[U-Boot] [PATCH v4 00/11] sunxi: sun5/7i: add the psci suspend function
Hi all,
Respin this series that was sent in October 2016, with comments and new psci aware SoC taken into account.
This series adds an implementation of the psci suspend function for both sun5i and sun7i. This was tested on Nextthing's CHIP, using cpuidle in Linux.
As the sun5i does not have a GIC, I needed to remove some code from the generic psci code. To do this I added an ARM_GIC Kconfig option which needs to be selected by each SoC having a GIC. I already added the relevant lines for SoCs selecting ARCH_SUPPORT_PSCI. As this Kconfig option is currently only used in the psci code, it should be safe to add it even if all the SoCs having a GIC do not select it, as long as they don't have psci functions.
On multi-core systems, we need to ensure all CPU are in psci suspend function to switch the cpu clk source. Likewise, the first CPU to exit the psci suspend function should restore the cpu clk source; and only the first one. This series adds a few atomic operation (with return support) in order to solve this problem. I used the Linux implementation.
This series is based on sunxi/master (6e39de1b337e) and can be found on: https://github.com/atenart/u-boot sunxi/psci-suspend
Thanks!
Antoine
Since v3: - Reworked the atomic functions with return support, based on the Linux implementation. - Do not disable LDO anymore. - Added some comments. - Poll the pll1 lock bit before switching to it. - Select CONFIG_ARM_GIC directly in CONFIG_TEGRA_COMMON. - Select ARM_GIC for mx7 and uniphier as well.
Since v2: - Stopped putting the dram into self-refresh. - Removed pll2-7 disabling. - Added an atomic variable to only change the cpuclk source when all CPUs are in idle. - Did a similar implementation to be sure the first CPU to leave the idle mode switches back the cpuclk source to pll1. - Rebased on the latest master and updated the patches.
Since v1: - Rebased on the latest master and updated the patches. - Fixed a compile warning I introduced in virt-v7.c - Added the missing ARM_GIC Kconfig options. - Fixed a commit message (removed 'HYP').
Antoine Tenart (11): arm: add atomic functions with return support arm: add the ARM_GIC configuration option sunxi: select ARM_GIC for sun[6789]i arm: select ARM_GIC for SoCs having a psci implementation tegra: select ARM_GIC for Tegra SoCs mx7: select ARM_GIC uniphier: select ARM_GIC arm: psci: protect GIC specific code with ARM_GIC sun5/7i: add an implementation of the psci suspend function sun5i: add defines used by the PSCI code sun5i: boot in non-secure mode by default
arch/arm/Kconfig | 13 ++++ arch/arm/cpu/armv7/mx7/Kconfig | 1 + arch/arm/cpu/armv7/nonsec_virt.S | 6 ++ arch/arm/cpu/armv7/sunxi/Makefile | 9 ++- arch/arm/cpu/armv7/sunxi/psci.c | 40 +--------- arch/arm/cpu/armv7/sunxi/psci.h | 58 ++++++++++++++ arch/arm/cpu/armv7/sunxi/psci_suspend.c | 108 ++++++++++++++++++++++++++ arch/arm/cpu/armv7/virt-v7.c | 42 ++++++---- arch/arm/include/asm/arch-sunxi/clock_sun4i.h | 2 + arch/arm/include/asm/atomic.h | 36 +++++++++ arch/arm/mach-tegra/Kconfig | 1 + arch/arm/mach-uniphier/Kconfig | 1 + board/sunxi/Kconfig | 12 +++ include/configs/sun5i.h | 2 + 14 files changed, 278 insertions(+), 53 deletions(-) create mode 100644 arch/arm/cpu/armv7/sunxi/psci.h create mode 100644 arch/arm/cpu/armv7/sunxi/psci_suspend.c
Implement three atomic functions to allow making an atomic operation that returns the value. Adds: atomic_add_return(), atomic_sub_return(), atomic_inc_return() and atomic_dec_return().
This is heavily based on the Linux implementation of such functions for ARM.
