[PATCH v2 00/14] spl: mmc: Some tweaks for SPL, particularly with MMC
This series includes various minor fixes and tweaks found when trying to reduce the size of MMC code in SPL.
Changes in v2: - Avoid changing comment - Various updates to log messages - Drop an unnecessary cast - Update commit message to mention the runtime impact - Leave assert() alone since it is only compiled in with LOG_DEBUG - Update 'return ret' to 'return 0' when ret is known to be 0 - Use uint for arg to spl_mmc_get_device_index()
Simon Glass (14): rockchip: Move the default timer init to a common file spl: Correct use of CMD_BOOTI and CMD_BOOTZ spl: Remove some #ifdefs in spl_parse_image_header() spl: Remove remaining #ifdef in spl_parse_image_header() mmc: Use logging instead of printf() mmc: Use logging instead of pr_err() log: Avoid including function names by default spl: mmc: Drop checks for CONFIG_SPL_LIBCOMMON_SUPPORT spl: mmc: Handle error codes consistently spl: mmc: Adjust args of spl_mmc_find_device() spl: mmc: Try to clean up raw-mode options spl: Use unified inline functions for spl_load_info spl: Create a function to init spl_load_info blk: Correct comment for blk_get_devnum_by_uclass_idname()
arch/arm/include/asm/arch-rockchip/timer.h | 3 + arch/arm/mach-imx/imx8m/soc.c | 2 + arch/arm/mach-imx/spl_imx_romapi.c | 27 +-- arch/arm/mach-rockchip/Makefile | 4 +- arch/arm/mach-rockchip/spl.c | 21 +-- arch/arm/mach-rockchip/spl_common.c | 36 ++++ arch/arm/mach-rockchip/tpl.c | 30 +--- arch/arm/mach-sunxi/spl_spi_sunxi.c | 3 +- .../imx8mp_rsb3720a1/imx8mp_rsb3720a1.c | 4 +- common/log_console.c | 4 +- common/spl/Kconfig | 52 +++--- common/spl/spl.c | 30 ++-- common/spl/spl_blk_fs.c | 9 +- common/spl/spl_ext.c | 3 +- common/spl/spl_fat.c | 10 +- common/spl/spl_mmc.c | 159 ++++++++---------- common/spl/spl_nand.c | 4 +- common/spl/spl_net.c | 3 +- common/spl/spl_nor.c | 6 +- common/spl/spl_ram.c | 3 +- common/spl/spl_semihosting.c | 4 +- common/spl/spl_spi.c | 4 +- common/spl/spl_ymodem.c | 4 +- configs/am335x_guardian_defconfig | 2 +- configs/am335x_pdu001_defconfig | 2 +- configs/am3517_evm_defconfig | 2 +- configs/am62ax_evm_a53_defconfig | 1 + configs/am62ax_evm_r5_defconfig | 1 + configs/am62px_evm_a53_defconfig | 1 + configs/am62px_evm_r5_defconfig | 1 + configs/am62x_beagleplay_a53_defconfig | 1 + configs/am62x_beagleplay_r5_defconfig | 1 + configs/am62x_evm_a53_defconfig | 1 + configs/am62x_evm_r5_defconfig | 1 + configs/am64x_evm_a53_defconfig | 1 + configs/am64x_evm_r5_defconfig | 1 + configs/am65x_evm_a53_defconfig | 1 + configs/am65x_evm_r5_defconfig | 1 + configs/brppt2_defconfig | 2 +- configs/brsmarc1_defconfig | 2 +- configs/cgtqmx8_defconfig | 1 + configs/chromebit_mickey_defconfig | 2 +- configs/chromebook_jerry_defconfig | 2 +- configs/chromebook_minnie_defconfig | 2 +- configs/chromebook_speedy_defconfig | 2 +- configs/ci20_mmc_defconfig | 1 + configs/da850evm_defconfig | 2 +- configs/da850evm_nand_defconfig | 2 +- configs/deneb_defconfig | 1 + configs/display5_defconfig | 2 +- configs/display5_factory_defconfig | 2 +- configs/draco-rastaban_defconfig | 2 +- configs/draco-thuban_defconfig | 2 +- .../gardena-smart-gateway-at91sam_defconfig | 2 +- configs/giedi_defconfig | 1 + configs/imx28_xea_defconfig | 1 + configs/imx28_xea_sb_defconfig | 1 + configs/imx6q_logic_defconfig | 2 +- configs/imx8mm-cl-iot-gate-optee_defconfig | 1 + configs/imx8mm-cl-iot-gate_defconfig | 1 + configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 1 + configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 1 + configs/imx8mm-mx8menlo_defconfig | 1 + configs/imx8mm-phygate-tauri-l_defconfig | 1 + configs/imx8mm_beacon_defconfig | 1 + configs/imx8mm_beacon_fspi_defconfig | 1 + configs/imx8mm_data_modul_edm_sbc_defconfig | 1 + configs/imx8mm_evk_defconfig | 1 + configs/imx8mm_evk_fspi_defconfig | 1 + configs/imx8mm_phg_defconfig | 1 + configs/imx8mm_venice_defconfig | 1 + configs/imx8mn_beacon_2g_defconfig | 1 + configs/imx8mn_beacon_defconfig | 1 + configs/imx8mn_beacon_fspi_defconfig | 1 + configs/imx8mn_bsh_smm_s2_defconfig | 1 + configs/imx8mn_bsh_smm_s2pro_defconfig | 1 + configs/imx8mn_ddr4_evk_defconfig | 1 + configs/imx8mn_evk_defconfig | 1 + configs/imx8mn_var_som_defconfig | 1 + configs/imx8mn_venice_defconfig | 1 + configs/imx8mp-icore-mx8mp-edimm2.2_defconfig | 1 + configs/imx8mp_beacon_defconfig | 1 + configs/imx8mp_data_modul_edm_sbc_defconfig | 1 + configs/imx8mp_debix_model_a_defconfig | 1 + configs/imx8mp_dhcom_pdk2_defconfig | 1 + configs/imx8mp_dhcom_pdk3_defconfig | 1 + configs/imx8mp_evk_defconfig | 1 + configs/imx8mp_rsb3720a1_4G_defconfig | 2 + configs/imx8mp_rsb3720a1_6G_defconfig | 1 + configs/imx8mp_venice_defconfig | 1 + configs/imx8mq_cm_defconfig | 1 + configs/imx8mq_evk_defconfig | 1 + configs/imx8mq_phanbell_defconfig | 1 + configs/imx8mq_reform2_defconfig | 1 + configs/imx8qm_mek_defconfig | 1 + configs/imx8qxp_mek_defconfig | 1 + configs/imx8ulp_evk_defconfig | 1 + configs/imx93-phyboard-segin_defconfig | 1 + configs/imx93_11x11_evk_defconfig | 1 + configs/imx93_11x11_evk_ld_defconfig | 1 + configs/imx93_var_som_defconfig | 1 + configs/imxrt1020-evk_defconfig | 1 + configs/imxrt1050-evk_defconfig | 1 + configs/imxrt1050-evk_fspi_defconfig | 1 + configs/imxrt1170-evk_defconfig | 1 + configs/iot2050_defconfig | 1 + configs/j7200_evm_a72_defconfig | 1 + configs/j7200_evm_r5_defconfig | 1 + configs/j721e_beagleboneai64_a72_defconfig | 1 + configs/j721e_beagleboneai64_r5_defconfig | 1 + configs/j721e_evm_a72_defconfig | 1 + configs/j721e_evm_r5_defconfig | 1 + configs/j721s2_evm_a72_defconfig | 1 + configs/j721s2_evm_r5_defconfig | 1 + configs/j722s_evm_a53_defconfig | 1 + configs/j722s_evm_r5_defconfig | 1 + configs/j784s4_evm_a72_defconfig | 1 + configs/j784s4_evm_r5_defconfig | 1 + configs/kontron-sl-mx8mm_defconfig | 1 + configs/kontron_pitx_imx8m_defconfig | 1 + configs/kontron_sl28_defconfig | 1 + configs/librem5_defconfig | 1 + configs/ls1021aiot_sdcard_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atsn_sdcard_defconfig | 1 + ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + configs/msc_sm2s_imx8mp_defconfig | 1 + configs/omap35_logic_defconfig | 2 +- configs/omap35_logic_somlv_defconfig | 2 +- configs/omap3_logic_defconfig | 2 +- configs/omap3_logic_somlv_defconfig | 2 +- configs/phycore-imx8mm_defconfig | 1 + configs/phycore-imx8mp_defconfig | 1 + configs/phycore_am62x_a53_defconfig | 1 + configs/phycore_am62x_r5_defconfig | 1 + configs/phycore_am64x_a53_defconfig | 1 + configs/phycore_am64x_r5_defconfig | 1 + configs/pico-imx8mq_defconfig | 1 + configs/sama5d27_wlsom1_ek_mmc_defconfig | 2 +- .../sama5d27_wlsom1_ek_qspiflash_defconfig | 2 +- configs/sama5d2_icp_mmc_defconfig | 2 +- configs/sandbox_defconfig | 1 + configs/sandbox_noinst_defconfig | 1 + configs/sniper_defconfig | 2 +- configs/socfpga_secu1_defconfig | 2 +- configs/verdin-am62_a53_defconfig | 1 + configs/verdin-am62_r5_defconfig | 1 + configs/verdin-imx8mm_defconfig | 1 + configs/verdin-imx8mp_defconfig | 1 + drivers/mmc/mmc.c | 49 +++--- drivers/mmc/sdhci.c | 46 +++-- drivers/usb/gadget/f_sdp.c | 8 +- include/blk.h | 4 +- include/log.h | 16 +- include/spl.h | 60 ++++--- test/cmd/pinmux.c | 8 +- test/image/spl_load.c | 4 +- test/image/spl_load_os.c | 6 +- test/log/log_test.c | 4 +- 163 files changed, 429 insertions(+), 358 deletions(-) create mode 100644 arch/arm/mach-rockchip/spl_common.c
Rather than repeating the same code in two files (SPL and TPL), move it to a shared filed.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Dragan Simic dsimic@manjaro.org ---
(no changes since v1)
arch/arm/include/asm/arch-rockchip/timer.h | 3 ++ arch/arm/mach-rockchip/Makefile | 4 +-- arch/arm/mach-rockchip/spl.c | 21 +------------ arch/arm/mach-rockchip/spl_common.c | 36 ++++++++++++++++++++++ arch/arm/mach-rockchip/tpl.c | 30 +----------------- 5 files changed, 43 insertions(+), 51 deletions(-) create mode 100644 arch/arm/mach-rockchip/spl_common.c
diff --git a/arch/arm/include/asm/arch-rockchip/timer.h b/arch/arm/include/asm/arch-rockchip/timer.h index 77b54220447..b5fc738c98c 100644 --- a/arch/arm/include/asm/arch-rockchip/timer.h +++ b/arch/arm/include/asm/arch-rockchip/timer.h @@ -15,4 +15,7 @@ struct rk_timer { u32 timer_int_status; };
+/** rockchip_stimer_init() - Set up the timer ready for use */ +void rockchip_stimer_init(void); + #endif diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index c07bdaee4c3..3b13891ec24 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -8,9 +8,9 @@ # inaccessible/protected memory (and the bootrom-helper assumes that # the stack-pointer is valid before switching to the U-Boot stack). obj-spl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o -obj-spl-$(CONFIG_SPL_ROCKCHIP_COMMON_BOARD) += spl.o spl-boot-order.o +obj-spl-$(CONFIG_SPL_ROCKCHIP_COMMON_BOARD) += spl.o spl-boot-order.o spl_common.o obj-tpl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o -obj-tpl-$(CONFIG_TPL_ROCKCHIP_COMMON_BOARD) += tpl.o +obj-tpl-$(CONFIG_TPL_ROCKCHIP_COMMON_BOARD) += tpl.o spl_common.o obj-tpl-$(CONFIG_ROCKCHIP_PX30) += px30-board-tpl.o
obj-spl-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o diff --git a/arch/arm/mach-rockchip/spl.c b/arch/arm/mach-rockchip/spl.c index 3ce7e792b5a..bbd223bc524 100644 --- a/arch/arm/mach-rockchip/spl.c +++ b/arch/arm/mach-rockchip/spl.c @@ -13,6 +13,7 @@ #include <ram.h> #include <spl.h> #include <asm/arch-rockchip/bootrom.h> +#include <asm/arch-rockchip/timer.h> #include <asm/global_data.h> #include <asm/io.h> #include <linux/bitops.h> @@ -86,26 +87,6 @@ u32 spl_mmc_boot_mode(struct mmc *mmc, const u32 boot_device) #define TIMER_FMODE BIT(0) #define TIMER_RMODE BIT(1)
-__weak void rockchip_stimer_init(void) -{ -#if defined(CONFIG_ROCKCHIP_STIMER_BASE) - /* If Timer already enabled, don't re-init it */ - u32 reg = readl(CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); - - if (reg & TIMER_EN) - return; -#ifndef CONFIG_ARM64 - asm volatile("mcr p15, 0, %0, c14, c0, 0" - : : "r"(CONFIG_COUNTER_FREQUENCY)); -#endif - writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); - writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); - writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); - writel(TIMER_EN | TIMER_FMODE, CONFIG_ROCKCHIP_STIMER_BASE + - TIMER_CONTROL_REG); -#endif -} - __weak int board_early_init_f(void) { return 0; diff --git a/arch/arm/mach-rockchip/spl_common.c b/arch/arm/mach-rockchip/spl_common.c new file mode 100644 index 00000000000..b29f33448ab --- /dev/null +++ b/arch/arm/mach-rockchip/spl_common.c @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd + */ + +#include <asm/io.h> +#include <linux/bitops.h> + +#define TIMER_LOAD_COUNT_L 0x00 +#define TIMER_LOAD_COUNT_H 0x04 +#define TIMER_CONTROL_REG 0x10 +#define TIMER_EN 0x1 +#define TIMER_FMODE BIT(0) +#define TIMER_RMODE BIT(1) + +__weak void rockchip_stimer_init(void) +{ +#if defined(CONFIG_ROCKCHIP_STIMER_BASE) + /* If Timer already enabled, don't re-init it */ + u32 reg = readl(CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + + if (reg & TIMER_EN) + return; + +#ifndef CONFIG_ARM64 + asm volatile("mcr p15, 0, %0, c14, c0, 0" + : : "r"(CONFIG_COUNTER_FREQUENCY)); +#endif + + writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); + writel(TIMER_EN | TIMER_FMODE, CONFIG_ROCKCHIP_STIMER_BASE + + TIMER_CONTROL_REG); +#endif +} diff --git a/arch/arm/mach-rockchip/tpl.c b/arch/arm/mach-rockchip/tpl.c index 597a5caa84b..bbb9329e725 100644 --- a/arch/arm/mach-rockchip/tpl.c +++ b/arch/arm/mach-rockchip/tpl.c @@ -14,41 +14,13 @@ #include <version.h> #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> +#include <asm/arch-rockchip/timer.h> #include <linux/bitops.h>
#if CONFIG_IS_ENABLED(BANNER_PRINT) #include <timestamp.h> #endif
-#define TIMER_LOAD_COUNT_L 0x00 -#define TIMER_LOAD_COUNT_H 0x04 -#define TIMER_CONTROL_REG 0x10 -#define TIMER_EN 0x1 -#define TIMER_FMODE BIT(0) -#define TIMER_RMODE BIT(1) - -__weak void rockchip_stimer_init(void) -{ -#if defined(CONFIG_ROCKCHIP_STIMER_BASE) - /* If Timer already enabled, don't re-init it */ - u32 reg = readl(CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); - - if (reg & TIMER_EN) - return; - -#ifndef CONFIG_ARM64 - asm volatile("mcr p15, 0, %0, c14, c0, 0" - : : "r"(CONFIG_COUNTER_FREQUENCY)); -#endif - - writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); - writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); - writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); - writel(TIMER_EN | TIMER_FMODE, CONFIG_ROCKCHIP_STIMER_BASE + - TIMER_CONTROL_REG); -#endif -} - void board_init_f(ulong dummy) { struct udevice *dev;
Hi Simon,
- #endif
Please also remove the now unused constants just above this line, the same way you did for the tpl file.
With that,
Reviewed-by: Quentin Schulz quentin.schulz@cherry.de
Thanks! Quentin
These should have a CONFIG_ prefix. Add it.
Signed-off-by: Simon Glass sjg@chromium.org Fixes: 7a0d88076b9 ("Add in the ability to load and boot an uncompr...") Reviewed-by: Sean Anderson seanga2@gmail.com ---
common/spl/spl.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 7794ddccade..6f4a8bfb3f4 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -322,7 +322,7 @@ int spl_parse_image_header(struct spl_image_info *spl_image, #endif
#if CONFIG_IS_ENABLED(OS_BOOT) -#if defined(CMD_BOOTI) +#if defined(CONFIG_CMD_BOOTI) ulong start, size;
if (!booti_setup((ulong)header, &start, &size, 0)) { @@ -336,7 +336,7 @@ int spl_parse_image_header(struct spl_image_info *spl_image, spl_image->load_addr, spl_image->size); return 0; } -#elif defined(CMD_BOOTZ) +#elif defined(CONFIG_CMD_BOOTZ) ulong start, end;
if (!bootz_setup((ulong)header, &start, &end)) {
Hi Simon,
Maybe use IS_ENABLED(CMD_BOOTI) instead?
ulong start, size; if (!booti_setup((ulong)header, &start, &size, 0)) {
Ditto?
In any case,
Though.... i'm wondering why we are checking for CMD_BOOTI in SPL in the first place?
Cheers, Quentin
ulong start, end; if (!bootz_setup((ulong)header, &start, &end)) {
Hi Quentin,
On Mon, 22 Jul 2024 at 07:11, Quentin Schulz quentin.schulz@cherry.de wrote:
Hi Simon,
IS_ENABLED(CONFIG_CMD_BOOTI) I assume. Sure, but I don't think it matters as they are equivalent.
Ditto?
In any case,
I suppose it is to enable a feature in SPL only if it will be used in U-Boot?
