/msc_sm2s_imx8mp_defconfig +F: include/configs/msc_sm2s_imx8mp.h + ARM NEXELL S5P4418 M: Stefan Bosch stefan_b@posteo.net S: Maintained diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 30e69b9f67..510b8afc02 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -976,6 +976,7 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mp-dhcom-pdk2.dtb \ imx8mp-evk.dtb \ imx8mp-icore-mx8mp-edimm2.2.dtb \ + imx8mp-msc-sm2s.dtb \ imx8mp-phyboard-pollux-rdk.dtb \ imx8mp-venice.dtb \ imx8mp-venice-gw74xx.dtb \ diff --git a/arch/arm/dts/imx8mp-msc-sm2s-u-boot.dtsi b/arch/arm/dts/imx8mp-msc-sm2s-u-boot.dtsi new file mode 100644 index 0000000000..cf591adf5a --- /dev/null +++ b/arch/arm/dts/imx8mp-msc-sm2s-u-boot.dtsi @@ -0,0 +1,65 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + */ + +#include "imx8mp-u-boot.dtsi" + +/ { + model = "MSC SM2S-IMX8MPLUS"; + compatible = "avnet,sm2s-imx8mp", "fsl,imx8mp"; + + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + u-boot,dm-spl; + }; +}; + +®_usdhc2_vmmc { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&i2c1 { + u-boot,dm-spl; +}; + +&i2c2 { + u-boot,dm-spl; +}; + +&i2c3 { + u-boot,dm-spl; +}; + +&i2c4 { + u-boot,dm-spl; +}; + +&i2c5 { + u-boot,dm-spl; +}; + +&i2c6 { + u-boot,dm-spl; +}; + +&pinctrl_i2c6 { + u-boot,dm-spl; +}; + +&pmic { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mp-msc-sm2s.dts b/arch/arm/dts/imx8mp-msc-sm2s.dts new file mode 100644 index 0000000000..5dbec71747 --- /dev/null +++ b/arch/arm/dts/imx8mp-msc-sm2s.dts @@ -0,0 +1,820 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Avnet Embedded GmbH + */ + +/dts-v1/; + +#include "imx8mp.dtsi" +#include <dt-bindings/net/ti-dp83867.h> + +/ { + aliases { + rtc0 = &sys_rtc; + rtc1 = &snvs_rtc; + }; + + chosen { + stdout-path = &uart2; + }; + + reg_usb0_host_vbus: regulator-usb0-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb0_host_vbus"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb0_vbus>; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio1 12 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_usb1_host_vbus: regulator-usb1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb1_host_vbus"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb1_vbus>; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio1 14 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_usdhc2_vmmc: regulator-usdhc2 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2_vmmc>; + regulator-name = "VSD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>; + enable-active-high; + startup-delay-us = <100>; + off-on-delay-us = <12000>; + }; + + reg_flexcan1_xceiver: regulator-flexcan1 { + compatible = "regulator-fixed"; + regulator-name = "flexcan1-xceiver"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + reg_flexcan2_xceiver: regulator-flexcan2 { + compatible = "regulator-fixed"; + regulator-name = "flexcan2-xceiver"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + lcd0_backlight: backlight-0 { + compatible = "pwm-backlight"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lcd0_backlight>; + pwms = <&pwm1 0 100000 0>; + brightness-levels = <0 255>; + num-interpolated-steps = <255>; + default-brightness-level = <255>; + enable-gpios = <&gpio1 5 GPIO_ACTIVE_HIGH>; + status = "disabled"; + }; + + lcd1_backlight: backlight-1 { + compatible = "pwm-backlight"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lcd1_backlight>; + pwms = <&pwm2 0 100000 0>; + brightness-levels = <0 255>; + num-interpolated-steps = <255>; + default-brightness-level = <255>; + enable-gpios = <&gpio1 6 GPIO_ACTIVE_HIGH>; + status = "disabled"; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_leds>; + status = "okay"; + + led-sw { + label = "sw-led"; + gpios = <&gpio1 8 GPIO_ACTIVE_HIGH>; + default-state = "off"; + linux,default-trigger = "heartbeat"; + }; + }; + + extcon_usb0: extcon-usb0 { + compatible = "linux,extcon-usb-gpio"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb0_extcon>; + id-gpio = <&gpio1 3 GPIO_ACTIVE_HIGH>; + }; +}; + +&A53_0 { + cpu-supply = <&vcc_arm>; +}; + +&A53_1 { + cpu-supply = <&vcc_arm>; +}; + +&A53_2 { + cpu-supply = <&vcc_arm>; +}; + +&A53_3 { + cpu-supply = <&vcc_arm>; +}; + +&ecspi1 { + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi1>; + cs-gpios = <0>, <&gpio2 8 GPIO_ACTIVE_LOW>; +}; + +&ecspi2 { + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi2>; + cs-gpios = <0>, <&gpio2 9 GPIO_ACTIVE_LOW>; +}; + +&eqos { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_eqos>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy0>; + status = "okay"; + + mdio { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + eee-broken-1000t; + reset-gpios = <&tca6424 16 GPIO_ACTIVE_LOW>; + reset-assert-us = <1000>; + reset-deassert-us = <1000>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_25_NS>; + ti,tx-internal-delay = <DP83867_RGMIIDCTL_2_25_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + ti,clk-output-sel = <DP83867_CLK_O_SEL_OFF>; + }; + }; +}; + +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy1>; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy1: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + eee-broken-1000t; + reset-gpios = <&tca6424 17 GPIO_ACTIVE_LOW>; + reset-assert-us = <1000>; + reset-deassert-us = <1000>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_25_NS>; + ti,tx-internal-delay = <DP83867_RGMIIDCTL_2_25_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + ti,clk-output-sel = <DP83867_CLK_O_SEL_OFF>; + }; + }; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + clock-frequency = <400000>; + status = "okay"; + + id_eeprom: eeprom@50 { + compatible = "atmel,24c64"; + reg = <0x50>; + pagesize = <32>; + }; +}; + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + clock-frequency = <400000>; + status = "disabled"; +}; + +&i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + clock-frequency = <400000>; + status = "disabled"; +}; + +&i2c4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + clock-frequency = <400000>; + status = "disabled"; +}; + +&i2c5 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c5>; + clock-frequency = <400000>; + status = "disabled"; +}; + +&i2c6 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c6>; + clock-frequency = <400000>; + status = "okay"; + + tca6424: gpio@22 { + compatible = "ti,tca6424"; + reg = <0x22>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_tca6424>; + gpio-controller; + #gpio-cells = <2>; + gpio-line-names = "BOOT_SEL0#", "BOOT_SEL1#", "BOOT_SEL2#", + "gbe0_int", "gbe1_int", "pmic_int", "rtc_int", "lvds_int", + "PCIE_WAKE#", "cam2_rst", "cam2_pwr", "SLEEP#", + "wifi_pd", "tpm_int", "wifi_int", "PCIE_A_RST#", + "gbe0_rst", "gbe1_rst", "LID#", "BATLOW#", "CHARGING#", + "CHARGER_PRSNT#"; + interrupt-parent = <&gpio1>; + interrupts = <9 IRQ_TYPE_EDGE_RISING>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + dsi_lvds_bridge: bridge@2d { + compatible = "ti,sn65dsi83"; + reg = <0x2d>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lvds_bridge>; + enable-gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>; + status = "disabled"; + }; + + pmic: pmic@30 { + compatible = "ricoh,rn5t567"; + reg = <0x30>; + interrupt-parent = <&tca6424>; + interrupts = <5 IRQ_TYPE_EDGE_FALLING>; + + regulators { + DCDC1 { + regulator-name = "VCC_SOC"; + regulator-always-on; + regulator-min-microvolt = <950000>; + regulator-max-microvolt = <950000>; + }; + + DCDC2 { + regulator-name = "VCC_DRAM"; + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + }; + + vcc_arm: DCDC3 { + regulator-name = "VCC_ARM"; + regulator-always-on; + regulator-min-microvolt = <950000>; + regulator-max-microvolt = <950000>; + }; + + DCDC4 { + regulator-name = "VCC_1V8"; + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + LDO1 { + regulator-name = "VCC_LDO1_2V5"; + regulator-always-on; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + }; + + LDO2 { + regulator-name = "VCC_LDO2_1V8"; + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + LDO3 { + regulator-name = "VCC_ETH_2V5"; + regulator-always-on; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + }; + + LDO4 { + regulator-name = "VCC_DDR4_2V5"; + regulator-always-on; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + }; + + LDO5 { + regulator-name = "VCC_LDO5_1V8"; + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + LDORTC1 { + regulator-name = "VCC_SNVS_1V8"; + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + LDORTC2 { + regulator-name = "VCC_SNVS_3V3"; + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + }; + }; + + sys_rtc: rtc@32 { + compatible = "ricoh,r2221tl"; + reg = <0x32>; + interrupt-parent = <&tca6424>; + interrupts = <6 IRQ_TYPE_EDGE_FALLING>; + }; + + tmp_sensor: temperature-sensor@71 { + compatible = "ti,tmp103"; + reg = <0x71>; + }; +}; + +&flexcan1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan1>; + xceiver-supply = <®_flexcan1_xceiver>; + status = "disabled"; +}; + +&flexcan2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan2>; + xceiver-supply = <®_flexcan2_xceiver>; + status = "disabled"; +}; + +&flexspi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexspi0>; + status = "okay"; + + qspi_flash: flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + #address-cells = <1>; + #size-cells = <1>; + spi-max-frequency = <80000000>; + spi-tx-bus-width = <4>; + spi-rx-bus-width = <4>; + }; +}; + +&pwm1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm1>; + status = "disabled"; +}; + +&pwm2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm2>; + status = "disabled"; +}; + +&pwm3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm3>; + status = "disabled"; +}; + +&pwm4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm4>; + status = "disabled"; +}; + +&snvs_pwrkey { + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + uart-has-rtscts; + status = "okay"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + uart-has-rtscts; + status = "okay"; +}; + +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart4>; + status = "disabled"; +}; + +&usb3_phy0 { + vbus-supply = <®_usb0_host_vbus>; + status = "okay"; +}; + +&usb3_phy1 { + vbus-supply = <®_usb1_host_vbus>; + status = "okay"; +}; + +&usb3_0 { + status = "okay"; +}; + +&usb3_1 { + status = "okay"; +}; + +&usb_dwc3_0 { + dr_mode = "otg"; + hnp-disable; + srp-disable; + adp-disable; + extcon = <&extcon_usb0>; + status = "okay"; +}; + +&usb_dwc3_1 { + dr_mode = "host"; + status = "okay"; +}; + +&usdhc2 { + assigned-clocks = <&clk IMX8MP_CLK_USDHC2>; + assigned-clock-rates = <400000000>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; + cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio2 20 GPIO_ACTIVE_HIGH>; + bus-width = <4>; + vmmc-supply = <®_usdhc2_vmmc>; + status = "okay"; +}; + +&usdhc3 { + assigned-clocks = <&clk IMX8MP_CLK_USDHC3>; + assigned-clock-rates = <400000000>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl_ecspi1: ecspi1grp { + fsl,pins = + <MX8MP_IOMUXC_ECSPI1_MISO__ECSPI1_MISO 0x82>, + <MX8MP_IOMUXC_ECSPI1_MOSI__ECSPI1_MOSI 0x82>, + <MX8MP_IOMUXC_ECSPI1_SCLK__ECSPI1_SCLK 0x82>, + <MX8MP_IOMUXC_ECSPI1_SS0__ECSPI1_SS0 0x40000>, + <MX8MP_IOMUXC_SD1_DATA6__GPIO2_IO08 0x40000>; + }; + + pinctrl_ecspi2: ecspi2grp { + fsl,pins = + <MX8MP_IOMUXC_ECSPI2_MISO__ECSPI2_MISO 