Signed-off-by: Antoine Tenart antoine.tenart@free-electrons.com Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Mark Rutland mark.rutland@arm.com --- arch/arm/include/asm/atomic.h | 36 ++++++++++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+)
diff --git a/arch/arm/include/asm/atomic.h b/arch/arm/include/asm/atomic.h index 171f4d979281..4bfe62afaca1 100644 --- a/arch/arm/include/asm/atomic.h +++ b/arch/arm/include/asm/atomic.h @@ -73,6 +73,42 @@ static inline void atomic_dec(volatile atomic_t *v) local_irq_restore(flags); }
+#define ATOMIC_OP_RETURN(op, c_op, asm_op) \ +static inline int atomic_##op##_return(int i, volatile atomic_t *v) \ +{ \ + unsigned long tmp; \ + int result; \ + \ + /* prefetch */ \ + __asm__ __volatile__("pld\t%a0" \ + :: "p" (&v->counter)); \ + \ + __asm__ __volatile__("@ atomic_" #op "_return\n" \ +"1: ldrex %0, [%3]\n" \ +" " #asm_op " %0, %0, %4\n" \ +" strex %1, %0, [%3]\n" \ +" teq %1, #0\n" \ +" bne 1b" \ + : "=&r" (result), "=&r" (tmp), "+Qo" (v->counter) \ + : "r" (&v->counter), "Ir" (i) \ + : "cc"); \ + \ + return result; \ +} + +ATOMIC_OP_RETURN(add, +=, add) +ATOMIC_OP_RETURN(sub, -=, sub) + +static inline int atomic_inc_return(volatile atomic_t *v) +{ + return atomic_add_return(1, v); +} + +static inline int atomic_dec_return(volatile atomic_t *v) +{ + return atomic_sub_return(1, v); +} + static inline int atomic_dec_and_test(volatile atomic_t *v) { unsigned long flags = 0;
Some SoC does not have a GIC. Adds a configuration option to denote this, allowing to remove code configuring the GIC when it's not possible.
Signed-off-by: Antoine Tenart antoine.tenart@free-electrons.com Cc: Albert Aribaud albert.u.boot@aribaud.net --- arch/arm/Kconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index d8669ce7d6b1..c7aebae3b039 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -13,6 +13,9 @@ config DMA_ADDR_T_64BIT bool default y if ARM64
+config ARM_GIC + bool + config HAS_VBAR bool
Select the newly introduced ARM_GIC option to the relevant sunxi MACH configurations.
Signed-off-by: Antoine Tenart antoine.tenart@free-electrons.com --- board/sunxi/Kconfig | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 27bd42c64b98..e53cd9c21c33 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -83,6 +83,7 @@ config MACH_SUN5I
config MACH_SUN6I bool "sun6i (Allwinner A31)" + select ARM_GIC select CPU_V7 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT @@ -93,6 +94,7 @@ config MACH_SUN6I
config MACH_SUN7I bool "sun7i (Allwinner A20)" + select ARM_GIC select CPU_V7 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT @@ -103,6 +105,7 @@ config MACH_SUN7I
config MACH_SUN8I_A23 bool "sun8i (Allwinner A23)" + select ARM_GIC select CPU_V7 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT @@ -113,6 +116,7 @@ config MACH_SUN8I_A23
config MACH_SUN8I_A33 bool "sun8i (Allwinner A33)" + select ARM_GIC select CPU_V7 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT @@ -123,12 +127,14 @@ config MACH_SUN8I_A33
config MACH_SUN8I_A83T bool "sun8i (Allwinner A83T)" + select ARM_GIC select CPU_V7 select SUNXI_GEN_SUN6I select SUPPORT_SPL
config MACH_SUN8I_H3 bool "sun8i (Allwinner H3)" + select ARM_GIC select CPU_V7 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT @@ -138,6 +144,7 @@ config MACH_SUN8I_H3
config MACH_SUN8I_R40 bool "sun8i (Allwinner R40)" + select ARM_GIC select CPU_V7 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT @@ -147,6 +154,7 @@ config MACH_SUN8I_R40
config MACH_SUN8I_V3S bool "sun8i (Allwinner V3s)" + select ARM_GIC select CPU_V7 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT @@ -156,6 +164,7 @@ config MACH_SUN8I_V3S
config MACH_SUN9I bool "sun9i (Allwinner A80)" + select ARM_GIC select CPU_V7 select SUNXI_HIGH_SRAM select SUNXI_GEN_SUN6I
Select the newly introduced ARM_GIC option to the relevant MACH configurations.
