[U-Boot] [PATCH v2 1/6] i2c: rcar_i2c: Setup SCL/SDA delay at rcar_i2c_set_speed
It only needs to be done once.
Signed-off-by: Ismael Luceno ismael.luceno@silicon-gears.com --- drivers/i2c/rcar_i2c.c | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/drivers/i2c/rcar_i2c.c b/drivers/i2c/rcar_i2c.c index 10b0f8bad4..74643b085e 100644 --- a/drivers/i2c/rcar_i2c.c +++ b/drivers/i2c/rcar_i2c.c @@ -116,9 +116,7 @@ static int rcar_i2c_set_addr(struct udevice *dev, u8 chip, u8 read) writel(0, priv->base + RCAR_I2C_ICMSR); writel(priv->icccr, priv->base + RCAR_I2C_ICCCR);
- if (priv->type == RCAR_I2C_TYPE_GEN3) - writel(RCAR_I2C_ICFBSCR_TCYC17, priv->base + RCAR_I2C_ICFBSCR); - + /* Wait for the bus */ ret = wait_for_bit_le32(priv->base + RCAR_I2C_ICMCR, RCAR_I2C_ICMCR_FSDA, false, 2, true); if (ret) { @@ -304,6 +302,10 @@ scgd_find: priv->icccr = (scgd << RCAR_I2C_ICCCR_SCGD_OFF) | cdf; writel(priv->icccr, priv->base + RCAR_I2C_ICCCR);
+ if (priv->type == RCAR_I2C_TYPE_GEN3) + /* Set SCL/SDA delay */ + writel(RCAR_I2C_ICFBSCR_TCYC17, priv->base + RCAR_I2C_ICFBSCR); + return 0; }
base-commit: f08023c07d826fbc8e62fdd3367961b2f0b06844 prerequisite-patch-id: 9e5b0458bc15640eb483ccad91dbe85150f9f7be
Notes: Changes since v1: - Rebased on top of patch 1050650 ("i2c: rcar_i2c: Add Gen3 SoC support")
drivers/i2c/rcar_i2c.c | 45 +++++++++++++++++++++--------------------- 1 file changed, 23 insertions(+), 22 deletions(-)
diff --git a/drivers/i2c/rcar_i2c.c b/drivers/i2c/rcar_i2c.c index 74643b085e..c1a233b6e9 100644 --- a/drivers/i2c/rcar_i2c.c +++ b/drivers/i2c/rcar_i2c.c @@ -18,35 +18,36 @@ #include <asm/io.h> #include <wait_bit.h>
-#define RCAR_I2C_ICSCR 0x00 -#define RCAR_I2C_ICMCR 0x04 -#define RCAR_I2C_ICMCR_MDBS BIT(7) -#define RCAR_I2C_ICMCR_FSCL BIT(6) -#define RCAR_I2C_ICMCR_FSDA BIT(5) -#define RCAR_I2C_ICMCR_OBPC BIT(4) -#define RCAR_I2C_ICMCR_MIE BIT(3) +#define RCAR_I2C_ICSCR 0x00 /* slave ctrl */ +#define RCAR_I2C_ICMCR 0x04 /* master ctrl */ +#define RCAR_I2C_ICMCR_MDBS BIT(7) /* non-fifo mode switch */ +#define RCAR_I2C_ICMCR_FSCL BIT(6) /* override SCL pin */ +#define RCAR_I2C_ICMCR_FSDA BIT(5) /* override SDA pin */ +#define RCAR_I2C_ICMCR_OBPC BIT(4) /* override pins */ +#define RCAR_I2C_ICMCR_MIE BIT(3) /* master if enable */ #define RCAR_I2C_ICMCR_TSBE BIT(2) -#define RCAR_I2C_ICMCR_FSB BIT(1) -#define RCAR_I2C_ICMCR_ESG BIT(0) -#define RCAR_I2C_ICSSR 0x08 -#define RCAR_I2C_ICMSR 0x0c +#define RCAR_I2C_ICMCR_FSB BIT(1) /* force stop bit */ +#define RCAR_I2C_ICMCR_ESG BIT(0) /* enable start bit gen */ +#define RCAR_I2C_ICSSR 0x08 /* slave status */ +#define RCAR_I2C_ICMSR 0x0c /* master status */ #define RCAR_I2C_ICMSR_MASK 0x7f -#define RCAR_I2C_ICMSR_MNR BIT(6) -#define RCAR_I2C_ICMSR_MAL BIT(5) -#define RCAR_I2C_ICMSR_MST BIT(4) +#define RCAR_I2C_ICMSR_MNR BIT(6) /* Nack */ +#define RCAR_I2C_ICMSR_MAL BIT(5) /* Arbitration lost */ +#define RCAR_I2C_ICMSR_MST BIT(4) /* Stop */ #define RCAR_I2C_ICMSR_MDE BIT(3) #define RCAR_I2C_ICMSR_MDT BIT(2) #define RCAR_I2C_ICMSR_MDR BIT(1) #define RCAR_I2C_ICMSR_MAT BIT(0) -#define RCAR_I2C_ICSIER 0x10 -#define RCAR_I2C_ICMIER 0x14 -#define RCAR_I2C_ICCCR 0x18 +#define RCAR_I2C_ICSIER 0x10 /* slave irq enable */ +#define RCAR_I2C_ICMIER 0x14 /* master irq enable */ +#define RCAR_I2C_ICCCR 0x18 /* clock dividers */ #define RCAR_I2C_ICCCR_SCGD_OFF 3 -#define RCAR_I2C_ICSAR 0x1c -#define RCAR_I2C_ICMAR 0x20 -#define RCAR_I2C_ICRXD_ICTXD 0x24 -#define RCAR_I2C_ICFBSCR 0x38 -#define RCAR_I2C_ICFBSCR_TCYC17 0x0f +#define RCAR_I2C_ICSAR 0x1c /* slave address */ +#define RCAR_I2C_ICMAR 0x20 /* master address */ +#define RCAR_I2C_ICRXD_ICTXD 0x24 /* data port */ +#define RCAR_I2C_ICFBSCR 0x38 /* First Bit Setup Cycle (Gen3) */ +#define RCAR_I2C_ICFBSCR_TCYC17 0x0f /* 17*Tcyc delay 1st bit + between SDA and SCL */
enum rcar_i2c_type { RCAR_I2C_TYPE_GEN2,
On 3/5/19 12:16 PM, Ismael Luceno Cortes wrote:
Commit message is missing :(
Thanks!