0x82>, + <MX8MP_IOMUXC_ECSPI2_MOSI__ECSPI2_MOSI 0x82>, + <MX8MP_IOMUXC_ECSPI2_SCLK__ECSPI2_SCLK 0x82>, + <MX8MP_IOMUXC_ECSPI2_SS0__ECSPI2_SS0 0x40000>, + <MX8MP_IOMUXC_SD1_DATA7__GPIO2_IO09 0x40000>; + }; + + pinctrl_eqos: eqosgrp { + fsl,pins = + <MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC 0x3>, + <MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO 0x3>, + <MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0 0x91>, + <MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1 0x91>, + <MX8MP_IOMUXC_ENET_RD2__ENET_QOS_RGMII_RD2 0x91>, + <MX8MP_IOMUXC_ENET_RD3__ENET_QOS_RGMII_RD3 0x91>, + <MX8MP_IOMUXC_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x91>, + <MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x91>, + <MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0 0x1f>, + <MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1 0x1f>, + <MX8MP_IOMUXC_ENET_TD2__ENET_QOS_RGMII_TD2 0x1f>, + <MX8MP_IOMUXC_ENET_TD3__ENET_QOS_RGMII_TD3 0x1f>, + <MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x1f>, + <MX8MP_IOMUXC_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x1f>; + }; + + pinctrl_fec: fecgrp { + fsl,pins = + <MX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC 0x3>, + <MX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO 0x3>, + <MX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0 0x91>, + <MX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1 0x91>, + <MX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2 0x91>, + <MX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3 0x91>, + <MX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC 0x91>, + <MX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL 0x91>, + <MX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0 0x1f>, + <MX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1 0x1f>, + <MX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2 0x1f>, + <MX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3 0x1f>, + <MX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL 0x1f>, + <MX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC 0x1f>; + }; + + pinctrl_flexcan1: flexcan1grp { + fsl,pins = + <MX8MP_IOMUXC_SAI5_RXD1__CAN1_TX 0x154>, + <MX8MP_IOMUXC_SAI5_RXD2__CAN1_RX 0x154>; + }; + + pinctrl_flexcan2: flexcan2grp { + fsl,pins = + <MX8MP_IOMUXC_SAI5_MCLK__CAN2_RX 0x154>, + <MX8MP_IOMUXC_SAI5_RXD3__CAN2_TX 0x154>; + }; + + pinctrl_flexspi0: flexspi0grp { + fsl,pins = + <MX8MP_IOMUXC_NAND_ALE__FLEXSPI_A_SCLK 0x1c2>, + <MX8MP_IOMUXC_NAND_CE0_B__FLEXSPI_A_SS0_B 0x82>, + <MX8MP_IOMUXC_NAND_DATA00__FLEXSPI_A_DATA00 0x82>, + <MX8MP_IOMUXC_NAND_DATA01__FLEXSPI_A_DATA01 0x82>, + <MX8MP_IOMUXC_NAND_DATA02__FLEXSPI_A_DATA02 0x82>, + <MX8MP_IOMUXC_NAND_DATA03__FLEXSPI_A_DATA03 0x82>, + <MX8MP_IOMUXC_NAND_DQS__GPIO3_IO14 0x19>; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = + <MX8MP_IOMUXC_I2C1_SCL__I2C1_SCL 0x400001c3>, + <MX8MP_IOMUXC_I2C1_SDA__I2C1_SDA 0x400001c3>; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = + <MX8MP_IOMUXC_I2C2_SCL__I2C2_SCL 0x400001c3>, + <MX8MP_IOMUXC_I2C2_SDA__I2C2_SDA 0x400001c3>; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = + <MX8MP_IOMUXC_I2C3_SCL__I2C3_SCL 0x400001c3>, + <MX8MP_IOMUXC_I2C3_SDA__I2C3_SDA 0x400001c3>; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = + <MX8MP_IOMUXC_I2C4_SCL__I2C4_SCL 0x400001c3>, + <MX8MP_IOMUXC_I2C4_SDA__I2C4_SDA 0x400001c3>; + }; + + pinctrl_i2c5: i2c5grp { + fsl,pins = + <MX8MP_IOMUXC_SPDIF_TX__I2C5_SCL 0x400001c3>, + <MX8MP_IOMUXC_SPDIF_RX__I2C5_SDA 0x400001c3>; + }; + + pinctrl_i2c6: i2c6grp { + fsl,pins = + <MX8MP_IOMUXC_SAI5_RXFS__I2C6_SCL 0x400001c3>, + <MX8MP_IOMUXC_SAI5_RXC__I2C6_SDA 0x400001c3>; + }; + + pinctrl_lcd0_backlight: lcd0-backlightgrp { + fsl,pins = + <MX8MP_IOMUXC_GPIO1_IO05__GPIO1_IO05 0x41>; + }; + + pinctrl_lcd1_backlight: lcd1-backlightgrp { + fsl,pins = + <MX8MP_IOMUXC_GPIO1_IO06__GPIO1_IO06 0x41>; + }; + + pinctrl_leds: ledsgrp { + fsl,pins = + <MX8MP_IOMUXC_GPIO1_IO08__GPIO1_IO08 0x19>; + }; + + pinctrl_lvds_bridge: lvds-bridgegrp { + fsl,pins = + <MX8MP_IOMUXC_GPIO1_IO07__GPIO1_IO07 0x41>; + }; + + pinctrl_pwm1: pwm1grp { + fsl,pins = + <MX8MP_IOMUXC_SPDIF_EXT_CLK__PWM1_OUT 0x116>; + }; + + pinctrl_pwm2: pwm2grp { + fsl,pins = + <MX8MP_IOMUXC_SAI5_RXD0__PWM2_OUT 0x116>; + }; + + pinctrl_pwm3: pwm3grp { + fsl,pins = + <MX8MP_IOMUXC_GPIO1_IO10__PWM3_OUT 0x116>; + }; + + pinctrl_pwm4: pwm4grp { + fsl,pins = + <MX8MP_IOMUXC_SAI3_MCLK__PWM4_OUT 0x116>; + }; + + pinctrl_tca6424: tca6424grp { + fsl,pins = + <MX8MP_IOMUXC_GPIO1_IO09__GPIO1_IO09 0x41>; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = + <MX8MP_IOMUXC_UART1_RXD__UART1_DCE_RX 0x49>, + <MX8MP_IOMUXC_UART1_TXD__UART1_DCE_TX 0x49>; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = + <MX8MP_IOMUXC_SD1_DATA4__GPIO2_IO06 0x1c4>, + <MX8MP_IOMUXC_SD1_DATA5__GPIO2_IO07 0x1c4>, + <MX8MP_IOMUXC_UART2_RXD__UART2_DCE_RX 0x49>, + <MX8MP_IOMUXC_UART2_TXD__UART2_DCE_TX 0x49>; + }; + + pinctrl_uart3: uart3grp { + fsl,pins = + <MX8MP_IOMUXC_SD1_RESET_B__GPIO2_IO10 0x1c4>, + <MX8MP_IOMUXC_SD1_STROBE__GPIO2_IO11 0x1c4>, + <MX8MP_IOMUXC_UART3_RXD__UART3_DCE_RX 0x49>, + <MX8MP_IOMUXC_UART3_TXD__UART3_DCE_TX 0x49>; + }; + + pinctrl_uart4: uart4grp { + fsl,pins = + <MX8MP_IOMUXC_UART4_RXD__UART4_DCE_RX 0x49>, + <MX8MP_IOMUXC_UART4_TXD__UART4_DCE_TX 0x49>; + }; + + pinctrl_usb0_extcon: usb0-extcongrp { + fsl,pins = + <MX8MP_IOMUXC_GPIO1_IO03__GPIO1_IO03 0x19>; + }; + + pinctrl_usb0_vbus: usb0-vbusgrp { + fsl,pins = + <MX8MP_IOMUXC_GPIO1_IO12__GPIO1_IO12 0x19>; + }; + + pinctrl_usb1_vbus: usb1-vbusgrp { + fsl,pins = + <MX8MP_IOMUXC_GPIO1_IO14__GPIO1_IO14 0x19>; + }; + + pinctrl_usdhc2_gpio: