[PATCH 00/22] imx: add i.MX8MP support
i.IMX8M Plus is part of the i.MX8M SoC family, targeting industrial and consumer market. It includes an ML and AI accelerator, together with 4 Cortex-A53 core, DSP, GPU, VPU, M7 and etc.
This patchset is to add the support.
CI: https://travis-ci.org/MrVan/u-boot/builds/630883217
Peng Fan (21): imx: get cpu id/type of i.MX8MP imx8mp: set BYPASS ID SWAP to avoid AXI bus errors imx: cpu: enlarge bit mask to 0x1FF for cpu type imx: imx8m: add Kconfig entry for i.MX8MP imx: spl: support i.MX8MP spl_boot_device dt-bindings: clock: add i.MX8MP clock header arm: dts: add i.MX8MP pinfunc header imx: imx8mp: add basic clock imx: imx8m: add 1GHz fracpll entry pinctrl: imx8m: support i.MX8MP mxc_ocotp: support i.MX8MP ddr: imx8m: Add DRAM PLL to generate 1000Mhz output arm: dts: freescale: Add i.MX8MP dtsi support imx: imx8mp: add pin header file imx: add i.MX8MP PE property imx: Kconfig: make SPL_IMX_ROMAPI_LOADADDR visible to i.MX8MP imx: imx8m: only support non-dm code in clock_imx8mm.c clk: imx: add imx_clk_mux2_flags clk: imx: add i.MX8MP clk driver imx: imx8m: add imximage-8mp-lpddr4.cfg imx: add i.MX8MP EVK board
Ye Li (1): power: Add new PMIC PCA9450 driver
arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx8mp-evk-u-boot.dtsi | 121 ++ arch/arm/dts/imx8mp-evk.dts | 231 +++ arch/arm/dts/imx8mp-pinfunc.h | 931 ++++++++++++ arch/arm/dts/imx8mp.dtsi | 598 ++++++++ arch/arm/include/asm/arch-imx/cpu.h | 1 + arch/arm/include/asm/arch-imx8m/clock.h | 3 +- arch/arm/include/asm/arch-imx8m/clock_imx8mm.h | 112 +- arch/arm/include/asm/arch-imx8m/imx8mp_pins.h | 1080 +++++++++++++ arch/arm/include/asm/mach-imx/iomux-v3.h | 2 +- arch/arm/include/asm/mach-imx/sys_proto.h | 1 + arch/arm/mach-imx/Kconfig | 3 +- arch/arm/mach-imx/cpu.c | 6 +- arch/arm/mach-imx/imx8m/Kconfig | 11 + arch/arm/mach-imx/imx8m/Makefile | 2 +- arch/arm/mach-imx/imx8m/clock_imx8mm.c | 340 ++++- arch/arm/mach-imx/imx8m/clock_slice.c | 272 ++++ arch/arm/mach-imx/imx8m/imximage-8mp-lpddr4.cfg | 17 + arch/arm/mach-imx/imx8m/soc.c | 9 +- arch/arm/mach-imx/spl.c | 3 +- board/freescale/imx8mp_evk/Kconfig | 14 + board/freescale/imx8mp_evk/Makefile | 12 + board/freescale/imx8mp_evk/imx8mp_evk.c | 94 ++ board/freescale/imx8mp_evk/lpddr4_timing.c | 1847 +++++++++++++++++++++++ board/freescale/imx8mp_evk/spl.c | 158 ++ configs/imx8mp_evk_defconfig | 84 ++ drivers/clk/imx/Kconfig | 16 + drivers/clk/imx/Makefile | 2 + drivers/clk/imx/clk-imx8mp.c | 362 +++++ drivers/clk/imx/clk.h | 10 + drivers/ddr/imx/imx8m/ddrphy_utils.c | 4 + drivers/misc/mxc_ocotp.c | 13 + drivers/pinctrl/nxp/pinctrl-imx8m.c | 1 + drivers/power/pmic/Kconfig | 7 + drivers/power/pmic/Makefile | 2 + drivers/power/pmic/pca9450.c | 93 ++ drivers/power/pmic/pmic_pca9450.c | 50 + include/configs/imx8mp_evk.h | 165 ++ include/dt-bindings/clock/imx8mp-clock.h | 300 ++++ include/power/pca9450.h | 60 + 40 files changed, 6994 insertions(+), 46 deletions(-) create mode 100644 arch/arm/dts/imx8mp-evk-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mp-evk.dts create mode 100644 arch/arm/dts/imx8mp-pinfunc.h create mode 100644 arch/arm/dts/imx8mp.dtsi create mode 100644 arch/arm/include/asm/arch-imx8m/imx8mp_pins.h create mode 100644 arch/arm/mach-imx/imx8m/imximage-8mp-lpddr4.cfg create mode 100644 board/freescale/imx8mp_evk/Kconfig create mode 100644 board/freescale/imx8mp_evk/Makefile create mode 100644 board/freescale/imx8mp_evk/imx8mp_evk.c create mode 100644 board/freescale/imx8mp_evk/lpddr4_timing.c create mode 100644 board/freescale/imx8mp_evk/spl.c create mode 100644 configs/imx8mp_evk_defconfig create mode 100644 drivers/clk/imx/clk-imx8mp.c create mode 100644 drivers/power/pmic/pca9450.c create mode 100644 drivers/power/pmic/pmic_pca9450.c create mode 100644 include/configs/imx8mp_evk.h create mode 100644 include/dt-bindings/clock/imx8mp-clock.h create mode 100644 include/power/pca9450.h
Support get i.MX8MP cpu id and cpu type
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx/cpu.h | 1 + arch/arm/include/asm/mach-imx/sys_proto.h | 1 + arch/arm/mach-imx/cpu.c | 2 ++ arch/arm/mach-imx/imx8m/soc.c | 7 +++++-- 4 files changed, 9 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-imx/cpu.h b/arch/arm/include/asm/arch-imx/cpu.h index b0f4dd089f..5ade63665a 100644 --- a/arch/arm/include/asm/arch-imx/cpu.h +++ b/arch/arm/include/asm/arch-imx/cpu.h @@ -33,6 +33,7 @@ #define MXC_CPU_IMX8MMS 0x89 /* dummy ID */ #define MXC_CPU_IMX8MMSL 0x8a /* dummy ID */ #define MXC_CPU_IMX8MN 0x8b /* dummy ID */ +#define MXC_CPU_IMX8MP 0x182/* dummy ID */ #define MXC_CPU_IMX8QXP_A0 0x90 /* dummy ID */ #define MXC_CPU_IMX8QM 0x91 /* dummy ID */ #define MXC_CPU_IMX8QXP 0x92 /* dummy ID */ diff --git a/arch/arm/include/asm/mach-imx/sys_proto.h b/arch/arm/include/asm/mach-imx/sys_proto.h index c9b509e6a7..48fdfe91b1 100644 --- a/arch/arm/include/asm/mach-imx/sys_proto.h +++ b/arch/arm/include/asm/mach-imx/sys_proto.h @@ -54,6 +54,7 @@ #define is_imx8mms() (is_cpu_type(MXC_CPU_IMX8MMS)) #define is_imx8mmsl() (is_cpu_type(MXC_CPU_IMX8MMSL)) #define is_imx8mn() (is_cpu_type(MXC_CPU_IMX8MN)) +#define is_imx8mp() (is_cpu_type(MXC_CPU_IMX8MP))
#define is_imx8qxp() (is_cpu_type(MXC_CPU_IMX8QXP))
diff --git a/arch/arm/mach-imx/cpu.c b/arch/arm/mach-imx/cpu.c index 51c7c05f04..303f5bb4d6 100644 --- a/arch/arm/mach-imx/cpu.c +++ b/arch/arm/mach-imx/cpu.c @@ -92,6 +92,8 @@ static char *get_reset_cause(void) const char *get_imx_type(u32 imxtype) { switch (imxtype) { + case MXC_CPU_IMX8MP: + return "8MP"; /* Quad-core version of the imx8mp */ case MXC_CPU_IMX8MN: return "8MNano";/* Quad-core version of the imx8mn */ case MXC_CPU_IMX8MM: diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index 5ce5a180e8..9a039ce127 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -197,8 +197,11 @@ u32 get_cpu_rev(void)
reg &= 0xff;
- /* i.MX8MM */ - if (major_low == 0x42) { + /* iMX8MP */ + if (major_low == 0x43) { + return (MXC_CPU_IMX8MP << 12) | reg; + } else if (major_low == 0x42) { + /* iMX8MN */ return (MXC_CPU_IMX8MN << 12) | reg; } else if (major_low == 0x41) { type = get_cpu_variant_type(MXC_CPU_IMX8MM);
Set the BYPASS ID SWAP bit (GPR10 bit 1) in order for GPU not to generated AXI bus errors with TZC380 enabled.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/soc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index 9a039ce127..7fcbd53f30 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -57,7 +57,7 @@ void enable_tzc380(void) /* Enable TZASC and lock setting */ setbits_le32(&gpr->gpr[10], GPR_TZASC_EN); setbits_le32(&gpr->gpr[10], GPR_TZASC_EN_LOCK); - if (is_imx8mm() || is_imx8mn()) + if (is_imx8mm() || is_imx8mn() || is_imx8mp()) setbits_le32(&gpr->gpr[10], BIT(1)); /* * set Region 0 attribute to allow secure and non-secure
i.MX8MP use 0x182 as dummy id, 0xFF is not able the get the highest bit, so enlarge bit mask to 0x1FF to make it could detect cpu type correctly
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/cpu.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-imx/cpu.c b/arch/arm/mach-imx/cpu.c index 303f5bb4d6..bfa85c64c6 100644 --- a/arch/arm/mach-imx/cpu.c +++ b/arch/arm/mach-imx/cpu.c @@ -159,7 +159,7 @@ int print_cpuinfo(void) int cpu_tmp, minc, maxc, ret;
printf("CPU: Freescale i.MX%s rev%d.%d", - get_imx_type((cpurev & 0xFF000) >> 12), + get_imx_type((cpurev & 0x1FF000) >> 12), (cpurev & 0x000F0) >> 4, (cpurev & 0x0000F) >> 0); max_freq = get_cpu_speed_grade_hz(); @@ -171,7 +171,7 @@ int print_cpuinfo(void) } #else printf("CPU: Freescale i.MX%s rev%d.%d at %d MHz\n", - get_imx_type((cpurev & 0xFF000) >> 12), + get_imx_type((cpurev & 0x1FF000) >> 12), (cpurev & 0x000F0) >> 4, (cpurev & 0x0000F) >> 0, mxc_get_clock(MXC_ARM_CLK) / 1000000);
Add Kconfig entry for i.MX8MP
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/Kconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index eb4a73b3e2..251feb2074 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -16,6 +16,10 @@ config IMX8MN bool select IMX8M
+config IMX8MP + bool + select IMX8M + config SYS_SOC default "imx8m"
i.MX8MP follows i.MX8MN, so just let it use spl_board_boot_device
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/spl.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index dde1635a9d..5a6493a625 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -135,7 +135,8 @@ u32 spl_boot_device(void)
enum boot_device boot_device_spl = get_boot_device();
- if (IS_ENABLED(CONFIG_IMX8MM) || IS_ENABLED(CONFIG_IMX8MN)) + if (IS_ENABLED(CONFIG_IMX8MM) || IS_ENABLED(CONFIG_IMX8MN) || + IS_ENABLED(CONFIG_IMX8MP)) return spl_board_boot_device(boot_device_spl);
switch (boot_device_spl) {
Add i.MX8MP clock header
Signed-off-by: Peng Fan peng.fan@nxp.com --- include/dt-bindings/clock/imx8mp-clock.h | 300 +++++++++++++++++++++++++++++++ 1 file changed, 300 insertions(+) create mode 100644 include/dt-bindings/clock/imx8mp-clock.h
diff --git a/include/dt-bindings/clock/imx8mp-clock.h b/include/dt-bindings/clock/imx8mp-clock.h new file mode 100644 index 0000000000..2fab63186b --- /dev/null +++ b/include/dt-bindings/clock/imx8mp-clock.h @@ -0,0 +1,300 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2019 NXP + */ + +#ifndef __DT_BINDINGS_CLOCK_IMX8MP_H +#define __DT_BINDINGS_CLOCK_IMX8MP_H + +#define IMX8MP_CLK_DUMMY 0 +#define IMX8MP_CLK_32K 1 +#define IMX8MP_CLK_24M 2 +#define IMX8MP_OSC_HDMI_CLK 3 +#define IMX8MP_CLK_EXT1 4 +#define IMX8MP_CLK_EXT2 5 +#define IMX8MP_CLK_EXT3 6 +#define IMX8MP_CLK_EXT4 7 +#define IMX8MP_AUDIO_PLL1_REF_SEL 8 +#define IMX8MP_AUDIO_PLL2_REF_SEL 9 +#define IMX8MP_VIDEO_PLL1_REF_SEL 10 +#define IMX8MP_DRAM_PLL_REF_SEL 11 +#define IMX8MP_GPU_PLL_REF_SEL 12 +#define IMX8MP_VPU_PLL_REF_SEL 13 +#define IMX8MP_ARM_PLL_REF_SEL 14 +#define IMX8MP_SYS_PLL1_REF_SEL 15 +#define IMX8MP_SYS_PLL2_REF_SEL 16 +#define IMX8MP_SYS_PLL3_REF_SEL 17 +#define IMX8MP_AUDIO_PLL1 18 +#define IMX8MP_AUDIO_PLL2 19 +#define IMX8MP_VIDEO_PLL1 20 +#define IMX8MP_DRAM_PLL 21 +#define IMX8MP_GPU_PLL 22 +#define IMX8MP_VPU_PLL 23 +#define IMX8MP_ARM_PLL 24 +#define IMX8MP_SYS_PLL1 25 +#define IMX8MP_SYS_PLL2 26 +#define IMX8MP_SYS_PLL3 27 +#define IMX8MP_AUDIO_PLL1_BYPASS 28 +#define IMX8MP_AUDIO_PLL2_BYPASS 29 +#define IMX8MP_VIDEO_PLL1_BYPASS 30 +#define IMX8MP_DRAM_PLL_BYPASS 31 +#define IMX8MP_GPU_PLL_BYPASS 32 +#define IMX8MP_VPU_PLL_BYPASS 33 +#define IMX8MP_ARM_PLL_BYPASS 34 +#define IMX8MP_SYS_PLL1_BYPASS 35 +#define IMX8MP_SYS_PLL2_BYPASS 36 +#define IMX8MP_SYS_PLL3_BYPASS 37 +#define IMX8MP_AUDIO_PLL1_OUT 38 +#define IMX8MP_AUDIO_PLL2_OUT 39 +#define IMX8MP_VIDEO_PLL1_OUT 40 +#define IMX8MP_DRAM_PLL_OUT 41 +#define IMX8MP_GPU_PLL_OUT 42 +#define IMX8MP_VPU_PLL_OUT 43 +#define IMX8MP_ARM_PLL_OUT 44 +#define IMX8MP_SYS_PLL1_OUT 45 +#define IMX8MP_SYS_PLL2_OUT 46 +#define IMX8MP_SYS_PLL3_OUT 47 +#define IMX8MP_SYS_PLL1_40M 48 +#define IMX8MP_SYS_PLL1_80M 49 +#define IMX8MP_SYS_PLL1_100M 50 +#define IMX8MP_SYS_PLL1_133M 51 +#define IMX8MP_SYS_PLL1_160M 52 +#define IMX8MP_SYS_PLL1_200M 53 +#define IMX8MP_SYS_PLL1_266M 54 +#define IMX8MP_SYS_PLL1_400M 55 +#define IMX8MP_SYS_PLL1_800M 56 +#define IMX8MP_SYS_PLL2_50M 57 +#define IMX8MP_SYS_PLL2_100M 58 +#define IMX8MP_SYS_PLL2_125M 59 +#define IMX8MP_SYS_PLL2_166M 60 +#define IMX8MP_SYS_PLL2_200M 61 +#define IMX8MP_SYS_PLL2_250M 62 +#define IMX8MP_SYS_PLL2_333M 63 +#define IMX8MP_SYS_PLL2_500M 64 +#define IMX8MP_SYS_PLL2_1000M 65 +#define IMX8MP_CLK_A53_SRC 66 +#define IMX8MP_CLK_M7_SRC 67 +#define IMX8MP_CLK_ML_SRC 68 +#define IMX8MP_CLK_GPU3D_CORE_SRC 69 +#define IMX8MP_CLK_GPU3D_SHADER_SRC 70 +#define IMX8MP_CLK_GPU2D_SRC 71 +#define IMX8MP_CLK_AUDIO_AXI_SRC 72 +#define IMX8MP_CLK_HSIO_AXI_SRC 73 +#define IMX8MP_CLK_MEDIA_ISP_SRC 74 +#define IMX8MP_CLK_A53_CG 75 +#define IMX8MP_CLK_M4_CG 76 +#define IMX8MP_CLK_ML_CG 77 +#define IMX8MP_CLK_GPU3D_CORE_CG 78 +#define IMX8MP_CLK_GPU3D_SHADER_CG 79 +#define IMX8MP_CLK_GPU2D_CG 80 +#define IMX8MP_CLK_AUDIO_AXI_CG 81 +#define IMX8MP_CLK_HSIO_AXI_CG 82 +#define IMX8MP_CLK_MEDIA_ISP_CG 83 +#define IMX8MP_CLK_A53_DIV 84 +#define IMX8MP_CLK_M7_DIV 85 +#define IMX8MP_CLK_ML_DIV 86 +#define IMX8MP_CLK_GPU3D_CORE_DIV 87 +#define IMX8MP_CLK_GPU3D_SHADER_DIV 88 +#define IMX8MP_CLK_GPU2D_DIV 89 +#define IMX8MP_CLK_AUDIO_AXI_DIV 90 +#define IMX8MP_CLK_HSIO_AXI_DIV 91 +#define IMX8MP_CLK_MEDIA_ISP_DIV 92 +#define IMX8MP_CLK_MAIN_AXI 93 +#define IMX8MP_CLK_ENET_AXI 94 +#define IMX8MP_CLK_NAND_USDHC_BUS 95 +#define IMX8MP_CLK_VPU_BUS 96 +#define IMX8MP_CLK_MEDIA_AXI 97 +#define IMX8MP_CLK_MEDIA_APB 98 +#define IMX8MP_CLK_HDMI_APB 99 +#define IMX8MP_CLK_HDMI_AXI 100 +#define IMX8MP_CLK_GPU_AXI 101 +#define IMX8MP_CLK_GPU_AHB 102 +#define IMX8MP_CLK_NOC 103 +#define IMX8MP_CLK_NOC_IO 104 +#define IMX8MP_CLK_ML_AXI 105 +#define IMX8MP_CLK_ML_AHB 106 +#define IMX8MP_CLK_AHB 107 +#define IMX8MP_CLK_AUDIO_AHB 108 +#define IMX8MP_CLK_MIPI_DSI_ESC_RX 109 +#define IMX8MP_CLK_IPG_ROOT 110 +#define IMX8MP_CLK_IPG_AUDIO_ROOT 111 +#define IMX8MP_CLK_DRAM_ALT 112 +#define IMX8MP_CLK_DRAM_APB 113 +#define IMX8MP_CLK_VPU_G1 114 +#define IMX8MP_CLK_VPU_G2 115 +#define IMX8MP_CLK_CAN1 116 +#define IMX8MP_CLK_CAN2 117 +#define IMX8MP_CLK_MEMREPAIR 118 +#define IMX8MP_CLK_PCIE_PHY 119 +#define IMX8MP_CLK_PCIE_AUX 120 +#define IMX8MP_CLK_I2C5 121 +#define IMX8MP_CLK_I2C6 122 +#define IMX8MP_CLK_SAI1 123 +#define IMX8MP_CLK_SAI2 124 +#define IMX8MP_CLK_SAI3 125 +#define IMX8MP_CLK_SAI4 126 +#define IMX8MP_CLK_SAI5 127 +#define IMX8MP_CLK_SAI6 128 +#define IMX8MP_CLK_ENET_QOS 129 +#define IMX8MP_CLK_ENET_QOS_TIMER 130 +#define IMX8MP_CLK_ENET_REF 131 +#define IMX8MP_CLK_ENET_TIMER 132 +#define IMX8MP_CLK_ENET_PHY_REF 133 +#define IMX8MP_CLK_NAND 134 +#define IMX8MP_CLK_QSPI 135 +#define IMX8MP_CLK_USDHC1 136 +#define IMX8MP_CLK_USDHC2 137 +#define IMX8MP_CLK_I2C1 138 +#define IMX8MP_CLK_I2C2 139 +#define IMX8MP_CLK_I2C3 140 +#define IMX8MP_CLK_I2C4 141 +#define IMX8MP_CLK_UART1 142 +#define IMX8MP_CLK_UART2 143 +#define IMX8MP_CLK_UART3 144 +#define IMX8MP_CLK_UART4 145 +#define IMX8MP_CLK_USB_CORE_REF 146 +#define IMX8MP_CLK_USB_PHY_REF 147 +#define IMX8MP_CLK_GIC 148 +#define IMX8MP_CLK_ECSPI1 149 +#define IMX8MP_CLK_ECSPI2 150 +#define IMX8MP_CLK_PWM1 151 +#define IMX8MP_CLK_PWM2 152 +#define IMX8MP_CLK_PWM3 153 +#define IMX8MP_CLK_PWM4 154 +#define IMX8MP_CLK_GPT1 155 +#define IMX8MP_CLK_GPT2 156 +#define IMX8MP_CLK_GPT3 157 +#define IMX8MP_CLK_GPT4 158 +#define IMX8MP_CLK_GPT5 159 +#define IMX8MP_CLK_GPT6 160 +#define IMX8MP_CLK_TRACE 161 +#define IMX8MP_CLK_WDOG 162 +#define IMX8MP_CLK_WRCLK 163 +#define IMX8MP_CLK_IPP_DO_CLKO1 164 +#define IMX8MP_CLK_IPP_DO_CLKO2 165 +#define IMX8MP_CLK_HDMI_FDCC_TST 166 +#define IMX8MP_CLK_HDMI_27M 167 +#define IMX8MP_CLK_HDMI_REF_266M 168 +#define IMX8MP_CLK_USDHC3 169 +#define IMX8MP_CLK_MEDIA_CAM1_PIX 170 +#define IMX8MP_CLK_MEDIA_MIPI_PHY1_REF 171 +#define IMX8MP_CLK_MEDIA_DISP1_PIX 172 +#define IMX8MP_CLK_MEDIA_CAM2_PIX 173 +#define IMX8MP_CLK_MEDIA_MIPI_PHY2_REF 174 +#define IMX8MP_CLK_MEDIA_MIPI_CSI2_ESC 175 +#define IMX8MP_CLK_PCIE2_CTRL 176 +#define IMX8MP_CLK_PCIE2_PHY 177 +#define IMX8MP_CLK_MEDIA_MIPI_TEST_BYTE 178 +#define IMX8MP_CLK_ECSPI3 179 +#define IMX8MP_CLK_PDM 180 +#define IMX8MP_CLK_VPU_VC8000E 181 +#define IMX8MP_CLK_SAI7 182 +#define IMX8MP_CLK_GPC_ROOT 183 +#define IMX8MP_CLK_ANAMIX_ROOT 184 +#define IMX8MP_CLK_CPU_ROOT 185 +#define IMX8MP_CLK_CSU_ROOT 186 +#define IMX8MP_CLK_DEBUG_ROOT 187 +#define IMX8MP_CLK_DRAM1_ROOT 188 +#define IMX8MP_CLK_ECSPI1_ROOT 189 +#define IMX8MP_CLK_ECSPI2_ROOT 190 +#define IMX8MP_CLK_ECSPI3_ROOT 191 +#define IMX8MP_CLK_ENET1_ROOT 192 +#define IMX8MP_CLK_GPIO1_ROOT 193 +#define IMX8MP_CLK_GPIO2_ROOT 194 +#define IMX8MP_CLK_GPIO3_ROOT 195 +#define IMX8MP_CLK_GPIO4_ROOT 196 +#define IMX8MP_CLK_GPIO5_ROOT 197 +#define IMX8MP_CLK_GPT1_ROOT 198 +#define IMX8MP_CLK_GPT2_ROOT 199 +#define IMX8MP_CLK_GPT3_ROOT 200 +#define IMX8MP_CLK_GPT4_ROOT 201 +#define IMX8MP_CLK_GPT5_ROOT 202 +#define IMX8MP_CLK_GPT6_ROOT 203 +#define IMX8MP_CLK_HS_ROOT 204 +#define IMX8MP_CLK_I2C1_ROOT 205 +#define IMX8MP_CLK_I2C2_ROOT 206 +#define IMX8MP_CLK_I2C3_ROOT 207 +#define IMX8MP_CLK_I2C4_ROOT 208 +#define IMX8MP_CLK_IOMUX_ROOT 209 +#define IMX8MP_CLK_IPMUX1_ROOT 210 +#define IMX8MP_CLK_IPMUX2_ROOT 211 +#define IMX8MP_CLK_IPMUX3_ROOT 212 +#define IMX8MP_CLK_MU_ROOT 213 +#define IMX8MP_CLK_OCOTP_ROOT 214 +#define IMX8MP_CLK_OCRAM_ROOT 215 +#define IMX8MP_CLK_OCRAM_S_ROOT 216 +#define IMX8MP_CLK_PCIE_ROOT 217 +#define IMX8MP_CLK_PERFMON1_ROOT 218 +#define IMX8MP_CLK_PERFMON2_ROOT 219 +#define IMX8MP_CLK_PWM1_ROOT 220 +#define IMX8MP_CLK_PWM2_ROOT 221 +#define IMX8MP_CLK_PWM3_ROOT 222 +#define IMX8MP_CLK_PWM4_ROOT 223 +#define IMX8MP_CLK_QOS_ROOT 224 +#define IMX8MP_CLK_QOS_ENET_ROOT 225 +#define IMX8MP_CLK_QSPI_ROOT 226 +#define IMX8MP_CLK_NAND_ROOT 227 +#define IMX8MP_CLK_NAND_USDHC_BUS_RAWNAND_CLK 228 +#define IMX8MP_CLK_RDC_ROOT 229 +#define IMX8MP_CLK_ROM_ROOT 230 +#define IMX8MP_CLK_I2C5_ROOT 231 +#define IMX8MP_CLK_I2C6_ROOT 232 +#define IMX8MP_CLK_CAN1_ROOT 233 +#define IMX8MP_CLK_CAN2_ROOT 234 +#define IMX8MP_CLK_SCTR_ROOT 235 +#define IMX8MP_CLK_SDMA1_ROOT 236 +#define IMX8MP_CLK_ENET_QOS_ROOT 237 +#define IMX8MP_CLK_SEC_DEBUG_ROOT 238 +#define IMX8MP_CLK_SEMA1_ROOT 239 +#define IMX8MP_CLK_SEMA2_ROOT 240 +#define IMX8MP_CLK_IRQ_STEER_ROOT 241 +#define IMX8MP_CLK_SIM_ENET_ROOT 242 +#define IMX8MP_CLK_SIM_M_ROOT 243 +#define IMX8MP_CLK_SIM_MAIN_ROOT 244 +#define IMX8MP_CLK_SIM_S_ROOT 245 +#define IMX8MP_CLK_SIM_WAKEUP_ROOT 246 +#define IMX8MP_CLK_GPU2D_ROOT 247 +#define IMX8MP_CLK_GPU3D_ROOT 248 +#define IMX8MP_CLK_SNVS_ROOT 249 +#define IMX8MP_CLK_TRACE_ROOT 250 +#define IMX8MP_CLK_UART1_ROOT 251 +#define IMX8MP_CLK_UART2_ROOT 252 +#define IMX8MP_CLK_UART3_ROOT 253 +#define IMX8MP_CLK_UART4_ROOT 254 +#define IMX8MP_CLK_USB_ROOT 255 +#define IMX8MP_CLK_USB_PHY_ROOT 256 +#define IMX8MP_CLK_USDHC1_ROOT 257 +#define IMX8MP_CLK_USDHC2_ROOT 258 +#define IMX8MP_CLK_WDOG1_ROOT 259 +#define IMX8MP_CLK_WDOG2_ROOT 260 +#define IMX8MP_CLK_WDOG3_ROOT 261 +#define IMX8MP_CLK_VPU_G1_ROOT 262 +#define IMX8MP_CLK_GPU_ROOT 263 +#define IMX8MP_CLK_NOC_WRAPPER_ROOT 264 +#define IMX8MP_CLK_VPU_VC8KE_ROOT 265 +#define IMX8MP_CLK_VPU_G2_ROOT 266 +#define IMX8MP_CLK_NPU_ROOT 267 +#define IMX8MP_CLK_HSIO_ROOT 268 +#define IMX8MP_CLK_MEDIA_APB_ROOT 269 +#define IMX8MP_CLK_MEDIA_AXI_ROOT 270 +#define IMX8MP_CLK_MEDIA_CAM1_PIX_ROOT 271 +#define IMX8MP_CLK_MEDIA_CAM2_PIX_ROOT 272 +#define IMX8MP_CLK_MEDIA_DISP1_PIX_ROOT 273 +#define IMX8MP_CLK_MEDIA_DISP2_PIX_ROOT 274 +#define IMX8MP_CLK_MEDIA_MIPI_PHY1_REF_ROOT 275 +#define IMX8MP_CLK_MEDIA_ISP_ROOT 276 +#define IMX8MP_CLK_USDHC3_ROOT 277 +#define IMX8MP_CLK_HDMI_ROOT 278 +#define IMX8MP_CLK_XTAL_ROOT 279 +#define IMX8MP_CLK_PLL_ROOT 280 +#define IMX8MP_CLK_TSENSOR_ROOT 281 +#define IMX8MP_CLK_VPU_ROOT 282 +#define IMX8MP_CLK_MRPR_ROOT 283 +#define IMX8MP_CLK_AUDIO_ROOT 284 +#define IMX8MP_CLK_DRAM_ALT_ROOT 285 +#define IMX8MP_CLK_DRAM_CORE 286 +#define IMX8MP_CLK_ARM 287 + +#define IMX8MP_CLK_END 288 + +#endif
Add i.MX8MP pinfunc header for dts usage
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mp-pinfunc.h | 931 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 931 insertions(+) create mode 100644 arch/arm/dts/imx8mp-pinfunc.h
diff --git a/arch/arm/dts/imx8mp-pinfunc.h b/arch/arm/dts/imx8mp-pinfunc.h new file mode 100644 index 0000000000..da78f89b6c --- /dev/null +++ b/arch/arm/dts/imx8mp-pinfunc.h @@ -0,0 +1,931 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + */ + +#ifndef __DTS_IMX8MP_PINFUNC_H +#define __DTS_IMX8MP_PINFUNC_H + +/* + * The pin function ID is a tuple of + * <mux_reg conf_reg input_reg mux_mode input_val> + */ +#define MX8MP_IOMUXC_GPIO1_IO00__GPIO1_IO00 0x014 0x274 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO00__CCMSRCGPCMIX_ENET_PHY_REF_CLK_ROOT 0x014 0x274 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO00__MEDIAMIX_ISP_FL_TRIG_0 0x014 0x274 0x5D4 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO00__ANAMIX_REF_CLK_32K 0x014 0x274 0x000 0x5 0x0 +#define MX8MP_IOMUXC_GPIO1_IO00__CCMSRCGPCMIX_EXT_CLK1 0x014 0x274 0x000 0x6 0x0 +#define MX8MP_IOMUXC_GPIO1_IO00__SJC_FAIL 0x014 0x274 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO01__GPIO1_IO01 0x018 0x278 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO01__PWM1_OUT 0x018 0x278 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO01__MEDIAMIX_ISP_SHUTTER_TRIG_0 0x018 0x278 0x5DC 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO01__ANAMIX_REF_CLK_24M 0x018 0x278 0x000 0x5 0x0 +#define MX8MP_IOMUXC_GPIO1_IO01__CCMSRCGPCMIX_EXT_CLK2 0x018 0x278 0x000 0x6 0x0 +#define MX8MP_IOMUXC_GPIO1_IO01__SJC_ACTIVE 0x018 0x278 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO02__GPIO1_IO02 0x01C 0x27C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO02__WDOG1_WDOG_B 0x01C 0x27C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO02__MEDIAMIX_ISP_FLASH_TRIG_0 0x01C 0x27C 0x000 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO02__WDOG1_WDOG_ANY 0x01C 0x27C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_GPIO1_IO02__SJC_DE_B 0x01C 0x27C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO03__GPIO1_IO03 0x020 0x280 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO03__USDHC1_VSELECT 0x020 0x280 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO03__MEDIAMIX_ISP_PRELIGHT_TRIG_0 0x020 0x280 0x000 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO03__SDMA1_EXT_EVENT00 0x020 0x280 0x000 0x5 0x0 +#define MX8MP_IOMUXC_GPIO1_IO03__ANAMIX_XTAL_OK 0x020 0x280 0x000 0x6 0x0 +#define MX8MP_IOMUXC_GPIO1_IO03__SJC_DONE 0x020 0x280 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO04__GPIO1_IO04 0x024 0x284 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0x024 0x284 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO04__MEDIAMIX_ISP_SHUTTER_OPEN_0 0x024 0x284 0x000 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO04__SDMA1_EXT_EVENT01 0x024 0x284 0x000 0x5 0x0 +#define MX8MP_IOMUXC_GPIO1_IO04__ANAMIX_XTAL_OK_LV 0x024 0x284 0x000 0x6 0x0 +#define MX8MP_IOMUXC_GPIO1_IO04__USDHC1_TEST_TRIG 0x024 0x284 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO05__GPIO1_IO05 0x028 0x288 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO05__M7_NMI 0x028 0x288 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO05__MEDIAMIX_ISP_FL_TRIG_1 0x028 0x288 0x5D8 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO05__CCMSRCGPCMIX_PMIC_READY 0x028 0x288 0x554 0x5 0x0 +#define MX8MP_IOMUXC_GPIO1_IO05__CCMSRCGPCMIX_INT_BOOT 0x028 0x288 0x000 0x6 0x0 +#define MX8MP_IOMUXC_GPIO1_IO05__USDHC2_TEST_TRIG 0x028 0x288 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO06__GPIO1_IO06 0x02C 0x28C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO06__ENET_QOS_MDC 0x02C 0x28C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO06__MEDIAMIX_ISP_SHUTTER_TRIG_1 0x02C 0x28C 0x5E0 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO06__USDHC1_CD_B 0x02C 0x28C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_GPIO1_IO06__CCMSRCGPCMIX_EXT_CLK3 0x02C 0x28C 0x000 0x6 0x0 +#define MX8MP_IOMUXC_GPIO1_IO06__ECSPI1_TEST_TRIG 0x02C 0x28C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO07__GPIO1_IO07 0x030 0x290 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO07__ENET_QOS_MDIO 0x030 0x290 0x590 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO07__MEDIAMIX_ISP_FLASH_TRIG_1 0x030 0x290 0x000 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO07__USDHC1_WP 0x030 0x290 0x000 0x5 0x0 +#define MX8MP_IOMUXC_GPIO1_IO07__CCMSRCGPCMIX_EXT_CLK4 0x030 0x290 0x000 0x6 0x0 +#define MX8MP_IOMUXC_GPIO1_IO07__ECSPI2_TEST_TRIG 0x030 0x290 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO08__GPIO1_IO08 0x034 0x294 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO08__ENET_QOS_1588_EVENT0_IN 0x034 0x294 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO08__PWM1_OUT 0x034 0x294 0x000 0x2 0x0 +#define MX8MP_IOMUXC_GPIO1_IO08__MEDIAMIX_ISP_PRELIGHT_TRIG_1 0x034 0x294 0x000 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO08__ENET_QOS_1588_EVENT0_AUX_IN 0x034 0x294 0x000 0x4 0x0 +#define MX8MP_IOMUXC_GPIO1_IO08__USDHC2_RESET_B 0x034 0x294 0x000 0x5 0x0 +#define MX8MP_IOMUXC_GPIO1_IO08__CCMSRCGPCMIX_WAIT 0x034 0x294 0x000 0x6 0x0 +#define MX8MP_IOMUXC_GPIO1_IO08__FLEXSPI_TEST_TRIG 0x034 0x294 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO09__GPIO1_IO09 0x038 0x298 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO09__ENET_QOS_1588_EVENT0_OUT 0x038 0x298 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO09__PWM2_OUT 0x038 0x298 0x000 0x2 0x0 +#define MX8MP_IOMUXC_GPIO1_IO09__MEDIAMIX_ISP_SHUTTER_OPEN_1 0x038 0x298 0x000 0x3 0x0 +#define MX8MP_IOMUXC_GPIO1_IO09__USDHC3_RESET_B 0x038 0x298 0x000 0x4 0x0 +#define MX8MP_IOMUXC_GPIO1_IO09__AUDIOMIX_EXT_EVENT00 0x038 0x298 0x000 0x5 0x0 +#define MX8MP_IOMUXC_GPIO1_IO09__CCMSRCGPCMIX_STOP 0x038 0x298 0x000 0x6 0x0 +#define MX8MP_IOMUXC_GPIO1_IO09__RAWNAND_TEST_TRIG 0x038 0x298 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO10__GPIO1_IO10 0x03C 0x29C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO10__HSIOMIX_usb1_OTG_ID 0x03C 0x29C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO10__PWM3_OUT 0x03C 0x29C 0x000 0x2 0x0 +#define MX8MP_IOMUXC_GPIO1_IO10__OCOTP_FUSE_LATCHED 0x03C 0x29C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO11__GPIO1_IO11 0x040 0x2A0 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO11__HSIOMIX_usb2_OTG_ID 0x040 0x2A0 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO11__PWM2_OUT 0x040 0x2A0 0x000 0x2 0x0 +#define MX8MP_IOMUXC_GPIO1_IO11__USDHC3_VSELECT 0x040 0x2A0 0x000 0x4 0x0 +#define MX8MP_IOMUXC_GPIO1_IO11__CCMSRCGPCMIX_PMIC_READY 0x040 0x2A0 0x554 0x5 0x1 +#define MX8MP_IOMUXC_GPIO1_IO11__CCMSRCGPCMIX_OUT0 0x040 0x2A0 0x000 0x6 0x0 +#define MX8MP_IOMUXC_GPIO1_IO11__CAAM_RNG_OSC_OBS 0x040 0x2A0 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO12__GPIO1_IO12 0x044 0x2A4 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO12__HSIOMIX_usb1_OTG_PWR 0x044 0x2A4 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO12__AUDIOMIX_EXT_EVENT01 0x044 0x2A4 0x000 0x5 0x0 +#define MX8MP_IOMUXC_GPIO1_IO12__CCMSRCGPCMIX_OUT1 0x044 0x2A4 0x000 0x6 0x0 +#define MX8MP_IOMUXC_GPIO1_IO12__CSU_CSU_ALARM_AUT00 0x044 0x2A4 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO13__GPIO1_IO13 0x048 0x2A8 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO13__HSIOMIX_usb1_OTG_OC 0x048 0x2A8 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO13__PWM2_OUT 0x048 0x2A8 0x000 0x5 0x0 +#define MX8MP_IOMUXC_GPIO1_IO13__CCMSRCGPCMIX_OUT2 0x048 0x2A8 0x000 0x6 0x0 +#define MX8MP_IOMUXC_GPIO1_IO13__CSU_CSU_ALARM_AUT01 0x048 0x2A8 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO14__GPIO1_IO14 0x04C 0x2AC 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO14__HSIOMIX_usb2_OTG_PWR 0x04C 0x2AC 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO14__USDHC3_CD_B 0x04C 0x2AC 0x608 0x4 0x0 +#define MX8MP_IOMUXC_GPIO1_IO14__PWM3_OUT 0x04C 0x2AC 0x000 0x5 0x0 +#define MX8MP_IOMUXC_GPIO1_IO14__CCMSRCGPCMIX_CLKO1 0x04C 0x2AC 0x000 0x6 0x0 +#define MX8MP_IOMUXC_GPIO1_IO14__CSU_CSU_ALARM_AUT02 0x04C 0x2AC 0x000 0x7 0x0 +#define MX8MP_IOMUXC_GPIO1_IO15__GPIO1_IO15 0x050 0x2B0 0x000 0x0 0x0 +#define MX8MP_IOMUXC_GPIO1_IO15__HSIOMIX_usb2_OTG_OC 0x050 0x2B0 0x000 0x1 0x0 +#define MX8MP_IOMUXC_GPIO1_IO15__USDHC3_WP 0x050 0x2B0 0x634 0x4 0x0 +#define MX8MP_IOMUXC_GPIO1_IO15__PWM4_OUT 0x050 0x2B0 0x000 0x5 0x0 +#define MX8MP_IOMUXC_GPIO1_IO15__CCMSRCGPCMIX_CLKO2 0x050 0x2B0 0x000 0x6 0x0 +#define MX8MP_IOMUXC_GPIO1_IO15__CSU_CSU_INT_DEB 0x050 0x2B0 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ENET_MDC__ENET_QOS_MDC 0x054 0x2B4 0x000 0x0 0x0 +#define MX8MP_IOMUXC_ENET_MDC__AUDIOMIX_SAI6_TX_DATA00 0x054 0x2B4 0x000 0x2 0x0 +#define MX8MP_IOMUXC_ENET_MDC__GPIO1_IO16 0x054 0x2B4 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ENET_MDC__USDHC3_STROBE 0x054 0x2B4 0x630 0x6 0x0 +#define MX8MP_IOMUXC_ENET_MDC__SIM_M_HADDR15 0x054 0x2B4 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ENET_MDIO__ENET_QOS_MDIO 0x058 0x2B8 0x590 0x0 0x1 +#define MX8MP_IOMUXC_ENET_MDIO__AUDIOMIX_SAI6_TX_SYNC 0x058 0x2B8 0x528 0x2 0x0 +#define MX8MP_IOMUXC_ENET_MDIO__GPIO1_IO17 0x058 0x2B8 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ENET_MDIO__USDHC3_DATA5 0x058 0x2B8 0x624 0x6 0x0 +#define MX8MP_IOMUXC_ENET_MDIO__SIM_M_HADDR16 0x058 0x2B8 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ENET_TD3__ENET_QOS_RGMII_TD3 0x05C 0x2BC 0x000 0x0 0x0 +#define MX8MP_IOMUXC_ENET_TD3__AUDIOMIX_SAI6_TX_BCLK 0x05C 0x2BC 0x524 0x2 0x0 +#define MX8MP_IOMUXC_ENET_TD3__GPIO1_IO18 0x05C 0x2BC 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ENET_TD3__USDHC3_DATA6 0x05C 0x2BC 0x628 0x6 0x0 +#define MX8MP_IOMUXC_ENET_TD3__SIM_M_HADDR17 0x05C 0x2BC 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ENET_TD2__ENET_QOS_RGMII_TD2 0x060 0x2C0 0x000 0x0 0x0 +#define MX8MP_IOMUXC_ENET_TD2__CCM_ENET_QOS_CLOCK_GENERATE_REF_CLK 0x060 0x2C0 0x000 0x1 0x0 +#define MX8MP_IOMUXC_ENET_TD2__AUDIOMIX_SAI6_RX_DATA00 0x060 0x2C0 0x51C 0x2 0x0 +#define MX8MP_IOMUXC_ENET_TD2__GPIO1_IO19 0x060 0x2C0 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ENET_TD2__USDHC3_DATA7 0x060 0x2C0 0x62C 0x6 0x0 +#define MX8MP_IOMUXC_ENET_TD2__SIM_M_HADDR18 0x060 0x2C0 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ENET_TD1__ENET_QOS_RGMII_TD1 0x064 0x2C4 0x000 0x0 0x0 +#define MX8MP_IOMUXC_ENET_TD1__AUDIOMIX_SAI6_RX_SYNC 0x064 0x2C4 0x520 0x2 0x0 +#define MX8MP_IOMUXC_ENET_TD1__GPIO1_IO20 0x064 0x2C4 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ENET_TD1__USDHC3_CD_B 0x064 0x2C4 0x608 0x6 0x1 +#define MX8MP_IOMUXC_ENET_TD1__SIM_M_HADDR19 0x064 0x2C4 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ENET_TD0__ENET_QOS_RGMII_TD0 0x068 0x2C8 0x000 0x0 0x0 +#define MX8MP_IOMUXC_ENET_TD0__AUDIOMIX_SAI6_RX_BCLK 0x068 0x2C8 0x518 0x2 0x0 +#define MX8MP_IOMUXC_ENET_TD0__GPIO1_IO21 0x068 0x2C8 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ENET_TD0__USDHC3_WP 0x068 0x2C8 0x634 0x6 0x1 +#define MX8MP_IOMUXC_ENET_TD0__SIM_M_HADDR20 0x068 0x2C8 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x06C 0x2CC 0x000 0x0 0x0 +#define MX8MP_IOMUXC_ENET_TX_CTL__AUDIOMIX_SAI6_MCLK 0x06C 0x2CC 0x514 0x2 0x0 +#define MX8MP_IOMUXC_ENET_TX_CTL__AUDIOMIX_SPDIF_OUT 0x06C 0x2CC 0x000 0x3 0x0 +#define MX8MP_IOMUXC_ENET_TX_CTL__GPIO1_IO22 0x06C 0x2CC 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ENET_TX_CTL__USDHC3_DATA0 0x06C 0x2CC 0x610 0x6 0x0 +#define MX8MP_IOMUXC_ENET_TX_CTL__SIM_M_HADDR21 0x06C 0x2CC 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x070 0x2D0 0x000 0x0 0x0 +#define MX8MP_IOMUXC_ENET_TXC__ENET_QOS_TX_ER 0x070 0x2D0 0x000 0x1 0x0 +#define MX8MP_IOMUXC_ENET_TXC__AUDIOMIX_SAI7_TX_DATA00 0x070 0x2D0 0x000 0x2 0x0 +#define MX8MP_IOMUXC_ENET_TXC__GPIO1_IO23 0x070 0x2D0 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ENET_TXC__USDHC3_DATA1 0x070 0x2D0 0x614 0x6 0x0 +#define MX8MP_IOMUXC_ENET_TXC__SIM_M_HADDR22 0x070 0x2D0 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x074 0x2D4 0x000 0x0 0x0 +#define MX8MP_IOMUXC_ENET_RX_CTL__AUDIOMIX_SAI7_TX_SYNC 0x074 0x2D4 0x540 0x2 0x0 +#define MX8MP_IOMUXC_ENET_RX_CTL__AUDIOMIX_BIT_STREAM03 0x074 0x2D4 0x4CC 0x3 0x0 +#define MX8MP_IOMUXC_ENET_RX_CTL__GPIO1_IO24 0x074 0x2D4 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ENET_RX_CTL__USDHC3_DATA2 0x074 0x2D4 0x618 0x6 0x0 +#define MX8MP_IOMUXC_ENET_RX_CTL__SIM_M_HADDR23 0x074 0x2D4 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x078 0x2D8 0x000 0x0 0x0 +#define MX8MP_IOMUXC_ENET_RXC__ENET_QOS_RX_ER 0x078 0x2D8 0x000 0x1 0x0 +#define MX8MP_IOMUXC_ENET_RXC__AUDIOMIX_SAI7_TX_BCLK 0x078 0x2D8 0x53C 0x2 0x0 +#define MX8MP_IOMUXC_ENET_RXC__AUDIOMIX_BIT_STREAM02 0x078 0x2D8 0x4C8 0x3 0x0 +#define MX8MP_IOMUXC_ENET_RXC__GPIO1_IO25 0x078 0x2D8 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ENET_RXC__USDHC3_DATA3 0x078 0x2D8 0x61C 0x6 0x0 +#define MX8MP_IOMUXC_ENET_RXC__SIM_M_HADDR24 0x078 0x2D8 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ENET_RD0__ENET_QOS_RGMII_RD0 0x07C 0x2DC 0x000 0x0 0x0 +#define MX8MP_IOMUXC_ENET_RD0__AUDIOMIX_SAI7_RX_DATA00 0x07C 0x2DC 0x534 0x2 0x0 +#define MX8MP_IOMUXC_ENET_RD0__AUDIOMIX_BIT_STREAM01 0x07C 0x2DC 0x4C4 0x3 0x0 +#define MX8MP_IOMUXC_ENET_RD0__GPIO1_IO26 0x07C 0x2DC 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ENET_RD0__USDHC3_DATA4 0x07C 0x2DC 0x620 0x6 0x0 +#define MX8MP_IOMUXC_ENET_RD0__SIM_M_HADDR25 0x07C 0x2DC 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ENET_RD1__ENET_QOS_RGMII_RD1 0x080 0x2E0 0x000 0x0 0x0 +#define MX8MP_IOMUXC_ENET_RD1__AUDIOMIX_SAI7_RX_SYNC 0x080 0x2E0 0x538 0x2 0x0 +#define MX8MP_IOMUXC_ENET_RD1__AUDIOMIX_BIT_STREAM00 0x080 0x2E0 0x4C0 0x3 0x0 +#define MX8MP_IOMUXC_ENET_RD1__GPIO1_IO27 0x080 0x2E0 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ENET_RD1__USDHC3_RESET_B 0x080 0x2E0 0x000 0x6 0x0 +#define MX8MP_IOMUXC_ENET_RD1__SIM_M_HADDR26 0x080 0x2E0 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ENET_RD2__ENET_QOS_RGMII_RD2 0x084 0x2E4 0x000 0x0 0x0 +#define MX8MP_IOMUXC_ENET_RD2__AUDIOMIX_SAI7_RX_BCLK 0x084 0x2E4 0x530 0x2 0x0 +#define MX8MP_IOMUXC_ENET_RD2__AUDIOMIX_CLK 0x084 0x2E4 0x000 0x3 0x0 +#define MX8MP_IOMUXC_ENET_RD2__GPIO1_IO28 0x084 0x2E4 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ENET_RD2__USDHC3_CLK 0x084 0x2E4 0x604 0x6 0x0 +#define MX8MP_IOMUXC_ENET_RD2__SIM_M_HADDR27 0x084 0x2E4 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ENET_RD3__ENET_QOS_RGMII_RD3 0x088 0x2E8 0x000 0x0 0x0 +#define MX8MP_IOMUXC_ENET_RD3__AUDIOMIX_SAI7_MCLK 0x088 0x2E8 0x52C 0x2 0x0 +#define MX8MP_IOMUXC_ENET_RD3__AUDIOMIX_SPDIF_IN 0x088 0x2E8 0x544 0x3 0x0 +#define MX8MP_IOMUXC_ENET_RD3__GPIO1_IO29 0x088 0x2E8 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ENET_RD3__USDHC3_CMD 0x088 0x2E8 0x60C 0x6 0x0 +#define MX8MP_IOMUXC_ENET_RD3__SIM_M_HADDR28 0x088 0x2E8 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD1_CLK__USDHC1_CLK 0x08C 0x2EC 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD1_CLK__ENET1_MDC 0x08C 0x2EC 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SD1_CLK__I2C5_SCL 0x08C 0x2EC 0x5C4 0x3 0x0 +#define MX8MP_IOMUXC_SD1_CLK__UART1_DCE_TX 0x08C 0x2EC 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SD1_CLK__UART1_DTE_RX 0x08C 0x2EC 0x5E8 0x4 0x0 +#define MX8MP_IOMUXC_SD1_CLK__GPIO2_IO00 0x08C 0x2EC 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD1_CLK__SIM_M_HADDR29 0x08C 0x2EC 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD1_CMD__USDHC1_CMD 0x090 0x2F0 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD1_CMD__ENET1_MDIO 0x090 0x2F0 0x57C 0x1 0x0 +#define MX8MP_IOMUXC_SD1_CMD__I2C5_SDA 0x090 0x2F0 0x5C8 0x3 0x0 +#define MX8MP_IOMUXC_SD1_CMD__UART1_DCE_RX 0x090 0x2F0 0x5E8 0x4 0x1 +#define MX8MP_IOMUXC_SD1_CMD__UART1_DTE_TX 0x090 0x2F0 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SD1_CMD__GPIO2_IO01 0x090 0x2F0 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD1_CMD__SIM_M_HADDR30 0x090 0x2F0 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD1_DATA0__USDHC1_DATA0 0x094 0x2F4 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD1_DATA0__ENET1_RGMII_TD1 0x094 0x2F4 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SD1_DATA0__I2C6_SCL 0x094 0x2F4 0x5CC 0x3 0x0 +#define MX8MP_IOMUXC_SD1_DATA0__UART1_DCE_RTS 0x094 0x2F4 0x5E4 0x4 0x0 +#define MX8MP_IOMUXC_SD1_DATA0__UART1_DTE_CTS 0x094 0x2F4 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SD1_DATA0__GPIO2_IO02 0x094 0x2F4 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD1_DATA0__SIM_M_HADDR31 0x094 0x2F4 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD1_DATA1__USDHC1_DATA1 0x098 0x2F8 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD1_DATA1__ENET1_RGMII_TD0 0x098 0x2F8 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SD1_DATA1__I2C6_SDA 0x098 0x2F8 0x5D0 0x3 0x0 +#define MX8MP_IOMUXC_SD1_DATA1__UART1_DCE_CTS 0x098 0x2F8 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SD1_DATA1__UART1_DTE_RTS 0x098 0x2F8 0x5E4 0x4 0x1 +#define MX8MP_IOMUXC_SD1_DATA1__GPIO2_IO03 0x098 0x2F8 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD1_DATA1__SIM_M_HBURST00 0x098 0x2F8 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD1_DATA2__USDHC1_DATA2 0x09C 0x2FC 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD1_DATA2__ENET1_RGMII_RD0 0x09C 0x2FC 0x580 0x1 0x0 +#define MX8MP_IOMUXC_SD1_DATA2__I2C4_SCL 0x09C 0x2FC 0x5BC 0x3 0x0 +#define MX8MP_IOMUXC_SD1_DATA2__UART2_DCE_TX 0x09C 0x2FC 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SD1_DATA2__UART2_DTE_RX 0x09C 0x2FC 0x5F0 0x4 0x0 +#define MX8MP_IOMUXC_SD1_DATA2__GPIO2_IO04 0x09C 0x2FC 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD1_DATA2__SIM_M_HBURST01 0x09C 0x2FC 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD1_DATA3__USDHC1_DATA3 0x0A0 0x300 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD1_DATA3__ENET1_RGMII_RD1 0x0A0 0x300 0x584 0x1 0x0 +#define MX8MP_IOMUXC_SD1_DATA3__I2C4_SDA 0x0A0 0x300 0x5C0 0x3 0x0 +#define