Signed-off-by: Antoine Tenart antoine.tenart@free-electrons.com Cc: Albert Aribaud albert.u.boot@aribaud.net --- arch/arm/Kconfig | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index c7aebae3b039..8b13f6909f9c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -472,6 +472,7 @@ config ARCH_BCM283X
config TARGET_VEXPRESS_CA15_TC2 bool "Support vexpress_ca15_tc2" + select ARM_GIC select CPU_V7 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT @@ -556,14 +557,17 @@ config TARGET_BCM23550_W1D
config TARGET_BCM28155_AP bool "Support bcm28155_ap" + select ARM_GIC select CPU_V7
config TARGET_BCMCYGNUS bool "Support bcmcygnus" + select ARM_GIC select CPU_V7
config TARGET_BCMNSP bool "Support bcmnsp" + select ARM_GIC select CPU_V7
config TARGET_BCMNS2 @@ -622,6 +626,7 @@ config ARCH_MX7ULP
config ARCH_MX7 bool "Freescale MX7" + select ARM_GIC select CPU_V7 select SYS_FSL_HAS_SEC if SECURE_BOOT select SYS_FSL_SEC_COMPAT_4 @@ -995,6 +1000,7 @@ config TARGET_LS1012AFRDM
config TARGET_LS1021AQDS bool "Support ls1021aqds" + select ARM_GIC select BOARD_LATE_INIT select CPU_V7 select CPU_V7_HAS_NONSEC @@ -1008,6 +1014,7 @@ config TARGET_LS1021AQDS
config TARGET_LS1021ATWR bool "Support ls1021atwr" + select ARM_GIC select BOARD_LATE_INIT select CPU_V7 select CPU_V7_HAS_NONSEC @@ -1020,6 +1027,7 @@ config TARGET_LS1021ATWR
config TARGET_LS1021AIOT bool "Support ls1021aiot" + select ARM_GIC select BOARD_LATE_INIT select CPU_V7 select CPU_V7_HAS_NONSEC @@ -1100,7 +1108,9 @@ config TARGET_COLIBRI_PXA270
config ARCH_UNIPHIER bool "Socionext UniPhier SoCs" + select ARM_GIC select BOARD_LATE_INIT + select BLK select CLK_UNIPHIER select DM select DM_GPIO
2017-04-30 22:29 GMT+09:00 Antoine Tenart antoine.tenart@free-electrons.com:
"select BLK" is totally unrelated, and wrong. Please remove.
In 07/11, you add "select ARM_GIC" to ARCH_UNIPHIER_32BIT.
Here, "select ARM_GIC" to ARCH_UNIPHER including 32bit and 64bit.
What is your intention for CONFIG_ARM_GIC? As far as I see 08, this option is only effective for ARMv7.
Select the newly introduced ARM_GIC option to the relevant configuration which also have a psci implementation.
Signed-off-by: Antoine Tenart antoine.tenart@free-electrons.com Cc: Tom Warren twarren@nvidia.com --- arch/arm/mach-tegra/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index c67ffa5a2356..01f27b465bfe 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -22,6 +22,7 @@ config TEGRA_IVC
config TEGRA_COMMON bool "Tegra common options" + select ARM_GIC select CLK select DM select DM_ETH
Adding Stephen and Thierry for review/input. Antoine - what testing did you do?
Tom
-----Original Message----- From: Antoine Tenart [mailto:antoine.tenart@free-electrons.com] Sent: Sunday, April 30, 2017 6:30 AM To: maxime.ripard@free-electrons.com; wens@csie.org; jagan@openedev.com Cc: Antoine Tenart antoine.tenart@free-electrons.com; u- boot@lists.denx.de; Tom Warren TWarren@nvidia.com Subject: [PATCH v4 05/11] tegra: select ARM_GIC for Tegra SoCs
- select ARM_GIC select CLK select DM select DM_ETH
-- 2.11.0
----------------------------------------------------------------------------------- This email message is for the sole use of the intended recipient(s) and may contain confidential information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message. -----------------------------------------------------------------------------------
Antoine Tenart wrote at Sunday, April 30, 2017 6:30 AM:
It's true that all Tegra have ARM_GIC.
However, the commit description makes it sound as if enabling ARM_GIC enables PSCI support. That doesn't seem likely, but if it is true, I don't think this patch is correct. What is the actual implication of this patch?
Hi Stephen,
The commit description is misleading then. Selecting ARM_GIC doesn't enables PSCI support. However the common PSCI code is using the GIC which is not possible on all SoC. This new ARM_GIC option helps using (or not) the GIC specific code in PSCI. So, it's important to select this new option on a SoC previously supporting PSCI in U-Boot but it won't do anything if the SoC doesn't have a PSCI implementation.