usdhc2-gpiogrp { + fsl,pins = + <MX8MP_IOMUXC_SD2_CD_B__GPIO2_IO12 0x1c4>, + <MX8MP_IOMUXC_SD2_WP__GPIO2_IO20 0x1c4>; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = + <MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x190>, + <MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d0>, + <MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d0>, + <MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d0>, + <MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d0>, + <MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d0>, + <MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1>; + }; + + pinctrl_usdhc2_vmmc: usdhc2-vmmcgrp { + fsl,pins = + <MX8MP_IOMUXC_SD2_RESET_B__GPIO2_IO19 0x41>; + }; + + pinctrl_usdhc2_100mhz: usdhc2-100mhzgrp { + fsl,pins = + <MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x194>, + <MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d4>, + <MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d4>, + <MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d4>, + <MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d4>, + <MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d4>, + <MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1>; + }; + + pinctrl_usdhc2_200mhz: usdhc2-200mhzgrp { + fsl,pins = + <MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x196>, + <MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d6>, + <MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d6>, + <MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d6>, + <MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d6>, + <MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d6>, + <MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1>; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = + <MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x190>, + <MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d0>, + <MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d0>, + <MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d0>, + <MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d0>, + <MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d0>, + <MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d0>, + <MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d0>, + <MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d0>, + <MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d0>, + <MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x190>; + }; + + pinctrl_usdhc3_100mhz: usdhc3-100mhzgrp { + fsl,pins = + <MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x194>, + <MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d4>, + <MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d4>, + <MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d4>, + <MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d4>, + <MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d4>, + <MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d4>, + <MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d4>, + <MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d4>, + <MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d4>, + <MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x194>; + }; + + pinctrl_usdhc3_200mhz: usdhc3-200mhzgrp { + fsl,pins = + <MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x196>, + <MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d6>, + <MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d6>, + <MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d6>, + <MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d6>, + <MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d6>, + <MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d6>, + <MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d6>, + <MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d6>, + <MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d6>, + <MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x196>; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = + <MX8MP_IOMUXC_GPIO1_IO02__WDOG1_WDOG_B 0xc6>; + }; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 8cd7c7a8dd..eccee6b213 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -284,6 +284,13 @@ config TARGET_IMX8MP_RSB3720A1_6G select SUPPORT_SPL select IMX8M_LPDDR4
+config TARGET_MSC_SM2S_IMX8MP + bool "MSC SMARC2 i.MX8MPLUS" + select BINMAN + select IMX8MP + select SUPPORT_SPL + select IMX8M_LPDDR4 + config TARGET_LIBREM5 bool "Purism Librem5 Phone" select BINMAN @@ -311,6 +318,7 @@ source "board/google/imx8mq_phanbell/Kconfig" source "board/kontron/pitx_imx8m/Kconfig" source "board/kontron/sl-mx8mm/Kconfig" source "board/menlo/mx8menlo/Kconfig" +source "board/msc/sm2s_imx8mp/Kconfig" source "board/phytec/phycore_imx8mm/Kconfig" source "board/phytec/phycore_imx8mp/Kconfig" source "board/purism/librem5/Kconfig" diff --git a/board/msc/sm2s_imx8mp/Kconfig b/board/msc/sm2s_imx8mp/Kconfig new file mode 100644 index 0000000000..f71a5b2bcd --- /dev/null +++ b/board/msc/sm2s_imx8mp/Kconfig @@ -0,0 +1,15 @@ +if TARGET_MSC_SM2S_IMX8MP + +config SYS_BOARD + default "sm2s_imx8mp" + +config SYS_VENDOR + default "msc" + +config SYS_CONFIG_NAME + default "msc_sm2s_imx8mp" + +config IMX_CONFIG + default "board/msc/sm2s_imx8mp/imximage-8mp-lpddr4.cfg" + +endif diff --git a/board/msc/sm2s_imx8mp/Makefile b/board/msc/sm2s_imx8mp/Makefile new file mode 100644 index 0000000000..f60dd7260c --- /dev/null +++ b/board/msc/sm2s_imx8mp/Makefile @@ -0,0 +1,12 @@ +# +# Copyright (C) 2021 AVNET Embedded, MSC Technologies GmbH +# +# SPDX-License-Identifier: GPL-2.0 +# + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o lpddr4_timing.o +else +obj-y += sm2s_imx8mp.o +endif + diff --git a/board/msc/sm2s_imx8mp/imximage-8mp-lpddr4.cfg b/board/msc/sm2s_imx8mp/imximage-8mp-lpddr4.cfg new file mode 100644 index 0000000000..8aadedb102 --- /dev/null +++ b/board/msc/sm2s_imx8mp/imximage-8mp-lpddr4.cfg @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 NXP + */ + +ROM_VERSION v2 +BOOT_FROM sd +LOADER u-boot-spl-ddr.bin 0x920000 diff --git a/board/msc/sm2s_imx8mp/lpddr4_timing.c b/board/msc/sm2s_imx8mp/lpddr4_timing.c new file mode 100644 index 0000000000..e0d659af91 --- /dev/null +++ b/board/msc/sm2s_imx8mp/lpddr4_timing.c @@ -0,0 +1,1842 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x1 }, + { 0x3d400000, 0xa1080020 }, + { 0x3d400020, 0x1223 }, + { 0x3d400024, 0x16e3600 }, + { 0x3d400064, 0x5b00d2 }, + { 0x3d400070, 0x61027f10 }, + { 0x3d400074, 0x7b0 }, + { 0x3d4000d0, 0xc00305ba }, + { 0x3d4000d4, 0x940000 }, + { 0x3d4000dc, 0xd4002d }, + { 0x3d4000e0, 0x330000 }, + { 0x3d4000e8, 0x660048 }, + { 0x3d4000ec, 0x160048 }, + { 0x3d400100, 0x191e1920 }, + { 0x3d400104, 0x60630 }, + { 0x3d40010c, 0xb0b000 }, + { 0x3d400110, 0xe04080e }, + { 0x3d400114, 0x2040c0c }, + { 0x3d400118, 0x1010007 }, + { 0x3d40011c, 0x401 }, + { 0x3d400130, 0x20600 }, + { 0x3d400134, 0xc100002 }, + { 0x3d400138, 0xd8 }, + { 0x3d400144, 0x96004b }, + { 0x3d400180, 0x2ee0017 }, + { 0x3d400184, 0x2605b8e }, + { 0x3d400188, 0x0 }, + { 0x3d400190, 0x497820a }, + { 0x3d400194, 0x80303 }, + { 0x3d4001b4, 0x170a }, + { 0x3d4001a0, 0xe0400018 }, + { 0x3d4001a4, 0xdf00e4 }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001c0, 0x1 }, + { 0x3d4001c4, 0x1 }, + { 0x3d4000f4, 0xc99 }, + { 0x3d400108, 0x70e1617 }, + { 0x3d400200, 0x1f }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0x7070707 }, + { 0x3d40021c, 0xf0f }, + { 0x3d400250, 0x1705 }, + { 0x3d400254, 0x2c }, + { 0x3d40025c, 0x4000030 }, + { 0x3d400264, 0x900093e7 }, + { 0x3d40026c, 0x2005574 }, + { 0x3d400400, 0x111 }, + { 0x3d400404, 0x72ff }, + { 0x3d400408, 0x72ff }, + { 0x3d400494, 0x2100e07 }, + { 0x3d400498, 0x620096 }, + { 0x3d40049c, 0x1100e07 }, + { 0x3d4004a0, 0xc8012c }, + { 0x3d402020, 0x1021 }, + { 0x3d402024, 0x30d400 }, + { 0x3d402050, 0x20d000 }, + { 0x3d402064, 0xc001c }, + { 0x3d4020dc, 0x840000 }, + { 0x3d4020e0, 0x330000 }, + { 0x3d4020e8, 0x660048 }, + { 0x3d4020ec, 0x160048 }, + { 0x3d402100, 0xa040305 }, + { 0x3d402104, 0x30407 }, + { 0x3d402108, 0x203060b }, + { 0x3d40210c, 0x505000 }, + { 0x3d402110, 0x2040202 }, + { 0x3d402114, 0x2030202 }, + { 0x3d402118, 0x1010004 }, + { 0x3d40211c, 0x301 }, + { 0x3d402130, 0x20300 }, + { 0x3d402134, 0xa100002 }, + { 0x3d402138, 0x1d }, + { 0x3d402144, 0x14000a }, + { 0x3d402180, 0x640004 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x80303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d4020f4, 0xc99 }, + { 0x3d403020, 0x1021 }, + { 0x3d403024, 0xc3500 }, + { 0x3d403050, 0x20d000 }, + { 0x3d403064, 0x30007 }, + { 0x3d4030dc, 0x840000 }, + { 0x3d4030e0, 0x330000 }, + { 0x3d4030e8, 0x660048 }, + { 0x3d4030ec, 0x160048 }, + { 0x3d403100, 0xa010102 }, + { 0x3d403104, 0x30404 }, + { 0x3d403108, 0x203060b }, + { 0x3d40310c, 0x505000 }, + { 0x3d403110, 0x2040202 }, + { 0x3d403114, 0x2030202 }, + { 0x3d403118, 0x1010004 }, + { 0x3d40311c, 0x301 }, + { 0x3d403130, 0x20300 }, + { 0x3d403134, 0xa100002 }, + { 0x3d403138, 0x8 }, + { 0x3d403144, 0x50003 }, + { 0x3d403180, 0x190004 }, + { 0x3d403190, 0x3818200 }, + { 0x3d403194, 0x80303 }, + { 0x3d4031b4, 0x100 }, + { 0x3d4030f4, 0xc99 }, + { 0x3d400028, 0x0 }, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x0 }, + { 0x100a1, 0x1 }, + { 0x100a2, 0x2 }, + { 0x100a3, 0x3 }, + { 0x100a4, 0x4 }, + { 0x100a5, 0x5 }, + { 0x100a6, 0x6 }, + { 0x100a7, 0x7 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x1 }, + { 0x110a2, 0x3 }, + { 0x110a3, 0x4 }, + { 0x110a4, 0x5 }, + { 0x110a5, 0x2 }, + { 0x110a6, 0x7 }, + { 0x110a7, 0x6 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x1 }, + { 0x120a2, 0x3 }, + { 0x120a3, 0x2 }, + { 0x120a4, 0x5 }, + { 0x120a5, 0x4 }, + { 0x120a6, 0x7 }, + { 0x120a7, 0x6 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x1 }, + { 0x130a2, 0x2 }, + { 0x130a3, 0x3 }, + { 0x130a4, 0x4 }, + { 0x130a5, 0x5 }, + { 0x130a6, 0x6 }, + { 0x130a7, 0x7 }, + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x20024, 0x1e3 }, + { 0x2003a, 0x2 }, + { 0x120024, 0x1e3 }, + { 0x2003a, 0x2 }, + { 0x220024, 0x1e3 }, + { 0x2003a, 0x2 }, + { 0x20056, 0x3 }, + { 0x120056, 0x3 }, + { 0x220056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + { 0x10049, 0xeba }, + { 0x10149, 0xeba }, + { 0x11049, 0xeba }, + { 0x11149, 0xeba }, + { 0x12049, 0xeba }, + { 0x12149, 0xeba }, + { 0x13049, 0xeba }, + { 0x13149, 0xeba }, + { 0x110049, 0xeba }, + { 0x110149, 0xeba }, + { 0x111049, 0xeba }, + { 0x111149, 0xeba }, + { 0x112049, 0xeba }, + { 0x112149, 0xeba }, + { 0x113049, 0xeba }, + { 0x113149, 0xeba }, + { 0x210049, 0xeba }, + { 0x210149, 0xeba }, + { 0x211049, 0xeba }, + { 0x211149, 0xeba }, + { 0x212049, 0xeba }, + { 0x212149, 0xeba }, + { 0x213049, 0xeba }, + { 0x213149, 0xeba }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x2ee }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0x104 }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0x104 }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0x104 }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + { 0x2007d, 0x212 }, + { 0x12007d, 0x212 }, + { 0x22007d, 0x212 }, + { 0x2007c, 0x61 }, + { 0x12007c, 0x61 }, + { 0x22007c, 0x61 }, + { 0x1004a, 0x500 }, + { 0x1104a, 0x500 }, + { 0x1204a, 0x500 }, + { 0x1304a, 0x500 }, + { 0x2002c, 0x0 }, +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xbb8 