MX8MP_IOMUXC_SD1_DATA3__UART2_DCE_RX 0x0A0 0x300 0x5F0 0x4 0x1 +#define MX8MP_IOMUXC_SD1_DATA3__UART2_DTE_TX 0x0A0 0x300 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SD1_DATA3__GPIO2_IO05 0x0A0 0x300 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD1_DATA3__SIM_M_HBURST02 0x0A0 0x300 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD1_DATA4__USDHC1_DATA4 0x0A4 0x304 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD1_DATA4__ENET1_RGMII_TX_CTL 0x0A4 0x304 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SD1_DATA4__I2C1_SCL 0x0A4 0x304 0x5A4 0x3 0x0 +#define MX8MP_IOMUXC_SD1_DATA4__UART2_DCE_RTS 0x0A4 0x304 0x5EC 0x4 0x0 +#define MX8MP_IOMUXC_SD1_DATA4__UART2_DTE_CTS 0x0A4 0x304 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SD1_DATA4__GPIO2_IO06 0x0A4 0x304 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD1_DATA4__SIM_M_HRESP 0x0A4 0x304 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD1_DATA5__USDHC1_DATA5 0x0A8 0x308 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD1_DATA5__ENET1_TX_ER 0x0A8 0x308 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SD1_DATA5__I2C1_SDA 0x0A8 0x308 0x5A8 0x3 0x0 +#define MX8MP_IOMUXC_SD1_DATA5__UART2_DCE_CTS 0x0A8 0x308 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SD1_DATA5__UART2_DTE_RTS 0x0A8 0x308 0x5EC 0x4 0x1 +#define MX8MP_IOMUXC_SD1_DATA5__GPIO2_IO07 0x0A8 0x308 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD1_DATA5__TPSMP_HDATA05 0x0A8 0x308 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD1_DATA6__USDHC1_DATA6 0x0AC 0x30C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD1_DATA6__ENET1_RGMII_RX_CTL 0x0AC 0x30C 0x588 0x1 0x0 +#define MX8MP_IOMUXC_SD1_DATA6__I2C2_SCL 0x0AC 0x30C 0x5AC 0x3 0x0 +#define MX8MP_IOMUXC_SD1_DATA6__UART3_DCE_TX 0x0AC 0x30C 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SD1_DATA6__UART3_DTE_RX 0x0AC 0x30C 0x5F8 0x4 0x0 +#define MX8MP_IOMUXC_SD1_DATA6__GPIO2_IO08 0x0AC 0x30C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD1_DATA6__TPSMP_HDATA06 0x0AC 0x30C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD1_DATA7__USDHC1_DATA7 0x0B0 0x310 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD1_DATA7__ENET1_RX_ER 0x0B0 0x310 0x58C 0x1 0x0 +#define MX8MP_IOMUXC_SD1_DATA7__I2C2_SDA 0x0B0 0x310 0x5B0 0x3 0x0 +#define MX8MP_IOMUXC_SD1_DATA7__UART3_DCE_RX 0x0B0 0x310 0x5F8 0x4 0x1 +#define MX8MP_IOMUXC_SD1_DATA7__UART3_DTE_TX 0x0B0 0x310 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SD1_DATA7__GPIO2_IO09 0x0B0 0x310 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD1_DATA7__TPSMP_HDATA07 0x0B0 0x310 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD1_RESET_B__USDHC1_RESET_B 0x0B4 0x314 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD1_RESET_B__ENET1_TX_CLK 0x0B4 0x314 0x578 0x1 0x0 +#define MX8MP_IOMUXC_SD1_RESET_B__I2C3_SCL 0x0B4 0x314 0x5B4 0x3 0x0 +#define MX8MP_IOMUXC_SD1_RESET_B__UART3_DCE_RTS 0x0B4 0x314 0x5F4 0x4 0x0 +#define MX8MP_IOMUXC_SD1_RESET_B__UART3_DTE_CTS 0x0B4 0x314 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SD1_RESET_B__GPIO2_IO10 0x0B4 0x314 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD1_RESET_B__ECSPI3_TEST_TRIG 0x0B4 0x314 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD1_STROBE__USDHC1_STROBE 0x0B8 0x318 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD1_STROBE__I2C3_SDA 0x0B8 0x318 0x5B8 0x3 0x0 +#define MX8MP_IOMUXC_SD1_STROBE__UART3_DCE_CTS 0x0B8 0x318 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SD1_STROBE__UART3_DTE_RTS 0x0B8 0x318 0x5F4 0x4 0x1 +#define MX8MP_IOMUXC_SD1_STROBE__GPIO2_IO11 0x0B8 0x318 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD1_STROBE__USDHC3_TEST_TRIG 0x0B8 0x318 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD2_CD_B__USDHC2_CD_B 0x0BC 0x31C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD2_CD_B__GPIO2_IO12 0x0BC 0x31C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD2_CD_B__CCMSRCGPCMIX_TESTER_ACK 0x0BC 0x31C 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x0C0 0x320 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD2_CLK__ECSPI2_SCLK 0x0C0 0x320 0x568 0x2 0x0 +#define MX8MP_IOMUXC_SD2_CLK__UART4_DCE_RX 0x0C0 0x320 0x600 0x3 0x0 +#define MX8MP_IOMUXC_SD2_CLK__UART4_DTE_TX 0x0C0 0x320 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SD2_CLK__GPIO2_IO13 0x0C0 0x320 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD2_CLK__CCMSRCGPCMIX_OBSERVE0 0x0C0 0x320 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SD2_CLK__OBSERVE_MUX_OUT00 0x0C0 0x320 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x0C4 0x324 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD2_CMD__ECSPI2_MOSI 0x0C4 0x324 0x570 0x2 0x0 +#define MX8MP_IOMUXC_SD2_CMD__UART4_DCE_TX 0x0C4 0x324 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SD2_CMD__UART4_DTE_RX 0x0C4 0x324 0x600 0x3 0x1 +#define MX8MP_IOMUXC_SD2_CMD__AUDIOMIX_CLK 0x0C4 0x324 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SD2_CMD__GPIO2_IO14 0x0C4 0x324 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD2_CMD__CCMSRCGPCMIX_OBSERVE1 0x0C4 0x324 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SD2_CMD__OBSERVE_MUX_OUT01 0x0C4 0x324 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x0C8 0x328 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD2_DATA0__I2C4_SDA 0x0C8 0x328 0x5C0 0x2 0x1 +#define MX8MP_IOMUXC_SD2_DATA0__UART2_DCE_RX 0x0C8 0x328 0x5F0 0x3 0x2 +#define MX8MP_IOMUXC_SD2_DATA0__UART2_DTE_TX 0x0C8 0x328 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SD2_DATA0__AUDIOMIX_BIT_STREAM00 0x0C8 0x328 0x4C0 0x4 0x1 +#define MX8MP_IOMUXC_SD2_DATA0__GPIO2_IO15 0x0C8 0x328 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD2_DATA0__CCMSRCGPCMIX_OBSERVE2 0x0C8 0x328 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SD2_DATA0__OBSERVE_MUX_OUT02 0x0C8 0x328 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x0CC 0x32C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD2_DATA1__I2C4_SCL 0x0CC 0x32C 0x5BC 0x2 0x1 +#define MX8MP_IOMUXC_SD2_DATA1__UART2_DCE_TX 0x0CC 0x32C 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SD2_DATA1__UART2_DTE_RX 0x0CC 0x32C 0x5F0 0x3 0x3 +#define MX8MP_IOMUXC_SD2_DATA1__AUDIOMIX_BIT_STREAM01 0x0CC 0x32C 0x4C4 0x4 0x1 +#define MX8MP_IOMUXC_SD2_DATA1__GPIO2_IO16 0x0CC 0x32C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD2_DATA1__CCMSRCGPCMIX_WAIT 0x0CC 0x32C 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SD2_DATA1__OBSERVE_MUX_OUT03 0x0CC 0x32C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x0D0 0x330 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD2_DATA2__ECSPI2_SS0 0x0D0 0x330 0x574 0x2 0x0 +#define MX8MP_IOMUXC_SD2_DATA2__AUDIOMIX_SPDIF_OUT 0x0D0 0x330 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SD2_DATA2__AUDIOMIX_BIT_STREAM02 0x0D0 0x330 0x4C8 0x4 0x1 +#define MX8MP_IOMUXC_SD2_DATA2__GPIO2_IO17 0x0D0 0x330 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD2_DATA2__CCMSRCGPCMIX_STOP 0x0D0 0x330 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SD2_DATA2__OBSERVE_MUX_OUT04 0x0D0 0x330 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x0D4 0x334 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD2_DATA3__ECSPI2_MISO 0x0D4 0x334 0x56C 0x2 0x0 +#define MX8MP_IOMUXC_SD2_DATA3__AUDIOMIX_SPDIF_IN 0x0D4 0x334 0x544 0x3 0x1 +#define MX8MP_IOMUXC_SD2_DATA3__AUDIOMIX_BIT_STREAM03 0x0D4 0x334 0x4CC 0x4 0x1 +#define MX8MP_IOMUXC_SD2_DATA3__GPIO2_IO18 0x0D4 0x334 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD2_DATA3__CCMSRCGPCMIX_EARLY_RESET 0x0D4 0x334 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SD2_RESET_B__USDHC2_RESET_B 0x0D8 0x338 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD2_RESET_B__GPIO2_IO19 0x0D8 0x338 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD2_RESET_B__CCMSRCGPCMIX_SYSTEM_RESET 0x0D8 0x338 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SD2_WP__USDHC2_WP 0x0DC 0x33C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SD2_WP__GPIO2_IO20 0x0DC 0x33C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SD2_WP__CORESIGHT_EVENTI 0x0DC 0x33C 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SD2_WP__SIM_M_HMASTLOCK 0x0DC 0x33C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_ALE__RAWNAND_ALE 0x0E0 0x340 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_ALE__FLEXSPI_A_SCLK 0x0E0 0x340 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_ALE__AUDIOMIX_SAI3_TX_BCLK 0x0E0 0x340 0x4E8 0x2 0x0 +#define MX8MP_IOMUXC_NAND_ALE__MEDIAMIX_ISP_FL_TRIG_0 0x0E0 0x340 0x5D4 0x3 0x1 +#define MX8MP_IOMUXC_NAND_ALE__UART3_DCE_RX 0x0E0 0x340 0x5F8 0x4 0x2 +#define MX8MP_IOMUXC_NAND_ALE__UART3_DTE_TX 0x0E0 0x340 0x000 0x4 0x0 +#define MX8MP_IOMUXC_NAND_ALE__GPIO3_IO00 0x0E0 0x340 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_ALE__CORESIGHT_TRACE_CLK 0x0E0 0x340 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_ALE__SIM_M_HPROT00 0x0E0 0x340 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_CE0_B__RAWNAND_CE0_B 0x0E4 0x344 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_CE0_B__FLEXSPI_A_SS0_B 0x0E4 0x344 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_CE0_B__AUDIOMIX_SAI3_TX_DATA00 0x0E4 0x344 0x000 0x2 0x0 +#define MX8MP_IOMUXC_NAND_CE0_B__MEDIAMIX_ISP_SHUTTER_TRIG_0 0x0E4 0x344 0x5DC 0x3 0x1 +#define MX8MP_IOMUXC_NAND_CE0_B__UART3_DCE_TX 0x0E4 0x344 0x000 0x4 0x0 +#define MX8MP_IOMUXC_NAND_CE0_B__UART3_DTE_RX 0x0E4 0x344 0x5F8 0x4 0x3 +#define MX8MP_IOMUXC_NAND_CE0_B__GPIO3_IO01 0x0E4 0x344 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_CE0_B__CORESIGHT_TRACE_CTL 0x0E4 0x344 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_CE0_B__SIM_M_HPROT01 0x0E4 0x344 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_CE1_B__RAWNAND_CE1_B 0x0E8 0x348 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_CE1_B__FLEXSPI_A_SS1_B 0x0E8 0x348 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x0E8 0x348 0x630 0x2 0x1 +#define MX8MP_IOMUXC_NAND_CE1_B__I2C4_SCL 0x0E8 0x348 0x5BC 0x4 0x2 +#define MX8MP_IOMUXC_NAND_CE1_B__GPIO3_IO02 0x0E8 0x348 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_CE1_B__CORESIGHT_TRACE00 0x0E8 0x348 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_CE1_B__SIM_M_HPROT02 0x0E8 0x348 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_CE2_B__RAWNAND_CE2_B 0x0EC 0x34C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_CE2_B__FLEXSPI_B_SS0_B 0x0EC 0x34C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x0EC 0x34C 0x624 0x2 0x1 +#define MX8MP_IOMUXC_NAND_CE2_B__I2C4_SDA 0x0EC 0x34C 0x5C0 0x4 0x2 +#define MX8MP_IOMUXC_NAND_CE2_B__GPIO3_IO03 0x0EC 0x34C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_CE2_B__CORESIGHT_TRACE01 0x0EC 0x34C 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_CE2_B__SIM_M_HPROT03 0x0EC 0x34C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_CE3_B__RAWNAND_CE3_B 0x0F0 0x350 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_CE3_B__FLEXSPI_B_SS1_B 0x0F0 0x350 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x0F0 0x350 0x628 0x2 0x1 +#define MX8MP_IOMUXC_NAND_CE3_B__I2C3_SDA 0x0F0 0x350 0x5B8 0x4 0x1 +#define MX8MP_IOMUXC_NAND_CE3_B__GPIO3_IO04 0x0F0 0x350 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_CE3_B__CORESIGHT_TRACE02 0x0F0 0x350 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_CE3_B__SIM_M_HADDR00 0x0F0 0x350 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_CLE__RAWNAND_CLE 0x0F4 0x354 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_CLE__FLEXSPI_B_SCLK 0x0F4 0x354 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x0F4 0x354 0x62C 0x2 0x1 +#define MX8MP_IOMUXC_NAND_CLE__UART4_DCE_RX 0x0F4 0x354 0x600 0x4 0x2 +#define MX8MP_IOMUXC_NAND_CLE__UART4_DTE_TX 0x0F4 0x354 0x000 0x4 0x0 +#define MX8MP_IOMUXC_NAND_CLE__GPIO3_IO05 0x0F4 0x354 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_CLE__CORESIGHT_TRACE03 0x0F4 0x354 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_CLE__SIM_M_HADDR01 0x0F4 0x354 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_DATA00__RAWNAND_DATA00 0x0F8 0x358 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA00__FLEXSPI_A_DATA00 0x0F8 0x358 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_DATA00__AUDIOMIX_SAI3_RX_DATA00 0x0F8 0x358 0x4E4 0x2 0x0 +#define MX8MP_IOMUXC_NAND_DATA00__MEDIAMIX_ISP_FLASH_TRIG_0 0x0F8 0x358 0x000 0x3 0x0 +#define MX8MP_IOMUXC_NAND_DATA00__UART4_DCE_RX 0x0F8 0x358 0x600 0x4 0x3 +#define MX8MP_IOMUXC_NAND_DATA00__UART4_DTE_TX 0x0F8 0x358 0x000 0x4 0x0 +#define MX8MP_IOMUXC_NAND_DATA00__GPIO3_IO06 0x0F8 0x358 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_DATA00__CORESIGHT_TRACE04 0x0F8 0x358 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_DATA00__SIM_M_HADDR02 0x0F8 0x358 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_DATA01__RAWNAND_DATA01 0x0FC 0x35C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA01__FLEXSPI_A_DATA01 0x0FC 0x35C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_DATA01__AUDIOMIX_SAI3_TX_SYNC 0x0FC 0x35C 0x4EC 0x2 0x0 +#define MX8MP_IOMUXC_NAND_DATA01__MEDIAMIX_ISP_PRELIGHT_TRIG_0 0x0FC 0x35C 0x000 0x3 0x0 +#define MX8MP_IOMUXC_NAND_DATA01__UART4_DCE_TX 0x0FC 0x35C 0x000 0x4 0x0 +#define MX8MP_IOMUXC_NAND_DATA01__UART4_DTE_RX 0x0FC 0x35C 0x600 0x4 0x4 +#define MX8MP_IOMUXC_NAND_DATA01__GPIO3_IO07 0x0FC 0x35C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_DATA01__CORESIGHT_TRACE05 0x0FC 0x35C 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_DATA01__SIM_M_HADDR03 0x0FC 0x35C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_DATA02__RAWNAND_DATA02 0x100 0x360 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA02__FLEXSPI_A_DATA02 0x100 0x360 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_DATA02__USDHC3_CD_B 0x100 0x360 0x608 0x2 0x2 +#define MX8MP_IOMUXC_NAND_DATA02__UART4_DCE_CTS 0x100 0x360 0x000 0x3 0x0 +#define MX8MP_IOMUXC_NAND_DATA02__UART4_DTE_RTS 0x100 0x360 0x5FC 0x3 0x0 +#define MX8MP_IOMUXC_NAND_DATA02__I2C4_SDA 0x100 0x360 0x5C0 0x4 0x3 +#define MX8MP_IOMUXC_NAND_DATA02__GPIO3_IO08 0x100 0x360 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_DATA02__CORESIGHT_TRACE06 0x100 0x360 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_DATA02__SIM_M_HADDR04 0x100 0x360 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_DATA03__RAWNAND_DATA03 0x104 0x364 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA03__FLEXSPI_A_DATA03 0x104 0x364 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_DATA03__USDHC3_WP 0x104 0x364 0x634 0x2 0x2 +#define MX8MP_IOMUXC_NAND_DATA03__UART4_DCE_RTS 0x104 0x364 0x5FC 0x3 0x1 +#define MX8MP_IOMUXC_NAND_DATA03__UART4_DTE_CTS 0x104 0x364 0x000 0x3 0x0 +#define MX8MP_IOMUXC_NAND_DATA03__MEDIAMIX_ISP_FL_TRIG_1 0x104 0x364 0x5D8 0x4 0x1 +#define MX8MP_IOMUXC_NAND_DATA03__GPIO3_IO09 0x104 0x364 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_DATA03__CORESIGHT_TRACE07 0x104 0x364 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_DATA03__SIM_M_HADDR05 0x104 0x364 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_DATA04__RAWNAND_DATA04 0x108 0x368 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA04__FLEXSPI_B_DATA00 0x108 0x368 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x108 0x368 0x610 0x2 0x1 +#define MX8MP_IOMUXC_NAND_DATA04__FLEXSPI_A_DATA04 0x108 0x368 0x000 0x3 0x0 +#define MX8MP_IOMUXC_NAND_DATA04__MEDIAMIX_ISP_SHUTTER_TRIG_1 0x108 0x368 0x5E0 0x4 0x1 +#define MX8MP_IOMUXC_NAND_DATA04__GPIO3_IO10 0x108 0x368 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_DATA04__CORESIGHT_TRACE08 0x108 0x368 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_DATA04__SIM_M_HADDR06 0x108 0x368 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_DATA05__RAWNAND_DATA05 0x10C 0x36C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA05__FLEXSPI_B_DATA01 0x10C 0x36C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x10C 0x36C 0x614 0x2 0x1 +#define MX8MP_IOMUXC_NAND_DATA05__FLEXSPI_A_DATA05 0x10C 0x36C 0x000 0x3 0x0 +#define MX8MP_IOMUXC_NAND_DATA05__MEDIAMIX_ISP_FLASH_TRIG_1 0x10C 0x36C 0x000 0x4 0x0 +#define MX8MP_IOMUXC_NAND_DATA05__GPIO3_IO11 0x10C 0x36C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_DATA05__CORESIGHT_TRACE09 0x10C 0x36C 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_DATA05__SIM_M_HADDR07 0x10C 0x36C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_DATA06__RAWNAND_DATA06 0x110 0x370 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA06__FLEXSPI_B_DATA02 0x110 0x370 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x110 0x370 0x618 0x2 0x1 +#define MX8MP_IOMUXC_NAND_DATA06__FLEXSPI_A_DATA06 0x110 0x370 0x000 0x3 0x0 +#define MX8MP_IOMUXC_NAND_DATA06__MEDIAMIX_ISP_PRELIGHT_TRIG_1 0x110 0x370 0x000 0x4 0x0 +#define MX8MP_IOMUXC_NAND_DATA06__GPIO3_IO12 0x110 0x370 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_DATA06__CORESIGHT_TRACE10 0x110 0x370 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_DATA06__SIM_M_HADDR08 0x110 0x370 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_DATA07__RAWNAND_DATA07 0x114 0x374 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DATA07__FLEXSPI_B_DATA03 0x114 0x374 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x114 0x374 0x61C 0x2 0x1 +#define MX8MP_IOMUXC_NAND_DATA07__FLEXSPI_A_DATA07 0x114 0x374 0x000 0x3 0x0 +#define MX8MP_IOMUXC_NAND_DATA07__MEDIAMIX_ISP_SHUTTER_OPEN_1 0x114 0x374 0x000 0x4 0x0 +#define MX8MP_IOMUXC_NAND_DATA07__GPIO3_IO13 0x114 0x374 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_DATA07__CORESIGHT_TRACE11 0x114 0x374 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_DATA07__SIM_M_HADDR09 0x114 0x374 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_DQS__RAWNAND_DQS 0x118 0x378 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_DQS__FLEXSPI_A_DQS 0x118 0x378 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_DQS__AUDIOMIX_SAI3_MCLK 0x118 0x378 0x4E0 0x2 0x0 +#define MX8MP_IOMUXC_NAND_DQS__MEDIAMIX_ISP_SHUTTER_OPEN_0 0x118 0x378 0x000 0x3 0x0 +#define MX8MP_IOMUXC_NAND_DQS__I2C3_SCL 0x118 0x378 0x5B4 0x4 0x1 +#define MX8MP_IOMUXC_NAND_DQS__GPIO3_IO14 0x118 0x378 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_DQS__CORESIGHT_TRACE12 0x118 0x378 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_DQS__SIM_M_HADDR10 0x118 0x378 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_RE_B__RAWNAND_RE_B 0x11C 0x37C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_RE_B__FLEXSPI_B_DQS 0x11C 0x37C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x11C 0x37C 0x620 0x2 0x1 +#define MX8MP_IOMUXC_NAND_RE_B__UART4_DCE_TX 0x11C 0x37C 0x000 0x4 0x0 +#define MX8MP_IOMUXC_NAND_RE_B__UART4_DTE_RX 0x11C 0x37C 0x600 0x4 0x5 +#define MX8MP_IOMUXC_NAND_RE_B__GPIO3_IO15 0x11C 0x37C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_RE_B__CORESIGHT_TRACE13 0x11C 0x37C 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_RE_B__SIM_M_HADDR11 0x11C 0x37C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_READY_B__RAWNAND_READY_B 0x120 0x380 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_READY_B__USDHC3_RESET_B 0x120 0x380 0x000 0x2 0x0 +#define MX8MP_IOMUXC_NAND_READY_B__I2C3_SCL 0x120 0x380 0x5B4 0x4 0x2 +#define MX8MP_IOMUXC_NAND_READY_B__GPIO3_IO16 0x120 0x380 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_READY_B__CORESIGHT_TRACE14 0x120 0x380 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_READY_B__SIM_M_HADDR12 0x120 0x380 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_WE_B__RAWNAND_WE_B 0x124 0x384 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x124 0x384 0x604 0x2 0x1 +#define MX8MP_IOMUXC_NAND_WE_B__I2C3_SDA 0x124 0x384 0x5B8 0x4 0x2 +#define MX8MP_IOMUXC_NAND_WE_B__GPIO3_IO17 0x124 0x384 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_WE_B__CORESIGHT_TRACE15 0x124 0x384 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_WE_B__SIM_M_HADDR13 0x124 0x384 0x000 0x7 0x0 +#define MX8MP_IOMUXC_NAND_WP_B__RAWNAND_WP_B 0x128 0x388 0x000 0x0 0x0 +#define MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x128 0x388 0x60C 0x2 0x1 +#define MX8MP_IOMUXC_NAND_WP_B__I2C4_SCL 0x128 0x388 0x5BC 0x4 0x3 +#define MX8MP_IOMUXC_NAND_WP_B__GPIO3_IO18 0x128 0x388 0x000 0x5 0x0 +#define MX8MP_IOMUXC_NAND_WP_B__CORESIGHT_EVENTO 0x128 0x388 0x000 0x6 0x0 +#define MX8MP_IOMUXC_NAND_WP_B__SIM_M_HADDR14 0x128 0x388 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI5_RXFS__AUDIOMIX_SAI5_RX_SYNC 0x12C 0x38C 0x508 0x0 0x0 +#define MX8MP_IOMUXC_SAI5_RXFS__AUDIOMIX_SAI1_TX_DATA00 0x12C 0x38C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI5_RXFS__PWM4_OUT 0x12C 0x38C 0x000 0x2 0x0 +#define MX8MP_IOMUXC_SAI5_RXFS__I2C6_SCL 0x12C 0x38C 0x5CC 0x3 0x1 +#define MX8MP_IOMUXC_SAI5_RXFS__GPIO3_IO19 0x12C 0x38C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI5_RXC__AUDIOMIX_SAI5_RX_BCLK 0x130 0x390 0x4F4 0x0 0x0 +#define MX8MP_IOMUXC_SAI5_RXC__AUDIOMIX_SAI1_TX_DATA01 0x130 0x390 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI5_RXC__PWM3_OUT 0x130 0x390 0x000 0x2 0x0 +#define MX8MP_IOMUXC_SAI5_RXC__I2C6_SDA 0x130 0x390 0x5D0 0x3 0x1 +#define MX8MP_IOMUXC_SAI5_RXC__AUDIOMIX_CLK 0x130 0x390 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI5_RXC__GPIO3_IO20 0x130 0x390 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI5_RXD0__AUDIOMIX_SAI5_RX_DATA00 0x134 0x394 0x4F8 0x0 0x0 +#define MX8MP_IOMUXC_SAI5_RXD0__AUDIOMIX_SAI1_TX_DATA02 0x134 0x394 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI5_RXD0__PWM2_OUT 0x134 0x394 0x000 0x2 0x0 +#define MX8MP_IOMUXC_SAI5_RXD0__I2C5_SCL 0x134 0x394 0x5C4 0x3 0x1 +#define MX8MP_IOMUXC_SAI5_RXD0__AUDIOMIX_BIT_STREAM00 0x134 0x394 0x4C0 0x4 0x2 +#define MX8MP_IOMUXC_SAI5_RXD0__GPIO3_IO21 0x134 0x394 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI5_RXD1__AUDIOMIX_SAI5_RX_DATA01 0x138 0x398 0x4FC 0x0 0x0 +#define MX8MP_IOMUXC_SAI5_RXD1__AUDIOMIX_SAI1_TX_DATA03 0x138 0x398 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI5_RXD1__AUDIOMIX_SAI1_TX_SYNC 0x138 0x398 0x4D8 0x2 0x0 +#define MX8MP_IOMUXC_SAI5_RXD1__AUDIOMIX_SAI5_TX_SYNC 0x138 0x398 0x510 0x3 0x0 +#define MX8MP_IOMUXC_SAI5_RXD1__AUDIOMIX_BIT_STREAM01 0x138 0x398 0x4C4 0x4 0x2 +#define MX8MP_IOMUXC_SAI5_RXD1__GPIO3_IO22 0x138 0x398 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI5_RXD1__CAN1_TX 0x138 0x398 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SAI5_RXD2__AUDIOMIX_SAI5_RX_DATA02 0x13C 0x39C 0x500 0x0 0x0 +#define MX8MP_IOMUXC_SAI5_RXD2__AUDIOMIX_SAI1_TX_DATA04 0x13C 0x39C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI5_RXD2__AUDIOMIX_SAI1_TX_SYNC 0x13C 0x39C 0x4D8 0x2 0x1 +#define MX8MP_IOMUXC_SAI5_RXD2__AUDIOMIX_SAI5_TX_BCLK 0x13C 0x39C 0x50C 0x3 0x0 +#define MX8MP_IOMUXC_SAI5_RXD2__AUDIOMIX_BIT_STREAM02 0x13C 0x39C 0x4C8 0x4 0x2 +#define MX8MP_IOMUXC_SAI5_RXD2__GPIO3_IO23 0x13C 0x39C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI5_RXD2__CAN1_RX 0x13C 0x39C 0x54C 0x6 0x0 +#define MX8MP_IOMUXC_SAI5_RXD3__AUDIOMIX_SAI5_RX_DATA03 0x140 0x3A0 0x504 0x0 0x0 +#define MX8MP_IOMUXC_SAI5_RXD3__AUDIOMIX_SAI1_TX_DATA05 0x140 0x3A0 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI5_RXD3__AUDIOMIX_SAI1_TX_SYNC 0x140 0x3A0 0x4D8 0x2 0x2 +#define MX8MP_IOMUXC_SAI5_RXD3__AUDIOMIX_SAI5_TX_DATA00 0x140 0x3A0 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SAI5_RXD3__AUDIOMIX_BIT_STREAM03 0x140 0x3A0 0x4CC 0x4 0x2 +#define MX8MP_IOMUXC_SAI5_RXD3__GPIO3_IO24 0x140 0x3A0 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI5_RXD3__CAN2_TX 0x140 0x3A0 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SAI5_MCLK__AUDIOMIX_SAI5_MCLK 0x144 0x3A4 0x4F0 0x0 0x0 +#define MX8MP_IOMUXC_SAI5_MCLK__AUDIOMIX_SAI1_TX_BCLK 0x144 0x3A4 0x4D4 0x1 0x0 +#define MX8MP_IOMUXC_SAI5_MCLK__PWM1_OUT 0x144 0x3A4 0x000 0x2 0x0 +#define MX8MP_IOMUXC_SAI5_MCLK__I2C5_SDA 0x144 0x3A4 0x5C8 0x3 0x1 +#define MX8MP_IOMUXC_SAI5_MCLK__GPIO3_IO25 0x144 0x3A4 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI5_MCLK__CAN2_RX 0x144 0x3A4 0x550 0x6 0x0 +#define MX8MP_IOMUXC_SAI1_RXFS__AUDIOMIX_SAI1_RX_SYNC 0x148 0x3A8 0x4D0 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_RXFS__AUDIOMIX_SAI5_RX_SYNC 0x148 0x3A8 0x508 0x1 0x1 +#define MX8MP_IOMUXC_SAI1_RXFS__ENET1_1588_EVENT0_IN 0x148 0x3A8 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI1_RXFS__GPIO4_IO00 0x148 0x3A8 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_RXC__AUDIOMIX_SAI1_RX_BCLK 0x14C 0x3AC 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_RXC__AUDIOMIX_SAI5_RX_BCLK 0x14C 0x3AC 0x4F4 0x1 0x1 +#define MX8MP_IOMUXC_SAI1_RXC__AUDIOMIX_CLK 0x14C 0x3AC 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SAI1_RXC__ENET1_1588_EVENT0_OUT 0x14C 0x3AC 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI1_RXC__GPIO4_IO01 0x14C 0x3AC 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_RXD0__AUDIOMIX_SAI1_RX_DATA00 0x150 0x3B0 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_RXD0__AUDIOMIX_SAI5_RX_DATA00 0x150 0x3B0 0x4F8 0x1 0x1 +#define MX8MP_IOMUXC_SAI1_RXD0__AUDIOMIX_SAI1_TX_DATA01 0x150 0x3B0 0x000 0x2 0x0 +#define MX8MP_IOMUXC_SAI1_RXD0__AUDIOMIX_BIT_STREAM00 0x150 0x3B0 0x4C0 0x3 0x3 +#define MX8MP_IOMUXC_SAI1_RXD0__ENET1_1588_EVENT1_IN 0x150 0x3B0 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI1_RXD0__GPIO4_IO02 0x150 0x3B0 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_RXD1__AUDIOMIX_SAI1_RX_DATA01 0x154 0x3B4 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_RXD1__AUDIOMIX_SAI5_RX_DATA01 0x154 0x3B4 0x4FC 0x1 0x1 +#define MX8MP_IOMUXC_SAI1_RXD1__AUDIOMIX_BIT_STREAM01 0x154 0x3B4 0x4C4 0x3 0x3 +#define MX8MP_IOMUXC_SAI1_RXD1__ENET1_1588_EVENT1_OUT 0x154 0x3B4 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI1_RXD1__GPIO4_IO03 0x154 0x3B4 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_RXD2__AUDIOMIX_SAI1_RX_DATA02 0x158 0x3B8 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_RXD2__AUDIOMIX_SAI5_RX_DATA02 0x158 0x3B8 0x500 0x1 0x1 +#define MX8MP_IOMUXC_SAI1_RXD2__AUDIOMIX_BIT_STREAM02 0x158 0x3B8 0x4C8 0x3 0x3 +#define MX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC 0x158 0x3B8 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI1_RXD2__GPIO4_IO04 0x158 0x3B8 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_RXD3__AUDIOMIX_SAI1_RX_DATA03 0x15C 0x3BC 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_RXD3__AUDIOMIX_SAI5_RX_DATA03 0x15C 0x3BC 0x504 0x1 0x1 +#define MX8MP_IOMUXC_SAI1_RXD3__AUDIOMIX_BIT_STREAM03 0x15C 0x3BC 0x4CC 0x3 0x3 +#define MX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO 0x15C 0x3BC 0x57C 0x4 0x1 +#define MX8MP_IOMUXC_SAI1_RXD3__GPIO4_IO05 0x15C 0x3BC 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_RXD4__AUDIOMIX_SAI1_RX_DATA04 0x160 0x3C0 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_RXD4__AUDIOMIX_SAI6_TX_BCLK 0x160 0x3C0 0x524 0x1 0x1 +#define MX8MP_IOMUXC_SAI1_RXD4__AUDIOMIX_SAI6_RX_BCLK 0x160 0x3C0 0x518 0x2 0x1 +#define MX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0 0x160 0x3C0 0x580 0x4 0x1 +#define MX8MP_IOMUXC_SAI1_RXD4__GPIO4_IO06 0x160 0x3C0 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_RXD5__AUDIOMIX_SAI1_RX_DATA05 0x164 0x3C4 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_RXD5__AUDIOMIX_SAI6_TX_DATA00 0x164 0x3C4 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI1_RXD5__AUDIOMIX_SAI6_RX_DATA00 0x164 0x3C4 0x51C 0x2 0x1 +#define MX8MP_IOMUXC_SAI1_RXD5__AUDIOMIX_SAI1_RX_SYNC 0x164 0x3C4 0x4D0 0x3 0x1 +#define MX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1 0x164 0x3C4 0x584 0x4 0x1 +#define MX8MP_IOMUXC_SAI1_RXD5__GPIO4_IO07 0x164 0x3C4 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_RXD6__AUDIOMIX_SAI1_RX_DATA06 0x168 0x3C8 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_RXD6__AUDIOMIX_SAI6_TX_SYNC 0x168 0x3C8 0x528 0x1 0x1 +#define MX8MP_IOMUXC_SAI1_RXD6__AUDIOMIX_SAI6_RX_SYNC 0x168 0x3C8 0x520 0x2 0x1 +#define MX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2 0x168 0x3C8 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI1_RXD6__GPIO4_IO08 0x168 0x3C8 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_RXD7__AUDIOMIX_SAI1_RX_DATA07 0x16C 0x3CC 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_RXD7__AUDIOMIX_SAI6_MCLK 0x16C 0x3CC 0x514 0x1 0x1 +#define MX8MP_IOMUXC_SAI1_RXD7__AUDIOMIX_SAI1_TX_SYNC 0x16C 0x3CC 0x4D8 0x2 0x3 +#define MX8MP_IOMUXC_SAI1_RXD7__AUDIOMIX_SAI1_TX_DATA04 0x16C 0x3CC 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3 0x16C 0x3CC 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI1_RXD7__GPIO4_IO09 0x16C 0x3CC 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_TXFS__AUDIOMIX_SAI1_TX_SYNC 0x170 0x3D0 0x4D8 0x0 0x4 +#define MX8MP_IOMUXC_SAI1_TXFS__AUDIOMIX_SAI5_TX_SYNC 0x170 0x3D0 0x510 0x1 0x1 +#define MX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL 0x170 0x3D0 0x588 0x4 0x1 +#define MX8MP_IOMUXC_SAI1_TXFS__GPIO4_IO10 0x170 0x3D0 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_TXC__AUDIOMIX_SAI1_TX_BCLK 0x174 0x3D4 0x4D4 0x0 0x1 +#define MX8MP_IOMUXC_SAI1_TXC__AUDIOMIX_SAI5_TX_BCLK 0x174 0x3D4 0x50C 0x1 0x1 +#define MX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC 0x174 0x3D4 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI1_TXC__GPIO4_IO11 0x174 0x3D4 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_TXD0__AUDIOMIX_SAI1_TX_DATA00 0x178 0x3D8 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_TXD0__AUDIOMIX_SAI5_TX_DATA00 0x178 0x3D8 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0 0x178 0x3D8 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI1_TXD0__GPIO4_IO12 0x178 0x3D8 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_TXD1__AUDIOMIX_SAI1_TX_DATA01 0x17C 0x3DC 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_TXD1__AUDIOMIX_SAI5_TX_DATA01 0x17C 0x3DC 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1 0x17C 0x3DC 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI1_TXD1__GPIO4_IO13 0x17C 0x3DC 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_TXD2__AUDIOMIX_SAI1_TX_DATA02 0x180 0x3E0 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_TXD2__AUDIOMIX_SAI5_TX_DATA02 0x180 0x3E0 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2 0x180 0x3E0 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI1_TXD2__GPIO4_IO14 0x180 0x3E0 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_TXD3__AUDIOMIX_SAI1_TX_DATA03 0x184 0x3E4 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_TXD3__AUDIOMIX_SAI5_TX_DATA03 0x184 0x3E4 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3 0x184 0x3E4 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI1_TXD3__GPIO4_IO15 0x184 0x3E4 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_TXD4__AUDIOMIX_SAI1_TX_DATA04 0x188 0x3E8 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_TXD4__AUDIOMIX_SAI6_RX_BCLK 0x188 0x3E8 0x518 0x1 0x2 +#define MX8MP_IOMUXC_SAI1_TXD4__AUDIOMIX_SAI6_TX_BCLK 0x188 0x3E8 0x524 0x2 0x2 +#define MX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL 0x188 0x3E8 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI1_TXD4__GPIO4_IO16 0x188 0x3E8 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_TXD5__AUDIOMIX_SAI1_TX_DATA05 0x18C 0x3EC 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_TXD5__AUDIOMIX_SAI6_RX_DATA00 0x18C 0x3EC 0x51C 0x1 0x2 +#define MX8MP_IOMUXC_SAI1_TXD5__AUDIOMIX_SAI6_TX_DATA00 0x18C 0x3EC 0x000 0x2 0x0 +#define MX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC 0x18C 0x3EC 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI1_TXD5__GPIO4_IO17 0x18C 0x3EC 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_TXD6__AUDIOMIX_SAI1_TX_DATA06 0x190 0x3F0 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_TXD6__AUDIOMIX_SAI6_RX_SYNC 0x190 0x3F0 0x520 0x1 0x2 +#define MX8MP_IOMUXC_SAI1_TXD6__AUDIOMIX_SAI6_TX_SYNC 0x190 0x3F0 0x528 0x2 0x2 +#define MX8MP_IOMUXC_SAI1_TXD6__ENET1_RX_ER 0x190 0x3F0 0x58C 0x4 0x1 +#define MX8MP_IOMUXC_SAI1_TXD6__GPIO4_IO18 0x190 0x3F0 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_TXD7__AUDIOMIX_SAI1_TX_DATA07 0x194 0x3F4 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_TXD7__AUDIOMIX_SAI6_MCLK 0x194 0x3F4 0x514 0x1 0x2 +#define MX8MP_IOMUXC_SAI1_TXD7__AUDIOMIX_CLK 0x194 0x3F4 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SAI1_TXD7__ENET1_TX_ER 0x194 0x3F4 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI1_TXD7__GPIO4_IO19 0x194 0x3F4 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI1_MCLK__AUDIOMIX_SAI1_MCLK 0x198 0x3F8 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI1_MCLK__AUDIOMIX_SAI5_MCLK 0x198 0x3F8 0x4F0 0x1 0x1 +#define MX8MP_IOMUXC_SAI1_MCLK__AUDIOMIX_SAI1_TX_BCLK 0x198 0x3F8 0x4D4 0x2 0x2 +#define MX8MP_IOMUXC_SAI1_MCLK__ENET1_TX_CLK 0x198 0x3F8 0x578 0x4 0x1 +#define MX8MP_IOMUXC_SAI1_MCLK__GPIO4_IO20 0x198 0x3F8 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI2_RXFS__AUDIOMIX_SAI2_RX_SYNC 0x19C 0x3FC 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI2_RXFS__AUDIOMIX_SAI5_TX_SYNC 0x19C 0x3FC 0x510 0x1 0x2 +#define MX8MP_IOMUXC_SAI2_RXFS__AUDIOMIX_SAI5_TX_DATA01 0x19C 0x3FC 0x000 0x2 0x0 +#define MX8MP_IOMUXC_SAI2_RXFS__AUDIOMIX_SAI2_RX_DATA01 0x19C 0x3FC 0x4DC 0x3 0x0 +#define MX8MP_IOMUXC_SAI2_RXFS__UART1_DCE_TX 0x19C 0x3FC 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI2_RXFS__UART1_DTE_RX 0x19C 0x3FC 0x5E8 0x4 0x2 +#define MX8MP_IOMUXC_SAI2_RXFS__GPIO4_IO21 0x19C 0x3FC 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI2_RXFS__AUDIOMIX_BIT_STREAM02 0x19C 0x3FC 0x4C8 0x6 0x4 +#define MX8MP_IOMUXC_SAI2_RXFS__SIM_M_HSIZE00 0x19C 0x3FC 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI2_RXC__AUDIOMIX_SAI2_RX_BCLK 0x1A0 0x400 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI2_RXC__AUDIOMIX_SAI5_TX_BCLK 0x1A0 0x400 0x50C 0x1 0x2 +#define MX8MP_IOMUXC_SAI2_RXC__CAN1_TX 0x1A0 0x400 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SAI2_RXC__UART1_DCE_RX 0x1A0 0x400 0x5E8 0x4 0x3 +#define MX8MP_IOMUXC_SAI2_RXC__UART1_DTE_TX 0x1A0 0x400 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI2_RXC__GPIO4_IO22 0x1A0 0x400 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI2_RXC__AUDIOMIX_BIT_STREAM01 0x1A0 0x400 0x4C4 0x6 0x4 +#define MX8MP_IOMUXC_SAI2_RXC__SIM_M_HSIZE01 0x1A0 0x400 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI2_RXD0__AUDIOMIX_SAI2_RX_DATA00 0x1A4 0x404 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI2_RXD0__AUDIOMIX_SAI5_TX_DATA00 0x1A4 0x404 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI2_RXD0__ENET_QOS_1588_EVENT2_OUT 0x1A4 0x404 0x000 0x2 0x0 +#define MX8MP_IOMUXC_SAI2_RXD0__AUDIOMIX_SAI2_TX_DATA01 0x1A4 0x404 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SAI2_RXD0__UART1_DCE_RTS 0x1A4 0x404 0x5E4 0x4 0x2 +#define MX8MP_IOMUXC_SAI2_RXD0__UART1_DTE_CTS 0x1A4 0x404 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI2_RXD0__GPIO4_IO23 0x1A4 0x404 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI2_RXD0__AUDIOMIX_BIT_STREAM03 0x1A4 0x404 0x4CC 0x6 0x4 +#define MX8MP_IOMUXC_SAI2_RXD0__SIM_M_HSIZE02 0x1A4 0x404 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI2_TXFS__AUDIOMIX_SAI2_TX_SYNC 0x1A8 0x408 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI2_TXFS__AUDIOMIX_SAI5_TX_DATA01 0x1A8 0x408 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI2_TXFS__ENET_QOS_1588_EVENT3_OUT 0x1A8 0x408 0x000 0x2 0x0 +#define MX8MP_IOMUXC_SAI2_TXFS__AUDIOMIX_SAI2_TX_DATA01 0x1A8 0x408 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SAI2_TXFS__UART1_DCE_CTS 0x1A8 0x408 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI2_TXFS__UART1_DTE_RTS 0x1A8 0x408 0x5E4 0x4 0x3 +#define MX8MP_IOMUXC_SAI2_TXFS__GPIO4_IO24 0x1A8 0x408 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI2_TXFS__AUDIOMIX_BIT_STREAM02 0x1A8 0x408 0x4C8 0x6 0x5 +#define MX8MP_IOMUXC_SAI2_TXFS__SIM_M_HWRITE 0x1A8 0x408 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI2_TXC__AUDIOMIX_SAI2_TX_BCLK 0x1AC 0x40C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI2_TXC__AUDIOMIX_SAI5_TX_DATA02 0x1AC 0x40C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI2_TXC__CAN1_RX 0x1AC 0x40C 0x54C 0x3 0x1 +#define MX8MP_IOMUXC_SAI2_TXC__GPIO4_IO25 0x1AC 0x40C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI2_TXC__AUDIOMIX_BIT_STREAM01 0x1AC 0x40C 0x4C4 0x6 0x5 +#define MX8MP_IOMUXC_SAI2_TXC__SIM_M_HREADYOUT 0x1AC 0x40C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI2_TXD0__AUDIOMIX_SAI2_TX_DATA00 0x1B0 0x410 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI2_TXD0__AUDIOMIX_SAI5_TX_DATA03 0x1B0 0x410 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI2_TXD0__ENET_QOS_1588_EVENT2_IN 0x1B0 0x410 0x000 0x2 0x0 +#define MX8MP_IOMUXC_SAI2_TXD0__CAN2_TX 0x1B0 0x410 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SAI2_TXD0__ENET_QOS_1588_EVENT2_AUX_IN 0x1B0 0x410 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI2_TXD0__GPIO4_IO26 0x1B0 0x410 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI2_TXD0__CCMSRCGPCMIX_BOOT_MODE04 0x1B0 0x410 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SAI2_TXD0__TPSMP_CLK 0x1B0 0x410 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI2_MCLK__AUDIOMIX_SAI2_MCLK 0x1B4 0x414 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI2_MCLK__AUDIOMIX_SAI5_MCLK 0x1B4 0x414 0x4F0 0x1 0x2 +#define MX8MP_IOMUXC_SAI2_MCLK__ENET_QOS_1588_EVENT3_IN 