[PATCH v6 00/12] binman: rockchip: Migrate from rockchip SPL_FIT_GENERATOR script
At present rockchip 64-bit boards make use of a FIT-generator script written in Python. The script supports splitting an ELF file into several 'loadable' nodes in the FIT. Binman does not current support this feature.
This series adds binman support for ELF splitting. This works by adding a new 'fit,operation' property to the FIT subnodes, allowing this new way of generating nodes.
It also provides support for optional entries, by allowing them to be marked absent when the contents are obtained.
Some other fixes and improvements are needed along the way.
A new, common binman description is added for 64-bit boards which includes the required u-boot.itb file.
The existing script is removed, so that only a few zynq boards are now using a SPL_FIT_GENERATOR script:
avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0 xilinx_zynqmp_virt
Migration of those is hopefully in progress.
Note however that tools/k3_fit_atf.sh remains, used by a few boards that enable CONFIG_TI_SECURE_DEVICE so this series is copied there too:
am335x_hs_evm am335x_hs_evm_uart am43xx_hs_evm am57xx_hs_evm am57xx_hs_evm_usb am65x_hs_evm_a53 am65x_hs_evm_r5 dra7xx_hs_evm dra7xx_hs_evm_usb j721e_hs_evm_a72 j721e_hs_evm_r5 k2e_hs_evm k2g_hs_evm k2hk_hs_evm k2l_hs_evm
Ivan Mikhaylov has sent a patch to help with these, but I need to take a look at the testing side. In any case they should really be using binman for the image generation.
Changes in v6: - Add new patch to update entry docs - Add new patch to disable USE_SPL_FIT_GENERATOR by default - Add new patch to allow a binman entry to be marked absent - Update op-tee to support new v1 binary header
Changes in v5: - Update commit message to mention using parts of one image in another - Rename from 'Include binman script in 64-bit boards' - Drop duplicate #include in rk3368-u-boot.dtsi - Keep the name as fit for puma - Drop redundant check for CONFIG_ROCKCHIP_SPI_IMAGE - Drop imply of BINMAN in Kconfig (rely on ARCH_ROCKCHIP instead) - Rename blob to fit for puma and also SPI image
Changes in v3: - Add an offset to the FIT description - Add support for writing sections in binman - Rebase to master
Changes in v2: - Rename op-tee to tee-os - Drop use of .itb2 - Drop patches previously applied - Add various suggestions from Alper Nebi Yasak - Add patches to refactor binman's FIT support
Simon Glass (12): binman: Allow writing section contents to a file binman: Tidy up comment in fit _gen_node binman: Update entry docs binman: Support optional entries binman: Add a way to check for a valid ELF file binman: Support new op-tee binary format rockchip: evb-rk3288: Drop raw-image support rockchip: Use multiple-images for rk3399 rockchip: Support building the all output files in binman rockchip: Convert all boards to use binman rockchip: Drop the FIT generator script treewide: Disable USE_SPL_FIT_GENERATOR by default
Makefile | 11 +- arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi | 4 +- arch/arm/dts/rk3399-u-boot.dtsi | 3 +- arch/arm/dts/rockchip-u-boot.dtsi | 76 ++++- arch/arm/mach-rockchip/make_fit_atf.py | 267 ------------------ boot/Kconfig | 6 +- configs/am335x_evm_defconfig | 1 - configs/am335x_hs_evm_defconfig | 1 - configs/am335x_hs_evm_uart_defconfig | 1 - configs/am43xx_evm_defconfig | 1 - configs/am43xx_evm_rtconly_defconfig | 1 - configs/am43xx_evm_usbhost_boot_defconfig | 1 - configs/am43xx_hs_evm_defconfig | 1 - configs/am57xx_evm_defconfig | 1 - configs/am57xx_hs_evm_defconfig | 1 - configs/am57xx_hs_evm_usb_defconfig | 1 - configs/am65x_evm_a53_defconfig | 1 - configs/am65x_evm_r5_defconfig | 1 - configs/am65x_hs_evm_a53_defconfig | 1 - configs/am65x_hs_evm_r5_defconfig | 1 - ...edev_cc_v1_0_ultrazedev_som_v1_0_defconfig | 1 + configs/cgtqmx8_defconfig | 1 - configs/chromebook_link64_defconfig | 1 - configs/dh_imx6_defconfig | 1 - configs/display5_defconfig | 1 - configs/display5_factory_defconfig | 1 - configs/dra7xx_evm_defconfig | 1 - configs/dra7xx_hs_evm_defconfig | 1 - configs/dra7xx_hs_evm_usb_defconfig | 1 - configs/evb-ast2600_defconfig | 1 - configs/evb-rk3229_defconfig | 1 - configs/evb-rk3288_defconfig | 2 +- configs/gwventana_emmc_defconfig | 1 - configs/gwventana_gw5904_defconfig | 1 - configs/gwventana_nand_defconfig | 1 - configs/imx6qdl_icore_mipi_defconfig | 1 - configs/imx6qdl_icore_mmc_defconfig | 1 - configs/imx6qdl_icore_rqs_defconfig | 1 - configs/imx8mm-cl-iot-gate-optee_defconfig | 1 - configs/imx8mm-cl-iot-gate_defconfig | 1 - configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 1 - configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 1 - configs/imx8mm-mx8menlo_defconfig | 1 - configs/imx8mm_beacon_defconfig | 1 - configs/imx8mm_data_modul_edm_sbc_defconfig | 1 - configs/imx8mm_evk_defconfig | 1 - configs/imx8mm_evk_fspi_defconfig | 1 - configs/imx8mm_venice_defconfig | 1 - configs/imx8mn_beacon_2g_defconfig | 1 - configs/imx8mn_beacon_defconfig | 1 - configs/imx8mn_bsh_smm_s2_defconfig | 1 - configs/imx8mn_bsh_smm_s2pro_defconfig | 1 - configs/imx8mn_ddr4_evk_defconfig | 1 - configs/imx8mn_evk_defconfig | 1 - configs/imx8mn_var_som_defconfig | 1 - configs/imx8mn_venice_defconfig | 1 - configs/imx8mp-icore-mx8mp-edimm2.2_defconfig | 1 - configs/imx8mp_dhcom_pdk2_defconfig | 1 - configs/imx8mp_evk_defconfig | 1 - configs/imx8mp_rsb3720a1_4G_defconfig | 1 - configs/imx8mp_rsb3720a1_6G_defconfig | 1 - configs/imx8mp_venice_defconfig | 1 - configs/imx8mq_cm_defconfig | 1 - configs/imx8mq_evk_defconfig | 1 - configs/imx8mq_phanbell_defconfig | 1 - configs/imx8qm_rom7720_a1_4G_defconfig | 1 - configs/iot2050_defconfig | 1 - configs/j7200_evm_a72_defconfig | 1 - configs/j7200_evm_r5_defconfig | 1 - configs/j7200_hs_evm_a72_defconfig | 1 - configs/j7200_hs_evm_r5_defconfig | 1 - configs/j721e_evm_a72_defconfig | 1 - configs/j721e_evm_r5_defconfig | 1 - configs/j721e_hs_evm_a72_defconfig | 1 - configs/j721e_hs_evm_r5_defconfig | 1 - configs/j721s2_evm_a72_defconfig | 1 - configs/j721s2_evm_r5_defconfig | 1 - configs/j721s2_hs_evm_a72_defconfig | 1 - configs/j721s2_hs_evm_r5_defconfig | 1 - configs/kontron-sl-mx6ul_defconfig | 1 - configs/kontron-sl-mx8mm_defconfig | 1 - configs/kontron_pitx_imx8m_defconfig | 1 - configs/kontron_sl28_defconfig | 1 - configs/librem5_defconfig | 1 - configs/ls1046ardb_qspi_spl_defconfig | 1 - configs/mccmon6_nor_defconfig | 1 - configs/mccmon6_sd_defconfig | 1 - configs/mx6sabreauto_defconfig | 1 - configs/mx6sabresd_defconfig | 1 - configs/phycore-imx8mm_defconfig | 1 - configs/phycore-imx8mp_defconfig | 1 - configs/pico-imx6_defconfig | 1 - configs/pico-imx8mq_defconfig | 1 - configs/qemu-x86_64_defconfig | 1 - configs/sandbox_noinst_defconfig | 1 - configs/sandbox_spl_defconfig | 1 - configs/sandbox_vpl_defconfig | 1 - configs/socfpga_agilex_atf_defconfig | 1 - configs/socfpga_agilex_vab_defconfig | 1 - configs/socfpga_arria10_defconfig | 1 - configs/socfpga_chameleonv3_defconfig | 1 - configs/socfpga_n5x_atf_defconfig | 1 - configs/socfpga_n5x_vab_defconfig | 1 - configs/socfpga_stratix10_atf_defconfig | 1 - configs/stm32mp15_dhcom_basic_defconfig | 1 - configs/stm32mp15_dhcor_basic_defconfig | 1 - configs/verdin-imx8mm_defconfig | 1 - configs/verdin-imx8mp_defconfig | 1 - configs/wandboard_defconfig | 1 - configs/xilinx_zynq_virt_defconfig | 1 - configs/xilinx_zynqmp_virt_defconfig | 1 + tools/binman/binman.rst | 27 ++ tools/binman/control.py | 1 + tools/binman/elf.py | 16 ++ tools/binman/elf_test.py | 10 + tools/binman/entries.rst | 222 +++++++++++++-- tools/binman/entry.py | 22 ++ tools/binman/etype/_testing.py | 3 + tools/binman/etype/fit.py | 85 +++--- tools/binman/etype/section.py | 28 +- tools/binman/etype/tee_os.py | 70 ++++- tools/binman/ftest.py | 63 +++++ tools/binman/image.py | 3 - tools/binman/test/261_section_fname.dts | 29 ++ tools/binman/test/262_absent.dts | 20 ++ tools/binman/test/263_tee_os_opt.dts | 22 ++ tools/binman/test/264_tee_os_opt_fit.dts | 33 +++ 127 files changed, 670 insertions(+), 457 deletions(-) delete mode 100755 arch/arm/mach-rockchip/make_fit_atf.py create mode 100644 tools/binman/test/261_section_fname.dts create mode 100644 tools/binman/test/262_absent.dts create mode 100644 tools/binman/test/263_tee_os_opt.dts create mode 100644 tools/binman/test/264_tee_os_opt_fit.dts
At present only the image (which is a section) has a filename. Move this implementation to the entry_Section class so that any section can have a filename. With this, the section data is written to a file.
This allows parts of an image to be written, along with the entire image.
Make a note that this can be used to include the contents of a section in one image in another (later) image.
(no changes since v5)
tools/binman/binman.rst | 5 +++++ tools/binman/etype/section.py | 12 +++++++++- tools/binman/ftest.py | 14 ++++++++++++ tools/binman/image.py | 3 --- tools/binman/test/261_section_fname.dts | 29 +++++++++++++++++++++++++ 5 files changed, 59 insertions(+), 4 deletions(-) create mode 100644 tools/binman/test/261_section_fname.dts
diff --git a/tools/binman/binman.rst b/tools/binman/binman.rst index e7b231e0712..b091114fb91 100644 --- a/tools/binman/binman.rst +++ b/tools/binman/binman.rst @@ -836,6 +836,11 @@ name-prefix: renamed to 'ro-u-boot' and 'rw-u-boot'. This can be useful to distinguish binaries with otherwise identical names.
+filename: + This allows the contents of the section to be written to a file in the + output directory. This can sometimes be useful to use the data in one + section in different image, since there is currently no way to share data + beteen images other than through files.
Image Properties ---------------- diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index da561e2bcc7..305155c8461 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -144,6 +144,10 @@ class Entry_section(Entry): be written at offset 4 in the image file, since the first 16 bytes are skipped when writing.
+ filename + filename to write the unpadded section contents to within the output + directory (None to skip this). + Since a section is also an entry, it inherits all the properies of entries too.
@@ -163,6 +167,7 @@ class Entry_section(Entry): self._skip_at_start = None self._end_4gb = False self._ignore_missing = False + self._filename = None
def ReadNode(self): """Read properties from the section node""" @@ -183,6 +188,8 @@ class Entry_section(Entry): self._skip_at_start = 0 self._name_prefix = fdt_util.GetString(self._node, 'name-prefix') self.align_default = fdt_util.GetInt(self._node, 'align-default', 0) + self._filename = fdt_util.GetString(self._node, 'filename', + self._filename)
self.ReadEntries()
@@ -348,7 +355,8 @@ class Entry_section(Entry): """Get the contents of an entry
This builds the contents of the section, stores this as the contents of - the section and returns it + the section and returns it. If the section has a filename, the data is + written there also.
