[U-Boot] [PATCH 2/9] ARM: exynos: board: change the mmc/sd init sequence
Exynos4 can be used the dwmmc controller for eMMC. Then it needs to check dwmmc_init() at first.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- board/samsung/common/board.c | 13 ++++++------- 1 file changed, 6 insertions(+), 7 deletions(-)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index de154e0..9dc7c83 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -243,13 +243,6 @@ int board_eth_init(bd_t *bis) int board_mmc_init(bd_t *bis) { int ret; - -#ifdef CONFIG_SDHCI - /* mmc initializattion for available channels */ - ret = exynos_mmc_init(gd->fdt_blob); - if (ret) - debug("mmc init failed\n"); -#endif #ifdef CONFIG_DWMMC /* dwmmc initializattion for available channels */ ret = exynos_dwmmc_init(gd->fdt_blob); @@ -257,6 +250,12 @@ int board_mmc_init(bd_t *bis) debug("dwmmc init failed\n"); #endif
+#ifdef CONFIG_SDHCI + /* mmc initializattion for available channels */ + ret = exynos_mmc_init(gd->fdt_blob); + if (ret) + debug("mmc init failed\n"); +#endif return ret; } #endif
Jaehoon Chung