0x1B4 0x414 0x000 0x2 0x0 +#define MX8MP_IOMUXC_SAI2_MCLK__CAN2_RX 0x1B4 0x414 0x550 0x3 0x1 +#define MX8MP_IOMUXC_SAI2_MCLK__ENET_QOS_1588_EVENT3_AUX_IN 0x1B4 0x414 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI2_MCLK__GPIO4_IO27 0x1B4 0x414 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI2_MCLK__AUDIOMIX_SAI3_MCLK 0x1B4 0x414 0x4E0 0x6 0x1 +#define MX8MP_IOMUXC_SAI2_MCLK__TPSMP_HDATA_DIR 0x1B4 0x414 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI3_RXFS__AUDIOMIX_SAI3_RX_SYNC 0x1B8 0x418 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI3_RXFS__AUDIOMIX_SAI2_RX_DATA01 0x1B8 0x418 0x4DC 0x1 0x1 +#define MX8MP_IOMUXC_SAI3_RXFS__AUDIOMIX_SAI5_RX_SYNC 0x1B8 0x418 0x508 0x2 0x2 +#define MX8MP_IOMUXC_SAI3_RXFS__AUDIOMIX_SAI3_RX_DATA01 0x1B8 0x418 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SAI3_RXFS__AUDIOMIX_SPDIF_IN 0x1B8 0x418 0x544 0x4 0x2 +#define MX8MP_IOMUXC_SAI3_RXFS__GPIO4_IO28 0x1B8 0x418 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI3_RXFS__AUDIOMIX_BIT_STREAM00 0x1B8 0x418 0x4C0 0x6 0x4 +#define MX8MP_IOMUXC_SAI3_RXFS__TPSMP_HTRANS00 0x1B8 0x418 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI3_RXC__AUDIOMIX_SAI3_RX_BCLK 0x1BC 0x41C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI3_RXC__AUDIOMIX_SAI2_RX_DATA02 0x1BC 0x41C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI3_RXC__AUDIOMIX_SAI5_RX_BCLK 0x1BC 0x41C 0x4F4 0x2 0x2 +#define MX8MP_IOMUXC_SAI3_RXC__GPT1_CLK 0x1BC 0x41C 0x59C 0x3 0x0 +#define MX8MP_IOMUXC_SAI3_RXC__UART2_DCE_CTS 0x1BC 0x41C 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI3_RXC__UART2_DTE_RTS 0x1BC 0x41C 0x5EC 0x4 0x2 +#define MX8MP_IOMUXC_SAI3_RXC__GPIO4_IO29 0x1BC 0x41C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI3_RXC__AUDIOMIX_CLK 0x1BC 0x41C 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SAI3_RXC__TPSMP_HTRANS01 0x1BC 0x41C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI3_RXD__AUDIOMIX_SAI3_RX_DATA00 0x1C0 0x420 0x4E4 0x0 0x1 +#define MX8MP_IOMUXC_SAI3_RXD__AUDIOMIX_SAI2_RX_DATA03 0x1C0 0x420 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI3_RXD__AUDIOMIX_SAI5_RX_DATA00 0x1C0 0x420 0x4F8 0x2 0x2 +#define MX8MP_IOMUXC_SAI3_RXD__UART2_DCE_RTS 0x1C0 0x420 0x5EC 0x4 0x3 +#define MX8MP_IOMUXC_SAI3_RXD__UART2_DTE_CTS 0x1C0 0x420 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI3_RXD__GPIO4_IO30 0x1C0 0x420 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI3_RXD__AUDIOMIX_BIT_STREAM01 0x1C0 0x420 0x4C4 0x6 0x6 +#define MX8MP_IOMUXC_SAI3_RXD__TPSMP_HDATA00 0x1C0 0x420 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI3_TXFS__AUDIOMIX_SAI3_TX_SYNC 0x1C4 0x424 0x4EC 0x0 0x1 +#define MX8MP_IOMUXC_SAI3_TXFS__AUDIOMIX_SAI2_TX_DATA01 0x1C4 0x424 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI3_TXFS__AUDIOMIX_SAI5_RX_DATA01 0x1C4 0x424 0x4FC 0x2 0x2 +#define MX8MP_IOMUXC_SAI3_TXFS__AUDIOMIX_SAI3_TX_DATA01 0x1C4 0x424 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SAI3_TXFS__UART2_DCE_RX 0x1C4 0x424 0x5F0 0x4 0x4 +#define MX8MP_IOMUXC_SAI3_TXFS__UART2_DTE_TX 0x1C4 0x424 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI3_TXFS__GPIO4_IO31 0x1C4 0x424 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI3_TXFS__AUDIOMIX_BIT_STREAM03 0x1C4 0x424 0x4CC 0x6 0x5 +#define MX8MP_IOMUXC_SAI3_TXFS__TPSMP_HDATA01 0x1C4 0x424 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI3_TXC__AUDIOMIX_SAI3_TX_BCLK 0x1C8 0x428 0x4E8 0x0 0x1 +#define MX8MP_IOMUXC_SAI3_TXC__AUDIOMIX_SAI2_TX_DATA02 0x1C8 0x428 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI3_TXC__AUDIOMIX_SAI5_RX_DATA02 0x1C8 0x428 0x500 0x2 0x2 +#define MX8MP_IOMUXC_SAI3_TXC__GPT1_CAPTURE1 0x1C8 0x428 0x594 0x3 0x0 +#define MX8MP_IOMUXC_SAI3_TXC__UART2_DCE_TX 0x1C8 0x428 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI3_TXC__UART2_DTE_RX 0x1C8 0x428 0x5F0 0x4 0x5 +#define MX8MP_IOMUXC_SAI3_TXC__GPIO5_IO00 0x1C8 0x428 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI3_TXC__AUDIOMIX_BIT_STREAM02 0x1C8 0x428 0x4C8 0x6 0x6 +#define MX8MP_IOMUXC_SAI3_TXC__TPSMP_HDATA02 0x1C8 0x428 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI3_TXD__AUDIOMIX_SAI3_TX_DATA00 0x1CC 0x42C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SAI3_TXD__AUDIOMIX_SAI2_TX_DATA03 0x1CC 0x42C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI3_TXD__AUDIOMIX_SAI5_RX_DATA03 0x1CC 0x42C 0x504 0x2 0x2 +#define MX8MP_IOMUXC_SAI3_TXD__GPT1_CAPTURE2 0x1CC 0x42C 0x598 0x3 0x0 +#define MX8MP_IOMUXC_SAI3_TXD__AUDIOMIX_SPDIF_EXT_CLK 0x1CC 0x42C 0x548 0x4 0x0 +#define MX8MP_IOMUXC_SAI3_TXD__GPIO5_IO01 0x1CC 0x42C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI3_TXD__CCMSRCGPCMIX_BOOT_MODE05 0x1CC 0x42C 0x000 0x6 0x0 +#define MX8MP_IOMUXC_SAI3_TXD__TPSMP_HDATA03 0x1CC 0x42C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SAI3_MCLK__AUDIOMIX_SAI3_MCLK 0x1D0 0x430 0x4E0 0x0 0x2 +#define MX8MP_IOMUXC_SAI3_MCLK__PWM4_OUT 0x1D0 0x430 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SAI3_MCLK__AUDIOMIX_SAI5_MCLK 0x1D0 0x430 0x4F0 0x2 0x3 +#define MX8MP_IOMUXC_SAI3_MCLK__AUDIOMIX_SPDIF_OUT 0x1D0 0x430 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SAI3_MCLK__GPIO5_IO02 0x1D0 0x430 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SAI3_MCLK__AUDIOMIX_SPDIF_IN 0x1D0 0x430 0x544 0x6 0x3 +#define MX8MP_IOMUXC_SAI3_MCLK__TPSMP_HDATA04 0x1D0 0x430 0x000 0x7 0x0 +#define MX8MP_IOMUXC_SPDIF_TX__AUDIOMIX_SPDIF_OUT 0x1D4 0x434 0x000 0x0 0x0 +#define MX8MP_IOMUXC_SPDIF_TX__PWM3_OUT 0x1D4 0x434 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SPDIF_TX__I2C5_SCL 0x1D4 0x434 0x5C4 0x2 0x2 +#define MX8MP_IOMUXC_SPDIF_TX__GPT1_COMPARE1 0x1D4 0x434 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SPDIF_TX__CAN1_TX 0x1D4 0x434 0x000 0x4 0x0 +#define MX8MP_IOMUXC_SPDIF_TX__GPIO5_IO03 0x1D4 0x434 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SPDIF_RX__AUDIOMIX_SPDIF_IN 0x1D8 0x438 0x544 0x0 0x4 +#define MX8MP_IOMUXC_SPDIF_RX__PWM2_OUT 0x1D8 0x438 0x000 0x1 0x0 +#define MX8MP_IOMUXC_SPDIF_RX__I2C5_SDA 0x1D8 0x438 0x5C8 0x2 0x2 +#define MX8MP_IOMUXC_SPDIF_RX__GPT1_COMPARE2 0x1D8 0x438 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SPDIF_RX__CAN1_RX 0x1D8 0x438 0x54C 0x4 0x2 +#define MX8MP_IOMUXC_SPDIF_RX__GPIO5_IO04 0x1D8 0x438 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SPDIF_EXT_CLK__GPT1_COMPARE3 0x1DC 0x43C 0x000 0x3 0x0 +#define MX8MP_IOMUXC_SPDIF_EXT_CLK__GPIO5_IO05 0x1DC 0x43C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_SPDIF_EXT_CLK__AUDIOMIX_SPDIF_EXT_CLK 0x1DC 0x43C 0x548 0x0 0x1 +#define MX8MP_IOMUXC_SPDIF_EXT_CLK__PWM1_OUT 0x1DC 0x43C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_ECSPI1_SCLK__ECSPI1_SCLK 0x1E0 0x440 0x558 0x0 0x0 +#define MX8MP_IOMUXC_ECSPI1_SCLK__UART3_DCE_RX 0x1E0 0x440 0x5F8 0x1 0x4 +#define MX8MP_IOMUXC_ECSPI1_SCLK__UART3_DTE_TX 0x1E0 0x440 0x000 0x1 0x0 +#define MX8MP_IOMUXC_ECSPI1_SCLK__I2C1_SCL 0x1E0 0x440 0x5A4 0x2 0x1 +#define MX8MP_IOMUXC_ECSPI1_SCLK__AUDIOMIX_SAI7_RX_SYNC 0x1E0 0x440 0x538 0x3 0x1 +#define MX8MP_IOMUXC_ECSPI1_SCLK__GPIO5_IO06 0x1E0 0x440 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ECSPI1_SCLK__TPSMP_HDATA08 0x1E0 0x440 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ECSPI1_MOSI__ECSPI1_MOSI 0x1E4 0x444 0x560 0x0 0x0 +#define MX8MP_IOMUXC_ECSPI1_MOSI__UART3_DCE_TX 0x1E4 0x444 0x000 0x1 0x0 +#define MX8MP_IOMUXC_ECSPI1_MOSI__UART3_DTE_RX 0x1E4 0x444 0x5F8 0x1 0x5 +#define MX8MP_IOMUXC_ECSPI1_MOSI__I2C1_SDA 0x1E4 0x444 0x5A8 0x2 0x1 +#define MX8MP_IOMUXC_ECSPI1_MOSI__AUDIOMIX_SAI7_RX_BCLK 0x1E4 0x444 0x530 0x3 0x1 +#define MX8MP_IOMUXC_ECSPI1_MOSI__GPIO5_IO07 0x1E4 0x444 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ECSPI1_MOSI__TPSMP_HDATA09 0x1E4 0x444 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ECSPI1_MISO__ECSPI1_MISO 0x1E8 0x448 0x55C 0x0 0x0 +#define MX8MP_IOMUXC_ECSPI1_MISO__UART3_DCE_CTS 0x1E8 0x448 0x000 0x1 0x0 +#define MX8MP_IOMUXC_ECSPI1_MISO__UART3_DTE_RTS 0x1E8 0x448 0x5F4 0x1 0x2 +#define MX8MP_IOMUXC_ECSPI1_MISO__I2C2_SCL 0x1E8 0x448 0x5AC 0x2 0x1 +#define MX8MP_IOMUXC_ECSPI1_MISO__AUDIOMIX_SAI7_RX_DATA00 0x1E8 0x448 0x534 0x3 0x1 +#define MX8MP_IOMUXC_ECSPI1_MISO__GPIO5_IO08 0x1E8 0x448 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ECSPI1_MISO__TPSMP_HDATA10 0x1E8 0x448 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ECSPI1_SS0__ECSPI1_SS0 0x1EC 0x44C 0x564 0x0 0x0 +#define MX8MP_IOMUXC_ECSPI1_SS0__UART3_DCE_RTS 0x1EC 0x44C 0x5F4 0x1 0x3 +#define MX8MP_IOMUXC_ECSPI1_SS0__UART3_DTE_CTS 0x1EC 0x44C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_ECSPI1_SS0__I2C2_SDA 0x1EC 0x44C 0x5B0 0x2 0x1 +#define MX8MP_IOMUXC_ECSPI1_SS0__AUDIOMIX_SAI7_TX_SYNC 0x1EC 0x44C 0x540 0x3 0x1 +#define MX8MP_IOMUXC_ECSPI1_SS0__GPIO5_IO09 0x1EC 0x44C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ECSPI1_SS0__TPSMP_HDATA11 0x1EC 0x44C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ECSPI2_SCLK__ECSPI2_SCLK 0x1F0 0x450 0x568 0x0 0x1 +#define MX8MP_IOMUXC_ECSPI2_SCLK__UART4_DCE_RX 0x1F0 0x450 0x600 0x1 0x6 +#define MX8MP_IOMUXC_ECSPI2_SCLK__UART4_DTE_TX 0x1F0 0x450 0x000 0x1 0x0 +#define MX8MP_IOMUXC_ECSPI2_SCLK__I2C3_SCL 0x1F0 0x450 0x5B4 0x2 0x3 +#define MX8MP_IOMUXC_ECSPI2_SCLK__AUDIOMIX_SAI7_TX_BCLK 0x1F0 0x450 0x53C 0x3 0x1 +#define MX8MP_IOMUXC_ECSPI2_SCLK__GPIO5_IO10 0x1F0 0x450 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ECSPI2_SCLK__TPSMP_HDATA12 0x1F0 0x450 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ECSPI2_MOSI__ECSPI2_MOSI 0x1F4 0x454 0x570 0x0 0x1 +#define MX8MP_IOMUXC_ECSPI2_MOSI__UART4_DCE_TX 0x1F4 0x454 0x000 0x1 0x0 +#define MX8MP_IOMUXC_ECSPI2_MOSI__UART4_DTE_RX 0x1F4 0x454 0x600 0x1 0x7 +#define MX8MP_IOMUXC_ECSPI2_MOSI__I2C3_SDA 0x1F4 0x454 0x5B8 0x2 0x3 +#define MX8MP_IOMUXC_ECSPI2_MOSI__AUDIOMIX_SAI7_TX_DATA00 0x1F4 0x454 0x000 0x3 0x0 +#define MX8MP_IOMUXC_ECSPI2_MOSI__GPIO5_IO11 0x1F4 0x454 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ECSPI2_MOSI__TPSMP_HDATA13 0x1F4 0x454 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ECSPI2_MISO__GPIO5_IO12 0x1F8 0x458 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ECSPI2_MISO__TPSMP_HDATA14 0x1F8 0x458 0x000 0x7 0x0 +#define MX8MP_IOMUXC_ECSPI2_MISO__ECSPI2_MISO 0x1F8 0x458 0x56C 0x0 0x1 +#define MX8MP_IOMUXC_ECSPI2_MISO__UART4_DCE_CTS 0x1F8 0x458 0x000 0x1 0x0 +#define MX8MP_IOMUXC_ECSPI2_MISO__UART4_DTE_RTS 0x1F8 0x458 0x5FC 0x1 0x2 +#define MX8MP_IOMUXC_ECSPI2_MISO__I2C4_SCL 0x1F8 0x458 0x5BC 0x2 0x4 +#define MX8MP_IOMUXC_ECSPI2_MISO__AUDIOMIX_SAI7_MCLK 0x1F8 0x458 0x52C 0x3 0x1 +#define MX8MP_IOMUXC_ECSPI2_MISO__CCMSRCGPCMIX_CLKO1 0x1F8 0x458 0x000 0x4 0x0 +#define MX8MP_IOMUXC_ECSPI2_SS0__ECSPI2_SS0 0x1FC 0x45C 0x574 0x0 0x1 +#define MX8MP_IOMUXC_ECSPI2_SS0__UART4_DCE_RTS 0x1FC 0x45C 0x5FC 0x1 0x3 +#define MX8MP_IOMUXC_ECSPI2_SS0__UART4_DTE_CTS 0x1FC 0x45C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_ECSPI2_SS0__I2C4_SDA 0x1FC 0x45C 0x5C0 0x2 0x4 +#define MX8MP_IOMUXC_ECSPI2_SS0__CCMSRCGPCMIX_CLKO2 0x1FC 0x45C 0x000 0x4 0x0 +#define MX8MP_IOMUXC_ECSPI2_SS0__GPIO5_IO13 0x1FC 0x45C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_ECSPI2_SS0__TPSMP_HDATA15 0x1FC 0x45C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_I2C1_SCL__I2C1_SCL 0x200 0x460 0x5A4 0x0 0x2 +#define MX8MP_IOMUXC_I2C1_SCL__ENET_QOS_MDC 0x200 0x460 0x000 0x1 0x0 +#define MX8MP_IOMUXC_I2C1_SCL__ECSPI1_SCLK 0x200 0x460 0x558 0x3 0x1 +#define MX8MP_IOMUXC_I2C1_SCL__GPIO5_IO14 0x200 0x460 0x000 0x5 0x0 +#define MX8MP_IOMUXC_I2C1_SCL__TPSMP_HDATA16 0x200 0x460 0x000 0x7 0x0 +#define MX8MP_IOMUXC_I2C1_SDA__I2C1_SDA 0x204 0x464 0x5A8 0x0 0x2 +#define MX8MP_IOMUXC_I2C1_SDA__ENET_QOS_MDIO 0x204 0x464 0x590 0x1 0x2 +#define MX8MP_IOMUXC_I2C1_SDA__ECSPI1_MOSI 0x204 0x464 0x560 0x3 0x1 +#define MX8MP_IOMUXC_I2C1_SDA__GPIO5_IO15 0x204 0x464 0x000 0x5 0x0 +#define MX8MP_IOMUXC_I2C1_SDA__TPSMP_HDATA17 0x204 0x464 0x000 0x7 0x0 +#define MX8MP_IOMUXC_I2C2_SCL__I2C2_SCL 0x208 0x468 0x5AC 0x0 0x2 +#define MX8MP_IOMUXC_I2C2_SCL__ENET_QOS_1588_EVENT1_IN 0x208 0x468 0x000 0x1 0x0 +#define MX8MP_IOMUXC_I2C2_SCL__USDHC3_CD_B 0x208 0x468 0x608 0x2 0x3 +#define MX8MP_IOMUXC_I2C2_SCL__ECSPI1_MISO 0x208 0x468 0x55C 0x3 0x1 +#define MX8MP_IOMUXC_I2C2_SCL__ENET_QOS_1588_EVENT1_AUX_IN 0x208 0x468 0x000 0x4 0x0 +#define MX8MP_IOMUXC_I2C2_SCL__GPIO5_IO16 0x208 0x468 0x000 0x5 0x0 +#define MX8MP_IOMUXC_I2C2_SCL__TPSMP_HDATA18 0x208 0x468 0x000 0x7 0x0 +#define MX8MP_IOMUXC_I2C2_SDA__I2C2_SDA 0x20C 0x46C 0x5B0 0x0 0x2 +#define MX8MP_IOMUXC_I2C2_SDA__ENET_QOS_1588_EVENT1_OUT 0x20C 0x46C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_I2C2_SDA__USDHC3_WP 0x20C 0x46C 0x634 0x2 0x3 +#define MX8MP_IOMUXC_I2C2_SDA__ECSPI1_SS0 0x20C 0x46C 0x564 0x3 0x1 +#define MX8MP_IOMUXC_I2C2_SDA__GPIO5_IO17 0x20C 0x46C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_I2C2_SDA__TPSMP_HDATA19 0x20C 0x46C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_I2C3_SCL__I2C3_SCL 0x210 0x470 0x5B4 0x0 0x4 +#define MX8MP_IOMUXC_I2C3_SCL__PWM4_OUT 0x210 0x470 0x000 0x1 0x0 +#define MX8MP_IOMUXC_I2C3_SCL__GPT2_CLK 0x210 0x470 0x000 0x2 0x0 +#define MX8MP_IOMUXC_I2C3_SCL__ECSPI2_SCLK 0x210 0x470 0x568 0x3 0x2 +#define MX8MP_IOMUXC_I2C3_SCL__GPIO5_IO18 0x210 0x470 0x000 0x5 0x0 +#define MX8MP_IOMUXC_I2C3_SCL__TPSMP_HDATA20 0x210 0x470 0x000 0x7 0x0 +#define MX8MP_IOMUXC_I2C3_SDA__I2C3_SDA 0x214 0x474 0x5B8 0x0 0x4 +#define MX8MP_IOMUXC_I2C3_SDA__PWM3_OUT 0x214 0x474 0x000 0x1 0x0 +#define MX8MP_IOMUXC_I2C3_SDA__GPT3_CLK 0x214 0x474 0x000 0x2 0x0 +#define MX8MP_IOMUXC_I2C3_SDA__ECSPI2_MOSI 0x214 0x474 0x570 0x3 0x2 +#define MX8MP_IOMUXC_I2C3_SDA__GPIO5_IO19 0x214 0x474 0x000 0x5 0x0 +#define MX8MP_IOMUXC_I2C3_SDA__TPSMP_HDATA21 0x214 0x474 0x000 0x7 0x0 +#define MX8MP_IOMUXC_I2C4_SCL__I2C4_SCL 0x218 0x478 0x5BC 0x0 0x5 +#define MX8MP_IOMUXC_I2C4_SCL__PWM2_OUT 0x218 0x478 0x000 0x1 0x0 +#define MX8MP_IOMUXC_I2C4_SCL__HSIOMIX_PCIE_CLKREQ_B 0x218 0x478 0x5A0 0x2 0x0 +#define MX8MP_IOMUXC_I2C4_SCL__ECSPI2_MISO 0x218 0x478 0x56C 0x3 0x2 +#define MX8MP_IOMUXC_I2C4_SCL__GPIO5_IO20 0x218 0x478 0x000 0x5 0x0 +#define MX8MP_IOMUXC_I2C4_SCL__TPSMP_HDATA22 0x218 0x478 0x000 0x7 0x0 +#define MX8MP_IOMUXC_I2C4_SDA__I2C4_SDA 0x21C 0x47C 0x5C0 0x0 0x5 +#define MX8MP_IOMUXC_I2C4_SDA__PWM1_OUT 0x21C 0x47C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_I2C4_SDA__ECSPI2_SS0 0x21C 0x47C 0x574 0x3 0x2 +#define MX8MP_IOMUXC_I2C4_SDA__GPIO5_IO21 0x21C 0x47C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_I2C4_SDA__TPSMP_HDATA23 0x21C 0x47C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_UART1_RXD__UART1_DCE_RX 0x220 0x480 0x5E8 0x0 0x4 +#define MX8MP_IOMUXC_UART1_RXD__UART1_DTE_TX 0x220 0x480 0x000 0x0 0x0 +#define MX8MP_IOMUXC_UART1_RXD__ECSPI3_SCLK 0x220 0x480 0x000 0x1 0x0 +#define MX8MP_IOMUXC_UART1_RXD__GPIO5_IO22 0x220 0x480 0x000 0x5 0x0 +#define MX8MP_IOMUXC_UART1_RXD__TPSMP_HDATA24 0x220 0x480 0x000 0x7 0x0 +#define MX8MP_IOMUXC_UART1_TXD__UART1_DCE_TX 0x224 0x484 0x000 0x0 0x0 +#define MX8MP_IOMUXC_UART1_TXD__UART1_DTE_RX 0x224 0x484 0x5E8 0x0 0x5 +#define MX8MP_IOMUXC_UART1_TXD__ECSPI3_MOSI 0x224 0x484 0x000 0x1 0x0 +#define MX8MP_IOMUXC_UART1_TXD__GPIO5_IO23 0x224 0x484 0x000 0x5 0x0 +#define MX8MP_IOMUXC_UART1_TXD__TPSMP_HDATA25 0x224 0x484 0x000 0x7 0x0 +#define MX8MP_IOMUXC_UART2_RXD__UART2_DCE_RX 0x228 0x488 0x5F0 0x0 0x6 +#define MX8MP_IOMUXC_UART2_RXD__UART2_DTE_TX 0x228 0x488 0x000 0x0 0x0 +#define MX8MP_IOMUXC_UART2_RXD__ECSPI3_MISO 0x228 0x488 0x000 0x1 0x0 +#define MX8MP_IOMUXC_UART2_RXD__GPT1_COMPARE3 0x228 0x488 0x000 0x3 0x0 +#define MX8MP_IOMUXC_UART2_RXD__GPIO5_IO24 0x228 0x488 0x000 0x5 0x0 +#define MX8MP_IOMUXC_UART2_RXD__TPSMP_HDATA26 0x228 0x488 0x000 0x7 0x0 +#define MX8MP_IOMUXC_UART2_TXD__UART2_DCE_TX 0x22C 0x48C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_UART2_TXD__UART2_DTE_RX 0x22C 0x48C 0x5F0 0x0 0x7 +#define MX8MP_IOMUXC_UART2_TXD__ECSPI3_SS0 0x22C 0x48C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_UART2_TXD__GPT1_COMPARE2 0x22C 0x48C 0x000 0x3 0x0 +#define MX8MP_IOMUXC_UART2_TXD__GPIO5_IO25 0x22C 0x48C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_UART2_TXD__TPSMP_HDATA27 0x22C 0x48C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_UART3_RXD__UART3_DCE_RX 0x230 0x490 0x5F8 0x0 0x6 +#define MX8MP_IOMUXC_UART3_RXD__UART3_DTE_TX 0x230 0x490 0x000 0x0 0x0 +#define MX8MP_IOMUXC_UART3_RXD__UART1_DCE_CTS 0x230 0x490 0x000 0x1 0x0 +#define MX8MP_IOMUXC_UART3_RXD__UART1_DTE_RTS 0x230 0x490 0x5E4 0x1 0x4 +#define MX8MP_IOMUXC_UART3_RXD__USDHC3_RESET_B 0x230 0x490 0x000 0x2 0x0 +#define MX8MP_IOMUXC_UART3_RXD__GPT1_CAPTURE2 0x230 0x490 0x598 0x3 0x1 +#define MX8MP_IOMUXC_UART3_RXD__CAN2_TX 0x230 0x490 0x000 0x4 0x0 +#define MX8MP_IOMUXC_UART3_RXD__GPIO5_IO26 0x230 0x490 0x000 0x5 0x0 +#define MX8MP_IOMUXC_UART3_RXD__TPSMP_HDATA28 0x230 0x490 0x000 0x7 0x0 +#define MX8MP_IOMUXC_UART3_TXD__UART3_DCE_TX 0x234 0x494 0x000 0x0 0x0 +#define MX8MP_IOMUXC_UART3_TXD__UART3_DTE_RX 0x234 0x494 0x5F8 0x0 0x7 +#define MX8MP_IOMUXC_UART3_TXD__UART1_DCE_RTS 0x234 0x494 0x5E4 0x1 0x5 +#define MX8MP_IOMUXC_UART3_TXD__UART1_DTE_CTS 0x234 0x494 0x000 0x1 0x0 +#define MX8MP_IOMUXC_UART3_TXD__USDHC3_VSELECT 0x234 0x494 0x000 0x2 0x0 +#define MX8MP_IOMUXC_UART3_TXD__GPT1_CLK 0x234 0x494 0x59C 0x3 0x1 +#define MX8MP_IOMUXC_UART3_TXD__CAN2_RX 0x234 0x494 0x550 0x4 0x2 +#define MX8MP_IOMUXC_UART3_TXD__GPIO5_IO27 0x234 0x494 0x000 0x5 0x0 +#define MX8MP_IOMUXC_UART3_TXD__TPSMP_HDATA29 0x234 0x494 0x000 0x7 0x0 +#define MX8MP_IOMUXC_UART4_RXD__UART4_DCE_RX 0x238 0x498 0x600 0x0 0x8 +#define MX8MP_IOMUXC_UART4_RXD__UART4_DTE_TX 0x238 0x498 0x000 0x0 0x0 +#define MX8MP_IOMUXC_UART4_RXD__UART2_DCE_CTS 0x238 0x498 0x000 0x1 0x0 +#define MX8MP_IOMUXC_UART4_RXD__UART2_DTE_RTS 0x238 0x498 0x5EC 0x1 0x4 +#define MX8MP_IOMUXC_UART4_RXD__HSIOMIX_PCIE_CLKREQ_B 0x238 0x498 0x5A0 0x2 0x1 +#define MX8MP_IOMUXC_UART4_RXD__GPT1_COMPARE1 0x238 0x498 0x000 0x3 0x0 +#define MX8MP_IOMUXC_UART4_RXD__I2C6_SCL 0x238 0x498 0x5CC 0x4 0x2 +#define MX8MP_IOMUXC_UART4_RXD__GPIO5_IO28 0x238 0x498 0x000 0x5 0x0 +#define MX8MP_IOMUXC_UART4_RXD__TPSMP_HDATA30 0x238 0x498 0x000 0x7 0x0 +#define MX8MP_IOMUXC_UART4_TXD__UART4_DCE_TX 0x23C 0x49C 0x000 0x0 0x0 +#define MX8MP_IOMUXC_UART4_TXD__UART4_DTE_RX 0x23C 0x49C 0x600 0x0 0x9 +#define MX8MP_IOMUXC_UART4_TXD__UART2_DCE_RTS 0x23C 0x49C 0x5EC 0x1 0x5 +#define MX8MP_IOMUXC_UART4_TXD__UART2_DTE_CTS 0x23C 0x49C 0x000 0x1 0x0 +#define MX8MP_IOMUXC_UART4_TXD__GPT1_CAPTURE1 0x23C 0x49C 0x594 0x3 0x1 +#define MX8MP_IOMUXC_UART4_TXD__I2C6_SDA 0x23C 0x49C 0x5D0 0x4 0x2 +#define MX8MP_IOMUXC_UART4_TXD__GPIO5_IO29 0x23C 0x49C 0x000 0x5 0x0 +#define MX8MP_IOMUXC_UART4_TXD__TPSMP_HDATA31 0x23C 0x49C 0x000 0x7 0x0 +#define MX8MP_IOMUXC_HDMI_DDC_SCL__HDMIMIX_EARC_SCL 0x240 0x4A0 0x000 0x0 0x0 +#define MX8MP_IOMUXC_HDMI_DDC_SCL__I2C5_SCL 0x240 0x4A0 0x5C4 0x3 0x3 +#define MX8MP_IOMUXC_HDMI_DDC_SCL__CAN1_TX 0x240 0x4A0 0x000 0x4 0x0 +#define MX8MP_IOMUXC_HDMI_DDC_SCL__GPIO3_IO26 0x240 0x4A0 0x000 0x5 0x0 +#define MX8MP_IOMUXC_HDMI_DDC_SCL__AUDIOMIX_test_out00 0x240 0x4A0 0x000 0x6 0x0 +#define MX8MP_IOMUXC_HDMI_DDC_SDA__HDMIMIX_EARC_SDA 0x244 0x4A4 0x000 0x0 0x0 +#define MX8MP_IOMUXC_HDMI_DDC_SDA__I2C5_SDA 0x244 0x4A4 0x5C8 0x3 0x3 +#define MX8MP_IOMUXC_HDMI_DDC_SDA__CAN1_RX 0x244 0x4A4 0x54C 0x4 0x3 +#define MX8MP_IOMUXC_HDMI_DDC_SDA__GPIO3_IO27 0x244 0x4A4 0x000 0x5 0x0 +#define MX8MP_IOMUXC_HDMI_DDC_SDA__AUDIOMIX_test_out01 0x244 0x4A4 0x000 0x6 0x0 +#define MX8MP_IOMUXC_HDMI_CEC__HDMIMIX_EARC_CEC 0x248 0x4A8 0x000 0x0 0x0 +#define MX8MP_IOMUXC_HDMI_CEC__I2C6_SCL 0x248 0x4A8 0x5CC 0x3 0x3 +#define MX8MP_IOMUXC_HDMI_CEC__CAN2_TX 0x248 0x4A8 0x000 0x4 0x0 +#define MX8MP_IOMUXC_HDMI_CEC__GPIO3_IO28 0x248 0x4A8 0x000 0x5 0x0 +#define MX8MP_IOMUXC_HDMI_HPD__HDMIMIX_EARC_DC_HPD 0x24C 0x4AC 0x000 0x0 0x0 +#define MX8MP_IOMUXC_HDMI_HPD__AUDIOMIX_EARC_HDMI_HPD_O 0x24C 0x4AC 0x000 0x1 0x0 +#define MX8MP_IOMUXC_HDMI_HPD__I2C6_SDA 0x24C 0x4AC 0x5D0 0x3 0x3 +#define MX8MP_IOMUXC_HDMI_HPD__CAN2_RX 0x24C 0x4AC 0x550 0x4 0x3 +#define MX8MP_IOMUXC_HDMI_HPD__GPIO3_IO29 0x24C 0x4AC 0x000 0x5 0x0 + +#endif /* __DTS_IMX8MP_PINFUNC_H */
i.MX8MP has similar architecture as i.MX8MN, but it has different clk root and index, so add that to make i.MX8MP could use the non-dm clock driver.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx8m/clock.h | 3 +- arch/arm/include/asm/arch-imx8m/clock_imx8mm.h | 112 +++++++++- arch/arm/mach-imx/imx8m/Makefile | 2 +- arch/arm/mach-imx/imx8m/clock_slice.c | 272 +++++++++++++++++++++++++ 4 files changed, 386 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/arch-imx8m/clock.h b/arch/arm/include/asm/arch-imx8m/clock.h index c910b614ac..87cc4d3b2b 100644 --- a/arch/arm/include/asm/arch-imx8m/clock.h +++ b/arch/arm/include/asm/arch-imx8m/clock.h @@ -9,7 +9,8 @@
#ifdef CONFIG_IMX8MQ #include <asm/arch/clock_imx8mq.h> -#elif defined(CONFIG_IMX8MM) || defined(CONFIG_IMX8MN) +#elif defined(CONFIG_IMX8MM) || defined(CONFIG_IMX8MN) || \ + defined(CONFIG_IMX8MP) #include <asm/arch/clock_imx8mm.h> #else #error "Error no clock.h" diff --git a/arch/arm/include/asm/arch-imx8m/clock_imx8mm.h b/arch/arm/include/asm/arch-imx8m/clock_imx8mm.h index 76c73edc90..debed6bac7 100644 --- a/arch/arm/include/asm/arch-imx8m/clock_imx8mm.h +++ b/arch/arm/include/asm/arch-imx8m/clock_imx8mm.h @@ -52,7 +52,109 @@ enum pll_clocks { ANATOP_DRAM_PLL, };
-#ifdef CONFIG_IMX8MN +#ifdef CONFIG_IMX8MP +enum clk_root_index { + ARM_A53_CLK_ROOT = 0, + ARM_M7_CLK_ROOT = 1, + ML_CLK_ROOT = 2, + GPU3D_CORE_CLK_ROOT = 3, + GPU3D_SHADER_CLK_ROOT = 4, + GPU2D_CLK_ROOT = 5, + AUDIO_AXI_CLK_ROOT = 6, + HSIO_AXI_CLK_ROOT = 7, + MEDIA_ISP_CLK_ROOT = 8, + MAIN_AXI_CLK_ROOT = 16, + ENET_AXI_CLK_ROOT = 17, + NAND_USDHC_BUS_CLK_ROOT = 18, + VPU_BUS_CLK_ROOT = 19, + MEDIA_AXI_CLK_ROOT = 20, + MEDIA_APB_CLK_ROOT = 21, + HDMI_APB_CLK_ROOT = 22, + HDMI_AXI_CLK_ROOT = 23, + GPU_AXI_CLK_ROOT = 24, + GPU_AHB_CLK_ROOT = 25, + NOC_CLK_ROOT = 26, + NOC_IO_CLK_ROOT = 27, + ML_AXI_CLK_ROOT = 28, + ML_AHB_CLK_ROOT = 29, + AHB_CLK_ROOT = 32, + IPG_CLK_ROOT = 33, + AUDIO_AHB_CLK_ROOT = 34, + MIPI_DSI_ESC_RX_CLK_ROOT = 36, + MEDIA_DISP2_CLK_ROOT = 38, + DRAM_SEL_CFG = 48, + CORE_SEL_CFG = 49, + DRAM_ALT_CLK_ROOT = 64, + DRAM_APB_CLK_ROOT = 65, + VPU_G1_CLK_ROOT = 66, + VPU_G2_CLK_ROOT = 67, + CAN1_CLK_ROOT = 68, + CAN2_CLK_ROOT = 69, + PCIE_PHY_CLK_ROOT = 71, + PCIE_AUX_CLK_ROOT = 72, + I2C5_CLK_ROOT = 73, + I2C6_CLK_ROOT = 74, + SAI1_CLK_ROOT = 75, + SAI2_CLK_ROOT = 76, + SAI3_CLK_ROOT = 77, + SAI4_CLK_ROOT = 78, + SAI5_CLK_ROOT = 79, + SAI6_CLK_ROOT = 80, + ENET_QOS_CLK_ROOT = 81, + ENET_QOS_TIMER_CLK_ROOT = 82, + ENET_REF_CLK_ROOT = 83, + ENET_TIMER_CLK_ROOT = 84, + ENET_PHY_REF_CLK_ROOT = 85, + NAND_CLK_ROOT = 86, + QSPI_CLK_ROOT = 87, + USDHC1_CLK_ROOT = 88, + USDHC2_CLK_ROOT = 89, + I2C1_CLK_ROOT = 90, + I2C2_CLK_ROOT = 91, + I2C3_CLK_ROOT = 92, + I2C4_CLK_ROOT = 93, + UART1_CLK_ROOT = 94, + UART2_CLK_ROOT = 95, + UART3_CLK_ROOT = 96, + UART4_CLK_ROOT = 97, + USB_CORE_REF_CLK_ROOT = 98, + USB_PHY_REF_CLK_ROOT = 99, + GIC_CLK_ROOT = 100, + ECSPI1_CLK_ROOT = 101, + ECSPI2_CLK_ROOT = 102, + PWM1_CLK_ROOT = 103, + PWM2_CLK_ROOT = 104, + PWM3_CLK_ROOT = 105, + PWM4_CLK_ROOT = 106, + GPT1_CLK_ROOT = 107, + GPT2_CLK_ROOT = 108, + GPT3_CLK_ROOT = 109, + GPT4_CLK_ROOT = 110, + GPT5_CLK_ROOT = 111, + GPT6_CLK_ROOT = 112, + TRACE_CLK_ROOT = 113, + WDOG_CLK_ROOT = 114, + WRCLK_CLK_ROOT = 115, + IPP_DO_CLKO1 = 116, + IPP_DO_CLKO2 = 117, + HDMI_FDCC_TST_CLK_ROOT = 118, + HDMI_27M_CLK_ROOT = 119, + HDMI_REF_266M_CLK_ROOT = 120, + USDHC3_CLK_ROOT = 121, + MEDIA_CAM1_PIX_CLK_ROOT = 122, + MEDIA_MIPI_PHY1_REF_CLK_ROOT = 123, + MEDIA_DISP1_PIX_CLK_ROOT = 124, + MEDIA_CAM2_PIX_CLK_ROOT = 125, + MEDIA_LDB_CLK_ROOT = 126, + MEMREPAIR_CLK_ROOT = 127, + MEDIA_MIPI_TEST_BYTE_CLK = 130, + ECSPI3_CLK_ROOT = 131, + PDM_CLK_ROOT = 132, + VPU_VC8000E_CLK_ROOT = 133, + SAI7_CLK_ROOT = 134, + CLK_ROOT_MAX, +}; +#elif defined(CONFIG_IMX8MN) enum clk_root_index { ARM_A53_CLK_ROOT = 0, ARM_M7_CLK_ROOT = 1, @@ -284,6 +386,7 @@ enum clk_ccgr_index { CCGR_GPT2 = 17, CCGR_GPT3 = 18, CCGR_GPT4 = 19, + CCGR_AAM_8MP = 20, CCGR_GPT5 = 20, CCGR_GPT6 = 21, CCGR_HS = 22, @@ -315,7 +418,9 @@ enum clk_ccgr_index { CCGR_RAWNAND = 48, CCGR_RDC = 49, CCGR_ROM = 50, + CCGR_I2C5_8MP = 51, CCGR_SAI1 = 51, + CCGR_I2C6_8MP = 52, CCGR_SAI2 = 52, CCGR_SAI3 = 53, CCGR_SAI4 = 54, @@ -327,13 +432,16 @@ enum clk_ccgr_index { CCGR_SEC_DEBUG = 60, CCGR_SEMA1 = 61, CCGR_SEMA2 = 62, + CCGR_IRQ_STEER_8MP = 63, CCGR_SIM_DISPLAY = 63, CCGR_SIM_ENET = 64, CCGR_SIM_M = 65, CCGR_SIM_MAIN = 66, CCGR_SIM_S = 67, CCGR_SIM_WAKEUP = 68, + CCGR_GPU2D_8MP = 69, CCGR_SIM_HSIO = 69, + CCGR_GPU3D_8MP = 70, CCGR_SIM_VPU = 70, CCGR_SNVS = 71, CCGR_TRACE = 72, @@ -342,6 +450,7 @@ enum clk_ccgr_index { CCGR_UART3 = 75, CCGR_UART4 = 76, CCGR_USB_MSCALE_PL301 = 77, + CCGR_USB_PHY_8MP = 79, CCGR_GPU3D = 79, CCGR_USDHC1 = 81, CCGR_USDHC2 = 82, @@ -361,6 +470,7 @@ enum clk_ccgr_index { CCGR_PLL = 97, CCGR_TEMP_SENSOR = 98, CCGR_VPUMIX_BUS = 99, + CCGR_SAI7 = 101, CCGR_GPU2D = 102, CCGR_MAX }; diff --git a/arch/arm/mach-imx/imx8m/Makefile b/arch/arm/mach-imx/imx8m/Makefile index db4ba30c24..d9dee894aa 100644 --- a/arch/arm/mach-imx/imx8m/Makefile +++ b/arch/arm/mach-imx/imx8m/Makefile @@ -5,4 +5,4 @@ obj-y += lowlevel_init.o obj-y += clock_slice.o soc.o obj-$(CONFIG_IMX8MQ) += clock_imx8mq.o -obj-$(CONFIG_IMX8MM)$(CONFIG_IMX8MN) += clock_imx8mm.o +obj-$(CONFIG_IMX8MM)$(CONFIG_IMX8MN)$(CONFIG_IMX8MP) += clock_imx8mm.o diff --git a/arch/arm/mach-imx/imx8m/clock_slice.c b/arch/arm/mach-imx/imx8m/clock_slice.c index 09c5615004..31925ccaba 100644 --- a/arch/arm/mach-imx/imx8m/clock_slice.c +++ b/arch/arm/mach-imx/imx8m/clock_slice.c @@ -538,6 +538,278 @@ static struct clk_root_map root_array[] = { {DRAM_PLL1_CLK} }, }; +#elif defined(CONFIG_IMX8MP) +static struct clk_root_map root_array[] = { + {ARM_A53_CLK_ROOT, CORE_CLOCK_SLICE, 0, + {OSC_24M_CLK, ARM_PLL_CLK, SYSTEM_PLL2_500M_CLK, + SYSTEM_PLL2_1000M_CLK, SYSTEM_PLL1_800M_CLK, + SYSTEM_PLL1_400M_CLK, AUDIO_PLL1_CLK, SYSTEM_PLL3_CLK} + }, + {ARM_M7_CLK_ROOT, CORE_CLOCK_SLICE, 1, + {OSC_24M_CLK, SYSTEM_PLL2_200M_CLK, SYSTEM_PLL2_250M_CLK, + VPU_PLL_CLK, SYSTEM_PLL1_800M_CLK, + AUDIO_PLL1_CLK, VIDEO_PLL_CLK, SYSTEM_PLL3_CLK} + }, + {ML_CLK_ROOT, CORE_CLOCK_SLICE, 2, + {OSC_24M_CLK, SYSTEM_PLL2_200M_CLK, SYSTEM_PLL2_250M_CLK, + VPU_PLL_CLK, SYSTEM_PLL1_800M_CLK, + AUDIO_PLL1_CLK, VIDEO_PLL_CLK, SYSTEM_PLL3_CLK} + }, + {HSIO_AXI_CLK_ROOT, CORE_CLOCK_SLICE, 7, + {OSC_24M_CLK, SYSTEM_PLL2_500M_CLK, SYSTEM_PLL1_800M_CLK, + SYSTEM_PLL2_100M_CLK, SYSTEM_PLL2_200M_CLK, EXT_CLK_2, + EXT_CLK_4, AUDIO_PLL2_CLK} + }, + {MAIN_AXI_CLK_ROOT, BUS_CLOCK_SLICE, 0, + {OSC_24M_CLK, SYSTEM_PLL2_333M_CLK, SYSTEM_PLL1_800M_CLK, + SYSTEM_PLL2_250M_CLK, SYSTEM_PLL2_1000M_CLK, AUDIO_PLL1_CLK, + VIDEO_PLL_CLK, SYSTEM_PLL1_100M_CLK} + }, + {ENET_AXI_CLK_ROOT, BUS_CLOCK_SLICE, 1, + {OSC_24M_CLK, SYSTEM_PLL1_266M_CLK, SYSTEM_PLL1_800M_CLK, + SYSTEM_PLL2_250M_CLK, SYSTEM_PLL2_200M_CLK, AUDIO_PLL1_CLK, + VIDEO_PLL_CLK, SYSTEM_PLL3_CLK} + }, + {NAND_USDHC_BUS_CLK_ROOT, BUS_CLOCK_SLICE, 2, + {OSC_24M_CLK, SYSTEM_PLL1_266M_CLK, SYSTEM_PLL1_800M_CLK, + SYSTEM_PLL2_200M_CLK, SYSTEM_PLL1_133M_CLK, + SYSTEM_PLL3_CLK, SYSTEM_PLL2_250M_CLK, AUDIO_PLL1_CLK} + }, + {NOC_CLK_ROOT, BUS_CLOCK_SLICE, 10, + {OSC_24M_CLK, SYSTEM_PLL1_800M_CLK, SYSTEM_PLL3_CLK, + SYSTEM_PLL2_1000M_CLK, SYSTEM_PLL2_500M_CLK, + AUDIO_PLL1_CLK, VIDEO_PLL_CLK, AUDIO_PLL2_CLK} + }, + {NOC_IO_CLK_ROOT, BUS_CLOCK_SLICE, 11, + {OSC_24M_CLK, SYSTEM_PLL1_800M_CLK, SYSTEM_PLL3_CLK, + SYSTEM_PLL2_1000M_CLK, SYSTEM_PLL2_500M_CLK, + AUDIO_PLL1_CLK, VIDEO_PLL_CLK, AUDIO_PLL2_CLK} + }, + {ML_AXI_CLK_ROOT, BUS_CLOCK_SLICE, 12, + {OSC_24M_CLK, SYSTEM_PLL1_800M_CLK, GPU_PLL_CLK, + SYSTEM_PLL3_CLK, SYSTEM_PLL2_1000M_CLK, + AUDIO_PLL1_CLK, VIDEO_PLL_CLK, AUDIO_PLL2_CLK} + }, + {ML_AHB_CLK_ROOT, BUS_CLOCK_SLICE, 13, + {OSC_24M_CLK, SYSTEM_PLL1_800M_CLK, GPU_PLL_CLK, + SYSTEM_PLL3_CLK, SYSTEM_PLL2_1000M_CLK, + AUDIO_PLL1_CLK, VIDEO_PLL_CLK, AUDIO_PLL2_CLK} + }, + {AHB_CLK_ROOT, AHB_CLOCK_SLICE, 0, + {OSC_24M_CLK, SYSTEM_PLL1_133M_CLK, SYSTEM_PLL1_800M_CLK, + SYSTEM_PLL1_400M_CLK, SYSTEM_PLL2_125M_CLK, + SYSTEM_PLL3_CLK, AUDIO_PLL1_CLK, VIDEO_PLL_CLK} + }, + {DRAM_ALT_CLK_ROOT, IP_CLOCK_SLICE, 0, + {OSC_24M_CLK, SYSTEM_PLL1_800M_CLK, SYSTEM_PLL1_100M_CLK, + SYSTEM_PLL2_500M_CLK, SYSTEM_PLL2_1000M_CLK, + SYSTEM_PLL3_CLK, AUDIO_PLL1_CLK, SYSTEM_PLL1_266M_CLK} + }, + {DRAM_APB_CLK_ROOT, IP_CLOCK_SLICE, 1, + {OSC_24M_CLK, SYSTEM_PLL2_200M_CLK, SYSTEM_PLL1_40M_CLK, + SYSTEM_PLL1_160M_CLK, SYSTEM_PLL1_800M_CLK, + SYSTEM_PLL3_CLK, SYSTEM_PLL2_250M_CLK, AUDIO_PLL2_CLK} + }, + {MEMREPAIR_CLK_ROOT, IP_CLOCK_SLICE, 6, + {OSC_24M_CLK, SYSTEM_PLL1_160M_CLK, SYSTEM_PLL2_50M_CLK, + SYSTEM_PLL3_CLK, AUDIO_PLL1_CLK, VIDEO_PLL_CLK, AUDIO_PLL2_CLK, + SYSTEM_PLL1_133M_CLK} + }, + {I2C5_CLK_ROOT, IP_CLOCK_SLICE, 9, + {OSC_24M_CLK, SYSTEM_PLL1_160M_CLK, SYSTEM_PLL2_50M_CLK, + SYSTEM_PLL3_CLK, AUDIO_PLL1_CLK, VIDEO_PLL_CLK, AUDIO_PLL2_CLK, + SYSTEM_PLL1_133M_CLK} + }, + {I2C6_CLK_ROOT, IP_CLOCK_SLICE, 10, + {OSC_24M_CLK, SYSTEM_PLL1_160M_CLK, SYSTEM_PLL2_50M_CLK, + SYSTEM_PLL3_CLK, AUDIO_PLL1_CLK, VIDEO_PLL_CLK, AUDIO_PLL2_CLK, + SYSTEM_PLL1_133M_CLK} + }, + {ENET_QOS_CLK_ROOT, IP_CLOCK_SLICE, 17, + {OSC_24M_CLK, SYSTEM_PLL2_125M_CLK, SYSTEM_PLL2_50M_CLK, + SYSTEM_PLL2_100M_CLK, SYSTEM_PLL1_160M_CLK, + AUDIO_PLL1_CLK, VIDEO_PLL_CLK, EXT_CLK_4} + }, + {ENET_QOS_TIMER_CLK_ROOT, IP_CLOCK_SLICE, 18, + {OSC_24M_CLK, SYSTEM_PLL2_100M_CLK, AUDIO_PLL1_CLK, EXT_CLK_1, + EXT_CLK_2, EXT_CLK_3, EXT_CLK_4, VIDEO_PLL_CLK} + }, + {ENET_REF_CLK_ROOT, IP_CLOCK_SLICE, 19, + {OSC_24M_CLK, SYSTEM_PLL2_125M_CLK, SYSTEM_PLL2_50M_CLK, + SYSTEM_PLL2_100M_CLK, SYSTEM_PLL1_160M_CLK, + AUDIO_PLL1_CLK, VIDEO_PLL_CLK, EXT_CLK_4} + }, + {ENET_TIMER_CLK_ROOT, IP_CLOCK_SLICE, 20, + {OSC_24M_CLK, SYSTEM_PLL2_100M_CLK, AUDIO_PLL1_CLK, EXT_CLK_1, + EXT_CLK_2, EXT_CLK_3, EXT_CLK_4, VIDEO_PLL_CLK} + }, + {ENET_PHY_REF_CLK_ROOT, IP_CLOCK_SLICE, 21, + {OSC_24M_CLK, SYSTEM_PLL2_50M_CLK, SYSTEM_PLL2_125M_CLK, + SYSTEM_PLL2_200M_CLK, SYSTEM_PLL2_500M_CLK, AUDIO_PLL1_CLK, + VIDEO_PLL_CLK, AUDIO_PLL2_CLK} + }, + {NAND_CLK_ROOT, IP_CLOCK_SLICE, 22, + {OSC_24M_CLK, SYSTEM_PLL2_500M_CLK, AUDIO_PLL1_CLK, + SYSTEM_PLL1_400M_CLK, AUDIO_PLL2_CLK, SYSTEM_PLL3_CLK, + SYSTEM_PLL2_250M_CLK, VIDEO_PLL_CLK} + }, + {QSPI_CLK_ROOT, IP_CLOCK_SLICE, 23, + {OSC_24M_CLK, SYSTEM_PLL1_400M_CLK, SYSTEM_PLL2_333M_CLK, + SYSTEM_PLL2_500M_CLK, AUDIO_PLL2_CLK, + SYSTEM_PLL1_266M_CLK, SYSTEM_PLL3_CLK, SYSTEM_PLL1_100M_CLK} + }, + {USDHC1_CLK_ROOT, IP_CLOCK_SLICE, 24, + {OSC_24M_CLK, SYSTEM_PLL1_400M_CLK, SYSTEM_PLL1_800M_CLK, + SYSTEM_PLL2_500M_CLK, SYSTEM_PLL3_CLK, + SYSTEM_PLL1_266M_CLK, AUDIO_PLL2_CLK, SYSTEM_PLL1_100M_CLK} + }, + {USDHC2_CLK_ROOT, IP_CLOCK_SLICE, 25, + {OSC_24M_CLK, SYSTEM_PLL1_400M_CLK, SYSTEM_PLL1_800M_CLK, + SYSTEM_PLL2_500M_CLK, SYSTEM_PLL3_CLK, + SYSTEM_PLL1_266M_CLK, AUDIO_PLL2_CLK, SYSTEM_PLL1_100M_CLK} + }, + {I2C1_CLK_ROOT, IP_CLOCK_SLICE, 26, + {OSC_24M_CLK, SYSTEM_PLL1_160M_CLK, SYSTEM_PLL2_50M_CLK, + SYSTEM_PLL3_CLK, AUDIO_PLL1_CLK, VIDEO_PLL_CLK, + AUDIO_PLL2_CLK, SYSTEM_PLL1_133M_CLK} + }, + {I2C2_CLK_ROOT, IP_CLOCK_SLICE, 27, + {OSC_24M_CLK, SYSTEM_PLL1_160M_CLK, SYSTEM_PLL2_50M_CLK, + SYSTEM_PLL3_CLK, AUDIO_PLL1_CLK, VIDEO_PLL_CLK, + AUDIO_PLL2_CLK, SYSTEM_PLL1_133M_CLK} + }, + {I2C3_CLK_ROOT, IP_CLOCK_SLICE, 28, + {OSC_24M_CLK, SYSTEM_PLL1_160M_CLK, SYSTEM_PLL2_50M_CLK, + SYSTEM_PLL3_CLK, AUDIO_PLL1_CLK, VIDEO_PLL_CLK, + AUDIO_PLL2_CLK, SYSTEM_PLL1_133M_CLK} + }, + {I2C4_CLK_ROOT, IP_CLOCK_SLICE, 29, + {OSC_24M_CLK, SYSTEM_PLL1_160M_CLK, SYSTEM_PLL2_50M_CLK, + SYSTEM_PLL3_CLK, AUDIO_PLL1_CLK, VIDEO_PLL_CLK, + AUDIO_PLL2_CLK, SYSTEM_PLL1_133M_CLK} + }, + {UART1_CLK_ROOT, IP_CLOCK_SLICE, 30, + {OSC_24M_CLK, SYSTEM_PLL1_80M_CLK, SYSTEM_PLL2_200M_CLK, + SYSTEM_PLL2_100M_CLK, SYSTEM_PLL3_CLK, + EXT_CLK_2, EXT_CLK_4, AUDIO_PLL2_CLK} + }, + {UART2_CLK_ROOT, IP_CLOCK_SLICE, 31, + {OSC_24M_CLK, SYSTEM_PLL1_80M_CLK, SYSTEM_PLL2_200M_CLK, + SYSTEM_PLL2_100M_CLK, SYSTEM_PLL3_CLK, + EXT_CLK_2, EXT_CLK_3, AUDIO_PLL2_CLK} + }, + {UART3_CLK_ROOT, IP_CLOCK_SLICE, 32, + {OSC_24M_CLK, SYSTEM_PLL1_80M_CLK, SYSTEM_PLL2_200M_CLK, + SYSTEM_PLL2_100M_CLK, SYSTEM_PLL3_CLK, + EXT_CLK_2, EXT_CLK_4, AUDIO_PLL2_CLK} + }, + {UART4_CLK_ROOT, IP_CLOCK_SLICE, 33, + {OSC_24M_CLK, SYSTEM_PLL1_80M_CLK, SYSTEM_PLL2_200M_CLK, + SYSTEM_PLL2_100M_CLK, SYSTEM_PLL3_CLK, + EXT_CLK_2, EXT_CLK_3, AUDIO_PLL2_CLK} + }, + {USB_PHY_REF_CLK_ROOT, IP_CLOCK_SLICE, 35, + {OSC_24M_CLK, SYSTEM_PLL1_100M_CLK, SYSTEM_PLL1_40M_CLK, + SYSTEM_PLL2_100M_CLK, SYSTEM_PLL2_200M_CLK, + EXT_CLK_2, EXT_CLK_3, AUDIO_PLL2_CLK} + }, + {GIC_CLK_ROOT, IP_CLOCK_SLICE, 36, + {OSC_24M_CLK, SYSTEM_PLL2_200M_CLK, SYSTEM_PLL1_40M_CLK, + SYSTEM_PLL2_100M_CLK, SYSTEM_PLL1_800M_CLK, + EXT_CLK_2, EXT_CLK_4, AUDIO_PLL2_CLK} + }, + {ECSPI1_CLK_ROOT, IP_CLOCK_SLICE, 37, + {OSC_24M_CLK, SYSTEM_PLL2_200M_CLK, SYSTEM_PLL1_40M_CLK, + SYSTEM_PLL1_160M_CLK, SYSTEM_PLL1_800M_CLK, + SYSTEM_PLL3_CLK, SYSTEM_PLL2_250M_CLK, AUDIO_PLL2_CLK} + }, + {ECSPI2_CLK_ROOT, IP_CLOCK_SLICE, 38, + {OSC_24M_CLK, SYSTEM_PLL2_200M_CLK, SYSTEM_PLL1_40M_CLK, + SYSTEM_PLL1_160M_CLK, SYSTEM_PLL1_800M_CLK, + SYSTEM_PLL3_CLK, SYSTEM_PLL2_250M_CLK, AUDIO_PLL2_CLK} + }, + {PWM1_CLK_ROOT, IP_CLOCK_SLICE, 39, + {OSC_24M_CLK, SYSTEM_PLL2_100M_CLK, SYSTEM_PLL1_160M_CLK, + SYSTEM_PLL1_40M_CLK, SYSTEM_PLL3_CLK, EXT_CLK_1, + SYSTEM_PLL1_80M_CLK, VIDEO_PLL_CLK} + }, + {PWM2_CLK_ROOT, IP_CLOCK_SLICE, 40, + {OSC_24M_CLK, SYSTEM_PLL2_100M_CLK, SYSTEM_PLL1_160M_CLK, + SYSTEM_PLL1_40M_CLK, SYSTEM_PLL3_CLK, EXT_CLK_1, + SYSTEM_PLL1_80M_CLK, VIDEO_PLL_CLK} + }, + {PWM3_CLK_ROOT, IP_CLOCK_SLICE, 41, + {OSC_24M_CLK, SYSTEM_PLL2_100M_CLK, SYSTEM_PLL1_160M_CLK, + SYSTEM_PLL1_40M_CLK, SYSTEM_PLL3_CLK, EXT_CLK_2, + SYSTEM_PLL1_80M_CLK, VIDEO_PLL_CLK} + }, + {PWM4_CLK_ROOT, IP_CLOCK_SLICE, 42, + {OSC_24M_CLK, SYSTEM_PLL2_100M_CLK, SYSTEM_PLL1_160M_CLK, + SYSTEM_PLL1_40M_CLK, SYSTEM_PLL3_CLK, EXT_CLK_2, + SYSTEM_PLL1_80M_CLK, VIDEO_PLL_CLK} + }, + {GPT1_CLK_ROOT, IP_CLOCK_SLICE, 43, + {OSC_24M_CLK, SYSTEM_PLL2_100M_CLK, SYSTEM_PLL1_400M_CLK, + SYSTEM_PLL1_40M_CLK, VIDEO_PLL_CLK, + SYSTEM_PLL1_80M_CLK, AUDIO_PLL1_CLK, EXT_CLK_1} + }, + {GPT2_CLK_ROOT, IP_CLOCK_SLICE, 44, + {OSC_24M_CLK, SYSTEM_PLL2_100M_CLK, SYSTEM_PLL1_400M_CLK, + SYSTEM_PLL1_40M_CLK, VIDEO_PLL_CLK, + SYSTEM_PLL1_80M_CLK, AUDIO_PLL1_CLK, EXT_CLK_2} + }, + {GPT3_CLK_ROOT, IP_CLOCK_SLICE, 45, + {OSC_24M_CLK, SYSTEM_PLL2_100M_CLK, SYSTEM_PLL1_400M_CLK, + SYSTEM_PLL1_40M_CLK, VIDEO_PLL_CLK, + SYSTEM_PLL1_80M_CLK, AUDIO_PLL1_CLK, EXT_CLK_3} + }, + {GPT4_CLK_ROOT, IP_CLOCK_SLICE, 46, + {OSC_24M_CLK, SYSTEM_PLL2_100M_CLK, SYSTEM_PLL1_400M_CLK, + SYSTEM_PLL1_40M_CLK, VIDEO_PLL_CLK, + SYSTEM_PLL1_80M_CLK, AUDIO_PLL1_CLK, EXT_CLK_1} + }, + {GPT5_CLK_ROOT, IP_CLOCK_SLICE, 47, + {OSC_24M_CLK, SYSTEM_PLL2_100M_CLK, SYSTEM_PLL1_400M_CLK, + SYSTEM_PLL1_40M_CLK, VIDEO_PLL_CLK, + SYSTEM_PLL1_80M_CLK, AUDIO_PLL1_CLK, EXT_CLK_2} + }, + {GPT6_CLK_ROOT, IP_CLOCK_SLICE, 48, + {OSC_24M_CLK, SYSTEM_PLL2_100M_CLK, SYSTEM_PLL1_400M_CLK, + SYSTEM_PLL1_40M_CLK, VIDEO_PLL_CLK, + SYSTEM_PLL1_80M_CLK, AUDIO_PLL1_CLK, EXT_CLK_3} + }, + {TRACE_CLK_ROOT, IP_CLOCK_SLICE, 49, + {OSC_24M_CLK, SYSTEM_PLL1_133M_CLK, SYSTEM_PLL1_160M_CLK, + VPU_PLL_CLK, SYSTEM_PLL2_125M_CLK, + SYSTEM_PLL3_CLK, EXT_CLK_1, EXT_CLK_3} + }, + {WDOG_CLK_ROOT, IP_CLOCK_SLICE, 50, + {OSC_24M_CLK, SYSTEM_PLL1_133M_CLK, SYSTEM_PLL1_160M_CLK, + VPU_PLL_CLK, SYSTEM_PLL2_125M_CLK, + SYSTEM_PLL3_CLK, SYSTEM_PLL1_80M_CLK, SYSTEM_PLL2_166M_CLK} + }, + {WRCLK_CLK_ROOT, IP_CLOCK_SLICE, 51, + {OSC_24M_CLK, SYSTEM_PLL1_40M_CLK, VPU_PLL_CLK, + SYSTEM_PLL3_CLK, SYSTEM_PLL2_200M_CLK, + SYSTEM_PLL1_266M_CLK, SYSTEM_PLL2_500M_CLK, SYSTEM_PLL1_100M_CLK} + }, + {USDHC3_CLK_ROOT, IP_CLOCK_SLICE, 57, + {OSC_24M_CLK, SYSTEM_PLL1_400M_CLK, SYSTEM_PLL1_800M_CLK, + SYSTEM_PLL2_500M_CLK, SYSTEM_PLL3_CLK, + SYSTEM_PLL1_266M_CLK, AUDIO_PLL2_CLK, SYSTEM_PLL1_100M_CLK} + }, + {ECSPI3_CLK_ROOT, IP_CLOCK_SLICE, 67, + {OSC_24M_CLK, SYSTEM_PLL2_200M_CLK, SYSTEM_PLL1_40M_CLK, + SYSTEM_PLL1_160M_CLK, SYSTEM_PLL1_800M_CLK, + SYSTEM_PLL3_CLK, SYSTEM_PLL2_250M_CLK, AUDIO_PLL2_CLK} + }, + {DRAM_SEL_CFG, DRAM_SEL_CLOCK_SLICE, 0, + {DRAM_PLL1_CLK} + }, + {CORE_SEL_CFG, CORE_SEL_CLOCK_SLICE, 0, + {DRAM_PLL1_CLK} + }, +}; #endif
static int select(enum clk_root_index clock_id)
4000MTS DDR needs 1GHz fracpll, so add the entry
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/clock_imx8mm.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-imx/imx8m/clock_imx8mm.c b/arch/arm/mach-imx/imx8m/clock_imx8mm.c index ee44ba75fe..68575a2bd3 100644 --- a/arch/arm/mach-imx/imx8m/clock_imx8mm.c +++ b/arch/arm/mach-imx/imx8m/clock_imx8mm.c @@ -50,6 +50,7 @@ int enable_i2c_clk(unsigned char enable, unsigned i2c_num)
#ifdef CONFIG_SPL_BUILD static struct imx_int_pll_rate_table imx8mm_fracpll_tbl[] = { + PLL_1443X_RATE(1000000000U, 250, 3, 1, 0), PLL_1443X_RATE(800000000U, 300, 9, 0, 0), PLL_1443X_RATE(750000000U, 250, 8, 0, 0), PLL_1443X_RATE(650000000U, 325, 3, 2, 0),
Add i.MX8MP compatible to let the pinctrl driver could support i.MX8MP.
