[U-Boot] [PATCH 1/5] arm: exynos: clean up checkpatch issues
This patch will fix these checkpatch issues.
ERROR: Macros with complex values should be enclosed in parentheses +#define DEFAULT_DQS_X4 (DEFAULT_DQS << 24) || (DEFAULT_DQS << 16) \ + || (DEFAULT_DQS << 8) || (DEFAULT_DQS << 0)
ERROR: space prohibited before that ',' (ctx:WxW) + writel(val , &drex0->concontrol); ^
ERROR: space prohibited before that ',' (ctx:WxW) + writel(val , &drex1->concontrol); ^
Signed-off-by: Minkyu Kang mk7.kang@samsung.com --- arch/arm/mach-exynos/dmc_init_ddr3.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-exynos/dmc_init_ddr3.c b/arch/arm/mach-exynos/dmc_init_ddr3.c index 7c0b12a..25a9df9 100644 --- a/arch/arm/mach-exynos/dmc_init_ddr3.c +++ b/arch/arm/mach-exynos/dmc_init_ddr3.c @@ -20,8 +20,8 @@ #define TIMEOUT_US 10000 #define NUM_BYTE_LANES 4 #define DEFAULT_DQS 8 -#define DEFAULT_DQS_X4 (DEFAULT_DQS << 24) || (DEFAULT_DQS << 16) \ - || (DEFAULT_DQS << 8) || (DEFAULT_DQS << 0) +#define DEFAULT_DQS_X4 ((DEFAULT_DQS << 24) || (DEFAULT_DQS << 16) \ + || (DEFAULT_DQS << 8) || (DEFAULT_DQS << 0))
#ifdef CONFIG_EXYNOS5250 static void reset_phy_ctrl(void) @@ -856,10 +856,10 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, int reset) */ val = readl(&drex0->concontrol); val |= CONCONTROL_UPDATE_MODE; - writel(val , &drex0->concontrol); + writel(val, &drex0->concontrol); val = readl(&drex1->concontrol); val |= CONCONTROL_UPDATE_MODE; - writel(val , &drex1->concontrol); + writel(val, &drex1->concontrol);
return 0; }
- writel(val , &drex1->concontrol); ^
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Minkyu Kang
