[U-Boot] [RFC PATCH v2 00/11] SF: Migrate to Linux SPI NOR framework
U-Boot SPI NOR support (sf layer) is quite outdated as it does not support 4 byte addressing opcodes, SFDP table parsing and different types of quad mode enable sequences. Many newer flashes no longer support BANK registers used by sf layer to a access >16MB space. Also, many SPI controllers have special MMIO interfaces which provide accelerated read/write access but require knowledge of flash parameters to make use of it. Recent spi-mem layer provides a way to support such flashes but sf layer isn't using that. This patch series syncs SPI NOR framework from Linux v4.19. It also adds spi-mem support on top. So, we gain 4byte addressing support and SFDP support. This makes migrating to U-Boot MTD framework easier.
Tested with few Spansion, micron and macronix flashes with TI's dra7xx, k2g, am43xx EVMs. I dont have access to flashes from other vendors. So, I would greatly appreciate testing on other platforms. Complete series with dependencies here[1]
For clean build on some platforms, depends on CONFIG_SPI_FLASH migration to defconfigs [2]
[1] https://github.com/r-vignesh/u-boot.git branch: spi-nor-mig-v2 [2] https://patchwork.ozlabs.org/patch/1007485/
Change log: v2: Add lightweight SPI flash stack for boards with SPL size constraints Provide non DM version of spi-mem Fix build issues on different platforms as reported by travis-ci on v1
v1: https://patchwork.ozlabs.org/cover/1004689/
Vignesh R (11): spi: spi-mem: Allow use of spi_mem_exec_op for all SPI modes spi-mem: Claim SPI bus before spi mem access spi: Add non DM version of SPI_MEM sh: bitops: add hweight*() macros mtd: spi: Port SPI NOR framework from Linux mtd spi: Switch to new SPI NOR framework mtd: spi: Remove unused files mtd: spi: Add lightweight SPI flash stack for SPL sf_mtd: Simply mtd operations taurus_defconfig: Enable simple malloc in SPL axm_defconfig: Enable simple malloc in SPL
arch/sh/include/asm/bitops.h | 4 + common/spl/Kconfig | 16 + configs/axm_defconfig | 1 + configs/taurus_defconfig | 1 + drivers/mtd/spi/Kconfig | 8 + drivers/mtd/spi/Makefile | 10 +- drivers/mtd/spi/sandbox.c | 36 +- drivers/mtd/spi/sf_dataflash.c | 11 +- drivers/mtd/spi/sf_internal.h | 230 +--- drivers/mtd/spi/sf_mtd.c | 39 +- drivers/mtd/spi/sf_probe.c | 35 +- drivers/mtd/spi/spi-nor-ids.c | 294 ++++ drivers/mtd/spi/spi-nor-tiny.c | 806 +++++++++++ drivers/mtd/spi/spi-nor.c | 2300 +++++++++++++++++++++++++++++++ drivers/mtd/spi/spi_flash.c | 1337 ------------------ drivers/mtd/spi/spi_flash_ids.c | 211 --- drivers/spi/Kconfig | 4 +- drivers/spi/Makefile | 1 + drivers/spi/spi-mem-nodm.c | 89 ++ drivers/spi/spi-mem.c | 15 +- drivers/spi/stm32_qspi.c | 4 +- include/linux/mtd/cfi.h | 32 + include/linux/mtd/spi-nor.h | 421 ++++++ include/spi_flash.h | 105 +- 24 files changed, 4116 insertions(+), 1894 deletions(-) create mode 100644 drivers/mtd/spi/spi-nor-ids.c create mode 100644 drivers/mtd/spi/spi-nor-tiny.c create mode 100644 drivers/mtd/spi/spi-nor.c delete mode 100644 drivers/mtd/spi/spi_flash.c delete mode 100644 drivers/mtd/spi/spi_flash_ids.c create mode 100644 drivers/spi/spi-mem-nodm.c create mode 100644 include/linux/mtd/cfi.h create mode 100644 include/linux/mtd/spi-nor.h
SPI controllers support all types of SPI modes including dual/quad bus widths. Therefore remove constraint wrt SPI mode from spi-mem layer.
Signed-off-by: Vignesh R vigneshr@ti.com --- drivers/spi/spi-mem.c | 9 --------- 1 file changed, 9 deletions(-)
diff --git a/drivers/spi/spi-mem.c b/drivers/spi/spi-mem.c index af9aef009a73..1da20b8de5c4 100644 --- a/drivers/spi/spi-mem.c +++ b/drivers/spi/spi-mem.c @@ -323,15 +323,6 @@ int spi_mem_exec_op(struct spi_slave *slave, const struct spi_mem_op *op) return -EIO; #else
- /* U-Boot does not support parallel SPI data lanes */ - if ((op->cmd.buswidth != 1) || - (op->addr.nbytes && op->addr.buswidth != 1) || - (op->dummy.nbytes && op->dummy.buswidth != 1) || - (op->data.nbytes && op->data.buswidth != 1)) { - printf("Dual/Quad raw SPI transfers not supported\n"); - return -ENOTSUPP; - } - if (op->data.nbytes) { if (op->data.dir == SPI_MEM_DATA_IN) rx_buf = op->data.buf.in;
It is necessary to call spi_claim_bus() before starting any SPI transactions and this restriction would also apply when calling spi-mem operationss. Therefore claim and release bus before requesting transfer via exec_op.
Signed-off-by: Vignesh R vigneshr@ti.com --- drivers/spi/spi-mem.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/spi/spi-mem.c b/drivers/spi/spi-mem.c index 1da20b8de5c4..4c1463118ab2 100644 --- a/drivers/spi/spi-mem.c +++ b/drivers/spi/spi-mem.c @@ -231,7 +231,13 @@ int spi_mem_exec_op(struct spi_slave *slave, const struct spi_mem_op *op) mutex_lock(&ctlr->bus_lock_mutex); mutex_lock(&ctlr->io_mutex); #endif + ret = spi_claim_bus(slave); + if (ret < 0) + return ret; + ret = ops->mem_ops->exec_op(slave, op); + + spi_release_bus(slave); #ifndef __UBOOT__ mutex_unlock(&ctlr->io_mutex); mutex_unlock(&ctlr->bus_lock_mutex);
Add non DM version of SPI_MEM to support easy migration to new SPI NOR framework. This can be removed once DM_SPI conversion is complete.
Signed-off-by: Vignesh R vigneshr@ti.com --- drivers/spi/Kconfig | 4 +- drivers/spi/Makefile | 1 + drivers/spi/spi-mem-nodm.c | 89 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 92 insertions(+), 2 deletions(-) create mode 100644 drivers/spi/spi-mem-nodm.c
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 516188ea88e1..de334a33a283 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -16,8 +16,6 @@ config DM_SPI typically use driver-private data instead of extending the spi_slave structure.
-if DM_SPI - config SPI_MEM bool "SPI memory extension" help @@ -25,6 +23,8 @@ config SPI_MEM This extension is meant to simplify interaction with SPI memories by providing an high-level interface to send memory-like commands.
+if DM_SPI + config ALTERA_SPI bool "Altera SPI driver" help diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 7242ea7e4045..66666b26133f 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -11,6 +11,7 @@ obj-$(CONFIG_SOFT_SPI) += soft_spi.o obj-$(CONFIG_SPI_MEM) += spi-mem.o else obj-y += spi.o +obj-$(CONFIG_SPI_MEM) += spi-mem-nodm.o obj-$(CONFIG_SOFT_SPI) += soft_spi_legacy.o endif
diff --git a/drivers/spi/spi-mem-nodm.c b/drivers/spi/spi-mem-nodm.c new file mode 100644 index 000000000000..4d91761f56d3 --- /dev/null +++ b/drivers/spi/spi-mem-nodm.c @@ -0,0 +1,89 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#include <spi.h> +#include <spi-mem.h> + +int spi_mem_exec_op(struct spi_slave *slave, + const struct spi_mem_op *op) +{ + unsigned int pos = 0; + const u8 *tx_buf = NULL; + u8 *rx_buf = NULL; + u8 *op_buf; + int op_len; + u32 flag; + int ret; + int i; + + if (op->data.nbytes) { + if (op->data.dir == SPI_MEM_DATA_IN) + rx_buf = op->data.buf.in; + else + tx_buf = op->data.buf.out; + } + + op_len = sizeof(op->cmd.opcode) + op->addr.nbytes + op->dummy.nbytes; + op_buf = calloc(1, op_len); + + ret = spi_claim_bus(slave); + if (ret < 0) + return ret; + + op_buf[pos++] = op->cmd.opcode; + + if (op->addr.nbytes) { + for (i = 0; i < op->addr.nbytes; i++) + op_buf[pos + i] = op->addr.val >> + (8 * (op->addr.nbytes - i - 1)); + + pos += op->addr.nbytes; + } + + if (op->dummy.nbytes) + memset(op_buf + pos, 0xff, op->dummy.nbytes); + + /* 1st transfer: opcode + address + dummy cycles */ + flag = SPI_XFER_BEGIN; + /* Make sure to set END bit if no tx or rx data messages follow */ + if (!tx_buf && !rx_buf) + flag |= SPI_XFER_END; + + ret = spi_xfer(slave, op_len * 8, op_buf, NULL, flag); + if (ret) + return ret; + + /* 2nd transfer: rx or tx data path */ + if (tx_buf || rx_buf) { + ret = spi_xfer(slave, op->data.nbytes * 8, tx_buf, + rx_buf, SPI_XFER_END); + if (ret) + return ret; + } + + spi_release_bus(slave); + + for (i = 0; i < pos; i++) + debug("%02x ", op_buf[i]); + debug("| [%dB %s] ", + tx_buf || rx_buf ? op->data.nbytes : 0, + tx_buf || rx_buf ? (tx_buf ? "out" : "in") : "-"); + for (i = 0; i < op->data.nbytes; i++) + debug("%02x ", tx_buf ? tx_buf[i] : rx_buf[i]); + debug("[ret %d]\n", ret); + + free(op_buf); + + if (ret < 0) + return ret; + + return 0; +} + +int spi_mem_adjust_op_size(struct spi_slave *slave, + struct spi_mem_op *op) +{ + return 0; +}
Add hweight*() macros required for moving to new SF layer
Signed-off-by: Vignesh R vigneshr@ti.com --- arch/sh/include/asm/bitops.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/sh/include/asm/bitops.h b/arch/sh/include/asm/bitops.h index 8cb8385d76db..765f28f116bc 100644 --- a/arch/sh/include/asm/bitops.h +++ b/arch/sh/include/asm/bitops.h @@ -153,6 +153,10 @@ static inline int ffs (int x) } #define PLATFORM_FFS
+#define hweight32(x) generic_hweight32(x) +#define hweight16(x) generic_hweight16(x) +#define hweight8(x) generic_hweight8(x) + #endif /* __KERNEL__ */
#endif /* __ASM_SH_BITOPS_H */
Current U-Boot SPI NOR support (sf layer) is quite outdated as it does not support 4 byte addressing opcodes, SFDP table parsing and different types of quad mode enable sequences. Many newer flashes no longer support BANK registers used by sf layer to a access >16MB space. Also, many SPI controllers have special MMIO interfaces which provide accelerated read/write access but require knowledge of flash parameters to make use of it. Recent spi-mem layer provides a way to support such flashes but sf layer isn't using that. So sync SPI NOR framework from Linux v4.19 and add spi-mem support on top. in order to gain 4 byte addressing support, SFDP support and a way to support SPI controllers with MMIO flash interface.
Signed-off-by: Vignesh R vigneshr@ti.com --- drivers/mtd/spi/spi-nor.c | 2613 +++++++++++++++++++++++++++++++++++ include/linux/mtd/cfi.h | 32 + include/linux/mtd/spi-nor.h | 421 ++++++ 3 files changed, 3066 insertions(+) create mode 100644 drivers/mtd/spi/spi-nor.c create mode 100644 include/linux/mtd/cfi.h create mode 100644 include/linux/mtd/spi-nor.h
diff --git a/drivers/mtd/spi/spi-nor.c b/drivers/mtd/spi/spi-nor.c new file mode 100644 index 000000000000..ff79601a8896 --- /dev/null +++ b/drivers/mtd/spi/spi-nor.c @@ -0,0 +1,2613 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Based on m25p80.c, by Mike Lavender (mike@steroidmicros.com), with + * influence from lart.c (Abraham Van Der Merwe) and mtd_dataflash.c + * + * Copyright (C) 2005, Intec Automation Inc. + * Copyright (C) 2014, Freescale Semiconductor, Inc. + * + * Synced from Linux v4.19 + */ + +#include <common.h> +#include <linux/err.h> +#include <linux/errno.h> +#include <linux/log2.h> +#include <linux/math64.h> +#include <linux/sizes.h> + +#include <linux/mtd/mtd.h> +#include <linux/mtd/spi-nor.h> +#include <spi-mem.h> +#include <spi.h> + +/* Define max times to check status register before we give up. */ + +/* + * For everything but full-chip erase; probably could be much smaller, but kept + * around for safety for now + */ + +#define HZ CONFIG_SYS_HZ + +#define DEFAULT_READY_WAIT_JIFFIES (40UL * HZ) + +#define SPI_NOR_MAX_ID_LEN 6 +#define SPI_NOR_MAX_ADDR_WIDTH 4 + +struct flash_info { + char *name; + + /* + * This array stores the ID bytes. + * The first three bytes are the JEDIC ID. + * JEDEC ID zero means "no ID" (mostly older chips). + */ + u8 id[SPI_NOR_MAX_ID_LEN]; + u8 id_len; + + /* The size listed here is what works with SPINOR_OP_SE, which isn't + * necessarily called a "sector" by the vendor. + */ + unsigned int sector_size; + u16 n_sectors; + + u16 page_size; + u16 addr_width; + + u16 flags; +#define SECT_4K BIT(0) /* SPINOR_OP_BE_4K works uniformly */ +#define SPI_NOR_NO_ERASE BIT(1) /* No erase command needed */ +#define SST_WRITE BIT(2) /* use SST byte programming */ +#define SPI_NOR_NO_FR BIT(3) /* Can't do fastread */ +#define SECT_4K_PMC BIT(4) /* SPINOR_OP_BE_4K_PMC works uniformly */ +#define SPI_NOR_DUAL_READ BIT(5) /* Flash supports Dual Read */ +#define SPI_NOR_QUAD_READ BIT(6) /* Flash supports Quad Read */ +#define USE_FSR BIT(7) /* use flag status register */ +#define SPI_NOR_HAS_LOCK BIT(8) /* Flash supports lock/unlock via SR */ +#define SPI_NOR_HAS_TB BIT(9) /* + * Flash SR has Top/Bottom (TB) protect + * bit. Must be used with + * SPI_NOR_HAS_LOCK. + */ +#define SPI_S3AN BIT(10) /* + * Xilinx Spartan 3AN In-System Flash + * (MFR cannot be used for probing + * because it has the same value as + * ATMEL flashes) + */ +#define SPI_NOR_4B_OPCODES BIT(11) /* + * Use dedicated 4byte address op codes + * to support memory size above 128Mib. + */ +#define NO_CHIP_ERASE BIT(12) /* Chip does not support chip erase */ +#define SPI_NOR_SKIP_SFDP BIT(13) /* Skip parsing of SFDP tables */ +#define USE_CLSR BIT(14) /* use CLSR command */ + + int (*quad_enable)(struct spi_nor *nor); +}; + +#define JEDEC_MFR(info) ((info)->id[0]) + +static int spi_nor_read_write_reg(struct spi_nor *nor, struct spi_mem_op + *op, void *buf) +{ + if (op->data.dir == SPI_MEM_DATA_IN) + op->data.buf.in = buf; + else + op->data.buf.out = buf; + return spi_mem_exec_op(nor->spi, op); +} + +static int spi_nor_read_reg(struct spi_nor *nor, u8 code, u8 *val, int len) +{ + struct spi_mem_op op = SPI_MEM_OP(SPI_MEM_OP_CMD(code, 1), + SPI_MEM_OP_NO_ADDR, + SPI_MEM_OP_NO_DUMMY, + SPI_MEM_OP_DATA_IN(len, NULL, 1)); + int ret; + + ret = spi_nor_read_write_reg(nor, &op, val); + if (ret < 0) + dev_dbg(&flash->spimem->spi->dev, "error %d reading %x\n", ret, + code); + + return ret; +} + +static int spi_nor_write_reg(struct spi_nor *nor, u8 opcode, u8 *buf, int len) +{ + struct spi_mem_op op = SPI_MEM_OP(SPI_MEM_OP_CMD(opcode, 1), + SPI_MEM_OP_NO_ADDR, + SPI_MEM_OP_NO_DUMMY, + SPI_MEM_OP_DATA_OUT(len, NULL, 1)); + + return spi_nor_read_write_reg(nor, &op, buf); +} + +static ssize_t spi_nor_read_data(struct spi_nor *nor, loff_t from, size_t len, + u_char *buf) +{ + struct spi_mem_op op = + SPI_MEM_OP(SPI_MEM_OP_CMD(nor->read_opcode, 1), + SPI_MEM_OP_ADDR(nor->addr_width, from, 1), + SPI_MEM_OP_DUMMY(nor->read_dummy, 1), + SPI_MEM_OP_DATA_IN(len, buf, 1)); + size_t remaining = len; + int ret; + + /* get transfer protocols. */ + op.cmd.buswidth = spi_nor_get_protocol_inst_nbits(nor->read_proto); + op.addr.buswidth = spi_nor_get_protocol_addr_nbits(nor->read_proto); + op.dummy.buswidth = op.addr.buswidth; + op.data.buswidth = spi_nor_get_protocol_data_nbits(nor->read_proto); + + /* convert the dummy cycles to the number of bytes */ + op.dummy.nbytes = (nor->read_dummy * op.dummy.buswidth) / 8; + + while (remaining) { + op.data.nbytes = remaining < UINT_MAX ? remaining : UINT_MAX; + ret = spi_mem_adjust_op_size(nor->spi, &op); + if (ret) + return ret; + + ret = spi_mem_exec_op(nor->spi, &op); + if (ret) + return ret; + + op.addr.val += op.data.nbytes; + remaining -= op.data.nbytes; + op.data.buf.in += op.data.nbytes; + } + + return len; +} + +static ssize_t spi_nor_write_data(struct spi_nor *nor, loff_t to, size_t len, + const u_char *buf) +{ + struct spi_mem_op op = + SPI_MEM_OP(SPI_MEM_OP_CMD(nor->program_opcode, 1), + SPI_MEM_OP_ADDR(nor->addr_width, to, 1), + SPI_MEM_OP_NO_DUMMY, + SPI_MEM_OP_DATA_OUT(len, buf, 1)); + size_t remaining = len; + int ret; + + /* get transfer protocols. */ + op.cmd.buswidth = spi_nor_get_protocol_inst_nbits(nor->write_proto); + op.addr.buswidth = spi_nor_get_protocol_addr_nbits(nor->write_proto); + op.data.buswidth = spi_nor_get_protocol_data_nbits(nor->write_proto); + + if (nor->program_opcode == SPINOR_OP_AAI_WP && nor->sst_write_second) + op.addr.nbytes = 0; + + while (remaining) { + op.data.nbytes = remaining < UINT_MAX ? remaining : UINT_MAX; + ret = spi_mem_adjust_op_size(nor->spi, &op); + if (ret) + return ret; + + ret = spi_mem_exec_op(nor->spi, &op); + if (ret) + return ret; + + op.addr.val += op.data.nbytes; + remaining -= op.data.nbytes; + op.data.buf.out += op.data.nbytes; + } + + return len; +} + +/* + * Read the status register, returning its value in the location + * Return the status register value. + * Returns negative if error occurred. + */ +static int read_sr(struct spi_nor *nor) +{ + int ret; + u8 val; + + ret = nor->read_reg(nor, SPINOR_OP_RDSR, &val, 1); + if (ret < 0) { + pr_debug("error %d reading SR\n", (int)ret); + return ret; + } + + return val; +} + +/* + * Read the flag status register, returning its value in the location + * Return the status register value. + * Returns negative if error occurred. + */ +static int read_fsr(struct spi_nor *nor) +{ + int ret; + u8 val; + + ret = nor->read_reg(nor, SPINOR_OP_RDFSR, &val, 1); + if (ret < 0) { + pr_debug("error %d reading FSR\n", ret); + return ret; + } + + return val; +} + +/* + * Read configuration register, returning its value in the + * location. Return the configuration register value. + * Returns negative if error occurred. + */ +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) +static int read_cr(struct spi_nor *nor) +{ + int ret; + u8 val; + + ret = nor->read_reg(nor, SPINOR_OP_RDCR, &val, 1); + if (ret < 0) { + dev_dbg(nor->dev, "error %d reading CR\n", ret); + return ret; + } + + return val; +} +#endif + +/* + * Write status register 1 byte + * Returns negative if error occurred. + */ +static inline int write_sr(struct spi_nor *nor, u8 val) +{ + nor->cmd_buf[0] = val; + return nor->write_reg(nor, SPINOR_OP_WRSR, nor->cmd_buf, 1); +} + +/* + * Set write enable latch with Write Enable command. + * Returns negative if error occurred. + */ +static inline int write_enable(struct spi_nor *nor) +{ + return nor->write_reg(nor, SPINOR_OP_WREN, NULL, 0); +} + +/* + * Send write disable instruction to the chip. + */ +static inline int write_disable(struct spi_nor *nor) +{ + return nor->write_reg(nor, SPINOR_OP_WRDI, NULL, 0); +} + +static inline struct spi_nor *mtd_to_spi_nor(struct mtd_info *mtd) +{ + return mtd->priv; +} + +static u8 spi_nor_convert_opcode(u8 opcode, const u8 table[][2], size_t size) +{ + size_t i; + + for (i = 0; i < size; i++) + if (table[i][0] == opcode) + return table[i][1]; + + /* No conversion found, keep input op code. */ + return opcode; +} + +static inline u8 spi_nor_convert_3to4_read(u8 opcode) +{ + static const u8 spi_nor_3to4_read[][2] = { + { SPINOR_OP_READ, SPINOR_OP_READ_4B }, + { SPINOR_OP_READ_FAST, SPINOR_OP_READ_FAST_4B }, + { SPINOR_OP_READ_1_1_2, SPINOR_OP_READ_1_1_2_4B }, + { SPINOR_OP_READ_1_2_2, SPINOR_OP_READ_1_2_2_4B }, + { SPINOR_OP_READ_1_1_4, SPINOR_OP_READ_1_1_4_4B }, + { SPINOR_OP_READ_1_4_4, SPINOR_OP_READ_1_4_4_4B }, + }; + + return spi_nor_convert_opcode(opcode, spi_nor_3to4_read, + ARRAY_SIZE(spi_nor_3to4_read)); +} + +static inline u8 spi_nor_convert_3to4_program(u8 opcode) +{ + static const u8 spi_nor_3to4_program[][2] = { + { SPINOR_OP_PP, SPINOR_OP_PP_4B }, + { SPINOR_OP_PP_1_1_4, SPINOR_OP_PP_1_1_4_4B }, + { SPINOR_OP_PP_1_4_4, SPINOR_OP_PP_1_4_4_4B }, + }; + + return spi_nor_convert_opcode(opcode, spi_nor_3to4_program, + ARRAY_SIZE(spi_nor_3to4_program)); +} + +static inline u8 spi_nor_convert_3to4_erase(u8 opcode) +{ + static const u8 spi_nor_3to4_erase[][2] = { + { SPINOR_OP_BE_4K, SPINOR_OP_BE_4K_4B }, + { SPINOR_OP_BE_32K, SPINOR_OP_BE_32K_4B }, + { SPINOR_OP_SE, SPINOR_OP_SE_4B }, + }; + + return spi_nor_convert_opcode(opcode, spi_nor_3to4_erase, + ARRAY_SIZE(spi_nor_3to4_erase)); +} + +static void spi_nor_set_4byte_opcodes(struct spi_nor *nor, + const struct flash_info *info) +{ + /* Do some manufacturer fixups first */ + switch (JEDEC_MFR(info)) { + case SNOR_MFR_SPANSION: + /* No small sector erase for 4-byte command set */ + nor->erase_opcode = SPINOR_OP_SE; + nor->mtd.erasesize = info->sector_size; + break; + + default: + break; + } + + nor->read_opcode = spi_nor_convert_3to4_read(nor->read_opcode); + nor->program_opcode = spi_nor_convert_3to4_program(nor->program_opcode); + nor->erase_opcode = spi_nor_convert_3to4_erase(nor->erase_opcode); +} + +/* Enable/disable 4-byte addressing mode. */ +static inline int set_4byte(struct spi_nor *nor, const struct flash_info *info, + int enable) +{ + int status; + bool need_wren = false; + u8 cmd; + + switch (JEDEC_MFR(info)) { + case SNOR_MFR_MICRON: + /* Some Micron need WREN command; all will accept it */ + need_wren = true; + case SNOR_MFR_MACRONIX: + case SNOR_MFR_WINBOND: + if (need_wren) + write_enable(nor); + + cmd = enable ? SPINOR_OP_EN4B : SPINOR_OP_EX4B; + status = nor->write_reg(nor, cmd, NULL, 0); + if (need_wren) + write_disable(nor); + + if (!status && !enable && + JEDEC_MFR(info) == SNOR_MFR_WINBOND) { + /* + * On Winbond W25Q256FV, leaving 4byte mode causes + * the Extended Address Register to be set to 1, so all + * 3-byte-address reads come from the second 16M. + * We must clear the register to enable normal behavior. + */ + write_enable(nor); + nor->cmd_buf[0] = 0; + nor->write_reg(nor, SPINOR_OP_WREAR, nor->cmd_buf, 1); + write_disable(nor); + } + + return status; + default: + /* Spansion style */ + nor->cmd_buf[0] = enable << 7; + return nor->write_reg(nor, SPINOR_OP_BRWR, nor->cmd_buf, 1); + } +} + +static int spi_nor_sr_ready(struct spi_nor *nor) +{ + int sr = read_sr(nor); + + if (sr < 0) + return sr; + +#ifndef CONFIG_SPL_BUILD + if (nor->flags & SNOR_F_USE_CLSR && sr & (SR_E_ERR | SR_P_ERR)) { + if (sr & SR_E_ERR) + dev_dbg(nor->dev, "Erase Error occurred\n"); + else + dev_dbg(nor->dev, "Programming Error occurred\n"); + + nor->write_reg(nor, SPINOR_OP_CLSR, NULL, 0); + return -EIO; + } +#endif + + return !(sr & SR_WIP); +} + +static int spi_nor_fsr_ready(struct spi_nor *nor) +{ + int fsr = read_fsr(nor); + + if (fsr < 0) + return fsr; +#ifndef CONFIG_SPL_BUILD + if (fsr & (FSR_E_ERR | FSR_P_ERR)) { + if (fsr & FSR_E_ERR) + dev_dbg(nor->dev, "Erase operation failed.\n"); + else + dev_dbg(nor->dev, "Program operation failed.\n"); + + if (fsr & FSR_PT_ERR) + dev_dbg(nor->dev, + "Attempted to modify a protected sector.\n"); + + nor->write_reg(nor, SPINOR_OP_CLFSR, NULL, 0); + return -EIO; + } +#endif + return fsr & FSR_READY; +} + +static int spi_nor_ready(struct spi_nor *nor) +{ + int sr, fsr; + + sr = spi_nor_sr_ready(nor); + if (sr < 0) + return sr; + fsr = nor->flags & SNOR_F_USE_FSR ? spi_nor_fsr_ready(nor) : 1; + if (fsr < 0) + return fsr; + return sr && fsr; +} + +/* + * Service routine to read status register until ready, or timeout occurs. + * Returns non-zero if error. + */ +static int spi_nor_wait_till_ready_with_timeout(struct spi_nor *nor, + unsigned long timeout) +{ + unsigned long timebase; + int ret; + + timebase = get_timer(0); + + while (get_timer(timebase) < timeout) { + ret = spi_nor_ready(nor); + if (ret < 0) + return ret; + if (ret) + return 0; + } + + dev_err(nor->dev, "flash operation timed out\n"); + + return -ETIMEDOUT; +} + +static int spi_nor_wait_till_ready(struct spi_nor *nor) +{ + return spi_nor_wait_till_ready_with_timeout(nor, + DEFAULT_READY_WAIT_JIFFIES); +} + +/* + * Initiate the erasure of a single sector + */ +static int spi_nor_erase_sector(struct spi_nor *nor, u32 addr) +{ + u8 buf[SPI_NOR_MAX_ADDR_WIDTH]; + int i; + + if (nor->erase) + return nor->erase(nor, addr); + + /* + * Default implementation, if driver doesn't have a specialized HW + * control + */ + for (i = nor->addr_width - 1; i >= 0; i--) { + buf[i] = addr & 0xff; + addr >>= 8; + } + + return nor->write_reg(nor, nor->erase_opcode, buf, nor->addr_width); +} + +/* + * Erase an address range on the nor chip. The address range may extend + * one or more erase sectors. Return an error is there is a problem erasing. + */ +static int spi_nor_erase(struct mtd_info *mtd, struct erase_info *instr) +{ + struct spi_nor *nor = mtd_to_spi_nor(mtd); + u32 addr, len, rem; + int ret; + + dev_dbg(nor->dev, "at 0x%llx, len %lld\n", (long long)instr->addr, + (long long)instr->len); + + div_u64_rem(instr->len, mtd->erasesize, &rem); + if (rem) + return -EINVAL; + + addr = instr->addr; + len = instr->len; + + while (len) { + write_enable(nor); + + ret = spi_nor_erase_sector(nor, addr); + if (ret) + goto erase_err; + + addr += mtd->erasesize; + len -= mtd->erasesize; + + ret = spi_nor_wait_till_ready(nor); + if (ret) + goto erase_err; + } + + write_disable(nor); + +erase_err: + return ret; +} + +#if defined(CONFIG_SPI_FLASH_STMICRO) || defined(CONFIG_SPI_FLASH_SST) +/* Write status register and ensure bits in mask match written values */ +static int write_sr_and_check(struct spi_nor *nor, u8 status_new, u8 mask) +{ + int ret; + + write_enable(nor); + ret = write_sr(nor, status_new); + if (ret) + return ret; + + ret = spi_nor_wait_till_ready(nor); + if (ret) + return ret; + + ret = read_sr(nor); + if (ret < 0) + return ret; + + return ((ret & mask) != (status_new & mask)) ? -EIO : 0; +} + +static void stm_get_locked_range(struct spi_nor *nor, u8 sr, loff_t *ofs, + uint64_t *len) +{ + struct mtd_info *mtd = &nor->mtd; + u8 mask = SR_BP2 | SR_BP1 | SR_BP0; + int shift = ffs(mask) - 1; + int pow; + + if (!(sr & mask)) { + /* No protection */ + *ofs = 0; + *len = 0; + } else { + pow = ((sr & mask) ^ mask) >> shift; + *len = mtd->size >> pow; + if (nor->flags & SNOR_F_HAS_SR_TB && sr & SR_TB) + *ofs = 0; + else + *ofs = mtd->size - *len; + } +} + +/* + * Return 1 if the entire region is locked (if @locked is true) or unlocked (if + * @locked is false); 0 otherwise + */ +static int stm_check_lock_status_sr(struct spi_nor *nor, loff_t ofs, u64 len, + u8 sr, bool locked) +{ + loff_t lock_offs; + uint64_t lock_len; + + if (!len) + return 1; + + stm_get_locked_range(nor, sr, &lock_offs, &lock_len); + + if (locked) + /* Requested range is a sub-range of locked range */ + return (ofs + len <= lock_offs + lock_len) && (ofs >= lock_offs); + else + /* Requested range does not overlap with locked range */ + return (ofs >= lock_offs + lock_len) || (ofs + len <= lock_offs); +} + +static int stm_is_locked_sr(struct spi_nor *nor, loff_t ofs, uint64_t len, + u8 sr) +{ + return stm_check_lock_status_sr(nor, ofs, len, sr, true); +} + +static int stm_is_unlocked_sr(struct spi_nor *nor, loff_t ofs, uint64_t len, + u8 sr) +{ + return stm_check_lock_status_sr(nor, ofs, len, sr, false); +} + +/* + * Lock a region of the flash. Compatible with ST Micro and similar flash. + * Supports the block protection bits BP{0,1,2} in the status register + * (SR). Does not support these features found in newer SR bitfields: + * - SEC: sector/block protect - only handle SEC=0 (block protect) + * - CMP: complement protect - only support CMP=0 (range is not complemented) + * + * Support for the following is provided conditionally for some flash: + * - TB: top/bottom protect + * + * Sample table portion for 8MB flash (Winbond w25q64fw): + * + * SEC | TB | BP2 | BP1 | BP0 | Prot Length | Protected Portion + * -------------------------------------------------------------------------- + * X | X | 0 | 0 | 0 | NONE | NONE + * 0 | 0 | 0 | 0 | 1 | 128 KB | Upper 1/64 + * 0 | 0 | 0 | 1 | 0 | 256 KB | Upper 1/32 + * 0 | 0 | 0 | 1 | 1 | 512 KB | Upper 1/16 + * 0 | 0 | 1 | 0 | 0 | 1 MB | Upper 1/8 + * 0 | 0 | 1 | 0 | 1 | 2 MB | Upper 1/4 + * 0 | 0 | 1 | 1 | 0 | 4 MB | Upper 1/2 + * X | X | 1 | 1 | 1 | 8 MB | ALL + * ------|-------|-------|-------|-------|---------------|------------------- + * 0 | 1 | 0 | 0 | 1 | 128 KB | Lower 1/64 + * 0 | 1 | 0 | 1 | 0 | 256 KB | Lower 1/32 + * 0 | 1 | 0 | 1 | 1 | 512 KB | Lower 1/16 + * 0 | 1 | 1 | 0 | 0 | 1 MB | Lower 1/8 + * 0 | 1 | 1 | 0 | 1 | 2 MB | Lower 1/4 + * 0 | 1 | 1 | 1 | 0 | 4 MB | Lower 1/2 + * + * Returns negative on errors, 0 on success. + */ +static int stm_lock(struct spi_nor *nor, loff_t ofs, uint64_t len) +{ + struct mtd_info *mtd = &nor->mtd; + int status_old, status_new; + u8 mask = SR_BP2 | SR_BP1 | SR_BP0; + u8 shift = ffs(mask) - 1, pow, val; + loff_t lock_len; + bool can_be_top = true, can_be_bottom = nor->flags & SNOR_F_HAS_SR_TB; + bool use_top; + + status_old = read_sr(nor); + if (status_old < 0) + return status_old; + + /* If nothing in our range is unlocked, we don't need to do anything */ + if (stm_is_locked_sr(nor, ofs, len, status_old)) + return 0; + + /* If anything below us is unlocked, we can't use 'bottom' protection */ + if (!stm_is_locked_sr(nor, 0, ofs, status_old)) + can_be_bottom = false; + + /* If anything above us is unlocked, we can't use 'top' protection */ + if (!stm_is_locked_sr(nor, ofs + len, mtd->size - (ofs + len), + status_old)) + can_be_top = false; + + if (!can_be_bottom && !can_be_top) + return -EINVAL; + + /* Prefer top, if both are valid */ + use_top = can_be_top; + + /* lock_len: length of region that should end up locked */ + if (use_top) + lock_len = mtd->size - ofs; + else + lock_len = ofs + len; + + /* + * Need smallest pow such that: + * + * 1 / (2^pow) <= (len / size) + * + * so (assuming power-of-2 size) we do: + * + * pow = ceil(log2(size / len)) = log2(size) - floor(log2(len)) + */ + pow = ilog2(mtd->size) - ilog2(lock_len); + val = mask - (pow << shift); + if (val & ~mask) + return -EINVAL; + /* Don't "lock" with no region! */ + if (!(val & mask)) + return -EINVAL; + + status_new = (status_old & ~mask & ~SR_TB) | val; + + /* Disallow further writes if WP pin is asserted */ + status_new |= SR_SRWD; + + if (!use_top) + status_new |= SR_TB; + + /* Don't bother if they're the same */ + if (status_new == status_old) + return 0; + + /* Only modify protection if it will not unlock other areas */ + if ((status_new & mask) < (status_old & mask)) + return -EINVAL; + + return write_sr_and_check(nor, status_new, mask); +} + +/* + * Unlock a region of the flash. See stm_lock() for more info + * + * Returns negative on errors, 0 on success. + */ +static int stm_unlock(struct spi_nor *nor, loff_t ofs, uint64_t len) +{ + struct mtd_info *mtd = &nor->mtd; + int status_old, status_new; + u8 mask = SR_BP2 | SR_BP1 | SR_BP0; + u8 shift = ffs(mask) - 1, pow, val; + loff_t lock_len; + bool can_be_top = true, can_be_bottom = nor->flags & SNOR_F_HAS_SR_TB; + bool use_top; + + status_old = read_sr(nor); + if (status_old < 0) + return status_old; + + /* If nothing in our range is locked, we don't need to do anything */ + if (stm_is_unlocked_sr(nor, ofs, len, status_old)) + return 0; + + /* If anything below us is locked, we can't use 'top' protection */ + if (!stm_is_unlocked_sr(nor, 0, ofs, status_old)) + can_be_top = false; + + /* If anything above us is locked, we can't use 'bottom' protection */ + if (!stm_is_unlocked_sr(nor, ofs + len, mtd->size - (ofs + len), + status_old)) + can_be_bottom = false; + + if (!can_be_bottom && !can_be_top) + return -EINVAL; + + /* Prefer top, if both are valid */ + use_top = can_be_top; + + /* lock_len: length of region that should remain locked */ + if (use_top) + lock_len = mtd->size - (ofs + len); + else + lock_len = ofs; + + /* + * Need largest pow such that: + * + * 1 / (2^pow) >= (len / size) + * + * so (assuming power-of-2 size) we do: + * + * pow = floor(log2(size / len)) = log2(size) - ceil(log2(len)) + */ + pow = ilog2(mtd->size) - order_base_2(lock_len); + if (lock_len == 0) { + val = 0; /* fully unlocked */ + } else { + val = mask - (pow << shift); + /* Some power-of-two sizes are not supported */ + if (val & ~mask) + return -EINVAL; + } + + status_new = (status_old & ~mask & ~SR_TB) | val; + + /* Don't protect status register if we're fully unlocked */ + if (lock_len == 0) + status_new &= ~SR_SRWD; + + if (!use_top) + status_new |= SR_TB; + + /* Don't bother if they're the same */ + if (status_new == status_old) + return 0; + + /* Only modify protection if it will not lock other areas */ + if ((status_new & mask) > (status_old & mask)) + return -EINVAL; + + return write_sr_and_check(nor, status_new, mask); +} + +/* + * Check if a region of the flash is (completely) locked. See stm_lock() for + * more info. + * + * Returns 1 if entire region is locked, 0 if any portion is unlocked, and + * negative on errors. + */ +static int stm_is_locked(struct spi_nor *nor, loff_t ofs, uint64_t len) +{ + int status; + + status = read_sr(nor); + if (status < 0) + return status; + + return stm_is_locked_sr(nor, ofs, len, status); +} +#endif /* CONFIG_SPI_FLASH_STMICRO */ + +static int spi_nor_lock(struct mtd_info *mtd, loff_t ofs, uint64_t len) +{ + struct spi_nor *nor = mtd_to_spi_nor(mtd); + int ret; + + ret = nor->flash_lock(nor, ofs, len); + + return ret; +} + +static int spi_nor_unlock(struct mtd_info *mtd, loff_t ofs, uint64_t len) +{ + struct spi_nor *nor = mtd_to_spi_nor(mtd); + int ret; + + ret = nor->flash_unlock(nor, ofs, len); + + return ret; +} + +static int spi_nor_is_locked(struct mtd_info *mtd, loff_t ofs, uint64_t len) +{ + struct spi_nor *nor = mtd_to_spi_nor(mtd); + int ret; + + ret = nor->flash_is_locked(nor, ofs, len); + + return ret; +} + +/* Used when the "_ext_id" is two bytes at most */ +#define INFO(_jedec_id, _ext_id, _sector_size, _n_sectors, _flags) \ + .id = { \ + ((_jedec_id) >> 16) & 0xff, \ + ((_jedec_id) >> 8) & 0xff, \ + (_jedec_id) & 0xff, \ + ((_ext_id) >> 8) & 0xff, \ + (_ext_id) & 0xff, \ + }, \ + .id_len = (!(_jedec_id) ? 0 : (3 + ((_ext_id) ? 2 : 0))), \ + .sector_size = (_sector_size), \ + .n_sectors = (_n_sectors), \ + .page_size = 256, \ + .flags = (_flags), + +#define INFO6(_jedec_id, _ext_id, _sector_size, _n_sectors, _flags) \ + .id = { \ + ((_jedec_id) >> 16) & 0xff, \ + ((_jedec_id) >> 8) & 0xff, \ + (_jedec_id) & 0xff, \ + ((_ext_id) >> 16) & 0xff, \ + ((_ext_id) >> 8) & 0xff, \ + (_ext_id) & 0xff, \ + }, \ + .id_len = 6, \ + .sector_size = (_sector_size), \ + .n_sectors = (_n_sectors), \ + .page_size = 256, \ + .flags = (_flags), + +/* NOTE: double check command sets and memory organization when you add + * more nor chips. This current list focusses on newer chips, which + * have been converging on command sets which including JEDEC ID. + * + * All newly added entries should describe *hardware* and should use SECT_4K + * (or SECT_4K_PMC) if hardware supports erasing 4 KiB sectors. For usage + * scenarios excluding small sectors there is config option that can be + * disabled: CONFIG_MTD_SPI_NOR_USE_4K_SECTORS. + * For historical (and compatibility) reasons (before we got above config) some + * old entries may be missing 4K flag. + */ +const struct flash_info spi_nor_ids[] = { +#ifdef CONFIG_SPI_FLASH_ATMEL /* ATMEL */ + /* Atmel -- some are (confusingly) marketed as "DataFlash" */ + { "at26df321", INFO(0x1f4700, 0, 64 * 1024, 64, SECT_4K) }, + { "at25df321a", INFO(0x1f4701, 0, 64 * 1024, 64, SECT_4K) }, + + { "at45db011d", INFO(0x1f2200, 0, 64 * 1024, 4, SECT_4K) }, + { "at45db021d", INFO(0x1f2300, 0, 64 * 1024, 8, SECT_4K) }, + { "at45db041d", INFO(0x1f2400, 0, 64 * 1024, 8, SECT_4K) }, + { "at45db081d", INFO(0x1f2500, 0, 64 * 1024, 16, SECT_4K) }, + { "at45db161d", INFO(0x1f2600, 0, 64 * 1024, 32, SECT_4K) }, + { "at45db321d", INFO(0x1f2700, 0, 64 * 1024, 64, SECT_4K) }, + { "at45db641d", INFO(0x1f2800, 0, 64 * 1024, 128, SECT_4K) }, + { "at26df081a", INFO(0x1f4501, 0, 64 * 1024, 16, SECT_4K) }, +#endif +#ifdef CONFIG_SPI_FLASH_EON /* EON */ + /* EON -- en25xxx */ + { "en25q32b", INFO(0x1c3016, 0, 64 * 1024, 64, 0) }, + { "en25q64", INFO(0x1c3017, 0, 64 * 1024, 128, SECT_4K) }, + { "en25qh128", INFO(0x1c7018, 0, 64 * 1024, 256, 0) }, + { "en25s64", INFO(0x1c3817, 0, 64 * 1024, 128, SECT_4K) }, +#endif +#ifdef CONFIG_SPI_FLASH_GIGADEVICE /* GIGADEVICE */ + /* GigaDevice */ + { + "gd25q16", INFO(0xc84015, 0, 64 * 1024, 32, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + "gd25q32", INFO(0xc84016, 0, 64 * 1024, 64, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + "gd25lq32", INFO(0xc86016, 0, 64 * 1024, 64, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + "gd25q64", INFO(0xc84017, 0, 64 * 1024, 128, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, +#endif +#ifdef CONFIG_SPI_FLASH_ISSI /* ISSI */ + /* ISSI */ + { "is25lq040b", INFO(0x9d4013, 0, 64 * 1024, 8, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { "is25lp032", INFO(0x9d6016, 0, 64 * 1024, 64, 0) }, + { "is25lp064", INFO(0x9d6017, 0, 64 * 1024, 128, 0) }, + { "is25lp128", INFO(0x9d6018, 0, 64 * 1024, 256, + SECT_4K | SPI_NOR_DUAL_READ) }, + { "is25lp256", INFO(0x9d6019, 0, 64 * 1024, 512, + SECT_4K | SPI_NOR_DUAL_READ) }, + { "is25wp032", INFO(0x9d7016, 0, 64 * 1024, 64, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { "is25wp064", INFO(0x9d7017, 0, 64 * 1024, 128, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { "is25wp128", INFO(0x9d7018, 0, 64 * 1024, 256, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, +#endif +#ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ + /* Macronix */ + { "mx25l2005a", INFO(0xc22012, 0, 64 * 1024, 4, SECT_4K) }, + { "mx25l4005a", INFO(0xc22013, 0, 64 * 1024, 8, SECT_4K) }, + { "mx25l8005", INFO(0xc22014, 0, 64 * 1024, 16, 0) }, + { "mx25l1606e", INFO(0xc22015, 0, 64 * 1024, 32, SECT_4K) }, + { "mx25l3205d", INFO(0xc22016, 0, 64 * 1024, 64, SECT_4K) }, + { "mx25l6405d", INFO(0xc22017, 0, 64 * 1024, 128, SECT_4K) }, + { "mx25u2033e", INFO(0xc22532, 0, 64 * 1024, 4, SECT_4K) }, + { "mx25u1635e", INFO(0xc22535, 0, 64 * 1024, 32, SECT_4K) }, + { "mx25u6435f", INFO(0xc22537, 0, 64 * 1024, 128, SECT_4K) }, + { "mx25l12805d", INFO(0xc22018, 0, 64 * 1024, 256, 0) }, + { "mx25l12855e", INFO(0xc22618, 0, 64 * 1024, 256, 0) }, + { "mx25l25635e", INFO(0xc22019, 0, 64 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { "mx25u25635f", INFO(0xc22539, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_4B_OPCODES) }, + { "mx25l25655e", INFO(0xc22619, 0, 64 * 1024, 512, 0) }, + { "mx66l51235l", INFO(0xc2201a, 0, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + { "mx66u51235f", INFO(0xc2253a, 0, 64 * 1024, 1024, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + { "mx66l1g45g", INFO(0xc2201b, 0, 64 * 1024, 2048, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { "mx25l1633e", INFO(0xc22415, 0, 64 * 1024, 32, SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | SECT_4K) }, +#endif + +#ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */ + /* Micron */ + { "n25q016a", INFO(0x20bb15, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_QUAD_READ) }, + { "n25q032", INFO(0x20ba16, 0, 64 * 1024, 64, SPI_NOR_QUAD_READ) }, + { "n25q032a", INFO(0x20bb16, 0, 64 * 1024, 64, SPI_NOR_QUAD_READ) }, + { "n25q064", INFO(0x20ba17, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_QUAD_READ) }, + { "n25q064a", INFO(0x20bb17, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_QUAD_READ) }, + { "n25q128a11", INFO(0x20bb18, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_QUAD_READ) }, + { "n25q128a13", INFO(0x20ba18, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_QUAD_READ) }, + { "n25q256a", INFO(0x20ba19, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { "n25q256ax1", INFO(0x20bb19, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_QUAD_READ) }, + { "n25q512a", INFO(0x20bb20, 0, 64 * 1024, 1024, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ) }, + { "n25q512ax3", INFO(0x20ba20, 0, 64 * 1024, 1024, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ) }, + { "n25q00", INFO(0x20ba21, 0, 64 * 1024, 2048, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE) }, + { "n25q00a", INFO(0x20bb21, 0, 64 * 1024, 2048, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE) }, + { "mt25qu02g", INFO(0x20bb22, 0, 64 * 1024, 4096, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE) }, +#endif +#ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */ + /* Spansion/Cypress -- single (large) sector size only, at least + * for the chips listed here (without boot sectors). + */ + { "s25sl032p", INFO(0x010215, 0x4d00, 64 * 1024, 64, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { "s25sl064p", INFO(0x010216, 0x4d00, 64 * 1024, 128, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { "s25fl256s0", INFO(0x010219, 0x4d00, 256 * 1024, 128, USE_CLSR) }, + { "s25fl256s1", INFO(0x010219, 0x4d01, 64 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { "s25fl512s", INFO6(0x010220, 0x4d0081, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { "s25fl512s_256k", INFO(0x010220, 0x4d00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { "s25fl512s_64k", INFO(0x010220, 0x4d01, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { "s25fl512s_512k", INFO(0x010220, 0x4f00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { "s25sl12800", INFO(0x012018, 0x0300, 256 * 1024, 64, 0) }, + { "s25sl12801", INFO(0x012018, 0x0301, 64 * 1024, 256, 0) }, + { "s25fl128s", INFO6(0x012018, 0x4d0180, 64 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { "s25fl129p0", INFO(0x012018, 0x4d00, 256 * 1024, 64, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { "s25fl129p1", INFO(0x012018, 0x4d01, 64 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { "s25sl008a", INFO(0x010213, 0, 64 * 1024, 16, 0) }, + { "s25sl016a", INFO(0x010214, 0, 64 * 1024, 32, 0) }, + { "s25sl032a", INFO(0x010215, 0, 64 * 1024, 64, 0) }, + { "s25sl064a", INFO(0x010216, 0, 64 * 1024, 128, 0) }, + { "s25fl116k", INFO(0x014015, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { "s25fl164k", INFO(0x014017, 0, 64 * 1024, 128, SECT_4K) }, + { "s25fl208k", INFO(0x014014, 0, 64 * 1024, 16, SECT_4K | SPI_NOR_DUAL_READ) }, + { "s25fl128l", INFO(0x016018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, +#endif +#ifdef CONFIG_SPI_FLASH_SST /* SST */ + /* SST -- large erase sizes are "overlays", "sectors" are 4K */ + { "sst25vf040b", INFO(0xbf258d, 0, 64 * 1024, 8, SECT_4K | SST_WRITE) }, + { "sst25vf080b", INFO(0xbf258e, 0, 64 * 1024, 16, SECT_4K | SST_WRITE) }, + { "sst25vf016b", INFO(0xbf2541, 0, 64 * 1024, 32, SECT_4K | SST_WRITE) }, + { "sst25vf032b", INFO(0xbf254a, 0, 64 * 1024, 64, SECT_4K | SST_WRITE) }, + { "sst25vf064c", INFO(0xbf254b, 0, 64 * 1024, 128, SECT_4K) }, + { "sst25wf512", INFO(0xbf2501, 0, 64 * 1024, 1, SECT_4K | SST_WRITE) }, + { "sst25wf010", INFO(0xbf2502, 0, 64 * 1024, 2, SECT_4K | SST_WRITE) }, + { "sst25wf020", INFO(0xbf2503, 0, 64 * 1024, 4, SECT_4K | SST_WRITE) }, + { "sst25wf020a", INFO(0x621612, 0, 64 * 1024, 4, SECT_4K) }, + { "sst25wf040b", INFO(0x621613, 0, 64 * 1024, 8, SECT_4K) }, + { "sst25wf040", INFO(0xbf2504, 0, 64 * 1024, 8, SECT_4K | SST_WRITE) }, + { "sst25wf080", INFO(0xbf2505, 0, 64 * 1024, 16, SECT_4K | SST_WRITE) }, + { "sst26vf064b", INFO(0xbf2643, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { "sst26wf016", INFO(0xbf2651, 0, 64 * 1024, 32, SECT_4K) }, + { "sst26wf032", INFO(0xbf2622, 0, 64 * 1024, 64, SECT_4K) }, + { "sst26wf064", INFO(0xbf2643, 0, 64 * 1024, 128, SECT_4K) }, +#endif +#ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */ + /* ST Microelectronics -- newer production may have feature updates */ + { "m25p10", INFO(0x202011, 0, 32 * 1024, 4, 0) }, + { "m25p20", INFO(0x202012, 0, 64 * 1024, 4, 0) }, + { "m25p40", INFO(0x202013, 0, 64 * 1024, 8, 0) }, + { "m25p80", INFO(0x202014, 0, 64 * 1024, 16, 0) }, + { "m25p16", INFO(0x202015, 0, 64 * 1024, 32, 0) }, + { "m25p32", INFO(0x202016, 0, 64 * 1024, 64, 0) }, + { "m25p64", INFO(0x202017, 0, 64 * 1024, 128, 0) }, + { "m25p128", INFO(0x202018, 0, 256 * 1024, 64, 0) }, + { "m25pe16", INFO(0x208015, 0, 64 * 1024, 32, SECT_4K) }, + { "m25px16", INFO(0x207115, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { "m25px64", INFO(0x207117, 0, 64 * 1024, 128, 0) }, +#endif +#ifdef CONFIG_SPI_FLASH_WINBOND /* WINBOND */ + /* Winbond -- w25x "blocks" are 64K, "sectors" are 4KiB */ + { "w25x05", INFO(0xef3010, 0, 64 * 1024, 1, SECT_4K) }, + { "w25x10", INFO(0xef3011, 0, 64 * 1024, 2, SECT_4K) }, + { "w25x20", INFO(0xef3012, 0, 64 * 1024, 4, SECT_4K) }, + { "w25x40", INFO(0xef3013, 0, 64 * 1024, 8, SECT_4K) }, + { "w25x80", INFO(0xef3014, 0, 64 * 1024, 16, SECT_4K) }, + { "w25x16", INFO(0xef3015, 0, 64 * 1024, 32, SECT_4K) }, + { + "w25q16dw", INFO(0xef6015, 0, 64 * 1024, 32, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { "w25x32", INFO(0xef3016, 0, 64 * 1024, 64, SECT_4K) }, + { "w25q20cl", INFO(0xef4012, 0, 64 * 1024, 4, SECT_4K) }, + { "w25q20bw", INFO(0xef5012, 0, 64 * 1024, 4, SECT_4K) }, + { "w25q20ew", INFO(0xef6012, 0, 64 * 1024, 4, SECT_4K) }, + { "w25q32", INFO(0xef4016, 0, 64 * 1024, 64, SECT_4K) }, + { + "w25q32dw", INFO(0xef6016, 0, 64 * 1024, 64, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + "w25q32jv", INFO(0xef7016, 0, 64 * 1024, 64, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { "w25x64", INFO(0xef3017, 0, 64 * 1024, 128, SECT_4K) }, + { "w25q64", INFO(0xef4017, 0, 64 * 1024, 128, SECT_4K) }, + { + "w25q64dw", INFO(0xef6017, 0, 64 * 1024, 128, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + "w25q128fw", INFO(0xef6018, 0, 64 * 1024, 256, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { "w25q80", INFO(0xef5014, 0, 64 * 1024, 16, SECT_4K) }, + { "w25q80bl", INFO(0xef4014, 0, 64 * 1024, 16, SECT_4K) }, + { "w25q128", INFO(0xef4018, 0, 64 * 1024, 256, SECT_4K) }, + { "w25q256", INFO(0xef4019, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { "w25m512jv", INFO(0xef7119, 0, 64 * 1024, 1024, + SECT_4K | SPI_NOR_QUAD_READ | SPI_NOR_DUAL_READ) }, +#endif +#ifdef CONFIG_SPI_FLASH_XMC + /* XMC (Wuhan Xinxin Semiconductor Manufacturing Corp.) */ + { "XM25QH64A", INFO(0x207017, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { "XM25QH128A", INFO(0x207018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, +#endif + { }, +}; + +static const struct flash_info *spi_nor_read_id(struct spi_nor *nor) +{ + int tmp; + u8 id[SPI_NOR_MAX_ID_LEN]; + const struct flash_info *info; + + if (!ARRAY_SIZE(spi_nor_ids)) + return ERR_PTR(-ENODEV); + + tmp = nor->read_reg(nor, SPINOR_OP_RDID, id, SPI_NOR_MAX_ID_LEN); + if (tmp < 0) { + dev_dbg(nor->dev, "error %d reading JEDEC ID\n", tmp); + return ERR_PTR(tmp); + } + + for (tmp = 0; tmp < ARRAY_SIZE(spi_nor_ids) - 1; tmp++) { + info = &spi_nor_ids[tmp]; + if (info->id_len) { + if (!memcmp(info->id, id, info->id_len)) + return &spi_nor_ids[tmp]; + } + } + dev_err(nor->dev, "unrecognized JEDEC id bytes: %02x, %02x, %02x\n", + id[0], id[1], id[2]); + return ERR_PTR(-ENODEV); +} + +static int spi_nor_read(struct mtd_info *mtd, loff_t from, size_t len, + size_t *retlen, u_char *buf) +{ + struct spi_nor *nor = mtd_to_spi_nor(mtd); + int ret; + + dev_dbg(nor->dev, "from 0x%08x, len %zd\n", (u32)from, len); + + while (len) { + loff_t addr = from; + + ret = nor->read(nor, addr, len, buf); + if (ret == 0) { + /* We shouldn't see 0-length reads */ + ret = -EIO; + goto read_err; + } + if (ret < 0) + goto read_err; + + *retlen += ret; + buf += ret; + from += ret; + len -= ret; + } + ret = 0; + +read_err: + return ret; +} + +#ifdef CONFIG_SPI_FLASH_SST +static int sst_write(struct mtd_info *mtd, loff_t to, size_t len, + size_t *retlen, const u_char *buf) +{ + struct spi_nor *nor = mtd_to_spi_nor(mtd); + size_t actual; + int ret; + + dev_dbg(nor->dev, "to 0x%08x, len %zd\n", (u32)to, len); + + write_enable(nor); + + nor->sst_write_second = false; + + actual = to % 2; + /* Start write from odd address. */ + if (actual) { + nor->program_opcode = SPINOR_OP_BP; + + /* write one byte. */ + ret = nor->write(nor, to, 1, buf); + if (ret < 0) + goto sst_write_err; + ret = spi_nor_wait_till_ready(nor); + if (ret) + goto sst_write_err; + } + to += actual; + + /* Write out most of the data here. */ + for (; actual < len - 1; actual += 2) { + nor->program_opcode = SPINOR_OP_AAI_WP; + + /* write two bytes. */ + ret = nor->write(nor, to, 2, buf + actual); + if (ret < 0) + goto sst_write_err; + ret = spi_nor_wait_till_ready(nor); + if (ret) + goto sst_write_err; + to += 2; + nor->sst_write_second = true; + } + nor->sst_write_second = false; + + write_disable(nor); + ret = spi_nor_wait_till_ready(nor); + if (ret) + goto sst_write_err; + + /* Write out trailing byte if it exists. */ + if (actual != len) { + write_enable(nor); + + nor->program_opcode = SPINOR_OP_BP; + ret = nor->write(nor, to, 1, buf + actual); + if (ret < 0) + goto sst_write_err; + ret = spi_nor_wait_till_ready(nor); + if (ret) + goto sst_write_err; + write_disable(nor); + actual += 1; + } +sst_write_err: + *retlen += actual; + return ret; +} +#endif +/* + * Write an address range to the nor chip. Data must be written in + * FLASH_PAGESIZE chunks. The address range may be any size provided + * it is within the physical boundaries. + */ +static int spi_nor_write(struct mtd_info *mtd, loff_t to, size_t len, + size_t *retlen, const u_char *buf) +{ + struct spi_nor *nor = mtd_to_spi_nor(mtd); + size_t page_offset, page_remain, i; + ssize_t ret; + + dev_dbg(nor->dev, "to 0x%08x, len %zd\n", (u32)to, len); + + for (i = 0; i < len; ) { + ssize_t written; + loff_t addr = to + i; + + /* + * If page_size is a power of two, the offset can be quickly + * calculated with an AND operation. On the other cases we + * need to do a modulus operation (more expensive). + * Power of two numbers have only one bit set and we can use + * the instruction hweight32 to detect if we need to do a + * modulus (do_div()) or not. + */ + if (hweight32(nor->page_size) == 1) { + page_offset = addr & (nor->page_size - 1); + } else { + u64 aux = addr; + + page_offset = do_div(aux, nor->page_size); + } + /* the size of data remaining on the first page */ + page_remain = min_t(size_t, + nor->page_size - page_offset, len - i); + + write_enable(nor); + ret = nor->write(nor, addr, page_remain, buf + i); + if (ret < 0) + goto write_err; + written = ret; + + ret = spi_nor_wait_till_ready(nor); + if (ret) + goto write_err; + *retlen += written; + i += written; + if (written != page_remain) { + dev_dbg(nor->dev, + "While writing %zu bytes written %zd bytes\n", + page_remain, written); + ret = -EIO; + goto write_err; + } + } + +write_err: + return ret; +} + +#ifdef CONFIG_SPI_FLASH_MACRONIX +/** + * macronix_quad_enable() - set QE bit in Status Register. + * @nor: pointer to a 'struct spi_nor' + * + * Set the Quad Enable (QE) bit in the Status Register. + * + * bit 6 of the Status Register is the QE bit for Macronix like QSPI memories. + * + * Return: 0 on success, -errno otherwise. + */ +static int macronix_quad_enable(struct spi_nor *nor) +{ + int ret, val; + + val = read_sr(nor); + if (val < 0) + return val; + if (val & SR_QUAD_EN_MX) + return 0; + + write_enable(nor); + + write_sr(nor, val | SR_QUAD_EN_MX); + + ret = spi_nor_wait_till_ready(nor); + if (ret) + return ret; + + ret = read_sr(nor); + if (!(ret > 0 && (ret & SR_QUAD_EN_MX))) { + dev_err(nor->dev, "Macronix Quad bit not set\n"); + return -EINVAL; + } + + return 0; +} +#endif + +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) +/* + * Write status Register and configuration register with 2 bytes + * The first byte will be written to the status register, while the + * second byte will be written to the configuration register. + * Return negative if error occurred. + */ +static int write_sr_cr(struct spi_nor *nor, u8 *sr_cr) +{ + int ret; + + write_enable(nor); + + ret = nor->write_reg(nor, SPINOR_OP_WRSR, sr_cr, 2); + if (ret < 0) { + dev_dbg(nor->dev, + "error while writing configuration register\n"); + return -EINVAL; + } + + ret = spi_nor_wait_till_ready(nor); + if (ret) { + dev_dbg(nor->dev, + "timeout while writing configuration register\n"); + return ret; + } + + return 0; +} + +/** + * spansion_read_cr_quad_enable() - set QE bit in Configuration Register. + * @nor: pointer to a 'struct spi_nor' + * + * Set the Quad Enable (QE) bit in the Configuration Register. + * This function should be used with QSPI memories supporting the Read + * Configuration Register (35h) instruction. + * + * bit 1 of the Configuration Register is the QE bit for Spansion like QSPI + * memories. + * + * Return: 0 on success, -errno otherwise. + */ +static int spansion_read_cr_quad_enable(struct spi_nor *nor) +{ + u8 sr_cr[2]; + int ret; + + /* Check current Quad Enable bit value. */ + ret = read_cr(nor); + if (ret < 0) { + dev_dbg(dev, "error while reading configuration register\n"); + return -EINVAL; + } + + if (ret & CR_QUAD_EN_SPAN) + return 0; + + sr_cr[1] = ret | CR_QUAD_EN_SPAN; + + /* Keep the current value of the Status Register. */ + ret = read_sr(nor); + if (ret < 0) { + dev_dbg(dev, "error while reading status register\n"); + return -EINVAL; + } + sr_cr[0] = ret; + + ret = write_sr_cr(nor, sr_cr); + if (ret) + return ret; + + /* Read back and check it. */ + ret = read_cr(nor); + if (!(ret > 0 && (ret & CR_QUAD_EN_SPAN))) { + dev_dbg(nor->dev, "Spansion Quad bit not set\n"); + return -EINVAL; + } + + return 0; +} + +#if CONFIG_IS_ENABLED(SPI_FLASH_SFDP_SUPPORT) +/** + * spansion_no_read_cr_quad_enable() - set QE bit in Configuration Register. + * @nor: pointer to a 'struct spi_nor' + * + * Set the Quad Enable (QE) bit in the Configuration Register. + * This function should be used with QSPI memories not supporting the Read + * Configuration Register (35h) instruction. + * + * bit 1 of the Configuration Register is the QE bit for Spansion like QSPI + * memories. + * + * Return: 0 on success, -errno otherwise. + */ +static int spansion_no_read_cr_quad_enable(struct spi_nor *nor) +{ + u8 sr_cr[2]; + int ret; + + /* Keep the current value of the Status Register. */ + ret = read_sr(nor); + if (ret < 0) { + dev_dbg(nor->dev, "error while reading status register\n"); + return -EINVAL; + } + sr_cr[0] = ret; + sr_cr[1] = CR_QUAD_EN_SPAN; + + return write_sr_cr(nor, sr_cr); +} + +#endif /* CONFIG_SPI_FLASH_SFDP_SUPPORT */ +#endif /* CONFIG_SPI_FLASH_SPANSION */ + +struct spi_nor_read_command { + u8 num_mode_clocks; + u8 num_wait_states; + u8 opcode; + enum spi_nor_protocol proto; +}; + +struct spi_nor_pp_command { + u8 opcode; + enum spi_nor_protocol proto; +}; + +enum spi_nor_read_command_index { + SNOR_CMD_READ, + SNOR_CMD_READ_FAST, + SNOR_CMD_READ_1_1_1_DTR, + + /* Dual SPI */ + SNOR_CMD_READ_1_1_2, + SNOR_CMD_READ_1_2_2, + SNOR_CMD_READ_2_2_2, + SNOR_CMD_READ_1_2_2_DTR, + + /* Quad SPI */ + SNOR_CMD_READ_1_1_4, + SNOR_CMD_READ_1_4_4, + SNOR_CMD_READ_4_4_4, + SNOR_CMD_READ_1_4_4_DTR, + + /* Octo SPI */ + SNOR_CMD_READ_1_1_8, + SNOR_CMD_READ_1_8_8, + SNOR_CMD_READ_8_8_8, + SNOR_CMD_READ_1_8_8_DTR, + + SNOR_CMD_READ_MAX +}; + +enum spi_nor_pp_command_index { + SNOR_CMD_PP, + + /* Quad SPI */ + SNOR_CMD_PP_1_1_4, + SNOR_CMD_PP_1_4_4, + SNOR_CMD_PP_4_4_4, + + /* Octo SPI */ + SNOR_CMD_PP_1_1_8, + SNOR_CMD_PP_1_8_8, + SNOR_CMD_PP_8_8_8, + + SNOR_CMD_PP_MAX +}; + +struct spi_nor_flash_parameter { + u64 size; + u32 page_size; + + struct spi_nor_hwcaps hwcaps; + struct spi_nor_read_command reads[SNOR_CMD_READ_MAX]; + struct spi_nor_pp_command page_programs[SNOR_CMD_PP_MAX]; + + int (*quad_enable)(struct spi_nor *nor); +}; + +static void +spi_nor_set_read_settings(struct spi_nor_read_command *read, + u8 num_mode_clocks, + u8 num_wait_states, + u8 opcode, + enum spi_nor_protocol proto) +{ + read->num_mode_clocks = num_mode_clocks; + read->num_wait_states = num_wait_states; + read->opcode = opcode; + read->proto = proto; +} + +static void +spi_nor_set_pp_settings(struct spi_nor_pp_command *pp, + u8 opcode, + enum spi_nor_protocol proto) +{ + pp->opcode = opcode; + pp->proto = proto; +} + +#ifdef CONFIG_SPI_FLASH_SFDP_SUPPORT +/* + * Serial Flash Discoverable Parameters (SFDP) parsing. + */ + +/** + * spi_nor_read_sfdp() - read Serial Flash Discoverable Parameters. + * @nor: pointer to a 'struct spi_nor' + * @addr: offset in the SFDP area to start reading data from + * @len: number of bytes to read + * @buf: buffer where the SFDP data are copied into (dma-safe memory) + * + * Whatever the actual numbers of bytes for address and dummy cycles are + * for (Fast) Read commands, the Read SFDP (5Ah) instruction is always + * followed by a 3-byte address and 8 dummy clock cycles. + * + * Return: 0 on success, -errno otherwise. + */ +static int spi_nor_read_sfdp(struct spi_nor *nor, u32 addr, + size_t len, void *buf) +{ + u8 addr_width, read_opcode, read_dummy; + int ret; + + read_opcode = nor->read_opcode; + addr_width = nor->addr_width; + read_dummy = nor->read_dummy; + + nor->read_opcode = SPINOR_OP_RDSFDP; + nor->addr_width = 3; + nor->read_dummy = 8; + + while (len) { + ret = nor->read(nor, addr, len, (u8 *)buf); + if (!ret || ret > len) { + ret = -EIO; + goto read_err; + } + if (ret < 0) + goto read_err; + + buf += ret; + addr += ret; + len -= ret; + } + ret = 0; + +read_err: + nor->read_opcode = read_opcode; + nor->addr_width = addr_width; + nor->read_dummy = read_dummy; + + return ret; +} + +struct sfdp_parameter_header { + u8 id_lsb; + u8 minor; + u8 major; + u8 length; /* in double words */ + u8 parameter_table_pointer[3]; /* byte address */ + u8 id_msb; +}; + +#define SFDP_PARAM_HEADER_ID(p) (((p)->id_msb << 8) | (p)->id_lsb) +#define SFDP_PARAM_HEADER_PTP(p) \ + (((p)->parameter_table_pointer[2] << 16) | \ + ((p)->parameter_table_pointer[1] << 8) | \ + ((p)->parameter_table_pointer[0] << 0)) + +#define SFDP_BFPT_ID 0xff00 /* Basic Flash Parameter Table */ +#define SFDP_SECTOR_MAP_ID 0xff81 /* Sector Map Table */ + +#define SFDP_SIGNATURE 0x50444653U +#define SFDP_JESD216_MAJOR 1 +#define SFDP_JESD216_MINOR 0 +#define SFDP_JESD216A_MINOR 5 +#define SFDP_JESD216B_MINOR 6 + +struct sfdp_header { + u32 signature; /* Ox50444653U <=> "SFDP" */ + u8 minor; + u8 major; + u8 nph; /* 0-base number of parameter headers */ + u8 unused; + + /* Basic Flash Parameter Table. */ + struct sfdp_parameter_header bfpt_header; +}; + +/* Basic Flash Parameter Table */ + +/* + * JESD216 rev B defines a Basic Flash Parameter Table of 16 DWORDs. + * They are indexed from 1 but C arrays are indexed from 0. + */ +#define BFPT_DWORD(i) ((i) - 1) +#define BFPT_DWORD_MAX 16 + +/* The first version of JESB216 defined only 9 DWORDs. */ +#define BFPT_DWORD_MAX_JESD216 9 + +/* 1st DWORD. */ +#define BFPT_DWORD1_FAST_READ_1_1_2 BIT(16) +#define BFPT_DWORD1_ADDRESS_BYTES_MASK GENMASK(18, 17) +#define BFPT_DWORD1_ADDRESS_BYTES_3_ONLY (0x0UL << 17) +#define BFPT_DWORD1_ADDRESS_BYTES_3_OR_4 (0x1UL << 17) +#define BFPT_DWORD1_ADDRESS_BYTES_4_ONLY (0x2UL << 17) +#define BFPT_DWORD1_DTR BIT(19) +#define BFPT_DWORD1_FAST_READ_1_2_2 BIT(20) +#define BFPT_DWORD1_FAST_READ_1_4_4 BIT(21) +#define BFPT_DWORD1_FAST_READ_1_1_4 BIT(22) + +/* 5th DWORD. */ +#define BFPT_DWORD5_FAST_READ_2_2_2 BIT(0) +#define BFPT_DWORD5_FAST_READ_4_4_4 BIT(4) + +/* 11th DWORD. */ +#define BFPT_DWORD11_PAGE_SIZE_SHIFT 4 +#define BFPT_DWORD11_PAGE_SIZE_MASK GENMASK(7, 4) + +/* 15th DWORD. */ + +/* + * (from JESD216 rev B) + * Quad Enable Requirements (QER): + * - 000b: Device does not have a QE bit. Device detects 1-1-4 and 1-4-4 + * reads based on instruction. DQ3/HOLD# functions are hold during + * instruction phase. + * - 001b: QE is bit 1 of status register 2. It is set via Write Status with + * two data bytes where bit 1 of the second byte is one. + * [...] + * Writing only one byte to the status register has the side-effect of + * clearing status register 2, including the QE bit. The 100b code is + * used if writing one byte to the status register does not modify + * status register 2. + * - 010b: QE is bit 6 of status register 1. It is set via Write Status with + * one data byte where bit 6 is one. + * [...] + * - 011b: QE is bit 7 of status register 2. It is set via Write status + * register 2 instruction 3Eh with one data byte where bit 7 is one. + * [...] + * The status register 2 is read using instruction 3Fh. + * - 100b: QE is bit 1 of status register 2. It is set via Write Status with + * two data bytes where bit 1 of the second byte is one. + * [...] + * In contrast to the 001b code, writing one byte to the status + * register does not modify status register 2. + * - 101b: QE is bit 1 of status register 2. Status register 1 is read using + * Read Status instruction 05h. Status register2 is read using + * instruction 35h. QE is set via Writ Status instruction 01h with + * two data bytes where bit 1 of the second byte is one. + * [...] + */ +#define BFPT_DWORD15_QER_MASK GENMASK(22, 20) +#define BFPT_DWORD15_QER_NONE (0x0UL << 20) /* Micron */ +#define BFPT_DWORD15_QER_SR2_BIT1_BUGGY (0x1UL << 20) +#define BFPT_DWORD15_QER_SR1_BIT6 (0x2UL << 20) /* Macronix */ +#define BFPT_DWORD15_QER_SR2_BIT7 (0x3UL << 20) +#define BFPT_DWORD15_QER_SR2_BIT1_NO_RD (0x4UL << 20) +#define BFPT_DWORD15_QER_SR2_BIT1 (0x5UL << 20) /* Spansion */ + +struct sfdp_bfpt { + u32 dwords[BFPT_DWORD_MAX]; +}; + +/* Fast Read settings. */ + +static inline void +spi_nor_set_read_settings_from_bfpt(struct spi_nor_read_command *read, + u16 half, + enum spi_nor_protocol proto) +{ + read->num_mode_clocks = (half >> 5) & 0x07; + read->num_wait_states = (half >> 0) & 0x1f; + read->opcode = (half >> 8) & 0xff; + read->proto = proto; +} + +struct sfdp_bfpt_read { + /* The Fast Read x-y-z hardware capability in params->hwcaps.mask. */ + u32 hwcaps; + + /* + * The <supported_bit> bit in <supported_dword> BFPT DWORD tells us + * whether the Fast Read x-y-z command is supported. + */ + u32 supported_dword; + u32 supported_bit; + + /* + * The half-word at offset <setting_shift> in <setting_dword> BFPT DWORD + * encodes the op code, the number of mode clocks and the number of wait + * states to be used by Fast Read x-y-z command. + */ + u32 settings_dword; + u32 settings_shift; + + /* The SPI protocol for this Fast Read x-y-z command. */ + enum spi_nor_protocol proto; +}; + +static const struct sfdp_bfpt_read sfdp_bfpt_reads[] = { + /* Fast Read 1-1-2 */ + { + SNOR_HWCAPS_READ_1_1_2, + BFPT_DWORD(1), BIT(16), /* Supported bit */ + BFPT_DWORD(4), 0, /* Settings */ + SNOR_PROTO_1_1_2, + }, + + /* Fast Read 1-2-2 */ + { + SNOR_HWCAPS_READ_1_2_2, + BFPT_DWORD(1), BIT(20), /* Supported bit */ + BFPT_DWORD(4), 16, /* Settings */ + SNOR_PROTO_1_2_2, + }, + + /* Fast Read 2-2-2 */ + { + SNOR_HWCAPS_READ_2_2_2, + BFPT_DWORD(5), BIT(0), /* Supported bit */ + BFPT_DWORD(6), 16, /* Settings */ + SNOR_PROTO_2_2_2, + }, + + /* Fast Read 1-1-4 */ + { + SNOR_HWCAPS_READ_1_1_4, + BFPT_DWORD(1), BIT(22), /* Supported bit */ + BFPT_DWORD(3), 16, /* Settings */ + SNOR_PROTO_1_1_4, + }, + + /* Fast Read 1-4-4 */ + { + SNOR_HWCAPS_READ_1_4_4, + BFPT_DWORD(1), BIT(21), /* Supported bit */ + BFPT_DWORD(3), 0, /* Settings */ + SNOR_PROTO_1_4_4, + }, + + /* Fast Read 4-4-4 */ + { + SNOR_HWCAPS_READ_4_4_4, + BFPT_DWORD(5), BIT(4), /* Supported bit */ + BFPT_DWORD(7), 16, /* Settings */ + SNOR_PROTO_4_4_4, + }, +}; + +struct sfdp_bfpt_erase { + /* + * The half-word at offset <shift> in DWORD <dwoard> encodes the + * op code and erase sector size to be used by Sector Erase commands. + */ + u32 dword; + u32 shift; +}; + +static const struct sfdp_bfpt_erase sfdp_bfpt_erases[] = { + /* Erase Type 1 in DWORD8 bits[15:0] */ + {BFPT_DWORD(8), 0}, + + /* Erase Type 2 in DWORD8 bits[31:16] */ + {BFPT_DWORD(8), 16}, + + /* Erase Type 3 in DWORD9 bits[15:0] */ + {BFPT_DWORD(9), 0}, + + /* Erase Type 4 in DWORD9 bits[31:16] */ + {BFPT_DWORD(9), 16}, +}; + +static int spi_nor_hwcaps_read2cmd(u32 hwcaps); + +/** + * spi_nor_parse_bfpt() - read and parse the Basic Flash Parameter Table. + * @nor: pointer to a 'struct spi_nor' + * @bfpt_header: pointer to the 'struct sfdp_parameter_header' describing + * the Basic Flash Parameter Table length and version + * @params: pointer to the 'struct spi_nor_flash_parameter' to be + * filled + * + * The Basic Flash Parameter Table is the main and only mandatory table as + * defined by the SFDP (JESD216) specification. + * It provides us with the total size (memory density) of the data array and + * the number of address bytes for Fast Read, Page Program and Sector Erase + * commands. + * For Fast READ commands, it also gives the number of mode clock cycles and + * wait states (regrouped in the number of dummy clock cycles) for each + * supported instruction op code. + * For Page Program, the page size is now available since JESD216 rev A, however + * the supported instruction op codes are still not provided. + * For Sector Erase commands, this table stores the supported instruction op + * codes and the associated sector sizes. + * Finally, the Quad Enable Requirements (QER) are also available since JESD216 + * rev A. The QER bits encode the manufacturer dependent procedure to be + * executed to set the Quad Enable (QE) bit in some internal register of the + * Quad SPI memory. Indeed the QE bit, when it exists, must be set before + * sending any Quad SPI command to the memory. Actually, setting the QE bit + * tells the memory to reassign its WP# and HOLD#/RESET# pins to functions IO2 + * and IO3 hence enabling 4 (Quad) I/O lines. + * + * Return: 0 on success, -errno otherwise. + */ +static int spi_nor_parse_bfpt(struct spi_nor *nor, + const struct sfdp_parameter_header *bfpt_header, + struct spi_nor_flash_parameter *params) +{ + struct mtd_info *mtd = &nor->mtd; + struct sfdp_bfpt bfpt; + size_t len; + int i, cmd, err; + u32 addr; + u16 half; + + /* JESD216 Basic Flash Parameter Table length is at least 9 DWORDs. */ + if (bfpt_header->length < BFPT_DWORD_MAX_JESD216) + return -EINVAL; + + /* Read the Basic Flash Parameter Table. */ + len = min_t(size_t, sizeof(bfpt), + bfpt_header->length * sizeof(u32)); + addr = SFDP_PARAM_HEADER_PTP(bfpt_header); + memset(&bfpt, 0, sizeof(bfpt)); + err = spi_nor_read_sfdp(nor, addr, len, &bfpt); + if (err < 0) + return err; + + /* Fix endianness of the BFPT DWORDs. */ + for (i = 0; i < BFPT_DWORD_MAX; i++) + bfpt.dwords[i] = le32_to_cpu(bfpt.dwords[i]); + + /* Number of address bytes. */ + switch (bfpt.dwords[BFPT_DWORD(1)] & BFPT_DWORD1_ADDRESS_BYTES_MASK) { + case BFPT_DWORD1_ADDRESS_BYTES_3_ONLY: + nor->addr_width = 3; + break; + + case BFPT_DWORD1_ADDRESS_BYTES_4_ONLY: + nor->addr_width = 4; + break; + + default: + break; + } + + /* Flash Memory Density (in bits). */ + params->size = bfpt.dwords[BFPT_DWORD(2)]; + if (params->size & BIT(31)) { + params->size &= ~BIT(31); + + /* + * Prevent overflows on params->size. Anyway, a NOR of 2^64 + * bits is unlikely to exist so this error probably means + * the BFPT we are reading is corrupted/wrong. + */ + if (params->size > 63) + return -EINVAL; + + params->size = 1ULL << params->size; + } else { + params->size++; + } + params->size >>= 3; /* Convert to bytes. */ + + /* Fast Read settings. */ + for (i = 0; i < ARRAY_SIZE(sfdp_bfpt_reads); i++) { + const struct sfdp_bfpt_read *rd = &sfdp_bfpt_reads[i]; + struct spi_nor_read_command *read; + + if (!(bfpt.dwords[rd->supported_dword] & rd->supported_bit)) { + params->hwcaps.mask &= ~rd->hwcaps; + continue; + } + + params->hwcaps.mask |= rd->hwcaps; + cmd = spi_nor_hwcaps_read2cmd(rd->hwcaps); + read = ¶ms->reads[cmd]; + half = bfpt.dwords[rd->settings_dword] >> rd->settings_shift; + spi_nor_set_read_settings_from_bfpt(read, half, rd->proto); + } + + /* Sector Erase settings. */ + for (i = 0; i < ARRAY_SIZE(sfdp_bfpt_erases); i++) { + const struct sfdp_bfpt_erase *er = &sfdp_bfpt_erases[i]; + u32 erasesize; + u8 opcode; + + half = bfpt.dwords[er->dword] >> er->shift; + erasesize = half & 0xff; + + /* erasesize == 0 means this Erase Type is not supported. */ + if (!erasesize) + continue; + + erasesize = 1U << erasesize; + opcode = (half >> 8) & 0xff; +#ifdef CONFIG_MTD_SPI_NOR_USE_4K_SECTORS + if (erasesize == SZ_4K) { + nor->erase_opcode = opcode; + mtd->erasesize = erasesize; + break; + } +#endif + if (!mtd->erasesize || mtd->erasesize < erasesize) { + nor->erase_opcode = opcode; + mtd->erasesize = erasesize; + } + } + + /* Stop here if not JESD216 rev A or later. */ + if (bfpt_header->length < BFPT_DWORD_MAX) + return 0; + + /* Page size: this field specifies 'N' so the page size = 2^N bytes. */ + params->page_size = bfpt.dwords[BFPT_DWORD(11)]; + params->page_size &= BFPT_DWORD11_PAGE_SIZE_MASK; + params->page_size >>= BFPT_DWORD11_PAGE_SIZE_SHIFT; + params->page_size = 1U << params->page_size; + + /* Quad Enable Requirements. */ + switch (bfpt.dwords[BFPT_DWORD(15)] & BFPT_DWORD15_QER_MASK) { + case BFPT_DWORD15_QER_NONE: + params->quad_enable = NULL; + break; + +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) + case BFPT_DWORD15_QER_SR2_BIT1_BUGGY: + case BFPT_DWORD15_QER_SR2_BIT1_NO_RD: + params->quad_enable = spansion_no_read_cr_quad_enable; + break; +#endif + +#ifdef CONFIG_SPI_FLASH_MACRONIX + case BFPT_DWORD15_QER_SR1_BIT6: + params->quad_enable = macronix_quad_enable; + break; +#endif +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) + case BFPT_DWORD15_QER_SR2_BIT1: + params->quad_enable = spansion_read_cr_quad_enable; + break; +#endif + + default: + return -EINVAL; + } + + return 0; +} + +/** + * spi_nor_parse_sfdp() - parse the Serial Flash Discoverable Parameters. + * @nor: pointer to a 'struct spi_nor' + * @params: pointer to the 'struct spi_nor_flash_parameter' to be + * filled + * + * The Serial Flash Discoverable Parameters are described by the JEDEC JESD216 + * specification. This is a standard which tends to supported by almost all + * (Q)SPI memory manufacturers. Those hard-coded tables allow us to learn at + * runtime the main parameters needed to perform basic SPI flash operations such + * as Fast Read, Page Program or Sector Erase commands. + * + * Return: 0 on success, -errno otherwise. + */ +static int spi_nor_parse_sfdp(struct spi_nor *nor, + struct spi_nor_flash_parameter *params) +{ + const struct sfdp_parameter_header *param_header, *bfpt_header; + struct sfdp_parameter_header *param_headers = NULL; + struct sfdp_header header; + size_t psize; + int i, err; + + /* Get the SFDP header. */ + err = spi_nor_read_sfdp(nor, 0, sizeof(header), &header); + if (err < 0) + return err; + + /* Check the SFDP header version. */ + if (le32_to_cpu(header.signature) != SFDP_SIGNATURE || + header.major != SFDP_JESD216_MAJOR) + return -EINVAL; + + /* + * Verify that the first and only mandatory parameter header is a + * Basic Flash Parameter Table header as specified in JESD216. + */ + bfpt_header = &header.bfpt_header; + if (SFDP_PARAM_HEADER_ID(bfpt_header) != SFDP_BFPT_ID || + bfpt_header->major != SFDP_JESD216_MAJOR) + return -EINVAL; + + /* + * Allocate memory then read all parameter headers with a single + * Read SFDP command. These parameter headers will actually be parsed + * twice: a first time to get the latest revision of the basic flash + * parameter table, then a second time to handle the supported optional + * tables. + * Hence we read the parameter headers once for all to reduce the + * processing time. Also we use kmalloc() instead of devm_kmalloc() + * because we don't need to keep these parameter headers: the allocated + * memory is always released with kfree() before exiting this function. + */ + if (header.nph) { + psize = header.nph * sizeof(*param_headers); + + param_headers = kmalloc(psize, GFP_KERNEL); + if (!param_headers) + return -ENOMEM; + + err = spi_nor_read_sfdp(nor, sizeof(header), + psize, param_headers); + if (err < 0) { + dev_err(dev, "failed to read SFDP parameter headers\n"); + goto exit; + } + } + + /* + * Check other parameter headers to get the latest revision of + * the basic flash parameter table. + */ + for (i = 0; i < header.nph; i++) { + param_header = ¶m_headers[i]; + + if (SFDP_PARAM_HEADER_ID(param_header) == SFDP_BFPT_ID && + param_header->major == SFDP_JESD216_MAJOR && + (param_header->minor > bfpt_header->minor || + (param_header->minor == bfpt_header->minor && + param_header->length > bfpt_header->length))) + bfpt_header = param_header; + } + + err = spi_nor_parse_bfpt(nor, bfpt_header, params); + if (err) + goto exit; + + /* Parse other parameter headers. */ + for (i = 0; i < header.nph; i++) { + param_header = ¶m_headers[i]; + + switch (SFDP_PARAM_HEADER_ID(param_header)) { + case SFDP_SECTOR_MAP_ID: + dev_info(dev, "non-uniform erase sector maps are not supported yet.\n"); + break; + + default: + break; + } + + if (err) + goto exit; + } + +exit: + kfree(param_headers); + return err; +} +#else +static int spi_nor_parse_sfdp(struct spi_nor *nor, + struct spi_nor_flash_parameter *params) +{ + return -EINVAL; +} +#endif /* CONFIG_SPI_FLASH_SFDP_SUPPORT */ + +static int spi_nor_init_params(struct spi_nor *nor, + const struct flash_info *info, + struct spi_nor_flash_parameter *params) +{ + /* Set legacy flash parameters as default. */ + memset(params, 0, sizeof(*params)); + + /* Set SPI NOR sizes. */ + params->size = info->sector_size * info->n_sectors; + params->page_size = info->page_size; + + /* (Fast) Read settings. */ + params->hwcaps.mask |= SNOR_HWCAPS_READ; + spi_nor_set_read_settings(¶ms->reads[SNOR_CMD_READ], + 0, 0, SPINOR_OP_READ, + SNOR_PROTO_1_1_1); + + if (!(info->flags & SPI_NOR_NO_FR)) { + params->hwcaps.mask |= SNOR_HWCAPS_READ_FAST; + spi_nor_set_read_settings(¶ms->reads[SNOR_CMD_READ_FAST], + 0, 8, SPINOR_OP_READ_FAST, + SNOR_PROTO_1_1_1); + } + + if (info->flags & SPI_NOR_DUAL_READ) { + params->hwcaps.mask |= SNOR_HWCAPS_READ_1_1_2; + spi_nor_set_read_settings(¶ms->reads[SNOR_CMD_READ_1_1_2], + 0, 8, SPINOR_OP_READ_1_1_2, + SNOR_PROTO_1_1_2); + } + + if (info->flags & SPI_NOR_QUAD_READ) { + params->hwcaps.mask |= SNOR_HWCAPS_READ_1_1_4; + spi_nor_set_read_settings(¶ms->reads[SNOR_CMD_READ_1_1_4], + 0, 8, SPINOR_OP_READ_1_1_4, + SNOR_PROTO_1_1_4); + } + + /* Page Program settings. */ + params->hwcaps.mask |= SNOR_HWCAPS_PP; + spi_nor_set_pp_settings(¶ms->page_programs[SNOR_CMD_PP], + SPINOR_OP_PP, SNOR_PROTO_1_1_1); + + if (info->flags & SPI_NOR_QUAD_READ) { + params->hwcaps.mask |= SNOR_HWCAPS_PP_1_1_4; + spi_nor_set_pp_settings(¶ms->page_programs[SNOR_CMD_PP_1_1_4], + SPINOR_OP_PP_1_1_4, SNOR_PROTO_1_1_4); + } + + /* Select the procedure to set the Quad Enable bit. */ + if (params->hwcaps.mask & (SNOR_HWCAPS_READ_QUAD | + SNOR_HWCAPS_PP_QUAD)) { + switch (JEDEC_MFR(info)) { +#ifdef CONFIG_SPI_FLASH_MACRONIX + case SNOR_MFR_MACRONIX: + params->quad_enable = macronix_quad_enable; + break; +#endif + case SNOR_MFR_MICRON: + break; + + default: +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) + /* Kept only for backward compatibility purpose. */ + params->quad_enable = spansion_read_cr_quad_enable; +#endif + break; + } +#ifndef __UBOOT__ + /* + * Some manufacturer like GigaDevice may use different + * bit to set QE on different memories, so the MFR can't + * indicate the quad_enable method for this case, we need + * set it in flash info list. + */ + if (info->quad_enable) + params->quad_enable = info->quad_enable; +#endif + } + + /* Override the parameters with data read from SFDP tables. */ + nor->addr_width = 0; + nor->mtd.erasesize = 0; + if ((info->flags & (SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ)) && + !(info->flags & SPI_NOR_SKIP_SFDP)) { + struct spi_nor_flash_parameter sfdp_params; + + memcpy(&sfdp_params, params, sizeof(sfdp_params)); + if (spi_nor_parse_sfdp(nor, &sfdp_params)) { + nor->addr_width = 0; + nor->mtd.erasesize = 0; + } else { + memcpy(params, &sfdp_params, sizeof(*params)); + } + } + + return 0; +} + +static int spi_nor_select_read(struct spi_nor *nor, + const struct spi_nor_flash_parameter *params, + u32 shared_hwcaps) +{ + int best_match = shared_hwcaps & SNOR_HWCAPS_READ_MASK; + int cmd; + const struct spi_nor_read_command *read; + + if (best_match < 0) + return -EINVAL; + + if (best_match & SNOR_HWCAPS_READ_1_4_4) + cmd = SNOR_CMD_READ_1_4_4; + else if (best_match & SNOR_HWCAPS_READ_1_1_4) + cmd = SNOR_CMD_READ_1_1_4; + else + cmd = SNOR_CMD_READ; + + read = ¶ms->reads[cmd]; + nor->read_opcode = read->opcode; + nor->read_proto = read->proto; + + /* + * In the spi-nor framework, we don't need to make the difference + * between mode clock cycles and wait state clock cycles. + * Indeed, the value of the mode clock cycles is used by a QSPI + * flash memory to know whether it should enter or leave its 0-4-4 + * (Continuous Read / XIP) mode. + * eXecution In Place is out of the scope of the mtd sub-system. + * Hence we choose to merge both mode and wait state clock cycles + * into the so called dummy clock cycles. + */ + nor->read_dummy = read->num_mode_clocks + read->num_wait_states; + return 0; +} + +static int spi_nor_select_pp(struct spi_nor *nor, + const struct spi_nor_flash_parameter *params, + u32 shared_hwcaps) +{ + int best_match = shared_hwcaps & SNOR_HWCAPS_PP_MASK; + int cmd; + const struct spi_nor_pp_command *pp; + + if (best_match < 0) + return -EINVAL; + + if (best_match & SNOR_HWCAPS_PP_1_1_4) + cmd = SNOR_CMD_PP_1_1_4; + else + cmd = SNOR_CMD_PP; + + pp = ¶ms->page_programs[cmd]; + nor->program_opcode = pp->opcode; + nor->write_proto = pp->proto; + return 0; +} + +static int spi_nor_select_erase(struct spi_nor *nor, + const struct flash_info *info) +{ + struct mtd_info *mtd = &nor->mtd; + + /* Do nothing if already configured from SFDP. */ + if (mtd->erasesize) + return 0; + +#ifdef CONFIG_SPI_FLASH_USE_4K_SECTORS + /* prefer "small sector" erase if possible */ + if (info->flags & SECT_4K) { + nor->erase_opcode = SPINOR_OP_BE_4K; + mtd->erasesize = 4096; + } else if (info->flags & SECT_4K_PMC) { + nor->erase_opcode = SPINOR_OP_BE_4K_PMC; + mtd->erasesize = 4096; + } else +#endif + { + nor->erase_opcode = SPINOR_OP_SE; + mtd->erasesize = info->sector_size; + } + return 0; +} + +static int spi_nor_setup(struct spi_nor *nor, const struct flash_info *info, + const struct spi_nor_flash_parameter *params, + const struct spi_nor_hwcaps *hwcaps) +{ + u32 ignored_mask, shared_mask; + bool enable_quad_io; + int err; + + /* + * Keep only the hardware capabilities supported by both the SPI + * controller and the SPI flash memory. + */ + shared_mask = hwcaps->mask & params->hwcaps.mask; + + /* SPI n-n-n protocols are not supported yet. */ + ignored_mask = (SNOR_HWCAPS_READ_2_2_2 | + SNOR_HWCAPS_READ_4_4_4 | + SNOR_HWCAPS_READ_8_8_8 | + SNOR_HWCAPS_PP_4_4_4 | + SNOR_HWCAPS_PP_8_8_8); + if (shared_mask & ignored_mask) { + dev_dbg(nor->dev, + "SPI n-n-n protocols are not supported yet.\n"); + shared_mask &= ~ignored_mask; + } + + /* Select the (Fast) Read command. */ + err = spi_nor_select_read(nor, params, shared_mask); + if (err) { + dev_dbg(nor->dev, + "can't select read settings supported by both the SPI controller and memory.\n"); + return err; + } + + /* Select the Page Program command. */ + err = spi_nor_select_pp(nor, params, shared_mask); + if (err) { + dev_dbg(nor->dev, + "can't select write settings supported by both the SPI controller and memory.\n"); + return err; + } + + /* Select the Sector Erase command. */ + err = spi_nor_select_erase(nor, info); + if (err) { + dev_dbg(nor->dev, + "can't select erase settings supported by both the SPI controller and memory.\n"); + return err; + } + + /* Enable Quad I/O if needed. */ + enable_quad_io = (spi_nor_get_protocol_width(nor->read_proto) == 4 || + spi_nor_get_protocol_width(nor->write_proto) == 4); + if (enable_quad_io && params->quad_enable) + nor->quad_enable = params->quad_enable; + else + nor->quad_enable = NULL; + + return 0; +} + +static int spi_nor_init(struct spi_nor *nor) +{ + int err; + + /* + * Atmel, SST, Intel/Numonyx, and others serial NOR tend to power up + * with the software protection bits set + */ + if (JEDEC_MFR(nor->info) == SNOR_MFR_ATMEL || + JEDEC_MFR(nor->info) == SNOR_MFR_INTEL || + JEDEC_MFR(nor->info) == SNOR_MFR_SST || + nor->info->flags & SPI_NOR_HAS_LOCK) { + write_enable(nor); + write_sr(nor, 0); + spi_nor_wait_till_ready(nor); + } + + if (nor->quad_enable) { + err = nor->quad_enable(nor); + if (err) { + dev_dbg(nor->dev, "quad mode not supported\n"); + return err; + } + } + + if (nor->addr_width == 4 && + (JEDEC_MFR(nor->info) != SNOR_MFR_SPANSION) && + !