As for Tegra SoCs, a few of them provide a PSCI implementation. At first I selected ARM_GIC only for those providing a PSCI implementation but we decided to do this directly for all Tegra SoCs (in the v3 thread) as this option doesn't do anything not related to PSCI, and because all Tegra SoCs do have a GIC.
Thanks, Antoine
On 05/02/2017 12:51 AM, Antoine Tenart wrote:
Hi Stephen,
OK, then the patch content sounds fine. I'd suggest rewording the commit description to more fully explain the situation; something similar to what you wrote in email above. Thanks.
Hi Stephen,
I tested using CPU idle with a mainline kernel on both the CHIP and an A20 board (both have an Allwinner SoC). I also measured the overall power consumption using the ACME cape from BayLibre.
Antoine
On Tue, May 02, 2017 at 08:39:03AM +0200, Antoine Tenart wrote:
Hi Stephen,
Of course I meant Tom... Sorry for that.
Antoine
Antoine
-- Antoine Ténart, Free Electrons Embedded Linux and Kernel engineering http://free-electrons.com
Signed-off-by: Antoine Tenart antoine.tenart@free-electrons.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/armv7/mx7/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/cpu/armv7/mx7/Kconfig b/arch/arm/cpu/armv7/mx7/Kconfig index 8dfb4c96464f..412e4aba3c2a 100644 --- a/arch/arm/cpu/armv7/mx7/Kconfig +++ b/arch/arm/cpu/armv7/mx7/Kconfig @@ -2,6 +2,7 @@ if ARCH_MX7
config MX7 bool + select ARM_GIC select ROM_UNIFIED_SECTIONS select CPU_V7_HAS_VIRT select CPU_V7_HAS_NONSEC
Signed-off-by: Antoine Tenart antoine.tenart@free-electrons.com Cc: Masahiro Yamada yamada.masahiro@socionext.com --- arch/arm/mach-uniphier/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-uniphier/Kconfig b/arch/arm/mach-uniphier/Kconfig index 5739325da71b..e6164974db57 100644 --- a/arch/arm/mach-uniphier/Kconfig +++ b/arch/arm/mach-uniphier/Kconfig @@ -5,6 +5,7 @@ config SYS_CONFIG_NAME
config ARCH_UNIPHIER_32BIT bool + select ARM_GIC select CPU_V7 select CPU_V7_HAS_NONSEC select ARMV7_NONSEC
Introducing the ARM_GIC configuration option, use it to only use GIC specific code in ARM PSCI function when the SoC has a GIC.
Signed-off-by: Antoine Tenart antoine.tenart@free-electrons.com Cc: Albert ARIBAUD albert.u.boot@aribaud.net --- arch/arm/cpu/armv7/nonsec_virt.S | 6 ++++++ arch/arm/cpu/armv7/virt-v7.c | 42 ++++++++++++++++++++++++++-------------- 2 files changed, 34 insertions(+), 14 deletions(-)
diff --git a/arch/arm/cpu/armv7/nonsec_virt.S b/arch/arm/cpu/armv7/nonsec_virt.S index e39aba711587..fb9902cc7253 100644 --- a/arch/arm/cpu/armv7/nonsec_virt.S +++ b/arch/arm/cpu/armv7/nonsec_virt.S @@ -164,6 +164,7 @@ ENDPROC(_smp_pen) * though, but we check this in C before calling this function. */ ENTRY(_nonsec_init) +#ifdef CONFIG_ARM_GIC get_gicd_addr r3
mvn r1, #0 @ all bits to 1 @@ -175,6 +176,7 @@ ENTRY(_nonsec_init) str r1, [r3, #GICC_CTLR] @ and clear all other bits mov r1, #0xff str r1, [r3, #GICC_PMR] @ set priority mask register +#endif
mrc p15, 0, r0, c1, c1, 2 movw r1, #0x3fff @@ -200,7 +202,11 @@ ENTRY(_nonsec_init) mcr p15, 0, r1, c12, c0, 1 @ set MVBAR to secure vectors isb
+#ifdef CONFIG_ARM_GIC mov r0, r3 @ return GICC address +#else + mov r0, #0 +#endif bx lr ENDPROC(_nonsec_init)