Hi Simon,
Should we rather use IS_ENABLED(CONFIG_CMD_BOOTZ)? (same question for booti)
In any case, Reviewed-by: Quentin Schulz quentin.schulz@cherry.de
Thanks! Quentin
This function has a number of unnecessary #ifdefs so remove them.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Sean Anderson seanga2@gmail.com ---
common/spl/spl.c | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 6f4a8bfb3f4..02567e766f1 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -308,8 +308,10 @@ int spl_parse_image_header(struct spl_image_info *spl_image, ret = spl_parse_legacy_header(spl_image, header); if (ret) return ret; - } else { -#ifdef CONFIG_SPL_PANIC_ON_RAW_IMAGE + return 0; + } + + if (IS_ENABLED(CONFIG_SPL_PANIC_ON_RAW_IMAGE)) { /* * CONFIG_SPL_PANIC_ON_RAW_IMAGE is defined when the * code which loads images in SPL cannot guarantee that @@ -319,10 +321,9 @@ int spl_parse_image_header(struct spl_image_info *spl_image, * is bad, and thus should be skipped silently. */ panic("** no mkimage signature but raw image not supported"); -#endif + }
-#if CONFIG_IS_ENABLED(OS_BOOT) -#if defined(CONFIG_CMD_BOOTI) + if (CONFIG_IS_ENABLED(OS_BOOT) && IS_ENABLED(CONFIG_CMD_BOOTI)) { ulong start, size;
if (!booti_setup((ulong)header, &start, &size, 0)) { @@ -336,7 +337,7 @@ int spl_parse_image_header(struct spl_image_info *spl_image, spl_image->load_addr, spl_image->size); return 0; } -#elif defined(CONFIG_CMD_BOOTZ) + } else if (CONFIG_IS_ENABLED(OS_BOOT) && IS_ENABLED(CONFIG_CMD_BOOTZ)) { ulong start, end;
if (!bootz_setup((ulong)header, &start, &end)) { @@ -350,11 +351,11 @@ int spl_parse_image_header(struct spl_image_info *spl_image, spl_image->load_addr, spl_image->size); return 0; } -#endif -#endif + }
- if (!spl_parse_board_header(spl_image, bootdev, (const void *)header, sizeof(*header))) - return 0; + if (!spl_parse_board_header(spl_image, bootdev, (const void *)header, + sizeof(*header))) + return 0;
#ifdef CONFIG_SPL_RAW_IMAGE_SUPPORT /* Signature not found - assume u-boot.bin */ @@ -366,7 +367,6 @@ int spl_parse_image_header(struct spl_image_info *spl_image, debug("Raw boot image support not enabled, proceeding to other boot methods\n"); return -EINVAL; #endif - }
return 0; }
Hi Simon,
- } else {
- if (IS_ENABLED(CONFIG_SPL_PANIC_ON_RAW_IMAGE)) { /*
- CONFIG_SPL_PANIC_ON_RAW_IMAGE is defined when the
- code which loads images in SPL cannot guarantee that
- if (CONFIG_IS_ENABLED(OS_BOOT) && IS_ENABLED(CONFIG_CMD_BOOTI)) {
Ah, I see. Done in this commit :) Ignore comment on patch 2 then :)
Thanks! Quentin
Define spl_set_header_raw_uboot() always so we can drop the last #ifdef in this function.
common/spl/spl.c | 10 ++++------ 1 file changed, 4 insertions(+), 6 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 02567e766f1..30ff1e6f7d7 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -245,7 +245,6 @@ __weak struct legacy_img_hdr *spl_get_load_buffer(ssize_t offset, size_t size) return map_sysmem(CONFIG_TEXT_BASE + offset, 0); }
-#ifdef CONFIG_SPL_RAW_IMAGE_SUPPORT void spl_set_header_raw_uboot(struct spl_image_info *spl_image) { ulong u_boot_pos = spl_get_image_pos(); @@ -273,7 +272,6 @@ void spl_set_header_raw_uboot(struct spl_image_info *spl_image) spl_image->os = IH_OS_U_BOOT; spl_image->name = "U-Boot"; } -#endif
__weak int spl_parse_board_header(struct spl_image_info *spl_image, const struct spl_boot_device *bootdev, @@ -357,16 +355,16 @@ int spl_parse_image_header(struct spl_image_info *spl_image, sizeof(*header))) return 0;
-#ifdef CONFIG_SPL_RAW_IMAGE_SUPPORT + if (IS_ENABLED(CONFIG_SPL_RAW_IMAGE_SUPPORT)) { /* Signature not found - assume u-boot.bin */ debug("mkimage signature not found - ih_magic = %x\n", - header->ih_magic); + header->ih_magic); spl_set_header_raw_uboot(spl_image); -#else + } else { /* RAW image not supported, proceed to other boot methods. */ debug("Raw boot image support not enabled, proceeding to other boot methods\n"); return -EINVAL; -#endif + }
return 0; }
Hi Simon,
Changes in v2:
I assume this doesn't add too much to the SPL in terms of size? Otherwise we could just define an empty function when CONFIG_SPL_RAW_IMAGE_SUPPORT isn't defined to avoid bloating the SPL?
- if (IS_ENABLED(CONFIG_SPL_RAW_IMAGE_SUPPORT)) { /* Signature not found - assume u-boot.bin */ debug("mkimage signature not found - ih_magic = %x\n",
header->ih_magic);
spl_set_header_raw_uboot(spl_image);header->ih_magic);
We could return 0 here.......
-#else
- } else {
.... to avoid here the else whose last instruction is returning -EINVAL.
Thanks! Quentin
Hi Quentin,
On Tue, 6 Aug 2024 at 07:24, Quentin Schulz quentin.schulz@cherry.de wrote:
Hi Simon,
Changes in v2:
header->ih_magic);
-#else
} else {
Sure, but then the function would be returning -EINVAL at the end. We try to have functions end with success, with failure handled by its returning early. That way we can read the 'normal' flow of the function from top to bottom.
Thanks! Quentin
Thanks for all your reviews.
The code makes quite a few uses of __func__ which puts the function name into the resulting SPL image. Use the log subsystem instead, to reduce size.
The CONFIG_LOGF_FUNC option can be used to enable the function name.
Changes in v2: - Various updates to log messages - Drop an unnecessary cast
drivers/mmc/sdhci.c | 46 +++++++++++++++++++-------------------------- 1 file changed, 19 insertions(+), 27 deletions(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 560b7e889c7..eb5a144f8d4 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -32,8 +32,7 @@ static void sdhci_reset(struct sdhci_host *host, u8 mask) sdhci_writeb(host, mask, SDHCI_SOFTWARE_RESET); while (sdhci_readb(host, SDHCI_SOFTWARE_RESET) & mask) { if (timeout == 0) { - printf("%s: Reset 0x%x never completed.\n", - __func__, (int)mask); + log_warning("Reset %x never completed\n", mask); return; } timeout--; @@ -139,8 +138,7 @@ static int sdhci_transfer_data(struct sdhci_host *host, struct mmc_data *data) do { stat = sdhci_readl(host, SDHCI_INT_STATUS); if (stat & SDHCI_INT_ERROR) { - pr_debug("%s: Error detected in status(0x%X)!\n", - __func__, stat); + log_debug("Error detected in status(%x)!\n", stat); return -EIO; } if (!transfer_done && (stat & rdy)) { @@ -173,7 +171,7 @@ static int sdhci_transfer_data(struct sdhci_host *host, struct mmc_data *data) if (timeout-- > 0) udelay(10); else { - printf("%s: Transfer data timeout\n", __func__); + log_err("Transfer data timeout\n"); return -ETIMEDOUT; } } while (!(stat & SDHCI_INT_DATA_END)); @@ -232,7 +230,7 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd,
while (sdhci_readl(host, SDHCI_PRESENT_STATE) & mask) { if (time >= cmd_timeout) { - printf("%s: MMC: %d busy ", __func__, mmc_dev); + log_warning("mmc%d busy ", mmc_dev); if (2 * cmd_timeout <= SDHCI_CMD_MAX_TIMEOUT) { cmd_timeout += cmd_timeout; printf("timeout increasing to: %u ms.\n", @@ -316,8 +314,8 @@ static int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, }
if (get_timer(start) >= SDHCI_READ_STATUS_TIMEOUT) { - printf("%s: Timeout for status update: %08x %08x\n", - __func__, stat, mask); + log_warning("Timeout for status update: %08x %08x\n", + stat, mask); return -ETIMEDOUT; } } while ((stat & mask) != mask); @@ -358,7 +356,7 @@ static int sdhci_execute_tuning(struct udevice *dev, uint opcode) struct mmc *mmc = mmc_get_mmc_dev(dev); struct sdhci_host *host = mmc->priv;
- debug("%s\n", __func__); + log_debug("sdhci tuning\n");
if (host->ops && host->ops->platform_execute_tuning) { err = host->ops->platform_execute_tuning(mmc, opcode); @@ -380,8 +378,7 @@ int sdhci_set_clock(struct mmc *mmc, unsigned int clock) while (sdhci_readl(host, SDHCI_PRESENT_STATE) & (SDHCI_CMD_INHIBIT | SDHCI_DATA_INHIBIT)) { if (timeout == 0) { - printf("%s: Timeout to wait cmd & data inhibit\n", - __func__); + log_err("Timeout waiting for cmd & data inhibit\n"); return -EBUSY; }
@@ -397,7 +394,7 @@ int sdhci_set_clock(struct mmc *mmc, unsigned int clock) if (host->ops && host->ops->set_delay) { ret = host->ops->set_delay(host); if (ret) { - printf("%s: Error while setting tap delay\n", __func__); + log_err("Error while setting tap delay\n"); return ret; } } @@ -405,7 +402,7 @@ int sdhci_set_clock(struct mmc *mmc, unsigned int clock) if (host->ops && host->ops->config_dll) { ret = host->ops->config_dll(host, clock, false); if (ret) { - printf("%s: Error while configuring dll\n", __func__); + log_err("Error configuring dll\n"); return ret; } } @@ -456,7 +453,7 @@ int sdhci_set_clock(struct mmc *mmc, unsigned int clock) if (host->ops && host->ops->config_dll) { ret = host->ops->config_dll(host, clock, true); if (ret) { - printf("%s: Error while configuring dll\n", __func__); + log_err("Error enabling dll\n"); return ret; } } @@ -472,8 +469,7 @@ int sdhci_set_clock(struct mmc *mmc, unsigned int clock) while (!((clk = sdhci_readw(host, SDHCI_CLOCK_CONTROL)) & SDHCI_CLOCK_INT_STABLE)) { if (timeout == 0) { - printf("%s: Internal clock never stabilised.\n", - __func__); + log_err("Internal clock never stabilised.\n"); return -EBUSY; } timeout--; @@ -738,8 +734,7 @@ static int sdhci_init(struct mmc *mmc) if (host->quirks & SDHCI_QUIRK_32BIT_DMA_ADDR) { host->align_buffer = memalign(8, 512 * 1024); if (!host->align_buffer) { - printf("%s: Aligned buffer alloc failed!!!\n", - __func__); + log_err("Aligned buffer alloc failed\n"); return -ENOMEM; } } @@ -881,20 +876,18 @@ int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, #else caps = sdhci_readl(host, SDHCI_CAPABILITIES); #endif - debug("%s, caps: 0x%x\n", __func__, caps); + log_debug("caps: 0x%x\n", caps);
#if CONFIG_IS_ENABLED(MMC_SDHCI_SDMA) if ((caps & SDHCI_CAN_DO_SDMA)) { host->flags |= USE_SDMA; } else { - debug("%s: Your controller doesn't support SDMA!!\n", - __func__); + log_debug("Controller doesn't support SDMA\n"); } #endif #if CONFIG_IS_ENABLED(MMC_SDHCI_ADMA) if (!(caps & SDHCI_CAN_DO_ADMA2)) { - printf("%s: Your controller doesn't support ADMA!!\n", - __func__); + log_err("Controller doesn't support ADMA\n"); return -EINVAL; } if (!host->adma_desc_table) { @@ -927,7 +920,7 @@ int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, #else caps_1 = sdhci_readl(host, SDHCI_CAPABILITIES_1); #endif - debug("%s, caps_1: 0x%x\n", __func__, caps_1); + log_debug("caps_1: %x\n", caps_1); host->clk_mul = (caps_1 & SDHCI_CLOCK_MUL_MASK) >> SDHCI_CLOCK_MUL_SHIFT;
@@ -953,8 +946,7 @@ int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, host->max_clk *= host->clk_mul; } if (host->max_clk == 0) { - printf("%s: Hardware doesn't specify base clock frequency\n", - __func__); + log_err("Hardware doesn't specify base clock frequency\n"); return -EINVAL; } if (f_max && (f_max < host->max_clk)) @@ -1047,7 +1039,7 @@ int add_sdhci(struct sdhci_host *host, u32 f_max, u32 f_min)
host->mmc = mmc_create(&host->cfg, host); if (host->mmc == NULL) { - printf("%s: mmc create fail!\n", __func__); + log_err("mmc create fail\n"); return -ENOMEM; }
Hi Simon,
If I didn't misread the code, I believe that __func__ is **always** in the image whenever LOG is defined, just that it may not be printed?
c.f. https://source.denx.de/u-boot/u-boot/-/blob/master/include/log.h?ref_type=he...
Changes in v2:
If log_* functions aren't changing the meaning of printf formats, please keep the 0x prefix to highlight it is hex digits as there's some overlap in hex and dec digits. This applies to all 0x%x that were changed to %x in this patch.
__func__, stat);
} if (!transfer_done && (stat & rdy)) {log_debug("Error detected in status(%x)!\n", stat); return -EIO;
} } while (!(stat & SDHCI_INT_DATA_END));log_err("Transfer data timeout\n"); return -ETIMEDOUT;
I would suggest to migrate this to the same log level as the busy message. Same for the puts(timeout) which is outside of this git context.
} } while ((stat & mask) != mask);stat, mask); return -ETIMEDOUT;
__func__);
}log_err("Timeout waiting for cmd & data inhibit\n"); return -EBUSY;
} }log_err("Error while setting tap delay\n"); return ret;
} }log_err("Error configuring dll\n"); return ret;
Is this really only about enabling the DLL?
In rockchip_sdhci, the function does a lot more when enable=true than enable=false so I feel like it's a bit disingenuous to downgrade config_dll(..., 1) to "enabling dll".
Also not sure what made you decide on the log level but aside from the aforementioned issues, looks good to me.
Cheers, Quentin
Hi Quentin,
On Tue, 6 Aug 2024 at 08:01, Quentin Schulz quentin.schulz@cherry.de wrote:
Hi Simon,
Yes that's right. It is fixed by [1]
Changes in v2:
__func__, stat);
log_debug("sdhci tuning\n"); if (host->ops && host->ops->platform_execute_tuning) { err = host->ops->platform_execute_tuning(mmc, opcode);
__func__);
Cheers, Quentin
[1] https://patchwork.ozlabs.org/project/uboot/patch/20240721152600.3212917-8-sj...
Use the log subsystem instead of dev, to avoid including function names in the code.
drivers/mmc/mmc.c | 49 ++++++++++++++++++++++++----------------------- 1 file changed, 25 insertions(+), 24 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index b18dc331f78..b0105afe5d6 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -294,7 +294,7 @@ int mmc_poll_for_busy(struct mmc *mmc, int timeout_ms)
if (status & MMC_STATUS_MASK) { #if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) - pr_err("Status Error: 0x%08x\n", status); + log_err("Status Error: %08x\n", status); #endif return -ECOMM; } @@ -307,7 +307,7 @@ int mmc_poll_for_busy(struct mmc *mmc, int timeout_ms)
if (timeout_ms <= 0) { #if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) - pr_err("Timeout waiting card ready\n"); + log_err("Timeout waiting card ready\n"); #endif return -ETIMEDOUT; } @@ -449,7 +449,7 @@ static int mmc_read_blocks(struct mmc *mmc, void *dst, lbaint_t start, if (blkcnt > 1) { if (mmc_send_stop_transmission(mmc, false)) { #if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) - pr_err("mmc fail to send stop cmd\n"); + log_err("mmc fail to send stop cmd\n"); #endif return 0; } @@ -500,8 +500,8 @@ ulong mmc_bread(struct blk_desc *block_dev, lbaint_t start, lbaint_t blkcnt,
if ((start + blkcnt) > block_dev->lba) { #if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) - pr_err("MMC: block number 0x" LBAF " exceeds max(0x" LBAF ")\n", - start + blkcnt, block_dev->lba); + log_err("MMC: block number " LBAF " exceeds max(" LBAF ")\n", + start + blkcnt, block_dev->lba); #endif return 0; } @@ -997,7 +997,7 @@ static int mmc_get_capabilities(struct mmc *mmc) return 0;
if (!ext_csd) { - pr_err("No ext_csd found!\n"); /* this should enver happen */ + log_err("No ext_csd found!\n"); /* this should enver happen */ return -ENOTSUPP; }
@@ -1109,17 +1109,17 @@ int mmc_hwpart_config(struct mmc *mmc, return -EINVAL;
if (IS_SD(mmc) || (mmc->version < MMC_VERSION_4_41)) { - pr_err("eMMC >= 4.4 required for enhanced user data area\n"); + log_err("eMMC >= 4.4 required for enhanced user data area\n"); return -EMEDIUMTYPE; }
if (!(mmc->part_support & PART_SUPPORT)) { - pr_err("Card does not support partitioning\n"); + log_err("Card does not support partitioning\n"); return -EMEDIUMTYPE; }
if (!mmc->hc_wp_grp_size) { - pr_err("Card does not define HC WP group size\n"); + log_err("Card does not define HC WP group size\n"); return -EMEDIUMTYPE; }
@@ -1127,8 +1127,7 @@ int mmc_hwpart_config(struct mmc *mmc, if (conf->user.enh_size) { if (conf->user.enh_size % mmc->hc_wp_grp_size || conf->user.enh_start % mmc->hc_wp_grp_size) { - pr_err("User data enhanced area not HC WP group " - "size aligned\n"); + log_err("User data enhanced area not HC WP group size aligned\n"); return -EINVAL; } part_attrs |= EXT_CSD_ENH_USR; @@ -1146,8 +1145,8 @@ int mmc_hwpart_config(struct mmc *mmc,
for (pidx = 0; pidx < 4; pidx++) { if (conf->gp_part[pidx].size % mmc->hc_wp_grp_size) { - pr_err("GP%i partition not HC WP group size " - "aligned\n", pidx+1); + log_err("GP%i partition not HC WP group-size aligned\n", + pidx + 1); return -EINVAL; } gp_size_mult[pidx] = conf->gp_part[pidx].size / mmc->hc_wp_grp_size; @@ -1158,7 +1157,7 @@ int mmc_hwpart_config(struct mmc *mmc, }
if (part_attrs && ! (mmc->part_support & ENHNCD_SUPPORT)) { - pr_err("Card does not support enhanced attribute\n"); + log_err("Card does not support enhanced attribute\n"); return -EMEDIUMTYPE; }
@@ -1171,8 +1170,8 @@ int mmc_hwpart_config(struct mmc *mmc, (ext_csd[EXT_CSD_MAX_ENH_SIZE_MULT+1] << 8) + ext_csd[EXT_CSD_MAX_ENH_SIZE_MULT]; if (tot_enh_size_mult > max_enh_size_mult) { - pr_err("Total enhanced size exceeds maximum (%u > %u)\n", - tot_enh_size_mult, max_enh_size_mult); + log_err("Total enhanced size exceeds maximum (%x > %x)\n", + tot_enh_size_mult, max_enh_size_mult); return -EMEDIUMTYPE; }
@@ -1205,7 +1204,7 @@ int mmc_hwpart_config(struct mmc *mmc,
if (ext_csd[EXT_CSD_PARTITION_SETTING] & EXT_CSD_PARTITION_SETTING_COMPLETED) { - pr_err("Card already partitioned\n"); + log_err("Card already partitioned\n"); return -EPERM; }
@@ -1876,7 +1875,7 @@ error: } }
- pr_err("unable to select a mode\n"); + log_err("unable to select a mode\n"); return -ENOTSUPP; }
@@ -2254,7 +2253,7 @@ error: } }
- pr_err("unable to select a mode : %d\n", err); + log_err("unable to select a mode: %d\n", err);
return -ENOTSUPP; } @@ -2921,8 +2920,10 @@ retry:
if (err) { #if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) - if (!quiet) - pr_err("Card did not respond to voltage select! : %d\n", err); + if (!quiet) { + log_err("Card did not respond to voltage select! : %d\n", + err); + } #endif return -EOPNOTSUPP; } @@ -2955,7 +2956,7 @@ int mmc_start_init(struct mmc *mmc) | MMC_CAP(MMC_LEGACY) | MMC_MODE_1BIT); } else { - pr_err("bus_mode requested is not supported\n"); + log_err("bus_mode requested is not supported\n"); return -EINVAL; } } @@ -2975,7 +2976,7 @@ int mmc_start_init(struct mmc *mmc) if (no_card) { mmc->has_init = 0; #if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_LIBCOMMON_SUPPORT) - pr_err("MMC: no card present\n"); + log_err("MMC: no card present\n"); #endif return -ENOMEDIUM; } @@ -3104,7 +3105,7 @@ static int mmc_probe(struct bd_info *bis) uclass_foreach_dev(dev, uc) { ret = device_probe(dev); if (ret) - pr_err("%s - probe failed: %d\n", dev->name, ret); + log_err("%s - probe failed: %d\n", dev->name, ret); }
Hi Simon,
Please don't remove the 0x prefix (will not comment on other patches in this series if it happens again, please check :) ).