(nor->info->flags & SPI_NOR_4B_OPCODES)) { + /* + * If the RESET# pin isn't hooked up properly, or the system + * otherwise doesn't perform a reset command in the boot + * sequence, it's impossible to 100% protect against unexpected + * reboots (e.g., crashes). Warn the user (or hopefully, system + * designer) that this is bad. + */ + if (nor->flags & SNOR_F_BROKEN_RESET) + printf("enabling reset hack; may not recover from unexpected reboots\n"); + set_4byte(nor, nor->info, 1); + } + + return 0; +} + +int spi_nor_scan(struct spi_nor *nor) +{ + struct spi_nor_flash_parameter params; + const struct flash_info *info = NULL; + struct mtd_info *mtd = &nor->mtd; + struct spi_nor_hwcaps hwcaps = { + .mask = SNOR_HWCAPS_READ | + SNOR_HWCAPS_READ_FAST | + SNOR_HWCAPS_PP, + }; + struct spi_slave *spi = nor->spi; + int ret; + + /* Reset SPI protocol for all commands. */ + nor->reg_proto = SNOR_PROTO_1_1_1; + nor->read_proto = SNOR_PROTO_1_1_1; + nor->write_proto = SNOR_PROTO_1_1_1; + nor->read = spi_nor_read_data; + nor->write = spi_nor_write_data; + nor->read_reg = spi_nor_read_reg; + nor->write_reg = spi_nor_write_reg; + + if (spi->mode & SPI_RX_QUAD) { + hwcaps.mask |= SNOR_HWCAPS_READ_1_1_4; + + if (spi->mode & SPI_TX_QUAD) + hwcaps.mask |= (SNOR_HWCAPS_READ_1_4_4 | + SNOR_HWCAPS_PP_1_1_4 | + SNOR_HWCAPS_PP_1_4_4); + } else if (spi->mode & SPI_RX_DUAL) { + hwcaps.mask |= SNOR_HWCAPS_READ_1_1_2; + + if (spi->mode & SPI_TX_DUAL) + hwcaps.mask |= SNOR_HWCAPS_READ_1_2_2; + } + + info = spi_nor_read_id(nor); + if (IS_ERR_OR_NULL(info)) + return -ENOENT; + /* Parse the Serial Flash Discoverable Parameters table. */ + ret = spi_nor_init_params(nor, info, ¶ms); + if (ret) + return ret; + + if (!mtd->name) + mtd->name = info->name; + mtd->priv = nor; + mtd->type = MTD_NORFLASH; + mtd->writesize = 1; + mtd->flags = MTD_CAP_NORFLASH; + mtd->size = params.size; + mtd->_erase = spi_nor_erase; + mtd->_read = spi_nor_read; + +#if defined(CONFIG_SPI_FLASH_STMICRO) || defined(CONFIG_SPI_FLASH_SST) + /* NOR protection support for STmicro/Micron chips and similar */ + if (JEDEC_MFR(info) == SNOR_MFR_ST || + JEDEC_MFR(info) == SNOR_MFR_MICRON || + JEDEC_MFR(info) == SNOR_MFR_SST || + info->flags & SPI_NOR_HAS_LOCK) { + nor->flash_lock = stm_lock; + nor->flash_unlock = stm_unlock; + nor->flash_is_locked = stm_is_locked; + } +#endif + + if (nor->flash_lock && nor->flash_unlock && nor->flash_is_locked) { + mtd->_lock = spi_nor_lock; + mtd->_unlock = spi_nor_unlock; + mtd->_is_locked = spi_nor_is_locked; + } + +#ifdef CONFIG_SPI_FLASH_SST + /* sst nor chips use AAI word program */ + if (info->flags & SST_WRITE) + mtd->_write = sst_write; + else +#endif + mtd->_write = spi_nor_write; + + if (info->flags & USE_FSR) + nor->flags |= SNOR_F_USE_FSR; + if (info->flags & SPI_NOR_HAS_TB) + nor->flags |= SNOR_F_HAS_SR_TB; + if (info->flags & NO_CHIP_ERASE) + nor->flags |= SNOR_F_NO_OP_CHIP_ERASE; + if (info->flags & USE_CLSR) + nor->flags |= SNOR_F_USE_CLSR; + + if (info->flags & SPI_NOR_NO_ERASE) + mtd->flags |= MTD_NO_ERASE; + + nor->page_size = params.page_size; + mtd->writebufsize = nor->page_size; + + /* Some devices cannot do fast-read, no matter what DT tells us */ + if (info->flags & SPI_NOR_NO_FR) + params.hwcaps.mask &= ~SNOR_HWCAPS_READ_FAST; + + /* + * Configure the SPI memory: + * - select op codes for (Fast) Read, Page Program and Sector Erase. + * - set the number of dummy cycles (mode cycles + wait states). + * - set the SPI protocols for register and memory accesses. + * - set the Quad Enable bit if needed (required by SPI x-y-4 protos). + */ + ret = spi_nor_setup(nor, info, ¶ms, &hwcaps); + if (ret) + return ret; + + if (nor->addr_width) { + /* already configured from SFDP */ + } else if (info->addr_width) { + nor->addr_width = info->addr_width; + } else if (mtd->size > 0x1000000) { + /* enable 4-byte addressing if the device exceeds 16MiB */ + nor->addr_width = 4; + if (JEDEC_MFR(info) == SNOR_MFR_SPANSION || + info->flags & SPI_NOR_4B_OPCODES) + spi_nor_set_4byte_opcodes(nor, info); + } else { + nor->addr_width = 3; + } + + if (nor->addr_width > SPI_NOR_MAX_ADDR_WIDTH) { + dev_dbg(dev, "address width is too large: %u\n", + nor->addr_width); + return -EINVAL; + } + + /* Send all the required SPI flash commands to initialize device */ + nor->info = info; + ret = spi_nor_init(nor); + if (ret) + return ret; + + nor->name = mtd->name; + nor->size = mtd->size; + nor->erase_size = mtd->erasesize; + nor->sector_size = mtd->erasesize; + +#ifndef CONFIG_SPL_BUILD + printf("SF: Detected %s with page size ", nor->name); + print_size(nor->page_size, ", erase size "); + print_size(nor->erase_size, ", total "); + print_size(nor->size, ""); + puts("\n"); +#endif + +#ifndef __UBOOT__ + dev_info(dev, "%s (%lld Kbytes)\n", info->name, + (long long)mtd->size >> 10); + + dev_dbg(dev, + "mtd .name = %s, .size = 0x%llx (%lldMiB), " + ".erasesize = 0x%.8x (%uKiB) .numeraseregions = %d\n", + mtd->name, (long long)mtd->size, (long long)(mtd->size >> 20), + mtd->erasesize, mtd->erasesize / 1024, mtd->numeraseregions); + + if (mtd->numeraseregions) + for (i = 0; i < mtd->numeraseregions; i++) + dev_dbg(dev, + "mtd.eraseregions[%d] = { .offset = 0x%llx, " + ".erasesize = 0x%.8x (%uKiB), " + ".numblocks = %d }\n", + i, (long long)mtd->eraseregions[i].offset, + mtd->eraseregions[i].erasesize, + mtd->eraseregions[i].erasesize / 1024, + mtd->eraseregions[i].numblocks); +#endif + + return 0; +} +EXPORT_SYMBOL_GPL(spi_nor_scan); + +/* U-Boot specific functions, need to extend MTD to support these */ +int spi_flash_cmd_get_sw_write_prot(struct spi_nor *nor) +{ + int sr = read_sr(nor); + + if (sr < 0) + return sr; + + return (sr >> 2) & 7; +} + +MODULE_LICENSE("GPL"); +MODULE_AUTHOR("Huang Shijie shijie8@gmail.com"); +MODULE_AUTHOR("Mike Lavender"); +MODULE_DESCRIPTION("framework for SPI NOR"); diff --git a/include/linux/mtd/cfi.h b/include/linux/mtd/cfi.h new file mode 100644 index 000000000000..3555518bd3f1 --- /dev/null +++ b/include/linux/mtd/cfi.h @@ -0,0 +1,32 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright © 2000-2010 David Woodhouse dwmw2@infradead.org et al. + * + */ + +#ifndef __MTD_CFI_H__ +#define __MTD_CFI_H__ + +#define CFI_MFR_ANY 0xFFFF +#define CFI_ID_ANY 0xFFFF +#define CFI_MFR_CONTINUATION 0x007F + +#define CFI_MFR_AMD 0x0001 +#define CFI_MFR_AMIC 0x0037 +#define CFI_MFR_ATMEL 0x001F +#define CFI_MFR_EON 0x001C +#define CFI_MFR_FUJITSU 0x0004 +#define CFI_MFR_HYUNDAI 0x00AD +#define CFI_MFR_INTEL 0x0089 +#define CFI_MFR_MACRONIX 0x00C2 +#define CFI_MFR_NEC 0x0010 +#define CFI_MFR_PMC 0x009D +#define CFI_MFR_SAMSUNG 0x00EC +#define CFI_MFR_SHARP 0x00B0 +#define CFI_MFR_SST 0x00BF +#define CFI_MFR_ST 0x0020 /* STMicroelectronics */ +#define CFI_MFR_MICRON 0x002C /* Micron */ +#define CFI_MFR_TOSHIBA 0x0098 +#define CFI_MFR_WINBOND 0x00DA + +#endif /* __MTD_CFI_H__ */ diff --git a/include/linux/mtd/spi-nor.h b/include/linux/mtd/spi-nor.h new file mode 100644 index 000000000000..2cc86b16030c --- /dev/null +++ b/include/linux/mtd/spi-nor.h @@ -0,0 +1,421 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2014 Freescale Semiconductor, Inc. + * Synced from Linux v4.19 + */ + +#ifndef __LINUX_MTD_SPI_NOR_H +#define __LINUX_MTD_SPI_NOR_H + +#include <linux/bitops.h> +#include <linux/mtd/cfi.h> +#include <linux/mtd/mtd.h> + +/* + * Manufacturer IDs + * + * The first byte returned from the flash after sending opcode SPINOR_OP_RDID. + * Sometimes these are the same as CFI IDs, but sometimes they aren't. + */ +#define SNOR_MFR_ATMEL CFI_MFR_ATMEL +#define SNOR_MFR_GIGADEVICE 0xc8 +#define SNOR_MFR_INTEL CFI_MFR_INTEL +#define SNOR_MFR_ST CFI_MFR_ST /* ST Micro <--> Micron */ +#define SNOR_MFR_MICRON CFI_MFR_MICRON /* ST Micro <--> Micron */ +#define SNOR_MFR_MACRONIX CFI_MFR_MACRONIX +#define SNOR_MFR_SPANSION CFI_MFR_AMD +#define SNOR_MFR_SST CFI_MFR_SST +#define SNOR_MFR_WINBOND 0xef /* Also used by some Spansion */ + +/* + * Note on opcode nomenclature: some opcodes have a format like + * SPINOR_OP_FUNCTION{4,}_x_y_z. The numbers x, y, and z stand for the number + * of I/O lines used for the opcode, address, and data (respectively). The + * FUNCTION has an optional suffix of '4', to represent an opcode which + * requires a 4-byte (32-bit) address. + */ + +/* Flash opcodes. */ +#define SPINOR_OP_WREN 0x06 /* Write enable */ +#define SPINOR_OP_RDSR 0x05 /* Read status register */ +#define SPINOR_OP_WRSR 0x01 /* Write status register 1 byte */ +#define SPINOR_OP_RDSR2 0x3f /* Read status register 2 */ +#define SPINOR_OP_WRSR2 0x3e /* Write status register 2 */ +#define SPINOR_OP_READ 0x03 /* Read data bytes (low frequency) */ +#define SPINOR_OP_READ_FAST 0x0b /* Read data bytes (high frequency) */ +#define SPINOR_OP_READ_1_1_2 0x3b /* Read data bytes (Dual Output SPI) */ +#define SPINOR_OP_READ_1_2_2 0xbb /* Read data bytes (Dual I/O SPI) */ +#define SPINOR_OP_READ_1_1_4 0x6b /* Read data bytes (Quad Output SPI) */ +#define SPINOR_OP_READ_1_4_4 0xeb /* Read data bytes (Quad I/O SPI) */ +#define SPINOR_OP_PP 0x02 /* Page program (up to 256 bytes) */ +#define SPINOR_OP_PP_1_1_4 0x32 /* Quad page program */ +#define SPINOR_OP_PP_1_4_4 0x38 /* Quad page program */ +#define SPINOR_OP_BE_4K 0x20 /* Erase 4KiB block */ +#define SPINOR_OP_BE_4K_PMC 0xd7 /* Erase 4KiB block on PMC chips */ +#define SPINOR_OP_BE_32K 0x52 /* Erase 32KiB block */ +#define SPINOR_OP_CHIP_ERASE 0xc7 /* Erase whole flash chip */ +#define SPINOR_OP_SE 0xd8 /* Sector erase (usually 64KiB) */ +#define SPINOR_OP_RDID 0x9f /* Read JEDEC ID */ +#define SPINOR_OP_RDSFDP 0x5a /* Read SFDP */ +#define SPINOR_OP_RDCR 0x35 /* Read configuration register */ +#define SPINOR_OP_RDFSR 0x70 /* Read flag status register */ +#define SPINOR_OP_CLFSR 0x50 /* Clear flag status register */ +#define SPINOR_OP_RDEAR 0xc8 /* Read Extended Address Register */ +#define SPINOR_OP_WREAR 0xc5 /* Write Extended Address Register */ + +/* 4-byte address opcodes - used on Spansion and some Macronix flashes. */ +#define SPINOR_OP_READ_4B 0x13 /* Read data bytes (low frequency) */ +#define SPINOR_OP_READ_FAST_4B 0x0c /* Read data bytes (high frequency) */ +#define SPINOR_OP_READ_1_1_2_4B 0x3c /* Read data bytes (Dual Output SPI) */ +#define SPINOR_OP_READ_1_2_2_4B 0xbc /* Read data bytes (Dual I/O SPI) */ +#define SPINOR_OP_READ_1_1_4_4B 0x6c /* Read data bytes (Quad Output SPI) */ +#define SPINOR_OP_READ_1_4_4_4B 0xec /* Read data bytes (Quad I/O SPI) */ +#define SPINOR_OP_PP_4B 0x12 /* Page program (up to 256 bytes) */ +#define SPINOR_OP_PP_1_1_4_4B 0x34 /* Quad page program */ +#define SPINOR_OP_PP_1_4_4_4B 0x3e /* Quad page program */ +#define SPINOR_OP_BE_4K_4B 0x21 /* Erase 4KiB block */ +#define SPINOR_OP_BE_32K_4B 0x5c /* Erase 32KiB block */ +#define SPINOR_OP_SE_4B 0xdc /* Sector erase (usually 64KiB) */ + +/* Double Transfer Rate opcodes - defined in JEDEC JESD216B. */ +#define SPINOR_OP_READ_1_1_1_DTR 0x0d +#define SPINOR_OP_READ_1_2_2_DTR 0xbd +#define SPINOR_OP_READ_1_4_4_DTR 0xed + +#define SPINOR_OP_READ_1_1_1_DTR_4B 0x0e +#define SPINOR_OP_READ_1_2_2_DTR_4B 0xbe +#define SPINOR_OP_READ_1_4_4_DTR_4B 0xee + +/* Used for SST flashes only. */ +#define SPINOR_OP_BP 0x02 /* Byte program */ +#define SPINOR_OP_WRDI 0x04 /* Write disable */ +#define SPINOR_OP_AAI_WP 0xad /* Auto address increment word program */ + +/* Used for S3AN flashes only */ +#define SPINOR_OP_XSE 0x50 /* Sector erase */ +#define SPINOR_OP_XPP 0x82 /* Page program */ +#define SPINOR_OP_XRDSR 0xd7 /* Read status register */ + +#define XSR_PAGESIZE BIT(0) /* Page size in Po2 or Linear */ +#define XSR_RDY BIT(7) /* Ready */ + +/* Used for Macronix and Winbond flashes. */ +#define SPINOR_OP_EN4B 0xb7 /* Enter 4-byte mode */ +#define SPINOR_OP_EX4B 0xe9 /* Exit 4-byte mode */ + +/* Used for Spansion flashes only. */ +#define SPINOR_OP_BRWR 0x17 /* Bank register write */ +#define SPINOR_OP_CLSR 0x30 /* Clear status register 1 */ + +/* Used for Micron flashes only. */ +#define SPINOR_OP_RD_EVCR 0x65 /* Read EVCR register */ +#define SPINOR_OP_WD_EVCR 0x61 /* Write EVCR register */ + +/* Status Register bits. */ +#define SR_WIP BIT(0) /* Write in progress */ +#define SR_WEL BIT(1) /* Write enable latch */ +/* meaning of other SR_* bits may differ between vendors */ +#define SR_BP0 BIT(2) /* Block protect 0 */ +#define SR_BP1 BIT(3) /* Block protect 1 */ +#define SR_BP2 BIT(4) /* Block protect 2 */ +#define SR_TB BIT(5) /* Top/Bottom protect */ +#define SR_SRWD BIT(7) /* SR write protect */ +/* Spansion/Cypress specific status bits */ +#define SR_E_ERR BIT(5) +#define SR_P_ERR BIT(6) + +#define SR_QUAD_EN_MX BIT(6) /* Macronix Quad I/O */ + +/* Enhanced Volatile Configuration Register bits */ +#define EVCR_QUAD_EN_MICRON BIT(7) /* Micron Quad I/O */ + +/* Flag Status Register bits */ +#define FSR_READY BIT(7) /* Device status, 0 = Busy, 1 = Ready */ +#define FSR_E_ERR BIT(5) /* Erase operation status */ +#define FSR_P_ERR BIT(4) /* Program operation status */ +#define FSR_PT_ERR BIT(1) /* Protection error bit */ + +/* Configuration Register bits. */ +#define CR_QUAD_EN_SPAN BIT(1) /* Spansion Quad I/O */ + +/* Status Register 2 bits. */ +#define SR2_QUAD_EN_BIT7 BIT(7) + +/* Supported SPI protocols */ +#define SNOR_PROTO_INST_MASK GENMASK(23, 16) +#define SNOR_PROTO_INST_SHIFT 16 +#define SNOR_PROTO_INST(_nbits) \ + ((((unsigned long)(_nbits)) << SNOR_PROTO_INST_SHIFT) & \ + SNOR_PROTO_INST_MASK) + +#define SNOR_PROTO_ADDR_MASK GENMASK(15, 8) +#define SNOR_PROTO_ADDR_SHIFT 8 +#define SNOR_PROTO_ADDR(_nbits) \ + ((((unsigned long)(_nbits)) << SNOR_PROTO_ADDR_SHIFT) & \ + SNOR_PROTO_ADDR_MASK) + +#define SNOR_PROTO_DATA_MASK GENMASK(7, 0) +#define SNOR_PROTO_DATA_SHIFT 0 +#define SNOR_PROTO_DATA(_nbits) \ + ((((unsigned long)(_nbits)) << SNOR_PROTO_DATA_SHIFT) & \ + SNOR_PROTO_DATA_MASK) + +#define SNOR_PROTO_IS_DTR BIT(24) /* Double Transfer Rate */ + +#define SNOR_PROTO_STR(_inst_nbits, _addr_nbits, _data_nbits) \ + (SNOR_PROTO_INST(_inst_nbits) | \ + SNOR_PROTO_ADDR(_addr_nbits) | \ + SNOR_PROTO_DATA(_data_nbits)) +#define SNOR_PROTO_DTR(_inst_nbits, _addr_nbits, _data_nbits) \ + (SNOR_PROTO_IS_DTR | \ + SNOR_PROTO_STR(_inst_nbits, _addr_nbits, _data_nbits)) + +enum spi_nor_protocol { + SNOR_PROTO_1_1_1 = SNOR_PROTO_STR(1, 1, 1), + SNOR_PROTO_1_1_2 = SNOR_PROTO_STR(1, 1, 2), + SNOR_PROTO_1_1_4 = SNOR_PROTO_STR(1, 1, 4), + SNOR_PROTO_1_1_8 = SNOR_PROTO_STR(1, 1, 8), + SNOR_PROTO_1_2_2 = SNOR_PROTO_STR(1, 2, 2), + SNOR_PROTO_1_4_4 = SNOR_PROTO_STR(1, 4, 4), + SNOR_PROTO_1_8_8 = SNOR_PROTO_STR(1, 8, 8), + SNOR_PROTO_2_2_2 = SNOR_PROTO_STR(2, 2, 2), + SNOR_PROTO_4_4_4 = SNOR_PROTO_STR(4, 4, 4), + SNOR_PROTO_8_8_8 = SNOR_PROTO_STR(8, 8, 8), + + SNOR_PROTO_1_1_1_DTR = SNOR_PROTO_DTR(1, 1, 1), + SNOR_PROTO_1_2_2_DTR = SNOR_PROTO_DTR(1, 2, 2), + SNOR_PROTO_1_4_4_DTR = SNOR_PROTO_DTR(1, 4, 4), + SNOR_PROTO_1_8_8_DTR = SNOR_PROTO_DTR(1, 8, 8), +}; + +static inline bool spi_nor_protocol_is_dtr(enum spi_nor_protocol proto) +{ + return !!(proto & SNOR_PROTO_IS_DTR); +} + +static inline u8 spi_nor_get_protocol_inst_nbits(enum spi_nor_protocol proto) +{ + return ((unsigned long)(proto & SNOR_PROTO_INST_MASK)) >> + SNOR_PROTO_INST_SHIFT; +} + +static inline u8 spi_nor_get_protocol_addr_nbits(enum spi_nor_protocol proto) +{ + return ((unsigned long)(proto & SNOR_PROTO_ADDR_MASK)) >> + SNOR_PROTO_ADDR_SHIFT; +} + +static inline u8 spi_nor_get_protocol_data_nbits(enum spi_nor_protocol proto) +{ + return ((unsigned long)(proto & SNOR_PROTO_DATA_MASK)) >> + SNOR_PROTO_DATA_SHIFT; +} + +static inline u8 spi_nor_get_protocol_width(enum spi_nor_protocol proto) +{ + return spi_nor_get_protocol_data_nbits(proto); +} + +#define SPI_NOR_MAX_CMD_SIZE 8 +enum spi_nor_ops { + SPI_NOR_OPS_READ = 0, + SPI_NOR_OPS_WRITE, + SPI_NOR_OPS_ERASE, + SPI_NOR_OPS_LOCK, + SPI_NOR_OPS_UNLOCK, +}; + +enum spi_nor_option_flags { + SNOR_F_USE_FSR = BIT(0), + SNOR_F_HAS_SR_TB = BIT(1), + SNOR_F_NO_OP_CHIP_ERASE = BIT(2), + SNOR_F_S3AN_ADDR_DEFAULT = BIT(3), + SNOR_F_READY_XSR_RDY = BIT(4), + SNOR_F_USE_CLSR = BIT(5), + SNOR_F_BROKEN_RESET = BIT(6), +}; + +/** + * struct flash_info - Forward declaration of a structure used internally by + * spi_nor_scan() + */ +struct flash_info; + +/* TODO: Remove, once all users of spi_flash interface are moved to MTD */ +#define spi_flash spi_nor + +/** + * struct spi_nor - Structure for defining a the SPI NOR layer + * @mtd: point to a mtd_info structure + * @lock: the lock for the read/write/erase/lock/unlock operations + * @dev: point to a spi device, or a spi nor controller device. + * @info: spi-nor part JDEC MFR id and other info + * @page_size: the page size of the SPI NOR + * @addr_width: number of address bytes + * @erase_opcode: the opcode for erasing a sector + * @read_opcode: the read opcode + * @read_dummy: the dummy needed by the read operation + * @program_opcode: the program opcode + * @sst_write_second: used by the SST write operation + * @flags: flag options for the current SPI-NOR (SNOR_F_*) + * @read_proto: the SPI protocol for read operations + * @write_proto: the SPI protocol for write operations + * @reg_proto the SPI protocol for read_reg/write_reg/erase operations + * @cmd_buf: used by the write_reg + * @prepare: [OPTIONAL] do some preparations for the + * read/write/erase/lock/unlock operations + * @unprepare: [OPTIONAL] do some post work after the + * read/write/erase/lock/unlock operations + * @read_reg: [DRIVER-SPECIFIC] read out the register + * @write_reg: [DRIVER-SPECIFIC] write data to the register + * @read: [DRIVER-SPECIFIC] read data from the SPI NOR + * @write: [DRIVER-SPECIFIC] write data to the SPI NOR + * @erase: [DRIVER-SPECIFIC] erase a sector of the SPI NOR + * at the offset @offs; if not provided by the driver, + * spi-nor will send the erase opcode via write_reg() + * @flash_lock: [FLASH-SPECIFIC] lock a region of the SPI NOR + * @flash_unlock: [FLASH-SPECIFIC] unlock a region of the SPI NOR + * @flash_is_locked: [FLASH-SPECIFIC] check if a region of the SPI NOR is + * @quad_enable: [FLASH-SPECIFIC] enables SPI NOR quad mode + * completely locked + * @priv: the private data + */ +struct spi_nor { + struct mtd_info mtd; +#ifndef __UBOOT__ + struct mutex lock; + struct device *dev; +#else + struct udevice *dev; + struct spi_slave *spi; +#endif + const struct flash_info *info; + u32 page_size; + u8 addr_width; + u8 erase_opcode; + u8 read_opcode; + u8 read_dummy; + u8 program_opcode; + enum spi_nor_protocol read_proto; + enum spi_nor_protocol write_proto; + enum spi_nor_protocol reg_proto; + bool sst_write_second; + u32 flags; + u8 cmd_buf[SPI_NOR_MAX_CMD_SIZE]; + + int (*prepare)(struct spi_nor *nor, enum spi_nor_ops ops); + void (*unprepare)(struct spi_nor *nor, enum spi_nor_ops ops); + int (*read_reg)(struct spi_nor *nor, u8 opcode, u8 *buf, int len); + int (*write_reg)(struct spi_nor *nor, u8 opcode, u8 *buf, int len); + + ssize_t (*read)(struct spi_nor *nor, loff_t from, + size_t len, u_char *read_buf); + ssize_t (*write)(struct spi_nor *nor, loff_t to, + size_t len, const u_char *write_buf); + int (*erase)(struct spi_nor *nor, loff_t offs); + + int (*flash_lock)(struct spi_nor *nor, loff_t ofs, uint64_t len); + int (*flash_unlock)(struct spi_nor *nor, loff_t ofs, uint64_t len); + int (*flash_is_locked)(struct spi_nor *nor, loff_t ofs, uint64_t len); + int (*quad_enable)(struct spi_nor *nor); + + void *priv; +/* Compatibility for spi_flash, remove once sf layer is merged with mtd */ + const char *name; + u32 size; + u32 sector_size; + u32 erase_size; +}; + +static inline void spi_nor_set_flash_node(struct spi_nor *nor, + const struct device_node *np) +{ + mtd_set_of_node(&nor->mtd, np); +} + +static inline const struct +device_node *spi_nor_get_flash_node(struct spi_nor *nor) +{ + return mtd_get_of_node(&nor->mtd); +} + +/** + * struct spi_nor_hwcaps - Structure for describing the hardware capabilies + * supported by the SPI controller (bus master). + * @mask: the bitmask listing all the supported hw capabilies + */ +struct spi_nor_hwcaps { + u32 mask; +}; + +/* + *(Fast) Read capabilities. + * MUST be ordered by priority: the higher bit position, the higher priority. + * As a matter of performances, it is relevant to use Octo SPI protocols first, + * then Quad SPI protocols before Dual SPI protocols, Fast Read and lastly + * (Slow) Read. + */ +#define SNOR_HWCAPS_READ_MASK GENMASK(14, 0) +#define SNOR_HWCAPS_READ BIT(0) +#define SNOR_HWCAPS_READ_FAST BIT(1) +#define SNOR_HWCAPS_READ_1_1_1_DTR BIT(2) + +#define SNOR_HWCAPS_READ_DUAL GENMASK(6, 3) +#define SNOR_HWCAPS_READ_1_1_2 BIT(3) +#define SNOR_HWCAPS_READ_1_2_2 BIT(4) +#define SNOR_HWCAPS_READ_2_2_2 BIT(5) +#define SNOR_HWCAPS_READ_1_2_2_DTR BIT(6) + +#define SNOR_HWCAPS_READ_QUAD GENMASK(10, 7) +#define SNOR_HWCAPS_READ_1_1_4 BIT(7) +#define SNOR_HWCAPS_READ_1_4_4 BIT(8) +#define SNOR_HWCAPS_READ_4_4_4 BIT(9) +#define SNOR_HWCAPS_READ_1_4_4_DTR BIT(10) + +#define SNOR_HWCPAS_READ_OCTO GENMASK(14, 11) +#define SNOR_HWCAPS_READ_1_1_8 BIT(11) +#define SNOR_HWCAPS_READ_1_8_8 BIT(12) +#define SNOR_HWCAPS_READ_8_8_8 BIT(13) +#define SNOR_HWCAPS_READ_1_8_8_DTR BIT(14) + +/* + * Page Program capabilities. + * MUST be ordered by priority: the higher bit position, the higher priority. + * Like (Fast) Read capabilities, Octo/Quad SPI protocols are preferred to the + * legacy SPI 1-1-1 protocol. + * Note that Dual Page Programs are not supported because there is no existing + * JEDEC/SFDP standard to define them. Also at this moment no SPI flash memory + * implements such commands. + */ +#define SNOR_HWCAPS_PP_MASK GENMASK(22, 16) +#define SNOR_HWCAPS_PP BIT(16) + +#define SNOR_HWCAPS_PP_QUAD GENMASK(19, 17) +#define SNOR_HWCAPS_PP_1_1_4 BIT(17) +#define SNOR_HWCAPS_PP_1_4_4 BIT(18) +#define SNOR_HWCAPS_PP_4_4_4 BIT(19) + +#define SNOR_HWCAPS_PP_OCTO GENMASK(22, 20) +#define SNOR_HWCAPS_PP_1_1_8 BIT(20) +#define SNOR_HWCAPS_PP_1_8_8 BIT(21) +#define SNOR_HWCAPS_PP_8_8_8 BIT(22) + +/** + * spi_nor_scan() - scan the SPI NOR + * @nor: the spi_nor structure + * + * The drivers can use this function to scan the SPI NOR. + * In the scanning, it will try to get all the necessary information to + * fill the mtd_info{} and the spi_nor{}. + * + * Return: 0 for success, others for failure. + */ +int spi_nor_scan(struct spi_nor *nor); + +/** + * spi_nor_restore_addr_mode() - restore the status of SPI NOR + * @nor: the spi_nor structure + */ +void spi_nor_restore(struct spi_nor *nor); + +#endif
Am 04.12.2018 um 13:26 schrieb Vignesh R:
Current U-Boot SPI NOR support (sf layer) is quite outdated as it does not support 4 byte addressing opcodes, SFDP table parsing and different types of quad mode enable sequences. Many newer flashes no longer support BANK registers used by sf layer to a access >16MB space. Also, many SPI controllers have special MMIO interfaces which provide accelerated read/write access but require knowledge of flash parameters to make use of it. Recent spi-mem layer provides a way to support such flashes but sf layer isn't using that. So sync SPI NOR framework from Linux v4.19 and add spi-mem support on top. in order to gain 4 byte addressing support, SFDP support and a way to support SPI controllers with MMIO flash interface.
Signed-off-by: Vignesh R vigneshr@ti.com
drivers/mtd/spi/spi-nor.c | 2613 +++++++++++++++++++++++++++++++++++ include/linux/mtd/cfi.h | 32 + include/linux/mtd/spi-nor.h | 421 ++++++ 3 files changed, 3066 insertions(+) create mode 100644 drivers/mtd/spi/spi-nor.c create mode 100644 include/linux/mtd/cfi.h create mode 100644 include/linux/mtd/spi-nor.h
diff --git a/drivers/mtd/spi/spi-nor.c b/drivers/mtd/spi/spi-nor.c new file mode 100644 index 000000000000..ff79601a8896 --- /dev/null +++ b/drivers/mtd/spi/spi-nor.c @@ -0,0 +1,2613 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
- Based on m25p80.c, by Mike Lavender (mike@steroidmicros.com), with
- influence from lart.c (Abraham Van Der Merwe) and mtd_dataflash.c
- Copyright (C) 2005, Intec Automation Inc.
- Copyright (C) 2014, Freescale Semiconductor, Inc.
- Synced from Linux v4.19
+#include <common.h> +#include <linux/err.h> +#include <linux/errno.h> +#include <linux/log2.h> +#include <linux/math64.h> +#include <linux/sizes.h>
+#include <linux/mtd/mtd.h> +#include <linux/mtd/spi-nor.h> +#include <spi-mem.h> +#include <spi.h>
+/* Define max times to check status register before we give up. */
- For everything but full-chip erase; probably could be much smaller, but kept
- around for safety for now
+#define HZ CONFIG_SYS_HZ
+#define DEFAULT_READY_WAIT_JIFFIES (40UL * HZ)
+#define SPI_NOR_MAX_ID_LEN 6 +#define SPI_NOR_MAX_ADDR_WIDTH 4
+struct flash_info {
- char *name;
* This array stores the ID bytes.
* The first three bytes are the JEDIC ID.
* JEDEC ID zero means "no ID" (mostly older chips).
- u8 id[SPI_NOR_MAX_ID_LEN];
- u8 id_len;
- /* The size listed here is what works with SPINOR_OP_SE, which isn't
* necessarily called a "sector" by the vendor.
- unsigned int sector_size;
- u16 n_sectors;
- u16 page_size;
- u16 addr_width;
- u16 flags;
+#define SECT_4K BIT(0) /* SPINOR_OP_BE_4K works uniformly */ +#define SPI_NOR_NO_ERASE BIT(1) /* No erase command needed */ +#define SST_WRITE BIT(2) /* use SST byte programming */ +#define SPI_NOR_NO_FR BIT(3) /* Can't do fastread */ +#define SECT_4K_PMC BIT(4) /* SPINOR_OP_BE_4K_PMC works uniformly */ +#define SPI_NOR_DUAL_READ BIT(5) /* Flash supports Dual Read */ +#define SPI_NOR_QUAD_READ BIT(6) /* Flash supports Quad Read */ +#define USE_FSR BIT(7) /* use flag status register */ +#define SPI_NOR_HAS_LOCK BIT(8) /* Flash supports lock/unlock via SR */ +#define SPI_NOR_HAS_TB BIT(9) /*
* Flash SR has Top/Bottom (TB) protect
* bit. Must be used with
* SPI_NOR_HAS_LOCK.
+#define SPI_S3AN BIT(10) /*
* Xilinx Spartan 3AN In-System Flash
* (MFR cannot be used for probing
* because it has the same value as
* ATMEL flashes)
+#define SPI_NOR_4B_OPCODES BIT(11) /*
* Use dedicated 4byte address op codes
* to support memory size above 128Mib.
+#define NO_CHIP_ERASE BIT(12) /* Chip does not support chip erase */ +#define SPI_NOR_SKIP_SFDP BIT(13) /* Skip parsing of SFDP tables */ +#define USE_CLSR BIT(14) /* use CLSR command */
- int (*quad_enable)(struct spi_nor *nor);
+#define JEDEC_MFR(info) ((info)->id[0])
+static int spi_nor_read_write_reg(struct spi_nor *nor, struct spi_mem_op
*op, void *buf)
- if (op->data.dir == SPI_MEM_DATA_IN)
op->data.buf.in = buf;
- else
op->data.buf.out = buf;
- return spi_mem_exec_op(nor->spi, op);
+static int spi_nor_read_reg(struct spi_nor *nor, u8 code, u8 *val, int len) +{
- struct spi_mem_op op = SPI_MEM_OP(SPI_MEM_OP_CMD(code, 1),
SPI_MEM_OP_NO_ADDR,
SPI_MEM_OP_NO_DUMMY,
SPI_MEM_OP_DATA_IN(len, NULL, 1));
- int ret;
- ret = spi_nor_read_write_reg(nor, &op, val);
- if (ret < 0)
dev_dbg(&flash->spimem->spi->dev, "error %d reading %x\n", ret,
code);
- return ret;
+static int spi_nor_write_reg(struct spi_nor *nor, u8 opcode, u8 *buf, int len) +{
- struct spi_mem_op op = SPI_MEM_OP(SPI_MEM_OP_CMD(opcode, 1),
SPI_MEM_OP_NO_ADDR,
SPI_MEM_OP_DATA_OUT(len, NULL, 1));
- return spi_nor_read_write_reg(nor, &op, buf);
+static ssize_t spi_nor_read_data(struct spi_nor *nor, loff_t from, size_t len,
u_char *buf)
SPI_MEM_OP(SPI_MEM_OP_CMD(nor->read_opcode, 1),
SPI_MEM_OP_ADDR(nor->addr_width, from, 1),
SPI_MEM_OP_DUMMY(nor->read_dummy, 1),
SPI_MEM_OP_DATA_IN(len, buf, 1));
- size_t remaining = len;
- int ret;
- /* get transfer protocols. */
- op.cmd.buswidth = spi_nor_get_protocol_inst_nbits(nor->read_proto);
- op.addr.buswidth = spi_nor_get_protocol_addr_nbits(nor->read_proto);
- op.dummy.buswidth = op.addr.buswidth;
- op.data.buswidth = spi_nor_get_protocol_data_nbits(nor->read_proto);
- /* convert the dummy cycles to the number of bytes */
- op.dummy.nbytes = (nor->read_dummy * op.dummy.buswidth) / 8;
- while (remaining) {
op.data.nbytes = remaining < UINT_MAX ? remaining : UINT_MAX;
ret = spi_mem_adjust_op_size(nor->spi, &op);
if (ret)
return ret;
ret = spi_mem_exec_op(nor->spi, &op);
if (ret)
return ret;
op.addr.val += op.data.nbytes;
remaining -= op.data.nbytes;
op.data.buf.in += op.data.nbytes;
- return len;
+static ssize_t spi_nor_write_data(struct spi_nor *nor, loff_t to, size_t len,
const u_char *buf)
SPI_MEM_OP(SPI_MEM_OP_CMD(nor->program_opcode, 1),
SPI_MEM_OP_ADDR(nor->addr_width, to, 1),
SPI_MEM_OP_DATA_OUT(len, buf, 1));
- int ret;
- op.cmd.buswidth = spi_nor_get_protocol_inst_nbits(nor->write_proto);
- op.addr.buswidth = spi_nor_get_protocol_addr_nbits(nor->write_proto);
- op.data.buswidth = spi_nor_get_protocol_data_nbits(nor->write_proto);
- if (nor->program_opcode == SPINOR_OP_AAI_WP && nor->sst_write_second)
op.addr.nbytes = 0;
if (ret)
return ret;
if (ret)
return ret;
op.data.buf.out += op.data.nbytes;
- return len;
- Read the status register, returning its value in the location
- Return the status register value.
- Returns negative if error occurred.
+static int read_sr(struct spi_nor *nor) +{
- int ret;
- u8 val;
- ret = nor->read_reg(nor, SPINOR_OP_RDSR, &val, 1);
- if (ret < 0) {
pr_debug("error %d reading SR\n", (int)ret);
return ret;
- return val;
- Read the flag status register, returning its value in the location
+static int read_fsr(struct spi_nor *nor) +{
- int ret;
- u8 val;
- ret = nor->read_reg(nor, SPINOR_OP_RDFSR, &val, 1);
- if (ret < 0) {
pr_debug("error %d reading FSR\n", ret);
return ret;
- return val;
- Read configuration register, returning its value in the
- location. Return the configuration register value.
+#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) +static int read_cr(struct spi_nor *nor) +{
- int ret;
- u8 val;
- ret = nor->read_reg(nor, SPINOR_OP_RDCR, &val, 1);
- if (ret < 0) {
dev_dbg(nor->dev, "error %d reading CR\n", ret);
return ret;
- return val;
+} +#endif
- Write status register 1 byte
+static inline int write_sr(struct spi_nor *nor, u8 val) +{
- nor->cmd_buf[0] = val;
- return nor->write_reg(nor, SPINOR_OP_WRSR, nor->cmd_buf, 1);
- Set write enable latch with Write Enable command.
+static inline int write_enable(struct spi_nor *nor) +{
- return nor->write_reg(nor, SPINOR_OP_WREN, NULL, 0);
- Send write disable instruction to the chip.
+static inline int write_disable(struct spi_nor *nor) +{
- return nor->write_reg(nor, SPINOR_OP_WRDI, NULL, 0);
+static inline struct spi_nor *mtd_to_spi_nor(struct mtd_info *mtd) +{
- return mtd->priv;
+static u8 spi_nor_convert_opcode(u8 opcode, const u8 table[][2], size_t size) +{
- size_t i;
- for (i = 0; i < size; i++)
if (table[i][0] == opcode)
return table[i][1];
- /* No conversion found, keep input op code. */
- return opcode;
+static inline u8 spi_nor_convert_3to4_read(u8 opcode) +{
- static const u8 spi_nor_3to4_read[][2] = {
{ SPINOR_OP_READ, SPINOR_OP_READ_4B },
{ SPINOR_OP_READ_FAST, SPINOR_OP_READ_FAST_4B },
{ SPINOR_OP_READ_1_1_2, SPINOR_OP_READ_1_1_2_4B },
{ SPINOR_OP_READ_1_2_2, SPINOR_OP_READ_1_2_2_4B },
{ SPINOR_OP_READ_1_1_4, SPINOR_OP_READ_1_1_4_4B },
{ SPINOR_OP_READ_1_4_4, SPINOR_OP_READ_1_4_4_4B },
- return spi_nor_convert_opcode(opcode, spi_nor_3to4_read,
ARRAY_SIZE(spi_nor_3to4_read));
+static inline u8 spi_nor_convert_3to4_program(u8 opcode) +{
- static const u8 spi_nor_3to4_program[][2] = {
{ SPINOR_OP_PP, SPINOR_OP_PP_4B },
{ SPINOR_OP_PP_1_1_4, SPINOR_OP_PP_1_1_4_4B },
{ SPINOR_OP_PP_1_4_4, SPINOR_OP_PP_1_4_4_4B },
- return spi_nor_convert_opcode(opcode, spi_nor_3to4_program,
ARRAY_SIZE(spi_nor_3to4_program));
+static inline u8 spi_nor_convert_3to4_erase(u8 opcode) +{
- static const u8 spi_nor_3to4_erase[][2] = {
{ SPINOR_OP_BE_4K, SPINOR_OP_BE_4K_4B },
{ SPINOR_OP_BE_32K, SPINOR_OP_BE_32K_4B },
{ SPINOR_OP_SE, SPINOR_OP_SE_4B },
- return spi_nor_convert_opcode(opcode, spi_nor_3to4_erase,
ARRAY_SIZE(spi_nor_3to4_erase));
+static void spi_nor_set_4byte_opcodes(struct spi_nor *nor,
- /* Do some manufacturer fixups first */
- switch (JEDEC_MFR(info)) {
- case SNOR_MFR_SPANSION:
/* No small sector erase for 4-byte command set */
nor->mtd.erasesize = info->sector_size;
break;
- default:
break;
- nor->read_opcode = spi_nor_convert_3to4_read(nor->read_opcode);
- nor->program_opcode = spi_nor_convert_3to4_program(nor->program_opcode);
- nor->erase_opcode = spi_nor_convert_3to4_erase(nor->erase_opcode);
+/* Enable/disable 4-byte addressing mode. */ +static inline int set_4byte(struct spi_nor *nor, const struct flash_info *info,
int enable)
- int status;
- bool need_wren = false;
- u8 cmd;
- case SNOR_MFR_MICRON:
/* Some Micron need WREN command; all will accept it */
need_wren = true;
- case SNOR_MFR_MACRONIX:
- case SNOR_MFR_WINBOND:
if (need_wren)
write_enable(nor);
cmd = enable ? SPINOR_OP_EN4B : SPINOR_OP_EX4B;
status = nor->write_reg(nor, cmd, NULL, 0);
if (need_wren)
write_disable(nor);
if (!status && !enable &&
JEDEC_MFR(info) == SNOR_MFR_WINBOND) {
* On Winbond W25Q256FV, leaving 4byte mode causes
* the Extended Address Register to be set to 1, so all
* 3-byte-address reads come from the second 16M.
* We must clear the register to enable normal behavior.
write_enable(nor);
nor->cmd_buf[0] = 0;
nor->write_reg(nor, SPINOR_OP_WREAR, nor->cmd_buf, 1);
write_disable(nor);
return status;
- default:
/* Spansion style */
nor->cmd_buf[0] = enable << 7;
return nor->write_reg(nor, SPINOR_OP_BRWR, nor->cmd_buf, 1);
+static int spi_nor_sr_ready(struct spi_nor *nor) +{
- int sr = read_sr(nor);
- if (sr < 0)
return sr;
- if (nor->flags & SNOR_F_USE_CLSR && sr & (SR_E_ERR | SR_P_ERR)) {
if (sr & SR_E_ERR)
dev_dbg(nor->dev, "Erase Error occurred\n");
else
dev_dbg(nor->dev, "Programming Error occurred\n");
nor->write_reg(nor, SPINOR_OP_CLSR, NULL, 0);
return -EIO;
- return !(sr & SR_WIP);
+static int spi_nor_fsr_ready(struct spi_nor *nor) +{
- int fsr = read_fsr(nor);
- if (fsr < 0)
return fsr;
- if (fsr & (FSR_E_ERR | FSR_P_ERR)) {
if (fsr & FSR_E_ERR)
dev_dbg(nor->dev, "Erase operation failed.\n");
else
dev_dbg(nor->dev, "Program operation failed.\n");
if (fsr & FSR_PT_ERR)
dev_dbg(nor->dev,
"Attempted to modify a protected sector.\n");
nor->write_reg(nor, SPINOR_OP_CLFSR, NULL, 0);
return -EIO;
- return fsr & FSR_READY;
+static int spi_nor_ready(struct spi_nor *nor) +{
- int sr, fsr;
- sr = spi_nor_sr_ready(nor);
- if (sr < 0)
return sr;
- fsr = nor->flags & SNOR_F_USE_FSR ? spi_nor_fsr_ready(nor) : 1;
- if (fsr < 0)
return fsr;
- return sr && fsr;
- Service routine to read status register until ready, or timeout occurs.
- Returns non-zero if error.
+static int spi_nor_wait_till_ready_with_timeout(struct spi_nor *nor,
unsigned long timeout)
- unsigned long timebase;
- int ret;
- timebase = get_timer(0);
- while (get_timer(timebase) < timeout) {
ret = spi_nor_ready(nor);
if (ret < 0)
return ret;
if (ret)
- dev_err(nor->dev, "flash operation timed out\n");
- return -ETIMEDOUT;
+static int spi_nor_wait_till_ready(struct spi_nor *nor) +{
- return spi_nor_wait_till_ready_with_timeout(nor,
DEFAULT_READY_WAIT_JIFFIES);
- Initiate the erasure of a single sector
+static int spi_nor_erase_sector(struct spi_nor *nor, u32 addr) +{
- u8 buf[SPI_NOR_MAX_ADDR_WIDTH];
- int i;
- if (nor->erase)
return nor->erase(nor, addr);
* Default implementation, if driver doesn't have a specialized HW
* control
- for (i = nor->addr_width - 1; i >= 0; i--) {
buf[i] = addr & 0xff;
addr >>= 8;
- return nor->write_reg(nor, nor->erase_opcode, buf, nor->addr_width);
- Erase an address range on the nor chip. The address range may extend
- one or more erase sectors. Return an error is there is a problem erasing.
+static int spi_nor_erase(struct mtd_info *mtd, struct erase_info *instr) +{
- struct spi_nor *nor = mtd_to_spi_nor(mtd);
- u32 addr, len, rem;
- int ret;
- dev_dbg(nor->dev, "at 0x%llx, len %lld\n", (long long)instr->addr,
(long long)instr->len);
- div_u64_rem(instr->len, mtd->erasesize, &rem);
- if (rem)
return -EINVAL;
- addr = instr->addr;
- len = instr->len;
- while (len) {
write_enable(nor);
ret = spi_nor_erase_sector(nor, addr);
if (ret)
goto erase_err;
addr += mtd->erasesize;
len -= mtd->erasesize;
ret = spi_nor_wait_till_ready(nor);
if (ret)
goto erase_err;
- write_disable(nor);
+erase_err:
- return ret;
+#if defined(CONFIG_SPI_FLASH_STMICRO) || defined(CONFIG_SPI_FLASH_SST) +/* Write status register and ensure bits in mask match written values */ +static int write_sr_and_check(struct spi_nor *nor, u8 status_new, u8 mask) +{
- int ret;
- write_enable(nor);
- ret = write_sr(nor, status_new);
- if (ret)
return ret;
- ret = spi_nor_wait_till_ready(nor);
- if (ret)
return ret;
- ret = read_sr(nor);
- if (ret < 0)
return ret;
- return ((ret & mask) != (status_new & mask)) ? -EIO : 0;
+static void stm_get_locked_range(struct spi_nor *nor, u8 sr, loff_t *ofs,
uint64_t *len)
- struct mtd_info *mtd = &nor->mtd;
- u8 mask = SR_BP2 | SR_BP1 | SR_BP0;
- int shift = ffs(mask) - 1;
- int pow;
- if (!(sr & mask)) {
/* No protection */
*ofs = 0;
*len = 0;
- } else {
pow = ((sr & mask) ^ mask) >> shift;
*len = mtd->size >> pow;
if (nor->flags & SNOR_F_HAS_SR_TB && sr & SR_TB)
*ofs = 0;
else
*ofs = mtd->size - *len;
- Return 1 if the entire region is locked (if @locked is true) or unlocked (if
- @locked is false); 0 otherwise
+static int stm_check_lock_status_sr(struct spi_nor *nor, loff_t ofs, u64 len,
u8 sr, bool locked)
- loff_t lock_offs;
- uint64_t lock_len;
- if (!len)
return 1;
- stm_get_locked_range(nor, sr, &lock_offs, &lock_len);
- if (locked)
/* Requested range is a sub-range of locked range */
return (ofs + len <= lock_offs + lock_len) && (ofs >= lock_offs);
- else
/* Requested range does not overlap with locked range */
return (ofs >= lock_offs + lock_len) || (ofs + len <= lock_offs);
+static int stm_is_locked_sr(struct spi_nor *nor, loff_t ofs, uint64_t len,
u8 sr)
- return stm_check_lock_status_sr(nor, ofs, len, sr, true);
+static int stm_is_unlocked_sr(struct spi_nor *nor, loff_t ofs, uint64_t len,
u8 sr)
- return stm_check_lock_status_sr(nor, ofs, len, sr, false);
- Lock a region of the flash. Compatible with ST Micro and similar flash.
- Supports the block protection bits BP{0,1,2} in the status register
- (SR). Does not support these features found in newer SR bitfields:
- SEC: sector/block protect - only handle SEC=0 (block protect)
- CMP: complement protect - only support CMP=0 (range is not complemented)
- Support for the following is provided conditionally for some flash:
- TB: top/bottom protect
- Sample table portion for 8MB flash (Winbond w25q64fw):
- SEC | TB | BP2 | BP1 | BP0 | Prot Length | Protected Portion
- X | X | 0 | 0 | 0 | NONE | NONE
- 0 | 0 | 0 | 0 | 1 | 128 KB | Upper 1/64
- 0 | 0 | 0 | 1 | 0 | 256 KB | Upper 1/32
- 0 | 0 | 0 | 1 | 1 | 512 KB | Upper 1/16
- 0 | 0 | 1 | 0 | 0 | 1 MB | Upper 1/8
- 0 | 0 | 1 | 0 | 1 | 2 MB | Upper 1/4
- 0 | 0 | 1 | 1 | 0 | 4 MB | Upper 1/2
- X | X | 1 | 1 | 1 | 8 MB | ALL
- 0 | 1 | 0 | 0 | 1 | 128 KB | Lower 1/64
- 0 | 1 | 0 | 1 | 0 | 256 KB | Lower 1/32
- 0 | 1 | 0 | 1 | 1 | 512 KB | Lower 1/16
- 0 | 1 | 1 | 0 | 0 | 1 MB | Lower 1/8
- 0 | 1 | 1 | 0 | 1 | 2 MB | Lower 1/4
- 0 | 1 | 1 | 1 | 0 | 4 MB | Lower 1/2
- Returns negative on errors, 0 on success.
+static int stm_lock(struct spi_nor *nor, loff_t ofs, uint64_t len) +{
- int status_old, status_new;
- u8 shift = ffs(mask) - 1, pow, val;
- loff_t lock_len;
- bool can_be_top = true, can_be_bottom = nor->flags & SNOR_F_HAS_SR_TB;
- bool use_top;
- status_old = read_sr(nor);
- if (status_old < 0)
return status_old;
- /* If nothing in our range is unlocked, we don't need to do anything */
- if (stm_is_locked_sr(nor, ofs, len, status_old))
- /* If anything below us is unlocked, we can't use 'bottom' protection */
- if (!stm_is_locked_sr(nor, 0, ofs, status_old))
can_be_bottom = false;
- /* If anything above us is unlocked, we can't use 'top' protection */
- if (!stm_is_locked_sr(nor, ofs + len, mtd->size - (ofs + len),
status_old))
can_be_top = false;
- if (!can_be_bottom && !can_be_top)
return -EINVAL;
- /* Prefer top, if both are valid */
- use_top = can_be_top;
- /* lock_len: length of region that should end up locked */
- if (use_top)
lock_len = mtd->size - ofs;
- else
lock_len = ofs + len;
* Need smallest pow such that:
* 1 / (2^pow) <= (len / size)
* so (assuming power-of-2 size) we do:
* pow = ceil(log2(size / len)) = log2(size) - floor(log2(len))
- pow = ilog2(mtd->size) - ilog2(lock_len);
- val = mask - (pow << shift);
- if (val & ~mask)
return -EINVAL;
- /* Don't "lock" with no region! */
- if (!(val & mask))
return -EINVAL;
- status_new = (status_old & ~mask & ~SR_TB) | val;
- /* Disallow further writes if WP pin is asserted */
- status_new |= SR_SRWD;
- if (!use_top)
status_new |= SR_TB;
- /* Don't bother if they're the same */
- if (status_new == status_old)
- /* Only modify protection if it will not unlock other areas */
- if ((status_new & mask) < (status_old & mask))
return -EINVAL;
- return write_sr_and_check(nor, status_new, mask);
- Unlock a region of the flash. See stm_lock() for more info
+static int stm_unlock(struct spi_nor *nor, loff_t ofs, uint64_t len) +{
- loff_t lock_len;
- bool use_top;
return status_old;
- /* If nothing in our range is locked, we don't need to do anything */
- if (stm_is_unlocked_sr(nor, ofs, len, status_old))
- /* If anything below us is locked, we can't use 'top' protection */
- if (!stm_is_unlocked_sr(nor, 0, ofs, status_old))
can_be_top = false;
- /* If anything above us is locked, we can't use 'bottom' protection */
- if (!stm_is_unlocked_sr(nor, ofs + len, mtd->size - (ofs + len),
status_old))
return -EINVAL;
- /* lock_len: length of region that should remain locked */
- if (use_top)
lock_len = mtd->size - (ofs + len);
- else
lock_len = ofs;
* Need largest pow such that:
* 1 / (2^pow) >= (len / size)
* pow = floor(log2(size / len)) = log2(size) - ceil(log2(len))
- pow = ilog2(mtd->size) - order_base_2(lock_len);
- if (lock_len == 0) {
val = 0; /* fully unlocked */
- } else {
/* Some power-of-two sizes are not supported */
if (val & ~mask)
return -EINVAL;
- /* Don't protect status register if we're fully unlocked */
status_new &= ~SR_SRWD;
- if (!use_top)
- /* Only modify protection if it will not lock other areas */
- if ((status_new & mask) > (status_old & mask))
return -EINVAL;
- Check if a region of the flash is (completely) locked. See stm_lock() for
- more info.
- Returns 1 if entire region is locked, 0 if any portion is unlocked, and
- negative on errors.
+static int stm_is_locked(struct spi_nor *nor, loff_t ofs, uint64_t len) +{
- int status;
- status = read_sr(nor);
- if (status < 0)
return status;
- return stm_is_locked_sr(nor, ofs, len, status);
+} +#endif /* CONFIG_SPI_FLASH_STMICRO */
+static int spi_nor_lock(struct mtd_info *mtd, loff_t ofs, uint64_t len) +{
- int ret;
- ret = nor->flash_lock(nor, ofs, len);
- return ret;
+static int spi_nor_unlock(struct mtd_info *mtd, loff_t ofs, uint64_t len) +{
- int ret;
- ret = nor->flash_unlock(nor, ofs, len);
- return ret;
+static int spi_nor_is_locked(struct mtd_info *mtd, loff_t ofs, uint64_t len) +{
- int ret;
- ret = nor->flash_is_locked(nor, ofs, len);
- return ret;
+/* Used when the "_ext_id" is two bytes at most */ +#define INFO(_jedec_id, _ext_id, _sector_size, _n_sectors, _flags) \
.id = { \
((_jedec_id) >> 16) & 0xff, \
((_jedec_id) >> 8) & 0xff, \
(_jedec_id) & 0xff, \
((_ext_id) >> 8) & 0xff, \
(_ext_id) & 0xff, \
.id_len = (!(_jedec_id) ? 0 : (3 + ((_ext_id) ? 2 : 0))), \
.sector_size = (_sector_size), \
.n_sectors = (_n_sectors), \
.page_size = 256, \
.flags = (_flags),
+#define INFO6(_jedec_id, _ext_id, _sector_size, _n_sectors, _flags) \
.id = { \
((_ext_id) >> 16) & 0xff, \
(_ext_id) & 0xff, \
.id_len = 6, \
.page_size = 256, \
.flags = (_flags),
+/* NOTE: double check command sets and memory organization when you add
- more nor chips. This current list focusses on newer chips, which
- have been converging on command sets which including JEDEC ID.
- All newly added entries should describe *hardware* and should use SECT_4K
- (or SECT_4K_PMC) if hardware supports erasing 4 KiB sectors. For usage
- scenarios excluding small sectors there is config option that can be
- disabled: CONFIG_MTD_SPI_NOR_USE_4K_SECTORS.
- For historical (and compatibility) reasons (before we got above config) some
- old entries may be missing 4K flag.