diff --git a/arch/arm/cpu/armv7/virt-v7.c b/arch/arm/cpu/armv7/virt-v7.c index d33e5c61a9c2..a34305853a34 100644 --- a/arch/arm/cpu/armv7/virt-v7.c +++ b/arch/arm/cpu/armv7/virt-v7.c @@ -82,22 +82,11 @@ void __weak smp_kick_all_cpus(void) kick_secondary_cpus_gic(gic_dist_addr); }
-__weak void psci_board_init(void) -{ -} - -int armv7_init_nonsec(void) +#ifdef CONFIG_ARM_GIC +static int psci_gic_setup(void) { - unsigned int reg; - unsigned itlinesnr, i; unsigned long gic_dist_addr; - - /* check whether the CPU supports the security extensions */ - reg = read_id_pfr1(); - if ((reg & 0xF0) == 0) { - printf("nonsec: Security extensions not implemented.\n"); - return -1; - } + unsigned itlinesnr, i;
/* the SCR register will be set directly in the monitor mode handler, * according to the spec one should not tinker with it in secure state @@ -123,6 +112,31 @@ int armv7_init_nonsec(void) for (i = 1; i <= itlinesnr; i++) writel((unsigned)-1, gic_dist_addr + GICD_IGROUPRn + 4 * i);
+ return 0; +} +#endif + +__weak void psci_board_init(void) +{ +} + +int armv7_init_nonsec(void) +{ + unsigned int reg; + + /* check whether the CPU supports the security extensions */ + reg = read_id_pfr1(); + if ((reg & 0xF0) == 0) { + printf("nonsec: Security extensions not implemented.\n"); + return -1; + } + +#ifdef CONFIG_ARM_GIC + int ret = psci_gic_setup(); + if (ret) + return ret; +#endif + psci_board_init();
Add the suspend psci function for sun5i and sun7i. Thus function switches the cpu clk source to osc24M or to losc depending on the SoC family.
Signed-off-by: Antoine Tenart antoine.tenart@free-electrons.com --- arch/arm/cpu/armv7/sunxi/Makefile | 9 ++- arch/arm/cpu/armv7/sunxi/psci.c | 40 +--------- arch/arm/cpu/armv7/sunxi/psci.h | 58 ++++++++++++++ arch/arm/cpu/armv7/sunxi/psci_suspend.c | 108 ++++++++++++++++++++++++++ arch/arm/include/asm/arch-sunxi/clock_sun4i.h | 2 + 5 files changed, 178 insertions(+), 39 deletions(-) create mode 100644 arch/arm/cpu/armv7/sunxi/psci.h create mode 100644 arch/arm/cpu/armv7/sunxi/psci_suspend.c
diff --git a/arch/arm/cpu/armv7/sunxi/Makefile b/arch/arm/cpu/armv7/sunxi/Makefile index b35b9df4a9d6..80667268a0fc 100644 --- a/arch/arm/cpu/armv7/sunxi/Makefile +++ b/arch/arm/cpu/armv7/sunxi/Makefile @@ -13,7 +13,14 @@ obj-$(CONFIG_MACH_SUN6I) += tzpc.o obj-$(CONFIG_MACH_SUN8I_H3) += tzpc.o
ifndef CONFIG_SPL_BUILD -obj-$(CONFIG_ARMV7_PSCI) += psci.o +ifdef CONFIG_ARMV7_PSCI +obj-$(CONFIG_MACH_SUN6I) += psci.o +obj-$(CONFIG_MACH_SUN7I) += psci.o +obj-$(CONFIG_MACH_SUN8I) += psci.o + +obj-$(CONFIG_MACH_SUN5I) += psci_suspend.o +obj-$(CONFIG_MACH_SUN7I) += psci_suspend.o +endif endif
ifdef CONFIG_SPL_BUILD diff --git a/arch/arm/cpu/armv7/sunxi/psci.c b/arch/arm/cpu/armv7/sunxi/psci.c index b3a34de1aafe..a86608cf3493 100644 --- a/arch/arm/cpu/armv7/sunxi/psci.c +++ b/arch/arm/cpu/armv7/sunxi/psci.c @@ -22,6 +22,8 @@
#include <linux/bitops.h>
+#include "psci.h" + #define __irq __attribute__ ((interrupt ("IRQ")))
#define GICD_BASE (SUNXI_GIC400_BASE + GIC_DIST_OFFSET) @@ -38,44 +40,6 @@ #define SUN8I_R40_PWR_CLAMP(cpu) (0x120 + (cpu) * 0x4) #define SUN8I_R40_SRAMC_SOFT_ENTRY_REG0 (0xbc)
