[PATCH 1/5] GitLab: Remove "tags" stanzas
Given the structure of our current GitLab tests, we don't make real use of the tags. Furthermore, these tags prevent the automatic usage of the default GitLab runners. Remove these tags.
Reported-by: Roger Meier r.meier@siemens.com Signed-off-by: Tom Rini trini@konsulko.com --- .gitlab-ci.yml | 46 ---------------------------------------------- 1 file changed, 46 deletions(-)
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 2cdcd864c86a..ceba5ce7a905 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -11,7 +11,6 @@ stages: - world build
.buildman_and_testpy_template: &buildman_and_testpy_dfn - tags: [ 'all' ] stage: test.py before_script: # Clone uboot-test-hooks @@ -53,7 +52,6 @@ stages: --build-dir "$UBOOT_TRAVIS_BUILD_DIR"
build all 32bit ARM platforms: - tags: [ 'all' ] stage: world build script: - ret=0; @@ -64,7 +62,6 @@ build all 32bit ARM platforms: fi;
build all 64bit ARM platforms: - tags: [ 'all' ] stage: world build script: - virtualenv -p /usr/bin/python3 /tmp/venv @@ -78,7 +75,6 @@ build all 64bit ARM platforms: fi;
build all PowerPC platforms: - tags: [ 'all' ] stage: world build script: - ret=0; @@ -89,7 +85,6 @@ build all PowerPC platforms: fi;
build all other platforms: - tags: [ 'all' ] stage: world build script: - ret=0; @@ -102,14 +97,12 @@ build all other platforms: # QA jobs for code analytics # static code analysis with cppcheck (we can add --enable=all later) cppcheck: - tags: [ 'all' ] stage: testsuites script: - cppcheck -j$(nproc) --force --quiet --inline-suppr .
# search for TODO within source tree grep TODO/FIXME/HACK: - tags: [ 'all' ] stage: testsuites script: - grep -r TODO . @@ -119,7 +112,6 @@ grep TODO/FIXME/HACK:
# build HTML documentation htmldocs: - tags: [ 'all' ] stage: testsuites script: - virtualenv -p /usr/bin/python3 /tmp/venvhtml @@ -129,34 +121,29 @@ htmldocs:
# some statistics about the code base sloccount: - tags: [ 'all' ] stage: testsuites script: - sloccount .
# ensure all configs have MAINTAINERS entries Check for configs without MAINTAINERS entry: - tags: [ 'all' ] stage: testsuites script: - if [ `./tools/genboardscfg.py -f 2>&1 | wc -l` -ne 0 ]; then exit 1; fi
# Ensure host tools build Build tools-only: - tags: [ 'all' ] stage: testsuites script: - make tools-only_config tools-only -j$(nproc)
# Ensure env tools build Build envtools: - tags: [ 'all' ] stage: testsuites script: - make tools-only_config envtools -j$(nproc)
Run binman, buildman, dtoc, Kconfig and patman testsuites: - tags: [ 'all' ] stage: testsuites script: - git config --global user.name "GitLab CI Runner"; @@ -176,7 +163,6 @@ Run binman, buildman, dtoc, Kconfig and patman testsuites: make testconfig
Run tests for Nokia RX-51 (aka N900): - tags: [ 'all' ] stage: testsuites script: - ./tools/buildman/buildman --fetch-arch arm; @@ -185,54 +171,46 @@ Run tests for Nokia RX-51 (aka N900):
# Test sandbox with test.py sandbox test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "sandbox" <<: *buildman_and_testpy_dfn
sandbox with clang test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "sandbox" OVERRIDE: "-O clang-10" <<: *buildman_and_testpy_dfn
sandbox_spl test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "sandbox_spl" TEST_PY_TEST_SPEC: "test_ofplatdata or test_handoff or test_spl" <<: *buildman_and_testpy_dfn
evb-ast2500 test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "evb-ast2500" TEST_PY_ID: "--id qemu" <<: *buildman_and_testpy_dfn
sandbox_flattree test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "sandbox_flattree" <<: *buildman_and_testpy_dfn
vexpress_ca15_tc2 test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "vexpress_ca15_tc2" TEST_PY_ID: "--id qemu" <<: *buildman_and_testpy_dfn
vexpress_ca9x4 test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "vexpress_ca9x4" TEST_PY_ID: "--id qemu" <<: *buildman_and_testpy_dfn
integratorcp_cm926ejs test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "integratorcp_cm926ejs" TEST_PY_TEST_SPEC: "not sleep" @@ -240,49 +218,42 @@ integratorcp_cm926ejs test.py: <<: *buildman_and_testpy_dfn
qemu_arm test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "qemu_arm" TEST_PY_TEST_SPEC: "not sleep" <<: *buildman_and_testpy_dfn
qemu_arm64 test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "qemu_arm64" TEST_PY_TEST_SPEC: "not sleep" <<: *buildman_and_testpy_dfn