#endif return -ETIMEDOUT; }log_err("Timeout waiting card ready\n");
#endif return 0; }log_err("mmc fail to send stop cmd\n");
DOn't remove the 0x prefix please.
#endif return 0; }start + blkcnt, block_dev->lba);
if (!ext_csd) {
return -ENOTSUPP; }log_err("No ext_csd found!\n"); /* this should enver happen */
return -EMEDIUMTYPE; }log_err("Card does not define HC WP group size\n");
"size aligned\n");
} part_attrs |= EXT_CSD_ENH_USR;log_err("User data enhanced area not HC WP group size aligned\n"); return -EINVAL;
} gp_size_mult[pidx] = conf->gp_part[pidx].size / mmc->hc_wp_grp_size;pidx + 1); return -EINVAL;
return -EMEDIUMTYPE; }log_err("Card does not support enhanced attribute\n");
If you change the type (why?) to hex, please add 0x prefix to explicit the base.
return -EMEDIUMTYPE; }tot_enh_size_mult, max_enh_size_mult);
return -EPERM; }log_err("Card already partitioned\n");
- log_err("unable to select a mode\n"); return -ENOTSUPP; }
return -ENOTSUPP; }
if (err) {
if (!quiet)
if (!quiet) {
err);
We still don't need the curly brackets here.
Looking good otherwise, Cheers, Quentin
Hi Quentin,
On Tue, 6 Aug 2024 at 08:10, Quentin Schulz quentin.schulz@cherry.de wrote:
Hi Simon,
OK...hex is the default though.
if (!ext_csd) {
log_err("eMMC >= 4.4 required for enhanced user data area\n"); return -EMEDIUMTYPE; } if (!(mmc->part_support & PART_SUPPORT)) {
log_err("Card does not support partitioning\n"); return -EMEDIUMTYPE; } if (!mmc->hc_wp_grp_size) {
"size aligned\n");
}log_err("unable to select a mode\n"); return -ENOTSUPP;
log_err("unable to select a mode: %d\n", err); return -ENOTSUPP;
if (err) {
if (!quiet)
if (!quiet) {
err);
Hi Simon,
On 8/11/24 4:50 PM, Simon Glass wrote:
Hi Quentin,
Hi Simon,
Can you please clarify what you meant by "it's the default though"?
Cheers, Quentin
Hi Quentin,
On Mon, 12 Aug 2024 at 02:58, Quentin Schulz quentin.schulz@cherry.de wrote:
Hi Simon,
Hi Quentin,
Hi Simon,
U-Boot uses hex by default, so anything printed out or entered is normally in hex. There are a few exceptions, not all of them correct. I did send a series to allow decimal numbers but it has been deferred for a while now[1].
[1] https://patchwork.ozlabs.org/project/uboot/patch/20210724150341.243074-13-sj...
Hi Simon,
On 8/13/24 2:16 PM, Simon Glass wrote:
Hi Quentin,
Hi Simon,
Hi Quentin,
Hi Simon,
Gotcha. This actually has been painful to me and I've made the mistake a few times already, e.g. writing 256 blocks instead of 100 (100 aka 0x100 instead of base10 100). Are you aware whether this is made explicit in the docs somewhere? So I could refer to it if I ever need to explain stuff?
Interesting :)
Cheers, Quentin
Hi Quentin,
On Tue, 13 Aug 2024 at 06:29, Quentin Schulz quentin.schulz@cherry.de wrote:
Hi Simon,
Hi Quentin,
wrote:
Hi Simon,
Hi Quentin,
wrote:
Hi Simon,
names
in the code.
timeout_ms)
in
stuff?
I believe it was in the old Denx manual. I found it in a Digi one [2]:
Numbers used by U-Boot are always considered to be in hexadecimal format.
For example, U-Boot understands number 30100000 as 0x30100000.
Perhaps we should add something like that to doc/usage?
Interesting :)
Cheers, Quentin
[2] https://hub.digi.com/dp/path=/support/asset/u-boot-reference-manual/
Hi Simon,
On 8/13/24 3:02 PM, Simon Glass wrote:
Hi Quentin,
Hi Simon,
Hi Quentin,
wrote:
Hi Simon,
Hi Quentin,
wrote:
Hi Simon,
On 7/21/24 5:25 PM, Simon Glass wrote: > Use the log subsystem instead of dev, to avoid including function
names
> in the code. > > The CONFIG_LOGF_FUNC option can be used to enable the function name. > > Signed-off-by: Simon Glass sjg@chromium.org > Reviewed-by: Sean Anderson seanga2@gmail.com > --- > > (no changes since v1) > > drivers/mmc/mmc.c | 49
> 1 file changed, 25 insertions(+), 24 deletions(-) > > diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c > index b18dc331f78..b0105afe5d6 100644 > --- a/drivers/mmc/mmc.c > +++ b/drivers/mmc/mmc.c > @@ -294,7 +294,7 @@ int mmc_poll_for_busy(struct mmc *mmc, int
timeout_ms)
> > if (status & MMC_STATUS_MASK) { > #if !defined(CONFIG_SPL_BUILD) ||
> - pr_err("Status Error: 0x%08x\n", status); > + log_err("Status Error: %08x\n", status);
in
stuff?
Should have grepped in doc/ myself before asking others to do so for me :)
https://docs.u-boot.org/en/latest/usage/cmdline.html#representing-numbers documents this.
I would guess this is "good enough"? If not, not sure how to make this better? Hopefully, the commands that do not interpret as hex any string missing the 0x prefix have their help text specify this!
Cheers, Quentin
Hi Quentin,
On Tue, 13 Aug 2024 at 07:09, Quentin Schulz quentin.schulz@cherry.de wrote:
Hi Simon,
Hi Quentin,
Hi Simon,
Hi Quentin,
wrote:
Hi Simon,
Hi Quentin,
wrote:
> > Hi Simon, > > On 7/21/24 5:25 PM, Simon Glass wrote: >> Use the log subsystem instead of dev, to avoid including function
names
>> in the code. >> >> The CONFIG_LOGF_FUNC option can be used to enable the function name. >> >> Signed-off-by: Simon Glass sjg@chromium.org >> Reviewed-by: Sean Anderson seanga2@gmail.com >> --- >> >> (no changes since v1) >> >> drivers/mmc/mmc.c | 49
>> 1 file changed, 25 insertions(+), 24 deletions(-) >> >> diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c >> index b18dc331f78..b0105afe5d6 100644 >> --- a/drivers/mmc/mmc.c >> +++ b/drivers/mmc/mmc.c >> @@ -294,7 +294,7 @@ int mmc_poll_for_busy(struct mmc *mmc, int
timeout_ms)
>> >> if (status & MMC_STATUS_MASK) { >> #if !defined(CONFIG_SPL_BUILD) ||
>> - pr_err("Status Error: 0x%08x\n", status); >> + log_err("Status Error: %08x\n", status); > > Please don't remove the 0x prefix (will not comment on other patches
in
stuff?
Ah, good spotting!
Yes, one hopes so. Tests can help with that too, so long as the numbers are larger than 9.
Regards, SImon
Unless function names are requested, the logging system should not compile these into the code. Adjust the macros to handle this.
This means that turning on function names at runtime won't work unless CONFIG_LOGF_FUNC is enabled. We could perhaps split this into a separate option if that is a problem.
Enable CONFIG_LOGF_FUNC logging for sandbox since the tests expect the function names to be included. Fix up the pinmux test which checks a logging statement.
Changes in v2: - Update commit message to mention the runtime impact - Leave assert() alone since it is only compiled in with LOG_DEBUG
common/log_console.c | 4 ++-- configs/sandbox_defconfig | 1 + include/log.h | 16 +++++++++++----- test/cmd/pinmux.c | 8 +++++++- test/log/log_test.c | 4 ++-- 5 files changed, 23 insertions(+), 10 deletions(-)
diff --git a/common/log_console.c b/common/log_console.c index c27101b8fe2..9376baad664 100644 --- a/common/log_console.c +++ b/common/log_console.c @@ -38,10 +38,10 @@ static int log_console_emit(struct log_device *ldev, struct log_rec *rec) printf("%d-", rec->line); if (fmt & BIT(LOGF_FUNC)) { if (CONFIG_IS_ENABLED(USE_TINY_PRINTF)) { - printf("%s()", rec->func); + printf("%s()", rec->func ?: "?"); } else { printf("%*s()", CONFIG_LOGF_FUNC_PAD, - rec->func); + rec->func ?: "?"); } } } diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index dc5fcdbd1c9..a1a9e174de8 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -39,6 +39,7 @@ CONFIG_PRE_CONSOLE_BUFFER=y CONFIG_LOG=y CONFIG_LOG_MAX_LEVEL=9 CONFIG_LOG_DEFAULT_LEVEL=6 +CONFIG_LOGF_FUNC=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_STACKPROTECTOR=y CONFIG_CMD_CPU=y diff --git a/include/log.h b/include/log.h index fc0d5984472..69dcb339543 100644 --- a/include/log.h +++ b/include/log.h @@ -125,7 +125,7 @@ static inline int log_uc_cat(enum uclass_id id) * @level: Level of log record (indicating its severity) * @file: File name of file where log record was generated * @line: Line number in file where log record was generated - * @func: Function where log record was generated + * @func: Function where log record was generated, NULL if not known * @fmt: printf() format string for log record * @...: Optional parameters, according to the format string @fmt * Return: 0 if log record was emitted, -ve on error @@ -141,7 +141,7 @@ int _log(enum log_category_t cat, enum log_level_t level, const char *file, * @level: Level of log record (indicating its severity) * @file: File name of file where log record was generated * @line: Line number in file where log record was generated - * @func: Function where log record was generated + * @func: Function where log record was generated, NULL if not known * @addr: Starting address to display at start of line * @data: pointer to data buffer * @width: data value width. May be 1, 2, or 4. @@ -193,6 +193,12 @@ int _log_buffer(enum log_category_t cat, enum log_level_t level, #define _LOG_DEBUG 0 #endif
+#ifdef CONFIG_LOGF_FUNC +#define _log_func __func__ +#else +#define _log_func NULL +#endif + #if CONFIG_IS_ENABLED(LOG)
/* Emit a log record if the level is less that the maximum */ @@ -201,7 +207,7 @@ int _log_buffer(enum log_category_t cat, enum log_level_t level, if (_LOG_DEBUG != 0 || _l <= _LOG_MAX_LEVEL) \ _log((enum log_category_t)(_cat), \ (enum log_level_t)(_l | _LOG_DEBUG), __FILE__, \ - __LINE__, __func__, \ + __LINE__, _log_func, \ pr_fmt(_fmt), ##_args); \ })
@@ -211,7 +217,7 @@ int _log_buffer(enum log_category_t cat, enum log_level_t level, if (_LOG_DEBUG != 0 || _l <= _LOG_MAX_LEVEL) \ _log_buffer((enum log_category_t)(_cat), \ (enum log_level_t)(_l | _LOG_DEBUG), __FILE__, \ - __LINE__, __func__, _addr, _data, \ + __LINE__, _log_func, _addr, _data, \ _width, _count, _linelen); \ }) #else @@ -314,7 +320,7 @@ void __assert_fail(const char *assertion, const char *file, unsigned int line, #define assert_noisy(x) \ ({ bool _val = (x); \ if (!_val) \ - __assert_fail(#x, "?", __LINE__, __func__); \ + __assert_fail(#x, "?", __LINE__, _log_func); \ _val; \ })
diff --git a/test/cmd/pinmux.c b/test/cmd/pinmux.c index 4253baa5646..7ab7004b684 100644 --- a/test/cmd/pinmux.c +++ b/test/cmd/pinmux.c @@ -30,7 +30,13 @@ static int dm_test_cmd_pinmux_status_pinname(struct unit_test_state *uts)
console_record_reset(); run_command("pinmux status P9", 0); - ut_assert_nextlinen("single-pinctrl pinctrl-single-no-width: missing register width"); + if (IS_ENABLED(CONFIG_LOGF_FUNC)) { + ut_assert_nextlinen( + " single_of_to_plat() single-pinctrl pinctrl-single-no-width: missing register width"); + } else { + ut_assert_nextlinen( + "single-pinctrl pinctrl-single-no-width: missing register width"); + } ut_assert_nextlinen("P9 not found"); ut_assert_console_end();
diff --git a/test/log/log_test.c b/test/log/log_test.c index 855353a9c40..d756b96dbac 100644 --- a/test/log/log_test.c +++ b/test/log/log_test.c @@ -452,8 +452,8 @@ int log_test_buffer(struct unit_test_state *uts) /* This one should product no output due to the debug level */ log_buffer(LOGC_BOOT, LOGL_DEBUG, 0, buf, 1, 0x12, 0);
- ut_assert_nextline("00000000: 00 11 22 33 44 55 66 77 88 99 aa bb cc dd ee ff .."3DUfw........"); - ut_assert_nextline("00000010: 10 00 .."); + ut_assert_nextline(" log_test_buffer() 00000000: 00 11 22 33 44 55 66 77 88 99 aa bb cc dd ee ff .."3DUfw........"); + ut_assert_nextline(" log_test_buffer() 00000010: 10 00 .."); ut_assert_console_end(); free(buf);
Hi Simon,
I now understand the statement in patches earlier in this series :)
Changes in v2:
What about setting _log_func to "?" if LOGF_FUNC isn't set?
rec->func);
rec->func ?: "?");
I think you missed a similar change in common/log_syslog.c if I can trust my grep-fu?
Cheers, Quentin
Hi Quentin,
On Tue, 6 Aug 2024 at 08:16, Quentin Schulz quentin.schulz@cherry.de wrote:
Hi Simon,
Changes in v2:
That would require all call sites to pass a pointer to the string, rather than just NULL. I suspect it would increase code size?
rec->func);
rec->func ?: "?");
Yes, thanks.
Hi Simon,
Hi Quentin,
Hi Simon,
Changes in v2:
I probably missed something, but log_rec->func doesn't seem to be used in many places (common/log_console.c and common/log_syslog.c).
log_console_emit() is only called through log_dispatch() itself only called from _log().
_log is called from: - cmd/log.c:do_log_rec(), the func parameter is provided by argv[5] which I assume cannot be NULL because argc<7 is checked. - common/log.c:_log_buffer() which is called by log_buffer() - include/log.h:log()/log_buffer() which is modified to swap __func__ with _log_func (so __func__ or <insert placeholder> which is NULL or "?" I suggested there). the rec->func argument cannot be changed from any of the caller.
So I assume we would be fine?
As for the size increase, I would hope that the compiler knows it can store the same string at only one place and then reuse it instead of having it in many places, but I know nothing about compilers so it's just me guessing :)
In any case, either is fine by me!
Cheers, Quentin
Hi Quentin,
On Mon, 12 Aug 2024 at 10:56, Quentin Schulz quentin.schulz@cherry.de wrote:
Hi Simon,
Hi Quentin,
Hi Simon,
Changes in v2:
Just a note that I never got back to checking this. Common strings with the preprocessor end up with a single string in the object file, or at least they do in my experience. Since the function name is likely unique within U-Boot, this should be fine, as you say.
Outside a single compilation unit it can be a different story. I suspect (and hope) that LTO would deal with this OK, but otherwise I'm really not sure what would happen.
I suspect we may tweak this again, but this patch does resolve the code-size issue that bugged me.
