[U-Boot] [PATCH] 85xx: Enable the DDR3 SPD support for P2020DS board
* The ELPIDA 2GB unbuffered DDR3 SDRAM DIMMs - EBJ21EE8BAFA-AE-E 600MT/s, 667MT/s and 800MT/s passed on P2020DS * Micron 1GB unbuffered DDR3 SDRAM DIMMs - MT9JSF12872AY-1G4D1 600MT/s, 667MT/s and 800MT/s passed on P2020DS
Signed-off-by: Dave Liu daveliu@freescale.com Signed-off-by: Travis Wheatley Travis.Wheatley@freescale.com --- board/freescale/p2020ds/ddr.c | 34 ++++++++++++++++------------------ include/configs/P2020DS.h | 6 ++++-- 2 files changed, 20 insertions(+), 20 deletions(-)
diff --git a/board/freescale/p2020ds/ddr.c b/board/freescale/p2020ds/ddr.c index b9c0cb2..aaff6e8 100644 --- a/board/freescale/p2020ds/ddr.c +++ b/board/freescale/p2020ds/ddr.c @@ -51,27 +51,21 @@ typedef struct { * cpo 2-0x1E (30) */
- -/* XXX: these values need to be checked for all interleaving modes. */ -/* XXX: No reliable dual-rank 800 MHz setting has been found. It may - * seem reliable, but errors will appear when memory intensive - * program is run. */ -/* XXX: Single rank at 800 MHz is OK. */ const board_specific_parameters_t board_specific_parameters[][20] = { { /* memory controller 0 */ - /* lo| hi| num| clk| cpo|wrdata|2T */ - /* mhz| mhz|ranks|adjst| | delay| */ - { 0, 333, 2, 6, 7, 3, 0}, - {334, 400, 2, 6, 9, 3, 0}, - {401, 549, 2, 6, 11, 3, 0}, - {550, 680, 2, 1, 10, 5, 0}, - {681, 850, 2, 1, 12, 5, 1}, - { 0, 333, 1, 6, 7, 3, 0}, - {334, 400, 1, 6, 9, 3, 0}, - {401, 549, 1, 6, 11, 3, 0}, - {550, 680, 1, 1, 10, 5, 0}, - {681, 850, 1, 1, 12, 5, 0} + /* lo| hi| num| clk| cpo|wrdata|2T */ + /* mhz| mhz|ranks|adjst| | delay| */ + { 0, 333, 2, 4, 0x1f, 2, 0}, + {334, 400, 2, 4, 0x1f, 2, 0}, + {401, 549, 2, 4, 0x1f, 2, 0}, + {550, 680, 2, 4, 0x1f, 3, 0}, + {681, 850, 2, 4, 0x1f, 4, 0}, + { 0, 333, 1, 4, 0x1f, 2, 0}, + {334, 400, 1, 4, 0x1f, 2, 0}, + {401, 549, 1, 4, 0x1f, 2, 0}, + {550, 680, 1, 4, 0x1f, 3, 0}, + {681, 850, 1, 4, 0x1f, 4, 0} }, };
@@ -127,4 +121,8 @@ void fsl_ddr_board_options(memctl_options_t *popts, * - number of DIMMs installed */ popts->half_strength_driver_enable = 0; + /* + * Disable write leveling + */ + popts->wrlvl_en = 0; } diff --git a/include/configs/P2020DS.h b/include/configs/P2020DS.h index e4119e3..0564242 100644 --- a/include/configs/P2020DS.h +++ b/include/configs/P2020DS.h @@ -82,8 +82,8 @@ extern unsigned long calculate_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_NUM_ADDR_MAP 16 /* number of TLB1 entries */ #endif
-#define CONFIG_SYS_MEMTEST_START 0x00000000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x7fffffff +#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_PANIC_HANG /* do not reset board on panic */
/* @@ -121,6 +121,8 @@ extern unsigned long calculate_board_ddr_clk(unsigned long dummy); #define CONFIG_CHIP_SELECTS_PER_CTRL 2
/* I2C addresses of SPD EEPROMs */ +#define CONFIG_SPD_EEPROM +#define CONFIG_DDR_SPD #define CONFIG_SYS_SPD_BUS_NUM 0 /* SPD EEPROM located on I2C bus 0 */ #define SPD_EEPROM_ADDRESS1 0x51 /* CTLR 0 DIMM 0 */
Dear Andy & Kumar,
In message 1244849221-17692-1-git-send-email-daveliu@freescale.com Dave Liu wrote:
- The ELPIDA 2GB unbuffered DDR3 SDRAM DIMMs - EBJ21EE8BAFA-AE-E 600MT/s, 667MT/s and 800MT/s passed on P2020DS
- Micron 1GB unbuffered DDR3 SDRAM DIMMs - MT9JSF12872AY-1G4D1 600MT/s, 667MT/s and 800MT/s passed on P2020DS
Please check the status of this patch:
http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/61457
Dave Liu
