[PATCH] Add support for Davicom DM96xx based USB 10/100 ethernet devices
Ported from Linux driver - drivers/net/usb9601.c
Signed-off-by: hyyoxhk hyyoxhk@163.com --- drivers/usb/eth/Kconfig | 8 ++++++++ drivers/usb/eth/Makefile | 1 + 2 files changed, 9 insertions(+)
diff --git a/drivers/usb/eth/Kconfig b/drivers/usb/eth/Kconfig index 2f6bfa8e71..8a47ca0ec4 100644 --- a/drivers/usb/eth/Kconfig +++ b/drivers/usb/eth/Kconfig @@ -62,4 +62,12 @@ config USB_ETHER_SMSC95XX Say Y here if you would like to support SMSC LAN95xx based USB 2.0 Ethernet Devices.
+config USB_ETHER_DM9601 + bool "Davicom DM96xx based USB 10/100 ethernet devices" + depends on USB_HOST_ETHER + depends on DM_ETH + ---help--- + This option adds support for Davicom DM9601/DM9620/DM9621A + based USB 10/100 Ethernet adapters. + endif diff --git a/drivers/usb/eth/Makefile b/drivers/usb/eth/Makefile index 2e5d0782e8..044b12f028 100644 --- a/drivers/usb/eth/Makefile +++ b/drivers/usb/eth/Makefile @@ -9,6 +9,7 @@ obj-$(CONFIG_USB_ETHER_ASIX) += asix.o obj-$(CONFIG_USB_ETHER_ASIX88179) += asix88179.o obj-$(CONFIG_USB_ETHER_MCS7830) += mcs7830.o obj-$(CONFIG_USB_ETHER_SMSC95XX) += smsc95xx.o +obj-$(CONFIG_USB_ETHER_DM9601) += dm9601.o obj-$(CONFIG_USB_ETHER_LAN75XX) += lan7x.o lan75xx.o obj-$(CONFIG_USB_ETHER_LAN78XX) += lan7x.o lan78xx.o obj-$(CONFIG_USB_ETHER_RTL8152) += r8152.o r8152_fw.o
You forgot to add the driver file.
hyyoxhk