Reviewed-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/pinctrl/nxp/pinctrl-imx8m.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/pinctrl/nxp/pinctrl-imx8m.c b/drivers/pinctrl/nxp/pinctrl-imx8m.c index b3844314b3..5b7cbb69ae 100644 --- a/drivers/pinctrl/nxp/pinctrl-imx8m.c +++ b/drivers/pinctrl/nxp/pinctrl-imx8m.c @@ -22,6 +22,7 @@ static const struct udevice_id imx8m_pinctrl_match[] = { { .compatible = "fsl,imx8mq-iomuxc", .data = (ulong)&imx8mq_pinctrl_soc_info }, { .compatible = "fsl,imx8mm-iomuxc", .data = (ulong)&imx8mq_pinctrl_soc_info }, { .compatible = "fsl,imx8mn-iomuxc", .data = (ulong)&imx8mq_pinctrl_soc_info }, + { .compatible = "fsl,imx8mp-iomuxc", .data = (ulong)&imx8mq_pinctrl_soc_info }, { /* sentinel */ } };
i.MX8MP use similar ocotp as i.MX8MN, but has changed fuse banks and ctrl register bit definitions, so update to reflect that.
Reviewed-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/misc/mxc_ocotp.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/misc/mxc_ocotp.c b/drivers/misc/mxc_ocotp.c index 1b945e9727..80cd8dceda 100644 --- a/drivers/misc/mxc_ocotp.c +++ b/drivers/misc/mxc_ocotp.c @@ -35,7 +35,16 @@ #define BM_OUT_STATUS_LOCKED 0x00000800 #define BM_OUT_STATUS_PROGFAIL 0x00001000 #elif defined(CONFIG_IMX8M) +#ifdef CONFIG_IMX8MP +#undef BM_CTRL_ADDR +#undef BM_CTRL_ERROR +#undef BM_CTRL_BUSY +#define BM_CTRL_ADDR 0x000001ff +#define BM_CTRL_ERROR 0x00000400 +#define BM_CTRL_BUSY 0x00000200 +#else #define BM_CTRL_ADDR 0x000000ff +#endif #else #define BM_CTRL_ADDR 0x0000007f #endif @@ -82,7 +91,11 @@ #define FUSE_BANKS 31 #elif defined(CONFIG_IMX8M) #define FUSE_BANK_SIZE 0x40 +#ifdef CONFIG_IMX8MP +#define FUSE_BANKS 96 +#else #define FUSE_BANKS 64 +#endif #else #error "Unsupported architecture\n" #endif
We will generate DRAM 4000MT/s as default for i.MX8MP. So need DRAM PLL to generate 1000Mhz clock to DDR PHY and controller.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/ddr/imx/imx8m/ddrphy_utils.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/ddr/imx/imx8m/ddrphy_utils.c b/drivers/ddr/imx/imx8m/ddrphy_utils.c index e60503309e..7b4ab7c77a 100644 --- a/drivers/ddr/imx/imx8m/ddrphy_utils.c +++ b/drivers/ddr/imx/imx8m/ddrphy_utils.c @@ -106,6 +106,10 @@ void wait_ddrphy_training_complete(void) void ddrphy_init_set_dfi_clk(unsigned int drate) { switch (drate) { + case 4000: + dram_pll_init(MHZ(1000)); + dram_disable_bypass(); + break; case 3200: dram_pll_init(MHZ(800)); dram_disable_bypass();
The i.MX8M Plus Media Applications Processor is part of the growing mScale family targeting the consumer and industrial market. It brings an effective Machine Learning and AI accelerator that enables a new class of applications. It is built in Samsung 14LPP to achieve both high performance and low power consumption and relies on a powerful fully coherent core complex based on a quad core ARM Cortex-A53 cluster and Cortex-M7 low-power coprocessor, audio digital signal processor, machine learning and graphics accelerators.
Add the basic dtsi support for i.MX8MP.
Patch from Anson Huang for Kernel https://patchwork.kernel.org/patch/11310915/
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mp.dtsi | 598 +++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 598 insertions(+) create mode 100644 arch/arm/dts/imx8mp.dtsi
diff --git a/arch/arm/dts/imx8mp.dtsi b/arch/arm/dts/imx8mp.dtsi new file mode 100644 index 0000000000..0fb29cc812 --- /dev/null +++ b/arch/arm/dts/imx8mp.dtsi @@ -0,0 +1,598 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2019 NXP + */ + +#include <dt-bindings/clock/imx8mp-clock.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + +#include "imx8mp-pinfunc.h" + +/ { + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + aliases { + ethernet0 = &fec; + gpio0 = &gpio1; + gpio1 = &gpio2; + gpio2 = &gpio3; + gpio3 = &gpio4; + gpio4 = &gpio5; + mmc0 = &usdhc1; + mmc1 = &usdhc2; + mmc2 = &usdhc3; + serial0 = &uart1; + serial1 = &uart2; + serial2 = &uart3; + serial3 = &uart4; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + A53_0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0>; + clock-latency = <61036>; + clocks = <&clk IMX8MP_CLK_ARM>; + enable-method = "psci"; + next-level-cache = <&A53_L2>; + }; + + A53_1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x1>; + clock-latency = <61036>; + clocks = <&clk IMX8MP_CLK_ARM>; + enable-method = "psci"; + next-level-cache = <&A53_L2>; + }; + + A53_2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x2>; + clock-latency = <61036>; + clocks = <&clk IMX8MP_CLK_ARM>; + enable-method = "psci"; + next-level-cache = <&A53_L2>; + }; + + A53_3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x3>; + clock-latency = <61036>; + clocks = <&clk IMX8MP_CLK_ARM>; + enable-method = "psci"; + next-level-cache = <&A53_L2>; + }; + + A53_L2: l2-cache0 { + compatible = "cache"; + }; + }; + + osc_32k: clock-osc-32k { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "osc_32k"; + }; + + osc_24m: clock-osc-24m { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + clock-output-names = "osc_24m"; + }; + + clk_ext1: clock-ext1 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <133000000>; + clock-output-names = "clk_ext1"; + }; + + clk_ext2: clock-ext2 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <133000000>; + clock-output-names = "clk_ext2"; + }; + + clk_ext3: clock-ext3 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <133000000>; + clock-output-names = "clk_ext3"; + }; + + clk_ext4: clock-ext4 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency= <133000000>; + clock-output-names = "clk_ext4"; + }; + + psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>; + clock-frequency = <8000000>; + arm,no-tick-in-suspend; + }; + + soc@0 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x0 0x0 0x3e000000>; + + aips1: bus@30000000 { + compatible = "simple-bus"; + reg = <0x30000000 0x400000>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + gpio1: gpio@30200000 { + compatible = "fsl,imx8mp-gpio", "fsl,imx35-gpio"; + reg = <0x30200000 0x10000>; + interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_GPIO1_ROOT>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 5 30>; + }; + + gpio2: gpio@30210000 { + compatible = "fsl,imx8mp-gpio", "fsl,imx35-gpio"; + reg = <0x30210000 0x10000>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_GPIO2_ROOT>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 35 21>; + }; + + gpio3: gpio@30220000 { + compatible = "fsl,imx8mp-gpio", "fsl,imx35-gpio"; + reg = <0x30220000 0x10000>; + interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_GPIO3_ROOT>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 56 26>, <&iomuxc 0 144 4>; + }; + + gpio4: gpio@30230000 { + compatible = "fsl,imx8mp-gpio", "fsl,imx35-gpio"; + reg = <0x30230000 0x10000>; + interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_GPIO4_ROOT>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 82 32>; + }; + + gpio5: gpio@30240000 { + compatible = "fsl,imx8mp-gpio", "fsl,imx35-gpio"; + reg = <0x30240000 0x10000>; + interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_GPIO5_ROOT>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 114 30>; + }; + + wdog1: watchdog@30280000 { + compatible = "fsl,imx8mp-wdt", "fsl,imx21-wdt"; + reg = <0x30280000 0x10000>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_WDOG1_ROOT>; + status = "disabled"; + }; + + iomuxc: pinctrl@30330000 { + compatible = "fsl,imx8mp-iomuxc"; + reg = <0x30330000 0x10000>; + }; + + gpr: iomuxc-gpr@30340000 { + compatible = "fsl,imx8mp-iomuxc-gpr", "syscon"; + reg = <0x30340000 0x10000>; + }; + + ocotp: ocotp-ctrl@30350000 { + compatible = "fsl,imx8mp-ocotp", "fsl,imx8mm-ocotp", "syscon"; + reg = <0x30350000 0x10000>; + clocks = <&clk IMX8MP_CLK_OCOTP_ROOT>; + /* For nvmem subnodes */ + #address-cells = <1>; + #size-cells = <1>; + + cpu_speed_grade: speed-grade@10 { + reg = <0x10 4>; + }; + }; + + anatop: anatop@30360000 { + compatible = "fsl,imx8mp-anatop", "fsl,imx8mm-anatop", + "syscon"; + reg = <0x30360000 0x10000>; + }; + + snvs: snvs@30370000 { + compatible = "fsl,sec-v4.0-mon","syscon", "simple-mfd"; + reg = <0x30370000 0x10000>; + + snvs_rtc: snvs-rtc-lp { + compatible = "fsl,sec-v4.0-mon-rtc-lp"; + regmap =<&snvs>; + offset = <0x34>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_SNVS_ROOT>; + clock-names = "snvs-rtc"; + }; + + snvs_pwrkey: snvs-powerkey { + compatible = "fsl,sec-v4.0-pwrkey"; + regmap = <&snvs>; + interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + linux,keycode = <KEY_POWER>; + wakeup-source; + status = "disabled"; + }; + }; + + clk: clock-controller@30380000 { + compatible = "fsl,imx8mp-ccm"; + reg = <0x30380000 0x10000>; + #clock-cells = <1>; + clocks = <&osc_32k>, <&osc_24m>, <&clk_ext1>, <&clk_ext2>, + <&clk_ext3>, <&clk_ext4>; + clock-names = "osc_32k", "osc_24m", "clk_ext1", "clk_ext2", + "clk_ext3", "clk_ext4"; + assigned-clocks = <&clk IMX8MP_CLK_AUDIO_AHB>, + <&clk IMX8MP_CLK_IPG_AUDIO_ROOT>, + <&clk IMX8MP_AUDIO_PLL1>, + <&clk IMX8MP_AUDIO_PLL2>; + }; + + src: src@30390000 { + compatible = "fsl,imx8mp-src", "fsl,imx8mq-src", "syscon"; + reg = <0x30390000 0x10000>; + interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; + #reset-cells = <1>; + }; + }; + + aips2: bus@30400000 { + compatible = "simple-bus"; + reg = <0x30400000 0x400000>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + pwm1: pwm@30660000 { + compatible = "fsl,imx8mp-pwm", "fsl,imx27-pwm"; + reg = <0x30660000 0x10000>; + interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_PWM1_ROOT>, + <&clk IMX8MP_CLK_PWM1_ROOT>; + clock-names = "ipg", "per"; + #pwm-cells = <2>; + status = "disabled"; + }; + + pwm2: pwm@30670000 { + compatible = "fsl,imx8mp-pwm", "fsl,imx27-pwm"; + reg = <0x30670000 0x10000>; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_PWM2_ROOT>, + <&clk IMX8MP_CLK_PWM2_ROOT>; + clock-names = "ipg", "per"; + #pwm-cells = <2>; + status = "disabled"; + }; + + pwm3: pwm@30680000 { + compatible = "fsl,imx8mp-pwm", "fsl,imx27-pwm"; + reg = <0x30680000 0x10000>; + interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_PWM3_ROOT>, + <&clk IMX8MP_CLK_PWM3_ROOT>; + clock-names = "ipg", "per"; + #pwm-cells = <2>; + status = "disabled"; + }; + + pwm4: pwm@30690000 { + compatible = "fsl,imx8mp-pwm", "fsl,imx27-pwm"; + reg = <0x30690000 0x10000>; + interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_PWM4_ROOT>, + <&clk IMX8MP_CLK_PWM4_ROOT>; + clock-names = "ipg", "per"; + #pwm-cells = <2>; + status = "disabled"; + }; + }; + + aips3: bus@30800000 { + compatible = "simple-bus"; + reg = <0x30800000 0x400000>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + ecspi1: spi@30820000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx8mp-ecspi", "fsl,imx51-ecspi"; + reg = <0x30820000 0x10000>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_ECSPI1_ROOT>, + <&clk IMX8MP_CLK_ECSPI1_ROOT>; + clock-names = "ipg", "per"; + dmas = <&sdma1 0 7 1>, <&sdma1 1 7 2>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + ecspi2: spi@30830000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx8mp-ecspi", "fsl,imx51-ecspi"; + reg = <0x30830000 0x10000>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_ECSPI2_ROOT>, + <&clk IMX8MP_CLK_ECSPI2_ROOT>; + clock-names = "ipg", "per"; + dmas = <&sdma1 2 7 1>, <&sdma1 3 7 2>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + ecspi3: spi@30840000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx8mp-ecspi", "fsl,imx51-ecspi"; + reg = <0x30840000 0x10000>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_ECSPI3_ROOT>, + <&clk IMX8MP_CLK_ECSPI3_ROOT>; + clock-names = "ipg", "per"; + dmas = <&sdma1 4 7 1>, <&sdma1 5 7 2>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + uart1: serial@30860000 { + compatible = "fsl,imx8mp-uart", "fsl,imx6q-uart"; + reg = <0x30860000 0x10000>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_UART1_ROOT>, + <&clk IMX8MP_CLK_UART1_ROOT>; + clock-names = "ipg", "per"; + dmas = <&sdma1 22 4 0>, <&sdma1 23 4 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + uart3: serial@30880000 { + compatible = "fsl,imx8mp-uart", "fsl,imx6q-uart"; + reg = <0x30880000 0x10000>; + interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_UART3_ROOT>, + <&clk IMX8MP_CLK_UART3_ROOT>; + clock-names = "ipg", "per"; + dmas = <&sdma1 26 4 0>, <&sdma1 27 4 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + uart2: serial@30890000 { + compatible = "fsl,imx8mp-uart", "fsl,imx6q-uart"; + reg = <0x30890000 0x10000>; + interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_UART2_ROOT>, + <&clk IMX8MP_CLK_UART2_ROOT>; + clock-names = "ipg", "per"; + status = "disabled"; + }; + + i2c1: i2c@30a20000 { + compatible = "fsl,imx8mp-i2c", "fsl,imx21-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x30a20000 0x10000>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_I2C1_ROOT>; + status = "disabled"; + }; + + i2c2: i2c@30a30000 { + compatible = "fsl,imx8mp-i2c", "fsl,imx21-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x30a30000 0x10000>; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_I2C2_ROOT>; + status = "disabled"; + }; + + i2c3: i2c@30a40000 { + compatible = "fsl,imx8mm-i2c", "fsl,imx21-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x30a40000 0x10000>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_I2C3_ROOT>; + status = "disabled"; + }; + + i2c4: i2c@30a50000 { + compatible = "fsl,imx8mp-i2c", "fsl,imx21-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x30a50000 0x10000>; + interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_I2C4_ROOT>; + status = "disabled"; + }; + + uart4: serial@30a60000 { + compatible = "fsl,imx8mp-uart", "fsl,imx6q-uart"; + reg = <0x30a60000 0x10000>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_UART4_ROOT>, + <&clk IMX8MP_CLK_UART4_ROOT>; + clock-names = "ipg", "per"; + dmas = <&sdma1 28 4 0>, <&sdma1 29 4 0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + i2c5: i2c@30ad0000 { + compatible = "fsl,imx8mp-i2c", "fsl,imx21-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x30ad0000 0x10000>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_I2C5_ROOT>; + status = "disabled"; + }; + + i2c6: i2c@30ae0000 { + compatible = "fsl,imx8mp-i2c", "fsl,imx21-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x30ae0000 0x10000>; + interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_I2C6_ROOT>; + status = "disabled"; + }; + + usdhc1: mmc@30b40000 { + compatible = "fsl,imx8mm-usdhc", "fsl,imx7d-usdhc"; + reg = <0x30b40000 0x10000>; + interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_DUMMY>, + <&clk IMX8MP_CLK_NAND_USDHC_BUS>, + <&clk IMX8MP_CLK_USDHC1_ROOT>; + clock-names = "ipg", "ahb", "per"; + fsl,tuning-start-tap = <20>; + fsl,tuning-step= <2>; + bus-width = <4>; + status = "disabled"; + }; + + usdhc2: mmc@30b50000 { + compatible = "fsl,imx8mm-usdhc", "fsl,imx7d-usdhc"; + reg = <0x30b50000 0x10000>; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_DUMMY>, + <&clk IMX8MP_CLK_NAND_USDHC_BUS>, + <&clk IMX8MP_CLK_USDHC2_ROOT>; + clock-names = "ipg", "ahb", "per"; + fsl,tuning-start-tap = <20>; + fsl,tuning-step= <2>; + bus-width = <4>; + status = "disabled"; + }; + + usdhc3: mmc@30b60000 { + compatible = "fsl,imx8mm-usdhc", "fsl,imx7d-usdhc"; + reg = <0x30b60000 0x10000>; + interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_DUMMY>, + <&clk IMX8MP_CLK_NAND_USDHC_BUS>, + <&clk IMX8MP_CLK_USDHC3_ROOT>; + clock-names = "ipg", "ahb", "per"; + fsl,tuning-start-tap = <20>; + fsl,tuning-step= <2>; + bus-width = <4>; + status = "disabled"; + }; + + sdma1: dma-controller@30bd0000 { + compatible = "fsl,imx8mp-sdma", "fsl,imx8mq-sdma"; + reg = <0x30bd0000 0x10000>; + interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_SDMA1_ROOT>, + <&clk IMX8MP_CLK_SDMA1_ROOT>; + clock-names = "ipg", "ahb"; + #dma-cells = <3>; + fsl,sdma-ram-script-name = "imx/sdma/sdma-imx7d.bin"; + }; + + fec: ethernet@30be0000 { + compatible = "fsl,imx8mm-fec", "fsl,imx8mq-fec", "fsl,imx6sx-fec"; + reg = <0x30be0000 0x10000>; + interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX8MP_CLK_ENET1_ROOT>, + <&clk IMX8MP_CLK_SIM_ENET_ROOT>, + <&clk IMX8MP_CLK_ENET_TIMER>, + <&clk IMX8MP_CLK_ENET_REF>, + <&clk IMX8MP_CLK_ENET_PHY_REF>; + clock-names = "ipg", "ahb", "ptp", + "enet_clk_ref", "enet_out"; + assigned-clocks = <&clk IMX8MP_CLK_ENET_AXI>, + <&clk IMX8MP_CLK_ENET_TIMER>, + <&clk IMX8MP_CLK_ENET_REF>, + <&clk IMX8MP_CLK_ENET_TIMER>; + assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_266M>, + <&clk IMX8MP_SYS_PLL2_100M>, + <&clk IMX8MP_SYS_PLL2_125M>; + assigned-clock-rates = <0>, <0>, <125000000>, <100000000>; + fsl,num-tx-queues = <3>; + fsl,num-rx-queues = <3>; + status = "disabled"; + }; + }; + + gic: interrupt-controller@38800000 { + compatible = "arm,gic-v3"; + reg = <0x38800000 0x10000>, + <0x38880000 0xc0000>; + #interrupt-cells = <3>; + interrupt-controller; + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; + interrupt-parent = <&gic>; + }; + }; +};
PCA9450 PMIC series is used to support iMX8MM (PCA9450A) and iMX8MN (PCA9450B). Add the PMIC driver for both PCA9450A and PCA9450B.
Signed-off-by: Robin Gong yibin.gong@nxp.com Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/power/pmic/Kconfig | 7 +++ drivers/power/pmic/Makefile | 2 + drivers/power/pmic/pca9450.c | 93 +++++++++++++++++++++++++++++++++++++++ drivers/power/pmic/pmic_pca9450.c | 50 +++++++++++++++++++++ include/power/pca9450.h | 60 +++++++++++++++++++++++++ 5 files changed, 212 insertions(+) create mode 100644 drivers/power/pmic/pca9450.c create mode 100644 drivers/power/pmic/pmic_pca9450.c create mode 100644 include/power/pca9450.h
diff --git a/drivers/power/pmic/Kconfig b/drivers/power/pmic/Kconfig index b4bf018674..df9372c239 100644 --- a/drivers/power/pmic/Kconfig +++ b/drivers/power/pmic/Kconfig @@ -77,6 +77,13 @@ config DM_PMIC_FAN53555 The driver implements read/write operations for use with the FAN53555 regulator driver and binds the regulator driver to its node.
+config DM_PMIC_PCA9450 + bool "Enable Driver Model for PMIC PCA9450" + depends on DM_PMIC + help + This config enables implementation of driver-model pmic uclass features + for PMIC PCA9450. The driver implements read/write operations. + config DM_PMIC_PFUZE100 bool "Enable Driver Model for PMIC PFUZE100" depends on DM_PMIC diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index ec64327805..7b6cb0ee1b 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -10,6 +10,7 @@ obj-$(CONFIG_DM_PMIC_MAX8998) += max8998.o obj-$(CONFIG_DM_PMIC_MC34708) += mc34708.o obj-$(CONFIG_$(SPL_)DM_PMIC_BD71837) += bd71837.o obj-$(CONFIG_$(SPL_)DM_PMIC_PFUZE100) += pfuze100.o +obj-$(CONFIG_$(SPL_)DM_PMIC_PCA9450) += pca9450.o obj-$(CONFIG_PMIC_S2MPS11) += s2mps11.o obj-$(CONFIG_DM_PMIC_SANDBOX) += sandbox.o i2c_pmic_emul.o obj-$(CONFIG_PMIC_ACT8846) += act8846.o @@ -31,6 +32,7 @@ obj-$(CONFIG_POWER_MAX77696) += pmic_max77696.o obj-$(CONFIG_POWER_MAX8998) += pmic_max8998.o obj-$(CONFIG_POWER_MAX8997) += pmic_max8997.o obj-$(CONFIG_POWER_MUIC_MAX8997) += muic_max8997.o +obj-$(CONFIG_POWER_PCA9450) += pmic_pca9450.o obj-$(CONFIG_POWER_PFUZE100) += pmic_pfuze100.o obj-$(CONFIG_POWER_PFUZE3000) += pmic_pfuze3000.o obj-$(CONFIG_POWER_TPS65217) += pmic_tps65217.o diff --git a/drivers/power/pmic/pca9450.c b/drivers/power/pmic/pca9450.c new file mode 100644 index 0000000000..77986c47d7 --- /dev/null +++ b/drivers/power/pmic/pca9450.c @@ -0,0 +1,93 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + */ + +#include <common.h> +#include <fdtdec.h> +#include <errno.h> +#include <dm.h> +#include <i2c.h> +#include <power/pmic.h> +#include <power/regulator.h> +#include <power/pca9450.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct pmic_child_info pmic_children_info[] = { + /* buck */ + { .prefix = "b", .driver = PCA9450_REGULATOR_DRIVER}, + /* ldo */ + { .prefix = "l", .driver = PCA9450_REGULATOR_DRIVER}, + { }, +}; + +static int pca9450_reg_count(struct udevice *dev) +{ + return PCA9450_REG_NUM; +} + +static int pca9450_write(struct udevice *dev, uint reg, const uint8_t *buff, + int len) +{ + if (dm_i2c_write(dev, reg, buff, len)) { + pr_err("write error to device: %p register: %#x!", dev, reg); + return -EIO; + } + + return 0; +} + +static int pca9450_read(struct udevice *dev, uint reg, uint8_t *buff, + int len) +{ + if (dm_i2c_read(dev, reg, buff, len)) { + pr_err("read error from device: %p register: %#x!", dev, reg); + return -EIO; + } + + return 0; +} + +static int pca9450_bind(struct udevice *dev) +{ + int children; + ofnode regulators_node; + + regulators_node = dev_read_subnode(dev, "regulators"); + if (!ofnode_valid(regulators_node)) { + debug("%s: %s regulators subnode not found!", __func__, + dev->name); + return -ENXIO; + } + + debug("%s: '%s' - found regulators subnode\n", __func__, dev->name); + + children = pmic_bind_children(dev, regulators_node, + pmic_children_info); + if (!children) + debug("%s: %s - no child found\n", __func__, dev->name); + + /* Always return success for this device */ + return 0; +} + +static struct dm_pmic_ops pca9450_ops = { + .reg_count = pca9450_reg_count, + .read = pca9450_read, + .write = pca9450_write, +}; + +static const struct udevice_id pca9450_ids[] = { + { .compatible = "nxp,pca9450a", .data = 0x35, }, + { .compatible = "nxp,pca9450b", .data = 0x25, }, + { } +}; + +U_BOOT_DRIVER(pmic_pca9450) = { + .name = "pca9450 pmic", + .id = UCLASS_PMIC, + .of_match = pca9450_ids, + .bind = pca9450_bind, + .ops = &pca9450_ops, +}; diff --git a/drivers/power/pmic/pmic_pca9450.c b/drivers/power/pmic/pmic_pca9450.c new file mode 100644 index 0000000000..67a9090200 --- /dev/null +++ b/drivers/power/pmic/pmic_pca9450.c @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + */ + +#include <common.h> +#include <errno.h> +#include <i2c.h> +#include <power/pmic.h> +#include <power/pca9450.h> + +static const char pca9450_name[] = "PCA9450"; + +int power_pca9450a_init(unsigned char bus) +{ + struct pmic *p = pmic_alloc(); + + if (!p) { + printf("%s: POWER allocation error!\n", __func__); + return -ENOMEM; + } + + p->name = pca9450_name; + p->interface = PMIC_I2C; + p->number_of_regs = PCA9450_REG_NUM; + p->hw.i2c.addr = 0x35; + p->hw.i2c.tx_num = 1; + p->bus = bus; + + return 0; +} + +int power_pca9450b_init(unsigned char bus) +{ + struct pmic *p = pmic_alloc(); + + if (!p) { + printf("%s: POWER allocation error!\n", __func__); + return -ENOMEM; + } + + p->name = pca9450_name; + p->interface = PMIC_I2C; + p->number_of_regs = PCA9450_REG_NUM; + p->hw.i2c.addr = 0x25; + p->hw.i2c.tx_num = 1; + p->bus = bus; + + return 0; +} diff --git a/include/power/pca9450.h b/include/power/pca9450.h new file mode 100644 index 0000000000..5d4f58ca44 --- /dev/null +++ b/include/power/pca9450.h @@ -0,0 +1,60 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + */ + +#ifndef PCA9450_H_ +#define PCA9450_H_ + +#define PCA9450_REGULATOR_DRIVER "pca9450_regulator" + +enum { + PCA9450_REG_DEV_ID = 0x00, + PCA9450_INT1 = 0x01, + PCA9450_INT1_MSK = 0x02, + PCA9450_STATUS1 = 0x03, + PCA9450_STATUS2 = 0x04, + PCA9450_PWRON_STAT = 0x05, + PCA9450_SW_RST = 0x06, + PCA9450_PWR_CTRL = 0x07, + PCA9450_RESET_CTRL = 0x08, + PCA9450_CONFIG1 = 0x09, + PCA9450_CONFIG2 = 0x0A, + PCA9450_BUCK123_DVS = 0x0C, + PCA9450_BUCK1OUT_LIMIT = 0x0D, + PCA9450_BUCK2OUT_LIMIT = 0x0E, + PCA9450_BUCK3OUT_LIMIT = 0x0F, + PCA9450_BUCK1CTRL = 0x10, + PCA9450_BUCK1OUT_DVS0 = 0x11, + PCA9450_BUCK1OUT_DVS1 = 0x12, + PCA9450_BUCK2CTRL = 0x13, + PCA9450_BUCK2OUT_DVS0 = 0x14, + PCA9450_BUCK2OUT_DVS1 = 0x15, + PCA9450_BUCK3CTRL = 0x16, + PCA9450_BUCK3OUT_DVS0 = 0x17, + PCA9450_BUCK3OUT_DVS1 = 0x18, + PCA9450_BUCK4CTRL = 0x19, + PCA9450_BUCK4OUT = 0x1A, + PCA9450_BUCK5CTRL = 0x1B, + PCA9450_BUCK5OUT = 0x1C, + PCA9450_BUCK6CTRL = 0x1D, + PCA9450_BUCK6OUT = 0x1E, + PCA9450_LDO_AD_CTRL = 0x20, + PCA9450_LDO1CTRL = 0x21, + PCA9450_LDO2CTRL = 0x22, + PCA9450_LDO3CTRL = 0x23, + PCA9450_LDO4CTRL = 0x24, + PCA9450_LDO5CTRL_L = 0x25, + PCA9450_LDO5CTRL_H = 0x26, + PCA9450_LOADSW_CTRL = 0x2A, + PCA9450_VRFLT1_STS = 0x2B, + PCA9450_VRFLT2_STS = 0x2C, + PCA9450_VRFLT1_MASK = 0x2D, + PCA9450_VRFLT2_MASK = 0x2E, + PCA9450_REG_NUM, +}; + +int power_pca9450a_init(unsigned char bus); +int power_pca9450b_init(unsigned char bus); + +#endif
Add pin header file for i.MX8MP
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx8m/imx8mp_pins.h | 1080 +++++++++++++++++++++++++ 1 file changed, 1080 insertions(+) create mode 100644 arch/arm/include/asm/arch-imx8m/imx8mp_pins.h
diff --git a/arch/arm/include/asm/arch-imx8m/imx8mp_pins.h b/arch/arm/include/asm/arch-imx8m/imx8mp_pins.h new file mode 100644 index 0000000000..e7f3221823 --- /dev/null +++ b/arch/arm/include/asm/arch-imx8m/imx8mp_pins.h @@ -0,0 +1,1080 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + */ + +#ifndef __ASM_ARCH_IMX8MP_PINS_H__ +#define __ASM_ARCH_IMX8MP_PINS_H__ + +#include <asm/mach-imx/iomux-v3.h> + +enum { + MX8MP_PAD_GPIO1_IO00__GPIO1_IO00 = IOMUX_PAD(0x0274, 0x0014, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO00__CCMSRCGPCMIX_ENET_PHY_REF_CLK_ROOT = IOMUX_PAD(0x0274, 0x0014, 1, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO00__MEDIAMIX_ISP_FL_TRIG_0 = IOMUX_PAD(0x0274, 0x0014, 3, 0x05D4, 0, 0), + MX8MP_PAD_GPIO1_IO00__ANAMIX_REF_CLK_32K = IOMUX_PAD(0x0274, 0x0014, 5, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO00__CCMSRCGPCMIX_EXT_CLK1 = IOMUX_PAD(0x0274, 0x0014, 6, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO00__SJC_FAIL = IOMUX_PAD(0x0274, 0x0014, 7, 0x0000, 0, 0), + + MX8MP_PAD_GPIO1_IO01__GPIO1_IO01 = IOMUX_PAD(0x0278, 0x0018, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO01__PWM1_OUT = IOMUX_PAD(0x0278, 0x0018, 1, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO01__MEDIAMIX_ISP_SHUTTER_TRIG_0 = IOMUX_PAD(0x0278, 0x0018, 3, 0x05DC, 0, 0), + MX8MP_PAD_GPIO1_IO01__ANAMIX_REF_CLK_24M = IOMUX_PAD(0x0278, 0x0018, 5, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO01__CCMSRCGPCMIX_EXT_CLK2 = IOMUX_PAD(0x0278, 0x0018, 6, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO01__SJC_ACTIVE = IOMUX_PAD(0x0278, 0x0018, 7, 0x0000, 0, 0), + + MX8MP_PAD_GPIO1_IO02__GPIO1_IO02 = IOMUX_PAD(0x027C, 0x001C, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_B = IOMUX_PAD(0x027C, 0x001C, 1, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO02__MEDIAMIX_ISP_FLASH_TRIG_0 = IOMUX_PAD(0x027C, 0x001C, 3, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_ANY = IOMUX_PAD(0x027C, 0x001C, 5, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO02__SJC_DE_B = IOMUX_PAD(0x027C, 0x001C, 7, 0x0000, 0, 0), + + MX8MP_PAD_GPIO1_IO03__GPIO1_IO03 = IOMUX_PAD(0x0280, 0x0020, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO03__USDHC1_VSELECT = IOMUX_PAD(0x0280, 0x0020, 1, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO03__MEDIAMIX_ISP_PRELIGHT_TRIG_0 = IOMUX_PAD(0x0280, 0x0020, 3, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO03__SDMA1_EXT_EVENT00 = IOMUX_PAD(0x0280, 0x0020, 5, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO03__ANAMIX_XTAL_OK = IOMUX_PAD(0x0280, 0x0020, 6, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO03__SJC_DONE = IOMUX_PAD(0x0280, 0x0020, 7, 0x0000, 0, 0), + + MX8MP_PAD_GPIO1_IO04__GPIO1_IO04 = IOMUX_PAD(0x0284, 0x0024, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO04__USDHC2_VSELECT = IOMUX_PAD(0x0284, 0x0024, 1, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO04__MEDIAMIX_ISP_SHUTTER_OPEN_0 = IOMUX_PAD(0x0284, 0x0024, 3, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO04__SDMA1_EXT_EVENT01 = IOMUX_PAD(0x0284, 0x0024, 5, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO04__ANAMIX_XTAL_OK_LV = IOMUX_PAD(0x0284, 0x0024, 6, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO04__USDHC1_TEST_TRIG = IOMUX_PAD(0x0284, 0x0024, 7, 0x0000, 0, 0), + + MX8MP_PAD_GPIO1_IO05__GPIO1_IO05 = IOMUX_PAD(0x0288, 0x0028, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO05__M7_NMI = IOMUX_PAD(0x0288, 0x0028, 1, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO05__MEDIAMIX_ISP_FL_TRIG_1 = IOMUX_PAD(0x0288, 0x0028, 3, 0x05D8, 0, 0), + MX8MP_PAD_GPIO1_IO05__CCMSRCGPCMIX_PMIC_READY = IOMUX_PAD(0x0288, 0x0028, 5, 0x0554, 0, 0), + MX8MP_PAD_GPIO1_IO05__CCMSRCGPCMIX_INT_BOOT = IOMUX_PAD(0x0288, 0x0028, 6, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO05__USDHC2_TEST_TRIG = IOMUX_PAD(0x0288, 0x0028, 7, 0x0000, 0, 0), + + MX8MP_PAD_GPIO1_IO06__GPIO1_IO06 = IOMUX_PAD(0x028C, 0x002C, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO06__ENET_QOS_MDC = IOMUX_PAD(0x028C, 0x002C, 1, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO06__MEDIAMIX_ISP_SHUTTER_TRIG_1 = IOMUX_PAD(0x028C, 0x002C, 3, 0x05E0, 0, 0), + MX8MP_PAD_GPIO1_IO06__USDHC1_CD_B = IOMUX_PAD(0x028C, 0x002C, 5, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO06__CCMSRCGPCMIX_EXT_CLK3 = IOMUX_PAD(0x028C, 0x002C, 6, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO06__ECSPI1_TEST_TRIG = IOMUX_PAD(0x028C, 0x002C, 7, 0x0000, 0, 0), + + MX8MP_PAD_GPIO1_IO07__GPIO1_IO07 = IOMUX_PAD(0x0290, 0x0030, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO07__ENET_QOS_MDIO = IOMUX_PAD(0x0290, 0x0030, 1, 0x0590, 0, 0), + MX8MP_PAD_GPIO1_IO07__MEDIAMIX_ISP_FLASH_TRIG_1 = IOMUX_PAD(0x0290, 0x0030, 3, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO07__USDHC1_WP = IOMUX_PAD(0x0290, 0x0030, 5, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO07__CCMSRCGPCMIX_EXT_CLK4 = IOMUX_PAD(0x0290, 0x0030, 6, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO07__ECSPI2_TEST_TRIG = IOMUX_PAD(0x0290, 0x0030, 7, 0x0000, 0, 0), + + MX8MP_PAD_GPIO1_IO08__GPIO1_IO08 = IOMUX_PAD(0x0294, 0x0034, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO08__ENET_QOS_1588_EVENT0_IN = IOMUX_PAD(0x0294, 0x0034, 1, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO08__PWM1_OUT = IOMUX_PAD(0x0294, 0x0034, 2, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO08__MEDIAMIX_ISP_PRELIGHT_TRIG_1 = IOMUX_PAD(0x0294, 0x0034, 3, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO08__ENET_QOS_1588_EVENT0_AUX_IN = IOMUX_PAD(0x0294, 0x0034, 4, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO08__USDHC2_RESET_B = IOMUX_PAD(0x0294, 0x0034, 5, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO08__CCMSRCGPCMIX_WAIT = IOMUX_PAD(0x0294, 0x0034, 6, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO08__FLEXSPI_TEST_TRIG = IOMUX_PAD(0x0294, 0x0034, 7, 0x0000, 0, 0), + + MX8MP_PAD_GPIO1_IO09__GPIO1_IO09 = IOMUX_PAD(0x0298, 