This check is not needed now, since printf() resolved to nothing if not available. Drop the #ifdefs
common/spl/spl_mmc.c | 20 +------------------- 1 file changed, 1 insertion(+), 19 deletions(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index ccab0be4be2..ddc85aaeda7 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -51,9 +51,7 @@ int mmc_load_image_raw_sector(struct spl_image_info *spl_image, load.read = h_spl_load_read; ret = spl_load(spl_image, bootdev, &load, 0, sector << bd->log2blksz); if (ret) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT puts("mmc_load_image_raw_sector: mmc block read error\n"); -#endif return -1; }
@@ -70,9 +68,7 @@ static int spl_mmc_get_device_index(u32 boot_device) return 1; }
-#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("spl: unsupported mmc boot device.\n"); -#endif
return -ENODEV; } @@ -91,18 +87,14 @@ static int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device) err = mmc_initialize(NULL); #endif /* DM_MMC */ if (err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("spl: could not initialize mmc. error: %d\n", err); -#endif return err; } *mmcp = find_mmc_device(mmc_dev); err = *mmcp ? 0 : -ENODEV; if (err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("spl: could not find mmc device %d. error: %d\n", mmc_dev, err); -#endif return err; }
@@ -135,10 +127,8 @@ static int mmc_load_image_raw_partition(struct spl_image_info *spl_image,
err = part_get_info(mmc_get_blk_desc(mmc), partition, &info); if (err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT puts("spl: partition error\n"); -#endif - return -1; + return -err; }
#ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR @@ -164,9 +154,7 @@ static int mmc_load_image_raw_os(struct spl_image_info *spl_image, CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS, (void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR); if (count != CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT puts("mmc_load_image_raw_os: mmc block read error\n"); -#endif return -1; } #endif /* CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR */ @@ -368,9 +356,7 @@ int spl_mmc_load(struct spl_image_info *spl_image, err = mmc_init(mmc); if (err) { mmc = NULL; -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("spl: mmc init failed with error: %d\n", err); -#endif return err; } } @@ -387,9 +373,7 @@ int spl_mmc_load(struct spl_image_info *spl_image, err = blk_dselect_hwpart(mmc_get_blk_desc(mmc), part);
if (err) { -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT puts("spl: mmc partition switch failed\n"); -#endif return err; } /* Fall through */ @@ -428,10 +412,8 @@ int spl_mmc_load(struct spl_image_info *spl_image,
break; #endif -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT default: puts("spl: mmc: wrong boot mode\n"); -#endif }
return err;
Hi Simon,
Thanks! Quentin
Use 'ret' as the return code, since it may not be an error and this is the common name in U-Boot. Make sure to return the error code when given, rather than transforming it into -1 (-EPERM).
Changes in v2: - Update 'return ret' to 'return 0' when ret is known to be 0
common/spl/spl_mmc.c | 129 ++++++++++++++++++++++--------------------- 1 file changed, 65 insertions(+), 64 deletions(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index ddc85aaeda7..bc6087e88cd 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -52,7 +52,7 @@ int mmc_load_image_raw_sector(struct spl_image_info *spl_image, ret = spl_load(spl_image, bootdev, &load, 0, sector << bd->log2blksz); if (ret) { puts("mmc_load_image_raw_sector: mmc block read error\n"); - return -1; + return ret; }
return 0; @@ -75,27 +75,27 @@ static int spl_mmc_get_device_index(u32 boot_device)
static int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device) { - int err, mmc_dev; + int ret, mmc_dev;
mmc_dev = spl_mmc_get_device_index(boot_device); if (mmc_dev < 0) return mmc_dev;
#if CONFIG_IS_ENABLED(DM_MMC) - err = mmc_init_device(mmc_dev); + ret = mmc_init_device(mmc_dev); #else - err = mmc_initialize(NULL); + ret = mmc_initialize(NULL); #endif /* DM_MMC */ - if (err) { - printf("spl: could not initialize mmc. error: %d\n", err); - return err; + if (ret) { + printf("spl: could not initialize mmc. error: %d\n", ret); + return ret; } *mmcp = find_mmc_device(mmc_dev); - err = *mmcp ? 0 : -ENODEV; - if (err) { + ret = *mmcp ? 0 : -ENODEV; + if (ret) { printf("spl: could not find mmc device %d. error: %d\n", - mmc_dev, err); - return err; + mmc_dev, ret); + return ret; }
return 0; @@ -108,14 +108,14 @@ static int mmc_load_image_raw_partition(struct spl_image_info *spl_image, unsigned long sector) { struct disk_partition info; - int err; + int ret;
#ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE int type_part; /* Only support MBR so DOS_ENTRY_NUMBERS */ for (type_part = 1; type_part <= DOS_ENTRY_NUMBERS; type_part++) { - err = part_get_info(mmc_get_blk_desc(mmc), type_part, &info); - if (err) + ret = part_get_info(mmc_get_blk_desc(mmc), type_part, &info); + if (ret) continue; if (info.sys_ind == CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE) { @@ -125,10 +125,10 @@ static int mmc_load_image_raw_partition(struct spl_image_info *spl_image, } #endif
- err = part_get_info(mmc_get_blk_desc(mmc), partition, &info); - if (err) { + ret = part_get_info(mmc_get_blk_desc(mmc), partition, &info); + if (ret) { puts("spl: partition error\n"); - return -err; + return ret; }
#ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR @@ -155,7 +155,7 @@ static int mmc_load_image_raw_os(struct spl_image_info *spl_image, (void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR); if (count != CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS) { puts("mmc_load_image_raw_os: mmc block read error\n"); - return -1; + return -EIO; } #endif /* CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR */
@@ -193,7 +193,7 @@ static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct mmc *mmc, const char *filename) { - int err = -ENOSYS; + int ret = -ENOSYS;
__maybe_unused int partition = CONFIG_SYS_MMCSD_FS_BOOT_PARTITION;
@@ -202,8 +202,8 @@ static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct disk_partition info; debug("Checking for the first MBR bootable partition\n"); for (int type_part = 1; type_part <= DOS_ENTRY_NUMBERS; type_part++) { - err = part_get_info(mmc_get_blk_desc(mmc), type_part, &info); - if (err) + ret = part_get_info(mmc_get_blk_desc(mmc), type_part, &info); + if (ret) continue; debug("Partition %d is of type %d and bootable=%d\n", type_part, info.sys_ind, info.bootable); if (info.bootable != 0) { @@ -221,40 +221,40 @@ static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image,
#ifdef CONFIG_SPL_FS_FAT if (!spl_start_uboot()) { - err = spl_load_image_fat_os(spl_image, bootdev, mmc_get_blk_desc(mmc), - partition); - if (!err) - return err; + ret = spl_load_image_fat_os(spl_image, bootdev, mmc_get_blk_desc(mmc), + partition); + if (!ret) + return 0; } #ifdef CONFIG_SPL_FS_LOAD_PAYLOAD_NAME - err = spl_load_image_fat(spl_image, bootdev, mmc_get_blk_desc(mmc), + ret = spl_load_image_fat(spl_image, bootdev, mmc_get_blk_desc(mmc), partition, filename); - if (!err) - return err; + if (!ret) + return ret; #endif #endif #ifdef CONFIG_SPL_FS_EXT4 if (!spl_start_uboot()) { - err = spl_load_image_ext_os(spl_image, bootdev, mmc_get_blk_desc(mmc), - partition); - if (!err) - return err; + ret = spl_load_image_ext_os(spl_image, bootdev, mmc_get_blk_desc(mmc), + partition); + if (!ret) + return 0; } #ifdef CONFIG_SPL_FS_LOAD_PAYLOAD_NAME - err = spl_load_image_ext(spl_image, bootdev, mmc_get_blk_desc(mmc), + ret = spl_load_image_ext(spl_image, bootdev, mmc_get_blk_desc(mmc), partition, filename); - if (!err) - return err; + if (!ret) + return 0; #endif #endif
#if defined(CONFIG_SPL_FS_FAT) || defined(CONFIG_SPL_FS_EXT4) - err = -ENOENT; + ret = -ENOENT; #endif
- return err; + return ret; } #endif
@@ -342,73 +342,74 @@ int spl_mmc_load(struct spl_image_info *spl_image, unsigned long raw_sect) { u32 boot_mode; - int err = 0; + int ret = 0; __maybe_unused int part = 0; int mmc_dev;
/* Perform peripheral init only once for an mmc device */ mmc_dev = spl_mmc_get_device_index(bootdev->boot_device); if (!mmc || spl_mmc_get_mmc_devnum(mmc) != mmc_dev) { - err = spl_mmc_find_device(&mmc, bootdev->boot_device); - if (err) - return err; + ret = spl_mmc_find_device(&mmc, bootdev->boot_device); + if (ret) + return ret;
- err = mmc_init(mmc); - if (err) { + ret = mmc_init(mmc); + if (ret) { mmc = NULL; - printf("spl: mmc init failed with error: %d\n", err); - return err; + printf("spl: mmc init failed with error: %d\n", ret); + return ret; } }
boot_mode = spl_mmc_boot_mode(mmc, bootdev->boot_device); - err = -EINVAL; + ret = -EINVAL; switch (boot_mode) { case MMCSD_MODE_EMMCBOOT: part = spl_mmc_emmc_boot_partition(mmc);
if (CONFIG_IS_ENABLED(MMC_TINY)) - err = mmc_switch_part(mmc, part); + ret = mmc_switch_part(mmc, part); else - err = blk_dselect_hwpart(mmc_get_blk_desc(mmc), part); + ret = blk_dselect_hwpart(mmc_get_blk_desc(mmc), part);
- if (err) { + if (ret) { puts("spl: mmc partition switch failed\n"); - return err; + return ret; } /* Fall through */ case MMCSD_MODE_RAW: debug("spl: mmc boot mode: raw\n");
if (!spl_start_uboot()) { - err = mmc_load_image_raw_os(spl_image, bootdev, mmc); - if (!err) - return err; + ret = mmc_load_image_raw_os(spl_image, bootdev, mmc); + if (!ret) + return 0; }
raw_sect = spl_mmc_get_uboot_raw_sector(mmc, raw_sect);
#ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION - err = mmc_load_image_raw_partition(spl_image, bootdev, + ret = mmc_load_image_raw_partition(spl_image, bootdev, mmc, raw_part, raw_sect); - if (!err) - return err; + if (!ret) + return 0; #endif #ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR - err = mmc_load_image_raw_sector(spl_image, bootdev, mmc, - raw_sect + spl_mmc_raw_uboot_offset(part)); - if (!err) - return err; + ret = mmc_load_image_raw_sector(spl_image, bootdev, mmc, + raw_sect + + spl_mmc_raw_uboot_offset(part)); + if (!ret) + return 0; #endif /* If RAW mode fails, try FS mode. */ #ifdef CONFIG_SYS_MMCSD_FS_BOOT case MMCSD_MODE_FS: debug("spl: mmc boot mode: fs\n");
- err = spl_mmc_do_fs_boot(spl_image, bootdev, mmc, filename); - if (!err) - return err; + ret = spl_mmc_do_fs_boot(spl_image, bootdev, mmc, filename); + if (!ret) + return 0;
break; #endif @@ -416,7 +417,7 @@ int spl_mmc_load(struct spl_image_info *spl_image, puts("spl: mmc: wrong boot mode\n"); }
int spl_mmc_load_image(struct spl_image_info *spl_image,
At present spl_mmc_load() is the only caller of this function, passing it a boot_device, an index into the available MMC devices. Pass the device number instead, since it is known by the caller and simplifies the code.
Changes in v2: - Use uint for arg to spl_mmc_get_device_index()
common/spl/spl_mmc.c | 12 ++++-------- 1 file changed, 4 insertions(+), 8 deletions(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index bc6087e88cd..887ea760b84 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -58,7 +58,7 @@ int mmc_load_image_raw_sector(struct spl_image_info *spl_image, return 0; }
-static int spl_mmc_get_device_index(u32 boot_device) +static int spl_mmc_get_device_index(uint boot_device) { switch (boot_device) { case BOOT_DEVICE_MMC1: @@ -73,13 +73,9 @@ static int spl_mmc_get_device_index(u32 boot_device) return -ENODEV; }
-static int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device) +static int spl_mmc_find_device(struct mmc **mmcp, int mmc_dev) { - int ret, mmc_dev; - - mmc_dev = spl_mmc_get_device_index(boot_device); - if (mmc_dev < 0) - return mmc_dev; + int ret;
#if CONFIG_IS_ENABLED(DM_MMC) ret = mmc_init_device(mmc_dev); @@ -349,7 +345,7 @@ int spl_mmc_load(struct spl_image_info *spl_image, /* Perform peripheral init only once for an mmc device */ mmc_dev = spl_mmc_get_device_index(bootdev->boot_device); if (!mmc || spl_mmc_get_mmc_devnum(mmc) != mmc_dev) { - ret = spl_mmc_find_device(&mmc, bootdev->boot_device); + ret = spl_mmc_find_device(&mmc, mmc_dev); if (ret) return ret;
Hi Simon,
Thanks! Quentin
Make the raw-mode options depend on SPL_SYS_MMCSD_RAW_MODE in a more direct way. This makes it easier to understand the options with 'make menuconfig'.
There are three different ways of specifying the offset:
- sector offset - partition number - partition type
So make these a choice, so it is more obvious what is going on.
Update existing boards to enable SPL_SYS_MMCSD_RAW_MODE where needed.
Reviewed-by: Sean Anderson seanga2@gmail.com Signed-off-by: Simon Glass sjg@chromium.org ---
arch/arm/mach-imx/imx8m/soc.c | 2 + arch/arm/mach-imx/spl_imx_romapi.c | 13 ++++- .../imx8mp_rsb3720a1/imx8mp_rsb3720a1.c | 4 +- common/spl/Kconfig | 52 +++++++++++-------- configs/am335x_guardian_defconfig | 2 +- configs/am335x_pdu001_defconfig | 2 +- configs/am3517_evm_defconfig | 2 +- configs/am62ax_evm_a53_defconfig | 1 + configs/am62ax_evm_r5_defconfig | 1 + configs/am62px_evm_a53_defconfig | 1 + configs/am62px_evm_r5_defconfig | 1 + configs/am62x_beagleplay_a53_defconfig | 1 + configs/am62x_beagleplay_r5_defconfig | 1 + configs/am62x_evm_a53_defconfig | 1 + configs/am62x_evm_r5_defconfig | 1 + configs/am64x_evm_a53_defconfig | 1 + configs/am64x_evm_r5_defconfig | 1 + configs/am65x_evm_a53_defconfig | 1 + configs/am65x_evm_r5_defconfig | 1 + configs/brppt2_defconfig | 2 +- configs/brsmarc1_defconfig | 2 +- configs/cgtqmx8_defconfig | 1 + configs/chromebit_mickey_defconfig | 2 +- configs/chromebook_jerry_defconfig | 2 +- configs/chromebook_minnie_defconfig | 2 +- configs/chromebook_speedy_defconfig | 2 +- configs/ci20_mmc_defconfig | 1 + configs/da850evm_defconfig | 2 +- configs/da850evm_nand_defconfig | 2 +- configs/deneb_defconfig | 1 + configs/display5_defconfig | 2 +- configs/display5_factory_defconfig | 2 +- configs/draco-rastaban_defconfig | 2 +- configs/draco-thuban_defconfig | 2 +- .../gardena-smart-gateway-at91sam_defconfig | 2 +- configs/giedi_defconfig | 1 + configs/imx28_xea_defconfig | 1 + configs/imx28_xea_sb_defconfig | 1 + configs/imx6q_logic_defconfig | 2 +- configs/imx8mm-cl-iot-gate-optee_defconfig | 1 + configs/imx8mm-cl-iot-gate_defconfig | 1 + configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 1 + configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 1 + configs/imx8mm-mx8menlo_defconfig | 1 + configs/imx8mm-phygate-tauri-l_defconfig | 1 + configs/imx8mm_beacon_defconfig | 1 + configs/imx8mm_beacon_fspi_defconfig | 1 + configs/imx8mm_data_modul_edm_sbc_defconfig | 1 + configs/imx8mm_evk_defconfig | 1 + configs/imx8mm_evk_fspi_defconfig | 1 + configs/imx8mm_phg_defconfig | 1 + configs/imx8mm_venice_defconfig | 1 + configs/imx8mn_beacon_2g_defconfig | 1 + configs/imx8mn_beacon_defconfig | 1 + configs/imx8mn_beacon_fspi_defconfig | 1 + configs/imx8mn_bsh_smm_s2_defconfig | 1 + configs/imx8mn_bsh_smm_s2pro_defconfig | 1 + configs/imx8mn_ddr4_evk_defconfig | 1 + configs/imx8mn_evk_defconfig | 1 + configs/imx8mn_var_som_defconfig | 1 + configs/imx8mn_venice_defconfig | 1 + configs/imx8mp-icore-mx8mp-edimm2.2_defconfig | 1 + configs/imx8mp_beacon_defconfig | 1 + configs/imx8mp_data_modul_edm_sbc_defconfig | 1 + configs/imx8mp_debix_model_a_defconfig | 1 + configs/imx8mp_dhcom_pdk2_defconfig | 1 + configs/imx8mp_dhcom_pdk3_defconfig | 1 + configs/imx8mp_evk_defconfig | 1 + configs/imx8mp_rsb3720a1_4G_defconfig | 2 + configs/imx8mp_rsb3720a1_6G_defconfig | 1 + configs/imx8mp_venice_defconfig | 1 + configs/imx8mq_cm_defconfig | 1 + configs/imx8mq_evk_defconfig | 1 + configs/imx8mq_phanbell_defconfig | 1 + configs/imx8mq_reform2_defconfig | 1 + configs/imx8qm_mek_defconfig | 1 + configs/imx8qxp_mek_defconfig | 1 + configs/imx8ulp_evk_defconfig | 1 + configs/imx93-phyboard-segin_defconfig | 1 + configs/imx93_11x11_evk_defconfig | 1 + configs/imx93_11x11_evk_ld_defconfig | 1 + configs/imx93_var_som_defconfig | 1 + configs/imxrt1020-evk_defconfig | 1 + configs/imxrt1050-evk_defconfig | 1 + configs/imxrt1050-evk_fspi_defconfig | 1 + configs/imxrt1170-evk_defconfig | 1 + configs/iot2050_defconfig | 1 + configs/j7200_evm_a72_defconfig | 1 + configs/j7200_evm_r5_defconfig | 1 + configs/j721e_beagleboneai64_a72_defconfig | 1 + configs/j721e_beagleboneai64_r5_defconfig | 1 + configs/j721e_evm_a72_defconfig | 1 + configs/j721e_evm_r5_defconfig | 1 + configs/j721s2_evm_a72_defconfig | 1 + configs/j721s2_evm_r5_defconfig | 1 + configs/j722s_evm_a53_defconfig | 1 + configs/j722s_evm_r5_defconfig | 1 + configs/j784s4_evm_a72_defconfig | 1 + configs/j784s4_evm_r5_defconfig | 1 + configs/kontron-sl-mx8mm_defconfig | 1 + configs/kontron_pitx_imx8m_defconfig | 1 + configs/kontron_sl28_defconfig | 1 + configs/librem5_defconfig | 1 + configs/ls1021aiot_sdcard_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atsn_sdcard_defconfig | 1 + ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + configs/msc_sm2s_imx8mp_defconfig | 1 + configs/omap35_logic_defconfig | 2 +- configs/omap35_logic_somlv_defconfig | 2 +- configs/omap3_logic_defconfig | 2 +- configs/omap3_logic_somlv_defconfig | 2 +- configs/phycore-imx8mm_defconfig | 1 + configs/phycore-imx8mp_defconfig | 1 + configs/phycore_am62x_a53_defconfig | 1 + configs/phycore_am62x_r5_defconfig | 1 + configs/phycore_am64x_a53_defconfig | 1 + configs/phycore_am64x_r5_defconfig | 1 + configs/pico-imx8mq_defconfig | 1 + configs/sama5d27_wlsom1_ek_mmc_defconfig | 2 +- .../sama5d27_wlsom1_ek_qspiflash_defconfig | 2 +- configs/sama5d2_icp_mmc_defconfig | 2 +- configs/sandbox_noinst_defconfig | 1 + configs/sniper_defconfig | 2 +- configs/socfpga_secu1_defconfig | 2 +- configs/verdin-am62_a53_defconfig | 1 + configs/verdin-am62_r5_defconfig | 1 + configs/verdin-imx8mm_defconfig | 1 + configs/verdin-imx8mp_defconfig | 1 + 133 files changed, 175 insertions(+), 52 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index be38ca52885..f30178ae213 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -735,6 +735,7 @@ int boot_mode_getprisec(void) #endif
#if defined(CONFIG_IMX8MN) || defined(CONFIG_IMX8MP) +#ifdef SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION #define IMG_CNTN_SET1_OFFSET GENMASK(22, 19) unsigned long arch_spl_mmc_get_uboot_raw_sector(struct mmc *mmc, unsigned long raw_sect) @@ -769,6 +770,7 @@ unsigned long arch_spl_mmc_get_uboot_raw_sector(struct mmc *mmc,
return raw_sect; } +#endif /* SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION */ #endif
bool is_usb_boot(void) diff --git a/arch/arm/mach-imx/spl_imx_romapi.c b/arch/arm/mach-imx/spl_imx_romapi.c index 9a86f5c133f..bdaea439d7f 100644 --- a/arch/arm/mach-imx/spl_imx_romapi.c +++ b/arch/arm/mach-imx/spl_imx_romapi.c @@ -33,8 +33,17 @@ ulong spl_romapi_raw_seekable_read(u32 offset, u32 size, void *buf)
ulong __weak spl_romapi_get_uboot_base(u32 image_offset, u32 rom_bt_dev) { - return image_offset + - (CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512 - 0x8000); + u32 sector = 0; + + /* + * Some boards use this value even though MMC is not enabled in SPL, for + * example imx8mn_bsh_smm_s2 + */ +#ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR + sector = CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR; +#endif + + return image_offset + sector * 512 - 0x8000; }
static int is_boot_from_stream_device(u32 boot) diff --git a/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c b/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c index 070933fb54b..af083c3c38f 100644 --- a/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c +++ b/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c @@ -190,7 +190,7 @@ int board_late_init(void) return 0; }
-#ifdef CONFIG_SPL_MMC +#ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR #define UBOOT_RAW_SECTOR_OFFSET 0x40 unsigned long board_spl_mmc_get_uboot_raw_sector(struct mmc *mmc, unsigned long raw_sector) @@ -204,4 +204,4 @@ unsigned long board_spl_mmc_get_uboot_raw_sector(struct mmc *mmc, return CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR; } } -#endif /* CONFIG_SPL_MMC */ +#endif /* CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR */ diff --git a/common/spl/Kconfig b/common/spl/Kconfig index af43b5f5d3c..55a42a3a7c7 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -490,24 +490,45 @@ config SPL_DISPLAY_PRINT the board.