qemu_mips test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "qemu_mips" TEST_PY_TEST_SPEC: "not sleep" <<: *buildman_and_testpy_dfn
qemu_mipsel test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "qemu_mipsel" TEST_PY_TEST_SPEC: "not sleep" <<: *buildman_and_testpy_dfn
qemu_mips64 test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "qemu_mips64" TEST_PY_TEST_SPEC: "not sleep" <<: *buildman_and_testpy_dfn
qemu_mips64el test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "qemu_mips64el" TEST_PY_TEST_SPEC: "not sleep" <<: *buildman_and_testpy_dfn
qemu_malta test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "malta" TEST_PY_TEST_SPEC: "not sleep and not efi" @@ -290,7 +261,6 @@ qemu_malta test.py: <<: *buildman_and_testpy_dfn
qemu_maltael test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "maltael" TEST_PY_TEST_SPEC: "not sleep and not efi" @@ -298,7 +268,6 @@ qemu_maltael test.py: <<: *buildman_and_testpy_dfn
qemu_malta64 test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "malta64" TEST_PY_TEST_SPEC: "not sleep and not efi" @@ -306,7 +275,6 @@ qemu_malta64 test.py: <<: *buildman_and_testpy_dfn
qemu_malta64el test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "malta64el" TEST_PY_TEST_SPEC: "not sleep and not efi" @@ -314,84 +282,72 @@ qemu_malta64el test.py: <<: *buildman_and_testpy_dfn
qemu-ppce500 test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "qemu-ppce500" TEST_PY_TEST_SPEC: "not sleep" <<: *buildman_and_testpy_dfn
qemu-riscv32 test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "qemu-riscv32" TEST_PY_TEST_SPEC: "not sleep" <<: *buildman_and_testpy_dfn
qemu-riscv64 test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "qemu-riscv64" TEST_PY_TEST_SPEC: "not sleep" <<: *buildman_and_testpy_dfn
qemu-riscv32_spl test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "qemu-riscv32_spl" TEST_PY_TEST_SPEC: "not sleep" <<: *buildman_and_testpy_dfn
qemu-riscv64_spl test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "qemu-riscv64_spl" TEST_PY_TEST_SPEC: "not sleep" <<: *buildman_and_testpy_dfn
qemu-x86 test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "qemu-x86" TEST_PY_TEST_SPEC: "not sleep" <<: *buildman_and_testpy_dfn
qemu-x86_64 test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "qemu-x86_64" TEST_PY_TEST_SPEC: "not sleep" <<: *buildman_and_testpy_dfn
r2dplus_i82557c test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "r2dplus" TEST_PY_ID: "--id i82557c_qemu" <<: *buildman_and_testpy_dfn
r2dplus_pcnet test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "r2dplus" TEST_PY_ID: "--id pcnet_qemu" <<: *buildman_and_testpy_dfn
r2dplus_rtl8139 test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "r2dplus" TEST_PY_ID: "--id rtl8139_qemu" <<: *buildman_and_testpy_dfn
r2dplus_tulip test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "r2dplus" TEST_PY_ID: "--id tulip_qemu" <<: *buildman_and_testpy_dfn
xilinx_zynq_virt test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "xilinx_zynq_virt" TEST_PY_TEST_SPEC: "not sleep" @@ -399,7 +355,6 @@ xilinx_zynq_virt test.py: <<: *buildman_and_testpy_dfn
xilinx_versal_virt test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "xilinx_versal_virt" TEST_PY_TEST_SPEC: "not sleep" @@ -407,7 +362,6 @@ xilinx_versal_virt test.py: <<: *buildman_and_testpy_dfn
xtfpga test.py: - tags: [ 'all' ] variables: TEST_PY_BD: "xtfpga" TEST_PY_TEST_SPEC: "not sleep"
The latest versions of pygit2 are not available in practically any distribution at this time. Furthermore, we don't need the latest in order to run all of our testsuites. Reduce this version requirement to something older that meets our needs while still supporting running our tests on older hosts (and so, test labs).
Reported-by: Tom Warren twarren@nvidia.com Signed-off-by: Tom Rini trini@konsulko.com --- test/py/requirements.txt | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/test/py/requirements.txt b/test/py/requirements.txt index 926bccad694f..89ca259b213b 100644 --- a/test/py/requirements.txt +++ b/test/py/requirements.txt @@ -11,7 +11,7 @@ pbr==5.4.3 pluggy==0.13.0 py==1.8.0 pyelftools==0.27 -pygit2==1.4.0 +pygit2==0.28.2 pyparsing==2.4.2 pytest==5.2.1 python-mimeparse==1.6.0
Given that test/py/requirements.txt has all required test modules, make use of that rather than a manual pip install list before running our assorted tool testsuites.
