[U-Boot] [PATCH V3] ddr: socfpga: Fix EMIF clear timeout
The current EMIF clear timeout handling code was applying bitwise operations to signed data types and as it was, was extremely hard to read. Replace it with simple wait_for_bit(). Expand the error handling to make it more readable too.
This patch also changes the timeout for emif_clear() from 14 hours to 1 second.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See chin.liang.see@intel.com Cc: Dinh Nguyen dinguyen@kernel.org Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Cc: Tien Fong Chee tien.fong.chee@intel.com --- V2: Subject should read ddr: socfpga: , fix this V3: Zap DDR_MAX_TRIES --- drivers/ddr/altera/sdram_arria10.c | 25 +++++++++++-------------- 1 file changed, 11 insertions(+), 14 deletions(-)
diff --git a/drivers/ddr/altera/sdram_arria10.c b/drivers/ddr/altera/sdram_arria10.c index be5ce778e8..b450a1b1be 100644 --- a/drivers/ddr/altera/sdram_arria10.c +++ b/drivers/ddr/altera/sdram_arria10.c @@ -31,7 +31,6 @@ static u64 sdram_size_calc(void); #define DDR_REG_CORE2SEQ 0xFFD05078 #define DDR_READ_LATENCY_DELAY 40 #define DDR_SIZE_2GB_HEX 0x80000000 -#define DDR_MAX_TRIES 0x00100000
#define IO48_MMR_DRAMSTS 0xFFCFA0EC #define IO48_MMR_NIOS2_RESERVE0 0xFFCFA110 @@ -133,22 +132,16 @@ static unsigned char ddr_wait_bit(u32 ereg, u32 bit,
static int emif_clear(void) { - u32 i = DDR_MAX_TRIES; - u8 ret = 0; - writel(0, DDR_REG_CORE2SEQ);
- do { - ret = !wait_for_bit_le32((u32 *)DDR_REG_SEQ2CORE, - SEQ2CORE_MASK, 1, 50, 0); - } while (ret && (--i > 0)); - - return !i; + return wait_for_bit_le32((u32 *)DDR_REG_SEQ2CORE, + SEQ2CORE_MASK, 0, 1000, 0); }
static int emif_reset(void) { u32 c2s, s2c; + int ret;
c2s = readl(DDR_REG_CORE2SEQ); s2c = readl(DDR_REG_SEQ2CORE); @@ -159,9 +152,12 @@ static int emif_reset(void) readl(IO48_MMR_NIOS2_RESERVE2), readl(IO48_MMR_DRAMSTS));
- if ((s2c & SEQ2CORE_MASK) && emif_clear()) { - debug("failed emif_clear()\n"); - return -EPERM; + if (s2c & SEQ2CORE_MASK) { + ret = emif_clear(); + if (ret) { + debug("failed emif_clear()\n"); + return -EPERM; + } }
writel(CORE2SEQ_INT_REQ, DDR_REG_CORE2SEQ); @@ -173,7 +169,8 @@ static int emif_reset(void) debug("emif_reset interrupt acknowledged\n"); }
- if (emif_clear()) { + ret = emif_clear(); + if (ret) { debug("emif_clear() failed\n"); return -EPERM; }
Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
u8 ret = 0;
do {
return !i;
int ret;
return -EPERM;
ret = emif_clear();
if (ret) {
return -EPERM;
- ret = emif_clear();
- if (ret) { debug("emif_clear() failed\n"); return -EPERM; }
Simon Goldschmidt