-static void __secure cp15_write_cntp_tval(u32 tval) -{ - asm volatile ("mcr p15, 0, %0, c14, c2, 0" : : "r" (tval)); -} - -static void __secure cp15_write_cntp_ctl(u32 val) -{ - asm volatile ("mcr p15, 0, %0, c14, c2, 1" : : "r" (val)); -} - -static u32 __secure cp15_read_cntp_ctl(void) -{ - u32 val; - - asm volatile ("mrc p15, 0, %0, c14, c2, 1" : "=r" (val)); - - return val; -} - -#define ONE_MS (COUNTER_FREQUENCY / 1000) - -static void __secure __mdelay(u32 ms) -{ - u32 reg = ONE_MS * ms; - - cp15_write_cntp_tval(reg); - isb(); - cp15_write_cntp_ctl(3); - - do { - isb(); - reg = cp15_read_cntp_ctl(); - } while (!(reg & BIT(2))); - - cp15_write_cntp_ctl(0); - isb(); -} - static void __secure clamp_release(u32 __maybe_unused *clamp) { #if defined(CONFIG_MACH_SUN6I) || defined(CONFIG_MACH_SUN7I) || \ diff --git a/arch/arm/cpu/armv7/sunxi/psci.h b/arch/arm/cpu/armv7/sunxi/psci.h new file mode 100644 index 000000000000..248c25772e65 --- /dev/null +++ b/arch/arm/cpu/armv7/sunxi/psci.h @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2016 + * Author: Chen-Yu Tsai wens@csie.org + * + * Based on assembly code by Marc Zyngier marc.zyngier@arm.com, + * which was based on code by Carl van Schaik carl@ok-labs.com. + * + * SPDX-License-Identifier: GPL-2.0 + */ +#ifndef _SUNXI_PSCI_H_ +#define _SUNXI_PSCI_H_ + +#include <asm/armv7.h> +#include <linux/bitops.h> + +#ifdef CONFIG_TIMER_CLK_FREQ +static void __secure cp15_write_cntp_tval(u32 tval) +{ + asm volatile ("mcr p15, 0, %0, c14, c2, 0" : : "r" (tval)); +} + +static void __secure cp15_write_cntp_ctl(u32 val) +{ + asm volatile ("mcr p15, 0, %0, c14, c2, 1" : : "r" (val)); +} + +static u32 __secure cp15_read_cntp_ctl(void) +{ + u32 val; + + asm volatile ("mrc p15, 0, %0, c14, c2, 1" : "=r" (val)); + + return val; +} + +#define ONE_MS (COUNTER_FREQUENCY / 1000) + +void __secure __mdelay(u32 ms) +{ + u32 reg = ONE_MS * ms; + + cp15_write_cntp_tval(reg); + isb(); + cp15_write_cntp_ctl(3); + + do { + isb(); + reg = cp15_read_cntp_ctl(); + } while (!(reg & BIT(2))); + + cp15_write_cntp_ctl(0); + isb(); +} +#else +#define __mdelay(ms) +#endif + +#endif diff --git a/arch/arm/cpu/armv7/sunxi/psci_suspend.c b/arch/arm/cpu/armv7/sunxi/psci_suspend.c new file mode 100644 index 000000000000..0a8f2c165891 --- /dev/null +++ b/arch/arm/cpu/armv7/sunxi/psci_suspend.c @@ -0,0 +1,108 @@ +/* + * Copyright (C) 2017 Antoine Tenart antoine.tenart@free-electrons.com + * + * Based on Allwinner code. + * Copyright 2007-2012 (C) Allwinner Technology Co., Ltd. + * + * SPDX-License-Identifier: GPL-2.0 + */ +#include <config.h> +#include <common.h> + +#include <asm/atomic.h> +#include <asm/arch/clock.h> +#include <asm/arch/dram.h> +#include <asm/armv7.h> +#include <asm/io.h> +#include <asm/psci.h> +#include <asm/secure.h> +#include <asm/system.h> + +#include <linux/bitops.h> + +#include "psci.h" + +#if defined(CONFIG_MACH_SUN5I) +#define NR_CPUS 1 +#elif defined(CONFIG_MACH_SUN7I) +#define NR_CPUS 2 +#endif + +/* + * The PSCI suspend function switch cpuclk to another source and disable + * pll1. As this function is called per-CPU, it should only do this when + * all the CPUs are in idle state. + * + * The 'cnt' variable keeps track of the number of CPU which are in the