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x131f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4866 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4866 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x332d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x332d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4866 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4866 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3300 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3300 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4866 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4866 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3300 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3300 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xbb8 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x61 }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x1f7f }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4866 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4866 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x332d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x332d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xb }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x633 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x633 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x633 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x633 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x633 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x633 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x633 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x633 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x633 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x633 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x633 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x633 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x633 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xb }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x1 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x625 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x625 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a4, 0x0 }, + { 0x900a5, 0x790 }, + { 0x900a6, 0x11a }, + { 0x900a7, 0x8 }, + { 0x900a8, 0x7aa }, + { 0x900a9, 0x2a }, + { 0x900aa, 0x10 }, + { 0x900ab, 0x7b2 }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x0 }, + { 0x900ae, 0x7c8 }, + { 0x900af, 0x109 }, + { 0x900b0, 0x10 }, + { 0x900b1, 0x10 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x1 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xd }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x8 }, + { 0x90159, 0xe8 }, + { 0x9015a, 0x109 }, + { 0x9015b, 0x0 }, + { 0x9015c, 0x8140 }, + { 0x9015d, 0x10c }, + { 0x9015e, 0x10 }, + { 0x9015f, 0x8138 }, + { 0x90160, 0x104 }, + { 0x90161, 0x8 }, + { 0x90162, 0x448 }, + { 0x90163, 0x109 }, + { 0x90164, 0xf }, + { 0x90165, 0x7c0 }, + { 0x90166, 0x109 }, + { 0x90167, 0x0 }, + { 0x90168, 0xe8 }, + { 0x90169, 0x109 }, + { 0x9016a, 0x47 }, + { 0x9016b, 0x630 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0x8 }, + { 0x9016e, 0x618 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x8 }, + { 0x90171, 0xe0 }, + { 0x90172, 0x109 }, + { 0x90173, 0x0 }, + { 0x90174, 0x7c8 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0x8140 }, + { 0x90178, 0x10c }, + { 0x90179, 0x0 }, + { 0x9017a, 0x478 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x0 }, + { 0x9017d, 0x1 }, + { 0x9017e, 0x8 }, + { 0x9017f, 0x8 }, + { 0x90180, 0x4 }, + { 0x90181, 0x0 }, + { 0x90006, 0x8 }, + { 0x90007, 0x7c8 }, + { 0x90008, 0x109 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x400 }, + { 0x9000b, 0x106 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x29 }, + { 0x90026, 0x68 }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x200be, 0x3 }, + { 0x2000b, 0x34b }, + { 0x2000c, 0xbb }, + { 0x2000d, 0x753 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0x70 }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x1c }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x2060 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x20089, 0x1 }, + { 0x20088, 0x19 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 } +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3000mts 1D */ + .drate = 3000, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3000mts 2D */ + .drate = 3000, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3000, 400, 100, }, +}; diff --git a/board/msc/sm2s_imx8mp/sm2s_imx8mp.c b/board/msc/sm2s_imx8mp/sm2s_imx8mp.c new file mode 100644 index 0000000000..3913c4f242 --- /dev/null +++ b/board/msc/sm2s_imx8mp/sm2s_imx8mp.c @@ -0,0 +1,60 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Based on vendor support provided by AVNET Embedded + * + * Copyright (C) 2021 AVNET Embedded, MSC Technologies GmbH + * Copyright 2021 General Electric Company + * Copyright 2021 Collabora Ltd. + */ + +#include <common.h> +#include <errno.