[PATCH 0/4] Making veyrons boot, 2020 edition
This is a series to make veyrons (tested on a veyron speedy), boot atleast to the u-boot prompt, the first 3 patches are necessary and the 4th one kinda just managed to catch this patch train ;)
PS. Thanks to swiftgeek on IRC for some bisecting & testing, thus getting me curious enough to investigate these myself.
Urja Rannikko (4): rockchip: spl: veyron speedy boots from SPI rockchip: veyron: move board_early_init_f to _r (after reloc) rockchip: spl-boot-order: do not attempt to access fdt if OF_PLATDATA defconfig: veyron: no need for CONFIG_SPL_PINCTRL_FULL
arch/arm/mach-rockchip/spl-boot-order.c | 6 ++++++ arch/arm/mach-rockchip/spl.c | 3 ++- board/google/veyron/veyron.c | 2 +- configs/chromebit_mickey_defconfig | 4 ++-- configs/chromebook_jerry_defconfig | 5 ++--- configs/chromebook_minnie_defconfig | 4 ++-- configs/chromebook_speedy_defconfig | 3 ++- 7 files changed, 17 insertions(+), 10 deletions(-)
Apparently speedy was forgotten from this list of veyron devices.
Fixes: 49105fb7ed ("rockchip: add common spl board file") Signed-off-by: Urja Rannikko urjaman@gmail.com --- arch/arm/mach-rockchip/spl.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/spl.c b/arch/arm/mach-rockchip/spl.c index 0b76af6080..2c2b4ea5c0 100644 --- a/arch/arm/mach-rockchip/spl.c +++ b/arch/arm/mach-rockchip/spl.c @@ -49,7 +49,8 @@ u32 spl_boot_device(void)
#if defined(CONFIG_TARGET_CHROMEBOOK_JERRY) || \ defined(CONFIG_TARGET_CHROMEBIT_MICKEY) || \ - defined(CONFIG_TARGET_CHROMEBOOK_MINNIE) + defined(CONFIG_TARGET_CHROMEBOOK_MINNIE) || \ + defined(CONFIG_TARGET_CHROMEBOOK_SPEEDY) return BOOT_DEVICE_SPI; #endif if (CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BROM))
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks,
- Kever
return BOOT_DEVICE_SPI; #endif if (CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BROM))defined(CONFIG_TARGET_CHROMEBOOK_SPEEDY)
Previously veyron_init() was called in board_init() context, which is called after relocation. Moving it to veyron.c used board_early_init_f which is called way earlier, and causes veyron_init to hang. Using board_early_init_r instead fixes this.
Fixes: b678f2790c ("rockchip: rk3288: Move veyron_init() back to veyron.c") Signed-off-by: Urja Rannikko urjaman@gmail.com --- board/google/veyron/veyron.c | 2 +- configs/chromebit_mickey_defconfig | 1 + configs/chromebook_jerry_defconfig | 2 +- configs/chromebook_minnie_defconfig | 1 + configs/chromebook_speedy_defconfig | 2 +- 5 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/board/google/veyron/veyron.c b/board/google/veyron/veyron.c index 6b9c34818b..04321094ef 100644 --- a/board/google/veyron/veyron.c +++ b/board/google/veyron/veyron.c @@ -68,7 +68,7 @@ static int veyron_init(void) } #endif
-int board_early_init_f(void) +int board_early_init_r(void) { struct udevice *dev; int ret; diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index b1ad7bdd1d..b290f0fcb9 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -19,6 +19,7 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-mickey.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 16eee2238b..f6bdf80aee 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -20,7 +20,7 @@ CONFIG_LOG=y CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-jerry.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index 2c0415431f..c229177f64 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -20,6 +20,7 @@ CONFIG_SILENT_CONSOLE=y CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-minnie.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 diff --git a/configs/chromebook_speedy_defconfig b/configs/chromebook_speedy_defconfig index b4116a34e6..be434871ff 100644 --- a/configs/chromebook_speedy_defconfig +++ b/configs/chromebook_speedy_defconfig @@ -20,7 +20,7 @@ CONFIG_SILENT_CONSOLE=y CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-speedy.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000
Thanks,
- Kever
gd->fdt_blob is null if using OF_PLATDATA in SPL, which causes a hang after f0921f5098 ("fdt: Sync up to the latest libfdt"). We use the same test that is used in spl_common_init on whether to call fdtdec_setup to unconditionally avoid linking in the fdt-using code when not necessary and thus reduce SPL size.