Args: required: True if the data must be present, False if it is OK to @@ -363,6 +371,8 @@ class Entry_section(Entry): if data is None: return None self.SetContents(data) + if self._filename: + tools.write_file(tools.get_output_filename(self._filename), data) return data
def GetOffsets(self): diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 62ee86b9b75..c3cb32dca26 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -6077,5 +6077,19 @@ fdt fdtmap Extract the devicetree blob from the fdtmap 'Cannot write symbols to an ELF file without Python elftools', str(exc.exception))
+ def testSectionFilename(self): + """Check writing of section contents to a file""" + data = self._DoReadFile('261_section_fname.dts') + expected = (b'&&' + U_BOOT_DATA + b'&&&' + + tools.get_bytes(ord('!'), 7) + + U_BOOT_DATA + tools.get_bytes(ord('&'), 12)) + self.assertEqual(expected, data) + + sect_fname = tools.get_output_filename('outfile.bin') + self.assertTrue(os.path.exists(sect_fname)) + sect_data = tools.read_file(sect_fname) + self.assertEqual(U_BOOT_DATA, sect_data) + + if __name__ == "__main__": unittest.main() diff --git a/tools/binman/image.py b/tools/binman/image.py index 6d4bff58436..b84dd21e22a 100644 --- a/tools/binman/image.py +++ b/tools/binman/image.py @@ -94,9 +94,6 @@ class Image(section.Entry_section):
def ReadNode(self): super().ReadNode() - filename = fdt_util.GetString(self._node, 'filename') - if filename: - self._filename = filename self.allow_repack = fdt_util.GetBool(self._node, 'allow-repack') self._symlink = fdt_util.GetString(self._node, 'symlink')
diff --git a/tools/binman/test/261_section_fname.dts b/tools/binman/test/261_section_fname.dts new file mode 100644 index 00000000000..790381e7301 --- /dev/null +++ b/tools/binman/test/261_section_fname.dts @@ -0,0 +1,29 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + pad-byte = <0x26>; + size = <0x20>; + section@0 { + size = <0x10>; + pad-byte = <0x21>; + pad-before = <2>; + pad-after = <3>; + + section { + filename = "outfile.bin"; + u-boot { + }; + }; + }; + section@1 { + u-boot { + }; + }; + }; +};
Expand this comment to cover both cases that are supported.
(no changes since v1)
tools/binman/etype/fit.py | 16 +++++++++++----- 1 file changed, 11 insertions(+), 5 deletions(-)
diff --git a/tools/binman/etype/fit.py b/tools/binman/etype/fit.py index 7860e2aeea3..8ad4f3a8a83 100644 --- a/tools/binman/etype/fit.py +++ b/tools/binman/etype/fit.py @@ -579,11 +579,17 @@ class Entry_fit(Entry_section): def _gen_node(base_node, node, depth, in_images, entry): """Generate nodes from a template
- This creates one node for each member of self._fdts using the - provided template. If a property value contains 'NAME' it is - replaced with the filename of the FDT. If a property value contains - SEQ it is replaced with the node sequence number, where 1 is the - first. + This creates one or more nodes depending on the fit,operation being + used. + + For OP_GEN_FDT_NODES it creates one node for each member of + self._fdts using the provided template. If a property value contains + 'NAME' it is replaced with the filename of the FDT. If a property + value contains SEQ it is replaced with the node sequence number, + where 1 is the first. + + For OP_SPLIT_ELF it emits one node for each section in the ELF file. + If the file is missing, nothing is generated.
Args: base_node (Node): Base Node of the FIT (with 'description'
These have got out of data recently. Regenerate them.
tools/binman/entries.rst | 187 ++++++++++++++++++++++++++++++++++----- 1 file changed, 163 insertions(+), 24 deletions(-)
diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index 3dc32db8a54..ec7465d0127 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -216,9 +216,9 @@ This is a blob containing a device tree. The contents of the blob are obtained from the list of available device-tree files, managed by the 'state' module.
-Additional Properties / Entry arguments: - - prepend: Header type to use: - length: 32-bit length header +Additional attributes: + prepend: Header used (e.g. 'length') +
.. _etype_blob_ext: @@ -1178,11 +1178,13 @@ Properties / Entry arguments: - multiple-data-files: boolean to tell binman to pass all files as datafiles to mkimage instead of creating a temporary file the result of datafiles concatenation + - filename: filename of output binary generated by mkimage
The data passed to mkimage via the -d flag is collected from subnodes of the mkimage node, e.g.::
mkimage { + filename = "imximage.bin"; args = "-n test -T imximage";
u-boot-spl { @@ -1190,13 +1192,14 @@ mkimage node, e.g.:: };
This calls mkimage to create an imximage with `u-boot-spl.bin` as the data -file, which mkimage being called like this:: +file, with mkimage being called like this::
mkimage -d <data_file> -n test -T imximage <output_file>
The output from mkimage then becomes part of the image produced by -binman. If you need to put mulitple things in the data file, you can use -a section, or just multiple subnodes like this:: +binman but also is written into `imximage.bin` file. If you need to put +multiple things in the data file, you can use a section, or just multiple +subnodes like this::
mkimage { args = "-n test -T imximage"; @@ -1208,24 +1211,27 @@ a section, or just multiple subnodes like this:: }; };
-To pass all datafiles untouched to mkimage:: +Note that binman places the contents (here SPL and TPL) into a single file +and passes that to mkimage using the -d option.
- mkimage { - args = "-n rk3399 -T rkspi"; - multiple-data-files; +pass all datafiles untouched to mkimage::
- u-boot-tpl { - }; +image { +rgs = "-n rk3399 -T rkspi"; +ultiple-data-files;
- u-boot-spl { - }; - }; +-boot-tpl { +;
-This calls mkimage to create a Rockchip RK3399-specific first stage -bootloader, made of TPL+SPL. Since this first stage bootloader requires to -align the TPL and SPL but also some weird hacks that is handled by mkimage -directly, binman is told to not perform the concatenation of datafiles prior -to passing the data to mkimage. +-boot-spl { +; + + +s calls mkimage to create a Rockchip RK3399-specific first stage +tloader, made of TPL+SPL. Since this first stage bootloader requires to +gn the TPL and SPL but also some weird hacks that is handled by mkimage +ectly, binman is told to not perform the concatenation of datafiles prior +passing the data to mkimage.
To use CONFIG options in the arguments, use a string list instead, as in this example which also produces four arguments:: @@ -1242,17 +1248,17 @@ the 'data-to-imagename' property::
mkimage { args = "-T imximage"; - data-to-imagename'; + data-to-imagename;
u-boot-spl { }; };
That will pass the data to mkimage both as the data file (with -d) and as -the image name (with -n). - +the image name (with -n). In both cases, a filename is passed as the +argument, with the actual data being in that file.
-If need to pass different data in with -n, then use an imagename subnode:: +If need to pass different data in with -n, then use an `imagename` subnode::
mkimage { args = "-T imximage"; @@ -1271,6 +1277,7 @@ This will pass in u-boot-spl as the input data and the .cfgout file as the -n data.
+ .. _etype_opensbi:
Entry: opensbi: RISC-V OpenSBI fw_dynamic blob @@ -1478,6 +1485,10 @@ skip-at-start be written at offset 4 in the image file, since the first 16 bytes are skipped when writing.
+filename + filename to write the unpadded section contents to within the output + directory (None to skip this). + Since a section is also an entry, it inherits all the properies of entries too.
@@ -2034,6 +2045,134 @@ Entry types that have a part to play in handling microcode:
+.. _etype_u_boot_vpl: + +Entry: u-boot-vpl: U-Boot VPL binary +------------------------------------ + +Properties / Entry arguments: + - filename: Filename of u-boot-vpl.bin (default 'vpl/u-boot-vpl.bin') + +This is the U-Boot VPL (Verifying Program Loader) binary. This is a small +binary which loads before SPL, typically into on-chip SRAM. It is +responsible for locating, loading and jumping to SPL, the next-stage +loader. Note that VPL is not relocatable so must be loaded to the correct +address in SRAM, or written to run from the correct address if direct +flash execution is possible (e.g. on x86 devices). + +SPL can access binman symbols at runtime. See: + + 'Access to binman entry offsets at run time (symbols)' + +in the binman README for more information. + +The ELF file 'vpl/u-boot-vpl' must also be available for this to work, since +binman uses that to look up symbols to write into the VPL binary. + + + +.. _etype_u_boot_vpl_bss_pad: + +Entry: u-boot-vpl-bss-pad: U-Boot VPL binary padded with a BSS region +--------------------------------------------------------------------- + +Properties / Entry arguments: + None + +This holds the padding added after the VPL binary to cover the BSS (Block +Started by Symbol) region. This region holds the various variables used by +VPL. It is set to 0 by VPL when it starts up. If you want to append data to +the VPL image (such as a device tree file), you must pad out the BSS region +to avoid the data overlapping with U-Boot variables. This entry is useful in +that case. It automatically pads out the entry size to cover both the code, +data and BSS. + +The contents of this entry will a certain number of zero bytes, determined +by __bss_size + +The ELF file 'vpl/u-boot-vpl' must also be available for this to work, since +binman uses that to look up the BSS address. + + + +.. _etype_u_boot_vpl_dtb: + +Entry: u-boot-vpl-dtb: U-Boot VPL device tree +--------------------------------------------- + +Properties / Entry arguments: + - filename: Filename of u-boot.dtb (default 'vpl/u-boot-vpl.dtb') + +This is the VPL device tree, containing configuration information for +VPL. VPL needs this to know what devices are present and which drivers +to activate. + + + +.. _etype_u_boot_vpl_elf: + +Entry: u-boot-vpl-elf: U-Boot VPL ELF image +------------------------------------------- + +Properties / Entry arguments: + - filename: Filename of VPL u-boot (default 'vpl/u-boot-vpl') + +This is the U-Boot VPL ELF image. It does not include a device tree but can +be relocated to any address for execution. + + + +.. _etype_u_boot_vpl_expanded: + +Entry: u-boot-vpl-expanded: U-Boot VPL flat binary broken out into its component parts +-------------------------------------------------------------------------------------- + +Properties / Entry arguments: + - vpl-dtb: Controls whether this entry is selected (set to 'y' or '1' to + select) + +This is a section containing the U-Boot binary, BSS padding if needed and a +devicetree. Using this entry type automatically creates this section, with +the following entries in it: + + u-boot-vpl-nodtb + u-boot-vpl-bss-pad + u-boot-dtb + +Having the devicetree separate allows binman to update it in the final +image, so that the entries positions are provided to the running U-Boot. + +This entry is selected based on the value of the 'vpl-dtb' entryarg. If +this is non-empty (and not 'n' or '0') then this expanded entry is selected. + + + +.. _etype_u_boot_vpl_nodtb: + +Entry: u-boot-vpl-nodtb: VPL binary without device tree appended +---------------------------------------------------------------- + +Properties / Entry arguments: + - filename: Filename to include (default 'vpl/u-boot-vpl-nodtb.bin') + +This is the U-Boot VPL binary, It does not include a device tree blob at +the end of it so may not be able to work without it, assuming VPL needs +a device tree to operate on your platform. You can add a u_boot_vpl_dtb +entry after this one, or use a u_boot_vpl entry instead, which normally +expands to a section containing u-boot-vpl-dtb, u-boot-vpl-bss-pad and +u-boot-vpl-dtb + +VPL can access binman symbols at runtime. See: + + 'Access to binman entry offsets at run time (symbols)' + +in the binman README for more information. + +The ELF file 'vpl/u-boot-vpl' must also be available for this to work, since +binman uses that to look up symbols to write into the VPL binary. + + + .. _etype_u_boot_with_ucode_ptr:
Entry: u-boot-with-ucode-ptr: U-Boot with embedded microcode pointer
Support entries which can be optional depending on their contents. This allows special entry types which appear in the image only when needed.
tools/binman/binman.rst | 22 ++++++++++++++++++++++ tools/binman/control.py | 1 + tools/binman/entry.py | 9 +++++++++ tools/binman/etype/_testing.py | 3 +++ tools/binman/etype/section.py | 7 +++++++ tools/binman/ftest.py | 5 +++++ tools/binman/test/262_absent.dts | 20 ++++++++++++++++++++ 7 files changed, 67 insertions(+) create mode 100644 tools/binman/test/262_absent.dts
diff --git a/tools/binman/binman.rst b/tools/binman/binman.rst index b091114fb91..1ab6d012b83 100644 --- a/tools/binman/binman.rst +++ b/tools/binman/binman.rst @@ -1012,6 +1012,28 @@ For the BSS case, a 'spl-bss-pad' entry arg controls whether it is present. All entry args are provided by the U-Boot Makefile.