0x0038, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO09__ENET_QOS_1588_EVENT0_OUT = IOMUX_PAD(0x0298, 0x0038, 1, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO09__PWM2_OUT = IOMUX_PAD(0x0298, 0x0038, 2, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO09__MEDIAMIX_ISP_SHUTTER_OPEN_1 = IOMUX_PAD(0x0298, 0x0038, 3, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO09__USDHC3_RESET_B = IOMUX_PAD(0x0298, 0x0038, 4, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO09__AUDIOMIX_EXT_EVENT00 = IOMUX_PAD(0x0298, 0x0038, 5, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO09__CCMSRCGPCMIX_STOP = IOMUX_PAD(0x0298, 0x0038, 6, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO09__RAWNAND_TEST_TRIG = IOMUX_PAD(0x0298, 0x0038, 7, 0x0000, 0, 0), + + MX8MP_PAD_GPIO1_IO10__GPIO1_IO10 = IOMUX_PAD(0x029C, 0x003C, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO10__HSIOMIX_usb1_OTG_ID = IOMUX_PAD(0x029C, 0x003C, 1, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO10__PWM3_OUT = IOMUX_PAD(0x029C, 0x003C, 2, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO10__OCOTP_FUSE_LATCHED = IOMUX_PAD(0x029C, 0x003C, 7, 0x0000, 0, 0), + + MX8MP_PAD_GPIO1_IO11__GPIO1_IO11 = IOMUX_PAD(0x02A0, 0x0040, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO11__HSIOMIX_usb2_OTG_ID = IOMUX_PAD(0x02A0, 0x0040, 1, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO11__PWM2_OUT = IOMUX_PAD(0x02A0, 0x0040, 2, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO11__USDHC3_VSELECT = IOMUX_PAD(0x02A0, 0x0040, 4, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO11__CCMSRCGPCMIX_PMIC_READY = IOMUX_PAD(0x02A0, 0x0040, 5, 0x0554, 1, 0), + MX8MP_PAD_GPIO1_IO11__CCMSRCGPCMIX_OUT0 = IOMUX_PAD(0x02A0, 0x0040, 6, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO11__CAAM_RNG_OSC_OBS = IOMUX_PAD(0x02A0, 0x0040, 7, 0x0000, 0, 0), + + MX8MP_PAD_GPIO1_IO12__GPIO1_IO12 = IOMUX_PAD(0x02A4, 0x0044, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO12__HSIOMIX_usb1_OTG_PWR = IOMUX_PAD(0x02A4, 0x0044, 1, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO12__AUDIOMIX_EXT_EVENT01 = IOMUX_PAD(0x02A4, 0x0044, 5, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO12__CCMSRCGPCMIX_OUT1 = IOMUX_PAD(0x02A4, 0x0044, 6, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO12__CSU_CSU_ALARM_AUT00 = IOMUX_PAD(0x02A4, 0x0044, 7, 0x0000, 0, 0), + + MX8MP_PAD_GPIO1_IO13__GPIO1_IO13 = IOMUX_PAD(0x02A8, 0x0048, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO13__HSIOMIX_usb1_OTG_OC = IOMUX_PAD(0x02A8, 0x0048, 1, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO13__PWM2_OUT = IOMUX_PAD(0x02A8, 0x0048, 5, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO13__CCMSRCGPCMIX_OUT2 = IOMUX_PAD(0x02A8, 0x0048, 6, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO13__CSU_CSU_ALARM_AUT01 = IOMUX_PAD(0x02A8, 0x0048, 7, 0x0000, 0, 0), + + MX8MP_PAD_GPIO1_IO14__GPIO1_IO14 = IOMUX_PAD(0x02AC, 0x004C, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO14__HSIOMIX_usb2_OTG_PWR = IOMUX_PAD(0x02AC, 0x004C, 1, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO14__USDHC3_CD_B = IOMUX_PAD(0x02AC, 0x004C, 4, 0x0608, 0, 0), + MX8MP_PAD_GPIO1_IO14__PWM3_OUT = IOMUX_PAD(0x02AC, 0x004C, 5, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO14__CCMSRCGPCMIX_CLKO1 = IOMUX_PAD(0x02AC, 0x004C, 6, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO14__CSU_CSU_ALARM_AUT02 = IOMUX_PAD(0x02AC, 0x004C, 7, 0x0000, 0, 0), + + MX8MP_PAD_GPIO1_IO15__GPIO1_IO15 = IOMUX_PAD(0x02B0, 0x0050, 0, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO15__HSIOMIX_usb2_OTG_OC = IOMUX_PAD(0x02B0, 0x0050, 1, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO15__USDHC3_WP = IOMUX_PAD(0x02B0, 0x0050, 4, 0x0634, 0, 0), + MX8MP_PAD_GPIO1_IO15__PWM4_OUT = IOMUX_PAD(0x02B0, 0x0050, 5, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO15__CCMSRCGPCMIX_CLKO2 = IOMUX_PAD(0x02B0, 0x0050, 6, 0x0000, 0, 0), + MX8MP_PAD_GPIO1_IO15__CSU_CSU_INT_DEB = IOMUX_PAD(0x02B0, 0x0050, 7, 0x0000, 0, 0), + + MX8MP_PAD_ENET_MDC__ENET_QOS_MDC = IOMUX_PAD(0x02B4, 0x0054, 0, 0x0000, 0, 0), + MX8MP_PAD_ENET_MDC__AUDIOMIX_SAI6_TX_DATA00 = IOMUX_PAD(0x02B4, 0x0054, 2, 0x0000, 0, 0), + MX8MP_PAD_ENET_MDC__GPIO1_IO16 = IOMUX_PAD(0x02B4, 0x0054, 5, 0x0000, 0, 0), + MX8MP_PAD_ENET_MDC__USDHC3_STROBE = IOMUX_PAD(0x02B4, 0x0054, 6, 0x0630, 0, 0), + MX8MP_PAD_ENET_MDC__SIM_M_HADDR15 = IOMUX_PAD(0x02B4, 0x0054, 7, 0x0000, 0, 0), + + MX8MP_PAD_ENET_MDIO__ENET_QOS_MDIO = IOMUX_PAD(0x02B8, 0x0058, 0, 0x0590, 1, 0), + MX8MP_PAD_ENET_MDIO__AUDIOMIX_SAI6_TX_SYNC = IOMUX_PAD(0x02B8, 0x0058, 2, 0x0528, 0, 0), + MX8MP_PAD_ENET_MDIO__GPIO1_IO17 = IOMUX_PAD(0x02B8, 0x0058, 5, 0x0000, 0, 0), + MX8MP_PAD_ENET_MDIO__USDHC3_DATA5 = IOMUX_PAD(0x02B8, 0x0058, 6, 0x0624, 0, 0), + MX8MP_PAD_ENET_MDIO__SIM_M_HADDR16 = IOMUX_PAD(0x02B8, 0x0058, 7, 0x0000, 0, 0), + + MX8MP_PAD_ENET_TD3__ENET_QOS_RGMII_TD3 = IOMUX_PAD(0x02BC, 0x005C, 0, 0x0000, 0, 0), + MX8MP_PAD_ENET_TD3__AUDIOMIX_SAI6_TX_BCLK = IOMUX_PAD(0x02BC, 0x005C, 2, 0x0524, 0, 0), + MX8MP_PAD_ENET_TD3__GPIO1_IO18 = IOMUX_PAD(0x02BC, 0x005C, 5, 0x0000, 0, 0), + MX8MP_PAD_ENET_TD3__USDHC3_DATA6 = IOMUX_PAD(0x02BC, 0x005C, 6, 0x0628, 0, 0), + MX8MP_PAD_ENET_TD3__SIM_M_HADDR17 = IOMUX_PAD(0x02BC, 0x005C, 7, 0x0000, 0, 0), + + MX8MP_PAD_ENET_TD2__ENET_QOS_RGMII_TD2 = IOMUX_PAD(0x02C0, 0x0060, 0, 0x0000, 0, 0), + MX8MP_PAD_ENET_TD2__CCM_ENET_QOS_CLOCK_GENERATE_REF_CLK = IOMUX_PAD(0x02C0, 0x0060, 1, 0x0000, 0, 0), + MX8MP_PAD_ENET_TD2__AUDIOMIX_SAI6_RX_DATA00 = IOMUX_PAD(0x02C0, 0x0060, 2, 0x051C, 0, 0), + MX8MP_PAD_ENET_TD2__GPIO1_IO19 = IOMUX_PAD(0x02C0, 0x0060, 5, 0x0000, 0, 0), + MX8MP_PAD_ENET_TD2__USDHC3_DATA7 = IOMUX_PAD(0x02C0, 0x0060, 6, 0x062C, 0, 0), + MX8MP_PAD_ENET_TD2__SIM_M_HADDR18 = IOMUX_PAD(0x02C0, 0x0060, 7, 0x0000, 0, 0), + + MX8MP_PAD_ENET_TD1__ENET_QOS_RGMII_TD1 = IOMUX_PAD(0x02C4, 0x0064, 0, 0x0000, 0, 0), + MX8MP_PAD_ENET_TD1__AUDIOMIX_SAI6_RX_SYNC = IOMUX_PAD(0x02C4, 0x0064, 2, 0x0520, 0, 0), + MX8MP_PAD_ENET_TD1__GPIO1_IO20 = IOMUX_PAD(0x02C4, 0x0064, 5, 0x0000, 0, 0), + MX8MP_PAD_ENET_TD1__USDHC3_CD_B = IOMUX_PAD(0x02C4, 0x0064, 6, 0x0608, 1, 0), + MX8MP_PAD_ENET_TD1__SIM_M_HADDR19 = IOMUX_PAD(0x02C4, 0x0064, 7, 0x0000, 0, 0), + + MX8MP_PAD_ENET_TD0__ENET_QOS_RGMII_TD0 = IOMUX_PAD(0x02C8, 0x0068, 0, 0x0000, 0, 0), + MX8MP_PAD_ENET_TD0__AUDIOMIX_SAI6_RX_BCLK = IOMUX_PAD(0x02C8, 0x0068, 2, 0x0518, 0, 0), + MX8MP_PAD_ENET_TD0__GPIO1_IO21 = IOMUX_PAD(0x02C8, 0x0068, 5, 0x0000, 0, 0), + MX8MP_PAD_ENET_TD0__USDHC3_WP = IOMUX_PAD(0x02C8, 0x0068, 6, 0x0634, 1, 0), + MX8MP_PAD_ENET_TD0__SIM_M_HADDR20 = IOMUX_PAD(0x02C8, 0x0068, 7, 0x0000, 0, 0), + + MX8MP_PAD_ENET_TX_CTL__ENET_QOS_RGMII_TX_CTL = IOMUX_PAD(0x02CC, 0x006C, 0, 0x0000, 0, 0), + MX8MP_PAD_ENET_TX_CTL__AUDIOMIX_SAI6_MCLK = IOMUX_PAD(0x02CC, 0x006C, 2, 0x0514, 0, 0), + MX8MP_PAD_ENET_TX_CTL__AUDIOMIX_SPDIF_OUT = IOMUX_PAD(0x02CC, 0x006C, 3, 0x0000, 0, 0), + MX8MP_PAD_ENET_TX_CTL__GPIO1_IO22 = IOMUX_PAD(0x02CC, 0x006C, 5, 0x0000, 0, 0), + MX8MP_PAD_ENET_TX_CTL__USDHC3_DATA0 = IOMUX_PAD(0x02CC, 0x006C, 6, 0x0610, 0, 0), + MX8MP_PAD_ENET_TX_CTL__SIM_M_HADDR21 = IOMUX_PAD(0x02CC, 0x006C, 7, 0x0000, 0, 0), + + MX8MP_PAD_ENET_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK = IOMUX_PAD(0x02D0, 0x0070, 0, 0x0000, 0, 0), + MX8MP_PAD_ENET_TXC__ENET_QOS_TX_ER = IOMUX_PAD(0x02D0, 0x0070, 1, 0x0000, 0, 0), + MX8MP_PAD_ENET_TXC__AUDIOMIX_SAI7_TX_DATA00 = IOMUX_PAD(0x02D0, 0x0070, 2, 0x0000, 0, 0), + MX8MP_PAD_ENET_TXC__GPIO1_IO23 = IOMUX_PAD(0x02D0, 0x0070, 5, 0x0000, 0, 0), + MX8MP_PAD_ENET_TXC__USDHC3_DATA1 = IOMUX_PAD(0x02D0, 0x0070, 6, 0x0614, 0, 0), + MX8MP_PAD_ENET_TXC__SIM_M_HADDR22 = IOMUX_PAD(0x02D0, 0x0070, 7, 0x0000, 0, 0), + + MX8MP_PAD_ENET_RX_CTL__ENET_QOS_RGMII_RX_CTL = IOMUX_PAD(0x02D4, 0x0074, 0, 0x0000, 0, 0), + MX8MP_PAD_ENET_RX_CTL__AUDIOMIX_SAI7_TX_SYNC = IOMUX_PAD(0x02D4, 0x0074, 2, 0x0540, 0, 0), + MX8MP_PAD_ENET_RX_CTL__AUDIOMIX_BIT_STREAM03 = IOMUX_PAD(0x02D4, 0x0074, 3, 0x04CC, 0, 0), + MX8MP_PAD_ENET_RX_CTL__GPIO1_IO24 = IOMUX_PAD(0x02D4, 0x0074, 5, 0x0000, 0, 0), + MX8MP_PAD_ENET_RX_CTL__USDHC3_DATA2 = IOMUX_PAD(0x02D4, 0x0074, 6, 0x0618, 0, 0), + MX8MP_PAD_ENET_RX_CTL__SIM_M_HADDR23 = IOMUX_PAD(0x02D4, 0x0074, 7, 0x0000, 0, 0), + + MX8MP_PAD_ENET_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK = IOMUX_PAD(0x02D8, 0x0078, 0, 0x0000, 0, 0), + MX8MP_PAD_ENET_RXC__ENET_QOS_RX_ER = IOMUX_PAD(0x02D8, 0x0078, 1, 0x0000, 0, 0), + MX8MP_PAD_ENET_RXC__AUDIOMIX_SAI7_TX_BCLK = IOMUX_PAD(0x02D8, 0x0078, 2, 0x053C, 0, 0), + MX8MP_PAD_ENET_RXC__AUDIOMIX_BIT_STREAM02 = IOMUX_PAD(0x02D8, 0x0078, 3, 0x04C8, 0, 0), + MX8MP_PAD_ENET_RXC__GPIO1_IO25 = IOMUX_PAD(0x02D8, 0x0078, 5, 0x0000, 0, 0), + MX8MP_PAD_ENET_RXC__USDHC3_DATA3 = IOMUX_PAD(0x02D8, 0x0078, 6, 0x061C, 0, 0), + MX8MP_PAD_ENET_RXC__SIM_M_HADDR24 = IOMUX_PAD(0x02D8, 0x0078, 7, 0x0000, 0, 0), + + MX8MP_PAD_ENET_RD0__ENET_QOS_RGMII_RD0 = IOMUX_PAD(0x02DC, 0x007C, 0, 0x0000, 0, 0), + MX8MP_PAD_ENET_RD0__AUDIOMIX_SAI7_RX_DATA00 = IOMUX_PAD(0x02DC, 0x007C, 2, 0x0534, 0, 0), + MX8MP_PAD_ENET_RD0__AUDIOMIX_BIT_STREAM01 = IOMUX_PAD(0x02DC, 0x007C, 3, 0x04C4, 0, 0), + MX8MP_PAD_ENET_RD0__GPIO1_IO26 = IOMUX_PAD(0x02DC, 0x007C, 5, 0x0000, 0, 0), + MX8MP_PAD_ENET_RD0__USDHC3_DATA4 = IOMUX_PAD(0x02DC, 0x007C, 6, 0x0620, 0, 0), + MX8MP_PAD_ENET_RD0__SIM_M_HADDR25 = IOMUX_PAD(0x02DC, 0x007C, 7, 0x0000, 0, 0), + + MX8MP_PAD_ENET_RD1__ENET_QOS_RGMII_RD1 = IOMUX_PAD(0x02E0, 0x0080, 0, 0x0000, 0, 0), + MX8MP_PAD_ENET_RD1__AUDIOMIX_SAI7_RX_SYNC = IOMUX_PAD(0x02E0, 0x0080, 2, 0x0538, 0, 0), + MX8MP_PAD_ENET_RD1__AUDIOMIX_BIT_STREAM00 = IOMUX_PAD(0x02E0, 0x0080, 3, 0x04C0, 0, 0), + MX8MP_PAD_ENET_RD1__GPIO1_IO27 = IOMUX_PAD(0x02E0, 0x0080, 5, 0x0000, 0, 0), + MX8MP_PAD_ENET_RD1__USDHC3_RESET_B = IOMUX_PAD(0x02E0, 0x0080, 6, 0x0000, 0, 0), + MX8MP_PAD_ENET_RD1__SIM_M_HADDR26 = IOMUX_PAD(0x02E0, 0x0080, 7, 0x0000, 0, 0), + + MX8MP_PAD_ENET_RD2__ENET_QOS_RGMII_RD2 = IOMUX_PAD(0x02E4, 0x0084, 0, 0x0000, 0, 0), + MX8MP_PAD_ENET_RD2__AUDIOMIX_SAI7_RX_BCLK = IOMUX_PAD(0x02E4, 0x0084, 2, 0x0530, 0, 0), + MX8MP_PAD_ENET_RD2__AUDIOMIX_CLK = IOMUX_PAD(0x02E4, 0x0084, 3, 0x0000, 0, 0), + MX8MP_PAD_ENET_RD2__GPIO1_IO28 = IOMUX_PAD(0x02E4, 0x0084, 5, 0x0000, 0, 0), + MX8MP_PAD_ENET_RD2__USDHC3_CLK = IOMUX_PAD(0x02E4, 0x0084, 6, 0x0604, 0, 0), + MX8MP_PAD_ENET_RD2__SIM_M_HADDR27 = IOMUX_PAD(0x02E4, 0x0084, 7, 0x0000, 0, 0), + + MX8MP_PAD_ENET_RD3__ENET_QOS_RGMII_RD3 = IOMUX_PAD(0x02E8, 0x0088, 0, 0x0000, 0, 0), + MX8MP_PAD_ENET_RD3__AUDIOMIX_SAI7_MCLK = IOMUX_PAD(0x02E8, 0x0088, 2, 0x052C, 0, 0), + MX8MP_PAD_ENET_RD3__AUDIOMIX_SPDIF_IN = IOMUX_PAD(0x02E8, 0x0088, 3, 0x0544, 0, 0), + MX8MP_PAD_ENET_RD3__GPIO1_IO29 = IOMUX_PAD(0x02E8, 0x0088, 5, 0x0000, 0, 0), + MX8MP_PAD_ENET_RD3__USDHC3_CMD = IOMUX_PAD(0x02E8, 0x0088, 6, 0x060C, 0, 0), + MX8MP_PAD_ENET_RD3__SIM_M_HADDR28 = IOMUX_PAD(0x02E8, 0x0088, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD1_CLK__USDHC1_CLK = IOMUX_PAD(0x02EC, 0x008C, 0, 0x0000, 0, 0), + MX8MP_PAD_SD1_CLK__ENET1_MDC = IOMUX_PAD(0x02EC, 0x008C, 1, 0x0000, 0, 0), + MX8MP_PAD_SD1_CLK__I2C5_SCL = IOMUX_PAD(0x02EC, 0x008C, 3 | IOMUX_CONFIG_SION, 0x05C4, 0, 0), + MX8MP_PAD_SD1_CLK__UART1_DCE_TX = IOMUX_PAD(0x02EC, 0x008C, 4, 0x0000, 0, 0), + MX8MP_PAD_SD1_CLK__UART1_DTE_RX = IOMUX_PAD(0x02EC, 0x008C, 4, 0x05E8, 0, 0), + MX8MP_PAD_SD1_CLK__GPIO2_IO00 = IOMUX_PAD(0x02EC, 0x008C, 5, 0x0000, 0, 0), + MX8MP_PAD_SD1_CLK__SIM_M_HADDR29 = IOMUX_PAD(0x02EC, 0x008C, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD1_CMD__USDHC1_CMD = IOMUX_PAD(0x02F0, 0x0090, 0, 0x0000, 0, 0), + MX8MP_PAD_SD1_CMD__ENET1_MDIO = IOMUX_PAD(0x02F0, 0x0090, 1, 0x057C, 0, 0), + MX8MP_PAD_SD1_CMD__I2C5_SDA = IOMUX_PAD(0x02F0, 0x0090, 3 | IOMUX_CONFIG_SION, 0x05C8, 0, 0), + MX8MP_PAD_SD1_CMD__UART1_DCE_RX = IOMUX_PAD(0x02F0, 0x0090, 4, 0x05E8, 1, 0), + MX8MP_PAD_SD1_CMD__UART1_DTE_TX = IOMUX_PAD(0x02F0, 0x0090, 4, 0x0000, 0, 0), + MX8MP_PAD_SD1_CMD__GPIO2_IO01 = IOMUX_PAD(0x02F0, 0x0090, 5, 0x0000, 0, 0), + MX8MP_PAD_SD1_CMD__SIM_M_HADDR30 = IOMUX_PAD(0x02F0, 0x0090, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD1_DATA0__USDHC1_DATA0 = IOMUX_PAD(0x02F4, 0x0094, 0, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA0__ENET1_RGMII_TD1 = IOMUX_PAD(0x02F4, 0x0094, 1, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA0__I2C6_SCL = IOMUX_PAD(0x02F4, 0x0094, 3 | IOMUX_CONFIG_SION, 0x05CC, 0, 0), + MX8MP_PAD_SD1_DATA0__UART1_DCE_RTS = IOMUX_PAD(0x02F4, 0x0094, 4, 0x05E4, 0, 0), + MX8MP_PAD_SD1_DATA0__UART1_DTE_CTS = IOMUX_PAD(0x02F4, 0x0094, 4, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA0__GPIO2_IO02 = IOMUX_PAD(0x02F4, 0x0094, 5, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA0__SIM_M_HADDR31 = IOMUX_PAD(0x02F4, 0x0094, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD1_DATA1__USDHC1_DATA1 = IOMUX_PAD(0x02F8, 0x0098, 0, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA1__ENET1_RGMII_TD0 = IOMUX_PAD(0x02F8, 0x0098, 1, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA1__I2C6_SDA = IOMUX_PAD(0x02F8, 0x0098, 3 | IOMUX_CONFIG_SION, 0x05D0, 0, 0), + MX8MP_PAD_SD1_DATA1__UART1_DCE_CTS = IOMUX_PAD(0x02F8, 0x0098, 4, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA1__UART1_DTE_RTS = IOMUX_PAD(0x02F8, 0x0098, 4, 0x05E4, 1, 0), + MX8MP_PAD_SD1_DATA1__GPIO2_IO03 = IOMUX_PAD(0x02F8, 0x0098, 5, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA1__SIM_M_HBURST00 = IOMUX_PAD(0x02F8, 0x0098, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD1_DATA2__USDHC1_DATA2 = IOMUX_PAD(0x02FC, 0x009C, 0, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA2__ENET1_RGMII_RD0 = IOMUX_PAD(0x02FC, 0x009C, 1, 0x0580, 0, 0), + MX8MP_PAD_SD1_DATA2__I2C4_SCL = IOMUX_PAD(0x02FC, 0x009C, 3 | IOMUX_CONFIG_SION, 0x05BC, 0, 0), + MX8MP_PAD_SD1_DATA2__UART2_DCE_TX = IOMUX_PAD(0x02FC, 0x009C, 4, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA2__UART2_DTE_RX = IOMUX_PAD(0x02FC, 0x009C, 4, 0x05F0, 0, 0), + MX8MP_PAD_SD1_DATA2__GPIO2_IO04 = IOMUX_PAD(0x02FC, 0x009C, 5, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA2__SIM_M_HBURST01 = IOMUX_PAD(0x02FC, 0x009C, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD1_DATA3__USDHC1_DATA3 = IOMUX_PAD(0x0300, 0x00A0, 0, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA3__ENET1_RGMII_RD1 = IOMUX_PAD(0x0300, 0x00A0, 1, 0x0584, 0, 0), + MX8MP_PAD_SD1_DATA3__I2C4_SDA = IOMUX_PAD(0x0300, 0x00A0, 3 | IOMUX_CONFIG_SION, 0x05C0, 0, 0), + MX8MP_PAD_SD1_DATA3__UART2_DCE_RX = IOMUX_PAD(0x0300, 0x00A0, 4, 0x05F0, 1, 0), + MX8MP_PAD_SD1_DATA3__UART2_DTE_TX = IOMUX_PAD(0x0300, 0x00A0, 4, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA3__GPIO2_IO05 = IOMUX_PAD(0x0300, 0x00A0, 5, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA3__SIM_M_HBURST02 = IOMUX_PAD(0x0300, 0x00A0, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD1_DATA4__USDHC1_DATA4 = IOMUX_PAD(0x0304, 0x00A4, 0, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA4__ENET1_RGMII_TX_CTL = IOMUX_PAD(0x0304, 0x00A4, 1, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA4__I2C1_SCL = IOMUX_PAD(0x0304, 0x00A4, 3 | IOMUX_CONFIG_SION, 0x05A4, 0, 0), + MX8MP_PAD_SD1_DATA4__UART2_DCE_RTS = IOMUX_PAD(0x0304, 0x00A4, 4, 0x05EC, 0, 0), + MX8MP_PAD_SD1_DATA4__UART2_DTE_CTS = IOMUX_PAD(0x0304, 0x00A4, 4, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA4__GPIO2_IO06 = IOMUX_PAD(0x0304, 0x00A4, 5, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA4__SIM_M_HRESP = IOMUX_PAD(0x0304, 0x00A4, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD1_DATA5__USDHC1_DATA5 = IOMUX_PAD(0x0308, 0x00A8, 0, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA5__ENET1_TX_ER = IOMUX_PAD(0x0308, 0x00A8, 1, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA5__I2C1_SDA = IOMUX_PAD(0x0308, 0x00A8, 3 | IOMUX_CONFIG_SION, 0x05A8, 0, 0), + MX8MP_PAD_SD1_DATA5__UART2_DCE_CTS = IOMUX_PAD(0x0308, 0x00A8, 4, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA5__UART2_DTE_RTS = IOMUX_PAD(0x0308, 0x00A8, 4, 0x05EC, 1, 0), + MX8MP_PAD_SD1_DATA5__GPIO2_IO07 = IOMUX_PAD(0x0308, 0x00A8, 5, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA5__TPSMP_HDATA05 = IOMUX_PAD(0x0308, 0x00A8, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD1_DATA6__USDHC1_DATA6 = IOMUX_PAD(0x030C, 0x00AC, 0, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA6__ENET1_RGMII_RX_CTL = IOMUX_PAD(0x030C, 0x00AC, 1, 0x0588, 0, 0), + MX8MP_PAD_SD1_DATA6__I2C2_SCL = IOMUX_PAD(0x030C, 0x00AC, 3 | IOMUX_CONFIG_SION, 0x05AC, 0, 0), + MX8MP_PAD_SD1_DATA6__UART3_DCE_TX = IOMUX_PAD(0x030C, 0x00AC, 4, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA6__UART3_DTE_RX = IOMUX_PAD(0x030C, 0x00AC, 4, 0x05F8, 0, 0), + MX8MP_PAD_SD1_DATA6__GPIO2_IO08 = IOMUX_PAD(0x030C, 0x00AC, 5, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA6__TPSMP_HDATA06 = IOMUX_PAD(0x030C, 0x00AC, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD1_DATA7__USDHC1_DATA7 = IOMUX_PAD(0x0310, 0x00B0, 0, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA7__ENET1_RX_ER = IOMUX_PAD(0x0310, 0x00B0, 1, 0x058C, 0, 0), + MX8MP_PAD_SD1_DATA7__I2C2_SDA = IOMUX_PAD(0x0310, 0x00B0, 3 | IOMUX_CONFIG_SION, 0x05B0, 0, 0), + MX8MP_PAD_SD1_DATA7__UART3_DCE_RX = IOMUX_PAD(0x0310, 0x00B0, 4, 0x05F8, 1, 0), + MX8MP_PAD_SD1_DATA7__UART3_DTE_TX = IOMUX_PAD(0x0310, 0x00B0, 4, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA7__GPIO2_IO09 = IOMUX_PAD(0x0310, 0x00B0, 5, 0x0000, 0, 0), + MX8MP_PAD_SD1_DATA7__TPSMP_HDATA07 = IOMUX_PAD(0x0310, 0x00B0, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD1_RESET_B__USDHC1_RESET_B = IOMUX_PAD(0x0314, 0x00B4, 0, 0x0000, 0, 0), + MX8MP_PAD_SD1_RESET_B__ENET1_TX_CLK = IOMUX_PAD(0x0314, 0x00B4, 1, 0x0578, 0, 0), + MX8MP_PAD_SD1_RESET_B__I2C3_SCL = IOMUX_PAD(0x0314, 0x00B4, 3 | IOMUX_CONFIG_SION, 0x05B4, 0, 0), + MX8MP_PAD_SD1_RESET_B__UART3_DCE_RTS = IOMUX_PAD(0x0314, 0x00B4, 4, 0x05F4, 0, 0), + MX8MP_PAD_SD1_RESET_B__UART3_DTE_CTS = IOMUX_PAD(0x0314, 0x00B4, 4, 0x0000, 0, 0), + MX8MP_PAD_SD1_RESET_B__GPIO2_IO10 = IOMUX_PAD(0x0314, 0x00B4, 5, 0x0000, 0, 0), + MX8MP_PAD_SD1_RESET_B__ECSPI3_TEST_TRIG = IOMUX_PAD(0x0314, 0x00B4, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD1_STROBE__USDHC1_STROBE = IOMUX_PAD(0x0318, 0x00B8, 0, 0x0000, 0, 0), + MX8MP_PAD_SD1_STROBE__I2C3_SDA = IOMUX_PAD(0x0318, 0x00B8, 3 | IOMUX_CONFIG_SION, 0x05B8, 0, 0), + MX8MP_PAD_SD1_STROBE__UART3_DCE_CTS = IOMUX_PAD(0x0318, 0x00B8, 4, 0x0000, 0, 0), + MX8MP_PAD_SD1_STROBE__UART3_DTE_RTS = IOMUX_PAD(0x0318, 0x00B8, 4, 0x05F4, 1, 0), + MX8MP_PAD_SD1_STROBE__GPIO2_IO11 = IOMUX_PAD(0x0318, 0x00B8, 5, 0x0000, 0, 0), + MX8MP_PAD_SD1_STROBE__USDHC3_TEST_TRIG = IOMUX_PAD(0x0318, 0x00B8, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD2_CD_B__USDHC2_CD_B = IOMUX_PAD(0x031C, 0x00BC, 0, 0x0000, 0, 0), + MX8MP_PAD_SD2_CD_B__GPIO2_IO12 = IOMUX_PAD(0x031C, 0x00BC, 5, 0x0000, 0, 0), + MX8MP_PAD_SD2_CD_B__CCMSRCGPCMIX_TESTER_ACK = IOMUX_PAD(0x031C, 0x00BC, 6, 0x0000, 0, 0), + + MX8MP_PAD_SD2_CLK__USDHC2_CLK = IOMUX_PAD(0x0320, 0x00C0, 0, 0x0000, 0, 0), + MX8MP_PAD_SD2_CLK__ECSPI2_SCLK = IOMUX_PAD(0x0320, 0x00C0, 2, 0x0568, 0, 0), + MX8MP_PAD_SD2_CLK__UART4_DCE_RX = IOMUX_PAD(0x0320, 0x00C0, 3, 0x0600, 0, 0), + MX8MP_PAD_SD2_CLK__UART4_DTE_TX = IOMUX_PAD(0x0320, 0x00C0, 3, 0x0000, 0, 0), + MX8MP_PAD_SD2_CLK__GPIO2_IO13 = IOMUX_PAD(0x0320, 0x00C0, 5, 0x0000, 0, 0), + MX8MP_PAD_SD2_CLK__CCMSRCGPCMIX_OBSERVE0 = IOMUX_PAD(0x0320, 0x00C0, 6, 0x0000, 0, 0), + MX8MP_PAD_SD2_CLK__OBSERVE_MUX_OUT00 = IOMUX_PAD(0x0320, 0x00C0, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD2_CMD__USDHC2_CMD = IOMUX_PAD(0x0324, 0x00C4, 0, 0x0000, 0, 0), + MX8MP_PAD_SD2_CMD__ECSPI2_MOSI = IOMUX_PAD(0x0324, 0x00C4, 2, 0x0570, 0, 0), + MX8MP_PAD_SD2_CMD__UART4_DCE_TX = IOMUX_PAD(0x0324, 0x00C4, 3, 0x0000, 0, 0), + MX8MP_PAD_SD2_CMD__UART4_DTE_RX = IOMUX_PAD(0x0324, 0x00C4, 3, 0x0600, 1, 0), + MX8MP_PAD_SD2_CMD__AUDIOMIX_CLK = IOMUX_PAD(0x0324, 0x00C4, 4, 0x0000, 0, 0), + MX8MP_PAD_SD2_CMD__GPIO2_IO14 = IOMUX_PAD(0x0324, 0x00C4, 5, 0x0000, 0, 0), + MX8MP_PAD_SD2_CMD__CCMSRCGPCMIX_OBSERVE1 = IOMUX_PAD(0x0324, 0x00C4, 6, 0x0000, 0, 0), + MX8MP_PAD_SD2_CMD__OBSERVE_MUX_OUT01 = IOMUX_PAD(0x0324, 0x00C4, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD2_DATA0__USDHC2_DATA0 = IOMUX_PAD(0x0328, 0x00C8, 0, 0x0000, 0, 0), + MX8MP_PAD_SD2_DATA0__I2C4_SDA = IOMUX_PAD(0x0328, 0x00C8, 2 | IOMUX_CONFIG_SION, 0x05C0, 1, 0), + MX8MP_PAD_SD2_DATA0__UART2_DCE_RX = IOMUX_PAD(0x0328, 0x00C8, 3, 0x05F0, 2, 0), + MX8MP_PAD_SD2_DATA0__UART2_DTE_TX = IOMUX_PAD(0x0328, 0x00C8, 3, 0x0000, 0, 0), + MX8MP_PAD_SD2_DATA0__AUDIOMIX_BIT_STREAM00 = IOMUX_PAD(0x0328, 0x00C8, 4, 0x04C0, 1, 0), + MX8MP_PAD_SD2_DATA0__GPIO2_IO15 = IOMUX_PAD(0x0328, 0x00C8, 5, 0x0000, 0, 0), + MX8MP_PAD_SD2_DATA0__CCMSRCGPCMIX_OBSERVE2 = IOMUX_PAD(0x0328, 0x00C8, 6, 0x0000, 0, 0), + MX8MP_PAD_SD2_DATA0__OBSERVE_MUX_OUT02 = IOMUX_PAD(0x0328, 0x00C8, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD2_DATA1__USDHC2_DATA1 = IOMUX_PAD(0x032C, 0x00CC, 0, 0x0000, 0, 0), + MX8MP_PAD_SD2_DATA1__I2C4_SCL = IOMUX_PAD(0x032C, 0x00CC, 2 | IOMUX_CONFIG_SION, 0x05BC, 1, 0), + MX8MP_PAD_SD2_DATA1__UART2_DCE_TX = IOMUX_PAD(0x032C, 0x00CC, 3, 0x0000, 0, 0), + MX8MP_PAD_SD2_DATA1__UART2_DTE_RX = IOMUX_PAD(0x032C, 0x00CC, 3, 0x05F0, 3, 0), + MX8MP_PAD_SD2_DATA1__AUDIOMIX_BIT_STREAM01 = IOMUX_PAD(0x032C, 0x00CC, 4, 0x04C4, 1, 0), + MX8MP_PAD_SD2_DATA1__GPIO2_IO16 = IOMUX_PAD(0x032C, 0x00CC, 5, 0x0000, 0, 0), + MX8MP_PAD_SD2_DATA1__CCMSRCGPCMIX_WAIT = IOMUX_PAD(0x032C, 0x00CC, 6, 0x0000, 0, 0), + MX8MP_PAD_SD2_DATA1__OBSERVE_MUX_OUT03 = IOMUX_PAD(0x032C, 0x00CC, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD2_DATA2__USDHC2_DATA2 = IOMUX_PAD(0x0330, 0x00D0, 0, 0x0000, 0, 0), + MX8MP_PAD_SD2_DATA2__ECSPI2_SS0 = IOMUX_PAD(0x0330, 0x00D0, 2, 0x0574, 0, 0), + MX8MP_PAD_SD2_DATA2__AUDIOMIX_SPDIF_OUT = IOMUX_PAD(0x0330, 0x00D0, 3, 0x0000, 0, 0), + MX8MP_PAD_SD2_DATA2__AUDIOMIX_BIT_STREAM02 = IOMUX_PAD(0x0330, 0x00D0, 4, 0x04C8, 1, 0), + MX8MP_PAD_SD2_DATA2__GPIO2_IO17 = IOMUX_PAD(0x0330, 0x00D0, 5, 0x0000, 0, 0), + MX8MP_PAD_SD2_DATA2__CCMSRCGPCMIX_STOP = IOMUX_PAD(0x0330, 0x00D0, 6, 0x0000, 0, 0), + MX8MP_PAD_SD2_DATA2__OBSERVE_MUX_OUT04 = IOMUX_PAD(0x0330, 0x00D0, 7, 0x0000, 0, 0), + + MX8MP_PAD_SD2_DATA3__USDHC2_DATA3 = IOMUX_PAD(0x0334, 0x00D4, 0, 0x0000, 0, 0), + MX8MP_PAD_SD2_DATA3__ECSPI2_MISO = IOMUX_PAD(0x0334, 0x00D4, 2, 0x056C, 0, 0), + MX8MP_PAD_SD2_DATA3__AUDIOMIX_SPDIF_IN = IOMUX_PAD(0x0334, 0x00D4, 3, 0x0544, 1, 0), + MX8MP_PAD_SD2_DATA3__AUDIOMIX_BIT_STREAM03 = IOMUX_PAD(0x0334, 0x00D4, 4, 0x04CC, 1, 0), + MX8MP_PAD_SD2_DATA3__GPIO2_IO18 = IOMUX_PAD(0x0334, 0x00D4, 5, 0x0000, 0, 0), + MX8MP_PAD_SD2_DATA3__CCMSRCGPCMIX_EARLY_RESET = IOMUX_PAD(0x0334, 0x00D4, 6, 0x0000, 0, 0), + + MX8MP_PAD_SD2_RESET_B__USDHC2_RESET_B = IOMUX_PAD(0x0338, 0x00D8, 0, 0x0000, 0, 0), + MX8MP_PAD_SD2_RESET_B__GPIO2_IO19 = IOMUX_PAD(0x0338, 0x00D8, 5, 0x0000, 0, 0), + MX8MP_PAD_SD2_RESET_B__CCMSRCGPCMIX_SYSTEM_RESET = IOMUX_PAD(0x0338, 0x00D8, 6, 0x0000, 0, 0), + + MX8MP_PAD_SD2_WP__USDHC2_WP = IOMUX_PAD(0x033C, 0x00DC, 0, 0x0000, 0, 0), + MX8MP_PAD_SD2_WP__GPIO2_IO20 = IOMUX_PAD(0x033C, 0x00DC, 5, 0x0000, 0, 0), + MX8MP_PAD_SD2_WP__CORESIGHT_EVENTI = IOMUX_PAD(0x033C, 0x00DC, 6, 0x0000, 0, 0), + MX8MP_PAD_SD2_WP__SIM_M_HMASTLOCK = IOMUX_PAD(0x033C, 0x00DC, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_ALE__RAWNAND_ALE = IOMUX_PAD(0x0340, 0x00E0, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_ALE__FLEXSPI_A_SCLK = IOMUX_PAD(0x0340, 0x00E0, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_ALE__AUDIOMIX_SAI3_TX_BCLK = IOMUX_PAD(0x0340, 0x00E0, 2, 0x04E8, 0, 0), + MX8MP_PAD_NAND_ALE__MEDIAMIX_ISP_FL_TRIG_0 = IOMUX_PAD(0x0340, 0x00E0, 3, 0x05D4, 1, 0), + MX8MP_PAD_NAND_ALE__UART3_DCE_RX = IOMUX_PAD(0x0340, 0x00E0, 4, 0x05F8, 2, 0), + MX8MP_PAD_NAND_ALE__UART3_DTE_TX = IOMUX_PAD(0x0340, 0x00E0, 4, 0x0000, 0, 0), + MX8MP_PAD_NAND_ALE__GPIO3_IO00 = IOMUX_PAD(0x0340, 0x00E0, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_ALE__CORESIGHT_TRACE_CLK = IOMUX_PAD(0x0340, 0x00E0, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_ALE__SIM_M_HPROT00 = IOMUX_PAD(0x0340, 0x00E0, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_CE0_B__RAWNAND_CE0_B = IOMUX_PAD(0x0344, 0x00E4, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE0_B__FLEXSPI_A_SS0_B = IOMUX_PAD(0x0344, 0x00E4, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE0_B__AUDIOMIX_SAI3_TX_DATA00 = IOMUX_PAD(0x0344, 0x00E4, 2, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE0_B__MEDIAMIX_ISP_SHUTTER_TRIG_0 = IOMUX_PAD(0x0344, 0x00E4, 3, 0x05DC, 1, 0), + MX8MP_PAD_NAND_CE0_B__UART3_DCE_TX = IOMUX_PAD(0x0344, 0x00E4, 4, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE0_B__UART3_DTE_RX = IOMUX_PAD(0x0344, 0x00E4, 4, 0x05F8, 3, 0), + MX8MP_PAD_NAND_CE0_B__GPIO3_IO01 = IOMUX_PAD(0x0344, 0x00E4, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE0_B__CORESIGHT_TRACE_CTL = IOMUX_PAD(0x0344, 0x00E4, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE0_B__SIM_M_HPROT01 = IOMUX_PAD(0x0344, 0x00E4, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_CE1_B__RAWNAND_CE1_B = IOMUX_PAD(0x0348, 0x00E8, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE1_B__FLEXSPI_A_SS1_B = IOMUX_PAD(0x0348, 0x00E8, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE1_B__USDHC3_STROBE = IOMUX_PAD(0x0348, 0x00E8, 2, 0x0630, 1, 0), + MX8MP_PAD_NAND_CE1_B__I2C4_SCL = IOMUX_PAD(0x0348, 0x00E8, 4 | IOMUX_CONFIG_SION, 0x05BC, 2, 0), + MX8MP_PAD_NAND_CE1_B__GPIO3_IO02 = IOMUX_PAD(0x0348, 0x00E8, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE1_B__CORESIGHT_TRACE00 = IOMUX_PAD(0x0348, 0x00E8, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE1_B__SIM_M_HPROT02 = IOMUX_PAD(0x0348, 0x00E8, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_CE2_B__RAWNAND_CE2_B = IOMUX_PAD(0x034C, 0x00EC, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE2_B__FLEXSPI_B_SS0_B = IOMUX_PAD(0x034C, 0x00EC, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE2_B__USDHC3_DATA5 = IOMUX_PAD(0x034C, 0x00EC, 2, 0x0624, 1, 0), + MX8MP_PAD_NAND_CE2_B__I2C4_SDA = IOMUX_PAD(0x034C, 0x00EC, 4 | IOMUX_CONFIG_SION, 0x05C0, 2, 0), + MX8MP_PAD_NAND_CE2_B__GPIO3_IO03 = IOMUX_PAD(0x034C, 0x00EC, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE2_B__CORESIGHT_TRACE01 = IOMUX_PAD(0x034C, 0x00EC, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE2_B__SIM_M_HPROT03 = IOMUX_PAD(0x034C, 0x00EC, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_CE3_B__RAWNAND_CE3_B = IOMUX_PAD(0x0350, 0x00F0, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE3_B__FLEXSPI_B_SS1_B = IOMUX_PAD(0x0350, 0x00F0, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE3_B__USDHC3_DATA6 = IOMUX_PAD(0x0350, 0x00F0, 2, 0x0628, 1, 0), + MX8MP_PAD_NAND_CE3_B__I2C3_SDA = IOMUX_PAD(0x0350, 0x00F0, 4 | IOMUX_CONFIG_SION, 0x05B8, 1, 0), + MX8MP_PAD_NAND_CE3_B__GPIO3_IO04 = IOMUX_PAD(0x0350, 0x00F0, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE3_B__CORESIGHT_TRACE02 = IOMUX_PAD(0x0350, 0x00F0, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_CE3_B__SIM_M_HADDR00 = IOMUX_PAD(0x0350, 0x00F0, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_CLE__RAWNAND_CLE = IOMUX_PAD(0x0354, 0x00F4, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_CLE__FLEXSPI_B_SCLK = IOMUX_PAD(0x0354, 0x00F4, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_CLE__USDHC3_DATA7 = IOMUX_PAD(0x0354, 0x00F4, 2, 0x062C, 1, 0), + MX8MP_PAD_NAND_CLE__UART4_DCE_RX = IOMUX_PAD(0x0354, 0x00F4, 4, 0x0600, 2, 0), + MX8MP_PAD_NAND_CLE__UART4_DTE_TX = IOMUX_PAD(0x0354, 0x00F4, 4, 0x0000, 0, 0), + MX8MP_PAD_NAND_CLE__GPIO3_IO05 = IOMUX_PAD(0x0354, 0x00F4, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_CLE__CORESIGHT_TRACE03 = IOMUX_PAD(0x0354, 0x00F4, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_CLE__SIM_M_HADDR01 = IOMUX_PAD(0x0354, 0x00F4, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_DATA00__RAWNAND_DATA00 = IOMUX_PAD(0x0358, 0x00F8, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA00__FLEXSPI_A_DATA00 = IOMUX_PAD(0x0358, 0x00F8, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA00__AUDIOMIX_SAI3_RX_DATA00 = IOMUX_PAD(0x0358, 0x00F8, 2, 0x04E4, 0, 0), + MX8MP_PAD_NAND_DATA00__MEDIAMIX_ISP_FLASH_TRIG_0 = IOMUX_PAD(0x0358, 0x00F8, 3, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA00__UART4_DCE_RX = IOMUX_PAD(0x0358, 0x00F8, 4, 0x0600, 3, 0), + MX8MP_PAD_NAND_DATA00__UART4_DTE_TX = IOMUX_PAD(0x0358, 0x00F8, 4, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA00__GPIO3_IO06 = IOMUX_PAD(0x0358, 0x00F8, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA00__CORESIGHT_TRACE04 = IOMUX_PAD(0x0358, 0x00F8, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA00__SIM_M_HADDR02 = IOMUX_PAD(0x0358, 0x00F8, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_DATA01__RAWNAND_DATA01 = IOMUX_PAD(0x035C, 0x00FC, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA01__FLEXSPI_A_DATA01 = IOMUX_PAD(0x035C, 0x00FC, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA01__AUDIOMIX_SAI3_TX_SYNC = IOMUX_PAD(0x035C, 0x00FC, 2, 0x04EC, 0, 0), + MX8MP_PAD_NAND_DATA01__MEDIAMIX_ISP_PRELIGHT_TRIG_0 = IOMUX_PAD(0x035C, 0x00FC, 3, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA01__UART4_DCE_TX = IOMUX_PAD(0x035C, 0x00FC, 4, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA01__UART4_DTE_RX = IOMUX_PAD(0x035C, 0x00FC, 4, 0x0600, 4, 0), + MX8MP_PAD_NAND_DATA01__GPIO3_IO07 = IOMUX_PAD(0x035C, 0x00FC, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA01__CORESIGHT_TRACE05 = IOMUX_PAD(0x035C, 0x00FC, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA01__SIM_M_HADDR03 = IOMUX_PAD(0x035C, 0x00FC, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_DATA02__RAWNAND_DATA02 = IOMUX_PAD(0x0360, 0x0100, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA02__FLEXSPI_A_DATA02 = IOMUX_PAD(0x0360, 0x0100, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA02__USDHC3_CD_B = IOMUX_PAD(0x0360, 0x0100, 2, 0x0608, 2, 0), + MX8MP_PAD_NAND_DATA02__UART4_DCE_CTS = IOMUX_PAD(0x0360, 0x0100, 3, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA02__UART4_DTE_RTS = IOMUX_PAD(0x0360, 0x0100, 3, 0x05FC, 0, 0), + MX8MP_PAD_NAND_DATA02__I2C4_SDA = IOMUX_PAD(0x0360, 0x0100, 4 | IOMUX_CONFIG_SION, 0x05C0, 3, 0), + MX8MP_PAD_NAND_DATA02__GPIO3_IO08 = IOMUX_PAD(0x0360, 0x0100, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA02__CORESIGHT_TRACE06 = IOMUX_PAD(0x0360, 0x0100, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA02__SIM_M_HADDR04 = IOMUX_PAD(0x0360, 0x0100, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_DATA03__RAWNAND_DATA03 = IOMUX_PAD(0x0364, 