+const struct flash_info spi_nor_ids[] = { +#ifdef CONFIG_SPI_FLASH_ATMEL /* ATMEL */
- /* Atmel -- some are (confusingly) marketed as "DataFlash" */
- { "at26df321", INFO(0x1f4700, 0, 64 * 1024, 64, SECT_4K) },
- { "at25df321a", INFO(0x1f4701, 0, 64 * 1024, 64, SECT_4K) },
- { "at45db011d", INFO(0x1f2200, 0, 64 * 1024, 4, SECT_4K) },
- { "at45db021d", INFO(0x1f2300, 0, 64 * 1024, 8, SECT_4K) },
- { "at45db041d", INFO(0x1f2400, 0, 64 * 1024, 8, SECT_4K) },
- { "at45db081d", INFO(0x1f2500, 0, 64 * 1024, 16, SECT_4K) },
- { "at45db161d", INFO(0x1f2600, 0, 64 * 1024, 32, SECT_4K) },
- { "at45db321d", INFO(0x1f2700, 0, 64 * 1024, 64, SECT_4K) },
- { "at45db641d", INFO(0x1f2800, 0, 64 * 1024, 128, SECT_4K) },
- { "at26df081a", INFO(0x1f4501, 0, 64 * 1024, 16, SECT_4K) },
+#endif +#ifdef CONFIG_SPI_FLASH_EON /* EON */
- /* EON -- en25xxx */
- { "en25q32b", INFO(0x1c3016, 0, 64 * 1024, 64, 0) },
- { "en25q64", INFO(0x1c3017, 0, 64 * 1024, 128, SECT_4K) },
- { "en25qh128", INFO(0x1c7018, 0, 64 * 1024, 256, 0) },
- { "en25s64", INFO(0x1c3817, 0, 64 * 1024, 128, SECT_4K) },
+#endif +#ifdef CONFIG_SPI_FLASH_GIGADEVICE /* GIGADEVICE */
- /* GigaDevice */
"gd25q16", INFO(0xc84015, 0, 64 * 1024, 32,
SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ |
SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB)
"gd25q32", INFO(0xc84016, 0, 64 * 1024, 64,
"gd25lq32", INFO(0xc86016, 0, 64 * 1024, 64,
"gd25q64", INFO(0xc84017, 0, 64 * 1024, 128,
+#endif +#ifdef CONFIG_SPI_FLASH_ISSI /* ISSI */
- /* ISSI */
- { "is25lq040b", INFO(0x9d4013, 0, 64 * 1024, 8,
SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
- { "is25lp032", INFO(0x9d6016, 0, 64 * 1024, 64, 0) },
- { "is25lp064", INFO(0x9d6017, 0, 64 * 1024, 128, 0) },
- { "is25lp128", INFO(0x9d6018, 0, 64 * 1024, 256,
SECT_4K | SPI_NOR_DUAL_READ) },
- { "is25lp256", INFO(0x9d6019, 0, 64 * 1024, 512,
- { "is25wp032", INFO(0x9d7016, 0, 64 * 1024, 64,
- { "is25wp064", INFO(0x9d7017, 0, 64 * 1024, 128,
- { "is25wp128", INFO(0x9d7018, 0, 64 * 1024, 256,
+#endif +#ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */
- /* Macronix */
- { "mx25l2005a", INFO(0xc22012, 0, 64 * 1024, 4, SECT_4K) },
- { "mx25l4005a", INFO(0xc22013, 0, 64 * 1024, 8, SECT_4K) },
- { "mx25l8005", INFO(0xc22014, 0, 64 * 1024, 16, 0) },
- { "mx25l1606e", INFO(0xc22015, 0, 64 * 1024, 32, SECT_4K) },
- { "mx25l3205d", INFO(0xc22016, 0, 64 * 1024, 64, SECT_4K) },
- { "mx25l6405d", INFO(0xc22017, 0, 64 * 1024, 128, SECT_4K) },
- { "mx25u2033e", INFO(0xc22532, 0, 64 * 1024, 4, SECT_4K) },
- { "mx25u1635e", INFO(0xc22535, 0, 64 * 1024, 32, SECT_4K) },
- { "mx25u6435f", INFO(0xc22537, 0, 64 * 1024, 128, SECT_4K) },
- { "mx25l12805d", INFO(0xc22018, 0, 64 * 1024, 256, 0) },
- { "mx25l12855e", INFO(0xc22618, 0, 64 * 1024, 256, 0) },
- { "mx25l25635e", INFO(0xc22019, 0, 64 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
- { "mx25u25635f", INFO(0xc22539, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_4B_OPCODES) },
- { "mx25l25655e", INFO(0xc22619, 0, 64 * 1024, 512, 0) },
- { "mx66l51235l", INFO(0xc2201a, 0, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) },
- { "mx66u51235f", INFO(0xc2253a, 0, 64 * 1024, 1024, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) },
- { "mx66l1g45g", INFO(0xc2201b, 0, 64 * 1024, 2048, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
- { "mx25l1633e", INFO(0xc22415, 0, 64 * 1024, 32, SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | SECT_4K) },
+#ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */
- /* Micron */
- { "n25q016a", INFO(0x20bb15, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_QUAD_READ) },
- { "n25q032", INFO(0x20ba16, 0, 64 * 1024, 64, SPI_NOR_QUAD_READ) },
- { "n25q032a", INFO(0x20bb16, 0, 64 * 1024, 64, SPI_NOR_QUAD_READ) },
- { "n25q064", INFO(0x20ba17, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_QUAD_READ) },
- { "n25q064a", INFO(0x20bb17, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_QUAD_READ) },
- { "n25q128a11", INFO(0x20bb18, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_QUAD_READ) },
- { "n25q128a13", INFO(0x20ba18, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_QUAD_READ) },
- { "n25q256a", INFO(0x20ba19, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
- { "n25q256ax1", INFO(0x20bb19, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_QUAD_READ) },
- { "n25q512a", INFO(0x20bb20, 0, 64 * 1024, 1024, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ) },
- { "n25q512ax3", INFO(0x20ba20, 0, 64 * 1024, 1024, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ) },
- { "n25q00", INFO(0x20ba21, 0, 64 * 1024, 2048, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE) },
- { "n25q00a", INFO(0x20bb21, 0, 64 * 1024, 2048, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE) },
- { "mt25qu02g", INFO(0x20bb22, 0, 64 * 1024, 4096, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE) },
+#endif +#ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */
- /* Spansion/Cypress -- single (large) sector size only, at least
* for the chips listed here (without boot sectors).
- { "s25sl032p", INFO(0x010215, 0x4d00, 64 * 1024, 64, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
- { "s25sl064p", INFO(0x010216, 0x4d00, 64 * 1024, 128, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
- { "s25fl256s0", INFO(0x010219, 0x4d00, 256 * 1024, 128, USE_CLSR) },
- { "s25fl256s1", INFO(0x010219, 0x4d01, 64 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) },
- { "s25fl512s", INFO6(0x010220, 0x4d0081, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) },
- { "s25fl512s_256k", INFO(0x010220, 0x4d00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) },
- { "s25fl512s_64k", INFO(0x010220, 0x4d01, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) },
- { "s25fl512s_512k", INFO(0x010220, 0x4f00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) },
- { "s25sl12800", INFO(0x012018, 0x0300, 256 * 1024, 64, 0) },
- { "s25sl12801", INFO(0x012018, 0x0301, 64 * 1024, 256, 0) },
- { "s25fl128s", INFO6(0x012018, 0x4d0180, 64 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) },
- { "s25fl129p0", INFO(0x012018, 0x4d00, 256 * 1024, 64, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) },
- { "s25fl129p1", INFO(0x012018, 0x4d01, 64 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) },
- { "s25sl008a", INFO(0x010213, 0, 64 * 1024, 16, 0) },
- { "s25sl016a", INFO(0x010214, 0, 64 * 1024, 32, 0) },
- { "s25sl032a", INFO(0x010215, 0, 64 * 1024, 64, 0) },
- { "s25sl064a", INFO(0x010216, 0, 64 * 1024, 128, 0) },
- { "s25fl116k", INFO(0x014015, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
- { "s25fl164k", INFO(0x014017, 0, 64 * 1024, 128, SECT_4K) },
- { "s25fl208k", INFO(0x014014, 0, 64 * 1024, 16, SECT_4K | SPI_NOR_DUAL_READ) },
- { "s25fl128l", INFO(0x016018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) },
+#endif +#ifdef CONFIG_SPI_FLASH_SST /* SST */
- /* SST -- large erase sizes are "overlays", "sectors" are 4K */
- { "sst25vf040b", INFO(0xbf258d, 0, 64 * 1024, 8, SECT_4K | SST_WRITE) },
- { "sst25vf080b", INFO(0xbf258e, 0, 64 * 1024, 16, SECT_4K | SST_WRITE) },
- { "sst25vf016b", INFO(0xbf2541, 0, 64 * 1024, 32, SECT_4K | SST_WRITE) },
- { "sst25vf032b", INFO(0xbf254a, 0, 64 * 1024, 64, SECT_4K | SST_WRITE) },
- { "sst25vf064c", INFO(0xbf254b, 0, 64 * 1024, 128, SECT_4K) },
- { "sst25wf512", INFO(0xbf2501, 0, 64 * 1024, 1, SECT_4K | SST_WRITE) },
- { "sst25wf010", INFO(0xbf2502, 0, 64 * 1024, 2, SECT_4K | SST_WRITE) },
- { "sst25wf020", INFO(0xbf2503, 0, 64 * 1024, 4, SECT_4K | SST_WRITE) },
- { "sst25wf020a", INFO(0x621612, 0, 64 * 1024, 4, SECT_4K) },
- { "sst25wf040b", INFO(0x621613, 0, 64 * 1024, 8, SECT_4K) },
- { "sst25wf040", INFO(0xbf2504, 0, 64 * 1024, 8, SECT_4K | SST_WRITE) },
- { "sst25wf080", INFO(0xbf2505, 0, 64 * 1024, 16, SECT_4K | SST_WRITE) },
- { "sst26vf064b", INFO(0xbf2643, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
- { "sst26wf016", INFO(0xbf2651, 0, 64 * 1024, 32, SECT_4K) },
- { "sst26wf032", INFO(0xbf2622, 0, 64 * 1024, 64, SECT_4K) },
- { "sst26wf064", INFO(0xbf2643, 0, 64 * 1024, 128, SECT_4K) },
+#endif +#ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */
- /* ST Microelectronics -- newer production may have feature updates */
- { "m25p10", INFO(0x202011, 0, 32 * 1024, 4, 0) },
- { "m25p20", INFO(0x202012, 0, 64 * 1024, 4, 0) },
- { "m25p40", INFO(0x202013, 0, 64 * 1024, 8, 0) },
- { "m25p80", INFO(0x202014, 0, 64 * 1024, 16, 0) },
- { "m25p16", INFO(0x202015, 0, 64 * 1024, 32, 0) },
- { "m25p32", INFO(0x202016, 0, 64 * 1024, 64, 0) },
- { "m25p64", INFO(0x202017, 0, 64 * 1024, 128, 0) },
- { "m25p128", INFO(0x202018, 0, 256 * 1024, 64, 0) },
- { "m25pe16", INFO(0x208015, 0, 64 * 1024, 32, SECT_4K) },
- { "m25px16", INFO(0x207115, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
- { "m25px64", INFO(0x207117, 0, 64 * 1024, 128, 0) },
+#endif +#ifdef CONFIG_SPI_FLASH_WINBOND /* WINBOND */
- /* Winbond -- w25x "blocks" are 64K, "sectors" are 4KiB */
- { "w25x05", INFO(0xef3010, 0, 64 * 1024, 1, SECT_4K) },
- { "w25x10", INFO(0xef3011, 0, 64 * 1024, 2, SECT_4K) },
- { "w25x20", INFO(0xef3012, 0, 64 * 1024, 4, SECT_4K) },
- { "w25x40", INFO(0xef3013, 0, 64 * 1024, 8, SECT_4K) },
- { "w25x80", INFO(0xef3014, 0, 64 * 1024, 16, SECT_4K) },
- { "w25x16", INFO(0xef3015, 0, 64 * 1024, 32, SECT_4K) },
"w25q16dw", INFO(0xef6015, 0, 64 * 1024, 32,
- { "w25x32", INFO(0xef3016, 0, 64 * 1024, 64, SECT_4K) },
- { "w25q20cl", INFO(0xef4012, 0, 64 * 1024, 4, SECT_4K) },
- { "w25q20bw", INFO(0xef5012, 0, 64 * 1024, 4, SECT_4K) },
- { "w25q20ew", INFO(0xef6012, 0, 64 * 1024, 4, SECT_4K) },
- { "w25q32", INFO(0xef4016, 0, 64 * 1024, 64, SECT_4K) },
"w25q32dw", INFO(0xef6016, 0, 64 * 1024, 64,
"w25q32jv", INFO(0xef7016, 0, 64 * 1024, 64,
- { "w25x64", INFO(0xef3017, 0, 64 * 1024, 128, SECT_4K) },
- { "w25q64", INFO(0xef4017, 0, 64 * 1024, 128, SECT_4K) },
"w25q64dw", INFO(0xef6017, 0, 64 * 1024, 128,
"w25q128fw", INFO(0xef6018, 0, 64 * 1024, 256,
- { "w25q80", INFO(0xef5014, 0, 64 * 1024, 16, SECT_4K) },
- { "w25q80bl", INFO(0xef4014, 0, 64 * 1024, 16, SECT_4K) },
- { "w25q128", INFO(0xef4018, 0, 64 * 1024, 256, SECT_4K) },
- { "w25q256", INFO(0xef4019, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
- { "w25m512jv", INFO(0xef7119, 0, 64 * 1024, 1024,
SECT_4K | SPI_NOR_QUAD_READ | SPI_NOR_DUAL_READ) },
+#endif +#ifdef CONFIG_SPI_FLASH_XMC
- /* XMC (Wuhan Xinxin Semiconductor Manufacturing Corp.) */
- { "XM25QH64A", INFO(0x207017, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
- { "XM25QH128A", INFO(0x207018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
+static const struct flash_info *spi_nor_read_id(struct spi_nor *nor) +{
- int tmp;
- const struct flash_info *info;
- if (!ARRAY_SIZE(spi_nor_ids))
return ERR_PTR(-ENODEV);
- tmp = nor->read_reg(nor, SPINOR_OP_RDID, id, SPI_NOR_MAX_ID_LEN);
- if (tmp < 0) {
dev_dbg(nor->dev, "error %d reading JEDEC ID\n", tmp);
return ERR_PTR(tmp);
- for (tmp = 0; tmp < ARRAY_SIZE(spi_nor_ids) - 1; tmp++) {
info = &spi_nor_ids[tmp];
if (info->id_len) {
if (!memcmp(info->id, id, info->id_len))
return &spi_nor_ids[tmp];
- dev_err(nor->dev, "unrecognized JEDEC id bytes: %02x, %02x, %02x\n",
id[0], id[1], id[2]);
- return ERR_PTR(-ENODEV);
+static int spi_nor_read(struct mtd_info *mtd, loff_t from, size_t len,
size_t *retlen, u_char *buf)
- int ret;
- dev_dbg(nor->dev, "from 0x%08x, len %zd\n", (u32)from, len);
- while (len) {
loff_t addr = from;
ret = nor->read(nor, addr, len, buf);
if (ret == 0) {
/* We shouldn't see 0-length reads */
ret = -EIO;
goto read_err;
if (ret < 0)
goto read_err;
*retlen += ret;
buf += ret;
from += ret;
len -= ret;
- ret = 0;
+read_err:
- return ret;
+#ifdef CONFIG_SPI_FLASH_SST +static int sst_write(struct mtd_info *mtd, loff_t to, size_t len,
size_t *retlen, const u_char *buf)
- size_t actual;
- int ret;
- dev_dbg(nor->dev, "to 0x%08x, len %zd\n", (u32)to, len);
- nor->sst_write_second = false;
- actual = to % 2;
- /* Start write from odd address. */
- if (actual) {
nor->program_opcode = SPINOR_OP_BP;
/* write one byte. */
ret = nor->write(nor, to, 1, buf);
if (ret < 0)
goto sst_write_err;
if (ret)
goto sst_write_err;
- to += actual;
- /* Write out most of the data here. */
- for (; actual < len - 1; actual += 2) {
nor->program_opcode = SPINOR_OP_AAI_WP;
/* write two bytes. */
ret = nor->write(nor, to, 2, buf + actual);
if (ret < 0)
goto sst_write_err;
if (ret)
goto sst_write_err;
to += 2;
nor->sst_write_second = true;
- if (ret)
goto sst_write_err;
- /* Write out trailing byte if it exists. */
- if (actual != len) {
write_enable(nor);
ret = nor->write(nor, to, 1, buf + actual);
if (ret < 0)
goto sst_write_err;
if (ret)
goto sst_write_err;
write_disable(nor);
actual += 1;
+sst_write_err:
- *retlen += actual;
- return ret;
+} +#endif +/*
- Write an address range to the nor chip. Data must be written in
- FLASH_PAGESIZE chunks. The address range may be any size provided
- it is within the physical boundaries.
+static int spi_nor_write(struct mtd_info *mtd, loff_t to, size_t len,
- size_t *retlen, const u_char *buf)
- size_t page_offset, page_remain, i;
- ssize_t ret;
- for (i = 0; i < len; ) {
ssize_t written;
loff_t addr = to + i;
* If page_size is a power of two, the offset can be quickly
* calculated with an AND operation. On the other cases we
* need to do a modulus operation (more expensive).
* Power of two numbers have only one bit set and we can use
* the instruction hweight32 to detect if we need to do a
* modulus (do_div()) or not.
if (hweight32(nor->page_size) == 1) {
page_offset = addr & (nor->page_size - 1);
} else {
u64 aux = addr;
page_offset = do_div(aux, nor->page_size);
/* the size of data remaining on the first page */
page_remain = min_t(size_t,
nor->page_size - page_offset, len - i);
write_enable(nor);
ret = nor->write(nor, addr, page_remain, buf + i);
if (ret < 0)
goto write_err;
written = ret;
if (ret)
goto write_err;
*retlen += written;
i += written;
if (written != page_remain) {
dev_dbg(nor->dev,
"While writing %zu bytes written %zd bytes\n",
page_remain, written);
ret = -EIO;
goto write_err;
+write_err:
- return ret;
+#ifdef CONFIG_SPI_FLASH_MACRONIX +/**
- macronix_quad_enable() - set QE bit in Status Register.
- @nor: pointer to a 'struct spi_nor'
- Set the Quad Enable (QE) bit in the Status Register.
- bit 6 of the Status Register is the QE bit for Macronix like QSPI memories.
- Return: 0 on success, -errno otherwise.
+static int macronix_quad_enable(struct spi_nor *nor) +{
- int ret, val;
- val = read_sr(nor);
- if (val < 0)
return val;
- if (val & SR_QUAD_EN_MX)
- write_sr(nor, val | SR_QUAD_EN_MX);
- if (ret)
return ret;
- if (!(ret > 0 && (ret & SR_QUAD_EN_MX))) {
dev_err(nor->dev, "Macronix Quad bit not set\n");
return -EINVAL;
+} +#endif
+#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) +/*
- Write status Register and configuration register with 2 bytes
- The first byte will be written to the status register, while the
- second byte will be written to the configuration register.
- Return negative if error occurred.
+static int write_sr_cr(struct spi_nor *nor, u8 *sr_cr) +{
- int ret;
- ret = nor->write_reg(nor, SPINOR_OP_WRSR, sr_cr, 2);
- if (ret < 0) {
dev_dbg(nor->dev,
"error while writing configuration register\n");
return -EINVAL;
- if (ret) {
dev_dbg(nor->dev,
"timeout while writing configuration register\n");
return ret;
- spansion_read_cr_quad_enable() - set QE bit in Configuration Register.
- Set the Quad Enable (QE) bit in the Configuration Register.
- This function should be used with QSPI memories supporting the Read
- Configuration Register (35h) instruction.
- bit 1 of the Configuration Register is the QE bit for Spansion like QSPI
- memories.
+static int spansion_read_cr_quad_enable(struct spi_nor *nor) +{
- u8 sr_cr[2];
- int ret;
- /* Check current Quad Enable bit value. */
- ret = read_cr(nor);
- if (ret < 0) {
dev_dbg(dev, "error while reading configuration register\n");
return -EINVAL;
- if (ret & CR_QUAD_EN_SPAN)
- sr_cr[1] = ret | CR_QUAD_EN_SPAN;
- /* Keep the current value of the Status Register. */
- if (ret < 0) {
dev_dbg(dev, "error while reading status register\n");
return -EINVAL;
- sr_cr[0] = ret;
- ret = write_sr_cr(nor, sr_cr);
- if (ret)
return ret;
- /* Read back and check it. */
- if (!(ret > 0 && (ret & CR_QUAD_EN_SPAN))) {
dev_dbg(nor->dev, "Spansion Quad bit not set\n");
return -EINVAL;
+#if CONFIG_IS_ENABLED(SPI_FLASH_SFDP_SUPPORT) +/**
- spansion_no_read_cr_quad_enable() - set QE bit in Configuration Register.
- This function should be used with QSPI memories not supporting the Read
- memories.
+static int spansion_no_read_cr_quad_enable(struct spi_nor *nor) +{
- u8 sr_cr[2];
- int ret;
- if (ret < 0) {
dev_dbg(nor->dev, "error while reading status register\n");
return -EINVAL;
- sr_cr[0] = ret;
- sr_cr[1] = CR_QUAD_EN_SPAN;
- return write_sr_cr(nor, sr_cr);
+#endif /* CONFIG_SPI_FLASH_SFDP_SUPPORT */ +#endif /* CONFIG_SPI_FLASH_SPANSION */
+struct spi_nor_read_command {
- u8 num_mode_clocks;
- u8 num_wait_states;
- u8 opcode;
- enum spi_nor_protocol proto;
+struct spi_nor_pp_command {
- u8 opcode;
+enum spi_nor_read_command_index {
- SNOR_CMD_READ,
- SNOR_CMD_READ_FAST,
- SNOR_CMD_READ_1_1_1_DTR,
- /* Dual SPI */
- SNOR_CMD_READ_1_1_2,
- SNOR_CMD_READ_1_2_2,
- SNOR_CMD_READ_2_2_2,
- SNOR_CMD_READ_1_2_2_DTR,
- /* Quad SPI */
- SNOR_CMD_READ_1_1_4,
- SNOR_CMD_READ_1_4_4,
- SNOR_CMD_READ_4_4_4,
- SNOR_CMD_READ_1_4_4_DTR,
- /* Octo SPI */
- SNOR_CMD_READ_1_1_8,
- SNOR_CMD_READ_1_8_8,
- SNOR_CMD_READ_8_8_8,
- SNOR_CMD_READ_1_8_8_DTR,
- SNOR_CMD_READ_MAX
+enum spi_nor_pp_command_index {
- SNOR_CMD_PP,
- /* Quad SPI */
- SNOR_CMD_PP_1_1_4,
- SNOR_CMD_PP_1_4_4,
- SNOR_CMD_PP_4_4_4,
- /* Octo SPI */
- SNOR_CMD_PP_1_1_8,
- SNOR_CMD_PP_1_8_8,
- SNOR_CMD_PP_8_8_8,
- SNOR_CMD_PP_MAX
+struct spi_nor_flash_parameter {
- u64 size;
- u32 page_size;
- struct spi_nor_hwcaps hwcaps;
- struct spi_nor_read_command reads[SNOR_CMD_READ_MAX];
- struct spi_nor_pp_command page_programs[SNOR_CMD_PP_MAX];
+static void +spi_nor_set_read_settings(struct spi_nor_read_command *read,
u8 num_mode_clocks,
u8 num_wait_states,
u8 opcode,
- read->num_mode_clocks = num_mode_clocks;
- read->num_wait_states = num_wait_states;
- read->opcode = opcode;
- read->proto = proto;
+static void +spi_nor_set_pp_settings(struct spi_nor_pp_command *pp,
u8 opcode,
- pp->opcode = opcode;
- pp->proto = proto;
+#ifdef CONFIG_SPI_FLASH_SFDP_SUPPORT
This must use CONFIG_IS_ENABLED for SFDP to work in SPL.
- Serial Flash Discoverable Parameters (SFDP) parsing.
- spi_nor_read_sfdp() - read Serial Flash Discoverable Parameters.
- @addr: offset in the SFDP area to start reading data from
- @len: number of bytes to read
- @buf: buffer where the SFDP data are copied into (dma-safe memory)
- Whatever the actual numbers of bytes for address and dummy cycles are
- for (Fast) Read commands, the Read SFDP (5Ah) instruction is always
- followed by a 3-byte address and 8 dummy clock cycles.
+static int spi_nor_read_sfdp(struct spi_nor *nor, u32 addr,
size_t len, void *buf)
- u8 addr_width, read_opcode, read_dummy;
- int ret;
- read_opcode = nor->read_opcode;
- addr_width = nor->addr_width;
- read_dummy = nor->read_dummy;
- nor->read_opcode = SPINOR_OP_RDSFDP;
- nor->addr_width = 3;
- nor->read_dummy = 8;
- while (len) {
ret = nor->read(nor, addr, len, (u8 *)buf);
if (!ret || ret > len) {
ret = -EIO;
goto read_err;
if (ret < 0)
goto read_err;
buf += ret;
addr += ret;
len -= ret;
- ret = 0;
+read_err:
- nor->read_opcode = read_opcode;
- nor->addr_width = addr_width;
- nor->read_dummy = read_dummy;
- return ret;
+struct sfdp_parameter_header {
- u8 id_lsb;
- u8 minor;
- u8 major;
- u8 length; /* in double words */
- u8 parameter_table_pointer[3]; /* byte address */
- u8 id_msb;
+#define SFDP_PARAM_HEADER_ID(p) (((p)->id_msb << 8) | (p)->id_lsb) +#define SFDP_PARAM_HEADER_PTP(p) \
- (((p)->parameter_table_pointer[2] << 16) | \
((p)->parameter_table_pointer[1] << 8) | \
((p)->parameter_table_pointer[0] << 0))
+#define SFDP_BFPT_ID 0xff00 /* Basic Flash Parameter Table */ +#define SFDP_SECTOR_MAP_ID 0xff81 /* Sector Map Table */
+#define SFDP_SIGNATURE 0x50444653U +#define SFDP_JESD216_MAJOR 1 +#define SFDP_JESD216_MINOR 0 +#define SFDP_JESD216A_MINOR 5 +#define SFDP_JESD216B_MINOR 6
+struct sfdp_header {
- u32 signature; /* Ox50444653U <=> "SFDP" */
- u8 minor;
- u8 major;
- u8 nph; /* 0-base number of parameter headers */
- u8 unused;
- /* Basic Flash Parameter Table. */
- struct sfdp_parameter_header bfpt_header;
+/* Basic Flash Parameter Table */
- JESD216 rev B defines a Basic Flash Parameter Table of 16 DWORDs.
- They are indexed from 1 but C arrays are indexed from 0.
+#define BFPT_DWORD(i) ((i) - 1) +#define BFPT_DWORD_MAX 16
+/* The first version of JESB216 defined only 9 DWORDs. */ +#define BFPT_DWORD_MAX_JESD216 9
+/* 1st DWORD. */ +#define BFPT_DWORD1_FAST_READ_1_1_2 BIT(16) +#define BFPT_DWORD1_ADDRESS_BYTES_MASK GENMASK(18, 17) +#define BFPT_DWORD1_ADDRESS_BYTES_3_ONLY (0x0UL << 17) +#define BFPT_DWORD1_ADDRESS_BYTES_3_OR_4 (0x1UL << 17) +#define BFPT_DWORD1_ADDRESS_BYTES_4_ONLY (0x2UL << 17) +#define BFPT_DWORD1_DTR BIT(19) +#define BFPT_DWORD1_FAST_READ_1_2_2 BIT(20) +#define BFPT_DWORD1_FAST_READ_1_4_4 BIT(21) +#define BFPT_DWORD1_FAST_READ_1_1_4 BIT(22)
+/* 5th DWORD. */ +#define BFPT_DWORD5_FAST_READ_2_2_2 BIT(0) +#define BFPT_DWORD5_FAST_READ_4_4_4 BIT(4)
+/* 11th DWORD. */ +#define BFPT_DWORD11_PAGE_SIZE_SHIFT 4 +#define BFPT_DWORD11_PAGE_SIZE_MASK GENMASK(7, 4)
+/* 15th DWORD. */
- (from JESD216 rev B)
- Quad Enable Requirements (QER):
- 000b: Device does not have a QE bit. Device detects 1-1-4 and 1-4-4
reads based on instruction. DQ3/HOLD# functions are hold during
instruction phase.
- 001b: QE is bit 1 of status register 2. It is set via Write Status with
two data bytes where bit 1 of the second byte is one.
Writing only one byte to the status register has the side-effect of
clearing status register 2, including the QE bit. The 100b code is
used if writing one byte to the status register does not modify
status register 2.
- 010b: QE is bit 6 of status register 1. It is set via Write Status with
one data byte where bit 6 is one.
- 011b: QE is bit 7 of status register 2. It is set via Write status
register 2 instruction 3Eh with one data byte where bit 7 is one.
The status register 2 is read using instruction 3Fh.
- 100b: QE is bit 1 of status register 2. It is set via Write Status with
In contrast to the 001b code, writing one byte to the status
register does not modify status register 2.
- 101b: QE is bit 1 of status register 2. Status register 1 is read using
Read Status instruction 05h. Status register2 is read using
instruction 35h. QE is set via Writ Status instruction 01h with
+#define BFPT_DWORD15_QER_MASK GENMASK(22, 20) +#define BFPT_DWORD15_QER_NONE (0x0UL << 20) /* Micron */ +#define BFPT_DWORD15_QER_SR2_BIT1_BUGGY (0x1UL << 20) +#define BFPT_DWORD15_QER_SR1_BIT6 (0x2UL << 20) /* Macronix */ +#define BFPT_DWORD15_QER_SR2_BIT7 (0x3UL << 20) +#define BFPT_DWORD15_QER_SR2_BIT1_NO_RD (0x4UL << 20) +#define BFPT_DWORD15_QER_SR2_BIT1 (0x5UL << 20) /* Spansion */
+struct sfdp_bfpt {
- u32 dwords[BFPT_DWORD_MAX];
+/* Fast Read settings. */
+static inline void +spi_nor_set_read_settings_from_bfpt(struct spi_nor_read_command *read,
u16 half,
- read->num_mode_clocks = (half >> 5) & 0x07;
- read->num_wait_states = (half >> 0) & 0x1f;
- read->opcode = (half >> 8) & 0xff;
+struct sfdp_bfpt_read {
- /* The Fast Read x-y-z hardware capability in params->hwcaps.mask. */
- u32 hwcaps;
* The <supported_bit> bit in <supported_dword> BFPT DWORD tells us
* whether the Fast Read x-y-z command is supported.
- u32 supported_dword;
- u32 supported_bit;
* The half-word at offset <setting_shift> in <setting_dword> BFPT DWORD
* encodes the op code, the number of mode clocks and the number of wait
* states to be used by Fast Read x-y-z command.
- u32 settings_dword;
- u32 settings_shift;
- /* The SPI protocol for this Fast Read x-y-z command. */
+static const struct sfdp_bfpt_read sfdp_bfpt_reads[] = {
- /* Fast Read 1-1-2 */
SNOR_HWCAPS_READ_1_1_2,
BFPT_DWORD(1), BIT(16), /* Supported bit */
BFPT_DWORD(4), 0, /* Settings */
SNOR_PROTO_1_1_2,
- /* Fast Read 1-2-2 */
SNOR_HWCAPS_READ_1_2_2,
BFPT_DWORD(1), BIT(20), /* Supported bit */
BFPT_DWORD(4), 16, /* Settings */
SNOR_PROTO_1_2_2,
- /* Fast Read 2-2-2 */
SNOR_HWCAPS_READ_2_2_2,
BFPT_DWORD(5), BIT(0), /* Supported bit */
BFPT_DWORD(6), 16, /* Settings */
SNOR_PROTO_2_2_2,
- /* Fast Read 1-1-4 */
SNOR_HWCAPS_READ_1_1_4,
BFPT_DWORD(1), BIT(22), /* Supported bit */
BFPT_DWORD(3), 16, /* Settings */
SNOR_PROTO_1_1_4,
- /* Fast Read 1-4-4 */
SNOR_HWCAPS_READ_1_4_4,
BFPT_DWORD(1), BIT(21), /* Supported bit */
BFPT_DWORD(3), 0, /* Settings */
SNOR_PROTO_1_4_4,
- /* Fast Read 4-4-4 */
SNOR_HWCAPS_READ_4_4_4,
BFPT_DWORD(5), BIT(4), /* Supported bit */
BFPT_DWORD(7), 16, /* Settings */
SNOR_PROTO_4_4_4,
+struct sfdp_bfpt_erase {
* The half-word at offset <shift> in DWORD <dwoard> encodes the
* op code and erase sector size to be used by Sector Erase commands.
- u32 dword;
- u32 shift;
+static const struct sfdp_bfpt_erase sfdp_bfpt_erases[] = {
- /* Erase Type 1 in DWORD8 bits[15:0] */
- {BFPT_DWORD(8), 0},
- /* Erase Type 2 in DWORD8 bits[31:16] */
- {BFPT_DWORD(8), 16},
- /* Erase Type 3 in DWORD9 bits[15:0] */
- {BFPT_DWORD(9), 0},
- /* Erase Type 4 in DWORD9 bits[31:16] */
- {BFPT_DWORD(9), 16},
+static int spi_nor_hwcaps_read2cmd(u32 hwcaps);
This function is never defined. Compiling with SFDP support fails.
- spi_nor_parse_bfpt() - read and parse the Basic Flash Parameter Table.
- @bfpt_header: pointer to the 'struct sfdp_parameter_header' describing
the Basic Flash Parameter Table length and version
- @params: pointer to the 'struct spi_nor_flash_parameter' to be
filled
- The Basic Flash Parameter Table is the main and only mandatory table as
- defined by the SFDP (JESD216) specification.
- It provides us with the total size (memory density) of the data array and
- the number of address bytes for Fast Read, Page Program and Sector Erase
- commands.
- For Fast READ commands, it also gives the number of mode clock cycles and
- wait states (regrouped in the number of dummy clock cycles) for each
- supported instruction op code.
- For Page Program, the page size is now available since JESD216 rev A, however
- the supported instruction op codes are still not provided.
- For Sector Erase commands, this table stores the supported instruction op
- codes and the associated sector sizes.
- Finally, the Quad Enable Requirements (QER) are also available since JESD216
- rev A. The QER bits encode the manufacturer dependent procedure to be
- executed to set the Quad Enable (QE) bit in some internal register of the
- Quad SPI memory. Indeed the QE bit, when it exists, must be set before
- sending any Quad SPI command to the memory. Actually, setting the QE bit
- tells the memory to reassign its WP# and HOLD#/RESET# pins to functions IO2
- and IO3 hence enabling 4 (Quad) I/O lines.
+static int spi_nor_parse_bfpt(struct spi_nor *nor,
const struct sfdp_parameter_header *bfpt_header,
struct spi_nor_flash_parameter *params)
- struct sfdp_bfpt bfpt;
- size_t len;
- int i, cmd, err;
- u32 addr;
- u16 half;
- /* JESD216 Basic Flash Parameter Table length is at least 9 DWORDs. */
- if (bfpt_header->length < BFPT_DWORD_MAX_JESD216)
return -EINVAL;
- /* Read the Basic Flash Parameter Table. */
- len = min_t(size_t, sizeof(bfpt),
bfpt_header->length * sizeof(u32));
- addr = SFDP_PARAM_HEADER_PTP(bfpt_header);
- memset(&bfpt, 0, sizeof(bfpt));
- err = spi_nor_read_sfdp(nor, addr, len, &bfpt);
- if (err < 0)
return err;
- /* Fix endianness of the BFPT DWORDs. */
- for (i = 0; i < BFPT_DWORD_MAX; i++)
bfpt.dwords[i] = le32_to_cpu(bfpt.dwords[i]);
- /* Number of address bytes. */
- switch (bfpt.dwords[BFPT_DWORD(1)] & BFPT_DWORD1_ADDRESS_BYTES_MASK) {
- case BFPT_DWORD1_ADDRESS_BYTES_3_ONLY:
break;
- case BFPT_DWORD1_ADDRESS_BYTES_4_ONLY:
nor->addr_width = 4;
break;
- default:
break;
- /* Flash Memory Density (in bits). */
- params->size = bfpt.dwords[BFPT_DWORD(2)];
- if (params->size & BIT(31)) {
params->size &= ~BIT(31);
* Prevent overflows on params->size. Anyway, a NOR of 2^64
* bits is unlikely to exist so this error probably means
* the BFPT we are reading is corrupted/wrong.
if (params->size > 63)
return -EINVAL;
params->size = 1ULL << params->size;
- } else {
params->size++;
- params->size >>= 3; /* Convert to bytes. */
- /* Fast Read settings. */
- for (i = 0; i < ARRAY_SIZE(sfdp_bfpt_reads); i++) {
const struct sfdp_bfpt_read *rd = &sfdp_bfpt_reads[i];
struct spi_nor_read_command *read;
if (!(bfpt.dwords[rd->supported_dword] & rd->supported_bit)) {
params->hwcaps.mask &= ~rd->hwcaps;
continue;
params->hwcaps.mask |= rd->hwcaps;
cmd = spi_nor_hwcaps_read2cmd(rd->hwcaps);
read = ¶ms->reads[cmd];
half = bfpt.dwords[rd->settings_dword] >> rd->settings_shift;
spi_nor_set_read_settings_from_bfpt(read, half, rd->proto);
- /* Sector Erase settings. */
- for (i = 0; i < ARRAY_SIZE(sfdp_bfpt_erases); i++) {
const struct sfdp_bfpt_erase *er = &sfdp_bfpt_erases[i];
u32 erasesize;
u8 opcode;
half = bfpt.dwords[er->dword] >> er->shift;
erasesize = half & 0xff;
/* erasesize == 0 means this Erase Type is not supported. */
if (!erasesize)
continue;
erasesize = 1U << erasesize;
+#ifdef CONFIG_MTD_SPI_NOR_USE_4K_SECTORS
if (erasesize == SZ_4K) {
nor->erase_opcode = opcode;
mtd->erasesize = erasesize;
break;
if (!mtd->erasesize || mtd->erasesize < erasesize) {
- /* Stop here if not JESD216 rev A or later. */
- if (bfpt_header->length < BFPT_DWORD_MAX)
- /* Page size: this field specifies 'N' so the page size = 2^N bytes. */
- params->page_size = bfpt.dwords[BFPT_DWORD(11)];
- params->page_size &= BFPT_DWORD11_PAGE_SIZE_MASK;
- params->page_size >>= BFPT_DWORD11_PAGE_SIZE_SHIFT;
- params->page_size = 1U << params->page_size;
- /* Quad Enable Requirements. */
- switch (bfpt.dwords[BFPT_DWORD(15)] & BFPT_DWORD15_QER_MASK) {
- case BFPT_DWORD15_QER_NONE:
params->quad_enable = NULL;
break;
- case BFPT_DWORD15_QER_SR2_BIT1_BUGGY:
- case BFPT_DWORD15_QER_SR2_BIT1_NO_RD:
params->quad_enable = spansion_no_read_cr_quad_enable;
break;
- case BFPT_DWORD15_QER_SR1_BIT6:
params->quad_enable = macronix_quad_enable;
break;
+#endif +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND)
- case BFPT_DWORD15_QER_SR2_BIT1:
params->quad_enable = spansion_read_cr_quad_enable;
break;
- default:
return -EINVAL;
- spi_nor_parse_sfdp() - parse the Serial Flash Discoverable Parameters.
filled
- The Serial Flash Discoverable Parameters are described by the JEDEC JESD216
- specification. This is a standard which tends to supported by almost all
- (Q)SPI memory manufacturers. Those hard-coded tables allow us to learn at
- runtime the main parameters needed to perform basic SPI flash operations such
- as Fast Read, Page Program or Sector Erase commands.
+static int spi_nor_parse_sfdp(struct spi_nor *nor,
- const struct sfdp_parameter_header *param_header, *bfpt_header;
- struct sfdp_parameter_header *param_headers = NULL;
- struct sfdp_header header;
- size_t psize;
- int i, err;
- /* Get the SFDP header. */
- err = spi_nor_read_sfdp(nor, 0, sizeof(header), &header);
- if (err < 0)
return err;
- /* Check the SFDP header version. */
- if (le32_to_cpu(header.signature) != SFDP_SIGNATURE ||
header.major != SFDP_JESD216_MAJOR)
return -EINVAL;
* Verify that the first and only mandatory parameter header is a
* Basic Flash Parameter Table header as specified in JESD216.
- bfpt_header = &header.bfpt_header;
- if (SFDP_PARAM_HEADER_ID(bfpt_header) != SFDP_BFPT_ID ||
bfpt_header->major != SFDP_JESD216_MAJOR)
return -EINVAL;
* Allocate memory then read all parameter headers with a single
* Read SFDP command. These parameter headers will actually be parsed
* twice: a first time to get the latest revision of the basic flash
* parameter table, then a second time to handle the supported optional
* tables.
* Hence we read the parameter headers once for all to reduce the
* processing time. Also we use kmalloc() instead of devm_kmalloc()
* because we don't need to keep these parameter headers: the allocated
* memory is always released with kfree() before exiting this function.
- if (header.nph) {
psize = header.nph * sizeof(*param_headers);
param_headers = kmalloc(psize, GFP_KERNEL);
if (!param_headers)
return -ENOMEM;
err = spi_nor_read_sfdp(nor, sizeof(header),
psize, param_headers);
if (err < 0) {
dev_err(dev, "failed to read SFDP parameter headers\n");
goto exit;
* Check other parameter headers to get the latest revision of
* the basic flash parameter table.
- for (i = 0; i < header.nph; i++) {
param_header = ¶m_headers[i];
if (SFDP_PARAM_HEADER_ID(param_header) == SFDP_BFPT_ID &&
param_header->major == SFDP_JESD216_MAJOR &&
(param_header->minor > bfpt_header->minor ||
(param_header->minor == bfpt_header->minor &&
param_header->length > bfpt_header->length)))
bfpt_header = param_header;
- err = spi_nor_parse_bfpt(nor, bfpt_header, params);
- if (err)
goto exit;
- /* Parse other parameter headers. */
switch (SFDP_PARAM_HEADER_ID(param_header)) {
case SFDP_SECTOR_MAP_ID:
dev_info(dev, "non-uniform erase sector maps are not supported yet.\n");
break;
default:
break;
if (err)
goto exit;
+exit:
- kfree(param_headers);
- return err;
+} +#else +static int spi_nor_parse_sfdp(struct spi_nor *nor,
- return -EINVAL;
+} +#endif /* CONFIG_SPI_FLASH_SFDP_SUPPORT */
+static int spi_nor_init_params(struct spi_nor *nor,
- /* Set legacy flash parameters as default. */
- memset(params, 0, sizeof(*params));
- /* Set SPI NOR sizes. */
- params->size = info->sector_size * info->n_sectors;
- params->page_size = info->page_size;
- /* (Fast) Read settings. */
- params->hwcaps.mask |= SNOR_HWCAPS_READ;
- spi_nor_set_read_settings(¶ms->reads[SNOR_CMD_READ],
0, 0, SPINOR_OP_READ,
SNOR_PROTO_1_1_1);
- if (!(info->flags & SPI_NOR_NO_FR)) {
params->hwcaps.mask |= SNOR_HWCAPS_READ_FAST;
spi_nor_set_read_settings(¶ms->reads[SNOR_CMD_READ_FAST],
0, 8, SPINOR_OP_READ_FAST,
SNOR_PROTO_1_1_1);
- if (info->flags & SPI_NOR_DUAL_READ) {
params->hwcaps.mask |= SNOR_HWCAPS_READ_1_1_2;
spi_nor_set_read_settings(¶ms->reads[SNOR_CMD_READ_1_1_2],
0, 8, SPINOR_OP_READ_1_1_2,
SNOR_PROTO_1_1_2);
- if (info->flags & SPI_NOR_QUAD_READ) {
params->hwcaps.mask |= SNOR_HWCAPS_READ_1_1_4;
spi_nor_set_read_settings(¶ms->reads[SNOR_CMD_READ_1_1_4],
0, 8, SPINOR_OP_READ_1_1_4,
SNOR_PROTO_1_1_4);
- /* Page Program settings. */
- params->hwcaps.mask |= SNOR_HWCAPS_PP;
- spi_nor_set_pp_settings(¶ms->page_programs[SNOR_CMD_PP],
SPINOR_OP_PP, SNOR_PROTO_1_1_1);
params->hwcaps.mask |= SNOR_HWCAPS_PP_1_1_4;
spi_nor_set_pp_settings(¶ms->page_programs[SNOR_CMD_PP_1_1_4],
SPINOR_OP_PP_1_1_4, SNOR_PROTO_1_1_4);
- /* Select the procedure to set the Quad Enable bit. */
- if (params->hwcaps.mask & (SNOR_HWCAPS_READ_QUAD |
SNOR_HWCAPS_PP_QUAD)) {
break;
break;
default:
/* Kept only for backward compatibility purpose. */
break;
+#ifndef __UBOOT__
* Some manufacturer like GigaDevice may use different
* bit to set QE on different memories, so the MFR can't
* indicate the quad_enable method for this case, we need
* set it in flash info list.
if (info->quad_enable)
params->quad_enable = info->quad_enable;
- /* Override the parameters with data read from SFDP tables. */
- nor->addr_width = 0;
- nor->mtd.erasesize = 0;
- if ((info->flags & (SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ)) &&
!(info->flags & SPI_NOR_SKIP_SFDP)) {
struct spi_nor_flash_parameter sfdp_params;
memcpy(&sfdp_params, params, sizeof(sfdp_params));
if (spi_nor_parse_sfdp(nor, &sfdp_params)) {
} else {
memcpy(params, &sfdp_params, sizeof(*params));
+static int spi_nor_select_read(struct spi_nor *nor,
const struct spi_nor_flash_parameter *params,
u32 shared_hwcaps)
- int best_match = shared_hwcaps & SNOR_HWCAPS_READ_MASK;
- int cmd;
- const struct spi_nor_read_command *read;
- if (best_match < 0)
return -EINVAL;
- if (best_match & SNOR_HWCAPS_READ_1_4_4)
cmd = SNOR_CMD_READ_1_4_4;
- else if (best_match & SNOR_HWCAPS_READ_1_1_4)
cmd = SNOR_CMD_READ_1_1_4;
- else
cmd = SNOR_CMD_READ;
- read = ¶ms->reads[cmd];
- nor->read_opcode = read->opcode;
- nor->read_proto = read->proto;
* In the spi-nor framework, we don't need to make the difference
* between mode clock cycles and wait state clock cycles.
* Indeed, the value of the mode clock cycles is used by a QSPI
* flash memory to know whether it should enter or leave its 0-4-4
* (Continuous Read / XIP) mode.
* eXecution In Place is out of the scope of the mtd sub-system.
* Hence we choose to merge both mode and wait state clock cycles
* into the so called dummy clock cycles.
- nor->read_dummy = read->num_mode_clocks + read->num_wait_states;
+static int spi_nor_select_pp(struct spi_nor *nor,
u32 shared_hwcaps)
- int best_match = shared_hwcaps & SNOR_HWCAPS_PP_MASK;
- int cmd;
- const struct spi_nor_pp_command *pp;
return -EINVAL;
- if (best_match & SNOR_HWCAPS_PP_1_1_4)
cmd = SNOR_CMD_PP_1_1_4;
- else
cmd = SNOR_CMD_PP;
- pp = ¶ms->page_programs[cmd];
- nor->program_opcode = pp->opcode;
- nor->write_proto = pp->proto;
+static int spi_nor_select_erase(struct spi_nor *nor,
const struct flash_info *info)
- /* Do nothing if already configured from SFDP. */
- if (mtd->erasesize)
+#ifdef CONFIG_SPI_FLASH_USE_4K_SECTORS
- /* prefer "small sector" erase if possible */
- if (info->flags & SECT_4K) {
nor->erase_opcode = SPINOR_OP_BE_4K;
mtd->erasesize = 4096;
- } else if (info->flags & SECT_4K_PMC) {
nor->erase_opcode = SPINOR_OP_BE_4K_PMC;
- } else
nor->erase_opcode = SPINOR_OP_SE;
mtd->erasesize = info->sector_size;
+static int spi_nor_setup(struct spi_nor *nor, const struct flash_info *info,
const struct spi_nor_hwcaps *hwcaps)
- u32 ignored_mask, shared_mask;
- bool enable_quad_io;
- int err;
* Keep only the hardware capabilities supported by both the SPI
* controller and the SPI flash memory.
- shared_mask = hwcaps->mask & params->hwcaps.mask;
- /* SPI n-n-n protocols are not supported yet. */
- ignored_mask = (SNOR_HWCAPS_READ_2_2_2 |
SNOR_HWCAPS_READ_4_4_4 |
SNOR_HWCAPS_READ_8_8_8 |
SNOR_HWCAPS_PP_4_4_4 |
SNOR_HWCAPS_PP_8_8_8);
- if (shared_mask & ignored_mask) {
dev_dbg(nor->dev,
"SPI n-n-n protocols are not supported yet.\n");
shared_mask &= ~ignored_mask;
- /* Select the (Fast) Read command. */
- err = spi_nor_select_read(nor, params, shared_mask);
- if (err) {
dev_dbg(nor->dev,
"can't select read settings supported by both the SPI controller and memory.\n");
return err;
- /* Select the Page Program command. */
- err = spi_nor_select_pp(nor, params, shared_mask);
- if (err) {
dev_dbg(nor->dev,
"can't select write settings supported by both the SPI controller and memory.\n");
return err;
- /* Select the Sector Erase command. */
- err = spi_nor_select_erase(nor, info);
- if (err) {
dev_dbg(nor->dev,
"can't select erase settings supported by both the SPI controller and memory.\n");
return err;
- /* Enable Quad I/O if needed. */
- enable_quad_io = (spi_nor_get_protocol_width(nor->read_proto) == 4 ||
spi_nor_get_protocol_width(nor->write_proto) == 4);
- if (enable_quad_io && params->quad_enable)
nor->quad_enable = params->quad_enable;
- else
nor->quad_enable = NULL;
+static int spi_nor_init(struct spi_nor *nor) +{
- int err;
* Atmel, SST, Intel/Numonyx, and others serial NOR tend to power up
* with the software protection bits set
- if (JEDEC_MFR(nor->info) == SNOR_MFR_ATMEL ||
JEDEC_MFR(nor->info) == SNOR_MFR_INTEL ||
JEDEC_MFR(nor->info) == SNOR_MFR_SST ||
nor->info->flags & SPI_NOR_HAS_LOCK) {
write_enable(nor);
write_sr(nor, 0);
- if (nor->quad_enable) {
err = nor->quad_enable(nor);
if (err) {
dev_dbg(nor->dev, "quad mode not supported\n");
return err;
- if (nor->addr_width == 4 &&
(JEDEC_MFR(nor->info) != SNOR_MFR_SPANSION) &&
!(nor->info->flags & SPI_NOR_4B_OPCODES)) {
* If the RESET# pin isn't hooked up properly, or the system
* otherwise doesn't perform a reset command in the boot
* sequence, it's impossible to 100% protect against unexpected
* reboots (e.g., crashes). Warn the user (or hopefully, system
* designer) that this is bad.
if (nor->flags & SNOR_F_BROKEN_RESET)
printf("enabling reset hack; may not recover from unexpected reboots\n");
set_4byte(nor, nor->info, 1);
+int spi_nor_scan(struct spi_nor *nor) +{
- struct spi_nor_flash_parameter params;
- const struct flash_info *info = NULL;
- struct spi_nor_hwcaps hwcaps = {
.mask = SNOR_HWCAPS_READ |
SNOR_HWCAPS_READ_FAST |
SNOR_HWCAPS_PP,
- struct spi_slave *spi = nor->spi;
- int ret;
- /* Reset SPI protocol for all commands. */
- nor->reg_proto = SNOR_PROTO_1_1_1;
- nor->read_proto = SNOR_PROTO_1_1_1;
- nor->write_proto = SNOR_PROTO_1_1_1;
- nor->read = spi_nor_read_data;
- nor->write = spi_nor_write_data;
- nor->read_reg = spi_nor_read_reg;
- nor->write_reg = spi_nor_write_reg;
- if (spi->mode & SPI_RX_QUAD) {
if (spi->mode & SPI_TX_QUAD)
hwcaps.mask |= (SNOR_HWCAPS_READ_1_4_4 |
SNOR_HWCAPS_PP_1_1_4 |
SNOR_HWCAPS_PP_1_4_4);
- } else if (spi->mode & SPI_RX_DUAL) {
if (spi->mode & SPI_TX_DUAL)
hwcaps.mask |= SNOR_HWCAPS_READ_1_2_2;
- info = spi_nor_read_id(nor);
- if (IS_ERR_OR_NULL(info))
return -ENOENT;
- /* Parse the Serial Flash Discoverable Parameters table. */
- ret = spi_nor_init_params(nor, info, ¶ms);
- if (ret)
return ret;
- if (!mtd->name)
mtd->name = info->name;
- mtd->priv = nor;
- mtd->type = MTD_NORFLASH;
- mtd->writesize = 1;
- mtd->flags = MTD_CAP_NORFLASH;
- mtd->size = params.size;
- mtd->_erase = spi_nor_erase;
- mtd->_read = spi_nor_read;
- /* NOR protection support for STmicro/Micron chips and similar */
- if (JEDEC_MFR(info) == SNOR_MFR_ST ||
JEDEC_MFR(info) == SNOR_MFR_MICRON ||
JEDEC_MFR(info) == SNOR_MFR_SST ||
nor->flash_lock = stm_lock;
nor->flash_unlock = stm_unlock;
nor->flash_is_locked = stm_is_locked;
- if (nor->flash_lock && nor->flash_unlock && nor->flash_is_locked) {
mtd->_lock = spi_nor_lock;
mtd->_unlock = spi_nor_unlock;
mtd->_is_locked = spi_nor_is_locked;
- /* sst nor chips use AAI word program */
- if (info->flags & SST_WRITE)
mtd->_write = sst_write;
- else
mtd->_write = spi_nor_write;
- if (info->flags & USE_FSR)
nor->flags |= SNOR_F_USE_FSR;
- if (info->flags & SPI_NOR_HAS_TB)
nor->flags |= SNOR_F_HAS_SR_TB;
- if (info->flags & NO_CHIP_ERASE)
nor->flags |= SNOR_F_NO_OP_CHIP_ERASE;
- if (info->flags & USE_CLSR)
nor->flags |= SNOR_F_USE_CLSR;
- if (info->flags & SPI_NOR_NO_ERASE)
mtd->flags |= MTD_NO_ERASE;
- nor->page_size = params.page_size;
- mtd->writebufsize = nor->page_size;
- /* Some devices cannot do fast-read, no matter what DT tells us */
- if (info->flags & SPI_NOR_NO_FR)
params.hwcaps.mask &= ~SNOR_HWCAPS_READ_FAST;
* Configure the SPI memory:
* - select op codes for (Fast) Read, Page Program and Sector Erase.
* - set the number of dummy cycles (mode cycles + wait states).
* - set the SPI protocols for register and memory accesses.
* - set the Quad Enable bit if needed (required by SPI x-y-4 protos).