+Optional entries +---------------- + +Some entries need to exist only if certain conditions are met. For example, an +entry may want to appear in the image only if a file has a particular format. +Obviously the entry must exist in the image description for it to be processed +at all, so a way needs to be found to have the entry remove itself. + +To handle this, when entry.ObtainContents() is called, the entry can call +entry.mark_absent() to mark itself as absent, passing a suitable message as the +reason. + +Any absent entries are dropped immediately after ObtainContents() has been +called on all entries. + +It is not possible for an entry to mark itself absent at any other point in the +processing. It must happen in the ObtainContents() method. + +The effect is as if the entry had never been present at all, since the image +is packed without it and it disappears from the list of entries. + + Compression -----------
diff --git a/tools/binman/control.py b/tools/binman/control.py index 964c6984f9b..07225381146 100644 --- a/tools/binman/control.py +++ b/tools/binman/control.py @@ -552,6 +552,7 @@ def ProcessImage(image, update_fdt, write_map, get_contents=True, image.SetAllowMissing(allow_missing) image.SetAllowFakeBlob(allow_fake_blobs) image.GetEntryContents() + image.drop_absent() image.GetEntryOffsets()
# We need to pack the entries to figure out where everything diff --git a/tools/binman/entry.py b/tools/binman/entry.py index 1be31a05e00..637aece3705 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -91,6 +91,10 @@ class Entry(object): file, or is a binary file produced from an ELF file auto_write_symbols (bool): True to write ELF symbols into this entry's contents + absent (bool): True if this entry is absent. This can be controlled by + the entry itself, allowing it to vanish in certain circumstances. + An absent entry is removed during processing so that it does not + appear in the map """ fake_dir = None
@@ -133,6 +137,7 @@ class Entry(object): self.comp_bintool = None self.elf_fname = None self.auto_write_symbols = auto_write_symbols + self.absent = False
@staticmethod def FindEntryClass(etype, expanded): @@ -1281,3 +1286,7 @@ features to produce new behaviours. not_present.append(prop) if not_present: self.Raise(f"'{self.etype}' entry is missing properties: {' '.join(not_present)}") + + def mark_absent(self, msg): + tout.info("Entry '%s' marked absent: %s" % (self._node.path, msg)) + self.absent = True diff --git a/tools/binman/etype/_testing.py b/tools/binman/etype/_testing.py index 69600487814..1c1efb21a44 100644 --- a/tools/binman/etype/_testing.py +++ b/tools/binman/etype/_testing.py @@ -63,6 +63,7 @@ class Entry__testing(Entry): 'bad-update-contents-twice') self.return_contents_later = fdt_util.GetBool(self._node, 'return-contents-later') + self.set_to_absent = fdt_util.GetBool(self._node, 'set-to-absent')
# Set to True when the entry is ready to process the FDT. self.process_fdt_ready = False @@ -119,6 +120,8 @@ class Entry__testing(Entry): if self.require_bintool_for_contents: if self.bintool_for_contents is None: self.Raise("Required bintool unusable in ObtainContents()") + if self.set_to_absent: + self.mark_absent('for testing purposes') return True
def GetOffsets(self): diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index 305155c8461..dcb7a062047 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -672,6 +672,9 @@ class Entry_section(Entry):
def GetEntryContents(self, skip_entry=None): """Call ObtainContents() for each entry in the section + + Note that this may set entry.absent to True if the entry is not + actually needed """ def _CheckDone(entry): if entry != skip_entry: @@ -716,6 +719,10 @@ class Entry_section(Entry): todo) return True
+ def drop_absent(self): + """Drop entries which are absent""" + self._entries = {n: e for n, e in self._entries.items() if not e.absent} + def _SetEntryOffsetSize(self, name, offset, size): """Set the offset and size of an entry
diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index c3cb32dca26..f47a745f1e1 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -6090,6 +6090,11 @@ fdt fdtmap Extract the devicetree blob from the fdtmap sect_data = tools.read_file(sect_fname) self.assertEqual(U_BOOT_DATA, sect_data)
+ def testAbsent(self): + """Check handling of absent entries""" + data = self._DoReadFile('262_absent.dts') + self.assertEqual(U_BOOT_DATA + U_BOOT_IMG_DATA, data) +
if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/262_absent.dts b/tools/binman/test/262_absent.dts new file mode 100644 index 00000000000..2ab8766c878 --- /dev/null +++ b/tools/binman/test/262_absent.dts @@ -0,0 +1,20 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + }; + + _testing { + set-to-absent; + }; + + u-boot-img { + }; + }; +};
Add a function which checks whether data is in ELF format or not. This will be used by binman to check this for entries.
tools/binman/elf.py | 16 ++++++++++++++++ tools/binman/elf_test.py | 10 ++++++++++ 2 files changed, 26 insertions(+)
diff --git a/tools/binman/elf.py b/tools/binman/elf.py index fe50bf542c3..2f4b7d1a08e 100644 --- a/tools/binman/elf.py +++ b/tools/binman/elf.py @@ -21,6 +21,7 @@ ELF_TOOLS = True try: from elftools.elf.elffile import ELFFile from elftools.elf.elffile import ELFError + import elftools from elftools.elf.sections import SymbolTableSection except: # pragma: no cover ELF_TOOLS = False @@ -518,3 +519,18 @@ def read_loadable_segments(data): rend = start + segment['p_filesz'] segments.append((i, segment['p_paddr'], data[start:rend])) return segments, entry + +def is_valid(data): + """Check if some binary data is a valid ELF file + + Args: + data (bytes): Bytes to check + + Returns: + bool: True if a valid Elf file, False if not + """ + try: + DecodeElf(data, 0) + return True + except elftools.common.exceptions.ELFError: + return False diff --git a/tools/binman/elf_test.py b/tools/binman/elf_test.py index 75b867c2be8..082a3e1d28c 100644 --- a/tools/binman/elf_test.py +++ b/tools/binman/elf_test.py @@ -348,6 +348,16 @@ class TestElf(unittest.TestCase): finally: elf.ELF_TOOLS = old_val
+ def test_is_valid(self): + """Test is_valid()""" + self.assertEqual(False, elf.is_valid(b'')) + self.assertEqual(False, elf.is_valid(b'1234')) + + fname = self.ElfTestFile('elf_sections') + data = tools.read_file(fname) + self.assertEqual(True, elf.is_valid(data)) + self.assertEqual(False, elf.is_valid(data[4:])) +
if __name__ == '__main__': unittest.main()
OP-TEE has a format with a binary header that can be used instead of the ELF file. With newer versions of OP-TEE this may be required on some platforms.
Add support for this in binman. First, add a method to obtain the ELF sections from an entry, then use that in the FIT support. We then end up with the ability to support both types of OP-TEE files, depending on which one is passed in with the entry argument (TEE=xxx in the U-Boot build).
tools/binman/entries.rst | 35 +++++++++++- tools/binman/entry.py | 13 +++++ tools/binman/etype/fit.py | 69 +++++++++++++---------- tools/binman/etype/section.py | 9 +++ tools/binman/etype/tee_os.py | 70 +++++++++++++++++++++++- tools/binman/ftest.py | 44 +++++++++++++++ tools/binman/test/263_tee_os_opt.dts | 22 ++++++++ tools/binman/test/264_tee_os_opt_fit.dts | 33 +++++++++++ 8 files changed, 263 insertions(+), 32 deletions(-) create mode 100644 tools/binman/test/263_tee_os_opt.dts create mode 100644 tools/binman/test/264_tee_os_opt_fit.dts
diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index ec7465d0127..277ca6aafd7 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1508,12 +1508,45 @@ Entry: tee-os: Entry containing an OP-TEE Trusted OS (TEE) blob
Properties / Entry arguments: - tee-os-path: Filename of file to read into entry. This is typically - called tee-pager.bin + called tee.bin or tee.elf
This entry holds the run-time firmware, typically started by U-Boot SPL. See the U-Boot README for your architecture or board for how to use it. See https://github.com/OP-TEE/optee_os for more information about OP-TEE.
+Note that if the file is in ELF format, it must go in a FIT. In that case, +this entry will mark itself as absent, providing the data only through the +read_elf_segments() method. + +Marking this entry as absent means that it if is used in the wrong context +it can be automatically dropped. Thus it is possible to add anb OP-TEE entry +like this:: + + binman { + tee-os { + }; + }; + +and pass either an ELF or plain binary in with -a tee-os-path <filename> +and have binman do the right thing: + + - include the entry if tee.bin is provided and it doesn't have the v1 + header + - drop it otherwise + +When used within a FIT, we can do:: + + binman { + fit { + tee-os { + }; + }; + }; + +which will split the ELF into separate nodes for each segment, if an ELF +file is provide (see Flat Image Tree / FIT), or produce a single node if +the binary v1 format is provided. +
.. _etype_text: diff --git a/tools/binman/entry.py b/tools/binman/entry.py index 637aece3705..de51d295891 100644 --- a/tools/binman/entry.py +++ b/tools/binman/entry.py @@ -1290,3 +1290,16 @@ features to produce new behaviours. def mark_absent(self, msg): tout.info("Entry '%s' marked absent: %s" % (self._node.path, msg)) self.absent = True + + def read_elf_segments(self): + """Read segments from an entry that can generate an ELF file + + Returns: + tuple: + list of segments, each: + int: Segment number (0 = first) + int: Start address of segment in memory + bytes: Contents of segment + int: entry address of ELF file + """ + return None diff --git a/tools/binman/etype/fit.py b/tools/binman/etype/fit.py index 8ad4f3a8a83..21c769a1cbe 100644 --- a/tools/binman/etype/fit.py +++ b/tools/binman/etype/fit.py @@ -540,41 +540,34 @@ class Entry_fit(Entry_section): else: self.Raise("Generator node requires 'fit,fdt-list' property")
- def _gen_split_elf(base_node, node, elf_data, missing): + def _gen_split_elf(base_node, node, segments, entry_addr): """Add nodes for the ELF file, one per group of contiguous segments
Args: base_node (Node): Template node from the binman definition node (Node): Node to replace (in the FIT being built) - data (bytes): ELF-format data to process (may be empty) - missing (bool): True if any of the data is missing
+ segments, entry_addr + + data (bytes): ELF-format data to process (may be empty) """ - # If any pieces are missing, skip this. The missing entries will - # show an error - if not missing: - try: - segments, entry = elf.read_loadable_segments(elf_data) - except ValueError as exc: - self._raise_subnode(node, - f'Failed to read ELF file: {str(exc)}') - for (seq, start, data) in segments: - node_name = node.name[1:].replace('SEQ', str(seq + 1)) - with fsw.add_node(node_name): - loadables.append(node_name) - for pname, prop in node.props.items(): - if not pname.startswith('fit,'): - fsw.property(pname, prop.bytes) - elif pname == 'fit,load': - fsw.property_u32('load', start) - elif pname == 'fit,entry': - if seq == 0: - fsw.property_u32('entry', entry) - elif pname == 'fit,data': - fsw.property('data', bytes(data)) - elif pname != 'fit,operation': - self._raise_subnode( - node, f"Unknown directive '{pname}'") + for (seq, start, data) in segments: + node_name = node.name[1:].replace('SEQ', str(seq + 1)) + with fsw.add_node(node_name): + loadables.append(node_name) + for pname, prop in node.props.items(): + if not pname.startswith('fit,'): + fsw.property(pname, prop.bytes) + elif pname == 'fit,load': + fsw.property_u32('load', start) + elif pname == 'fit,entry': + if seq == 0: + fsw.property_u32('entry', entry_addr) + elif pname == 'fit,data': + fsw.property('data', bytes(data)) + elif pname != 'fit,operation': + self._raise_subnode( + node, f"Unknown directive '{pname}'")
def _gen_node(base_node, node, depth, in_images, entry): """Generate nodes from a template @@ -598,6 +591,8 @@ class Entry_fit(Entry_section): depth (int): Current node depth (0 is the base 'fit' node) in_images (bool): True if this is inside the 'images' node, so that 'data' properties should be generated + entry (entry_Section): Entry for the second containing the + contents of this node """ oper = self._get_operation(base_node, node) if oper == OP_GEN_FDT_NODES: @@ -609,10 +604,24 @@ class Entry_fit(Entry_section): missing_list = [] entry.ObtainContents() entry.Pack(0) - data = entry.GetData() entry.CheckMissing(missing_list)
- _gen_split_elf(base_node, node, data, bool(missing_list)) + # If any pieces are missing, skip this. The missing entries will + # show an error + if not missing_list: + segs = entry.read_elf_segments() + if segs: + segments, entry_addr = segs + else: + elf_data = entry.GetData() + try: + segments, entry_addr = ( + elf.read_loadable_segments(elf_data)) + except ValueError as exc: + self._raise_subnode( + node, f'Failed to read ELF file: {str(exc)}') + + _gen_split_elf(base_node, node, segments, entry_addr)
