[U-Boot] [PATCH] serial: Rename driver vcth to vct to support other board variants
Moved driver vcth.c to vct.c to better reflect the VCT board series. This driver is now used by the VCT platforms:
vct_premium vct_platinum vct_platinumsvc
Signed-off-by: Stefan Roese sr@denx.de --- drivers/serial/Makefile | 2 +- drivers/serial/{vcth.c => vct.c} | 8 ++++++-- 2 files changed, 7 insertions(+), 3 deletions(-) rename drivers/serial/{vcth.c => vct.c} (94%)
diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 17235ff..c7a1882 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -38,7 +38,7 @@ COBJS-$(CONFIG_PL011_SERIAL) += serial_pl01x.o COBJS-$(CONFIG_XILINX_UARTLITE) += serial_xuartlite.o COBJS-$(CONFIG_SCIF_CONSOLE) += serial_sh.o COBJS-$(CONFIG_USB_TTY) += usbtty.o -COBJS-$(CONFIG_VCTH_SERIAL) += vcth.o +COBJS-$(CONFIG_VCT_SERIAL) += vct.o
COBJS := $(sort $(COBJS-y)) SRCS := $(COBJS:.o=.c) diff --git a/drivers/serial/vcth.c b/drivers/serial/vct.c similarity index 94% rename from drivers/serial/vcth.c rename to drivers/serial/vct.c index 2c847d0..556c114 100755 --- a/drivers/serial/vcth.c +++ b/drivers/serial/vct.c @@ -21,7 +21,11 @@ #include <common.h> #include <asm/io.h>
+#ifdef CONFIG_VCT_PLATINUMAVC +#define UART_1_BASE 0xBDC30000 +#else #define UART_1_BASE 0xBF89C000 +#endif
#define UART_RBR_OFF 0x00 /* receiver buffer reg */ #define UART_THR_OFF 0x00 /* transmit holding reg */ @@ -53,7 +57,7 @@ #define UART_7DATA_BITS 0x0002 /* 7 [bits] 1 bits 2 */ #define UART_8DATA_BITS 0x0003 /* 8 [bits] 1 bits 2 */
-static void vcth_uart_set_baud_rate(u32 address, u32 dh, u32 dl) +static void vct_uart_set_baud_rate(u32 address, u32 dh, u32 dl) { u32 val = __raw_readl(UART_1_BASE + UART_LCR_OFF);
@@ -74,7 +78,7 @@ static void vcth_uart_set_baud_rate(u32 address, u32 dh, u32 dl) int serial_init(void) { __raw_writel(UART_DIS_ALL_INTER, UART_1_BASE + UART_IER_OFF); - vcth_uart_set_baud_rate(UART_1_BASE, 0, UART_115200_BDR); + vct_uart_set_baud_rate(UART_1_BASE, 0, UART_115200_BDR); __raw_writel(UART_8DATA_BITS, UART_1_BASE + UART_LCR_OFF);
Dear Stefan Roese,
Applied, thanks.
Stefan Roese