- ret = spi_nor_setup(nor, info, ¶ms, &hwcaps);
- if (ret)
return ret;
- if (nor->addr_width) {
/* already configured from SFDP */
- } else if (info->addr_width) {
nor->addr_width = info->addr_width;
- } else if (mtd->size > 0x1000000) {
/* enable 4-byte addressing if the device exceeds 16MiB */
if (JEDEC_MFR(info) == SNOR_MFR_SPANSION ||
spi_nor_set_4byte_opcodes(nor, info);
- } else {
- if (nor->addr_width > SPI_NOR_MAX_ADDR_WIDTH) {
dev_dbg(dev, "address width is too large: %u\n",
nor->addr_width);
return -EINVAL;
- /* Send all the required SPI flash commands to initialize device */
- nor->info = info;
- ret = spi_nor_init(nor);
- if (ret)
return ret;
- nor->name = mtd->name;
- nor->size = mtd->size;
- nor->erase_size = mtd->erasesize;
- nor->sector_size = mtd->erasesize;
+#ifndef CONFIG_SPL_BUILD
- printf("SF: Detected %s with page size ", nor->name);
- print_size(nor->page_size, ", erase size ");
- print_size(nor->erase_size, ", total ");
- print_size(nor->size, "");
- puts("\n");
+#ifndef __UBOOT__
- dev_info(dev, "%s (%lld Kbytes)\n", info->name,
(long long)mtd->size >> 10);
- dev_dbg(dev,
"mtd .name = %s, .size = 0x%llx (%lldMiB), "
".erasesize = 0x%.8x (%uKiB) .numeraseregions = %d\n",
mtd->name, (long long)mtd->size, (long long)(mtd->size >> 20),
mtd->erasesize, mtd->erasesize / 1024, mtd->numeraseregions);
- if (mtd->numeraseregions)
for (i = 0; i < mtd->numeraseregions; i++)
dev_dbg(dev,
"mtd.eraseregions[%d] = { .offset = 0x%llx, "
".erasesize = 0x%.8x (%uKiB), "
".numblocks = %d }\n",
i, (long long)mtd->eraseregions[i].offset,
mtd->eraseregions[i].erasesize,
mtd->eraseregions[i].erasesize / 1024,
mtd->eraseregions[i].numblocks);
+} +EXPORT_SYMBOL_GPL(spi_nor_scan);
+/* U-Boot specific functions, need to extend MTD to support these */ +int spi_flash_cmd_get_sw_write_prot(struct spi_nor *nor) +{
- if (sr < 0)
return sr;
- return (sr >> 2) & 7;
+MODULE_LICENSE("GPL"); +MODULE_AUTHOR("Huang Shijie shijie8@gmail.com"); +MODULE_AUTHOR("Mike Lavender"); +MODULE_DESCRIPTION("framework for SPI NOR"); diff --git a/include/linux/mtd/cfi.h b/include/linux/mtd/cfi.h new file mode 100644 index 000000000000..3555518bd3f1 --- /dev/null +++ b/include/linux/mtd/cfi.h @@ -0,0 +1,32 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
- Copyright © 2000-2010 David Woodhouse dwmw2@infradead.org et al.
+#ifndef __MTD_CFI_H__ +#define __MTD_CFI_H__
+#define CFI_MFR_ANY 0xFFFF +#define CFI_ID_ANY 0xFFFF +#define CFI_MFR_CONTINUATION 0x007F
+#define CFI_MFR_AMD 0x0001 +#define CFI_MFR_AMIC 0x0037 +#define CFI_MFR_ATMEL 0x001F +#define CFI_MFR_EON 0x001C +#define CFI_MFR_FUJITSU 0x0004 +#define CFI_MFR_HYUNDAI 0x00AD +#define CFI_MFR_INTEL 0x0089 +#define CFI_MFR_MACRONIX 0x00C2 +#define CFI_MFR_NEC 0x0010 +#define CFI_MFR_PMC 0x009D +#define CFI_MFR_SAMSUNG 0x00EC +#define CFI_MFR_SHARP 0x00B0 +#define CFI_MFR_SST 0x00BF +#define CFI_MFR_ST 0x0020 /* STMicroelectronics */ +#define CFI_MFR_MICRON 0x002C /* Micron */ +#define CFI_MFR_TOSHIBA 0x0098 +#define CFI_MFR_WINBOND 0x00DA
+#endif /* __MTD_CFI_H__ */ diff --git a/include/linux/mtd/spi-nor.h b/include/linux/mtd/spi-nor.h new file mode 100644 index 000000000000..2cc86b16030c --- /dev/null +++ b/include/linux/mtd/spi-nor.h @@ -0,0 +1,421 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
- Copyright (C) 2014 Freescale Semiconductor, Inc.
- Synced from Linux v4.19
+#ifndef __LINUX_MTD_SPI_NOR_H +#define __LINUX_MTD_SPI_NOR_H
+#include <linux/bitops.h> +#include <linux/mtd/cfi.h> +#include <linux/mtd/mtd.h>
- Manufacturer IDs
- The first byte returned from the flash after sending opcode SPINOR_OP_RDID.
- Sometimes these are the same as CFI IDs, but sometimes they aren't.
+#define SNOR_MFR_ATMEL CFI_MFR_ATMEL +#define SNOR_MFR_GIGADEVICE 0xc8 +#define SNOR_MFR_INTEL CFI_MFR_INTEL +#define SNOR_MFR_ST CFI_MFR_ST /* ST Micro <--> Micron */ +#define SNOR_MFR_MICRON CFI_MFR_MICRON /* ST Micro <--> Micron */ +#define SNOR_MFR_MACRONIX CFI_MFR_MACRONIX +#define SNOR_MFR_SPANSION CFI_MFR_AMD +#define SNOR_MFR_SST CFI_MFR_SST +#define SNOR_MFR_WINBOND 0xef /* Also used by some Spansion */
- Note on opcode nomenclature: some opcodes have a format like
- SPINOR_OP_FUNCTION{4,}_x_y_z. The numbers x, y, and z stand for the number
- of I/O lines used for the opcode, address, and data (respectively). The
- FUNCTION has an optional suffix of '4', to represent an opcode which
- requires a 4-byte (32-bit) address.
+/* Flash opcodes. */ +#define SPINOR_OP_WREN 0x06 /* Write enable */ +#define SPINOR_OP_RDSR 0x05 /* Read status register */ +#define SPINOR_OP_WRSR 0x01 /* Write status register 1 byte */ +#define SPINOR_OP_RDSR2 0x3f /* Read status register 2 */ +#define SPINOR_OP_WRSR2 0x3e /* Write status register 2 */ +#define SPINOR_OP_READ 0x03 /* Read data bytes (low frequency) */ +#define SPINOR_OP_READ_FAST 0x0b /* Read data bytes (high frequency) */ +#define SPINOR_OP_READ_1_1_2 0x3b /* Read data bytes (Dual Output SPI) */ +#define SPINOR_OP_READ_1_2_2 0xbb /* Read data bytes (Dual I/O SPI) */ +#define SPINOR_OP_READ_1_1_4 0x6b /* Read data bytes (Quad Output SPI) */ +#define SPINOR_OP_READ_1_4_4 0xeb /* Read data bytes (Quad I/O SPI) */ +#define SPINOR_OP_PP 0x02 /* Page program (up to 256 bytes) */ +#define SPINOR_OP_PP_1_1_4 0x32 /* Quad page program */ +#define SPINOR_OP_PP_1_4_4 0x38 /* Quad page program */ +#define SPINOR_OP_BE_4K 0x20 /* Erase 4KiB block */ +#define SPINOR_OP_BE_4K_PMC 0xd7 /* Erase 4KiB block on PMC chips */ +#define SPINOR_OP_BE_32K 0x52 /* Erase 32KiB block */ +#define SPINOR_OP_CHIP_ERASE 0xc7 /* Erase whole flash chip */ +#define SPINOR_OP_SE 0xd8 /* Sector erase (usually 64KiB) */ +#define SPINOR_OP_RDID 0x9f /* Read JEDEC ID */ +#define SPINOR_OP_RDSFDP 0x5a /* Read SFDP */ +#define SPINOR_OP_RDCR 0x35 /* Read configuration register */ +#define SPINOR_OP_RDFSR 0x70 /* Read flag status register */ +#define SPINOR_OP_CLFSR 0x50 /* Clear flag status register */ +#define SPINOR_OP_RDEAR 0xc8 /* Read Extended Address Register */ +#define SPINOR_OP_WREAR 0xc5 /* Write Extended Address Register */
+/* 4-byte address opcodes - used on Spansion and some Macronix flashes. */ +#define SPINOR_OP_READ_4B 0x13 /* Read data bytes (low frequency) */ +#define SPINOR_OP_READ_FAST_4B 0x0c /* Read data bytes (high frequency) */ +#define SPINOR_OP_READ_1_1_2_4B 0x3c /* Read data bytes (Dual Output SPI) */ +#define SPINOR_OP_READ_1_2_2_4B 0xbc /* Read data bytes (Dual I/O SPI) */ +#define SPINOR_OP_READ_1_1_4_4B 0x6c /* Read data bytes (Quad Output SPI) */ +#define SPINOR_OP_READ_1_4_4_4B 0xec /* Read data bytes (Quad I/O SPI) */ +#define SPINOR_OP_PP_4B 0x12 /* Page program (up to 256 bytes) */ +#define SPINOR_OP_PP_1_1_4_4B 0x34 /* Quad page program */ +#define SPINOR_OP_PP_1_4_4_4B 0x3e /* Quad page program */ +#define SPINOR_OP_BE_4K_4B 0x21 /* Erase 4KiB block */ +#define SPINOR_OP_BE_32K_4B 0x5c /* Erase 32KiB block */ +#define SPINOR_OP_SE_4B 0xdc /* Sector erase (usually 64KiB) */
+/* Double Transfer Rate opcodes - defined in JEDEC JESD216B. */ +#define SPINOR_OP_READ_1_1_1_DTR 0x0d +#define SPINOR_OP_READ_1_2_2_DTR 0xbd +#define SPINOR_OP_READ_1_4_4_DTR 0xed
+#define SPINOR_OP_READ_1_1_1_DTR_4B 0x0e +#define SPINOR_OP_READ_1_2_2_DTR_4B 0xbe +#define SPINOR_OP_READ_1_4_4_DTR_4B 0xee
+/* Used for SST flashes only. */ +#define SPINOR_OP_BP 0x02 /* Byte program */ +#define SPINOR_OP_WRDI 0x04 /* Write disable */ +#define SPINOR_OP_AAI_WP 0xad /* Auto address increment word program */
+/* Used for S3AN flashes only */ +#define SPINOR_OP_XSE 0x50 /* Sector erase */ +#define SPINOR_OP_XPP 0x82 /* Page program */ +#define SPINOR_OP_XRDSR 0xd7 /* Read status register */
+#define XSR_PAGESIZE BIT(0) /* Page size in Po2 or Linear */ +#define XSR_RDY BIT(7) /* Ready */
+/* Used for Macronix and Winbond flashes. */ +#define SPINOR_OP_EN4B 0xb7 /* Enter 4-byte mode */ +#define SPINOR_OP_EX4B 0xe9 /* Exit 4-byte mode */
+/* Used for Spansion flashes only. */ +#define SPINOR_OP_BRWR 0x17 /* Bank register write */ +#define SPINOR_OP_CLSR 0x30 /* Clear status register 1 */
+/* Used for Micron flashes only. */ +#define SPINOR_OP_RD_EVCR 0x65 /* Read EVCR register */ +#define SPINOR_OP_WD_EVCR 0x61 /* Write EVCR register */
+/* Status Register bits. */ +#define SR_WIP BIT(0) /* Write in progress */ +#define SR_WEL BIT(1) /* Write enable latch */ +/* meaning of other SR_* bits may differ between vendors */ +#define SR_BP0 BIT(2) /* Block protect 0 */ +#define SR_BP1 BIT(3) /* Block protect 1 */ +#define SR_BP2 BIT(4) /* Block protect 2 */ +#define SR_TB BIT(5) /* Top/Bottom protect */ +#define SR_SRWD BIT(7) /* SR write protect */ +/* Spansion/Cypress specific status bits */ +#define SR_E_ERR BIT(5) +#define SR_P_ERR BIT(6)
+#define SR_QUAD_EN_MX BIT(6) /* Macronix Quad I/O */
+/* Enhanced Volatile Configuration Register bits */ +#define EVCR_QUAD_EN_MICRON BIT(7) /* Micron Quad I/O */
+/* Flag Status Register bits */ +#define FSR_READY BIT(7) /* Device status, 0 = Busy, 1 = Ready */ +#define FSR_E_ERR BIT(5) /* Erase operation status */ +#define FSR_P_ERR BIT(4) /* Program operation status */ +#define FSR_PT_ERR BIT(1) /* Protection error bit */
+/* Configuration Register bits. */ +#define CR_QUAD_EN_SPAN BIT(1) /* Spansion Quad I/O */
+/* Status Register 2 bits. */ +#define SR2_QUAD_EN_BIT7 BIT(7)
+/* Supported SPI protocols */ +#define SNOR_PROTO_INST_MASK GENMASK(23, 16) +#define SNOR_PROTO_INST_SHIFT 16 +#define SNOR_PROTO_INST(_nbits) \
- ((((unsigned long)(_nbits)) << SNOR_PROTO_INST_SHIFT) & \
SNOR_PROTO_INST_MASK)
+#define SNOR_PROTO_ADDR_MASK GENMASK(15, 8) +#define SNOR_PROTO_ADDR_SHIFT 8 +#define SNOR_PROTO_ADDR(_nbits) \
- ((((unsigned long)(_nbits)) << SNOR_PROTO_ADDR_SHIFT) & \
SNOR_PROTO_ADDR_MASK)
+#define SNOR_PROTO_DATA_MASK GENMASK(7, 0) +#define SNOR_PROTO_DATA_SHIFT 0 +#define SNOR_PROTO_DATA(_nbits) \
- ((((unsigned long)(_nbits)) << SNOR_PROTO_DATA_SHIFT) & \
SNOR_PROTO_DATA_MASK)
+#define SNOR_PROTO_IS_DTR BIT(24) /* Double Transfer Rate */
+#define SNOR_PROTO_STR(_inst_nbits, _addr_nbits, _data_nbits) \
- (SNOR_PROTO_INST(_inst_nbits) | \
SNOR_PROTO_ADDR(_addr_nbits) | \
SNOR_PROTO_DATA(_data_nbits))
+#define SNOR_PROTO_DTR(_inst_nbits, _addr_nbits, _data_nbits) \
- (SNOR_PROTO_IS_DTR | \
SNOR_PROTO_STR(_inst_nbits, _addr_nbits, _data_nbits))
+enum spi_nor_protocol {
- SNOR_PROTO_1_1_1 = SNOR_PROTO_STR(1, 1, 1),
- SNOR_PROTO_1_1_2 = SNOR_PROTO_STR(1, 1, 2),
- SNOR_PROTO_1_1_4 = SNOR_PROTO_STR(1, 1, 4),
- SNOR_PROTO_1_1_8 = SNOR_PROTO_STR(1, 1, 8),
- SNOR_PROTO_1_2_2 = SNOR_PROTO_STR(1, 2, 2),
- SNOR_PROTO_1_4_4 = SNOR_PROTO_STR(1, 4, 4),
- SNOR_PROTO_1_8_8 = SNOR_PROTO_STR(1, 8, 8),
- SNOR_PROTO_2_2_2 = SNOR_PROTO_STR(2, 2, 2),
- SNOR_PROTO_4_4_4 = SNOR_PROTO_STR(4, 4, 4),
- SNOR_PROTO_8_8_8 = SNOR_PROTO_STR(8, 8, 8),
- SNOR_PROTO_1_1_1_DTR = SNOR_PROTO_DTR(1, 1, 1),
- SNOR_PROTO_1_2_2_DTR = SNOR_PROTO_DTR(1, 2, 2),
- SNOR_PROTO_1_4_4_DTR = SNOR_PROTO_DTR(1, 4, 4),
- SNOR_PROTO_1_8_8_DTR = SNOR_PROTO_DTR(1, 8, 8),
+static inline bool spi_nor_protocol_is_dtr(enum spi_nor_protocol proto) +{
- return !!(proto & SNOR_PROTO_IS_DTR);
+static inline u8 spi_nor_get_protocol_inst_nbits(enum spi_nor_protocol proto) +{
- return ((unsigned long)(proto & SNOR_PROTO_INST_MASK)) >>
SNOR_PROTO_INST_SHIFT;
+static inline u8 spi_nor_get_protocol_addr_nbits(enum spi_nor_protocol proto) +{
- return ((unsigned long)(proto & SNOR_PROTO_ADDR_MASK)) >>
SNOR_PROTO_ADDR_SHIFT;
+static inline u8 spi_nor_get_protocol_data_nbits(enum spi_nor_protocol proto) +{
- return ((unsigned long)(proto & SNOR_PROTO_DATA_MASK)) >>
SNOR_PROTO_DATA_SHIFT;
+static inline u8 spi_nor_get_protocol_width(enum spi_nor_protocol proto) +{
- return spi_nor_get_protocol_data_nbits(proto);
+#define SPI_NOR_MAX_CMD_SIZE 8 +enum spi_nor_ops {
- SPI_NOR_OPS_READ = 0,
- SPI_NOR_OPS_WRITE,
- SPI_NOR_OPS_ERASE,
- SPI_NOR_OPS_LOCK,
- SPI_NOR_OPS_UNLOCK,
+enum spi_nor_option_flags {
- SNOR_F_USE_FSR = BIT(0),
- SNOR_F_HAS_SR_TB = BIT(1),
- SNOR_F_NO_OP_CHIP_ERASE = BIT(2),
- SNOR_F_S3AN_ADDR_DEFAULT = BIT(3),
- SNOR_F_READY_XSR_RDY = BIT(4),
- SNOR_F_USE_CLSR = BIT(5),
- SNOR_F_BROKEN_RESET = BIT(6),
- struct flash_info - Forward declaration of a structure used internally by
spi_nor_scan()
+struct flash_info;
+/* TODO: Remove, once all users of spi_flash interface are moved to MTD */ +#define spi_flash spi_nor
- struct spi_nor - Structure for defining a the SPI NOR layer
- @mtd: point to a mtd_info structure
- @lock: the lock for the read/write/erase/lock/unlock operations
- @dev: point to a spi device, or a spi nor controller device.
- @info: spi-nor part JDEC MFR id and other info
- @page_size: the page size of the SPI NOR
- @addr_width: number of address bytes
- @erase_opcode: the opcode for erasing a sector
- @read_opcode: the read opcode
- @read_dummy: the dummy needed by the read operation
- @program_opcode: the program opcode
- @sst_write_second: used by the SST write operation
- @flags: flag options for the current SPI-NOR (SNOR_F_*)
- @read_proto: the SPI protocol for read operations
- @write_proto: the SPI protocol for write operations
- @reg_proto the SPI protocol for read_reg/write_reg/erase operations
- @cmd_buf: used by the write_reg
- @prepare: [OPTIONAL] do some preparations for the
- @unprepare: [OPTIONAL] do some post work after the
- @read_reg: [DRIVER-SPECIFIC] read out the register
- @write_reg: [DRIVER-SPECIFIC] write data to the register
- @read: [DRIVER-SPECIFIC] read data from the SPI NOR
- @write: [DRIVER-SPECIFIC] write data to the SPI NOR
- @erase: [DRIVER-SPECIFIC] erase a sector of the SPI NOR
at the offset @offs; if not provided by the driver,
spi-nor will send the erase opcode via write_reg()
- @flash_lock: [FLASH-SPECIFIC] lock a region of the SPI NOR
- @flash_unlock: [FLASH-SPECIFIC] unlock a region of the SPI NOR
- @flash_is_locked: [FLASH-SPECIFIC] check if a region of the SPI NOR is
- @quad_enable: [FLASH-SPECIFIC] enables SPI NOR quad mode
completely locked
- @priv: the private data
+struct spi_nor {
- struct mtd_info mtd;
+#ifndef __UBOOT__
- struct mutex lock;
- struct device *dev;
+#else
- struct udevice *dev;
- struct spi_slave *spi;
- u32 page_size;
- u8 addr_width;
- u8 erase_opcode;
- u8 read_opcode;
- u8 read_dummy;
- u8 program_opcode;
- enum spi_nor_protocol read_proto;
- enum spi_nor_protocol write_proto;
- enum spi_nor_protocol reg_proto;
- bool sst_write_second;
- u32 flags;
- u8 cmd_buf[SPI_NOR_MAX_CMD_SIZE];
- int (*prepare)(struct spi_nor *nor, enum spi_nor_ops ops);
- void (*unprepare)(struct spi_nor *nor, enum spi_nor_ops ops);
- int (*read_reg)(struct spi_nor *nor, u8 opcode, u8 *buf, int len);
- int (*write_reg)(struct spi_nor *nor, u8 opcode, u8 *buf, int len);
- ssize_t (*read)(struct spi_nor *nor, loff_t from,
size_t len, u_char *read_buf);
- ssize_t (*write)(struct spi_nor *nor, loff_t to,
size_t len, const u_char *write_buf);
- int (*erase)(struct spi_nor *nor, loff_t offs);
- int (*flash_lock)(struct spi_nor *nor, loff_t ofs, uint64_t len);
- int (*flash_unlock)(struct spi_nor *nor, loff_t ofs, uint64_t len);
- int (*flash_is_locked)(struct spi_nor *nor, loff_t ofs, uint64_t len);
- int (*quad_enable)(struct spi_nor *nor);
- void *priv;
+/* Compatibility for spi_flash, remove once sf layer is merged with mtd */
- const char *name;
- u32 size;
- u32 sector_size;
- u32 erase_size;
+static inline void spi_nor_set_flash_node(struct spi_nor *nor,
const struct device_node *np)
- mtd_set_of_node(&nor->mtd, np);
+static inline const struct +device_node *spi_nor_get_flash_node(struct spi_nor *nor) +{
- return mtd_get_of_node(&nor->mtd);
- struct spi_nor_hwcaps - Structure for describing the hardware capabilies
- supported by the SPI controller (bus master).
- @mask: the bitmask listing all the supported hw capabilies
+struct spi_nor_hwcaps {
- u32 mask;
- *(Fast) Read capabilities.
- MUST be ordered by priority: the higher bit position, the higher priority.
- As a matter of performances, it is relevant to use Octo SPI protocols first,
- then Quad SPI protocols before Dual SPI protocols, Fast Read and lastly
- (Slow) Read.
+#define SNOR_HWCAPS_READ_MASK GENMASK(14, 0) +#define SNOR_HWCAPS_READ BIT(0) +#define SNOR_HWCAPS_READ_FAST BIT(1) +#define SNOR_HWCAPS_READ_1_1_1_DTR BIT(2)
+#define SNOR_HWCAPS_READ_DUAL GENMASK(6, 3) +#define SNOR_HWCAPS_READ_1_1_2 BIT(3) +#define SNOR_HWCAPS_READ_1_2_2 BIT(4) +#define SNOR_HWCAPS_READ_2_2_2 BIT(5) +#define SNOR_HWCAPS_READ_1_2_2_DTR BIT(6)
+#define SNOR_HWCAPS_READ_QUAD GENMASK(10, 7) +#define SNOR_HWCAPS_READ_1_1_4 BIT(7) +#define SNOR_HWCAPS_READ_1_4_4 BIT(8) +#define SNOR_HWCAPS_READ_4_4_4 BIT(9) +#define SNOR_HWCAPS_READ_1_4_4_DTR BIT(10)
+#define SNOR_HWCPAS_READ_OCTO GENMASK(14, 11) +#define SNOR_HWCAPS_READ_1_1_8 BIT(11) +#define SNOR_HWCAPS_READ_1_8_8 BIT(12) +#define SNOR_HWCAPS_READ_8_8_8 BIT(13) +#define SNOR_HWCAPS_READ_1_8_8_DTR BIT(14)
- Page Program capabilities.
- Like (Fast) Read capabilities, Octo/Quad SPI protocols are preferred to the
- legacy SPI 1-1-1 protocol.
- Note that Dual Page Programs are not supported because there is no existing
- JEDEC/SFDP standard to define them. Also at this moment no SPI flash memory
- implements such commands.
+#define SNOR_HWCAPS_PP_MASK GENMASK(22, 16) +#define SNOR_HWCAPS_PP BIT(16)
+#define SNOR_HWCAPS_PP_QUAD GENMASK(19, 17) +#define SNOR_HWCAPS_PP_1_1_4 BIT(17) +#define SNOR_HWCAPS_PP_1_4_4 BIT(18) +#define SNOR_HWCAPS_PP_4_4_4 BIT(19)
+#define SNOR_HWCAPS_PP_OCTO GENMASK(22, 20) +#define SNOR_HWCAPS_PP_1_1_8 BIT(20) +#define SNOR_HWCAPS_PP_1_8_8 BIT(21) +#define SNOR_HWCAPS_PP_8_8_8 BIT(22)
- spi_nor_scan() - scan the SPI NOR
- @nor: the spi_nor structure
- The drivers can use this function to scan the SPI NOR.
- In the scanning, it will try to get all the necessary information to
- fill the mtd_info{} and the spi_nor{}.
- Return: 0 for success, others for failure.
+int spi_nor_scan(struct spi_nor *nor);
- spi_nor_restore_addr_mode() - restore the status of SPI NOR
+void spi_nor_restore(struct spi_nor *nor);
Switch spi_flash_* interfaces to call into new SPI NOR framework via MTD layer. Fix up sf_dataflash to work in legacy way. And update sandbox to use new interfaces/defintions
Signed-off-by: Vignesh R vigneshr@ti.com --- common/spl/Kconfig | 7 + drivers/mtd/spi/Kconfig | 8 ++ drivers/mtd/spi/Makefile | 4 +- drivers/mtd/spi/sandbox.c | 36 +++--- drivers/mtd/spi/sf_dataflash.c | 11 +- drivers/mtd/spi/sf_internal.h | 228 +++++++-------------------------- drivers/mtd/spi/sf_probe.c | 33 +++-- drivers/mtd/spi/spi-nor.c | 59 +-------- drivers/spi/stm32_qspi.c | 4 +- include/spi_flash.h | 105 ++++----------- 10 files changed, 130 insertions(+), 365 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 0ddbffc7d1c6..2b6f315b1cf3 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -727,6 +727,13 @@ config SPL_SPI_FLASH_SUPPORT lines). This enables the drivers in drivers/mtd/spi as part of an SPL build. This normally requires SPL_SPI_SUPPORT.
+config SPL_SPI_FLASH_SFDP_SUPPORT + bool "SFDP table parsing support for SPI NOR flashes" + help + Enable support for parsing and auto discovery of parameters for + SPI NOR flashes using Serial Flash Discoverable Parameters (SFDP) + tables as per JESD216 standard in SPL. + config SPL_SPI_LOAD bool "Support loading from SPI flash" depends on SPL_SPI_FLASH_SUPPORT diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index 76d5a1d11527..d735884b48db 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -27,6 +27,7 @@ config SPI_FLASH_SANDBOX
config SPI_FLASH bool "Legacy SPI Flash Interface support" + select SPI_MEM help Enable the legacy SPI flash support. This will include basic standard support for things like probing, read / write, and @@ -34,6 +35,13 @@ config SPI_FLASH
If unsure, say N
+config SPI_FLASH_SFDP_SUPPORT + bool "SFDP table parsing support for SPI NOR flashes" + help + Enable support for parsing and auto discovery of parameters for + SPI NOR flashes using Serial Flash Discoverable Parameters (SFDP) + tables as per JESD216 standard. + config SPI_FLASH_BAR bool "SPI flash Bank/Extended address register support" depends on SPI_FLASH diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index b4c7e1c98bd5..9cd6672e93ce 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -9,7 +9,7 @@ ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SPL_SPI_BOOT) += fsl_espi_spl.o endif
-obj-$(CONFIG_SPI_FLASH) += sf_probe.o spi_flash.o spi_flash_ids.o sf.o -obj-$(CONFIG_SPI_FLASH_DATAFLASH) += sf_dataflash.o +obj-$(CONFIG_SPI_FLASH) += sf_probe.o spi-nor.o +obj-$(CONFIG_SPI_FLASH_DATAFLASH) += sf_dataflash.o sf.o obj-$(CONFIG_SPI_FLASH_MTD) += sf_mtd.o obj-$(CONFIG_SPI_FLASH_SANDBOX) += sandbox.o diff --git a/drivers/mtd/spi/sandbox.c b/drivers/mtd/spi/sandbox.c index 7b9891cb981c..084c66e9840b 100644 --- a/drivers/mtd/spi/sandbox.c +++ b/drivers/mtd/spi/sandbox.c @@ -92,7 +92,7 @@ struct sandbox_spi_flash { /* The current flash status (see STAT_XXX defines above) */ u16 status; /* Data describing the flash we're emulating */ - const struct spi_flash_info *data; + const struct flash_info *data; /* The file on disk to serv up data from */ int fd; }; @@ -122,7 +122,7 @@ static int sandbox_sf_probe(struct udevice *dev) /* spec = idcode:file */ struct sandbox_spi_flash *sbsf = dev_get_priv(dev); size_t len, idname_len; - const struct spi_flash_info *data; + const struct flash_info *data; struct sandbox_spi_flash_plat_data *pdata = dev_get_platdata(dev); struct sandbox_state *state = state_get_current(); struct dm_spi_slave_platdata *slave_plat; @@ -155,7 +155,7 @@ static int sandbox_sf_probe(struct udevice *dev) idname_len = strlen(spec); debug("%s: device='%s'\n", __func__, spec);
- for (data = spi_flash_ids; data->name; data++) { + for (data = spi_nor_ids; data->name; data++) { len = strlen(data->name); if (idname_len != len) continue; @@ -243,43 +243,43 @@ static int sandbox_sf_process_cmd(struct sandbox_spi_flash *sbsf, const u8 *rx,
sbsf->cmd = rx[0]; switch (sbsf->cmd) { - case CMD_READ_ID: + case SPINOR_OP_RDID: sbsf->state = SF_ID; sbsf->cmd = SF_ID; break; - case CMD_READ_ARRAY_FAST: + case SPINOR_OP_READ_FAST: sbsf->pad_addr_bytes = 1; - case CMD_READ_ARRAY_SLOW: - case CMD_PAGE_PROGRAM: + case SPINOR_OP_READ: + case SPINOR_OP_PP: sbsf->state = SF_ADDR; break; - case CMD_WRITE_DISABLE: + case SPINOR_OP_WRDI: debug(" write disabled\n"); sbsf->status &= ~STAT_WEL; break; - case CMD_READ_STATUS: + case SPINOR_OP_RDSR: sbsf->state = SF_READ_STATUS; break; - case CMD_READ_STATUS1: + case SPINOR_OP_RDSR2: sbsf->state = SF_READ_STATUS1; break; - case CMD_WRITE_ENABLE: + case SPINOR_OP_WREN: debug(" write enabled\n"); sbsf->status |= STAT_WEL; break; - case CMD_WRITE_STATUS: + case SPINOR_OP_WRSR: sbsf->state = SF_WRITE_STATUS; break; default: { int flags = sbsf->data->flags;
/* we only support erase here */ - if (sbsf->cmd == CMD_ERASE_CHIP) { + if (sbsf->cmd == SPINOR_OP_CHIP_ERASE) { sbsf->erase_size = sbsf->data->sector_size * sbsf->data->n_sectors; - } else if (sbsf->cmd == CMD_ERASE_4K && (flags & SECT_4K)) { + } else if (sbsf->cmd == SPINOR_OP_BE_4K && (flags & SECT_4K)) { sbsf->erase_size = 4 << 10; - } else if (sbsf->cmd == CMD_ERASE_64K && !(flags & SECT_4K)) { + } else if (sbsf->cmd == SPINOR_OP_SE && !(flags & SECT_4K)) { sbsf->erase_size = 64 << 10; } else { debug(" cmd unknown: %#x\n", sbsf->cmd); @@ -380,11 +380,11 @@ static int sandbox_sf_xfer(struct udevice *dev, unsigned int bitlen, return -EIO; } switch (sbsf->cmd) { - case CMD_READ_ARRAY_FAST: - case CMD_READ_ARRAY_SLOW: + case SPINOR_OP_READ_FAST: + case SPINOR_OP_READ: sbsf->state = SF_READ; break; - case CMD_PAGE_PROGRAM: + case SPINOR_OP_PP: sbsf->state = SF_WRITE; break; default: diff --git a/drivers/mtd/spi/sf_dataflash.c b/drivers/mtd/spi/sf_dataflash.c index 4a60c1b2b43a..b6a2631747a9 100644 --- a/drivers/mtd/spi/sf_dataflash.c +++ b/drivers/mtd/spi/sf_dataflash.c @@ -18,6 +18,7 @@
#include "sf_internal.h"
+#define CMD_READ_ID 0x9f /* reads can bypass the buffers */ #define OP_READ_CONTINUOUS 0xE8 #define OP_READ_PAGE 0xD2 @@ -441,7 +442,7 @@ static int add_dataflash(struct udevice *dev, char *name, int nr_pages, return 0; }
-struct flash_info { +struct data_flash_info { char *name;
/* @@ -460,7 +461,7 @@ struct flash_info { #define IS_POW2PS 0x0001 /* uses 2^N byte pages */ };
-static struct flash_info dataflash_data[] = { +static struct data_flash_info dataflash_data[] = { /* * NOTE: chips with SUP_POW2PS (rev D and up) need two entries, * one with IS_POW2PS and the other without. The entry with the @@ -501,12 +502,12 @@ static struct flash_info dataflash_data[] = { { "at45db642d", 0x1f2800, 8192, 1024, 10, SUP_POW2PS | IS_POW2PS}, };
-static struct flash_info *jedec_probe(struct spi_slave *spi) +static struct data_flash_info *jedec_probe(struct spi_slave *spi) { int tmp; uint8_t id[5]; uint32_t jedec; - struct flash_info *info; + struct data_flash_info *info; int status;
/* @@ -583,7 +584,7 @@ static int spi_dataflash_probe(struct udevice *dev) { struct spi_slave *spi = dev_get_parent_priv(dev); struct spi_flash *spi_flash; - struct flash_info *info; + struct data_flash_info *info; int status;
spi_flash = dev_get_uclass_priv(dev); diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 46a504441751..55619f5aea5c 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -12,142 +12,66 @@ #include <linux/types.h> #include <linux/compiler.h>
-/* Dual SPI flash memories - see SPI_COMM_DUAL_... */ -enum spi_dual_flash { - SF_SINGLE_FLASH = 0, - SF_DUAL_STACKED_FLASH = BIT(0), - SF_DUAL_PARALLEL_FLASH = BIT(1), -}; - -enum spi_nor_option_flags { - SNOR_F_SST_WR = BIT(0), - SNOR_F_USE_FSR = BIT(1), - SNOR_F_USE_UPAGE = BIT(3), -}; - -#define SPI_FLASH_3B_ADDR_LEN 3 -#define SPI_FLASH_CMD_LEN (1 + SPI_FLASH_3B_ADDR_LEN) -#define SPI_FLASH_16MB_BOUN 0x1000000 - -/* CFI Manufacture ID's */ -#define SPI_FLASH_CFI_MFR_SPANSION 0x01 -#define SPI_FLASH_CFI_MFR_STMICRO 0x20 -#define SPI_FLASH_CFI_MFR_MICRON 0x2C -#define SPI_FLASH_CFI_MFR_MACRONIX 0xc2 -#define SPI_FLASH_CFI_MFR_SST 0xbf -#define SPI_FLASH_CFI_MFR_WINBOND 0xef -#define SPI_FLASH_CFI_MFR_ATMEL 0x1f - -/* Erase commands */ -#define CMD_ERASE_4K 0x20 -#define CMD_ERASE_CHIP 0xc7 -#define CMD_ERASE_64K 0xd8 - -/* Write commands */ -#define CMD_WRITE_STATUS 0x01 -#define CMD_PAGE_PROGRAM 0x02 -#define CMD_WRITE_DISABLE 0x04 -#define CMD_WRITE_ENABLE 0x06 -#define CMD_QUAD_PAGE_PROGRAM 0x32 - -/* Read commands */ -#define CMD_READ_ARRAY_SLOW 0x03 -#define CMD_READ_ARRAY_FAST 0x0b -#define CMD_READ_DUAL_OUTPUT_FAST 0x3b -#define CMD_READ_DUAL_IO_FAST 0xbb -#define CMD_READ_QUAD_OUTPUT_FAST 0x6b -#define CMD_READ_QUAD_IO_FAST 0xeb -#define CMD_READ_ID 0x9f -#define CMD_READ_STATUS 0x05 -#define CMD_READ_STATUS1 0x35 -#define CMD_READ_CONFIG 0x35 -#define CMD_FLAG_STATUS 0x70 - -/* Bank addr access commands */ -#ifdef CONFIG_SPI_FLASH_BAR -# define CMD_BANKADDR_BRWR 0x17 -# define CMD_BANKADDR_BRRD 0x16 -# define CMD_EXTNADDR_WREAR 0xC5 -# define CMD_EXTNADDR_RDEAR 0xC8 -#endif +#define SPI_NOR_MAX_ID_LEN 6 +#define SPI_NOR_MAX_ADDR_WIDTH 4
-/* Common status */ -#define STATUS_WIP BIT(0) -#define STATUS_QEB_WINSPAN BIT(1) -#define STATUS_QEB_MXIC BIT(6) -#define STATUS_PEC BIT(7) -#define SR_BP0 BIT(2) /* Block protect 0 */ -#define SR_BP1 BIT(3) /* Block protect 1 */ -#define SR_BP2 BIT(4) /* Block protect 2 */ - -/* Flash timeout values */ -#define SPI_FLASH_PROG_TIMEOUT (2 * CONFIG_SYS_HZ) -#define SPI_FLASH_PAGE_ERASE_TIMEOUT (5 * CONFIG_SYS_HZ) -#define SPI_FLASH_SECTOR_ERASE_TIMEOUT (10 * CONFIG_SYS_HZ) - -/* SST specific */ -#ifdef CONFIG_SPI_FLASH_SST -#define SST26_CMD_READ_BPR 0x72 -#define SST26_CMD_WRITE_BPR 0x42 - -#define SST26_BPR_8K_NUM 4 -#define SST26_MAX_BPR_REG_LEN (18 + 1) -#define SST26_BOUND_REG_SIZE ((32 + SST26_BPR_8K_NUM * 8) * SZ_1K) - -enum lock_ctl { - SST26_CTL_LOCK, - SST26_CTL_UNLOCK, - SST26_CTL_CHECK -}; - -# define CMD_SST_BP 0x02 /* Byte Program */ -# define CMD_SST_AAI_WP 0xAD /* Auto Address Incr Word Program */ - -int sst_write_wp(struct spi_flash *flash, u32 offset, size_t len, - const void *buf); -int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, - const void *buf); -#endif - -#define JEDEC_MFR(info) ((info)->id[0]) -#define JEDEC_ID(info) (((info)->id[1]) << 8 | ((info)->id[2])) -#define JEDEC_EXT(info) (((info)->id[3]) << 8 | ((info)->id[4])) -#define SPI_FLASH_MAX_ID_LEN 6 - -struct spi_flash_info { - /* Device name ([MANUFLETTER][DEVTYPE][DENSITY][EXTRAINFO]) */ - const char *name; +struct flash_info { + char *name;
/* * This array stores the ID bytes. * The first three bytes are the JEDIC ID. * JEDEC ID zero means "no ID" (mostly older chips). */ - u8 id[SPI_FLASH_MAX_ID_LEN]; + u8 id[SPI_NOR_MAX_ID_LEN]; u8 id_len;
- /* - * The size listed here is what works with SPINOR_OP_SE, which isn't + /* The size listed here is what works with SPINOR_OP_SE, which isn't * necessarily called a "sector" by the vendor. */ - u32 sector_size; - u32 n_sectors; + unsigned int sector_size; + u16 n_sectors;
u16 page_size; + u16 addr_width;
u16 flags; -#define SECT_4K BIT(0) /* CMD_ERASE_4K works uniformly */ -#define E_FSR BIT(1) /* use flag status register for */ -#define SST_WR BIT(2) /* use SST byte/word programming */ -#define WR_QPP BIT(3) /* use Quad Page Program */ -#define RD_QUAD BIT(4) /* use Quad Read */ -#define RD_DUAL BIT(5) /* use Dual Read */ -#define RD_QUADIO BIT(6) /* use Quad IO Read */ -#define RD_DUALIO BIT(7) /* use Dual IO Read */ -#define RD_FULL (RD_QUAD | RD_DUAL | RD_QUADIO | RD_DUALIO) +#define SECT_4K BIT(0) /* SPINOR_OP_BE_4K works uniformly */ +#define SPI_NOR_NO_ERASE BIT(1) /* No erase command needed */ +#define SST_WRITE BIT(2) /* use SST byte programming */ +#define SPI_NOR_NO_FR BIT(3) /* Can't do fastread */ +#define SECT_4K_PMC BIT(4) /* SPINOR_OP_BE_4K_PMC works uniformly */ +#define SPI_NOR_DUAL_READ BIT(5) /* Flash supports Dual Read */ +#define SPI_NOR_QUAD_READ BIT(6) /* Flash supports Quad Read */ +#define USE_FSR BIT(7) /* use flag status register */ +#define SPI_NOR_HAS_LOCK BIT(8) /* Flash supports lock/unlock via SR */ +#define SPI_NOR_HAS_TB BIT(9) /* + * Flash SR has Top/Bottom (TB) protect + * bit. Must be used with + * SPI_NOR_HAS_LOCK. + */ +#define SPI_S3AN BIT(10) /* + * Xilinx Spartan 3AN In-System Flash + * (MFR cannot be used for probing + * because it has the same value as + * ATMEL flashes) + */ +#define SPI_NOR_4B_OPCODES BIT(11) /* + * Use dedicated 4byte address op codes + * to support memory size above 128Mib. + */ +#define NO_CHIP_ERASE BIT(12) /* Chip does not support chip erase */ +#define SPI_NOR_SKIP_SFDP BIT(13) /* Skip parsing of SFDP tables */ +#define USE_CLSR BIT(14) /* use CLSR command */ +#ifndef __UBOOT__ + int (*quad_enable)(struct spi_nor *nor); +#endif };
-extern const struct spi_flash_info spi_flash_ids[]; +extern const struct flash_info spi_nor_ids[]; + +#define JEDEC_MFR(info) ((info)->id[0]) +#define JEDEC_ID(info) (((info)->id[1]) << 8 | ((info)->id[2]))
/* Send a single-byte command to the device and read the response */ int spi_flash_cmd(struct spi_slave *spi, u8 cmd, void *response, size_t len); @@ -167,78 +91,12 @@ int spi_flash_cmd_write(struct spi_slave *spi, const u8 *cmd, size_t cmd_len, const void *data, size_t data_len);
-/* Flash erase(sectors) operation, support all possible erase commands */ -int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len); - /* Get software write-protect value (BP bits) */ int spi_flash_cmd_get_sw_write_prot(struct spi_flash *flash);
-/* Lock stmicro spi flash region */ -int stm_lock(struct spi_flash *flash, u32 ofs, size_t len); - -/* Unlock stmicro spi flash region */ -int stm_unlock(struct spi_flash *flash, u32 ofs, size_t len); - -/* Check if a stmicro spi flash region is completely locked */ -int stm_is_locked(struct spi_flash *flash, u32 ofs, size_t len); - -/* Enable writing on the SPI flash */ -static inline int spi_flash_cmd_write_enable(struct spi_flash *flash) -{ - return spi_flash_cmd(flash->spi, CMD_WRITE_ENABLE, NULL, 0); -} - -/* Disable writing on the SPI flash */ -static inline int spi_flash_cmd_write_disable(struct spi_flash *flash) -{ - return spi_flash_cmd(flash->spi, CMD_WRITE_DISABLE, NULL, 0); -} - -/* - * Used for spi_flash write operation - * - SPI claim - * - spi_flash_cmd_write_enable - * - spi_flash_cmd_write - * - spi_flash_wait_till_ready - * - SPI release - */ -int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd, - size_t cmd_len, const void *buf, size_t buf_len); - -/* - * Flash write operation, support all possible write commands. - * Write the requested data out breaking it up into multiple write - * commands as needed per the write size. - */ -int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset, - size_t len, const void *buf); - -/* - * Same as spi_flash_cmd_read() except it also claims/releases the SPI - * bus. Used as common part of the ->read() operation. - */ -int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, - size_t cmd_len, void *data, size_t data_len); - -/* Flash read operation, support all possible read commands */ -int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, - size_t len, void *data);
#ifdef CONFIG_SPI_FLASH_MTD int spi_flash_mtd_register(struct spi_flash *flash); void spi_flash_mtd_unregister(void); #endif - -/** - * spi_flash_scan - scan the SPI FLASH - * @flash: the spi flash structure - * - * The drivers can use this fuction to scan the SPI FLASH. - * In the scanning, it will try to get all the necessary information to - * fill the spi_flash{}. - * - * Return: 0 for success, others for failure. - */ -int spi_flash_scan(struct spi_flash *flash); - #endif /* _SF_INTERNAL_H_ */ diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 5a2e932de8f8..c4c25a7e8403 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -40,7 +40,7 @@ static int spi_flash_probe_slave(struct spi_flash *flash) return ret; }
- ret = spi_flash_scan(flash); + ret = spi_nor_scan(flash); if (ret) goto err_read_id;
@@ -96,32 +96,38 @@ static int spi_flash_std_read(struct udevice *dev, u32 offset, size_t len, void *buf) { struct spi_flash *flash = dev_get_uclass_priv(dev); + struct mtd_info *mtd = &flash->mtd; + size_t retlen;
- return log_ret(spi_flash_cmd_read_ops(flash, offset, len, buf)); + return log_ret(mtd->_read(mtd, offset, len, &retlen, buf)); }
static int spi_flash_std_write(struct udevice *dev, u32 offset, size_t len, const void *buf) { struct spi_flash *flash = dev_get_uclass_priv(dev); + struct mtd_info *mtd = &flash->mtd; + size_t retlen;
-#if defined(CONFIG_SPI_FLASH_SST) - if (flash->flags & SNOR_F_SST_WR) { - if (flash->spi->mode & SPI_TX_BYTE) - return sst_write_bp(flash, offset, len, buf); - else - return sst_write_wp(flash, offset, len, buf); - } -#endif - - return spi_flash_cmd_write_ops(flash, offset, len, buf); + return mtd->_write(mtd, offset, len, &retlen, buf); }
static int spi_flash_std_erase(struct udevice *dev, u32 offset, size_t len) { struct spi_flash *flash = dev_get_uclass_priv(dev); + struct mtd_info *mtd = &flash->mtd; + struct erase_info instr; + + if (offset % mtd->erasesize || len % mtd->erasesize) { + printf("SF: Erase offset/length not multiple of erase size\n"); + return -EINVAL; + } + + memset(&instr, 0, sizeof(instr)); + instr.addr = offset; + instr.len = len;
- return spi_flash_cmd_erase_ops(flash, offset, len); + return mtd->_erase(mtd, &instr); }
static int spi_flash_std_get_sw_write_prot(struct udevice *dev) @@ -153,6 +159,7 @@ static const struct dm_spi_flash_ops spi_flash_std_ops = {
static const struct udevice_id spi_flash_std_ids[] = { { .compatible = "spi-flash" }, + { .compatible = "jedec,spi-nor" }, { } };
diff --git a/drivers/mtd/spi/spi-nor.c b/drivers/mtd/spi/spi-nor.c index ff79601a8896..a192087882a1 100644 --- a/drivers/mtd/spi/spi-nor.c +++ b/drivers/mtd/spi/spi-nor.c @@ -21,6 +21,8 @@ #include <spi-mem.h> #include <spi.h>
+#include "sf_internal.h" + /* Define max times to check status register before we give up. */
/* @@ -32,63 +34,6 @@
#define DEFAULT_READY_WAIT_JIFFIES (40UL * HZ)
-#define SPI_NOR_MAX_ID_LEN 6 -#define SPI_NOR_MAX_ADDR_WIDTH 4 - -struct flash_info { - char *name; - - /* - * This array stores the ID bytes. - * The first three bytes are the JEDIC ID. - * JEDEC ID zero means "no ID" (mostly older chips). - */ - u8 id[SPI_NOR_MAX_ID_LEN]; - u8 id_len; - - /* The size listed here is what works with SPINOR_OP_SE, which isn't - * necessarily called a "sector" by the vendor. - */ - unsigned int sector_size; - u16 n_sectors; - - u16 page_size; - u16 addr_width; - - u16 flags; -#define SECT_4K BIT(0) /* SPINOR_OP_BE_4K works uniformly */ -#define SPI_NOR_NO_ERASE BIT(1) /* No erase command needed */ -#define SST_WRITE BIT(2) /* use SST byte programming */ -#define SPI_NOR_NO_FR BIT(3) /* Can't do fastread */ -#define SECT_4K_PMC BIT(4) /* SPINOR_OP_BE_4K_PMC works uniformly */ -#define SPI_NOR_DUAL_READ BIT(5) /* Flash supports Dual Read */ -#define SPI_NOR_QUAD_READ BIT(6) /* Flash supports Quad Read */ -#define USE_FSR BIT(7) /* use flag status register */ -#define SPI_NOR_HAS_LOCK BIT(8) /* Flash supports lock/unlock via SR */ -#define SPI_NOR_HAS_TB BIT(9) /* - * Flash SR has Top/Bottom (TB) protect - * bit. Must be used with - * SPI_NOR_HAS_LOCK. - */ -#define SPI_S3AN BIT(10) /* - * Xilinx Spartan 3AN In-System Flash - * (MFR cannot be used for probing - * because it has the same value as - * ATMEL flashes) - */ -#define SPI_NOR_4B_OPCODES BIT(11) /* - * Use dedicated 4byte address op codes - * to support memory size above 128Mib. - */ -#define NO_CHIP_ERASE BIT(12) /* Chip does not support chip erase */ -#define SPI_NOR_SKIP_SFDP BIT(13) /* Skip parsing of SFDP tables */ -#define USE_CLSR BIT(14) /* use CLSR command */ - - int (*quad_enable)(struct spi_nor *nor); -}; - -#define JEDEC_MFR(info) ((info)->id[0]) - static int spi_nor_read_write_reg(struct spi_nor *nor, struct spi_mem_op *op, void *buf) { diff --git a/drivers/spi/stm32_qspi.c b/drivers/spi/stm32_qspi.c index 3b92254a5ce1..8b60d7c3b224 100644 --- a/drivers/spi/stm32_qspi.c +++ b/drivers/spi/stm32_qspi.c @@ -271,9 +271,9 @@ static void _stm32_qspi_enable_mmap(struct stm32_qspi_priv *priv, { unsigned int ccr_reg;
- priv->command = flash->read_cmd | CMD_HAS_ADR | CMD_HAS_DATA + priv->command = flash->read_opcode | CMD_HAS_ADR | CMD_HAS_DATA | CMD_HAS_DUMMY; - priv->dummycycles = flash->dummy_byte * 8; + priv->dummycycles = flash->read_dummy;
ccr_reg = _stm32_qspi_gen_ccr(priv, STM32_QSPI_CCR_MEM_MAP);
diff --git a/include/spi_flash.h b/include/spi_flash.h index e427e960d54f..7f691e8559cd 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -11,6 +11,7 @@
#include <dm.h> /* Because we dereference struct udevice here */ #include <linux/types.h> +#include <linux/mtd/spi-nor.h>
#ifndef CONFIG_SF_DEFAULT_SPEED # define CONFIG_SF_DEFAULT_SPEED 1000000 @@ -27,86 +28,6 @@
struct spi_slave;
-/** - * struct spi_flash - SPI flash structure - * - * @spi: SPI slave - * @dev: SPI flash device - * @name: Name of SPI flash - * @dual_flash: Indicates dual flash memories - dual stacked, parallel - * @shift: Flash shift useful in dual parallel - * @flags: Indication of spi flash flags - * @size: Total flash size - * @page_size: Write (page) size - * @sector_size: Sector size - * @erase_size: Erase size - * @bank_read_cmd: Bank read cmd - * @bank_write_cmd: Bank write cmd - * @bank_curr: Current flash bank - * @erase_cmd: Erase cmd 4K, 32K, 64K - * @read_cmd: Read cmd - Array Fast, Extn read and quad read. - * @write_cmd: Write cmd - page and quad program. - * @dummy_byte: Dummy cycles for read operation. - * @memory_map: Address of read-only SPI flash access - * @flash_lock: lock a region of the SPI Flash - * @flash_unlock: unlock a region of the SPI Flash - * @flash_is_locked: check if a region of the SPI Flash is completely locked - * @read: Flash read ops: Read len bytes at offset into buf - * Supported cmds: Fast Array Read - * @write: Flash write ops: Write len bytes from buf into offset - * Supported cmds: Page Program - * @erase: Flash erase ops: Erase len bytes from offset - * Supported cmds: Sector erase 4K, 32K, 64K - * return 0 - Success, 1 - Failure - */ -struct spi_flash { - struct spi_slave *spi; -#ifdef CONFIG_DM_SPI_FLASH - struct udevice *dev; -#endif - const char *name; - u8 dual_flash; - u8 shift; - u16 flags; - - u32 size; - u32 page_size; - u32 sector_size; - u32 erase_size; -#ifdef CONFIG_SPI_FLASH_BAR - u8 bank_read_cmd; - u8 bank_write_cmd; - u8 bank_curr; -#endif - u8 erase_cmd; - u8 read_cmd; - u8 write_cmd; - u8 dummy_byte; - - void *memory_map; - - int (*flash_lock)(struct spi_flash *flash, u32 ofs, size_t len); - int (*flash_unlock)(struct spi_flash *flash, u32 ofs, size_t len); - int (*flash_is_locked)(struct spi_flash *flash, u32 ofs, size_t len); -#ifndef CONFIG_DM_SPI_FLASH - /* - * These are not strictly needed for driver model, but keep them here - * while the transition is in progress. - * - * Normally each driver would provide its own operations, but for - * SPI flash most chips use the same algorithms. One approach is - * to create a 'common' SPI flash device which knows how to talk - * to most devices, and then allow other drivers to be used instead - * if required, perhaps with a way of scanning through the list to - * find the driver that matches the device. - */ - int (*read)(struct spi_flash *flash, u32 offset, size_t len, void *buf); - int (*write)(struct spi_flash *flash, u32 offset, size_t len, - const void *buf); - int (*erase)(struct spi_flash *flash, u32 offset, size_t len); -#endif -}; - struct dm_spi_flash_ops { int (*read)(struct udevice *dev, u32 offset, size_t len, void *buf); int (*write)(struct udevice *dev, u32 offset, size_t len, @@ -225,19 +146,37 @@ void spi_flash_free(struct spi_flash *flash); static inline int spi_flash_read(struct spi_flash *flash, u32 offset, size_t len, void *buf) { - return flash->read(flash, offset, len, buf); + struct mtd_info *mtd = &flash->mtd; + size_t retlen; + + return mtd->_read(mtd, offset, len, &retlen, buf); }
static inline int spi_flash_write(struct spi_flash *flash, u32 offset, size_t len, const void *buf) { - return flash->write(flash, offset, len, buf); + struct mtd_info *mtd = &flash->mtd; + size_t retlen; + + return mtd->_write(mtd, offset, len, &retlen, buf); }
static inline int spi_flash_erase(struct spi_flash *flash, u32 offset, size_t len) { - return flash->erase(flash, offset, len); + struct mtd_info *mtd = &flash->mtd; + struct erase_info instr; + + if (offset % mtd->erasesize || len % mtd->erasesize) { + printf("SF: Erase offset/length not multiple of erase size\n"); + return -EINVAL; + } + + memset(&instr, 0, sizeof(instr)); + instr.addr = offset; + instr.len = len; + + return mtd->_erase(mtd, &instr); } #endif
help
I know other options are like this, too, but I would prefer it if this option was disabled or hidden when SPL_SPI_FLASH_SUPPORT is disabled.