def _add_node(base_node, depth, node): """Add nodes to the output FIT diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index dcb7a062047..57bfee0b286 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -948,3 +948,12 @@ class Entry_section(Entry): super().AddBintools(btools) for entry in self._entries.values(): entry.AddBintools(btools) + + def read_elf_segments(self): + entries = self.GetEntries() + + # If the section only has one entry, see if it can provide ELF segments + if len(entries) == 1: + for entry in entries.values(): + return entry.read_elf_segments() + return None diff --git a/tools/binman/etype/tee_os.py b/tools/binman/etype/tee_os.py index 6ce4b672de4..a7c95812cd7 100644 --- a/tools/binman/etype/tee_os.py +++ b/tools/binman/etype/tee_os.py @@ -4,19 +4,87 @@ # Entry-type module for OP-TEE Trusted OS firmware blob #
+import struct + from binman.etype.blob_named_by_arg import Entry_blob_named_by_arg +from binman import elf
class Entry_tee_os(Entry_blob_named_by_arg): """Entry containing an OP-TEE Trusted OS (TEE) blob
This entry holds the run-time firmware, typically started by U-Boot SPL. See the U-Boot README for your architecture or board for how to use it. See https://github.com/OP-TEE/optee_os for more information about OP-TEE. + + Note that if the file is in ELF format, it must go in a FIT. In that case, + this entry will mark itself as absent, providing the data only through the + read_elf_segments() method. + + Marking this entry as absent means that it if is used in the wrong context + it can be automatically dropped. Thus it is possible to add anb OP-TEE entry + like this:: + + binman { + tee-os { + }; + }; + + and pass either an ELF or plain binary in with -a tee-os-path <filename> + and have binman do the right thing: + + - include the entry if tee.bin is provided and it doesn't have the v1 + header + - drop it otherwise + + When used within a FIT, we can do:: + + binman { + fit { + tee-os { + }; + }; + }; + + which will split the ELF into separate nodes for each segment, if an ELF + file is provide (see Flat Image Tree / FIT), or produce a single node if + the binary v1 format is provided. """ def __init__(self, section, etype, node): super().__init__(section, etype, node, 'tee-os') self.external = True + + @staticmethod + def is_optee_bin(data): + return len(data) >= 8 and data[0:5] == b'OPTE\x01' + + def ObtainContents(self, fake_size=0): + ok = super().ObtainContents(fake_size) + if not ok: + return False + if not self.missing: + if elf.is_valid(self.data): + self.mark_absent('uses Elf format which must be in a FIT') + elif self.is_optee_bin(self.data): + self.mark_absent('uses v1 format which must be in a FIT') + return True + + def read_elf_segments(self): + data = self.GetData() + if self.is_optee_bin(data): + # OP-TEE v1 format (tee.bin) + init_sz, start_hi, start_lo, _, paged_sz = ( + struct.unpack_from('<5I', data, 0x8)) + if paged_sz != 0: + self.Raise("OP-TEE paged mode not supported") + e_entry = (start_hi << 32) + start_lo + p_addr = e_entry + p_data = data[0x1c:] + if len(p_data) != init_sz: + self.Raise("Invalid OP-TEE file: size mismatch (expected %#x, have %#x)" % + (init_sz, len(p_data))) + return [[0, p_addr, p_data]], e_entry + return None diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index f47a745f1e1..52d55345d01 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -112,6 +112,8 @@ REPACK_DTB_PROPS = ['orig-offset', 'orig-size'] # Supported compression bintools COMP_BINTOOLS = ['bzip2', 'gzip', 'lz4', 'lzma_alone', 'lzop', 'xz', 'zstd']
+TEE_ADDR = 0x5678 + class TestFunctional(unittest.TestCase): """Functional tests for binman
@@ -219,6 +221,13 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('tee.elf', tools.read_file(cls.ElfTestFile('elf_sections')))
+ # Newer OP_TEE file in v1 binary format + init_sz, start_hi, start_lo, dummy, paged_sz = ( + len(U_BOOT_DATA), 0, TEE_ADDR, 0, 0) + data = b'OPTE\x01xxx' + struct.pack('<5I', init_sz, start_hi, start_lo, + dummy, paged_sz) + U_BOOT_DATA + TestFunctional._MakeInputFile('tee.bin', data) + cls.comp_bintools = {} for name in COMP_BINTOOLS: cls.comp_bintools[name] = bintool.Bintool.create(name) @@ -6095,6 +6104,41 @@ fdt fdtmap Extract the devicetree blob from the fdtmap data = self._DoReadFile('262_absent.dts') self.assertEqual(U_BOOT_DATA + U_BOOT_IMG_DATA, data)
+ def testPackTeeOsOptional(self): + """Test that an image with an optional TEE binary can be created""" + entry_args = { + 'tee-os-path': 'tee.elf', + } + data = self._DoReadFileDtb('263_tee_os_opt.dts', + entry_args=entry_args)[0] + self.assertEqual(U_BOOT_DATA + U_BOOT_IMG_DATA, data) + + def testFitTeeOsOptionalFit(self): + """Test an image with a FIT with an optional OP-TEE binary""" + if not elf.ELF_TOOLS: + self.skipTest('Python elftools not available') + entry_args = { + 'of-list': 'test-fdt1 test-fdt2', + 'default-dt': 'test-fdt2', + 'tee-os-path': 'tee.bin', + } + test_subdir = os.path.join(self._indir, TEST_FDT_SUBDIR) + data = self._DoReadFileDtb( + '264_tee_os_opt_fit.dts', + entry_args=entry_args, + extra_indirs=[test_subdir])[0] + + # There should be only one node, holding the data set up in SetUpClass() + # for tee.bin + dtb = fdt.Fdt.FromData(data) + dtb.Scan() + node = dtb.GetNode('/images/tee-1') + self.assertEqual(TEE_ADDR, + fdt_util.fdt32_to_cpu(node.props['load'].value)) + self.assertEqual(TEE_ADDR, + fdt_util.fdt32_to_cpu(node.props['entry'].value)) + self.assertEqual(U_BOOT_DATA, node.props['data'].bytes) +
if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/263_tee_os_opt.dts b/tools/binman/test/263_tee_os_opt.dts new file mode 100644 index 00000000000..2e4ec24ac2c --- /dev/null +++ b/tools/binman/test/263_tee_os_opt.dts @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + }; + tee-os { + /* + * this results in nothing being added since only the + * .bin format is supported by this etype, unless it is + * part of a FIT + */ + }; + u-boot-img { + }; + }; +}; diff --git a/tools/binman/test/264_tee_os_opt_fit.dts b/tools/binman/test/264_tee_os_opt_fit.dts new file mode 100644 index 00000000000..ae44b433edf --- /dev/null +++ b/tools/binman/test/264_tee_os_opt_fit.dts @@ -0,0 +1,33 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + fit { + description = "test-desc"; + #address-cells = <1>; + fit,fdt-list = "of-list"; + + images { + @tee-SEQ { + fit,operation = "split-elf"; + description = "TEE"; + type = "tee"; + arch = "arm64"; + os = "tee"; + compression = "none"; + fit,load; + fit,entry; + fit,data; + + tee-os { + }; + }; + }; + }; + }; +};
This boards uses SPL_FIT so does not need to support loading a raw image. Drop it to avoid binman trying to insert a symbol which has no value.
configs/evb-rk3288_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 8f8d34c7038..6d3bb5a2944 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -29,6 +29,7 @@ CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_NO_BSS_LIMIT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK=0xff718000 CONFIG_SPL_STACK_R=y
Enable multiple-images so we can generate more than one image. Also add a comment for the end of the #if block.
Changes in v5: - Rename from 'Include binman script in 64-bit boards' - Drop duplicate #include in rk3368-u-boot.dtsi - Keep the name as fit for puma - Drop redundant check for CONFIG_ROCKCHIP_SPI_IMAGE - Drop imply of BINMAN in Kconfig (rely on ARCH_ROCKCHIP instead)
arch/arm/dts/rk3399-u-boot.dtsi | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/rk3399-u-boot.dtsi b/arch/arm/dts/rk3399-u-boot.dtsi index 3c1a15fe51b..85a4f472d5d 100644 --- a/arch/arm/dts/rk3399-u-boot.dtsi +++ b/arch/arm/dts/rk3399-u-boot.dtsi @@ -62,6 +62,7 @@
#if defined(CONFIG_ROCKCHIP_SPI_IMAGE) && defined(CONFIG_HAS_ROM) &binman { + multiple-images; rom { filename = "u-boot.rom"; size = <0x400000>; @@ -82,7 +83,7 @@ }; }; }; -#endif +#endif /* CONFIG_ROCKCHIP_SPI_IMAGE */
&cru { u-boot,dm-pre-reloc;
Add the required binman images to replace the Makefile rules which are currently used. This includes subsuming:
- tpl/u-boot-tpl-rockchip.bin if TPL is enabled - idbloader.img if either or both of SPL and TPL are enabled - u-boot.itb if SPL_FIT is enabled - u-boot-rockchip.bin if SPL is used, either using u-boot.itb when SPL_FIT is enabled or u-boot.img when it isn't
Note that the intermediate files are dropped with binman, since it producing everything in one pass. This means that tpl/u-boot-tpl-rockchip.bin is not created, for example.
Note that for some 32-bit rk3288 boards, rockchip-optee.dtsi is included.
Changes in v5: - Rename blob to fit for puma and also SPI image
arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi | 4 +- arch/arm/dts/rockchip-u-boot.dtsi | 76 +++++++++++++++++++-- 2 files changed, 72 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi b/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi index f8335c74a74..906098fae07 100644 --- a/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi +++ b/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi @@ -46,14 +46,14 @@
&binman { simple-bin { - blob { + fit { offset = <((CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR - 64) * 512)>; }; };
#ifdef CONFIG_ROCKCHIP_SPI_IMAGE simple-bin-spi { - blob { + fit { /* same as u-boot,spl-payload-offset */ offset = <0x80000>; }; diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi index 584f21eb5bf..22dfbbb3661 100644 --- a/arch/arm/dts/rockchip-u-boot.dtsi +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -30,14 +30,77 @@ }; };
-#ifdef CONFIG_ARM64 - blob { +#if defined(CONFIG_SPL_FIT) && defined(CONFIG_ARM64) + fit: fit { + description = "FIT image for U-Boot with bl31 (TF-A)"; + #address-cells = <1>; + fit,fdt-list = "of-list"; filename = "u-boot.itb"; + fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; + offset = <CONFIG_SPL_PAD_TO>; + images { + u-boot { + description = "U-Boot (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + u-boot-nodtb { + }; + }; + + @atf-SEQ { + fit,operation = "split-elf"; + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + os = "arm-trusted-firmware"; + compression = "none"; + fit,load; + fit,entry; + fit,data; + + atf-bl31 { + }; + }; + @tee-SEQ { + fit,operation = "split-elf"; + description = "TEE"; + type = "tee"; + arch = "arm64"; + os = "tee"; + compression = "none"; + fit,load; + fit,entry; + fit,data; + + tee-os { + }; + }; + + @fdt-SEQ { + description = "fdt-NAME"; + compression = "none"; + type = "flat_dt"; + }; + }; + + configurations { + default = "@config-DEFAULT-SEQ"; + @config-SEQ { + description = "NAME.dtb"; + fdt = "fdt-SEQ"; + firmware = "u-boot"; + fit,loadables; + }; + }; + }; #else u-boot-img { -#endif offset = <CONFIG_SPL_PAD_TO>; }; +#endif };
#ifdef CONFIG_ROCKCHIP_SPI_IMAGE @@ -59,7 +122,8 @@ };
#ifdef CONFIG_ARM64 - blob { + fit { + type = "blob"; filename = "u-boot.itb"; #else u-boot-img { @@ -68,6 +132,6 @@ offset = <CONFIG_SYS_SPI_U_BOOT_OFFS>; }; }; -#endif +#endif /* CONFIG_ROCKCHIP_SPI_IMAGE */ }; -#endif +#endif /* CONFIG_SPL */
Instead of the bash script, use binman to generate the FIT for arm64.
For 32-bit boards, use binman for all images, dropping the intermediate files.
With this change, only Zynq is now using SPL_FIT_GENERATOR so update the Kconfig rule accordingly.
Clean up the Makefile to the extent possible. Unfortunately, two boards do not use SPL_FRAMEWORK so don't enable the u-boot.img rule:
evb-rk3036 kylin-rk3036
So a small remnant remains.
Makefile | 8 +------- boot/Kconfig | 2 +- 2 files changed, 2 insertions(+), 8 deletions(-)
diff --git a/Makefile b/Makefile index 9d84f964817..566eeb5a248 100644 --- a/Makefile +++ b/Makefile @@ -1006,14 +1006,9 @@ ifeq ($(CONFIG_INIT_SP_RELATIVE)$(CONFIG_OF_SEPARATE),yy) INPUTS-y += init_sp_bss_offset_check endif
-ifeq ($(CONFIG_ARCH_ROCKCHIP)$(CONFIG_SPL),yy) -# Binman image dependencies -ifeq ($(CONFIG_ARM64),y) -INPUTS-y += u-boot.itb -else +ifeq ($(CONFIG_ARCH_ROCKCHIP)_$(CONFIG_SPL_FRAMEWORK),y_) INPUTS-y += u-boot.img endif -endif
INPUTS-$(CONFIG_X86) += u-boot-x86-start16.bin u-boot-x86-reset16.bin \ $(if $(CONFIG_SPL_X86_16BIT_INIT),spl/u-boot-spl.bin) \ @@ -1485,7 +1480,6 @@ OBJCOPYFLAGS_u-boot-with-spl.bin = -I binary -O binary \ u-boot-with-spl.bin: $(SPL_IMAGE) $(SPL_PAYLOAD) FORCE $(call if_changed,pad_cat)
- ifeq ($(CONFIG_ARCH_LPC32XX)$(CONFIG_SPL),yy) MKIMAGEFLAGS_lpc32xx-spl.img = -T lpc32xximage -a $(CONFIG_SPL_TEXT_BASE)
diff --git a/boot/Kconfig b/boot/Kconfig index 668270cc660..2fec861acd3 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -277,7 +277,7 @@ config SPL_FIT_SOURCE
config USE_SPL_FIT_GENERATOR bool "Use a script to generate the .its script" - default y if SPL_FIT && (!ARCH_SUNXI && !RISCV) + default y if SPL_FIT && ARCH_ZYNQMP
config SPL_FIT_GENERATOR string ".its file generator script for U-Boot FIT image"
This is not used anymore. Drop it.