Signed-off-by: Tom Rini trini@konsulko.com --- .azure-pipelines.yml | 2 +- .gitlab-ci.yml | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index a6279427e138..0a4f90f75f3b 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -144,7 +144,7 @@ jobs: export USER=azure virtualenv -p /usr/bin/python3 /tmp/venv . /tmp/venv/bin/activate - pip install pyelftools pytest pygit2 + pip install -r test/py/requirements.txt export UBOOT_TRAVIS_BUILD_DIR=/tmp/sandbox_spl export PYTHONPATH=${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc/pylibfdt export PATH=${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc:${PATH} diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index ceba5ce7a905..ce0e63481a11 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -151,7 +151,7 @@ Run binman, buildman, dtoc, Kconfig and patman testsuites: export USER=gitlab; virtualenv -p /usr/bin/python3 /tmp/venv; . /tmp/venv/bin/activate; - pip install pyelftools pytest pygit2; + pip install -r test/py/requirements.txt; export UBOOT_TRAVIS_BUILD_DIR=/tmp/sandbox_spl; export PYTHONPATH="${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc/pylibfdt"; export PATH="${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc:${PATH}";
It seems only pytest is listed in test/py/requirements.txt?
Regards, Bin
Not since: commit f4a60b036308ca4a0a3ad08587b7f9b72d3565d5 Author: Igor Opaniuk igor.opaniuk@foundries.io Date: Mon Jan 25 14:28:41 2021 +0200
test: py: add pygit2 and pyelftools to requirements.txt
Ah, yes! Was looking at an old branch.
Applied to u-boot-dm, thanks!
The patman tests require the requests module, add it.
Cc: Simon Glass sjg@chromium.org Signed-off-by: Tom Rini trini@konsulko.com --- test/py/requirements.txt | 1 + 1 file changed, 1 insertion(+)
diff --git a/test/py/requirements.txt b/test/py/requirements.txt index 89ca259b213b..f396eb646362 100644 --- a/test/py/requirements.txt +++ b/test/py/requirements.txt @@ -16,6 +16,7 @@ pyparsing==2.4.2 pytest==5.2.1 python-mimeparse==1.6.0 python-subunit==1.3.0 +requests==2.25.1 six==1.12.0 testtools==2.3.0 traceback2==1.4.0
Given that we have tests that require pygit2 and it can be installed like any other python module, fail much more loudly if it is missing.
Cc: Simon Glass sjg@chromium.org Signed-off-by: Tom Rini trini@konsulko.com --- tools/patman/func_test.py | 19 ++----------------- 1 file changed, 2 insertions(+), 17 deletions(-)
diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index 89072b1ae7fa..b956fb96f396 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -25,13 +25,8 @@ from patman import terminal from patman import tools from patman.test_util import capture_sys_output
-try: - import pygit2 - HAVE_PYGIT2 = True - from patman import status -except ModuleNotFoundError: - HAVE_PYGIT2 = False - +import pygit2 +from patman import status
class TestFunctional(unittest.TestCase): """Functional tests for checking that patman behaves correctly""" @@ -458,7 +453,6 @@ complicated as possible''') repo.branches.local.create('base', base_target) return repo
- @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') def testBranch(self): """Test creating patches from a branch""" repo = self.make_git_tree() @@ -604,7 +598,6 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c ["Found possible blank line(s) at end of file 'lib/fdtdec.c'"], pstrm.commit.warn)
- @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') def testNoUpstream(self): """Test CountCommitsToBranch when there is no upstream""" repo = self.make_git_tree() @@ -642,7 +635,6 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c {'id': '1', 'name': 'Some patch'}]} raise ValueError('Fake Patchwork does not understand: %s' % subpath)
- @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') def testStatusMismatch(self): """Test Patchwork patches not matching the series""" series = Series() @@ -652,7 +644,6 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c self.assertIn('Warning: Patchwork reports 1 patches, series has 0', err.getvalue())
- @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') def testStatusReadPatch(self): """Test handling a single patch in Patchwork""" series = Series() @@ -665,7 +656,6 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c self.assertEqual('1', patch.id) self.assertEqual('Some patch', patch.raw_subject)
- @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') def testParseSubject(self): """Test parsing of the patch subject""" patch = status.Patch('1') @@ -728,7 +718,6 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c self.assertEqual('RESEND', patch.prefix) self.assertEqual(None, patch.version)
- @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') def testCompareSeries(self): """Test operation of compare_with_series()""" commit1 = Commit('abcd') @@ -831,7 +820,6 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c return patch.comments raise ValueError('Fake Patchwork does not understand: %s' % subpath)
- @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') def testFindNewResponses(self): """Test operation of find_new_responses()""" commit1 = Commit('abcd') @@ -970,7 +958,6 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c return patch.comments raise ValueError('Fake Patchwork does not understand: %s' % subpath)
- @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') def testCreateBranch(self): """Test operation of create_branch()""" repo = self.make_git_tree() @@ -1058,7 +1045,6 @@ diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c self.assertEqual('Reviewed-by: %s' % self.mary, next(lines)) self.assertEqual('Tested-by: %s' % self.leb, next(lines))
- @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') def testParseSnippets(self): """Test parsing of review snippets""" text = '''Hi Fred, @@ -1142,7 +1128,6 @@ line8 'line2', 'line3', 'line4', 'line5', 'line6', 'line7', 'line8']], pstrm.snippets)
- @unittest.skipIf(not HAVE_PYGIT2, 'Missing python3-pygit2') def testReviewSnippets(self): """Test showing of review snippets""" def _to_submitter(who):
Bin Meng