Checkpatch is complaining:
WARNING: line over 80 characters #137: FILE: drivers/i2c/rcar_i2c.c:47: +#define RCAR_I2C_ICFBSCR 0x38 /* First Bit Setup Cycle (Gen3) */
WARNING: Block comments use * on subsequent lines #139: FILE: drivers/i2c/rcar_i2c.c:49: +#define RCAR_I2C_ICFBSCR_TCYC17 0x0f /* 17*Tcyc delay 1st bit + between SDA and SCL */
WARNING: Block comments use a trailing */ on a separate line #139: FILE: drivers/i2c/rcar_i2c.c:49: + between SDA and SCL */
total: 1 errors, 3 warnings, 0 checks, 60 lines checked
Please fix and run scripts/checkpatch.pl on the patches before posting them.
Do the reset before clearing the MSR, otherwise it may result in a read or write operation instead if the start condition is repeated.
drivers/i2c/rcar_i2c.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/i2c/rcar_i2c.c b/drivers/i2c/rcar_i2c.c index c1a233b6e9..7131f0c994 100644 --- a/drivers/i2c/rcar_i2c.c +++ b/drivers/i2c/rcar_i2c.c @@ -130,9 +130,11 @@ static int rcar_i2c_set_addr(struct udevice *dev, u8 chip, u8 read) }
writel((chip << 1) | read, priv->base + RCAR_I2C_ICMAR); - writel(0, priv->base + RCAR_I2C_ICMSR); + /* Reset */ writel(RCAR_I2C_ICMCR_MDBS | RCAR_I2C_ICMCR_MIE | RCAR_I2C_ICMCR_ESG, priv->base + RCAR_I2C_ICMCR); + /* Clear Status */ + writel(0, priv->base + RCAR_I2C_ICMSR);
ret = wait_for_bit_le32(priv->base + RCAR_I2C_ICMSR, mask, true, 100, true);
Reviewed-by: Marek Vasut marek.vasut+renesas@gmail.com
/* Clear Status */
drivers/i2c/rcar_i2c.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/i2c/rcar_i2c.c b/drivers/i2c/rcar_i2c.c index 7131f0c994..d6b0418290 100644 --- a/drivers/i2c/rcar_i2c.c +++ b/drivers/i2c/rcar_i2c.c @@ -217,7 +217,7 @@ static int rcar_i2c_xfer(struct udevice *dev, struct i2c_msg *msg, int nmsgs) ret = rcar_i2c_write_common(dev, msg);
if (ret) - return -EREMOTEIO; + return ret; }
return ret;
Commit message is missing :-(
if (ret)
return -EREMOTEIO;
return ret;
return ret;
Notes: Changes since v1: - Rebased on top of patch 1050650 ("i2c: rcar_i2c: Add Gen3 SoC support") - Fixed masking of return value from rcar_i2c_set_addr
drivers/i2c/rcar_i2c.c | 14 +++++--------- 1 file changed, 5 insertions(+), 9 deletions(-)
diff --git a/drivers/i2c/rcar_i2c.c b/drivers/i2c/rcar_i2c.c index d6b0418290..4556b115bd 100644 --- a/drivers/i2c/rcar_i2c.c +++ b/drivers/i2c/rcar_i2c.c @@ -154,10 +154,6 @@ static int rcar_i2c_read_common(struct udevice *dev, struct i2c_msg *msg) u32 icmcr = RCAR_I2C_ICMCR_MDBS | RCAR_I2C_ICMCR_MIE; int i, ret = -EREMOTEIO;
- ret = rcar_i2c_set_addr(dev, msg->addr, 1); - if (ret) - return ret; - for (i = 0; i < msg->len; i++) { if (msg->len - 1 == i) icmcr |= RCAR_I2C_ICMCR_FSB; @@ -184,10 +180,6 @@ static int rcar_i2c_write_common(struct udevice *dev, struct i2c_msg *msg) u32 icmcr = RCAR_I2C_ICMCR_MDBS | RCAR_I2C_ICMCR_MIE; int i, ret = -EREMOTEIO;
- ret = rcar_i2c_set_addr(dev, msg->addr, 0); - if (ret) - return ret; - for (i = 0; i < msg->len; i++) { writel(msg->buf[i], priv->base + RCAR_I2C_ICRXD_ICTXD); writel(icmcr, priv->base + RCAR_I2C_ICMCR); @@ -211,6 +203,10 @@ static int rcar_i2c_xfer(struct udevice *dev, struct i2c_msg *msg, int nmsgs) int ret;
