[U-Boot] [PATCH] mx6: Fix calculation of emi_slow clock rate
This is porting of Freescale's patch from version imx_v2009.08_3.0.35_4.0.0, that fixes the obvious mistype of bits offset macro name (ACLK_EMI_PODF_OFFSET was used instead of ACLK_EMI_SLOW_PODF_OFFSET).
Using the occasion, change the variable name 'emi_slow_pof' to more consistent 'emi_slow_podf'.
Signed-off-by: Jason Liu r64343@freescale.com Signed-off-by: Andrew Gabbasov andrew_gabbasov@mentor.com --- arch/arm/cpu/armv7/mx6/clock.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index 3c0d908..064f8c8 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -244,13 +244,13 @@ static u32 get_axi_clk(void)
static u32 get_emi_slow_clk(void) { - u32 emi_clk_sel, emi_slow_pof, cscmr1, root_freq = 0; + u32 emi_clk_sel, emi_slow_podf, cscmr1, root_freq = 0;
cscmr1 = __raw_readl(&imx_ccm->cscmr1); emi_clk_sel = cscmr1 & MXC_CCM_CSCMR1_ACLK_EMI_SLOW_MASK; emi_clk_sel >>= MXC_CCM_CSCMR1_ACLK_EMI_SLOW_OFFSET; - emi_slow_pof = cscmr1 & MXC_CCM_CSCMR1_ACLK_EMI_SLOW_PODF_MASK; - emi_slow_pof >>= MXC_CCM_CSCMR1_ACLK_EMI_PODF_OFFSET; + emi_slow_podf = cscmr1 & MXC_CCM_CSCMR1_ACLK_EMI_SLOW_PODF_MASK; + emi_slow_podf >>= MXC_CCM_CSCMR1_ACLK_EMI_SLOW_PODF_OFFSET;
switch (emi_clk_sel) { case 0: @@ -267,7 +267,7 @@ static u32 get_emi_slow_clk(void) break; }
- return root_freq / (emi_slow_pof + 1); + return root_freq / (emi_slow_podf + 1); }
#ifdef CONFIG_MX6SL
Acked-by: Dirk Behme dirk.behme@de.bosch.com
Thanks
Dirk
#ifdef CONFIG_MX6SL
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Andrew Gabbasov
Dirk Behme
Stefano Babic