If unsure, say N
help
case CMD_READ_ID:
case SPINOR_OP_WRSR: sbsf->state = SF_WRITE_STATUS; break; default: { int flags = sbsf->data->flags; /* we only support erase here */
struct data_flash_info *info; int status; /*
struct data_flash_info *info; int status; spi_flash = dev_get_uclass_priv(dev);
-enum lock_ctl {
SST26_CTL_LOCK,
SST26_CTL_UNLOCK,
SST26_CTL_CHECK
const void *buf);
const void *buf);
-#endif
const char *name;
char *name; /* * This array stores the ID bytes. * The first three bytes are the JEDIC ID. * JEDEC ID zero means "no ID" (mostly older chips). */
u32 sector_size;
u32 n_sectors;
u16 n_sectors; u16 page_size;
u16 addr_width; u16 flags;
* SPI_NOR_HAS_LOCK.
* ATMEL flashes)
+#endif };
- Used for spi_flash write operation
- SPI claim
- SPI release
- Flash write operation, support all possible write commands.
- Write the requested data out breaking it up into multiple write
- commands as needed per the write size.
- Same as spi_flash_cmd_read() except it also claims/releases the SPI
- bus. Used as common part of the ->read() operation.
- spi_flash_scan - scan the SPI FLASH
- @flash: the spi flash structure
- The drivers can use this fuction to scan the SPI FLASH.
- fill the spi_flash{}.
size_t retlen;
size_t retlen;
else
-#endif
return -EINVAL;
instr.len = len;
char *name;
u8 id_len;
u16 n_sectors;
u16 page_size;
u16 addr_width;
u16 flags;
* SPI_NOR_HAS_LOCK.
* ATMEL flashes)
priv->dummycycles = flash->read_dummy; ccr_reg = _stm32_qspi_gen_ccr(priv, STM32_QSPI_CCR_MEM_MAP);
struct spi_slave;
- struct spi_flash - SPI flash structure
- @spi: SPI slave
- @dev: SPI flash device
- @name: Name of SPI flash
- @dual_flash: Indicates dual flash memories - dual stacked, parallel
- @shift: Flash shift useful in dual parallel
- @flags: Indication of spi flash flags
- @size: Total flash size
- @page_size: Write (page) size
- @sector_size: Sector size
- @erase_size: Erase size
- @bank_read_cmd: Bank read cmd
- @bank_write_cmd: Bank write cmd
- @bank_curr: Current flash bank
- @erase_cmd: Erase cmd 4K, 32K, 64K
- @read_cmd: Read cmd - Array Fast, Extn read and quad read.
- @write_cmd: Write cmd - page and quad program.
- @dummy_byte: Dummy cycles for read operation.
- @memory_map: Address of read-only SPI flash access
- @flash_lock: lock a region of the SPI Flash
- @flash_unlock: unlock a region of the SPI Flash
- @flash_is_locked: check if a region of the SPI Flash is completely locked
- @read: Flash read ops: Read len bytes at offset into buf
- @write: Flash write ops: Write len bytes from buf into offset
- @erase: Flash erase ops: Erase len bytes from offset
- return 0 - Success, 1 - Failure
-struct spi_flash {
-#endif
const char *name;
u8 dual_flash;
u8 shift;
u16 flags;
u32 size;
u32 page_size;
u32 sector_size;
u32 erase_size;
u8 bank_read_cmd;
u8 bank_write_cmd;
u8 bank_curr;
-#endif
u8 erase_cmd;
u8 read_cmd;
u8 write_cmd;
u8 dummy_byte;
void *memory_map;
const void *buf);
-#endif -};
size_t retlen;
size_t retlen;
return -EINVAL;
instr.len = len;
} #endif
-- 2.19.2
help
I agree, will fix that in next revision.
Regards Vignesh
If unsure, say N
help
case CMD_READ_ID:
-enum lock_ctl {
SST26_CTL_LOCK,
SST26_CTL_UNLOCK,
SST26_CTL_CHECK
const void *buf);
const void *buf);
-#endif
const char *name;
u32 sector_size;
u32 n_sectors;
* SPI_NOR_HAS_LOCK.
* ATMEL flashes)
+#endif };
- SPI claim
- SPI release
size_t retlen;
size_t retlen;
else
-#endif
return -EINVAL;
instr.len = len;
char *name;
u8 id_len;
u16 n_sectors;
u16 page_size;
u16 addr_width;
u16 flags;
* SPI_NOR_HAS_LOCK.
* ATMEL flashes)
struct spi_slave;
- @spi: SPI slave
-struct spi_flash {
-#endif
const char *name;
u8 dual_flash;
u8 shift;
u16 flags;
u32 size;
u32 page_size;
u32 sector_size;
u32 erase_size;
u8 bank_read_cmd;
u8 bank_write_cmd;
u8 bank_curr;
-#endif
u8 erase_cmd;
u8 read_cmd;
u8 write_cmd;
u8 dummy_byte;
void *memory_map;
const void *buf);
-#endif -};
size_t retlen;
size_t retlen;
return -EINVAL;
instr.len = len;
} #endif
-- 2.19.2
spi_flash and spi_flash_ids are no longer needed after SPI NOR migration. Remove them.
Signed-off-by: Vignesh R vigneshr@ti.com --- drivers/mtd/spi/spi_flash.c | 1337 ------------------------------- drivers/mtd/spi/spi_flash_ids.c | 211 ----- 2 files changed, 1548 deletions(-) delete mode 100644 drivers/mtd/spi/spi_flash.c delete mode 100644 drivers/mtd/spi/spi_flash_ids.c
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c deleted file mode 100644 index 0c2392f28a43..000000000000 --- a/drivers/mtd/spi/spi_flash.c +++ /dev/null @@ -1,1337 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * SPI Flash Core - * - * Copyright (C) 2015 Jagan Teki jteki@openedev.com - * Copyright (C) 2013 Jagannadha Sutradharudu Teki, Xilinx Inc. - * Copyright (C) 2010 Reinhard Meyer, EMK Elektronik - * Copyright (C) 2008 Atmel Corporation - */ - -#include <common.h> -#include <errno.h> -#include <malloc.h> -#include <mapmem.h> -#include <spi.h> -#include <spi_flash.h> -#include <linux/log2.h> -#include <linux/sizes.h> -#include <dma.h> - -#include "sf_internal.h" - -static void spi_flash_addr(u32 addr, u8 *cmd) -{ - /* cmd[0] is actual command */ - cmd[1] = addr >> 16; - cmd[2] = addr >> 8; - cmd[3] = addr >> 0; -} - -static int read_sr(struct spi_flash *flash, u8 *rs) -{ - int ret; - u8 cmd; - - cmd = CMD_READ_STATUS; - ret = spi_flash_read_common(flash, &cmd, 1, rs, 1); - if (ret < 0) { - debug("SF: fail to read status register\n"); - return ret; - } - - return 0; -} - -static int read_fsr(struct spi_flash *flash, u8 *fsr) -{ - int ret; - const u8 cmd = CMD_FLAG_STATUS; - - ret = spi_flash_read_common(flash, &cmd, 1, fsr, 1); - if (ret < 0) { - debug("SF: fail to read flag status register\n"); - return ret; - } - - return 0; -} - -static int write_sr(struct spi_flash *flash, u8 ws) -{ - u8 cmd; - int ret; - - cmd = CMD_WRITE_STATUS; - ret = spi_flash_write_common(flash, &cmd, 1, &ws, 1); - if (ret < 0) { - debug("SF: fail to write status register\n"); - return ret; - } - - return 0; -} - -#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) -static int read_cr(struct spi_flash *flash, u8 *rc) -{ - int ret; - u8 cmd; - - cmd = CMD_READ_CONFIG; - ret = spi_flash_read_common(flash, &cmd, 1, rc, 1); - if (ret < 0) { - debug("SF: fail to read config register\n"); - return ret; - } - - return 0; -} - -static int write_cr(struct spi_flash *flash, u8 wc) -{ - u8 data[2]; - u8 cmd; - int ret; - - ret = read_sr(flash, &data[0]); - if (ret < 0) - return ret; - - cmd = CMD_WRITE_STATUS; - data[1] = wc; - ret = spi_flash_write_common(flash, &cmd, 1, &data, 2); - if (ret) { - debug("SF: fail to write config register\n"); - return ret; - } - - return 0; -} -#endif - -int spi_flash_cmd_get_sw_write_prot(struct spi_flash *flash) -{ - u8 status; - int ret; - - ret = read_sr(flash, &status); - if (ret) - return ret; - - return (status >> 2) & 7; -} - -#ifdef CONFIG_SPI_FLASH_BAR -/* - * This "clean_bar" is necessary in a situation when one was accessing - * spi flash memory > 16 MiB by using Bank Address Register's BA24 bit. - * - * After it the BA24 bit shall be cleared to allow access to correct - * memory region after SW reset (by calling "reset" command). - * - * Otherwise, the BA24 bit may be left set and then after reset, the - * ROM would read/write/erase SPL from 16 MiB * bank_sel address. - */ -static int clean_bar(struct spi_flash *flash) -{ - u8 cmd, bank_sel = 0; - - if (flash->bank_curr == 0) - return 0; - cmd = flash->bank_write_cmd; - flash->bank_curr = 0; - - return spi_flash_write_common(flash, &cmd, 1, &bank_sel, 1); -} - -static int write_bar(struct spi_flash *flash, u32 offset) -{ - u8 cmd, bank_sel; - int ret; - - bank_sel = offset / (SPI_FLASH_16MB_BOUN << flash->shift); - if (bank_sel == flash->bank_curr) - goto bar_end; - - cmd = flash->bank_write_cmd; - ret = spi_flash_write_common(flash, &cmd, 1, &bank_sel, 1); - if (ret < 0) { - debug("SF: fail to write bank register\n"); - return ret; - } - -bar_end: - flash->bank_curr = bank_sel; - return flash->bank_curr; -} - -static int read_bar(struct spi_flash *flash, const struct spi_flash_info *info) -{ - u8 curr_bank = 0; - int ret; - - if (flash->size <= SPI_FLASH_16MB_BOUN) - goto bar_end; - - switch (JEDEC_MFR(info)) { - case SPI_FLASH_CFI_MFR_SPANSION: - flash->bank_read_cmd = CMD_BANKADDR_BRRD; - flash->bank_write_cmd = CMD_BANKADDR_BRWR; - break; - default: - flash->bank_read_cmd = CMD_EXTNADDR_RDEAR; - flash->bank_write_cmd = CMD_EXTNADDR_WREAR; - } - - ret = spi_flash_read_common(flash, &flash->bank_read_cmd, 1, - &curr_bank, 1); - if (ret) { - debug("SF: fail to read bank addr register\n"); - return ret; - } - -bar_end: - flash->bank_curr = curr_bank; - return 0; -} -#endif - -#ifdef CONFIG_SF_DUAL_FLASH -static void spi_flash_dual(struct spi_flash *flash, u32 *addr) -{ - switch (flash->dual_flash) { - case SF_DUAL_STACKED_FLASH: - if (*addr >= (flash->size >> 1)) { - *addr -= flash->size >> 1; - flash->flags |= SNOR_F_USE_UPAGE; - } else { - flash->flags &= ~SNOR_F_USE_UPAGE; - } - break; - case SF_DUAL_PARALLEL_FLASH: - *addr >>= flash->shift; - break; - default: - debug("SF: Unsupported dual_flash=%d\n", flash->dual_flash); - break; - } -} -#endif - -static int spi_flash_sr_ready(struct spi_flash *flash) -{ - u8 sr; - int ret; - - ret = read_sr(flash, &sr); - if (ret < 0) - return ret; - - return !(sr & STATUS_WIP); -} - -static int spi_flash_fsr_ready(struct spi_flash *flash) -{ - u8 fsr; - int ret; - - ret = read_fsr(flash, &fsr); - if (ret < 0) - return ret; - - return fsr & STATUS_PEC; -} - -static int spi_flash_ready(struct spi_flash *flash) -{ - int sr, fsr; - - sr = spi_flash_sr_ready(flash); - if (sr < 0) - return sr; - - fsr = 1; - if (flash->flags & SNOR_F_USE_FSR) { - fsr = spi_flash_fsr_ready(flash); - if (fsr < 0) - return fsr; - } - - return sr && fsr; -} - -static int spi_flash_wait_till_ready(struct spi_flash *flash, - unsigned long timeout) -{ - unsigned long timebase; - int ret; - - timebase = get_timer(0); - - while (get_timer(timebase) < timeout) { - ret = spi_flash_ready(flash); - if (ret < 0) - return ret; - if (ret) - return 0; - } - - printf("SF: Timeout!\n"); - - return -ETIMEDOUT; -} - -int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd, - size_t cmd_len, const void *buf, size_t buf_len) -{ - struct spi_slave *spi = flash->spi; - unsigned long timeout = SPI_FLASH_PROG_TIMEOUT; - int ret; - - if (buf == NULL) - timeout = SPI_FLASH_PAGE_ERASE_TIMEOUT; - - ret = spi_claim_bus(spi); - if (ret) { - debug("SF: unable to claim SPI bus\n"); - return ret; - } - - ret = spi_flash_cmd_write_enable(flash); - if (ret < 0) { - debug("SF: enabling write failed\n"); - return ret; - } - - ret = spi_flash_cmd_write(spi, cmd, cmd_len, buf, buf_len); - if (ret < 0) { - debug("SF: write cmd failed\n"); - return ret; - } - - ret = spi_flash_wait_till_ready(flash, timeout); - if (ret < 0) { - debug("SF: write %s timed out\n", - timeout == SPI_FLASH_PROG_TIMEOUT ? - "program" : "page erase"); - return ret; - } - - spi_release_bus(spi); - - return ret; -} - -int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len) -{ - u32 erase_size, erase_addr; - u8 cmd[SPI_FLASH_CMD_LEN]; - int ret = -1; - - erase_size = flash->erase_size; - if (offset % erase_size || len % erase_size) { - printf("SF: Erase offset/length not multiple of erase size\n"); - return -1; - } - - if (flash->flash_is_locked) { - if (flash->flash_is_locked(flash, offset, len) > 0) { - printf("offset 0x%x is protected and cannot be erased\n", - offset); - return -EINVAL; - } - } - - cmd[0] = flash->erase_cmd; - while (len) { - erase_addr = offset; - -#ifdef CONFIG_SF_DUAL_FLASH - if (flash->dual_flash > SF_SINGLE_FLASH) - spi_flash_dual(flash, &erase_addr); -#endif -#ifdef CONFIG_SPI_FLASH_BAR - ret = write_bar(flash, erase_addr); - if (ret < 0) - return ret; -#endif - spi_flash_addr(erase_addr, cmd); - - debug("SF: erase %2x %2x %2x %2x (%x)\n", cmd[0], cmd[1], - cmd[2], cmd[3], erase_addr); - - ret = spi_flash_write_common(flash, cmd, sizeof(cmd), NULL, 0); - if (ret < 0) { - debug("SF: erase failed\n"); - break; - } - - offset += erase_size; - len -= erase_size; - } - -#ifdef CONFIG_SPI_FLASH_BAR - ret = clean_bar(flash); -#endif - - return ret; -} - -int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset, - size_t len, const void *buf) -{ - struct spi_slave *spi = flash->spi; - unsigned long byte_addr, page_size; - u32 write_addr; - size_t chunk_len, actual; - u8 cmd[SPI_FLASH_CMD_LEN]; - int ret = -1; - - page_size = flash->page_size; - - if (flash->flash_is_locked) { - if (flash->flash_is_locked(flash, offset, len) > 0) { - printf("offset 0x%x is protected and cannot be written\n", - offset); - return -EINVAL; - } - } - - cmd[0] = flash->write_cmd; - for (actual = 0; actual < len; actual += chunk_len) { - write_addr = offset; - -#ifdef CONFIG_SF_DUAL_FLASH - if (flash->dual_flash > SF_SINGLE_FLASH) - spi_flash_dual(flash, &write_addr); -#endif -#ifdef CONFIG_SPI_FLASH_BAR - ret = write_bar(flash, write_addr); - if (ret < 0) - return ret; -#endif - byte_addr = offset % page_size; - chunk_len = min(len - actual, (size_t)(page_size - byte_addr)); - - if (spi->max_write_size) - chunk_len = min(chunk_len, - spi->max_write_size - sizeof(cmd)); - - spi_flash_addr(write_addr, cmd); - - debug("SF: 0x%p => cmd = { 0x%02x 0x%02x%02x%02x } chunk_len = %zu\n", - buf + actual, cmd[0], cmd[1], cmd[2], cmd[3], chunk_len); - - ret = spi_flash_write_common(flash, cmd, sizeof(cmd), - buf + actual, chunk_len); - if (ret < 0) { - debug("SF: write failed\n"); - break; - } - - offset += chunk_len; - } - -#ifdef CONFIG_SPI_FLASH_BAR - ret = clean_bar(flash); -#endif - - return ret; -} - -int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, - size_t cmd_len, void *data, size_t data_len) -{ - struct spi_slave *spi = flash->spi; - int ret; - - ret = spi_claim_bus(spi); - if (ret) { - debug("SF: unable to claim SPI bus\n"); - return ret; - } - - ret = spi_flash_cmd_read(spi, cmd, cmd_len, data, data_len); - if (ret < 0) { - debug("SF: read cmd failed\n"); - return ret; - } - - spi_release_bus(spi); - - return ret; -} - -/* - * TODO: remove the weak after all the other spi_flash_copy_mmap - * implementations removed from drivers - */ -void __weak spi_flash_copy_mmap(void *data, void *offset, size_t len) -{ -#ifdef CONFIG_DMA - if (!dma_memcpy(data, offset, len)) - return; -#endif - memcpy(data, offset, len); -} - -int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, - size_t len, void *data) -{ - struct spi_slave *spi = flash->spi; - u8 cmdsz; - u32 remain_len, read_len, read_addr; - int bank_sel = 0; - int ret = 0; - - /* Handle memory-mapped SPI */ - if (flash->memory_map) { - ret = spi_claim_bus(spi); - if (ret) { - debug("SF: unable to claim SPI bus\n"); - return log_ret(ret); - } - spi_xfer(spi, 0, NULL, NULL, SPI_XFER_MMAP); - spi_flash_copy_mmap(data, flash->memory_map + offset, len); - spi_xfer(spi, 0, NULL, NULL, SPI_XFER_MMAP_END); - spi_release_bus(spi); - return 0; - } - - cmdsz = SPI_FLASH_CMD_LEN + flash->dummy_byte; - u8 cmd[cmdsz]; - - cmd[0] = flash->read_cmd; - while (len) { - read_addr = offset; - -#ifdef CONFIG_SF_DUAL_FLASH - if (flash->dual_flash > SF_SINGLE_FLASH) - spi_flash_dual(flash, &read_addr); -#endif -#ifdef CONFIG_SPI_FLASH_BAR - ret = write_bar(flash, read_addr); - if (ret < 0) - return log_ret(ret); - bank_sel = flash->bank_curr; -#endif - remain_len = ((SPI_FLASH_16MB_BOUN << flash->shift) * - (bank_sel + 1)) - offset; - if (len < remain_len) - read_len = len; - else - read_len = remain_len; - - if (spi->max_read_size) - read_len = min(read_len, spi->max_read_size); - - spi_flash_addr(read_addr, cmd); - - ret = spi_flash_read_common(flash, cmd, cmdsz, data, read_len); - if (ret < 0) { - debug("SF: read failed\n"); - break; - } - - offset += read_len; - len -= read_len; - data += read_len; - } - -#ifdef CONFIG_SPI_FLASH_BAR - ret = clean_bar(flash); -#endif - - return log_ret(ret); -} - -#ifdef CONFIG_SPI_FLASH_SST -static bool sst26_process_bpr(u32 bpr_size, u8 *cmd, u32 bit, enum lock_ctl ctl) -{ - switch (ctl) { - case SST26_CTL_LOCK: - cmd[bpr_size - (bit / 8) - 1] |= BIT(bit % 8); - break; - case SST26_CTL_UNLOCK: - cmd[bpr_size - (bit / 8) - 1] &= ~BIT(bit % 8); - break; - case SST26_CTL_CHECK: - return !!(cmd[bpr_size - (bit / 8) - 1] & BIT(bit % 8)); - } - - return false; -} - -/* - * sst26wf016/sst26wf032/sst26wf064 have next block protection: - * 4x - 8 KByte blocks - read & write protection bits - upper addresses - * 1x - 32 KByte blocks - write protection bits - * rest - 64 KByte blocks - write protection bits - * 1x - 32 KByte blocks - write protection bits - * 4x - 8 KByte blocks - read & write protection bits - lower addresses - * - * We'll support only per 64k lock/unlock so lower and upper 64 KByte region - * will be treated as single block. - */ - -/* - * Lock, unlock or check lock status of the flash region of the flash (depending - * on the lock_ctl value) - */ -static int sst26_lock_ctl(struct spi_flash *flash, u32 ofs, size_t len, enum lock_ctl ctl) -{ - u32 i, bpr_ptr, rptr_64k, lptr_64k, bpr_size; - bool lower_64k = false, upper_64k = false; - u8 cmd, bpr_buff[SST26_MAX_BPR_REG_LEN] = {}; - int ret; - - /* Check length and offset for 64k alignment */ - if ((ofs & (SZ_64K - 1)) || (len & (SZ_64K - 1))) - return -EINVAL; - - if (ofs + len > flash->size) - return -EINVAL; - - /* SST26 family has only 16 Mbit, 32 Mbit and 64 Mbit IC */ - if (flash->size != SZ_2M && - flash->size != SZ_4M && - flash->size != SZ_8M) - return -EINVAL; - - bpr_size = 2 + (flash->size / SZ_64K / 8); - - cmd = SST26_CMD_READ_BPR; - ret = spi_flash_read_common(flash, &cmd, 1, bpr_buff, bpr_size); - if (ret < 0) { - printf("SF: fail to read block-protection register\n"); - return ret; - } - - rptr_64k = min_t(u32, ofs + len , flash->size - SST26_BOUND_REG_SIZE); - lptr_64k = max_t(u32, ofs, SST26_BOUND_REG_SIZE); - - upper_64k = ((ofs + len) > (flash->size - SST26_BOUND_REG_SIZE)); - lower_64k = (ofs < SST26_BOUND_REG_SIZE); - - /* Lower bits in block-protection register are about 64k region */ - bpr_ptr = lptr_64k / SZ_64K - 1; - - /* Process 64K blocks region */ - while (lptr_64k < rptr_64k) { - if (sst26_process_bpr(bpr_size, bpr_buff, bpr_ptr, ctl)) - return EACCES; - - bpr_ptr++; - lptr_64k += SZ_64K; - } - - /* 32K and 8K region bits in BPR are after 64k region bits */ - bpr_ptr = (flash->size - 2 * SST26_BOUND_REG_SIZE) / SZ_64K; - - /* Process lower 32K block region */ - if (lower_64k) - if (sst26_process_bpr(bpr_size, bpr_buff, bpr_ptr, ctl)) - return EACCES; - - bpr_ptr++; - - /* Process upper 32K block region */ - if (upper_64k) - if (sst26_process_bpr(bpr_size, bpr_buff, bpr_ptr, ctl)) - return EACCES; - - bpr_ptr++; - - /* Process lower 8K block regions */ - for (i = 0; i < SST26_BPR_8K_NUM; i++) { - if (lower_64k) - if (sst26_process_bpr(bpr_size, bpr_buff, bpr_ptr, ctl)) - return EACCES; - - /* In 8K area BPR has both read and write protection bits */ - bpr_ptr += 2; - } - - /* Process upper 8K block regions */ - for (i = 0; i < SST26_BPR_8K_NUM; i++) { - if (upper_64k) - if (sst26_process_bpr(bpr_size, bpr_buff, bpr_ptr, ctl)) - return EACCES; - - /* In 8K area BPR has both read and write protection bits */ - bpr_ptr += 2; - } - - /* If we check region status we don't need to write BPR back */ - if (ctl == SST26_CTL_CHECK) - return 0; - - cmd = SST26_CMD_WRITE_BPR; - ret = spi_flash_write_common(flash, &cmd, 1, bpr_buff, bpr_size); - if (ret < 0) { - printf("SF: fail to write block-protection register\n"); - return ret; - } - - return 0; -} - -static int sst26_unlock(struct spi_flash *flash, u32 ofs, size_t len) -{ - return sst26_lock_ctl(flash, ofs, len, SST26_CTL_UNLOCK); -} - -static int sst26_lock(struct spi_flash *flash, u32 ofs, size_t len) -{ - return sst26_lock_ctl(flash, ofs, len, SST26_CTL_LOCK); -} - -/* - * Returns EACCES (positive value) if region is locked, 0 if region is unlocked, - * and negative on errors. - */ -static int sst26_is_locked(struct spi_flash *flash, u32 ofs, size_t len) -{ - /* - * is_locked function is used for check before reading or erasing flash - * region, so offset and length might be not 64k allighned, so adjust - * them to be 64k allighned as sst26_lock_ctl works only with 64k - * allighned regions. - */ - ofs -= ofs & (SZ_64K - 1); - len = len & (SZ_64K - 1) ? (len & ~(SZ_64K - 1)) + SZ_64K : len; - - return sst26_lock_ctl(flash, ofs, len, SST26_CTL_CHECK); -} - -static int sst_byte_write(struct spi_flash *flash, u32 offset, const void *buf) -{ - struct spi_slave *spi = flash->spi; - int ret; - u8 cmd[4] = { - CMD_SST_BP, - offset >> 16, - offset >> 8, - offset, - }; - - debug("BP[%02x]: 0x%p => cmd = { 0x%02x 0x%06x }\n", - spi_w8r8(spi, CMD_READ_STATUS), buf, cmd[0], offset); - - ret = spi_flash_cmd_write_enable(flash); - if (ret) - return ret; - - ret = spi_flash_cmd_write(spi, cmd, sizeof(cmd), buf, 1); - if (ret) - return ret; - - return spi_flash_wait_till_ready(flash, SPI_FLASH_PROG_TIMEOUT); -} - -int sst_write_wp(struct spi_flash *flash, u32 offset, size_t len, - const void *buf) -{ - struct spi_slave *spi = flash->spi; - size_t actual, cmd_len; - int ret; - u8 cmd[4]; - - ret = spi_claim_bus(spi); - if (ret) { - debug("SF: Unable to claim SPI bus\n"); - return ret; - } - - /* If the data is not word aligned, write out leading single byte */ - actual = offset % 2; - if (actual) { - ret = sst_byte_write(flash, offset, buf); - if (ret) - goto done; - } - offset += actual; - - ret = spi_flash_cmd_write_enable(flash); - if (ret) - goto done; - - cmd_len = 4; - cmd[0] = CMD_SST_AAI_WP; - cmd[1] = offset >> 16; - cmd[2] = offset >> 8; - cmd[3] = offset; - - for (; actual < len - 1; actual += 2) { - debug("WP[%02x]: 0x%p => cmd = { 0x%02x 0x%06x }\n", - spi_w8r8(spi, CMD_READ_STATUS), buf + actual, - cmd[0], offset); - - ret = spi_flash_cmd_write(spi, cmd, cmd_len, - buf + actual, 2); - if (ret) { - debug("SF: sst word program failed\n"); - break; - } - - ret = spi_flash_wait_till_ready(flash, SPI_FLASH_PROG_TIMEOUT); - if (ret) - break; - - cmd_len = 1; - offset += 2; - } - - if (!ret) - ret = spi_flash_cmd_write_disable(flash); - - /* If there is a single trailing byte, write it out */ - if (!ret && actual != len) - ret = sst_byte_write(flash, offset, buf + actual); - - done: - debug("SF: sst: program %s %zu bytes @ 0x%zx\n", - ret ? "failure" : "success", len, offset - actual); - - spi_release_bus(spi); - return ret; -} - -int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, - const void *buf) -{ - struct spi_slave *spi = flash->spi; - size_t actual; - int ret; - - ret = spi_claim_bus(spi); - if (ret) { - debug("SF: Unable to claim SPI bus\n"); - return ret; - } - - for (actual = 0; actual < len; actual++) { - ret = sst_byte_write(flash, offset, buf + actual); - if (ret) { - debug("SF: sst byte program failed\n"); - break; - } - offset++; - } - - if (!ret) - ret = spi_flash_cmd_write_disable(flash); - - debug("SF: sst: program %s %zu bytes @ 0x%zx\n", - ret ? "failure" : "success", len, offset - actual); - - spi_release_bus(spi); - return ret; -} -#endif - -#if defined(CONFIG_SPI_FLASH_STMICRO) || defined(CONFIG_SPI_FLASH_SST) -static void stm_get_locked_range(struct spi_flash *flash, u8 sr, loff_t *ofs, - u64 *len) -{ - u8 mask = SR_BP2 | SR_BP1 | SR_BP0; - int shift = ffs(mask) - 1; - int pow; - - if (!(sr & mask)) { - /* No protection */ - *ofs = 0; - *len = 0; - } else { - pow = ((sr & mask) ^ mask) >> shift; - *len = flash->size >> pow; - *ofs = flash->size - *len; - } -} - -/* - * Return 1 if the entire region is locked, 0 otherwise - */ -static int stm_is_locked_sr(struct spi_flash *flash, loff_t ofs, u64 len, - u8 sr) -{ - loff_t lock_offs; - u64 lock_len; - - stm_get_locked_range(flash, sr, &lock_offs, &lock_len); - - return (ofs + len <= lock_offs + lock_len) && (ofs >= lock_offs); -} - -/* - * Check if a region of the flash is (completely) locked. See stm_lock() for - * more info. - * - * Returns 1 if entire region is locked, 0 if any portion is unlocked, and - * negative on errors. - */ -int stm_is_locked(struct spi_flash *flash, u32 ofs, size_t len) -{ - int status; - u8 sr; - - status = read_sr(flash, &sr); - if (status < 0) - return status; - - return stm_is_locked_sr(flash, ofs, len, sr); -} - -/* - * Lock a region of the flash. Compatible with ST Micro and similar flash. - * Supports only the block protection bits BP{0,1,2} in the status register - * (SR). Does not support these features found in newer SR bitfields: - * - TB: top/bottom protect - only handle TB=0 (top protect) - * - SEC: sector/block protect - only handle SEC=0 (block protect) - * - CMP: complement protect - only support CMP=0 (range is not complemented) - * - * Sample table portion for 8MB flash (Winbond w25q64fw): - * - * SEC | TB | BP2 | BP1 | BP0 | Prot Length | Protected Portion - * -------------------------------------------------------------------------- - * X | X | 0 | 0 | 0 | NONE | NONE - * 0 | 0 | 0 | 0 | 1 | 128 KB | Upper 1/64 - * 0 | 0 | 0 | 1 | 0 | 256 KB | Upper 1/32 - * 0 | 0 | 0 | 1 | 1 | 512 KB | Upper 1/16 - * 0 | 0 | 1 | 0 | 0 | 1 MB | Upper 1/8 - * 0 | 0 | 1 | 0 | 1 | 2 MB | Upper 1/4 - * 0 | 0 | 1 | 1 | 0 | 4 MB | Upper 1/2 - * X | X | 1 | 1 | 1 | 8 MB | ALL - * - * Returns negative on errors, 0 on success. - */ -int stm_lock(struct spi_flash *flash, u32 ofs, size_t len) -{ - u8 status_old, status_new; - u8 mask = SR_BP2 | SR_BP1 | SR_BP0; - u8 shift = ffs(mask) - 1, pow, val; - int ret; - - ret = read_sr(flash, &status_old); - if (ret < 0) - return ret; - - /* SPI NOR always locks to the end */ - if (ofs + len != flash->size) { - /* Does combined region extend to end? */ - if (!stm_is_locked_sr(flash, ofs + len, flash->size - ofs - len, - status_old)) - return -EINVAL; - len = flash->size - ofs; - } - - /* - * Need smallest pow such that: - * - * 1 / (2^pow) <= (len / size) - * - * so (assuming power-of-2 size) we do: - * - * pow = ceil(log2(size / len)) = log2(size) - floor(log2(len)) - */ - pow = ilog2(flash->size) - ilog2(len); - val = mask - (pow << shift); - if (val & ~mask) - return -EINVAL; - - /* Don't "lock" with no region! */ - if (!(val & mask)) - return -EINVAL; - - status_new = (status_old & ~mask) | val; - - /* Only modify protection if it will not unlock other areas */ - if ((status_new & mask) <= (status_old & mask)) - return -EINVAL; - - write_sr(flash, status_new); - - return 0; -} - -/* - * Unlock a region of the flash. See stm_lock() for more info - * - * Returns negative on errors, 0 on success. - */ -int stm_unlock(struct spi_flash *flash, u32 ofs, size_t len) -{ - uint8_t status_old, status_new; - u8 mask = SR_BP2 | SR_BP1 | SR_BP0; - u8 shift = ffs(mask) - 1, pow, val; - int ret; - - ret = read_sr(flash, &status_old); - if (ret < 0) - return ret; - - /* Cannot unlock; would unlock larger region than requested */ - if (stm_is_locked_sr(flash, ofs - flash->erase_size, flash->erase_size, - status_old)) - return -EINVAL; - /* - * Need largest pow such that: - * - * 1 / (2^pow) >= (len / size) - * - * so (assuming power-of-2 size) we do: - * - * pow = floor(log2(size / len)) = log2(size) - ceil(log2(len)) - */ - pow = ilog2(flash->size) - order_base_2(flash->size - (ofs + len)); - if (ofs + len == flash->size) { - val = 0; /* fully unlocked */ - } else { - val = mask - (pow << shift); - /* Some power-of-two sizes are not supported */ - if (val & ~mask) - return -EINVAL; - } - - status_new = (status_old & ~mask) | val; - - /* Only modify protection if it will not lock other areas */ - if ((status_new & mask) >= (status_old & mask)) - return -EINVAL; - - write_sr(flash, status_new); - - return 0; -} -#endif - - -#ifdef CONFIG_SPI_FLASH_MACRONIX -static int macronix_quad_enable(struct spi_flash *flash) -{ - u8 qeb_status; - int ret; - - ret = read_sr(flash, &qeb_status); - if (ret < 0) - return ret; - - if (qeb_status & STATUS_QEB_MXIC) - return 0; - - ret = write_sr(flash, qeb_status | STATUS_QEB_MXIC); - if (ret < 0) - return ret; - - /* read SR and check it */ - ret = read_sr(flash, &qeb_status); - if (!(ret >= 0 && (qeb_status & STATUS_QEB_MXIC))) { - printf("SF: Macronix SR Quad bit not clear\n"); - return -EINVAL; - } - - return ret; -} -#endif - -#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) -static int spansion_quad_enable(struct spi_flash *flash) -{ - u8 qeb_status; - int ret; - - ret = read_cr(flash, &qeb_status); - if (ret < 0) - return ret; - - if (qeb_status & STATUS_QEB_WINSPAN) - return 0; - - ret = write_cr(flash, qeb_status | STATUS_QEB_WINSPAN); - if (ret < 0) - return ret; - - /* read CR and check it */ - ret = read_cr(flash, &qeb_status); - if (!(ret >= 0 && (qeb_status & STATUS_QEB_WINSPAN))) { - printf("SF: Spansion CR Quad bit not clear\n"); - return -EINVAL; - } - - return ret; -} -#endif - -static const struct spi_flash_info *spi_flash_read_id(struct spi_flash *flash) -{ - int tmp; - u8 id[SPI_FLASH_MAX_ID_LEN]; - const struct spi_flash_info *info; - - tmp = spi_flash_cmd(flash->spi, CMD_READ_ID, id, SPI_FLASH_MAX_ID_LEN); - if (tmp < 0) { - printf("SF: error %d reading JEDEC ID\n", tmp); - return ERR_PTR(tmp); - } - - info = spi_flash_ids; - for (; info->name != NULL; info++) { - if (info->id_len) { - if (!memcmp(info->id, id, info->id_len)) - return info; - } - } - - printf("SF: unrecognized JEDEC id bytes: %02x, %02x, %02x\n", - id[0], id[1], id[2]); - return ERR_PTR(-ENODEV); -} - -static int set_quad_mode(struct spi_flash *flash, - const struct spi_flash_info *info) -{ - switch (JEDEC_MFR(info)) { -#ifdef CONFIG_SPI_FLASH_MACRONIX - case SPI_FLASH_CFI_MFR_MACRONIX: - return macronix_quad_enable(flash); -#endif -#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) - case SPI_FLASH_CFI_MFR_SPANSION: - case SPI_FLASH_CFI_MFR_WINBOND: - return spansion_quad_enable(flash); -#endif -#ifdef CONFIG_SPI_FLASH_STMICRO - case SPI_FLASH_CFI_MFR_STMICRO: - case SPI_FLASH_CFI_MFR_MICRON: - debug("SF: QEB is volatile for %02x flash\n", JEDEC_MFR(info)); - return 0; -#endif - default: - printf("SF: Need set QEB func for %02x flash\n", - JEDEC_MFR(info)); - return -1; - } -} - -#if CONFIG_IS_ENABLED(OF_CONTROL) -int spi_flash_decode_fdt(struct spi_flash *flash) -{ -#ifdef CONFIG_DM_SPI_FLASH - fdt_addr_t addr; - fdt_size_t size; - - addr = dev_read_addr_size(flash->dev, "memory-map", &size); - if (addr == FDT_ADDR_T_NONE) { - debug("%s: Cannot decode address\n", __func__); - return 0; - } - - if (flash->size > size) { - debug("%s: Memory map must cover entire device\n", __func__); - return -1; - } - flash->memory_map = map_sysmem(addr, size); -#endif - - return 0; -} -#endif /* CONFIG_IS_ENABLED(OF_CONTROL) */ - -int spi_flash_scan(struct spi_flash *flash) -{ - struct spi_slave *spi = flash->spi; - const struct spi_flash_info *info = NULL; - int ret; - - info = spi_flash_read_id(flash); - if (IS_ERR_OR_NULL(info)) - return -ENOENT; - - /* - * Flash powers up read-only, so clear BP# bits. - * - * Note on some flash (like Macronix), QE (quad enable) bit is in the - * same status register as BP# bits, and we need preserve its original - * value during a reboot cycle as this is required by some platforms - * (like Intel ICH SPI controller working under descriptor mode). - */ - if (JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_ATMEL || - (JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_SST) || - (JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_MACRONIX)) { - u8 sr = 0; - - if (JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_MACRONIX) { - read_sr(flash, &sr); - sr &= STATUS_QEB_MXIC; - } - write_sr(flash, sr); - } - - flash->name = info->name; - flash->memory_map = spi->memory_map; - - if (info->flags & SST_WR) - flash->flags |= SNOR_F_SST_WR; - -#ifndef CONFIG_DM_SPI_FLASH - flash->write = spi_flash_cmd_write_ops; -#if defined(CONFIG_SPI_FLASH_SST) - if (flash->flags & SNOR_F_SST_WR) { - if (spi->mode & SPI_TX_BYTE) - flash->write = sst_write_bp; - else - flash->write = sst_write_wp; - } -#endif - flash->erase = spi_flash_cmd_erase_ops; - flash->read = spi_flash_cmd_read_ops; -#endif - -#if defined(CONFIG_SPI_FLASH_STMICRO) || defined(CONFIG_SPI_FLASH_SST) - /* NOR protection support for STmicro/Micron chips and similar */ - if (JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_STMICRO || - JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_MICRON || - JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_SST) { - flash->flash_lock = stm_lock; - flash->flash_unlock = stm_unlock; - flash->flash_is_locked = stm_is_locked; - } -#endif - -/* sst26wf series block protection implementation differs from other series */ -#if defined(CONFIG_SPI_FLASH_SST) - if (JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_SST && info->id[1] == 0x26) { - flash->flash_lock = sst26_lock; - flash->flash_unlock = sst26_unlock; - flash->flash_is_locked = sst26_is_locked; - } -#endif - - /* Compute the flash size */ - flash->shift = (flash->dual_flash & SF_DUAL_PARALLEL_FLASH) ? 1 : 0; - flash->page_size = info->page_size; - /* - * The Spansion S25FS512S, S25FL032P and S25FL064P have 256b pages, - * yet use the 0x4d00 Extended JEDEC code. The rest of the Spansion - * flashes with the 0x4d00 Extended JEDEC code have 512b pages. - * All of the others have 256b pages. - */ - if (JEDEC_EXT(info) == 0x4d00) { - if ((JEDEC_ID(info) != 0x0215) && - (JEDEC_ID(info) != 0x0216) && - (JEDEC_ID(info) != 0x0220)) - flash->page_size = 512; - } - flash->page_size <<= flash->shift; - flash->sector_size = info->sector_size << flash->shift; - flash->size = flash->sector_size * info->n_sectors << flash->shift; -#ifdef CONFIG_SF_DUAL_FLASH - if (flash->dual_flash & SF_DUAL_STACKED_FLASH) - flash->size <<= 1; -#endif - -#ifdef CONFIG_SPI_FLASH_USE_4K_SECTORS - /* Compute erase sector and command */ - if (info->flags & SECT_4K) { - flash->erase_cmd = CMD_ERASE_4K; - flash->erase_size = 4096 << flash->shift; - } else -#endif - { - flash->erase_cmd = CMD_ERASE_64K; - flash->erase_size = flash->sector_size; - } - - /* Now erase size becomes valid sector size */ - flash->sector_size = flash->erase_size; - - /* Look for read commands */ - flash->read_cmd = CMD_READ_ARRAY_FAST; - if (spi->mode & SPI_RX_SLOW) - flash->read_cmd = CMD_READ_ARRAY_SLOW; - else if (spi->mode & SPI_RX_QUAD && info->flags & RD_QUAD) - flash->read_cmd = CMD_READ_QUAD_OUTPUT_FAST; - else if (spi->mode & SPI_RX_DUAL && info->flags & RD_DUAL) - flash->read_cmd = CMD_READ_DUAL_OUTPUT_FAST; - - /* Look for write commands */ - if (info->flags & WR_QPP && spi->mode & SPI_TX_QUAD) - flash->write_cmd = CMD_QUAD_PAGE_PROGRAM; - else - /* Go for default supported write cmd */ - flash->write_cmd = CMD_PAGE_PROGRAM; - - /* Set the quad enable bit - only for quad commands */ - if ((flash->read_cmd == CMD_READ_QUAD_OUTPUT_FAST) || - (flash->read_cmd == CMD_READ_QUAD_IO_FAST) || - (flash->write_cmd == CMD_QUAD_PAGE_PROGRAM)) { - ret = set_quad_mode(flash, info); - if (ret) { - debug("SF: Fail to set QEB for %02x\n", - JEDEC_MFR(info)); - return -EINVAL; - } - } - - /* Read dummy_byte: dummy byte is determined based on the - * dummy cycles of a particular command. - * Fast commands - dummy_byte = dummy_cycles/8 - * I/O commands- dummy_byte = (dummy_cycles * no.of lines)/8 - * For I/O commands except cmd[0] everything goes on no.of lines - * based on particular command but incase of fast commands except - * data all go on single line irrespective of command. - */ - switch (flash->read_cmd) { - case CMD_READ_QUAD_IO_FAST: - flash->dummy_byte = 2; - break; - case CMD_READ_ARRAY_SLOW: - flash->dummy_byte = 0; - break; - default: - flash->dummy_byte = 1; - } - -#ifdef CONFIG_SPI_FLASH_STMICRO - if (info->flags & E_FSR) - flash->flags |= SNOR_F_USE_FSR; -#endif - - /* Configure the BAR - discover bank cmds and read current bank */ -#ifdef CONFIG_SPI_FLASH_BAR - ret = read_bar(flash, info); - if (ret < 0) - return ret; -#endif - -#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) - ret = spi_flash_decode_fdt(flash); - if (ret) { - debug("SF: FDT decode error\n"); - return -EINVAL; - } -#endif - -#ifndef CONFIG_SPL_BUILD - printf("SF: Detected %s with page size ", flash->name); - print_size(flash->page_size, ", erase size "); - print_size(flash->erase_size, ", total "); - print_size(flash->size, ""); - if (flash->memory_map) - printf(", mapped at %p", flash->memory_map); - puts("\n"); -#endif - -#ifndef CONFIG_SPI_FLASH_BAR - if (((flash->dual_flash == SF_SINGLE_FLASH) && - (flash->size > SPI_FLASH_16MB_BOUN)) || - ((flash->dual_flash > SF_SINGLE_FLASH) && - (flash->size > SPI_FLASH_16MB_BOUN << 1))) { - puts("SF: Warning - Only lower 16MiB accessible,"); - puts(" Full access #define CONFIG_SPI_FLASH_BAR\n"); - } -#endif - - return 0; -} diff --git a/drivers/mtd/spi/spi_flash_ids.c b/drivers/mtd/spi/spi_flash_ids.c deleted file mode 100644 index ad0a0c815014..000000000000 --- a/drivers/mtd/spi/spi_flash_ids.c +++ /dev/null @@ -1,211 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * SPI Flash ID's. - * - * Copyright (C) 2016 Jagan Teki jagan@openedev.com - * Copyright (C) 2013 Jagannadha Sutradharudu Teki, Xilinx Inc. - */ - -#include <common.h> -#include <spi.h> -#include <spi_flash.h> - -#include "sf_internal.h" - -/* Used when the "_ext_id" is two bytes at most */ -#define INFO(_jedec_id, _ext_id, _sector_size, _n_sectors, _flags) \ - .id = { \ - ((_jedec_id) >> 16) & 0xff, \ - ((_jedec_id) >> 8) & 0xff, \ - (_jedec_id) & 0xff, \ - ((_ext_id) >> 8) & 0xff, \ - (_ext_id) & 0xff, \ - }, \ - .id_len = (!(_jedec_id) ? 0 : (3 + ((_ext_id) ? 2 : 0))), \ - .sector_size = (_sector_size), \ - .n_sectors = (_n_sectors), \ - .page_size = 256, \ - .flags = (_flags), - -#define INFO6(_jedec_id, _ext_id, _sector_size, _n_sectors, _flags) \ - .id = { \ - ((_jedec_id) >> 16) & 0xff, \ - ((_jedec_id) >> 8) & 0xff, \ - (_jedec_id) & 0xff, \ - ((_ext_id) >> 16) & 0xff, \ - ((_ext_id) >> 8) & 0xff, \ - (_ext_id) & 0xff, \ - }, \ - .id_len = 6, \ - .sector_size = (_sector_size), \ - .n_sectors = (_n_sectors), \ - .page_size = 256, \ - .flags = (_flags), - -const struct spi_flash_info spi_flash_ids[] = { -#ifdef CONFIG_SPI_FLASH_ATMEL /* ATMEL */ - {"at45db011d", INFO(0x1f2200, 0x0, 64 * 1024, 4, SECT_4K) }, - {"at45db021d", INFO(0x1f2300, 0x0, 64 * 1024, 8, SECT_4K) }, - {"at45db041d", INFO(0x1f2400, 0x0, 64 * 1024, 8, SECT_4K) }, - {"at45db081d", INFO(0x1f2500, 0x0, 64 * 1024, 16, SECT_4K) }, - {"at45db161d", INFO(0x1f2600, 0x0, 64 * 1024, 32, SECT_4K) }, - {"at45db321d", INFO(0x1f2700, 0x0, 64 * 1024, 64, SECT_4K) }, - {"at45db641d", INFO(0x1f2800, 0x0, 64 * 1024, 128, SECT_4K) }, - {"at25df321a", INFO(0x1f4701, 0x0, 64 * 1024, 64, SECT_4K) }, - {"at25df321", INFO(0x1f4700, 0x0, 64 * 1024, 64, SECT_4K) }, - {"at26df081a", INFO(0x1f4501, 0x0, 64 * 1024, 16, SECT_4K) }, -#endif -#ifdef CONFIG_SPI_FLASH_EON /* EON */ - {"en25q32b", INFO(0x1c3016, 0x0, 64 * 1024, 64, 0) }, - {"en25q64", INFO(0x1c3017, 0x0, 64 * 1024, 128, SECT_4K) }, - {"en25q128b", INFO(0x1c3018, 0x0, 64 * 1024, 256, 0) }, - {"en25s64", INFO(0x1c3817, 0x0, 64 * 1024, 128, 0) }, -#endif -#ifdef CONFIG_SPI_FLASH_GIGADEVICE /* GIGADEVICE */ - {"gd25q16c", INFO(0xc84015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K) }, - {"gd25q64b", INFO(0xc84017, 0x0, 64 * 1024, 128, SECT_4K) }, - {"gd25q32b", INFO(0xc84016, 0x0, 64 * 1024, 64, SECT_4K) }, - {"gd25lq32", INFO(0xc86016, 0x0, 64 * 1024, 64, SECT_4K) }, -#endif -#ifdef CONFIG_SPI_FLASH_ISSI /* ISSI */ - {"is25lq040b", INFO(0x9d4013, 0x0, 64 * 1024, 8, 0) }, - {"is25lp032", INFO(0x9d6016, 0x0, 64 * 1024, 64, 0) }, - {"is25lp064", INFO(0x9d6017, 0x0, 64 * 1024, 128, 0) }, - {"is25lp128", INFO(0x9d6018, 0x0, 64 * 1024, 256, 0) }, - {"is25lp256", INFO(0x9d6019, 0x0, 64 * 1024, 512, 0) }, - {"is25wp032", INFO(0x9d7016, 0x0, 64 * 1024, 64, RD_FULL | SECT_4K) }, - {"is25wp064", INFO(0x9d7017, 0x0, 64 * 1024, 128, RD_FULL | SECT_4K) }, - {"is25wp128", INFO(0x9d7018, 0x0, 64 * 1024, 256, RD_FULL | SECT_4K) }, -#endif -#ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ - {"mx25l2006e", INFO(0xc22012, 0x0, 64 * 1024, 4, 0) }, - {"mx25l4005", INFO(0xc22013, 0x0, 64 * 1024, 8, 0) }, - {"mx25l8005", INFO(0xc22014, 0x0, 64 * 1024, 16, 0) }, - {"mx25l1605d", INFO(0xc22015, 0x0, 64 * 1024, 32, 0) }, - {"mx25l3205d", INFO(0xc22016, 0x0, 64 * 1024, 64, 0) }, - {"mx25l6405d", INFO(0xc22017, 0x0, 64 * 1024, 128, 0) }, - {"mx25l12805", INFO(0xc22018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, - {"mx25l25635f", INFO(0xc22019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP) }, - {"mx25l51235f", INFO(0xc2201a, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP) }, - {"mx25l1633e", INFO(0xc22415, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K) }, - {"mx25u6435f", INFO(0xc22537, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP) }, - {"mx25l12855e", INFO(0xc22618, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, - {"mx25u1635e", INFO(0xc22535, 0x0, 64 * 1024, 32, SECT_4K) }, - {"mx25u25635f", INFO(0xc22539, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP) }, - {"mx66u51235f", INFO(0xc2253a, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP) }, - {"mx66l1g45g", INFO(0xc2201b, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP) }, -#endif -#ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */ - {"s25fl008a", INFO(0x010213, 0x0, 64 * 1024, 16, 0) }, - {"s25fl016a", INFO(0x010214, 0x0, 64 * 1024, 32, 0) }, - {"s25fl032a", INFO(0x010215, 0x0, 64 * 1024, 64, 0) }, - {"s25fl064a", INFO(0x010216, 0x0, 64 * 1024, 128, 0) }, - {"s25fl208k", INFO(0x014014, 0x0, 64 * 1024, 16, 0) }, - {"s25fl116k", INFO(0x014015, 0x0, 64 * 1024, 32, 0) }, - {"s25fl164k", INFO(0x014017, 0x0140, 64 * 1024, 128, 0) }, - {"s25fl128p_256k", INFO(0x012018, 0x0300, 256 * 1024, 64, RD_FULL | WR_QPP) }, - {"s25fl128p_64k", INFO(0x012018, 0x0301, 64 * 1024, 256, RD_FULL | WR_QPP) }, - {"s25fl032p", INFO(0x010215, 0x4d00, 64 * 1024, 64, RD_FULL | WR_QPP) }, - {"s25fl064p", INFO(0x010216, 0x4d00, 64 * 1024, 128, RD_FULL | WR_QPP) }, - {"s25fl128s_256k", INFO(0x012018, 0x4d00, 256 * 1024, 64, RD_FULL | WR_QPP) }, - {"s25fl128s_64k", INFO(0x012018, 0x4d01, 64 * 1024, 256, RD_FULL | WR_QPP) }, - {"s25fl128l", INFO(0x016018, 0, 64 * 1024, 256, RD_FULL | WR_QPP) }, - {"s25fl256s_256k", INFO(0x010219, 0x4d00, 256 * 1024, 128, RD_FULL | WR_QPP) }, - {"s25fs256s_64k", INFO6(0x010219, 0x4d0181, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, - {"s25fl256s_64k", INFO(0x010219, 0x4d01, 64 * 1024, 512, RD_FULL | WR_QPP) }, - {"s25fs512s", INFO6(0x010220, 0x4d0081, 256 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) }, - {"s25fl512s_256k", INFO(0x010220, 0x4d00, 256 * 1024, 256, RD_FULL | WR_QPP) }, - {"s25fl512s_64k", INFO(0x010220, 0x4d01, 64 * 1024, 1024, RD_FULL | WR_QPP) }, - {"s25fl512s_512k", INFO(0x010220, 0x4f00, 256 * 1024, 256, RD_FULL | WR_QPP) }, -#endif -#ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */ - {"m25p10", INFO(0x202011, 0x0, 32 * 1024, 4, 0) }, - {"m25p20", INFO(0x202012, 0x0, 64 * 1024, 4, 0) }, - {"m25p40", INFO(0x202013, 0x0, 64 * 1024, 8, 0) }, - {"m25p80", INFO(0x202014, 0x0, 64 * 1024, 16, 0) }, - {"m25p16", INFO(0x202015, 0x0, 64 * 1024, 32, 0) }, - {"m25pE16", INFO(0x208015, 0x1000, 64 * 1024, 32, 0) }, - {"m25pX16", INFO(0x207115, 0x1000, 64 * 1024, 32, RD_QUAD | RD_DUAL) }, - {"m25p32", INFO(0x202016, 0x0, 64 * 1024, 64, 0) }, - {"m25p64", INFO(0x202017, 0x0, 64 * 1024, 128, 0) }, - {"m25p128", INFO(0x202018, 0x0, 256 * 1024, 64, 0) }, - {"m25pX64", INFO(0x207117, 0x0, 64 * 1024, 128, SECT_4K) }, - {"n25q016a", INFO(0x20bb15, 0x0, 64 * 1024, 32, SECT_4K) }, - {"n25q32", INFO(0x20ba16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, - {"n25q32a", INFO(0x20bb16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, - {"n25q64", INFO(0x20ba17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, - {"n25q64a", INFO(0x20bb17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, - {"n25q128", INFO(0x20ba18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, - {"n25q128a", INFO(0x20bb18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, - {"n25q256", INFO(0x20ba19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, - {"n25q256a", INFO(0x20bb19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, - {"n25q512", INFO(0x20ba20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, - {"n25q512a", INFO(0x20bb20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, - {"n25q1024", INFO(0x20ba21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, - {"n25q1024a", INFO(0x20bb21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, - {"mt25qu02g", INFO(0x20bb22, 0x0, 64 * 1024, 4096, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, - {"mt25ql02g", INFO(0x20ba22, 0x0, 64 * 1024, 4096, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, - {"mt35xu512g", INFO6(0x2c5b1a, 0x104100, 128 * 1024, 512, E_FSR | SECT_4K) }, -#endif -#ifdef CONFIG_SPI_FLASH_SST /* SST */ - {"sst25vf040b", INFO(0xbf258d, 0x0, 64 * 1024, 8, SECT_4K | SST_WR) }, - {"sst25vf080b", INFO(0xbf258e, 0x0, 64 * 1024, 16, SECT_4K | SST_WR) }, - {"sst25vf016b", INFO(0xbf2541, 0x0, 64 * 1024, 32, SECT_4K | SST_WR) }, - {"sst25vf032b", INFO(0xbf254a, 0x0, 64 * 1024, 64, SECT_4K | SST_WR) }, - {"sst25vf064c", INFO(0xbf254b, 0x0, 64 * 1024, 128, SECT_4K) }, - {"sst25wf512", INFO(0xbf2501, 0x0, 64 * 1024, 1, SECT_4K | SST_WR) }, - {"sst25wf010", INFO(0xbf2502, 0x0, 64 * 1024, 2, SECT_4K | SST_WR) }, - {"sst25wf020", INFO(0xbf2503, 0x0, 64 * 1024, 4, SECT_4K | SST_WR) }, - {"sst25wf040", INFO(0xbf2504, 0x0, 64 * 1024, 8, SECT_4K | SST_WR) }, - {"sst25wf040b", INFO(0x621613, 0x0, 64 * 1024, 8, SECT_4K) }, - {"sst25wf080", INFO(0xbf2505, 0x0, 64 * 1024, 16, SECT_4K | SST_WR) }, - {"sst26wf016", INFO(0xbf2651, 0x0, 64 * 1024, 32, SECT_4K) }, - {"sst26wf032", INFO(0xbf2622, 0x0, 64 * 1024, 64, SECT_4K) }, - {"sst26wf064", INFO(0xbf2643, 0x0, 64 * 1024, 128, SECT_4K) }, -#endif -#ifdef CONFIG_SPI_FLASH_WINBOND /* WINBOND */ - {"w25p80", INFO(0xef2014, 0x0, 64 * 1024, 16, 0) }, - {"w25p16", INFO(0xef2015, 0x0, 64 * 1024, 32, 0) }, - {"w25p32", INFO(0xef2016, 0x0, 64 * 1024, 64, 0) }, - {"w25x40", INFO(0xef3013, 0x0, 64 * 1024, 8, SECT_4K) }, - {"w25x16", INFO(0xef3015, 0x0, 64 * 1024, 32, SECT_4K) }, - {"w25x32", INFO(0xef3016, 0x0, 64 * 1024, 64, SECT_4K) }, - {"w25x64", INFO(0xef3017, 0x0, 64 * 1024, 128, SECT_4K) }, - {"w25q80bl", INFO(0xef4014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q16cl", INFO(0xef4015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q32bv", INFO(0xef4016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q64cv", INFO(0xef4017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q128bv", INFO(0xef4018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q256", INFO(0xef4019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q80bw", INFO(0xef5014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q16dw", INFO(0xef6015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q16jv", INFO(0xef7015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q32dw", INFO(0xef6016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q32jv", INFO(0xef7016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q64dw", INFO(0xef6017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q64jv", INFO(0xef7017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q128fw", INFO(0xef6018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q128jv", INFO(0xef7018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q256fw", INFO(0xef6019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, - {"w25q256jw", INFO(0xef7019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, -#endif -#ifdef CONFIG_SPI_FLASH_XMC /* Wuhan Xinxin Semiconductor Manufacturing Corp */ - { "xm25qh64a", INFO(0x207017, 0x0, 64 * 1024, 128, SECT_4K | RD_DUAL | RD_QUAD) }, - { "xm25qh128a", INFO(0x207018, 0x0, 64 * 1024, 256, SECT_4K | RD_DUAL | RD_QUAD) }, -#endif - {}, /* Empty entry to terminate the list */ - /* - * Note: - * Below paired flash devices has similar spi_flash params. - * (s25fl129p_64k, s25fl128s_64k) - * (w25q80bl, w25q80bv) - * (w25q16cl, w25q16dv, w25q16jv) - * (w25q32bv, w25q32fv_spi) - * (w25q64cv, w25q64fv_spi) - * (w25q128bv, w25q128fv_spi) - * (w25q32dw, w25q32fv_qpi) - * (w25q64dw, w25q64fv_qpi) - * (w25q128fw, w25q128fv_qpi) - * (w25q256fw, w25q256fv_qpi) - */ -};
Add a tiny SPI flash stack that just supports reading data/images from SPI flash. This is useful for boards that have SPL size constraints and would need to use SPI flash framework just to read images/data from flash. There is approximately 1.5 to 2KB savings with this.