for (; nmsgs > 0; nmsgs--, msg++) { + ret = rcar_i2c_set_addr(dev, msg->addr, 1); + if (ret) + return ret; + if (msg->flags & I2C_M_RD) ret = rcar_i2c_read_common(dev, msg); else @@ -220,7 +216,7 @@ static int rcar_i2c_xfer(struct udevice *dev, struct i2c_msg *msg, int nmsgs) return ret; }
- return ret; + return 0; }
static int rcar_i2c_probe_chip(struct udevice *dev, uint addr, uint flags)
The patch itself is fine though. Can you fill the commit message and do a V3 of the series ?
- if (ret)
return ret;
- if (ret)
return ret;
if (ret)
return ret;
- if (msg->flags & I2C_M_RD) ret = rcar_i2c_read_common(dev, msg); else
- return ret;
Cosmetic change. Any call to the recover function would need to do the same check afterwards, so it's sensible to make it part of the function.
Notes: Changes since v1: - Rebased on top of patch 1050650 ("i2c: rcar_i2c: Add Gen3 SoC support") - Explained the change - Replaced C99-style variable declaration
drivers/i2c/rcar_i2c.c | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/drivers/i2c/rcar_i2c.c b/drivers/i2c/rcar_i2c.c index 4556b115bd..21bcf09101 100644 --- a/drivers/i2c/rcar_i2c.c +++ b/drivers/i2c/rcar_i2c.c @@ -77,12 +77,13 @@ static int rcar_i2c_finish(struct udevice *dev) return ret; }
-static void rcar_i2c_recover(struct udevice *dev) +static int rcar_i2c_recover(struct udevice *dev) { struct rcar_i2c_priv *priv = dev_get_priv(dev); u32 mcr = RCAR_I2C_ICMCR_MDBS | RCAR_I2C_ICMCR_OBPC; u32 mcra = mcr | RCAR_I2C_ICMCR_FSDA; int i; + u32 ret;
/* Send 9 SCL pulses */ for (i = 0; i < 9; i++) { @@ -102,6 +103,9 @@ static void rcar_i2c_recover(struct udevice *dev) udelay(5); writel(mcra | RCAR_I2C_ICMCR_FSCL, priv->base + RCAR_I2C_ICMCR); udelay(5); + + ret = readl(priv->base + RCAR_I2C_ICMSR); + return ret & RCAR_I2C_ICMCR_FSDA; }
static int rcar_i2c_set_addr(struct udevice *dev, u8 chip, u8 read) @@ -121,9 +125,7 @@ static int rcar_i2c_set_addr(struct udevice *dev, u8 chip, u8 read) ret = wait_for_bit_le32(priv->base + RCAR_I2C_ICMCR, RCAR_I2C_ICMCR_FSDA, false, 2, true); if (ret) { - rcar_i2c_recover(dev); - val = readl(priv->base + RCAR_I2C_ICMSR); - if (val & RCAR_I2C_ICMCR_FSDA) { + if (rcar_i2c_recover(dev)) { dev_err(dev, "Bus busy, aborting\n"); return ret; }
- u32 ret;
Can you change this to "reg" or something like that ? $ret is usually a signed int return value, so this could be confusing.
- ret = readl(priv->base + RCAR_I2C_ICMSR);
- return ret & RCAR_I2C_ICMCR_FSDA;
What about doing this instead
reg = readl... if (reg & ...FSDA) return -EBUSY;
That way, the code will use standard errno.h return values.
}if (rcar_i2c_recover(dev)) { dev_err(dev, "Bus busy, aborting\n"); return ret;
- u32 ret;
Ok.
Makes sense.
As much as I hate to do it, I need to ask you to reword the commit message again.
When I look at just the commit message and I read "It only needs to be done once.", I literally have no clue what the change does. I need to look into the patch.
- /* Wait for the bus */ ret = wait_for_bit_le32(priv->base + RCAR_I2C_ICMCR, RCAR_I2C_ICMCR_FSDA, false, 2, true); if (ret) {
Please add brackets around the multi-line code, so it's obvious what is in the if conditional and what is not.
return 0; }