config SPL_SYS_MMCSD_RAW_MODE - bool - help - Support booting from an MMC without a filesystem. - -config SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR - bool "MMC raw mode: by sector" + bool "Use raw reads to locate the next boot phase" + depends on SPL_DM_MMC || SPL_MMC default y if ARCH_SUNXI || ARCH_DAVINCI || ARCH_UNIPHIER || \ ARCH_MX6 || ARCH_MX7 || \ ARCH_ROCKCHIP || ARCH_MVEBU || ARCH_SOCFPGA || \ ARCH_AT91 || ARCH_ZYNQ || ARCH_KEYSTONE || OMAP34XX || \ OMAP44XX || OMAP54XX || AM33XX || AM43XX || \ TARGET_SIFIVE_UNLEASHED || TARGET_SIFIVE_UNMATCHED + help + Support booting from an MMC without a filesystem. + +if SPL_SYS_MMCSD_RAW_MODE + +choice + prompt "Method for locating next phase of boot (e.g. U-Boot)" + +config SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR + bool "MMC raw mode: by sector" select SPL_LOAD_BLOCK if SPL_MMC - select SPL_SYS_MMCSD_RAW_MODE if SPL_MMC help Use sector number for specifying U-Boot location on MMC/SD in raw mode.
+config SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION + bool "MMC Raw mode: by partition" + select SPL_LOAD_BLOCK if SPL_MMC + help + Use a partition for loading U-Boot when using MMC/SD in raw mode. + +config SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE + bool "MMC raw mode: by partition type" + depends on DOS_PARTITION && SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION + help + Use partition type for specifying U-Boot partition on MMC/SD in + raw mode. U-Boot will be loaded from the first partition of this + type to be found. + +endchoice + config SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR hex "Address on the MMC to load U-Boot from" depends on SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR @@ -538,13 +559,6 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_DATA_PART_OFFSET
If unsure, leave the default.
-config SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION - bool "MMC Raw mode: by partition" - select SPL_LOAD_BLOCK if SPL_MMC - select SPL_SYS_MMCSD_RAW_MODE if SPL_MMC - help - Use a partition for loading U-Boot when using MMC/SD in raw mode. - config SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION hex "Partition to use to load U-Boot from" depends on SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION @@ -553,14 +567,6 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION Partition on the MMC to load U-Boot from when the MMC is being used in raw mode
-config SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE - bool "MMC raw mode: by partition type" - depends on DOS_PARTITION && SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION - help - Use partition type for specifying U-Boot partition on MMC/SD in - raw mode. U-Boot will be loaded from the first partition of this - type to be found. - config SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE hex "Partition Type on the MMC to load U-Boot from" depends on SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE @@ -568,6 +574,8 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE Partition Type on the MMC to load U-Boot from, when the MMC is being used in raw mode.
+endif # SPL_SYS_MMCSD_RAW_MODE + config SUPPORT_EMMC_BOOT_OVERRIDE_PART_CONFIG bool "Override eMMC EXT_CSC_PART_CONFIG by user defined partition" depends on SUPPORT_EMMC_BOOT diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index 75138542431..14a14c257c2 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -34,7 +34,7 @@ CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_ETH=y CONFIG_SPL_I2C=y diff --git a/configs/am335x_pdu001_defconfig b/configs/am335x_pdu001_defconfig index febe5ebaabb..ddb7ee9239c 100644 --- a/configs/am335x_pdu001_defconfig +++ b/configs/am335x_pdu001_defconfig @@ -26,7 +26,7 @@ CONFIG_BOOTCOMMAND="run eval_boot_device;part uuid mmc ${mmc_boot}:${root_fs_par CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_I2C=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_POWER=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 3236f1dd672..064c8bfe007 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -25,7 +25,7 @@ CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C is not set CONFIG_SPL_MTD=y diff --git a/configs/am62ax_evm_a53_defconfig b/configs/am62ax_evm_a53_defconfig index 4a351cd015a..b905ff74f2a 100644 --- a/configs/am62ax_evm_a53_defconfig +++ b/configs/am62ax_evm_a53_defconfig @@ -30,6 +30,7 @@ CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_PAD_TO=0x0 CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" diff --git a/configs/am62ax_evm_r5_defconfig b/configs/am62ax_evm_r5_defconfig index 44ccb6baa90..092d0830623 100644 --- a/configs/am62ax_evm_r5_defconfig +++ b/configs/am62ax_evm_r5_defconfig @@ -39,6 +39,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 CONFIG_SPL_DMA=y diff --git a/configs/am62px_evm_a53_defconfig b/configs/am62px_evm_a53_defconfig index 30d48340249..f367eb65031 100644 --- a/configs/am62px_evm_a53_defconfig +++ b/configs/am62px_evm_a53_defconfig @@ -37,6 +37,7 @@ CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_PAD_TO=0x0 CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y diff --git a/configs/am62px_evm_r5_defconfig b/configs/am62px_evm_r5_defconfig index ace55696737..4f7be44cfba 100644 --- a/configs/am62px_evm_r5_defconfig +++ b/configs/am62px_evm_r5_defconfig @@ -40,6 +40,7 @@ CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 CONFIG_SPL_DMA=y diff --git a/configs/am62x_beagleplay_a53_defconfig b/configs/am62x_beagleplay_a53_defconfig index 79c82d1ff7a..af54f9670a7 100644 --- a/configs/am62x_beagleplay_a53_defconfig +++ b/configs/am62x_beagleplay_a53_defconfig @@ -40,6 +40,7 @@ CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" diff --git a/configs/am62x_beagleplay_r5_defconfig b/configs/am62x_beagleplay_r5_defconfig index d0cc4f5b405..ee4c43ff97f 100644 --- a/configs/am62x_beagleplay_r5_defconfig +++ b/configs/am62x_beagleplay_r5_defconfig @@ -45,6 +45,7 @@ CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 CONFIG_SPL_DM_MAILBOX=y diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index ca993b427bd..0b7ee942a0a 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -38,6 +38,7 @@ CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" diff --git a/configs/am62x_evm_r5_defconfig b/configs/am62x_evm_r5_defconfig index 4b2e57b13a0..78ed3f62d06 100644 --- a/configs/am62x_evm_r5_defconfig +++ b/configs/am62x_evm_r5_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 CONFIG_SPL_DM_MAILBOX=y diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index 66792595711..9a70a304f2e 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -43,6 +43,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1800 CONFIG_SPL_DMA=y diff --git a/configs/am64x_evm_r5_defconfig b/configs/am64x_evm_r5_defconfig index 96475d4c1b8..1e83b7ff1fe 100644 --- a/configs/am64x_evm_r5_defconfig +++ b/configs/am64x_evm_r5_defconfig @@ -50,6 +50,7 @@ CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 CONFIG_SPL_DMA=y diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index 925a88e2547..f22b9afdb3b 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -44,6 +44,7 @@ CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y diff --git a/configs/am65x_evm_r5_defconfig b/configs/am65x_evm_r5_defconfig index 4fc9c39711c..1660bf93530 100644 --- a/configs/am65x_evm_r5_defconfig +++ b/configs/am65x_evm_r5_defconfig @@ -46,6 +46,7 @@ CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 CONFIG_SPL_DMA=y diff --git a/configs/brppt2_defconfig b/configs/brppt2_defconfig index 47b37bbc807..2f29cb3dc46 100644 --- a/configs/brppt2_defconfig +++ b/configs/brppt2_defconfig @@ -34,7 +34,7 @@ CONFIG_SYS_PBSIZE=532 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC=y -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_I2C=y CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig index f584b8d30b1..5b9a822c9ae 100644 --- a/configs/brsmarc1_defconfig +++ b/configs/brsmarc1_defconfig @@ -43,7 +43,7 @@ CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x500000 -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_I2C=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_DM_SPI_FLASH=y diff --git a/configs/cgtqmx8_defconfig b/configs/cgtqmx8_defconfig index 24dfdae11e3..a9283ad49ea 100644 --- a/configs/cgtqmx8_defconfig +++ b/configs/cgtqmx8_defconfig @@ -43,6 +43,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x120000 CONFIG_SPL_SYS_MALLOC_SIZE=0x3000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 CONFIG_SYS_MMCSD_FS_BOOT_PARTITION=0 diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index e5d805d7da7..93bf4f5c592 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -38,7 +38,7 @@ CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_NO_BSS_LIMIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_CMD_GPIO=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 9bc59539dc8..a1df1f830f0 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -37,7 +37,7 @@ CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_NO_BSS_LIMIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_CMD_GPIO=y diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index 26fa05e543b..03520b6af40 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -38,7 +38,7 @@ CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_NO_BSS_LIMIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_CMD_GPIO=y diff --git a/configs/chromebook_speedy_defconfig b/configs/chromebook_speedy_defconfig index 5deb09b28ec..607fd288197 100644 --- a/configs/chromebook_speedy_defconfig +++ b/configs/chromebook_speedy_defconfig @@ -38,7 +38,7 @@ CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_NO_BSS_LIMIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_CMD_GPIO=y diff --git a/configs/ci20_mmc_defconfig b/configs/ci20_mmc_defconfig index 39f33844e46..90574d2a157 100644 --- a/configs/ci20_mmc_defconfig +++ b/configs/ci20_mmc_defconfig @@ -32,6 +32,7 @@ CONFIG_SYS_MALLOC_BOOTPARAMS=y CONFIG_SPL_MAX_SIZE=0x2e00 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set # CONFIG_SPL_BANNER_PRINT is not set +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1c CONFIG_SPL_MMC_TINY=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 30d1a93fec3..d10faa5b275 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -50,7 +50,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xc0f70000 CONFIG_SPL_SYS_MALLOC_SIZE=0x110000 -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x8000 diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index 62cbd02b69a..7e59b6ff876 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -46,7 +46,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xc0f70000 CONFIG_SPL_SYS_MALLOC_SIZE=0x110000 -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/deneb_defconfig b/configs/deneb_defconfig index 4b9b0734c5a..4731e84e388 100644 --- a/configs/deneb_defconfig +++ b/configs/deneb_defconfig @@ -55,6 +55,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x120000 CONFIG_SPL_SYS_MALLOC_SIZE=0x3000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 CONFIG_SPL_POWER_DOMAIN=y diff --git a/configs/display5_defconfig b/configs/display5_defconfig index 1d3336b8c6a..7463f4f52b5 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -42,7 +42,7 @@ CONFIG_SYS_PBSIZE=2076 CONFIG_MISC_INIT_R=y CONFIG_SPL_BOOTCOUNT_LIMIT=y CONFIG_SPL_SYS_MALLOC=y -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_SAVEENV=y diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index 7c681f095c5..59d0c5d0370 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -39,7 +39,7 @@ CONFIG_SYS_CBSIZE=2048 CONFIG_SYS_PBSIZE=2084 CONFIG_MISC_INIT_R=y CONFIG_SPL_SYS_MALLOC=y -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_DMA=y CONFIG_SPL_I2C=y CONFIG_SPL_OS_BOOT=y diff --git a/configs/draco-rastaban_defconfig b/configs/draco-rastaban_defconfig index 43d29f5b11a..acba6f2b958 100644 --- a/configs/draco-rastaban_defconfig +++ b/configs/draco-rastaban_defconfig @@ -35,7 +35,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80208000 -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/draco-thuban_defconfig b/configs/draco-thuban_defconfig index b457b22fc64..dd4799f900a 100644 --- a/configs/draco-thuban_defconfig +++ b/configs/draco-thuban_defconfig @@ -35,7 +35,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80208000 -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_I2C=y CONFIG_SPL_NAND_DRIVERS=y CONFIG_SPL_NAND_ECC=y diff --git a/configs/gardena-smart-gateway-at91sam_defconfig b/configs/gardena-smart-gateway-at91sam_defconfig index 3b9466c830f..42f116fac13 100644 --- a/configs/gardena-smart-gateway-at91sam_defconfig +++ b/configs/gardena-smart-gateway-at91sam_defconfig @@ -46,7 +46,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_NAND_RAW_ONLY=y CONFIG_SPL_NAND_DRIVERS=y diff --git a/configs/giedi_defconfig b/configs/giedi_defconfig index c7390d1d323..774ab647ccd 100644 --- a/configs/giedi_defconfig +++ b/configs/giedi_defconfig @@ -55,6 +55,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x120000 CONFIG_SPL_SYS_MALLOC_SIZE=0x3000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 CONFIG_SPL_POWER_DOMAIN=y diff --git a/configs/imx28_xea_defconfig b/configs/imx28_xea_defconfig index 822a329187f..d1470014fd7 100644 --- a/configs/imx28_xea_defconfig +++ b/configs/imx28_xea_defconfig @@ -48,6 +48,7 @@ CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x0 CONFIG_SUPPORT_EMMC_BOOT_OVERRIDE_PART_CONFIG=y diff --git a/configs/imx28_xea_sb_defconfig b/configs/imx28_xea_sb_defconfig index 8d48d8c5078..aa1116aa4b0 100644 --- a/configs/imx28_xea_sb_defconfig +++ b/configs/imx28_xea_sb_defconfig @@ -29,6 +29,7 @@ CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0 CONFIG_SUPPORT_EMMC_BOOT_OVERRIDE_PART_CONFIG=y diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 7203583003c..b893da6c92a 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -30,7 +30,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_SYS_MALLOC=y -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_DMA=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot-dtb.img" CONFIG_SPL_I2C=y diff --git a/configs/imx8mm-cl-iot-gate-optee_defconfig b/configs/imx8mm-cl-iot-gate-optee_defconfig index f5bb50c5f39..0b7dd632b59 100644 --- a/configs/imx8mm-cl-iot-gate-optee_defconfig +++ b/configs/imx8mm-cl-iot-gate-optee_defconfig @@ -37,6 +37,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm-cl-iot-gate_defconfig b/configs/imx8mm-cl-iot-gate_defconfig index b36ad7c867c..9312e9f72a7 100644 --- a/configs/imx8mm-cl-iot-gate_defconfig +++ b/configs/imx8mm-cl-iot-gate_defconfig @@ -39,6 +39,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig index d4e9d9f342d..f37297cdbf7 100644 --- a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig +++ b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig @@ -36,6 +36,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_POWER=y diff --git a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig index c85a14119e7..950246ecded 100644 --- a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig +++ b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig @@ -36,6 +36,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_POWER=y diff --git a/configs/imx8mm-mx8menlo_defconfig b/configs/imx8mm-mx8menlo_defconfig index 5e6bbb3e508..8644177a769 100644 --- a/configs/imx8mm-mx8menlo_defconfig +++ b/configs/imx8mm-mx8menlo_defconfig @@ -52,6 +52,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm-phygate-tauri-l_defconfig b/configs/imx8mm-phygate-tauri-l_defconfig index 41765f1ddc5..51a6c6ea320 100644 --- a/configs/imx8mm-phygate-tauri-l_defconfig +++ b/configs/imx8mm-phygate-tauri-l_defconfig @@ -37,6 +37,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm_beacon_defconfig b/configs/imx8mm_beacon_defconfig index e3dcbfe0452..7f0cb9a06bf 100644 --- a/configs/imx8mm_beacon_defconfig +++ b/configs/imx8mm_beacon_defconfig @@ -38,6 +38,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm_beacon_fspi_defconfig b/configs/imx8mm_beacon_fspi_defconfig index 0aca853afd9..354a671bafb 100644 --- a/configs/imx8mm_beacon_fspi_defconfig +++ b/configs/imx8mm_beacon_fspi_defconfig @@ -41,6 +41,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm_data_modul_edm_sbc_defconfig b/configs/imx8mm_data_modul_edm_sbc_defconfig index f26a8791cd0..a78ae0c1eaa 100644 --- a/configs/imx8mm_data_modul_edm_sbc_defconfig +++ b/configs/imx8mm_data_modul_edm_sbc_defconfig @@ -59,6 +59,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm_evk_defconfig b/configs/imx8mm_evk_defconfig index ff33d1532a0..927b41c4cc2 100644 --- a/configs/imx8mm_evk_defconfig +++ b/configs/imx8mm_evk_defconfig @@ -35,6 +35,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm_evk_fspi_defconfig