Makefile | 3 - arch/arm/mach-rockchip/make_fit_atf.py | 267 ------------------------- boot/Kconfig | 1 - 3 files changed, 271 deletions(-) delete mode 100755 arch/arm/mach-rockchip/make_fit_atf.py
diff --git a/Makefile b/Makefile index 566eeb5a248..34f0e547880 100644 --- a/Makefile +++ b/Makefile @@ -1373,9 +1373,6 @@ $(U_BOOT_ITS): $(subst ",,$(CONFIG_SPL_FIT_SOURCE)) else ifneq ($(CONFIG_USE_SPL_FIT_GENERATOR),) U_BOOT_ITS := u-boot.its -ifeq ($(CONFIG_SPL_FIT_GENERATOR),"arch/arm/mach-rockchip/make_fit_atf.py") -U_BOOT_ITS_DEPS += u-boot -endif $(U_BOOT_ITS): $(U_BOOT_ITS_DEPS) FORCE $(srctree)/$(CONFIG_SPL_FIT_GENERATOR) \ $(patsubst %,arch/$(ARCH)/dts/%.dtb,$(subst ",,$(CONFIG_OF_LIST))) > $@ diff --git a/arch/arm/mach-rockchip/make_fit_atf.py b/arch/arm/mach-rockchip/make_fit_atf.py deleted file mode 100755 index 08cfe9f51e9..00000000000 --- a/arch/arm/mach-rockchip/make_fit_atf.py +++ /dev/null @@ -1,267 +0,0 @@ -#!/usr/bin/env python3 -""" -# SPDX-License-Identifier: GPL-2.0+ -# -# A script to generate FIT image source for rockchip boards -# with ARM Trusted Firmware -# and multiple device trees (given on the command line) -# -# usage: $0 <dt_name> [<dt_name> [<dt_name] ...] -""" - -import os -import sys -import getopt -import logging -import struct - -DT_HEADER = """ -/* - * This is a generated file. - */ -/dts-v1/; - -/ { - description = "FIT image for U-Boot with bl31 (TF-A)"; - #address-cells = <1>; - - images { -""" - -DT_UBOOT = """ - uboot { - description = "U-Boot (64-bit)"; - data = /incbin/("u-boot-nodtb.bin"); - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <0x%08x>; - }; - -""" - -DT_IMAGES_NODE_END = """ }; - -""" - -DT_END = "};" - -def append_bl31_node(file, atf_index, phy_addr, elf_entry): - # Append BL31 DT node to input FIT dts file. - data = 'bl31_0x%08x.bin' % phy_addr - file.write('\t\tatf_%d {\n' % atf_index) - file.write('\t\t\tdescription = "ARM Trusted Firmware";\n') - file.write('\t\t\tdata = /incbin/("%s");\n' % data) - file.write('\t\t\ttype = "firmware";\n') - file.write('\t\t\tarch = "arm64";\n') - file.write('\t\t\tos = "arm-trusted-firmware";\n') - file.write('\t\t\tcompression = "none";\n') - file.write('\t\t\tload = <0x%08x>;\n' % phy_addr) - if atf_index == 1: - file.write('\t\t\tentry = <0x%08x>;\n' % elf_entry) - file.write('\t\t};\n') - file.write('\n') - -def append_tee_node(file, atf_index, phy_addr, elf_entry): - # Append TEE DT node to input FIT dts file. - data = 'tee_0x%08x.bin' % phy_addr - file.write('\t\tatf_%d {\n' % atf_index) - file.write('\t\t\tdescription = "TEE";\n') - file.write('\t\t\tdata = /incbin/("%s");\n' % data) - file.write('\t\t\ttype = "tee";\n') - file.write('\t\t\tarch = "arm64";\n') - file.write('\t\t\tos = "tee";\n') - file.write('\t\t\tcompression = "none";\n') - file.write('\t\t\tload = <0x%08x>;\n' % phy_addr) - file.write('\t\t\tentry = <0x%08x>;\n' % elf_entry) - file.write('\t\t};\n') - file.write('\n') - -def append_fdt_node(file, dtbs): - # Append FDT nodes. - cnt = 1 - for dtb in dtbs: - dtname = os.path.basename(dtb) - file.write('\t\tfdt_%d {\n' % cnt) - file.write('\t\t\tdescription = "%s";\n' % dtname) - file.write('\t\t\tdata = /incbin/("%s");\n' % dtb) - file.write('\t\t\ttype = "flat_dt";\n') - file.write('\t\t\tcompression = "none";\n') - file.write('\t\t};\n') - file.write('\n') - cnt = cnt + 1 - -def append_conf_section(file, cnt, dtname, segments): - file.write('\t\tconfig_%d {\n' % cnt) - file.write('\t\t\tdescription = "%s";\n' % dtname) - file.write('\t\t\tfirmware = "atf_1";\n') - file.write('\t\t\tloadables = "uboot"') - if segments > 1: - file.write(',') - for i in range(1, segments): - file.write('"atf_%d"' % (i + 1)) - if i != (segments - 1): - file.write(',') - else: - file.write(';\n') - if segments <= 1: - file.write(';\n') - file.write('\t\t\tfdt = "fdt_%d";\n' % cnt) - file.write('\t\t};\n') - file.write('\n') - -def append_conf_node(file, dtbs, segments): - # Append configeration nodes. - cnt = 1 - file.write('\tconfigurations {\n') - file.write('\t\tdefault = "config_1";\n') - for dtb in dtbs: - dtname = os.path.basename(dtb) - append_conf_section(file, cnt, dtname, segments) - cnt = cnt + 1 - file.write('\t};\n') - file.write('\n') - -def generate_atf_fit_dts_uboot(fit_file, uboot_file_name): - segments = unpack_elf(uboot_file_name) - if len(segments) != 1: - raise ValueError("Invalid u-boot ELF image '%s'" % uboot_file_name) - index, entry, p_paddr, data = segments[0] - fit_file.write(DT_UBOOT % p_paddr) - -def generate_atf_fit_dts_bl31(fit_file, bl31_file_name, tee_file_name, dtbs_file_name): - segments = unpack_elf(bl31_file_name) - for index, entry, paddr, data in segments: - append_bl31_node(fit_file, index + 1, paddr, entry) - num_segments = len(segments) - - if tee_file_name: - tee_segments = unpack_tee_file(tee_file_name) - for index, entry, paddr, data in tee_segments: - append_tee_node(fit_file, num_segments + index + 1, paddr, entry) - num_segments = num_segments + len(tee_segments) - - append_fdt_node(fit_file, dtbs_file_name) - fit_file.write(DT_IMAGES_NODE_END) - append_conf_node(fit_file, dtbs_file_name, num_segments) - -def generate_atf_fit_dts(fit_file_name, bl31_file_name, tee_file_name, uboot_file_name, dtbs_file_name): - # Generate FIT script for ATF image. - if fit_file_name != sys.stdout: - fit_file = open(fit_file_name, "wb") - else: - fit_file = sys.stdout - - fit_file.write(DT_HEADER) - generate_atf_fit_dts_uboot(fit_file, uboot_file_name) - generate_atf_fit_dts_bl31(fit_file, bl31_file_name, tee_file_name, dtbs_file_name) - fit_file.write(DT_END) - - if fit_file_name != sys.stdout: - fit_file.close() - -def generate_atf_binary(bl31_file_name): - for index, entry, paddr, data in unpack_elf(bl31_file_name): - file_name = 'bl31_0x%08x.bin' % paddr - with open(file_name, "wb") as atf: - atf.write(data) - -def generate_tee_binary(tee_file_name): - if tee_file_name: - for index, entry, paddr, data in unpack_tee_file(tee_file_name): - file_name = 'tee_0x%08x.bin' % paddr - with open(file_name, "wb") as atf: - atf.write(data) - -def unpack_elf(filename): - with open(filename, 'rb') as file: - elf = file.read() - if elf[0:7] != b'\x7fELF\x02\x01\x01' or elf[18:20] != b'\xb7\x00': - raise ValueError("Invalid arm64 ELF file '%s'" % filename) - - e_entry, e_phoff = struct.unpack_from('<2Q', elf, 0x18) - e_phentsize, e_phnum = struct.unpack_from('<2H', elf, 0x36) - segments = [] - - for index in range(e_phnum): - offset = e_phoff + e_phentsize * index - p_type, p_flags, p_offset = struct.unpack_from('<LLQ', elf, offset) - if p_type == 1: # PT_LOAD - p_paddr, p_filesz = struct.unpack_from('<2Q', elf, offset + 0x18) - if p_filesz > 0: - p_data = elf[p_offset:p_offset + p_filesz] - segments.append((index, e_entry, p_paddr, p_data)) - return segments - -def unpack_tee_file(filename): - if filename.endswith('.elf'): - return unpack_elf(filename) - with open(filename, 'rb') as file: - bin = file.read() - segments = [] - if bin[0:5] == b'OPTE\x01': - # OP-TEE v1 format (tee.bin) - init_sz, start_hi, start_lo, _, paged_sz = struct.unpack_from('<5I', - bin, - 0x8) - if paged_sz != 0: - raise ValueError("OP-TEE paged mode not supported") - e_entry = (start_hi << 32) + start_lo - p_addr = e_entry - p_data = bin[0x1c:] - if len(p_data) != init_sz: - raise ValueError("Invalid file '%s': size mismatch " - "(expected %d, have %d)" % (filename, init_sz, - len(p_data))) - segments.append((0, e_entry, p_addr, p_data)) - else: - raise ValueError("Unknown format for TEE file '%s'" % filename) - return segments - -def main(): - uboot_elf = "./u-boot" - fit_its = sys.stdout - if "BL31" in os.environ: - bl31_elf=os.getenv("BL31"); - elif os.path.isfile("./bl31.elf"): - bl31_elf = "./bl31.elf" - else: - os.system("echo 'int main(){}' > bl31.c") - os.system("${CROSS_COMPILE}gcc -c bl31.c -o bl31.elf") - bl31_elf = "./bl31.elf" - logging.basicConfig(format='%(levelname)s:%(message)s', level=logging.DEBUG) - logging.warning(' BL31 file bl31.elf NOT found, resulting binary is non-functional') - logging.warning(' Please read Building section in doc/README.rockchip') - - if "TEE" in os.environ: - tee_file = os.getenv("TEE") - elif os.path.isfile("./tee.bin"): - tee_file = "./tee.bin" - elif os.path.isfile("./tee.elf"): - tee_file = "./tee.elf" - else: - tee_file = "" - - opts, args = getopt.getopt(sys.argv[1:], "o:u:b:t:h") - for opt, val in opts: - if opt == "-o": - fit_its = val - elif opt == "-u": - uboot_elf = val - elif opt == "-b": - bl31_elf = val - elif opt == "-t": - tee_file = val - elif opt == "-h": - print(__doc__) - sys.exit(2) - - dtbs = args - - generate_atf_fit_dts(fit_its, bl31_elf, tee_file, uboot_elf, dtbs) - generate_atf_binary(bl31_elf) - generate_tee_binary(tee_file) - -if __name__ == "__main__": - main() diff --git a/boot/Kconfig b/boot/Kconfig index 2fec861acd3..1bee68739ce 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -282,7 +282,6 @@ config USE_SPL_FIT_GENERATOR config SPL_FIT_GENERATOR string ".its file generator script for U-Boot FIT image" depends on USE_SPL_FIT_GENERATOR - default "arch/arm/mach-rockchip/make_fit_atf.py" if SPL_LOAD_FIT && ARCH_ROCKCHIP default "arch/arm/mach-zynqmp/mkimage_fit_atf.sh" if SPL_LOAD_FIT && ARCH_ZYNQMP help Specifies a (platform specific) script file to generate the FIT
This option is deprecated and only used by two boards. Enable it for just those two boards, so others don't accidentally enable it.