idle + * state. The last one setup cpuclk for idle. + * + * The 'clk_state' varibale holds the cpu clk state (idle or normal). + */ +atomic_t __secure_data cnt, clk_state; + +#define CLK_NORMAL 0 +#define CLK_IDLE 1 + +static void __secure sunxi_clock_enter_idle(struct sunxi_ccm_reg *ccm) +{ + /* switch cpuclk to osc24m */ + clrsetbits_le32(&ccm->cpu_ahb_apb0_cfg, 0x3 << CPU_CLK_SRC_SHIFT, + CPU_CLK_SRC_OSC24M << CPU_CLK_SRC_SHIFT); + + /* disable pll1 */ + clrbits_le32(&ccm->pll1_cfg, CCM_PLL1_CTRL_EN); + +#ifndef CONFIG_MACH_SUN7I + /* + * Switch cpuclk to losc. Based on my experience this didn't worked for + * sun7i, hence the ifndef. + */ + clrbits_le32(&ccm->cpu_ahb_apb0_cfg, 0x3 << CPU_CLK_SRC_SHIFT); +#endif +} + +static void __secure sunxi_clock_leave_idle(struct sunxi_ccm_reg *ccm) +{ +#ifndef CONFIG_MACH_SUN7I + /* switch cpuclk to osc24m */ + clrsetbits_le32(&ccm->cpu_ahb_apb0_cfg, 0x3 << CPU_CLK_SRC_SHIFT, + CPU_CLK_SRC_OSC24M << CPU_CLK_SRC_SHIFT); +#endif + + /* enable pll1 */ + setbits_le32(&ccm->pll1_cfg, CCM_PLL1_CTRL_EN); + + /* wait for the clock to lock */ + while (readl(&ccm->pll1_cfg) & BIT(28)); + + /* switch cpuclk to pll1 */ + clrsetbits_le32(&ccm->cpu_ahb_apb0_cfg, 0x3 << CPU_CLK_SRC_SHIFT, + CPU_CLK_SRC_PLL1 << CPU_CLK_SRC_SHIFT); +} + +void __secure psci_cpu_suspend(void) +{ + struct sunxi_ccm_reg *ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + + if (atomic_inc_return(&cnt) == NR_CPUS) { + /* wait for any sunxi_clock_leave_idle() to finish */ + while (atomic_read(&clk_state) != CLK_NORMAL) + __mdelay(1); + + sunxi_clock_enter_idle(ccm); + atomic_set(&clk_state, CLK_IDLE); + } + + /* idle */ + DSB; + wfi(); + + if (atomic_dec_return(&cnt) == NR_CPUS - 1) { + /* wait for any sunxi_clock_enter_idle() to finish */ + while (atomic_read(&clk_state) != CLK_IDLE) + __mdelay(1); + + sunxi_clock_leave_idle(ccm); + atomic_set(&clk_state, CLK_NORMAL); + } +} diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun4i.h b/arch/arm/include/asm/arch-sunxi/clock_sun4i.h index d1c5ad0a739b..12b0f22a1368 100644 --- a/arch/arm/include/asm/arch-sunxi/clock_sun4i.h +++ b/arch/arm/include/asm/arch-sunxi/clock_sun4i.h @@ -208,6 +208,8 @@ struct sunxi_ccm_reg { #define CCM_AHB_GATE_DLL (0x1 << 15) #define CCM_AHB_GATE_ACE (0x1 << 16)
+#define CCM_PLL1_CTRL_EN (0x1 << 31) + #define CCM_PLL3_CTRL_M_SHIFT 0 #define CCM_PLL3_CTRL_M_MASK (0x7f << CCM_PLL3_CTRL_M_SHIFT) #define CCM_PLL3_CTRL_M(n) (((n) & 0x7f) << 0)
Hi Antoine,
On Sun, Apr 30, 2017 at 03:29:54PM +0200, Antoine Tenart wrote:
- The PSCI suspend function switch cpuclk to another source and disable
- pll1. As this function is called per-CPU, it should only do this when
- all the CPUs are in idle state.
- The 'cnt' variable keeps track of the number of CPU which are in the idle
- state. The last one setup cpuclk for idle.
- The 'clk_state' varibale holds the cpu clk state (idle or normal).
- /* switch cpuclk to osc24m */
- clrsetbits_le32(&ccm->cpu_ahb_apb0_cfg, 0x3 << CPU_CLK_SRC_SHIFT,
- /* disable pll1 */
- clrbits_le32(&ccm->pll1_cfg, CCM_PLL1_CTRL_EN);
- clrbits_le32(&ccm->cpu_ahb_apb0_cfg, 0x3 << CPU_CLK_SRC_SHIFT);
Do we enter idle per-core, or is it a cluster-wide state?