b/configs/imx8mm_evk_fspi_defconfig index a57dc47f26f..96c0a46bcec 100644 --- a/configs/imx8mm_evk_fspi_defconfig +++ b/configs/imx8mm_evk_fspi_defconfig @@ -39,6 +39,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm_phg_defconfig b/configs/imx8mm_phg_defconfig index e14dcdf9a3d..2fd319b3a6c 100644 --- a/configs/imx8mm_phg_defconfig +++ b/configs/imx8mm_phg_defconfig @@ -36,6 +36,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index f4d999bfcef..fc3e3ec3779 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -44,6 +44,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_beacon_2g_defconfig b/configs/imx8mn_beacon_2g_defconfig index 1129d8070cc..7a1931510e8 100644 --- a/configs/imx8mn_beacon_2g_defconfig +++ b/configs/imx8mn_beacon_2g_defconfig @@ -48,6 +48,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_beacon_defconfig b/configs/imx8mn_beacon_defconfig index f4af99847d1..eebfb0d7a7d 100644 --- a/configs/imx8mn_beacon_defconfig +++ b/configs/imx8mn_beacon_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_beacon_fspi_defconfig b/configs/imx8mn_beacon_fspi_defconfig index cecde443367..6acbb8a0215 100644 --- a/configs/imx8mn_beacon_fspi_defconfig +++ b/configs/imx8mn_beacon_fspi_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_bsh_smm_s2_defconfig b/configs/imx8mn_bsh_smm_s2_defconfig index b4351a392ef..29d7cdab922 100644 --- a/configs/imx8mn_bsh_smm_s2_defconfig +++ b/configs/imx8mn_bsh_smm_s2_defconfig @@ -42,6 +42,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_DMA=y diff --git a/configs/imx8mn_bsh_smm_s2pro_defconfig b/configs/imx8mn_bsh_smm_s2pro_defconfig index 0faa3376fd3..151a9a520ab 100644 --- a/configs/imx8mn_bsh_smm_s2pro_defconfig +++ b/configs/imx8mn_bsh_smm_s2pro_defconfig @@ -43,6 +43,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_ddr4_evk_defconfig b/configs/imx8mn_ddr4_evk_defconfig index 82e3ce19480..93380a0ddde 100644 --- a/configs/imx8mn_ddr4_evk_defconfig +++ b/configs/imx8mn_ddr4_evk_defconfig @@ -41,6 +41,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_evk_defconfig b/configs/imx8mn_evk_defconfig index 2402e9e8bfb..662703a312d 100644 --- a/configs/imx8mn_evk_defconfig +++ b/configs/imx8mn_evk_defconfig @@ -44,6 +44,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_var_som_defconfig b/configs/imx8mn_var_som_defconfig index 218415fad57..0155cb2044e 100644 --- a/configs/imx8mn_var_som_defconfig +++ b/configs/imx8mn_var_som_defconfig @@ -46,6 +46,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mn_venice_defconfig b/configs/imx8mn_venice_defconfig index b65fef0a806..93e6a28535c 100644 --- a/configs/imx8mn_venice_defconfig +++ b/configs/imx8mn_venice_defconfig @@ -46,6 +46,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp-icore-mx8mp-edimm2.2_defconfig b/configs/imx8mp-icore-mx8mp-edimm2.2_defconfig index 05f68c7e2ae..497a908f7a7 100644 --- a/configs/imx8mp-icore-mx8mp-edimm2.2_defconfig +++ b/configs/imx8mp-icore-mx8mp-edimm2.2_defconfig @@ -44,6 +44,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp_beacon_defconfig b/configs/imx8mp_beacon_defconfig index 3c337d4bd25..ba676c95467 100644 --- a/configs/imx8mp_beacon_defconfig +++ b/configs/imx8mp_beacon_defconfig @@ -53,6 +53,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp_data_modul_edm_sbc_defconfig b/configs/imx8mp_data_modul_edm_sbc_defconfig index fe3e757eefd..c8948e85961 100644 --- a/configs/imx8mp_data_modul_edm_sbc_defconfig +++ b/configs/imx8mp_data_modul_edm_sbc_defconfig @@ -66,6 +66,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x4c000000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp_debix_model_a_defconfig b/configs/imx8mp_debix_model_a_defconfig index aa1de6d6909..c76ab232b12 100644 --- a/configs/imx8mp_debix_model_a_defconfig +++ b/configs/imx8mp_debix_model_a_defconfig @@ -37,6 +37,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp_dhcom_pdk2_defconfig b/configs/imx8mp_dhcom_pdk2_defconfig index 79b3e96c8e3..f807b0cfc37 100644 --- a/configs/imx8mp_dhcom_pdk2_defconfig +++ b/configs/imx8mp_dhcom_pdk2_defconfig @@ -64,6 +64,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x4c000000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 # CONFIG_SPL_FIT_IMAGE_TINY is not set diff --git a/configs/imx8mp_dhcom_pdk3_defconfig b/configs/imx8mp_dhcom_pdk3_defconfig index 8ef8bf4db27..05895d6dd6f 100644 --- a/configs/imx8mp_dhcom_pdk3_defconfig +++ b/configs/imx8mp_dhcom_pdk3_defconfig @@ -66,6 +66,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x4c000000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 # CONFIG_SPL_FIT_IMAGE_TINY is not set diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index f5ba022b075..fe05eeadd70 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -41,6 +41,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp_rsb3720a1_4G_defconfig b/configs/imx8mp_rsb3720a1_4G_defconfig index 54789365aa9..7a7f3907b06 100644 --- a/configs/imx8mp_rsb3720a1_4G_defconfig +++ b/configs/imx8mp_rsb3720a1_4G_defconfig @@ -53,6 +53,8 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp_rsb3720a1_6G_defconfig b/configs/imx8mp_rsb3720a1_6G_defconfig index 4b0b71d03d9..75d110f91d1 100644 --- a/configs/imx8mp_rsb3720a1_6G_defconfig +++ b/configs/imx8mp_rsb3720a1_6G_defconfig @@ -53,6 +53,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mp_venice_defconfig b/configs/imx8mp_venice_defconfig index df93774b307..b08e4ae4e1f 100644 --- a/configs/imx8mp_venice_defconfig +++ b/configs/imx8mp_venice_defconfig @@ -48,6 +48,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mq_cm_defconfig b/configs/imx8mq_cm_defconfig index 5eb96d3826a..ac45c3d669d 100644 --- a/configs/imx8mq_cm_defconfig +++ b/configs/imx8mq_cm_defconfig @@ -40,6 +40,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index 3c1701a3768..2a51681c335 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -42,6 +42,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mq_phanbell_defconfig b/configs/imx8mq_phanbell_defconfig index 3a3fb754fa4..4c36827b2ae 100644 --- a/configs/imx8mq_phanbell_defconfig +++ b/configs/imx8mq_phanbell_defconfig @@ -43,6 +43,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8mq_reform2_defconfig b/configs/imx8mq_reform2_defconfig index 1844e3c8b84..2a951f16de4 100644 --- a/configs/imx8mq_reform2_defconfig +++ b/configs/imx8mq_reform2_defconfig @@ -45,6 +45,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/imx8qm_mek_defconfig b/configs/imx8qm_mek_defconfig index bf02d3e4f67..a96fb310cdd 100644 --- a/configs/imx8qm_mek_defconfig +++ b/configs/imx8qm_mek_defconfig @@ -48,6 +48,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x120000 CONFIG_SPL_SYS_MALLOC_SIZE=0x3000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 CONFIG_SPL_POWER_DOMAIN=y diff --git a/configs/imx8qxp_mek_defconfig b/configs/imx8qxp_mek_defconfig index d6b79f53893..56cc8347926 100644 --- a/configs/imx8qxp_mek_defconfig +++ b/configs/imx8qxp_mek_defconfig @@ -49,6 +49,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x120000 CONFIG_SPL_SYS_MALLOC_SIZE=0x3000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 CONFIG_SPL_POWER_DOMAIN=y diff --git a/configs/imx8ulp_evk_defconfig b/configs/imx8ulp_evk_defconfig index b302df1f351..7e1a53f289a 100644 --- a/configs/imx8ulp_evk_defconfig +++ b/configs/imx8ulp_evk_defconfig @@ -43,6 +43,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x22040000 CONFIG_SPL_SYS_MALLOC_SIZE=0x8000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_WATCHDOG=y diff --git a/configs/imx93-phyboard-segin_defconfig b/configs/imx93-phyboard-segin_defconfig index e3eb0029fa4..6e9e9c5a19b 100644 --- a/configs/imx93-phyboard-segin_defconfig +++ b/configs/imx93-phyboard-segin_defconfig @@ -44,6 +44,7 @@ CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_LOAD_IMX_CONTAINER=y CONFIG_IMX_CONTAINER_CFG="arch/arm/mach-imx/imx9/container.cfg" # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1040 CONFIG_SPL_I2C=y diff --git a/configs/imx93_11x11_evk_defconfig b/configs/imx93_11x11_evk_defconfig index 2246715d822..78efb7bae81 100644 --- a/configs/imx93_11x11_evk_defconfig +++ b/configs/imx93_11x11_evk_defconfig @@ -42,6 +42,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x83200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1040 CONFIG_SPL_I2C=y diff --git a/configs/imx93_11x11_evk_ld_defconfig b/configs/imx93_11x11_evk_ld_defconfig index deed068550a..fd33fd54762 100644 --- a/configs/imx93_11x11_evk_ld_defconfig +++ b/configs/imx93_11x11_evk_ld_defconfig @@ -43,6 +43,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x83200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1040 CONFIG_SPL_I2C=y diff --git a/configs/imx93_var_som_defconfig b/configs/imx93_var_som_defconfig index 94ce213f93a..14f220e8a3c 100644 --- a/configs/imx93_var_som_defconfig +++ b/configs/imx93_var_som_defconfig @@ -45,6 +45,7 @@ CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_LOAD_IMX_CONTAINER=y CONFIG_IMX_CONTAINER_CFG="arch/arm/mach-imx/imx9/container.cfg" # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1040 CONFIG_SPL_I2C=y diff --git a/configs/imxrt1020-evk_defconfig b/configs/imxrt1020-evk_defconfig index 80c8769926e..72bbd720153 100644 --- a/configs/imxrt1020-evk_defconfig +++ b/configs/imxrt1020-evk_defconfig @@ -31,6 +31,7 @@ CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x100 # CONFIG_BOOTM_NETBSD is not set diff --git a/configs/imxrt1050-evk_defconfig b/configs/imxrt1050-evk_defconfig index 086fc47ec27..fdbce8e6aa9 100644 --- a/configs/imxrt1050-evk_defconfig +++ b/configs/imxrt1050-evk_defconfig @@ -35,6 +35,7 @@ CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x100 CONFIG_SPL_NOR_SUPPORT=y diff --git a/configs/imxrt1050-evk_fspi_defconfig b/configs/imxrt1050-evk_fspi_defconfig index 4b252cfa5d0..03543ed0a30 100644 --- a/configs/imxrt1050-evk_fspi_defconfig +++ b/configs/imxrt1050-evk_fspi_defconfig @@ -36,6 +36,7 @@ CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x100 CONFIG_SPL_NOR_SUPPORT=y diff --git a/configs/imxrt1170-evk_defconfig b/configs/imxrt1170-evk_defconfig index 83825da6de9..fe0058aa5ce 100644 --- a/configs/imxrt1170-evk_defconfig +++ b/configs/imxrt1170-evk_defconfig @@ -31,6 +31,7 @@ CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x100 # CONFIG_BOOTM_NETBSD is not set diff --git a/configs/iot2050_defconfig b/configs/iot2050_defconfig index 8654bf20865..2a7a958dec2 100644 --- a/configs/iot2050_defconfig +++ b/configs/iot2050_defconfig @@ -53,6 +53,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DM_MAILBOX=y diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index fcfa9265996..137ca3f0d02 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -45,6 +45,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1800 CONFIG_SPL_DMA=y diff --git a/configs/j7200_evm_r5_defconfig b/configs/j7200_evm_r5_defconfig index e023af24674..774a9eff439 100644 --- a/configs/j7200_evm_r5_defconfig +++ b/configs/j7200_evm_r5_defconfig @@ -44,6 +44,7 @@ CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 CONFIG_SPL_DMA=y diff --git a/configs/j721e_beagleboneai64_a72_defconfig b/configs/j721e_beagleboneai64_a72_defconfig index ead1d8389c6..b720c74999d 100644 --- a/configs/j721e_beagleboneai64_a72_defconfig +++ b/configs/j721e_beagleboneai64_a72_defconfig @@ -44,6 +44,7 @@ CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y diff --git a/configs/j721e_beagleboneai64_r5_defconfig b/configs/j721e_beagleboneai64_r5_defconfig index 314161b8a62..ce96e4921b8 100644 --- a/configs/j721e_beagleboneai64_r5_defconfig +++ b/configs/j721e_beagleboneai64_r5_defconfig @@ -42,6 +42,7 @@ CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 CONFIG_SPL_DMA=y diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index acb6e9c556e..c50e98391ff 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -44,6 +44,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index f1c9bbd3fa8..3b4a7c3c0ee 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -49,6 +49,7 @@ CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 CONFIG_SPL_DMA=y diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index 5800e4be963..d78ebb5cfd4 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -43,6 +43,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index d0af664a6b7..b6adb6a77d7 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -50,6 +50,7 @@ CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 CONFIG_SPL_DMA=y diff --git a/configs/j722s_evm_a53_defconfig b/configs/j722s_evm_a53_defconfig index 1675cedb25e..98620222a07 100644 --- a/configs/j722s_evm_a53_defconfig +++ b/configs/j722s_evm_a53_defconfig @@ -37,6 +37,7 @@ CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_PAD_TO=0x0 CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y diff --git a/configs/j722s_evm_r5_defconfig b/configs/j722s_evm_r5_defconfig index 8ba3916807d..e574be9e19d 100644 --- a/configs/j722s_evm_r5_defconfig +++ b/configs/j722s_evm_r5_defconfig @@ -40,6 +40,7 @@ CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 CONFIG_SPL_DMA=y diff --git a/configs/j784s4_evm_a72_defconfig b/configs/j784s4_evm_a72_defconfig index d6505f60c57..29f9f3dabde 100644 --- a/configs/j784s4_evm_a72_defconfig +++ b/configs/j784s4_evm_a72_defconfig @@ -38,6 +38,7 @@ CONFIG_LOGLEVEL=7 CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y diff --git a/configs/j784s4_evm_r5_defconfig b/configs/j784s4_evm_r5_defconfig index 543b0a50d7a..a1168819497 100644 --- a/configs/j784s4_evm_r5_defconfig +++ b/configs/j784s4_evm_r5_defconfig @@ -44,6 +44,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 CONFIG_SPL_DMA=y diff --git a/configs/kontron-sl-mx8mm_defconfig b/configs/kontron-sl-mx8mm_defconfig index f2570289298..9321a077260 100644 --- a/configs/kontron-sl-mx8mm_defconfig +++ b/configs/kontron-sl-mx8mm_defconfig @@ -44,6 +44,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/kontron_pitx_imx8m_defconfig b/configs/kontron_pitx_imx8m_defconfig index c2133470fc9..52238831229 100644 --- a/configs/kontron_pitx_imx8m_defconfig +++ b/configs/kontron_pitx_imx8m_defconfig @@ -44,6 +44,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/kontron_sl28_defconfig b/configs/kontron_sl28_defconfig index a1d5f89b1ec..c4493e50a32 100644 --- a/configs/kontron_sl28_defconfig +++ b/configs/kontron_sl28_defconfig @@ -51,6 +51,7 @@ CONFIG_SPL_MAX_SIZE=0x20000 CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x900 CONFIG_SPL_MPC8XXX_INIT_DDR=y diff --git a/configs/librem5_defconfig b/configs/librem5_defconfig index 6999a689e29..248fc1fdde4 100644 --- a/configs/librem5_defconfig +++ b/configs/librem5_defconfig @@ -46,6 +46,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index 2354f4113ae..981093a9fb5 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -49,6 +49,7 @@ CONFIG_SPL_FSL_PBL=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x82080000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 136ca9a2670..4fc0e66e485 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -60,6 +60,7 @@ CONFIG_SPL_FSL_PBL=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80200000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index befb4ae442c..72632b87701 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -59,6 +59,7 @@ CONFIG_SPL_FSL_PBL=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x820c0000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index db06a03fe6b..78dce4dcbba 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -58,6 +58,7 @@ CONFIG_SPL_FSL_PBL=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x820c0000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021atsn_sdcard_defconfig b/configs/ls1021atsn_sdcard_defconfig index e5d8eeb8a2f..0853bfbd3a0 100644 --- a/configs/ls1021atsn_sdcard_defconfig +++ b/configs/ls1021atsn_sdcard_defconfig @@ -52,6 +52,7 @@ CONFIG_SPL_FSL_PBL=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x82100000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index dc0e507263f..28434d8e191 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -60,6 +60,7 @@ CONFIG_SPL_FSL_PBL=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x82104000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 9980d6106ec..b4348f12678 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -61,6 +61,7 @@ CONFIG_SPL_FSL_PBL=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x82100000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index ed92e34dccf..8d2c391f0e8 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -62,6 +62,7 @@ CONFIG_SPL_FSL_PBL=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x82100000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/msc_sm2s_imx8mp_defconfig b/configs/msc_sm2s_imx8mp_defconfig index 2e1d112a3e7..47ed5cfb214 100644 --- a/configs/msc_sm2s_imx8mp_defconfig +++ b/configs/msc_sm2s_imx8mp_defconfig @@ -43,6 +43,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index 23b2e503385..a35c027f952 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -28,7 +28,7 @@ CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C is not set CONFIG_SPL_MTD=y diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index a5f242ff40c..28e85bf5173 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -29,7 +29,7 @@ CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C is not set CONFIG_SPL_MTD=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index d081d4e0fb4..045290838e4 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -27,7 +27,7 @@ CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C is not set CONFIG_SPL_MTD=y diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 68e89d245ee..583f79059a5 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -29,7 +29,7 @@ CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C is not set CONFIG_SPL_MTD=y diff --git a/configs/phycore-imx8mm_defconfig b/configs/phycore-imx8mm_defconfig index f9fd7255df7..ce322887bae 100644 --- a/configs/phycore-imx8mm_defconfig +++ b/configs/phycore-imx8mm_defconfig @@ -38,6 +38,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/phycore-imx8mp_defconfig b/configs/phycore-imx8mp_defconfig index 8dd4963bdc0..a296d2e3a99 100644 --- a/configs/phycore-imx8mp_defconfig +++ b/configs/phycore-imx8mp_defconfig @@ -43,6 +43,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 # CONFIG_SPL_CRYPTO is not set diff --git a/configs/phycore_am62x_a53_defconfig b/configs/phycore_am62x_a53_defconfig index 39161b722b1..d8b129f7dd0 100644 --- a/configs/phycore_am62x_a53_defconfig +++ b/configs/phycore_am62x_a53_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/phycore_am62x_r5_defconfig b/configs/phycore_am62x_r5_defconfig index b7d0273dd74..7fc3abf1262 100644 --- a/configs/phycore_am62x_r5_defconfig +++ b/configs/phycore_am62x_r5_defconfig @@ -48,6 +48,7 @@ CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 CONFIG_SPL_I2C=y diff --git a/configs/phycore_am64x_a53_defconfig b/configs/phycore_am64x_a53_defconfig index 1af72e8bb32..5cf24b9debf 100644 --- a/configs/phycore_am64x_a53_defconfig +++ b/configs/phycore_am64x_a53_defconfig @@ -45,6 +45,7 @@ CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y diff --git a/configs/phycore_am64x_r5_defconfig b/configs/phycore_am64x_r5_defconfig index a0d78241928..72d10f76647 100644 --- a/configs/phycore_am64x_r5_defconfig +++ b/configs/phycore_am64x_r5_defconfig @@ -49,6 +49,7 @@ CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 CONFIG_SPL_DMA=y diff --git a/configs/pico-imx8mq_defconfig b/configs/pico-imx8mq_defconfig index cf91eb563b9..ef876abbd36 100644 --- a/configs/pico-imx8mq_defconfig +++ b/configs/pico-imx8mq_defconfig @@ -43,6 +43,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/sama5d27_wlsom1_ek_mmc_defconfig b/configs/sama5d27_wlsom1_ek_mmc_defconfig index 89a5bcdfac8..25213af37c5 100644 --- a/configs/sama5d27_wlsom1_ek_mmc_defconfig +++ b/configs/sama5d27_wlsom1_ek_mmc_defconfig @@ -48,7 +48,7 @@ CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SPL_DISPLAY_PRINT=y -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_AT91_MCK_BYPASS=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig index a07044578a8..5502858fead 100644 --- a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig +++ b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig @@ -48,7 +48,7 @@ CONFIG_SPL_MAX_SIZE=0x10000 CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SPL_DISPLAY_PRINT=y -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 diff --git a/configs/sama5d2_icp_mmc_defconfig b/configs/sama5d2_icp_mmc_defconfig index 6b9fa27de63..98b931c375d 100644 --- a/configs/sama5d2_icp_mmc_defconfig +++ b/configs/sama5d2_icp_mmc_defconfig @@ -49,7 +49,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 CONFIG_SPL_DISPLAY_PRINT=y -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_AT91_MCK_BYPASS=y diff --git a/configs/sandbox_noinst_defconfig b/configs/sandbox_noinst_defconfig index f37230151a0..bfd95e2398f 100644 --- a/configs/sandbox_noinst_defconfig +++ b/configs/sandbox_noinst_defconfig @@ -43,6 +43,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0xa000000 CONFIG_SPL_SYS_MALLOC_SIZE=0x4000000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x0 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index 0243b15f31c..d0dbd105d0c 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -22,7 +22,7 @@ CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80208000 -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=2 # CONFIG_SPL_FS_EXT4 is not set diff --git a/configs/socfpga_secu1_defconfig b/configs/socfpga_secu1_defconfig index a08ba22fdb5..3a3b8a77c22 100644 --- a/configs/socfpga_secu1_defconfig +++ b/configs/socfpga_secu1_defconfig @@ -42,7 +42,7 @@ CONFIG_SPL_PAD_TO=0x10000 CONFIG_SPL_NO_BSS_LIMIT=y CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK=y # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set -# CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set +# CONFIG_SPL_SYS_MMCSD_RAW_MODE is not set CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=0x1 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE is not set CONFIG_SPL_MTD=y diff --git a/configs/verdin-am62_a53_defconfig b/configs/verdin-am62_a53_defconfig index 464d0bbb159..27f089317e3 100644 --- a/configs/verdin-am62_a53_defconfig +++ b/configs/verdin-am62_a53_defconfig @@ -51,6 +51,7 @@ CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y diff --git a/configs/verdin-am62_r5_defconfig b/configs/verdin-am62_r5_defconfig index e39ee2ac6fe..bd9ecd94922 100644 --- a/configs/verdin-am62_r5_defconfig +++ b/configs/verdin-am62_r5_defconfig @@ -41,6 +41,7 @@ CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 CONFIG_SPL_ENV_SUPPORT=y diff --git a/configs/verdin-imx8mm_defconfig b/configs/verdin-imx8mm_defconfig index ef7f3b1bc10..9ca205586a0 100644 --- a/configs/verdin-imx8mm_defconfig +++ b/configs/verdin-imx8mm_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y diff --git a/configs/verdin-imx8mp_defconfig b/configs/verdin-imx8mp_defconfig index fca91f7b1ee..c74398f4f8b 100644 --- a/configs/verdin-imx8mp_defconfig +++ b/configs/verdin-imx8mp_defconfig @@ -60,6 +60,7 @@ CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x42200000 CONFIG_SPL_SYS_MALLOC_SIZE=0x80000 +CONFIG_SPL_SYS_MMCSD_RAW_MODE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 CONFIG_SPL_I2C=y
Hi Simon,
On 7/21/24 5:25 PM, Simon Glass wrote:
Make the raw-mode options depend on SPL_SYS_MMCSD_RAW_MODE in a more direct way. This makes it easier to understand the options with 'make menuconfig'.
There are three different ways of specifying the offset:
- sector offset
- partition number
- partition type
So make these a choice, so it is more obvious what is going on.
Update existing boards to enable SPL_SYS_MMCSD_RAW_MODE where needed.
Reviewed-by: Sean Anderson seanga2@gmail.com Signed-off-by: Simon Glass sjg@chromium.org
(no changes since v1)
arch/arm/mach-imx/imx8m/soc.c | 2 + arch/arm/mach-imx/spl_imx_romapi.c | 13 ++++- .../imx8mp_rsb3720a1/imx8mp_rsb3720a1.c | 4 +- common/spl/Kconfig | 52 +++++++++++-------- configs/am335x_guardian_defconfig | 2 +- configs/am335x_pdu001_defconfig | 2 +- configs/am3517_evm_defconfig | 2 +- configs/am62ax_evm_a53_defconfig | 1 + configs/am62ax_evm_r5_defconfig | 1 + configs/am62px_evm_a53_defconfig | 1 + configs/am62px_evm_r5_defconfig | 1 + configs/am62x_beagleplay_a53_defconfig | 1 + configs/am62x_beagleplay_r5_defconfig | 1 + configs/am62x_evm_a53_defconfig | 1 + configs/am62x_evm_r5_defconfig | 1 + configs/am64x_evm_a53_defconfig | 1 + configs/am64x_evm_r5_defconfig | 1 + configs/am65x_evm_a53_defconfig | 1 + configs/am65x_evm_r5_defconfig | 1 + configs/brppt2_defconfig | 2 +- configs/brsmarc1_defconfig | 2 +- configs/cgtqmx8_defconfig | 1 + configs/chromebit_mickey_defconfig | 2 +- configs/chromebook_jerry_defconfig | 2 +- configs/chromebook_minnie_defconfig | 2 +- configs/chromebook_speedy_defconfig | 2 +- configs/ci20_mmc_defconfig | 1 + configs/da850evm_defconfig | 2 +- configs/da850evm_nand_defconfig | 2 +- configs/deneb_defconfig | 1 + configs/display5_defconfig | 2 +- configs/display5_factory_defconfig | 2 +- configs/draco-rastaban_defconfig | 2 +- configs/draco-thuban_defconfig | 2 +- .../gardena-smart-gateway-at91sam_defconfig | 2 +- configs/giedi_defconfig | 1 + configs/imx28_xea_defconfig | 1 + configs/imx28_xea_sb_defconfig | 1 + configs/imx6q_logic_defconfig | 2 +- configs/imx8mm-cl-iot-gate-optee_defconfig | 1 + configs/imx8mm-cl-iot-gate_defconfig | 1 + configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 1 + configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 1 + configs/imx8mm-mx8menlo_defconfig | 1 + configs/imx8mm-phygate-tauri-l_defconfig | 1 + configs/imx8mm_beacon_defconfig | 1 + configs/imx8mm_beacon_fspi_defconfig | 1 + configs/imx8mm_data_modul_edm_sbc_defconfig | 1 + configs/imx8mm_evk_defconfig | 1 + configs/imx8mm_evk_fspi_defconfig | 1 + configs/imx8mm_phg_defconfig | 1 + configs/imx8mm_venice_defconfig | 1 + configs/imx8mn_beacon_2g_defconfig | 1 + configs/imx8mn_beacon_defconfig | 1 + configs/imx8mn_beacon_fspi_defconfig | 1 + configs/imx8mn_bsh_smm_s2_defconfig | 1 + configs/imx8mn_bsh_smm_s2pro_defconfig | 1 + configs/imx8mn_ddr4_evk_defconfig | 1 + configs/imx8mn_evk_defconfig | 1 + configs/imx8mn_var_som_defconfig | 1 + configs/imx8mn_venice_defconfig | 1 + configs/imx8mp-icore-mx8mp-edimm2.2_defconfig | 1 + configs/imx8mp_beacon_defconfig | 1 + configs/imx8mp_data_modul_edm_sbc_defconfig | 1 + configs/imx8mp_debix_model_a_defconfig | 1 + configs/imx8mp_dhcom_pdk2_defconfig | 1 + configs/imx8mp_dhcom_pdk3_defconfig | 1 + configs/imx8mp_evk_defconfig | 1 + configs/imx8mp_rsb3720a1_4G_defconfig | 2 + configs/imx8mp_rsb3720a1_6G_defconfig | 1 + configs/imx8mp_venice_defconfig | 1 + configs/imx8mq_cm_defconfig | 1 + configs/imx8mq_evk_defconfig | 1 + configs/imx8mq_phanbell_defconfig | 1 + configs/imx8mq_reform2_defconfig | 1 + configs/imx8qm_mek_defconfig | 1 + configs/imx8qxp_mek_defconfig | 1 + configs/imx8ulp_evk_defconfig | 1 + configs/imx93-phyboard-segin_defconfig | 1 + configs/imx93_11x11_evk_defconfig | 1 + configs/imx93_11x11_evk_ld_defconfig | 1 + configs/imx93_var_som_defconfig | 1 + configs/imxrt1020-evk_defconfig | 1 + configs/imxrt1050-evk_defconfig | 1 + configs/imxrt1050-evk_fspi_defconfig | 1 + configs/imxrt1170-evk_defconfig | 1 + configs/iot2050_defconfig | 1 + configs/j7200_evm_a72_defconfig | 1 + configs/j7200_evm_r5_defconfig | 1 + configs/j721e_beagleboneai64_a72_defconfig | 1 + configs/j721e_beagleboneai64_r5_defconfig | 1 + configs/j721e_evm_a72_defconfig | 1 + configs/j721e_evm_r5_defconfig | 1 + configs/j721s2_evm_a72_defconfig | 1 + configs/j721s2_evm_r5_defconfig | 1 + configs/j722s_evm_a53_defconfig | 1 + configs/j722s_evm_r5_defconfig | 1 + configs/j784s4_evm_a72_defconfig | 1 + configs/j784s4_evm_r5_defconfig | 1 + configs/kontron-sl-mx8mm_defconfig | 1 + configs/kontron_pitx_imx8m_defconfig | 1 + configs/kontron_sl28_defconfig | 1 + configs/librem5_defconfig | 1 + configs/ls1021aiot_sdcard_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atsn_sdcard_defconfig | 1 + ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + configs/msc_sm2s_imx8mp_defconfig | 1 + configs/omap35_logic_defconfig | 2 +- configs/omap35_logic_somlv_defconfig | 2 +- configs/omap3_logic_defconfig | 2 +- configs/omap3_logic_somlv_defconfig | 2 +- configs/phycore-imx8mm_defconfig | 1 + configs/phycore-imx8mp_defconfig | 1 + configs/phycore_am62x_a53_defconfig | 1 + configs/phycore_am62x_r5_defconfig | 1 + configs/phycore_am64x_a53_defconfig | 1 + configs/phycore_am64x_r5_defconfig | 1 + configs/pico-imx8mq_defconfig | 1 + configs/sama5d27_wlsom1_ek_mmc_defconfig | 2 +- .../sama5d27_wlsom1_ek_qspiflash_defconfig | 2 +- configs/sama5d2_icp_mmc_defconfig | 2 +- configs/sandbox_noinst_defconfig | 1 + configs/sniper_defconfig | 2 +- configs/socfpga_secu1_defconfig | 2 +- configs/verdin-am62_a53_defconfig | 1 + configs/verdin-am62_r5_defconfig | 1 + configs/verdin-imx8mm_defconfig | 1 + configs/verdin-imx8mp_defconfig | 1 + 133 files changed, 175 insertions(+), 52 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index be38ca52885..f30178ae213 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -735,6 +735,7 @@ int boot_mode_getprisec(void) #endif
#if defined(CONFIG_IMX8MN) || defined(CONFIG_IMX8MP) +#ifdef SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION #define IMG_CNTN_SET1_OFFSET GENMASK(22, 19) unsigned long arch_spl_mmc_get_uboot_raw_sector(struct mmc *mmc, unsigned long raw_sect) @@ -769,6 +770,7 @@ unsigned long arch_spl_mmc_get_uboot_raw_sector(struct mmc *mmc,
return raw_sect; } +#endif /* SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION */ #endif
bool is_usb_boot(void) diff --git a/arch/arm/mach-imx/spl_imx_romapi.c b/arch/arm/mach-imx/spl_imx_romapi.c index 9a86f5c133f..bdaea439d7f 100644 --- a/arch/arm/mach-imx/spl_imx_romapi.c +++ b/arch/arm/mach-imx/spl_imx_romapi.c @@ -33,8 +33,17 @@ ulong spl_romapi_raw_seekable_read(u32 offset, u32 size, void *buf)
ulong __weak spl_romapi_get_uboot_base(u32 image_offset, u32 rom_bt_dev) {
- return image_offset +
(CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512 - 0x8000);
- u32 sector = 0;
* Some boards use this value even though MMC is not enabled in SPL, for
* example imx8mn_bsh_smm_s2
+#ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
- sector = CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR;
return image_offset + sector * 512 - 0x8000; }
static int is_boot_from_stream_device(u32 boot)
diff --git a/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c b/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c index 070933fb54b..af083c3c38f 100644 --- a/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c +++ b/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c @@ -190,7 +190,7 @@ int board_late_init(void) return 0; }
-#ifdef CONFIG_SPL_MMC +#ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR #define UBOOT_RAW_SECTOR_OFFSET 0x40 unsigned long board_spl_mmc_get_uboot_raw_sector(struct mmc *mmc, unsigned long raw_sector) @@ -204,4 +204,4 @@ unsigned long board_spl_mmc_get_uboot_raw_sector(struct mmc *mmc, return CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR; } } -#endif /* CONFIG_SPL_MMC */ +#endif /* CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR */ diff --git a/common/spl/Kconfig b/common/spl/Kconfig index af43b5f5d3c..55a42a3a7c7 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -490,24 +490,45 @@ config SPL_DISPLAY_PRINT the board.
config SPL_SYS_MMCSD_RAW_MODE
- bool
- help
Support booting from an MMC without a filesystem.
-config SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
- bool "MMC raw mode: by sector"
- bool "Use raw reads to locate the next boot phase"
- depends on SPL_DM_MMC || SPL_MMC
This one is a weird one to me, we can have DM_MMC without MMC? Shouldn't we fix it?
default y if ARCH_SUNXI || ARCH_DAVINCI || ARCH_UNIPHIER || \ ARCH_MX6 || ARCH_MX7 || \ ARCH_ROCKCHIP || ARCH_MVEBU || ARCH_SOCFPGA || \ ARCH_AT91 || ARCH_ZYNQ || ARCH_KEYSTONE || OMAP34XX || \ OMAP44XX || OMAP54XX || AM33XX || AM43XX || \ TARGET_SIFIVE_UNLEASHED || TARGET_SIFIVE_UNMATCHED
- help
+if SPL_SYS_MMCSD_RAW_MODE
+choice
- prompt "Method for locating next phase of boot (e.g. U-Boot)"
+config SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR
- bool "MMC raw mode: by sector" select SPL_LOAD_BLOCK if SPL_MMC
We can remove the if SPL_MMC here as SPL_SYS_MMCSD_RAW_MODE already depends on it and this choice is guarded by it.
- select SPL_SYS_MMCSD_RAW_MODE if SPL_MMC help Use sector number for specifying U-Boot location on MMC/SD in raw mode.
+config SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION
- bool "MMC Raw mode: by partition"
Lower case "raw" here to match the two other choices?
- select SPL_LOAD_BLOCK if SPL_MMC
Ditto wrt SPL_MMC that I brought up earlier.
- help
Use a partition for loading U-Boot when using MMC/SD in raw mode.
+config SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE
- bool "MMC raw mode: by partition type"
- depends on DOS_PARTITION && SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION
This can never be met, as SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION is another option in the same choice.
Cheers, Quentin
Hi Quentin,
On Tue, 6 Aug 2024 at 08:53, Quentin Schulz quentin.schulz@cherry.de wrote:
Hi Simon,
- sector offset
- partition number
- partition type
return raw_sect;
u32 sector = 0;
bool
help
My understanding is that MMC means it supports mmc without driver model.