Changes in v6: - Add new patch to disable USE_SPL_FIT_GENERATOR by default - Add new patch to allow a binman entry to be marked absent - Update op-tee to support new v1 binary header
Changes in v3: - Add support for writing sections in binman - Rebase to master
Changes in v2: - Drop patches previously applied - Add various suggestions from Alper Nebi Yasak - Add patches to refactor binman's FIT support
boot/Kconfig | 5 +++-- configs/am335x_evm_defconfig | 1 - configs/am335x_hs_evm_defconfig | 1 - configs/am335x_hs_evm_uart_defconfig | 1 - configs/am43xx_evm_defconfig | 1 - configs/am43xx_evm_rtconly_defconfig | 1 - configs/am43xx_evm_usbhost_boot_defconfig | 1 - configs/am43xx_hs_evm_defconfig | 1 - configs/am57xx_evm_defconfig | 1 - configs/am57xx_hs_evm_defconfig | 1 - configs/am57xx_hs_evm_usb_defconfig | 1 - configs/am65x_evm_a53_defconfig | 1 - configs/am65x_evm_r5_defconfig | 1 - configs/am65x_hs_evm_a53_defconfig | 1 - configs/am65x_hs_evm_r5_defconfig | 1 - .../avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig | 1 + configs/cgtqmx8_defconfig | 1 - configs/chromebook_link64_defconfig | 1 - configs/dh_imx6_defconfig | 1 - configs/display5_defconfig | 1 - configs/display5_factory_defconfig | 1 - configs/dra7xx_evm_defconfig | 1 - configs/dra7xx_hs_evm_defconfig | 1 - configs/dra7xx_hs_evm_usb_defconfig | 1 - configs/evb-ast2600_defconfig | 1 - configs/evb-rk3229_defconfig | 1 - configs/evb-rk3288_defconfig | 1 - configs/gwventana_emmc_defconfig | 1 - configs/gwventana_gw5904_defconfig | 1 - configs/gwventana_nand_defconfig | 1 - configs/imx6qdl_icore_mipi_defconfig | 1 - configs/imx6qdl_icore_mmc_defconfig | 1 - configs/imx6qdl_icore_rqs_defconfig | 1 - configs/imx8mm-cl-iot-gate-optee_defconfig | 1 - configs/imx8mm-cl-iot-gate_defconfig | 1 - configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 1 - configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 1 - configs/imx8mm-mx8menlo_defconfig | 1 - configs/imx8mm_beacon_defconfig | 1 - configs/imx8mm_data_modul_edm_sbc_defconfig | 1 - configs/imx8mm_evk_defconfig | 1 - configs/imx8mm_evk_fspi_defconfig | 1 - configs/imx8mm_venice_defconfig | 1 - configs/imx8mn_beacon_2g_defconfig | 1 - configs/imx8mn_beacon_defconfig | 1 - configs/imx8mn_bsh_smm_s2_defconfig | 1 - configs/imx8mn_bsh_smm_s2pro_defconfig | 1 - configs/imx8mn_ddr4_evk_defconfig | 1 - configs/imx8mn_evk_defconfig | 1 - configs/imx8mn_var_som_defconfig | 1 - configs/imx8mn_venice_defconfig | 1 - configs/imx8mp-icore-mx8mp-edimm2.2_defconfig | 1 - configs/imx8mp_dhcom_pdk2_defconfig | 1 - configs/imx8mp_evk_defconfig | 1 - configs/imx8mp_rsb3720a1_4G_defconfig | 1 - configs/imx8mp_rsb3720a1_6G_defconfig | 1 - configs/imx8mp_venice_defconfig | 1 - configs/imx8mq_cm_defconfig | 1 - configs/imx8mq_evk_defconfig | 1 - configs/imx8mq_phanbell_defconfig | 1 - configs/imx8qm_rom7720_a1_4G_defconfig | 1 - configs/iot2050_defconfig | 1 - configs/j7200_evm_a72_defconfig | 1 - configs/j7200_evm_r5_defconfig | 1 - configs/j7200_hs_evm_a72_defconfig | 1 - configs/j7200_hs_evm_r5_defconfig | 1 - configs/j721e_evm_a72_defconfig | 1 - configs/j721e_evm_r5_defconfig | 1 - configs/j721e_hs_evm_a72_defconfig | 1 - configs/j721e_hs_evm_r5_defconfig | 1 - configs/j721s2_evm_a72_defconfig | 1 - configs/j721s2_evm_r5_defconfig | 1 - configs/j721s2_hs_evm_a72_defconfig | 1 - configs/j721s2_hs_evm_r5_defconfig | 1 - configs/kontron-sl-mx6ul_defconfig | 1 - configs/kontron-sl-mx8mm_defconfig | 1 - configs/kontron_pitx_imx8m_defconfig | 1 - configs/kontron_sl28_defconfig | 1 - configs/librem5_defconfig | 1 - configs/ls1046ardb_qspi_spl_defconfig | 1 - configs/mccmon6_nor_defconfig | 1 - configs/mccmon6_sd_defconfig | 1 - configs/mx6sabreauto_defconfig | 1 - configs/mx6sabresd_defconfig | 1 - configs/phycore-imx8mm_defconfig | 1 - configs/phycore-imx8mp_defconfig | 1 - configs/pico-imx6_defconfig | 1 - configs/pico-imx8mq_defconfig | 1 - configs/qemu-x86_64_defconfig | 1 - configs/sandbox_noinst_defconfig | 1 - configs/sandbox_spl_defconfig | 1 - configs/sandbox_vpl_defconfig | 1 - configs/socfpga_agilex_atf_defconfig | 1 - configs/socfpga_agilex_vab_defconfig | 1 - configs/socfpga_arria10_defconfig | 1 - configs/socfpga_chameleonv3_defconfig | 1 - configs/socfpga_n5x_atf_defconfig | 1 - configs/socfpga_n5x_vab_defconfig | 1 - configs/socfpga_stratix10_atf_defconfig | 1 - configs/stm32mp15_dhcom_basic_defconfig | 1 - configs/stm32mp15_dhcor_basic_defconfig | 1 - configs/verdin-imx8mm_defconfig | 1 - configs/verdin-imx8mp_defconfig | 1 - configs/wandboard_defconfig | 1 - configs/xilinx_zynq_virt_defconfig | 1 - configs/xilinx_zynqmp_virt_defconfig | 1 + 106 files changed, 5 insertions(+), 105 deletions(-)
diff --git a/boot/Kconfig b/boot/Kconfig index 1bee68739ce..dd40560bd43 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -277,12 +277,13 @@ config SPL_FIT_SOURCE
config USE_SPL_FIT_GENERATOR bool "Use a script to generate the .its script" - default y if SPL_FIT && ARCH_ZYNQMP + help + This is deprecated. Please do not use it. Use binman instead.
config SPL_FIT_GENERATOR string ".its file generator script for U-Boot FIT image" depends on USE_SPL_FIT_GENERATOR - default "arch/arm/mach-zynqmp/mkimage_fit_atf.sh" if SPL_LOAD_FIT && ARCH_ZYNQMP + default "arch/arm/mach-zynqmp/mkimage_fit_atf.sh" if ARCH_ZYNQMP help Specifies a (platform specific) script file to generate the FIT source file used to build the U-Boot FIT image file. This gets diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 78e63c91750..f1995da8169 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -14,7 +14,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_TIMESTAMP=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run init_console; run finduuid; run distro_bootcmd" CONFIG_LOGLEVEL=3 diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index 5dc9ba98fde..72609da3150 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -13,7 +13,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_TIMESTAMP=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run init_console; run finduuid; run distro_bootcmd" CONFIG_LOGLEVEL=3 diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index 68513c1b6a9..22562d4c63d 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -16,7 +16,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_TIMESTAMP=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run init_console; run finduuid; run distro_bootcmd" CONFIG_LOGLEVEL=3 diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 2faf1322f9e..cb8a7e39ad3 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -13,7 +13,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4033ff00 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index 4241070930f..ae82fe30686 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -13,7 +13,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4033ff00 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 91270d032bf..6a08a1c792a 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -12,7 +12,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4033ff00 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index b6b74af735e..1af4914faa4 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -18,7 +18,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4033ff00 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 054e9747a8b..b3490dabaab 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -18,7 +18,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037ff00 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS2,115200 androidboot.console=ttyS2 androidboot.hardware=beagle_x15board" diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 02a2543a3f0..c0d5a5893ec 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -21,7 +21,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037ff00 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS2,115200 androidboot.console=ttyS2 androidboot.hardware=beagle_x15board" diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index 84eca42aac0..66dfb96f6a6 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -23,7 +23,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037ff00 CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80200000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS2,115200 androidboot.console=ttyS2 androidboot.hardware=beagle_x15board" diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index fe3346f2150..84ca386eafd 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -30,7 +30,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" CONFIG_LOGLEVEL=7 diff --git a/configs/am65x_evm_r5_defconfig b/configs/am65x_evm_r5_defconfig index 45f50b6ae8e..64e1416162b 100644 --- a/configs/am65x_evm_r5_defconfig +++ b/configs/am65x_evm_r5_defconfig @@ -28,7 +28,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41c7effc # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y diff --git a/configs/am65x_hs_evm_a53_defconfig b/configs/am65x_hs_evm_a53_defconfig index 79182a77f30..94beb9ed67c 100644 --- a/configs/am65x_hs_evm_a53_defconfig +++ b/configs/am65x_hs_evm_a53_defconfig @@ -30,7 +30,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_fit_${boot}; run get_overlaystring; run run_fit" CONFIG_LOGLEVEL=7 diff --git a/configs/am65x_hs_evm_r5_defconfig b/configs/am65x_hs_evm_r5_defconfig index cbd702c3eda..9b463044211 100644 --- a/configs/am65x_hs_evm_r5_defconfig +++ b/configs/am65x_hs_evm_r5_defconfig @@ -27,7 +27,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41c7effc # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_MAX_SIZE=0x58000 diff --git a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig index 0a3d710a8b1..7cc2b3453f5 100644 --- a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig +++ b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig @@ -20,6 +20,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x10000000 +CONFIG_USE_SPL_FIT_GENERATOR=y CONFIG_BOOTDELAY=0 # CONFIG_DISPLAY_CPUINFO is not set CONFIG_CLOCKS=y diff --git a/configs/cgtqmx8_defconfig b/configs/cgtqmx8_defconfig index 019701010ac..d5924b7f6d3 100644 --- a/configs/cgtqmx8_defconfig +++ b/configs/cgtqmx8_defconfig @@ -22,7 +22,6 @@ CONFIG_REMAKE_ELF=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/chromebook_link64_defconfig b/configs/chromebook_link64_defconfig index 570c4e82a47..bfb2b809f9b 100644 --- a/configs/chromebook_link64_defconfig +++ b/configs/chromebook_link64_defconfig @@ -20,7 +20,6 @@ CONFIG_HAVE_VGA_BIOS=y CONFIG_X86_OFFSET_U_BOOT=0xffa00000 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SHOW_BOOT_PROGRESS=y diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index 04a5447e34d..62c446f86a9 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -33,7 +33,6 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=3 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y diff --git a/configs/display5_defconfig b/configs/display5_defconfig index dbd917b4ddb..34696c03416 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -32,7 +32,6 @@ CONFIG_SPL_SPI=y CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index 7508702eb95..5ed59cbb8e0 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -29,7 +29,6 @@ CONFIG_SPL_SPI=y CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index d91cf3e1301..ed47a396d5c 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -20,7 +20,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037fef0 CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80200000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS0,115200 androidboot.console=ttyS0 androidboot.hardware=jacinto6evmboard" diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 195bc0e4ee0..ffff1116e7a 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -23,7 +23,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037fef0 CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80200000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS0,115200 androidboot.console=ttyS0 androidboot.hardware=jacinto6evmboard" diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig index 99cdbbc02f8..fd24cb0a23d 100644 --- a/configs/dra7xx_hs_evm_usb_defconfig +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -24,7 +24,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037fef0 CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80200000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS0,115200 androidboot.console=ttyS0 androidboot.hardware=jacinto6evmboard" diff --git a/configs/evb-ast2600_defconfig b/configs/evb-ast2600_defconfig index 2fac79bbd72..11f3d57a8f4 100644 --- a/configs/evb-ast2600_defconfig +++ b/configs/evb-ast2600_defconfig @@ -28,7 +28,6 @@ CONFIG_FIT=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x10000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS4,115200n8 root=/dev/ram rw" CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig index 33202e48fe7..f8a95aed911 100644 --- a/configs/evb-rk3229_defconfig +++ b/configs/evb-rk3229_defconfig @@ -23,7 +23,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x61100000 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3229-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 