[PATCH] ARM: imx8m: support env in fat and ext4
Change boot device logic to also allow environment stored in fat and in ext4 when booting from SD or from eMMC.
As the boot device check for SD and for eMMC was depending on ENV_IS_IN_MMC being defined, change the ifdef blocks at env_get_location to use IS_ENABLED instead for all modes, returning NOWHERE when no valid mode is found.
Signed-off-by: Ricardo Salveti ricardo@foundries.io --- arch/arm/mach-imx/imx8m/soc.c | 35 +++++++++++++++-------------------- 1 file changed, 15 insertions(+), 20 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index f2ddc834d4b..a3ce517a104 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -1306,40 +1306,35 @@ void do_error(struct pt_regs *pt_regs, unsigned int esr) enum env_location env_get_location(enum env_operation op, int prio) { enum boot_device dev = get_boot_device(); - enum env_location env_loc = ENVL_UNKNOWN;
if (prio) - return env_loc; + return ENVL_UNKNOWN;
switch (dev) { -#ifdef CONFIG_ENV_IS_IN_SPI_FLASH case QSPI_BOOT: - env_loc = ENVL_SPI_FLASH; - break; -#endif -#ifdef CONFIG_ENV_IS_IN_NAND + if (IS_ENABLED(CONFIG_ENV_IS_IN_SPI_FLASH)) + return ENVL_SPI_FLASH; + return ENVL_NOWHERE; case NAND_BOOT: - env_loc = ENVL_NAND; - break; -#endif -#ifdef CONFIG_ENV_IS_IN_MMC + if (IS_ENABLED(CONFIG_ENV_IS_IN_NAND)) + return ENVL_NAND; + return ENVL_NOWHERE; case SD1_BOOT: case SD2_BOOT: case SD3_BOOT: case MMC1_BOOT: case MMC2_BOOT: case MMC3_BOOT: - env_loc = ENVL_MMC; - break; -#endif + if (IS_ENABLED(CONFIG_ENV_IS_IN_MMC)) + return ENVL_MMC; + else if (IS_ENABLED(CONFIG_ENV_IS_IN_EXT4)) + return ENVL_EXT4; + else if (IS_ENABLED(CONFIG_ENV_IS_IN_FAT)) + return ENVL_FAT; + return ENVL_NOWHERE; default: -#if defined(CONFIG_ENV_IS_NOWHERE) - env_loc = ENVL_NOWHERE; -#endif - break; + return ENVL_NOWHERE; } - - return env_loc; }
#ifndef ENV_IS_EMBEDDED
Reviewed-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io
enum env_location env_loc = ENVL_UNKNOWN; if (prio)
return env_loc;
return ENVL_UNKNOWN; switch (dev) {
break;
break;
return ENVL_NAND;
env_loc = ENVL_MMC;
break;
-#endif
return ENVL_MMC;
return ENVL_EXT4;
return ENVL_FAT;
-#endif
break;
return env_loc;
2.33.0
Reviewed-by: Fabio Estevam festevam@gmail.com
Change boot device logic to also allow environment stored in fat and in ext4 when booting from SD or from eMMC. As the boot device check for SD and for eMMC was depending on ENV_IS_IN_MMC being defined, change the ifdef blocks at env_get_location to use IS_ENABLED instead for all modes, returning NOWHERE when no valid mode is found. Signed-off-by: Ricardo Salveti ricardo@foundries.io Reviewed-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Reviewed-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Fabio Estevam
Oleksandr Suvorov
Ricardo Salveti
sbabic@denx.de
