[U-Boot] Pull request: u-boot-net.git master
Hi Tom,
The following changes since commit c98b171e1098f94b2ff7720c45a25a602882f876:
Merge branch 'rmobile' of git://git.denx.de/u-boot-sh (2016-08-20 16:40:34 -0400)
git://git.denx.de/u-boot-net.git master
for you to fetch changes up to 8c83c0303c0eaa5f5323d08ffe1f786759e509be:
net: mii: check phy advertising register when geting link status (2016-08-22 14:21:23 -0500)
---------------------------------------------------------------- Dongpo Li (1): net: mii: check phy advertising register when geting link status
Guillaume GARDET (1): net: NFS: Add NFSv3 support
Hou Zhiqiang (1): net/fm: Remove unused code of FMan QMI
Joe Hershberger (12): net: Stop including NFS overhead in defragment max net: nfs: Remove separate buffer for default name net: nfs: Remove unused define net: nfs: Share the file handle buffer for v2 / v3 net: nfs: Correct the reply data buffer size net: nfs: Fix lines that are too long net: nfs: Consolidate handling of NFSv3 attributes net: nfs: Correct a comment net: nfs: Use consistent names for the rpc_pkt net: nfs: Move some prints to debug statements net: nfs: Use the tx buffer to construct rpc msgs net: nfs: Simplify rpc_add_credentials()
karl beldan (4): net: davinci_emac: Remove useless dcache ops on descriptors net: davinci_emac: Round up top tx buffer boundaries for dcache ops net: davinci_emac: Invalidate only the received portion of a buffer net: davinci_emac: Restore the internal MDIO accessors return values
common/miiphyutil.c | 18 ++- drivers/net/davinci_emac.c | 53 ++----- drivers/net/fm/fm.c | 3 - net/net.c | 10 +- net/nfs.c | 368 +++++++++++++++++++++++++++++++-------------- net/nfs.h | 15 +- 6 files changed, 293 insertions(+), 174 deletions(-)
Thanks! -Joe
On Mon, Aug 22, 2016 at 09:26:53PM -0500, Joe Hershberger wrote:
Hi Tom,
Joe Hershberger