6d3bb5a2944..e3f3225f6ff 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -22,7 +22,6 @@ CONFIG_SYS_MONITOR_LEN=614400 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rk3288-evb-rk808.dtb" CONFIG_SILENT_CONSOLE=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index f999b447755..e2f80e5b90c 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -29,7 +29,6 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 4c6291f0c51..6923018e9d7 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -29,7 +29,6 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 4e062e477e8..039a82cf9e0 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -29,7 +29,6 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 diff --git a/configs/imx6qdl_icore_mipi_defconfig b/configs/imx6qdl_icore_mipi_defconfig index 90eb153c45f..5045f60400a 100644 --- a/configs/imx6qdl_icore_mipi_defconfig +++ b/configs/imx6qdl_icore_mipi_defconfig @@ -28,7 +28,6 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index f5a7e969786..2831eb7d4e8 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -31,7 +31,6 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index ee2c597bcb2..b9383ed55b4 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -25,7 +25,6 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 diff --git a/configs/imx8mm-cl-iot-gate-optee_defconfig b/configs/imx8mm-cl-iot-gate-optee_defconfig index 80b801f9fed..586cb40f14b 100644 --- a/configs/imx8mm-cl-iot-gate-optee_defconfig +++ b/configs/imx8mm-cl-iot-gate-optee_defconfig @@ -22,7 +22,6 @@ CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_HAS_BSS_LINKER_SECTION=y diff --git a/configs/imx8mm-cl-iot-gate_defconfig b/configs/imx8mm-cl-iot-gate_defconfig index e8e9d23c2eb..d26b083c6e9 100644 --- a/configs/imx8mm-cl-iot-gate_defconfig +++ b/configs/imx8mm-cl-iot-gate_defconfig @@ -24,7 +24,6 @@ CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_HAS_BSS_LINKER_SECTION=y diff --git a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig index 846efa52f8c..56e9038d296 100644 --- a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig +++ b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig @@ -22,7 +22,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mm-icore-mx8mm-ctouch2.dtb" CONFIG_SPL_HAS_BSS_LINKER_SECTION=y diff --git a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig index 2814d3b3cb9..b54c01f9acb 100644 --- a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig +++ b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig @@ -22,7 +22,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mm-icore-mx8mm-edimm2.2.dtb" CONFIG_SPL_HAS_BSS_LINKER_SECTION=y diff --git a/configs/imx8mm-mx8menlo_defconfig b/configs/imx8mm-mx8menlo_defconfig index f1e48bba965..da6c7add3f7 100644 --- a/configs/imx8mm-mx8menlo_defconfig +++ b/configs/imx8mm-mx8menlo_defconfig @@ -28,7 +28,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOOTCOMMAND="mmc partconf 0 distro_bootpart && load ${devtype} ${devnum}:${distro_bootpart} ${loadaddr} boot/fitImage && source ${loadaddr}:bootscr-boot.cmd ; reset" CONFIG_DEFAULT_FDT_FILE="imx8mm-mx8menlo.dtb" diff --git a/configs/imx8mm_beacon_defconfig b/configs/imx8mm_beacon_defconfig index 93f66310975..178c62a40fc 100644 --- a/configs/imx8mm_beacon_defconfig +++ b/configs/imx8mm_beacon_defconfig @@ -22,7 +22,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; fi;" diff --git a/configs/imx8mm_data_modul_edm_sbc_defconfig b/configs/imx8mm_data_modul_edm_sbc_defconfig index 3ccd26817ba..d9bd907761f 100644 --- a/configs/imx8mm_data_modul_edm_sbc_defconfig +++ b/configs/imx8mm_data_modul_edm_sbc_defconfig @@ -30,7 +30,6 @@ CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x44000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTARGS=y diff --git a/configs/imx8mm_evk_defconfig b/configs/imx8mm_evk_defconfig index 5d1f30a660b..bea790182bd 100644 --- a/configs/imx8mm_evk_defconfig +++ b/configs/imx8mm_evk_defconfig @@ -23,7 +23,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_HAS_BSS_LINKER_SECTION=y diff --git a/configs/imx8mm_evk_fspi_defconfig b/configs/imx8mm_evk_fspi_defconfig index 7c43dcf05cd..8e733df2955 100644 --- a/configs/imx8mm_evk_fspi_defconfig +++ b/configs/imx8mm_evk_fspi_defconfig @@ -23,7 +23,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_MAX_SIZE=0x25000 diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index 65031ab64db..2041cb47cd7 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -26,7 +26,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_PREBOOT=y diff --git a/configs/imx8mn_beacon_2g_defconfig b/configs/imx8mn_beacon_2g_defconfig index ba6856eafb0..5dd94e7423a 100644 --- a/configs/imx8mn_beacon_2g_defconfig +++ b/configs/imx8mn_beacon_2g_defconfig @@ -27,7 +27,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" diff --git a/configs/imx8mn_beacon_defconfig b/configs/imx8mn_beacon_defconfig index c73f7d7082b..ee815767803 100644 --- a/configs/imx8mn_beacon_defconfig +++ b/configs/imx8mn_beacon_defconfig @@ -26,7 +26,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" diff --git a/configs/imx8mn_bsh_smm_s2_defconfig b/configs/imx8mn_bsh_smm_s2_defconfig index 47f4e15e5d6..454ca46aec1 100644 --- a/configs/imx8mn_bsh_smm_s2_defconfig +++ b/configs/imx8mn_bsh_smm_s2_defconfig @@ -23,7 +23,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="freescale/imx8mn-bsh-smm-s2.dtb" CONFIG_ARCH_MISC_INIT=y diff --git a/configs/imx8mn_bsh_smm_s2pro_defconfig b/configs/imx8mn_bsh_smm_s2pro_defconfig index 5092ec1206d..0384e781e28 100644 --- a/configs/imx8mn_bsh_smm_s2pro_defconfig +++ b/configs/imx8mn_bsh_smm_s2pro_defconfig @@ -24,7 +24,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="freescale/imx8mn-bsh-smm-s2pro.dtb" CONFIG_ARCH_MISC_INIT=y diff --git a/configs/imx8mn_ddr4_evk_defconfig b/configs/imx8mn_ddr4_evk_defconfig index e238122d25a..bc5a92c3a3e 100644 --- a/configs/imx8mn_ddr4_evk_defconfig +++ b/configs/imx8mn_ddr4_evk_defconfig @@ -23,7 +23,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mn-ddr4-evk.dtb" CONFIG_ARCH_MISC_INIT=y diff --git a/configs/imx8mn_evk_defconfig b/configs/imx8mn_evk_defconfig index 777b01a0f23..941d1666e46 100644 --- a/configs/imx8mn_evk_defconfig +++ b/configs/imx8mn_evk_defconfig @@ -23,7 +23,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mn-evk.dtb" CONFIG_ARCH_MISC_INIT=y diff --git a/configs/imx8mn_var_som_defconfig b/configs/imx8mn_var_som_defconfig index 560b445a9cd..ac5ed963f60 100644 --- a/configs/imx8mn_var_som_defconfig +++ b/configs/imx8mn_var_som_defconfig @@ -25,7 +25,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="freescale/imx8mn-var-som-symphony.dtb" CONFIG_ARCH_MISC_INIT=y diff --git a/configs/imx8mn_venice_defconfig b/configs/imx8mn_venice_defconfig index d785915fa2e..86db0da2c1e 100644 --- a/configs/imx8mn_venice_defconfig +++ b/configs/imx8mn_venice_defconfig @@ -27,7 +27,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_PREBOOT=y diff --git a/configs/imx8mp-icore-mx8mp-edimm2.2_defconfig b/configs/imx8mp-icore-mx8mp-edimm2.2_defconfig index f679fbe2514..01074ccfe9c 100644 --- a/configs/imx8mp-icore-mx8mp-edimm2.2_defconfig +++ b/configs/imx8mp-icore-mx8mp-edimm2.2_defconfig @@ -26,7 +26,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mp-icore-mx8mp-edimm2.2.dtb" CONFIG_BOARD_LATE_INIT=y diff --git a/configs/imx8mp_dhcom_pdk2_defconfig b/configs/imx8mp_dhcom_pdk2_defconfig index ecc28c89ef7..af97ed4836d 100644 --- a/configs/imx8mp_dhcom_pdk2_defconfig +++ b/configs/imx8mp_dhcom_pdk2_defconfig @@ -35,7 +35,6 @@ CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x44000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTARGS=y diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index 91ec39d0237..7e1233707e9 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -26,7 +26,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mp-evk.dtb" CONFIG_BOARD_LATE_INIT=y diff --git a/configs/imx8mp_rsb3720a1_4G_defconfig b/configs/imx8mp_rsb3720a1_4G_defconfig index 5e29320b267..b23a74c45c3 100644 --- a/configs/imx8mp_rsb3720a1_4G_defconfig +++ b/configs/imx8mp_rsb3720a1_4G_defconfig @@ -29,7 +29,6 @@ CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mp-rsb3720-a1.dtb" diff --git a/configs/imx8mp_rsb3720a1_6G_defconfig b/configs/imx8mp_rsb3720a1_6G_defconfig index 11c3e1ffefd..40c28b43f11 100644 --- a/configs/imx8mp_rsb3720a1_6G_defconfig +++ b/configs/imx8mp_rsb3720a1_6G_defconfig @@ -29,7 +29,6 @@ CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx8mp-rsb3720-a1.dtb" diff --git a/configs/imx8mp_venice_defconfig b/configs/imx8mp_venice_defconfig index 220b2a2cff1..90c8164b618 100644 --- a/configs/imx8mp_venice_defconfig +++ b/configs/imx8mp_venice_defconfig @@ -27,7 +27,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_PREBOOT=y diff --git a/configs/imx8mq_cm_defconfig b/configs/imx8mq_cm_defconfig index ad42237a0cc..385a6b19bd4 100644 --- a/configs/imx8mq_cm_defconfig +++ b/configs/imx8mq_cm_defconfig @@ -26,7 +26,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_SPL_FIT_PRINT=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_MAX_SIZE=0x1f000 diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index 79a27dedb37..b02aa6a49eb 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -27,7 +27,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y diff --git a/configs/imx8mq_phanbell_defconfig b/configs/imx8mq_phanbell_defconfig index 7169e4d3f93..9e7cfabc413 100644 --- a/configs/imx8mq_phanbell_defconfig +++ b/configs/imx8mq_phanbell_defconfig @@ -25,7 +25,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_SD_BOOT=y CONFIG_USE_BOOTCOMMAND=y diff --git a/configs/imx8qm_rom7720_a1_4G_defconfig b/configs/imx8qm_rom7720_a1_4G_defconfig index 7819bef8638..e74e35f32e1 100644 --- a/configs/imx8qm_rom7720_a1_4G_defconfig +++ b/configs/imx8qm_rom7720_a1_4G_defconfig @@ -22,7 +22,6 @@ CONFIG_REMAKE_ELF=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" diff --git a/configs/iot2050_defconfig b/configs/iot2050_defconfig index 4ae85f391b7..f83283ec220 100644 --- a/configs/iot2050_defconfig +++ b/configs/iot2050_defconfig @@ -27,7 +27,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80100000 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTSTAGE=y CONFIG_SHOW_BOOT_PROGRESS=y diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index e7cdd84ecba..b3f7c4521ec 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -30,7 +30,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" CONFIG_LOGLEVEL=7 diff --git a/configs/j7200_evm_r5_defconfig b/configs/j7200_evm_r5_defconfig index 87101cbf53e..291341cc761 100644 --- a/configs/j7200_evm_r5_defconfig +++ b/configs/j7200_evm_r5_defconfig @@ -27,7 +27,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41cf5bfc CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_MAX_SIZE=0xc0000 diff --git a/configs/j7200_hs_evm_a72_defconfig b/configs/j7200_hs_evm_a72_defconfig index b9598ca1fe2..9d18aed6300 100644 --- a/configs/j7200_hs_evm_a72_defconfig +++ b/configs/j7200_hs_evm_a72_defconfig @@ -31,7 +31,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_fit_${boot}; run get_overlaystring; run run_fit" CONFIG_LOGLEVEL=7 diff --git a/configs/j7200_hs_evm_r5_defconfig b/configs/j7200_hs_evm_r5_defconfig index 608778ade86..ab3461efe9c 100644 --- a/configs/j7200_hs_evm_r5_defconfig +++ b/configs/j7200_hs_evm_r5_defconfig @@ -27,7 +27,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41cf5bfc # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_MAX_SIZE=0xc0000 diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index 48a24446941..b0570d88ad9 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -28,7 +28,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd; run init_${boot}; run main_cpsw0_qsgmii_phyinit; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" CONFIG_LOGLEVEL=7 diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index d6da4c6ae2e..fa89fa45227 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -27,7 +27,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41cf5bfc CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/j721e_hs_evm_a72_defconfig b/configs/j721e_hs_evm_a72_defconfig index a1cc7da0bfb..8f009b49708 100644 --- a/configs/j721e_hs_evm_a72_defconfig +++ b/configs/j721e_hs_evm_a72_defconfig @@ -29,7 +29,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run main_cpsw0_qsgmii_phyinit; run boot_rprocs; run get_fit_${boot}; run get_overlay_${boot}; run run_fit" CONFIG_LOGLEVEL=7 diff --git a/configs/j721e_hs_evm_r5_defconfig b/configs/j721e_hs_evm_r5_defconfig index eb9df365538..709127fb1d1 100644 --- a/configs/j721e_hs_evm_r5_defconfig +++ b/configs/j721e_hs_evm_r5_defconfig @@ -27,7 +27,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41cf5bfc # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index 2b2f80c4aaa..df63003736a 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -30,7 +30,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" CONFIG_LOGLEVEL=7 diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 2de5d87bdb2..bdc6782ed6a 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -29,7 +29,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41c76000 CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y diff --git a/configs/j721s2_hs_evm_a72_defconfig b/configs/j721s2_hs_evm_a72_defconfig index 3e0ec40fb2e..8615aa1e202 100644 --- a/configs/j721s2_hs_evm_a72_defconfig +++ b/configs/j721s2_hs_evm_a72_defconfig @@ -31,7 +31,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_fit_${boot}; run get_overlaystring; run run_fit" CONFIG_LOGLEVEL=7 diff --git a/configs/j721s2_hs_evm_r5_defconfig b/configs/j721s2_hs_evm_r5_defconfig index bc8672f7096..3dbec11c458 100644 --- a/configs/j721s2_hs_evm_r5_defconfig +++ b/configs/j721s2_hs_evm_r5_defconfig @@ -29,7 +29,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41c76000 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y diff --git a/configs/kontron-sl-mx6ul_defconfig b/configs/kontron-sl-mx6ul_defconfig index 7391e597642..015480d277c 100644 --- a/configs/kontron-sl-mx6ul_defconfig +++ b/configs/kontron-sl-mx6ul_defconfig @@ -25,7 +25,6 @@ CONFIG_SYS_MEMTEST_END=0x90000000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_TYPES=y diff --git a/configs/kontron-sl-mx8mm_defconfig b/configs/kontron-sl-mx8mm_defconfig index 62fd984debd..b4a3a7b5f03 100644 --- a/configs/kontron-sl-mx8mm_defconfig +++ b/configs/kontron-sl-mx8mm_defconfig @@ -28,7 +28,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOARD_TYPES=y CONFIG_BOARD_LATE_INIT=y diff --git a/configs/kontron_pitx_imx8m_defconfig b/configs/kontron_pitx_imx8m_defconfig index 898a0b45e85..5976c292139 100644 --- a/configs/kontron_pitx_imx8m_defconfig +++ b/configs/kontron_pitx_imx8m_defconfig @@ -26,7 +26,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_SPL_FIT_PRINT=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y diff --git a/configs/kontron_sl28_defconfig b/configs/kontron_sl28_defconfig index 9b90ed478cc..2aa36d6698e 100644 --- a/configs/kontron_sl28_defconfig +++ b/configs/kontron_sl28_defconfig @@ -33,7 +33,6 @@ CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_MP=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 diff --git a/configs/librem5_defconfig b/configs/librem5_defconfig index 8be8421db3a..8bebd17e4bd 100644 --- a/configs/librem5_defconfig +++ b/configs/librem5_defconfig @@ -27,7 +27,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOOTDELAY=0 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/ls1046ardb_qspi_spl_defconfig b/configs/ls1046ardb_qspi_spl_defconfig index 560362695ff..a138f616746 100644 --- a/configs/ls1046ardb_qspi_spl_defconfig +++ b/configs/ls1046ardb_qspi_spl_defconfig @@ -35,7 +35,6 @@ CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_MP=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_RAMBOOT_PBL=y CONFIG_SYS_FSL_PBL_PBI="board/freescale/ls1046ardb/ls1046ardb_qspi_pbi.cfg" diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index 2566bdef168..b0787e12052 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -20,7 +20,6 @@ CONFIG_ENV_ADDR=0x8040000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set # CONFIG_USE_BOOTCOMMAND is not set CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_BOARD_INIT=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index 43ffc3c6bc1..2f9cd13f225 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -22,7 +22,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set # CONFIG_USE_BOOTCOMMAND is not set CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_BOARD_INIT=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 8e94a84409d..5b2a3a2a397 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -26,7 +26,6 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_SPL_FIT_PRINT=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 9472e032c81..cb2f34f00a0 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -25,7 +25,6 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_SPL_FIT_PRINT=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi" diff --git a/configs/phycore-imx8mm_defconfig b/configs/phycore-imx8mm_defconfig index fab2550536f..5a60fb1530f 100644 --- a/configs/phycore-imx8mm_defconfig +++ b/configs/phycore-imx8mm_defconfig @@ -22,7 +22,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadimage; then run mmcboot; else run netboot; fi; fi;" diff --git a/configs/phycore-imx8mp_defconfig b/configs/phycore-imx8mp_defconfig index 248631b7a8f..8b0f3ca35f3 100644 --- a/configs/phycore-imx8mp_defconfig +++ b/configs/phycore-imx8mp_defconfig @@ -23,7 +23,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadimage; then run mmcboot; else run netboot; fi; fi;" diff --git a/configs/pico-imx6_defconfig b/configs/pico-imx6_defconfig index a6ed013f8b6..3f1b07bf9e8 100644 --- a/configs/pico-imx6_defconfig +++ b/configs/pico-imx6_defconfig @@ -24,7 +24,6 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_SPL_FIT_PRINT=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTCOMMAND="run default_boot" CONFIG_DEFAULT_FDT_FILE="ask" CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y diff --git a/configs/pico-imx8mq_defconfig b/configs/pico-imx8mq_defconfig index 1b49eb2ed99..73c681b4e85 100644 --- a/configs/pico-imx8mq_defconfig +++ b/configs/pico-imx8mq_defconfig @@ -25,7 +25,6 @@ CONFIG_SYS_MONITOR_LEN=524288 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi" diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index 0f4811e5d7a..fd4d500bf32 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -19,7 +19,6 @@ CONFIG_X86_OFFSET_U_BOOT=0xfff00000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_SYS_MONITOR_BASE=0x01110000 CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y diff --git a/configs/sandbox_noinst_defconfig b/configs/sandbox_noinst_defconfig index a12235559bf..b961fc82367 100644 --- a/configs/sandbox_noinst_defconfig +++ b/configs/sandbox_noinst_defconfig @@ -20,7 +20,6 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_BOOTSTAGE_FDT=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 4d70466fa9d..e583897a565 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -20,7 +20,6 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_BOOTSTAGE_FDT=y diff --git a/configs/sandbox_vpl_defconfig b/configs/sandbox_vpl_defconfig index c94b059a978..f3856c03638 100644 --- a/configs/sandbox_vpl_defconfig +++ b/configs/sandbox_vpl_defconfig @@ -27,7 +27,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_BEST_MATCH=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_BOOTSTAGE_FDT=y diff --git a/configs/socfpga_agilex_atf_defconfig b/configs/socfpga_agilex_atf_defconfig index 9269eccf17a..52807bb1ac4 100644 --- a/configs/socfpga_agilex_atf_defconfig +++ b/configs/socfpga_agilex_atf_defconfig @@ -22,7 +22,6 @@ CONFIG_FIT=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x02000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" diff --git a/configs/socfpga_agilex_vab_defconfig b/configs/socfpga_agilex_vab_defconfig index da4545effff..87fd1c5ccd7 100644 --- a/configs/socfpga_agilex_vab_defconfig +++ b/configs/socfpga_agilex_vab_defconfig @@ -23,7 +23,6 @@ CONFIG_FIT=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x02000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index 4e2dc0c9857..d94d7f0188d 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -17,7 +17,6 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xffe2b000 CONFIG_FIT=y CONFIG_TIMESTAMP=y CONFIG_SPL_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/socfpga_chameleonv3_defconfig b/configs/socfpga_chameleonv3_defconfig index 00c4cf30089..4bbce3591da 100644 --- a/configs/socfpga_chameleonv3_defconfig +++ b/configs/socfpga_chameleonv3_defconfig @@ -11,7 +11,6 @@ CONFIG_SPL_FS_FAT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_MISC_INIT_R=y CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SYS_SPL_MALLOC=y diff --git a/configs/socfpga_n5x_atf_defconfig b/configs/socfpga_n5x_atf_defconfig index 4d856d535a3..64aa5328538 100644 --- a/configs/socfpga_n5x_atf_defconfig +++ b/configs/socfpga_n5x_atf_defconfig @@ -21,7 +21,6 @@ CONFIG_FIT=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x02000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon panic=-1 earlyprintk=ttyS0,115200" diff --git a/configs/socfpga_n5x_vab_defconfig b/configs/socfpga_n5x_vab_defconfig index a6714b265e1..bc59a0f44bd 100644 --- a/configs/socfpga_n5x_vab_defconfig +++ b/configs/socfpga_n5x_vab_defconfig @@ -22,7 +22,6 @@ CONFIG_FIT=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x02000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon panic=-1 earlyprintk=ttyS0,115200" diff --git a/configs/socfpga_stratix10_atf_defconfig b/configs/socfpga_stratix10_atf_defconfig index e0e6b2d0461..3c46fdfc997 100644 --- a/configs/socfpga_stratix10_atf_defconfig +++ b/configs/socfpga_stratix10_atf_defconfig @@ -22,7 +22,6 @@ CONFIG_FIT=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x02000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=5 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="earlycon" diff --git a/configs/stm32mp15_dhcom_basic_defconfig b/configs/stm32mp15_dhcom_basic_defconfig index 3ba396b9671..216b04b0b1e 100644 --- a/configs/stm32mp15_dhcom_basic_defconfig +++ b/configs/stm32mp15_dhcom_basic_defconfig @@ -23,7 +23,6 @@ CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0xc1000000 CONFIG_SPL_FIT_SOURCE="board/dhelectronics/dh_stm32mp1/u-boot-dhcom.its" -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" CONFIG_CONSOLE_MUX=y diff --git a/configs/stm32mp15_dhcor_basic_defconfig b/configs/stm32mp15_dhcor_basic_defconfig index ddd96ac4d29..13026ae9768 100644 --- a/configs/stm32mp15_dhcor_basic_defconfig +++ b/configs/stm32mp15_dhcor_basic_defconfig @@ -21,7 +21,6 @@ CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0xc1000000 CONFIG_SPL_FIT_SOURCE="board/dhelectronics/dh_stm32mp1/u-boot-dhcor.its" -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" CONFIG_CONSOLE_MUX=y diff --git a/configs/verdin-imx8mm_defconfig b/configs/verdin-imx8mm_defconfig index 62f85883cb2..faaddad3ff3 100644 --- a/configs/verdin-imx8mm_defconfig +++ b/configs/verdin-imx8mm_defconfig @@ -26,7 +26,6 @@ CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOOTDELAY=1 CONFIG_USE_PREBOOT=y diff --git a/configs/verdin-imx8mp_defconfig b/configs/verdin-imx8mp_defconfig index bae8179bfde..481f57c5d4b 100644 --- a/configs/verdin-imx8mp_defconfig +++ b/configs/verdin-imx8mp_defconfig @@ -32,7 +32,6 @@ CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOOTDELAY=1 CONFIG_USE_PREBOOT=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index a6baff1e24c..e418e4d2074 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -27,7 +27,6 @@ CONFIG_SYS_MONITOR_LEN=409600 CONFIG_FIT=y CONFIG_SPL_FIT_PRINT=y CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/xilinx_zynq_virt_defconfig b/configs/xilinx_zynq_virt_defconfig index a4c555dac5c..28e78e365ff 100644 --- a/configs/xilinx_zynq_virt_defconfig +++ b/configs/xilinx_zynq_virt_defconfig @@ -24,7 +24,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_FIT_PRINT=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x10000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_LEGACY_IMAGE_FORMAT=y # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_PREBOOT=y diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 4732c39bdbe..eeae9f34067 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -25,6 +25,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x10000000 +CONFIG_USE_SPL_FIT_GENERATOR=y # CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="run scsi_init;usb start"
On Sat, 17 Dec 2022 at 09:11, Simon Glass sjg@chromium.org wrote:
At present rockchip 64-bit boards make use of a FIT-generator script written in Python. The script supports splitting an ELF file into several 'loadable' nodes in the FIT. Binman does not current support this feature.
This series adds binman support for ELF splitting. This works by adding a new 'fit,operation' property to the FIT subnodes, allowing this new way of generating nodes.
It also provides support for optional entries, by allowing them to be marked absent when the contents are obtained.
Some other fixes and improvements are needed along the way.
A new, common binman description is added for 64-bit boards which includes the required u-boot.itb file.
The existing script is removed, so that only a few zynq boards are now using a SPL_FIT_GENERATOR script:
avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0 xilinx_zynqmp_virt
Migration of those is hopefully in progress.
Note however that tools/k3_fit_atf.sh remains, used by a few boards that enable CONFIG_TI_SECURE_DEVICE so this series is copied there too:
am335x_hs_evm am335x_hs_evm_uart am43xx_hs_evm am57xx_hs_evm am57xx_hs_evm_usb am65x_hs_evm_a53 am65x_hs_evm_r5 dra7xx_hs_evm dra7xx_hs_evm_usb j721e_hs_evm_a72 j721e_hs_evm_r5 k2e_hs_evm k2g_hs_evm k2hk_hs_evm k2l_hs_evm
Ivan Mikhaylov has sent a patch to help with these, but I need to take a look at the testing side. In any case they should really be using binman for the image generation.
Changes in v6:
- Add new patch to update entry docs
Please ignore this version as it does not have full test coverage. I will send v7.