./tools/qconfig.py -f ~SPL_MMC SPL_DM_MMC 93 matches ./tools/qconfig.py -f SPL_MMC ~SPL_DM_MMC 254 matches
so there are cases on both sides...so it looks like we need it as I have it?
help
+choice
Oh that's interesting...will fix. it makes me wonder what happens with this mode with SPL_DM_MMC??
help
Cheers, Quentin
Rather than declaring completely separate functions, put the code for each case into the same function. This makes it easier to read.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Sean Anderson seanga2@gmail.com ---
include/spl.h | 18 +++++++----------- 1 file changed, 7 insertions(+), 11 deletions(-)
diff --git a/include/spl.h b/include/spl.h index 5dfdf778d2d..2f6a3e64c10 100644 --- a/include/spl.h +++ b/include/spl.h @@ -306,31 +306,27 @@ struct spl_load_info { void *buf); #if IS_ENABLED(CONFIG_SPL_LOAD_BLOCK) int bl_len; +#endif };
static inline int spl_get_bl_len(struct spl_load_info *info) { +#if IS_ENABLED(CONFIG_SPL_LOAD_BLOCK) return info->bl_len; -} - -static inline void spl_set_bl_len(struct spl_load_info *info, int bl_len) -{ - info->bl_len = bl_len; -} #else -}; - -static inline int spl_get_bl_len(struct spl_load_info *info) -{ return 1; +#endif }
static inline void spl_set_bl_len(struct spl_load_info *info, int bl_len) { +#if IS_ENABLED(CONFIG_SPL_LOAD_BLOCK) + info->bl_len = bl_len; +#else if (bl_len != 1) panic("CONFIG_SPL_LOAD_BLOCK not enabled"); -} #endif +}
/* * We need to know the position of U-Boot in memory so we can jump to it. We
Hi Simon,
Reviewed-by: Quentin Schulz quentin.schulz@cherry.de
Thanks! Quentin
Rather than having every caller set this up individually, create a common init function. This allows new fields to be added without the risk of them being left uninited.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Michael Trimarchi michael@amarulasolutions.com ---
arch/arm/mach-imx/spl_imx_romapi.c | 14 ++------- arch/arm/mach-sunxi/spl_spi_sunxi.c | 3 +- common/spl/spl_blk_fs.c | 9 ++---- common/spl/spl_ext.c | 3 +- common/spl/spl_fat.c | 10 +++---- common/spl/spl_mmc.c | 4 +-- common/spl/spl_nand.c | 4 +-- common/spl/spl_net.c | 3 +- common/spl/spl_nor.c | 6 ++-- common/spl/spl_ram.c | 3 +- common/spl/spl_semihosting.c | 4 +-- common/spl/spl_spi.c | 4 +-- common/spl/spl_ymodem.c | 4 +-- drivers/usb/gadget/f_sdp.c | 8 ++---- include/spl.h | 44 ++++++++++++++++++++--------- test/image/spl_load.c | 4 +-- test/image/spl_load_os.c | 6 +--- 17 files changed, 55 insertions(+), 78 deletions(-)
diff --git a/arch/arm/mach-imx/spl_imx_romapi.c b/arch/arm/mach-imx/spl_imx_romapi.c index bdaea439d7f..3982f4cca18 100644 --- a/arch/arm/mach-imx/spl_imx_romapi.c +++ b/arch/arm/mach-imx/spl_imx_romapi.c @@ -108,18 +108,13 @@ static int spl_romapi_load_image_seekable(struct spl_image_info *spl_image, if (IS_ENABLED(CONFIG_SPL_LOAD_FIT) && image_get_magic(header) == FDT_MAGIC) { struct spl_load_info load;
- memset(&load, 0, sizeof(load)); - spl_set_bl_len(&load, pagesize); - load.read = spl_romapi_read_seekable; + spl_load_init(&load, spl_romapi_read_seekable, NULL, pagesize); return spl_load_simple_fit(spl_image, &load, offset, header); } else if (IS_ENABLED(CONFIG_SPL_LOAD_IMX_CONTAINER) && valid_container_hdr((void *)header)) { struct spl_load_info load;
- memset(&load, 0, sizeof(load)); - spl_set_bl_len(&load, pagesize); - load.read = spl_romapi_read_seekable; - + spl_load_init(&load, spl_romapi_read_seekable, NULL, pagesize); ret = spl_load_imx_container(spl_image, &load, offset); } else { /* TODO */ @@ -341,10 +336,7 @@ static int spl_romapi_load_image_stream(struct spl_image_info *spl_image, ss.end = p; ss.pagesize = pagesize;
- memset(&load, 0, sizeof(load)); - spl_set_bl_len(&load, 1); - load.read = spl_romapi_read_stream; - load.priv = &ss; + spl_load_init(&load, spl_romapi_read_stream, &ss, 1);
return spl_load_simple_fit(spl_image, &load, (ulong)phdr, phdr); } diff --git a/arch/arm/mach-sunxi/spl_spi_sunxi.c b/arch/arm/mach-sunxi/spl_spi_sunxi.c index d7abdc2e401..5f72e809952 100644 --- a/arch/arm/mach-sunxi/spl_spi_sunxi.c +++ b/arch/arm/mach-sunxi/spl_spi_sunxi.c @@ -390,8 +390,7 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, struct spl_load_info load;
debug("Found FIT image\n"); - spl_set_bl_len(&load, 1); - load.read = spi_load_read; + spl_load_init(&load, spi_load_read, NULL, 1); ret = spl_load_simple_fit(spl_image, &load, load_offset, header); } else { diff --git a/common/spl/spl_blk_fs.c b/common/spl/spl_blk_fs.c index bc551c5c074..bbf90a9741e 100644 --- a/common/spl/spl_blk_fs.c +++ b/common/spl/spl_blk_fs.c @@ -80,11 +80,8 @@ int spl_blk_load_image(struct spl_image_info *spl_image, return ret; }
- load.read = spl_fit_read; - if (IS_ENABLED(CONFIG_SPL_FS_FAT_DMA_ALIGN)) - spl_set_bl_len(&load, ARCH_DMA_MINALIGN); - else - spl_set_bl_len(&load, 1); - load.priv = &dev; + spl_load_init(&load, spl_fit_read, &dev, + IS_ENABLED(CONFIG_SPL_FS_FAT_DMA_ALIGN) ? + ARCH_DMA_MINALIGN : 1); return spl_load(spl_image, bootdev, &load, filesize, 0); } diff --git a/common/spl/spl_ext.c b/common/spl/spl_ext.c index 76f49a5a8a6..c5478820a9b 100644 --- a/common/spl/spl_ext.c +++ b/common/spl/spl_ext.c @@ -51,8 +51,7 @@ int spl_load_image_ext(struct spl_image_info *spl_image, goto end; }
- spl_set_bl_len(&load, 1); - load.read = spl_fit_read; + spl_load_init(&load, spl_fit_read, NULL, 1); err = spl_load(spl_image, bootdev, &load, filelen, 0);
end: diff --git a/common/spl/spl_fat.c b/common/spl/spl_fat.c index bd8aab253a9..fce451b7664 100644 --- a/common/spl/spl_fat.c +++ b/common/spl/spl_fat.c @@ -83,12 +83,10 @@ int spl_load_image_fat(struct spl_image_info *spl_image, size = 0; }
- load.read = spl_fit_read; - if (IS_ENABLED(CONFIG_SPL_FS_FAT_DMA_ALIGN)) - spl_set_bl_len(&load, ARCH_DMA_MINALIGN); - else - spl_set_bl_len(&load, 1); - load.priv = (void *)filename; + spl_load_init(&load, spl_fit_read, (void *)filename, + IS_ENABLED(CONFIG_SPL_FS_FAT_DMA_ALIGN) ? + ARCH_DMA_MINALIGN : 1); + err = spl_load(spl_image, bootdev, &load, size, 0);
end: diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 887ea760b84..3fd81608e9f 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -46,9 +46,7 @@ int mmc_load_image_raw_sector(struct spl_image_info *spl_image, struct blk_desc *bd = mmc_get_blk_desc(mmc); struct spl_load_info load;
- load.priv = bd; - spl_set_bl_len(&load, bd->blksz); - load.read = h_spl_load_read; + spl_load_init(&load, h_spl_load_read, bd, bd->blksz); ret = spl_load(spl_image, bootdev, &load, 0, sector << bd->log2blksz); if (ret) { puts("mmc_load_image_raw_sector: mmc block read error\n"); diff --git a/common/spl/spl_nand.c b/common/spl/spl_nand.c index 5631fa6d563..22883f4e8b9 100644 --- a/common/spl/spl_nand.c +++ b/common/spl/spl_nand.c @@ -71,9 +71,7 @@ static int spl_nand_load_element(struct spl_image_info *spl_image, { struct spl_load_info load;
- load.priv = &offset; - spl_set_bl_len(&load, 1); - load.read = spl_nand_read; + spl_load_init(&load, spl_nand_read, &offset, 1); return spl_load(spl_image, bootdev, &load, 0, offset); }
diff --git a/common/spl/spl_net.c b/common/spl/spl_net.c index be7278bb933..2be7b73ed35 100644 --- a/common/spl/spl_net.c +++ b/common/spl/spl_net.c @@ -47,8 +47,7 @@ static int spl_net_load_image(struct spl_image_info *spl_image, return rv; }
- spl_set_bl_len(&load, 1); - load.read = spl_net_load_read; + spl_load_init(&load, spl_net_load_read, NULL, 1); return spl_load(spl_image, bootdev, &load, 0, 0); } #endif diff --git a/common/spl/spl_nor.c b/common/spl/spl_nor.c index ed76b5e1293..1021d933999 100644 --- a/common/spl/spl_nor.c +++ b/common/spl/spl_nor.c @@ -49,8 +49,7 @@ static int spl_nor_load_image(struct spl_image_info *spl_image, int ret;
debug("Found FIT\n"); - spl_set_bl_len(&load, 1); - load.read = spl_nor_load_read; + spl_load_init(&load, spl_nor_load_read, NULL, 1);
ret = spl_load_simple_fit(spl_image, &load, CONFIG_SYS_OS_BASE, @@ -93,8 +92,7 @@ static int spl_nor_load_image(struct spl_image_info *spl_image, * Load real U-Boot from its location in NOR flash to its * defined location in SDRAM */ - spl_set_bl_len(&load, 1); - load.read = spl_nor_load_read; + spl_load_init(&load, spl_nor_load_read, NULL, 1); return spl_load(spl_image, bootdev, &load, 0, spl_nor_get_uboot_base()); } SPL_LOAD_IMAGE_METHOD("NOR", 0, BOOT_DEVICE_NOR, spl_nor_load_image); diff --git a/common/spl/spl_ram.c b/common/spl/spl_ram.c index 5a23841f698..71b7a8374bb 100644 --- a/common/spl/spl_ram.c +++ b/common/spl/spl_ram.c @@ -69,8 +69,7 @@ static int spl_ram_load_image(struct spl_image_info *spl_image, struct spl_load_info load;
debug("Found FIT\n"); - spl_set_bl_len(&load, 1); - load.read = spl_ram_load_read; + spl_load_init(&load, spl_ram_load_read, NULL, 1); ret = spl_load_simple_fit(spl_image, &load, 0, header); } else { ulong u_boot_pos = spl_get_image_pos(); diff --git a/common/spl/spl_semihosting.c b/common/spl/spl_semihosting.c index 2047248f39b..f36863fe48d 100644 --- a/common/spl/spl_semihosting.c +++ b/common/spl/spl_semihosting.c @@ -43,9 +43,7 @@ static int spl_smh_load_image(struct spl_image_info *spl_image, } len = ret;
- load.read = smh_fit_read; - spl_set_bl_len(&load, 1); - load.priv = &fd; + spl_load_init(&load, smh_fit_read, &fd, 1); ret = spl_load(spl_image, bootdev, &load, len, 0); if (ret) log_debug("could not read %s: %d\n", filename, ret); diff --git a/common/spl/spl_spi.c b/common/spl/spl_spi.c index 8ab4803f7c4..691a431a926 100644 --- a/common/spl/spl_spi.c +++ b/common/spl/spl_spi.c @@ -77,9 +77,7 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, return -ENODEV; }
- load.priv = flash; - spl_set_bl_len(&load, 1); - load.read = spl_spi_fit_read; + spl_load_init(&load, spl_spi_fit_read, flash, 1);
#if CONFIG_IS_ENABLED(OS_BOOT) if (spl_start_uboot()) { diff --git a/common/spl/spl_ymodem.c b/common/spl/spl_ymodem.c index 4c7222af612..2be957134c1 100644 --- a/common/spl/spl_ymodem.c +++ b/common/spl/spl_ymodem.c @@ -132,11 +132,9 @@ int spl_ymodem_load_image(struct spl_image_info *spl_image, struct ymodem_fit_info info;
debug("Found FIT\n"); - load.priv = (void *)&info; - spl_set_bl_len(&load, 1); + spl_load_init(&load, ymodem_read_fit, (void *)&info, 1); info.buf = buf; info.image_read = BUF_SIZE; - load.read = ymodem_read_fit; ret = spl_load_simple_fit(spl_image, &load, 0, (void *)buf); size = info.image_read;
diff --git a/drivers/usb/gadget/f_sdp.c b/drivers/usb/gadget/f_sdp.c index 89496917a61..8a962c038fe 100644 --- a/drivers/usb/gadget/f_sdp.c +++ b/drivers/usb/gadget/f_sdp.c @@ -843,9 +843,7 @@ static int sdp_handle_in_ep(struct spl_image_info *spl_image, struct spl_load_info load;
debug("Found FIT\n"); - load.priv = header; - spl_set_bl_len(&load, 1); - load.read = sdp_load_read; + spl_load_init(&load, sdp_load_read, header, 1); spl_load_simple_fit(spl_image, &load, 0, header);
@@ -856,9 +854,7 @@ static int sdp_handle_in_ep(struct spl_image_info *spl_image, valid_container_hdr((void *)header)) { struct spl_load_info load;
- load.priv = header; - spl_set_bl_len(&load, 1); - load.read = sdp_load_read; + spl_load_init(&load, sdp_load_read, header, 1); spl_load_imx_container(spl_image, &load, 0); return SDP_EXIT; } diff --git a/include/spl.h b/include/spl.h index 2f6a3e64c10..12bf308e890 100644 --- a/include/spl.h +++ b/include/spl.h @@ -282,28 +282,32 @@ static inline void *spl_image_fdt_addr(struct spl_image_info *info) #endif }
+struct spl_load_info; + +/** + * spl_load_reader() - Read from device + * + * @load: Information about the load state + * @offset: Offset to read from in bytes. This must be a multiple of + * @load->bl_len. + * @count: Number of bytes to read. This must be a multiple of + * @load->bl_len. + * @buf: Buffer to read into + * @return number of bytes read, 0 on error + */ +typedef ulong (*spl_load_reader)(struct spl_load_info *load, ulong sector, + ulong count, void *buf); + /** * Information required to load data from a device * + * @read: Function to call to read from the device * @priv: Private data for the device * @bl_len: Block length for reading in bytes - * @read: Function to call to read from the device */ struct spl_load_info { + spl_load_reader read; void *priv; - /** - * read() - Read from device - * - * @load: Information about the load state - * @offset: Offset to read from in bytes. This must be a multiple of - * @load->bl_len. - * @count: Number of bytes to read. This must be a multiple of - * @load->bl_len. - * @buf: Buffer to read into - * @return number of bytes read, 0 on error - */ - ulong (*read)(struct spl_load_info *load, ulong sector, ulong count, - void *buf); #if IS_ENABLED(CONFIG_SPL_LOAD_BLOCK) int bl_len; #endif @@ -328,6 +332,18 @@ static inline void spl_set_bl_len(struct spl_load_info *info, int bl_len) #endif }
+/** + * spl_load_init() - Set up a new spl_load_info structure + */ +static inline void spl_load_init(struct spl_load_info *load, + spl_load_reader h_read, void *priv, + uint bl_len) +{ + load->read = h_read; + load->priv = priv; + spl_set_bl_len(load, bl_len); +} + /* * We need to know the position of U-Boot in memory so we can jump to it. We * allow any U-Boot binary to be used (u-boot.bin, u-boot-nodtb.bin, diff --git a/test/image/spl_load.c b/test/image/spl_load.c index 7cbad40ea0c..3b6206955d3 100644 --- a/test/image/spl_load.c +++ b/test/image/spl_load.c @@ -343,9 +343,7 @@ static int spl_test_image(struct unit_test_state *uts, const char *test_name, } else { struct spl_load_info load;
- spl_set_bl_len(&load, 1); - load.priv = img; - load.read = spl_test_read; + spl_load_init(&load, spl_test_read, img, 1); if (type == IMX8) ut_assertok(spl_load_imx_container(&info_read, &load, 0)); diff --git a/test/image/spl_load_os.c b/test/image/spl_load_os.c index 7d5fb9b07e0..dc09ba191bf 100644 --- a/test/image/spl_load_os.c +++ b/test/image/spl_load_os.c @@ -49,9 +49,7 @@ static int spl_test_load(struct unit_test_state *uts) int ret; int fd;
- memset(&load, '\0', sizeof(load)); - spl_set_bl_len(&load, 512); - load.read = read_fit_image; + spl_load_init(&load, read_fit_image, &text_ctx, 512);
ret = sandbox_find_next_phase(fname, sizeof(fname), true); if (ret) @@ -64,8 +62,6 @@ static int spl_test_load(struct unit_test_state *uts) ut_asserteq(512, os_read(fd, header, 512)); text_ctx.fd = fd;
- load.priv = &text_ctx; - ut_assertok(spl_load_simple_fit(&image, &load, 0, header));
Update the comment to match the function. Fix the indentation while we are here.
include/blk.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/blk.h b/include/blk.h index 7c7cf7f2b10..1fc9a5b8471 100644 --- a/include/blk.h +++ b/include/blk.h @@ -650,7 +650,7 @@ struct blk_driver *blk_driver_lookup_type(int uclass_id); struct blk_desc *blk_get_devnum_by_uclass_id(enum uclass_id uclass_id, int devnum);
/** - * blk_get_devnum_by_uclass_id() - Get a block device by type name, and number + * blk_get_devnum_by_uclass_idname() - Get block device by type name and number * * This looks up the block device type based on @uclass_idname, then calls * blk_get_devnum_by_uclass_id(). @@ -660,7 +660,7 @@ struct blk_desc *blk_get_devnum_by_uclass_id(enum uclass_id uclass_id, int devnu * Return: point to block device descriptor, or NULL if not found */ struct blk_desc *blk_get_devnum_by_uclass_idname(const char *uclass_idname, - int devnum); + int devnum);
/** * blk_dselect_hwpart() - select a hardware partition
Hi Simon,
Thanks! Quentin
Quentin Schulz
