[U-Boot] [PATCH] powerpc/c29xpcie: Getting DDR SPD image from 16-bit sub-address EEPROM
Currently, there is only one EEPROM on c29xpcie board which isAT24C1024. We program the SPD data at beginning of the AT24C1024.But the AT24C1024 has a 16-bit sub-address mode. This patch is tomake it work when getting SPD in a 16-bit sub-address EEPROM.
Signed-off-by: Po Liu Po.Liu@freescale.com --- board/freescale/c29xpcie/ddr.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/board/freescale/c29xpcie/ddr.c b/board/freescale/c29xpcie/ddr.c index 3337d6c..28f1bd2 100644 --- a/board/freescale/c29xpcie/ddr.c +++ b/board/freescale/c29xpcie/ddr.c @@ -84,3 +84,15 @@ void fsl_ddr_board_options(memctl_options_t *popts, popts->cs_local_opts[i].odt_wr_cfg = FSL_DDR_ODT_CS; } } + +void get_spd(generic_spd_eeprom_t *spd, u8 i2c_address) +{ + int ret = i2c_read(i2c_address, 0, 2, (uchar *)spd, + sizeof(generic_spd_eeprom_t)); + + if (ret) { + printf("DDR: failed to read SPD from address %u\n", + i2c_address); + memset(spd, 0, sizeof(generic_spd_eeprom_t)); + } +}
- int ret = i2c_read(i2c_address, 0, 2, (uchar *)spd,
- if (ret) {
i2c_address);
Please fix the compiling warning. You need to include i2c.h, per internal review.
York
Signed-off-by: Po Liu Po.Liu@freescale.com --- Changes for V2: - add #include <i2c.h>
board/freescale/c29xpcie/ddr.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/board/freescale/c29xpcie/ddr.c b/board/freescale/c29xpcie/ddr.c index b017cfd..614944b 100644 --- a/board/freescale/c29xpcie/ddr.c +++ b/board/freescale/c29xpcie/ddr.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <i2c.h> #include <asm/fsl_law.h> #include <asm/fsl_ddr_sdram.h> #include <asm/fsl_ddr_dimm_params.h> @@ -84,3 +85,15 @@ void fsl_ddr_board_options(memctl_options_t *popts, popts->cs_local_opts[i].odt_wr_cfg = FSL_DDR_ODT_CS; } } + +void get_spd(generic_spd_eeprom_t *spd, u8 i2c_address) +{ + int ret = i2c_read(i2c_address, 0, 2, (uchar *)spd, + sizeof(generic_spd_eeprom_t)); + + if (ret) { + printf("DDR: failed to read SPD from address %u\n", + i2c_address); + memset(spd, 0, sizeof(generic_spd_eeprom_t)); + } +}
(uchar) is wrong.
int i2c_read(uint8_t chip, unsigned int addr, int alen, uint8_t *buffer, int len);
The type for this parameter is uint8_t.
The proper fix is to change the i2c_read() function should be changed to take a void*.
Currently, there is only one EEPROM on c29xpcie board which is AT24C1024. We program the SPD data at beginning of the AT24C1024.But the AT24C1024 has a 16-bit sub-address mode. This patch is tomake it work when getting SPD in a 16-bit sub-address EEPROM.
Signed-off-by: Po Liu Po.Liu@freescale.com --- Changes for V2: - add #include <i2c.h> Changes for V3: - change spd type to uint8_t according to the define
diff --git a/board/freescale/c29xpcie/ddr.c b/board/freescale/c29xpcie/ddr.c index 57a9b61..ff7989a 100644 --- a/board/freescale/c29xpcie/ddr.c +++ b/board/freescale/c29xpcie/ddr.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <i2c.h> #include <asm/fsl_law.h> #include <asm/fsl_ddr_sdram.h> #include <asm/fsl_ddr_dimm_params.h> @@ -92,3 +93,15 @@ void fsl_ddr_board_options(memctl_options_t *popts, popts->cs_local_opts[i].odt_wr_cfg = FSL_DDR_ODT_CS; } } + +void get_spd(generic_spd_eeprom_t *spd, u8 i2c_address) +{ + int ret = i2c_read(i2c_address, 0, 2, (uint8_t *)spd, + sizeof(generic_spd_eeprom_t)); + + if (ret) { + printf("DDR: failed to read SPD from address %u\n", + i2c_address); + memset(spd, 0, sizeof(generic_spd_eeprom_t)); + } +}
Changes for V2:
Changes for V3:
Applied to u-boot-mpc85xx/master. Thanks.
York
Po Liu
Timur Tabi
York Sun
