[PATCH] arm: dts: k3-j721e-sk/common-proc-board: Fix boot
Since commit 9e644284ab81 ("dm: core: Report bootph-pre-ram/sram node as pre-reloc after relocation") A53 u-boot proper is broken. This is because nodes marked as 'bootph-pre-ram' are not available at u-boot proper before relocation.
To fix this we mark all nodes in u-boot.dtsi as 'bootph-all'.
Fixes: 69b19ca67bcb ("arm: dts: k3-j721e: Sync with v6.6-rc1") Cc: Neha Francis n-francis@ti.com Signed-off-by: Nishanth Menon nm@ti.com ---
The original patch was reviewed prior to commit 9e644284ab81 However the recent break in u-boot requires fixup to maintain sanity.
Neha: I have only build tested this and have assumed this follows the same pattern of fails with other platforms - please test and review for functionality.
.../k3-j721e-common-proc-board-u-boot.dtsi | 82 +++++++++---------- arch/arm/dts/k3-j721e-sk-u-boot.dtsi | 70 ++++++++-------- 2 files changed, 76 insertions(+), 76 deletions(-)
diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi index c638af63c180..cd95907b981b 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -6,27 +6,27 @@ #include "k3-j721e-binman.dtsi"
&cbass_main { - bootph-pre-ram; + bootph-all; };
&main_navss { - bootph-pre-ram; + bootph-all; };
&cbass_mcu_wakeup { - bootph-pre-ram; + bootph-all;
chipid@43000014 { - bootph-pre-ram; + bootph-all; }; };
&mcu_navss { - bootph-pre-ram; + bootph-all; };
&mcu_ringacc { - bootph-pre-ram; + bootph-all; };
&mcu_udmap { @@ -38,144 +38,144 @@ <0x0 0x28400000 0x0 0x2000>; reg-names = "gcfg", "rchan", "rchanrt", "tchan", "tchanrt", "rflow"; - bootph-pre-ram; + bootph-all; };
&secure_proxy_main { - bootph-pre-ram; + bootph-all; };
&dmsc { - bootph-pre-ram; + bootph-all; k3_sysreset: sysreset-controller { compatible = "ti,sci-sysreset"; - bootph-pre-ram; + bootph-all; }; };
&k3_pds { - bootph-pre-ram; + bootph-all; };
&k3_clks { - bootph-pre-ram; + bootph-all; };
&k3_reset { - bootph-pre-ram; + bootph-all; };
&wkup_pmx0 { - bootph-pre-ram; + bootph-all; };
&main_pmx0 { - bootph-pre-ram; + bootph-all; };
&main_uart0 { - bootph-pre-ram; + bootph-all; };
&mcu_uart0 { - bootph-pre-ram; + bootph-all; };
&main_sdhci0 { - bootph-pre-ram; + bootph-all; };
&main_sdhci1 { - bootph-pre-ram; + bootph-all; };
&main_uart0_pins_default { - bootph-pre-ram; + bootph-all; };
&main_usbss0_pins_default { - bootph-pre-ram; + bootph-all; };
&usbss0 { - bootph-pre-ram; + bootph-all; };
&usb0 { dr_mode = "peripheral"; - bootph-pre-ram; + bootph-all; };
&main_mmc1_pins_default { - bootph-pre-ram; + bootph-all; };
&wkup_i2c0_pins_default { - bootph-pre-ram; + bootph-all; };
&wkup_uart0 { - bootph-pre-ram; + bootph-all; status = "okay"; };
&wkup_i2c0 { - bootph-pre-ram; + bootph-all; status = "okay"; };
&main_i2c0 { - bootph-pre-ram; + bootph-all; };
&main_i2c0_pins_default { - bootph-pre-ram; + bootph-all; };
&main_esm { - bootph-pre-ram; + bootph-all; };
&exp2 { - bootph-pre-ram; + bootph-all; };
&mcu_fss0_ospi0_pins_default { - bootph-pre-ram; + bootph-all; };
&fss { - bootph-pre-ram; + bootph-all; };
&wkup_gpio0 { - bootph-pre-ram; + bootph-all; };
&ospi0 { - bootph-pre-ram; + bootph-all;
flash@0 { - bootph-pre-ram; + bootph-all; }; };
&ospi1 { - bootph-pre-ram; + bootph-all;
&mcu_fss0_hpb0_pins_default { - bootph-pre-ram; + bootph-all; };
&wkup_gpio_pins_default { - bootph-pre-ram; + bootph-all; };
&mcu_fss0_ospi1_pins_default { - bootph-pre-ram; + bootph-all; }; diff --git a/arch/arm/dts/k3-j721e-sk-u-boot.dtsi b/arch/arm/dts/k3-j721e-sk-u-boot.dtsi index 57da7c210a8d..370fe5190b2d 100644 --- a/arch/arm/dts/k3-j721e-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-sk-u-boot.dtsi @@ -6,27 +6,27 @@ #include "k3-j721e-binman.dtsi"
&mcu_udmap { @@ -38,120 +38,120 @@ <0x0 0x28400000 0x0 0x2000>; reg-names = "gcfg", "rchan", "rchanrt", "tchan", "tchanrt", "rflow"; - bootph-pre-ram; + bootph-all; };
&usb0 { dr_mode = "host"; - bootph-pre-ram; + bootph-all; };
&main_usbss1_pins_default { - bootph-pre-ram; + bootph-all; };
&usbss1 { - bootph-pre-ram; + bootph-all; };
&usb1 { dr_mode = "host"; - bootph-pre-ram; + bootph-all; };
&wkup_i2c0 { - bootph-pre-ram; + bootph-all; };
partition@3fc0000 { - bootph-pre-ram; + bootph-all; }; }; };
Tested-by: Tom Rini trini@konsulko.com # J721E-EVM GP
Hi Nishanth,
Thanks for this patch!
Tested-by: Neha Malcom Francis n-francis@ti.com
(Tested on J721E-EVM and J721E-sk)
Reviewed-by: Roger Quadros rogerq@kernel.org
Fixes: 69b19ca67bcb ("arm: dts: k3-j721e: Sync with v6.6-rc1") Cc: Neha Francis n-francis@ti.com Signed-off-by: Nishanth Menon nm@ti.com Tested-by: Tom Rini trini@konsulko.com # J721E-EVM GP Tested-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Roger Quadros rogerq@kernel.org
Neha Malcom Francis
Nishanth Menon
Roger Quadros