The A20 has a single clock for both CPUs, so that might explain why it didn't work for you: if you enter idle for only one core, and change the clock for both, then you're probably crashing the second core in the process.
Is that really needed? Whatever state we're in at this point, we just want to switch back to the PLL1, right?
Thanks, Maxime
Hi Maxime,
This is cluster-wise, as sunxi_clock_enter_idle() is only called when all CPU are in IDLE state (called the PSCI suspend function). See psci_cpu_suspend().
I think it wasn't working for some reasons if we didn't switch to osc24m first, but that was a while ago. I can test again.
Thanks, Antoine
It seems to work without switching back to osc24m first. I'll remove this.
Thanks! Antoine
On Tue, May 2, 2017 at 3:23 PM, Antoine Tenart antoine.tenart@free-electrons.com wrote:
This is probably going to work badly with the sunxi-ng clock driver in Linux, which will temporarily switch over to osc24M while changing the clock rate of PLL1, then switch back.
ChenYu
It doesn't do so for the A20, only the later SoCs.
I'm not sure whether using cpufreq and cpuidle at the same time is valid either.
Maxime
This is cluster wise, cpuclk with be switched to losc (or osc24m) only if all CPU are in the idle state. Likewise, the first CPU to leave this state will switch back cpuclk to pll1. So that shouldn't be an issue for the sunxi-ng clock driver in Linux.
Antoine
Hi Maxime,
Hmm, ok. That's still a bit weird. The clock documentation says that you should wait 8 cycles when you reparent, which is something you're not doing. Maybe that can be the issue.
Maxime
That might explain the issue.
Antoine
The sun5i SoCs can take advantage of the newly introduce PSCI suspend function. Add defines used by the PSCI code.
Signed-off-by: Antoine Tenart antoine.tenart@free-electrons.com --- include/configs/sun5i.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/sun5i.h b/include/configs/sun5i.h index ec8f3199ba34..6927c21363fb 100644 --- a/include/configs/sun5i.h +++ b/include/configs/sun5i.h @@ -18,6 +18,8 @@
#define CONFIG_SUNXI_USB_PHYS 2
+#define CONFIG_ARMV7_SECURE_BASE SUNXI_SRAM_A1_BASE + /* * Include common sunxi configuration where most the settings are */
sun5i now implements the psci suspend function. In order to be used by the kernel, we should now boot in non-secure mode. Enable it by default.
Signed-off-by: Antoine Tenart antoine.tenart@free-electrons.com --- board/sunxi/Kconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index e53cd9c21c33..043980b83831 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -77,9 +77,12 @@ config MACH_SUN4I config MACH_SUN5I bool "sun5i (Allwinner A13)" select CPU_V7 + select CPU_V7_HAS_NONSEC + select ARCH_SUPPORT_PSCI select ARM_CORTEX_CPU_IS_UP select SUNXI_GEN_SUN4I select SUPPORT_SPL + select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
- select CPU_V7_HAS_NONSEC
- select ARCH_SUPPORT_PSCI select ARM_CORTEX_CPU_IS_UP select SUNXI_GEN_SUN4I select SUPPORT_SPL
- select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
It would be better to sort these options.
Maxime
Hi Maxime,
I followed what was done for the other MACH_SUN* definitions, assuming there was some logic behind it. Otherwise I agree sorted options are better.
Antoine
On Tue, May 02, 2017 at 08:54:59AM +0200, Antoine Tenart wrote:
Hi Maxime,
If you can explain it to me then, I'm all ears ;)
Maxime
On 2017-04-30 07:29, Antoine Tenart wrote:
Hi all,
Does this get suspend to memory working on the Nextthing CHIP ?
If so which kernel version and what DTS changes and config changes are needed ?
Hi Angus,
No, this is used for CPU idle.
Antoine
Hi Antoine
Does a different PSCI function need to be implemented in u-boot to support suspend or does it need some kernel work ?
Thanks Angus
I think there is another PSCI function for this. But you would also need kernel work for all device drivers to support to be suspended and resumed.
Antoine
participants (7)
Angus Ainslie
Antoine Tenart
Chen-Yu Tsai
Masahiro Yamada
Maxime Ripard
Stephen Warren
Tom Warren
