[U-Boot] [PATCH] net: Change the NFS_TIMEOUT to 20s for using nfs load image.
The NFS_TIMEOUT is 2s before. It is too short for some nfs server to respond.
Signed-off-by: Jin Qing b24347@freescale.com --- We are not sure what is the expected timeout period. Using 20s to make sure the mount works.
net/nfs.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/net/nfs.c b/net/nfs.c index 4017c3e..cabadfe 100644 --- a/net/nfs.c +++ b/net/nfs.c @@ -33,7 +33,7 @@
#define HASHES_PER_LINE 65 /* Number of "loading" hashes per line */ #define NFS_RETRY_COUNT 30 -#define NFS_TIMEOUT 2000UL +#define NFS_TIMEOUT 20000UL
static int fs_mounted = 0; static unsigned long rpc_id = 0;
Dear Li Yang,
You mean 30 retries (NFS_RETRY_COUNT) every two seconds were not sufficient in your case?
That's a full minute...
Waiting 10 minutes for a command to complete seems way too long to me.
On Mon, Aug 16, 2010 at 6:09 PM, Wolfgang Denk wd@denx.de wrote:
Dear Li Yang,
It didn't retry 30 times before it fails completely in our test:
Load address: 0x400000 Loading: T T T T T *** ERROR: Cannot mount T T *** ERROR: Cannot umount
Looks like the state machine is not working as expected?
- Leo
Dear Li Yang,
In message AANLkTi=o6z1eBM1af94ZP5-s6_3Vf6TTP2VEdHDZWe=A@mail.gmail.com you wrote:
...or something else is causing errors.
I have never seen such behaviour yet. Please try and debug it. Simply raising the timeout limit seems the wrong approach to me.
Dear Wolfgang,
The work flow is that: Every "timeout" is reached, it will call NfsSend() and whatever the state is finally it will call rpc_req() which will increase the rpc_id value every time. The rpc_id value is increased but the reply.id is not increased by "timeout". This makes the judgement statement: If (ntohl(rpc_pkt.u.reply.id) != rpc_id) is true and it will return -1. Then we got the error message: *** ERROR: Cannot mount.
So far, I am raising the timeout limit to avoid rpc_id being increased unexpectedly.
Do you have any suggestion about this issue?
Best Regards, Jin Qing
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: 2010年8月16日 18:46 To: Li Yang-R58472 Cc: u-boot@lists.denx.de; Jin Qing-B24347 Subject: Re: [U-Boot] [PATCH] net: Change the NFS_TIMEOUT to 20s for using nfs load image.
Dear Li Yang,
Dear Jin Qing-B24347,
In message F37F9B48E0E59D42A5F9491A3CAD99AD7E8E37@zch01exm28.fsl.freescale.net you wrote:
What sort of NFS server is this?
Dear Wolfgang
statement:
increased
unexpectedly.
It is a Debian NFS server.
Best regards, Jin Qing
Jin Qing-B24347
Li Yang