Signed-off-by: Urja Rannikko urjaman@gmail.com --- arch/arm/mach-rockchip/spl-boot-order.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/mach-rockchip/spl-boot-order.c b/arch/arm/mach-rockchip/spl-boot-order.c index c147d5821e..d23829a789 100644 --- a/arch/arm/mach-rockchip/spl-boot-order.c +++ b/arch/arm/mach-rockchip/spl-boot-order.c @@ -98,6 +98,12 @@ __weak const char *board_spl_was_booted_from(void)
void board_boot_order(u32 *spl_boot_list) { + /* In case of no fdt (or only platdata), use spl_boot_device() */ + if (!CONFIG_IS_ENABLED(OF_CONTROL) || CONFIG_IS_ENABLED(OF_PLATDATA)) { + spl_boot_list[0] = spl_boot_device(); + return; + } + const void *blob = gd->fdt_blob; int chosen_node = fdt_path_offset(blob, "/chosen"); int idx = 0;
Thanks, - Kever
- /* In case of no fdt (or only platdata), use spl_boot_device() */
- if (!CONFIG_IS_ENABLED(OF_CONTROL) || CONFIG_IS_ENABLED(OF_PLATDATA)) {
return;
- const void *blob = gd->fdt_blob; int chosen_node = fdt_path_offset(blob, "/chosen"); int idx = 0;
Veyrons do not need full pinctrl support for SPL. The full pinctrl support does nothing when enabled with OF_PLATDATA, thus was already unused. This frees about 4kB of SPL size.
Signed-off-by: Urja Rannikko urjaman@gmail.com --- configs/chromebit_mickey_defconfig | 3 +-- configs/chromebook_jerry_defconfig | 3 +-- configs/chromebook_minnie_defconfig | 3 +-- configs/chromebook_speedy_defconfig | 1 + 4 files changed, 4 insertions(+), 6 deletions(-)
diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index b290f0fcb9..23efafb0d2 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -73,8 +73,7 @@ CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_PINCTRL=y CONFIG_PINCONF=y CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINMUX is not set -CONFIG_SPL_PINCONF=y +# CONFIG_SPL_PINCTRL_FULL is not set CONFIG_DM_PMIC=y # CONFIG_SPL_PMIC_CHILDREN is not set CONFIG_PMIC_RK8XX=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index f6bdf80aee..443e3cdace 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -75,8 +75,7 @@ CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_PINCTRL=y CONFIG_PINCONF=y CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINMUX is not set -CONFIG_SPL_PINCONF=y +# CONFIG_SPL_PINCTRL_FULL is not set CONFIG_DM_PMIC=y # CONFIG_SPL_PMIC_CHILDREN is not set CONFIG_PMIC_RK8XX=y diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index c229177f64..99ac0e0674 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -75,8 +75,7 @@ CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_PINCTRL=y CONFIG_PINCONF=y CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINMUX is not set -CONFIG_SPL_PINCONF=y +# CONFIG_SPL_PINCTRL_FULL is not set CONFIG_DM_PMIC=y # CONFIG_SPL_PMIC_CHILDREN is not set CONFIG_PMIC_RK8XX=y diff --git a/configs/chromebook_speedy_defconfig b/configs/chromebook_speedy_defconfig index be434871ff..5a5152541b 100644 --- a/configs/chromebook_speedy_defconfig +++ b/configs/chromebook_speedy_defconfig @@ -74,6 +74,7 @@ CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_PINCTRL=y CONFIG_PINCONF=y CONFIG_SPL_PINCTRL=y +# CONFIG_SPL_PINCTRL_FULL is not set CONFIG_DM_PMIC=y # CONFIG_SPL_PMIC_CHILDREN is not set CONFIG_PMIC_RK8XX=y
Thanks, - Kever
Kever Yang
Urja Rannikko
