[U-Boot] [PATCH] i2c:mxc fix array size of i2c_data
We should not hardcode array size of i2c_data to 3. To CONFIG_FSL_LSCH3, there are 4 i2c interface, but not 3. So the size of i2c_data array should be calculated using "ARRAY_SIZE(i2c_bases)".
To avoid compile error, move i2c_bases before sram_data structure which contains i2c_data array.
Signed-off-by: Peng Fan Peng.Fan@freescale.com --- drivers/i2c/mxc_i2c.c | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 021b2fe..fc5ee35 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -402,17 +402,6 @@ int bus_i2c_write(void *base, uchar chip, uint addr, int alen, return ret; }
-struct i2c_parms { - void *base; - void *idle_bus_data; - int (*idle_bus_fn)(void *p); -}; - -struct sram_data { - unsigned curr_i2c_bus; - struct i2c_parms i2c_data[3]; -}; - static void * const i2c_bases[] = { #if defined(CONFIG_MX25) (void *)IMX_I2C_BASE, @@ -439,6 +428,17 @@ static void * const i2c_bases[] = { #endif };
+struct i2c_parms { + void *base; + void *idle_bus_data; + int (*idle_bus_fn)(void *p); +}; + +struct sram_data { + unsigned curr_i2c_bus; + struct i2c_parms i2c_data[ARRAY_SIZE(i2c_bases)]; +}; + void *i2c_get_base(struct i2c_adapter *adap) { return i2c_bases[adap->hwadapnr];
Hello Peng Fan,
Am 06.01.2015 07:12, schrieb Peng Fan:
Acked-by: Heiko Schocher hs@denx.de
@Stefano: Would you pick up this patch, or should I?
bye, Heiko
-struct i2c_parms {
- void *base;
-struct sram_data {
+struct i2c_parms {
- void *base;
+struct sram_data {
- struct i2c_parms i2c_data[ARRAY_SIZE(i2c_bases)];
- void *i2c_get_base(struct i2c_adapter *adap) { return i2c_bases[adap->hwadapnr];
Heiko Schocher
Peng Fan