0x0104, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA03__FLEXSPI_A_DATA03 = IOMUX_PAD(0x0364, 0x0104, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA03__USDHC3_WP = IOMUX_PAD(0x0364, 0x0104, 2, 0x0634, 2, 0), + MX8MP_PAD_NAND_DATA03__UART4_DCE_RTS = IOMUX_PAD(0x0364, 0x0104, 3, 0x05FC, 1, 0), + MX8MP_PAD_NAND_DATA03__UART4_DTE_CTS = IOMUX_PAD(0x0364, 0x0104, 3, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA03__MEDIAMIX_ISP_FL_TRIG_1 = IOMUX_PAD(0x0364, 0x0104, 4, 0x05D8, 1, 0), + MX8MP_PAD_NAND_DATA03__GPIO3_IO09 = IOMUX_PAD(0x0364, 0x0104, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA03__CORESIGHT_TRACE07 = IOMUX_PAD(0x0364, 0x0104, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA03__SIM_M_HADDR05 = IOMUX_PAD(0x0364, 0x0104, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_DATA04__RAWNAND_DATA04 = IOMUX_PAD(0x0368, 0x0108, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA04__FLEXSPI_B_DATA00 = IOMUX_PAD(0x0368, 0x0108, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA04__USDHC3_DATA0 = IOMUX_PAD(0x0368, 0x0108, 2, 0x0610, 1, 0), + MX8MP_PAD_NAND_DATA04__FLEXSPI_A_DATA04 = IOMUX_PAD(0x0368, 0x0108, 3, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA04__MEDIAMIX_ISP_SHUTTER_TRIG_1 = IOMUX_PAD(0x0368, 0x0108, 4, 0x05E0, 1, 0), + MX8MP_PAD_NAND_DATA04__GPIO3_IO10 = IOMUX_PAD(0x0368, 0x0108, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA04__CORESIGHT_TRACE08 = IOMUX_PAD(0x0368, 0x0108, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA04__SIM_M_HADDR06 = IOMUX_PAD(0x0368, 0x0108, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_DATA05__RAWNAND_DATA05 = IOMUX_PAD(0x036C, 0x010C, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA05__FLEXSPI_B_DATA01 = IOMUX_PAD(0x036C, 0x010C, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA05__USDHC3_DATA1 = IOMUX_PAD(0x036C, 0x010C, 2, 0x0614, 1, 0), + MX8MP_PAD_NAND_DATA05__FLEXSPI_A_DATA05 = IOMUX_PAD(0x036C, 0x010C, 3, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA05__MEDIAMIX_ISP_FLASH_TRIG_1 = IOMUX_PAD(0x036C, 0x010C, 4, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA05__GPIO3_IO11 = IOMUX_PAD(0x036C, 0x010C, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA05__CORESIGHT_TRACE09 = IOMUX_PAD(0x036C, 0x010C, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA05__SIM_M_HADDR07 = IOMUX_PAD(0x036C, 0x010C, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_DATA06__RAWNAND_DATA06 = IOMUX_PAD(0x0370, 0x0110, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA06__FLEXSPI_B_DATA02 = IOMUX_PAD(0x0370, 0x0110, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA06__USDHC3_DATA2 = IOMUX_PAD(0x0370, 0x0110, 2, 0x0618, 1, 0), + MX8MP_PAD_NAND_DATA06__FLEXSPI_A_DATA06 = IOMUX_PAD(0x0370, 0x0110, 3, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA06__MEDIAMIX_ISP_PRELIGHT_TRIG_1 = IOMUX_PAD(0x0370, 0x0110, 4, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA06__GPIO3_IO12 = IOMUX_PAD(0x0370, 0x0110, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA06__CORESIGHT_TRACE10 = IOMUX_PAD(0x0370, 0x0110, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA06__SIM_M_HADDR08 = IOMUX_PAD(0x0370, 0x0110, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_DATA07__RAWNAND_DATA07 = IOMUX_PAD(0x0374, 0x0114, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA07__FLEXSPI_B_DATA03 = IOMUX_PAD(0x0374, 0x0114, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA07__USDHC3_DATA3 = IOMUX_PAD(0x0374, 0x0114, 2, 0x061C, 1, 0), + MX8MP_PAD_NAND_DATA07__FLEXSPI_A_DATA07 = IOMUX_PAD(0x0374, 0x0114, 3, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA07__MEDIAMIX_ISP_SHUTTER_OPEN_1 = IOMUX_PAD(0x0374, 0x0114, 4, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA07__GPIO3_IO13 = IOMUX_PAD(0x0374, 0x0114, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA07__CORESIGHT_TRACE11 = IOMUX_PAD(0x0374, 0x0114, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_DATA07__SIM_M_HADDR09 = IOMUX_PAD(0x0374, 0x0114, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_DQS__RAWNAND_DQS = IOMUX_PAD(0x0378, 0x0118, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_DQS__FLEXSPI_A_DQS = IOMUX_PAD(0x0378, 0x0118, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_DQS__AUDIOMIX_SAI3_MCLK = IOMUX_PAD(0x0378, 0x0118, 2, 0x04E0, 0, 0), + MX8MP_PAD_NAND_DQS__MEDIAMIX_ISP_SHUTTER_OPEN_0 = IOMUX_PAD(0x0378, 0x0118, 3, 0x0000, 0, 0), + MX8MP_PAD_NAND_DQS__I2C3_SCL = IOMUX_PAD(0x0378, 0x0118, 4 | IOMUX_CONFIG_SION, 0x05B4, 1, 0), + MX8MP_PAD_NAND_DQS__GPIO3_IO14 = IOMUX_PAD(0x0378, 0x0118, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_DQS__CORESIGHT_TRACE12 = IOMUX_PAD(0x0378, 0x0118, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_DQS__SIM_M_HADDR10 = IOMUX_PAD(0x0378, 0x0118, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_RE_B__RAWNAND_RE_B = IOMUX_PAD(0x037C, 0x011C, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_RE_B__FLEXSPI_B_DQS = IOMUX_PAD(0x037C, 0x011C, 1, 0x0000, 0, 0), + MX8MP_PAD_NAND_RE_B__USDHC3_DATA4 = IOMUX_PAD(0x037C, 0x011C, 2, 0x0620, 1, 0), + MX8MP_PAD_NAND_RE_B__UART4_DCE_TX = IOMUX_PAD(0x037C, 0x011C, 4, 0x0000, 0, 0), + MX8MP_PAD_NAND_RE_B__UART4_DTE_RX = IOMUX_PAD(0x037C, 0x011C, 4, 0x0600, 5, 0), + MX8MP_PAD_NAND_RE_B__GPIO3_IO15 = IOMUX_PAD(0x037C, 0x011C, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_RE_B__CORESIGHT_TRACE13 = IOMUX_PAD(0x037C, 0x011C, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_RE_B__SIM_M_HADDR11 = IOMUX_PAD(0x037C, 0x011C, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_READY_B__RAWNAND_READY_B = IOMUX_PAD(0x0380, 0x0120, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_READY_B__USDHC3_RESET_B = IOMUX_PAD(0x0380, 0x0120, 2, 0x0000, 0, 0), + MX8MP_PAD_NAND_READY_B__I2C3_SCL = IOMUX_PAD(0x0380, 0x0120, 4 | IOMUX_CONFIG_SION, 0x05B4, 2, 0), + MX8MP_PAD_NAND_READY_B__GPIO3_IO16 = IOMUX_PAD(0x0380, 0x0120, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_READY_B__CORESIGHT_TRACE14 = IOMUX_PAD(0x0380, 0x0120, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_READY_B__SIM_M_HADDR12 = IOMUX_PAD(0x0380, 0x0120, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_WE_B__RAWNAND_WE_B = IOMUX_PAD(0x0384, 0x0124, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_WE_B__USDHC3_CLK = IOMUX_PAD(0x0384, 0x0124, 2, 0x0604, 1, 0), + MX8MP_PAD_NAND_WE_B__I2C3_SDA = IOMUX_PAD(0x0384, 0x0124, 4 | IOMUX_CONFIG_SION, 0x05B8, 2, 0), + MX8MP_PAD_NAND_WE_B__GPIO3_IO17 = IOMUX_PAD(0x0384, 0x0124, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_WE_B__CORESIGHT_TRACE15 = IOMUX_PAD(0x0384, 0x0124, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_WE_B__SIM_M_HADDR13 = IOMUX_PAD(0x0384, 0x0124, 7, 0x0000, 0, 0), + + MX8MP_PAD_NAND_WP_B__RAWNAND_WP_B = IOMUX_PAD(0x0388, 0x0128, 0, 0x0000, 0, 0), + MX8MP_PAD_NAND_WP_B__USDHC3_CMD = IOMUX_PAD(0x0388, 0x0128, 2, 0x060C, 1, 0), + MX8MP_PAD_NAND_WP_B__I2C4_SCL = IOMUX_PAD(0x0388, 0x0128, 4 | IOMUX_CONFIG_SION, 0x05BC, 3, 0), + MX8MP_PAD_NAND_WP_B__GPIO3_IO18 = IOMUX_PAD(0x0388, 0x0128, 5, 0x0000, 0, 0), + MX8MP_PAD_NAND_WP_B__CORESIGHT_EVENTO = IOMUX_PAD(0x0388, 0x0128, 6, 0x0000, 0, 0), + MX8MP_PAD_NAND_WP_B__SIM_M_HADDR14 = IOMUX_PAD(0x0388, 0x0128, 7, 0x0000, 0, 0), + + MX8MP_PAD_SAI5_RXFS__AUDIOMIX_SAI5_RX_SYNC = IOMUX_PAD(0x038C, 0x012C, 0, 0x0508, 0, 0), + MX8MP_PAD_SAI5_RXFS__AUDIOMIX_SAI1_TX_DATA00 = IOMUX_PAD(0x038C, 0x012C, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI5_RXFS__PWM4_OUT = IOMUX_PAD(0x038C, 0x012C, 2, 0x0000, 0, 0), + MX8MP_PAD_SAI5_RXFS__I2C6_SCL = IOMUX_PAD(0x038C, 0x012C, 3 | IOMUX_CONFIG_SION, 0x05CC, 1, 0), + MX8MP_PAD_SAI5_RXFS__GPIO3_IO19 = IOMUX_PAD(0x038C, 0x012C, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI5_RXC__AUDIOMIX_SAI5_RX_BCLK = IOMUX_PAD(0x0390, 0x0130, 0, 0x04F4, 0, 0), + MX8MP_PAD_SAI5_RXC__AUDIOMIX_SAI1_TX_DATA01 = IOMUX_PAD(0x0390, 0x0130, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI5_RXC__PWM3_OUT = IOMUX_PAD(0x0390, 0x0130, 2, 0x0000, 0, 0), + MX8MP_PAD_SAI5_RXC__I2C6_SDA = IOMUX_PAD(0x0390, 0x0130, 3 | IOMUX_CONFIG_SION, 0x05D0, 1, 0), + MX8MP_PAD_SAI5_RXC__AUDIOMIX_CLK = IOMUX_PAD(0x0390, 0x0130, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI5_RXC__GPIO3_IO20 = IOMUX_PAD(0x0390, 0x0130, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI5_RXD0__AUDIOMIX_SAI5_RX_DATA00 = IOMUX_PAD(0x0394, 0x0134, 0, 0x04F8, 0, 0), + MX8MP_PAD_SAI5_RXD0__AUDIOMIX_SAI1_TX_DATA02 = IOMUX_PAD(0x0394, 0x0134, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI5_RXD0__PWM2_OUT = IOMUX_PAD(0x0394, 0x0134, 2, 0x0000, 0, 0), + MX8MP_PAD_SAI5_RXD0__I2C5_SCL = IOMUX_PAD(0x0394, 0x0134, 3 | IOMUX_CONFIG_SION, 0x05C4, 1, 0), + MX8MP_PAD_SAI5_RXD0__AUDIOMIX_BIT_STREAM00 = IOMUX_PAD(0x0394, 0x0134, 4, 0x04C0, 2, 0), + MX8MP_PAD_SAI5_RXD0__GPIO3_IO21 = IOMUX_PAD(0x0394, 0x0134, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI5_RXD1__AUDIOMIX_SAI5_RX_DATA01 = IOMUX_PAD(0x0398, 0x0138, 0, 0x04FC, 0, 0), + MX8MP_PAD_SAI5_RXD1__AUDIOMIX_SAI1_TX_DATA03 = IOMUX_PAD(0x0398, 0x0138, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI5_RXD1__AUDIOMIX_SAI1_TX_SYNC = IOMUX_PAD(0x0398, 0x0138, 2, 0x04D8, 0, 0), + MX8MP_PAD_SAI5_RXD1__AUDIOMIX_SAI5_TX_SYNC = IOMUX_PAD(0x0398, 0x0138, 3, 0x0510, 0, 0), + MX8MP_PAD_SAI5_RXD1__AUDIOMIX_BIT_STREAM01 = IOMUX_PAD(0x0398, 0x0138, 4, 0x04C4, 2, 0), + MX8MP_PAD_SAI5_RXD1__GPIO3_IO22 = IOMUX_PAD(0x0398, 0x0138, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI5_RXD1__CAN1_TX = IOMUX_PAD(0x0398, 0x0138, 6, 0x0000, 0, 0), + + MX8MP_PAD_SAI5_RXD2__AUDIOMIX_SAI5_RX_DATA02 = IOMUX_PAD(0x039C, 0x013C, 0, 0x0500, 0, 0), + MX8MP_PAD_SAI5_RXD2__AUDIOMIX_SAI1_TX_DATA04 = IOMUX_PAD(0x039C, 0x013C, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI5_RXD2__AUDIOMIX_SAI1_TX_SYNC = IOMUX_PAD(0x039C, 0x013C, 2, 0x04D8, 1, 0), + MX8MP_PAD_SAI5_RXD2__AUDIOMIX_SAI5_TX_BCLK = IOMUX_PAD(0x039C, 0x013C, 3, 0x050C, 0, 0), + MX8MP_PAD_SAI5_RXD2__AUDIOMIX_BIT_STREAM02 = IOMUX_PAD(0x039C, 0x013C, 4, 0x04C8, 2, 0), + MX8MP_PAD_SAI5_RXD2__GPIO3_IO23 = IOMUX_PAD(0x039C, 0x013C, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI5_RXD2__CAN1_RX = IOMUX_PAD(0x039C, 0x013C, 6, 0x054C, 0, 0), + + MX8MP_PAD_SAI5_RXD3__AUDIOMIX_SAI5_RX_DATA03 = IOMUX_PAD(0x03A0, 0x0140, 0, 0x0504, 0, 0), + MX8MP_PAD_SAI5_RXD3__AUDIOMIX_SAI1_TX_DATA05 = IOMUX_PAD(0x03A0, 0x0140, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI5_RXD3__AUDIOMIX_SAI1_TX_SYNC = IOMUX_PAD(0x03A0, 0x0140, 2, 0x04D8, 2, 0), + MX8MP_PAD_SAI5_RXD3__AUDIOMIX_SAI5_TX_DATA00 = IOMUX_PAD(0x03A0, 0x0140, 3, 0x0000, 0, 0), + MX8MP_PAD_SAI5_RXD3__AUDIOMIX_BIT_STREAM03 = IOMUX_PAD(0x03A0, 0x0140, 4, 0x04CC, 2, 0), + MX8MP_PAD_SAI5_RXD3__GPIO3_IO24 = IOMUX_PAD(0x03A0, 0x0140, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI5_RXD3__CAN2_TX = IOMUX_PAD(0x03A0, 0x0140, 6, 0x0000, 0, 0), + + MX8MP_PAD_SAI5_MCLK__AUDIOMIX_SAI5_MCLK = IOMUX_PAD(0x03A4, 0x0144, 0, 0x04F0, 0, 0), + MX8MP_PAD_SAI5_MCLK__AUDIOMIX_SAI1_TX_BCLK = IOMUX_PAD(0x03A4, 0x0144, 1, 0x04D4, 0, 0), + MX8MP_PAD_SAI5_MCLK__PWM1_OUT = IOMUX_PAD(0x03A4, 0x0144, 2, 0x0000, 0, 0), + MX8MP_PAD_SAI5_MCLK__I2C5_SDA = IOMUX_PAD(0x03A4, 0x0144, 3 | IOMUX_CONFIG_SION, 0x05C8, 1, 0), + MX8MP_PAD_SAI5_MCLK__GPIO3_IO25 = IOMUX_PAD(0x03A4, 0x0144, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI5_MCLK__CAN2_RX = IOMUX_PAD(0x03A4, 0x0144, 6, 0x0550, 0, 0), + + MX8MP_PAD_SAI1_RXFS__AUDIOMIX_SAI1_RX_SYNC = IOMUX_PAD(0x03A8, 0x0148, 0, 0x04D0, 0, 0), + MX8MP_PAD_SAI1_RXFS__AUDIOMIX_SAI5_RX_SYNC = IOMUX_PAD(0x03A8, 0x0148, 1, 0x0508, 1, 0), + MX8MP_PAD_SAI1_RXFS__ENET1_1588_EVENT0_IN = IOMUX_PAD(0x03A8, 0x0148, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXFS__GPIO4_IO00 = IOMUX_PAD(0x03A8, 0x0148, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_RXC__AUDIOMIX_SAI1_RX_BCLK = IOMUX_PAD(0x03AC, 0x014C, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXC__AUDIOMIX_SAI5_RX_BCLK = IOMUX_PAD(0x03AC, 0x014C, 1, 0x04F4, 1, 0), + MX8MP_PAD_SAI1_RXC__AUDIOMIX_CLK = IOMUX_PAD(0x03AC, 0x014C, 3, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXC__ENET1_1588_EVENT0_OUT = IOMUX_PAD(0x03AC, 0x014C, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXC__GPIO4_IO01 = IOMUX_PAD(0x03AC, 0x014C, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_RXD0__AUDIOMIX_SAI1_RX_DATA00 = IOMUX_PAD(0x03B0, 0x0150, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD0__AUDIOMIX_SAI5_RX_DATA00 = IOMUX_PAD(0x03B0, 0x0150, 1, 0x04F8, 1, 0), + MX8MP_PAD_SAI1_RXD0__AUDIOMIX_SAI1_TX_DATA01 = IOMUX_PAD(0x03B0, 0x0150, 2, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD0__AUDIOMIX_BIT_STREAM00 = IOMUX_PAD(0x03B0, 0x0150, 3, 0x04C0, 3, 0), + MX8MP_PAD_SAI1_RXD0__ENET1_1588_EVENT1_IN = IOMUX_PAD(0x03B0, 0x0150, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD0__GPIO4_IO02 = IOMUX_PAD(0x03B0, 0x0150, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_RXD1__AUDIOMIX_SAI1_RX_DATA01 = IOMUX_PAD(0x03B4, 0x0154, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD1__AUDIOMIX_SAI5_RX_DATA01 = IOMUX_PAD(0x03B4, 0x0154, 1, 0x04FC, 1, 0), + MX8MP_PAD_SAI1_RXD1__AUDIOMIX_BIT_STREAM01 = IOMUX_PAD(0x03B4, 0x0154, 3, 0x04C4, 3, 0), + MX8MP_PAD_SAI1_RXD1__ENET1_1588_EVENT1_OUT = IOMUX_PAD(0x03B4, 0x0154, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD1__GPIO4_IO03 = IOMUX_PAD(0x03B4, 0x0154, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_RXD2__AUDIOMIX_SAI1_RX_DATA02 = IOMUX_PAD(0x03B8, 0x0158, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD2__AUDIOMIX_SAI5_RX_DATA02 = IOMUX_PAD(0x03B8, 0x0158, 1, 0x0500, 1, 0), + MX8MP_PAD_SAI1_RXD2__AUDIOMIX_BIT_STREAM02 = IOMUX_PAD(0x03B8, 0x0158, 3, 0x04C8, 3, 0), + MX8MP_PAD_SAI1_RXD2__ENET1_MDC = IOMUX_PAD(0x03B8, 0x0158, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD2__GPIO4_IO04 = IOMUX_PAD(0x03B8, 0x0158, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_RXD3__AUDIOMIX_SAI1_RX_DATA03 = IOMUX_PAD(0x03BC, 0x015C, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD3__AUDIOMIX_SAI5_RX_DATA03 = IOMUX_PAD(0x03BC, 0x015C, 1, 0x0504, 1, 0), + MX8MP_PAD_SAI1_RXD3__AUDIOMIX_BIT_STREAM03 = IOMUX_PAD(0x03BC, 0x015C, 3, 0x04CC, 3, 0), + MX8MP_PAD_SAI1_RXD3__ENET1_MDIO = IOMUX_PAD(0x03BC, 0x015C, 4, 0x057C, 1, 0), + MX8MP_PAD_SAI1_RXD3__GPIO4_IO05 = IOMUX_PAD(0x03BC, 0x015C, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_RXD4__AUDIOMIX_SAI1_RX_DATA04 = IOMUX_PAD(0x03C0, 0x0160, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD4__AUDIOMIX_SAI6_TX_BCLK = IOMUX_PAD(0x03C0, 0x0160, 1, 0x0524, 1, 0), + MX8MP_PAD_SAI1_RXD4__AUDIOMIX_SAI6_RX_BCLK = IOMUX_PAD(0x03C0, 0x0160, 2, 0x0518, 1, 0), + MX8MP_PAD_SAI1_RXD4__ENET1_RGMII_RD0 = IOMUX_PAD(0x03C0, 0x0160, 4, 0x0580, 1, 0), + MX8MP_PAD_SAI1_RXD4__GPIO4_IO06 = IOMUX_PAD(0x03C0, 0x0160, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_RXD5__AUDIOMIX_SAI1_RX_DATA05 = IOMUX_PAD(0x03C4, 0x0164, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD5__AUDIOMIX_SAI6_TX_DATA00 = IOMUX_PAD(0x03C4, 0x0164, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD5__AUDIOMIX_SAI6_RX_DATA00 = IOMUX_PAD(0x03C4, 0x0164, 2, 0x051C, 1, 0), + MX8MP_PAD_SAI1_RXD5__AUDIOMIX_SAI1_RX_SYNC = IOMUX_PAD(0x03C4, 0x0164, 3, 0x04D0, 1, 0), + MX8MP_PAD_SAI1_RXD5__ENET1_RGMII_RD1 = IOMUX_PAD(0x03C4, 0x0164, 4, 0x0584, 1, 0), + MX8MP_PAD_SAI1_RXD5__GPIO4_IO07 = IOMUX_PAD(0x03C4, 0x0164, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_RXD6__AUDIOMIX_SAI1_RX_DATA06 = IOMUX_PAD(0x03C8, 0x0168, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD6__AUDIOMIX_SAI6_TX_SYNC = IOMUX_PAD(0x03C8, 0x0168, 1, 0x0528, 1, 0), + MX8MP_PAD_SAI1_RXD6__AUDIOMIX_SAI6_RX_SYNC = IOMUX_PAD(0x03C8, 0x0168, 2, 0x0520, 1, 0), + MX8MP_PAD_SAI1_RXD6__ENET1_RGMII_RD2 = IOMUX_PAD(0x03C8, 0x0168, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD6__GPIO4_IO08 = IOMUX_PAD(0x03C8, 0x0168, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_RXD7__AUDIOMIX_SAI1_RX_DATA07 = IOMUX_PAD(0x03CC, 0x016C, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD7__AUDIOMIX_SAI6_MCLK = IOMUX_PAD(0x03CC, 0x016C, 1, 0x0514, 1, 0), + MX8MP_PAD_SAI1_RXD7__AUDIOMIX_SAI1_TX_SYNC = IOMUX_PAD(0x03CC, 0x016C, 2, 0x04D8, 3, 0), + MX8MP_PAD_SAI1_RXD7__AUDIOMIX_SAI1_TX_DATA04 = IOMUX_PAD(0x03CC, 0x016C, 3, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD7__ENET1_RGMII_RD3 = IOMUX_PAD(0x03CC, 0x016C, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI1_RXD7__GPIO4_IO09 = IOMUX_PAD(0x03CC, 0x016C, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_TXFS__AUDIOMIX_SAI1_TX_SYNC = IOMUX_PAD(0x03D0, 0x0170, 0, 0x04D8, 4, 0), + MX8MP_PAD_SAI1_TXFS__AUDIOMIX_SAI5_TX_SYNC = IOMUX_PAD(0x03D0, 0x0170, 1, 0x0510, 1, 0), + MX8MP_PAD_SAI1_TXFS__ENET1_RGMII_RX_CTL = IOMUX_PAD(0x03D0, 0x0170, 4, 0x0588, 1, 0), + MX8MP_PAD_SAI1_TXFS__GPIO4_IO10 = IOMUX_PAD(0x03D0, 0x0170, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_TXC__AUDIOMIX_SAI1_TX_BCLK = IOMUX_PAD(0x03D4, 0x0174, 0, 0x04D4, 1, 0), + MX8MP_PAD_SAI1_TXC__AUDIOMIX_SAI5_TX_BCLK = IOMUX_PAD(0x03D4, 0x0174, 1, 0x050C, 1, 0), + MX8MP_PAD_SAI1_TXC__ENET1_RGMII_RXC = IOMUX_PAD(0x03D4, 0x0174, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXC__GPIO4_IO11 = IOMUX_PAD(0x03D4, 0x0174, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_TXD0__AUDIOMIX_SAI1_TX_DATA00 = IOMUX_PAD(0x03D8, 0x0178, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD0__AUDIOMIX_SAI5_TX_DATA00 = IOMUX_PAD(0x03D8, 0x0178, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD0__ENET1_RGMII_TD0 = IOMUX_PAD(0x03D8, 0x0178, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD0__GPIO4_IO12 = IOMUX_PAD(0x03D8, 0x0178, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_TXD1__AUDIOMIX_SAI1_TX_DATA01 = IOMUX_PAD(0x03DC, 0x017C, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD1__AUDIOMIX_SAI5_TX_DATA01 = IOMUX_PAD(0x03DC, 0x017C, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD1__ENET1_RGMII_TD1 = IOMUX_PAD(0x03DC, 0x017C, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD1__GPIO4_IO13 = IOMUX_PAD(0x03DC, 0x017C, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_TXD2__AUDIOMIX_SAI1_TX_DATA02 = IOMUX_PAD(0x03E0, 0x0180, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD2__AUDIOMIX_SAI5_TX_DATA02 = IOMUX_PAD(0x03E0, 0x0180, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD2__ENET1_RGMII_TD2 = IOMUX_PAD(0x03E0, 0x0180, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD2__GPIO4_IO14 = IOMUX_PAD(0x03E0, 0x0180, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_TXD3__AUDIOMIX_SAI1_TX_DATA03 = IOMUX_PAD(0x03E4, 0x0184, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD3__AUDIOMIX_SAI5_TX_DATA03 = IOMUX_PAD(0x03E4, 0x0184, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD3__ENET1_RGMII_TD3 = IOMUX_PAD(0x03E4, 0x0184, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD3__GPIO4_IO15 = IOMUX_PAD(0x03E4, 0x0184, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_TXD4__AUDIOMIX_SAI1_TX_DATA04 = IOMUX_PAD(0x03E8, 0x0188, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD4__AUDIOMIX_SAI6_RX_BCLK = IOMUX_PAD(0x03E8, 0x0188, 1, 0x0518, 2, 0), + MX8MP_PAD_SAI1_TXD4__AUDIOMIX_SAI6_TX_BCLK = IOMUX_PAD(0x03E8, 0x0188, 2, 0x0524, 2, 0), + MX8MP_PAD_SAI1_TXD4__ENET1_RGMII_TX_CTL = IOMUX_PAD(0x03E8, 0x0188, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD4__GPIO4_IO16 = IOMUX_PAD(0x03E8, 0x0188, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_TXD5__AUDIOMIX_SAI1_TX_DATA05 = IOMUX_PAD(0x03EC, 0x018C, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD5__AUDIOMIX_SAI6_RX_DATA00 = IOMUX_PAD(0x03EC, 0x018C, 1, 0x051C, 2, 0), + MX8MP_PAD_SAI1_TXD5__AUDIOMIX_SAI6_TX_DATA00 = IOMUX_PAD(0x03EC, 0x018C, 2, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD5__ENET1_RGMII_TXC = IOMUX_PAD(0x03EC, 0x018C, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD5__GPIO4_IO17 = IOMUX_PAD(0x03EC, 0x018C, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_TXD6__AUDIOMIX_SAI1_TX_DATA06 = IOMUX_PAD(0x03F0, 0x0190, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD6__AUDIOMIX_SAI6_RX_SYNC = IOMUX_PAD(0x03F0, 0x0190, 1, 0x0520, 2, 0), + MX8MP_PAD_SAI1_TXD6__AUDIOMIX_SAI6_TX_SYNC = IOMUX_PAD(0x03F0, 0x0190, 2, 0x0528, 2, 0), + MX8MP_PAD_SAI1_TXD6__ENET1_RX_ER = IOMUX_PAD(0x03F0, 0x0190, 4, 0x058C, 1, 0), + MX8MP_PAD_SAI1_TXD6__GPIO4_IO18 = IOMUX_PAD(0x03F0, 0x0190, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_TXD7__AUDIOMIX_SAI1_TX_DATA07 = IOMUX_PAD(0x03F4, 0x0194, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD7__AUDIOMIX_SAI6_MCLK = IOMUX_PAD(0x03F4, 0x0194, 1, 0x0514, 2, 0), + MX8MP_PAD_SAI1_TXD7__AUDIOMIX_CLK = IOMUX_PAD(0x03F4, 0x0194, 3, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD7__ENET1_TX_ER = IOMUX_PAD(0x03F4, 0x0194, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI1_TXD7__GPIO4_IO19 = IOMUX_PAD(0x03F4, 0x0194, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI1_MCLK__AUDIOMIX_SAI1_MCLK = IOMUX_PAD(0x03F8, 0x0198, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI1_MCLK__AUDIOMIX_SAI5_MCLK = IOMUX_PAD(0x03F8, 0x0198, 1, 0x04F0, 1, 0), + MX8MP_PAD_SAI1_MCLK__AUDIOMIX_SAI1_TX_BCLK = IOMUX_PAD(0x03F8, 0x0198, 2, 0x04D4, 2, 0), + MX8MP_PAD_SAI1_MCLK__ENET1_TX_CLK = IOMUX_PAD(0x03F8, 0x0198, 4, 0x0578, 1, 0), + MX8MP_PAD_SAI1_MCLK__GPIO4_IO20 = IOMUX_PAD(0x03F8, 0x0198, 5, 0x0000, 0, 0), + + MX8MP_PAD_SAI2_RXFS__AUDIOMIX_SAI2_RX_SYNC = IOMUX_PAD(0x03FC, 0x019C, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI2_RXFS__AUDIOMIX_SAI5_TX_SYNC = IOMUX_PAD(0x03FC, 0x019C, 1, 0x0510, 2, 0), + MX8MP_PAD_SAI2_RXFS__AUDIOMIX_SAI5_TX_DATA01 = IOMUX_PAD(0x03FC, 0x019C, 2, 0x0000, 0, 0), + MX8MP_PAD_SAI2_RXFS__AUDIOMIX_SAI2_RX_DATA01 = IOMUX_PAD(0x03FC, 0x019C, 3, 0x04DC, 0, 0), + MX8MP_PAD_SAI2_RXFS__UART1_DCE_TX = IOMUX_PAD(0x03FC, 0x019C, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI2_RXFS__UART1_DTE_RX = IOMUX_PAD(0x03FC, 0x019C, 4, 0x05E8, 2, 0), + MX8MP_PAD_SAI2_RXFS__GPIO4_IO21 = IOMUX_PAD(0x03FC, 0x019C, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI2_RXFS__AUDIOMIX_BIT_STREAM02 = IOMUX_PAD(0x03FC, 0x019C, 6, 0x04C8, 4, 0), + MX8MP_PAD_SAI2_RXFS__SIM_M_HSIZE00 = IOMUX_PAD(0x03FC, 0x019C, 7, 0x0000, 0, 0), + + MX8MP_PAD_SAI2_RXC__AUDIOMIX_SAI2_RX_BCLK = IOMUX_PAD(0x0400, 0x01A0, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI2_RXC__AUDIOMIX_SAI5_TX_BCLK = IOMUX_PAD(0x0400, 0x01A0, 1, 0x050C, 2, 0), + MX8MP_PAD_SAI2_RXC__CAN1_TX = IOMUX_PAD(0x0400, 0x01A0, 3, 0x0000, 0, 0), + MX8MP_PAD_SAI2_RXC__UART1_DCE_RX = IOMUX_PAD(0x0400, 0x01A0, 4, 0x05E8, 3, 0), + MX8MP_PAD_SAI2_RXC__UART1_DTE_TX = IOMUX_PAD(0x0400, 0x01A0, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI2_RXC__GPIO4_IO22 = IOMUX_PAD(0x0400, 0x01A0, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI2_RXC__AUDIOMIX_BIT_STREAM01 = IOMUX_PAD(0x0400, 0x01A0, 6, 0x04C4, 4, 0), + MX8MP_PAD_SAI2_RXC__SIM_M_HSIZE01 = IOMUX_PAD(0x0400, 0x01A0, 7, 0x0000, 0, 0), + + MX8MP_PAD_SAI2_RXD0__AUDIOMIX_SAI2_RX_DATA00 = IOMUX_PAD(0x0404, 0x01A4, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI2_RXD0__AUDIOMIX_SAI5_TX_DATA00 = IOMUX_PAD(0x0404, 0x01A4, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI2_RXD0__ENET_QOS_1588_EVENT2_OUT = IOMUX_PAD(0x0404, 0x01A4, 2, 0x0000, 0, 0), + MX8MP_PAD_SAI2_RXD0__AUDIOMIX_SAI2_TX_DATA01 = IOMUX_PAD(0x0404, 0x01A4, 3, 0x0000, 0, 0), + MX8MP_PAD_SAI2_RXD0__UART1_DCE_RTS = IOMUX_PAD(0x0404, 0x01A4, 4, 0x05E4, 2, 0), + MX8MP_PAD_SAI2_RXD0__UART1_DTE_CTS = IOMUX_PAD(0x0404, 0x01A4, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI2_RXD0__GPIO4_IO23 = IOMUX_PAD(0x0404, 0x01A4, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI2_RXD0__AUDIOMIX_BIT_STREAM03 = IOMUX_PAD(0x0404, 0x01A4, 6, 0x04CC, 4, 0), + MX8MP_PAD_SAI2_RXD0__SIM_M_HSIZE02 = IOMUX_PAD(0x0404, 0x01A4, 7, 0x0000, 0, 0), + + MX8MP_PAD_SAI2_TXFS__AUDIOMIX_SAI2_TX_SYNC = IOMUX_PAD(0x0408, 0x01A8, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXFS__AUDIOMIX_SAI5_TX_DATA01 = IOMUX_PAD(0x0408, 0x01A8, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXFS__ENET_QOS_1588_EVENT3_OUT = IOMUX_PAD(0x0408, 0x01A8, 2, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXFS__AUDIOMIX_SAI2_TX_DATA01 = IOMUX_PAD(0x0408, 0x01A8, 3, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXFS__UART1_DCE_CTS = IOMUX_PAD(0x0408, 0x01A8, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXFS__UART1_DTE_RTS = IOMUX_PAD(0x0408, 0x01A8, 4, 0x05E4, 3, 0), + MX8MP_PAD_SAI2_TXFS__GPIO4_IO24 = IOMUX_PAD(0x0408, 0x01A8, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXFS__AUDIOMIX_BIT_STREAM02 = IOMUX_PAD(0x0408, 0x01A8, 6, 0x04C8, 5, 0), + MX8MP_PAD_SAI2_TXFS__SIM_M_HWRITE = IOMUX_PAD(0x0408, 0x01A8, 7, 0x0000, 0, 0), + + MX8MP_PAD_SAI2_TXC__AUDIOMIX_SAI2_TX_BCLK = IOMUX_PAD(0x040C, 0x01AC, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXC__AUDIOMIX_SAI5_TX_DATA02 = IOMUX_PAD(0x040C, 0x01AC, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXC__CAN1_RX = IOMUX_PAD(0x040C, 0x01AC, 3, 0x054C, 1, 0), + MX8MP_PAD_SAI2_TXC__GPIO4_IO25 = IOMUX_PAD(0x040C, 0x01AC, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXC__AUDIOMIX_BIT_STREAM01 = IOMUX_PAD(0x040C, 0x01AC, 6, 0x04C4, 5, 0), + MX8MP_PAD_SAI2_TXC__SIM_M_HREADYOUT = IOMUX_PAD(0x040C, 0x01AC, 7, 0x0000, 0, 0), + + MX8MP_PAD_SAI2_TXD0__AUDIOMIX_SAI2_TX_DATA00 = IOMUX_PAD(0x0410, 0x01B0, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXD0__AUDIOMIX_SAI5_TX_DATA03 = IOMUX_PAD(0x0410, 0x01B0, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXD0__ENET_QOS_1588_EVENT2_IN = IOMUX_PAD(0x0410, 0x01B0, 2, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXD0__CAN2_TX = IOMUX_PAD(0x0410, 0x01B0, 3, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXD0__ENET_QOS_1588_EVENT2_AUX_IN = IOMUX_PAD(0x0410, 0x01B0, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXD0__GPIO4_IO26 = IOMUX_PAD(0x0410, 0x01B0, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXD0__CCMSRCGPCMIX_BOOT_MODE04 = IOMUX_PAD(0x0410, 0x01B0, 6, 0x0000, 0, 0), + MX8MP_PAD_SAI2_TXD0__TPSMP_CLK = IOMUX_PAD(0x0410, 0x01B0, 7, 0x0000, 0, 0), + + MX8MP_PAD_SAI2_MCLK__AUDIOMIX_SAI2_MCLK = IOMUX_PAD(0x0414, 0x01B4, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI2_MCLK__AUDIOMIX_SAI5_MCLK = IOMUX_PAD(0x0414, 0x01B4, 1, 0x04F0, 2, 0), + MX8MP_PAD_SAI2_MCLK__ENET_QOS_1588_EVENT3_IN = IOMUX_PAD(0x0414, 0x01B4, 2, 0x0000, 0, 0), + MX8MP_PAD_SAI2_MCLK__CAN2_RX = IOMUX_PAD(0x0414, 0x01B4, 3, 0x0550, 1, 0), + MX8MP_PAD_SAI2_MCLK__ENET_QOS_1588_EVENT3_AUX_IN = IOMUX_PAD(0x0414, 0x01B4, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI2_MCLK__GPIO4_IO27 = IOMUX_PAD(0x0414, 0x01B4, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI2_MCLK__AUDIOMIX_SAI3_MCLK = IOMUX_PAD(0x0414, 0x01B4, 6, 0x04E0, 1, 0), + MX8MP_PAD_SAI2_MCLK__TPSMP_HDATA_DIR = IOMUX_PAD(0x0414, 0x01B4, 7, 0x0000, 0, 0), + + MX8MP_PAD_SAI3_RXFS__AUDIOMIX_SAI3_RX_SYNC = IOMUX_PAD(0x0418, 0x01B8, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI3_RXFS__AUDIOMIX_SAI2_RX_DATA01 = IOMUX_PAD(0x0418, 0x01B8, 1, 0x04DC, 1, 0), + MX8MP_PAD_SAI3_RXFS__AUDIOMIX_SAI5_RX_SYNC = IOMUX_PAD(0x0418, 0x01B8, 2, 0x0508, 2, 0), + MX8MP_PAD_SAI3_RXFS__AUDIOMIX_SAI3_RX_DATA01 = IOMUX_PAD(0x0418, 0x01B8, 3, 0x0000, 0, 0), + MX8MP_PAD_SAI3_RXFS__AUDIOMIX_SPDIF_IN = IOMUX_PAD(0x0418, 0x01B8, 4, 0x0544, 2, 0), + MX8MP_PAD_SAI3_RXFS__GPIO4_IO28 = IOMUX_PAD(0x0418, 0x01B8, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI3_RXFS__AUDIOMIX_BIT_STREAM00 = IOMUX_PAD(0x0418, 0x01B8, 6, 0x04C0, 4, 0), + MX8MP_PAD_SAI3_RXFS__TPSMP_HTRANS00 = IOMUX_PAD(0x0418, 0x01B8, 7, 0x0000, 0, 0), + + MX8MP_PAD_SAI3_RXC__AUDIOMIX_SAI3_RX_BCLK = IOMUX_PAD(0x041C, 0x01BC, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI3_RXC__AUDIOMIX_SAI2_RX_DATA02 = IOMUX_PAD(0x041C, 0x01BC, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI3_RXC__AUDIOMIX_SAI5_RX_BCLK = IOMUX_PAD(0x041C, 0x01BC, 2, 0x04F4, 2, 0), + MX8MP_PAD_SAI3_RXC__GPT1_CLK = IOMUX_PAD(0x041C, 0x01BC, 3, 0x059C, 0, 0), + MX8MP_PAD_SAI3_RXC__UART2_DCE_CTS = IOMUX_PAD(0x041C, 0x01BC, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI3_RXC__UART2_DTE_RTS = IOMUX_PAD(0x041C, 0x01BC, 4, 0x05EC, 2, 0), + MX8MP_PAD_SAI3_RXC__GPIO4_IO29 = IOMUX_PAD(0x041C, 0x01BC, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI3_RXC__AUDIOMIX_CLK = IOMUX_PAD(0x041C, 0x01BC, 6, 0x0000, 0, 0), + MX8MP_PAD_SAI3_RXC__TPSMP_HTRANS01 = IOMUX_PAD(0x041C, 0x01BC, 7, 0x0000, 0, 0), + + MX8MP_PAD_SAI3_RXD__AUDIOMIX_SAI3_RX_DATA00 = IOMUX_PAD(0x0420, 0x01C0, 0, 0x04E4, 1, 0), + MX8MP_PAD_SAI3_RXD__AUDIOMIX_SAI2_RX_DATA03 = IOMUX_PAD(0x0420, 0x01C0, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI3_RXD__AUDIOMIX_SAI5_RX_DATA00 = IOMUX_PAD(0x0420, 0x01C0, 2, 0x04F8, 2, 0), + MX8MP_PAD_SAI3_RXD__UART2_DCE_RTS = IOMUX_PAD(0x0420, 0x01C0, 4, 0x05EC, 3, 0), + MX8MP_PAD_SAI3_RXD__UART2_DTE_CTS = IOMUX_PAD(0x0420, 0x01C0, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI3_RXD__GPIO4_IO30 = IOMUX_PAD(0x0420, 0x01C0, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI3_RXD__AUDIOMIX_BIT_STREAM01 = IOMUX_PAD(0x0420, 0x01C0, 6, 0x04C4, 6, 0), + MX8MP_PAD_SAI3_RXD__TPSMP_HDATA00 = IOMUX_PAD(0x0420, 0x01C0, 7, 0x0000, 0, 0), + + MX8MP_PAD_SAI3_TXFS__AUDIOMIX_SAI3_TX_SYNC = IOMUX_PAD(0x0424, 0x01C4, 0, 0x04EC, 1, 0), + MX8MP_PAD_SAI3_TXFS__AUDIOMIX_SAI2_TX_DATA01 = IOMUX_PAD(0x0424, 0x01C4, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI3_TXFS__AUDIOMIX_SAI5_RX_DATA01 = IOMUX_PAD(0x0424, 0x01C4, 2, 0x04FC, 2, 0), + MX8MP_PAD_SAI3_TXFS__AUDIOMIX_SAI3_TX_DATA01 = IOMUX_PAD(0x0424, 0x01C4, 3, 0x0000, 0, 0), + MX8MP_PAD_SAI3_TXFS__UART2_DCE_RX = IOMUX_PAD(0x0424, 0x01C4, 4, 0x05F0, 4, 0), + MX8MP_PAD_SAI3_TXFS__UART2_DTE_TX = IOMUX_PAD(0x0424, 0x01C4, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI3_TXFS__GPIO4_IO31 = IOMUX_PAD(0x0424, 0x01C4, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI3_TXFS__AUDIOMIX_BIT_STREAM03 = IOMUX_PAD(0x0424, 0x01C4, 6, 0x04CC, 5, 0), + MX8MP_PAD_SAI3_TXFS__TPSMP_HDATA01 = IOMUX_PAD(0x0424, 0x01C4, 7, 0x0000, 0, 0), + + MX8MP_PAD_SAI3_TXC__AUDIOMIX_SAI3_TX_BCLK = IOMUX_PAD(0x0428, 0x01C8, 0, 0x04E8, 1, 0), + MX8MP_PAD_SAI3_TXC__AUDIOMIX_SAI2_TX_DATA02 = IOMUX_PAD(0x0428, 0x01C8, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI3_TXC__AUDIOMIX_SAI5_RX_DATA02 = IOMUX_PAD(0x0428, 0x01C8, 2, 0x0500, 2, 0), + MX8MP_PAD_SAI3_TXC__GPT1_CAPTURE1 = IOMUX_PAD(0x0428, 0x01C8, 3, 0x0594, 0, 0), + MX8MP_PAD_SAI3_TXC__UART2_DCE_TX = IOMUX_PAD(0x0428, 0x01C8, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI3_TXC__UART2_DTE_RX = IOMUX_PAD(0x0428, 0x01C8, 4, 0x05F0, 5, 0), + MX8MP_PAD_SAI3_TXC__GPIO5_IO00 = IOMUX_PAD(0x0428, 