Based on prior work of reducing spi flash id table by Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
Signed-off-by: Vignesh R vigneshr@ti.com --- common/spl/Kconfig | 9 + drivers/mtd/spi/Makefile | 8 +- drivers/mtd/spi/sf_internal.h | 2 + drivers/mtd/spi/spi-nor-ids.c | 294 ++++++++++++ drivers/mtd/spi/spi-nor-tiny.c | 806 +++++++++++++++++++++++++++++++++ drivers/mtd/spi/spi-nor.c | 266 +---------- 6 files changed, 1122 insertions(+), 263 deletions(-) create mode 100644 drivers/mtd/spi/spi-nor-ids.c create mode 100644 drivers/mtd/spi/spi-nor-tiny.c
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 2b6f315b1cf3..e3597249188c 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -727,6 +727,15 @@ config SPL_SPI_FLASH_SUPPORT lines). This enables the drivers in drivers/mtd/spi as part of an SPL build. This normally requires SPL_SPI_SUPPORT.
+config SPL_SPI_FLASH_TINY + bool "Enable low footprint SPL SPI Flash support" + depends on SPL_SPI_FLASH_SUPPORT + help + Enable lightweight SPL SPI Flash support that supports just reading + data/images from flash. No support to write/erase flash. Enable + this if you have SPL size limitations and don't need full + fledged SPI flash support. + config SPL_SPI_FLASH_SFDP_SUPPORT bool "SFDP table parsing support for SPI NOR flashes" help diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index 9cd6672e93ce..4d1588ecc169 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -7,9 +7,15 @@ obj-$(CONFIG_DM_SPI_FLASH) += sf-uclass.o
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SPL_SPI_BOOT) += fsl_espi_spl.o +ifeq ($(CONFIG_SPL_SPI_FLASH_TINY),y) +obj-$(CONFIG_SPL_SPI_FLASH_TINY) += sf_probe.o spi-nor-tiny.o spi-nor-ids.o +else +obj-$(CONFIG_SPI_FLASH) += sf_probe.o spi-nor.o spi-nor-ids.o +endif +else +obj-$(CONFIG_SPI_FLASH) += sf_probe.o spi-nor.o spi-nor-ids.o endif
-obj-$(CONFIG_SPI_FLASH) += sf_probe.o spi-nor.o obj-$(CONFIG_SPI_FLASH_DATAFLASH) += sf_dataflash.o sf.o obj-$(CONFIG_SPI_FLASH_MTD) += sf_mtd.o obj-$(CONFIG_SPI_FLASH_SANDBOX) += sandbox.o diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 55619f5aea5c..7e7d400cdbdf 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -16,7 +16,9 @@ #define SPI_NOR_MAX_ADDR_WIDTH 4
struct flash_info { +#if !CONFIG_IS_ENABLED(SPI_FLASH_TINY) char *name; +#endif
/* * This array stores the ID bytes. diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c new file mode 100644 index 000000000000..fd20c86b3aef --- /dev/null +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -0,0 +1,294 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#include <common.h> +#include <spi.h> +#include <spi_flash.h> + +#include "sf_internal.h" + +/* Exclude chip names for SPL to save space */ +#if !CONFIG_IS_ENABLED(SPI_FLASH_TINY) +#define INFO_NAME(_name) .name = _name, +#else +#define INFO_NAME(_name) +#endif + +/* Used when the "_ext_id" is two bytes at most */ +#define INFO(_name, _jedec_id, _ext_id, _sector_size, _n_sectors, _flags) \ + INFO_NAME(_name) \ + .id = { \ + ((_jedec_id) >> 16) & 0xff, \ + ((_jedec_id) >> 8) & 0xff, \ + (_jedec_id) & 0xff, \ + ((_ext_id) >> 8) & 0xff, \ + (_ext_id) & 0xff, \ + }, \ + .id_len = (!(_jedec_id) ? 0 : (3 + ((_ext_id) ? 2 : 0))), \ + .sector_size = (_sector_size), \ + .n_sectors = (_n_sectors), \ + .page_size = 256, \ + .flags = (_flags), + +#define INFO6(_name, _jedec_id, _ext_id, _sector_size, _n_sectors, _flags) \ + INFO_NAME(_name) \ + .id = { \ + ((_jedec_id) >> 16) & 0xff, \ + ((_jedec_id) >> 8) & 0xff, \ + (_jedec_id) & 0xff, \ + ((_ext_id) >> 16) & 0xff, \ + ((_ext_id) >> 8) & 0xff, \ + (_ext_id) & 0xff, \ + }, \ + .id_len = 6, \ + .sector_size = (_sector_size), \ + .n_sectors = (_n_sectors), \ + .page_size = 256, \ + .flags = (_flags), + +/* NOTE: double check command sets and memory organization when you add + * more nor chips. This current list focusses on newer chips, which + * have been converging on command sets which including JEDEC ID. + * + * All newly added entries should describe *hardware* and should use SECT_4K + * (or SECT_4K_PMC) if hardware supports erasing 4 KiB sectors. For usage + * scenarios excluding small sectors there is config option that can be + * disabled: CONFIG_MTD_SPI_NOR_USE_4K_SECTORS. + * For historical (and compatibility) reasons (before we got above config) some + * old entries may be missing 4K flag. + */ +const struct flash_info spi_nor_ids[] = { +#ifdef CONFIG_SPI_FLASH_ATMEL /* ATMEL */ + /* Atmel -- some are (confusingly) marketed as "DataFlash" */ + { INFO("at26df321", 0x1f4700, 0, 64 * 1024, 64, SECT_4K) }, + { INFO("at25df321a", 0x1f4701, 0, 64 * 1024, 64, SECT_4K) }, + + { INFO("at45db011d", 0x1f2200, 0, 64 * 1024, 4, SECT_4K) }, + { INFO("at45db021d", 0x1f2300, 0, 64 * 1024, 8, SECT_4K) }, + { INFO("at45db041d", 0x1f2400, 0, 64 * 1024, 8, SECT_4K) }, + { INFO("at45db081d", 0x1f2500, 0, 64 * 1024, 16, SECT_4K) }, + { INFO("at45db161d", 0x1f2600, 0, 64 * 1024, 32, SECT_4K) }, + { INFO("at45db321d", 0x1f2700, 0, 64 * 1024, 64, SECT_4K) }, + { INFO("at45db641d", 0x1f2800, 0, 64 * 1024, 128, SECT_4K) }, + { INFO("at26df081a", 0x1f4501, 0, 64 * 1024, 16, SECT_4K) }, +#endif +#ifdef CONFIG_SPI_FLASH_EON /* EON */ + /* EON -- en25xxx */ + { INFO("en25q32b", 0x1c3016, 0, 64 * 1024, 64, 0) }, + { INFO("en25q64", 0x1c3017, 0, 64 * 1024, 128, SECT_4K) }, + { INFO("en25qh128", 0x1c7018, 0, 64 * 1024, 256, 0) }, + { INFO("en25s64", 0x1c3817, 0, 64 * 1024, 128, SECT_4K) }, +#endif +#ifdef CONFIG_SPI_FLASH_GIGADEVICE /* GIGADEVICE */ + /* GigaDevice */ + { + INFO("gd25q16", 0xc84015, 0, 64 * 1024, 32, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("gd25q32", 0xc84016, 0, 64 * 1024, 64, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("gd25lq32", 0xc86016, 0, 64 * 1024, 64, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("gd25q64", 0xc84017, 0, 64 * 1024, 128, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, +#endif +#ifdef CONFIG_SPI_FLASH_ISSI /* ISSI */ + /* ISSI */ + { INFO("is25lq040b", 0x9d4013, 0, 64 * 1024, 8, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("is25lp032", 0x9d6016, 0, 64 * 1024, 64, 0) }, + { INFO("is25lp064", 0x9d6017, 0, 64 * 1024, 128, 0) }, + { INFO("is25lp128", 0x9d6018, 0, 64 * 1024, 256, + SECT_4K | SPI_NOR_DUAL_READ) }, + { INFO("is25lp256", 0x9d6019, 0, 64 * 1024, 512, + SECT_4K | SPI_NOR_DUAL_READ) }, + { INFO("is25wp032", 0x9d7016, 0, 64 * 1024, 64, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("is25wp064", 0x9d7017, 0, 64 * 1024, 128, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("is25wp128", 0x9d7018, 0, 64 * 1024, 256, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, +#endif +#ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ + /* Macronix */ + { INFO("mx25l2005a", 0xc22012, 0, 64 * 1024, 4, SECT_4K) }, + { INFO("mx25l4005a", 0xc22013, 0, 64 * 1024, 8, SECT_4K) }, + { INFO("mx25l8005", 0xc22014, 0, 64 * 1024, 16, 0) }, + { INFO("mx25l1606e", 0xc22015, 0, 64 * 1024, 32, SECT_4K) }, + { INFO("mx25l3205d", 0xc22016, 0, 64 * 1024, 64, SECT_4K) }, + { INFO("mx25l6405d", 0xc22017, 0, 64 * 1024, 128, SECT_4K) }, + { INFO("mx25u2033e", 0xc22532, 0, 64 * 1024, 4, SECT_4K) }, + { INFO("mx25u1635e", 0xc22535, 0, 64 * 1024, 32, SECT_4K) }, + { INFO("mx25u6435f", 0xc22537, 0, 64 * 1024, 128, SECT_4K) }, + { INFO("mx25l12805d", 0xc22018, 0, 64 * 1024, 256, 0) }, + { INFO("mx25l12855e", 0xc22618, 0, 64 * 1024, 256, 0) }, + { INFO("mx25l25635e", 0xc22019, 0, 64 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("mx25u25635f", 0xc22539, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_4B_OPCODES) }, + { INFO("mx25l25655e", 0xc22619, 0, 64 * 1024, 512, 0) }, + { INFO("mx66l51235l", 0xc2201a, 0, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx66u51235f", 0xc2253a, 0, 64 * 1024, 1024, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx66l1g45g", 0xc2201b, 0, 64 * 1024, 2048, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("mx25l1633e", 0xc22415, 0, 64 * 1024, 32, SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | SECT_4K) }, +#endif + +#ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */ + /* Micron */ + { INFO("n25q016a", 0x20bb15, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_QUAD_READ) }, + { INFO("n25q032", 0x20ba16, 0, 64 * 1024, 64, SPI_NOR_QUAD_READ) }, + { INFO("n25q032a", 0x20bb16, 0, 64 * 1024, 64, SPI_NOR_QUAD_READ) }, + { INFO("n25q064", 0x20ba17, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_QUAD_READ) }, + { INFO("n25q064a", 0x20bb17, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_QUAD_READ) }, + { INFO("n25q128a11", 0x20bb18, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_QUAD_READ) }, + { INFO("n25q128a13", 0x20ba18, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_QUAD_READ) }, + { INFO("n25q256a", 0x20ba19, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("n25q256ax1", 0x20bb19, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_QUAD_READ) }, + { INFO("n25q512a", 0x20bb20, 0, 64 * 1024, 1024, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ) }, + { INFO("n25q512ax3", 0x20ba20, 0, 64 * 1024, 1024, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ) }, + { INFO("n25q00", 0x20ba21, 0, 64 * 1024, 2048, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE) }, + { INFO("n25q00a", 0x20bb21, 0, 64 * 1024, 2048, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE) }, + { INFO("mt25qu02g", 0x20bb22, 0, 64 * 1024, 4096, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE) }, +#endif +#ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */ + /* Spansion/Cypress -- single (large) sector size only, at least + * for the chips listed here (without boot sectors). + */ + { INFO("s25sl032p", 0x010215, 0x4d00, 64 * 1024, 64, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("s25sl064p", 0x010216, 0x4d00, 64 * 1024, 128, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("s25fl256s0", 0x010219, 0x4d00, 256 * 1024, 128, USE_CLSR) }, + { INFO("s25fl256s1", 0x010219, 0x4d01, 64 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { INFO6("s25fl512s", 0x010220, 0x4d0081, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { INFO("s25fl512s_256k", 0x010220, 0x4d00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { INFO("s25fl512s_64k", 0x010220, 0x4d01, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { INFO("s25fl512s_512k", 0x010220, 0x4f00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { INFO("s25sl12800", 0x012018, 0x0300, 256 * 1024, 64, 0) }, + { INFO("s25sl12801", 0x012018, 0x0301, 64 * 1024, 256, 0) }, + { INFO6("s25fl128s", 0x012018, 0x4d0180, 64 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { INFO("s25fl129p0", 0x012018, 0x4d00, 256 * 1024, 64, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { INFO("s25fl129p1", 0x012018, 0x4d01, 64 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { INFO("s25sl008a", 0x010213, 0, 64 * 1024, 16, 0) }, + { INFO("s25sl016a", 0x010214, 0, 64 * 1024, 32, 0) }, + { INFO("s25sl032a", 0x010215, 0, 64 * 1024, 64, 0) }, + { INFO("s25sl064a", 0x010216, 0, 64 * 1024, 128, 0) }, + { INFO("s25fl116k", 0x014015, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("s25fl164k", 0x014017, 0, 64 * 1024, 128, SECT_4K) }, + { INFO("s25fl208k", 0x014014, 0, 64 * 1024, 16, SECT_4K | SPI_NOR_DUAL_READ) }, + { INFO("s25fl128l", 0x016018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, +#endif +#ifdef CONFIG_SPI_FLASH_SST /* SST */ + /* SST -- large erase sizes are "overlays", "sectors" are 4K */ + { INFO("sst25vf040b", 0xbf258d, 0, 64 * 1024, 8, SECT_4K | SST_WRITE) }, + { INFO("sst25vf080b", 0xbf258e, 0, 64 * 1024, 16, SECT_4K | SST_WRITE) }, + { INFO("sst25vf016b", 0xbf2541, 0, 64 * 1024, 32, SECT_4K | SST_WRITE) }, + { INFO("sst25vf032b", 0xbf254a, 0, 64 * 1024, 64, SECT_4K | SST_WRITE) }, + { INFO("sst25vf064c", 0xbf254b, 0, 64 * 1024, 128, SECT_4K) }, + { INFO("sst25wf512", 0xbf2501, 0, 64 * 1024, 1, SECT_4K | SST_WRITE) }, + { INFO("sst25wf010", 0xbf2502, 0, 64 * 1024, 2, SECT_4K | SST_WRITE) }, + { INFO("sst25wf020", 0xbf2503, 0, 64 * 1024, 4, SECT_4K | SST_WRITE) }, + { INFO("sst25wf020a", 0x621612, 0, 64 * 1024, 4, SECT_4K) }, + { INFO("sst25wf040b", 0x621613, 0, 64 * 1024, 8, SECT_4K) }, + { INFO("sst25wf040", 0xbf2504, 0, 64 * 1024, 8, SECT_4K | SST_WRITE) }, + { INFO("sst25wf080", 0xbf2505, 0, 64 * 1024, 16, SECT_4K | SST_WRITE) }, + { INFO("sst26vf064b", 0xbf2643, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("sst26wf016", 0xbf2651, 0, 64 * 1024, 32, SECT_4K) }, + { INFO("sst26wf032", 0xbf2622, 0, 64 * 1024, 64, SECT_4K) }, + { INFO("sst26wf064", 0xbf2643, 0, 64 * 1024, 128, SECT_4K) }, +#endif +#ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */ + /* ST Microelectronics -- newer production may have feature updates */ + { INFO("m25p10", 0x202011, 0, 32 * 1024, 4, 0) }, + { INFO("m25p20", 0x202012, 0, 64 * 1024, 4, 0) }, + { INFO("m25p40", 0x202013, 0, 64 * 1024, 8, 0) }, + { INFO("m25p80", 0x202014, 0, 64 * 1024, 16, 0) }, + { INFO("m25p16", 0x202015, 0, 64 * 1024, 32, 0) }, + { INFO("m25p32", 0x202016, 0, 64 * 1024, 64, 0) }, + { INFO("m25p64", 0x202017, 0, 64 * 1024, 128, 0) }, + { INFO("m25p128", 0x202018, 0, 256 * 1024, 64, 0) }, + { INFO("m25pe16", 0x208015, 0, 64 * 1024, 32, SECT_4K) }, + { INFO("m25px16", 0x207115, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("m25px64", 0x207117, 0, 64 * 1024, 128, 0) }, +#endif +#ifdef CONFIG_SPI_FLASH_WINBOND /* WINBOND */ + /* Winbond -- w25x "blocks" are 64K, "sectors" are 4KiB */ + { INFO("w25p80", 0xef2014, 0x0, 64 * 1024, 16, 0) }, + { INFO("w25p16", 0xef2015, 0x0, 64 * 1024, 32, 0) }, + { INFO("w25p32", 0xef2016, 0x0, 64 * 1024, 64, 0) }, + { INFO("w25x05", 0xef3010, 0, 64 * 1024, 1, SECT_4K) }, + { INFO("w25x40", 0xef3013, 0, 64 * 1024, 8, SECT_4K) }, + { INFO("w25x16", 0xef3015, 0, 64 * 1024, 32, SECT_4K) }, + { + INFO("w25q16dw", 0xef6015, 0, 64 * 1024, 32, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { INFO("w25x32", 0xef3016, 0, 64 * 1024, 64, SECT_4K) }, + { INFO("w25q20cl", 0xef4012, 0, 64 * 1024, 4, SECT_4K) }, + { INFO("w25q20bw", 0xef5012, 0, 64 * 1024, 4, SECT_4K) }, + { INFO("w25q20ew", 0xef6012, 0, 64 * 1024, 4, SECT_4K) }, + { INFO("w25q32", 0xef4016, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { + INFO("w25q32dw", 0xef6016, 0, 64 * 1024, 64, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25q32jv", 0xef7016, 0, 64 * 1024, 64, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { INFO("w25x64", 0xef3017, 0, 64 * 1024, 128, SECT_4K) }, + { + INFO("w25q64dw", 0xef6017, 0, 64 * 1024, 128, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25q64jv", 0xef7017, 0, 64 * 1024, 128, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25q128fw", 0xef6018, 0, 64 * 1024, 256, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25q128jv", 0xef7018, 0, 64 * 1024, 256, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25q256fw", 0xef6019, 0, 64 * 1024, 512, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { + INFO("w25q256jw", 0xef7019, 0, 64 * 1024, 512, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, + { INFO("w25q80", 0xef5014, 0, 64 * 1024, 16, SECT_4K) }, + { INFO("w25q80bl", 0xef4014, 0, 64 * 1024, 16, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("w25q16cl", 0xef4015, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("w25q64cv", 0xef4017, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("w25q128", 0xef4018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("w25q256", 0xef4019, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, +#endif +#ifdef CONFIG_SPI_FLASH_XMC + /* XMC (Wuhan Xinxin Semiconductor Manufacturing Corp.) */ + { INFO("XM25QH64A", 0x207017, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("XM25QH128A", 0x207018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, +#endif + { }, +}; diff --git a/drivers/mtd/spi/spi-nor-tiny.c b/drivers/mtd/spi/spi-nor-tiny.c new file mode 100644 index 000000000000..c3075d44bea8 --- /dev/null +++ b/drivers/mtd/spi/spi-nor-tiny.c @@ -0,0 +1,806 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Based on m25p80.c, by Mike Lavender (mike@steroidmicros.com), with + * influence from lart.c (Abraham Van Der Merwe) and mtd_dataflash.c + * + * Copyright (C) 2005, Intec Automation Inc. + * Copyright (C) 2014, Freescale Semiconductor, Inc. + * + * Synced from Linux v4.19 + */ + +#include <common.h> +#include <linux/err.h> +#include <linux/errno.h> +#include <linux/log2.h> +#include <linux/math64.h> +#include <linux/sizes.h> + +#include <linux/mtd/mtd.h> +#include <linux/mtd/spi-nor.h> +#include <spi-mem.h> +#include <spi.h> + +#include "sf_internal.h" + +/* Define max times to check status register before we give up. */ + +/* + * For everything but full-chip erase; probably could be much smaller, but kept + * around for safety for now + */ + +#define HZ CONFIG_SYS_HZ + +#define DEFAULT_READY_WAIT_JIFFIES (40UL * HZ) + +static int spi_nor_read_write_reg(struct spi_nor *nor, struct spi_mem_op + *op, void *buf) +{ + if (op->data.dir == SPI_MEM_DATA_IN) + op->data.buf.in = buf; + else + op->data.buf.out = buf; + return spi_mem_exec_op(nor->spi, op); +} + +static int spi_nor_read_reg(struct spi_nor *nor, u8 code, u8 *val, int len) +{ + struct spi_mem_op op = SPI_MEM_OP(SPI_MEM_OP_CMD(code, 1), + SPI_MEM_OP_NO_ADDR, + SPI_MEM_OP_NO_DUMMY, + SPI_MEM_OP_DATA_IN(len, NULL, 1)); + int ret; + + ret = spi_nor_read_write_reg(nor, &op, val); + if (ret < 0) + dev_dbg(&flash->spimem->spi->dev, "error %d reading %x\n", ret, + code); + + return ret; +} + +static int spi_nor_write_reg(struct spi_nor *nor, u8 opcode, u8 *buf, int len) +{ + struct spi_mem_op op = SPI_MEM_OP(SPI_MEM_OP_CMD(opcode, 1), + SPI_MEM_OP_NO_ADDR, + SPI_MEM_OP_NO_DUMMY, + SPI_MEM_OP_DATA_OUT(len, NULL, 1)); + + return spi_nor_read_write_reg(nor, &op, buf); +} + +static ssize_t spi_nor_read_data(struct spi_nor *nor, loff_t from, size_t len, + u_char *buf) +{ + struct spi_mem_op op = + SPI_MEM_OP(SPI_MEM_OP_CMD(nor->read_opcode, 1), + SPI_MEM_OP_ADDR(nor->addr_width, from, 1), + SPI_MEM_OP_DUMMY(nor->read_dummy, 1), + SPI_MEM_OP_DATA_IN(len, buf, 1)); + size_t remaining = len; + int ret; + + /* get transfer protocols. */ + op.cmd.buswidth = spi_nor_get_protocol_inst_nbits(nor->read_proto); + op.addr.buswidth = spi_nor_get_protocol_addr_nbits(nor->read_proto); + op.dummy.buswidth = op.addr.buswidth; + op.data.buswidth = spi_nor_get_protocol_data_nbits(nor->read_proto); + + /* convert the dummy cycles to the number of bytes */ + op.dummy.nbytes = (nor->read_dummy * op.dummy.buswidth) / 8; + + while (remaining) { + op.data.nbytes = remaining < UINT_MAX ? remaining : UINT_MAX; + ret = spi_mem_adjust_op_size(nor->spi, &op); + if (ret) + return ret; + + ret = spi_mem_exec_op(nor->spi, &op); + if (ret) + return ret; + + op.addr.val += op.data.nbytes; + remaining -= op.data.nbytes; + op.data.buf.in += op.data.nbytes; + } + + return len; +} + +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) +/* + * Read configuration register, returning its value in the + * location. Return the configuration register value. + * Returns negative if error occurred. + */ +static int read_cr(struct spi_nor *nor) +{ + int ret; + u8 val; + + ret = spi_nor_read_reg(nor, SPINOR_OP_RDCR, &val, 1); + if (ret < 0) { + dev_dbg(nor->dev, "error %d reading CR\n", ret); + return ret; + } + + return val; +} +#endif + +/* + * Write status register 1 byte + * Returns negative if error occurred. + */ +static inline int write_sr(struct spi_nor *nor, u8 val) +{ + nor->cmd_buf[0] = val; + return spi_nor_write_reg(nor, SPINOR_OP_WRSR, nor->cmd_buf, 1); +} + +/* + * Set write enable latch with Write Enable command. + * Returns negative if error occurred. + */ +static inline int write_enable(struct spi_nor *nor) +{ + return spi_nor_write_reg(nor, SPINOR_OP_WREN, NULL, 0); +} + +/* + * Send write disable instruction to the chip. + */ +static inline int write_disable(struct spi_nor *nor) +{ + return spi_nor_write_reg(nor, SPINOR_OP_WRDI, NULL, 0); +} + +static inline struct spi_nor *mtd_to_spi_nor(struct mtd_info *mtd) +{ + return mtd->priv; +} + +static u8 spi_nor_convert_opcode(u8 opcode, const u8 table[][2], size_t size) +{ + size_t i; + + for (i = 0; i < size; i++) + if (table[i][0] == opcode) + return table[i][1]; + + /* No conversion found, keep input op code. */ + return opcode; +} + +static inline u8 spi_nor_convert_3to4_read(u8 opcode) +{ + static const u8 spi_nor_3to4_read[][2] = { + { SPINOR_OP_READ, SPINOR_OP_READ_4B }, + { SPINOR_OP_READ_FAST, SPINOR_OP_READ_FAST_4B }, + { SPINOR_OP_READ_1_1_2, SPINOR_OP_READ_1_1_2_4B }, + { SPINOR_OP_READ_1_2_2, SPINOR_OP_READ_1_2_2_4B }, + { SPINOR_OP_READ_1_1_4, SPINOR_OP_READ_1_1_4_4B }, + { SPINOR_OP_READ_1_4_4, SPINOR_OP_READ_1_4_4_4B }, + }; + + return spi_nor_convert_opcode(opcode, spi_nor_3to4_read, + ARRAY_SIZE(spi_nor_3to4_read)); +} + +static void spi_nor_set_4byte_opcodes(struct spi_nor *nor, + const struct flash_info *info) +{ + nor->read_opcode = spi_nor_convert_3to4_read(nor->read_opcode); +} + +/* Enable/disable 4-byte addressing mode. */ +static inline int set_4byte(struct spi_nor *nor, const struct flash_info *info, + int enable) +{ + int status; + bool need_wren = false; + u8 cmd; + + switch (JEDEC_MFR(info)) { + case SNOR_MFR_MICRON: + /* Some Micron need WREN command; all will accept it */ + need_wren = true; + case SNOR_MFR_MACRONIX: + case SNOR_MFR_WINBOND: + if (need_wren) + write_enable(nor); + + cmd = enable ? SPINOR_OP_EN4B : SPINOR_OP_EX4B; + status = spi_nor_write_reg(nor, cmd, NULL, 0); + if (need_wren) + write_disable(nor); + + if (!status && !enable && + JEDEC_MFR(info) == SNOR_MFR_WINBOND) { + /* + * On Winbond W25Q256FV, leaving 4byte mode causes + * the Extended Address Register to be set to 1, so all + * 3-byte-address reads come from the second 16M. + * We must clear the register to enable normal behavior. + */ + write_enable(nor); + nor->cmd_buf[0] = 0; + spi_nor_write_reg(nor, SPINOR_OP_WREAR, + nor->cmd_buf, 1); + write_disable(nor); + } + + return status; + default: + /* Spansion style */ + nor->cmd_buf[0] = enable << 7; + return spi_nor_write_reg(nor, SPINOR_OP_BRWR, nor->cmd_buf, 1); + } +} + +#if defined(CONFIG_SPI_FLASH_SPANSION) || \ + defined(CONFIG_SPI_FLASH_WINBOND) || \ + defined(CONFIG_SPI_FLASH_MACRONIX) +/* + * Read the status register, returning its value in the location + * Return the status register value. + * Returns negative if error occurred. + */ +static int read_sr(struct spi_nor *nor) +{ + int ret; + u8 val; + + ret = spi_nor_read_reg(nor, SPINOR_OP_RDSR, &val, 1); + if (ret < 0) { + pr_debug("error %d reading SR\n", (int)ret); + return ret; + } + + return val; +} + +/* + * Read the flag status register, returning its value in the location + * Return the status register value. + * Returns negative if error occurred. + */ +static int read_fsr(struct spi_nor *nor) +{ + int ret; + u8 val; + + ret = spi_nor_read_reg(nor, SPINOR_OP_RDFSR, &val, 1); + if (ret < 0) { + pr_debug("error %d reading FSR\n", ret); + return ret; + } + + return val; +} + +static int spi_nor_sr_ready(struct spi_nor *nor) +{ + int sr = read_sr(nor); + + if (sr < 0) + return sr; + + return !(sr & SR_WIP); +} + +static int spi_nor_fsr_ready(struct spi_nor *nor) +{ + int fsr = read_fsr(nor); + + if (fsr < 0) + return fsr; + return fsr & FSR_READY; +} + +static int spi_nor_ready(struct spi_nor *nor) +{ + int sr, fsr; + + sr = spi_nor_sr_ready(nor); + if (sr < 0) + return sr; + fsr = nor->flags & SNOR_F_USE_FSR ? spi_nor_fsr_ready(nor) : 1; + if (fsr < 0) + return fsr; + return sr && fsr; +} + +/* + * Service routine to read status register until ready, or timeout occurs. + * Returns non-zero if error. + */ +static int spi_nor_wait_till_ready_with_timeout(struct spi_nor *nor, + unsigned long timeout) +{ + unsigned long timebase; + int ret; + + timebase = get_timer(0); + + while (get_timer(timebase) < timeout) { + ret = spi_nor_ready(nor); + if (ret < 0) + return ret; + if (ret) + return 0; + } + + dev_err(nor->dev, "flash operation timed out\n"); + + return -ETIMEDOUT; +} + +static int spi_nor_wait_till_ready(struct spi_nor *nor) +{ + return spi_nor_wait_till_ready_with_timeout(nor, + DEFAULT_READY_WAIT_JIFFIES); +} +#endif /* CONFIG_SPI_FLASH_SPANSION */ + +/* + * Erase an address range on the nor chip. The address range may extend + * one or more erase sectors. Return an error is there is a problem erasing. + */ +static int spi_nor_erase(struct mtd_info *mtd, struct erase_info *instr) +{ + return -ENOTSUPP; +} + +static const struct flash_info *spi_nor_read_id(struct spi_nor *nor) +{ + int tmp; + u8 id[SPI_NOR_MAX_ID_LEN]; + const struct flash_info *info; + + tmp = spi_nor_read_reg(nor, SPINOR_OP_RDID, id, SPI_NOR_MAX_ID_LEN); + if (tmp < 0) { + dev_dbg(nor->dev, "error %d reading JEDEC ID\n", tmp); + return ERR_PTR(tmp); + } + + info = spi_nor_ids; + for (; info->sector_size != 0; info++) { + if (info->id_len) { + if (!memcmp(info->id, id, info->id_len)) + return info; + } + } + dev_dbg(nor->dev, "unrecognized JEDEC id bytes: %02x, %02x, %02x\n", + id[0], id[1], id[2]); + return ERR_PTR(-ENODEV); +} + +static int spi_nor_read(struct mtd_info *mtd, loff_t from, size_t len, + size_t *retlen, u_char *buf) +{ + struct spi_nor *nor = mtd_to_spi_nor(mtd); + int ret; + + dev_dbg(nor->dev, "from 0x%08x, len %zd\n", (u32)from, len); + + while (len) { + loff_t addr = from; + + ret = spi_nor_read_data(nor, addr, len, buf); + if (ret == 0) { + /* We shouldn't see 0-length reads */ + ret = -EIO; + goto read_err; + } + if (ret < 0) + goto read_err; + + *retlen += ret; + buf += ret; + from += ret; + len -= ret; + } + ret = 0; + +read_err: + return ret; +} + +/* + * Write an address range to the nor chip. Data must be written in + * FLASH_PAGESIZE chunks. The address range may be any size provided + * it is within the physical boundaries. + */ +static int spi_nor_write(struct mtd_info *mtd, loff_t to, size_t len, + size_t *retlen, const u_char *buf) +{ + return -ENOTSUPP; +} + +#ifdef CONFIG_SPI_FLASH_MACRONIX +/** + * macronix_quad_enable() - set QE bit in Status Register. + * @nor: pointer to a 'struct spi_nor' + * + * Set the Quad Enable (QE) bit in the Status Register. + * + * bit 6 of the Status Register is the QE bit for Macronix like QSPI memories. + * + * Return: 0 on success, -errno otherwise. + */ +static int macronix_quad_enable(struct spi_nor *nor) +{ + int ret, val; + + val = read_sr(nor); + if (val < 0) + return val; + if (val & SR_QUAD_EN_MX) + return 0; + + write_enable(nor); + + write_sr(nor, val | SR_QUAD_EN_MX); + + ret = spi_nor_wait_till_ready(nor); + if (ret) + return ret; + + ret = read_sr(nor); + if (!(ret > 0 && (ret & SR_QUAD_EN_MX))) { + dev_err(nor->dev, "Macronix Quad bit not set\n"); + return -EINVAL; + } + + return 0; +} +#endif + +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) +/* + * Write status Register and configuration register with 2 bytes + * The first byte will be written to the status register, while the + * second byte will be written to the configuration register. + * Return negative if error occurred. + */ +static int write_sr_cr(struct spi_nor *nor, u8 *sr_cr) +{ + int ret; + + write_enable(nor); + + ret = spi_nor_write_reg(nor, SPINOR_OP_WRSR, sr_cr, 2); + if (ret < 0) { + dev_dbg(nor->dev, + "error while writing configuration register\n"); + return -EINVAL; + } + + ret = spi_nor_wait_till_ready(nor); + if (ret) { + dev_dbg(nor->dev, + "timeout while writing configuration register\n"); + return ret; + } + + return 0; +} + +/** + * spansion_read_cr_quad_enable() - set QE bit in Configuration Register. + * @nor: pointer to a 'struct spi_nor' + * + * Set the Quad Enable (QE) bit in the Configuration Register. + * This function should be used with QSPI memories supporting the Read + * Configuration Register (35h) instruction. + * + * bit 1 of the Configuration Register is the QE bit for Spansion like QSPI + * memories. + * + * Return: 0 on success, -errno otherwise. + */ +static int spansion_read_cr_quad_enable(struct spi_nor *nor) +{ + u8 sr_cr[2]; + int ret; + + /* Check current Quad Enable bit value. */ + ret = read_cr(nor); + if (ret < 0) { + dev_dbg(dev, "error while reading configuration register\n"); + return -EINVAL; + } + + if (ret & CR_QUAD_EN_SPAN) + return 0; + + sr_cr[1] = ret | CR_QUAD_EN_SPAN; + + /* Keep the current value of the Status Register. */ + ret = read_sr(nor); + if (ret < 0) { + dev_dbg(dev, "error while reading status register\n"); + return -EINVAL; + } + sr_cr[0] = ret; + + ret = write_sr_cr(nor, sr_cr); + if (ret) + return ret; + + /* Read back and check it. */ + ret = read_cr(nor); + if (!(ret > 0 && (ret & CR_QUAD_EN_SPAN))) { + dev_dbg(nor->dev, "Spansion Quad bit not set\n"); + return -EINVAL; + } + + return 0; +} +#endif /* CONFIG_SPI_FLASH_SPANSION */ + +struct spi_nor_read_command { + u8 num_mode_clocks; + u8 num_wait_states; + u8 opcode; + enum spi_nor_protocol proto; +}; + +enum spi_nor_read_command_index { + SNOR_CMD_READ, + SNOR_CMD_READ_FAST, + + /* Quad SPI */ + SNOR_CMD_READ_1_1_4, + + SNOR_CMD_READ_MAX +}; + +struct spi_nor_flash_parameter { + struct spi_nor_hwcaps hwcaps; + struct spi_nor_read_command reads[SNOR_CMD_READ_MAX]; +}; + +static void +spi_nor_set_read_settings(struct spi_nor_read_command *read, + u8 num_mode_clocks, + u8 num_wait_states, + u8 opcode, + enum spi_nor_protocol proto) +{ + read->num_mode_clocks = num_mode_clocks; + read->num_wait_states = num_wait_states; + read->opcode = opcode; + read->proto = proto; +} + +static int spi_nor_init_params(struct spi_nor *nor, + const struct flash_info *info, + struct spi_nor_flash_parameter *params) +{ + /* (Fast) Read settings. */ + params->hwcaps.mask = SNOR_HWCAPS_READ; + spi_nor_set_read_settings(¶ms->reads[SNOR_CMD_READ], + 0, 0, SPINOR_OP_READ, + SNOR_PROTO_1_1_1); + + if (!(info->flags & SPI_NOR_NO_FR)) { + params->hwcaps.mask |= SNOR_HWCAPS_READ_FAST; + spi_nor_set_read_settings(¶ms->reads[SNOR_CMD_READ_FAST], + 0, 8, SPINOR_OP_READ_FAST, + SNOR_PROTO_1_1_1); + } + + if (info->flags & SPI_NOR_QUAD_READ) { + params->hwcaps.mask |= SNOR_HWCAPS_READ_1_1_4; + spi_nor_set_read_settings(¶ms->reads[SNOR_CMD_READ_1_1_4], + 0, 8, SPINOR_OP_READ_1_1_4, + SNOR_PROTO_1_1_4); + } + + return 0; +} + +static int spi_nor_select_read(struct spi_nor *nor, + const struct spi_nor_flash_parameter *params, + u32 shared_hwcaps) +{ + int best_match = shared_hwcaps & SNOR_HWCAPS_READ_MASK; + int cmd; + const struct spi_nor_read_command *read; + + if (best_match < 0) + return -EINVAL; + + if (best_match & SNOR_HWCAPS_READ_1_1_4) + cmd = SNOR_CMD_READ_1_1_4; + else + cmd = SNOR_CMD_READ; + + read = ¶ms->reads[cmd]; + nor->read_opcode = read->opcode; + nor->read_proto = read->proto; + + /* + * In the spi-nor framework, we don't need to make the difference + * between mode clock cycles and wait state clock cycles. + * Indeed, the value of the mode clock cycles is used by a QSPI + * flash memory to know whether it should enter or leave its 0-4-4 + * (Continuous Read / XIP) mode. + * eXecution In Place is out of the scope of the mtd sub-system. + * Hence we choose to merge both mode and wait state clock cycles + * into the so called dummy clock cycles. + */ + nor->read_dummy = read->num_mode_clocks + read->num_wait_states; + return 0; +} + +static int spi_nor_setup(struct spi_nor *nor, const struct flash_info *info, + const struct spi_nor_flash_parameter *params, + const struct spi_nor_hwcaps *hwcaps) +{ + u32 shared_mask; + int err; + + /* + * Keep only the hardware capabilities supported by both the SPI + * controller and the SPI flash memory. + */ + shared_mask = hwcaps->mask & params->hwcaps.mask; + + /* Select the (Fast) Read command. */ + err = spi_nor_select_read(nor, params, shared_mask); + if (err) { + dev_dbg(nor->dev, + "can't select read settings supported by both the SPI controller and memory.\n"); + return err; + } + + /* Enable Quad I/O if needed. */ + if (spi_nor_get_protocol_width(nor->read_proto) == 4) { + switch (JEDEC_MFR(info)) { +#ifdef CONFIG_SPI_FLASH_MACRONIX + case SNOR_MFR_MACRONIX: + err = macronix_quad_enable(nor); + break; +#endif + case SNOR_MFR_MICRON: + break; + + default: +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) + /* Kept only for backward compatibility purpose. */ + err = spansion_read_cr_quad_enable(nor); +#endif + break; + } + } + if (err) { + dev_dbg(nor->dev, "quad mode not supported\n"); + return err; + } + + return 0; +} + +static int spi_nor_init(struct spi_nor *nor) +{ + if (nor->addr_width == 4 && + (JEDEC_MFR(nor->info) != SNOR_MFR_SPANSION) && + !(nor->info->flags & SPI_NOR_4B_OPCODES)) { + /* + * If the RESET# pin isn't hooked up properly, or the system + * otherwise doesn't perform a reset command in the boot + * sequence, it's impossible to 100% protect against unexpected + * reboots (e.g., crashes). Warn the user (or hopefully, system + * designer) that this is bad. + */ + if (nor->flags & SNOR_F_BROKEN_RESET) + printf("enabling reset hack; may not recover from unexpected reboots\n"); + set_4byte(nor, nor->info, 1); + } + + return 0; +} + +int spi_nor_scan(struct spi_nor *nor) +{ + struct spi_nor_flash_parameter params; + const struct flash_info *info = NULL; + struct mtd_info *mtd = &nor->mtd; + struct spi_nor_hwcaps hwcaps = { + .mask = SNOR_HWCAPS_READ | + SNOR_HWCAPS_READ_FAST + }; + struct spi_slave *spi = nor->spi; + int ret; + + /* Reset SPI protocol for all commands. */ + nor->reg_proto = SNOR_PROTO_1_1_1; + nor->read_proto = SNOR_PROTO_1_1_1; + nor->write_proto = SNOR_PROTO_1_1_1; + + if (spi->mode & SPI_RX_QUAD) + hwcaps.mask |= SNOR_HWCAPS_READ_1_1_4; + + info = spi_nor_read_id(nor); + if (IS_ERR_OR_NULL(info)) + return -ENOENT; + /* Parse the Serial Flash Discoverable Parameters table. */ + ret = spi_nor_init_params(nor, info, ¶ms); + if (ret) + return ret; + + mtd->name = "spi-flash"; + mtd->priv = nor; + mtd->type = MTD_NORFLASH; + mtd->writesize = 1; + mtd->flags = MTD_CAP_NORFLASH; + mtd->size = info->sector_size * info->n_sectors; + mtd->_erase = spi_nor_erase; + mtd->_read = spi_nor_read; + mtd->_write = spi_nor_write; + + nor->size = mtd->size; + + if (info->flags & USE_FSR) + nor->flags |= SNOR_F_USE_FSR; + if (info->flags & USE_CLSR) + nor->flags |= SNOR_F_USE_CLSR; + + if (info->flags & SPI_NOR_NO_FR) + params.hwcaps.mask &= ~SNOR_HWCAPS_READ_FAST; + + /* + * Configure the SPI memory: + * - select op codes for (Fast) Read, Page Program and Sector Erase. + * - set the number of dummy cycles (mode cycles + wait states). + * - set the SPI protocols for register and memory accesses. + * - set the Quad Enable bit if needed (required by SPI x-y-4 protos). + */ + ret = spi_nor_setup(nor, info, ¶ms, &hwcaps); + if (ret) + return ret; + + if (nor->addr_width) { + /* already configured from SFDP */ + } else if (info->addr_width) { + nor->addr_width = info->addr_width; + } else if (mtd->size > 0x1000000) { + /* enable 4-byte addressing if the device exceeds 16MiB */ + nor->addr_width = 4; + if (JEDEC_MFR(info) == SNOR_MFR_SPANSION || + info->flags & SPI_NOR_4B_OPCODES) + spi_nor_set_4byte_opcodes(nor, info); + } else { + nor->addr_width = 3; + } + + if (nor->addr_width > SPI_NOR_MAX_ADDR_WIDTH) { + dev_dbg(dev, "address width is too large: %u\n", + nor->addr_width); + return -EINVAL; + } + + /* Send all the required SPI flash commands to initialize device */ + nor->info = info; + ret = spi_nor_init(nor); + if (ret) + return ret; + + return 0; +} +EXPORT_SYMBOL_GPL(spi_nor_scan); + +/* U-Boot specific functions, need to extend MTD to support these */ +int spi_flash_cmd_get_sw_write_prot(struct spi_nor *nor) +{ + return -ENOTSUPP; +} + +MODULE_LICENSE("GPL"); +MODULE_AUTHOR("Huang Shijie shijie8@gmail.com"); +MODULE_AUTHOR("Mike Lavender"); +MODULE_DESCRIPTION("framework for SPI NOR"); diff --git a/drivers/mtd/spi/spi-nor.c b/drivers/mtd/spi/spi-nor.c index a192087882a1..80e6c03bd100 100644 --- a/drivers/mtd/spi/spi-nor.c +++ b/drivers/mtd/spi/spi-nor.c @@ -823,284 +823,26 @@ static int spi_nor_is_locked(struct mtd_info *mtd, loff_t ofs, uint64_t len) return ret; }