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx8mp_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm-generic/gpio.h> +#include <linux/delay.h> + +DECLARE_GLOBAL_DATA_PTR; + +static void setup_fec(void) +{ + struct iomuxc_gpr_base_regs *gpr = + (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; + + /* Enable RGMII TX clk output */ + setbits_le32(&gpr->gpr[1], BIT(22)); +} + +static int setup_eqos(void) +{ + struct iomuxc_gpr_base_regs *gpr = + (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; + + /* set INTF as RGMII, enable RGMII TXC clock */ + clrsetbits_le32(&gpr->gpr[1], + IOMUXC_GPR_GPR1_GPR_ENET_QOS_INTF_SEL_MASK, BIT(16)); + setbits_le32(&gpr->gpr[1], BIT(19) | BIT(21)); + + return set_clk_eqos(ENET_125MHZ); +} + +int board_phy_config(struct phy_device *phydev) +{ + if (phydev->drv->config) + phydev->drv->config(phydev); + return 0; +} + +int board_init(void) +{ + setup_fec(); + + setup_eqos(); + + return 0; +} diff --git a/board/msc/sm2s_imx8mp/spl.c b/board/msc/sm2s_imx8mp/spl.c new file mode 100644 index 0000000000..d20c9c52c9 --- /dev/null +++ b/board/msc/sm2s_imx8mp/spl.c @@ -0,0 +1,273 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Based on vendor support provided by AVNET Embedded + * + * Copyright (C) 2021 AVNET Embedded, MSC Technologies GmbH + * Copyright 2021 General Electric Company + * Copyright 2021 Collabora Ltd. + */ + +#include <common.h> +#include <cpu_func.h> +#include <fsl_esdhc_imx.h> +#include <hang.h> +#include <i2c.h> +#include <image.h> +#include <init.h> +#include <log.h> +#include <mmc.h> +#include <spl.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/ddr.h> +#include <asm/arch/imx8mp_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <dm/uclass.h> +#include <dm/device.h> +#include <linux/delay.h> +#include <power/pmic.h> +#include <power/rn5t567_pmic.h> + +DECLARE_GLOBAL_DATA_PTR; + +int spl_board_boot_device(enum boot_device boot_dev_spl) +{ + return BOOT_DEVICE_BOOTROM; +} + +void spl_dram_init(void) +{ + ddr_init(&dram_timing); +} + +void spl_board_init(void) +{ + /* + * Set GIC clock to 500Mhz for OD VDD_SOC. Kernel driver does + * not allow to change it. Should set the clock after PMIC + * setting done. Default is 400Mhz (system_pll1_800m with div = 2) + * set by ROM for ND VDD_SOC + */ + clock_enable(CCGR_GIC, 0); + clock_set_target_val(GIC_CLK_ROOT, CLK_ROOT_ON | CLK_ROOT_SOURCE_SEL(5)); + clock_enable(CCGR_GIC, 1); + + puts("Normal Boot\n"); +} + +#define USDHC_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE \ + | PAD_CTL_PE | PAD_CTL_FSEL2) +#define USDHC_GPIO_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_DSE1) +#define USDHC_CD_PAD_CTRL (PAD_CTL_PE | PAD_CTL_PUE | PAD_CTL_HYS \ + | PAD_CTL_DSE4) + +static const iomux_v3_cfg_t usdhc2_pads[] = { + MX8MP_PAD_SD2_CLK__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_SD2_CMD__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_SD2_DATA0__USDHC2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_SD2_DATA1__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_SD2_DATA2__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_SD2_DATA3__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_SD2_RESET_B__GPIO2_IO19 | MUX_PAD_CTRL(USDHC_GPIO_PAD_CTRL), + MX8MP_PAD_SD2_WP__GPIO2_IO20 | MUX_PAD_CTRL(USDHC_GPIO_PAD_CTRL), + MX8MP_PAD_SD2_CD_B__GPIO2_IO12 | MUX_PAD_CTRL(USDHC_CD_PAD_CTRL), +}; + +#define USDHC2_CD_GPIO IMX_GPIO_NR(2, 12) +#define USDHC2_RESET_GPIO IMX_GPIO_NR(2, 19) + +static const iomux_v3_cfg_t usdhc3_pads[] = { + MX8MP_PAD_NAND_WE_B__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_WP_B__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_DATA04__USDHC3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_DATA05__USDHC3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_DATA06__USDHC3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_DATA07__USDHC3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_RE_B__USDHC3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_CE2_B__USDHC3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_CE3_B__USDHC3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_CLE__USDHC3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_READY_B__USDHC3_RESET_B | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX8MP_PAD_NAND_CE1_B__USDHC3_STROBE | MUX_PAD_CTRL(USDHC_PAD_CTRL), + +}; + +static struct fsl_esdhc_cfg usdhc_cfg[] = { + { USDHC2_BASE_ADDR, 0, 4 }, + { USDHC3_BASE_ADDR, 0, 8 }, +}; + +int board_mmc_init(struct bd_info *bis) +{ + int i, ret; + /* + * According to the board_mmc_init() the following map is done: + * (U-Boot device node) (Physical Port) + * mmc0 (sd) USDHC2 + * mmc1 (emmc) USDHC3 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + init_clk_usdhc(1); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + imx_iomux_v3_setup_multiple_pads(usdhc2_pads, + ARRAY_SIZE(usdhc2_pads)); + gpio_request(USDHC2_RESET_GPIO, "usdhc2_reset"); + gpio_direction_output(USDHC2_RESET_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC2_RESET_GPIO, 1); + gpio_request(USDHC2_CD_GPIO, "usdhc2 cd"); + gpio_direction_input(USDHC2_CD_GPIO); + break; + case 1: + init_clk_usdhc(2); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + imx_iomux_v3_setup_multiple_pads(usdhc3_pads, + ARRAY_SIZE(usdhc3_pads)); + break; + default: + printf("Warning: you configured more USDHC controllers (%d) than supported by the board\n", + i + 1); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) + return ret; + } + + return 0; +} + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC2_BASE_ADDR: + ret = !gpio_get_value(USDHC2_CD_GPIO); + break; + case USDHC3_BASE_ADDR: + ret = 1; + break; + } + + return ret; +} + +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) + +static const iomux_v3_cfg_t wdog_pads[] = { + MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), +}; + +#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) + +static const iomux_v3_cfg_t ser0_pads[] = { + MX8MP_PAD_UART2_RXD__UART2_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX8MP_PAD_UART2_TXD__UART2_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +int board_early_init_f(void) +{ + struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; + + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); + set_wdog_reset(wdog); + + imx_iomux_v3_setup_multiple_pads(ser0_pads, ARRAY_SIZE(ser0_pads)); + + return 0; +} + +static const iomux_v3_cfg_t reset_out_pad[] = { + MX8MP_PAD_SAI2_MCLK__GPIO4_IO27 | MUX_PAD_CTRL(0x19) +}; + +#define RESET_OUT_GPIO IMX_GPIO_NR(4, 27) + +static void pulse_reset_out(void) +{ + imx_iomux_v3_setup_multiple_pads(reset_out_pad, ARRAY_SIZE(reset_out_pad)); + + gpio_request(RESET_OUT_GPIO, "reset_out_gpio"); + gpio_direction_output(RESET_OUT_GPIO, 0); + udelay(10); + gpio_direction_output(RESET_OUT_GPIO, 1); +} + +#define I2C_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PE) +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +struct i2c_pads_info i2c_dev_pads = { + .scl = { + .i2c_mode = MX8MP_PAD_SAI5_RXFS__I2C6_SCL | PC, + .gpio_mode = MX8MP_PAD_SAI5_RXFS__GPIO3_IO19 | PC, + .gp = IMX_GPIO_NR(3, 19), + }, + .sda = { + .i2c_mode = MX8MP_PAD_SAI5_RXC__I2C6_SDA | PC, + .gpio_mode = MX8MP_PAD_SAI5_RXC__GPIO3_IO20 | PC, + .gp = IMX_GPIO_NR(3, 20), + }, +}; + +int power_init_board(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_seq(UCLASS_PMIC, 0, &dev); + if (ret) { + printf("Error: Failed to get PMIC\n"); + return ret; + } + + /* set VCC_DRAM (buck2) to 1.1V */ + pmic_reg_write(dev, RN5T567_DC2DAC, 0x28); + + /* set VCC_ARM (buck2) to 0.95V */ + pmic_reg_write(dev, RN5T567_DC3DAC, 0x1C); + + return 0; +} + +int board_fit_config_name_match(const char *name) +{ + return 0; +} + +void board_init_f(ulong dummy) +{ + int ret; + + arch_cpu_init(); + + init_uart_clk(1); + + board_early_init_f(); + + pulse_reset_out(); + + timer_init(); + + ret = spl_early_init(); + if (ret) { + printf("Error: failed to initialize SPL!\n"); + hang(); + } + + preloader_console_init(); + + enable_tzc380(); + + power_init_board(); + + spl_dram_init(); +} diff --git a/configs/msc_sm2s_imx8mp_defconfig b/configs/msc_sm2s_imx8mp_defconfig new file mode 100644 index 0000000000..a4f39061ae --- /dev/null +++ b/configs/msc_sm2s_imx8mp_defconfig @@ -0,0 +1,105 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mp-msc-sm2s" +CONFIG_SPL_TEXT_BASE=0x920000 +CONFIG_TARGET_MSC_SM2S_IMX8MP=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_BOOT_GET_CMDLINE=y +CONFIG_SYS_BARGSIZE=2048 +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_DEFAULT_FDT_FILE="imx8mp-msc-sm2s.dtb" +CONFIG_SPL_MAX_SIZE=0x26000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x0098FC00 +CONFIG_SPL_BSS_MAX_SIZE=0x400 +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0x960000 +CONFIG_SYS_SPL_MALLOC=y +CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y +CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x42200000 +CONFIG_SYS_SPL_MALLOC_SIZE=0x80000 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_MAXARGS=64 +CONFIG_SYS_CBSIZE=2048 +CONFIG_SYS_PBSIZE=2074 +CONFIG_SYS_BOOTM_LEN=0x2000000 +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="interrupt-parent interrupts" +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_USE_ETHPRIME=y +CONFIG_ETHPRIME="eth1" +CONFIG_SPL_DM=y +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMX8MP=y +CONFIG_CLK_IMX8MP=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_FSL_USDHC=y +CONFIG_PHY_TI=y +CONFIG_DM_ETH=y +CONFIG_DM_ETH_PHY=y +CONFIG_PHY_GIGE=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_IMX=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RN5T567=y +CONFIG_SPL_PMIC_RN5T567=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_PSCI=y diff --git a/include/configs/msc_sm2s_imx8mp.h b/include/configs/msc_sm2s_imx8mp.h new file mode 100644 index 0000000000..59ab7329fa --- /dev/null +++ b/include/configs/msc_sm2s_imx8mp.h @@ -0,0 +1,64 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Based on vendor support provided by AVNET Embedded + * + * Copyright (C) 2021 AVNET Embedded, MSC Technologies GmbH + * Copyright 2021 General Electric Company + * Copyright 2021 Collabora Ltd. + */ + +#ifndef __MSC_SM2S_IMX8MP_H +#define __MSC_SM2S_IMX8MP_H + +#include <linux/sizes.h> +#include <linux/stringify.h> +#include <asm/arch/imx-regs.h> + +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_UBOOT_BASE (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) + +#if defined(CONFIG_CMD_NET) +#define CONFIG_FEC_MXC_PHYADDR 1 +#define PHY_ANEG_TIMEOUT 20000 +#endif + +#ifndef CONFIG_SPL_BUILD +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 1) \ + func(MMC, mmc, 2) + +#include <config_distro_bootcmd.h> +#endif + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + BOOTENV \ + "scriptaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "image=Image\0" \ + "console=ttymxc1,115200\0" \ + "fdt_addr_r=0x43000000\0" \ + "boot_fdt=try\0" \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "initrd_addr=0x43800000\0" \ + "bootm_size=0x10000000\0" \ + "mmcpart=1\0" \ + "mmcroot=/dev/mmcblk1p2 rootwait rw\0" \ + +/* Link Definitions */ + +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x80000 + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 +#define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */ +#define PHYS_SDRAM_2 0xc0000000 +#define PHYS_SDRAM_2_SIZE 0x0 + +#define CONFIG_MXC_UART_BASE UART2_BASE_ADDR + +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#endif
Add support for the MSC SM2S-IMX8PLUS SMARC Module. Tested in conjunction with the MSC SM2-MB-EP1 Mini-ITX Carrier Board. Signed-off-by: Martyn Welch martyn.welch@collabora.com
Best regards, Stefano Babic
The i.MX8MP also has USDHC3, allow access to the relvant base address definition. Signed-off-by: Martyn Welch martyn.welch@collabora.com
Jaehoon Chung
Martyn Welch
Peng Fan
sbabic@denx.de