0x01C8, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI3_TXC__AUDIOMIX_BIT_STREAM02 = IOMUX_PAD(0x0428, 0x01C8, 6, 0x04C8, 6, 0), + MX8MP_PAD_SAI3_TXC__TPSMP_HDATA02 = IOMUX_PAD(0x0428, 0x01C8, 7, 0x0000, 0, 0), + + MX8MP_PAD_SAI3_TXD__AUDIOMIX_SAI3_TX_DATA00 = IOMUX_PAD(0x042C, 0x01CC, 0, 0x0000, 0, 0), + MX8MP_PAD_SAI3_TXD__AUDIOMIX_SAI2_TX_DATA03 = IOMUX_PAD(0x042C, 0x01CC, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI3_TXD__AUDIOMIX_SAI5_RX_DATA03 = IOMUX_PAD(0x042C, 0x01CC, 2, 0x0504, 2, 0), + MX8MP_PAD_SAI3_TXD__GPT1_CAPTURE2 = IOMUX_PAD(0x042C, 0x01CC, 3, 0x0598, 0, 0), + MX8MP_PAD_SAI3_TXD__AUDIOMIX_SPDIF_EXT_CLK = IOMUX_PAD(0x042C, 0x01CC, 4, 0x0548, 0, 0), + MX8MP_PAD_SAI3_TXD__GPIO5_IO01 = IOMUX_PAD(0x042C, 0x01CC, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI3_TXD__CCMSRCGPCMIX_BOOT_MODE05 = IOMUX_PAD(0x042C, 0x01CC, 6, 0x0000, 0, 0), + MX8MP_PAD_SAI3_TXD__TPSMP_HDATA03 = IOMUX_PAD(0x042C, 0x01CC, 7, 0x0000, 0, 0), + + MX8MP_PAD_SAI3_MCLK__AUDIOMIX_SAI3_MCLK = IOMUX_PAD(0x0430, 0x01D0, 0, 0x04E0, 2, 0), + MX8MP_PAD_SAI3_MCLK__PWM4_OUT = IOMUX_PAD(0x0430, 0x01D0, 1, 0x0000, 0, 0), + MX8MP_PAD_SAI3_MCLK__AUDIOMIX_SAI5_MCLK = IOMUX_PAD(0x0430, 0x01D0, 2, 0x04F0, 3, 0), + MX8MP_PAD_SAI3_MCLK__AUDIOMIX_SPDIF_OUT = IOMUX_PAD(0x0430, 0x01D0, 4, 0x0000, 0, 0), + MX8MP_PAD_SAI3_MCLK__GPIO5_IO02 = IOMUX_PAD(0x0430, 0x01D0, 5, 0x0000, 0, 0), + MX8MP_PAD_SAI3_MCLK__AUDIOMIX_SPDIF_IN = IOMUX_PAD(0x0430, 0x01D0, 6, 0x0544, 3, 0), + MX8MP_PAD_SAI3_MCLK__TPSMP_HDATA04 = IOMUX_PAD(0x0430, 0x01D0, 7, 0x0000, 0, 0), + + MX8MP_PAD_SPDIF_TX__AUDIOMIX_SPDIF_OUT = IOMUX_PAD(0x0434, 0x01D4, 0, 0x0000, 0, 0), + MX8MP_PAD_SPDIF_TX__PWM3_OUT = IOMUX_PAD(0x0434, 0x01D4, 1, 0x0000, 0, 0), + MX8MP_PAD_SPDIF_TX__I2C5_SCL = IOMUX_PAD(0x0434, 0x01D4, 2 | IOMUX_CONFIG_SION, 0x05C4, 2, 0), + MX8MP_PAD_SPDIF_TX__GPT1_COMPARE1 = IOMUX_PAD(0x0434, 0x01D4, 3, 0x0000, 0, 0), + MX8MP_PAD_SPDIF_TX__CAN1_TX = IOMUX_PAD(0x0434, 0x01D4, 4, 0x0000, 0, 0), + MX8MP_PAD_SPDIF_TX__GPIO5_IO03 = IOMUX_PAD(0x0434, 0x01D4, 5, 0x0000, 0, 0), + + MX8MP_PAD_SPDIF_RX__AUDIOMIX_SPDIF_IN = IOMUX_PAD(0x0438, 0x01D8, 0, 0x0544, 4, 0), + MX8MP_PAD_SPDIF_RX__PWM2_OUT = IOMUX_PAD(0x0438, 0x01D8, 1, 0x0000, 0, 0), + MX8MP_PAD_SPDIF_RX__I2C5_SDA = IOMUX_PAD(0x0438, 0x01D8, 2 | IOMUX_CONFIG_SION, 0x05C8, 2, 0), + MX8MP_PAD_SPDIF_RX__GPT1_COMPARE2 = IOMUX_PAD(0x0438, 0x01D8, 3, 0x0000, 0, 0), + MX8MP_PAD_SPDIF_RX__CAN1_RX = IOMUX_PAD(0x0438, 0x01D8, 4, 0x054C, 2, 0), + MX8MP_PAD_SPDIF_RX__GPIO5_IO04 = IOMUX_PAD(0x0438, 0x01D8, 5, 0x0000, 0, 0), + MX8MP_PAD_SPDIF_EXT_CLK__GPT1_COMPARE3 = IOMUX_PAD(0x043C, 0x01DC, 3, 0x0000, 0, 0), + MX8MP_PAD_SPDIF_EXT_CLK__GPIO5_IO05 = IOMUX_PAD(0x043C, 0x01DC, 5, 0x0000, 0, 0), + + MX8MP_PAD_SPDIF_EXT_CLK__AUDIOMIX_SPDIF_EXT_CLK = IOMUX_PAD(0x043C, 0x01DC, 0, 0x0548, 1, 0), + MX8MP_PAD_SPDIF_EXT_CLK__PWM1_OUT = IOMUX_PAD(0x043C, 0x01DC, 1, 0x0000, 0, 0), + + MX8MP_PAD_ECSPI1_SCLK__ECSPI1_SCLK = IOMUX_PAD(0x0440, 0x01E0, 0, 0x0558, 0, 0), + MX8MP_PAD_ECSPI1_SCLK__UART3_DCE_RX = IOMUX_PAD(0x0440, 0x01E0, 1, 0x05F8, 4, 0), + MX8MP_PAD_ECSPI1_SCLK__UART3_DTE_TX = IOMUX_PAD(0x0440, 0x01E0, 1, 0x0000, 0, 0), + MX8MP_PAD_ECSPI1_SCLK__I2C1_SCL = IOMUX_PAD(0x0440, 0x01E0, 2 | IOMUX_CONFIG_SION, 0x05A4, 1, 0), + MX8MP_PAD_ECSPI1_SCLK__AUDIOMIX_SAI7_RX_SYNC = IOMUX_PAD(0x0440, 0x01E0, 3, 0x0538, 1, 0), + MX8MP_PAD_ECSPI1_SCLK__GPIO5_IO06 = IOMUX_PAD(0x0440, 0x01E0, 5, 0x0000, 0, 0), + MX8MP_PAD_ECSPI1_SCLK__TPSMP_HDATA08 = IOMUX_PAD(0x0440, 0x01E0, 7, 0x0000, 0, 0), + + MX8MP_PAD_ECSPI1_MOSI__ECSPI1_MOSI = IOMUX_PAD(0x0444, 0x01E4, 0, 0x0560, 0, 0), + MX8MP_PAD_ECSPI1_MOSI__UART3_DCE_TX = IOMUX_PAD(0x0444, 0x01E4, 1, 0x0000, 0, 0), + MX8MP_PAD_ECSPI1_MOSI__UART3_DTE_RX = IOMUX_PAD(0x0444, 0x01E4, 1, 0x05F8, 5, 0), + MX8MP_PAD_ECSPI1_MOSI__I2C1_SDA = IOMUX_PAD(0x0444, 0x01E4, 2 | IOMUX_CONFIG_SION, 0x05A8, 1, 0), + MX8MP_PAD_ECSPI1_MOSI__AUDIOMIX_SAI7_RX_BCLK = IOMUX_PAD(0x0444, 0x01E4, 3, 0x0530, 1, 0), + MX8MP_PAD_ECSPI1_MOSI__GPIO5_IO07 = IOMUX_PAD(0x0444, 0x01E4, 5, 0x0000, 0, 0), + MX8MP_PAD_ECSPI1_MOSI__TPSMP_HDATA09 = IOMUX_PAD(0x0444, 0x01E4, 7, 0x0000, 0, 0), + + MX8MP_PAD_ECSPI1_MISO__ECSPI1_MISO = IOMUX_PAD(0x0448, 0x01E8, 0, 0x055C, 0, 0), + MX8MP_PAD_ECSPI1_MISO__UART3_DCE_CTS = IOMUX_PAD(0x0448, 0x01E8, 1, 0x0000, 0, 0), + MX8MP_PAD_ECSPI1_MISO__UART3_DTE_RTS = IOMUX_PAD(0x0448, 0x01E8, 1, 0x05F4, 2, 0), + MX8MP_PAD_ECSPI1_MISO__I2C2_SCL = IOMUX_PAD(0x0448, 0x01E8, 2 | IOMUX_CONFIG_SION, 0x05AC, 1, 0), + MX8MP_PAD_ECSPI1_MISO__AUDIOMIX_SAI7_RX_DATA00 = IOMUX_PAD(0x0448, 0x01E8, 3, 0x0534, 1, 0), + MX8MP_PAD_ECSPI1_MISO__GPIO5_IO08 = IOMUX_PAD(0x0448, 0x01E8, 5, 0x0000, 0, 0), + MX8MP_PAD_ECSPI1_MISO__TPSMP_HDATA10 = IOMUX_PAD(0x0448, 0x01E8, 7, 0x0000, 0, 0), + + MX8MP_PAD_ECSPI1_SS0__ECSPI1_SS0 = IOMUX_PAD(0x044C, 0x01EC, 0, 0x0564, 0, 0), + MX8MP_PAD_ECSPI1_SS0__UART3_DCE_RTS = IOMUX_PAD(0x044C, 0x01EC, 1, 0x05F4, 3, 0), + MX8MP_PAD_ECSPI1_SS0__UART3_DTE_CTS = IOMUX_PAD(0x044C, 0x01EC, 1, 0x0000, 0, 0), + MX8MP_PAD_ECSPI1_SS0__I2C2_SDA = IOMUX_PAD(0x044C, 0x01EC, 2 | IOMUX_CONFIG_SION, 0x05B0, 1, 0), + MX8MP_PAD_ECSPI1_SS0__AUDIOMIX_SAI7_TX_SYNC = IOMUX_PAD(0x044C, 0x01EC, 3, 0x0540, 1, 0), + MX8MP_PAD_ECSPI1_SS0__GPIO5_IO09 = IOMUX_PAD(0x044C, 0x01EC, 5, 0x0000, 0, 0), + MX8MP_PAD_ECSPI1_SS0__TPSMP_HDATA11 = IOMUX_PAD(0x044C, 0x01EC, 7, 0x0000, 0, 0), + + MX8MP_PAD_ECSPI2_SCLK__ECSPI2_SCLK = IOMUX_PAD(0x0450, 0x01F0, 0, 0x0568, 1, 0), + MX8MP_PAD_ECSPI2_SCLK__UART4_DCE_RX = IOMUX_PAD(0x0450, 0x01F0, 1, 0x0600, 6, 0), + MX8MP_PAD_ECSPI2_SCLK__UART4_DTE_TX = IOMUX_PAD(0x0450, 0x01F0, 1, 0x0000, 0, 0), + MX8MP_PAD_ECSPI2_SCLK__I2C3_SCL = IOMUX_PAD(0x0450, 0x01F0, 2 | IOMUX_CONFIG_SION, 0x05B4, 3, 0), + MX8MP_PAD_ECSPI2_SCLK__AUDIOMIX_SAI7_TX_BCLK = IOMUX_PAD(0x0450, 0x01F0, 3, 0x053C, 1, 0), + MX8MP_PAD_ECSPI2_SCLK__GPIO5_IO10 = IOMUX_PAD(0x0450, 0x01F0, 5, 0x0000, 0, 0), + MX8MP_PAD_ECSPI2_SCLK__TPSMP_HDATA12 = IOMUX_PAD(0x0450, 0x01F0, 7, 0x0000, 0, 0), + + MX8MP_PAD_ECSPI2_MOSI__ECSPI2_MOSI = IOMUX_PAD(0x0454, 0x01F4, 0, 0x0570, 1, 0), + MX8MP_PAD_ECSPI2_MOSI__UART4_DCE_TX = IOMUX_PAD(0x0454, 0x01F4, 1, 0x0000, 0, 0), + MX8MP_PAD_ECSPI2_MOSI__UART4_DTE_RX = IOMUX_PAD(0x0454, 0x01F4, 1, 0x0600, 7, 0), + MX8MP_PAD_ECSPI2_MOSI__I2C3_SDA = IOMUX_PAD(0x0454, 0x01F4, 2 | IOMUX_CONFIG_SION, 0x05B8, 3, 0), + MX8MP_PAD_ECSPI2_MOSI__AUDIOMIX_SAI7_TX_DATA00 = IOMUX_PAD(0x0454, 0x01F4, 3, 0x0000, 0, 0), + MX8MP_PAD_ECSPI2_MOSI__GPIO5_IO11 = IOMUX_PAD(0x0454, 0x01F4, 5, 0x0000, 0, 0), + MX8MP_PAD_ECSPI2_MOSI__TPSMP_HDATA13 = IOMUX_PAD(0x0454, 0x01F4, 7, 0x0000, 0, 0), + MX8MP_PAD_ECSPI2_MISO__GPIO5_IO12 = IOMUX_PAD(0x0458, 0x01F8, 5, 0x0000, 0, 0), + MX8MP_PAD_ECSPI2_MISO__TPSMP_HDATA14 = IOMUX_PAD(0x0458, 0x01F8, 7, 0x0000, 0, 0), + + MX8MP_PAD_ECSPI2_MISO__ECSPI2_MISO = IOMUX_PAD(0x0458, 0x01F8, 0, 0x056C, 1, 0), + MX8MP_PAD_ECSPI2_MISO__UART4_DCE_CTS = IOMUX_PAD(0x0458, 0x01F8, 1, 0x0000, 0, 0), + MX8MP_PAD_ECSPI2_MISO__UART4_DTE_RTS = IOMUX_PAD(0x0458, 0x01F8, 1, 0x05FC, 2, 0), + MX8MP_PAD_ECSPI2_MISO__I2C4_SCL = IOMUX_PAD(0x0458, 0x01F8, 2 | IOMUX_CONFIG_SION, 0x05BC, 4, 0), + MX8MP_PAD_ECSPI2_MISO__AUDIOMIX_SAI7_MCLK = IOMUX_PAD(0x0458, 0x01F8, 3, 0x052C, 1, 0), + MX8MP_PAD_ECSPI2_MISO__CCMSRCGPCMIX_CLKO1 = IOMUX_PAD(0x0458, 0x01F8, 4, 0x0000, 0, 0), + + MX8MP_PAD_ECSPI2_SS0__ECSPI2_SS0 = IOMUX_PAD(0x045C, 0x01FC, 0, 0x0574, 1, 0), + MX8MP_PAD_ECSPI2_SS0__UART4_DCE_RTS = IOMUX_PAD(0x045C, 0x01FC, 1, 0x05FC, 3, 0), + MX8MP_PAD_ECSPI2_SS0__UART4_DTE_CTS = IOMUX_PAD(0x045C, 0x01FC, 1, 0x0000, 0, 0), + MX8MP_PAD_ECSPI2_SS0__I2C4_SDA = IOMUX_PAD(0x045C, 0x01FC, 2 | IOMUX_CONFIG_SION, 0x05C0, 4, 0), + MX8MP_PAD_ECSPI2_SS0__CCMSRCGPCMIX_CLKO2 = IOMUX_PAD(0x045C, 0x01FC, 4, 0x0000, 0, 0), + MX8MP_PAD_ECSPI2_SS0__GPIO5_IO13 = IOMUX_PAD(0x045C, 0x01FC, 5, 0x0000, 0, 0), + MX8MP_PAD_ECSPI2_SS0__TPSMP_HDATA15 = IOMUX_PAD(0x045C, 0x01FC, 7, 0x0000, 0, 0), + + MX8MP_PAD_I2C1_SCL__I2C1_SCL = IOMUX_PAD(0x0460, 0x0200, 0 | IOMUX_CONFIG_SION, 0x05A4, 2, 0), + MX8MP_PAD_I2C1_SCL__ENET_QOS_MDC = IOMUX_PAD(0x0460, 0x0200, 1, 0x0000, 0, 0), + MX8MP_PAD_I2C1_SCL__ECSPI1_SCLK = IOMUX_PAD(0x0460, 0x0200, 3, 0x0558, 1, 0), + MX8MP_PAD_I2C1_SCL__GPIO5_IO14 = IOMUX_PAD(0x0460, 0x0200, 5, 0x0000, 0, 0), + MX8MP_PAD_I2C1_SCL__TPSMP_HDATA16 = IOMUX_PAD(0x0460, 0x0200, 7, 0x0000, 0, 0), + + MX8MP_PAD_I2C1_SDA__I2C1_SDA = IOMUX_PAD(0x0464, 0x0204, 0 | IOMUX_CONFIG_SION, 0x05A8, 2, 0), + MX8MP_PAD_I2C1_SDA__ENET_QOS_MDIO = IOMUX_PAD(0x0464, 0x0204, 1, 0x0590, 2, 0), + MX8MP_PAD_I2C1_SDA__ECSPI1_MOSI = IOMUX_PAD(0x0464, 0x0204, 3, 0x0560, 1, 0), + MX8MP_PAD_I2C1_SDA__GPIO5_IO15 = IOMUX_PAD(0x0464, 0x0204, 5, 0x0000, 0, 0), + MX8MP_PAD_I2C1_SDA__TPSMP_HDATA17 = IOMUX_PAD(0x0464, 0x0204, 7, 0x0000, 0, 0), + + MX8MP_PAD_I2C2_SCL__I2C2_SCL = IOMUX_PAD(0x0468, 0x0208, 0 | IOMUX_CONFIG_SION, 0x05AC, 2, 0), + MX8MP_PAD_I2C2_SCL__ENET_QOS_1588_EVENT1_IN = IOMUX_PAD(0x0468, 0x0208, 1, 0x0000, 0, 0), + MX8MP_PAD_I2C2_SCL__USDHC3_CD_B = IOMUX_PAD(0x0468, 0x0208, 2, 0x0608, 3, 0), + MX8MP_PAD_I2C2_SCL__ECSPI1_MISO = IOMUX_PAD(0x0468, 0x0208, 3, 0x055C, 1, 0), + MX8MP_PAD_I2C2_SCL__ENET_QOS_1588_EVENT1_AUX_IN = IOMUX_PAD(0x0468, 0x0208, 4, 0x0000, 0, 0), + MX8MP_PAD_I2C2_SCL__GPIO5_IO16 = IOMUX_PAD(0x0468, 0x0208, 5, 0x0000, 0, 0), + MX8MP_PAD_I2C2_SCL__TPSMP_HDATA18 = IOMUX_PAD(0x0468, 0x0208, 7, 0x0000, 0, 0), + + MX8MP_PAD_I2C2_SDA__I2C2_SDA = IOMUX_PAD(0x046C, 0x020C, 0 | IOMUX_CONFIG_SION, 0x05B0, 2, 0), + MX8MP_PAD_I2C2_SDA__ENET_QOS_1588_EVENT1_OUT = IOMUX_PAD(0x046C, 0x020C, 1, 0x0000, 0, 0), + MX8MP_PAD_I2C2_SDA__USDHC3_WP = IOMUX_PAD(0x046C, 0x020C, 2, 0x0634, 3, 0), + MX8MP_PAD_I2C2_SDA__ECSPI1_SS0 = IOMUX_PAD(0x046C, 0x020C, 3, 0x0564, 1, 0), + MX8MP_PAD_I2C2_SDA__GPIO5_IO17 = IOMUX_PAD(0x046C, 0x020C, 5, 0x0000, 0, 0), + MX8MP_PAD_I2C2_SDA__TPSMP_HDATA19 = IOMUX_PAD(0x046C, 0x020C, 7, 0x0000, 0, 0), + + MX8MP_PAD_I2C3_SCL__I2C3_SCL = IOMUX_PAD(0x0470, 0x0210, 0 | IOMUX_CONFIG_SION, 0x05B4, 4, 0), + MX8MP_PAD_I2C3_SCL__PWM4_OUT = IOMUX_PAD(0x0470, 0x0210, 1, 0x0000, 0, 0), + MX8MP_PAD_I2C3_SCL__GPT2_CLK = IOMUX_PAD(0x0470, 0x0210, 2, 0x0000, 0, 0), + MX8MP_PAD_I2C3_SCL__ECSPI2_SCLK = IOMUX_PAD(0x0470, 0x0210, 3, 0x0568, 2, 0), + MX8MP_PAD_I2C3_SCL__GPIO5_IO18 = IOMUX_PAD(0x0470, 0x0210, 5, 0x0000, 0, 0), + MX8MP_PAD_I2C3_SCL__TPSMP_HDATA20 = IOMUX_PAD(0x0470, 0x0210, 7, 0x0000, 0, 0), + + MX8MP_PAD_I2C3_SDA__I2C3_SDA = IOMUX_PAD(0x0474, 0x0214, 0 | IOMUX_CONFIG_SION, 0x05B8, 4, 0), + MX8MP_PAD_I2C3_SDA__PWM3_OUT = IOMUX_PAD(0x0474, 0x0214, 1, 0x0000, 0, 0), + MX8MP_PAD_I2C3_SDA__GPT3_CLK = IOMUX_PAD(0x0474, 0x0214, 2, 0x0000, 0, 0), + MX8MP_PAD_I2C3_SDA__ECSPI2_MOSI = IOMUX_PAD(0x0474, 0x0214, 3, 0x0570, 2, 0), + MX8MP_PAD_I2C3_SDA__GPIO5_IO19 = IOMUX_PAD(0x0474, 0x0214, 5, 0x0000, 0, 0), + MX8MP_PAD_I2C3_SDA__TPSMP_HDATA21 = IOMUX_PAD(0x0474, 0x0214, 7, 0x0000, 0, 0), + + MX8MP_PAD_I2C4_SCL__I2C4_SCL = IOMUX_PAD(0x0478, 0x0218, 0 | IOMUX_CONFIG_SION, 0x05BC, 5, 0), + MX8MP_PAD_I2C4_SCL__PWM2_OUT = IOMUX_PAD(0x0478, 0x0218, 1, 0x0000, 0, 0), + MX8MP_PAD_I2C4_SCL__HSIOMIX_PCIE_CLKREQ_B = IOMUX_PAD(0x0478, 0x0218, 2, 0x05A0, 0, 0), + MX8MP_PAD_I2C4_SCL__ECSPI2_MISO = IOMUX_PAD(0x0478, 0x0218, 3, 0x056C, 2, 0), + MX8MP_PAD_I2C4_SCL__GPIO5_IO20 = IOMUX_PAD(0x0478, 0x0218, 5, 0x0000, 0, 0), + MX8MP_PAD_I2C4_SCL__TPSMP_HDATA22 = IOMUX_PAD(0x0478, 0x0218, 7, 0x0000, 0, 0), + + MX8MP_PAD_I2C4_SDA__I2C4_SDA = IOMUX_PAD(0x047C, 0x021C, 0 | IOMUX_CONFIG_SION, 0x05C0, 5, 0), + MX8MP_PAD_I2C4_SDA__PWM1_OUT = IOMUX_PAD(0x047C, 0x021C, 1, 0x0000, 0, 0), + MX8MP_PAD_I2C4_SDA__ECSPI2_SS0 = IOMUX_PAD(0x047C, 0x021C, 3, 0x0574, 2, 0), + MX8MP_PAD_I2C4_SDA__GPIO5_IO21 = IOMUX_PAD(0x047C, 0x021C, 5, 0x0000, 0, 0), + MX8MP_PAD_I2C4_SDA__TPSMP_HDATA23 = IOMUX_PAD(0x047C, 0x021C, 7, 0x0000, 0, 0), + + MX8MP_PAD_UART1_RXD__UART1_DCE_RX = IOMUX_PAD(0x0480, 0x0220, 0, 0x05E8, 4, 0), + + MX8MP_PAD_UART1_RXD__UART1_DTE_TX = IOMUX_PAD(0x0480, 0x0220, 0, 0x0000, 0, 0), + MX8MP_PAD_UART1_RXD__ECSPI3_SCLK = IOMUX_PAD(0x0480, 0x0220, 1, 0x0000, 0, 0), + MX8MP_PAD_UART1_RXD__GPIO5_IO22 = IOMUX_PAD(0x0480, 0x0220, 5, 0x0000, 0, 0), + MX8MP_PAD_UART1_RXD__TPSMP_HDATA24 = IOMUX_PAD(0x0480, 0x0220, 7, 0x0000, 0, 0), + + MX8MP_PAD_UART1_TXD__UART1_DCE_TX = IOMUX_PAD(0x0484, 0x0224, 0, 0x0000, 0, 0), + + MX8MP_PAD_UART1_TXD__UART1_DTE_RX = IOMUX_PAD(0x0484, 0x0224, 0, 0x05E8, 5, 0), + MX8MP_PAD_UART1_TXD__ECSPI3_MOSI = IOMUX_PAD(0x0484, 0x0224, 1, 0x0000, 0, 0), + MX8MP_PAD_UART1_TXD__GPIO5_IO23 = IOMUX_PAD(0x0484, 0x0224, 5, 0x0000, 0, 0), + MX8MP_PAD_UART1_TXD__TPSMP_HDATA25 = IOMUX_PAD(0x0484, 0x0224, 7, 0x0000, 0, 0), + + MX8MP_PAD_UART2_RXD__UART2_DCE_RX = IOMUX_PAD(0x0488, 0x0228, 0, 0x05F0, 6, 0), + + MX8MP_PAD_UART2_RXD__UART2_DTE_TX = IOMUX_PAD(0x0488, 0x0228, 0, 0x0000, 0, 0), + MX8MP_PAD_UART2_RXD__ECSPI3_MISO = IOMUX_PAD(0x0488, 0x0228, 1, 0x0000, 0, 0), + MX8MP_PAD_UART2_RXD__GPT1_COMPARE3 = IOMUX_PAD(0x0488, 0x0228, 3, 0x0000, 0, 0), + MX8MP_PAD_UART2_RXD__GPIO5_IO24 = IOMUX_PAD(0x0488, 0x0228, 5, 0x0000, 0, 0), + MX8MP_PAD_UART2_RXD__TPSMP_HDATA26 = IOMUX_PAD(0x0488, 0x0228, 7, 0x0000, 0, 0), + + MX8MP_PAD_UART2_TXD__UART2_DCE_TX = IOMUX_PAD(0x048C, 0x022C, 0, 0x0000, 0, 0), + + MX8MP_PAD_UART2_TXD__UART2_DTE_RX = IOMUX_PAD(0x048C, 0x022C, 0, 0x05F0, 7, 0), + MX8MP_PAD_UART2_TXD__ECSPI3_SS0 = IOMUX_PAD(0x048C, 0x022C, 1, 0x0000, 0, 0), + MX8MP_PAD_UART2_TXD__GPT1_COMPARE2 = IOMUX_PAD(0x048C, 0x022C, 3, 0x0000, 0, 0), + MX8MP_PAD_UART2_TXD__GPIO5_IO25 = IOMUX_PAD(0x048C, 0x022C, 5, 0x0000, 0, 0), + MX8MP_PAD_UART2_TXD__TPSMP_HDATA27 = IOMUX_PAD(0x048C, 0x022C, 7, 0x0000, 0, 0), + + MX8MP_PAD_UART3_RXD__UART3_DCE_RX = IOMUX_PAD(0x0490, 0x0230, 0, 0x05F8, 6, 0), + + MX8MP_PAD_UART3_RXD__UART3_DTE_TX = IOMUX_PAD(0x0490, 0x0230, 0, 0x0000, 0, 0), + MX8MP_PAD_UART3_RXD__UART1_DCE_CTS = IOMUX_PAD(0x0490, 0x0230, 1, 0x0000, 0, 0), + MX8MP_PAD_UART3_RXD__UART1_DTE_RTS = IOMUX_PAD(0x0490, 0x0230, 1, 0x05E4, 4, 0), + MX8MP_PAD_UART3_RXD__USDHC3_RESET_B = IOMUX_PAD(0x0490, 0x0230, 2, 0x0000, 0, 0), + MX8MP_PAD_UART3_RXD__GPT1_CAPTURE2 = IOMUX_PAD(0x0490, 0x0230, 3, 0x0598, 1, 0), + MX8MP_PAD_UART3_RXD__CAN2_TX = IOMUX_PAD(0x0490, 0x0230, 4, 0x0000, 0, 0), + MX8MP_PAD_UART3_RXD__GPIO5_IO26 = IOMUX_PAD(0x0490, 0x0230, 5, 0x0000, 0, 0), + MX8MP_PAD_UART3_RXD__TPSMP_HDATA28 = IOMUX_PAD(0x0490, 0x0230, 7, 0x0000, 0, 0), + + MX8MP_PAD_UART3_TXD__UART3_DCE_TX = IOMUX_PAD(0x0494, 0x0234, 0, 0x0000, 0, 0), + + MX8MP_PAD_UART3_TXD__UART3_DTE_RX = IOMUX_PAD(0x0494, 0x0234, 0, 0x05F8, 7, 0), + MX8MP_PAD_UART3_TXD__UART1_DCE_RTS = IOMUX_PAD(0x0494, 0x0234, 1, 0x05E4, 5, 0), + MX8MP_PAD_UART3_TXD__UART1_DTE_CTS = IOMUX_PAD(0x0494, 0x0234, 1, 0x0000, 0, 0), + MX8MP_PAD_UART3_TXD__USDHC3_VSELECT = IOMUX_PAD(0x0494, 0x0234, 2, 0x0000, 0, 0), + MX8MP_PAD_UART3_TXD__GPT1_CLK = IOMUX_PAD(0x0494, 0x0234, 3, 0x059C, 1, 0), + MX8MP_PAD_UART3_TXD__CAN2_RX = IOMUX_PAD(0x0494, 0x0234, 4, 0x0550, 2, 0), + MX8MP_PAD_UART3_TXD__GPIO5_IO27 = IOMUX_PAD(0x0494, 0x0234, 5, 0x0000, 0, 0), + MX8MP_PAD_UART3_TXD__TPSMP_HDATA29 = IOMUX_PAD(0x0494, 0x0234, 7, 0x0000, 0, 0), + + MX8MP_PAD_UART4_RXD__UART4_DCE_RX = IOMUX_PAD(0x0498, 0x0238, 0, 0x0600, 8, 0), + + MX8MP_PAD_UART4_RXD__UART4_DTE_TX = IOMUX_PAD(0x0498, 0x0238, 0, 0x0000, 0, 0), + MX8MP_PAD_UART4_RXD__UART2_DCE_CTS = IOMUX_PAD(0x0498, 0x0238, 1, 0x0000, 0, 0), + MX8MP_PAD_UART4_RXD__UART2_DTE_RTS = IOMUX_PAD(0x0498, 0x0238, 1, 0x05EC, 4, 0), + MX8MP_PAD_UART4_RXD__HSIOMIX_PCIE_CLKREQ_B = IOMUX_PAD(0x0498, 0x0238, 2, 0x05A0, 1, 0), + MX8MP_PAD_UART4_RXD__GPT1_COMPARE1 = IOMUX_PAD(0x0498, 0x0238, 3, 0x0000, 0, 0), + MX8MP_PAD_UART4_RXD__I2C6_SCL = IOMUX_PAD(0x0498, 0x0238, 4 | IOMUX_CONFIG_SION, 0x05CC, 2, 0), + MX8MP_PAD_UART4_RXD__GPIO5_IO28 = IOMUX_PAD(0x0498, 0x0238, 5, 0x0000, 0, 0), + MX8MP_PAD_UART4_RXD__TPSMP_HDATA30 = IOMUX_PAD(0x0498, 0x0238, 7, 0x0000, 0, 0), + + MX8MP_PAD_UART4_TXD__UART4_DCE_TX = IOMUX_PAD(0x049C, 0x023C, 0, 0x0000, 0, 0), + + MX8MP_PAD_UART4_TXD__UART4_DTE_RX = IOMUX_PAD(0x049C, 0x023C, 0, 0x0600, 9, 0), + MX8MP_PAD_UART4_TXD__UART2_DCE_RTS = IOMUX_PAD(0x049C, 0x023C, 1, 0x05EC, 5, 0), + MX8MP_PAD_UART4_TXD__UART2_DTE_CTS = IOMUX_PAD(0x049C, 0x023C, 1, 0x0000, 0, 0), + MX8MP_PAD_UART4_TXD__GPT1_CAPTURE1 = IOMUX_PAD(0x049C, 0x023C, 3, 0x0594, 1, 0), + MX8MP_PAD_UART4_TXD__I2C6_SDA = IOMUX_PAD(0x049C, 0x023C, 4 | IOMUX_CONFIG_SION, 0x05D0, 2, 0), + MX8MP_PAD_UART4_TXD__GPIO5_IO29 = IOMUX_PAD(0x049C, 0x023C, 5, 0x0000, 0, 0), + MX8MP_PAD_UART4_TXD__TPSMP_HDATA31 = IOMUX_PAD(0x049C, 0x023C, 7, 0x0000, 0, 0), + + MX8MP_PAD_HDMI_DDC_SCL__HDMIMIX_EARC_SCL = IOMUX_PAD(0x04A0, 0x0240, 0, 0x0000, 0, 0), + MX8MP_PAD_HDMI_DDC_SCL__I2C5_SCL = IOMUX_PAD(0x04A0, 0x0240, 3 | IOMUX_CONFIG_SION, 0x05C4, 3, 0), + MX8MP_PAD_HDMI_DDC_SCL__CAN1_TX = IOMUX_PAD(0x04A0, 0x0240, 4, 0x0000, 0, 0), + MX8MP_PAD_HDMI_DDC_SCL__GPIO3_IO26 = IOMUX_PAD(0x04A0, 0x0240, 5, 0x0000, 0, 0), + MX8MP_PAD_HDMI_DDC_SCL__AUDIOMIX_test_out00 = IOMUX_PAD(0x04A0, 0x0240, 6, 0x0000, 0, 0), + + MX8MP_PAD_HDMI_DDC_SDA__HDMIMIX_EARC_SDA = IOMUX_PAD(0x04A4, 0x0244, 0, 0x0000, 0, 0), + MX8MP_PAD_HDMI_DDC_SDA__I2C5_SDA = IOMUX_PAD(0x04A4, 0x0244, 3 | IOMUX_CONFIG_SION, 0x05C8, 3, 0), + MX8MP_PAD_HDMI_DDC_SDA__CAN1_RX = IOMUX_PAD(0x04A4, 0x0244, 4, 0x054C, 3, 0), + MX8MP_PAD_HDMI_DDC_SDA__GPIO3_IO27 = IOMUX_PAD(0x04A4, 0x0244, 5, 0x0000, 0, 0), + MX8MP_PAD_HDMI_DDC_SDA__AUDIOMIX_test_out01 = IOMUX_PAD(0x04A4, 0x0244, 6, 0x0000, 0, 0), + + MX8MP_PAD_HDMI_CEC__HDMIMIX_EARC_CEC = IOMUX_PAD(0x04A8, 0x0248, 0, 0x0000, 0, 0), + MX8MP_PAD_HDMI_CEC__I2C6_SCL = IOMUX_PAD(0x04A8, 0x0248, 3 | IOMUX_CONFIG_SION, 0x05CC, 3, 0), + MX8MP_PAD_HDMI_CEC__CAN2_TX = IOMUX_PAD(0x04A8, 0x0248, 4, 0x0000, 0, 0), + MX8MP_PAD_HDMI_CEC__GPIO3_IO28 = IOMUX_PAD(0x04A8, 0x0248, 5, 0x0000, 0, 0), + + MX8MP_PAD_HDMI_HPD__HDMIMIX_EARC_DC_HPD = IOMUX_PAD(0x04AC, 0x024C, 0, 0x0000, 0, 0), + MX8MP_PAD_HDMI_HPD__AUDIOMIX_EARC_HDMI_HPD_O = IOMUX_PAD(0x04AC, 0x024C, 1, 0x0000, 0, 0), + MX8MP_PAD_HDMI_HPD__I2C6_SDA = IOMUX_PAD(0x04AC, 0x024C, 3 | IOMUX_CONFIG_SION, 0x05D0, 3, 0), + MX8MP_PAD_HDMI_HPD__CAN2_RX = IOMUX_PAD(0x04AC, 0x024C, 4, 0x0550, 3, 0), + MX8MP_PAD_HDMI_HPD__GPIO3_IO29 = IOMUX_PAD(0x04AC, 0x024C, 5, 0x0000, 0, 0), +}; +#endif /* __ASM_ARCH_IMX8MP_PINS_H__ */
i.MX8MP does not have LVTTL, it has a PE property
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/mach-imx/iomux-v3.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/mach-imx/iomux-v3.h b/arch/arm/include/asm/mach-imx/iomux-v3.h index 3d5586ed4f..06dbd8d943 100644 --- a/arch/arm/include/asm/mach-imx/iomux-v3.h +++ b/arch/arm/include/asm/mach-imx/iomux-v3.h @@ -104,7 +104,7 @@ typedef u64 iomux_v3_cfg_t; #define PAD_CTL_ODE (0x1 << 5) #define PAD_CTL_PUE (0x1 << 6) #define PAD_CTL_HYS (0x1 << 7) -#if defined(CONFIG_IMX8MM) || defined(CONFIG_IMX8MN) +#if defined(CONFIG_IMX8MM) || defined(CONFIG_IMX8MN) || defined(CONFIG_IMX8MP) #define PAD_CTL_PE (0x1 << 8) #else #define PAD_CTL_LVTTL (0x1 << 8)
i.MX8MP ROM support ROMAPI as i.MX8MN, so make SPL_IMX_ROMAPI_LOADADDR visible to i.MX8MP
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/Kconfig | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/mach-imx/Kconfig b/arch/arm/mach-imx/Kconfig index 4ce2799b72..aa140c4798 100644 --- a/arch/arm/mach-imx/Kconfig +++ b/arch/arm/mach-imx/Kconfig @@ -112,7 +112,7 @@ config DDRMC_VF610_CALIBRATION
config SPL_IMX_ROMAPI_LOADADDR hex "Default load address to load image through ROM API" - depends on IMX8MN + depends on IMX8MN || IMX8MP
config IMX_DCD_ADDR hex "DCD Blocks location on the image" @@ -123,4 +123,3 @@ config IMX_DCD_ADDR the ROM code to configure the device at early boot stage, is located. This information is shared with the user via mkimage -l just so the image can be signed. -
The drivers/clk/imx/*.c are used for CLK dm case, the clock_imx8mm.c is used for non CLK dm case, let's split it. Sometimes it is hard to enable CLK dm in SPL stage, considering code size, malloc size requirement, the splittion will make it easy to use non CLK dm in SPL stage.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/clock_imx8mm.c | 339 +++++++++++++++++++++++++++++---- 1 file changed, 306 insertions(+), 33 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/clock_imx8mm.c b/arch/arm/mach-imx/imx8m/clock_imx8mm.c index 68575a2bd3..ca4b4c05ab 100644 --- a/arch/arm/mach-imx/imx8m/clock_imx8mm.c +++ b/arch/arm/mach-imx/imx8m/clock_imx8mm.c @@ -10,9 +10,6 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> #include <asm/io.h> -#include <clk.h> -#include <clk-uclass.h> -#include <dt-bindings/clock/imx8mm-clock.h> #include <div64.h> #include <errno.h>
@@ -22,30 +19,18 @@ static struct anamix_pll *ana_pll = (struct anamix_pll *)ANATOP_BASE_ADDR;
void enable_ocotp_clk(unsigned char enable) { - struct clk *clkp; - int ret; - - ret = clk_get_by_id(IMX8MM_CLK_OCOTP_ROOT, &clkp); - if (ret) { - printf("%s: err: %d\n", __func__, ret); - return; - } - - enable ? clk_enable(clkp) : clk_disable(clkp); + clock_enable(CCGR_OCOTP, !!enable); }
int enable_i2c_clk(unsigned char enable, unsigned i2c_num) { - struct clk *clkp; - int ret; + /* 0 - 3 is valid i2c num */ + if (i2c_num > 3) + return -EINVAL;
- ret = clk_get_by_id(IMX8MM_CLK_I2C1_ROOT + i2c_num, &clkp); - if (ret) { - printf("%s: err: %d\n", __func__, ret); - return ret; - } + clock_enable(CCGR_I2C1 + i2c_num, !!enable);
- return enable ? clk_enable(clkp) : clk_disable(clkp); + return 0; }
#ifdef CONFIG_SPL_BUILD @@ -283,24 +268,312 @@ u32 imx_get_uartclk(void) return 24000000U; }
+u32 decode_intpll(enum clk_root_src intpll) +{ + u32 pll_gnrl_ctl, pll_div_ctl, pll_clke_mask; + u32 main_div, pre_div, post_div, div; + u64 freq; + + switch (intpll) { + case ARM_PLL_CLK: + pll_gnrl_ctl = readl(&ana_pll->arm_pll_gnrl_ctl); + pll_div_ctl = readl(&ana_pll->arm_pll_div_ctl); + break; + case GPU_PLL_CLK: + pll_gnrl_ctl = readl(&ana_pll->gpu_pll_gnrl_ctl); + pll_div_ctl = readl(&ana_pll->gpu_pll_div_ctl); + break; + case VPU_PLL_CLK: + pll_gnrl_ctl = readl(&ana_pll->vpu_pll_gnrl_ctl); + pll_div_ctl = readl(&ana_pll->vpu_pll_div_ctl); + break; + case SYSTEM_PLL1_800M_CLK: + case SYSTEM_PLL1_400M_CLK: + case SYSTEM_PLL1_266M_CLK: + case SYSTEM_PLL1_200M_CLK: + case SYSTEM_PLL1_160M_CLK: + case SYSTEM_PLL1_133M_CLK: + case SYSTEM_PLL1_100M_CLK: + case SYSTEM_PLL1_80M_CLK: + case SYSTEM_PLL1_40M_CLK: + pll_gnrl_ctl = readl(&ana_pll->sys_pll1_gnrl_ctl); + pll_div_ctl = readl(&ana_pll->sys_pll1_div_ctl); + break; + case SYSTEM_PLL2_1000M_CLK: + case SYSTEM_PLL2_500M_CLK: + case SYSTEM_PLL2_333M_CLK: + case SYSTEM_PLL2_250M_CLK: + case SYSTEM_PLL2_200M_CLK: + case SYSTEM_PLL2_166M_CLK: + case SYSTEM_PLL2_125M_CLK: + case SYSTEM_PLL2_100M_CLK: + case SYSTEM_PLL2_50M_CLK: + pll_gnrl_ctl = readl(&ana_pll->sys_pll2_gnrl_ctl); + pll_div_ctl = readl(&ana_pll->sys_pll2_div_ctl); + break; + case SYSTEM_PLL3_CLK: + pll_gnrl_ctl = readl(&ana_pll->sys_pll3_gnrl_ctl); + pll_div_ctl = readl(&ana_pll->sys_pll3_div_ctl); + break; + default: + return -EINVAL; + } + + /* Only support SYS_XTAL 24M, PAD_CLK not take into consideration */ + if ((pll_gnrl_ctl & INTPLL_REF_CLK_SEL_MASK) != 0) + return 0; + + if ((pll_gnrl_ctl & INTPLL_RST_MASK) == 0) + return 0; + + /* + * When BYPASS is equal to 1, PLL enters the bypass mode + * regardless of the values of RESETB + */ + if (pll_gnrl_ctl & INTPLL_BYPASS_MASK) + return 24000000u; + + if (!(pll_gnrl_ctl & INTPLL_LOCK_MASK)) { + puts("pll not locked\n"); + return 0; + } + + switch (intpll) { + case ARM_PLL_CLK: + case GPU_PLL_CLK: + case VPU_PLL_CLK: + case SYSTEM_PLL3_CLK: + case SYSTEM_PLL1_800M_CLK: + case SYSTEM_PLL2_1000M_CLK: + pll_clke_mask = INTPLL_CLKE_MASK; + div = 1; + break; + + case SYSTEM_PLL1_400M_CLK: + case SYSTEM_PLL2_500M_CLK: + pll_clke_mask = INTPLL_DIV2_CLKE_MASK; + div = 2; + break; + + case SYSTEM_PLL1_266M_CLK: + case SYSTEM_PLL2_333M_CLK: + pll_clke_mask = INTPLL_DIV3_CLKE_MASK; + div = 3; + break; + + case SYSTEM_PLL1_200M_CLK: + case SYSTEM_PLL2_250M_CLK: + pll_clke_mask = INTPLL_DIV4_CLKE_MASK; + div = 4; + break; + + case SYSTEM_PLL1_160M_CLK: + case SYSTEM_PLL2_200M_CLK: + pll_clke_mask = INTPLL_DIV5_CLKE_MASK; + div = 5; + break; + + case SYSTEM_PLL1_133M_CLK: + case SYSTEM_PLL2_166M_CLK: + pll_clke_mask = INTPLL_DIV6_CLKE_MASK; + div = 6; + break; + + case SYSTEM_PLL1_100M_CLK: + case SYSTEM_PLL2_125M_CLK: + pll_clke_mask = INTPLL_DIV8_CLKE_MASK; + div = 8; + break; + + case SYSTEM_PLL1_80M_CLK: + case SYSTEM_PLL2_100M_CLK: + pll_clke_mask = INTPLL_DIV10_CLKE_MASK; + div = 10; + break; + + case SYSTEM_PLL1_40M_CLK: + case SYSTEM_PLL2_50M_CLK: + pll_clke_mask = INTPLL_DIV20_CLKE_MASK; + div = 20; + break; + default: + return -EINVAL; + } + + if ((pll_gnrl_ctl & pll_clke_mask) == 0) + return 0; + + main_div = (pll_div_ctl & INTPLL_MAIN_DIV_MASK) >> + INTPLL_MAIN_DIV_SHIFT; + pre_div = (pll_div_ctl & INTPLL_PRE_DIV_MASK) >> + INTPLL_PRE_DIV_SHIFT; + post_div = (pll_div_ctl & INTPLL_POST_DIV_MASK) >> + INTPLL_POST_DIV_SHIFT; + + /* FFVCO = (m * FFIN) / p, FFOUT = (m * FFIN) / (p * 2^s) */ + freq = 24000000ULL * main_div; + return lldiv(freq, pre_div * (1 << post_div) * div); +} + +u32 decode_fracpll(enum clk_root_src frac_pll) +{ + u32 pll_gnrl_ctl, pll_fdiv_ctl0, pll_fdiv_ctl1; + u32 main_div, pre_div, post_div, k; + + switch (frac_pll) { + case DRAM_PLL1_CLK: + pll_gnrl_ctl = readl(&ana_pll->dram_pll_gnrl_ctl); + pll_fdiv_ctl0 = readl(&ana_pll->dram_pll_fdiv_ctl0); + pll_fdiv_ctl1 = readl(&ana_pll->dram_pll_fdiv_ctl1); + break; + case AUDIO_PLL1_CLK: + pll_gnrl_ctl = readl(&ana_pll->audio_pll1_gnrl_ctl); + pll_fdiv_ctl0 = readl(&ana_pll->audio_pll1_fdiv_ctl0); + pll_fdiv_ctl1 = readl(&ana_pll->audio_pll1_fdiv_ctl1); + break; + case AUDIO_PLL2_CLK: + pll_gnrl_ctl = readl(&ana_pll->audio_pll2_gnrl_ctl); + pll_fdiv_ctl0 = readl(&ana_pll->audio_pll2_fdiv_ctl0); + pll_fdiv_ctl1 = readl(&ana_pll->audio_pll2_fdiv_ctl1); + break; + case VIDEO_PLL_CLK: + pll_gnrl_ctl = readl(&ana_pll->video_pll1_gnrl_ctl); + pll_fdiv_ctl0 = readl(&ana_pll->video_pll1_fdiv_ctl0); + pll_fdiv_ctl1 = readl(&ana_pll->video_pll1_fdiv_ctl1); + break; + default: + printf("Not supported\n"); + return 0; + } + + /* Only support SYS_XTAL 24M, PAD_CLK not take into consideration */ + if ((pll_gnrl_ctl & INTPLL_REF_CLK_SEL_MASK) != 0) + return 0; + + if ((pll_gnrl_ctl & INTPLL_RST_MASK) == 0) + return 0; + /* + * When BYPASS is equal to 1, PLL enters the bypass mode + * regardless of the values of RESETB + */ + if (pll_gnrl_ctl & INTPLL_BYPASS_MASK) + return 24000000u; + + if (!(pll_gnrl_ctl & INTPLL_LOCK_MASK)) { + puts("pll not locked\n"); + return 0; + } + + if (!(pll_gnrl_ctl & INTPLL_CLKE_MASK)) + return 0; + + main_div = (pll_fdiv_ctl0 & INTPLL_MAIN_DIV_MASK) >> + INTPLL_MAIN_DIV_SHIFT; + pre_div = (pll_fdiv_ctl0 & INTPLL_PRE_DIV_MASK) >> + INTPLL_PRE_DIV_SHIFT; + post_div = (pll_fdiv_ctl0 & INTPLL_POST_DIV_MASK) >> + INTPLL_POST_DIV_SHIFT; + + k = pll_fdiv_ctl1 & GENMASK(15, 0); + + return lldiv((main_div * 65536 + k) * 24000000ULL, + 65536 * pre_div * (1 << post_div)); +} + +u32 get_root_src_clk(enum clk_root_src root_src) +{ + switch (root_src) { + case OSC_24M_CLK: + return 24000000u; + case OSC_HDMI_CLK: + return 26000000u; + case OSC_32K_CLK: + return 32000u; + case ARM_PLL_CLK: + case GPU_PLL_CLK: + case VPU_PLL_CLK: + case SYSTEM_PLL1_800M_CLK: + case SYSTEM_PLL1_400M_CLK: + case SYSTEM_PLL1_266M_CLK: + case SYSTEM_PLL1_200M_CLK: + case SYSTEM_PLL1_160M_CLK: + case SYSTEM_PLL1_133M_CLK: + case SYSTEM_PLL1_100M_CLK: + case SYSTEM_PLL1_80M_CLK: + case SYSTEM_PLL1_40M_CLK: + case SYSTEM_PLL2_1000M_CLK: + case SYSTEM_PLL2_500M_CLK: + case SYSTEM_PLL2_333M_CLK: + case SYSTEM_PLL2_250M_CLK: + case SYSTEM_PLL2_200M_CLK: + case SYSTEM_PLL2_166M_CLK: + case SYSTEM_PLL2_125M_CLK: + case SYSTEM_PLL2_100M_CLK: + case SYSTEM_PLL2_50M_CLK: + case SYSTEM_PLL3_CLK: + return decode_intpll(root_src); + case DRAM_PLL1_CLK: + case AUDIO_PLL1_CLK: + case AUDIO_PLL2_CLK: + case VIDEO_PLL_CLK: + return decode_fracpll(root_src); + default: + return 0; + } + + return 0; +} + +u32 get_root_clk(enum clk_root_index clock_id) +{ + enum clk_root_src root_src; + u32 post_podf, pre_podf, root_src_clk; + + if (clock_root_enabled(clock_id) <= 0) + return 0; + + if (clock_get_prediv(clock_id, &pre_podf) < 0) + return 0; + + if (clock_get_postdiv(clock_id, &post_podf) < 0) + return 0; + + if (clock_get_src(clock_id, &root_src) < 0) + return 0; + + root_src_clk = get_root_src_clk(root_src); + + return root_src_clk / (post_podf + 1) / (pre_podf + 1); +} + u32 mxc_get_clock(enum mxc_clock clk) { - struct clk *clkp; - int ret; + u32 val;
switch (clk) { - case MXC_IPG_CLK: - ret = clk_get_by_id(IMX8MM_CLK_IPG_ROOT, &clkp); - if (ret) - return 0; - return clk_get_rate(clkp); case MXC_ARM_CLK: - ret = clk_get_by_id(IMX8MM_CLK_A53_DIV, &clkp); - if (ret) - return 0; - return clk_get_rate(clkp); + return get_root_clk(ARM_A53_CLK_ROOT); + case MXC_IPG_CLK: + clock_get_target_val(IPG_CLK_ROOT, &val); + val = val & 0x3; + return get_root_clk(AHB_CLK_ROOT) / 2 / (val + 1); + case MXC_CSPI_CLK: + return get_root_clk(ECSPI1_CLK_ROOT); + case MXC_ESDHC_CLK: + return get_root_clk(USDHC1_CLK_ROOT); + case MXC_ESDHC2_CLK: + return get_root_clk(USDHC2_CLK_ROOT); + case MXC_ESDHC3_CLK: + return get_root_clk(USDHC3_CLK_ROOT); + case MXC_I2C_CLK: + return get_root_clk(I2C1_CLK_ROOT); + case MXC_UART_CLK: + return get_root_clk(UART1_CLK_ROOT); + case MXC_QSPI_CLK: + return get_root_clk(QSPI_CLK_ROOT); default: - printf("%s: %d not supported\n", __func__, clk); + printf("Unsupported mxc_clock %d\n", clk); + break; }
Add imx_clk_mux2_flags which will be used by i.MX8MP
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Lukasz Majewski lukma@denx.de --- drivers/clk/imx/clk.h | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/drivers/clk/imx/clk.h b/drivers/clk/imx/clk.h index 07dcf94ea5..60f287046b 100644 --- a/drivers/clk/imx/clk.h +++ b/drivers/clk/imx/clk.h @@ -125,6 +125,16 @@ static inline struct clk *imx_clk_mux_flags(const char *name, width, 0); }
+static inline struct clk *imx_clk_mux2_flags(const char *name, + void __iomem *reg, u8 shift, u8 width, + const char * const *parents, + int num_parents, unsigned long flags) +{ + return clk_register_mux(NULL, name, parents, num_parents, + flags | CLK_SET_RATE_NO_REPARENT | CLK_OPS_PARENT_ENABLE, + reg, shift, width, 0); +} + static inline struct clk *imx_clk_mux(const char *name, void __iomem *reg, u8 shift, u8 width, const char * const *parents, int num_parents)
Add i.MX8MP clk driver for i.MX8MP CLK driver model usage
V1: To align with linux coding style, the 80 chars warning is not fixed.