-/* Used when the "_ext_id" is two bytes at most */ -#define INFO(_jedec_id, _ext_id, _sector_size, _n_sectors, _flags) \ - .id = { \ - ((_jedec_id) >> 16) & 0xff, \ - ((_jedec_id) >> 8) & 0xff, \ - (_jedec_id) & 0xff, \ - ((_ext_id) >> 8) & 0xff, \ - (_ext_id) & 0xff, \ - }, \ - .id_len = (!(_jedec_id) ? 0 : (3 + ((_ext_id) ? 2 : 0))), \ - .sector_size = (_sector_size), \ - .n_sectors = (_n_sectors), \ - .page_size = 256, \ - .flags = (_flags), - -#define INFO6(_jedec_id, _ext_id, _sector_size, _n_sectors, _flags) \ - .id = { \ - ((_jedec_id) >> 16) & 0xff, \ - ((_jedec_id) >> 8) & 0xff, \ - (_jedec_id) & 0xff, \ - ((_ext_id) >> 16) & 0xff, \ - ((_ext_id) >> 8) & 0xff, \ - (_ext_id) & 0xff, \ - }, \ - .id_len = 6, \ - .sector_size = (_sector_size), \ - .n_sectors = (_n_sectors), \ - .page_size = 256, \ - .flags = (_flags), - -/* NOTE: double check command sets and memory organization when you add - * more nor chips. This current list focusses on newer chips, which - * have been converging on command sets which including JEDEC ID. - * - * All newly added entries should describe *hardware* and should use SECT_4K - * (or SECT_4K_PMC) if hardware supports erasing 4 KiB sectors. For usage - * scenarios excluding small sectors there is config option that can be - * disabled: CONFIG_MTD_SPI_NOR_USE_4K_SECTORS. - * For historical (and compatibility) reasons (before we got above config) some - * old entries may be missing 4K flag. - */ -const struct flash_info spi_nor_ids[] = { -#ifdef CONFIG_SPI_FLASH_ATMEL /* ATMEL */ - /* Atmel -- some are (confusingly) marketed as "DataFlash" */ - { "at26df321", INFO(0x1f4700, 0, 64 * 1024, 64, SECT_4K) }, - { "at25df321a", INFO(0x1f4701, 0, 64 * 1024, 64, SECT_4K) }, - - { "at45db011d", INFO(0x1f2200, 0, 64 * 1024, 4, SECT_4K) }, - { "at45db021d", INFO(0x1f2300, 0, 64 * 1024, 8, SECT_4K) }, - { "at45db041d", INFO(0x1f2400, 0, 64 * 1024, 8, SECT_4K) }, - { "at45db081d", INFO(0x1f2500, 0, 64 * 1024, 16, SECT_4K) }, - { "at45db161d", INFO(0x1f2600, 0, 64 * 1024, 32, SECT_4K) }, - { "at45db321d", INFO(0x1f2700, 0, 64 * 1024, 64, SECT_4K) }, - { "at45db641d", INFO(0x1f2800, 0, 64 * 1024, 128, SECT_4K) }, - { "at26df081a", INFO(0x1f4501, 0, 64 * 1024, 16, SECT_4K) }, -#endif -#ifdef CONFIG_SPI_FLASH_EON /* EON */ - /* EON -- en25xxx */ - { "en25q32b", INFO(0x1c3016, 0, 64 * 1024, 64, 0) }, - { "en25q64", INFO(0x1c3017, 0, 64 * 1024, 128, SECT_4K) }, - { "en25qh128", INFO(0x1c7018, 0, 64 * 1024, 256, 0) }, - { "en25s64", INFO(0x1c3817, 0, 64 * 1024, 128, SECT_4K) }, -#endif -#ifdef CONFIG_SPI_FLASH_GIGADEVICE /* GIGADEVICE */ - /* GigaDevice */ - { - "gd25q16", INFO(0xc84015, 0, 64 * 1024, 32, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | - SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) - }, - { - "gd25q32", INFO(0xc84016, 0, 64 * 1024, 64, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | - SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) - }, - { - "gd25lq32", INFO(0xc86016, 0, 64 * 1024, 64, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | - SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) - }, - { - "gd25q64", INFO(0xc84017, 0, 64 * 1024, 128, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | - SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) - }, -#endif -#ifdef CONFIG_SPI_FLASH_ISSI /* ISSI */ - /* ISSI */ - { "is25lq040b", INFO(0x9d4013, 0, 64 * 1024, 8, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, - { "is25lp032", INFO(0x9d6016, 0, 64 * 1024, 64, 0) }, - { "is25lp064", INFO(0x9d6017, 0, 64 * 1024, 128, 0) }, - { "is25lp128", INFO(0x9d6018, 0, 64 * 1024, 256, - SECT_4K | SPI_NOR_DUAL_READ) }, - { "is25lp256", INFO(0x9d6019, 0, 64 * 1024, 512, - SECT_4K | SPI_NOR_DUAL_READ) }, - { "is25wp032", INFO(0x9d7016, 0, 64 * 1024, 64, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, - { "is25wp064", INFO(0x9d7017, 0, 64 * 1024, 128, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, - { "is25wp128", INFO(0x9d7018, 0, 64 * 1024, 256, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, -#endif -#ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ - /* Macronix */ - { "mx25l2005a", INFO(0xc22012, 0, 64 * 1024, 4, SECT_4K) }, - { "mx25l4005a", INFO(0xc22013, 0, 64 * 1024, 8, SECT_4K) }, - { "mx25l8005", INFO(0xc22014, 0, 64 * 1024, 16, 0) }, - { "mx25l1606e", INFO(0xc22015, 0, 64 * 1024, 32, SECT_4K) }, - { "mx25l3205d", INFO(0xc22016, 0, 64 * 1024, 64, SECT_4K) }, - { "mx25l6405d", INFO(0xc22017, 0, 64 * 1024, 128, SECT_4K) }, - { "mx25u2033e", INFO(0xc22532, 0, 64 * 1024, 4, SECT_4K) }, - { "mx25u1635e", INFO(0xc22535, 0, 64 * 1024, 32, SECT_4K) }, - { "mx25u6435f", INFO(0xc22537, 0, 64 * 1024, 128, SECT_4K) }, - { "mx25l12805d", INFO(0xc22018, 0, 64 * 1024, 256, 0) }, - { "mx25l12855e", INFO(0xc22618, 0, 64 * 1024, 256, 0) }, - { "mx25l25635e", INFO(0xc22019, 0, 64 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, - { "mx25u25635f", INFO(0xc22539, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_4B_OPCODES) }, - { "mx25l25655e", INFO(0xc22619, 0, 64 * 1024, 512, 0) }, - { "mx66l51235l", INFO(0xc2201a, 0, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, - { "mx66u51235f", INFO(0xc2253a, 0, 64 * 1024, 1024, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, - { "mx66l1g45g", INFO(0xc2201b, 0, 64 * 1024, 2048, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, - { "mx25l1633e", INFO(0xc22415, 0, 64 * 1024, 32, SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | SECT_4K) }, -#endif - -#ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */ - /* Micron */ - { "n25q016a", INFO(0x20bb15, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_QUAD_READ) }, - { "n25q032", INFO(0x20ba16, 0, 64 * 1024, 64, SPI_NOR_QUAD_READ) }, - { "n25q032a", INFO(0x20bb16, 0, 64 * 1024, 64, SPI_NOR_QUAD_READ) }, - { "n25q064", INFO(0x20ba17, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_QUAD_READ) }, - { "n25q064a", INFO(0x20bb17, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_QUAD_READ) }, - { "n25q128a11", INFO(0x20bb18, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_QUAD_READ) }, - { "n25q128a13", INFO(0x20ba18, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_QUAD_READ) }, - { "n25q256a", INFO(0x20ba19, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, - { "n25q256ax1", INFO(0x20bb19, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_QUAD_READ) }, - { "n25q512a", INFO(0x20bb20, 0, 64 * 1024, 1024, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ) }, - { "n25q512ax3", INFO(0x20ba20, 0, 64 * 1024, 1024, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ) }, - { "n25q00", INFO(0x20ba21, 0, 64 * 1024, 2048, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE) }, - { "n25q00a", INFO(0x20bb21, 0, 64 * 1024, 2048, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE) }, - { "mt25qu02g", INFO(0x20bb22, 0, 64 * 1024, 4096, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE) }, -#endif -#ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */ - /* Spansion/Cypress -- single (large) sector size only, at least - * for the chips listed here (without boot sectors). - */ - { "s25sl032p", INFO(0x010215, 0x4d00, 64 * 1024, 64, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, - { "s25sl064p", INFO(0x010216, 0x4d00, 64 * 1024, 128, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, - { "s25fl256s0", INFO(0x010219, 0x4d00, 256 * 1024, 128, USE_CLSR) }, - { "s25fl256s1", INFO(0x010219, 0x4d01, 64 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, - { "s25fl512s", INFO6(0x010220, 0x4d0081, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, - { "s25fl512s_256k", INFO(0x010220, 0x4d00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, - { "s25fl512s_64k", INFO(0x010220, 0x4d01, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, - { "s25fl512s_512k", INFO(0x010220, 0x4f00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, - { "s25sl12800", INFO(0x012018, 0x0300, 256 * 1024, 64, 0) }, - { "s25sl12801", INFO(0x012018, 0x0301, 64 * 1024, 256, 0) }, - { "s25fl128s", INFO6(0x012018, 0x4d0180, 64 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, - { "s25fl129p0", INFO(0x012018, 0x4d00, 256 * 1024, 64, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, - { "s25fl129p1", INFO(0x012018, 0x4d01, 64 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, - { "s25sl008a", INFO(0x010213, 0, 64 * 1024, 16, 0) }, - { "s25sl016a", INFO(0x010214, 0, 64 * 1024, 32, 0) }, - { "s25sl032a", INFO(0x010215, 0, 64 * 1024, 64, 0) }, - { "s25sl064a", INFO(0x010216, 0, 64 * 1024, 128, 0) }, - { "s25fl116k", INFO(0x014015, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, - { "s25fl164k", INFO(0x014017, 0, 64 * 1024, 128, SECT_4K) }, - { "s25fl208k", INFO(0x014014, 0, 64 * 1024, 16, SECT_4K | SPI_NOR_DUAL_READ) }, - { "s25fl128l", INFO(0x016018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, -#endif -#ifdef CONFIG_SPI_FLASH_SST /* SST */ - /* SST -- large erase sizes are "overlays", "sectors" are 4K */ - { "sst25vf040b", INFO(0xbf258d, 0, 64 * 1024, 8, SECT_4K | SST_WRITE) }, - { "sst25vf080b", INFO(0xbf258e, 0, 64 * 1024, 16, SECT_4K | SST_WRITE) }, - { "sst25vf016b", INFO(0xbf2541, 0, 64 * 1024, 32, SECT_4K | SST_WRITE) }, - { "sst25vf032b", INFO(0xbf254a, 0, 64 * 1024, 64, SECT_4K | SST_WRITE) }, - { "sst25vf064c", INFO(0xbf254b, 0, 64 * 1024, 128, SECT_4K) }, - { "sst25wf512", INFO(0xbf2501, 0, 64 * 1024, 1, SECT_4K | SST_WRITE) }, - { "sst25wf010", INFO(0xbf2502, 0, 64 * 1024, 2, SECT_4K | SST_WRITE) }, - { "sst25wf020", INFO(0xbf2503, 0, 64 * 1024, 4, SECT_4K | SST_WRITE) }, - { "sst25wf020a", INFO(0x621612, 0, 64 * 1024, 4, SECT_4K) }, - { "sst25wf040b", INFO(0x621613, 0, 64 * 1024, 8, SECT_4K) }, - { "sst25wf040", INFO(0xbf2504, 0, 64 * 1024, 8, SECT_4K | SST_WRITE) }, - { "sst25wf080", INFO(0xbf2505, 0, 64 * 1024, 16, SECT_4K | SST_WRITE) }, - { "sst26vf064b", INFO(0xbf2643, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, - { "sst26wf016", INFO(0xbf2651, 0, 64 * 1024, 32, SECT_4K) }, - { "sst26wf032", INFO(0xbf2622, 0, 64 * 1024, 64, SECT_4K) }, - { "sst26wf064", INFO(0xbf2643, 0, 64 * 1024, 128, SECT_4K) }, -#endif -#ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */ - /* ST Microelectronics -- newer production may have feature updates */ - { "m25p10", INFO(0x202011, 0, 32 * 1024, 4, 0) }, - { "m25p20", INFO(0x202012, 0, 64 * 1024, 4, 0) }, - { "m25p40", INFO(0x202013, 0, 64 * 1024, 8, 0) }, - { "m25p80", INFO(0x202014, 0, 64 * 1024, 16, 0) }, - { "m25p16", INFO(0x202015, 0, 64 * 1024, 32, 0) }, - { "m25p32", INFO(0x202016, 0, 64 * 1024, 64, 0) }, - { "m25p64", INFO(0x202017, 0, 64 * 1024, 128, 0) }, - { "m25p128", INFO(0x202018, 0, 256 * 1024, 64, 0) }, - { "m25pe16", INFO(0x208015, 0, 64 * 1024, 32, SECT_4K) }, - { "m25px16", INFO(0x207115, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, - { "m25px64", INFO(0x207117, 0, 64 * 1024, 128, 0) }, -#endif -#ifdef CONFIG_SPI_FLASH_WINBOND /* WINBOND */ - /* Winbond -- w25x "blocks" are 64K, "sectors" are 4KiB */ - { "w25x05", INFO(0xef3010, 0, 64 * 1024, 1, SECT_4K) }, - { "w25x10", INFO(0xef3011, 0, 64 * 1024, 2, SECT_4K) }, - { "w25x20", INFO(0xef3012, 0, 64 * 1024, 4, SECT_4K) }, - { "w25x40", INFO(0xef3013, 0, 64 * 1024, 8, SECT_4K) }, - { "w25x80", INFO(0xef3014, 0, 64 * 1024, 16, SECT_4K) }, - { "w25x16", INFO(0xef3015, 0, 64 * 1024, 32, SECT_4K) }, - { - "w25q16dw", INFO(0xef6015, 0, 64 * 1024, 32, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | - SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) - }, - { "w25x32", INFO(0xef3016, 0, 64 * 1024, 64, SECT_4K) }, - { "w25q20cl", INFO(0xef4012, 0, 64 * 1024, 4, SECT_4K) }, - { "w25q20bw", INFO(0xef5012, 0, 64 * 1024, 4, SECT_4K) }, - { "w25q20ew", INFO(0xef6012, 0, 64 * 1024, 4, SECT_4K) }, - { "w25q32", INFO(0xef4016, 0, 64 * 1024, 64, SECT_4K) }, - { - "w25q32dw", INFO(0xef6016, 0, 64 * 1024, 64, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | - SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) - }, - { - "w25q32jv", INFO(0xef7016, 0, 64 * 1024, 64, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | - SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) - }, - { "w25x64", INFO(0xef3017, 0, 64 * 1024, 128, SECT_4K) }, - { "w25q64", INFO(0xef4017, 0, 64 * 1024, 128, SECT_4K) }, - { - "w25q64dw", INFO(0xef6017, 0, 64 * 1024, 128, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | - SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) - }, - { - "w25q128fw", INFO(0xef6018, 0, 64 * 1024, 256, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | - SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) - }, - { "w25q80", INFO(0xef5014, 0, 64 * 1024, 16, SECT_4K) }, - { "w25q80bl", INFO(0xef4014, 0, 64 * 1024, 16, SECT_4K) }, - { "w25q128", INFO(0xef4018, 0, 64 * 1024, 256, SECT_4K) }, - { "w25q256", INFO(0xef4019, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, - { "w25m512jv", INFO(0xef7119, 0, 64 * 1024, 1024, - SECT_4K | SPI_NOR_QUAD_READ | SPI_NOR_DUAL_READ) }, -#endif -#ifdef CONFIG_SPI_FLASH_XMC - /* XMC (Wuhan Xinxin Semiconductor Manufacturing Corp.) */ - { "XM25QH64A", INFO(0x207017, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, - { "XM25QH128A", INFO(0x207018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, -#endif - { }, -}; - static const struct flash_info *spi_nor_read_id(struct spi_nor *nor) { int tmp; u8 id[SPI_NOR_MAX_ID_LEN]; const struct flash_info *info;
- if (!ARRAY_SIZE(spi_nor_ids)) - return ERR_PTR(-ENODEV); - tmp = nor->read_reg(nor, SPINOR_OP_RDID, id, SPI_NOR_MAX_ID_LEN); if (tmp < 0) { dev_dbg(nor->dev, "error %d reading JEDEC ID\n", tmp); return ERR_PTR(tmp); }
- for (tmp = 0; tmp < ARRAY_SIZE(spi_nor_ids) - 1; tmp++) { - info = &spi_nor_ids[tmp]; + info = spi_nor_ids; + for (; info->name; info++) { if (info->id_len) { if (!memcmp(info->id, id, info->id_len)) - return &spi_nor_ids[tmp]; + return info; } } + dev_err(nor->dev, "unrecognized JEDEC id bytes: %02x, %02x, %02x\n", id[0], id[1], id[2]); return ERR_PTR(-ENODEV);
We could reduce the size further by removing write functionality (and everything that's related to write, like write protection, etc.). If this was a Kconfig option, write-related code in drivers could be left out as well.
But that's probably work for the future?
help
Am I right that this does not do anything when SPL_SPI_FLASH_TINY is enabled? Should it somehow depend on "not tiny"?
Would it make sense to have "sf_probe.o" and "spi-nor-ids.o" the same for all 3 configs to reduce duplicate lines?
endif
- Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/
INFO_NAME(_name) \
.id = { \
(_ext_id) & 0xff, \
.page_size = 256, \
.flags = (_flags),
INFO_NAME(_name) \
.id = { \
(_ext_id) & 0xff, \
.id_len = 6, \
.page_size = 256, \
.flags = (_flags),
- more nor chips. This current list focusses on newer chips, which
- have been converging on command sets which including JEDEC ID.
- All newly added entries should describe *hardware* and should use SECT_4K
- (or SECT_4K_PMC) if hardware supports erasing 4 KiB sectors. For usage
- scenarios excluding small sectors there is config option that can be
- disabled: CONFIG_MTD_SPI_NOR_USE_4K_SECTORS.
- For historical (and compatibility) reasons (before we got above config) some
- old entries may be missing 4K flag.
/* GigaDevice */
/* ISSI */
/* Macronix */
/* Micron */
- Based on m25p80.c, by Mike Lavender (mike@steroidmicros.com), with
- influence from lart.c (Abraham Van Der Merwe) and mtd_dataflash.c
- Copyright (C) 2005, Intec Automation Inc.
- Copyright (C) 2014, Freescale Semiconductor, Inc.
- Synced from Linux v4.19
- For everything but full-chip erase; probably could be much smaller, but kept
- around for safety for now
*op, void *buf)
else
SPI_MEM_OP_NO_ADDR,
int ret;
if (ret < 0)
code);
return ret;
SPI_MEM_OP_NO_ADDR,
u_char *buf)
int ret;
while (remaining) {
if (ret)
return ret;
if (ret)
return ret;
return len;
- Read configuration register, returning its value in the
- location. Return the configuration register value.
- Returns negative if error occurred.
int ret;
u8 val;
if (ret < 0) {
return ret;
return val;
+} +#endif
- Write status register 1 byte
- Set write enable latch with Write Enable command.
- Send write disable instruction to the chip.
return mtd->priv;
size_t i;
return table[i][1];
return opcode;
int enable)
int status;
u8 cmd;
need_wren = true;
if (need_wren)
write_enable(nor);
if (need_wren)
write_disable(nor);
write_enable(nor);
nor->cmd_buf, 1);
write_disable(nor);
return status;
default:
- Read the status register, returning its value in the location
- Return the status register value.
int ret;
u8 val;
if (ret < 0) {
return ret;
return val;
- Read the flag status register, returning its value in the location
int ret;
u8 val;
if (ret < 0) {
return ret;
return val;
if (sr < 0)
return sr;
if (fsr < 0)
return fsr;
int sr, fsr;
if (sr < 0)
return sr;
if (fsr < 0)
return fsr;
return sr && fsr;
- Service routine to read status register until ready, or timeout occurs.
- Returns non-zero if error.
int ret;
if (ret < 0)
return ret;
if (ret)
return -ETIMEDOUT;
- Erase an address range on the nor chip. The address range may extend
- one or more erase sectors. Return an error is there is a problem erasing.
return -ENOTSUPP;
int tmp;
if (tmp < 0) {
info = spi_nor_ids;
if (info->id_len) {
return info;
int ret;
while (len) {
loff_t addr = from;
if (ret == 0) {
ret = -EIO;
goto read_err;
if (ret < 0)
goto read_err;
*retlen += ret;
buf += ret;
from += ret;
len -= ret;
ret = 0;
+read_err:
return ret;
- Write an address range to the nor chip. Data must be written in
- FLASH_PAGESIZE chunks. The address range may be any size provided
- it is within the physical boundaries.
return -ENOTSUPP;
- macronix_quad_enable() - set QE bit in Status Register.
- @nor: pointer to a 'struct spi_nor'
- Set the Quad Enable (QE) bit in the Status Register.
- bit 6 of the Status Register is the QE bit for Macronix like QSPI memories.
- Return: 0 on success, -errno otherwise.
int ret, val;
val = read_sr(nor);
if (val < 0)
return val;
write_enable(nor);
if (ret)
return ret;
ret = read_sr(nor);
return -EINVAL;
+} +#endif
- Write status Register and configuration register with 2 bytes
- The first byte will be written to the status register, while the
- second byte will be written to the configuration register.
- Return negative if error occurred.
int ret;
write_enable(nor);
if (ret < 0) {
dev_dbg(nor->dev,
return -EINVAL;
if (ret) {
dev_dbg(nor->dev,
return ret;
- spansion_read_cr_quad_enable() - set QE bit in Configuration Register.
- Set the Quad Enable (QE) bit in the Configuration Register.
- This function should be used with QSPI memories supporting the Read
- Configuration Register (35h) instruction.
- bit 1 of the Configuration Register is the QE bit for Spansion like QSPI
- memories.
u8 sr_cr[2];
int ret;
ret = read_cr(nor);
if (ret < 0) {
return -EINVAL;
ret = read_sr(nor);
if (ret < 0) {
return -EINVAL;
sr_cr[0] = ret;
if (ret)
return ret;
ret = read_cr(nor);
return -EINVAL;
u8 num_mode_clocks;
u8 num_wait_states;
u8 opcode;
SNOR_CMD_READ,
SNOR_CMD_READ_FAST,
/* Quad SPI */
SNOR_CMD_READ_MAX
u8 num_mode_clocks,
u8 num_wait_states,
u8 opcode,
SNOR_PROTO_1_1_1);
SNOR_PROTO_1_1_1);
SNOR_PROTO_1_1_4);
u32 shared_hwcaps)
int cmd;
if (best_match < 0)
return -EINVAL;
else
u32 shared_mask;
int err;
if (err) {
dev_dbg(nor->dev,
return err;
break;
break;
default:
break;
if (err) {
return err;
int ret;
return -ENOENT;
if (ret)
return ret;
mtd->priv = nor;
mtd->writesize = 1;
if (ret)
return ret;
} else {
nor->addr_width);
return -EINVAL;
nor->info = info;
if (ret)
return ret;
return -ENOTSUPP;
.id = { \
(_ext_id) & 0xff, \
.page_size = 256, \
.flags = (_flags),
.id = { \
(_ext_id) & 0xff, \
.id_len = 6, \
.page_size = 256, \
.flags = (_flags),
/* GigaDevice */
/* ISSI */
/* Macronix */
-#endif
/* Micron */
-#endif
info = spi_nor_ids;
return info; } }
-- 2.19.2
Yes, for now
help
Will take care of that.
Ok, I changed that to:
diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index 9cd6672e93ce..9f7ab87b4c5f 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -4,12 +4,20 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
obj-$(CONFIG_DM_SPI_FLASH) += sf-uclass.o +spi-flash-y := sf_probe.o spi-nor-ids.o
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SPL_SPI_BOOT) += fsl_espi_spl.o +ifeq ($(CONFIG_SPL_SPI_FLASH_TINY),y) +spi-flash-y += spi-nor-tiny.o +else +spi-flash-y += spi-nor.o +endif +else +spi-flash-y += spi-nor.o endif
-obj-$(CONFIG_SPI_FLASH) += sf_probe.o spi-nor.o +obj-$(CONFIG_SPI_FLASH) += spi-flash.o
Regards Vignesh
endif
INFO_NAME(_name) \
.id = { \
(_ext_id) & 0xff, \
.page_size = 256, \
.flags = (_flags),
INFO_NAME(_name) \
.id = { \
(_ext_id) & 0xff, \
.id_len = 6, \
.page_size = 256, \
.flags = (_flags),
/* GigaDevice */
/* ISSI */
/* Macronix */
/* Micron */
*op, void *buf)
else
SPI_MEM_OP_NO_ADDR,
int ret;
if (ret < 0)
code);
return ret;
SPI_MEM_OP_NO_ADDR,
u_char *buf)
int ret;
while (remaining) {
if (ret)
return ret;
if (ret)
return ret;
return len;
int ret;
u8 val;
if (ret < 0) {
return ret;
return val;
+} +#endif
return mtd->priv;
size_t i;
return table[i][1];
return opcode;
int enable)
int status;
u8 cmd;
need_wren = true;
if (need_wren)
write_enable(nor);
if (need_wren)
write_disable(nor);
write_enable(nor);
nor->cmd_buf, 1);
write_disable(nor);
return status;
default:
int ret;
u8 val;
if (ret < 0) {
return ret;
return val;
int ret;
u8 val;
if (ret < 0) {
return ret;
return val;
if (sr < 0)
return sr;
if (fsr < 0)
return fsr;
int sr, fsr;
if (sr < 0)
return sr;
if (fsr < 0)
return fsr;
return sr && fsr;
int ret;
if (ret < 0)
return ret;
if (ret)
return -ETIMEDOUT;
return -ENOTSUPP;
int tmp;
if (tmp < 0) {
info = spi_nor_ids;
if (info->id_len) {
return info;
int ret;
while (len) {
loff_t addr = from;
if (ret == 0) {
ret = -EIO;
goto read_err;
if (ret < 0)
goto read_err;
*retlen += ret;
buf += ret;
from += ret;
len -= ret;
ret = 0;
+read_err:
return ret;
return -ENOTSUPP;
int ret, val;
val = read_sr(nor);
if (val < 0)
return val;
write_enable(nor);
if (ret)
return ret;
ret = read_sr(nor);
return -EINVAL;
+} +#endif
int ret;
write_enable(nor);
if (ret < 0) {
dev_dbg(nor->dev,
return -EINVAL;
if (ret) {
dev_dbg(nor->dev,
return ret;
- memories.
u8 sr_cr[2];
int ret;
ret = read_cr(nor);
if (ret < 0) {
return -EINVAL;
ret = read_sr(nor);
if (ret < 0) {
return -EINVAL;
sr_cr[0] = ret;
if (ret)
return ret;
ret = read_cr(nor);
return -EINVAL;
u8 num_mode_clocks;
u8 num_wait_states;
u8 opcode;
SNOR_CMD_READ,
SNOR_CMD_READ_FAST,
/* Quad SPI */
SNOR_CMD_READ_MAX
u8 num_mode_clocks,
u8 num_wait_states,
u8 opcode,
SNOR_PROTO_1_1_1);
SNOR_PROTO_1_1_1);
SNOR_PROTO_1_1_4);
u32 shared_hwcaps)
int cmd;
if (best_match < 0)
return -EINVAL;
else
u32 shared_mask;
int err;
if (err) {
dev_dbg(nor->dev,
return err;
break;
break;
default:
break;
if (err) {
return err;
int ret;
return -ENOENT;
if (ret)
return ret;
mtd->priv = nor;
mtd->writesize = 1;
if (ret)
return ret;
} else {
nor->addr_width);
return -EINVAL;
nor->info = info;
if (ret)
return ret;
return -ENOTSUPP;
.id = { \
(_ext_id) & 0xff, \
.page_size = 256, \
.flags = (_flags),
.id = { \
(_ext_id) & 0xff, \
.id_len = 6, \
.page_size = 256, \
.flags = (_flags),
/* GigaDevice */
/* ISSI */
/* Macronix */
-#endif
/* Micron */
-#endif
info = spi_nor_ids;
return info; } }
-- 2.19.2
Now that there is new SPI NOR framework, simplify mtd device registration and read/write/erase operations.
Signed-off-by: Vignesh R vigneshr@ti.com --- drivers/mtd/spi/sf_internal.h | 2 +- drivers/mtd/spi/sf_mtd.c | 39 ++++++++++++----------------------- drivers/mtd/spi/sf_probe.c | 2 +- 3 files changed, 15 insertions(+), 28 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 7e7d400cdbdf..8b445bb0b506 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -99,6 +99,6 @@ int spi_flash_cmd_get_sw_write_prot(struct spi_flash *flash);
#ifdef CONFIG_SPI_FLASH_MTD int spi_flash_mtd_register(struct spi_flash *flash); -void spi_flash_mtd_unregister(void); +void spi_flash_mtd_unregister(struct spi_flash *flash); #endif #endif /* _SF_INTERNAL_H_ */ diff --git a/drivers/mtd/spi/sf_mtd.c b/drivers/mtd/spi/sf_mtd.c index 58d7e4439903..9c07ba3cadf7 100644 --- a/drivers/mtd/spi/sf_mtd.c +++ b/drivers/mtd/spi/sf_mtd.c @@ -9,17 +9,15 @@ #include <linux/mtd/mtd.h> #include <spi_flash.h>
-static struct mtd_info sf_mtd_info; static char sf_mtd_name[8];
static int spi_flash_mtd_erase(struct mtd_info *mtd, struct erase_info *instr) { - struct spi_flash *flash = mtd->priv; int err;
instr->state = MTD_ERASING;
- err = spi_flash_erase(flash, instr->addr, instr->len); + err = mtd->_erase(mtd, instr); if (err) { instr->state = MTD_ERASE_FAILED; instr->fail_addr = MTD_FAIL_ADDR_UNKNOWN; @@ -35,10 +33,9 @@ static int spi_flash_mtd_erase(struct mtd_info *mtd, struct erase_info *instr) static int spi_flash_mtd_read(struct mtd_info *mtd, loff_t from, size_t len, size_t *retlen, u_char *buf) { - struct spi_flash *flash = mtd->priv; int err;
- err = spi_flash_read(flash, from, len, buf); + err = mtd->_read(mtd, from, len, retlen, buf); if (!err) *retlen = len;
@@ -48,10 +45,9 @@ static int spi_flash_mtd_read(struct mtd_info *mtd, loff_t from, size_t len, static int spi_flash_mtd_write(struct mtd_info *mtd, loff_t to, size_t len, size_t *retlen, const u_char *buf) { - struct spi_flash *flash = mtd->priv; int err;
- err = spi_flash_write(flash, to, len, buf); + err = mtd->_write(mtd, to, len, retlen, buf); if (!err) *retlen = len;
@@ -73,31 +69,22 @@ static int spi_flash_mtd_number(void)
int spi_flash_mtd_register(struct spi_flash *flash) { - memset(&sf_mtd_info, 0, sizeof(sf_mtd_info)); + struct mtd_info *mtd = &flash->mtd; sprintf(sf_mtd_name, "nor%d", spi_flash_mtd_number());
- sf_mtd_info.name = sf_mtd_name; - sf_mtd_info.type = MTD_NORFLASH; - sf_mtd_info.flags = MTD_CAP_NORFLASH; - sf_mtd_info.writesize = 1; - sf_mtd_info.writebufsize = flash->page_size; - - sf_mtd_info._erase = spi_flash_mtd_erase; - sf_mtd_info._read = spi_flash_mtd_read; - sf_mtd_info._write = spi_flash_mtd_write; - sf_mtd_info._sync = spi_flash_mtd_sync; - - sf_mtd_info.size = flash->size; - sf_mtd_info.priv = flash; + mtd->name = sf_mtd_name; + mtd->_erase = spi_flash_mtd_erase; + mtd->_read = spi_flash_mtd_read; + mtd->_write = spi_flash_mtd_write; + mtd->_sync = spi_flash_mtd_sync;
/* Only uniform flash devices for now */ - sf_mtd_info.numeraseregions = 0; - sf_mtd_info.erasesize = flash->sector_size; + mtd->numeraseregions = 0;
- return add_mtd_device(&sf_mtd_info); + return add_mtd_device(mtd); }
-void spi_flash_mtd_unregister(void) +void spi_flash_mtd_unregister(struct spi_flash *flash) { - del_mtd_device(&sf_mtd_info); + del_mtd_device(&flash->mtd); } diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index c4c25a7e8403..81c9de54b6a8 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -84,7 +84,7 @@ struct spi_flash *spi_flash_probe(unsigned int busnum, unsigned int cs, void spi_flash_free(struct spi_flash *flash) { #ifdef CONFIG_SPI_FLASH_MTD - spi_flash_mtd_unregister(); + spi_flash_mtd_unregister(flash); #endif spi_free_slave(flash->spi); free(flash);
- err = mtd->_erase(mtd, instr);
Please don't dereference mtd hooks directly. I'm pretty sure the mtd_erase() overhead is negligible, and if it's not, you can implement dummy wrappers for the SPL case to reduce it to zero.
Hi Boris,
I did start with mtd_* APIs here. But, ended up with bunch of patches just to get MTD configs in shape to satisfy compile time dependencies. I will send a patch to use mtd_* APIs here once Miquel's MTD config cleanups are in. Thanks for the review!
Hi Vignesh,
Vignesh R vigneshr@ti.com wrote on Wed, 5 Dec 2018 13:30:27 +0530:
Hi Boris,
As an FYI, it took me more than 30 Travis builds to get the MTD Kconfigs/Makefiles (+ defconfigs) in shape :)
To find faulty configurations (for example, configurations using CONFIG_SPI_FLASH_MTD but without enabling CONFIG_MTD) I wrote a small script just to open these files automatically. As a reference if someone wants to use/improve it, it is there [1].
[1] http://code.bulix.org/4ep8u5-518535
Thanks, Miquèl
Enable SPL simple malloc to reduce SPL size
Signed-off-by: Vignesh R vigneshr@ti.com --- configs/taurus_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index e53e075d4825..9c3a1276aa8f 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -64,3 +64,4 @@ CONFIG_USE_TINY_PRINTF=y CONFIG_WDT=y CONFIG_WDT_AT91=y CONFIG_AT91_HW_WDT_TIMEOUT=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y
Enable CONFIG_SPL_SYS_MALLOC_SIMPLE in SPL to reduce SPL size
Signed-off-by: Vignesh R vigneshr@ti.com --- configs/axm_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/axm_defconfig b/configs/axm_defconfig index 89d6b6f2012c..16c093b37b83 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -44,3 +44,4 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_USE_TINY_PRINTF=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y
On Tue, 4 Dec 2018 17:56:48 +0530 Vignesh R vigneshr@ti.com wrote:
U-Boot SPI NOR support (sf layer) is quite outdated as it does not support 4 byte addressing opcodes, SFDP table parsing and different types of quad mode enable sequences. Many newer flashes no longer support BANK registers used by sf layer to a access >16MB space. Also, many SPI controllers have special MMIO interfaces which provide accelerated read/write access but require knowledge of flash parameters to make use of it. Recent spi-mem layer provides a way to support such flashes but sf layer isn't using that. This patch series syncs SPI NOR framework from Linux v4.19. It also adds spi-mem support on top. So, we gain 4byte addressing support and SFDP support. This makes migrating to U-Boot MTD framework easier.
Glad to see that happen sooner than I had expected. Looks like the patch series is in a good shape already, and I'm happy to see the u-boot spi-nor layer being based on the Linux one.
Good job, and thanks again for working on that!
Boris
Am 04.12.2018 um 13:55 schrieb Boris Brezillon:
Right, I do appreciate this!
I did some compilation tests first and I'm happy to say that with the SPL_SPI_FLASH_TINY option enabled, my SPL is about 1900 byte smaller than before :-)
However, my socfpga socrates board does not boot. I'll have to investigate why. I just applied this series and compiled for socfpga_socrates_defconfig. Is there anything else I should have changed to make it work?
Thanks!
Oops, that's unfortunate. Just to be sure, does SPL fail to come up or SPL fails to load U-Boot from flash? Is this with SPL_SPI_FLASH_TINY enabled?
Could you enable debug prints at the end of spi_mem_exec_op() in drivers/spi/spi-mem.c to see what commands are sent and their responses?
I have TI EVM with Cadence QSPI(like SoCFPGA) but with a Spansion flash and that seems to work fine with both full and tiny stack.
Thanks!
I tried both TINY and standard. Both are failing to load U-Boot (I get the standard error message that loading from SPI flash failed).
OK, I'll do that.
That's why I thought it could somehow be defconfig-related...?
Am 05.12.2018 um 07:55 schrieb Simon Goldschmidt:
Thanks!
OK, I'll do that.
OK, so I enabled some debugging and the first issue is that U-Boot has SNOR_MFR_MICRON and SNOR_MFR_ST while Linux only has SNOR_MFR_MICRON but defines it to CFI_MFR_ST (0x20, U-Boot ends up with 0x2c). While this might be correct, it leads to my n25q256a not being handled as "micron-like" and the code falls through to using Spansion-like opcode (0x17) that my chip does not understand.
However, after changing this (and using opcode 0xb7 to bring the chip into 4 byte mode, including 0x06 for write-enable), it still does not work as it uses the 'READ' opcode 0x03 instead of the 'FAST READ' opcode 0x0b that U-Boot used until now. The problem here might be that 'READ' cannot do Quad-SPI (4-4-4) and I'm not sure the Cadence driver can handle Extended-SPI (1-1-1) that the 'READ' command is limited to...
Using SFDP would probably help, but that doesn't compile (as I wrote in the other thread).
On the other hand, enabling SFDP will increase the text/rodata size for SPL. We might need to remove the non-SFDP and write code as a counter measure to prevent increasing code size.
Hi Simon,
OK, I'll do that.
Oops, sorry, the micron chip I had has CFI MFR id of 0x2c, so I overlooked this. I have updated this now.
I had accidentally dropped Fast Read from SPI NOR layer and have sync'd it up now. I see that in socfpga dts, flash does not contain: spi-rx-bus-width = <4>; Therefore SPI NOR layer falls back to READ (even though its a QSPI flash). But nevertheless with updated branch[1] you should see falling back to FAST READ with Cadence QSPI on your board (and 1-1-4, if rx bus width is 4).
Sorry for that. I have fixed that up and tested SFDP parsing logic with a Spansion flash. Note that Cadence QSPI wont support SFDP parsing as driver enables Quad mode for all reads and SFDP is only 1-1-1.
That's not an option as Flash devices (even though have same JEDEC ID) manufactured before JESD216 std dont have SFDP populated. So, we will need to have both non-SFDP and SFDP support with option to disable SFDP (for size and boot time optimizations).
Thanks for all the debugging! It would be great if you could try below branch and let me know if it fixes all the issues. If yes, I will remove RFC and post new series.
[1] https://github.com/r-vignesh/u-boot.git spi-nor-mig-patch-v1
On Thu, Dec 6, 2018 at 2:45 PM Vignesh R vigneshr@ti.com wrote:
Hi Simon,
OK, I'll do that.
We can add that if it helps. I'll try to update the upstream Linux dts anyway to add "jeded,spi-nor" compatible once Neil's series is applied.
Oh, I haven't really looked into that yet. That's sad.
Well, my idea was if you'd know that all the flash chips on your board supported it, you'd be safe. It would only be a Kconfig option to reduce binary size (get rid of the flash IDs table).
But if SFDP doesn't work for QSPI anyway, that's not the best idea, I guess...
Sure, I'll try to find the time soon.
-- Regards Vignesh
Am 06.12.2018 um 14:54 schrieb Simon Goldschmidt:
Hi Simon,
OK, I'll do that.
Had a quick test with both standard and tiny in SPL and both configs now work on my board. I haven't tested SFDP as you said it does not works on Cadence QSPI. (I tested compiling it though, and that works now.)
Oh, and I think it's important to say that with your spi-nor-tiny code, SPL code size is reduced by 1980 bytes for my config (socfpga_socrates_defconfig)!
-- Regards Vignesh
Hi Simon,
> I did some compilation tests first and I'm happy to say that with the > SPL_SPI_FLASH_TINY option enabled, my SPL is about 1900 byte smaller > than before :-) > > However, my socfpga socrates board does not boot. I'll have to > investigate why. I just applied this series and compiled for > socfpga_socrates_defconfig. Is there anything else I should have changed > to make it work? >
OK, I'll do that.
Yes, thats one of the motivation for this series. I wanted to use same driver to support Cadence Octal SPI IP but this simply wasn't possible due disconnect b/w SF and SPI layer. I plan to fix Cadence QSPI by moving to spi-mem layer once SF layer is in place
Yeah, current U-Boot SPI layer does not allow SPI Flash layer to communicate bus width to SPI controller drivers. Either drivers capable of supporting Quad mode should move to spi-mem framework or spi_xfer() interface needs to be expanded.
I used below hack to test SFDP with Cadence QSPI:
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index a8af35203035..9dbf9aa7d20c 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -559,7 +559,7 @@ int cadence_qspi_apb_indirect_read_setup(struct cadence_spi_platdata *plat, /* Configure the opcode */ rd_reg = cmdbuf[0] << CQSPI_REG_RD_INSTR_OPCODE_LSB;
- if (rx_width & SPI_RX_QUAD) + if (rx_width & SPI_RX_QUAD && (cmdbuf[0] != 0x5a)) /* Instruction and address at DQ0, data at DQ0-3. */ rd_reg |= CQSPI_INST_TYPE_QUAD << CQSPI_REG_RD_INSTR_TYPE_DATA_LSB;
Thats good to know.
-- Regards Vignesh
Am 06.12.2018 um 18:39 schrieb Vignesh R:
Hi Simon,
>> I did some compilation tests first and I'm happy to say that with the >> SPL_SPI_FLASH_TINY option enabled, my SPL is about 1900 byte smaller >> than before :-) >> >> However, my socfpga socrates board does not boot. I'll have to >> investigate why. I just applied this series and compiled for >> socfpga_socrates_defconfig. Is there anything else I should have changed >> to make it work? >> > > Oops, that's unfortunate. > Just to be sure, does SPL fail to come up or SPL fails to load U-Boot > from flash? Is this with SPL_SPI_FLASH_TINY enabled?
> Could you enable debug prints at the end of spi_mem_exec_op() in > drivers/spi/spi-mem.c to see what commands are sent and their responses?
OK, I'll do that.
> I have TI EVM with Cadence QSPI(like SoCFPGA) but with a Spansion flash > and that seems to work fine with both full and tiny stack.
After enabling DEBUG in spi-mem.c, I see that we're changing to 4-byte mode (via b7h) instead of using 4-byte opcodes. Unfortunately, this conflicts with the boot rom using the default read opcose in 3-byte mode on warm reboot.
Do you plan to change this or would this be fixed by parsing SFDP?
Just by accident, I saw that enabling the SFDP config does not seem to break booting. But it still switches to 4-byte mode, so it probably just fails to parse and continues the non-SFDP way?
But this is Spansion-specific, right?
Thats good to know.
-- Regards Vignesh
Am 05.12.2018 um 07:55 schrieb Simon Goldschmidt: > On Wed, Dec 5, 2018 at 7:51 AM Vignesh R vigneshr@ti.com wrote:
Oh, I see n25q256a entry is missing SPI_NOR_4B_OPCODES flag in the spi_nor_ids table. In non SFDP configuration adding SPI_NOR_4B_OPCODES flag should avoid sending 0xb7 and use 4-byte opcodes directly. May be you could give that a try?
For stateless 4-byte addressing mode with SFDP, we need to parse JEDEC 4-byte Address Instruction Parameter Header and Table (part of JESD216B) to get 4 byte addressing opcode. We need to port this patch once accepted to Linux kernel: https://lore.kernel.org/patchwork/patch/1022200/
Nope, SFDP command operates in 1-1-1 mode for all flash devices. But if you don't have rx width set to 4 in DT, above hack is not needed and SFDP parsing would work fine with Cadence QSPI.
On 06/12/18 2:15 AM, Simon Goldschmidt wrote: > Am 05.12.2018 um 07:55 schrieb Simon Goldschmidt: >> On Wed, Dec 5, 2018 at 7:51 AM Vignesh R vigneshr@ti.com wrote: [...]
Yes, that did the trick. With SFDP disabled I now see 9Fh (read ID) followed directly by 0Ch (4-byte FAST READ). Just like it should be. With SFDP enabled, I get 9Fh, 5Ah, 5Ah and then 0Ch. Both configs do work fine for me, so:
Tested-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
-- Regards Vignesh
We(someone) has proposed this sync before, but we(at-least I) rely on implementing via DM not direct sync to Linux. ofcourse other subsystems might have doing this but I literally don't propose to do that, since it may fire the u-boot implementation in future.
If you really get things up further, try to check this DM based spi-nor here[1] and lets discuss on u-boot point-of-view. I've paused this because of non-dm code, but I'm thinking we even re-change this to fit MTD driver-model (this is my TODO, once spi dm migration done).
[1] http://git.denx.de/?p=u-boot-spi.git;a=shortlog;h=refs/heads/next-working
We need to make sure things overall are a good fit and I know we've had some back and forth on this, but, "sync with Linux subsystem and make it work cleanly (as possible) in U-Boot" is the path I think we need to take and I like what Vignesh has done and to repeat myself from earlier, I want to see this series (or rather, it's overall evolution) come in for v2019.04. Progress over time on top of those changes is good but as you note, your series is from a year ago and that was a pretty long evolution in that direction too. We need to get this solved and since we have motivated developers right now, I want to see this resolved. Thanks!
Hi Jagan,
As I said in my cover letter, U-Boot sf layer is unable to support newer flashes mainly due to lack of 4 byte addressing and proper support for MMIO capable SPI controllers. My idea of fixing this is to borrow _features_ from Linux SPI NOR "as is". All that's needed is stateless 4 byte addressing, SFDP parsing(optionally), Quad/Octal support and spi-mem like abstraction for MMIO capable Controllers. I see no point in re-coding them from ground up.
Could you be more specific on what you would like to see here in DM way? I have no issues in adapting this code to any framework here in U-Boot. Linux has driver model and SPI NOR subsystem is a framework and therefore any code ported from Linux will inherently have those abstractions. The only difference I see wrt your code in branch below vs this series is SPI-NOR uclass. This can be easily achieved by moving nor->ops out of struct spi_nor into uclass abstraction. Upstream Linux is anyways merging m25p80 and spi-nor so I did not see a need for SPI NOR uclass. I am okay to change that if you insist on having it.
Could you explain what might be possible issues in future? I will work on it.
AFAICS, Non DM code is not going away anytime soon. Meanwhile, IMHO, lack of 4 byte addressing support is significantly hampering new development (as evident from number of people trying to add 4 byte addressing support.)
IIRC, last post of this branch was in January 2018. And looking at my inbox, its seems that 4 byte addressing was broken in that series. If you add 4 byte addressing + SFDP parsing logic + spi-mem support to above branch, I am pretty sure you spi-nor.c would look almost the same to whats there in this series.
Regards Vignesh
Am 06.12.2018 um 19:25 schrieb Vignesh R:
Hi Jagan,
And this is exactly why I'm testing this series: it's the only series I've seen in the last months that seems to properly handle 4-byte addressing (even if it does not fully do that for me, yet, but it's still RFC).
I have a bug in my hardware that requires me to put the chip back to 3-byte mode manually up to now. I've sent a patch for that and this patch has been rejected.
So now I'm testing this series to see if it allows me to run U-Boot mainline on my board without additional patches required.
Simon
Regards Vignesh _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
No, please don't add a SPI_NOR_UCLASS. We already have the MTD_UCLASS which is barely used by drivers, so if anything, we should work on converting drivers to this UCLASS and maybe automate a few more things for MTD drivers (like MTD dev registration/deregistration [1]) instead of adding yet another UCLASS.
If you need an example of how integration with the DM (and the MTD UCLASS) should be been done, you can look at the SPI NAND driver [2].
[1]http://code.bulix.org/9lart9-519406 [2]http://git.denx.de/?p=u-boot.git;a=blob;f=drivers/mtd/nand/spi/core.c;h=cb8f...
I agree.
Yeah, that can be done once MTD Kconfig cleanup is done and we have dropped UCLASS_SPI_FLASH (would also require sf_dataflash.c to be moved to MTD)
On Thu, Dec 6, 2018 at 11:55 PM Vignesh R vigneshr@ti.com wrote:
Hi Jagan,
Merging or syncing spi-nor features stuff from Linux is good, I'm not stopping that. but this can be do by satisfying u-boot driver-model with proper architectural model. I know you take care but I'm not sure ie what can be manageable for long term.
Let's discuss the proper architectural model, so-that we can move further to incorporate the changes accordingly. (thanks at last we have a thread to discuss)
Linux m25p80 is moved to spi-nor right? so does controllers on spi-nor should be reside in same area like drivers/mtd/spi-nor or it should be part of spi-mem. The last mail with Boris, noted all spi-nor can't be fit into spi-mem(sorry I lost the thread)
Example: we have zynq qspi it support BAR(with >16MB flashes), dual qspi ect so does it comes under spi-mem or spi-nor?
So, if no driver should be part of spi-nor and all can be handle spi-mem even-though they have controller specific features, yes we can skip SPI_NOR_UCLASS otherwise we need spi-nor uclass that can be child uclass of MTD.
On Mon, 10 Dec 2018 18:32:09 +0530 Jagan Teki jagan@amarulasolutions.com wrote:
Hi Jagan,
Having discussions about the long term plan is good, as long as it's not blocking support for new features for too long. Look, you've been discussing the spi-nor stuff for more than 1 year now, and people are still waiting it. Yogesh's attempt seems to go in the right direction, so let's not block that just because we don't know how to integrate things in the DM (that's not entirely BTW, I suggested an approach in one of my previous reply).
Everything should go in drivers/spi/ and be exposed as spi/spi-mem controllers. So yes, that's one aspect where Linux and u-boot should differ IMO, at least until we have all SPI NOR controller drivers converted to spi-mem in Linux.
That's the idea, yes. Note that I'm open to any discussion regarding the needed features and how we want expose that at the spi-mem level.
Hi Jagan,
To be clear, we've been having this discussion for probably closer to two or three years now. Which is why at this point what I'm saying we need to do is get a logical evolution of To be clear, we've been having this discussion for probably closer to two or three years now. Which is why at this point what I'm saying we need to do is get a logical evolution of Vignesh's series in, for v2019.04 and improve it over time. The notion of "we'll block progress on new features in order to make sure we get conversion done" has failed. Lets go back to good old reliable incremental change over time.
Hi Jagan,
Yes, ATM all drivers fit into spi/spi-mem APIs and don't see any need for new spi-nor uclass
In current mainline U-Boot, I see _no_ users of flags: SF_DUAL_STACKED_FLASH and SF_DUAL_PARALLEL_FLASH (I don't see flash->dual_flash set to any of the above enums). But if we do need to support such flashes in future, current address translation logic can be added to spi-nor.c (based on a DT flag), along with a way to pass this info via spi-mem ops. I would suggest to look at spi-mem ops (and in Linux mainline as well), if there are any shortcomings we can discuss here.
In fact, after this series is merged, UCLASS_SPI_FLASH can be dropped and we can move to spi-nor(and sf_dataflash.c) directly under UCLASS_MTD. But, mostly likely would need to provide a lightweight MTD for SPL (similar to spi-nor-tiny.c) before that can be done.
Regards Vignesh
Hi Vignesh,
Vignesh R vigneshr@ti.com wrote on Mon, 10 Dec 2018 23:08:38 +0530:
Hi Jagan,
That would be great!
Thanks, Miquèl
participants (6)
Boris Brezillon
Jagan Teki
Miquel Raynal
Simon Goldschmidt
Vignesh R