drivers/clk/imx/Kconfig | 16 ++ drivers/clk/imx/Makefile | 2 + drivers/clk/imx/clk-imx8mp.c | 362 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 380 insertions(+) create mode 100644 drivers/clk/imx/clk-imx8mp.c
diff --git a/drivers/clk/imx/Kconfig b/drivers/clk/imx/Kconfig index 0ba8bc9f63..2f149ff6f8 100644 --- a/drivers/clk/imx/Kconfig +++ b/drivers/clk/imx/Kconfig @@ -52,3 +52,19 @@ config CLK_IMX8MN select CLK_CCF help This enables support clock driver for i.MX8MN platforms. + +config SPL_CLK_IMX8MP + bool "SPL clock support for i.MX8MP" + depends on ARCH_IMX8M && SPL + select SPL_CLK + select SPL_CLK_CCF + help + This enables SPL DM/DTS support for clock driver in i.MX8MP + +config CLK_IMX8MP + bool "Clock support for i.MX8MP" + depends on ARCH_IMX8M + select CLK + select CLK_CCF + help + This enables support clock driver for i.MX8MP platforms. diff --git a/drivers/clk/imx/Makefile b/drivers/clk/imx/Makefile index 222c5a4e08..255a87b18e 100644 --- a/drivers/clk/imx/Makefile +++ b/drivers/clk/imx/Makefile @@ -14,3 +14,5 @@ obj-$(CONFIG_$(SPL_TPL_)CLK_IMX8MM) += clk-imx8mm.o clk-pll14xx.o \ clk-composite-8m.o obj-$(CONFIG_$(SPL_TPL_)CLK_IMX8MN) += clk-imx8mn.o clk-pll14xx.o \ clk-composite-8m.o +obj-$(CONFIG_$(SPL_TPL_)CLK_IMX8MP) += clk-imx8mp.o clk-pll14xx.o \ + clk-composite-8m.o diff --git a/drivers/clk/imx/clk-imx8mp.c b/drivers/clk/imx/clk-imx8mp.c new file mode 100644 index 0000000000..a2693d2f7a --- /dev/null +++ b/drivers/clk/imx/clk-imx8mp.c @@ -0,0 +1,362 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright 2019 NXP + * Peng Fan peng.fan@nxp.com + */ + +#include <common.h> +#include <clk.h> +#include <clk-uclass.h> +#include <dm.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <dt-bindings/clock/imx8mp-clock.h> + +#include "clk.h" + +#define PLL_1416X_RATE(_rate, _m, _p, _s) \ + { \ + .rate = (_rate), \ + .mdiv = (_m), \ + .pdiv = (_p), \ + .sdiv = (_s), \ + } + +#define PLL_1443X_RATE(_rate, _m, _p, _s, _k) \ + { \ + .rate = (_rate), \ + .mdiv = (_m), \ + .pdiv = (_p), \ + .sdiv = (_s), \ + .kdiv = (_k), \ + } + +static const struct imx_pll14xx_rate_table imx8mp_pll1416x_tbl[] = { + PLL_1416X_RATE(1800000000U, 225, 3, 0), + PLL_1416X_RATE(1600000000U, 200, 3, 0), + PLL_1416X_RATE(1200000000U, 300, 3, 1), + PLL_1416X_RATE(1000000000U, 250, 3, 1), + PLL_1416X_RATE(800000000U, 200, 3, 1), + PLL_1416X_RATE(750000000U, 250, 2, 2), + PLL_1416X_RATE(700000000U, 350, 3, 2), + PLL_1416X_RATE(600000000U, 300, 3, 2), +}; + +static const struct imx_pll14xx_rate_table imx8mp_drampll_tbl[] = { + PLL_1443X_RATE(650000000U, 325, 3, 2, 0), +}; + +static struct imx_pll14xx_clk imx8mp_dram_pll __initdata = { + .type = PLL_1443X, + .rate_table = imx8mp_drampll_tbl, + .rate_count = ARRAY_SIZE(imx8mp_drampll_tbl), +}; + +static struct imx_pll14xx_clk imx8mp_arm_pll __initdata = { + .type = PLL_1416X, + .rate_table = imx8mp_pll1416x_tbl, + .rate_count = ARRAY_SIZE(imx8mp_pll1416x_tbl), +}; + +static struct imx_pll14xx_clk imx8mp_sys_pll __initdata = { + .type = PLL_1416X, + .rate_table = imx8mp_pll1416x_tbl, + .rate_count = ARRAY_SIZE(imx8mp_pll1416x_tbl), +}; + +static const char *pll_ref_sels[] = { "clock-osc-24m", "dummy", "dummy", "dummy", }; +static const char *dram_pll_bypass_sels[] = {"dram_pll", "dram_pll_ref_sel", }; +static const char *arm_pll_bypass_sels[] = {"arm_pll", "arm_pll_ref_sel", }; +static const char *sys_pll1_bypass_sels[] = {"sys_pll1", "sys_pll1_ref_sel", }; +static const char *sys_pll2_bypass_sels[] = {"sys_pll2", "sys_pll2_ref_sel", }; +static const char *sys_pll3_bypass_sels[] = {"sys_pll3", "sys_pll3_ref_sel", }; + +static const char *imx8mp_a53_sels[] = {"clock-osc-24m", "arm_pll_out", "sys_pll2_500m", + "sys_pll2_1000m", "sys_pll1_800m", "sys_pll1_400m", + "audio_pll1_out", "sys_pll3_out", }; + +static const char *imx8mp_main_axi_sels[] = {"clock-osc-24m", "sys_pll2_333m", "sys_pll1_800m", + "sys_pll2_250m", "sys_pll2_1000m", "audio_pll1_out", + "video_pll1_out", "sys_pll1_100m",}; + +static const char *imx8mp_nand_usdhc_sels[] = {"clock-osc-24m", "sys_pll1_266m", "sys_pll1_800m", + "sys_pll2_200m", "sys_pll1_133m", "sys_pll3_out", + "sys_pll2_250m", "audio_pll1_out", }; + +static const char *imx8mp_noc_sels[] = {"clock-osc-24m", "sys_pll1_800m", "sys_pll3_out", + "sys_pll2_1000m", "sys_pll2_500m", "audio_pll1_out", + "video_pll1_out", "audio_pll2_out", }; + +static const char *imx8mp_noc_io_sels[] = {"clock-osc-24m", "sys_pll1_800m", "sys_pll3_out", + "sys_pll2_1000m", "sys_pll2_500m", "audio_pll1_out", + "video_pll1_out", "audio_pll2_out", }; + +static const char *imx8mp_ahb_sels[] = {"clock-osc-24m", "sys_pll1_133m", "sys_pll1_800m", + "sys_pll1_400m", "sys_pll2_125m", "sys_pll3_out", + "audio_pll1_out", "video_pll1_out", }; + +static const char *imx8mp_dram_alt_sels[] = {"clock-osc-24m", "sys_pll1_800m", "sys_pll1_100m", + "sys_pll2_500m", "sys_pll2_1000m", "sys_pll3_out", + "audio_pll1_out", "sys_pll1_266m", }; + +static const char *imx8mp_dram_apb_sels[] = {"clock-osc-24m", "sys_pll2_200m", "sys_pll1_40m", + "sys_pll1_160m", "sys_pll1_800m", "sys_pll3_out", + "sys_pll2_250m", "audio_pll2_out", }; + +static const char *imx8mp_i2c5_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_pll2_50m", + "sys_pll3_out", "audio_pll1_out", "video_pll1_out", + "audio_pll2_out", "sys_pll1_133m", }; + +static const char *imx8mp_i2c6_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_pll2_50m", + "sys_pll3_out", "audio_pll1_out", "video_pll1_out", + "audio_pll2_out", "sys_pll1_133m", }; + +static const char *imx8mp_usdhc1_sels[] = {"clock-osc-24m", "sys_pll1_400m", "sys_pll1_800m", + "sys_pll2_500m", "sys_pll3_out", "sys_pll1_266m", + "audio_pll2_out", "sys_pll1_100m", }; + +static const char *imx8mp_usdhc2_sels[] = {"clock-osc-24m", "sys_pll1_400m", "sys_pll1_800m", + "sys_pll2_500m", "sys_pll3_out", "sys_pll1_266m", + "audio_pll2_out", "sys_pll1_100m", }; + +static const char *imx8mp_i2c1_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_pll2_50m", + "sys_pll3_out", "audio_pll1_out", "video_pll1_out", + "audio_pll2_out", "sys_pll1_133m", }; + +static const char *imx8mp_i2c2_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_pll2_50m", + "sys_pll3_out", "audio_pll1_out", "video_pll1_out", + "audio_pll2_out", "sys_pll1_133m", }; + +static const char *imx8mp_i2c3_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_pll2_50m", + "sys_pll3_out", "audio_pll1_out", "video_pll1_out", + "audio_pll2_out", "sys_pll1_133m", }; + +static const char *imx8mp_i2c4_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_pll2_50m", + "sys_pll3_out", "audio_pll1_out", "video_pll1_out", + "audio_pll2_out", "sys_pll1_133m", }; + +static const char *imx8mp_uart1_sels[] = {"clock-osc-24m", "sys_pll1_80m", "sys_pll2_200m", + "sys_pll2_100m", "sys_pll3_out", "clk_ext2", + "clk_ext4", "audio_pll2_out", }; + +static const char *imx8mp_uart2_sels[] = {"clock-osc-24m", "sys_pll1_80m", "sys_pll2_200m", + "sys_pll2_100m", "sys_pll3_out", "clk_ext2", + "clk_ext3", "audio_pll2_out", }; + +static const char *imx8mp_uart3_sels[] = {"clock-osc-24m", "sys_pll1_80m", "sys_pll2_200m", + "sys_pll2_100m", "sys_pll3_out", "clk_ext2", + "clk_ext4", "audio_pll2_out", }; + +static const char *imx8mp_uart4_sels[] = {"clock-osc-24m", "sys_pll1_80m", "sys_pll2_200m", + "sys_pll2_100m", "sys_pll3_out", "clk_ext2", + "clk_ext3", "audio_pll2_out", }; + +static const char *imx8mp_gic_sels[] = {"clock-osc-24m", "sys_pll2_200m", "sys_pll1_40m", + "sys_pll2_100m", "sys_pll1_800m", + "sys_pll2_500m", "clk_ext4", "audio_pll2_out" }; + +static const char *imx8mp_wdog_sels[] = {"clock-osc-24m", "sys_pll1_133m", "sys_pll1_160m", + "vpu_pll_out", "sys_pll2_125m", "sys_pll3_out", + "sys_pll1_80m", "sys_pll2_166m" }; + +static const char *imx8mp_usdhc3_sels[] = {"clock-osc-24m", "sys_pll1_400m", "sys_pll1_800m", + "sys_pll2_500m", "sys_pll3_out", "sys_pll1_266m", + "audio_pll2_out", "sys_pll1_100m", }; + +static const char *imx8mp_dram_core_sels[] = {"dram_pll_out", "dram_alt_root", }; + + +static ulong imx8mp_clk_get_rate(struct clk *clk) +{ + struct clk *c; + int ret; + + debug("%s(#%lu)\n", __func__, clk->id); + + ret = clk_get_by_id(clk->id, &c); + if (ret) + return ret; + + return clk_get_rate(c); +} + +static ulong imx8mp_clk_set_rate(struct clk *clk, unsigned long rate) +{ + struct clk *c; + int ret; + + debug("%s(#%lu), rate: %lu\n", __func__, clk->id, rate); + + ret = clk_get_by_id(clk->id, &c); + if (ret) + return ret; + + return clk_set_rate(c, rate); +} + +static int __imx8mp_clk_enable(struct clk *clk, bool enable) +{ + struct clk *c; + int ret; + + debug("%s(#%lu) en: %d\n", __func__, clk->id, enable); + + ret = clk_get_by_id(clk->id, &c); + if (ret) + return ret; + + if (enable) + ret = clk_enable(c); + else + ret = clk_disable(c); + + return ret; +} + +static int imx8mp_clk_disable(struct clk *clk) +{ + return __imx8mp_clk_enable(clk, 0); +} + +static int imx8mp_clk_enable(struct clk *clk) +{ + return __imx8mp_clk_enable(clk, 1); +} + +static struct clk_ops imx8mp_clk_ops = { + .set_rate = imx8mp_clk_set_rate, + .get_rate = imx8mp_clk_get_rate, + .enable = imx8mp_clk_enable, + .disable = imx8mp_clk_disable, +}; + +static int imx8mp_clk_probe(struct udevice *dev) +{ + void __iomem *base; + + base = (void *)ANATOP_BASE_ADDR; + + clk_dm(IMX8MP_DRAM_PLL_REF_SEL, imx_clk_mux("dram_pll_ref_sel", base + 0x50, 0, 2, pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + clk_dm(IMX8MP_ARM_PLL_REF_SEL, imx_clk_mux("arm_pll_ref_sel", base + 0x84, 0, 2, pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + clk_dm(IMX8MP_SYS_PLL1_REF_SEL, imx_clk_mux("sys_pll1_ref_sel", base + 0x94, 0, 2, pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + clk_dm(IMX8MP_SYS_PLL2_REF_SEL, imx_clk_mux("sys_pll2_ref_sel", base + 0x104, 0, 2, pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + clk_dm(IMX8MP_SYS_PLL3_REF_SEL, imx_clk_mux("sys_pll3_ref_sel", base + 0x114, 0, 2, pll_ref_sels, ARRAY_SIZE(pll_ref_sels))); + + clk_dm(IMX8MP_DRAM_PLL, imx_clk_pll14xx("dram_pll", "dram_pll_ref_sel", base + 0x50, &imx8mp_dram_pll)); + clk_dm(IMX8MP_ARM_PLL, imx_clk_pll14xx("arm_pll", "arm_pll_ref_sel", base + 0x84, &imx8mp_arm_pll)); + clk_dm(IMX8MP_SYS_PLL1, imx_clk_pll14xx("sys_pll1", "sys_pll1_ref_sel", base + 0x94, &imx8mp_sys_pll)); + clk_dm(IMX8MP_SYS_PLL2, imx_clk_pll14xx("sys_pll2", "sys_pll2_ref_sel", base + 0x104, &imx8mp_sys_pll)); + clk_dm(IMX8MP_SYS_PLL3, imx_clk_pll14xx("sys_pll3", "sys_pll3_ref_sel", base + 0x114, &imx8mp_sys_pll)); + + clk_dm(IMX8MP_DRAM_PLL_BYPASS, imx_clk_mux_flags("dram_pll_bypass", base + 0x50, 4, 1, dram_pll_bypass_sels, ARRAY_SIZE(dram_pll_bypass_sels), CLK_SET_RATE_PARENT)); + clk_dm(IMX8MP_ARM_PLL_BYPASS, imx_clk_mux_flags("arm_pll_bypass", base + 0x84, 4, 1, arm_pll_bypass_sels, ARRAY_SIZE(arm_pll_bypass_sels), CLK_SET_RATE_PARENT)); + clk_dm(IMX8MP_SYS_PLL1_BYPASS, imx_clk_mux_flags("sys_pll1_bypass", base + 0x94, 4, 1, sys_pll1_bypass_sels, ARRAY_SIZE(sys_pll1_bypass_sels), CLK_SET_RATE_PARENT)); + clk_dm(IMX8MP_SYS_PLL2_BYPASS, imx_clk_mux_flags("sys_pll2_bypass", base + 0x104, 4, 1, sys_pll2_bypass_sels, ARRAY_SIZE(sys_pll2_bypass_sels), CLK_SET_RATE_PARENT)); + clk_dm(IMX8MP_SYS_PLL3_BYPASS, imx_clk_mux_flags("sys_pll3_bypass", base + 0x114, 4, 1, sys_pll3_bypass_sels, ARRAY_SIZE(sys_pll3_bypass_sels), CLK_SET_RATE_PARENT)); + + clk_dm(IMX8MP_DRAM_PLL_OUT, imx_clk_gate("dram_pll_out", "dram_pll_bypass", base + 0x50, 13)); + clk_dm(IMX8MP_ARM_PLL_OUT, imx_clk_gate("arm_pll_out", "arm_pll_bypass", base + 0x84, 11)); + clk_dm(IMX8MP_SYS_PLL1_OUT, imx_clk_gate("sys_pll1_out", "sys_pll1_bypass", base + 0x94, 11)); + clk_dm(IMX8MP_SYS_PLL2_OUT, imx_clk_gate("sys_pll2_out", "sys_pll2_bypass", base + 0x104, 11)); + clk_dm(IMX8MP_SYS_PLL3_OUT, imx_clk_gate("sys_pll3_out", "sys_pll3_bypass", base + 0x114, 11)); + + clk_dm(IMX8MP_SYS_PLL1_40M, imx_clk_fixed_factor("sys_pll1_40m", "sys_pll1_out", 1, 20)); + clk_dm(IMX8MP_SYS_PLL1_80M, imx_clk_fixed_factor("sys_pll1_80m", "sys_pll1_out", 1, 10)); + clk_dm(IMX8MP_SYS_PLL1_100M, imx_clk_fixed_factor("sys_pll1_100m", "sys_pll1_out", 1, 8)); + clk_dm(IMX8MP_SYS_PLL1_133M, imx_clk_fixed_factor("sys_pll1_133m", "sys_pll1_out", 1, 6)); + clk_dm(IMX8MP_SYS_PLL1_160M, imx_clk_fixed_factor("sys_pll1_160m", "sys_pll1_out", 1, 5)); + clk_dm(IMX8MP_SYS_PLL1_200M, imx_clk_fixed_factor("sys_pll1_200m", "sys_pll1_out", 1, 4)); + clk_dm(IMX8MP_SYS_PLL1_266M, imx_clk_fixed_factor("sys_pll1_266m", "sys_pll1_out", 1, 3)); + clk_dm(IMX8MP_SYS_PLL1_400M, imx_clk_fixed_factor("sys_pll1_400m", "sys_pll1_out", 1, 2)); + clk_dm(IMX8MP_SYS_PLL1_800M, imx_clk_fixed_factor("sys_pll1_800m", "sys_pll1_out", 1, 1)); + + clk_dm(IMX8MP_SYS_PLL2_50M, imx_clk_fixed_factor("sys_pll2_50m", "sys_pll2_out", 1, 20)); + clk_dm(IMX8MP_SYS_PLL2_100M, imx_clk_fixed_factor("sys_pll2_100m", "sys_pll2_out", 1, 10)); + clk_dm(IMX8MP_SYS_PLL2_125M, imx_clk_fixed_factor("sys_pll2_125m", "sys_pll2_out", 1, 8)); + clk_dm(IMX8MP_SYS_PLL2_166M, imx_clk_fixed_factor("sys_pll2_166m", "sys_pll2_out", 1, 6)); + clk_dm(IMX8MP_SYS_PLL2_200M, imx_clk_fixed_factor("sys_pll2_200m", "sys_pll2_out", 1, 5)); + clk_dm(IMX8MP_SYS_PLL2_250M, imx_clk_fixed_factor("sys_pll2_250m", "sys_pll2_out", 1, 4)); + clk_dm(IMX8MP_SYS_PLL2_333M, imx_clk_fixed_factor("sys_pll2_333m", "sys_pll2_out", 1, 3)); + clk_dm(IMX8MP_SYS_PLL2_500M, imx_clk_fixed_factor("sys_pll2_500m", "sys_pll2_out", 1, 2)); + clk_dm(IMX8MP_SYS_PLL2_1000M, imx_clk_fixed_factor("sys_pll2_1000m", "sys_pll2_out", 1, 1)); + + base = dev_read_addr_ptr(dev); + if (base == (void *)FDT_ADDR_T_NONE) + return -EINVAL; + + clk_dm(IMX8MP_CLK_A53_SRC, imx_clk_mux2("arm_a53_src", base + 0x8000, 24, 3, imx8mp_a53_sels, ARRAY_SIZE(imx8mp_a53_sels))); + clk_dm(IMX8MP_CLK_A53_CG, imx_clk_gate3("arm_a53_cg", "arm_a53_src", base + 0x8000, 28)); + clk_dm(IMX8MP_CLK_A53_DIV, imx_clk_divider2("arm_a53_div", "arm_a53_cg", base + 0x8000, 0, 3)); + + clk_dm(IMX8MP_CLK_MAIN_AXI, imx8m_clk_composite_critical("main_axi", imx8mp_main_axi_sels, base + 0x8800)); + clk_dm(IMX8MP_CLK_NAND_USDHC_BUS, imx8m_clk_composite_critical("nand_usdhc_bus", imx8mp_nand_usdhc_sels, base + 0x8900)); + clk_dm(IMX8MP_CLK_NOC, imx8m_clk_composite_critical("noc", imx8mp_noc_sels, base + 0x8d00)); + clk_dm(IMX8MP_CLK_NOC_IO, imx8m_clk_composite_critical("noc_io", imx8mp_noc_io_sels, base + 0x8d80)); + + clk_dm(IMX8MP_CLK_AHB, imx8m_clk_composite_critical("ahb_root", imx8mp_ahb_sels, base + 0x9000)); + + clk_dm(IMX8MP_CLK_IPG_ROOT, imx_clk_divider2("ipg_root", "ahb_root", base + 0x9080, 0, 1)); + + clk_dm(IMX8MP_CLK_DRAM_ALT, imx8m_clk_composite("dram_alt", imx8mp_dram_alt_sels, base + 0xa000)); + clk_dm(IMX8MP_CLK_DRAM_APB, imx8m_clk_composite_critical("dram_apb", imx8mp_dram_apb_sels, base + 0xa080)); + clk_dm(IMX8MP_CLK_I2C5, imx8m_clk_composite("i2c5", imx8mp_i2c5_sels, base + 0xa480)); + clk_dm(IMX8MP_CLK_I2C6, imx8m_clk_composite("i2c6", imx8mp_i2c6_sels, base + 0xa500)); + clk_dm(IMX8MP_CLK_USDHC1, imx8m_clk_composite("usdhc1", imx8mp_usdhc1_sels, base + 0xac00)); + clk_dm(IMX8MP_CLK_USDHC2, imx8m_clk_composite("usdhc2", imx8mp_usdhc2_sels, base + 0xac80)); + clk_dm(IMX8MP_CLK_I2C1, imx8m_clk_composite("i2c1", imx8mp_i2c1_sels, base + 0xad00)); + clk_dm(IMX8MP_CLK_I2C2, imx8m_clk_composite("i2c2", imx8mp_i2c2_sels, base + 0xad80)); + clk_dm(IMX8MP_CLK_I2C3, imx8m_clk_composite("i2c3", imx8mp_i2c3_sels, base + 0xae00)); + clk_dm(IMX8MP_CLK_I2C4, imx8m_clk_composite("i2c4", imx8mp_i2c4_sels, base + 0xae80)); + + clk_dm(IMX8MP_CLK_UART1, imx8m_clk_composite("uart1", imx8mp_uart1_sels, base + 0xaf00)); + clk_dm(IMX8MP_CLK_UART2, imx8m_clk_composite("uart2", imx8mp_uart2_sels, base + 0xaf80)); + clk_dm(IMX8MP_CLK_UART3, imx8m_clk_composite("uart3", imx8mp_uart3_sels, base + 0xb000)); + clk_dm(IMX8MP_CLK_UART4, imx8m_clk_composite("uart4", imx8mp_uart4_sels, base + 0xb080)); + clk_dm(IMX8MP_CLK_GIC, imx8m_clk_composite_critical("gic", imx8mp_gic_sels, base + 0xb200)); + + clk_dm(IMX8MP_CLK_WDOG, imx8m_clk_composite("wdog", imx8mp_wdog_sels, base + 0xb900)); + clk_dm(IMX8MP_CLK_USDHC3, imx8m_clk_composite("usdhc3", imx8mp_usdhc3_sels, base + 0xbc80)); + + clk_dm(IMX8MP_CLK_DRAM_ALT_ROOT, imx_clk_fixed_factor("dram_alt_root", "dram_alt", 1, 4)); + clk_dm(IMX8MP_CLK_DRAM_CORE, imx_clk_mux2_flags("dram_core_clk", base + 0x9800, 24, 1, imx8mp_dram_core_sels, ARRAY_SIZE(imx8mp_dram_core_sels), CLK_IS_CRITICAL)); + + clk_dm(IMX8MP_CLK_DRAM1_ROOT, imx_clk_gate4_flags("dram1_root_clk", "dram_core_clk", base + 0x4050, 0, CLK_IS_CRITICAL)); + clk_dm(IMX8MP_CLK_GPIO1_ROOT, imx_clk_gate4("gpio1_root_clk", "ipg_root", base + 0x40b0, 0)); + clk_dm(IMX8MP_CLK_GPIO2_ROOT, imx_clk_gate4("gpio2_root_clk", "ipg_root", base + 0x40c0, 0)); + clk_dm(IMX8MP_CLK_GPIO3_ROOT, imx_clk_gate4("gpio3_root_clk", "ipg_root", base + 0x40d0, 0)); + clk_dm(IMX8MP_CLK_GPIO4_ROOT, imx_clk_gate4("gpio4_root_clk", "ipg_root", base + 0x40e0, 0)); + clk_dm(IMX8MP_CLK_GPIO5_ROOT, imx_clk_gate4("gpio5_root_clk", "ipg_root", base + 0x40f0, 0)); + clk_dm(IMX8MP_CLK_I2C1_ROOT, imx_clk_gate4("i2c1_root_clk", "i2c1", base + 0x4170, 0)); + clk_dm(IMX8MP_CLK_I2C2_ROOT, imx_clk_gate4("i2c2_root_clk", "i2c2", base + 0x4180, 0)); + clk_dm(IMX8MP_CLK_I2C3_ROOT, imx_clk_gate4("i2c3_root_clk", "i2c3", base + 0x4190, 0)); + clk_dm(IMX8MP_CLK_I2C4_ROOT, imx_clk_gate4("i2c4_root_clk", "i2c4", base + 0x41a0, 0)); + clk_dm(IMX8MP_CLK_I2C5_ROOT, imx_clk_gate2("i2c5_root_clk", "i2c5", base + 0x4330, 0)); + clk_dm(IMX8MP_CLK_I2C6_ROOT, imx_clk_gate2("i2c6_root_clk", "i2c6", base + 0x4340, 0)); + clk_dm(IMX8MP_CLK_UART1_ROOT, imx_clk_gate4("uart1_root_clk", "uart1", base + 0x4490, 0)); + clk_dm(IMX8MP_CLK_UART2_ROOT, imx_clk_gate4("uart2_root_clk", "uart2", base + 0x44a0, 0)); + clk_dm(IMX8MP_CLK_UART3_ROOT, imx_clk_gate4("uart3_root_clk", "uart3", base + 0x44b0, 0)); + clk_dm(IMX8MP_CLK_UART4_ROOT, imx_clk_gate4("uart4_root_clk", "uart4", base + 0x44c0, 0)); + clk_dm(IMX8MP_CLK_USDHC1_ROOT, imx_clk_gate4("usdhc1_root_clk", "usdhc1", base + 0x4510, 0)); + clk_dm(IMX8MP_CLK_USDHC2_ROOT, imx_clk_gate4("usdhc2_root_clk", "usdhc2", base + 0x4520, 0)); + clk_dm(IMX8MP_CLK_WDOG1_ROOT, imx_clk_gate4("wdog1_root_clk", "wdog", base + 0x4530, 0)); + clk_dm(IMX8MP_CLK_WDOG2_ROOT, imx_clk_gate4("wdog2_root_clk", "wdog", base + 0x4540, 0)); + clk_dm(IMX8MP_CLK_WDOG3_ROOT, imx_clk_gate4("wdog3_root_clk", "wdog", base + 0x4550, 0)); + + clk_dm(IMX8MP_CLK_USDHC3_ROOT, imx_clk_gate4("usdhc3_root_clk", "usdhc3", base + 0x45e0, 0)); + + return 0; +} + +static const struct udevice_id imx8mp_clk_ids[] = { + { .compatible = "fsl,imx8mp-ccm" }, + { }, +}; + +U_BOOT_DRIVER(imx8mp_clk) = { + .name = "clk_imx8mp", + .id = UCLASS_CLK, + .of_match = imx8mp_clk_ids, + .ops = &imx8mp_clk_ops, + .probe = imx8mp_clk_probe, + .flags = DM_FLAG_PRE_RELOC, +};
Add imximage-8mp-lpddr4.cfg for imximage usage, almost same as i.MX8MN ddr4 cfg, but with different ddr firmware
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/imximage-8mp-lpddr4.cfg | 17 +++++++++++++++++ 1 file changed, 17 insertions(+) create mode 100644 arch/arm/mach-imx/imx8m/imximage-8mp-lpddr4.cfg
diff --git a/arch/arm/mach-imx/imx8m/imximage-8mp-lpddr4.cfg b/arch/arm/mach-imx/imx8m/imximage-8mp-lpddr4.cfg new file mode 100644 index 0000000000..586a5ff306 --- /dev/null +++ b/arch/arm/mach-imx/imx8m/imximage-8mp-lpddr4.cfg @@ -0,0 +1,17 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + */ + +#define __ASSEMBLY__ + +FIT +ROM_VERSION v2 +BOOT_FROM sd +LOADER spl/u-boot-spl-ddr.bin 0x920000 +SECOND_LOADER u-boot.itb 0x40200000 0x60000 + +DDR_FW lpddr4_pmu_train_1d_imem.bin +DDR_FW lpddr4_pmu_train_1d_dmem.bin +DDR_FW lpddr4_pmu_train_2d_imem.bin +DDR_FW lpddr4_pmu_train_2d_dmem.bin
Add basic i.MX8MP EVK board support
U-Boot SPL 2020.01-rc4-00388-gb1bf40c0ae-dirty (Dec 30 2019 - 17:55:33 +0800) power_pca9450b_init DDRINFO: start DRAM init DDRINFO:ddrphy calibration done DDRINFO: ddrmix config done Normal Boot Failed to find clock node. Check device tree WDT: Not found! Trying to boot from BOOTROM image offset 0x8000, pagesize 0x200, ivt offset 0x0
U-Boot 2020.01-rc4-00388-gb1bf40c0ae-dirty (Dec 30 2019 - 17:55:33 +0800)
CPU: Freescale i.MX8MP rev1.0 at 1000 MHz Reset cause: POR Model: NXP i.MX8MPlus EVK board DRAM: 6 GiB MMC: FSL_SDHC: 1, FSL_SDHC: 2 Loading Environment from MMC... OK In: serial Out: serial Err: serial Net: No ethernet found. Hit any key to stop autoboot: 0 u-boot=> mmc list FSL_SDHC: 1 (SD) FSL_SDHC: 2
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx8mp-evk-u-boot.dtsi | 121 ++ arch/arm/dts/imx8mp-evk.dts | 231 ++++ arch/arm/mach-imx/imx8m/Kconfig | 7 + board/freescale/imx8mp_evk/Kconfig | 14 + board/freescale/imx8mp_evk/Makefile | 12 + board/freescale/imx8mp_evk/imx8mp_evk.c | 94 ++ board/freescale/imx8mp_evk/lpddr4_timing.c | 1847 ++++++++++++++++++++++++++++ board/freescale/imx8mp_evk/spl.c | 158 +++ configs/imx8mp_evk_defconfig | 84 ++ include/configs/imx8mp_evk.h | 165 +++ 11 files changed, 2735 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx8mp-evk-u-boot.dtsi create mode 100644 arch/arm/dts/imx8mp-evk.dts create mode 100644 board/freescale/imx8mp_evk/Kconfig create mode 100644 board/freescale/imx8mp_evk/Makefile create mode 100644 board/freescale/imx8mp_evk/imx8mp_evk.c create mode 100644 board/freescale/imx8mp_evk/lpddr4_timing.c create mode 100644 board/freescale/imx8mp_evk/spl.c create mode 100644 configs/imx8mp_evk_defconfig create mode 100644 include/configs/imx8mp_evk.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 93deb266ea..212de794f5 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -700,7 +700,8 @@ dtb-$(CONFIG_ARCH_IMX8) += \ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mm-evk.dtb \ imx8mn-ddr4-evk.dtb \ - imx8mq-evk.dtb + imx8mq-evk.dtb \ + imx8mp-evk.dtb
dtb-$(CONFIG_RCAR_GEN2) += \ r8a7790-lager-u-boot.dtb \ diff --git a/arch/arm/dts/imx8mp-evk-u-boot.dtsi b/arch/arm/dts/imx8mp-evk-u-boot.dtsi new file mode 100644 index 0000000000..4675ada0a0 --- /dev/null +++ b/arch/arm/dts/imx8mp-evk-u-boot.dtsi @@ -0,0 +1,121 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + */ + +&{/soc@0} { + u-boot,dm-pre-reloc; + u-boot,dm-spl; +}; + +&clk { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&osc_32k { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&osc_24m { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&aips1 { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&aips2 { + u-boot,dm-spl; +}; + +&aips3 { + u-boot,dm-spl; +}; + +&iomuxc { + u-boot,dm-spl; +}; + +®_usdhc2_vmmc { + u-boot,dm-spl; +}; + +&pinctrl_uart2 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2_gpio { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3 { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&uart2 { + u-boot,dm-spl; +}; + +&i2c1 { + u-boot,dm-spl; +}; + +&i2c2 { + u-boot,dm-spl; +}; + +&i2c3 { + u-boot,dm-spl; +}; + +&i2c4 { + u-boot,dm-spl; +}; + +&i2c5 { + u-boot,dm-spl; +}; + +&i2c6 { + u-boot,dm-spl; +}; + +&usdhc1 { + u-boot,dm-spl; +}; + +&usdhc2 { + u-boot,dm-spl; +}; + +&usdhc3 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mp-evk.dts b/arch/arm/dts/imx8mp-evk.dts new file mode 100644 index 0000000000..6df3beb92d --- /dev/null +++ b/arch/arm/dts/imx8mp-evk.dts @@ -0,0 +1,231 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2019 NXP + */ + +/dts-v1/; + +#include "imx8mp.dtsi" + +/ { + model = "NXP i.MX8MPlus EVK board"; + compatible = "fsl,imx8mp-evk", "fsl,imx8mp"; + + chosen { + stdout-path = &uart2; + }; + + memory@40000000 { + device_type = "memory"; + reg = <0x0 0x40000000 0 0xc0000000>, + <0x1 0x00000000 0 0xc0000000>; + }; + + reg_usdhc2_vmmc: regulator-usdhc2 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; + regulator-name = "VSD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; +}; + +&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy1>; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy1: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + eee-broken-1000t; + reset-gpios = <&gpio4 2 GPIO_ACTIVE_LOW>; + }; + }; +}; + +&snvs_pwrkey { + status = "okay"; +}; + +&uart2 { + /* console */ + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +&usdhc2 { + assigned-clocks = <&clk IMX8MP_CLK_USDHC2>; + assigned-clock-rates = <400000000>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; + cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>; + vmmc-supply = <®_usdhc2_vmmc>; + bus-width = <4>; + status = "okay"; +}; + +&usdhc3 { + assigned-clocks = <&clk IMX8MP_CLK_USDHC3>; + assigned-clock-rates = <400000000>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + + pinctrl_fec: fecgrp { + fsl,pins = < + MX8MP_IOMUXC_SAI1_RXD2__ENET1_MDC 0x3 + MX8MP_IOMUXC_SAI1_RXD3__ENET1_MDIO 0x3 + MX8MP_IOMUXC_SAI1_RXD4__ENET1_RGMII_RD0 0x91 + MX8MP_IOMUXC_SAI1_RXD5__ENET1_RGMII_RD1 0x91 + MX8MP_IOMUXC_SAI1_RXD6__ENET1_RGMII_RD2 0x91 + MX8MP_IOMUXC_SAI1_RXD7__ENET1_RGMII_RD3 0x91 + MX8MP_IOMUXC_SAI1_TXC__ENET1_RGMII_RXC 0x91 + MX8MP_IOMUXC_SAI1_TXFS__ENET1_RGMII_RX_CTL 0x91 + MX8MP_IOMUXC_SAI1_TXD0__ENET1_RGMII_TD0 0x1f + MX8MP_IOMUXC_SAI1_TXD1__ENET1_RGMII_TD1 0x1f + MX8MP_IOMUXC_SAI1_TXD2__ENET1_RGMII_TD2 0x1f + MX8MP_IOMUXC_SAI1_TXD3__ENET1_RGMII_TD3 0x1f + MX8MP_IOMUXC_SAI1_TXD4__ENET1_RGMII_TX_CTL 0x1f + MX8MP_IOMUXC_SAI1_TXD5__ENET1_RGMII_TXC 0x1f + MX8MP_IOMUXC_SAI1_RXD0__GPIO4_IO02 0x19 + >; + }; + + pinctrl_reg_usdhc2_vmmc: regusdhc2vmmc { + fsl,pins = < + MX8MP_IOMUXC_SD2_RESET_B__GPIO2_IO19 0x41 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MP_IOMUXC_UART2_RXD__UART2_DCE_RX 0x49 + MX8MP_IOMUXC_UART2_TXD__UART2_DCE_TX 0x49 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x190 + MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d0 + MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d0 + MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d0 + MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d0 + MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d0 + MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2grp-100mhz { + fsl,pins = < + MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x194 + MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d4 + MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d4 + MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d4 + MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d4 + MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d4 + MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2grp-200mhz { + fsl,pins = < + MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x196 + MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d6 + MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d6 + MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d6 + MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d6 + MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d6 + MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1 + >; + }; + + pinctrl_usdhc2_gpio: usdhc2grp-gpio { + fsl,pins = < + MX8MP_IOMUXC_SD2_CD_B__GPIO2_IO12 0x1c4 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x190 + MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d0 + MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d0 + MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d0 + MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d0 + MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d0 + MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d0 + MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d0 + MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d0 + MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d0 + MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x190 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3grp-100mhz { + fsl,pins = < + MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x194 + MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d4 + MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d4 + MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d4 + MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d4 + MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d4 + MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d4 + MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d4 + MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d4 + MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d4 + MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x194 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3grp-200mhz { + fsl,pins = < + MX8MP_IOMUXC_NAND_WE_B__USDHC3_CLK 0x196 + MX8MP_IOMUXC_NAND_WP_B__USDHC3_CMD 0x1d6 + MX8MP_IOMUXC_NAND_DATA04__USDHC3_DATA0 0x1d6 + MX8MP_IOMUXC_NAND_DATA05__USDHC3_DATA1 0x1d6 + MX8MP_IOMUXC_NAND_DATA06__USDHC3_DATA2 0x1d6 + MX8MP_IOMUXC_NAND_DATA07__USDHC3_DATA3 0x1d6 + MX8MP_IOMUXC_NAND_RE_B__USDHC3_DATA4 0x1d6 + MX8MP_IOMUXC_NAND_CE2_B__USDHC3_DATA5 0x1d6 + MX8MP_IOMUXC_NAND_CE3_B__USDHC3_DATA6 0x1d6 + MX8MP_IOMUXC_NAND_CLE__USDHC3_DATA7 0x1d6 + MX8MP_IOMUXC_NAND_CE1_B__USDHC3_STROBE 0x196 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX8MP_IOMUXC_GPIO1_IO02__WDOG1_WDOG_B 0xc6 + >; + }; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 251feb2074..72affb1bdc 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -44,10 +44,17 @@ config TARGET_IMX8MN_EVK select SUPPORT_SPL select IMX8M_DDR4
+config TARGET_IMX8MP_EVK + bool "imx8mp LPDDR4 EVK board" + select IMX8MP + select SUPPORT_SPL + select IMX8M_LPDDR4 + endchoice
source "board/freescale/imx8mq_evk/Kconfig" source "board/freescale/imx8mm_evk/Kconfig" source "board/freescale/imx8mn_evk/Kconfig" +source "board/freescale/imx8mp_evk/Kconfig"
endif diff --git a/board/freescale/imx8mp_evk/Kconfig b/board/freescale/imx8mp_evk/Kconfig new file mode 100644 index 0000000000..49bb29a45d --- /dev/null +++ b/board/freescale/imx8mp_evk/Kconfig @@ -0,0 +1,14 @@ +if TARGET_IMX8MP_EVK + +config SYS_BOARD + default "imx8mp_evk" + +config SYS_VENDOR + default "freescale" + +config SYS_CONFIG_NAME + default "imx8mp_evk" + +source "board/freescale/common/Kconfig" + +endif diff --git a/board/freescale/imx8mp_evk/Makefile b/board/freescale/imx8mp_evk/Makefile new file mode 100644 index 0000000000..106bf9a1ed --- /dev/null +++ b/board/freescale/imx8mp_evk/Makefile @@ -0,0 +1,12 @@ +# +# Copyright 2019 NXP +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += imx8mp_evk.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing.o +endif diff --git a/board/freescale/imx8mp_evk/imx8mp_evk.c b/board/freescale/imx8mp_evk/imx8mp_evk.c new file mode 100644 index 0000000000..f004af681b --- /dev/null +++ b/board/freescale/imx8mp_evk/imx8mp_evk.c @@ -0,0 +1,94 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + */ + +#include <common.h> +#include <errno.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm-generic/gpio.h> +#include <asm/arch/imx8mp_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) + +static iomux_v3_cfg_t const uart_pads[] = { + MX8MP_PAD_UART2_RXD__UART2_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX8MP_PAD_UART2_TXD__UART2_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const wdog_pads[] = { + MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), +}; + +int board_early_init_f(void) +{ + struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; + + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); + + set_wdog_reset(wdog); + + imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); + + return 0; +} + +int dram_init(void) +{ + /* rom_pointer[1] contains the size of TEE occupies */ + if (rom_pointer[1]) + gd->ram_size = PHYS_SDRAM_SIZE - rom_pointer[1]; + else + gd->ram_size = PHYS_SDRAM_SIZE; + +#if CONFIG_NR_DRAM_BANKS > 1 + gd->ram_size += PHYS_SDRAM_2_SIZE; +#endif + + return 0; +} + +int dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + if (rom_pointer[1]) + + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE - rom_pointer[1]; + else + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + +#if CONFIG_NR_DRAM_BANKS > 1 + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; +#endif + + return 0; +} + +phys_size_t get_effective_memsize(void) +{ + if (rom_pointer[1]) + return (PHYS_SDRAM_SIZE - rom_pointer[1]); + else + return PHYS_SDRAM_SIZE; +} + +int board_init(void) +{ + return 0; +} + +int board_late_init(void) +{ +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + env_set("board_name", "EVK"); + env_set("board_rev", "iMX8MP"); +#endif + + return 0; +} diff --git a/board/freescale/imx8mp_evk/lpddr4_timing.c b/board/freescale/imx8mp_evk/lpddr4_timing.c new file mode 100644 index 0000000000..14542490bc --- /dev/null +++ b/board/freescale/imx8mp_evk/lpddr4_timing.c @@ -0,0 +1,1847 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x1 }, + { 0x3d400000, 0xa3080020 }, + { 0x3d400020, 0x323 }, + { 0x3d400024, 0x1e84800 }, + { 0x3d400064, 0x7a0118 }, + { 0x3d4000d0, 0xc00307a3 }, + { 0x3d4000d4, 0xc50000 }, + { 0x3d4000dc, 0xf4003f }, + { 0x3d4000e0, 0x330000 }, + { 0x3d4000e8, 0x460048 }, + { 0x3d4000ec, 0x150048 }, + { 0x3d400100, 0x2028222a }, + { 0x3d400104, 0x807bf }, + { 0x3d40010c, 0xe0e000 }, + { 0x3d400110, 0x12040a12 }, + { 0x3d400114, 0x2050f0f }, + { 0x3d400118, 0x1010009 }, + { 0x3d40011c, 0x501 }, + { 0x3d400130, 0x20800 }, + { 0x3d400134, 0xe100002 }, + { 0x3d400138, 0x120 }, + { 0x3d400144, 0xc80064 }, + { 0x3d400180, 0x3e8001e }, + { 0x3d400184, 0x3207a12 }, + { 0x3d400188, 0x0 }, + { 0x3d400190, 0x49f820e }, + { 0x3d400194, 0x80303 }, + { 0x3d4001b4, 0x1f0e }, + { 0x3d4001a0, 0xe0400018 }, + { 0x3d4001a4, 0xdf00e4 }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001c0, 0x1 }, + { 0x3d4001c4, 0x1 }, + { 0x3d4000f4, 0xc99 }, + { 0x3d400108, 0x9121c1c }, + { 0x3d400200, 0x16 }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0x68070707 }, + { 0x3d40021c, 0xf08 }, + { 0x3d400250, 0x29001701 }, + { 0x3d400254, 0x2c }, + { 0x3d40025c, 0x4000030 }, + { 0x3d400264, 0x900093e7 }, + { 0x3d40026c, 0x2005574 }, + { 0x3d400400, 0x111 }, + { 0x3d400408, 0x72ff }, + { 0x3d400494, 0x2100e07 }, + { 0x3d400498, 0x620096 }, + { 0x3d40049c, 0x1100e07 }, + { 0x3d4004a0, 0xc8012c }, + { 0x3d402020, 0x21 }, + { 0x3d402024, 0x7d00 }, + { 0x3d402050, 0x20d040 }, + { 0x3d402064, 0xc001c }, + { 0x3d4020dc, 0x840000 }, + { 0x3d4020e0, 0x310000 }, + { 0x3d4020e8, 0x66004d }, + { 0x3d4020ec, 0x16004d }, + { 0x3d402100, 0xa040305 }, + { 0x3d402104, 0x30407 }, + { 0x3d402108, 0x203060b }, + { 0x3d40210c, 0x505000 }, + { 0x3d402110, 0x2040202 }, + { 0x3d402114, 0x2030202 }, + { 0x3d402118, 0x1010004 }, + { 0x3d40211c, 0x301 }, + { 0x3d402130, 0x20300 }, + { 0x3d402134, 0xa100002 }, + { 0x3d402138, 0x1d }, + { 0x3d402144, 0x14000a }, + { 0x3d402180, 0x640004 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x80303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d4020f4, 0xc99 }, + { 0x3d403020, 0x21 }, + { 0x3d403024, 0x30d400 }, + { 0x3d403050, 0x20d040 }, + { 0x3d403064, 0x30007 }, + { 0x3d4030dc, 0x840000 }, + { 0x3d4030e0, 0x310000 }, + { 0x3d4030e8, 0x66004d }, + { 0x3d4030ec, 0x16004d }, + { 0x3d403100, 0xa010102 }, + { 0x3d403104, 0x30404 }, + { 0x3d403108, 0x203060b }, + { 0x3d40310c, 0x505000 }, + { 0x3d403110, 0x2040202 }, + { 0x3d403114, 0x2030202 }, + { 0x3d403118, 0x1010004 }, + { 0x3d40311c, 0x301 }, + { 0x3d403130, 0x20300 }, + { 0x3d403134, 0xa100002 }, + { 0x3d403138, 0x8 }, + { 0x3d403144, 0x50003 }, + { 0x3d403180, 0x190004 }, + { 0x3d403190, 0x3818200 }, + { 0x3d403194, 0x80303 }, + { 0x3d4031b4, 0x100 }, + { 0x3d400028, 0x0 }, +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x0 }, + { 0x100a1, 0x1 }, + { 0x100a2, 0x2 }, + { 0x100a3, 0x3 }, + { 0x100a4, 0x4 }, + { 0x100a5, 0x5 }, + { 0x100a6, 0x6 }, + { 0x100a7, 0x7 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x1 }, + { 0x110a2, 0x3 }, + { 0x110a3, 0x4 }, + { 0x110a4, 0x5 }, + { 0x110a5, 0x2 }, + { 0x110a6, 0x7 }, + { 0x110a7, 0x6 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x1 }, + { 0x120a2, 0x3 }, + { 0x120a3, 0x2 }, + { 0x120a4, 0x5 }, + { 0x120a5, 0x4 }, + { 0x120a6, 0x7 }, + { 0x120a7, 0x6 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x1 }, + { 0x130a2, 0x2 }, + { 0x130a3, 0x3 }, + { 0x130a4, 0x4 }, + { 0x130a5, 0x5 }, + { 0x130a6, 0x6 }, + { 0x130a7, 0x7 }, + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x18 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x20024, 0x1e3 }, + { 0x2003a, 0x2 }, + { 0x120024, 0x1e3 }, + { 0x2003a, 0x2 }, + { 0x220024, 0x1e3 }, + { 0x2003a, 0x2 }, + { 0x20056, 0x3 }, + { 0x120056, 0x3 }, + { 0x220056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + { 0x10049, 0xeba }, + { 0x10149, 0xeba }, + { 0x11049, 0xeba }, + { 0x11149, 0xeba }, + { 0x12049, 0xeba }, + { 0x12149, 0xeba }, + { 0x13049, 0xeba }, + { 0x13149, 0xeba }, + { 0x110049, 0xeba }, + { 0x110149, 0xeba }, + { 0x111049, 0xeba }, + { 0x111149, 0xeba }, + { 0x112049, 0xeba }, + { 0x112149, 0xeba }, + { 0x113049, 0xeba }, + { 0x113149, 0xeba }, + { 0x210049, 0xeba }, + { 0x210149, 0xeba }, + { 0x211049, 0xeba }, + { 0x211149, 0xeba }, + { 0x212049, 0xeba }, + { 0x212149, 0xeba }, + { 0x213049, 0xeba }, + { 0x213149, 0xeba }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x3e8 }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0x104 }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0x104 }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0x104 }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + { 0x2007d, 0x212 }, + { 0x12007d, 0x212 }, + { 0x22007d, 0x212 }, + { 0x2007c, 0x61 }, + { 0x12007c, 0x61 }, + { 0x22007c, 0x61 }, + { 0x1004a, 0x500 }, + { 0x1104a, 0x500 }, + { 0x1204a, 0x500 }, + { 0x1304a, 0x500 }, + { 0x2002c, 0x0 }, +}; + +/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xfa0 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x131f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x310 }, + { 0x54019, 0x3ff4 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4866 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x3ff4 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4866 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0xf400 }, + { 0x54033, 0x333f }, + { 0x54034, 0x6600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1600 }, + { 0x54038, 0xf400 }, + { 0x54039, 0x333f }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x310 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4846 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x15 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4846 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x15 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3300 }, + { 0x54034, 0x4600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1500 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3300 }, + { 0x5403a, 0x4600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1500 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400f, 0x100 }, + { 0x54012, 0x310 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4846 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x15 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4846 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x15 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3300 }, + { 0x54034, 0x4600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1500 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3300 }, + { 0x5403a, 0x4600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1500 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xfa0 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x14 }, + { 0x54008, 0x61 }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400d, 0x100 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x1f7f }, + { 0x54012, 0x310 }, + { 0x54019, 0x3ff4 }, + { 0x5401a, 0x33 }, + { 0x5401b, 0x4866 }, + { 0x5401c, 0x4800 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x3ff4 }, + { 0x54020, 0x33 }, + { 0x54021, 0x4866 }, + { 0x54022, 0x4800 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0xf400 }, + { 0x54033, 0x333f }, + { 0x54034, 0x6600 }, + { 0x54035, 0x48 }, + { 0x54036, 0x48 }, + { 0x54037, 0x1600 }, + { 0x54038, 0xf400 }, + { 0x54039, 0x333f }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x48 }, + { 0x5403c, 0x48 }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xb }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x633 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x633 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x633 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x633 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x633 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x633 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x633 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x633 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x633 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x633 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x633 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x633 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x633 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xb }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x1 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x625 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x625 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a4, 0x0 }, + { 0x900a5, 0x790 }, + { 0x900a6, 0x11a }, + { 0x900a7, 0x8 }, + { 0x900a8, 0x7aa }, + { 0x900a9, 0x2a }, + { 0x900aa, 0x10 }, + { 0x900ab, 0x7b2 }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x0 }, + { 0x900ae, 0x7c8 }, + { 0x900af, 0x109 }, + { 0x900b0, 0x10 }, + { 0x900b1, 0x10 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x1 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xd }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x0 }, + { 0x90159, 0x400 }, + { 0x9015a, 0x10e }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x10c }, + { 0x90164, 0x8 }, + { 0x90165, 0x7c8 }, + { 0x90166, 0x101 }, + { 0x90167, 0x8 }, + { 0x90168, 0x448 }, + { 0x90169, 0x109 }, + { 0x9016a, 0xf }, + { 0x9016b, 0x7c0 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0x0 }, + { 0x9016e, 0xe8 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x47 }, + { 0x90171, 0x630 }, + { 0x90172, 0x109 }, + { 0x90173, 0x8 }, + { 0x90174, 0x618 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0xe0 }, + { 0x90178, 0x109 }, + { 0x90179, 0x0 }, + { 0x9017a, 0x7c8 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x8 }, + { 0x9017d, 0x8140 }, + { 0x9017e, 0x10c }, + { 0x9017f, 0x0 }, + { 0x90180, 0x478 }, + { 0x90181, 0x109 }, + { 0x90182, 0x0 }, + { 0x90183, 0x1 }, + { 0x90184, 0x8 }, + { 0x90185, 0x8 }, + { 0x90186, 0x4 }, + { 0x90187, 0x8 }, + { 0x90188, 0x8 }, + { 0x90189, 0x7c8 }, + { 0x9018a, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x29 }, + { 0x90026, 0x6a }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x7d }, + { 0x2000c, 0xfa }, + { 0x2000d, 0x9c4 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0xc }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x2060 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x20089, 0x1 }, + { 0x20088, 0x19 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 } +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 4000mts 1D */ + .drate = 4000, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 4000mts 2D */ + .drate = 4000, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 4000, 400, 100, }, +}; diff --git a/board/freescale/imx8mp_evk/spl.c b/board/freescale/imx8mp_evk/spl.c new file mode 100644 index 0000000000..3c689f2d31 --- /dev/null +++ b/board/freescale/imx8mp_evk/spl.c @@ -0,0 +1,158 @@ +/* + * Copyright 2018-2019 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> +#include <asm/io.h> +#include <errno.h> +#include <asm/io.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/arch/imx8mp_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/boot_mode.h> +#include <power/pmic.h> + +#include <power/pca9450.h> +#include <asm/arch/clock.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <fsl_esdhc.h> +#include <mmc.h> +#include <asm/arch/ddr.h> + +#include <dm/uclass.h> +#include <dm/device.h> +#include <dm/uclass-internal.h> +#include <dm/device-internal.h> + +DECLARE_GLOBAL_DATA_PTR; + +int spl_board_boot_device(enum boot_device boot_dev_spl) +{ + return BOOT_DEVICE_BOOTROM; +} + +void spl_dram_init(void) +{ + ddr_init(&dram_timing); +} + +void spl_board_init(void) +{ + struct udevice *dev; + int ret; + + puts("Normal Boot\n"); + + ret = uclass_get_device_by_name(UCLASS_CLK, + "clock-controller@30380000", + &dev); + if (ret < 0) + printf("Failed to find clock node. Check device tree\n"); +} + +#define I2C_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PE) +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = MX8MP_PAD_I2C1_SCL__I2C1_SCL | PC, + .gpio_mode = MX8MP_PAD_I2C1_SCL__GPIO5_IO14 | PC, + .gp = IMX_GPIO_NR(5, 14), + }, + .sda = { + .i2c_mode = MX8MP_PAD_I2C1_SDA__I2C1_SDA | PC, + .gpio_mode = MX8MP_PAD_I2C1_SDA__GPIO5_IO15 | PC, + .gp = IMX_GPIO_NR(5, 15), + }, +}; + +#ifdef CONFIG_POWER +#define I2C_PMIC 0 +int power_init_board(void) +{ + struct pmic *p; + int ret; + + ret = power_pca9450b_init(I2C_PMIC); + if (ret) + printf("power init failed"); + p = pmic_get("PCA9450"); + pmic_probe(p); + + /* BUCKxOUT_DVS0/1 control BUCK123 output */ + pmic_reg_write(p, PCA9450_BUCK123_DVS, 0x29); + + /* + * increase VDD_SOC to typical value 0.95V before first + * DRAM access, set DVS1 to 0.85v for suspend. + * Enable DVS control through PMIC_STBY_REQ and + * set B1_ENMODE=1 (ON by PMIC_ON_REQ=H) + */ + pmic_reg_write(p, PCA9450_BUCK1OUT_DVS0, 0x1C); + pmic_reg_write(p, PCA9450_BUCK1OUT_DVS1, 0x14); + pmic_reg_write(p, PCA9450_BUCK1CTRL, 0x59); + + /* set WDOG_B_CFG to cold reset */ + pmic_reg_write(p, PCA9450_RESET_CTRL, 0xA1); + + return 0; +} +#endif + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif + +void board_init_f(ulong dummy) +{ + int ret; + + arch_cpu_init(); + + init_uart_clk(1); + + board_early_init_f(); + + timer_init(); + + preloader_console_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + ret = spl_init(); + if (ret) { + debug("spl_init() failed: %d\n", ret); + hang(); + } + + enable_tzc380(); + + /* Adjust pmic voltage to 1.0V for 800M */ + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + + power_init_board(); + + /* DDR initialization */ + spl_dram_init(); + + board_init_r(NULL, 0); +} + +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + puts("resetting ...\n"); + + reset_cpu(WDOG1_BASE_ADDR); + + return 0; +} diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig new file mode 100644 index 0000000000..61f0d91eb3 --- /dev/null +++ b/configs/imx8mp_evk_defconfig @@ -0,0 +1,84 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x10000 +CONFIG_DM_GPIO=y +CONFIG_TARGET_IMX8MP_EVK=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x400000 +CONFIG_NR_DRAM_BANKS=2 +CONFIG_SPL=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 +CONFIG_SPL_TEXT_BASE=0x920000 +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage-8mp-lpddr4.cfg" +CONFIG_DEFAULT_FDT_FILE="imx8mp-evk.dtb" +CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="u-boot=> " +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_CLK=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mp-evk" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_DM=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_CLK_IMX8MP=y +CONFIG_MXC_GPIO=y +CONFIG_DM_PCA953X=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_FSL_ESDHC_IMX=y +CONFIG_PHYLIB=y +CONFIG_DM_ETH=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_PSCI=y diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h new file mode 100644 index 0000000000..e91c71036d --- /dev/null +++ b/include/configs/imx8mp_evk.h @@ -0,0 +1,165 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + */ + +#ifndef __IMX8MP_EVK_H +#define __IMX8MP_EVK_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> + +#ifdef CONFIG_SECURE_BOOT +#define CONFIG_CSF_SIZE 0x2000 /* 8K region */ +#endif + +#define CONFIG_SPL_MAX_SIZE (152 * 1024) +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +#define CONFIG_SYS_UBOOT_BASE (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512) + +#ifdef CONFIG_SPL_BUILD +/*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_STACK 0x990000 +#define CONFIG_SPL_BSS_START_ADDR 0x0095e000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x2000 /* 8 KB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K /* 512 KB */ +#define CONFIG_SYS_ICACHE_OFF +#define CONFIG_SYS_DCACHE_OFF + +#define CONFIG_MALLOC_F_ADDR 0x940000 + +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + +#undef CONFIG_DM_MMC +#undef CONFIG_DM_PMIC +#undef CONFIG_DM_PMIC_PFUZE100 + +#define CONFIG_POWER +#define CONFIG_POWER_I2C +#define CONFIG_POWER_PCA9450 + +#undef CONFIG_DM_I2C +#define CONFIG_SYS_I2C + +#endif + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "image=Image\0" \ + "console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200\0" \ + "fdt_addr=0x43000000\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "boot_fdt=try\0" \ + "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "initrd_addr=0x43800000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs ${jh_clk} console=${console} root=${mmcroot}\0 " \ + "loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "else " \ + "echo wait for boot; " \ + "fi;\0" \ + "netargs=setenv bootargs ${jh_clk} console=${console} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${loadaddr} ${image}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "booti ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "else " \ + "booti; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else booti ${loadaddr} - ${fdt_addr}; fi" + +/* Link Definitions */ +#define CONFIG_LOADADDR 0x40480000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x80000 +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_MMC_ENV_DEV 1 /* USDHC2 */ +#define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */ + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN SZ_32M + +/* Totally 6GB DDR */ +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 +#define PHYS_SDRAM_SIZE 0xC0000000 /* 3 GB */ +#define PHYS_SDRAM_2 0x100000000 +#define PHYS_SDRAM_2_SIZE 0xC0000000 /* 3 GB */ + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ + (PHYS_SDRAM_SIZE >> 1)) + +#define CONFIG_MXC_UART_BASE UART2_BASE_ADDR + +/* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_CBSIZE 2048 +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +#define CONFIG_FSL_USDHC + +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +#define CONFIG_SYS_I2C_SPEED 100000 + +#endif
Hi Peng,
On Mon, Dec 30, 2019 at 7:08 AM Peng Fan peng.fan@nxp.com wrote:
imx: add i.MX8MP EVK board
Please add a README file mentioning the exact firmware/AT-F versions that need to be used to boot i.MX8MP EVK board.
Otherwise, the end user will face trouble finding the correct components.
Thanks
Hi Fabio,
Subject: Re: [PATCH 00/22] imx: add i.MX8MP support
Hi Peng,
This is no public AT-F and ddr firmware for this board now. We are at early stage currently. until NXP software release, there will be public AT-F and ddr firmware.
So people outside NXP will not able to test this board.
Thanks, Peng.
Thanks
Hi Peng,
Ok, understood, but please add a README file when these components become public.
What about i.MX8MN EVK board? There is still a missing README there and the AT-F and firmwares are public at this point.
It is getting hard to find the combination of U-Boot mainline + AT-F + firmware for i.MX8 family if they are not documented.
Thanks
Hi Peng,
and ddr firmware.
I'll add one, since we already have 8MN public release now.
Regards, Peng.
Thanks
Fabio Estevam
Peng Fan
